[PATCH] ARM: zynq: DT: Enable all FCLKs by default
The fclk-enable property is set to 0 which disables all FCLKs. Enable all FCLKs so they can be used as clock sources in the programmable logic.
Signed-off-by: Christian Kohn christian.kohn@xilinx.com Acked-by: Soren Brinkmann soren.brinkmann@xilinx.com Signed-off-by: Michal Simek michal.simek@amd.com ---
arch/arm/dts/zynq-7000.dtsi | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/zynq-7000.dtsi b/arch/arm/dts/zynq-7000.dtsi index edc147d63f1e..f72ef526f057 100644 --- a/arch/arm/dts/zynq-7000.dtsi +++ b/arch/arm/dts/zynq-7000.dtsi @@ -340,7 +340,7 @@ u-boot,dm-pre-reloc; #clock-cells = <1>; compatible = "xlnx,ps7-clkc"; - fclk-enable = <0>; + fclk-enable = <0xf>; clock-output-names = "armpll", "ddrpll", "iopll", "cpu_6or4x", "cpu_3or2x", "cpu_2x", "cpu_1x", "ddr2x", "ddr3x", "dci", "lqspi", "smc", "pcap", "gem0", "gem1",
fclk-enable = <0>;
Applied. M
Michal Simek
