[U-Boot] [PATCH v2 01/22] arm64: dts: uniphier: add reserved-memory for secure memory
[ Linux commit aa38571246c6ac279ebebd141157297bcb959d76 ]
The memory regions specified by /memreserve/ are passed to early_init_dt_reserve_memory_arch() with nomap=false, so it is not suitable for reserving memory for Trusted Firmware-A etc.
Use the more robust /reserved-memory node with the no-map property to prevent the kernel from mapping it.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/dts/uniphier-ld11.dtsi | 13 +++++++++++-- arch/arm/dts/uniphier-ld20.dtsi | 13 +++++++++++-- arch/arm/dts/uniphier-pxs3.dtsi | 13 +++++++++++-- 3 files changed, 33 insertions(+), 6 deletions(-)
diff --git a/arch/arm/dts/uniphier-ld11.dtsi b/arch/arm/dts/uniphier-ld11.dtsi index a3cd475b48d2..337a3537ed28 100644 --- a/arch/arm/dts/uniphier-ld11.dtsi +++ b/arch/arm/dts/uniphier-ld11.dtsi @@ -8,8 +8,6 @@ #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/gpio/uniphier-gpio.h>
-/memreserve/ 0x80000000 0x02000000; - / { compatible = "socionext,uniphier-ld11"; #address-cells = <2>; @@ -110,6 +108,17 @@ <1 10 4>; };
+ reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + secure-memory@81000000 { + reg = <0x0 0x81000000 0x0 0x01000000>; + no-map; + }; + }; + soc@0 { compatible = "simple-bus"; #address-cells = <1>; diff --git a/arch/arm/dts/uniphier-ld20.dtsi b/arch/arm/dts/uniphier-ld20.dtsi index baf23268366f..3721110b17a7 100644 --- a/arch/arm/dts/uniphier-ld20.dtsi +++ b/arch/arm/dts/uniphier-ld20.dtsi @@ -9,8 +9,6 @@ #include <dt-bindings/gpio/uniphier-gpio.h> #include <dt-bindings/thermal/thermal.h>
-/memreserve/ 0x80000000 0x02000000; - / { compatible = "socionext,uniphier-ld20"; #address-cells = <2>; @@ -215,6 +213,17 @@ }; };
+ reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + secure-memory@81000000 { + reg = <0x0 0x81000000 0x0 0x01000000>; + no-map; + }; + }; + soc@0 { compatible = "simple-bus"; #address-cells = <1>; diff --git a/arch/arm/dts/uniphier-pxs3.dtsi b/arch/arm/dts/uniphier-pxs3.dtsi index 961d4d3621f4..b1aff285c8b7 100644 --- a/arch/arm/dts/uniphier-pxs3.dtsi +++ b/arch/arm/dts/uniphier-pxs3.dtsi @@ -8,8 +8,6 @@ #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/gpio/uniphier-gpio.h>
-/memreserve/ 0x80000000 0x02000000; - / { compatible = "socionext,uniphier-pxs3"; #address-cells = <2>; @@ -138,6 +136,17 @@ <1 10 4>; };
This is a remnant of commit f89d6133eef2 ("configs: move CONFIG_SPL_TEXT_BASE to Kconfig").
include/configs/uniphier.h | 4 ---- 1 file changed, 4 deletions(-)
diff --git a/include/configs/uniphier.h b/include/configs/uniphier.h index 5b42e0c1dee5..6979165260c6 100644 --- a/include/configs/uniphier.h +++ b/include/configs/uniphier.h @@ -220,10 +220,6 @@ #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_TEXT_BASE)
/* only for SPL */ -#if defined(CONFIG_ARCH_UNIPHIER_LD4) || \ - defined(CONFIG_ARCH_UNIPHIER_SLD8) -#endif - #define CONFIG_SPL_STACK (0x00200000)
#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x20000
The .boot_device_fixup() is only called by SPL.
Now that 64-bit SoCs of this SoC family no longer support SPL, debug-uart-ld20.c is never compiled.
arch/arm/mach-uniphier/boot-device/boot-device-ld11.c | 8 -------- arch/arm/mach-uniphier/boot-device/boot-device.c | 2 -- arch/arm/mach-uniphier/boot-device/boot-device.h | 1 - 3 files changed, 11 deletions(-)
diff --git a/arch/arm/mach-uniphier/boot-device/boot-device-ld11.c b/arch/arm/mach-uniphier/boot-device/boot-device-ld11.c index 10093be0e43a..11e70a926fc8 100644 --- a/arch/arm/mach-uniphier/boot-device/boot-device-ld11.c +++ b/arch/arm/mach-uniphier/boot-device/boot-device-ld11.c @@ -58,11 +58,3 @@ int uniphier_ld20_boot_device_is_usb(u32 pinmon) { return !!(~pinmon & 0x00000780); } - -unsigned int uniphier_ld11_boot_device_fixup(unsigned int mode) -{ - if (mode == BOOT_DEVICE_MMC1 || mode == BOOT_DEVICE_USB) - mode = BOOT_DEVICE_BOARD; - - return mode; -} diff --git a/arch/arm/mach-uniphier/boot-device/boot-device.c b/arch/arm/mach-uniphier/boot-device/boot-device.c index 23be8cfcf00d..3c7643302d9e 100644 --- a/arch/arm/mach-uniphier/boot-device/boot-device.c +++ b/arch/arm/mach-uniphier/boot-device/boot-device.c @@ -91,7 +91,6 @@ static const struct uniphier_boot_device_info uniphier_boot_device_info[] = { .boot_device_table = uniphier_ld11_boot_device_table, .boot_device_count = &uniphier_ld11_boot_device_count, .boot_device_is_usb = uniphier_ld11_boot_device_is_usb, - .boot_device_fixup = uniphier_ld11_boot_device_fixup, .have_internal_stm = 1, }, #endif @@ -102,7 +101,6 @@ static const struct uniphier_boot_device_info uniphier_boot_device_info[] = { .boot_device_table = uniphier_ld11_boot_device_table, .boot_device_count = &uniphier_ld11_boot_device_count, .boot_device_is_usb = uniphier_ld20_boot_device_is_usb, - .boot_device_fixup = uniphier_ld11_boot_device_fixup, .have_internal_stm = 1, }, #endif diff --git a/arch/arm/mach-uniphier/boot-device/boot-device.h b/arch/arm/mach-uniphier/boot-device/boot-device.h index 44579f17d3e4..bbb634316b3a 100644 --- a/arch/arm/mach-uniphier/boot-device/boot-device.h +++ b/arch/arm/mach-uniphier/boot-device/boot-device.h @@ -30,6 +30,5 @@ int uniphier_ld20_boot_device_is_usb(u32 pinmon); int uniphier_pxs3_boot_device_is_usb(u32 pinmon);
unsigned int uniphier_pxs2_boot_device_fixup(unsigned int mode); -unsigned int uniphier_ld11_boot_device_fixup(unsigned int mode);
#endif /* _UNIPHIER_BOOT_DEVICE_H_ */
Now that 64-bit SoCs of this SoC family no longer support SPL, this Makefile can be slightly simpler.
arch/arm/mach-uniphier/clk/Makefile | 10 +++------- 1 file changed, 3 insertions(+), 7 deletions(-)
diff --git a/arch/arm/mach-uniphier/clk/Makefile b/arch/arm/mach-uniphier/clk/Makefile index 3d741b4c4d1b..d12f49e5230d 100644 --- a/arch/arm/mach-uniphier/clk/Makefile +++ b/arch/arm/mach-uniphier/clk/Makefile @@ -17,12 +17,8 @@ obj-$(CONFIG_ARCH_UNIPHIER_SLD8) += clk-ld4.o pll-ld4.o dpll-tail.o obj-$(CONFIG_ARCH_UNIPHIER_PRO5) += clk-pro5.o obj-$(CONFIG_ARCH_UNIPHIER_PXS2) += clk-pxs2.o obj-$(CONFIG_ARCH_UNIPHIER_LD6B) += clk-pxs2.o -obj-$(CONFIG_ARCH_UNIPHIER_LD11) += clk-ld11.o pll-ld11.o -obj-$(CONFIG_ARCH_UNIPHIER_LD20) += clk-ld20.o pll-ld20.o -obj-$(CONFIG_ARCH_UNIPHIER_PXS3) += clk-pxs3.o pll-pxs3.o +obj-$(CONFIG_ARCH_UNIPHIER_LD11) += clk-ld11.o pll-base-ld20.o pll-ld11.o +obj-$(CONFIG_ARCH_UNIPHIER_LD20) += clk-ld20.o pll-base-ld20.o pll-ld20.o +obj-$(CONFIG_ARCH_UNIPHIER_PXS3) += clk-pxs3.o pll-base-ld20.o pll-pxs3.o
endif - -obj-$(CONFIG_ARCH_UNIPHIER_LD11) += pll-base-ld20.o -obj-$(CONFIG_ARCH_UNIPHIER_LD20) += pll-base-ld20.o -obj-$(CONFIG_ARCH_UNIPHIER_PXS3) += pll-base-ld20.o
This is boolean logic.
.../mach-uniphier/boot-device/boot-device.c | 20 +++++++++---------- 1 file changed, 10 insertions(+), 10 deletions(-)
diff --git a/arch/arm/mach-uniphier/boot-device/boot-device.c b/arch/arm/mach-uniphier/boot-device/boot-device.c index 3c7643302d9e..c8339dbe1ba8 100644 --- a/arch/arm/mach-uniphier/boot-device/boot-device.c +++ b/arch/arm/mach-uniphier/boot-device/boot-device.c @@ -22,7 +22,7 @@ struct uniphier_boot_device_info { const unsigned int *boot_device_count; int (*boot_device_is_usb)(u32 pinmon); unsigned int (*boot_device_fixup)(unsigned int mode); - int have_internal_stm; + bool have_internal_stm; };
static const struct uniphier_boot_device_info uniphier_boot_device_info[] = { @@ -32,7 +32,7 @@ static const struct uniphier_boot_device_info uniphier_boot_device_info[] = { .boot_device_sel_shift = 1, .boot_device_table = uniphier_ld4_boot_device_table, .boot_device_count = &uniphier_ld4_boot_device_count, - .have_internal_stm = 1, + .have_internal_stm = true, }, #endif #if defined(CONFIG_ARCH_UNIPHIER_PRO4) @@ -41,7 +41,7 @@ static const struct uniphier_boot_device_info uniphier_boot_device_info[] = { .boot_device_sel_shift = 1, .boot_device_table = uniphier_ld4_boot_device_table, .boot_device_count = &uniphier_ld4_boot_device_count, - .have_internal_stm = 0, + .have_internal_stm = false, }, #endif #if defined(CONFIG_ARCH_UNIPHIER_SLD8) @@ -50,7 +50,7 @@ static const struct uniphier_boot_device_info uniphier_boot_device_info[] = { .boot_device_sel_shift = 1, .boot_device_table = uniphier_ld4_boot_device_table, .boot_device_count = &uniphier_ld4_boot_device_count, - .have_internal_stm = 1, + .have_internal_stm = true, }, #endif #if defined(CONFIG_ARCH_UNIPHIER_PRO5) @@ -59,7 +59,7 @@ static const struct uniphier_boot_device_info uniphier_boot_device_info[] = { .boot_device_sel_shift = 1, .boot_device_table = uniphier_pro5_boot_device_table, .boot_device_count = &uniphier_pro5_boot_device_count, - .have_internal_stm = 0, + .have_internal_stm = false, }, #endif #if defined(CONFIG_ARCH_UNIPHIER_PXS2) @@ -70,7 +70,7 @@ static const struct uniphier_boot_device_info uniphier_boot_device_info[] = { .boot_device_count = &uniphier_pxs2_boot_device_count, .boot_device_is_usb = uniphier_pxs2_boot_device_is_usb, .boot_device_fixup = uniphier_pxs2_boot_device_fixup, - .have_internal_stm = 0, + .have_internal_stm = false, }, #endif #if defined(CONFIG_ARCH_UNIPHIER_LD6B) @@ -81,7 +81,7 @@ static const struct uniphier_boot_device_info uniphier_boot_device_info[] = { .boot_device_count = &uniphier_pxs2_boot_device_count, .boot_device_is_usb = uniphier_pxs2_boot_device_is_usb, .boot_device_fixup = uniphier_pxs2_boot_device_fixup, - .have_internal_stm = 1, /* STM on A-chip */ + .have_internal_stm = true, /* STM on A-chip */ }, #endif #if defined(CONFIG_ARCH_UNIPHIER_LD11) @@ -91,7 +91,7 @@ static const struct uniphier_boot_device_info uniphier_boot_device_info[] = { .boot_device_table = uniphier_ld11_boot_device_table, .boot_device_count = &uniphier_ld11_boot_device_count, .boot_device_is_usb = uniphier_ld11_boot_device_is_usb, - .have_internal_stm = 1, + .have_internal_stm = true, }, #endif #if defined(CONFIG_ARCH_UNIPHIER_LD20) @@ -101,7 +101,7 @@ static const struct uniphier_boot_device_info uniphier_boot_device_info[] = { .boot_device_table = uniphier_ld11_boot_device_table, .boot_device_count = &uniphier_ld11_boot_device_count, .boot_device_is_usb = uniphier_ld20_boot_device_is_usb, - .have_internal_stm = 1, + .have_internal_stm = true, }, #endif #if defined(CONFIG_ARCH_UNIPHIER_PXS3) @@ -111,7 +111,7 @@ static const struct uniphier_boot_device_info uniphier_boot_device_info[] = { .boot_device_table = uniphier_pxs3_boot_device_table, .boot_device_count = &uniphier_pxs3_boot_device_count, .boot_device_is_usb = uniphier_pxs3_boot_device_is_usb, - .have_internal_stm = 0, + .have_internal_stm = false, }, #endif };
This file calls readl(), so needs to include <linux/io.h>. Currently, it relies on someone else including it.
arch/arm/mach-uniphier/boot-device/boot-device.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/mach-uniphier/boot-device/boot-device.c b/arch/arm/mach-uniphier/boot-device/boot-device.c index c8339dbe1ba8..59302150b89c 100644 --- a/arch/arm/mach-uniphier/boot-device/boot-device.c +++ b/arch/arm/mach-uniphier/boot-device/boot-device.c @@ -7,6 +7,7 @@ #include <common.h> #include <spl.h> #include <stdio.h> +#include <linux/io.h> #include <linux/log2.h>
#include "../init.h"
I also added comments for NAND clocks.
drivers/clk/uniphier/clk-uniphier-sys.c | 14 ++++++++------ 1 file changed, 8 insertions(+), 6 deletions(-)
diff --git a/drivers/clk/uniphier/clk-uniphier-sys.c b/drivers/clk/uniphier/clk-uniphier-sys.c index 487b43ebdab6..c627a4bf851a 100644 --- a/drivers/clk/uniphier/clk-uniphier-sys.c +++ b/drivers/clk/uniphier/clk-uniphier-sys.c @@ -18,8 +18,8 @@ const struct uniphier_clk_data uniphier_pxs2_sys_clk_data[] = { #if defined(CONFIG_ARCH_UNIPHIER_LD4) || defined(CONFIG_ARCH_UNIPHIER_SLD8) ||\ defined(CONFIG_ARCH_UNIPHIER_PRO4) || defined(CONFIG_ARCH_UNIPHIER_PRO5) ||\ defined(CONFIG_ARCH_UNIPHIER_PXS2) || defined(CONFIG_ARCH_UNIPHIER_LD6B) - UNIPHIER_LD4_SYS_CLK_NAND(2), - UNIPHIER_CLK_RATE(3, 200000000), + UNIPHIER_LD4_SYS_CLK_NAND(2), /* nand */ + UNIPHIER_CLK_RATE(3, 200000000), /* nand-4x */ UNIPHIER_CLK_GATE_SIMPLE(6, 0x2104, 12), /* ether (Pro4, PXs2) */ UNIPHIER_CLK_GATE_SIMPLE(7, 0x2104, 5), /* ether-gb (Pro4) */ UNIPHIER_CLK_GATE_SIMPLE(8, 0x2104, 10), /* stdmac */ @@ -35,8 +35,9 @@ const struct uniphier_clk_data uniphier_pxs2_sys_clk_data[] = {
const struct uniphier_clk_data uniphier_ld20_sys_clk_data[] = { #if defined(CONFIG_ARCH_UNIPHIER_LD11) || defined(CONFIG_ARCH_UNIPHIER_LD20) - UNIPHIER_LD11_SYS_CLK_NAND(2), - UNIPHIER_CLK_RATE(3, 200000000), + UNIPHIER_LD11_SYS_CLK_NAND(2), /* nand */ + UNIPHIER_CLK_RATE(3, 200000000), /* nand-4x */ + UNIPHIER_CLK_GATE_SIMPLE(4, 0x210c, 2), /* emmc */ UNIPHIER_CLK_GATE_SIMPLE(6, 0x210c, 6), /* ether */ UNIPHIER_CLK_GATE_SIMPLE(8, 0x210c, 8), /* stdmac */ UNIPHIER_CLK_GATE_SIMPLE(14, 0x210c, 14), /* usb30 (LD20) */ @@ -48,8 +49,9 @@ const struct uniphier_clk_data uniphier_ld20_sys_clk_data[] = {
const struct uniphier_clk_data uniphier_pxs3_sys_clk_data[] = { #if defined(CONFIG_ARCH_UNIPHIER_PXS3) - UNIPHIER_LD11_SYS_CLK_NAND(2), - UNIPHIER_CLK_RATE(3, 200000000), + UNIPHIER_LD11_SYS_CLK_NAND(2), /* nand */ + UNIPHIER_CLK_RATE(3, 200000000), /* nand-4x */ + UNIPHIER_CLK_GATE_SIMPLE(4, 0x210c, 2), /* emmc */ UNIPHIER_CLK_GATE_SIMPLE(6, 0x210c, 9), /* ether0 */ UNIPHIER_CLK_GATE_SIMPLE(7, 0x210c, 10), /* ether1 */ UNIPHIER_CLK_GATE_SIMPLE(12, 0x210c, 4), /* usb30 (gio0) */
If CONFIG_MICRO_SUPPORT_CARD is enabled, U-Boot tries to get access to the devices on the support card, which may not actually exist.
Check the DT and search for the on-board devices run-time. If the nodes are not found in DT, then disable the code.
arch/arm/mach-uniphier/micro-support-card.c | 33 +++++++++++++++++++++ 1 file changed, 33 insertions(+)
diff --git a/arch/arm/mach-uniphier/micro-support-card.c b/arch/arm/mach-uniphier/micro-support-card.c index 1be5685c6fbf..46879019fdaa 100644 --- a/arch/arm/mach-uniphier/micro-support-card.c +++ b/arch/arm/mach-uniphier/micro-support-card.c @@ -18,6 +18,25 @@ #define MICRO_SUPPORT_CARD_RESET ((MICRO_SUPPORT_CARD_BASE) + 0xd0034) #define MICRO_SUPPORT_CARD_REVISION ((MICRO_SUPPORT_CARD_BASE) + 0xd00E0)
+static bool support_card_found; + +static void support_card_detect(void) +{ + DECLARE_GLOBAL_DATA_PTR; + const void *fdt = gd->fdt_blob; + int offset; + + offset = fdt_node_offset_by_compatible(fdt, 0, "smsc,lan9118"); + if (offset < 0) + return; + + offset = fdt_node_offset_by_compatible(fdt, 0, "ns16550a"); + if (offset < 0) + return; + + support_card_found = true; +} + /* * 0: reset deassert, 1: reset * @@ -51,6 +70,11 @@ static int support_card_show_revision(void)
void support_card_init(void) { + support_card_detect(); + + if (!support_card_found) + return; + support_card_reset(); /* * After power on, we need to keep the LAN controller in reset state @@ -67,6 +91,9 @@ void support_card_init(void)
int board_eth_init(bd_t *bis) { + if (!support_card_found) + return 0; + return smc911x_initialize(0, SMC911X_BASE); } #endif @@ -161,6 +188,9 @@ static void detect_num_flash_banks(void)
void support_card_late_init(void) { + if (!support_card_found) + return; + detect_num_flash_banks(); }
@@ -221,6 +251,9 @@ void led_puts(const char *s) int i; u32 val = 0;
+ if (!support_card_found) + return; + if (!s) return;
If CONFIG_MICRO_SUPPORT_CARD is enabled, U-Boot initialize SBC (System Bus Controller), which may not be really necessary.
Check the "socionext,uniphier-system-bus" node in DT run-time. If and only if it is found and its "status" property is okay, initialize the SBC block.
arch/arm/mach-uniphier/Makefile | 3 ++- arch/arm/mach-uniphier/sbc/Makefile | 4 ++++ arch/arm/mach-uniphier/sbc/sbc-ld11.c | 3 +++ arch/arm/mach-uniphier/sbc/sbc-ld4.c | 3 +++ arch/arm/mach-uniphier/sbc/sbc-pxs2.c | 3 +++ arch/arm/mach-uniphier/sbc/sbc-regs.h | 2 ++ arch/arm/mach-uniphier/sbc/sbc.c | 16 ++++++++++++++++ 7 files changed, 33 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-uniphier/Makefile b/arch/arm/mach-uniphier/Makefile index d0c39d427379..caa79d1e53e6 100644 --- a/arch/arm/mach-uniphier/Makefile +++ b/arch/arm/mach-uniphier/Makefile @@ -18,13 +18,14 @@ ifndef CONFIG_SYSRESET obj-y += reset.o endif
-obj-$(CONFIG_MICRO_SUPPORT_CARD) += sbc/ micro-support-card.o +obj-$(CONFIG_MICRO_SUPPORT_CARD) += micro-support-card.o obj-y += pinctrl-glue.o obj-$(CONFIG_MMC) += mmc-first-dev.o obj-y += fdt-fixup.o
endif
+obj-y += sbc/ obj-y += soc-info.o obj-y += boot-device/ obj-y += clk/ diff --git a/arch/arm/mach-uniphier/sbc/Makefile b/arch/arm/mach-uniphier/sbc/Makefile index 912e05a725d6..4efdd419f046 100644 --- a/arch/arm/mach-uniphier/sbc/Makefile +++ b/arch/arm/mach-uniphier/sbc/Makefile @@ -1,5 +1,8 @@ # SPDX-License-Identifier: GPL-2.0+
+obj- += dummy.o + +ifndef CONFIG_SPL_BUILD obj-y += sbc.o
obj-$(CONFIG_ARCH_UNIPHIER_LD4) += sbc-ld4.o @@ -9,3 +12,4 @@ obj-$(CONFIG_ARCH_UNIPHIER_LD6B) += sbc-pxs2.o obj-$(CONFIG_ARCH_UNIPHIER_LD11) += sbc-ld11.o obj-$(CONFIG_ARCH_UNIPHIER_LD20) += sbc-ld11.o obj-$(CONFIG_ARCH_UNIPHIER_PXS3) += sbc-pxs2.o +endif diff --git a/arch/arm/mach-uniphier/sbc/sbc-ld11.c b/arch/arm/mach-uniphier/sbc/sbc-ld11.c index 44d8a1e3bd94..21972ac9494b 100644 --- a/arch/arm/mach-uniphier/sbc/sbc-ld11.c +++ b/arch/arm/mach-uniphier/sbc/sbc-ld11.c @@ -12,6 +12,9 @@
void uniphier_ld11_sbc_init(void) { + if (!uniphier_sbc_is_enabled()) + return; + uniphier_sbc_init_savepin();
/* necessary for ROM boot ?? */ diff --git a/arch/arm/mach-uniphier/sbc/sbc-ld4.c b/arch/arm/mach-uniphier/sbc/sbc-ld4.c index d08b571e23c1..72e9743c8f8a 100644 --- a/arch/arm/mach-uniphier/sbc/sbc-ld4.c +++ b/arch/arm/mach-uniphier/sbc/sbc-ld4.c @@ -13,6 +13,9 @@ void uniphier_ld4_sbc_init(void) { u32 tmp;
/* system bus output enable */ diff --git a/arch/arm/mach-uniphier/sbc/sbc-pxs2.c b/arch/arm/mach-uniphier/sbc/sbc-pxs2.c index 8c167ef0698b..3275f22ce96c 100644 --- a/arch/arm/mach-uniphier/sbc/sbc-pxs2.c +++ b/arch/arm/mach-uniphier/sbc/sbc-pxs2.c @@ -10,6 +10,9 @@
void uniphier_pxs2_sbc_init(void) { + if (!uniphier_sbc_is_enabled()) + return; + uniphier_sbc_init_savepin();
/* necessary for ROM boot ?? */ diff --git a/arch/arm/mach-uniphier/sbc/sbc-regs.h b/arch/arm/mach-uniphier/sbc/sbc-regs.h index 853015acbcab..e866816472b5 100644 --- a/arch/arm/mach-uniphier/sbc/sbc-regs.h +++ b/arch/arm/mach-uniphier/sbc/sbc-regs.h @@ -84,4 +84,6 @@ static inline int boot_is_swapped(void) } #endif
+int uniphier_sbc_is_enabled(void); + #endif /* ARCH_SBC_REGS_H */ diff --git a/arch/arm/mach-uniphier/sbc/sbc.c b/arch/arm/mach-uniphier/sbc/sbc.c index df01e5c01d51..6cf8cf2af80f 100644 --- a/arch/arm/mach-uniphier/sbc/sbc.c +++ b/arch/arm/mach-uniphier/sbc/sbc.c @@ -5,7 +5,9 @@ * Author: Masahiro Yamada yamada.masahiro@socionext.com */
+#include <common.h> #include <linux/io.h> +#include <asm/global_data.h>
#include "../init.h" #include "sbc-regs.h" @@ -31,6 +33,20 @@ #define SBCTRL2_SAVEPIN_MEM_VALUE 0x34000009 #define SBCTRL4_SAVEPIN_MEM_VALUE 0x02110210
+int uniphier_sbc_is_enabled(void) +{ + DECLARE_GLOBAL_DATA_PTR; + const void *fdt = gd->fdt_blob; + int offset; + + offset = fdt_node_offset_by_compatible(fdt, 0, + "socionext,uniphier-system-bus"); + if (offset < 0) + return 0; + + return fdtdec_get_is_enabled(fdt, offset); +} + static void __uniphier_sbc_init(int savepin) { /*
The planned new SoC does not have SBC (System Bus Controller) block. Make boot_is_swapped() an optional hook.
arch/arm/mach-uniphier/boot-device/boot-device.c | 16 ++++++++++++++-- arch/arm/mach-uniphier/sbc/Makefile | 2 +- arch/arm/mach-uniphier/sbc/sbc-boot.c | 13 +++++++++++++ arch/arm/mach-uniphier/sbc/sbc-regs.h | 9 +-------- arch/arm/mach-uniphier/sbc/sbc.c | 2 +- 5 files changed, 30 insertions(+), 12 deletions(-) create mode 100644 arch/arm/mach-uniphier/sbc/sbc-boot.c
diff --git a/arch/arm/mach-uniphier/boot-device/boot-device.c b/arch/arm/mach-uniphier/boot-device/boot-device.c index 59302150b89c..3c2e7b660f3e 100644 --- a/arch/arm/mach-uniphier/boot-device/boot-device.c +++ b/arch/arm/mach-uniphier/boot-device/boot-device.c @@ -23,6 +23,7 @@ struct uniphier_boot_device_info { const unsigned int *boot_device_count; int (*boot_device_is_usb)(u32 pinmon); unsigned int (*boot_device_fixup)(unsigned int mode); + int (*boot_is_swapped)(void); bool have_internal_stm; };
@@ -33,6 +34,7 @@ static const struct uniphier_boot_device_info uniphier_boot_device_info[] = { .boot_device_sel_shift = 1, .boot_device_table = uniphier_ld4_boot_device_table, .boot_device_count = &uniphier_ld4_boot_device_count, + .boot_is_swapped = uniphier_sbc_boot_is_swapped, .have_internal_stm = true, }, #endif @@ -42,6 +44,7 @@ static const struct uniphier_boot_device_info uniphier_boot_device_info[] = { .boot_device_sel_shift = 1, .boot_device_table = uniphier_ld4_boot_device_table, .boot_device_count = &uniphier_ld4_boot_device_count, + .boot_is_swapped = uniphier_sbc_boot_is_swapped, .have_internal_stm = false, }, #endif @@ -51,6 +54,7 @@ static const struct uniphier_boot_device_info uniphier_boot_device_info[] = { .boot_device_sel_shift = 1, .boot_device_table = uniphier_ld4_boot_device_table, .boot_device_count = &uniphier_ld4_boot_device_count, + .boot_is_swapped = uniphier_sbc_boot_is_swapped, .have_internal_stm = true, }, #endif @@ -60,6 +64,7 @@ static const struct uniphier_boot_device_info uniphier_boot_device_info[] = { .boot_device_sel_shift = 1, .boot_device_table = uniphier_pro5_boot_device_table, .boot_device_count = &uniphier_pro5_boot_device_count, + .boot_is_swapped = uniphier_sbc_boot_is_swapped, .have_internal_stm = false, }, #endif @@ -71,6 +76,7 @@ static const struct uniphier_boot_device_info uniphier_boot_device_info[] = { .boot_device_count = &uniphier_pxs2_boot_device_count, .boot_device_is_usb = uniphier_pxs2_boot_device_is_usb, .boot_device_fixup = uniphier_pxs2_boot_device_fixup, + .boot_is_swapped = uniphier_sbc_boot_is_swapped, .have_internal_stm = false, }, #endif @@ -82,6 +88,7 @@ static const struct uniphier_boot_device_info uniphier_boot_device_info[] = { .boot_device_count = &uniphier_pxs2_boot_device_count, .boot_device_is_usb = uniphier_pxs2_boot_device_is_usb, .boot_device_fixup = uniphier_pxs2_boot_device_fixup, + .boot_is_swapped = uniphier_sbc_boot_is_swapped, .have_internal_stm = true, /* STM on A-chip */ }, #endif @@ -92,6 +99,7 @@ static const struct uniphier_boot_device_info uniphier_boot_device_info[] = { .boot_device_table = uniphier_ld11_boot_device_table, .boot_device_count = &uniphier_ld11_boot_device_count, .boot_device_is_usb = uniphier_ld11_boot_device_is_usb, + .boot_is_swapped = uniphier_sbc_boot_is_swapped, .have_internal_stm = true, }, #endif @@ -102,6 +110,7 @@ static const struct uniphier_boot_device_info uniphier_boot_device_info[] = { .boot_device_table = uniphier_ld11_boot_device_table, .boot_device_count = &uniphier_ld11_boot_device_count, .boot_device_is_usb = uniphier_ld20_boot_device_is_usb, + .boot_is_swapped = uniphier_sbc_boot_is_swapped, .have_internal_stm = true, }, #endif @@ -112,6 +121,7 @@ static const struct uniphier_boot_device_info uniphier_boot_device_info[] = { .boot_device_table = uniphier_pxs3_boot_device_table, .boot_device_count = &uniphier_pxs3_boot_device_count, .boot_device_is_usb = uniphier_pxs3_boot_device_is_usb, + .boot_is_swapped = uniphier_sbc_boot_is_swapped, .have_internal_stm = false, }, #endif @@ -125,7 +135,7 @@ static unsigned int __uniphier_boot_device_raw( u32 pinmon; unsigned int boot_sel;
- if (boot_is_swapped()) + if (info->boot_is_swapped && info->boot_is_swapped()) return BOOT_DEVICE_NOR;
pinmon = readl(SG_PINMON0); @@ -208,7 +218,9 @@ static int do_pinmon(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) printf("STB Micon: %s\n", uniphier_boot_from_backend() ? "OFF" : "ON");
- printf("Boot Swap: %s\n", boot_is_swapped() ? "ON" : "OFF"); + if (info->boot_is_swapped) + printf("Boot Swap: %s\n", + info->boot_is_swapped() ? "ON" : "OFF");
diff --git a/arch/arm/mach-uniphier/sbc/Makefile b/arch/arm/mach-uniphier/sbc/Makefile index 4efdd419f046..6c698a392257 100644 --- a/arch/arm/mach-uniphier/sbc/Makefile +++ b/arch/arm/mach-uniphier/sbc/Makefile @@ -1,6 +1,6 @@ # SPDX-License-Identifier: GPL-2.0+
-obj- += dummy.o +obj-y += sbc-boot.o
ifndef CONFIG_SPL_BUILD obj-y += sbc.o diff --git a/arch/arm/mach-uniphier/sbc/sbc-boot.c b/arch/arm/mach-uniphier/sbc/sbc-boot.c new file mode 100644 index 000000000000..ec22b453e0fb --- /dev/null +++ b/arch/arm/mach-uniphier/sbc/sbc-boot.c @@ -0,0 +1,13 @@ +// SPDX-License-Identifier: GPL-2.0+ +// +// Copyright (C) 2011-2014 Panasonic Corporation +// Copyright (C) 2015-2019 Socionext Inc. + +#include <linux/io.h> + +#include "sbc-regs.h" + +int uniphier_sbc_boot_is_swapped(void) +{ + return !(readl(SBBASE0) & SBBASE_BANK_ENABLE); +} diff --git a/arch/arm/mach-uniphier/sbc/sbc-regs.h b/arch/arm/mach-uniphier/sbc/sbc-regs.h index e866816472b5..1e9618653f2d 100644 --- a/arch/arm/mach-uniphier/sbc/sbc-regs.h +++ b/arch/arm/mach-uniphier/sbc/sbc-regs.h @@ -76,14 +76,7 @@
#define PC0CTRL 0x598000c0
-#ifndef __ASSEMBLY__ -#include <linux/io.h> -static inline int boot_is_swapped(void) -{ - return !(readl(SBBASE0) & SBBASE_BANK_ENABLE); -} -#endif - +int uniphier_sbc_boot_is_swapped(void); int uniphier_sbc_is_enabled(void);
#endif /* ARCH_SBC_REGS_H */ diff --git a/arch/arm/mach-uniphier/sbc/sbc.c b/arch/arm/mach-uniphier/sbc/sbc.c index 6cf8cf2af80f..af8d6f4f9dc5 100644 --- a/arch/arm/mach-uniphier/sbc/sbc.c +++ b/arch/arm/mach-uniphier/sbc/sbc.c @@ -64,7 +64,7 @@ static void __uniphier_sbc_init(int savepin) writel(SBCTRL2_ADMULTIPLX_MEM_VALUE, SBCTRL12); }
- if (boot_is_swapped()) { + if (uniphier_sbc_boot_is_swapped()) { /* * Boot Swap On: boot from external NOR/SRAM * 0x42000000-0x43ffffff is a mirror of 0x40000000-0x41ffffff.
The planned new SoC supports the SD boot mode. Detect and display it.
arch/arm/mach-uniphier/board_late_init.c | 4 ++++ arch/arm/mach-uniphier/boot-device/boot-device.c | 8 ++++++++ 2 files changed, 12 insertions(+)
diff --git a/arch/arm/mach-uniphier/board_late_init.c b/arch/arm/mach-uniphier/board_late_init.c index 972dbe8ae553..86b128a91f95 100644 --- a/arch/arm/mach-uniphier/board_late_init.c +++ b/arch/arm/mach-uniphier/board_late_init.c @@ -68,6 +68,10 @@ int board_late_init(void) printf("eMMC Boot"); env_set("bootdev", "emmc"); break; + case BOOT_DEVICE_MMC2: + printf("SD Boot"); + env_set("bootdev", "sd"); + break; case BOOT_DEVICE_NAND: printf("NAND Boot"); env_set("bootdev", "nand"); diff --git a/arch/arm/mach-uniphier/boot-device/boot-device.c b/arch/arm/mach-uniphier/boot-device/boot-device.c index 3c2e7b660f3e..c9dfe13ed9c0 100644 --- a/arch/arm/mach-uniphier/boot-device/boot-device.c +++ b/arch/arm/mach-uniphier/boot-device/boot-device.c @@ -21,6 +21,7 @@ struct uniphier_boot_device_info { unsigned int boot_device_sel_shift; const struct uniphier_boot_device *boot_device_table; const unsigned int *boot_device_count; + int (*boot_device_is_sd)(u32 pinmon); int (*boot_device_is_usb)(u32 pinmon); unsigned int (*boot_device_fixup)(unsigned int mode); int (*boot_is_swapped)(void); @@ -140,6 +141,9 @@ static unsigned int __uniphier_boot_device_raw(
+ if (info->boot_device_is_sd && info->boot_device_is_sd(pinmon)) + return BOOT_DEVICE_MMC2; + if (info->boot_device_is_usb && info->boot_device_is_usb(pinmon)) return BOOT_DEVICE_USB;
@@ -224,6 +228,10 @@ static int do_pinmon(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
+ if (info->boot_device_is_sd) + printf("SD Boot: %s\n", + info->boot_device_is_sd(pinmon) ? "ON" : "OFF"); + if (info->boot_device_is_usb) printf("USB Boot: %s\n", info->boot_device_is_usb(pinmon) ? "ON" : "OFF");
The SG_* macros represent the address of SoC-glue registers. For a planned new SoC, its base address will be changed.
Turn the SG_* macros into the offset from the base address.
arch/arm/mach-uniphier/arm32/debug_ll.S | 16 +++++------ .../boot-device/boot-device-pxs3.c | 2 +- .../mach-uniphier/boot-device/boot-device.c | 6 ++-- arch/arm/mach-uniphier/clk/clk-ld11.c | 14 +++++----- arch/arm/mach-uniphier/clk/pll-ld4.c | 4 +-- arch/arm/mach-uniphier/clk/pll-pro4.c | 2 +- .../debug-uart/debug-uart-pro4.c | 2 +- .../debug-uart/debug-uart-pro5.c | 2 +- .../arm/mach-uniphier/debug-uart/debug-uart.c | 5 ++-- arch/arm/mach-uniphier/dram_init.c | 2 +- arch/arm/mach-uniphier/memconf.c | 2 +- arch/arm/mach-uniphier/sg-regs.h | 28 +++++++++++-------- arch/arm/mach-uniphier/soc-info.c | 2 +- 13 files changed, 46 insertions(+), 41 deletions(-)
diff --git a/arch/arm/mach-uniphier/arm32/debug_ll.S b/arch/arm/mach-uniphier/arm32/debug_ll.S index e56e1f679ca8..c155246ae8c9 100644 --- a/arch/arm/mach-uniphier/arm32/debug_ll.S +++ b/arch/arm/mach-uniphier/arm32/debug_ll.S @@ -22,7 +22,7 @@ #define DIV_ROUND(x, d) (((x) + ((d) / 2)) / (d))
.macro sg_set_pinsel, pin, muxval, mux_bits, reg_stride, ra, rd - ldr \ra, =(SG_PINCTRL_BASE + \pin * \mux_bits / 32 * \reg_stride) + ldr \ra, =(SG_BASE + SG_PINCTRL_BASE + \pin * \mux_bits / 32 * \reg_stride) ldr \rd, [\ra] and \rd, \rd, #~(((1 << \mux_bits) - 1) << (\pin * \mux_bits % 32)) orr \rd, \rd, #(\muxval << (\pin * \mux_bits % 32)) @@ -30,7 +30,7 @@ .endm
ENTRY(debug_ll_init) - ldr r0, =SG_REVISION + ldr r0, =(SG_BASE + SG_REVISION) ldr r1, [r0] and r1, r1, #SG_REVISION_TYPE_MASK mov r1, r1, lsr #SG_REVISION_TYPE_SHIFT @@ -40,7 +40,7 @@ ENTRY(debug_ll_init) cmp r1, #0x26 bne ld4_end
- ldr r0, =SG_IECTRL + ldr r0, =(SG_BASE + SG_IECTRL) ldr r1, [r0] orr r1, r1, #1 str r1, [r0] @@ -59,7 +59,7 @@ ld4_end:
sg_set_pinsel 128, 0, 4, 8, r0, r1 @ TXD0 -> TXD0
- ldr r0, =SG_LOADPINCTRL + ldr r0, =(SG_BASE + SG_LOADPINCTRL) mov r1, #1 str r1, [r0]
@@ -78,7 +78,7 @@ pro4_end: cmp r1, #0x29 bne sld8_end
- ldr r0, =SG_IECTRL + ldr r0, =(SG_BASE + SG_IECTRL) ldr r1, [r0] orr r1, r1, #1 str r1, [r0] @@ -100,7 +100,7 @@ sld8_end: sg_set_pinsel 51, 0, 4, 8, r0, r1 @ TXD2 -> TXD2 sg_set_pinsel 53, 0, 4, 8, r0, r1 @ TXD3 -> TXD3
@@ -119,7 +119,7 @@ pro5_end: cmp r1, #0x2E bne pxs2_end
- ldr r0, =SG_IECTRL + ldr r0, =(SG_BASE + SG_IECTRL) ldr r1, [r0] orr r1, r1, #1 str r1, [r0] @@ -144,7 +144,7 @@ pxs2_end: cmp r1, #0x2F bne ld6b_end
- ldr r0, =SG_IECTRL + ldr r0, =(SG_BASE + SG_IECTRL) ldr r1, [r0] orr r1, r1, #1 str r1, [r0] diff --git a/arch/arm/mach-uniphier/boot-device/boot-device-pxs3.c b/arch/arm/mach-uniphier/boot-device/boot-device-pxs3.c index 01a72c035052..2edf66d5c103 100644 --- a/arch/arm/mach-uniphier/boot-device/boot-device-pxs3.c +++ b/arch/arm/mach-uniphier/boot-device/boot-device-pxs3.c @@ -36,5 +36,5 @@ const unsigned uniphier_pxs3_boot_device_count =
int uniphier_pxs3_boot_device_is_usb(u32 pinmon) { - return !!(readl(SG_PINMON2) & BIT(31)); + return !!(readl(sg_base + SG_PINMON2) & BIT(31)); } diff --git a/arch/arm/mach-uniphier/boot-device/boot-device.c b/arch/arm/mach-uniphier/boot-device/boot-device.c index c9dfe13ed9c0..83f8c6a428cf 100644 --- a/arch/arm/mach-uniphier/boot-device/boot-device.c +++ b/arch/arm/mach-uniphier/boot-device/boot-device.c @@ -139,7 +139,7 @@ static unsigned int __uniphier_boot_device_raw( if (info->boot_is_swapped && info->boot_is_swapped()) return BOOT_DEVICE_NOR;
- pinmon = readl(SG_PINMON0); + pinmon = readl(sg_base + SG_PINMON0);
if (info->boot_device_is_sd && info->boot_device_is_sd(pinmon)) return BOOT_DEVICE_MMC2; @@ -200,7 +200,7 @@ int uniphier_have_internal_stm(void)
int uniphier_boot_from_backend(void) { - return !!(readl(SG_PINMON0) & BIT(27)); + return !!(readl(sg_base + SG_PINMON0) & BIT(27)); }
#ifndef CONFIG_SPL_BUILD @@ -226,7 +226,7 @@ static int do_pinmon(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) printf("Boot Swap: %s\n", info->boot_is_swapped() ? "ON" : "OFF");
if (info->boot_device_is_sd) printf("SD Boot: %s\n", diff --git a/arch/arm/mach-uniphier/clk/clk-ld11.c b/arch/arm/mach-uniphier/clk/clk-ld11.c index e997acf1b7d7..0917b33c2546 100644 --- a/arch/arm/mach-uniphier/clk/clk-ld11.c +++ b/arch/arm/mach-uniphier/clk/clk-ld11.c @@ -17,16 +17,16 @@ void uniphier_ld11_clk_init(void) { /* if booted from a device other than USB, without stand-by MPU */ - if ((readl(SG_PINMON0) & BIT(27)) && + if ((readl(sg_base + SG_PINMON0) & BIT(27)) && uniphier_boot_device_raw() != BOOT_DEVICE_USB) { - writel(1, SG_ETPHYPSHUT); - writel(1, SG_ETPHYCNT); + writel(1, sg_base + SG_ETPHYPSHUT); + writel(1, sg_base + SG_ETPHYCNT);
udelay(1); /* wait for regulator level 1.1V -> 2.5V */
- writel(3, SG_ETPHYCNT); - writel(3, SG_ETPHYPSHUT); - writel(7, SG_ETPHYCNT); + writel(3, sg_base + SG_ETPHYCNT); + writel(3, sg_base + SG_ETPHYPSHUT); + writel(7, sg_base + SG_ETPHYCNT); }
/* TODO: use "mmc-pwrseq-emmc" */ @@ -37,7 +37,7 @@ void uniphier_ld11_clk_init(void) int ch;
for (ch = 0; ch < 3; ch++) { - void __iomem *phyctrl = (void __iomem *)SG_USBPHYCTRL; + void __iomem *phyctrl = sg_base + SG_USBPHYCTRL;
writel(0x82280600, phyctrl + 8 * ch); writel(0x00000106, phyctrl + 8 * ch + 4); diff --git a/arch/arm/mach-uniphier/clk/pll-ld4.c b/arch/arm/mach-uniphier/clk/pll-ld4.c index 6a145a3baa12..34f1c9cc2898 100644 --- a/arch/arm/mach-uniphier/clk/pll-ld4.c +++ b/arch/arm/mach-uniphier/clk/pll-ld4.c @@ -16,7 +16,7 @@ static void upll_init(void) { u32 tmp, clk_mode_upll, clk_mode_axosel;
- tmp = readl(SG_PINMON0); + tmp = readl(sg_base + SG_PINMON0); clk_mode_upll = tmp & SG_PINMON0_CLK_MODE_UPLLSRC_MASK; clk_mode_axosel = tmp & SG_PINMON0_CLK_MODE_AXOSEL_MASK;
@@ -56,7 +56,7 @@ static void vpll_init(void) { u32 tmp, clk_mode_axosel;
- tmp = readl(SG_PINMON0); + tmp = readl(sg_base + SG_PINMON0); clk_mode_axosel = tmp & SG_PINMON0_CLK_MODE_AXOSEL_MASK;
/* set 1 to VPLA27WP and VPLA27WP */ diff --git a/arch/arm/mach-uniphier/clk/pll-pro4.c b/arch/arm/mach-uniphier/clk/pll-pro4.c index 2ee2ed6bd662..312a5fcfdfcf 100644 --- a/arch/arm/mach-uniphier/clk/pll-pro4.c +++ b/arch/arm/mach-uniphier/clk/pll-pro4.c @@ -17,7 +17,7 @@ static void vpll_init(void) u32 tmp, clk_mode_axosel;
/* Set VPLL27A & VPLL27B */ - tmp = readl(SG_PINMON0); + tmp = readl(sg_base + SG_PINMON0); clk_mode_axosel = tmp & SG_PINMON0_CLK_MODE_AXOSEL_MASK;
/* 25MHz or 6.25MHz is default for Pro4R, no need to set VPLLA/B */ diff --git a/arch/arm/mach-uniphier/debug-uart/debug-uart-pro4.c b/arch/arm/mach-uniphier/debug-uart/debug-uart-pro4.c index 0d6629918acc..9017a24a1049 100644 --- a/arch/arm/mach-uniphier/debug-uart/debug-uart-pro4.c +++ b/arch/arm/mach-uniphier/debug-uart/debug-uart-pro4.c @@ -20,7 +20,7 @@ unsigned int uniphier_pro4_debug_uart_init(void) sg_set_iectrl(0); sg_set_pinsel(128, 0, 4, 8); /* TXD0 -> TXD0 */
- writel(1, SG_LOADPINCTRL); + writel(1, sg_base + SG_LOADPINCTRL);
tmp = readl(SC_CLKCTRL); tmp |= SC_CLKCTRL_CEN_PERI; diff --git a/arch/arm/mach-uniphier/debug-uart/debug-uart-pro5.c b/arch/arm/mach-uniphier/debug-uart/debug-uart-pro5.c index 1a0a942f2dca..8e4d15c2913e 100644 --- a/arch/arm/mach-uniphier/debug-uart/debug-uart-pro5.c +++ b/arch/arm/mach-uniphier/debug-uart/debug-uart-pro5.c @@ -23,7 +23,7 @@ unsigned int uniphier_pro5_debug_uart_init(void) sg_set_pinsel(51, 0, 4, 8); /* TXD2 -> TXD2 */ sg_set_pinsel(53, 0, 4, 8); /* TXD3 -> TXD3 */
tmp = readl(SC_CLKCTRL); tmp |= SC_CLKCTRL_CEN_PERI; diff --git a/arch/arm/mach-uniphier/debug-uart/debug-uart.c b/arch/arm/mach-uniphier/debug-uart/debug-uart.c index bc96b2e7be1f..a70ce59accdc 100644 --- a/arch/arm/mach-uniphier/debug-uart/debug-uart.c +++ b/arch/arm/mach-uniphier/debug-uart/debug-uart.c @@ -32,7 +32,8 @@ void sg_set_pinsel(unsigned int pin, unsigned int muxval, unsigned int mux_bits, unsigned int reg_stride) { unsigned int shift = pin * mux_bits % 32; - unsigned long reg = SG_PINCTRL_BASE + pin * mux_bits / 32 * reg_stride; + void __iomem *reg = sg_base + SG_PINCTRL_BASE + + pin * mux_bits / 32 * reg_stride; u32 mask = (1U << mux_bits) - 1; u32 tmp;
@@ -45,7 +46,7 @@ void sg_set_pinsel(unsigned int pin, unsigned int muxval, void sg_set_iectrl(unsigned int pin) { unsigned int bit = pin % 32; - unsigned long reg = SG_IECTRL + pin / 32 * 4; + void __iomem *reg = sg_base + SG_IECTRL + pin / 32 * 4; u32 tmp;
tmp = readl(reg); diff --git a/arch/arm/mach-uniphier/dram_init.c b/arch/arm/mach-uniphier/dram_init.c index fa4b3e386b83..eca340b094e6 100644 --- a/arch/arm/mach-uniphier/dram_init.c +++ b/arch/arm/mach-uniphier/dram_init.c @@ -85,7 +85,7 @@ static int uniphier_memconf_decode(struct uniphier_dram_map *dram_map) return -EINVAL; }
- val = readl(SG_MEMCONF); + val = readl(sg_base + SG_MEMCONF);
/* set up ch0 */ dram_map[0].base = CONFIG_SYS_SDRAM_BASE; diff --git a/arch/arm/mach-uniphier/memconf.c b/arch/arm/mach-uniphier/memconf.c index 8105368df147..f69b489b76e5 100644 --- a/arch/arm/mach-uniphier/memconf.c +++ b/arch/arm/mach-uniphier/memconf.c @@ -140,7 +140,7 @@ static int __uniphier_memconf_init(const struct uniphier_board_data *bd, }
out: - writel(val, SG_MEMCONF); + writel(val, sg_base + SG_MEMCONF);
return 0; } diff --git a/arch/arm/mach-uniphier/sg-regs.h b/arch/arm/mach-uniphier/sg-regs.h index 39ffed5885df..cba02d1f4aee 100644 --- a/arch/arm/mach-uniphier/sg-regs.h +++ b/arch/arm/mach-uniphier/sg-regs.h @@ -10,15 +10,19 @@ #ifndef UNIPHIER_SG_REGS_H #define UNIPHIER_SG_REGS_H
+#ifndef __ASSEMBLY__ +#include <linux/compiler.h> +#define sg_base ((void __iomem *)SG_BASE) +#endif + /* Base Address */ -#define SG_CTRL_BASE 0x5f800000 -#define SG_DBG_BASE 0x5f900000 +#define SG_BASE 0x5f800000
/* Revision */ -#define SG_REVISION (SG_CTRL_BASE | 0x0000) +#define SG_REVISION 0x0000
/* Memory Configuration */ -#define SG_MEMCONF (SG_CTRL_BASE | 0x0400) +#define SG_MEMCONF 0x0400
#define SG_MEMCONF_CH0_SZ_MASK ((0x1 << 10) | (0x03 << 0)) #define SG_MEMCONF_CH0_SZ_64M ((0x0 << 10) | (0x01 << 0)) @@ -54,22 +58,22 @@
#define SG_MEMCONF_SPARSEMEM (0x1 << 4)
-#define SG_USBPHYCTRL (SG_CTRL_BASE | 0x500) -#define SG_ETPHYPSHUT (SG_CTRL_BASE | 0x554) -#define SG_ETPHYCNT (SG_CTRL_BASE | 0x550) +#define SG_USBPHYCTRL 0x0500 +#define SG_ETPHYPSHUT 0x0554 +#define SG_ETPHYCNT 0x0550
/* Pin Control */ -#define SG_PINCTRL_BASE (SG_CTRL_BASE | 0x1000) +#define SG_PINCTRL_BASE 0x1000
/* PH1-Pro4, PH1-Pro5 */ -#define SG_LOADPINCTRL (SG_CTRL_BASE | 0x1700) +#define SG_LOADPINCTRL 0x1700
/* Input Enable */ -#define SG_IECTRL (SG_CTRL_BASE | 0x1d00) +#define SG_IECTRL 0x1d00
/* Pin Monitor */ -#define SG_PINMON0 (SG_DBG_BASE | 0x0100) -#define SG_PINMON2 (SG_DBG_BASE | 0x0108) +#define SG_PINMON0 0x00100100 +#define SG_PINMON2 0x00100108
#define SG_PINMON0_CLK_MODE_UPLLSRC_MASK (0x3 << 19) #define SG_PINMON0_CLK_MODE_UPLLSRC_DEFAULT (0x0 << 19) diff --git a/arch/arm/mach-uniphier/soc-info.c b/arch/arm/mach-uniphier/soc-info.c index ce2d4b6dea4c..f021a8cab330 100644 --- a/arch/arm/mach-uniphier/soc-info.c +++ b/arch/arm/mach-uniphier/soc-info.c @@ -13,7 +13,7 @@ static unsigned int __uniphier_get_revision_field(unsigned int mask, unsigned int shift) { - u32 revision = readl(SG_REVISION); + u32 revision = readl(sg_base + SG_REVISION);
return (revision >> shift) & mask; }
The SC_* macros represent the address of SysCtrl registers. For a planned new SoC, its base address will be changed.
Turn the SC_* macros into the offset from the base address.
arch/arm/mach-uniphier/arm32/debug_ll.S | 8 +- arch/arm/mach-uniphier/clk/clk-dram-ld4.c | 12 +-- arch/arm/mach-uniphier/clk/clk-dram-pro5.c | 12 +-- arch/arm/mach-uniphier/clk/clk-dram-pxs2.c | 12 +-- arch/arm/mach-uniphier/clk/clk-early-ld4.c | 10 +-- arch/arm/mach-uniphier/clk/clk-ld20.c | 8 +- arch/arm/mach-uniphier/clk/clk-ld4.c | 12 +-- arch/arm/mach-uniphier/clk/clk-pro4.c | 18 ++-- arch/arm/mach-uniphier/clk/clk-pro5.c | 18 ++-- arch/arm/mach-uniphier/clk/clk-pxs2.c | 22 ++--- arch/arm/mach-uniphier/clk/clk-pxs3.c | 8 +- arch/arm/mach-uniphier/clk/dpll-ld4.c | 8 +- arch/arm/mach-uniphier/clk/dpll-pro4.c | 8 +- arch/arm/mach-uniphier/clk/dpll-sld8.c | 12 +-- arch/arm/mach-uniphier/clk/dpll-tail.c | 4 +- arch/arm/mach-uniphier/clk/pll-base-ld20.c | 41 ++-------- arch/arm/mach-uniphier/clk/pll-ld11.c | 18 ++-- arch/arm/mach-uniphier/clk/pll-ld20.c | 26 +++--- arch/arm/mach-uniphier/clk/pll-ld4.c | 82 +++++++++---------- arch/arm/mach-uniphier/clk/pll-pro4.c | 64 +++++++-------- arch/arm/mach-uniphier/clk/pll-pxs3.c | 30 +++---- .../debug-uart/debug-uart-ld6b.c | 4 +- .../debug-uart/debug-uart-pro4.c | 4 +- .../debug-uart/debug-uart-pro5.c | 4 +- .../debug-uart/debug-uart-pxs2.c | 4 +- arch/arm/mach-uniphier/reset.c | 10 +-- arch/arm/mach-uniphier/sc-regs.h | 49 ++++++----- arch/arm/mach-uniphier/sc64-regs.h | 43 +++++----- 28 files changed, 266 insertions(+), 285 deletions(-)
diff --git a/arch/arm/mach-uniphier/arm32/debug_ll.S b/arch/arm/mach-uniphier/arm32/debug_ll.S index c155246ae8c9..3fed7985fcd6 100644 --- a/arch/arm/mach-uniphier/arm32/debug_ll.S +++ b/arch/arm/mach-uniphier/arm32/debug_ll.S @@ -63,7 +63,7 @@ ld4_end: mov r1, #1 str r1, [r0]
- ldr r0, =SC_CLKCTRL + ldr r0, =(SC_BASE + SC_CLKCTRL) ldr r1, [r0] orr r1, r1, #SC_CLKCTRL_CEN_PERI str r1, [r0] @@ -104,7 +104,7 @@ sld8_end: mov r1, #1 str r1, [r0]
- ldr r0, =SC_CLKCTRL + ldr r0, =(SC_BASE + SC_CLKCTRL) ldr r1, [r0] orr r1, r1, #SC_CLKCTRL_CEN_PERI str r1, [r0] @@ -129,7 +129,7 @@ pro5_end: sg_set_pinsel 113, 8, 8, 4, r0, r1 @ TXD2 -> TXD2 sg_set_pinsel 219, 8, 8, 4, r0, r1 @ TXD3 -> TXD3
- ldr r0, =SC_CLKCTRL + ldr r0, =(SC_BASE + SC_CLKCTRL) ldr r1, [r0] orr r1, r1, #SC_CLKCTRL_CEN_PERI str r1, [r0] @@ -153,7 +153,7 @@ pxs2_end: sg_set_pinsel 115, 0, 8, 4, r0, r1 @ TXD1 -> TXD1 sg_set_pinsel 113, 2, 8, 4, r0, r1 @ SBO0 -> TXD2
- ldr r0, =SC_CLKCTRL + ldr r0, =(SC_BASE + SC_CLKCTRL) ldr r1, [r0] orr r1, r1, #SC_CLKCTRL_CEN_PERI str r1, [r0] diff --git a/arch/arm/mach-uniphier/clk/clk-dram-ld4.c b/arch/arm/mach-uniphier/clk/clk-dram-ld4.c index 39cde4400b4e..c796d364bb16 100644 --- a/arch/arm/mach-uniphier/clk/clk-dram-ld4.c +++ b/arch/arm/mach-uniphier/clk/clk-dram-ld4.c @@ -16,14 +16,14 @@ void uniphier_ld4_dram_clk_init(void) u32 tmp;
/* deassert reset */ - tmp = readl(SC_RSTCTRL); + tmp = readl(sc_base + SC_RSTCTRL); tmp |= SC_RSTCTRL_NRST_UMC1 | SC_RSTCTRL_NRST_UMC0; - writel(tmp, SC_RSTCTRL); - readl(SC_RSTCTRL); /* dummy read */ + writel(tmp, sc_base + SC_RSTCTRL); + readl(sc_base + SC_RSTCTRL); /* dummy read */
/* provide clocks */ - tmp = readl(SC_CLKCTRL); + tmp = readl(sc_base + SC_CLKCTRL); tmp |= SC_CLKCTRL_CEN_UMC; - writel(tmp, SC_CLKCTRL); - readl(SC_CLKCTRL); /* dummy read */ + writel(tmp, sc_base + SC_CLKCTRL); + readl(sc_base + SC_CLKCTRL); /* dummy read */ } diff --git a/arch/arm/mach-uniphier/clk/clk-dram-pro5.c b/arch/arm/mach-uniphier/clk/clk-dram-pro5.c index 7674ceb885fa..808d1ebfe190 100644 --- a/arch/arm/mach-uniphier/clk/clk-dram-pro5.c +++ b/arch/arm/mach-uniphier/clk/clk-dram-pro5.c @@ -18,17 +18,17 @@ void uniphier_pro5_dram_clk_init(void) * UMCA1, UMC31: Ch0 (WIO1) * UMCA0, UMC30: Ch0 (WIO0) */ - tmp = readl(SC_RSTCTRL4); + tmp = readl(sc_base + SC_RSTCTRL4); tmp |= SC_RSTCTRL4_NRST_UMCSB | SC_RSTCTRL4_NRST_UMCA2 | SC_RSTCTRL4_NRST_UMCA1 | SC_RSTCTRL4_NRST_UMCA0 | SC_RSTCTRL4_NRST_UMC31 | SC_RSTCTRL4_NRST_UMC30; - writel(tmp, SC_RSTCTRL4); - readl(SC_RSTCTRL4); /* dummy read */ + writel(tmp, sc_base + SC_RSTCTRL4); + readl(sc_base + SC_RSTCTRL4); /* dummy read */
/* provide clocks */ - tmp = readl(SC_CLKCTRL4); + tmp = readl(sc_base + SC_CLKCTRL4); tmp |= SC_CLKCTRL4_CEN_UMCSB | SC_CLKCTRL4_CEN_UMC1 | SC_CLKCTRL4_CEN_UMC0; - writel(tmp, SC_CLKCTRL4); - readl(SC_CLKCTRL4); /* dummy read */ + writel(tmp, sc_base + SC_CLKCTRL4); + readl(sc_base + SC_CLKCTRL4); /* dummy read */ } diff --git a/arch/arm/mach-uniphier/clk/clk-dram-pxs2.c b/arch/arm/mach-uniphier/clk/clk-dram-pxs2.c index ad4e83a84a2e..b78bd0167218 100644 --- a/arch/arm/mach-uniphier/clk/clk-dram-pxs2.c +++ b/arch/arm/mach-uniphier/clk/clk-dram-pxs2.c @@ -15,18 +15,18 @@ void uniphier_pxs2_dram_clk_init(void) u32 tmp;
/* deassert reset */ - tmp = readl(SC_RSTCTRL4); + tmp = readl(sc_base + SC_RSTCTRL4); tmp |= SC_RSTCTRL4_NRST_UMCSB | SC_RSTCTRL4_NRST_UMCA2 | SC_RSTCTRL4_NRST_UMCA1 | SC_RSTCTRL4_NRST_UMCA0 | SC_RSTCTRL4_NRST_UMC32 | SC_RSTCTRL4_NRST_UMC31 | SC_RSTCTRL4_NRST_UMC30; - writel(tmp, SC_RSTCTRL4); - readl(SC_RSTCTRL4); /* dummy read */ + writel(tmp, sc_base + SC_RSTCTRL4); + readl(sc_base + SC_RSTCTRL4); /* dummy read */
/* provide clocks */ - tmp = readl(SC_CLKCTRL4); + tmp = readl(sc_base + SC_CLKCTRL4); tmp |= SC_CLKCTRL4_CEN_UMCSB | SC_CLKCTRL4_CEN_UMC2 | SC_CLKCTRL4_CEN_UMC1 | SC_CLKCTRL4_CEN_UMC0; - writel(tmp, SC_CLKCTRL4); - readl(SC_CLKCTRL4); /* dummy read */ + writel(tmp, sc_base + SC_CLKCTRL4); + readl(sc_base + SC_CLKCTRL4); /* dummy read */ } diff --git a/arch/arm/mach-uniphier/clk/clk-early-ld4.c b/arch/arm/mach-uniphier/clk/clk-early-ld4.c index eb36a9e7ae45..f32f78dd26d8 100644 --- a/arch/arm/mach-uniphier/clk/clk-early-ld4.c +++ b/arch/arm/mach-uniphier/clk/clk-early-ld4.c @@ -17,14 +17,14 @@ void uniphier_ld4_early_clk_init(void)
/* deassert reset */ if (spl_boot_device() != BOOT_DEVICE_NAND) { - tmp = readl(SC_RSTCTRL); + tmp = readl(sc_base + SC_RSTCTRL); tmp &= ~SC_RSTCTRL_NRST_NAND; - writel(tmp, SC_RSTCTRL); + writel(tmp, sc_base + SC_RSTCTRL); };
/* provide clocks */ - tmp = readl(SC_CLKCTRL); + tmp = readl(sc_base + SC_CLKCTRL); tmp |= SC_CLKCTRL_CEN_SBC | SC_CLKCTRL_CEN_PERI; - writel(tmp, SC_CLKCTRL); - readl(SC_CLKCTRL); /* dummy read */ + writel(tmp, sc_base + SC_CLKCTRL); + readl(sc_base + SC_CLKCTRL); /* dummy read */ } diff --git a/arch/arm/mach-uniphier/clk/clk-ld20.c b/arch/arm/mach-uniphier/clk/clk-ld20.c index 02a14ddfb8bc..397b2d7384fd 100644 --- a/arch/arm/mach-uniphier/clk/clk-ld20.c +++ b/arch/arm/mach-uniphier/clk/clk-ld20.c @@ -15,13 +15,13 @@ void uniphier_ld20_clk_init(void) { u32 tmp;
- tmp = readl(SC_RSTCTRL6); + tmp = readl(sc_base + SC_RSTCTRL6); tmp |= BIT(8); /* Mali */ - writel(tmp, SC_RSTCTRL6); + writel(tmp, sc_base + SC_RSTCTRL6);
- tmp = readl(SC_CLKCTRL6); + tmp = readl(sc_base + SC_CLKCTRL6); tmp |= BIT(8); /* Mali */ - writel(tmp, SC_CLKCTRL6); + writel(tmp, sc_base + SC_CLKCTRL6);
/* TODO: use "mmc-pwrseq-emmc" */ writel(1, SDCTRL_EMMC_HW_RESET); diff --git a/arch/arm/mach-uniphier/clk/clk-ld4.c b/arch/arm/mach-uniphier/clk/clk-ld4.c index 9c88cde5e257..039394250396 100644 --- a/arch/arm/mach-uniphier/clk/clk-ld4.c +++ b/arch/arm/mach-uniphier/clk/clk-ld4.c @@ -15,18 +15,18 @@ void uniphier_ld4_clk_init(void) u32 tmp;
/* deassert reset */ - tmp = readl(SC_RSTCTRL); + tmp = readl(sc_base + SC_RSTCTRL); #ifdef CONFIG_NAND_DENALI tmp |= SC_RSTCTRL_NRST_NAND; #endif - writel(tmp, SC_RSTCTRL); - readl(SC_RSTCTRL); /* dummy read */ + writel(tmp, sc_base + SC_RSTCTRL); + readl(sc_base + SC_RSTCTRL); /* dummy read */
/* provide clocks */ - tmp = readl(SC_CLKCTRL); + tmp = readl(sc_base + SC_CLKCTRL); #ifdef CONFIG_NAND_DENALI tmp |= SC_CLKCTRL_CEN_NAND; #endif - writel(tmp, SC_CLKCTRL); - readl(SC_CLKCTRL); /* dummy read */ + writel(tmp, sc_base + SC_CLKCTRL); + readl(sc_base + SC_CLKCTRL); /* dummy read */ } diff --git a/arch/arm/mach-uniphier/clk/clk-pro4.c b/arch/arm/mach-uniphier/clk/clk-pro4.c index 32d44c0b6677..2b364dca4100 100644 --- a/arch/arm/mach-uniphier/clk/clk-pro4.c +++ b/arch/arm/mach-uniphier/clk/clk-pro4.c @@ -15,7 +15,7 @@ void uniphier_pro4_clk_init(void) u32 tmp;
/* deassert reset */ - tmp = readl(SC_RSTCTRL); + tmp = readl(sc_base + SC_RSTCTRL); #ifdef CONFIG_USB_DWC3_UNIPHIER tmp |= SC_RSTCTRL_NRST_USB3B0 | SC_RSTCTRL_NRST_USB3C0 | SC_RSTCTRL_NRST_GIO; @@ -23,18 +23,18 @@ void uniphier_pro4_clk_init(void) #ifdef CONFIG_NAND_DENALI tmp |= SC_RSTCTRL_NRST_NAND; #endif - writel(tmp, SC_RSTCTRL); - readl(SC_RSTCTRL); /* dummy read */ + writel(tmp, sc_base + SC_RSTCTRL); + readl(sc_base + SC_RSTCTRL); /* dummy read */
#ifdef CONFIG_USB_DWC3_UNIPHIER - tmp = readl(SC_RSTCTRL2); + tmp = readl(sc_base + SC_RSTCTRL2); tmp |= SC_RSTCTRL2_NRST_USB3B1 | SC_RSTCTRL2_NRST_USB3C1; - writel(tmp, SC_RSTCTRL2); - readl(SC_RSTCTRL2); /* dummy read */ + writel(tmp, sc_base + SC_RSTCTRL2); + readl(sc_base + SC_RSTCTRL2); /* dummy read */ #endif
/* provide clocks */ - tmp = readl(SC_CLKCTRL); + tmp = readl(sc_base + SC_CLKCTRL); #ifdef CONFIG_USB_DWC3_UNIPHIER tmp |= SC_CLKCTRL_CEN_USB31 | SC_CLKCTRL_CEN_USB30 | SC_CLKCTRL_CEN_GIO; @@ -42,6 +42,6 @@ void uniphier_pro4_clk_init(void) #ifdef CONFIG_NAND_DENALI tmp |= SC_CLKCTRL_CEN_NAND; #endif - writel(tmp, SC_CLKCTRL); - readl(SC_CLKCTRL); /* dummy read */ + writel(tmp, sc_base + SC_CLKCTRL); + readl(sc_base + SC_CLKCTRL); /* dummy read */ } diff --git a/arch/arm/mach-uniphier/clk/clk-pro5.c b/arch/arm/mach-uniphier/clk/clk-pro5.c index 338d73d07085..874964b2d5bc 100644 --- a/arch/arm/mach-uniphier/clk/clk-pro5.c +++ b/arch/arm/mach-uniphier/clk/clk-pro5.c @@ -13,25 +13,25 @@ void uniphier_pro5_clk_init(void) u32 tmp;
/* deassert reset */ - tmp = readl(SC_RSTCTRL); + tmp = readl(sc_base + SC_RSTCTRL); #ifdef CONFIG_USB_DWC3_UNIPHIER tmp |= SC_RSTCTRL_NRST_USB3B0 | SC_RSTCTRL_NRST_GIO; #endif #ifdef CONFIG_NAND_DENALI tmp |= SC_RSTCTRL_NRST_NAND; #endif - writel(tmp, SC_RSTCTRL); - readl(SC_RSTCTRL); /* dummy read */ + writel(tmp, sc_base + SC_RSTCTRL); + readl(sc_base + SC_RSTCTRL); /* dummy read */
#ifdef CONFIG_USB_DWC3_UNIPHIER - tmp = readl(SC_RSTCTRL2); + tmp = readl(sc_base + SC_RSTCTRL2); tmp |= SC_RSTCTRL2_NRST_USB3B1; - writel(tmp, SC_RSTCTRL2); - readl(SC_RSTCTRL2); /* dummy read */ + writel(tmp, sc_base + SC_RSTCTRL2); + readl(sc_base + SC_RSTCTRL2); /* dummy read */ #endif
/* provide clocks */ - tmp = readl(SC_CLKCTRL); + tmp = readl(sc_base + SC_CLKCTRL); #ifdef CONFIG_USB_DWC3_UNIPHIER tmp |= SC_CLKCTRL_CEN_USB31 | SC_CLKCTRL_CEN_USB30 | SC_CLKCTRL_CEN_GIO; @@ -39,6 +39,6 @@ void uniphier_pro5_clk_init(void) #ifdef CONFIG_NAND_DENALI tmp |= SC_CLKCTRL_CEN_NAND; #endif - writel(tmp, SC_CLKCTRL); - readl(SC_CLKCTRL); /* dummy read */ + writel(tmp, sc_base + SC_CLKCTRL); + readl(sc_base + SC_CLKCTRL); /* dummy read */ } diff --git a/arch/arm/mach-uniphier/clk/clk-pxs2.c b/arch/arm/mach-uniphier/clk/clk-pxs2.c index afa12fa071e7..8cb4f87ae54b 100644 --- a/arch/arm/mach-uniphier/clk/clk-pxs2.c +++ b/arch/arm/mach-uniphier/clk/clk-pxs2.c @@ -14,29 +14,29 @@ void uniphier_pxs2_clk_init(void) u32 tmp;
- tmp = readl(SC_RSTCTRL6); + tmp = readl(sc_base + SC_RSTCTRL6); tmp |= 0x37; - writel(tmp, SC_RSTCTRL6); + writel(tmp, sc_base + SC_RSTCTRL6); #endif
/* provide clocks */ - tmp = readl(SC_CLKCTRL); + tmp = readl(sc_base + SC_CLKCTRL); #ifdef CONFIG_USB_DWC3_UNIPHIER tmp |= BIT(20) | BIT(19) | SC_CLKCTRL_CEN_USB31 | SC_CLKCTRL_CEN_USB30 | SC_CLKCTRL_CEN_GIO; @@ -44,6 +44,6 @@ void uniphier_pxs2_clk_init(void) #ifdef CONFIG_NAND_DENALI tmp |= SC_CLKCTRL_CEN_NAND; #endif - writel(tmp, SC_CLKCTRL); - readl(SC_CLKCTRL); /* dummy read */ + writel(tmp, sc_base + SC_CLKCTRL); + readl(sc_base + SC_CLKCTRL); /* dummy read */ } diff --git a/arch/arm/mach-uniphier/clk/clk-pxs3.c b/arch/arm/mach-uniphier/clk/clk-pxs3.c index 73824e9ace63..33b9c5b73d1b 100644 --- a/arch/arm/mach-uniphier/clk/clk-pxs3.c +++ b/arch/arm/mach-uniphier/clk/clk-pxs3.c @@ -15,13 +15,13 @@ void uniphier_pxs3_clk_init(void) { u32 tmp;
/* TODO: use "mmc-pwrseq-emmc" */ writel(1, SDCTRL_EMMC_HW_RESET); diff --git a/arch/arm/mach-uniphier/clk/dpll-ld4.c b/arch/arm/mach-uniphier/clk/dpll-ld4.c index 4b9ec075a848..72fe8db8dd1d 100644 --- a/arch/arm/mach-uniphier/clk/dpll-ld4.c +++ b/arch/arm/mach-uniphier/clk/dpll-ld4.c @@ -23,7 +23,7 @@ int uniphier_ld4_dpll_init(const struct uniphier_board_data *bd) * Set 0xc(1600MHz)/0xd(1333MHz)/0xe(1066MHz) * to FOUT (DPLLCTRL.bit[29:20]) */ - tmp = readl(SC_DPLLCTRL); + tmp = readl(sc_base + SC_DPLLCTRL); tmp &= ~0x000f0000; switch (dram_freq) { case 1333: @@ -42,11 +42,11 @@ int uniphier_ld4_dpll_init(const struct uniphier_board_data *bd) #else tmp |= SC_DPLLCTRL_SSC_RATE; #endif - writel(tmp, SC_DPLLCTRL); + writel(tmp, sc_base + SC_DPLLCTRL);
- tmp = readl(SC_DPLLCTRL2); + tmp = readl(sc_base + SC_DPLLCTRL2); tmp |= SC_DPLLCTRL2_NRSTDS; - writel(tmp, SC_DPLLCTRL2); + writel(tmp, sc_base + SC_DPLLCTRL2);
/* Wait 500 usec until dpll gets stable */ udelay(500); diff --git a/arch/arm/mach-uniphier/clk/dpll-pro4.c b/arch/arm/mach-uniphier/clk/dpll-pro4.c index 29659464b57c..62594954848c 100644 --- a/arch/arm/mach-uniphier/clk/dpll-pro4.c +++ b/arch/arm/mach-uniphier/clk/dpll-pro4.c @@ -23,7 +23,7 @@ int uniphier_pro4_dpll_init(const struct uniphier_board_data *bd) * Set 0xc(1600MHz)/0xd(1333MHz)/0xe(1066MHz) * to FOUT ( DPLLCTRL.bit[29:20] ) */ - tmp = readl(SC_DPLLCTRL); + tmp = readl(sc_base + SC_DPLLCTRL); tmp &= ~(0x000f0000); switch (dram_freq) { case 1333: @@ -46,11 +46,11 @@ int uniphier_pro4_dpll_init(const struct uniphier_board_data *bd) #else tmp |= 0x00008000; #endif - writel(tmp, SC_DPLLCTRL); + writel(tmp, sc_base + SC_DPLLCTRL);
/* Wait until dpll gets stable */ udelay(500); diff --git a/arch/arm/mach-uniphier/clk/dpll-sld8.c b/arch/arm/mach-uniphier/clk/dpll-sld8.c index 1d7b75219849..1ac52d11f34a 100644 --- a/arch/arm/mach-uniphier/clk/dpll-sld8.c +++ b/arch/arm/mach-uniphier/clk/dpll-sld8.c @@ -22,10 +22,10 @@ int uniphier_sld8_dpll_init(const struct uniphier_board_data *bd) * [4] ICPD_TEST 0x1 * [3:0] ICPD 0xb */ - tmp = readl(SC_DPLLCTRL3); + tmp = readl(sc_base + SC_DPLLCTRL3); tmp &= ~0x00ff0717; tmp |= 0x00d0061b; - writel(tmp, SC_DPLLCTRL3); + writel(tmp, sc_base + SC_DPLLCTRL3);
/* * Set DPLL SSC parameters for DPLLCTRL @@ -33,14 +33,14 @@ int uniphier_sld8_dpll_init(const struct uniphier_board_data *bd) * [29:20] SSC_UPCNT 132 (0x084) 132 (0x084) * [14:0] SSC_dK 6335(0x18bf) 12710(0x31a6) */ - tmp = readl(SC_DPLLCTRL); + tmp = readl(sc_base + SC_DPLLCTRL); tmp &= ~0x3ff07fff; #ifdef DPLL_SSC_RATE_1PER tmp |= 0x084018bf; #else tmp |= 0x084031a6; #endif - writel(tmp, SC_DPLLCTRL); + writel(tmp, sc_base + SC_DPLLCTRL);
/* * Set DPLL SSC parameters for DPLLCTRL2 @@ -49,10 +49,10 @@ int uniphier_sld8_dpll_init(const struct uniphier_board_data *bd) * [26:20] SSC_M 79 (0x4f) * [19:0] SSC_K 964689 (0xeb851) */ - tmp = readl(SC_DPLLCTRL2); + tmp = readl(sc_base + SC_DPLLCTRL2); tmp &= ~0xefffffff; tmp |= 0x0cfeb851; - writel(tmp, SC_DPLLCTRL2); + writel(tmp, sc_base + SC_DPLLCTRL2);
/* Wait 500 usec until dpll gets stable */ udelay(500); diff --git a/arch/arm/mach-uniphier/clk/dpll-tail.c b/arch/arm/mach-uniphier/clk/dpll-tail.c index 7f434f669627..6ba5a3672743 100644 --- a/arch/arm/mach-uniphier/clk/dpll-tail.c +++ b/arch/arm/mach-uniphier/clk/dpll-tail.c @@ -14,7 +14,7 @@ void uniphier_ld4_dpll_ssc_en(void) { u32 tmp;
- tmp = readl(SC_DPLLCTRL); + tmp = readl(sc_base + SC_DPLLCTRL); tmp |= SC_DPLLCTRL_SSC_EN; - writel(tmp, SC_DPLLCTRL); + writel(tmp, sc_base + SC_DPLLCTRL); } diff --git a/arch/arm/mach-uniphier/clk/pll-base-ld20.c b/arch/arm/mach-uniphier/clk/pll-base-ld20.c index 67b8ee7c3e31..ea96d739c53d 100644 --- a/arch/arm/mach-uniphier/clk/pll-base-ld20.c +++ b/arch/arm/mach-uniphier/clk/pll-base-ld20.c @@ -12,6 +12,7 @@ #include <linux/io.h> #include <linux/sizes.h>
+#include "../sc64-regs.h" #include "pll.h"
/* PLL type: SSC */ @@ -31,13 +32,9 @@ int uniphier_ld20_sscpll_init(unsigned long reg_base, unsigned int freq, unsigned int ssc_rate, unsigned int divn) { - void __iomem *base; + void __iomem *base = sc_base + reg_base; u32 tmp;
- base = ioremap(reg_base, SZ_16); - if (!base) - return -ENOMEM; - if (freq != UNIPHIER_PLL_FREQ_DEFAULT) { tmp = readl(base); /* SSCPLLCTRL */ tmp &= ~SC_PLLCTRL_SSC_DK_MASK; @@ -60,57 +57,39 @@ int uniphier_ld20_sscpll_init(unsigned long reg_base, unsigned int freq, tmp |= SC_PLLCTRL2_NRSTDS; writel(tmp, base + 4);
- iounmap(base); - return 0; }
int uniphier_ld20_sscpll_ssc_en(unsigned long reg_base) { - void __iomem *base; + void __iomem *base = sc_base + reg_base; u32 tmp;
- base = ioremap(reg_base, SZ_16); - if (!base) - return -ENOMEM; - tmp = readl(base); /* SSCPLLCTRL */ tmp |= SC_PLLCTRL_SSC_EN; writel(tmp, base);
int uniphier_ld20_sscpll_set_regi(unsigned long reg_base, unsigned regi) { - void __iomem *base; + void __iomem *base = sc_base + reg_base; u32 tmp;
- base = ioremap(reg_base, SZ_16); - if (!base) - return -ENOMEM; - tmp = readl(base + 8); /* SSCPLLCTRL3 */ tmp &= ~SC_PLLCTRL3_REGI_MASK; tmp |= FIELD_PREP(SC_PLLCTRL3_REGI_MASK, regi); writel(tmp, base + 8);
int uniphier_ld20_vpll27_init(unsigned long reg_base) { - void __iomem *base; + void __iomem *base = sc_base + reg_base; u32 tmp;
- base = ioremap(reg_base, SZ_16); - if (!base) - return -ENOMEM; - tmp = readl(base); /* VPLL27CTRL */ tmp |= SC_VPLL27CTRL_WP; /* write protect off */ writel(tmp, base); @@ -123,25 +102,17 @@ int uniphier_ld20_vpll27_init(unsigned long reg_base) tmp &= ~SC_VPLL27CTRL_WP; /* write protect on */ writel(tmp, base);
int uniphier_ld20_dspll_init(unsigned long reg_base) { - void __iomem *base; + void __iomem *base = sc_base + reg_base; u32 tmp;
- base = ioremap(reg_base, SZ_16); - if (!base) - return -ENOMEM; - tmp = readl(base + 4); /* DSPLLCTRL2 */ tmp |= SC_DSPLLCTRL2_K_LD; writel(tmp, base + 4);
- iounmap(base); - return 0; } diff --git a/arch/arm/mach-uniphier/clk/pll-ld11.c b/arch/arm/mach-uniphier/clk/pll-ld11.c index fd724f3e8c21..7f07e3e92b86 100644 --- a/arch/arm/mach-uniphier/clk/pll-ld11.c +++ b/arch/arm/mach-uniphier/clk/pll-ld11.c @@ -11,15 +11,15 @@ #include "pll.h"
/* PLL type: SSC */ -#define SC_CPLLCTRL (SC_BASE_ADDR | 0x1400) /* CPU/ARM */ -#define SC_SPLLCTRL (SC_BASE_ADDR | 0x1410) /* misc */ -#define SC_MPLLCTRL (SC_BASE_ADDR | 0x1430) /* DSP */ -#define SC_VSPLLCTRL (SC_BASE_ADDR | 0x1440) /* Video codec, VPE etc. */ -#define SC_DPLLCTRL (SC_BASE_ADDR | 0x1460) /* DDR memory */ +#define SC_CPLLCTRL 0x1400 /* CPU/ARM */ +#define SC_SPLLCTRL 0x1410 /* misc */ +#define SC_MPLLCTRL 0x1430 /* DSP */ +#define SC_VSPLLCTRL 0x1440 /* Video codec, VPE etc. */ +#define SC_DPLLCTRL 0x1460 /* DDR memory */
/* PLL type: VPLL27 */ -#define SC_VPLL27FCTRL (SC_BASE_ADDR | 0x1500) -#define SC_VPLL27ACTRL (SC_BASE_ADDR | 0x1520) +#define SC_VPLL27FCTRL 0x1500 +#define SC_VPLL27ACTRL 0x1520
void uniphier_ld11_pll_init(void) { @@ -40,6 +40,6 @@ void uniphier_ld11_pll_init(void) uniphier_ld20_vpll27_init(SC_VPLL27FCTRL); uniphier_ld20_vpll27_init(SC_VPLL27ACTRL);
- writel(0, SC_CA53_GEARSET); /* Gear0: CPLL/2 */ - writel(SC_CA_GEARUPD, SC_CA53_GEARUPD); + writel(0, sc_base + SC_CA53_GEARSET); /* Gear0: CPLL/2 */ + writel(SC_CA_GEARUPD, sc_base + SC_CA53_GEARUPD); } diff --git a/arch/arm/mach-uniphier/clk/pll-ld20.c b/arch/arm/mach-uniphier/clk/pll-ld20.c index 682bd1e0c12e..04b3312a2a5a 100644 --- a/arch/arm/mach-uniphier/clk/pll-ld20.c +++ b/arch/arm/mach-uniphier/clk/pll-ld20.c @@ -11,23 +11,23 @@ #include "pll.h"
/* PLL type: SSC */ -#define SC_CPLLCTRL (SC_BASE_ADDR | 0x1400) /* CPU/ARM */ -#define SC_SPLLCTRL (SC_BASE_ADDR | 0x1410) /* misc */ -#define SC_SPLL2CTRL (SC_BASE_ADDR | 0x1420) /* DSP */ -#define SC_MPLLCTRL (SC_BASE_ADDR | 0x1430) /* Video codec */ -#define SC_VPPLLCTRL (SC_BASE_ADDR | 0x1440) /* VPE etc. */ -#define SC_GPPLLCTRL (SC_BASE_ADDR | 0x1450) /* GPU/Mali */ -#define SC_DPLL0CTRL (SC_BASE_ADDR | 0x1460) /* DDR memory 0 */ -#define SC_DPLL1CTRL (SC_BASE_ADDR | 0x1470) /* DDR memory 1 */ -#define SC_DPLL2CTRL (SC_BASE_ADDR | 0x1480) /* DDR memory 2 */ +#define SC_CPLLCTRL 0x1400 /* CPU/ARM */ +#define SC_SPLLCTRL 0x1410 /* misc */ +#define SC_SPLL2CTRL 0x1420 /* DSP */ +#define SC_MPLLCTRL 0x1430 /* Video codec */ +#define SC_VPPLLCTRL 0x1440 /* VPE etc. */ +#define SC_GPPLLCTRL 0x1450 /* GPU/Mali */ +#define SC_DPLL0CTRL 0x1460 /* DDR memory 0 */ +#define SC_DPLL1CTRL 0x1470 /* DDR memory 1 */ +#define SC_DPLL2CTRL 0x1480 /* DDR memory 2 */
/* PLL type: DSPLL */ -#define SC_VPLL8KCTRL (SC_BASE_ADDR | 0x1540) -#define SC_A2PLLCTRL (SC_BASE_ADDR | 0x15C0) +#define SC_VPLL8KCTRL 0x1540 +#define SC_A2PLLCTRL 0x15C0
void uniphier_ld20_pll_init(void) { diff --git a/arch/arm/mach-uniphier/clk/pll-ld4.c b/arch/arm/mach-uniphier/clk/pll-ld4.c index 34f1c9cc2898..c66031bdd05a 100644 --- a/arch/arm/mach-uniphier/clk/pll-ld4.c +++ b/arch/arm/mach-uniphier/clk/pll-ld4.c @@ -21,9 +21,9 @@ static void upll_init(void) clk_mode_axosel = tmp & SG_PINMON0_CLK_MODE_AXOSEL_MASK;
/* set 0 to SNRT(UPLLCTRL.bit28) and K_LD(UPLLCTRL.bit[27]) */ - tmp = readl(SC_UPLLCTRL); + tmp = readl(sc_base + SC_UPLLCTRL); tmp &= ~0x18000000; - writel(tmp, SC_UPLLCTRL); + writel(tmp, sc_base + SC_UPLLCTRL);
if (clk_mode_upll == SG_PINMON0_CLK_MODE_UPLLSRC_DEFAULT) { if (clk_mode_axosel == SG_PINMON0_CLK_MODE_AXOSEL_25000KHZ_U || @@ -38,18 +38,18 @@ static void upll_init(void) } }
/* set 1 to K_LD(UPLLCTRL.bit[27]) */ tmp |= 0x08000000; - writel(tmp, SC_UPLLCTRL); + writel(tmp, sc_base + SC_UPLLCTRL);
/* wait 10 usec */ udelay(10);
/* set 1 to SNRT(UPLLCTRL.bit[28]) */ tmp |= 0x10000000; - writel(tmp, SC_UPLLCTRL); + writel(tmp, sc_base + SC_UPLLCTRL); }
static void vpll_init(void) @@ -60,88 +60,88 @@ static void vpll_init(void) clk_mode_axosel = tmp & SG_PINMON0_CLK_MODE_AXOSEL_MASK;
/* set 1 to VPLA27WP and VPLA27WP */ - tmp = readl(SC_VPLL27ACTRL); + tmp = readl(sc_base + SC_VPLL27ACTRL); tmp |= 0x00000001; - writel(tmp, SC_VPLL27ACTRL); - tmp = readl(SC_VPLL27BCTRL); + writel(tmp, sc_base + SC_VPLL27ACTRL); + tmp = readl(sc_base + SC_VPLL27BCTRL); tmp |= 0x00000001; - writel(tmp, SC_VPLL27BCTRL); + writel(tmp, sc_base + SC_VPLL27BCTRL);
/* Set 0 to VPLA_K_LD and VPLB_K_LD */ - tmp = readl(SC_VPLL27ACTRL3); + tmp = readl(sc_base + SC_VPLL27ACTRL3); tmp &= ~0x10000000; - writel(tmp, SC_VPLL27ACTRL3); - tmp = readl(SC_VPLL27BCTRL3); + writel(tmp, sc_base + SC_VPLL27ACTRL3); + tmp = readl(sc_base + SC_VPLL27BCTRL3); tmp &= ~0x10000000; - writel(tmp, SC_VPLL27BCTRL3); + writel(tmp, sc_base + SC_VPLL27BCTRL3);
/* Set 0 to VPLA_SNRST and VPLB_SNRST */ - tmp = readl(SC_VPLL27ACTRL2); + tmp = readl(sc_base + SC_VPLL27ACTRL2); tmp &= ~0x10000000; - writel(tmp, SC_VPLL27ACTRL2); - tmp = readl(SC_VPLL27BCTRL2); + writel(tmp, sc_base + SC_VPLL27ACTRL2); + tmp = readl(sc_base + SC_VPLL27BCTRL2); tmp &= ~0x10000000; - writel(tmp, SC_VPLL27BCTRL2); + writel(tmp, sc_base + SC_VPLL27BCTRL2);
/* Set 0x20 to VPLA_SNRST and VPLB_SNRST */ - tmp = readl(SC_VPLL27ACTRL2); + tmp = readl(sc_base + SC_VPLL27ACTRL2); tmp &= ~0x0000007f; tmp |= 0x00000020; - writel(tmp, SC_VPLL27ACTRL2); - tmp = readl(SC_VPLL27BCTRL2); + writel(tmp, sc_base + SC_VPLL27ACTRL2); + tmp = readl(sc_base + SC_VPLL27BCTRL2); tmp &= ~0x0000007f; tmp |= 0x00000020; - writel(tmp, SC_VPLL27BCTRL2); + writel(tmp, sc_base + SC_VPLL27BCTRL2);
if (clk_mode_axosel == SG_PINMON0_CLK_MODE_AXOSEL_25000KHZ_U || clk_mode_axosel == SG_PINMON0_CLK_MODE_AXOSEL_25000KHZ_A) { /* AXO: 25MHz */ - tmp = readl(SC_VPLL27ACTRL3); + tmp = readl(sc_base + SC_VPLL27ACTRL3); tmp &= ~0x000fffff; tmp |= 0x00066664; - writel(tmp, SC_VPLL27ACTRL3); - tmp = readl(SC_VPLL27BCTRL3); + writel(tmp, sc_base + SC_VPLL27ACTRL3); + tmp = readl(sc_base + SC_VPLL27BCTRL3); tmp &= ~0x000fffff; tmp |= 0x00066664; - writel(tmp, SC_VPLL27BCTRL3); + writel(tmp, sc_base + SC_VPLL27BCTRL3); } else { /* AXO: default 24.576MHz */ - tmp = readl(SC_VPLL27ACTRL3); + tmp = readl(sc_base + SC_VPLL27ACTRL3); tmp &= ~0x000fffff; tmp |= 0x000f5800; - writel(tmp, SC_VPLL27ACTRL3); - tmp = readl(SC_VPLL27BCTRL3); + writel(tmp, sc_base + SC_VPLL27ACTRL3); + tmp = readl(sc_base + SC_VPLL27BCTRL3); tmp &= ~0x000fffff; tmp |= 0x000f5800; - writel(tmp, SC_VPLL27BCTRL3); + writel(tmp, sc_base + SC_VPLL27BCTRL3); }
/* Set 1 to VPLA_K_LD and VPLB_K_LD */ - tmp = readl(SC_VPLL27ACTRL3); + tmp = readl(sc_base + SC_VPLL27ACTRL3); tmp |= 0x10000000; - writel(tmp, SC_VPLL27ACTRL3); - tmp = readl(SC_VPLL27BCTRL3); + writel(tmp, sc_base + SC_VPLL27ACTRL3); + tmp = readl(sc_base + SC_VPLL27BCTRL3); tmp |= 0x10000000; - writel(tmp, SC_VPLL27BCTRL3); + writel(tmp, sc_base + SC_VPLL27BCTRL3);
/* Set 0 to VPLA_SNRST and VPLB_SNRST */ - tmp = readl(SC_VPLL27ACTRL2); + tmp = readl(sc_base + SC_VPLL27ACTRL2); tmp |= 0x10000000; - writel(tmp, SC_VPLL27ACTRL2); - tmp = readl(SC_VPLL27BCTRL2); + writel(tmp, sc_base + SC_VPLL27ACTRL2); + tmp = readl(sc_base + SC_VPLL27BCTRL2); tmp |= 0x10000000; - writel(tmp, SC_VPLL27BCTRL2); + writel(tmp, sc_base + SC_VPLL27BCTRL2);
/* set 0 to VPLA27WP and VPLA27WP */ - tmp = readl(SC_VPLL27ACTRL); + tmp = readl(sc_base + SC_VPLL27ACTRL); tmp &= ~0x00000001; - writel(tmp, SC_VPLL27ACTRL); - tmp = readl(SC_VPLL27BCTRL); + writel(tmp, sc_base + SC_VPLL27ACTRL); + tmp = readl(sc_base + SC_VPLL27BCTRL); tmp |= ~0x00000001; - writel(tmp, SC_VPLL27BCTRL); + writel(tmp, sc_base + SC_VPLL27BCTRL); }
void uniphier_ld4_pll_init(void) diff --git a/arch/arm/mach-uniphier/clk/pll-pro4.c b/arch/arm/mach-uniphier/clk/pll-pro4.c index 312a5fcfdfcf..b7dc3e261f81 100644 --- a/arch/arm/mach-uniphier/clk/pll-pro4.c +++ b/arch/arm/mach-uniphier/clk/pll-pro4.c @@ -26,80 +26,80 @@ static void vpll_init(void) return;
/* Disable write protect of VPLL27ACTRL[2-7]*, VPLL27BCTRL[2-8] */ - tmp = readl(SC_VPLL27ACTRL); + tmp = readl(sc_base + SC_VPLL27ACTRL); tmp |= 0x00000001; - writel(tmp, SC_VPLL27ACTRL); - tmp = readl(SC_VPLL27BCTRL); + writel(tmp, sc_base + SC_VPLL27ACTRL); + tmp = readl(sc_base + SC_VPLL27BCTRL); tmp |= 0x00000001; - writel(tmp, SC_VPLL27BCTRL); + writel(tmp, sc_base + SC_VPLL27BCTRL);
/* Unset VPLA_K_LD and VPLB_K_LD bit */ - tmp = readl(SC_VPLL27ACTRL3); + tmp = readl(sc_base + SC_VPLL27ACTRL3); tmp &= ~0x10000000; - writel(tmp, SC_VPLL27ACTRL3); - tmp = readl(SC_VPLL27BCTRL3); + writel(tmp, sc_base + SC_VPLL27ACTRL3); + tmp = readl(sc_base + SC_VPLL27BCTRL3); tmp &= ~0x10000000; - writel(tmp, SC_VPLL27BCTRL3); + writel(tmp, sc_base + SC_VPLL27BCTRL3);
/* Set VPLA_M and VPLB_M to 0x20 */ - tmp = readl(SC_VPLL27ACTRL2); + tmp = readl(sc_base + SC_VPLL27ACTRL2); tmp &= ~0x0000007f; tmp |= 0x00000020; - writel(tmp, SC_VPLL27ACTRL2); - tmp = readl(SC_VPLL27BCTRL2); + writel(tmp, sc_base + SC_VPLL27ACTRL2); + tmp = readl(sc_base + SC_VPLL27BCTRL2); tmp &= ~0x0000007f; tmp |= 0x00000020; - writel(tmp, SC_VPLL27BCTRL2); + writel(tmp, sc_base + SC_VPLL27BCTRL2);
if (clk_mode_axosel == SG_PINMON0_CLK_MODE_AXOSEL_25000KHZ || clk_mode_axosel == SG_PINMON0_CLK_MODE_AXOSEL_6250KHZ) { /* Set VPLA_K and VPLB_K for AXO: 25MHz */ - tmp = readl(SC_VPLL27ACTRL3); + tmp = readl(sc_base + SC_VPLL27ACTRL3); tmp &= ~0x000fffff; tmp |= 0x00066666; - writel(tmp, SC_VPLL27ACTRL3); - tmp = readl(SC_VPLL27BCTRL3); + writel(tmp, sc_base + SC_VPLL27ACTRL3); + tmp = readl(sc_base + SC_VPLL27BCTRL3); tmp &= ~0x000fffff; tmp |= 0x00066666; - writel(tmp, SC_VPLL27BCTRL3); + writel(tmp, sc_base + SC_VPLL27BCTRL3); } else { /* Set VPLA_K and VPLB_K for AXO: 24.576 MHz */ - tmp = readl(SC_VPLL27ACTRL3); + tmp = readl(sc_base + SC_VPLL27ACTRL3); tmp &= ~0x000fffff; tmp |= 0x000f5800; - writel(tmp, SC_VPLL27ACTRL3); - tmp = readl(SC_VPLL27BCTRL3); + writel(tmp, sc_base + SC_VPLL27ACTRL3); + tmp = readl(sc_base + SC_VPLL27BCTRL3); tmp &= ~0x000fffff; tmp |= 0x000f5800; - writel(tmp, SC_VPLL27BCTRL3); + writel(tmp, sc_base + SC_VPLL27BCTRL3); }
/* wait 1 usec */ udelay(1);
/* Set VPLA_K_LD and VPLB_K_LD to load K parameters */ - tmp = readl(SC_VPLL27ACTRL3); + tmp = readl(sc_base + SC_VPLL27ACTRL3); tmp |= 0x10000000; - writel(tmp, SC_VPLL27ACTRL3); - tmp = readl(SC_VPLL27BCTRL3); + writel(tmp, sc_base + SC_VPLL27ACTRL3); + tmp = readl(sc_base + SC_VPLL27BCTRL3); tmp |= 0x10000000; - writel(tmp, SC_VPLL27BCTRL3); + writel(tmp, sc_base + SC_VPLL27BCTRL3);
/* Unset VPLA_SNRST and VPLB_SNRST bit */ - tmp = readl(SC_VPLL27ACTRL2); + tmp = readl(sc_base + SC_VPLL27ACTRL2); tmp |= 0x10000000; - writel(tmp, SC_VPLL27ACTRL2); - tmp = readl(SC_VPLL27BCTRL2); + writel(tmp, sc_base + SC_VPLL27ACTRL2); + tmp = readl(sc_base + SC_VPLL27BCTRL2); tmp |= 0x10000000; - writel(tmp, SC_VPLL27BCTRL2); + writel(tmp, sc_base + SC_VPLL27BCTRL2);
/* Enable write protect of VPLL27ACTRL[2-7]*, VPLL27BCTRL[2-8] */ - tmp = readl(SC_VPLL27ACTRL); + tmp = readl(sc_base + SC_VPLL27ACTRL); tmp &= ~0x00000001; - writel(tmp, SC_VPLL27ACTRL); - tmp = readl(SC_VPLL27BCTRL); + writel(tmp, sc_base + SC_VPLL27ACTRL); + tmp = readl(sc_base + SC_VPLL27BCTRL); tmp &= ~0x00000001; - writel(tmp, SC_VPLL27BCTRL); + writel(tmp, sc_base + SC_VPLL27BCTRL); }
void uniphier_pro4_pll_init(void) diff --git a/arch/arm/mach-uniphier/clk/pll-pxs3.c b/arch/arm/mach-uniphier/clk/pll-pxs3.c index 5a1b1d25aca6..278f530ea9a3 100644 --- a/arch/arm/mach-uniphier/clk/pll-pxs3.c +++ b/arch/arm/mach-uniphier/clk/pll-pxs3.c @@ -10,25 +10,25 @@ #include "pll.h"
/* PLL type: SSC */ -#define SC_CPLLCTRL (SC_BASE_ADDR | 0x1400) /* CPU/ARM */ -#define SC_SPLLCTRL (SC_BASE_ADDR | 0x1410) /* misc */ -#define SC_SPLL2CTRL (SC_BASE_ADDR | 0x1420) /* DSP */ -#define SC_VPPLLCTRL (SC_BASE_ADDR | 0x1430) /* VPE */ -#define SC_VGPLLCTRL (SC_BASE_ADDR | 0x1440) -#define SC_DECPLLCTRL (SC_BASE_ADDR | 0x1450) -#define SC_ENCPLLCTRL (SC_BASE_ADDR | 0x1460) -#define SC_PXFPLLCTRL (SC_BASE_ADDR | 0x1470) -#define SC_DPLL0CTRL (SC_BASE_ADDR | 0x1480) /* DDR memory 0 */ -#define SC_DPLL1CTRL (SC_BASE_ADDR | 0x1490) /* DDR memory 1 */ -#define SC_DPLL2CTRL (SC_BASE_ADDR | 0x14a0) /* DDR memory 2 */ -#define SC_VSPLLCTRL (SC_BASE_ADDR | 0x14c0) +#define SC_CPLLCTRL 0x1400 /* CPU/ARM */ +#define SC_SPLLCTRL 0x1410 /* misc */ +#define SC_SPLL2CTRL 0x1420 /* DSP */ +#define SC_VPPLLCTRL 0x1430 /* VPE */ +#define SC_VGPLLCTRL 0x1440 +#define SC_DECPLLCTRL 0x1450 +#define SC_ENCPLLCTRL 0x1460 +#define SC_PXFPLLCTRL 0x1470 +#define SC_DPLL0CTRL 0x1480 /* DDR memory 0 */ +#define SC_DPLL1CTRL 0x1490 /* DDR memory 1 */ +#define SC_DPLL2CTRL 0x14a0 /* DDR memory 2 */ +#define SC_VSPLLCTRL 0x14c0
/* PLL type: DSPLL */ -#define SC_VPLL8KCTRL (SC_BASE_ADDR | 0x1540) +#define SC_VPLL8KCTRL 0x1540
void uniphier_pxs3_pll_init(void) { diff --git a/arch/arm/mach-uniphier/debug-uart/debug-uart-ld6b.c b/arch/arm/mach-uniphier/debug-uart/debug-uart-ld6b.c index 22d2caa1099e..f64ff39c9e65 100644 --- a/arch/arm/mach-uniphier/debug-uart/debug-uart-ld6b.c +++ b/arch/arm/mach-uniphier/debug-uart/debug-uart-ld6b.c @@ -22,9 +22,9 @@ unsigned int uniphier_ld6b_debug_uart_init(void) sg_set_pinsel(115, 0, 8, 4); /* TXD1 -> TXD1 */ sg_set_pinsel(113, 2, 8, 4); /* SBO0 -> TXD2 */
- tmp = readl(SC_CLKCTRL); + tmp = readl(sc_base + SC_CLKCTRL); tmp |= SC_CLKCTRL_CEN_PERI; - writel(tmp, SC_CLKCTRL); + writel(tmp, sc_base + SC_CLKCTRL);
return DIV_ROUND_CLOSEST(UNIPHIER_LD6B_UART_CLK, 16 * CONFIG_BAUDRATE); } diff --git a/arch/arm/mach-uniphier/debug-uart/debug-uart-pro4.c b/arch/arm/mach-uniphier/debug-uart/debug-uart-pro4.c index 9017a24a1049..79c6c101e229 100644 --- a/arch/arm/mach-uniphier/debug-uart/debug-uart-pro4.c +++ b/arch/arm/mach-uniphier/debug-uart/debug-uart-pro4.c @@ -22,9 +22,9 @@ unsigned int uniphier_pro4_debug_uart_init(void)
return DIV_ROUND_CLOSEST(UNIPHIER_PRO4_UART_CLK, 16 * CONFIG_BAUDRATE); } diff --git a/arch/arm/mach-uniphier/debug-uart/debug-uart-pro5.c b/arch/arm/mach-uniphier/debug-uart/debug-uart-pro5.c index 8e4d15c2913e..ef3b383ee431 100644 --- a/arch/arm/mach-uniphier/debug-uart/debug-uart-pro5.c +++ b/arch/arm/mach-uniphier/debug-uart/debug-uart-pro5.c @@ -25,9 +25,9 @@ unsigned int uniphier_pro5_debug_uart_init(void)
return DIV_ROUND_CLOSEST(UNIPHIER_PRO5_UART_CLK, 16 * CONFIG_BAUDRATE); } diff --git a/arch/arm/mach-uniphier/debug-uart/debug-uart-pxs2.c b/arch/arm/mach-uniphier/debug-uart/debug-uart-pxs2.c index 5d50c4fa244a..ee8caad1d458 100644 --- a/arch/arm/mach-uniphier/debug-uart/debug-uart-pxs2.c +++ b/arch/arm/mach-uniphier/debug-uart/debug-uart-pxs2.c @@ -23,9 +23,9 @@ unsigned int uniphier_pxs2_debug_uart_init(void) sg_set_pinsel(113, 8, 8, 4); /* TXD2 -> TXD2 */ sg_set_pinsel(219, 8, 8, 4); /* TXD3 -> TXD3 */
return DIV_ROUND_CLOSEST(UNIPHIER_PXS2_UART_CLK, 16 * CONFIG_BAUDRATE); } diff --git a/arch/arm/mach-uniphier/reset.c b/arch/arm/mach-uniphier/reset.c index 28c95e2ce580..31685d000940 100644 --- a/arch/arm/mach-uniphier/reset.c +++ b/arch/arm/mach-uniphier/reset.c @@ -22,14 +22,14 @@ void __SECURE reset_cpu(unsigned long ignored) { u32 tmp;
- writel(5, SC_IRQTIMSET); /* default value */ + writel(5, sc_base + SC_IRQTIMSET); /* default value */
- tmp = readl(SC_SLFRSTSEL); + tmp = readl(sc_base + SC_SLFRSTSEL); tmp &= ~0x3; /* mask [1:0] */ tmp |= 0x0; /* XRST reboot */ - writel(tmp, SC_SLFRSTSEL); + writel(tmp, sc_base + SC_SLFRSTSEL);
- tmp = readl(SC_SLFRSTCTL); + tmp = readl(sc_base + SC_SLFRSTCTL); tmp |= 0x1; - writel(tmp, SC_SLFRSTCTL); + writel(tmp, sc_base + SC_SLFRSTCTL); } diff --git a/arch/arm/mach-uniphier/sc-regs.h b/arch/arm/mach-uniphier/sc-regs.h index 28de19c039c2..e43116e064bd 100644 --- a/arch/arm/mach-uniphier/sc-regs.h +++ b/arch/arm/mach-uniphier/sc-regs.h @@ -10,31 +10,36 @@ #ifndef ARCH_SC_REGS_H #define ARCH_SC_REGS_H
-#define SC_BASE_ADDR 0x61840000 +#ifndef __ASSEMBLY__ +#include <linux/compiler.h> +#define sc_base ((void __iomem *)SC_BASE) +#endif
-#define SC_DPLLCTRL (SC_BASE_ADDR | 0x1200) +#define SC_BASE 0x61840000 + +#define SC_DPLLCTRL 0x1200 #define SC_DPLLCTRL_SSC_EN (0x1 << 31) #define SC_DPLLCTRL_FOUTMODE_MASK (0xf << 16) #define SC_DPLLCTRL_SSC_RATE (0x1 << 15)
-#define SC_DPLLCTRL2 (SC_BASE_ADDR | 0x1204) +#define SC_DPLLCTRL2 0x1204 #define SC_DPLLCTRL2_NRSTDS (0x1 << 28)
-#define SC_DPLLCTRL3 (SC_BASE_ADDR | 0x1208) +#define SC_DPLLCTRL3 0x1208 #define SC_DPLLCTRL3_LPFSEL_COEF2 (0x0 << 31) #define SC_DPLLCTRL3_LPFSEL_COEF3 (0x1 << 31)
-#define SC_UPLLCTRL (SC_BASE_ADDR | 0x1210) +#define SC_UPLLCTRL 0x1210
-#define SC_VPLL27ACTRL (SC_BASE_ADDR | 0x1270) -#define SC_VPLL27ACTRL2 (SC_BASE_ADDR | 0x1274) -#define SC_VPLL27ACTRL3 (SC_BASE_ADDR | 0x1278) +#define SC_VPLL27ACTRL 0x1270 +#define SC_VPLL27ACTRL2 0x1274 +#define SC_VPLL27ACTRL3 0x1278
-#define SC_VPLL27BCTRL (SC_BASE_ADDR | 0x1290) -#define SC_VPLL27BCTRL2 (SC_BASE_ADDR | 0x1294) -#define SC_VPLL27BCTRL3 (SC_BASE_ADDR | 0x1298) +#define SC_VPLL27BCTRL 0x1290 +#define SC_VPLL27BCTRL2 0x1294 +#define SC_VPLL27BCTRL3 0x1298
-#define SC_RSTCTRL (SC_BASE_ADDR | 0x2000) +#define SC_RSTCTRL 0x2000 #define SC_RSTCTRL_NRST_USB3B0 (0x1 << 17) /* USB3 #0 bus */ #define SC_RSTCTRL_NRST_USB3C0 (0x1 << 16) /* USB3 #0 core */ #define SC_RSTCTRL_NRST_ETHER (0x1 << 12) @@ -44,14 +49,14 @@ #define SC_RSTCTRL_NRST_UMC0 (0x1 << 4) #define SC_RSTCTRL_NRST_NAND (0x1 << 2)
-#define SC_RSTCTRL2 (SC_BASE_ADDR | 0x2004) +#define SC_RSTCTRL2 0x2004 #define SC_RSTCTRL2_NRST_USB3B1 (0x1 << 17) /* USB3 #1 bus */ #define SC_RSTCTRL2_NRST_USB3C1 (0x1 << 16) /* USB3 #1 core */
-#define SC_RSTCTRL3 (SC_BASE_ADDR | 0x2008) +#define SC_RSTCTRL3 0x2008
/* Pro5 or newer */ -#define SC_RSTCTRL4 (SC_BASE_ADDR | 0x200c) +#define SC_RSTCTRL4 0x200c #define SC_RSTCTRL4_NRST_UMCSB (0x1 << 12) /* UMC system bus */ #define SC_RSTCTRL4_NRST_UMCA2 (0x1 << 10) /* UMC ch2 standby */ #define SC_RSTCTRL4_NRST_UMCA1 (0x1 << 9) /* UMC ch1 standby */ @@ -60,11 +65,11 @@ #define SC_RSTCTRL4_NRST_UMC31 (0x1 << 5) /* UMC ch1 */ #define SC_RSTCTRL4_NRST_UMC30 (0x1 << 4) /* UMC ch0 */
-#define SC_RSTCTRL5 (SC_BASE_ADDR | 0x2010) +#define SC_RSTCTRL5 0x2010
-#define SC_RSTCTRL6 (SC_BASE_ADDR | 0x2014) +#define SC_RSTCTRL6 0x2014
-#define SC_CLKCTRL (SC_BASE_ADDR | 0x2104) +#define SC_CLKCTRL 0x2104 #define SC_CLKCTRL_CEN_USB31 (0x1 << 17) /* USB3 #1 */ #define SC_CLKCTRL_CEN_USB30 (0x1 << 16) /* USB3 #0 */ #define SC_CLKCTRL_CEN_ETHER (0x1 << 12) @@ -76,15 +81,15 @@ #define SC_CLKCTRL_CEN_PERI (0x1 << 0)
/* Pro5 or newer */ -#define SC_CLKCTRL4 (SC_BASE_ADDR | 0x210c) +#define SC_CLKCTRL4 0x210c #define SC_CLKCTRL4_CEN_UMCSB (0x1 << 12) /* UMC system bus */ #define SC_CLKCTRL4_CEN_UMC2 (0x1 << 2) /* UMC ch2 */ #define SC_CLKCTRL4_CEN_UMC1 (0x1 << 1) /* UMC ch1 */ #define SC_CLKCTRL4_CEN_UMC0 (0x1 << 0) /* UMC ch0 */
/* System reset control register */ -#define SC_IRQTIMSET (SC_BASE_ADDR | 0x3000) -#define SC_SLFRSTSEL (SC_BASE_ADDR | 0x3010) -#define SC_SLFRSTCTL (SC_BASE_ADDR | 0x3014) +#define SC_IRQTIMSET 0x3000 +#define SC_SLFRSTSEL 0x3010 +#define SC_SLFRSTCTL 0x3014
#endif /* ARCH_SC_REGS_H */ diff --git a/arch/arm/mach-uniphier/sc64-regs.h b/arch/arm/mach-uniphier/sc64-regs.h index 83f34e3faf1e..1f3b41a336b3 100644 --- a/arch/arm/mach-uniphier/sc64-regs.h +++ b/arch/arm/mach-uniphier/sc64-regs.h @@ -9,28 +9,33 @@ #ifndef SC64_REGS_H #define SC64_REGS_H
-#define SC_RSTCTRL (SC_BASE_ADDR | 0x2000) -#define SC_RSTCTRL3 (SC_BASE_ADDR | 0x2008) -#define SC_RSTCTRL4 (SC_BASE_ADDR | 0x200c) -#define SC_RSTCTRL5 (SC_BASE_ADDR | 0x2010) -#define SC_RSTCTRL6 (SC_BASE_ADDR | 0x2014) -#define SC_RSTCTRL7 (SC_BASE_ADDR | 0x2018) +#define SC_BASE 0x61840000
-#define SC_CLKCTRL (SC_BASE_ADDR | 0x2100) -#define SC_CLKCTRL3 (SC_BASE_ADDR | 0x2108) -#define SC_CLKCTRL4 (SC_BASE_ADDR | 0x210c) -#define SC_CLKCTRL5 (SC_BASE_ADDR | 0x2110) -#define SC_CLKCTRL6 (SC_BASE_ADDR | 0x2114) -#define SC_CLKCTRL7 (SC_BASE_ADDR | 0x2118) +#define SC_RSTCTRL 0x2000 +#define SC_RSTCTRL3 0x2008 +#define SC_RSTCTRL4 0x200c +#define SC_RSTCTRL5 0x2010 +#define SC_RSTCTRL6 0x2014 +#define SC_RSTCTRL7 0x2018
-#define SC_CA72_GEARST (SC_BASE_ADDR | 0x8000) -#define SC_CA72_GEARSET (SC_BASE_ADDR | 0x8004) -#define SC_CA72_GEARUPD (SC_BASE_ADDR | 0x8008) -#define SC_CA53_GEARST (SC_BASE_ADDR | 0x8080) -#define SC_CA53_GEARSET (SC_BASE_ADDR | 0x8084) -#define SC_CA53_GEARUPD (SC_BASE_ADDR | 0x8088) +#define SC_CLKCTRL 0x2100 +#define SC_CLKCTRL3 0x2108 +#define SC_CLKCTRL4 0x210c +#define SC_CLKCTRL5 0x2110 +#define SC_CLKCTRL6 0x2114 +#define SC_CLKCTRL7 0x2118 + +#define SC_CA72_GEARST 0x8000 +#define SC_CA72_GEARSET 0x8004 +#define SC_CA72_GEARUPD 0x8008 +#define SC_CA53_GEARST 0x8080 +#define SC_CA53_GEARSET 0x8084 +#define SC_CA53_GEARUPD 0x8088 #define SC_CA_GEARUPD (1 << 0)
#endif /* SC64_REGS_H */
Until the last SoC, the register addresses have been hard-coded because they are always constant. For a planned new SoC, the register bases will be completely changed. I insist on supporting multiple SoCs/boards by a single defconfig (uniphier_v8_defconfig) since duplicating similar defconfig files is a maintenance burden. The base addresses must be fixed-up at run-time somehow.
Previously, the board init code identified the SoC by reading out the SG_REVISION register. This is much easier than parsing DT.
You cannot do it any more because the base address of SG will be changed. The SG_REVISION register exists to read out the SoC ID, but you never know its address before identifying the SoC. Oh well.
So, the possible solution is to parse the DT, and find out the node with "*-soc-glue" compatible string. Then, sg_base is set to the value of the "reg" property. The sc_base is set up likewise.
It is worth noting a pit-fall. Having sc_base and sg_base in the global scope will make the life easier, but the global variables are poorly supported before the relocation. In fact, the .bss section overwraps with DT. Allocating them in the .bss section would break DT. So, I gave dummy initializers to assign them in the .data section.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/mach-uniphier/Makefile | 1 + arch/arm/mach-uniphier/base-address.c | 67 +++++++++++++++++++++++++++ arch/arm/mach-uniphier/base-address.h | 18 +++++++ arch/arm/mach-uniphier/cpu-info.c | 6 +++ arch/arm/mach-uniphier/sc64-regs.h | 2 +- arch/arm/mach-uniphier/sg-regs.h | 4 ++ 6 files changed, 97 insertions(+), 1 deletion(-) create mode 100644 arch/arm/mach-uniphier/base-address.c create mode 100644 arch/arm/mach-uniphier/base-address.h
diff --git a/arch/arm/mach-uniphier/Makefile b/arch/arm/mach-uniphier/Makefile index caa79d1e53e6..115af244cd55 100644 --- a/arch/arm/mach-uniphier/Makefile +++ b/arch/arm/mach-uniphier/Makefile @@ -13,6 +13,7 @@ else obj-$(CONFIG_DISPLAY_CPUINFO) += cpu-info.o obj-y += dram_init.o obj-y += board_init.o +obj-$(CONFIG_ARCH_UNIPHIER_V8_MULTI) += base-address.o obj-$(CONFIG_BOARD_LATE_INIT) += board_late_init.o ifndef CONFIG_SYSRESET obj-y += reset.o diff --git a/arch/arm/mach-uniphier/base-address.c b/arch/arm/mach-uniphier/base-address.c new file mode 100644 index 000000000000..5ee742e363ff --- /dev/null +++ b/arch/arm/mach-uniphier/base-address.c @@ -0,0 +1,67 @@ +// SPDX-License-Identifier: GPL-2.0-only +// +// Copyright (C) 2019 Socionext Inc. +// Author: Masahiro Yamada yamada.masahiro@socionext.com + +#include <common.h> +#include <dm/of.h> +#include <fdt_support.h> +#include <linux/io.h> +#include <linux/libfdt.h> +#include <linux/sizes.h> +#include <asm/global_data.h> + +#include "base-address.h" +#include "sc64-regs.h" +#include "sg-regs.h" + +/* + * Dummy initializers are needed to allocate these to .data section instead of + * .bss section. The .bss section is unusable before relocation because the + * .bss section and DT share the same address. Without the initializers, + * DT would be broken. + */ +void __iomem *sc_base = (void *)0xdeadbeef; +void __iomem *sg_base = (void *)0xdeadbeef; + +static u64 uniphier_base_address_get(const char *compat_tail) +{ + DECLARE_GLOBAL_DATA_PTR; + const void *fdt = gd->fdt_blob; + int offset, len, i; + const char *str; + + for (offset = fdt_next_node(fdt, 0, NULL); + offset >= 0; + offset = fdt_next_node(fdt, offset, NULL)) { + for (i = 0; + (str = fdt_stringlist_get(fdt, offset, "compatible", i, &len)); + i++) { + if (!memcmp(compat_tail, + str + len - strlen(compat_tail), + strlen(compat_tail))) + return fdt_get_base_address(fdt, offset); + } + } + + return OF_BAD_ADDR; +} + +int uniphier_base_address_init(void) +{ + u64 base; + + base = uniphier_base_address_get("-soc-glue"); + if (base == OF_BAD_ADDR) + return -EINVAL; + + sg_base = ioremap(base, SZ_8K); + + base = uniphier_base_address_get("-sysctrl"); + if (base == OF_BAD_ADDR) + return -EINVAL; + + sc_base = ioremap(base, SZ_64K); + + return 0; +} diff --git a/arch/arm/mach-uniphier/base-address.h b/arch/arm/mach-uniphier/base-address.h new file mode 100644 index 000000000000..6158ce7d66a1 --- /dev/null +++ b/arch/arm/mach-uniphier/base-address.h @@ -0,0 +1,18 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ +/* + * Copyright (C) 2019 Socionext Inc. + */ + +#ifndef __UNIPHIER_BASE_ADDRESS_H +#define __UNIPHIER_BASE_ADDRESS_H + +#ifdef CONFIG_ARCH_UNIPHIER_V8_MULTI +int uniphier_base_address_init(void); +#else +static inline int uniphier_base_address_init(void) +{ + return 0; +} +#endif + +#endif /* __UNIPHIER_BASE_ADDRESS_H */ diff --git a/arch/arm/mach-uniphier/cpu-info.c b/arch/arm/mach-uniphier/cpu-info.c index 9f5f5051b318..6a7b203a44da 100644 --- a/arch/arm/mach-uniphier/cpu-info.c +++ b/arch/arm/mach-uniphier/cpu-info.c @@ -10,11 +10,17 @@ #include <linux/io.h> #include <linux/printk.h>
+#include "base-address.h" #include "soc-info.h"
int print_cpuinfo(void) { unsigned int id, model, rev, required_model = 1, required_rev = 1; + int ret; + + ret = uniphier_base_address_init(); + if (ret) + return ret;
id = uniphier_get_soc_id(); model = uniphier_get_soc_model(); diff --git a/arch/arm/mach-uniphier/sc64-regs.h b/arch/arm/mach-uniphier/sc64-regs.h index 1f3b41a336b3..fdcca232b61c 100644 --- a/arch/arm/mach-uniphier/sc64-regs.h +++ b/arch/arm/mach-uniphier/sc64-regs.h @@ -11,7 +11,7 @@
#ifndef __ASSEMBLY__ #include <linux/compiler.h> -#define sc_base ((void __iomem *)SC_BASE) +extern void __iomem *sc_base; #endif
#define SC_BASE 0x61840000 diff --git a/arch/arm/mach-uniphier/sg-regs.h b/arch/arm/mach-uniphier/sg-regs.h index cba02d1f4aee..f47d10194987 100644 --- a/arch/arm/mach-uniphier/sg-regs.h +++ b/arch/arm/mach-uniphier/sg-regs.h @@ -12,8 +12,12 @@
#ifndef __ASSEMBLY__ #include <linux/compiler.h> +#ifdef CONFIG_ARCH_UNIPHIER_V8_MULTI +extern void __iomem *sg_base; +#else #define sg_base ((void __iomem *)SG_BASE) #endif +#endif /* __ASSEMBLY__ */
/* Base Address */ #define SG_BASE 0x5f800000
Currently, dram_init() code relies on the fact the DRAM size configuration exists in the SG_MEMCONF register.
This will no longer be true for a planned new SoC, which will replace SG_MEMCONF with a different register.
Refactor the hook in a more generic way.
arch/arm/mach-uniphier/dram_init.c | 148 ++++++++++++++++------------- 1 file changed, 84 insertions(+), 64 deletions(-)
diff --git a/arch/arm/mach-uniphier/dram_init.c b/arch/arm/mach-uniphier/dram_init.c index eca340b094e6..4a75d22db540 100644 --- a/arch/arm/mach-uniphier/dram_init.c +++ b/arch/arm/mach-uniphier/dram_init.c @@ -18,73 +18,17 @@
-struct uniphier_memif_data { - unsigned int soc_id; - unsigned long sparse_ch1_base; - int have_ch2; -}; - -static const struct uniphier_memif_data uniphier_memif_data[] = { - { - .soc_id = UNIPHIER_LD4_ID, - .sparse_ch1_base = 0xc0000000, - }, - { - .soc_id = UNIPHIER_PRO4_ID, - .sparse_ch1_base = 0xa0000000, - }, - { - .soc_id = UNIPHIER_SLD8_ID, - .sparse_ch1_base = 0xc0000000, - }, - { - .soc_id = UNIPHIER_PRO5_ID, - .sparse_ch1_base = 0xc0000000, - }, - { - .soc_id = UNIPHIER_PXS2_ID, - .sparse_ch1_base = 0xc0000000, - .have_ch2 = 1, - }, - { - .soc_id = UNIPHIER_LD6B_ID, - .sparse_ch1_base = 0xc0000000, - .have_ch2 = 1, - }, - { - .soc_id = UNIPHIER_LD11_ID, - .sparse_ch1_base = 0xc0000000, - }, - { - .soc_id = UNIPHIER_LD20_ID, - .sparse_ch1_base = 0xc0000000, - .have_ch2 = 1, - }, - { - .soc_id = UNIPHIER_PXS3_ID, - .sparse_ch1_base = 0xc0000000, - .have_ch2 = 1, - }, -}; -UNIPHIER_DEFINE_SOCDATA_FUNC(uniphier_get_memif_data, uniphier_memif_data) - struct uniphier_dram_map { unsigned long base; unsigned long size; };
-static int uniphier_memconf_decode(struct uniphier_dram_map *dram_map) +static int uniphier_memconf_decode(struct uniphier_dram_map *dram_map, + unsigned long sparse_ch1_base, bool have_ch2) { - const struct uniphier_memif_data *data; unsigned long size; u32 val;
- data = uniphier_get_memif_data(); - if (!data) { - pr_err("unsupported SoC\n"); - return -EINVAL; - } - val = readl(sg_base + SG_MEMCONF);
/* set up ch0 */ @@ -120,14 +64,14 @@ static int uniphier_memconf_decode(struct uniphier_dram_map *dram_map) dram_map[1].base = dram_map[0].base + size;
if (val & SG_MEMCONF_SPARSEMEM) { - if (dram_map[1].base > data->sparse_ch1_base) { + if (dram_map[1].base > sparse_ch1_base) { pr_warn("Sparse mem is enabled, but ch0 and ch1 overlap\n"); pr_warn("Only ch0 is available\n"); dram_map[1].base = 0; return 0; }
- dram_map[1].base = data->sparse_ch1_base; + dram_map[1].base = sparse_ch1_base; }
switch (val & SG_MEMCONF_CH1_SZ_MASK) { @@ -156,7 +100,7 @@ static int uniphier_memconf_decode(struct uniphier_dram_map *dram_map)
dram_map[1].size = size;
- if (!data->have_ch2 || val & SG_MEMCONF_CH2_DISABLE) + if (!have_ch2 || val & SG_MEMCONF_CH2_DISABLE) return 0;
/* set up ch2 */ @@ -191,6 +135,80 @@ static int uniphier_memconf_decode(struct uniphier_dram_map *dram_map) return 0; }
+static int uniphier_ld4_dram_map_get(struct uniphier_dram_map dram_map[]) +{ + return uniphier_memconf_decode(dram_map, 0xc0000000, false); +} + +static int uniphier_pro4_dram_map_get(struct uniphier_dram_map dram_map[]) +{ + return uniphier_memconf_decode(dram_map, 0xa0000000, false); +} + +static int uniphier_pxs2_dram_map_get(struct uniphier_dram_map dram_map[]) +{ + return uniphier_memconf_decode(dram_map, 0xc0000000, true); +} + +struct uniphier_dram_init_data { + unsigned int soc_id; + int (*dram_map_get)(struct uniphier_dram_map dram_map[]); +}; + +static const struct uniphier_dram_init_data uniphier_dram_init_data[] = { + { + .soc_id = UNIPHIER_LD4_ID, + .dram_map_get = uniphier_ld4_dram_map_get, + }, + { + .soc_id = UNIPHIER_PRO4_ID, + .dram_map_get = uniphier_pro4_dram_map_get, + }, + { + .soc_id = UNIPHIER_SLD8_ID, + .dram_map_get = uniphier_ld4_dram_map_get, + }, + { + .soc_id = UNIPHIER_PRO5_ID, + .dram_map_get = uniphier_ld4_dram_map_get, + }, + { + .soc_id = UNIPHIER_PXS2_ID, + .dram_map_get = uniphier_pxs2_dram_map_get, + }, + { + .soc_id = UNIPHIER_LD6B_ID, + .dram_map_get = uniphier_pxs2_dram_map_get, + }, + { + .soc_id = UNIPHIER_LD11_ID, + .dram_map_get = uniphier_ld4_dram_map_get, + }, + { + .soc_id = UNIPHIER_LD20_ID, + .dram_map_get = uniphier_pxs2_dram_map_get, + }, + { + .soc_id = UNIPHIER_PXS3_ID, + .dram_map_get = uniphier_pxs2_dram_map_get, + }, +}; +UNIPHIER_DEFINE_SOCDATA_FUNC(uniphier_get_dram_init_data, + uniphier_dram_init_data) + +static int uniphier_dram_map_get(struct uniphier_dram_map *dram_map) +{ + const struct uniphier_dram_init_data *data; + + data = uniphier_get_dram_init_data(); + if (!data) { + pr_err("unsupported SoC\n"); + return -ENOTSUPP; + } + + return data->dram_map_get(dram_map); +} + int dram_init(void) { struct uniphier_dram_map dram_map[3] = {}; @@ -198,7 +216,7 @@ int dram_init(void)
gd->ram_size = 0;
- ret = uniphier_memconf_decode(dram_map); + ret = uniphier_dram_map_get(dram_map); if (ret) return ret;
@@ -249,9 +267,11 @@ int dram_init(void) int dram_init_banksize(void) { struct uniphier_dram_map dram_map[3] = {}; - int i; + int ret, i;
- uniphier_memconf_decode(dram_map); + ret = uniphier_dram_map_get(dram_map); + if (ret) + return ret;
for (i = 0; i < ARRAY_SIZE(dram_map); i++) { if (i >= ARRAY_SIZE(gd->bd->bi_dram))
Make this function work with any channel being empty.
arch/arm/mach-uniphier/dram_init.c | 10 +++++++--- 1 file changed, 7 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-uniphier/dram_init.c b/arch/arm/mach-uniphier/dram_init.c index 4a75d22db540..ab4aa93f42a6 100644 --- a/arch/arm/mach-uniphier/dram_init.c +++ b/arch/arm/mach-uniphier/dram_init.c @@ -212,6 +212,8 @@ static int uniphier_dram_map_get(struct uniphier_dram_map *dram_map) int dram_init(void) { struct uniphier_dram_map dram_map[3] = {}; + bool valid_bank_found = false; + unsigned long prev_top; int ret, i;
gd->ram_size = 0; @@ -224,15 +226,14 @@ int dram_init(void) unsigned long max_size;
if (!dram_map[i].size) - break; + continue;
/* * U-Boot relocates itself to the tail of the memory region, * but it does not expect sparse memory. We use the first * contiguous chunk here. */ - if (i > 0 && dram_map[i - 1].base + dram_map[i - 1].size < - dram_map[i].base) + if (valid_bank_found && prev_top < dram_map[i].base) break;
/* @@ -252,6 +253,9 @@ int dram_init(void) }
gd->ram_size += dram_map[i].size; + + prev_top = dram_map[i].base + dram_map[i].size; + valid_bank_found = true; }
Currently, mem_map is hard-coded, and it worked well until the last SoC. For a planned new SoC, the addresses of peripherals and DRAM will be changed. Set it up run-time.
arch/arm/mach-uniphier/arm64/mem_map.c | 10 ++++++++++ arch/arm/mach-uniphier/dram_init.c | 24 ++++++++++++++++++++---- arch/arm/mach-uniphier/init.h | 8 ++++++++ 3 files changed, 38 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-uniphier/arm64/mem_map.c b/arch/arm/mach-uniphier/arm64/mem_map.c index 35e75e2ab2d2..7653bd2d3c65 100644 --- a/arch/arm/mach-uniphier/arm64/mem_map.c +++ b/arch/arm/mach-uniphier/arm64/mem_map.c @@ -7,6 +7,8 @@ #include <linux/types.h> #include <asm/armv8/mmu.h>
+#include "../init.h" + static struct mm_region uniphier_mem_map[] = { { .virt = 0x00000000, @@ -27,3 +29,11 @@ static struct mm_region uniphier_mem_map[] = { };
struct mm_region *mem_map = uniphier_mem_map; + +void uniphier_mem_map_init(unsigned long dram_base, unsigned long dram_size) +{ + uniphier_mem_map[0].size = dram_base; + uniphier_mem_map[1].virt = dram_base; + uniphier_mem_map[1].phys = dram_base; + uniphier_mem_map[1].size = dram_size; +} diff --git a/arch/arm/mach-uniphier/dram_init.c b/arch/arm/mach-uniphier/dram_init.c index ab4aa93f42a6..970fa09ef03c 100644 --- a/arch/arm/mach-uniphier/dram_init.c +++ b/arch/arm/mach-uniphier/dram_init.c @@ -13,6 +13,7 @@ #include <linux/sizes.h> #include <asm/global_data.h>
+#include "init.h" #include "sg-regs.h" #include "soc-info.h"
@@ -271,6 +272,8 @@ int dram_init(void) int dram_init_banksize(void) { struct uniphier_dram_map dram_map[3] = {}; + unsigned long base, top; + bool valid_bank_found = false; int ret, i;
ret = uniphier_dram_map_get(dram_map); @@ -278,12 +281,25 @@ int dram_init_banksize(void) return ret;
for (i = 0; i < ARRAY_SIZE(dram_map); i++) { - if (i >= ARRAY_SIZE(gd->bd->bi_dram)) - break; + if (i < ARRAY_SIZE(gd->bd->bi_dram)) { + gd->bd->bi_dram[i].start = dram_map[i].base; + gd->bd->bi_dram[i].size = dram_map[i].size; + } + + if (!dram_map[i].size) + continue;
- gd->bd->bi_dram[i].start = dram_map[i].base; - gd->bd->bi_dram[i].size = dram_map[i].size; + if (!valid_bank_found) + base = dram_map[i].base; + top = dram_map[i].base + dram_map[i].size; + valid_bank_found = true; }
+ if (!valid_bank_found) + return -EINVAL; + + /* map all the DRAM regions */ + uniphier_mem_map_init(base, top - base); + return 0; } diff --git a/arch/arm/mach-uniphier/init.h b/arch/arm/mach-uniphier/init.h index c6b3f3656ccc..b37ab2fa508d 100644 --- a/arch/arm/mach-uniphier/init.h +++ b/arch/arm/mach-uniphier/init.h @@ -102,5 +102,13 @@ unsigned int uniphier_boot_device_raw(void); int uniphier_have_internal_stm(void); int uniphier_boot_from_backend(void); int uniphier_pin_init(const char *pinconfig_name); +#ifdef CONFIG_ARM64 +void uniphier_mem_map_init(unsigned long dram_base, unsigned long dram_size); +#else +static inline void uniphier_mem_map_init(unsigned long dram_base, + unsigned long dram_size) +{ +} +#endif
#endif /* __MACH_INIT_H */
The base address of DRAM was 0x80000000 for all the ARM SoCs of this family in the past. It will be changed to 0x20000000 for a planned new SoC. To support multiple SoCs by the single uniphier_v8_defconfig, the base must be run-time determined.
arch/arm/mach-uniphier/dram_init.c | 5 ++++- include/configs/uniphier.h | 6 ------ 2 files changed, 4 insertions(+), 7 deletions(-)
diff --git a/arch/arm/mach-uniphier/dram_init.c b/arch/arm/mach-uniphier/dram_init.c index 970fa09ef03c..13821a928831 100644 --- a/arch/arm/mach-uniphier/dram_init.c +++ b/arch/arm/mach-uniphier/dram_init.c @@ -33,7 +33,7 @@ static int uniphier_memconf_decode(struct uniphier_dram_map *dram_map, val = readl(sg_base + SG_MEMCONF);
/* set up ch0 */ - dram_map[0].base = CONFIG_SYS_SDRAM_BASE; + dram_map[0].base = 0x80000000;
switch (val & SG_MEMCONF_CH0_SZ_MASK) { case SG_MEMCONF_CH0_SZ_64M: @@ -255,6 +255,9 @@ int dram_init(void)
+ if (!valid_bank_found) + gd->ram_base = dram_map[i].base; + prev_top = dram_map[i].base + dram_map[i].size; valid_bank_found = true; } diff --git a/include/configs/uniphier.h b/include/configs/uniphier.h index 6979165260c6..46d576d54aa1 100644 --- a/include/configs/uniphier.h +++ b/include/configs/uniphier.h @@ -90,10 +90,6 @@ #define CONFIG_SYS_NAND_DATA_BASE 0x68000000 #define CONFIG_SYS_NAND_BAD_BLOCK_POS 0
-/* memtest works on */ -#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE -#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x01000000) - /* * Network Configuration */ @@ -215,8 +211,6 @@
#define CONFIG_SYS_BOOTMAPSZ 0x20000000
-#define CONFIG_SYS_SDRAM_BASE 0x80000000 - #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_TEXT_BASE)
/* only for SPL */
For consistency with a function that will be added.
arch/arm/mach-uniphier/board_late_init.c | 20 +++++++++++++------- 1 file changed, 13 insertions(+), 7 deletions(-)
diff --git a/arch/arm/mach-uniphier/board_late_init.c b/arch/arm/mach-uniphier/board_late_init.c index 86b128a91f95..37b375c01984 100644 --- a/arch/arm/mach-uniphier/board_late_init.c +++ b/arch/arm/mach-uniphier/board_late_init.c @@ -31,24 +31,25 @@ static void nand_denali_wp_disable(void) #endif }
-static int uniphier_set_fdt_file(void) +static void uniphier_set_env_fdt_file(void) { DECLARE_GLOBAL_DATA_PTR; const char *compat; char dtb_name[256]; int buf_len = sizeof(dtb_name); + int ret;
if (env_get("fdtfile")) - return 0; /* do nothing if it is already set */ + return; /* do nothing if it is already set */
compat = fdt_stringlist_get(gd->fdt_blob, 0, "compatible", 0, NULL); if (!compat) - return -EINVAL; + goto fail;
/* rip off the vendor prefix "socionext," */ compat = strchr(compat, ','); if (!compat) - return -EINVAL; + goto fail; compat++;
strncpy(dtb_name, compat, buf_len); @@ -56,7 +57,13 @@ static int uniphier_set_fdt_file(void)
strncat(dtb_name, ".dtb", buf_len);
- return env_set("fdtfile", dtb_name); + ret = env_set("fdtfile", dtb_name); + if (ret) + goto fail; + + return; +fail: + pr_warn(""fdt_file" environment variable was not set correctly\n"); }
int board_late_init(void) @@ -96,8 +103,7 @@ int board_late_init(void)
printf("\n");
- if (uniphier_set_fdt_file()) - pr_warn("fdt_file environment was not set correctly\n"); + uniphier_set_env_fdt_file();
return 0; }
The base of DRAM will be changed for the next generation SoC. To support it along with existing SoCs in the single defconfig, set 'loadaddr' at boot-time by adding the offset to the DRAM base.
CONFIG_SYS_LOAD_ADDR is still hard-coded for compilation, but the value from environment variable 'loadaddr' should be used.
arch/arm/mach-uniphier/board_late_init.c | 32 ++++++++++++++++++++++++ include/configs/uniphier.h | 4 +-- 2 files changed, 34 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-uniphier/board_late_init.c b/arch/arm/mach-uniphier/board_late_init.c index 37b375c01984..dbd1f17e832e 100644 --- a/arch/arm/mach-uniphier/board_late_init.c +++ b/arch/arm/mach-uniphier/board_late_init.c @@ -66,6 +66,36 @@ fail: pr_warn(""fdt_file" environment variable was not set correctly\n"); }
+static void uniphier_set_env_addr(const char *env, const char *offset_env) +{ + unsigned long offset = 0; + const char *str; + char *end; + int ret; + + if (env_get(env)) + return; /* do nothing if it is already set */ + + if (offset_env) { + str = env_get(offset_env); + if (!str) + goto fail; + + offset = simple_strtoul(str, &end, 16); + if (*end) + goto fail; + } + + ret = env_set_hex(env, gd->ram_base + offset); + if (ret) + goto fail; + + return; + +fail: + pr_warn(""%s" environment variable was not set correctly\n", env); +} + int board_late_init(void) { puts("MODE: "); @@ -105,5 +135,7 @@ int board_late_init(void)
+ uniphier_set_env_addr("loadaddr", "loadaddr_offset"); + return 0; } diff --git a/include/configs/uniphier.h b/include/configs/uniphier.h index 46d576d54aa1..6d3d9b318881 100644 --- a/include/configs/uniphier.h +++ b/include/configs/uniphier.h @@ -98,8 +98,7 @@ #define CONFIG_GATEWAYIP 192.168.11.1 #define CONFIG_NETMASK 255.255.255.0
-#define CONFIG_LOADADDR 0x85000000 -#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR +#define CONFIG_SYS_LOAD_ADDR 0x85000000 #define CONFIG_SYS_BOOTM_LEN (32 << 20)
#if defined(CONFIG_ARM64) @@ -158,6 +157,7 @@ #define CONFIG_EXTRA_ENV_SETTINGS \ "netdev=eth0\0" \ "initrd_high=0xffffffffffffffff\0" \ + "loadaddr_offset=0x05000000\0" \ "script=boot.scr\0" \ "scriptaddr=0x85000000\0" \ "nor_base=0x42000000\0" \
Set the base address to the 'dram_base' environment variable, which will be useful for scripting.
arch/arm/mach-uniphier/board_late_init.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/mach-uniphier/board_late_init.c b/arch/arm/mach-uniphier/board_late_init.c index dbd1f17e832e..4701a2892379 100644 --- a/arch/arm/mach-uniphier/board_late_init.c +++ b/arch/arm/mach-uniphier/board_late_init.c @@ -135,6 +135,8 @@ int board_late_init(void)
+ uniphier_set_env_addr("dram_base", NULL); + uniphier_set_env_addr("loadaddr", "loadaddr_offset");
The base of DRAM will be changed for the next generation SoC. The addresses needed for booting the kernel should be shifted according to the DRAM base.
arch/arm/mach-uniphier/board_late_init.c | 4 ++++ include/configs/uniphier.h | 14 +++++++------- 2 files changed, 11 insertions(+), 7 deletions(-)
diff --git a/arch/arm/mach-uniphier/board_late_init.c b/arch/arm/mach-uniphier/board_late_init.c index 4701a2892379..3180b24330b4 100644 --- a/arch/arm/mach-uniphier/board_late_init.c +++ b/arch/arm/mach-uniphier/board_late_init.c @@ -139,5 +139,9 @@ int board_late_init(void)
+ uniphier_set_env_addr("kernel_addr_r", "kernel_addr_r_offset"); + uniphier_set_env_addr("ramdisk_addr_r", "ramdisk_addr_r_offset"); + uniphier_set_env_addr("fdt_addr_r", "fdt_addr_r_offset"); + return 0; } diff --git a/include/configs/uniphier.h b/include/configs/uniphier.h index 6d3d9b318881..68568f412245 100644 --- a/include/configs/uniphier.h +++ b/include/configs/uniphier.h @@ -121,8 +121,8 @@
#ifdef CONFIG_FIT #define CONFIG_BOOTFILE "fitImage" +#define KERNEL_ADDR_R_OFFSET "0x05100000" #define LINUXBOOT_ENV_SETTINGS \ - "kernel_addr_r=0x85100000\0" \ "tftpboot=tftpboot $kernel_addr_r $bootfile &&" \ "bootm $kernel_addr_r\0" \ "__nfsboot=run tftpboot\0" @@ -130,17 +130,13 @@ #ifdef CONFIG_ARM64 #define CONFIG_BOOTFILE "Image" #define LINUXBOOT_CMD "booti" -#define KERNEL_ADDR_R "kernel_addr_r=0x82080000\0" +#define KERNEL_ADDR_R_OFFSET "0x02080000" #else #define CONFIG_BOOTFILE "zImage" #define LINUXBOOT_CMD "bootz" -#define KERNEL_ADDR_R "kernel_addr_r=0x80208000\0" +#define KERNEL_ADDR_R_OFFSET "0x00208000" #endif #define LINUXBOOT_ENV_SETTINGS \ - "fdt_addr_r=0x85100000\0" \ - KERNEL_ADDR_R \ - "ramdisk_addr_r=0x86000000\0" \ - "ramdisk_file=rootfs.cpio.gz\0" \ "boot_common=setexpr bootm_low $kernel_addr_r '&' fe000000 && " \ LINUXBOOT_CMD " $kernel_addr_r $ramdisk_addr_r $fdt_addr_r\0" \ "tftpboot=tftpboot $kernel_addr_r $bootfile && " \ @@ -155,6 +151,10 @@ #endif
#define CONFIG_EXTRA_ENV_SETTINGS \ + "fdt_addr_r_offset=0x05100000\0" \ + "kernel_addr_r_offset=" KERNEL_ADDR_R_OFFSET "\0" \ + "ramdisk_addr_r_offset=0x06000000\0" \ + "ramdisk_file=rootfs.cpio.gz\0" \ "netdev=eth0\0" \ "initrd_high=0xffffffffffffffff\0" \ "loadaddr_offset=0x05000000\0" \
Masahiro Yamada
