[PATCH] configs: am65x_evm: Define the maximum file size for DFU
In include/dfu.h, if CONFIG_SYS_DFU_MAX_FILE_SIZE is not defined then it is defined as CONFIG_SYS_DFU_DATA_BUF_SIZE. This is 128 KiB for a53 core and 20 KiB for r5 core. If a larger file is transferred using dfu then it fails.
CONFIG_SYS_DFU_DATA_BUF_SIZE can not be increased as there is not enough heap memory to be allocated for the buffer in case of R5 spl.
Fix this by defining CONFIG_SYS_DFU_MAX_FILE_SIZE as the default CONFIG_SYS_DFU_DATA_BUF_SIZE value.
Signed-off-by: Aswath Govindraju a-govindraju@ti.com --- include/configs/am65x_evm.h | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/include/configs/am65x_evm.h b/include/configs/am65x_evm.h index 41c62785e438..9d9d0c93a206 100644 --- a/include/configs/am65x_evm.h +++ b/include/configs/am65x_evm.h @@ -56,6 +56,12 @@ #define CONFIG_SKIP_LOWLEVEL_INIT #endif
+/* + * If the maximum size is not declared then it is defined as + * CONFIG_SYS_DFU_DATA_BUF_SIZE. + */ +#define CONFIG_SYS_DFU_MAX_FILE_SIZE (1024 * 1024 * 8) /* 8 MiB */ + #define CONFIG_SPL_MAX_SIZE CONFIG_SYS_K3_MAX_DOWNLODABLE_IMAGE_SIZE
#define CONFIG_SYS_BOOTM_LEN SZ_64M
Applied to u-boot-ti/for-next
Thanks and regards, Lokesh
- If the maximum size is not declared then it is defined as
- CONFIG_SYS_DFU_DATA_BUF_SIZE.
Aswath Govindraju
Lokesh Vutla
