[U-Boot] [RFC PATCH 1/1] Add support for pengwyn board
This patch adds support for the silica pengwyn board with AM335x SoC
Signed-off-by: Lothar Felten lothar.felten@gmail.com --- arch/arm/include/asm/arch-am33xx/ddr_defs.h | 16 ++ board/silica/pengwyn/Makefile | 13 + board/silica/pengwyn/board.c | 245 +++++++++++++++++++ board/silica/pengwyn/board.h | 22 ++ board/silica/pengwyn/mux.c | 109 +++++++++ boards.cfg | 1 + include/configs/pengwyn.h | 340 +++++++++++++++++++++++++++ 7 files changed, 746 insertions(+)
diff --git a/arch/arm/include/asm/arch-am33xx/ddr_defs.h b/arch/arm/include/asm/arch-am33xx/ddr_defs.h index c1777df..60cb098 100644 --- a/arch/arm/include/asm/arch-am33xx/ddr_defs.h +++ b/arch/arm/include/asm/arch-am33xx/ddr_defs.h @@ -58,6 +58,22 @@ #define MT41J128MJT125_PHY_FIFO_WE 0x100 #define MT41J128MJT125_IOCTRL_VALUE 0x18B
+/* Micron MT41K128M16JT-187E */ +#define MT41K128MJT187E_EMIF_READ_LATENCY 0x06 +#define MT41K128MJT187E_EMIF_TIM1 0x0888B3DB +#define MT41K128MJT187E_EMIF_TIM2 0x36337FDA +#define MT41K128MJT187E_EMIF_TIM3 0x501F830F +#define MT41K128MJT187E_EMIF_SDCFG 0x61C04AB2 +#define MT41K128MJT187E_EMIF_SDREF 0x0000093B +#define MT41K128MJT187E_ZQ_CFG 0x50074BE4 +#define MT41K128MJT187E_RATIO 0x40 +#define MT41K128MJT187E_INVERT_CLKOUT 0x1 +#define MT41K128MJT187E_RD_DQS 0x3B +#define MT41K128MJT187E_WR_DQS 0x85 +#define MT41K128MJT187E_PHY_WR_DATA 0xC1 +#define MT41K128MJT187E_PHY_FIFO_WE 0x100 +#define MT41K128MJT187E_IOCTRL_VALUE 0x18B + /* Micron MT41J64M16JT-125 */ #define MT41J64MJT125_EMIF_SDCFG 0x61C04A32
diff --git a/board/silica/pengwyn/Makefile b/board/silica/pengwyn/Makefile new file mode 100644 index 0000000..c8b4f9a --- /dev/null +++ b/board/silica/pengwyn/Makefile @@ -0,0 +1,13 @@ +# +# Makefile +# +# Copyright (C) 2011 Texas Instruments Incorporated - http://www.ti.com/ +# +# SPDX-License-Identifier: GPL-2.0+ +# + +ifeq ($(CONFIG_SPL_BUILD)$(CONFIG_NOR_BOOT),y) +obj-y := mux.o +endif + +obj-y += board.o diff --git a/board/silica/pengwyn/board.c b/board/silica/pengwyn/board.c new file mode 100644 index 0000000..e6f59d4 --- /dev/null +++ b/board/silica/pengwyn/board.c @@ -0,0 +1,245 @@ +/* + * board.c + * + * Copyright (C) 2013 Lothar Felten lothar.felten@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation version 2. + * + * This program is distributed "as is" WITHOUT ANY WARRANTY of any + * kind, whether express or implied; without even the implied warranty + * of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <common.h> +#include <errno.h> +#include <spl.h> +#include <asm/arch/cpu.h> +#include <asm/arch/hardware.h> +#include <asm/arch/omap.h> +#include <asm/arch/ddr_defs.h> +#include <asm/arch/clock.h> +#include <asm/arch/gpio.h> +#include <asm/arch/mmc_host_def.h> +#include <asm/arch/sys_proto.h> +#include <asm/io.h> +#include <asm/emif.h> +#include <asm/gpio.h> +#include <i2c.h> +#include <miiphy.h> +#include <cpsw.h> +#include <power/tps65217.h> +#include "board.h" + +DECLARE_GLOBAL_DATA_PTR; + +static struct ctrl_dev *cdev = (struct ctrl_dev *)CTRL_DEVICE_BASE; + +/* MII mode defines */ +#define RMII_RGMII2_MODE_ENABLE 0x49 + +#if defined(CONFIG_SPL_BUILD) || defined(CONFIG_NOR_BOOT) + +/* DDR3 RAM timings */ +static const struct ddr_data ddr3_data = { + .datardsratio0 = MT41K128MJT187E_RD_DQS, + .datawdsratio0 = MT41K128MJT187E_WR_DQS, + .datafwsratio0 = MT41K128MJT187E_PHY_FIFO_WE, + .datawrsratio0 = MT41K128MJT187E_PHY_WR_DATA, +}; + +static const struct cmd_control ddr3_cmd_ctrl_data = { + .cmd0csratio = MT41K128MJT187E_RATIO, + .cmd0iclkout = MT41K128MJT187E_INVERT_CLKOUT, + .cmd1csratio = MT41K128MJT187E_RATIO, + .cmd1iclkout = MT41K128MJT187E_INVERT_CLKOUT, + .cmd2csratio = MT41K128MJT187E_RATIO, + .cmd2iclkout = MT41K128MJT187E_INVERT_CLKOUT, +}; + +static struct emif_regs ddr3_emif_reg_data = { + .sdram_config = MT41K128MJT187E_EMIF_SDCFG, + .ref_ctrl = MT41K128MJT187E_EMIF_SDREF, + .sdram_tim1 = MT41K128MJT187E_EMIF_TIM1, + .sdram_tim2 = MT41K128MJT187E_EMIF_TIM2, + .sdram_tim3 = MT41K128MJT187E_EMIF_TIM3, + .zq_config = MT41K128MJT187E_ZQ_CFG, + .emif_ddr_phy_ctlr_1 = MT41K128MJT187E_EMIF_READ_LATENCY | + PHY_EN_DYN_PWRDN, +}; + +const struct ctrl_ioregs ddr3_ioregs = { + .cm0ioctl = MT41K128MJT187E_IOCTRL_VALUE, + .cm1ioctl = MT41K128MJT187E_IOCTRL_VALUE, + .cm2ioctl = MT41K128MJT187E_IOCTRL_VALUE, + .dt0ioctl = MT41K128MJT187E_IOCTRL_VALUE, + .dt1ioctl = MT41K128MJT187E_IOCTRL_VALUE, +}; + +#ifdef CONFIG_SPL_OS_BOOT +int spl_start_uboot(void) +{ + /* break into full u-boot on 'c' */ + return serial_tstc() && serial_getc() == 'c'; +} +#endif + +#define OSC (V_OSCK/1000000) +const struct dpll_params dpll_ddr_266 = { + 266, OSC-1, 1, -1, -1, -1, -1}; +const struct dpll_params dpll_ddr_303 = { + 303, OSC-1, 1, -1, -1, -1, -1}; +const struct dpll_params dpll_ddr_400 = { + 400, OSC-1, 1, -1, -1, -1, -1}; + +void am33xx_spl_board_init(void) +{ + /* the pengwyn board uses the TPS650250 PMIC without I2C */ + /* interface and will output the following fixed voltages: */ + /* DCDC1=3V3 (IO) DCDC2=1V5 (DDR) DCDC3=1V26 (Vmpu) */ + /* VLDO1=1V8 (IO) VLDO2=1V8(IO) */ + /* Vcore=1V1 is fixed, generated by TPS62231 */ + + /* Get the frequency */ + dpll_mpu_opp100.m = am335x_get_efuse_mpu_max_freq(cdev); + + /* Set CORE Frequencies to OPP100 */ + do_setup_dpll(&dpll_core_regs, &dpll_core_opp100); + + /* 720MHz cpu, this might change on newer board revisions */ + dpll_mpu_opp100.m = MPUPLL_M_720; + do_setup_dpll(&dpll_mpu_regs, &dpll_mpu_opp100); +} + +const struct dpll_params *get_dpll_ddr_params(void) +{ + /* future configs can return other clock settings */ + return &dpll_ddr_303; +} + +void set_uart_mux_conf(void) +{ + enable_uart0_pin_mux(); +} + +void set_mux_conf_regs(void) +{ + enable_board_pin_mux(); +} + +void sdram_init(void) +{ + config_ddr(303, &ddr3_ioregs, &ddr3_data, + &ddr3_cmd_ctrl_data, &ddr3_emif_reg_data, 0); +} +#endif /* if CONFIG_SPL_BUILD */ + +/* + * Basic board specific setup. Pinmux has been handled already. + */ +int board_init(void) +{ + i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; + gpmc_init(); + return 0; +} + +#ifdef CONFIG_DRIVER_TI_CPSW +static void cpsw_control(int enabled) +{ + /* VTP can be added here */ + return; +} + +static struct cpsw_slave_data cpsw_slaves[] = { + { + .slave_reg_ofs = 0x208, + .sliver_reg_ofs = 0xd80, + .phy_id = 0, + .phy_if = PHY_INTERFACE_MODE_RMII, + }, + { + .slave_reg_ofs = 0x308, + .sliver_reg_ofs = 0xdc0, + .phy_id = 1, + .phy_if = PHY_INTERFACE_MODE_RMII, + }, +}; + +static struct cpsw_platform_data cpsw_data = { + .mdio_base = CPSW_MDIO_BASE, + .cpsw_base = CPSW_BASE, + .mdio_div = 0xff, + .channels = 8, + .cpdma_reg_ofs = 0x800, + .slaves = 1, + .slave_data = cpsw_slaves, + .ale_reg_ofs = 0xd00, + .ale_entries = 1024, + .host_port_reg_ofs = 0x108, + .hw_stats_reg_ofs = 0x900, + .bd_ram_ofs = 0x2000, + .mac_control = (1 << 5), + .control = cpsw_control, + .host_port_num = 0, + .version = CPSW_CTRL_VERSION_2, +}; +#endif + +#if defined(CONFIG_DRIVER_TI_CPSW) || \ + (defined(CONFIG_USB_ETHER) && defined(CONFIG_MUSB_GADGET)) +int board_eth_init(bd_t *bis) +{ + int rv, n = 0; +#ifdef CONFIG_DRIVER_TI_CPSW + uint8_t mac_addr[6]; + uint32_t mac_hi, mac_lo; + + if (!eth_getenv_enetaddr("ethaddr", mac_addr)) { + printf("<ethaddr> not set. Reading from E-fuse\n"); + /* try reading mac address from efuse */ + mac_lo = readl(&cdev->macid0l); + mac_hi = readl(&cdev->macid0h); + mac_addr[0] = mac_hi & 0xFF; + mac_addr[1] = (mac_hi & 0xFF00) >> 8; + mac_addr[2] = (mac_hi & 0xFF0000) >> 16; + mac_addr[3] = (mac_hi & 0xFF000000) >> 24; + mac_addr[4] = mac_lo & 0xFF; + mac_addr[5] = (mac_lo & 0xFF00) >> 8; + + if (is_valid_ether_addr(mac_addr)) + eth_setenv_enetaddr("ethaddr", mac_addr); + else + goto try_usbether; + } + + writel(RMII_RGMII2_MODE_ENABLE, &cdev->miisel); + + rv = cpsw_register(&cpsw_data); + if (rv < 0) + printf("Error %d registering CPSW switch\n", rv); + else + n += rv; +try_usbether: +#endif + +#if defined(CONFIG_USB_ETHER) && !defined(CONFIG_SPL_BUILD) + rv = usb_eth_initialize(bis); + if (rv < 0) + printf("Error %d registering USB_ETHER\n", rv); + else + n += rv; +#endif + return n; +} +#endif + +#ifdef CONFIG_BOARD_LATE_INIT +int board_late_init(void) +{ + return 0; +} +#endif diff --git a/board/silica/pengwyn/board.h b/board/silica/pengwyn/board.h new file mode 100644 index 0000000..0a44218 --- /dev/null +++ b/board/silica/pengwyn/board.h @@ -0,0 +1,22 @@ +/* + * board.h + * + * Copyright (C) 2013 Lothar Felten lothar.felten@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation version 2. + * + * This program is distributed "as is" WITHOUT ANY WARRANTY of any + * kind, whether express or implied; without even the implied warranty + * of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef _BOARD_H_ +#define _BOARD_H_ + +void enable_uart0_pin_mux(void); +void enable_board_pin_mux(void); + +#endif diff --git a/board/silica/pengwyn/mux.c b/board/silica/pengwyn/mux.c new file mode 100644 index 0000000..8b88795 --- /dev/null +++ b/board/silica/pengwyn/mux.c @@ -0,0 +1,109 @@ +/* + * mux.c + * + * Copyright (C) 2013 Lothar Felten lothar.felten@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation version 2. + * + * This program is distributed "as is" WITHOUT ANY WARRANTY of any + * kind, whether express or implied; without even the implied warranty + * of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <common.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/hardware.h> +#include <asm/arch/mux.h> +#include <asm/io.h> +#include "board.h" + +/* UART0 pins E15(rx),E16(tx) [E17(rts),E18(cts)] */ +static struct module_pin_mux uart0_pin_mux[] = { + {OFFSET(uart0_rxd), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* UART0_RXD */ + {OFFSET(uart0_txd), (MODE(0) | PULLUDEN)}, /* UART0_TXD */ + {-1}, +}; + +/* unused: UART1 pins D15(tx),D16(rx),D17(cts),D18(rts) */ + +/* I2C pins C16(scl)/C17(sda) */ +static struct module_pin_mux i2c0_pin_mux[] = { + {OFFSET(i2c0_sda), (MODE(0) | RXACTIVE | + PULLUDEN | SLEWCTRL)}, /* I2C0_DATA */ + {OFFSET(i2c0_scl), (MODE(0) | RXACTIVE | + PULLUDEN | SLEWCTRL)}, /* I2C0_SCLK */ + {-1}, +}; + +/* MMC0 pins */ +static struct module_pin_mux mmc0_pin_mux[] = { + {OFFSET(mmc0_dat3), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT3 */ + {OFFSET(mmc0_dat2), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT2 */ + {OFFSET(mmc0_dat1), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT1 */ + {OFFSET(mmc0_dat0), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT0 */ + {OFFSET(mmc0_clk), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_CLK */ + {OFFSET(mmc0_cmd), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_CMD */ + {OFFSET(spi0_cs1), (MODE(5) | RXACTIVE | PULLUP_EN)}, /* MMC0_CD */ + {-1}, +}; + +/* SPI0 pins A17(sclk),B17(d0),B16(d1),A16(cs0) [C15(cs1)] */ +static struct module_pin_mux spi0_pin_mux[] = { + {OFFSET(spi0_sclk), (MODE(0) | RXACTIVE | PULLUDEN)}, /* SPI0_SCLK */ + {OFFSET(spi0_d0), (MODE(0) | RXACTIVE | + PULLUDEN | PULLUP_EN)}, /* SPI0_D0 */ + {OFFSET(spi0_d1), (MODE(0) | RXACTIVE | PULLUDEN)}, /* SPI0_D1 */ + {OFFSET(spi0_cs0), (MODE(0) | RXACTIVE | + PULLUDEN | PULLUP_EN)}, /* SPI0_CS0 */ + {-1}, +}; + +static struct module_pin_mux rmii1_pin_mux[] = { + {OFFSET(mii1_crs), MODE(1) | RXACTIVE}, /* RMII1_CRS */ + {OFFSET(mii1_rxerr), MODE(1) | RXACTIVE}, /* RMII1_RXERR */ + {OFFSET(mii1_txen), MODE(1)}, /* RMII1_TXEN */ + {OFFSET(mii1_txd1), MODE(1)}, /* RMII1_TXD1 */ + {OFFSET(mii1_txd0), MODE(1)}, /* RMII1_TXD0 */ + {OFFSET(mii1_rxd1), MODE(1) | RXACTIVE}, /* RMII1_RXD1 */ + {OFFSET(mii1_rxd0), MODE(1) | RXACTIVE}, /* RMII1_RXD0 */ + {OFFSET(mdio_data), MODE(0) | RXACTIVE | PULLUP_EN}, /* MDIO_DATA */ + {OFFSET(mdio_clk), MODE(0) | PULLUP_EN}, /* MDIO_CLK */ + {OFFSET(rmii1_refclk), MODE(0) | RXACTIVE}, /* RMII1_REFCLK */ + {-1}, +}; + +static struct module_pin_mux nand_pin_mux[] = { + {OFFSET(gpmc_ad0), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD0 */ + {OFFSET(gpmc_ad1), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD1 */ + {OFFSET(gpmc_ad2), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD2 */ + {OFFSET(gpmc_ad3), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD3 */ + {OFFSET(gpmc_ad4), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD4 */ + {OFFSET(gpmc_ad5), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD5 */ + {OFFSET(gpmc_ad6), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD6 */ + {OFFSET(gpmc_ad7), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD7 */ + {OFFSET(gpmc_wait0), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* NAND WAIT */ + {OFFSET(gpmc_wpn), (MODE(7) | PULLUP_EN | RXACTIVE)}, /* NAND_WPN */ + {OFFSET(gpmc_csn0), (MODE(0) | PULLUDEN)}, /* NAND_CS0 */ + {OFFSET(gpmc_advn_ale), (MODE(0) | PULLUDEN)}, /* NAND_ADV_ALE */ + {OFFSET(gpmc_oen_ren), (MODE(0) | PULLUDEN)}, /* NAND_OE */ + {OFFSET(gpmc_wen), (MODE(0) | PULLUDEN)}, /* NAND_WEN */ + {OFFSET(gpmc_be0n_cle), (MODE(0) | PULLUDEN)}, /* NAND_BE_CLE */ + {-1}, +}; + +void enable_uart0_pin_mux(void) +{ + configure_module_pin_mux(uart0_pin_mux); +} + +void enable_board_pin_mux() +{ + configure_module_pin_mux(i2c0_pin_mux); + configure_module_pin_mux(uart0_pin_mux); + configure_module_pin_mux(rmii1_pin_mux); + configure_module_pin_mux(mmc0_pin_mux); + configure_module_pin_mux(nand_pin_mux); +} diff --git a/boards.cfg b/boards.cfg index 07ae05b..fc09fe1 100644 --- a/boards.cfg +++ b/boards.cfg @@ -254,6 +254,7 @@ Active arm armv7 am33xx phytec pcm051 Active arm armv7 am33xx siemens dxr2 dxr2 -
Roger Meier r.meier@siemens.com Active arm armv7 am33xx siemens pxm2 pxm2 -
Roger Meier r.meier@siemens.com Active arm armv7 am33xx siemens rut rut -
Roger Meier r.meier@siemens.com +Active arm armv7 am33xx silica pengwyn pengwyn -
Lothar Felten lothar.felten@gmail.com Active arm armv7 am33xx ti am335x am335x_boneblack am335x_evm:SERIAL1,CONS_INDEX=1,EMMC_BOOT Tom Rini trini@ti.com Active arm armv7 am33xx ti am335x am335x_evm am335x_evm:SERIAL1,CONS_INDEX=1,NAND Tom Rini trini@ti.com Active arm armv7 am33xx ti am335x am335x_evm_nor am335x_evm:SERIAL1,CONS_INDEX=1,NAND,NOR Tom Rini trini@ti.com diff --git a/include/configs/pengwyn.h b/include/configs/pengwyn.h new file mode 100644 index 0000000..65a1453 --- /dev/null +++ b/include/configs/pengwyn.h @@ -0,0 +1,340 @@ +/* + * pengwyn.h + * + * Copyright (C) 2013 Lothar Felten lothar.felten@gmail.com + * + * based on am335x_evm.h, Copyright (C) 2011 Texas Instruments Inc. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation version 2. + * + * This program is distributed "as is" WITHOUT ANY WARRANTY of any + * kind, whether express or implied; without even the implied warranty + * of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef __CONFIG_PENGWYN_H +#define __CONFIG_PENGWYN_H + +#define CONFIG_NAND +#define CONFIG_SERIAL1 +#define CONFIG_CONS_INDEX 1 + +#include <configs/ti_am335x_common.h> + +#define MACH_TYPE_PENGWYN 1234 +#define CONFIG_MACH_TYPE MACH_TYPE_PENGWYN + +/* Clock Defines */ +#define V_OSCK 24000000 +#define V_SCLK (V_OSCK) + +/* Always 128 KiB env size */ +#define CONFIG_ENV_SIZE (128 << 10) + +#ifdef CONFIG_NAND +#define NANDARGS \ + "mtdids=" MTDIDS_DEFAULT "\0" \ + "mtdparts=" MTDPARTS_DEFAULT "\0" \ + "nandargs=setenv bootargs console=${console} " \ + "${optargs} " \ + "root=${nandroot} " \ + "rootfstype=${nandrootfstype}\0" \ + "dfu_alt_info_nand=" DFU_ALT_INFO_NAND "\0" \ + "nandroot=ubi0:rootfs rw ubi.mtd=7,2048\0" \ + "nandrootfstype=ubifs rootwait=1\0" \ + "nandsrcaddr=0x280000\0" \ + "nandboot=echo Booting from nand ...; " \ + "run nandargs; " \ + "nand read ${loadaddr} ${nandsrcaddr} ${nandimgsize}; " \ + "bootz ${loadaddr}\0" \ + "nandimgsize=0x500000\0" +#else +#define NANDARGS "" +#endif + +#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG + +#ifndef CONFIG_SPL_BUILD +#define CONFIG_EXTRA_ENV_SETTINGS \ + "loadaddr=0x80200000\0" \ + "fdtaddr=0x80F80000\0" \ + "fdt_high=0xffffffff\0" \ + "boot_fdt=try\0" \ + "rdaddr=0x81000000\0" \ + "bootpart=0:2\0" \ + "bootdir=/boot\0" \ + "bootfile=zImage\0" \ + "fdtfile=undefined\0" \ + "console=ttyO0,115200n8\0" \ + "optargs=\0" \ + "dfu_alt_info_mmc=" DFU_ALT_INFO_MMC "\0" \ + "dfu_alt_info_emmc=rawemmc mmc 0 3751936\0" \ + "mmcdev=0\0" \ + "mmcroot=/dev/mmcblk0p2 ro\0" \ + "mmcrootfstype=ext4 rootwait\0" \ + "rootpath=/export/rootfs\0" \ + "nfsopts=nolock\0" \ + "static_ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}" \ + "::off\0" \ + "ramroot=/dev/ram0 rw ramdisk_size=65536 initrd=${rdaddr},64M\0" \ + "ramrootfstype=ext2\0" \ + "mmcargs=setenv bootargs console=${console} " \ + "${optargs} " \ + "root=${mmcroot} " \ + "rootfstype=${mmcrootfstype}\0" \ + "spiroot=/dev/mtdblock4 rw\0" \ + "spirootfstype=jffs2\0" \ + "spisrcaddr=0xe0000\0" \ + "spiimgsize=0x362000\0" \ + "spibusno=0\0" \ + "spiargs=setenv bootargs console=${console} " \ + "${optargs} " \ + "root=${spiroot} " \ + "rootfstype=${spirootfstype}\0" \ + "netargs=setenv bootargs console=${console} " \ + "${optargs} " \ + "root=/dev/nfs " \ + "nfsroot=${serverip}:${rootpath},${nfsopts} rw " \ + "ip=dhcp\0" \ + "bootenv=uEnv.txt\0" \ + "loadbootenv=load mmc ${mmcdev} ${loadaddr} ${bootenv}\0" \ + "importbootenv=echo Importing environment from mmc ...; " \ + "env import -t $loadaddr $filesize\0" \ + "dfu_alt_info_ram=" DFU_ALT_INFO_RAM "\0" \ + "ramargs=setenv bootargs console=${console} " \ + "${optargs} " \ + "root=${ramroot} " \ + "rootfstype=${ramrootfstype}\0" \ + "loadramdisk=load mmc ${mmcdev} ${rdaddr} ramdisk.gz\0" \ + "loadimage=load mmc ${bootpart} ${loadaddr} ${bootdir}/${bootfile}\0" \ + "loadfdt=load mmc ${bootpart} ${fdtaddr} ${bootdir}/${fdtfile}\0" \ + "mmcloados=run mmcargs; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if run loadfdt; then " \ + "bootz ${loadaddr} - ${fdtaddr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootz; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootz; " \ + "fi;\0" \ + "mmcboot=mmc dev ${mmcdev}; " \ + "if mmc rescan; then " \ + "echo SD/MMC found on device ${mmcdev};" \ + "if run loadbootenv; then " \ + "echo Loaded environment from ${bootenv};" \ + "run importbootenv;" \ + "fi;" \ + "if test -n $uenvcmd; then " \ + "echo Running uenvcmd ...;" \ + "run uenvcmd;" \ + "fi;" \ + "if run loadimage; then " \ + "run mmcloados;" \ + "fi;" \ + "fi;\0" \ + "spiboot=echo Booting from spi ...; " \ + "run spiargs; " \ + "sf probe ${spibusno}:0; " \ + "sf read ${loadaddr} ${spisrcaddr} ${spiimgsize}; " \ + "bootz ${loadaddr}\0" \ + "netboot=echo Booting from network ...; " \ + "setenv autoload no; " \ + "dhcp; " \ + "tftp ${loadaddr} ${bootfile}; " \ + "tftp ${fdtaddr} ${fdtfile}; " \ + "run netargs; " \ + "bootz ${loadaddr} - ${fdtaddr}\0" \ + "ramboot=echo Booting from ramdisk ...; " \ + "run ramargs; " \ + "bootz ${loadaddr} ${rdaddr} ${fdtaddr}\0" \ + "findfdt="\ + "if test $board_name = A335BONE; then " \ + "setenv fdtfile am335x-bone.dtb; fi; " \ + "if test $board_name = A335BNLT; then " \ + "setenv fdtfile am335x-boneblack.dtb; fi; " \ + "if test $board_name = A33515BB; then " \ + "setenv fdtfile am335x-evm.dtb; fi; " \ + "if test $board_name = A335X_SK; then " \ + "setenv fdtfile am335x-evmsk.dtb; fi; " \ + "if test $fdtfile = undefined; then " \ + "echo WARNING: no device tree found; fi; \0" \ + NANDARGS +#endif + +#define CONFIG_BOOTCOMMAND \ + "run findfdt; " \ + "run mmcboot;" \ + "setenv mmcdev 1; " \ + "setenv bootpart 1:2; " \ + "run mmcboot;" \ + "run nandboot;" + +/* NS16550 Configuration */ +#define CONFIG_SYS_NS16550_COM1 0x44e09000 /* Base EVM has UART0 */ +#define CONFIG_SYS_NS16550_COM2 0x48022000 /* UART1 */ +#define CONFIG_SYS_NS16550_COM3 0x48024000 /* UART2 */ +#define CONFIG_SYS_NS16550_COM4 0x481a6000 /* UART3 */ +#define CONFIG_SYS_NS16550_COM5 0x481a8000 /* UART4 */ +#define CONFIG_SYS_NS16550_COM6 0x481aa000 /* UART5 */ +#define CONFIG_BAUDRATE 115200 + +/* I2C Configuration */ +#define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_CMD_EEPROM +#define CONFIG_ENV_EEPROM_IS_ON_I2C +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 /* Main EEPROM */ +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 +#define CONFIG_SYS_I2C_MULTI_EEPROMS + +/* SPL */ +#define CONFIG_SPL_POWER_SUPPORT +#define CONFIG_SPL_YMODEM_SUPPORT + +/* USB gadget RNDIS */ +#define CONFIG_SPL_MUSB_NEW_SUPPORT + +/* General network SPL, both CPSW and USB gadget RNDIS */ +#define CONFIG_SPL_NET_SUPPORT +#define CONFIG_SPL_ENV_SUPPORT +#define CONFIG_SPL_NET_VCI_STRING "AM335x U-Boot SPL" + +/* NAND support */ +#ifdef CONFIG_NAND +#define CONFIG_CMD_NAND +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ + CONFIG_SYS_NAND_PAGE_SIZE) +#define CONFIG_SYS_NAND_PAGE_SIZE 2048 +#define CONFIG_SYS_NAND_OOBSIZE 64 +#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) +#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS +#define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ + 10, 11, 12, 13, 14, 15, 16, 17, \ + 18, 19, 20, 21, 22, 23, 24, 25, \ + 26, 27, 28, 29, 30, 31, 32, 33, \ + 34, 35, 36, 37, 38, 39, 40, 41, \ + 42, 43, 44, 45, 46, 47, 48, 49, \ + 50, 51, 52, 53, 54, 55, 56, 57, } + +#define CONFIG_SYS_NAND_ECCSIZE 512 +#define CONFIG_SYS_NAND_ECCBYTES 14 + +#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 + +#define GPMC_NAND_ECC_LP_x8_LAYOUT 1 +#define MTDIDS_DEFAULT "nand0=omap2-nand.0" +#define MTDPARTS_DEFAULT "mtdparts=omap2-nand.0:128k(SPL)," \ + "128k(SPL.backup1)," \ + "128k(SPL.backup2)," \ + "128k(SPL.backup3),1792k(u-boot)," \ + "128k(u-boot-spl-os)," \ + "128k(u-boot-env),5m(kernel),-(rootfs)" +#define CONFIG_ENV_OFFSET 0x260000 /* environment starts here */ +#define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ +#else +#define CONFIG_ENV_IS_NOWHERE +#endif /* NAND */ + + +/* + * USB configuration. We enable MUSB support, both for host and for + * gadget. We set USB0 as peripheral and USB1 as host, based on the + * board schematic and physical port wired to each. Then for host we + * add mass storage support and for gadget we add both RNDIS ethernet + * and DFU. + */ +#define CONFIG_USB_MUSB_DSPS +#define CONFIG_ARCH_MISC_INIT +#define CONFIG_MUSB_GADGET +#define CONFIG_MUSB_PIO_ONLY +#define CONFIG_MUSB_DISABLE_BULK_COMBINE_SPLIT +#define CONFIG_USB_GADGET +#define CONFIG_USBDOWNLOAD_GADGET +#define CONFIG_USB_GADGET_DUALSPEED +#define CONFIG_USB_GADGET_VBUS_DRAW 2 +#define CONFIG_MUSB_HOST +#define CONFIG_AM335X_USB0 +#define CONFIG_AM335X_USB0_MODE MUSB_PERIPHERAL +#define CONFIG_AM335X_USB1 +#define CONFIG_AM335X_USB1_MODE MUSB_HOST + +#ifdef CONFIG_MUSB_HOST +#define CONFIG_CMD_USB +#define CONFIG_USB_STORAGE +#endif + +#ifdef CONFIG_MUSB_GADGET +#define CONFIG_USB_ETHER +#define CONFIG_USB_ETH_RNDIS +#define CONFIG_USBNET_HOST_ADDR "de:ad:be:af:00:00" + +/* USB TI's IDs */ +#define CONFIG_G_DNL_VENDOR_NUM 0x0403 +#define CONFIG_G_DNL_PRODUCT_NUM 0xBD00 +#define CONFIG_G_DNL_MANUFACTURER "Texas Instruments" +#endif /* CONFIG_MUSB_GADGET */ + +#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_USBETH_SUPPORT) +/* disable host part of MUSB in SPL */ +#undef CONFIG_MUSB_HOST +/* Disable CPSW SPL support so we fit within the 101KiB limit. */ +#undef CONFIG_SPL_ETH_SUPPORT +#endif + +/* USB Device Firmware Update support */ +#define CONFIG_DFU_FUNCTION +#define CONFIG_DFU_MMC +#define CONFIG_CMD_DFU +#define DFU_ALT_INFO_MMC \ + "boot part 0 1;" \ + "rootfs part 0 2;" \ + "MLO fat 0 1;" \ + "MLO.raw mmc 100 100;" \ + "u-boot.img.raw mmc 300 400;" \ + "spl-os-args.raw mmc 80 80;" \ + "spl-os-image.raw mmc 900 2000;" \ + "spl-os-args fat 0 1;" \ + "spl-os-image fat 0 1;" \ + "u-boot.img fat 0 1;" \ + "uEnv.txt fat 0 1" +#ifdef CONFIG_NAND +#define CONFIG_DFU_NAND +#define DFU_ALT_INFO_NAND \ + "SPL part 0 1;" \ + "SPL.backup1 part 0 2;" \ + "SPL.backup2 part 0 3;" \ + "SPL.backup3 part 0 4;" \ + "u-boot part 0 5;" \ + "u-boot-spl-os part 0 6;" \ + "kernel part 0 8;" \ + "rootfs part 0 9" +#endif +#define CONFIG_DFU_RAM +#define DFU_ALT_INFO_RAM \ + "kernel ram 0x80200000 0xD80000;" \ + "fdt ram 0x80F80000 0x80000;" \ + "ramdisk ram 0x81000000 0x4000000" + +/* Network. */ +#define CONFIG_PHYLIB +#define CONFIG_PHY_ADDR 1 +#define CONFIG_PHY_RESET 1 +#define CONFIG_PHY_NATSEMI + +/* CPSW support */ +#define CONFIG_SPL_ETH_SUPPORT + +#define CONFIG_SPL_LDSCRIPT "$(CPUDIR)/am33xx/u-boot-spl.lds" + +#endif /* ! __CONFIG_PENGWYN_H */ +
Please consider using git send-email for submission. Your MUA broke the patch so it doesn't apply, and the From and S-o-b specs don't match.
virtually yours Gerhard Sittig
Dear micro1183,
Your patch is line-wrapped and does not apply. Please fix your mailer configuration.
- board.c
- Copyright (C) 2013 Lothar Felten lothar.felten@gmail.com
- published by the Free Software Foundation version 2.
Please use a SPDX license tag instead. And please notice that new code should have GPL-2.0+; GPL-2.0 is not sufficient.
Please fix globally.
Do you really need all these headers?
MACH-ID 1234 is registered for the gene1270 bord. Please do not hijack other board's IDs! Register your own instead, please.
This makes no sense. You will never need that much, and such a huge size just slows down booting etc.
Do you really need all of these?
Is this a good idea?
Is this really a TI board?
Dear Wolfgang,
thanks for your feedback.
On 01/24/2014 03:12 PM, Wolfgang Denk wrote:
Dear micro1183,
I tried to fix my settings and will test it by sending a patch to myself using git send-email.
- board.c
ok, done. I use a single line SPDX identifier for GPL-2.0+ now.
+#include <common.h> +#include "board.h"
cleaned them up now.
Where can I find a list of IDs? I can't find much information on a gene1270 board in arch/arm/tools/mach-types. Is a MACH_TYPE identifier mandatory?
Thanks. Set to 0x4000.
No, removed all but the console one.
I need some HW address and USB VID:PID to get it working. TI's code does it and so does siemens' rut. I could drop this functionality and remove it all.
Best regards, Lothar
Gerhard Sittig
micro1183
