[U-Boot-Users] 8540 and L1 cache mapping
Recently I have been studying the boot sequence for the 8540 based boards in U-Boot. I have a question on the location of the initial C stack.
As I understand it,
cpu/mpc85xx/start.S
uses L1 data cache as the location for the C stack prior to the relocation into RAM.
CFG_INIT_RAM_ADDR is defined within the relevant config file for each 6540 based board.
I see in the 8540 User Manual that there is a register which can be used to position L2 cache in physical address space but there does not appear to be a similar register for L1 cache.
However, I see that in the init.S files, for each board, entries are placed into TLB0 for memory at address CFG_INIT_RAM_ADDR. This is declared as cacheable and non-garded.
Am I correct in thinking that this is all that is required to position the C run-time stack in L1 D-cache ?
Thanks,
Charles.
-------------------------------------------------------------------------- Dr Charles J Gillan The Institute of Electronics, Communications and Information Technology (ECIT), Queen's University Belfast, Titanic Quarter Queens Road, Queens Island, Belfast, BT3 9DT Northern Ireland, UK Tel: +44 (0) 2890 971847 Fax: +44 (0) 2890 971702 ---------------------------------------------------------------------------
As I understand it,
cpu/mpc85xx/start.S
CFG_INIT_RAM_ADDR is defined within the relevant "config" file for each 6540 based board.
That should be it. We decided to use the L1 cache and lock lines into it for the initial C stack since we know that the L1 cache would always be there on an e500 core and were not sure if the L2 would be available.
- kumar
Charles J Gillan
Kumar Gala
