[U-Boot-Users] [patch] fix CONFIG_MICROBL*A*ZE typo
this fix CONFIG_MICROBL*A*ZE typo all over the place.
# OK I admit I don't use caps lock :< -- yashi
* Patch by Yasushi SHOJI, 29 Jun 2004: - fix CONFIG_MICROBL*A*ZE typo all over the place. sigh...
Index: u-boot/include/configs/suzaku.h =================================================================== --- u-boot.orig/include/configs/suzaku.h +++ u-boot/include/configs/suzaku.h @@ -36,7 +36,7 @@ * (easy to change) */
-#define CONFIG_MICROBLZE 1 /* This is an MicroBlaze CPU */ +#define CONFIG_MICROBLAZE 1 /* This is an MicroBlaze CPU */ #define CONFIG_SUZAKU 1 /* on an SUZAKU Board */
/*----------------------------------------------------------------------- Index: u-boot/examples/stubs.c =================================================================== --- u-boot.orig/examples/stubs.c +++ u-boot/examples/stubs.c @@ -94,7 +94,7 @@ gd_t *global_data; " move.l (%%a0), %%a0\n" \ " jmp (%%a0)\n" \ : : "i"(offsetof(gd_t, jt)), "i"(XF_ ## x * sizeof(void *)) : "a0"); -#elif defined(CONFIG_MICROBLZE) +#elif defined(CONFIG_MICROBLAZE) /* * r31 holds the pointer to the global_data. r5 is a call-clobbered. */ Index: u-boot/README =================================================================== --- u-boot.orig/README +++ u-boot/README @@ -242,7 +242,7 @@ The following options need to be configu
MicroBlaze based CPUs: ---------------------- - CONFIG_MICROBLZE + CONFIG_MICROBLAZE
- Board Type: Define exactly one of Index: u-boot/drivers/serial_xuartlite.c =================================================================== --- u-boot.orig/drivers/serial_xuartlite.c +++ u-boot/drivers/serial_xuartlite.c @@ -24,7 +24,7 @@
#include <config.h>
-#ifdef CONFIG_MICROBLZE +#ifdef CONFIG_MICROBLAZE
#include <asm/serial_xuartlite.h>
Added, thanks.
Yasushi SHOJI
