[U-Boot] [PATCH 2/5][v5] arch: powerpc: update the IFC IP input clock
IFC IP clock is always a constant divisor of platform clock pre-defined per SoC. Clock control register (CCR) used in current implementation governs IFC IP output clock.
So update IFC IP clock to be defined as per predefined clock divisor of platform clock.
Signed-off-by: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com --- Changes for v2: Split the patch in 2 patch set Changes for v3: Rebased on top of u-boot commit Changes for v4: fix compilation error Changes for v5: Adding FSL_IFC as dependency
README | 3 +++ arch/powerpc/cpu/mpc85xx/Kconfig | 16 ++++++++++++++++ arch/powerpc/cpu/mpc85xx/speed.c | 10 ++-------- 3 files changed, 21 insertions(+), 8 deletions(-)
diff --git a/README b/README index a95348a..9fda381 100644 --- a/README +++ b/README @@ -504,6 +504,9 @@ The following options need to be configured: CONFIG_SYS_FSL_IFC_LE Defines the IFC controller register space as Little Endian
+ CONFIG_SYS_FSL_IFC_CLK_DIV + Defines divider of platform clock(clock input to IFC controller). + CONFIG_SYS_FSL_PBL_PBI It enables addition of RCW (Power on reset configuration) in built image. Please refer doc/README.pblimage for more details diff --git a/arch/powerpc/cpu/mpc85xx/Kconfig b/arch/powerpc/cpu/mpc85xx/Kconfig index c67b6b0..8c6503d 100644 --- a/arch/powerpc/cpu/mpc85xx/Kconfig +++ b/arch/powerpc/cpu/mpc85xx/Kconfig @@ -1265,6 +1265,22 @@ config SYS_PPC_E500_DEBUG_TLB symbol should be set to the TLB1 entry to be used for this purpose. If unsure, do not change.
+config SYS_FSL_IFC_CLK_DIV + int "Divider of platform clock" + depends on FSL_IFC + default 2 if ARCH_B4420 || \ + ARCH_B4860 || \ + ARCH_T1024 || \ + ARCH_T1023 || \ + ARCH_T1040 || \ + ARCH_T1042 || \ + ARCH_T4160 || \ + ARCH_T4240 + default 1 + help + Defines divider of platform clock(clock input to + IFC controller). + source "board/freescale/b4860qds/Kconfig" source "board/freescale/bsc9131rdb/Kconfig" source "board/freescale/bsc9132qds/Kconfig" diff --git a/arch/powerpc/cpu/mpc85xx/speed.c b/arch/powerpc/cpu/mpc85xx/speed.c index fcf5d92..adba092 100644 --- a/arch/powerpc/cpu/mpc85xx/speed.c +++ b/arch/powerpc/cpu/mpc85xx/speed.c @@ -27,10 +27,6 @@ DECLARE_GLOBAL_DATA_PTR; void get_sys_info(sys_info_t *sys_info) { volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); -#ifdef CONFIG_FSL_IFC - struct fsl_ifc ifc_regs = {(void *)CONFIG_SYS_IFC_ADDR, (void *)NULL}; - u32 ccr; -#endif #ifdef CONFIG_FSL_CORENET volatile ccsr_clk_t *clk = (void *)(CONFIG_SYS_FSL_CORENET_CLK_ADDR); unsigned int cpu; @@ -640,10 +636,8 @@ void get_sys_info(sys_info_t *sys_info) #endif
#if defined(CONFIG_FSL_IFC) - ccr = ifc_in32(&ifc_regs.gregs->ifc_ccr); - ccr = ((ccr & IFC_CCR_CLK_DIV_MASK) >> IFC_CCR_CLK_DIV_SHIFT) + 1; - - sys_info->freq_localbus = sys_info->freq_systembus / ccr; + sys_info->freq_localbus = sys_info->freq_systembus / + CONFIG_SYS_FSL_IFC_CLK_DIV; #endif }
- CONFIG_SYS_FSL_PBL_PBI It enables addition of RCW (Power on reset configuration) in built image. Please refer doc/README.pblimage for more details
- int "Divider of platform clock"
- depends on FSL_IFC
- default 2 if ARCH_B4420 || \
ARCH_B4860 || \
ARCH_T1024 || \
ARCH_T1023 || \
ARCH_T1040 || \
ARCH_T1042 || \
ARCH_T4160 || \
ARCH_T4240
- default 1
- help
IFC controller).
- u32 ccr;
#endif }
After this change, sys_info->freq_localbus holds the input clock of local bus, instead of output clock previously. It should be noted in the commit message. Same comment goes to patch 3/5.
York
Prabhakar Kushwaha
york sun
