[U-Boot] [PATCH] Clarify applicable licensing terms in COPYING file.
Signed-off-by: Wolfgang Denk wd@denx.de --- COPYING | 9 ++++++++- 1 files changed, 8 insertions(+), 1 deletions(-)
diff --git a/COPYING b/COPYING index f616ab9..9930863 100644 --- a/COPYING +++ b/COPYING @@ -1,4 +1,11 @@ - NOTE! This copyright does *not* cover the so-called "standalone" + U-Boot is free software. It is copyrighted by Wolfgang Denk and +many others who contributed code (see the actual source code for +details). You can redistribute U-Boot and/or modify it under the +terms of the GNU General Public License as published by the Free +Software Foundation; either version 2 of the License (see text +below), or (at your option) any later version. + + NOTE! This license does *not* cover the so-called "standalone" applications that use U-Boot services by means of the jump table provided by U-Boot exactly for this purpose - this is merely considered normal use of U-Boot, and does *not* fall under the
- U-Boot is free software. It is copyrighted by Wolfgang Denk and
But there is code in U-Boot that cannot be distributed under later versions of the GPL...
-Scott
Dear Scott Wood,
Indeed. We need to work on this.
If you propose to use a different wording, please don't hesitate to make suggestions.
Dear Scott Wood,
How about:
U-Boot is free software. It is copyrighted by Wolfgang Denk and many others who contributed code (see the actual source code for details). You can redistribute U-Boot and/or modify it under the terms of version 2 of the GNU General Public License as published by the Free Software Foundation. Most of it can also be distributed, at your option, under any later version of the GNU General Public License -- see individual files for exceptions.
-Scott
Signed-off-by: Wolfgang Denk wd@denx.de --- v2: Rephrase as suggested by Scott Wood in http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/71743/focus=71761
COPYING | 10 +++++++++- 1 files changed, 9 insertions(+), 1 deletions(-)
diff --git a/COPYING b/COPYING index f616ab9..44d1983 100644 --- a/COPYING +++ b/COPYING @@ -1,4 +1,12 @@ - NOTE! This copyright does *not* cover the so-called "standalone" + U-Boot is Free Software. It is copyrighted by Wolfgang Denk and +many others who contributed code (see the actual source code for +details). You can redistribute U-Boot and/or modify it under the +terms of version 2 of the GNU General Public License as published by +the Free Software Foundation. Most of it can also be distributed, +at your option, under any later version of the GNU General Public +License -- see individual files for exceptions. + + NOTE! This license does *not* cover the so-called "standalone" applications that use U-Boot services by means of the jump table provided by U-Boot exactly for this purpose - this is merely considered normal use of U-Boot, and does *not* fall under the
Dear Wolfgang Denk,
Applied.
Scott Wood
