Bug: PDF documentation doesn't build according to instructions
When I follow the instructions for building PDF documentation ( https://docs.u-boot.org/en/latest/build/documentation.html ) , I run into an error at the texi2pdf step (attached). It appears to have to do with the boot flow diagram of k3_current not being an acceptable format for the pdf compiler. I tested this on several releases and it appears to have appeared in the v2023.10 release and continues to the latest. I was able to build the documentation on the v2023.07 release.
Take care,
Patrick Walton Co-founder/CEO Care Weather 801-227-4740 www.careweather.com ( http://www.careweather.com )
Unfortunately PDF docs are not part of CI and it seems that we would need a bit of work to make it automatically build as well. Patches to do this as well as fix the problem you reported would be much appreciated.
Patrick Walton
