On Thu, 23 Nov 2023 11:12:25 -0800 Stephen Graf stephen.graf@gmail.com wrote:
Hi Stephen,
Thank you for your reply.
Thanks for coming back. Please keep the list(s) on CC:, as this is also interesting for others, and more eyes help to find issues faster. CC:ing Piotr and Mikhail, who were debugging the LPDDR4 DRAM setup before.
I built u-boot with the proposed changes and it seems to work. It does however report "DRAM: 2048 MiB" although I have a board with only 1G.
Ah, that's a good report! I actually saw the same issue (reporting 8GB instead of 4GB), and my hunch is that it's related to some missing barriers or delays, as seen on other boards. Can you try to add a "dsb();" to the beginning of arch/arm/mach-sunxi/dram_helpers.c:mctl_mem_matches(), before the first writel()? I am still not convinced this is the right place to put the barrier, but it would confirm that this is the issue. Also I didn't see this effect consistently, so did this happen for you every time?
Another thing you could try is to increase the voltage to 1150mV, this is what Piotr needed for reliable operation.
When I built u-boot with the config that I used it reported 1G correctly. The Zunlong distros do have different images for various RAM configurations.
Yeah, I saw this, and I hope we can avoid this. I am not sure if you are the first one with a 1GB board, so your testing is definitely helpful.
I do not know enough about the details to determine which differences in the two configs result in the change.
I am more than willing to test and report if someone can direct me a bit.
sysadmin@ubuntu:~/defconfgs$ diff sg.txt andre.txt
(please use "diff -u", that's easier to read and people are more used to its output style)
9d8 < CONFIG_DRAM_SUN50I_H616_TPR0=0x0 11,13c10,12 < CONFIG_DRAM_SUN50I_H616_TPR10=0x402f0663 < CONFIG_DRAM_SUN50I_H616_TPR11=0x24242323
< CONFIG_DRAM_SUN50I_H616_TPR12=0x0e0e0e0e
CONFIG_DRAM_SUN50I_H616_TPR10=0x402f6663 CONFIG_DRAM_SUN50I_H616_TPR11=0x24242624 CONFIG_DRAM_SUN50I_H616_TPR12=0x0f0f100f
I don't think those minor timing differences matter much, but you can try to experiment with both set of values.
16d14 < CONFIG_DRAM_CLK=792
Not specifying DRAM_CLK means it uses the default 720 MHz. In the past lowering the DRAM frequency was an easy way to stabilise the DRAM setup, even though this might somewhat paper over other issues.
25c23
< CONFIG_SPI_FLASH_MACRONIX=y
CONFIG_SPI_FLASH_ZBIT=y
Please double check, but I think all new OrangePi boards now use a zBIT flash chip? Should have a small "Z" like logo on that 8 pin chip with the large pins on top.
27a26
CONFIG_AXP313_POWER=y
32,34c31 < CONFIG_AXP313_POWER=y < CONFIG_AXP_DCDC3_VOLT=1100
1100mV is the default, so putting exactly this value in doesn't change anything.
< CONFIG_CMD_BOOTZ=y
Why do you need bootz? I don't think this doing anything useful in mainline U-Boot. Don't know if OrangePi was just confused and had an actual use case for this.
A second issue that I discovered with both builds is that the Ethernet does not come up on a 1Gb switch, but works on a 100Mb switch.
There is a pending patch for mainline Linux, can you try to apply those DT changes to U-Boot's DT copy and see if that helps? https://lore.kernel.org/linux-sunxi/2303336.ElGaqSPkdT@jernej-laptop/T/#m77e...
Cheers, Andre
Output from the patch defconfig (1Gb LAN):
U-Boot SPL 2024.01-rc3-00009-g9e53e45292-dirty (Nov 23 2023 - 18:08:24 +0000) DRAM: 2048 MiB Trying to boot from MMC1 NOTICE: BL31: v2.10.0 (debug):v2.10.0 NOTICE: BL31: Built : 18:07:18, Nov 23 2023 NOTICE: BL31: Detected Allwinner H616 SoC (1823) NOTICE: BL31: Found U-Boot DTB at 0x4a0b2750, model: OrangePi Zero3 INFO: ARM GICv2 driver initialized INFO: Configuring SPC Controller INFO: PMIC: Probing AXP305 on RSB ERROR: RSB: set run-time address: 0x10003 INFO: Could not init RSB: -65539 INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services INFO: BL31: cortex_a53: CPU workaround for erratum 855873 was applied INFO: BL31: cortex_a53: CPU workaround for erratum 1530924 was applied INFO: PSCI: Suspend is unavailable INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 INFO: Changed devicetree.
U-Boot 2024.01-rc3-00009-g9e53e45292-dirty (Nov 23 2023 - 18:08:24 +0000) Allwinner Technology
CPU: Allwinner H616 (SUN50I) Model: OrangePi Zero3 DRAM: 2 GiB Core: 57 devices, 25 uclasses, devicetree: separate WDT: Not starting watchdog@30090a0 MMC: mmc@4020000: 0 Loading Environment from FAT... Unable to use mmc 0:1... In: serial@5000000 Out: serial@5000000 Err: serial@5000000 Allwinner mUSB OTG (Peripheral) Net: eth0: ethernet@5020000using musb-hdrc, OUT ep1out IN ep1in STATUS ep2in MAC de:ad:be:ef:00:01 HOST MAC de:ad:be:ef:00:00 RNDIS ready , eth1: usb_ether starting USB... Bus usb@5200000: USB EHCI 1.00 Bus usb@5200400: USB OHCI 1.0 scanning bus usb@5200000 for devices... 1 USB Device(s) found scanning bus usb@5200400 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device
Device 0: unknown device BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 BOOTP broadcast 4 BOOTP broadcast 5 BOOTP broadcast 6 BOOTP broadcast 7 BOOTP broadcast 8 BOOTP broadcast 9 BOOTP broadcast 10 BOOTP broadcast 11 BOOTP broadcast 12
Retry time exceeded; starting again missing environment variable: pxeuuid Retrieving file: pxelinux.cfg/01-02-00-d5-13-4f-ba *** ERROR: `serverip' not set
Output from the defconfig that I had used (100Mb LAN):
U-Boot SPL 2024.01-rc3-00009-g9e53e45292-dirty (Nov 23 2023 - 18:56:18 +0000) DRAM: 1024 MiB Trying to boot from MMC1 NOTICE: BL31: v2.10.0 (debug):v2.10.0 NOTICE: BL31: Built : 18:07:18, Nov 23 2023 NOTICE: BL31: Detected Allwinner H616 SoC (1823) NOTICE: BL31: Found U-Boot DTB at 0x4a0b3b68, model: OrangePi Zero3 INFO: ARM GICv2 driver initialized INFO: Configuring SPC Controller INFO: PMIC: Probing AXP305 on RSB ERROR: RSB: set run-time address: 0x10003 INFO: Could not init RSB: -65539 INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services INFO: BL31: cortex_a53: CPU workaround for erratum 855873 was applied INFO: BL31: cortex_a53: CPU workaround for erratum 1530924 was applied INFO: PSCI: Suspend is unavailable INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 INFO: Changed devicetree.
U-Boot 2024.01-rc3-00009-g9e53e45292-dirty (Nov 23 2023 - 18:56:18 +0000) Allwinner Technology
CPU: Allwinner H616 (SUN50I) Model: OrangePi Zero3 DRAM: 1 GiB Core: 57 devices, 25 uclasses, devicetree: separate WDT: Not starting watchdog@30090a0 MMC: mmc@4020000: 0 Loading Environment from FAT... Unable to use mmc 0:1... In: serial@5000000 Out: serial@5000000 Err: serial@5000000 Allwinner mUSB OTG (Peripheral) Net: eth0: ethernet@5020000using musb-hdrc, OUT ep1out IN ep1in STATUS ep2in MAC de:ad:be:ef:00:01 HOST MAC de:ad:be:ef:00:00 RNDIS ready , eth1: usb_ether starting USB... Bus usb@5200000: USB EHCI 1.00 Bus usb@5200400: USB OHCI 1.0 scanning bus usb@5200000 for devices... 1 USB Device(s) found scanning bus usb@5200400 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device
Device 0: unknown device BOOTP broadcast 1 DHCP client bound to address 192.168.1.63 (5 ms) *** Warning: no boot file name; using 'C0A8013F.img' Using ethernet@5020000 device TFTP from server 192.168.1.253; our IP address is 192.168.1.63 Filename 'C0A8013F.img'. Load address: 0x42000000 Loading: T T T
defconfig used:
CONFIG_ARM=y CONFIG_ARCH_SUNXI=y CONFIG_DEFAULT_DEVICE_TREE="sun50i-h618-orangepi-zero3" CONFIG_SPL=y CONFIG_DRAM_SUN50I_H616_DX_ODT=0x07070707 CONFIG_DRAM_SUN50I_H616_DX_DRI=0x0e0e0e0e CONFIG_DRAM_SUN50I_H616_CA_DRI=0x0e0e CONFIG_DRAM_SUN50I_H616_ODT_EN=0xaaaaeeee CONFIG_DRAM_SUN50I_H616_TPR0=0x0 CONFIG_DRAM_SUN50I_H616_TPR6=0x44000000 CONFIG_DRAM_SUN50I_H616_TPR10=0x402f0663 CONFIG_DRAM_SUN50I_H616_TPR11=0x24242323 CONFIG_DRAM_SUN50I_H616_TPR12=0x0e0e0e0e CONFIG_MACH_SUN50I_H616=y CONFIG_SUNXI_DRAM_H616_LPDDR4=y CONFIG_DRAM_CLK=792 CONFIG_R_I2C_ENABLE=y CONFIG_SPL_SPI_SUNXI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C=y CONFIG_SPL_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_SYS_I2C_SLAVE=0x7f CONFIG_SYS_I2C_SPEED=400000 CONFIG_SPI_FLASH_MACRONIX=y CONFIG_PHY_MOTORCOMM=y CONFIG_SUN8I_EMAC=y CONFIG_SPI=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_AXP313_POWER=y CONFIG_AXP_DCDC3_VOLT=1100 CONFIG_CMD_BOOTZ=y
On 2023-11-23 6:15 a.m., Andre Przywara wrote:
On Tue, 21 Nov 2023 21:52:12 -0800 Stephen Graf s_graf@telus.net wrote:
Hi Stephen,
I have been able to build a working (on my orangepi zero3 1G) u-boot for the orangepi zero3 with the following defconfig. Would it be possible to
thanks for your interest in contributing and for reaching out! As Peter already mentioned, you would need to send a patch, as generated by "git format-patch". "git send-email" would help you with sending this out.
But actually I sent a small series already last week: https://lore.kernel.org/u-boot/20231114013106.31336-1-andre.przywara@arm.com...
If you could apply these patches and test it on your board, I'd be grateful. If it works for you and you are happy, please reply to patch 3/3 and add a "Tested-by: Your Name your@email.com" line. For instructions how to reply, check "Reply instructions" at the end of that mailing list archive web page above.
I was just waiting for confirmations by other people before merging it.
Cheers, Andre
add this config to the working boards. I would test it again with an official build. The dtb/dts is in linux and in u-boot.
The H618 processor is software compatible with the H616 and the zero3 board is very similar to the zero2 with the exception of DDR3 replaced with LPDDR4 and the Realtek phy with Motorcomm.
I tested a u-boot build with the emac timing changes you pointed out and with CONFIG_DRAM_CLK=792. It looks like this configuration and dts changes works with both 100Mb and 1Gb switches.
I am struggling to get something to actually load. Is there an easy way to get a debian image onto the sd card so that u-boot can actually load something.
Console output:
U-Boot SPL 2024.01-rc3-00009-g9e53e45292-dirty (Nov 24 2023 - 18:47:11 +0000) DRAM: 1024 MiB Trying to boot from MMC1 NOTICE: BL31: v2.10.0 (debug):v2.10.0 NOTICE: BL31: Built : 18:07:18, Nov 23 2023 NOTICE: BL31: Detected Allwinner H616 SoC (1823) NOTICE: BL31: Found U-Boot DTB at 0x4a0b2750, model: OrangePi Zero3 INFO: ARM GICv2 driver initialized INFO: Configuring SPC Controller INFO: PMIC: Probing AXP305 on RSB ERROR: RSB: set run-time address: 0x10003 INFO: Could not init RSB: -65539 INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services INFO: BL31: cortex_a53: CPU workaround for erratum 855873 was applied INFO: BL31: cortex_a53: CPU workaround for erratum 1530924 was applied INFO: PSCI: Suspend is unavailable INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 INFO: Changed devicetree. U-Boot 2024.01-rc3-00009-g9e53e45292-dirty (Nov 24 2023 - 18:47:11 +0000) Allwinner Technology CPU: Allwinner H616 (SUN50I) Model: OrangePi Zero3 DRAM: 1 GiB Core: 57 devices, 25 uclasses, devicetree: separate WDT: Not starting watchdog@30090a0 MMC: mmc@4020000: 0 Loading Environment from FAT... Unable to read "uboot.env" from mmc0:1... In: serial@5000000 Out: serial@5000000 Err: serial@5000000 Allwinner mUSB OTG (Peripheral) Net: eth0: ethernet@5020000using musb-hdrc, OUT ep1out IN ep1in STATUS ep2in MAC de:ad:be:ef:00:01 HOST MAC de:ad:be:ef:00:00 RNDIS ready , eth1: usb_ether starting USB... Bus usb@5200000: USB EHCI 1.00 Bus usb@5200400: USB OHCI 1.0 scanning bus usb@5200000 for devices... 1 USB Device(s) found scanning bus usb@5200400 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... No EFI system partition No EFI system partition Failed to persist EFI variables BootOrder not defined EFI boot manager: Cannot load any image Device 0: unknown device BOOTP broadcast 1 DHCP client bound to address 192.168.1.63 (4 ms) *** Warning: no boot file name; using 'C0A8013F.img' Using ethernet@5020000 device TFTP from server 192.168.1.253; our IP address is 192.168.1.63 Filename 'C0A8013F.img'. Load address: 0x42000000 Loading: T T T
On 2023-11-23 4:11 p.m., Andre Przywara wrote:
On Thu, 23 Nov 2023 11:12:25 -0800 Stephen Grafstephen.graf@gmail.com wrote:
Hi Stephen,
25c23
27a26
Cheers, Andre
defconfig used:
On Tue, 21 Nov 2023 21:52:12 -0800 Stephen Grafs_graf@telus.net wrote:
Hi Stephen,
If you could apply these patches and test it on your board, I'd be grateful. If it works for you and you are happy, please reply to patch 3/3 and add a "Tested-by: Your Nameyour@email.com" line. For instructions how to reply, check "Reply instructions" at the end of that mailing list archive web page above.
Cheers, Andre
On Fri, 24 Nov 2023 11:04:31 -0800 Stephen Graf stephen.graf@gmail.com wrote:
Ah, great, thanks! I will see if I can pull the DT change in sometime soon.
Userland wise you can use any arm64 image, for instance any of the cloud images, or you nick it from some existing arm64 installation. Kernel wise the only requirement would be at least a v6.5 kernel, since only this one supports the Motorcomm Ethernet PHY and, more importantly: the PMIC. Any distro kernel would do, or you bake your own, defconfig should be enough for booting plus USB and MMC. CONFIG_DWMAC_SUN8I=y and CONFIG_MOTORCOMM_PHY=y should give you Ethernet on top, I think, but there might be more needed.
For a quick boot, set the commandline and load and boot the kernel: => setenv bootargs "console=ttyS0,115200n8 earlycon root=/dev/mmcblk0p2 rootwait" => load mmc 0:1 $kernel_addr_r Image-6.7-rc2 => booti $kernel_addr_r - $fdtcontroladdr
(those are rough instructions, please fill the gaps, or reply with specific questions)
You could even try to install a distro, using the official UEFI installers many distros provide. This process can be long and tedious, though, plus you need a v6.5 installer kernel, and would probably need to play around to get it booted automatically.
Console output:
This seems to got mangled, but looks like expected: you just have nothing that would load automatically. A USB stick with an UEFI boot program should be detected and started, for instance a distro installer. Still you would need a v6.5 kernel, without the PMIC driver you won't get far.
Cheers, Andre
P.S. You can put the whole firmware (U-Boot + TF-A) on the SPI flash, that gives you more freedom with the SD card. Just follow the instructions in doc/board/allwinner/sunxi.rst.
Hi Stephen,
25c23
27a26
Cheers, Andre
defconfig used:
Hi Stephen,
Cheers, Andre
Hi Stephen,
I tried using an additional barrier as you described:
diff --git a/arch/arm/mach-sunxi/dram_helpers.c b/arch/arm/mach-sunxi/dram_helpers.c index cdf2750..16938fa 100644 --- a/arch/arm/mach-sunxi/dram_helpers.c +++ b/arch/arm/mach-sunxi/dram_helpers.c @@ -34,6 +34,7 @@ bool mctl_mem_matches(u32 offset) { /* Try to write different values to RAM at two addresses */ writel(0, CFG_SYS_SDRAM_BASE); + dsb(); writel(0xaa55aa55, (ulong)CFG_SYS_SDRAM_BASE + offset); dsb(); /* Check if the same value is actually observed when reading back */
After this I did not notice any problems with incorrect configuration.
As I understand it, the problem occurs most often during a hot plug.
25c23
27a26
Cheers, Andre
defconfig used:
Hi Stephen,
Cheers, Andre
Andre Przywara
Mikhail Kalashnikov
Stephen Graf
