[PATCH] efi_loader: Add absolute path to EFI_VAR_FILE_NAME
If the ESP partition is formatted in ext4, we got the following error :
STM32MP> setenv -e -nv -bs -rt -v OsIndications =0x0000000000000004 GUID: 8be4df61-93ca-11d2-aa0d-00e098032b8c (EFI_GLOBAL_VARIABLE_GUID) Attributes: 0x7 Value: 00000000: 04 00 00 00 00 00 00 00 ........ File System is consistent Please supply Absolute path ** Error ext4fs_write() ** ** Unable to write file ubootefi.var ** Failed to persist EFI variables
Signed-off-by: Patrice Chotard patrice.chotard@foss.st.com ---
include/efi_variable.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/efi_variable.h b/include/efi_variable.h index 805e6c5f1e0..8d507460b20 100644 --- a/include/efi_variable.h +++ b/include/efi_variable.h @@ -92,7 +92,7 @@ efi_status_t efi_query_variable_info_int(u32 attributes, u64 *remaining_variable_storage_size, u64 *maximum_variable_size);
-#define EFI_VAR_FILE_NAME "ubootefi.var" +#define EFI_VAR_FILE_NAME "/ubootefi.var"
#define EFI_VAR_BUF_SIZE CONFIG_EFI_VAR_BUF_SIZE
Hi Patrice,
On Wed, 20 Mar 2024 at 12:31, Patrice Chotard patrice.chotard@foss.st.com wrote:
This error message comes from ext4_common.c and it's ext4 specific. Do you have any idea why this exists? What happens to other filesystems? IOW does this change the behavior of the existing code if it tries to write a file in FAT?
Thanks /Ilias
-- 2.25.1
On 20.03.24 12:53, Ilias Apalodimas wrote:
Hi Patrice,
When reading a file with the ext4 driver leading '/' are ignored by removing them in ext4fs_find_file1(). It is really inconsistent that when writing a leading '/' is required.
We can simply remove the check in ext4fs_get_parent_inode_num(). I found no issues when saving to an ext4 file system with the check removed.
I will send a patch.
Best regards
Heinrich
Thanks /Ilias
-- 2.25.1
Hi Patrice,
Ok thanks ;-)
Best regards
Heinrich
Thanks /Ilias
-- 2.25.1
On 3/20/24 12:53, Ilias Apalodimas wrote:
Hi Patrice,
I made a try in FAT with this patch, and there is no issue.
Thanks Patrice
Thanks /Ilias
-- 2.25.1
Ilias Apalodimas
Patrice CHOTARD
Patrice Chotard
