[U-Boot-Users] u-boot-1.1.1 ml300 compile problem
----- Forwarded message (env-from root) -----
From root Sun Aug 29 16:10:11 2004
Subject: u-boot-1.1.1 ml300 compile problem To: u-boot-users@lists-sourceforge.net Date: Sun, 29 Aug 2004 16:10:11 +0200 (CEST) X-Mailer: ELM [version 2.4ME+ PL60 (25)]
HI !
The mails in the archive on ml300 I found say to "compile u-boot first" or state that it compiles successfully, the problem I have is that this step fails.
Platform: Debian Xilinx: EDK 6.2
Procedure: copied boot.o crt0.o and libc.a to examples export CROSS_COMPILE=powerpc-eabi- make ml300_config make
IT failes with an undefined reference to main As I just ran this on the unmodified download version of u-boot to check the procedure before making any modifications for my board, I asume I'm doing somthing wrong in the procedure/setup - any hint to what I'm doing wrong or what the proper procedure would be ?
make[1]: Entering directory `/root/u-boot-1.1.1/tools' make[1]: `.depend' is up to date. make[1]: Leaving directory `/root/u-boot-1.1.1/tools' make[1]: Entering directory `/root/u-boot-1.1.1/examples' make[1]: `.depend' is up to date. make[1]: Leaving directory `/root/u-boot-1.1.1/examples' make[1]: Entering directory `/root/u-boot-1.1.1/post' make[1]: `.depend' is up to date. make[1]: Leaving directory `/root/u-boot-1.1.1/post' make[1]: Entering directory `/root/u-boot-1.1.1/post/cpu' make[1]: `.depend' is up to date. make[1]: Leaving directory `/root/u-boot-1.1.1/post/cpu' make -C tools all make[1]: Entering directory `/root/u-boot-1.1.1/tools' make[1]: Leaving directory `/root/u-boot-1.1.1/tools' make -C examples all make[1]: Entering directory `/root/u-boot-1.1.1/examples' powerpc-eabi-ld -g -Ttext 0x40000 \ -o hello_world -e hello_world hello_world.o libstubs.a \ -L/root/EDK/gnu/powerpc-eabi/lin/bin/../lib/gcc-lib/powerpc-eabi/2.95.3-4 -lgcc powerpc-eabi-objcopy -O srec hello_world hello_world.srec 2>/dev/null powerpc-eabi-gcc -g -Os -fPIC -ffixed-r14 -meabi -D__KERNEL__ -DTEXT_BASE=0x04000000 -I/root/u-boot-1.1.1/include -fno-builtin -ffreestanding -nostdinc -isystem /root/EDK/gnu/powerpc-eabi/lin/bin/../lib/gcc-lib/powerpc-eabi/2.95.3-4/include -pipe -DCONFIG_PPC -D__powerpc__ -DCONFIG_4xx -ffixed-r2 -ffixed-r29 -mstring -Wa,-m405 -mcpu=405 -msoft-float -Wall -Wstrict-prototypes -c -o sched.o sched.c powerpc-eabi-ld -g -Ttext 0x40000 \ -o sched -e sched sched.o libstubs.a \ -L/root/EDK/gnu/powerpc-eabi/lin/bin/../lib/gcc-lib/powerpc-eabi/2.95.3-4 -lgcc libxil.a(crt0.o): In function `_start': crt0.o(.text+0x78): undefined reference to `main' make[1]: *** [sched] Error 1 make[1]: Leaving directory `/root/u-boot-1.1.1/examples' make: *** [examples] Error 2
thx ! hofrat
Did you try the current version (top of tree in CVS) ?
Don't do that!
This is because you added files which don't belong to U-Boot.
Don't do that!
ok - then its something else - I actually added these files because of the errors I got with the stock 1.1.1 - which failed with ld not finding boot.o
below is the output from make with the relevant error.
make[1]: Entering directory `/root/u-boot-1.1.1/tools' make[1]: `.depend' is up to date. make[1]: Leaving directory `/root/u-boot-1.1.1/tools' make[1]: Entering directory `/root/u-boot-1.1.1/examples' make[1]: `.depend' is up to date. make[1]: Leaving directory `/root/u-boot-1.1.1/examples' make[1]: Entering directory `/root/u-boot-1.1.1/post' make[1]: `.depend' is up to date. make[1]: Leaving directory `/root/u-boot-1.1.1/post' make[1]: Entering directory `/root/u-boot-1.1.1/post/cpu' make[1]: `.depend' is up to date. make[1]: Leaving directory `/root/u-boot-1.1.1/post/cpu' make -C tools all make[1]: Entering directory `/root/u-boot-1.1.1/tools' make[1]: Leaving directory `/root/u-boot-1.1.1/tools' make -C examples all make[1]: Entering directory `/root/u-boot-1.1.1/examples' powerpc-eabi-ld -g -Ttext 0x40000 \ -o hello_world -e hello_world hello_world.o libstubs.a \ -L/root/EDK/gnu/powerpc-eabi/lin/bin/../lib/gcc-lib/powerpc-eabi/2.95.3-4 -lgcc powerpc-eabi-ld: cannot find boot.o make[1]: *** [hello_world] Error 1 make[1]: Leaving directory `/root/u-boot-1.1.1/examples' make: *** [examples] Error 2
thx ! hofrat
Check your toolchain.
There is no such object (or source) in U-Boot. I guess it comes though your compiler's library files. Use an approved toolchain instead.
Der Herr Hofrat
