Re: [U-Boot-Users] Newbie... still stuck with RAM disk
Wolfgang, I do have ext2 file system support in my kernel. The filesystem was made using 'mke2fs'.... courtesy of my constant companion book from Karim Yaghmour.
Thanks again for your help, Luke
Here is my current kernel file system related setup... # # File systems # CONFIG_AUTOFS4_FS=y CONFIG_TMPFS=y CONFIG_RAMFS=y CONFIG_PROC_FS=y CONFIG_DEVFS_FS=y CONFIG_DEVFS_MOUNT=y CONFIG_DEVPTS_FS=y CONFIG_EXT2_FS=y
# # Network File Systems # CONFIG_NFS_FS=y CONFIG_NFS_V3=y CONFIG_ROOT_NFS=y CONFIG_SUNRPC=y CONFIG_LOCKD=y CONFIG_LOCKD_V4=y
_________________________________________________________________ Express yourself with cool emoticons - download MSN Messenger today! http://www.msn.co.uk/messenger
OK.
Then try disabling devfs.
Hi all,
I am new to u-boot. I am porting u-boot to Blackfin processor. I am facing problems while loading the file via kermit to the target. Its waiting infinitely in the function k_recv, probably becoz its not receiving the START_CHAR. When i try sending the file from hyperterminal, it aborts after some time. What is the script send_image under tools directory? Do i need to do anything with that?
Please help me.
regards vidya
Did you read the documentation? The "loadb" command is described in detail at http://www.denx.de/twiki/bin/view/DULG/UBootCmdGroupDownload#Section_5.9.5.3.
This might be because bad / incorrect initializatioon of the serial port on either side of the connection. See also http://www.denx.de/twiki/bin/view/DULG/SystemSetup#Section_4.3.
I don't think that hyperterminal is capable of sending in Kermit binary protocol. Why don't you use kermit?
Did you read tools/scripts/README? If yes, which part did you not understand?
Luke Fimmerzane
Vidya S
