[PATCH] ARM: dts: renesas: Drop DTs with OF_UPSTREAM counterparts
Remove DTs which are now replaced by OF_UPSTREAM counterparts. No functional change expected.
Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- Cc: "Cogent Embedded, Inc." source@cogentembedded.com Cc: Adam Ford aford173@gmail.com Cc: Hai Pham hai.pham.ud@renesas.com Cc: Masakazu Mochizuki masakazu.mochizuki.wd@hitachi.com Cc: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com Cc: Tam Nguyen tam.nguyen.xa@renesas.com Cc: Tom Rini trini@konsulko.com --- arch/arm/dts/Makefile | 34 - arch/arm/dts/r8a774a1-beacon-rzg2m-kit.dts | 60 - arch/arm/dts/r8a774a1-hihope-rzg2m-ex.dts | 21 - arch/arm/dts/r8a774a1-hihope-rzg2m.dts | 37 - arch/arm/dts/r8a774a1.dtsi | 2865 -------------- arch/arm/dts/r8a774b1-beacon-rzg2n-kit.dts | 56 - arch/arm/dts/r8a774b1-hihope-rzg2n-ex.dts | 21 - arch/arm/dts/r8a774b1-hihope-rzg2n.dts | 41 - arch/arm/dts/r8a774b1.dtsi | 2716 ------------- arch/arm/dts/r8a774c0-cat874.dts | 455 --- arch/arm/dts/r8a774c0-ek874.dts | 14 - arch/arm/dts/r8a774c0.dtsi | 2000 ---------- arch/arm/dts/r8a774e1-beacon-rzg2h-kit.dts | 61 - arch/arm/dts/r8a774e1-hihope-rzg2h-ex.dts | 20 - arch/arm/dts/r8a774e1-hihope-rzg2h.dts | 41 - arch/arm/dts/r8a774e1.dtsi | 2997 -------------- arch/arm/dts/r8a7790-lager.dts | 947 ----- arch/arm/dts/r8a7790-stout.dts | 382 -- arch/arm/dts/r8a7790.dtsi | 1965 ---------- arch/arm/dts/r8a7791-koelsch.dts | 912 ----- arch/arm/dts/r8a7791-porter.dts | 523 --- arch/arm/dts/r8a7791.dtsi | 1891 --------- arch/arm/dts/r8a7792-blanche.dts | 364 -- arch/arm/dts/r8a7792.dtsi | 928 ----- arch/arm/dts/r8a7793-gose.dts | 818 ---- arch/arm/dts/r8a7793.dtsi | 1470 ------- arch/arm/dts/r8a7794-alt.dts | 533 --- arch/arm/dts/r8a7794-silk.dts | 578 --- arch/arm/dts/r8a7794.dtsi | 1437 ------- arch/arm/dts/r8a77950-salvator-x.dts | 49 - arch/arm/dts/r8a77950-ulcb.dts | 37 - arch/arm/dts/r8a77950.dtsi | 330 -- arch/arm/dts/r8a77951.dtsi | 3485 ----------------- arch/arm/dts/r8a77960-salvator-x.dts | 37 - arch/arm/dts/r8a77960-ulcb.dts | 38 - arch/arm/dts/r8a77960.dtsi | 3080 --------------- arch/arm/dts/r8a77965-salvator-x.dts | 32 - arch/arm/dts/r8a77965-ulcb.dts | 33 - arch/arm/dts/r8a77965.dtsi | 2889 -------------- arch/arm/dts/r8a77970-eagle.dts | 405 -- arch/arm/dts/r8a77970-v3msk.dts | 303 -- arch/arm/dts/r8a77970.dtsi | 1220 ------ arch/arm/dts/r8a77980-condor.dts | 24 - arch/arm/dts/r8a77980-v3hsk.dts | 293 -- arch/arm/dts/r8a77980.dtsi | 1625 -------- arch/arm/dts/r8a77990-ebisu.dts | 15 - arch/arm/dts/r8a77990.dtsi | 2154 ---------- arch/arm/dts/r8a77995-draak.dts | 16 - arch/arm/dts/r8a77995.dtsi | 1473 ------- arch/arm/dts/r8a779a0-falcon-cpu.dtsi | 359 -- arch/arm/dts/r8a779a0-falcon-csi-dsi.dtsi | 270 -- arch/arm/dts/r8a779a0-falcon-ethernet.dtsi | 15 - arch/arm/dts/r8a779a0-falcon.dts | 101 - arch/arm/dts/r8a779a0.dtsi | 2915 -------------- arch/arm/dts/r8a779f0-spider-cpu.dtsi | 210 - arch/arm/dts/r8a779f0-spider-ethernet.dtsi | 105 - arch/arm/dts/r8a779f0-spider.dts | 24 - arch/arm/dts/r8a779f0.dtsi | 1193 ------ arch/arm/dts/r8a779g0-white-hawk-cpu.dtsi | 375 -- arch/arm/dts/r8a779g0-white-hawk-csi-dsi.dtsi | 187 - .../arm/dts/r8a779g0-white-hawk-ethernet.dtsi | 16 - arch/arm/dts/r8a779g0-white-hawk.dts | 69 - arch/arm/dts/r8a779g0.dtsi | 2349 ----------- 63 files changed, 49913 deletions(-) delete mode 100644 arch/arm/dts/r8a774a1-beacon-rzg2m-kit.dts delete mode 100644 arch/arm/dts/r8a774a1-hihope-rzg2m-ex.dts delete mode 100644 arch/arm/dts/r8a774a1-hihope-rzg2m.dts delete mode 100644 arch/arm/dts/r8a774a1.dtsi delete mode 100644 arch/arm/dts/r8a774b1-beacon-rzg2n-kit.dts delete mode 100644 arch/arm/dts/r8a774b1-hihope-rzg2n-ex.dts delete mode 100644 arch/arm/dts/r8a774b1-hihope-rzg2n.dts delete mode 100644 arch/arm/dts/r8a774b1.dtsi delete mode 100644 arch/arm/dts/r8a774c0-cat874.dts delete mode 100644 arch/arm/dts/r8a774c0-ek874.dts delete mode 100644 arch/arm/dts/r8a774c0.dtsi delete mode 100644 arch/arm/dts/r8a774e1-beacon-rzg2h-kit.dts delete mode 100644 arch/arm/dts/r8a774e1-hihope-rzg2h-ex.dts delete mode 100644 arch/arm/dts/r8a774e1-hihope-rzg2h.dts delete mode 100644 arch/arm/dts/r8a774e1.dtsi delete mode 100644 arch/arm/dts/r8a7790-lager.dts delete mode 100644 arch/arm/dts/r8a7790-stout.dts delete mode 100644 arch/arm/dts/r8a7790.dtsi delete mode 100644 arch/arm/dts/r8a7791-koelsch.dts delete mode 100644 arch/arm/dts/r8a7791-porter.dts delete mode 100644 arch/arm/dts/r8a7791.dtsi delete mode 100644 arch/arm/dts/r8a7792-blanche.dts delete mode 100644 arch/arm/dts/r8a7792.dtsi delete mode 100644 arch/arm/dts/r8a7793-gose.dts delete mode 100644 arch/arm/dts/r8a7793.dtsi delete mode 100644 arch/arm/dts/r8a7794-alt.dts delete mode 100644 arch/arm/dts/r8a7794-silk.dts delete mode 100644 arch/arm/dts/r8a7794.dtsi delete mode 100644 arch/arm/dts/r8a77950-salvator-x.dts delete mode 100644 arch/arm/dts/r8a77950-ulcb.dts delete mode 100644 arch/arm/dts/r8a77950.dtsi delete mode 100644 arch/arm/dts/r8a77951.dtsi delete mode 100644 arch/arm/dts/r8a77960-salvator-x.dts delete mode 100644 arch/arm/dts/r8a77960-ulcb.dts delete mode 100644 arch/arm/dts/r8a77960.dtsi delete mode 100644 arch/arm/dts/r8a77965-salvator-x.dts delete mode 100644 arch/arm/dts/r8a77965-ulcb.dts delete mode 100644 arch/arm/dts/r8a77965.dtsi delete mode 100644 arch/arm/dts/r8a77970-eagle.dts delete mode 100644 arch/arm/dts/r8a77970-v3msk.dts delete mode 100644 arch/arm/dts/r8a77970.dtsi delete mode 100644 arch/arm/dts/r8a77980-condor.dts delete mode 100644 arch/arm/dts/r8a77980-v3hsk.dts delete mode 100644 arch/arm/dts/r8a77980.dtsi delete mode 100644 arch/arm/dts/r8a77990-ebisu.dts delete mode 100644 arch/arm/dts/r8a77990.dtsi delete mode 100644 arch/arm/dts/r8a77995-draak.dts delete mode 100644 arch/arm/dts/r8a77995.dtsi delete mode 100644 arch/arm/dts/r8a779a0-falcon-cpu.dtsi delete mode 100644 arch/arm/dts/r8a779a0-falcon-csi-dsi.dtsi delete mode 100644 arch/arm/dts/r8a779a0-falcon-ethernet.dtsi delete mode 100644 arch/arm/dts/r8a779a0-falcon.dts delete mode 100644 arch/arm/dts/r8a779a0.dtsi delete mode 100644 arch/arm/dts/r8a779f0-spider-cpu.dtsi delete mode 100644 arch/arm/dts/r8a779f0-spider-ethernet.dtsi delete mode 100644 arch/arm/dts/r8a779f0-spider.dts delete mode 100644 arch/arm/dts/r8a779f0.dtsi delete mode 100644 arch/arm/dts/r8a779g0-white-hawk-cpu.dtsi delete mode 100644 arch/arm/dts/r8a779g0-white-hawk-csi-dsi.dtsi delete mode 100644 arch/arm/dts/r8a779g0-white-hawk-ethernet.dtsi delete mode 100644 arch/arm/dts/r8a779g0-white-hawk.dts delete mode 100644 arch/arm/dts/r8a779g0.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 0c6f0221b77..f1d22ee7cf2 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1050,41 +1050,7 @@ dtb-$(CONFIG_ARCH_IMXRT) += imxrt1050-evk.dtb \ imxrt1020-evk.dtb \ imxrt1170-evk.dtb \
-dtb-$(CONFIG_RCAR_GEN2) += \ - r8a7790-lager.dtb \ - r8a7790-stout.dtb \ - r8a7791-koelsch.dtb \ - r8a7791-porter.dtb \ - r8a7792-blanche.dtb \ - r8a7793-gose.dtb \ - r8a7794-alt.dtb \ - r8a7794-silk.dtb - -dtb-$(CONFIG_RCAR_GEN3) += \ - r8a774a1-beacon-rzg2m-kit.dtb \ - r8a774b1-beacon-rzg2n-kit.dtb \ - r8a774e1-beacon-rzg2h-kit.dtb \ - r8a774a1-hihope-rzg2m.dtb \ - r8a774b1-hihope-rzg2n.dtb \ - r8a774c0-ek874.dtb \ - r8a774e1-hihope-rzg2h.dtb \ - r8a77951-ulcb.dtb \ - r8a77951-salvator-x.dtb \ - r8a77960-ulcb.dtb \ - r8a77960-salvator-x.dtb \ - r8a77965-ulcb.dtb \ - r8a77965-salvator-x.dtb \ - r8a77970-eagle.dtb \ - r8a77970-v3msk.dtb \ - r8a77980-condor.dtb \ - r8a77980-v3hsk.dtb \ - r8a77990-ebisu.dtb \ - r8a77995-draak.dtb - dtb-$(CONFIG_RCAR_GEN4) += \ - r8a779a0-falcon.dtb \ - r8a779f0-spider.dtb \ - r8a779g0-white-hawk.dtb \ r8a779h0-gray-hawk.dtb
dtb-$(CONFIG_TARGET_RZG2L) += \ diff --git a/arch/arm/dts/r8a774a1-beacon-rzg2m-kit.dts b/arch/arm/dts/r8a774a1-beacon-rzg2m-kit.dts deleted file mode 100644 index 24da6ee6ecc..00000000000 --- a/arch/arm/dts/r8a774a1-beacon-rzg2m-kit.dts +++ /dev/null @@ -1,60 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Copyright 2020, Compass Electronics Group, LLC - */ - -/dts-v1/; - -#include "r8a774a1.dtsi" -#include "beacon-renesom-som.dtsi" -#include "beacon-renesom-baseboard.dtsi" - -/ { - model = "Beacon EmbeddedWorks RZ/G2M Development Kit"; - compatible = "beacon,beacon-rzg2m", "renesas,r8a774a1"; - - aliases { - i2c0 = &i2c0; - i2c1 = &i2c1; - i2c2 = &i2c2; - i2c3 = &i2c3; - i2c4 = &i2c4; - i2c5 = &i2c5; - i2c6 = &i2c6; - i2c7 = &iic_pmic; - serial0 = &scif2; - serial1 = &hscif0; - serial2 = &hscif1; - serial3 = &scif0; - serial4 = &hscif2; - serial5 = &scif5; - ethernet0 = &avb; - mmc0 = &sdhi3; - mmc1 = &sdhi0; - mmc2 = &sdhi2; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - memory@600000000 { - device_type = "memory"; - reg = <0x6 0x00000000 0x0 0x80000000>; - }; -}; - -&du { - pinctrl-0 = <&du_pins>; - pinctrl-names = "default"; - status = "okay"; - - clocks = <&cpg CPG_MOD 724>, - <&cpg CPG_MOD 723>, - <&cpg CPG_MOD 722>, - <&versaclock5 1>, - <&x302_clk>, - <&versaclock5 2>; - clock-names = "du.0", "du.1", "du.2", - "dclkin.0", "dclkin.1", "dclkin.2"; -}; diff --git a/arch/arm/dts/r8a774a1-hihope-rzg2m-ex.dts b/arch/arm/dts/r8a774a1-hihope-rzg2m-ex.dts deleted file mode 100644 index a5ca86196a7..00000000000 --- a/arch/arm/dts/r8a774a1-hihope-rzg2m-ex.dts +++ /dev/null @@ -1,21 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the HiHope RZ/G2M Rev.3.0/4.0 connected to - * sub board - * - * Copyright (C) 2020 Renesas Electronics Corp. - */ - -#include "r8a774a1-hihope-rzg2m.dts" -#include "hihope-rzg2-ex.dtsi" - -/ { - model = "HopeRun HiHope RZ/G2M with sub board"; - compatible = "hoperun,hihope-rzg2-ex", "hoperun,hihope-rzg2m", - "renesas,r8a774a1"; -}; - -/* SW43 should be OFF, if in ON state SATA port will be activated */ -&pciec1 { - status = "okay"; -}; diff --git a/arch/arm/dts/r8a774a1-hihope-rzg2m.dts b/arch/arm/dts/r8a774a1-hihope-rzg2m.dts deleted file mode 100644 index 25ae255de0f..00000000000 --- a/arch/arm/dts/r8a774a1-hihope-rzg2m.dts +++ /dev/null @@ -1,37 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the HiHope RZ/G2M Rev.3.0/4.0 main board - * - * Copyright (C) 2020 Renesas Electronics Corp. - */ - -/dts-v1/; -#include "r8a774a1.dtsi" -#include "hihope-rev4.dtsi" - -/ { - model = "HopeRun HiHope RZ/G2M main board based on r8a774a1"; - compatible = "hoperun,hihope-rzg2m", "renesas,r8a774a1"; - - memory@48000000 { - device_type = "memory"; - /* first 128MB is reserved for secure area. */ - reg = <0x0 0x48000000 0x0 0x78000000>; - }; - - memory@600000000 { - device_type = "memory"; - reg = <0x6 0x00000000 0x0 0x80000000>; - }; -}; - -&du { - clocks = <&cpg CPG_MOD 724>, - <&cpg CPG_MOD 723>, - <&cpg CPG_MOD 722>, - <&versaclock5 1>, - <&x302_clk>, - <&versaclock5 2>; - clock-names = "du.0", "du.1", "du.2", - "dclkin.0", "dclkin.1", "dclkin.2"; -}; diff --git a/arch/arm/dts/r8a774a1.dtsi b/arch/arm/dts/r8a774a1.dtsi deleted file mode 100644 index 9065dc24342..00000000000 --- a/arch/arm/dts/r8a774a1.dtsi +++ /dev/null @@ -1,2865 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the r8a774a1 SoC - * - * Copyright (C) 2018 Renesas Electronics Corp. - */ - -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/clock/r8a774a1-cpg-mssr.h> -#include <dt-bindings/power/r8a774a1-sysc.h> - -#define CPG_AUDIO_CLK_I R8A774A1_CLK_S0D4 - -/ { - compatible = "renesas,r8a774a1"; - #address-cells = <2>; - #size-cells = <2>; - - /* - * The external audio clocks are configured as 0 Hz fixed frequency - * clocks by default. - * Boards that provide audio clocks should override them. - */ - audio_clk_a: audio_clk_a { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - audio_clk_b: audio_clk_b { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - audio_clk_c: audio_clk_c { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - /* External CAN clock - to be overridden by boards that provide it */ - can_clk: can { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - cluster0_opp: opp-table-0 { - compatible = "operating-points-v2"; - opp-shared; - - opp-500000000 { - opp-hz = /bits/ 64 <500000000>; - opp-microvolt = <820000>; - clock-latency-ns = <300000>; - }; - opp-1000000000 { - opp-hz = /bits/ 64 <1000000000>; - opp-microvolt = <820000>; - clock-latency-ns = <300000>; - }; - opp-1500000000 { - opp-hz = /bits/ 64 <1500000000>; - opp-microvolt = <820000>; - clock-latency-ns = <300000>; - opp-suspend; - }; - }; - - cluster1_opp: opp-table-1 { - compatible = "operating-points-v2"; - opp-shared; - - opp-800000000 { - opp-hz = /bits/ 64 <800000000>; - opp-microvolt = <820000>; - clock-latency-ns = <300000>; - }; - opp-1000000000 { - opp-hz = /bits/ 64 <1000000000>; - opp-microvolt = <820000>; - clock-latency-ns = <300000>; - }; - opp-1200000000 { - opp-hz = /bits/ 64 <1200000000>; - opp-microvolt = <820000>; - clock-latency-ns = <300000>; - }; - }; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - - cpu-map { - cluster0 { - core0 { - cpu = <&a57_0>; - }; - core1 { - cpu = <&a57_1>; - }; - }; - - cluster1 { - core0 { - cpu = <&a53_0>; - }; - core1 { - cpu = <&a53_1>; - }; - core2 { - cpu = <&a53_2>; - }; - core3 { - cpu = <&a53_3>; - }; - }; - }; - - a57_0: cpu@0 { - compatible = "arm,cortex-a57"; - reg = <0x0>; - device_type = "cpu"; - power-domains = <&sysc R8A774A1_PD_CA57_CPU0>; - next-level-cache = <&L2_CA57>; - enable-method = "psci"; - dynamic-power-coefficient = <854>; - clocks = <&cpg CPG_CORE R8A774A1_CLK_Z>; - operating-points-v2 = <&cluster0_opp>; - capacity-dmips-mhz = <1024>; - #cooling-cells = <2>; - }; - - a57_1: cpu@1 { - compatible = "arm,cortex-a57"; - reg = <0x1>; - device_type = "cpu"; - power-domains = <&sysc R8A774A1_PD_CA57_CPU1>; - next-level-cache = <&L2_CA57>; - enable-method = "psci"; - clocks = <&cpg CPG_CORE R8A774A1_CLK_Z>; - operating-points-v2 = <&cluster0_opp>; - capacity-dmips-mhz = <1024>; - #cooling-cells = <2>; - }; - - a53_0: cpu@100 { - compatible = "arm,cortex-a53"; - reg = <0x100>; - device_type = "cpu"; - power-domains = <&sysc R8A774A1_PD_CA53_CPU0>; - next-level-cache = <&L2_CA53>; - enable-method = "psci"; - #cooling-cells = <2>; - dynamic-power-coefficient = <277>; - clocks = <&cpg CPG_CORE R8A774A1_CLK_Z2>; - operating-points-v2 = <&cluster1_opp>; - capacity-dmips-mhz = <560>; - }; - - a53_1: cpu@101 { - compatible = "arm,cortex-a53"; - reg = <0x101>; - device_type = "cpu"; - power-domains = <&sysc R8A774A1_PD_CA53_CPU1>; - next-level-cache = <&L2_CA53>; - enable-method = "psci"; - clocks = <&cpg CPG_CORE R8A774A1_CLK_Z2>; - operating-points-v2 = <&cluster1_opp>; - capacity-dmips-mhz = <560>; - }; - - a53_2: cpu@102 { - compatible = "arm,cortex-a53"; - reg = <0x102>; - device_type = "cpu"; - power-domains = <&sysc R8A774A1_PD_CA53_CPU2>; - next-level-cache = <&L2_CA53>; - enable-method = "psci"; - clocks = <&cpg CPG_CORE R8A774A1_CLK_Z2>; - operating-points-v2 = <&cluster1_opp>; - capacity-dmips-mhz = <560>; - }; - - a53_3: cpu@103 { - compatible = "arm,cortex-a53"; - reg = <0x103>; - device_type = "cpu"; - power-domains = <&sysc R8A774A1_PD_CA53_CPU3>; - next-level-cache = <&L2_CA53>; - enable-method = "psci"; - clocks = <&cpg CPG_CORE R8A774A1_CLK_Z2>; - operating-points-v2 = <&cluster1_opp>; - capacity-dmips-mhz = <560>; - }; - - L2_CA57: cache-controller-0 { - compatible = "cache"; - power-domains = <&sysc R8A774A1_PD_CA57_SCU>; - cache-unified; - cache-level = <2>; - }; - - L2_CA53: cache-controller-1 { - compatible = "cache"; - power-domains = <&sysc R8A774A1_PD_CA53_SCU>; - cache-unified; - cache-level = <2>; - }; - }; - - extal_clk: extal { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board */ - clock-frequency = <0>; - }; - - extalr_clk: extalr { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board */ - clock-frequency = <0>; - }; - - /* External PCIe clock - can be overridden by the board */ - pcie_bus_clk: pcie_bus { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - pmu_a53 { - compatible = "arm,cortex-a53-pmu"; - interrupts-extended = <&gic GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&a53_0>, <&a53_1>, <&a53_2>, <&a53_3>; - }; - - pmu_a57 { - compatible = "arm,cortex-a57-pmu"; - interrupts-extended = <&gic GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&a57_0>, <&a57_1>; - }; - - psci { - compatible = "arm,psci-1.0", "arm,psci-0.2"; - method = "smc"; - }; - - /* External SCIF clock - to be overridden by boards that provide it */ - scif_clk: scif { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - soc { - compatible = "simple-bus"; - interrupt-parent = <&gic>; - #address-cells = <2>; - #size-cells = <2>; - ranges; - - rwdt: watchdog@e6020000 { - compatible = "renesas,r8a774a1-wdt", - "renesas,rcar-gen3-wdt"; - reg = <0 0xe6020000 0 0x0c>; - interrupts = <GIC_SPI 140 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 402>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 402>; - status = "disabled"; - }; - - gpio0: gpio@e6050000 { - compatible = "renesas,gpio-r8a774a1", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6050000 0 0x50>; - interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 0 16>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 912>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 912>; - }; - - gpio1: gpio@e6051000 { - compatible = "renesas,gpio-r8a774a1", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6051000 0 0x50>; - interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 32 29>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 911>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 911>; - }; - - gpio2: gpio@e6052000 { - compatible = "renesas,gpio-r8a774a1", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6052000 0 0x50>; - interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 64 15>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 910>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 910>; - }; - - gpio3: gpio@e6053000 { - compatible = "renesas,gpio-r8a774a1", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6053000 0 0x50>; - interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 96 16>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 909>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 909>; - }; - - gpio4: gpio@e6054000 { - compatible = "renesas,gpio-r8a774a1", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6054000 0 0x50>; - interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 128 18>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 908>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 908>; - }; - - gpio5: gpio@e6055000 { - compatible = "renesas,gpio-r8a774a1", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6055000 0 0x50>; - interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 160 26>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 907>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 907>; - }; - - gpio6: gpio@e6055400 { - compatible = "renesas,gpio-r8a774a1", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6055400 0 0x50>; - interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 192 32>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 906>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 906>; - }; - - gpio7: gpio@e6055800 { - compatible = "renesas,gpio-r8a774a1", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6055800 0 0x50>; - interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 224 4>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 905>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 905>; - }; - - pfc: pinctrl@e6060000 { - compatible = "renesas,pfc-r8a774a1"; - reg = <0 0xe6060000 0 0x50c>; - }; - - cmt0: timer@e60f0000 { - compatible = "renesas,r8a774a1-cmt0", - "renesas,rcar-gen3-cmt0"; - reg = <0 0xe60f0000 0 0x1004>; - interrupts = <GIC_SPI 142 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 143 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 303>; - clock-names = "fck"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 303>; - status = "disabled"; - }; - - cmt1: timer@e6130000 { - compatible = "renesas,r8a774a1-cmt1", - "renesas,rcar-gen3-cmt1"; - reg = <0 0xe6130000 0 0x1004>; - interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 127 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 302>; - clock-names = "fck"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 302>; - status = "disabled"; - }; - - cmt2: timer@e6140000 { - compatible = "renesas,r8a774a1-cmt1", - "renesas,rcar-gen3-cmt1"; - reg = <0 0xe6140000 0 0x1004>; - interrupts = <GIC_SPI 398 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 399 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 400 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 401 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 402 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 403 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 404 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 405 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 301>; - clock-names = "fck"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 301>; - status = "disabled"; - }; - - cmt3: timer@e6148000 { - compatible = "renesas,r8a774a1-cmt1", - "renesas,rcar-gen3-cmt1"; - reg = <0 0xe6148000 0 0x1004>; - interrupts = <GIC_SPI 470 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 471 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 472 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 473 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 474 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 475 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 476 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 477 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 300>; - clock-names = "fck"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 300>; - status = "disabled"; - }; - - cpg: clock-controller@e6150000 { - compatible = "renesas,r8a774a1-cpg-mssr"; - reg = <0 0xe6150000 0 0x0bb0>; - clocks = <&extal_clk>, <&extalr_clk>; - clock-names = "extal", "extalr"; - #clock-cells = <2>; - #power-domain-cells = <0>; - #reset-cells = <1>; - }; - - rst: reset-controller@e6160000 { - compatible = "renesas,r8a774a1-rst"; - reg = <0 0xe6160000 0 0x018c>; - }; - - sysc: system-controller@e6180000 { - compatible = "renesas,r8a774a1-sysc"; - reg = <0 0xe6180000 0 0x0400>; - #power-domain-cells = <1>; - }; - - tsc: thermal@e6198000 { - compatible = "renesas,r8a774a1-thermal"; - reg = <0 0xe6198000 0 0x100>, - <0 0xe61a0000 0 0x100>, - <0 0xe61a8000 0 0x100>; - interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 522>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 522>; - #thermal-sensor-cells = <1>; - }; - - intc_ex: interrupt-controller@e61c0000 { - compatible = "renesas,intc-ex-r8a774a1", "renesas,irqc"; - #interrupt-cells = <2>; - interrupt-controller; - reg = <0 0xe61c0000 0 0x200>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 161 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 407>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 407>; - }; - - tmu0: timer@e61e0000 { - compatible = "renesas,tmu-r8a774a1", "renesas,tmu"; - reg = <0 0xe61e0000 0 0x30>; - interrupts = <GIC_SPI 136 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 137 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 138 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 125>; - clock-names = "fck"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 125>; - status = "disabled"; - }; - - tmu1: timer@e6fc0000 { - compatible = "renesas,tmu-r8a774a1", "renesas,tmu"; - reg = <0 0xe6fc0000 0 0x30>; - interrupts = <GIC_SPI 128 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 129 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 130 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 124>; - clock-names = "fck"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 124>; - status = "disabled"; - }; - - tmu2: timer@e6fd0000 { - compatible = "renesas,tmu-r8a774a1", "renesas,tmu"; - reg = <0 0xe6fd0000 0 0x30>; - interrupts = <GIC_SPI 303 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 304 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 305 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 123>; - clock-names = "fck"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 123>; - status = "disabled"; - }; - - tmu3: timer@e6fe0000 { - compatible = "renesas,tmu-r8a774a1", "renesas,tmu"; - reg = <0 0xe6fe0000 0 0x30>; - interrupts = <GIC_SPI 131 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 132 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 133 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 122>; - clock-names = "fck"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 122>; - status = "disabled"; - }; - - tmu4: timer@ffc00000 { - compatible = "renesas,tmu-r8a774a1", "renesas,tmu"; - reg = <0 0xffc00000 0 0x30>; - interrupts = <GIC_SPI 406 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 407 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 408 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 121>; - clock-names = "fck"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 121>; - status = "disabled"; - }; - - i2c0: i2c@e6500000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a774a1", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6500000 0 0x40>; - interrupts = <GIC_SPI 287 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 931>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 931>; - dmas = <&dmac1 0x91>, <&dmac1 0x90>, - <&dmac2 0x91>, <&dmac2 0x90>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - status = "disabled"; - }; - - i2c1: i2c@e6508000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a774a1", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6508000 0 0x40>; - interrupts = <GIC_SPI 288 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 930>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 930>; - dmas = <&dmac1 0x93>, <&dmac1 0x92>, - <&dmac2 0x93>, <&dmac2 0x92>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c2: i2c@e6510000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a774a1", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6510000 0 0x40>; - interrupts = <GIC_SPI 286 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 929>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 929>; - dmas = <&dmac1 0x95>, <&dmac1 0x94>, - <&dmac2 0x95>, <&dmac2 0x94>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c3: i2c@e66d0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a774a1", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66d0000 0 0x40>; - interrupts = <GIC_SPI 290 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 928>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 928>; - dmas = <&dmac0 0x97>, <&dmac0 0x96>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - status = "disabled"; - }; - - i2c4: i2c@e66d8000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a774a1", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66d8000 0 0x40>; - interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 927>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 927>; - dmas = <&dmac0 0x99>, <&dmac0 0x98>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - status = "disabled"; - }; - - i2c5: i2c@e66e0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a774a1", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66e0000 0 0x40>; - interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 919>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 919>; - dmas = <&dmac0 0x9b>, <&dmac0 0x9a>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - status = "disabled"; - }; - - i2c6: i2c@e66e8000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a774a1", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66e8000 0 0x40>; - interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 918>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 918>; - dmas = <&dmac0 0x9d>, <&dmac0 0x9c>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - iic_pmic: i2c@e60b0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,iic-r8a774a1", - "renesas,rcar-gen3-iic", - "renesas,rmobile-iic"; - reg = <0 0xe60b0000 0 0x425>; - interrupts = <GIC_SPI 173 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 926>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 926>; - dmas = <&dmac0 0x11>, <&dmac0 0x10>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - hscif0: serial@e6540000 { - compatible = "renesas,hscif-r8a774a1", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe6540000 0 0x60>; - interrupts = <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 520>, - <&cpg CPG_CORE R8A774A1_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x31>, <&dmac1 0x30>, - <&dmac2 0x31>, <&dmac2 0x30>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 520>; - status = "disabled"; - }; - - hscif1: serial@e6550000 { - compatible = "renesas,hscif-r8a774a1", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe6550000 0 0x60>; - interrupts = <GIC_SPI 155 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 519>, - <&cpg CPG_CORE R8A774A1_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x33>, <&dmac1 0x32>, - <&dmac2 0x33>, <&dmac2 0x32>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 519>; - status = "disabled"; - }; - - hscif2: serial@e6560000 { - compatible = "renesas,hscif-r8a774a1", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe6560000 0 0x60>; - interrupts = <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 518>, - <&cpg CPG_CORE R8A774A1_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x35>, <&dmac1 0x34>, - <&dmac2 0x35>, <&dmac2 0x34>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 518>; - status = "disabled"; - }; - - hscif3: serial@e66a0000 { - compatible = "renesas,hscif-r8a774a1", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe66a0000 0 0x60>; - interrupts = <GIC_SPI 145 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 517>, - <&cpg CPG_CORE R8A774A1_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x37>, <&dmac0 0x36>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 517>; - status = "disabled"; - }; - - hscif4: serial@e66b0000 { - compatible = "renesas,hscif-r8a774a1", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe66b0000 0 0x60>; - interrupts = <GIC_SPI 146 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 516>, - <&cpg CPG_CORE R8A774A1_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x39>, <&dmac0 0x38>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 516>; - status = "disabled"; - }; - - hsusb: usb@e6590000 { - compatible = "renesas,usbhs-r8a774a1", - "renesas,rcar-gen3-usbhs"; - reg = <0 0xe6590000 0 0x200>; - interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 704>, <&cpg CPG_MOD 703>; - dmas = <&usb_dmac0 0>, <&usb_dmac0 1>, - <&usb_dmac1 0>, <&usb_dmac1 1>; - dma-names = "ch0", "ch1", "ch2", "ch3"; - renesas,buswait = <11>; - phys = <&usb2_phy0 3>; - phy-names = "usb"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 704>, <&cpg 703>; - status = "disabled"; - }; - - usb2_clksel: clock-controller@e6590630 { - compatible = "renesas,r8a774a1-rcar-usb2-clock-sel", - "renesas,rcar-gen3-usb2-clock-sel"; - reg = <0 0xe6590630 0 0x02>; - clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>, - <&usb_extal_clk>, <&usb3s0_clk>; - clock-names = "ehci_ohci", "hs-usb-if", - "usb_extal", "usb_xtal"; - #clock-cells = <0>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 703>, <&cpg 704>; - reset-names = "ehci_ohci", "hs-usb-if"; - status = "disabled"; - }; - - usb_dmac0: dma-controller@e65a0000 { - compatible = "renesas,r8a774a1-usb-dmac", - "renesas,usb-dmac"; - reg = <0 0xe65a0000 0 0x100>; - interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1"; - clocks = <&cpg CPG_MOD 330>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 330>; - #dma-cells = <1>; - dma-channels = <2>; - }; - - usb_dmac1: dma-controller@e65b0000 { - compatible = "renesas,r8a774a1-usb-dmac", - "renesas,usb-dmac"; - reg = <0 0xe65b0000 0 0x100>; - interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1"; - clocks = <&cpg CPG_MOD 331>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 331>; - #dma-cells = <1>; - dma-channels = <2>; - }; - - usb3_phy0: usb-phy@e65ee000 { - compatible = "renesas,r8a774a1-usb3-phy", - "renesas,rcar-gen3-usb3-phy"; - reg = <0 0xe65ee000 0 0x90>; - clocks = <&cpg CPG_MOD 328>, <&usb3s0_clk>, - <&usb_extal_clk>; - clock-names = "usb3-if", "usb3s_clk", "usb_extal"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 328>; - #phy-cells = <0>; - status = "disabled"; - }; - - dmac0: dma-controller@e6700000 { - compatible = "renesas,dmac-r8a774a1", - "renesas,rcar-dmac"; - reg = <0 0xe6700000 0 0x10000>; - interrupts = <GIC_SPI 199 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 200 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 201 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 202 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 203 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 204 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 205 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 206 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 207 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 208 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 209 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 210 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 211 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 212 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 213 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 214 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 215 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 219>; - clock-names = "fck"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 219>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_ds0 0>, <&ipmmu_ds0 1>, - <&ipmmu_ds0 2>, <&ipmmu_ds0 3>, - <&ipmmu_ds0 4>, <&ipmmu_ds0 5>, - <&ipmmu_ds0 6>, <&ipmmu_ds0 7>, - <&ipmmu_ds0 8>, <&ipmmu_ds0 9>, - <&ipmmu_ds0 10>, <&ipmmu_ds0 11>, - <&ipmmu_ds0 12>, <&ipmmu_ds0 13>, - <&ipmmu_ds0 14>, <&ipmmu_ds0 15>; - }; - - dmac1: dma-controller@e7300000 { - compatible = "renesas,dmac-r8a774a1", - "renesas,rcar-dmac"; - reg = <0 0xe7300000 0 0x10000>; - interrupts = <GIC_SPI 220 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 216 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 217 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 218 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 219 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 308 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 309 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 310 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 311 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 312 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 313 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 314 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 315 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 316 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 317 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 318 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 319 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 218>; - clock-names = "fck"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 218>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_ds1 0>, <&ipmmu_ds1 1>, - <&ipmmu_ds1 2>, <&ipmmu_ds1 3>, - <&ipmmu_ds1 4>, <&ipmmu_ds1 5>, - <&ipmmu_ds1 6>, <&ipmmu_ds1 7>, - <&ipmmu_ds1 8>, <&ipmmu_ds1 9>, - <&ipmmu_ds1 10>, <&ipmmu_ds1 11>, - <&ipmmu_ds1 12>, <&ipmmu_ds1 13>, - <&ipmmu_ds1 14>, <&ipmmu_ds1 15>; - }; - - dmac2: dma-controller@e7310000 { - compatible = "renesas,dmac-r8a774a1", - "renesas,rcar-dmac"; - reg = <0 0xe7310000 0 0x10000>; - interrupts = <GIC_SPI 416 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 417 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 418 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 419 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 420 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 421 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 422 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 423 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 424 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 425 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 426 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 427 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 428 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 429 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 430 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 431 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 397 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 217>; - clock-names = "fck"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 217>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_ds1 16>, <&ipmmu_ds1 17>, - <&ipmmu_ds1 18>, <&ipmmu_ds1 19>, - <&ipmmu_ds1 20>, <&ipmmu_ds1 21>, - <&ipmmu_ds1 22>, <&ipmmu_ds1 23>, - <&ipmmu_ds1 24>, <&ipmmu_ds1 25>, - <&ipmmu_ds1 26>, <&ipmmu_ds1 27>, - <&ipmmu_ds1 28>, <&ipmmu_ds1 29>, - <&ipmmu_ds1 30>, <&ipmmu_ds1 31>; - }; - - ipmmu_ds0: iommu@e6740000 { - compatible = "renesas,ipmmu-r8a774a1"; - reg = <0 0xe6740000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 0>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_ds1: iommu@e7740000 { - compatible = "renesas,ipmmu-r8a774a1"; - reg = <0 0xe7740000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 1>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_hc: iommu@e6570000 { - compatible = "renesas,ipmmu-r8a774a1"; - reg = <0 0xe6570000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 2>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_mm: iommu@e67b0000 { - compatible = "renesas,ipmmu-r8a774a1"; - reg = <0 0xe67b0000 0 0x1000>; - interrupts = <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_mp: iommu@ec670000 { - compatible = "renesas,ipmmu-r8a774a1"; - reg = <0 0xec670000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 4>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_pv0: iommu@fd800000 { - compatible = "renesas,ipmmu-r8a774a1"; - reg = <0 0xfd800000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 5>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_pv1: iommu@fd950000 { - compatible = "renesas,ipmmu-r8a774a1"; - reg = <0 0xfd950000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 6>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_vc0: iommu@fe6b0000 { - compatible = "renesas,ipmmu-r8a774a1"; - reg = <0 0xfe6b0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 8>; - power-domains = <&sysc R8A774A1_PD_A3VC>; - #iommu-cells = <1>; - }; - - ipmmu_vi0: iommu@febd0000 { - compatible = "renesas,ipmmu-r8a774a1"; - reg = <0 0xfebd0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 9>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - avb: ethernet@e6800000 { - compatible = "renesas,etheravb-r8a774a1", - "renesas,etheravb-rcar-gen3"; - reg = <0 0xe6800000 0 0x800>; - interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 47 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 63 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15", - "ch16", "ch17", "ch18", "ch19", - "ch20", "ch21", "ch22", "ch23", - "ch24"; - clocks = <&cpg CPG_MOD 812>; - clock-names = "fck"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 812>; - phy-mode = "rgmii"; - rx-internal-delay-ps = <0>; - tx-internal-delay-ps = <0>; - iommus = <&ipmmu_ds0 16>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - can0: can@e6c30000 { - compatible = "renesas,can-r8a774a1", - "renesas,rcar-gen3-can"; - reg = <0 0xe6c30000 0 0x1000>; - interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 916>, - <&cpg CPG_CORE R8A774A1_CLK_CANFD>, - <&can_clk>; - clock-names = "clkp1", "clkp2", "can_clk"; - assigned-clocks = <&cpg CPG_CORE R8A774A1_CLK_CANFD>; - assigned-clock-rates = <40000000>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 916>; - status = "disabled"; - }; - - can1: can@e6c38000 { - compatible = "renesas,can-r8a774a1", - "renesas,rcar-gen3-can"; - reg = <0 0xe6c38000 0 0x1000>; - interrupts = <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 915>, - <&cpg CPG_CORE R8A774A1_CLK_CANFD>, - <&can_clk>; - clock-names = "clkp1", "clkp2", "can_clk"; - assigned-clocks = <&cpg CPG_CORE R8A774A1_CLK_CANFD>; - assigned-clock-rates = <40000000>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 915>; - status = "disabled"; - }; - - canfd: can@e66c0000 { - compatible = "renesas,r8a774a1-canfd", - "renesas,rcar-gen3-canfd"; - reg = <0 0xe66c0000 0 0x8000>; - interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch_int", "g_int"; - clocks = <&cpg CPG_MOD 914>, - <&cpg CPG_CORE R8A774A1_CLK_CANFD>, - <&can_clk>; - clock-names = "fck", "canfd", "can_clk"; - assigned-clocks = <&cpg CPG_CORE R8A774A1_CLK_CANFD>; - assigned-clock-rates = <40000000>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 914>; - status = "disabled"; - - channel0 { - status = "disabled"; - }; - - channel1 { - status = "disabled"; - }; - }; - - pwm0: pwm@e6e30000 { - compatible = "renesas,pwm-r8a774a1", "renesas,pwm-rcar"; - reg = <0 0xe6e30000 0 0x8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - resets = <&cpg 523>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - status = "disabled"; - }; - - pwm1: pwm@e6e31000 { - compatible = "renesas,pwm-r8a774a1", "renesas,pwm-rcar"; - reg = <0 0xe6e31000 0 0x8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - resets = <&cpg 523>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - status = "disabled"; - }; - - pwm2: pwm@e6e32000 { - compatible = "renesas,pwm-r8a774a1", "renesas,pwm-rcar"; - reg = <0 0xe6e32000 0 0x8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - resets = <&cpg 523>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - status = "disabled"; - }; - - pwm3: pwm@e6e33000 { - compatible = "renesas,pwm-r8a774a1", "renesas,pwm-rcar"; - reg = <0 0xe6e33000 0 0x8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - resets = <&cpg 523>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - status = "disabled"; - }; - - pwm4: pwm@e6e34000 { - compatible = "renesas,pwm-r8a774a1", "renesas,pwm-rcar"; - reg = <0 0xe6e34000 0 0x8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - resets = <&cpg 523>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - status = "disabled"; - }; - - pwm5: pwm@e6e35000 { - compatible = "renesas,pwm-r8a774a1", "renesas,pwm-rcar"; - reg = <0 0xe6e35000 0 0x8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - resets = <&cpg 523>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - status = "disabled"; - }; - - pwm6: pwm@e6e36000 { - compatible = "renesas,pwm-r8a774a1", "renesas,pwm-rcar"; - reg = <0 0xe6e36000 0 0x8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - resets = <&cpg 523>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - status = "disabled"; - }; - - scif0: serial@e6e60000 { - compatible = "renesas,scif-r8a774a1", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6e60000 0 0x40>; - interrupts = <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 207>, - <&cpg CPG_CORE R8A774A1_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x51>, <&dmac1 0x50>, - <&dmac2 0x51>, <&dmac2 0x50>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 207>; - status = "disabled"; - }; - - scif1: serial@e6e68000 { - compatible = "renesas,scif-r8a774a1", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6e68000 0 0x40>; - interrupts = <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 206>, - <&cpg CPG_CORE R8A774A1_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x53>, <&dmac1 0x52>, - <&dmac2 0x53>, <&dmac2 0x52>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 206>; - status = "disabled"; - }; - - scif2: serial@e6e88000 { - compatible = "renesas,scif-r8a774a1", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6e88000 0 0x40>; - interrupts = <GIC_SPI 164 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 310>, - <&cpg CPG_CORE R8A774A1_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x13>, <&dmac1 0x12>, - <&dmac2 0x13>, <&dmac2 0x12>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 310>; - status = "disabled"; - }; - - scif3: serial@e6c50000 { - compatible = "renesas,scif-r8a774a1", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6c50000 0 0x40>; - interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 204>, - <&cpg CPG_CORE R8A774A1_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x57>, <&dmac0 0x56>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 204>; - status = "disabled"; - }; - - scif4: serial@e6c40000 { - compatible = "renesas,scif-r8a774a1", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6c40000 0 0x40>; - interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 203>, - <&cpg CPG_CORE R8A774A1_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x59>, <&dmac0 0x58>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 203>; - status = "disabled"; - }; - - scif5: serial@e6f30000 { - compatible = "renesas,scif-r8a774a1", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6f30000 0 0x40>; - interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 202>, - <&cpg CPG_CORE R8A774A1_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x5b>, <&dmac1 0x5a>, - <&dmac2 0x5b>, <&dmac2 0x5a>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 202>; - status = "disabled"; - }; - - msiof0: spi@e6e90000 { - compatible = "renesas,msiof-r8a774a1", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6e90000 0 0x0064>; - interrupts = <GIC_SPI 156 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 211>; - dmas = <&dmac1 0x41>, <&dmac1 0x40>, - <&dmac2 0x41>, <&dmac2 0x40>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 211>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof1: spi@e6ea0000 { - compatible = "renesas,msiof-r8a774a1", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6ea0000 0 0x0064>; - interrupts = <GIC_SPI 157 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 210>; - dmas = <&dmac1 0x43>, <&dmac1 0x42>, - <&dmac2 0x43>, <&dmac2 0x42>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 210>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof2: spi@e6c00000 { - compatible = "renesas,msiof-r8a774a1", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6c00000 0 0x0064>; - interrupts = <GIC_SPI 158 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 209>; - dmas = <&dmac0 0x45>, <&dmac0 0x44>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 209>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof3: spi@e6c10000 { - compatible = "renesas,msiof-r8a774a1", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6c10000 0 0x0064>; - interrupts = <GIC_SPI 159 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 208>; - dmas = <&dmac0 0x47>, <&dmac0 0x46>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 208>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - vin0: video@e6ef0000 { - compatible = "renesas,vin-r8a774a1"; - reg = <0 0xe6ef0000 0 0x1000>; - interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 811>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 811>; - renesas,id = <0>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin0csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin0>; - }; - vin0csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin0>; - }; - }; - }; - }; - - vin1: video@e6ef1000 { - compatible = "renesas,vin-r8a774a1"; - reg = <0 0xe6ef1000 0 0x1000>; - interrupts = <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 810>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 810>; - renesas,id = <1>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin1csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin1>; - }; - vin1csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin1>; - }; - }; - }; - }; - - vin2: video@e6ef2000 { - compatible = "renesas,vin-r8a774a1"; - reg = <0 0xe6ef2000 0 0x1000>; - interrupts = <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 809>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 809>; - renesas,id = <2>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin2csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin2>; - }; - vin2csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin2>; - }; - }; - }; - }; - - vin3: video@e6ef3000 { - compatible = "renesas,vin-r8a774a1"; - reg = <0 0xe6ef3000 0 0x1000>; - interrupts = <GIC_SPI 191 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 808>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 808>; - renesas,id = <3>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin3csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin3>; - }; - vin3csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin3>; - }; - }; - }; - }; - - vin4: video@e6ef4000 { - compatible = "renesas,vin-r8a774a1"; - reg = <0 0xe6ef4000 0 0x1000>; - interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 807>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 807>; - renesas,id = <4>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin4csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin4>; - }; - vin4csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin4>; - }; - }; - }; - }; - - vin5: video@e6ef5000 { - compatible = "renesas,vin-r8a774a1"; - reg = <0 0xe6ef5000 0 0x1000>; - interrupts = <GIC_SPI 175 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 806>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 806>; - renesas,id = <5>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin5csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin5>; - }; - vin5csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin5>; - }; - }; - }; - }; - - vin6: video@e6ef6000 { - compatible = "renesas,vin-r8a774a1"; - reg = <0 0xe6ef6000 0 0x1000>; - interrupts = <GIC_SPI 176 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 805>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 805>; - renesas,id = <6>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin6csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin6>; - }; - vin6csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin6>; - }; - }; - }; - }; - - vin7: video@e6ef7000 { - compatible = "renesas,vin-r8a774a1"; - reg = <0 0xe6ef7000 0 0x1000>; - interrupts = <GIC_SPI 171 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 804>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 804>; - renesas,id = <7>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin7csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin7>; - }; - vin7csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin7>; - }; - }; - }; - }; - - rcar_sound: sound@ec500000 { - /* - * #sound-dai-cells is required if simple-card - * - * Single DAI : #sound-dai-cells = <0>; <&rcar_sound>; - * Multi DAI : #sound-dai-cells = <1>; <&rcar_sound N>; - */ - /* - * #clock-cells is required for audio_clkout0/1/2/3 - * - * clkout : #clock-cells = <0>; <&rcar_sound>; - * clkout0/1/2/3: #clock-cells = <1>; <&rcar_sound N>; - */ - compatible = "renesas,rcar_sound-r8a774a1", "renesas,rcar_sound-gen3"; - reg = <0 0xec500000 0 0x1000>, /* SCU */ - <0 0xec5a0000 0 0x100>, /* ADG */ - <0 0xec540000 0 0x1000>, /* SSIU */ - <0 0xec541000 0 0x280>, /* SSI */ - <0 0xec760000 0 0x200>; /* Audio DMAC peri peri*/ - reg-names = "scu", "adg", "ssiu", "ssi", "audmapp"; - - clocks = <&cpg CPG_MOD 1005>, - <&cpg CPG_MOD 1006>, <&cpg CPG_MOD 1007>, - <&cpg CPG_MOD 1008>, <&cpg CPG_MOD 1009>, - <&cpg CPG_MOD 1010>, <&cpg CPG_MOD 1011>, - <&cpg CPG_MOD 1012>, <&cpg CPG_MOD 1013>, - <&cpg CPG_MOD 1014>, <&cpg CPG_MOD 1015>, - <&cpg CPG_MOD 1022>, <&cpg CPG_MOD 1023>, - <&cpg CPG_MOD 1024>, <&cpg CPG_MOD 1025>, - <&cpg CPG_MOD 1026>, <&cpg CPG_MOD 1027>, - <&cpg CPG_MOD 1028>, <&cpg CPG_MOD 1029>, - <&cpg CPG_MOD 1030>, <&cpg CPG_MOD 1031>, - <&cpg CPG_MOD 1020>, <&cpg CPG_MOD 1021>, - <&cpg CPG_MOD 1020>, <&cpg CPG_MOD 1021>, - <&cpg CPG_MOD 1019>, <&cpg CPG_MOD 1018>, - <&audio_clk_a>, <&audio_clk_b>, - <&audio_clk_c>, - <&cpg CPG_CORE R8A774A1_CLK_S0D4>; - clock-names = "ssi-all", - "ssi.9", "ssi.8", "ssi.7", "ssi.6", - "ssi.5", "ssi.4", "ssi.3", "ssi.2", - "ssi.1", "ssi.0", - "src.9", "src.8", "src.7", "src.6", - "src.5", "src.4", "src.3", "src.2", - "src.1", "src.0", - "mix.1", "mix.0", - "ctu.1", "ctu.0", - "dvc.0", "dvc.1", - "clk_a", "clk_b", "clk_c", "clk_i"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 1005>, - <&cpg 1006>, <&cpg 1007>, - <&cpg 1008>, <&cpg 1009>, - <&cpg 1010>, <&cpg 1011>, - <&cpg 1012>, <&cpg 1013>, - <&cpg 1014>, <&cpg 1015>; - reset-names = "ssi-all", - "ssi.9", "ssi.8", "ssi.7", "ssi.6", - "ssi.5", "ssi.4", "ssi.3", "ssi.2", - "ssi.1", "ssi.0"; - status = "disabled"; - - rcar_sound,ctu { - ctu00: ctu-0 { }; - ctu01: ctu-1 { }; - ctu02: ctu-2 { }; - ctu03: ctu-3 { }; - ctu10: ctu-4 { }; - ctu11: ctu-5 { }; - ctu12: ctu-6 { }; - ctu13: ctu-7 { }; - }; - - rcar_sound,dvc { - dvc0: dvc-0 { - dmas = <&audma1 0xbc>; - dma-names = "tx"; - }; - dvc1: dvc-1 { - dmas = <&audma1 0xbe>; - dma-names = "tx"; - }; - }; - - rcar_sound,mix { - mix0: mix-0 { }; - mix1: mix-1 { }; - }; - - rcar_sound,src { - src0: src-0 { - interrupts = <GIC_SPI 352 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x85>, <&audma1 0x9a>; - dma-names = "rx", "tx"; - }; - src1: src-1 { - interrupts = <GIC_SPI 353 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x87>, <&audma1 0x9c>; - dma-names = "rx", "tx"; - }; - src2: src-2 { - interrupts = <GIC_SPI 354 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x89>, <&audma1 0x9e>; - dma-names = "rx", "tx"; - }; - src3: src-3 { - interrupts = <GIC_SPI 355 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x8b>, <&audma1 0xa0>; - dma-names = "rx", "tx"; - }; - src4: src-4 { - interrupts = <GIC_SPI 356 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x8d>, <&audma1 0xb0>; - dma-names = "rx", "tx"; - }; - src5: src-5 { - interrupts = <GIC_SPI 357 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x8f>, <&audma1 0xb2>; - dma-names = "rx", "tx"; - }; - src6: src-6 { - interrupts = <GIC_SPI 358 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x91>, <&audma1 0xb4>; - dma-names = "rx", "tx"; - }; - src7: src-7 { - interrupts = <GIC_SPI 359 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x93>, <&audma1 0xb6>; - dma-names = "rx", "tx"; - }; - src8: src-8 { - interrupts = <GIC_SPI 360 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x95>, <&audma1 0xb8>; - dma-names = "rx", "tx"; - }; - src9: src-9 { - interrupts = <GIC_SPI 361 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x97>, <&audma1 0xba>; - dma-names = "rx", "tx"; - }; - }; - - rcar_sound,ssi { - ssi0: ssi-0 { - interrupts = <GIC_SPI 370 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x01>, <&audma1 0x02>; - dma-names = "rx", "tx"; - }; - ssi1: ssi-1 { - interrupts = <GIC_SPI 371 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x03>, <&audma1 0x04>; - dma-names = "rx", "tx"; - }; - ssi2: ssi-2 { - interrupts = <GIC_SPI 372 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x05>, <&audma1 0x06>; - dma-names = "rx", "tx"; - }; - ssi3: ssi-3 { - interrupts = <GIC_SPI 373 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x07>, <&audma1 0x08>; - dma-names = "rx", "tx"; - }; - ssi4: ssi-4 { - interrupts = <GIC_SPI 374 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x09>, <&audma1 0x0a>; - dma-names = "rx", "tx"; - }; - ssi5: ssi-5 { - interrupts = <GIC_SPI 375 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x0b>, <&audma1 0x0c>; - dma-names = "rx", "tx"; - }; - ssi6: ssi-6 { - interrupts = <GIC_SPI 376 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x0d>, <&audma1 0x0e>; - dma-names = "rx", "tx"; - }; - ssi7: ssi-7 { - interrupts = <GIC_SPI 377 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x0f>, <&audma1 0x10>; - dma-names = "rx", "tx"; - }; - ssi8: ssi-8 { - interrupts = <GIC_SPI 378 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x11>, <&audma1 0x12>; - dma-names = "rx", "tx"; - }; - ssi9: ssi-9 { - interrupts = <GIC_SPI 379 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x13>, <&audma1 0x14>; - dma-names = "rx", "tx"; - }; - }; - - rcar_sound,ssiu { - ssiu00: ssiu-0 { - dmas = <&audma0 0x15>, <&audma1 0x16>; - dma-names = "rx", "tx"; - }; - ssiu01: ssiu-1 { - dmas = <&audma0 0x35>, <&audma1 0x36>; - dma-names = "rx", "tx"; - }; - ssiu02: ssiu-2 { - dmas = <&audma0 0x37>, <&audma1 0x38>; - dma-names = "rx", "tx"; - }; - ssiu03: ssiu-3 { - dmas = <&audma0 0x47>, <&audma1 0x48>; - dma-names = "rx", "tx"; - }; - ssiu04: ssiu-4 { - dmas = <&audma0 0x3F>, <&audma1 0x40>; - dma-names = "rx", "tx"; - }; - ssiu05: ssiu-5 { - dmas = <&audma0 0x43>, <&audma1 0x44>; - dma-names = "rx", "tx"; - }; - ssiu06: ssiu-6 { - dmas = <&audma0 0x4F>, <&audma1 0x50>; - dma-names = "rx", "tx"; - }; - ssiu07: ssiu-7 { - dmas = <&audma0 0x53>, <&audma1 0x54>; - dma-names = "rx", "tx"; - }; - ssiu10: ssiu-8 { - dmas = <&audma0 0x49>, <&audma1 0x4a>; - dma-names = "rx", "tx"; - }; - ssiu11: ssiu-9 { - dmas = <&audma0 0x4B>, <&audma1 0x4C>; - dma-names = "rx", "tx"; - }; - ssiu12: ssiu-10 { - dmas = <&audma0 0x57>, <&audma1 0x58>; - dma-names = "rx", "tx"; - }; - ssiu13: ssiu-11 { - dmas = <&audma0 0x59>, <&audma1 0x5A>; - dma-names = "rx", "tx"; - }; - ssiu14: ssiu-12 { - dmas = <&audma0 0x5F>, <&audma1 0x60>; - dma-names = "rx", "tx"; - }; - ssiu15: ssiu-13 { - dmas = <&audma0 0xC3>, <&audma1 0xC4>; - dma-names = "rx", "tx"; - }; - ssiu16: ssiu-14 { - dmas = <&audma0 0xC7>, <&audma1 0xC8>; - dma-names = "rx", "tx"; - }; - ssiu17: ssiu-15 { - dmas = <&audma0 0xCB>, <&audma1 0xCC>; - dma-names = "rx", "tx"; - }; - ssiu20: ssiu-16 { - dmas = <&audma0 0x63>, <&audma1 0x64>; - dma-names = "rx", "tx"; - }; - ssiu21: ssiu-17 { - dmas = <&audma0 0x67>, <&audma1 0x68>; - dma-names = "rx", "tx"; - }; - ssiu22: ssiu-18 { - dmas = <&audma0 0x6B>, <&audma1 0x6C>; - dma-names = "rx", "tx"; - }; - ssiu23: ssiu-19 { - dmas = <&audma0 0x6D>, <&audma1 0x6E>; - dma-names = "rx", "tx"; - }; - ssiu24: ssiu-20 { - dmas = <&audma0 0xCF>, <&audma1 0xCE>; - dma-names = "rx", "tx"; - }; - ssiu25: ssiu-21 { - dmas = <&audma0 0xEB>, <&audma1 0xEC>; - dma-names = "rx", "tx"; - }; - ssiu26: ssiu-22 { - dmas = <&audma0 0xED>, <&audma1 0xEE>; - dma-names = "rx", "tx"; - }; - ssiu27: ssiu-23 { - dmas = <&audma0 0xEF>, <&audma1 0xF0>; - dma-names = "rx", "tx"; - }; - ssiu30: ssiu-24 { - dmas = <&audma0 0x6f>, <&audma1 0x70>; - dma-names = "rx", "tx"; - }; - ssiu31: ssiu-25 { - dmas = <&audma0 0x21>, <&audma1 0x22>; - dma-names = "rx", "tx"; - }; - ssiu32: ssiu-26 { - dmas = <&audma0 0x23>, <&audma1 0x24>; - dma-names = "rx", "tx"; - }; - ssiu33: ssiu-27 { - dmas = <&audma0 0x25>, <&audma1 0x26>; - dma-names = "rx", "tx"; - }; - ssiu34: ssiu-28 { - dmas = <&audma0 0x27>, <&audma1 0x28>; - dma-names = "rx", "tx"; - }; - ssiu35: ssiu-29 { - dmas = <&audma0 0x29>, <&audma1 0x2A>; - dma-names = "rx", "tx"; - }; - ssiu36: ssiu-30 { - dmas = <&audma0 0x2B>, <&audma1 0x2C>; - dma-names = "rx", "tx"; - }; - ssiu37: ssiu-31 { - dmas = <&audma0 0x2D>, <&audma1 0x2E>; - dma-names = "rx", "tx"; - }; - ssiu40: ssiu-32 { - dmas = <&audma0 0x71>, <&audma1 0x72>; - dma-names = "rx", "tx"; - }; - ssiu41: ssiu-33 { - dmas = <&audma0 0x17>, <&audma1 0x18>; - dma-names = "rx", "tx"; - }; - ssiu42: ssiu-34 { - dmas = <&audma0 0x19>, <&audma1 0x1A>; - dma-names = "rx", "tx"; - }; - ssiu43: ssiu-35 { - dmas = <&audma0 0x1B>, <&audma1 0x1C>; - dma-names = "rx", "tx"; - }; - ssiu44: ssiu-36 { - dmas = <&audma0 0x1D>, <&audma1 0x1E>; - dma-names = "rx", "tx"; - }; - ssiu45: ssiu-37 { - dmas = <&audma0 0x1F>, <&audma1 0x20>; - dma-names = "rx", "tx"; - }; - ssiu46: ssiu-38 { - dmas = <&audma0 0x31>, <&audma1 0x32>; - dma-names = "rx", "tx"; - }; - ssiu47: ssiu-39 { - dmas = <&audma0 0x33>, <&audma1 0x34>; - dma-names = "rx", "tx"; - }; - ssiu50: ssiu-40 { - dmas = <&audma0 0x73>, <&audma1 0x74>; - dma-names = "rx", "tx"; - }; - ssiu60: ssiu-41 { - dmas = <&audma0 0x75>, <&audma1 0x76>; - dma-names = "rx", "tx"; - }; - ssiu70: ssiu-42 { - dmas = <&audma0 0x79>, <&audma1 0x7a>; - dma-names = "rx", "tx"; - }; - ssiu80: ssiu-43 { - dmas = <&audma0 0x7b>, <&audma1 0x7c>; - dma-names = "rx", "tx"; - }; - ssiu90: ssiu-44 { - dmas = <&audma0 0x7d>, <&audma1 0x7e>; - dma-names = "rx", "tx"; - }; - ssiu91: ssiu-45 { - dmas = <&audma0 0x7F>, <&audma1 0x80>; - dma-names = "rx", "tx"; - }; - ssiu92: ssiu-46 { - dmas = <&audma0 0x81>, <&audma1 0x82>; - dma-names = "rx", "tx"; - }; - ssiu93: ssiu-47 { - dmas = <&audma0 0x83>, <&audma1 0x84>; - dma-names = "rx", "tx"; - }; - ssiu94: ssiu-48 { - dmas = <&audma0 0xA3>, <&audma1 0xA4>; - dma-names = "rx", "tx"; - }; - ssiu95: ssiu-49 { - dmas = <&audma0 0xA5>, <&audma1 0xA6>; - dma-names = "rx", "tx"; - }; - ssiu96: ssiu-50 { - dmas = <&audma0 0xA7>, <&audma1 0xA8>; - dma-names = "rx", "tx"; - }; - ssiu97: ssiu-51 { - dmas = <&audma0 0xA9>, <&audma1 0xAA>; - dma-names = "rx", "tx"; - }; - }; - }; - - audma0: dma-controller@ec700000 { - compatible = "renesas,dmac-r8a774a1", - "renesas,rcar-dmac"; - reg = <0 0xec700000 0 0x10000>; - interrupts = <GIC_SPI 350 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 320 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 321 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 322 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 323 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 324 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 325 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 326 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 327 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 328 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 329 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 330 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 331 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 332 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 333 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 334 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 335 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 502>; - clock-names = "fck"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 502>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_mp 0>, <&ipmmu_mp 1>, - <&ipmmu_mp 2>, <&ipmmu_mp 3>, - <&ipmmu_mp 4>, <&ipmmu_mp 5>, - <&ipmmu_mp 6>, <&ipmmu_mp 7>, - <&ipmmu_mp 8>, <&ipmmu_mp 9>, - <&ipmmu_mp 10>, <&ipmmu_mp 11>, - <&ipmmu_mp 12>, <&ipmmu_mp 13>, - <&ipmmu_mp 14>, <&ipmmu_mp 15>; - }; - - audma1: dma-controller@ec720000 { - compatible = "renesas,dmac-r8a774a1", - "renesas,rcar-dmac"; - reg = <0 0xec720000 0 0x10000>; - interrupts = <GIC_SPI 351 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 336 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 337 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 338 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 339 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 340 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 341 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 342 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 343 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 344 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 345 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 346 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 347 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 348 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 349 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 382 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 383 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 501>; - clock-names = "fck"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 501>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_mp 16>, <&ipmmu_mp 17>, - <&ipmmu_mp 18>, <&ipmmu_mp 19>, - <&ipmmu_mp 20>, <&ipmmu_mp 21>, - <&ipmmu_mp 22>, <&ipmmu_mp 23>, - <&ipmmu_mp 24>, <&ipmmu_mp 25>, - <&ipmmu_mp 26>, <&ipmmu_mp 27>, - <&ipmmu_mp 28>, <&ipmmu_mp 29>, - <&ipmmu_mp 30>, <&ipmmu_mp 31>; - }; - - xhci0: usb@ee000000 { - compatible = "renesas,xhci-r8a774a1", - "renesas,rcar-gen3-xhci"; - reg = <0 0xee000000 0 0xc00>; - interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 328>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 328>; - status = "disabled"; - }; - - usb3_peri0: usb@ee020000 { - compatible = "renesas,r8a774a1-usb3-peri", - "renesas,rcar-gen3-usb3-peri"; - reg = <0 0xee020000 0 0x400>; - interrupts = <GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 328>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 328>; - status = "disabled"; - }; - - ohci0: usb@ee080000 { - compatible = "generic-ohci"; - reg = <0 0xee080000 0 0x100>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>; - phys = <&usb2_phy0 1>; - phy-names = "usb"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 703>, <&cpg 704>; - status = "disabled"; - }; - - ohci1: usb@ee0a0000 { - compatible = "generic-ohci"; - reg = <0 0xee0a0000 0 0x100>; - interrupts = <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 702>; - phys = <&usb2_phy1 1>; - phy-names = "usb"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 702>; - status = "disabled"; - }; - - ehci0: usb@ee080100 { - compatible = "generic-ehci"; - reg = <0 0xee080100 0 0x100>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>; - phys = <&usb2_phy0 2>; - phy-names = "usb"; - companion = <&ohci0>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 703>, <&cpg 704>; - status = "disabled"; - }; - - ehci1: usb@ee0a0100 { - compatible = "generic-ehci"; - reg = <0 0xee0a0100 0 0x100>; - interrupts = <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 702>; - phys = <&usb2_phy1 2>; - phy-names = "usb"; - companion = <&ohci1>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 702>; - status = "disabled"; - }; - - usb2_phy0: usb-phy@ee080200 { - compatible = "renesas,usb2-phy-r8a774a1", - "renesas,rcar-gen3-usb2-phy"; - reg = <0 0xee080200 0 0x700>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 703>, <&cpg 704>; - #phy-cells = <1>; - status = "disabled"; - }; - - usb2_phy1: usb-phy@ee0a0200 { - compatible = "renesas,usb2-phy-r8a774a1", - "renesas,rcar-gen3-usb2-phy"; - reg = <0 0xee0a0200 0 0x700>; - clocks = <&cpg CPG_MOD 702>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 702>; - #phy-cells = <1>; - status = "disabled"; - }; - - sdhi0: mmc@ee100000 { - compatible = "renesas,sdhi-r8a774a1", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee100000 0 0x2000>; - interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 314>, <&cpg CPG_CORE R8A774A1_CLK_SD0H>; - clock-names = "core", "clkh"; - max-frequency = <200000000>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 314>; - status = "disabled"; - }; - - sdhi1: mmc@ee120000 { - compatible = "renesas,sdhi-r8a774a1", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee120000 0 0x2000>; - interrupts = <GIC_SPI 166 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 313>, <&cpg CPG_CORE R8A774A1_CLK_SD1H>; - clock-names = "core", "clkh"; - max-frequency = <200000000>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 313>; - status = "disabled"; - }; - - sdhi2: mmc@ee140000 { - compatible = "renesas,sdhi-r8a774a1", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee140000 0 0x2000>; - interrupts = <GIC_SPI 167 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 312>, <&cpg CPG_CORE R8A774A1_CLK_SD2H>; - clock-names = "core", "clkh"; - max-frequency = <200000000>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 312>; - status = "disabled"; - }; - - sdhi3: mmc@ee160000 { - compatible = "renesas,sdhi-r8a774a1", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee160000 0 0x2000>; - interrupts = <GIC_SPI 168 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 311>, <&cpg CPG_CORE R8A774A1_CLK_SD3H>; - clock-names = "core", "clkh"; - max-frequency = <200000000>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 311>; - status = "disabled"; - }; - - rpc: spi@ee200000 { - compatible = "renesas,r8a774a1-rpc-if", - "renesas,rcar-gen3-rpc-if"; - reg = <0 0xee200000 0 0x200>, - <0 0x08000000 0 0x4000000>, - <0 0xee208000 0 0x100>; - reg-names = "regs", "dirmap", "wbuf"; - interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 917>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 917>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - gic: interrupt-controller@f1010000 { - compatible = "arm,gic-400"; - #interrupt-cells = <3>; - #address-cells = <0>; - interrupt-controller; - reg = <0x0 0xf1010000 0 0x1000>, - <0x0 0xf1020000 0 0x20000>, - <0x0 0xf1040000 0 0x20000>, - <0x0 0xf1060000 0 0x20000>; - interrupts = <GIC_PPI 9 - (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_HIGH)>; - clocks = <&cpg CPG_MOD 408>; - clock-names = "clk"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 408>; - }; - - pciec0: pcie@fe000000 { - compatible = "renesas,pcie-r8a774a1", - "renesas,pcie-rcar-gen3"; - reg = <0 0xfe000000 0 0x80000>; - #address-cells = <3>; - #size-cells = <2>; - bus-range = <0x00 0xff>; - device_type = "pci"; - ranges = <0x01000000 0 0x00000000 0 0xfe100000 0 0x00100000>, - <0x02000000 0 0xfe200000 0 0xfe200000 0 0x00200000>, - <0x02000000 0 0x30000000 0 0x30000000 0 0x08000000>, - <0x42000000 0 0x38000000 0 0x38000000 0 0x08000000>; - /* Map all possible DDR/IOMMU as inbound ranges */ - dma-ranges = <0x42000000 0 0x00000000 0 0x00000000 1 0x00000000>; - interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>; - #interrupt-cells = <1>; - interrupt-map-mask = <0 0 0 0>; - interrupt-map = <0 0 0 0 &gic GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 319>, <&pcie_bus_clk>; - clock-names = "pcie", "pcie_bus"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 319>; - iommu-map = <0 &ipmmu_hc 0 1>; - iommu-map-mask = <0>; - status = "disabled"; - }; - - pciec1: pcie@ee800000 { - compatible = "renesas,pcie-r8a774a1", - "renesas,pcie-rcar-gen3"; - reg = <0 0xee800000 0 0x80000>; - #address-cells = <3>; - #size-cells = <2>; - bus-range = <0x00 0xff>; - device_type = "pci"; - ranges = <0x01000000 0 0x00000000 0 0xee900000 0 0x00100000>, - <0x02000000 0 0xeea00000 0 0xeea00000 0 0x00200000>, - <0x02000000 0 0xc0000000 0 0xc0000000 0 0x08000000>, - <0x42000000 0 0xc8000000 0 0xc8000000 0 0x08000000>; - /* Map all possible DDR/IOMMU as inbound ranges */ - dma-ranges = <0x42000000 0 0x00000000 0 0x00000000 1 0x00000000>; - interrupts = <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 149 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 150 IRQ_TYPE_LEVEL_HIGH>; - #interrupt-cells = <1>; - interrupt-map-mask = <0 0 0 0>; - interrupt-map = <0 0 0 0 &gic GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 318>, <&pcie_bus_clk>; - clock-names = "pcie", "pcie_bus"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 318>; - iommu-map = <0 &ipmmu_hc 1 1>; - iommu-map-mask = <0>; - status = "disabled"; - }; - - pciec0_ep: pcie-ep@fe000000 { - compatible = "renesas,r8a774a1-pcie-ep", - "renesas,rcar-gen3-pcie-ep"; - reg = <0x0 0xfe000000 0 0x80000>, - <0x0 0xfe100000 0 0x100000>, - <0x0 0xfe200000 0 0x200000>, - <0x0 0x30000000 0 0x8000000>, - <0x0 0x38000000 0 0x8000000>; - reg-names = "apb-base", "memory0", "memory1", "memory2", "memory3"; - interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 319>; - clock-names = "pcie"; - resets = <&cpg 319>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - status = "disabled"; - }; - - pciec1_ep: pcie-ep@ee800000 { - compatible = "renesas,r8a774a1-pcie-ep", - "renesas,rcar-gen3-pcie-ep"; - reg = <0x0 0xee800000 0 0x80000>, - <0x0 0xee900000 0 0x100000>, - <0x0 0xeea00000 0 0x200000>, - <0x0 0xc0000000 0 0x8000000>, - <0x0 0xc8000000 0 0x8000000>; - reg-names = "apb-base", "memory0", "memory1", "memory2", "memory3"; - interrupts = <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 149 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 150 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 318>; - clock-names = "pcie"; - resets = <&cpg 318>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - status = "disabled"; - }; - - fdp1@fe940000 { - compatible = "renesas,fdp1"; - reg = <0 0xfe940000 0 0x2400>; - interrupts = <GIC_SPI 262 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 119>; - power-domains = <&sysc R8A774A1_PD_A3VC>; - resets = <&cpg 119>; - renesas,fcp = <&fcpf0>; - }; - - fcpf0: fcp@fe950000 { - compatible = "renesas,fcpf"; - reg = <0 0xfe950000 0 0x200>; - clocks = <&cpg CPG_MOD 615>; - power-domains = <&sysc R8A774A1_PD_A3VC>; - resets = <&cpg 615>; - }; - - fcpvb0: fcp@fe96f000 { - compatible = "renesas,fcpv"; - reg = <0 0xfe96f000 0 0x200>; - clocks = <&cpg CPG_MOD 607>; - power-domains = <&sysc R8A774A1_PD_A3VC>; - resets = <&cpg 607>; - }; - - fcpvd0: fcp@fea27000 { - compatible = "renesas,fcpv"; - reg = <0 0xfea27000 0 0x200>; - clocks = <&cpg CPG_MOD 603>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 603>; - iommus = <&ipmmu_vi0 8>; - }; - - fcpvd1: fcp@fea2f000 { - compatible = "renesas,fcpv"; - reg = <0 0xfea2f000 0 0x200>; - clocks = <&cpg CPG_MOD 602>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 602>; - iommus = <&ipmmu_vi0 9>; - }; - - fcpvd2: fcp@fea37000 { - compatible = "renesas,fcpv"; - reg = <0 0xfea37000 0 0x200>; - clocks = <&cpg CPG_MOD 601>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 601>; - iommus = <&ipmmu_vi0 10>; - }; - - fcpvi0: fcp@fe9af000 { - compatible = "renesas,fcpv"; - reg = <0 0xfe9af000 0 0x200>; - clocks = <&cpg CPG_MOD 611>; - power-domains = <&sysc R8A774A1_PD_A3VC>; - resets = <&cpg 611>; - iommus = <&ipmmu_vc0 19>; - }; - - vspb: vsp@fe960000 { - compatible = "renesas,vsp2"; - reg = <0 0xfe960000 0 0x8000>; - interrupts = <GIC_SPI 266 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 626>; - power-domains = <&sysc R8A774A1_PD_A3VC>; - resets = <&cpg 626>; - - renesas,fcp = <&fcpvb0>; - }; - - vspd0: vsp@fea20000 { - compatible = "renesas,vsp2"; - reg = <0 0xfea20000 0 0x5000>; - interrupts = <GIC_SPI 466 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 623>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 623>; - - renesas,fcp = <&fcpvd0>; - }; - - vspd1: vsp@fea28000 { - compatible = "renesas,vsp2"; - reg = <0 0xfea28000 0 0x5000>; - interrupts = <GIC_SPI 467 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 622>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 622>; - - renesas,fcp = <&fcpvd1>; - }; - - vspd2: vsp@fea30000 { - compatible = "renesas,vsp2"; - reg = <0 0xfea30000 0 0x5000>; - interrupts = <GIC_SPI 468 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 621>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 621>; - - renesas,fcp = <&fcpvd2>; - }; - - vspi0: vsp@fe9a0000 { - compatible = "renesas,vsp2"; - reg = <0 0xfe9a0000 0 0x8000>; - interrupts = <GIC_SPI 444 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 631>; - power-domains = <&sysc R8A774A1_PD_A3VC>; - resets = <&cpg 631>; - - renesas,fcp = <&fcpvi0>; - }; - - csi20: csi2@fea80000 { - compatible = "renesas,r8a774a1-csi2"; - reg = <0 0xfea80000 0 0x10000>; - interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 714>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 714>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - csi20vin0: endpoint@0 { - reg = <0>; - remote-endpoint = <&vin0csi20>; - }; - csi20vin1: endpoint@1 { - reg = <1>; - remote-endpoint = <&vin1csi20>; - }; - csi20vin2: endpoint@2 { - reg = <2>; - remote-endpoint = <&vin2csi20>; - }; - csi20vin3: endpoint@3 { - reg = <3>; - remote-endpoint = <&vin3csi20>; - }; - csi20vin4: endpoint@4 { - reg = <4>; - remote-endpoint = <&vin4csi20>; - }; - csi20vin5: endpoint@5 { - reg = <5>; - remote-endpoint = <&vin5csi20>; - }; - csi20vin6: endpoint@6 { - reg = <6>; - remote-endpoint = <&vin6csi20>; - }; - csi20vin7: endpoint@7 { - reg = <7>; - remote-endpoint = <&vin7csi20>; - }; - }; - }; - }; - - csi40: csi2@feaa0000 { - compatible = "renesas,r8a774a1-csi2"; - reg = <0 0xfeaa0000 0 0x10000>; - interrupts = <GIC_SPI 246 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 716>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 716>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - csi40vin0: endpoint@0 { - reg = <0>; - remote-endpoint = <&vin0csi40>; - }; - csi40vin1: endpoint@1 { - reg = <1>; - remote-endpoint = <&vin1csi40>; - }; - csi40vin2: endpoint@2 { - reg = <2>; - remote-endpoint = <&vin2csi40>; - }; - csi40vin3: endpoint@3 { - reg = <3>; - remote-endpoint = <&vin3csi40>; - }; - csi40vin4: endpoint@4 { - reg = <4>; - remote-endpoint = <&vin4csi40>; - }; - csi40vin5: endpoint@5 { - reg = <5>; - remote-endpoint = <&vin5csi40>; - }; - csi40vin6: endpoint@6 { - reg = <6>; - remote-endpoint = <&vin6csi40>; - }; - csi40vin7: endpoint@7 { - reg = <7>; - remote-endpoint = <&vin7csi40>; - }; - }; - - }; - }; - - hdmi0: hdmi@fead0000 { - compatible = "renesas,r8a774a1-hdmi", - "renesas,rcar-gen3-hdmi"; - reg = <0 0xfead0000 0 0x10000>; - interrupts = <GIC_SPI 389 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 729>, - <&cpg CPG_CORE R8A774A1_CLK_HDMI>; - clock-names = "iahb", "isfr"; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 729>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - port@0 { - reg = <0>; - dw_hdmi0_in: endpoint { - remote-endpoint = <&du_out_hdmi0>; - }; - }; - port@1 { - reg = <1>; - }; - port@2 { - /* HDMI sound */ - reg = <2>; - }; - }; - }; - - du: display@feb00000 { - compatible = "renesas,du-r8a774a1"; - reg = <0 0xfeb00000 0 0x70000>; - interrupts = <GIC_SPI 256 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 268 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 269 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 724>, <&cpg CPG_MOD 723>, - <&cpg CPG_MOD 722>; - clock-names = "du.0", "du.1", "du.2"; - resets = <&cpg 724>, <&cpg 722>; - reset-names = "du.0", "du.2"; - status = "disabled"; - - renesas,vsps = <&vspd0 0>, <&vspd1 0>, <&vspd2 0>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - port@1 { - reg = <1>; - du_out_hdmi0: endpoint { - remote-endpoint = <&dw_hdmi0_in>; - }; - }; - port@2 { - reg = <2>; - du_out_lvds0: endpoint { - remote-endpoint = <&lvds0_in>; - }; - }; - }; - }; - - lvds0: lvds@feb90000 { - compatible = "renesas,r8a774a1-lvds"; - reg = <0 0xfeb90000 0 0x14>; - clocks = <&cpg CPG_MOD 727>; - power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>; - resets = <&cpg 727>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - lvds0_in: endpoint { - remote-endpoint = <&du_out_lvds0>; - }; - }; - port@1 { - reg = <1>; - }; - }; - }; - - prr: chipid@fff00044 { - compatible = "renesas,prr"; - reg = <0 0xfff00044 0 4>; - }; - }; - - thermal-zones { - sensor1_thermal: sensor1-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - thermal-sensors = <&tsc 0>; - sustainable-power = <3874>; - - trips { - sensor1_crit: sensor1-crit { - temperature = <120000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - }; - - sensor2_thermal: sensor2-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - thermal-sensors = <&tsc 1>; - sustainable-power = <3874>; - - trips { - sensor2_crit: sensor2-crit { - temperature = <120000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - }; - - sensor3_thermal: sensor3-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - thermal-sensors = <&tsc 2>; - sustainable-power = <3874>; - - cooling-maps { - map0 { - trip = <&target>; - cooling-device = <&a57_0 0 2>; - contribution = <1024>; - }; - map1 { - trip = <&target>; - cooling-device = <&a53_0 0 2>; - contribution = <1024>; - }; - }; - trips { - target: trip-point1 { - temperature = <100000>; - hysteresis = <1000>; - type = "passive"; - }; - - sensor3_crit: sensor3-crit { - temperature = <120000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - }; - }; - - timer { - compatible = "arm,armv8-timer"; - interrupts-extended = <&gic GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>; - }; - - /* External USB clocks - can be overridden by the board */ - usb3s0_clk: usb3s0 { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - usb_extal_clk: usb_extal { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; -}; diff --git a/arch/arm/dts/r8a774b1-beacon-rzg2n-kit.dts b/arch/arm/dts/r8a774b1-beacon-rzg2n-kit.dts deleted file mode 100644 index 8b9df6afffd..00000000000 --- a/arch/arm/dts/r8a774b1-beacon-rzg2n-kit.dts +++ /dev/null @@ -1,56 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Copyright 2020, Compass Electronics Group, LLC - */ - -/dts-v1/; - -#include "r8a774b1.dtsi" -#include "beacon-renesom-som.dtsi" -#include "beacon-renesom-baseboard.dtsi" - -/ { - model = "Beacon Embedded Works RZ/G2N Development Kit"; - compatible = "beacon,beacon-rzg2n", "renesas,r8a774b1"; - - aliases { - i2c0 = &i2c0; - i2c1 = &i2c1; - i2c2 = &i2c2; - i2c3 = &i2c3; - i2c4 = &i2c4; - i2c5 = &i2c5; - i2c6 = &i2c6; - i2c7 = &iic_pmic; - serial0 = &scif2; - serial1 = &hscif0; - serial2 = &hscif1; - serial3 = &scif0; - serial4 = &hscif2; - serial5 = &scif5; - serial6 = &scif4; - ethernet0 = &avb; - mmc0 = &sdhi3; - mmc1 = &sdhi0; - mmc2 = &sdhi2; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; -}; - -&du { - pinctrl-0 = <&du_pins>; - pinctrl-names = "default"; - status = "okay"; - - clocks = <&cpg CPG_MOD 724>, - <&cpg CPG_MOD 723>, - <&cpg CPG_MOD 721>, - <&versaclock5 1>, - <&x302_clk>, - <&versaclock5 2>; - clock-names = "du.0", "du.1", "du.3", - "dclkin.0", "dclkin.1", "dclkin.3"; -}; diff --git a/arch/arm/dts/r8a774b1-hihope-rzg2n-ex.dts b/arch/arm/dts/r8a774b1-hihope-rzg2n-ex.dts deleted file mode 100644 index 60d7c8adea0..00000000000 --- a/arch/arm/dts/r8a774b1-hihope-rzg2n-ex.dts +++ /dev/null @@ -1,21 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the HiHope RZ/G2N Rev.3.0/4.0 connected to - * sub board - * - * Copyright (C) 2020 Renesas Electronics Corp. - */ - -#include "r8a774b1-hihope-rzg2n.dts" -#include "hihope-rzg2-ex.dtsi" - -/ { - model = "HopeRun HiHope RZ/G2N with sub board"; - compatible = "hoperun,hihope-rzg2-ex", "hoperun,hihope-rzg2n", - "renesas,r8a774b1"; -}; - -/* Set SW43 = ON and SW1001[7] = OFF for SATA port to be activated */ -&sata { - status = "okay"; -}; diff --git a/arch/arm/dts/r8a774b1-hihope-rzg2n.dts b/arch/arm/dts/r8a774b1-hihope-rzg2n.dts deleted file mode 100644 index f1883cbd1a8..00000000000 --- a/arch/arm/dts/r8a774b1-hihope-rzg2n.dts +++ /dev/null @@ -1,41 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the HiHope RZ/G2N main board Rev.3.0/4.0 - * - * Copyright (C) 2020 Renesas Electronics Corp. - */ - -/dts-v1/; -#include "r8a774b1.dtsi" -#include "hihope-rev4.dtsi" - -/ { - model = "HopeRun HiHope RZ/G2N main board based on r8a774b1"; - compatible = "hoperun,hihope-rzg2n", "renesas,r8a774b1"; - - memory@48000000 { - device_type = "memory"; - /* first 128MB is reserved for secure area. */ - reg = <0x0 0x48000000 0x0 0x78000000>; - }; - - memory@480000000 { - device_type = "memory"; - reg = <0x4 0x80000000 0x0 0x80000000>; - }; -}; - -&du { - clocks = <&cpg CPG_MOD 724>, - <&cpg CPG_MOD 723>, - <&cpg CPG_MOD 721>, - <&versaclock5 1>, - <&x302_clk>, - <&versaclock5 2>; - clock-names = "du.0", "du.1", "du.3", - "dclkin.0", "dclkin.1", "dclkin.3"; -}; - -&sdhi3 { - mmc-hs400-1_8v; -}; diff --git a/arch/arm/dts/r8a774b1.dtsi b/arch/arm/dts/r8a774b1.dtsi deleted file mode 100644 index 75776decd21..00000000000 --- a/arch/arm/dts/r8a774b1.dtsi +++ /dev/null @@ -1,2716 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the r8a774b1 SoC - * - * Copyright (C) 2019 Renesas Electronics Corp. - */ - -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/clock/r8a774b1-cpg-mssr.h> -#include <dt-bindings/power/r8a774b1-sysc.h> - -#define CPG_AUDIO_CLK_I R8A774B1_CLK_S0D4 - -/ { - compatible = "renesas,r8a774b1"; - #address-cells = <2>; - #size-cells = <2>; - - /* - * The external audio clocks are configured as 0 Hz fixed frequency - * clocks by default. - * Boards that provide audio clocks should override them. - */ - audio_clk_a: audio_clk_a { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - audio_clk_b: audio_clk_b { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - audio_clk_c: audio_clk_c { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - /* External CAN clock - to be overridden by boards that provide it */ - can_clk: can { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - cluster0_opp: opp-table-0 { - compatible = "operating-points-v2"; - opp-shared; - - opp-500000000 { - opp-hz = /bits/ 64 <500000000>; - opp-microvolt = <830000>; - clock-latency-ns = <300000>; - }; - opp-1000000000 { - opp-hz = /bits/ 64 <1000000000>; - opp-microvolt = <830000>; - clock-latency-ns = <300000>; - }; - opp-1500000000 { - opp-hz = /bits/ 64 <1500000000>; - opp-microvolt = <830000>; - clock-latency-ns = <300000>; - opp-suspend; - }; - }; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - - a57_0: cpu@0 { - compatible = "arm,cortex-a57"; - reg = <0x0>; - device_type = "cpu"; - power-domains = <&sysc R8A774B1_PD_CA57_CPU0>; - next-level-cache = <&L2_CA57>; - enable-method = "psci"; - #cooling-cells = <2>; - dynamic-power-coefficient = <854>; - clocks = <&cpg CPG_CORE R8A774B1_CLK_Z>; - operating-points-v2 = <&cluster0_opp>; - }; - - a57_1: cpu@1 { - compatible = "arm,cortex-a57"; - reg = <0x1>; - device_type = "cpu"; - power-domains = <&sysc R8A774B1_PD_CA57_CPU1>; - next-level-cache = <&L2_CA57>; - enable-method = "psci"; - clocks = <&cpg CPG_CORE R8A774B1_CLK_Z>; - operating-points-v2 = <&cluster0_opp>; - }; - - L2_CA57: cache-controller-0 { - compatible = "cache"; - power-domains = <&sysc R8A774B1_PD_CA57_SCU>; - cache-unified; - cache-level = <2>; - }; - }; - - extal_clk: extal { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board */ - clock-frequency = <0>; - }; - - extalr_clk: extalr { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board */ - clock-frequency = <0>; - }; - - /* External PCIe clock - can be overridden by the board */ - pcie_bus_clk: pcie_bus { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - pmu_a57 { - compatible = "arm,cortex-a57-pmu"; - interrupts-extended = <&gic GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&a57_0>, <&a57_1>; - }; - - psci { - compatible = "arm,psci-1.0", "arm,psci-0.2"; - method = "smc"; - }; - - /* External SCIF clock - to be overridden by boards that provide it */ - scif_clk: scif { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - soc { - compatible = "simple-bus"; - interrupt-parent = <&gic>; - #address-cells = <2>; - #size-cells = <2>; - ranges; - - rwdt: watchdog@e6020000 { - compatible = "renesas,r8a774b1-wdt", - "renesas,rcar-gen3-wdt"; - reg = <0 0xe6020000 0 0x0c>; - interrupts = <GIC_SPI 140 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 402>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 402>; - status = "disabled"; - }; - - gpio0: gpio@e6050000 { - compatible = "renesas,gpio-r8a774b1", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6050000 0 0x50>; - interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 0 16>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 912>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 912>; - }; - - gpio1: gpio@e6051000 { - compatible = "renesas,gpio-r8a774b1", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6051000 0 0x50>; - interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 32 29>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 911>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 911>; - }; - - gpio2: gpio@e6052000 { - compatible = "renesas,gpio-r8a774b1", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6052000 0 0x50>; - interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 64 15>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 910>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 910>; - }; - - gpio3: gpio@e6053000 { - compatible = "renesas,gpio-r8a774b1", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6053000 0 0x50>; - interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 96 16>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 909>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 909>; - }; - - gpio4: gpio@e6054000 { - compatible = "renesas,gpio-r8a774b1", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6054000 0 0x50>; - interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 128 18>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 908>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 908>; - }; - - gpio5: gpio@e6055000 { - compatible = "renesas,gpio-r8a774b1", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6055000 0 0x50>; - interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 160 26>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 907>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 907>; - }; - - gpio6: gpio@e6055400 { - compatible = "renesas,gpio-r8a774b1", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6055400 0 0x50>; - interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 192 32>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 906>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 906>; - }; - - gpio7: gpio@e6055800 { - compatible = "renesas,gpio-r8a774b1", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6055800 0 0x50>; - interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 224 4>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 905>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 905>; - }; - - pfc: pinctrl@e6060000 { - compatible = "renesas,pfc-r8a774b1"; - reg = <0 0xe6060000 0 0x50c>; - }; - - cmt0: timer@e60f0000 { - compatible = "renesas,r8a774b1-cmt0", - "renesas,rcar-gen3-cmt0"; - reg = <0 0xe60f0000 0 0x1004>; - interrupts = <GIC_SPI 142 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 143 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 303>; - clock-names = "fck"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 303>; - status = "disabled"; - }; - - cmt1: timer@e6130000 { - compatible = "renesas,r8a774b1-cmt1", - "renesas,rcar-gen3-cmt1"; - reg = <0 0xe6130000 0 0x1004>; - interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 127 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 302>; - clock-names = "fck"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 302>; - status = "disabled"; - }; - - cmt2: timer@e6140000 { - compatible = "renesas,r8a774b1-cmt1", - "renesas,rcar-gen3-cmt1"; - reg = <0 0xe6140000 0 0x1004>; - interrupts = <GIC_SPI 398 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 399 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 400 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 401 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 402 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 403 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 404 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 405 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 301>; - clock-names = "fck"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 301>; - status = "disabled"; - }; - - cmt3: timer@e6148000 { - compatible = "renesas,r8a774b1-cmt1", - "renesas,rcar-gen3-cmt1"; - reg = <0 0xe6148000 0 0x1004>; - interrupts = <GIC_SPI 470 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 471 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 472 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 473 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 474 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 475 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 476 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 477 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 300>; - clock-names = "fck"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 300>; - status = "disabled"; - }; - - cpg: clock-controller@e6150000 { - compatible = "renesas,r8a774b1-cpg-mssr"; - reg = <0 0xe6150000 0 0x1000>; - clocks = <&extal_clk>, <&extalr_clk>; - clock-names = "extal", "extalr"; - #clock-cells = <2>; - #power-domain-cells = <0>; - #reset-cells = <1>; - }; - - rst: reset-controller@e6160000 { - compatible = "renesas,r8a774b1-rst"; - reg = <0 0xe6160000 0 0x0200>; - }; - - sysc: system-controller@e6180000 { - compatible = "renesas,r8a774b1-sysc"; - reg = <0 0xe6180000 0 0x0400>; - #power-domain-cells = <1>; - }; - - tsc: thermal@e6198000 { - compatible = "renesas,r8a774b1-thermal"; - reg = <0 0xe6198000 0 0x100>, - <0 0xe61a0000 0 0x100>, - <0 0xe61a8000 0 0x100>; - interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 522>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 522>; - #thermal-sensor-cells = <1>; - }; - - intc_ex: interrupt-controller@e61c0000 { - compatible = "renesas,intc-ex-r8a774b1", "renesas,irqc"; - #interrupt-cells = <2>; - interrupt-controller; - reg = <0 0xe61c0000 0 0x200>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 161 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 407>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 407>; - }; - - tmu0: timer@e61e0000 { - compatible = "renesas,tmu-r8a774b1", "renesas,tmu"; - reg = <0 0xe61e0000 0 0x30>; - interrupts = <GIC_SPI 136 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 137 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 138 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 125>; - clock-names = "fck"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 125>; - status = "disabled"; - }; - - tmu1: timer@e6fc0000 { - compatible = "renesas,tmu-r8a774b1", "renesas,tmu"; - reg = <0 0xe6fc0000 0 0x30>; - interrupts = <GIC_SPI 128 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 129 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 130 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 124>; - clock-names = "fck"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 124>; - status = "disabled"; - }; - - tmu2: timer@e6fd0000 { - compatible = "renesas,tmu-r8a774b1", "renesas,tmu"; - reg = <0 0xe6fd0000 0 0x30>; - interrupts = <GIC_SPI 303 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 304 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 305 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 123>; - clock-names = "fck"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 123>; - status = "disabled"; - }; - - tmu3: timer@e6fe0000 { - compatible = "renesas,tmu-r8a774b1", "renesas,tmu"; - reg = <0 0xe6fe0000 0 0x30>; - interrupts = <GIC_SPI 131 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 132 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 133 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 122>; - clock-names = "fck"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 122>; - status = "disabled"; - }; - - tmu4: timer@ffc00000 { - compatible = "renesas,tmu-r8a774b1", "renesas,tmu"; - reg = <0 0xffc00000 0 0x30>; - interrupts = <GIC_SPI 406 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 407 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 408 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 121>; - clock-names = "fck"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 121>; - status = "disabled"; - }; - - i2c0: i2c@e6500000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a774b1", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6500000 0 0x40>; - interrupts = <GIC_SPI 287 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 931>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 931>; - dmas = <&dmac1 0x91>, <&dmac1 0x90>, - <&dmac2 0x91>, <&dmac2 0x90>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - status = "disabled"; - }; - - i2c1: i2c@e6508000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a774b1", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6508000 0 0x40>; - interrupts = <GIC_SPI 288 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 930>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 930>; - dmas = <&dmac1 0x93>, <&dmac1 0x92>, - <&dmac2 0x93>, <&dmac2 0x92>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c2: i2c@e6510000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a774b1", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6510000 0 0x40>; - interrupts = <GIC_SPI 286 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 929>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 929>; - dmas = <&dmac1 0x95>, <&dmac1 0x94>, - <&dmac2 0x95>, <&dmac2 0x94>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c3: i2c@e66d0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a774b1", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66d0000 0 0x40>; - interrupts = <GIC_SPI 290 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 928>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 928>; - dmas = <&dmac0 0x97>, <&dmac0 0x96>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - status = "disabled"; - }; - - i2c4: i2c@e66d8000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a774b1", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66d8000 0 0x40>; - interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 927>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 927>; - dmas = <&dmac0 0x99>, <&dmac0 0x98>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - status = "disabled"; - }; - - i2c5: i2c@e66e0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a774b1", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66e0000 0 0x40>; - interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 919>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 919>; - dmas = <&dmac0 0x9b>, <&dmac0 0x9a>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - status = "disabled"; - }; - - i2c6: i2c@e66e8000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a774b1", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66e8000 0 0x40>; - interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 918>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 918>; - dmas = <&dmac0 0x9d>, <&dmac0 0x9c>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - iic_pmic: i2c@e60b0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,iic-r8a774b1", - "renesas,rcar-gen3-iic", - "renesas,rmobile-iic"; - reg = <0 0xe60b0000 0 0x425>; - interrupts = <GIC_SPI 173 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 926>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 926>; - dmas = <&dmac0 0x11>, <&dmac0 0x10>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - hscif0: serial@e6540000 { - compatible = "renesas,hscif-r8a774b1", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe6540000 0 0x60>; - interrupts = <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 520>, - <&cpg CPG_CORE R8A774B1_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x31>, <&dmac1 0x30>, - <&dmac2 0x31>, <&dmac2 0x30>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 520>; - status = "disabled"; - }; - - hscif1: serial@e6550000 { - compatible = "renesas,hscif-r8a774b1", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe6550000 0 0x60>; - interrupts = <GIC_SPI 155 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 519>, - <&cpg CPG_CORE R8A774B1_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x33>, <&dmac1 0x32>, - <&dmac2 0x33>, <&dmac2 0x32>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 519>; - status = "disabled"; - }; - - hscif2: serial@e6560000 { - compatible = "renesas,hscif-r8a774b1", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe6560000 0 0x60>; - interrupts = <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 518>, - <&cpg CPG_CORE R8A774B1_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x35>, <&dmac1 0x34>, - <&dmac2 0x35>, <&dmac2 0x34>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 518>; - status = "disabled"; - }; - - hscif3: serial@e66a0000 { - compatible = "renesas,hscif-r8a774b1", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe66a0000 0 0x60>; - interrupts = <GIC_SPI 145 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 517>, - <&cpg CPG_CORE R8A774B1_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x37>, <&dmac0 0x36>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 517>; - status = "disabled"; - }; - - hscif4: serial@e66b0000 { - compatible = "renesas,hscif-r8a774b1", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe66b0000 0 0x60>; - interrupts = <GIC_SPI 146 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 516>, - <&cpg CPG_CORE R8A774B1_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x39>, <&dmac0 0x38>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 516>; - status = "disabled"; - }; - - hsusb: usb@e6590000 { - compatible = "renesas,usbhs-r8a774b1", - "renesas,rcar-gen3-usbhs"; - reg = <0 0xe6590000 0 0x200>; - interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 704>, <&cpg CPG_MOD 703>; - dmas = <&usb_dmac0 0>, <&usb_dmac0 1>, - <&usb_dmac1 0>, <&usb_dmac1 1>; - dma-names = "ch0", "ch1", "ch2", "ch3"; - renesas,buswait = <11>; - phys = <&usb2_phy0 3>; - phy-names = "usb"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 704>, <&cpg 703>; - status = "disabled"; - }; - - usb2_clksel: clock-controller@e6590630 { - compatible = "renesas,r8a774b1-rcar-usb2-clock-sel", - "renesas,rcar-gen3-usb2-clock-sel"; - reg = <0 0xe6590630 0 0x02>; - clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>, - <&usb_extal_clk>, <&usb3s0_clk>; - clock-names = "ehci_ohci", "hs-usb-if", - "usb_extal", "usb_xtal"; - #clock-cells = <0>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 703>, <&cpg 704>; - reset-names = "ehci_ohci", "hs-usb-if"; - status = "disabled"; - }; - - usb_dmac0: dma-controller@e65a0000 { - compatible = "renesas,r8a774b1-usb-dmac", - "renesas,usb-dmac"; - reg = <0 0xe65a0000 0 0x100>; - interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1"; - clocks = <&cpg CPG_MOD 330>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 330>; - #dma-cells = <1>; - dma-channels = <2>; - }; - - usb_dmac1: dma-controller@e65b0000 { - compatible = "renesas,r8a774b1-usb-dmac", - "renesas,usb-dmac"; - reg = <0 0xe65b0000 0 0x100>; - interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1"; - clocks = <&cpg CPG_MOD 331>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 331>; - #dma-cells = <1>; - dma-channels = <2>; - }; - - usb3_phy0: usb-phy@e65ee000 { - compatible = "renesas,r8a774b1-usb3-phy", - "renesas,rcar-gen3-usb3-phy"; - reg = <0 0xe65ee000 0 0x90>; - clocks = <&cpg CPG_MOD 328>, <&usb3s0_clk>, - <&usb_extal_clk>; - clock-names = "usb3-if", "usb3s_clk", "usb_extal"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 328>; - #phy-cells = <0>; - status = "disabled"; - }; - - dmac0: dma-controller@e6700000 { - compatible = "renesas,dmac-r8a774b1", - "renesas,rcar-dmac"; - reg = <0 0xe6700000 0 0x10000>; - interrupts = <GIC_SPI 199 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 200 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 201 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 202 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 203 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 204 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 205 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 206 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 207 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 208 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 209 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 210 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 211 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 212 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 213 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 214 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 215 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 219>; - clock-names = "fck"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 219>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_ds0 0>, <&ipmmu_ds0 1>, - <&ipmmu_ds0 2>, <&ipmmu_ds0 3>, - <&ipmmu_ds0 4>, <&ipmmu_ds0 5>, - <&ipmmu_ds0 6>, <&ipmmu_ds0 7>, - <&ipmmu_ds0 8>, <&ipmmu_ds0 9>, - <&ipmmu_ds0 10>, <&ipmmu_ds0 11>, - <&ipmmu_ds0 12>, <&ipmmu_ds0 13>, - <&ipmmu_ds0 14>, <&ipmmu_ds0 15>; - }; - - dmac1: dma-controller@e7300000 { - compatible = "renesas,dmac-r8a774b1", - "renesas,rcar-dmac"; - reg = <0 0xe7300000 0 0x10000>; - interrupts = <GIC_SPI 220 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 216 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 217 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 218 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 219 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 308 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 309 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 310 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 311 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 312 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 313 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 314 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 315 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 316 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 317 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 318 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 319 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 218>; - clock-names = "fck"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 218>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_ds1 0>, <&ipmmu_ds1 1>, - <&ipmmu_ds1 2>, <&ipmmu_ds1 3>, - <&ipmmu_ds1 4>, <&ipmmu_ds1 5>, - <&ipmmu_ds1 6>, <&ipmmu_ds1 7>, - <&ipmmu_ds1 8>, <&ipmmu_ds1 9>, - <&ipmmu_ds1 10>, <&ipmmu_ds1 11>, - <&ipmmu_ds1 12>, <&ipmmu_ds1 13>, - <&ipmmu_ds1 14>, <&ipmmu_ds1 15>; - }; - - dmac2: dma-controller@e7310000 { - compatible = "renesas,dmac-r8a774b1", - "renesas,rcar-dmac"; - reg = <0 0xe7310000 0 0x10000>; - interrupts = <GIC_SPI 416 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 417 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 418 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 419 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 420 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 421 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 422 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 423 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 424 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 425 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 426 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 427 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 428 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 429 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 430 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 431 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 397 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 217>; - clock-names = "fck"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 217>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_ds1 16>, <&ipmmu_ds1 17>, - <&ipmmu_ds1 18>, <&ipmmu_ds1 19>, - <&ipmmu_ds1 20>, <&ipmmu_ds1 21>, - <&ipmmu_ds1 22>, <&ipmmu_ds1 23>, - <&ipmmu_ds1 24>, <&ipmmu_ds1 25>, - <&ipmmu_ds1 26>, <&ipmmu_ds1 27>, - <&ipmmu_ds1 28>, <&ipmmu_ds1 29>, - <&ipmmu_ds1 30>, <&ipmmu_ds1 31>; - }; - - ipmmu_ds0: iommu@e6740000 { - compatible = "renesas,ipmmu-r8a774b1"; - reg = <0 0xe6740000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 0>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_ds1: iommu@e7740000 { - compatible = "renesas,ipmmu-r8a774b1"; - reg = <0 0xe7740000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 1>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_hc: iommu@e6570000 { - compatible = "renesas,ipmmu-r8a774b1"; - reg = <0 0xe6570000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 2>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_mm: iommu@e67b0000 { - compatible = "renesas,ipmmu-r8a774b1"; - reg = <0 0xe67b0000 0 0x1000>; - interrupts = <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_mp: iommu@ec670000 { - compatible = "renesas,ipmmu-r8a774b1"; - reg = <0 0xec670000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 4>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_pv0: iommu@fd800000 { - compatible = "renesas,ipmmu-r8a774b1"; - reg = <0 0xfd800000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 6>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_vc0: iommu@fe6b0000 { - compatible = "renesas,ipmmu-r8a774b1"; - reg = <0 0xfe6b0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 12>; - power-domains = <&sysc R8A774B1_PD_A3VC>; - #iommu-cells = <1>; - }; - - ipmmu_vi0: iommu@febd0000 { - compatible = "renesas,ipmmu-r8a774b1"; - reg = <0 0xfebd0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 14>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_vp0: iommu@fe990000 { - compatible = "renesas,ipmmu-r8a774b1"; - reg = <0 0xfe990000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 16>; - power-domains = <&sysc R8A774B1_PD_A3VP>; - #iommu-cells = <1>; - }; - - avb: ethernet@e6800000 { - compatible = "renesas,etheravb-r8a774b1", - "renesas,etheravb-rcar-gen3"; - reg = <0 0xe6800000 0 0x800>; - interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 47 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 63 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15", - "ch16", "ch17", "ch18", "ch19", - "ch20", "ch21", "ch22", "ch23", - "ch24"; - clocks = <&cpg CPG_MOD 812>; - clock-names = "fck"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 812>; - phy-mode = "rgmii"; - rx-internal-delay-ps = <0>; - tx-internal-delay-ps = <0>; - iommus = <&ipmmu_ds0 16>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - can0: can@e6c30000 { - compatible = "renesas,can-r8a774b1", - "renesas,rcar-gen3-can"; - reg = <0 0xe6c30000 0 0x1000>; - interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 916>, - <&cpg CPG_CORE R8A774B1_CLK_CANFD>, - <&can_clk>; - clock-names = "clkp1", "clkp2", "can_clk"; - assigned-clocks = <&cpg CPG_CORE R8A774B1_CLK_CANFD>; - assigned-clock-rates = <40000000>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 916>; - status = "disabled"; - }; - - can1: can@e6c38000 { - compatible = "renesas,can-r8a774b1", - "renesas,rcar-gen3-can"; - reg = <0 0xe6c38000 0 0x1000>; - interrupts = <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 915>, - <&cpg CPG_CORE R8A774B1_CLK_CANFD>, - <&can_clk>; - clock-names = "clkp1", "clkp2", "can_clk"; - assigned-clocks = <&cpg CPG_CORE R8A774B1_CLK_CANFD>; - assigned-clock-rates = <40000000>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 915>; - status = "disabled"; - }; - - canfd: can@e66c0000 { - compatible = "renesas,r8a774b1-canfd", - "renesas,rcar-gen3-canfd"; - reg = <0 0xe66c0000 0 0x8000>; - interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch_int", "g_int"; - clocks = <&cpg CPG_MOD 914>, - <&cpg CPG_CORE R8A774B1_CLK_CANFD>, - <&can_clk>; - clock-names = "fck", "canfd", "can_clk"; - assigned-clocks = <&cpg CPG_CORE R8A774B1_CLK_CANFD>; - assigned-clock-rates = <40000000>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 914>; - status = "disabled"; - - channel0 { - status = "disabled"; - }; - - channel1 { - status = "disabled"; - }; - }; - - pwm0: pwm@e6e30000 { - compatible = "renesas,pwm-r8a774b1", "renesas,pwm-rcar"; - reg = <0 0xe6e30000 0 0x8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - resets = <&cpg 523>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - status = "disabled"; - }; - - pwm1: pwm@e6e31000 { - compatible = "renesas,pwm-r8a774b1", "renesas,pwm-rcar"; - reg = <0 0xe6e31000 0 0x8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - resets = <&cpg 523>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - status = "disabled"; - }; - - pwm2: pwm@e6e32000 { - compatible = "renesas,pwm-r8a774b1", "renesas,pwm-rcar"; - reg = <0 0xe6e32000 0 0x8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - resets = <&cpg 523>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - status = "disabled"; - }; - - pwm3: pwm@e6e33000 { - compatible = "renesas,pwm-r8a774b1", "renesas,pwm-rcar"; - reg = <0 0xe6e33000 0 0x8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - resets = <&cpg 523>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - status = "disabled"; - }; - - pwm4: pwm@e6e34000 { - compatible = "renesas,pwm-r8a774b1", "renesas,pwm-rcar"; - reg = <0 0xe6e34000 0 0x8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - resets = <&cpg 523>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - status = "disabled"; - }; - - pwm5: pwm@e6e35000 { - compatible = "renesas,pwm-r8a774b1", "renesas,pwm-rcar"; - reg = <0 0xe6e35000 0 0x8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - resets = <&cpg 523>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - status = "disabled"; - }; - - pwm6: pwm@e6e36000 { - compatible = "renesas,pwm-r8a774b1", "renesas,pwm-rcar"; - reg = <0 0xe6e36000 0 0x8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - resets = <&cpg 523>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - status = "disabled"; - }; - - scif0: serial@e6e60000 { - compatible = "renesas,scif-r8a774b1", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6e60000 0 0x40>; - interrupts = <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 207>, - <&cpg CPG_CORE R8A774B1_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x51>, <&dmac1 0x50>, - <&dmac2 0x51>, <&dmac2 0x50>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 207>; - status = "disabled"; - }; - - scif1: serial@e6e68000 { - compatible = "renesas,scif-r8a774b1", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6e68000 0 0x40>; - interrupts = <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 206>, - <&cpg CPG_CORE R8A774B1_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x53>, <&dmac1 0x52>, - <&dmac2 0x53>, <&dmac2 0x52>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 206>; - status = "disabled"; - }; - - scif2: serial@e6e88000 { - compatible = "renesas,scif-r8a774b1", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6e88000 0 0x40>; - interrupts = <GIC_SPI 164 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 310>, - <&cpg CPG_CORE R8A774B1_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x13>, <&dmac1 0x12>, - <&dmac2 0x13>, <&dmac2 0x12>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 310>; - status = "disabled"; - }; - - scif3: serial@e6c50000 { - compatible = "renesas,scif-r8a774b1", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6c50000 0 0x40>; - interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 204>, - <&cpg CPG_CORE R8A774B1_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x57>, <&dmac0 0x56>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 204>; - status = "disabled"; - }; - - scif4: serial@e6c40000 { - compatible = "renesas,scif-r8a774b1", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6c40000 0 0x40>; - interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 203>, - <&cpg CPG_CORE R8A774B1_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x59>, <&dmac0 0x58>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 203>; - status = "disabled"; - }; - - scif5: serial@e6f30000 { - compatible = "renesas,scif-r8a774b1", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6f30000 0 0x40>; - interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 202>, - <&cpg CPG_CORE R8A774B1_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x5b>, <&dmac1 0x5a>, - <&dmac2 0x5b>, <&dmac2 0x5a>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 202>; - status = "disabled"; - }; - - msiof0: spi@e6e90000 { - compatible = "renesas,msiof-r8a774b1", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6e90000 0 0x0064>; - interrupts = <GIC_SPI 156 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 211>; - dmas = <&dmac1 0x41>, <&dmac1 0x40>, - <&dmac2 0x41>, <&dmac2 0x40>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 211>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof1: spi@e6ea0000 { - compatible = "renesas,msiof-r8a774b1", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6ea0000 0 0x0064>; - interrupts = <GIC_SPI 157 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 210>; - dmas = <&dmac1 0x43>, <&dmac1 0x42>, - <&dmac2 0x43>, <&dmac2 0x42>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 210>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof2: spi@e6c00000 { - compatible = "renesas,msiof-r8a774b1", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6c00000 0 0x0064>; - interrupts = <GIC_SPI 158 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 209>; - dmas = <&dmac0 0x45>, <&dmac0 0x44>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 209>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof3: spi@e6c10000 { - compatible = "renesas,msiof-r8a774b1", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6c10000 0 0x0064>; - interrupts = <GIC_SPI 159 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 208>; - dmas = <&dmac0 0x47>, <&dmac0 0x46>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 208>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - vin0: video@e6ef0000 { - compatible = "renesas,vin-r8a774b1"; - reg = <0 0xe6ef0000 0 0x1000>; - interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 811>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 811>; - renesas,id = <0>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin0csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin0>; - }; - vin0csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin0>; - }; - }; - }; - }; - - vin1: video@e6ef1000 { - compatible = "renesas,vin-r8a774b1"; - reg = <0 0xe6ef1000 0 0x1000>; - interrupts = <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 810>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 810>; - renesas,id = <1>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin1csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin1>; - }; - vin1csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin1>; - }; - }; - }; - }; - - vin2: video@e6ef2000 { - compatible = "renesas,vin-r8a774b1"; - reg = <0 0xe6ef2000 0 0x1000>; - interrupts = <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 809>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 809>; - renesas,id = <2>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin2csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin2>; - }; - vin2csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin2>; - }; - }; - }; - }; - - vin3: video@e6ef3000 { - compatible = "renesas,vin-r8a774b1"; - reg = <0 0xe6ef3000 0 0x1000>; - interrupts = <GIC_SPI 191 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 808>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 808>; - renesas,id = <3>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin3csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin3>; - }; - vin3csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin3>; - }; - }; - }; - }; - - vin4: video@e6ef4000 { - compatible = "renesas,vin-r8a774b1"; - reg = <0 0xe6ef4000 0 0x1000>; - interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 807>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 807>; - renesas,id = <4>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin4csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin4>; - }; - vin4csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin4>; - }; - }; - }; - }; - - vin5: video@e6ef5000 { - compatible = "renesas,vin-r8a774b1"; - reg = <0 0xe6ef5000 0 0x1000>; - interrupts = <GIC_SPI 175 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 806>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 806>; - renesas,id = <5>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin5csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin5>; - }; - vin5csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin5>; - }; - }; - }; - }; - - vin6: video@e6ef6000 { - compatible = "renesas,vin-r8a774b1"; - reg = <0 0xe6ef6000 0 0x1000>; - interrupts = <GIC_SPI 176 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 805>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 805>; - renesas,id = <6>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin6csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin6>; - }; - vin6csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin6>; - }; - }; - }; - }; - - vin7: video@e6ef7000 { - compatible = "renesas,vin-r8a774b1"; - reg = <0 0xe6ef7000 0 0x1000>; - interrupts = <GIC_SPI 171 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 804>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 804>; - renesas,id = <7>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin7csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin7>; - }; - vin7csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin7>; - }; - }; - }; - }; - - rcar_sound: sound@ec500000 { - /* - * #sound-dai-cells is required if simple-card - * - * Single DAI : #sound-dai-cells = <0>; <&rcar_sound>; - * Multi DAI : #sound-dai-cells = <1>; <&rcar_sound N>; - */ - /* - * #clock-cells is required for audio_clkout0/1/2/3 - * - * clkout : #clock-cells = <0>; <&rcar_sound>; - * clkout0/1/2/3: #clock-cells = <1>; <&rcar_sound N>; - */ - compatible = "renesas,rcar_sound-r8a774b1", "renesas,rcar_sound-gen3"; - reg = <0 0xec500000 0 0x1000>, /* SCU */ - <0 0xec5a0000 0 0x100>, /* ADG */ - <0 0xec540000 0 0x1000>, /* SSIU */ - <0 0xec541000 0 0x280>, /* SSI */ - <0 0xec760000 0 0x200>; /* Audio DMAC peri peri*/ - reg-names = "scu", "adg", "ssiu", "ssi", "audmapp"; - - clocks = <&cpg CPG_MOD 1005>, - <&cpg CPG_MOD 1006>, <&cpg CPG_MOD 1007>, - <&cpg CPG_MOD 1008>, <&cpg CPG_MOD 1009>, - <&cpg CPG_MOD 1010>, <&cpg CPG_MOD 1011>, - <&cpg CPG_MOD 1012>, <&cpg CPG_MOD 1013>, - <&cpg CPG_MOD 1014>, <&cpg CPG_MOD 1015>, - <&cpg CPG_MOD 1022>, <&cpg CPG_MOD 1023>, - <&cpg CPG_MOD 1024>, <&cpg CPG_MOD 1025>, - <&cpg CPG_MOD 1026>, <&cpg CPG_MOD 1027>, - <&cpg CPG_MOD 1028>, <&cpg CPG_MOD 1029>, - <&cpg CPG_MOD 1030>, <&cpg CPG_MOD 1031>, - <&cpg CPG_MOD 1020>, <&cpg CPG_MOD 1021>, - <&cpg CPG_MOD 1020>, <&cpg CPG_MOD 1021>, - <&cpg CPG_MOD 1019>, <&cpg CPG_MOD 1018>, - <&audio_clk_a>, <&audio_clk_b>, - <&audio_clk_c>, - <&cpg CPG_CORE R8A774B1_CLK_S0D4>; - clock-names = "ssi-all", - "ssi.9", "ssi.8", "ssi.7", "ssi.6", - "ssi.5", "ssi.4", "ssi.3", "ssi.2", - "ssi.1", "ssi.0", - "src.9", "src.8", "src.7", "src.6", - "src.5", "src.4", "src.3", "src.2", - "src.1", "src.0", - "mix.1", "mix.0", - "ctu.1", "ctu.0", - "dvc.0", "dvc.1", - "clk_a", "clk_b", "clk_c", "clk_i"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 1005>, - <&cpg 1006>, <&cpg 1007>, - <&cpg 1008>, <&cpg 1009>, - <&cpg 1010>, <&cpg 1011>, - <&cpg 1012>, <&cpg 1013>, - <&cpg 1014>, <&cpg 1015>; - reset-names = "ssi-all", - "ssi.9", "ssi.8", "ssi.7", "ssi.6", - "ssi.5", "ssi.4", "ssi.3", "ssi.2", - "ssi.1", "ssi.0"; - status = "disabled"; - - rcar_sound,ctu { - ctu00: ctu-0 { }; - ctu01: ctu-1 { }; - ctu02: ctu-2 { }; - ctu03: ctu-3 { }; - ctu10: ctu-4 { }; - ctu11: ctu-5 { }; - ctu12: ctu-6 { }; - ctu13: ctu-7 { }; - }; - - rcar_sound,dvc { - dvc0: dvc-0 { - dmas = <&audma1 0xbc>; - dma-names = "tx"; - }; - dvc1: dvc-1 { - dmas = <&audma1 0xbe>; - dma-names = "tx"; - }; - }; - - rcar_sound,mix { - mix0: mix-0 { }; - mix1: mix-1 { }; - }; - - rcar_sound,src { - src0: src-0 { - interrupts = <GIC_SPI 352 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x85>, <&audma1 0x9a>; - dma-names = "rx", "tx"; - }; - src1: src-1 { - interrupts = <GIC_SPI 353 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x87>, <&audma1 0x9c>; - dma-names = "rx", "tx"; - }; - src2: src-2 { - interrupts = <GIC_SPI 354 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x89>, <&audma1 0x9e>; - dma-names = "rx", "tx"; - }; - src3: src-3 { - interrupts = <GIC_SPI 355 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x8b>, <&audma1 0xa0>; - dma-names = "rx", "tx"; - }; - src4: src-4 { - interrupts = <GIC_SPI 356 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x8d>, <&audma1 0xb0>; - dma-names = "rx", "tx"; - }; - src5: src-5 { - interrupts = <GIC_SPI 357 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x8f>, <&audma1 0xb2>; - dma-names = "rx", "tx"; - }; - src6: src-6 { - interrupts = <GIC_SPI 358 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x91>, <&audma1 0xb4>; - dma-names = "rx", "tx"; - }; - src7: src-7 { - interrupts = <GIC_SPI 359 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x93>, <&audma1 0xb6>; - dma-names = "rx", "tx"; - }; - src8: src-8 { - interrupts = <GIC_SPI 360 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x95>, <&audma1 0xb8>; - dma-names = "rx", "tx"; - }; - src9: src-9 { - interrupts = <GIC_SPI 361 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x97>, <&audma1 0xba>; - dma-names = "rx", "tx"; - }; - }; - - rcar_sound,ssi { - ssi0: ssi-0 { - interrupts = <GIC_SPI 370 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x01>, <&audma1 0x02>; - dma-names = "rx", "tx"; - }; - ssi1: ssi-1 { - interrupts = <GIC_SPI 371 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x03>, <&audma1 0x04>; - dma-names = "rx", "tx"; - }; - ssi2: ssi-2 { - interrupts = <GIC_SPI 372 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x05>, <&audma1 0x06>; - dma-names = "rx", "tx"; - }; - ssi3: ssi-3 { - interrupts = <GIC_SPI 373 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x07>, <&audma1 0x08>; - dma-names = "rx", "tx"; - }; - ssi4: ssi-4 { - interrupts = <GIC_SPI 374 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x09>, <&audma1 0x0a>; - dma-names = "rx", "tx"; - }; - ssi5: ssi-5 { - interrupts = <GIC_SPI 375 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x0b>, <&audma1 0x0c>; - dma-names = "rx", "tx"; - }; - ssi6: ssi-6 { - interrupts = <GIC_SPI 376 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x0d>, <&audma1 0x0e>; - dma-names = "rx", "tx"; - }; - ssi7: ssi-7 { - interrupts = <GIC_SPI 377 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x0f>, <&audma1 0x10>; - dma-names = "rx", "tx"; - }; - ssi8: ssi-8 { - interrupts = <GIC_SPI 378 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x11>, <&audma1 0x12>; - dma-names = "rx", "tx"; - }; - ssi9: ssi-9 { - interrupts = <GIC_SPI 379 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x13>, <&audma1 0x14>; - dma-names = "rx", "tx"; - }; - }; - - rcar_sound,ssiu { - ssiu00: ssiu-0 { - dmas = <&audma0 0x15>, <&audma1 0x16>; - dma-names = "rx", "tx"; - }; - ssiu01: ssiu-1 { - dmas = <&audma0 0x35>, <&audma1 0x36>; - dma-names = "rx", "tx"; - }; - ssiu02: ssiu-2 { - dmas = <&audma0 0x37>, <&audma1 0x38>; - dma-names = "rx", "tx"; - }; - ssiu03: ssiu-3 { - dmas = <&audma0 0x47>, <&audma1 0x48>; - dma-names = "rx", "tx"; - }; - ssiu04: ssiu-4 { - dmas = <&audma0 0x3F>, <&audma1 0x40>; - dma-names = "rx", "tx"; - }; - ssiu05: ssiu-5 { - dmas = <&audma0 0x43>, <&audma1 0x44>; - dma-names = "rx", "tx"; - }; - ssiu06: ssiu-6 { - dmas = <&audma0 0x4F>, <&audma1 0x50>; - dma-names = "rx", "tx"; - }; - ssiu07: ssiu-7 { - dmas = <&audma0 0x53>, <&audma1 0x54>; - dma-names = "rx", "tx"; - }; - ssiu10: ssiu-8 { - dmas = <&audma0 0x49>, <&audma1 0x4a>; - dma-names = "rx", "tx"; - }; - ssiu11: ssiu-9 { - dmas = <&audma0 0x4B>, <&audma1 0x4C>; - dma-names = "rx", "tx"; - }; - ssiu12: ssiu-10 { - dmas = <&audma0 0x57>, <&audma1 0x58>; - dma-names = "rx", "tx"; - }; - ssiu13: ssiu-11 { - dmas = <&audma0 0x59>, <&audma1 0x5A>; - dma-names = "rx", "tx"; - }; - ssiu14: ssiu-12 { - dmas = <&audma0 0x5F>, <&audma1 0x60>; - dma-names = "rx", "tx"; - }; - ssiu15: ssiu-13 { - dmas = <&audma0 0xC3>, <&audma1 0xC4>; - dma-names = "rx", "tx"; - }; - ssiu16: ssiu-14 { - dmas = <&audma0 0xC7>, <&audma1 0xC8>; - dma-names = "rx", "tx"; - }; - ssiu17: ssiu-15 { - dmas = <&audma0 0xCB>, <&audma1 0xCC>; - dma-names = "rx", "tx"; - }; - ssiu20: ssiu-16 { - dmas = <&audma0 0x63>, <&audma1 0x64>; - dma-names = "rx", "tx"; - }; - ssiu21: ssiu-17 { - dmas = <&audma0 0x67>, <&audma1 0x68>; - dma-names = "rx", "tx"; - }; - ssiu22: ssiu-18 { - dmas = <&audma0 0x6B>, <&audma1 0x6C>; - dma-names = "rx", "tx"; - }; - ssiu23: ssiu-19 { - dmas = <&audma0 0x6D>, <&audma1 0x6E>; - dma-names = "rx", "tx"; - }; - ssiu24: ssiu-20 { - dmas = <&audma0 0xCF>, <&audma1 0xCE>; - dma-names = "rx", "tx"; - }; - ssiu25: ssiu-21 { - dmas = <&audma0 0xEB>, <&audma1 0xEC>; - dma-names = "rx", "tx"; - }; - ssiu26: ssiu-22 { - dmas = <&audma0 0xED>, <&audma1 0xEE>; - dma-names = "rx", "tx"; - }; - ssiu27: ssiu-23 { - dmas = <&audma0 0xEF>, <&audma1 0xF0>; - dma-names = "rx", "tx"; - }; - ssiu30: ssiu-24 { - dmas = <&audma0 0x6f>, <&audma1 0x70>; - dma-names = "rx", "tx"; - }; - ssiu31: ssiu-25 { - dmas = <&audma0 0x21>, <&audma1 0x22>; - dma-names = "rx", "tx"; - }; - ssiu32: ssiu-26 { - dmas = <&audma0 0x23>, <&audma1 0x24>; - dma-names = "rx", "tx"; - }; - ssiu33: ssiu-27 { - dmas = <&audma0 0x25>, <&audma1 0x26>; - dma-names = "rx", "tx"; - }; - ssiu34: ssiu-28 { - dmas = <&audma0 0x27>, <&audma1 0x28>; - dma-names = "rx", "tx"; - }; - ssiu35: ssiu-29 { - dmas = <&audma0 0x29>, <&audma1 0x2A>; - dma-names = "rx", "tx"; - }; - ssiu36: ssiu-30 { - dmas = <&audma0 0x2B>, <&audma1 0x2C>; - dma-names = "rx", "tx"; - }; - ssiu37: ssiu-31 { - dmas = <&audma0 0x2D>, <&audma1 0x2E>; - dma-names = "rx", "tx"; - }; - ssiu40: ssiu-32 { - dmas = <&audma0 0x71>, <&audma1 0x72>; - dma-names = "rx", "tx"; - }; - ssiu41: ssiu-33 { - dmas = <&audma0 0x17>, <&audma1 0x18>; - dma-names = "rx", "tx"; - }; - ssiu42: ssiu-34 { - dmas = <&audma0 0x19>, <&audma1 0x1A>; - dma-names = "rx", "tx"; - }; - ssiu43: ssiu-35 { - dmas = <&audma0 0x1B>, <&audma1 0x1C>; - dma-names = "rx", "tx"; - }; - ssiu44: ssiu-36 { - dmas = <&audma0 0x1D>, <&audma1 0x1E>; - dma-names = "rx", "tx"; - }; - ssiu45: ssiu-37 { - dmas = <&audma0 0x1F>, <&audma1 0x20>; - dma-names = "rx", "tx"; - }; - ssiu46: ssiu-38 { - dmas = <&audma0 0x31>, <&audma1 0x32>; - dma-names = "rx", "tx"; - }; - ssiu47: ssiu-39 { - dmas = <&audma0 0x33>, <&audma1 0x34>; - dma-names = "rx", "tx"; - }; - ssiu50: ssiu-40 { - dmas = <&audma0 0x73>, <&audma1 0x74>; - dma-names = "rx", "tx"; - }; - ssiu60: ssiu-41 { - dmas = <&audma0 0x75>, <&audma1 0x76>; - dma-names = "rx", "tx"; - }; - ssiu70: ssiu-42 { - dmas = <&audma0 0x79>, <&audma1 0x7a>; - dma-names = "rx", "tx"; - }; - ssiu80: ssiu-43 { - dmas = <&audma0 0x7b>, <&audma1 0x7c>; - dma-names = "rx", "tx"; - }; - ssiu90: ssiu-44 { - dmas = <&audma0 0x7d>, <&audma1 0x7e>; - dma-names = "rx", "tx"; - }; - ssiu91: ssiu-45 { - dmas = <&audma0 0x7F>, <&audma1 0x80>; - dma-names = "rx", "tx"; - }; - ssiu92: ssiu-46 { - dmas = <&audma0 0x81>, <&audma1 0x82>; - dma-names = "rx", "tx"; - }; - ssiu93: ssiu-47 { - dmas = <&audma0 0x83>, <&audma1 0x84>; - dma-names = "rx", "tx"; - }; - ssiu94: ssiu-48 { - dmas = <&audma0 0xA3>, <&audma1 0xA4>; - dma-names = "rx", "tx"; - }; - ssiu95: ssiu-49 { - dmas = <&audma0 0xA5>, <&audma1 0xA6>; - dma-names = "rx", "tx"; - }; - ssiu96: ssiu-50 { - dmas = <&audma0 0xA7>, <&audma1 0xA8>; - dma-names = "rx", "tx"; - }; - ssiu97: ssiu-51 { - dmas = <&audma0 0xA9>, <&audma1 0xAA>; - dma-names = "rx", "tx"; - }; - }; - }; - - audma0: dma-controller@ec700000 { - compatible = "renesas,dmac-r8a774b1", - "renesas,rcar-dmac"; - reg = <0 0xec700000 0 0x10000>; - interrupts = <GIC_SPI 350 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 320 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 321 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 322 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 323 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 324 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 325 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 326 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 327 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 328 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 329 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 330 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 331 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 332 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 333 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 334 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 335 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 502>; - clock-names = "fck"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 502>; - #dma-cells = <1>; - dma-channels = <16>; - }; - - audma1: dma-controller@ec720000 { - compatible = "renesas,dmac-r8a774b1", - "renesas,rcar-dmac"; - reg = <0 0xec720000 0 0x10000>; - interrupts = <GIC_SPI 351 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 336 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 337 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 338 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 339 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 340 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 341 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 342 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 343 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 344 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 345 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 346 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 347 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 348 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 349 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 382 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 383 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 501>; - clock-names = "fck"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 501>; - #dma-cells = <1>; - dma-channels = <16>; - }; - - xhci0: usb@ee000000 { - compatible = "renesas,xhci-r8a774b1", - "renesas,rcar-gen3-xhci"; - reg = <0 0xee000000 0 0xc00>; - interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 328>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 328>; - status = "disabled"; - }; - - usb3_peri0: usb@ee020000 { - compatible = "renesas,r8a774b1-usb3-peri", - "renesas,rcar-gen3-usb3-peri"; - reg = <0 0xee020000 0 0x400>; - interrupts = <GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 328>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 328>; - status = "disabled"; - }; - - ohci0: usb@ee080000 { - compatible = "generic-ohci"; - reg = <0 0xee080000 0 0x100>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>; - phys = <&usb2_phy0 1>; - phy-names = "usb"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 703>, <&cpg 704>; - status = "disabled"; - }; - - ohci1: usb@ee0a0000 { - compatible = "generic-ohci"; - reg = <0 0xee0a0000 0 0x100>; - interrupts = <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 702>; - phys = <&usb2_phy1 1>; - phy-names = "usb"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 702>; - status = "disabled"; - }; - - ehci0: usb@ee080100 { - compatible = "generic-ehci"; - reg = <0 0xee080100 0 0x100>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>; - phys = <&usb2_phy0 2>; - phy-names = "usb"; - companion = <&ohci0>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 703>, <&cpg 704>; - status = "disabled"; - }; - - ehci1: usb@ee0a0100 { - compatible = "generic-ehci"; - reg = <0 0xee0a0100 0 0x100>; - interrupts = <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 702>; - phys = <&usb2_phy1 2>; - phy-names = "usb"; - companion = <&ohci1>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 702>; - status = "disabled"; - }; - - usb2_phy0: usb-phy@ee080200 { - compatible = "renesas,usb2-phy-r8a774b1", - "renesas,rcar-gen3-usb2-phy"; - reg = <0 0xee080200 0 0x700>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 703>, <&cpg 704>; - #phy-cells = <1>; - status = "disabled"; - }; - - usb2_phy1: usb-phy@ee0a0200 { - compatible = "renesas,usb2-phy-r8a774b1", - "renesas,rcar-gen3-usb2-phy"; - reg = <0 0xee0a0200 0 0x700>; - clocks = <&cpg CPG_MOD 702>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 702>; - #phy-cells = <1>; - status = "disabled"; - }; - - sdhi0: mmc@ee100000 { - compatible = "renesas,sdhi-r8a774b1", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee100000 0 0x2000>; - interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 314>, <&cpg CPG_CORE R8A774B1_CLK_SD0H>; - clock-names = "core", "clkh"; - max-frequency = <200000000>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 314>; - status = "disabled"; - }; - - sdhi1: mmc@ee120000 { - compatible = "renesas,sdhi-r8a774b1", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee120000 0 0x2000>; - interrupts = <GIC_SPI 166 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 313>, <&cpg CPG_CORE R8A774B1_CLK_SD1H>; - clock-names = "core", "clkh"; - max-frequency = <200000000>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 313>; - status = "disabled"; - }; - - sdhi2: mmc@ee140000 { - compatible = "renesas,sdhi-r8a774b1", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee140000 0 0x2000>; - interrupts = <GIC_SPI 167 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 312>, <&cpg CPG_CORE R8A774B1_CLK_SD2H>; - clock-names = "core", "clkh"; - max-frequency = <200000000>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 312>; - status = "disabled"; - }; - - sdhi3: mmc@ee160000 { - compatible = "renesas,sdhi-r8a774b1", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee160000 0 0x2000>; - interrupts = <GIC_SPI 168 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 311>, <&cpg CPG_CORE R8A774B1_CLK_SD3H>; - clock-names = "core", "clkh"; - max-frequency = <200000000>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 311>; - status = "disabled"; - }; - - rpc: spi@ee200000 { - compatible = "renesas,r8a774b1-rpc-if", - "renesas,rcar-gen3-rpc-if"; - reg = <0 0xee200000 0 0x200>, - <0 0x08000000 0 0x4000000>, - <0 0xee208000 0 0x100>; - reg-names = "regs", "dirmap", "wbuf"; - interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 917>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 917>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - sata: sata@ee300000 { - compatible = "renesas,sata-r8a774b1", - "renesas,rcar-gen3-sata"; - reg = <0 0xee300000 0 0x200000>; - interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 815>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 815>; - status = "disabled"; - }; - - gic: interrupt-controller@f1010000 { - compatible = "arm,gic-400"; - #interrupt-cells = <3>; - #address-cells = <0>; - interrupt-controller; - reg = <0x0 0xf1010000 0 0x1000>, - <0x0 0xf1020000 0 0x20000>, - <0x0 0xf1040000 0 0x20000>, - <0x0 0xf1060000 0 0x20000>; - interrupts = <GIC_PPI 9 - (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_HIGH)>; - clocks = <&cpg CPG_MOD 408>; - clock-names = "clk"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 408>; - }; - - pciec0: pcie@fe000000 { - compatible = "renesas,pcie-r8a774b1", - "renesas,pcie-rcar-gen3"; - reg = <0 0xfe000000 0 0x80000>; - #address-cells = <3>; - #size-cells = <2>; - bus-range = <0x00 0xff>; - device_type = "pci"; - ranges = <0x01000000 0 0x00000000 0 0xfe100000 0 0x00100000>, - <0x02000000 0 0xfe200000 0 0xfe200000 0 0x00200000>, - <0x02000000 0 0x30000000 0 0x30000000 0 0x08000000>, - <0x42000000 0 0x38000000 0 0x38000000 0 0x08000000>; - /* Map all possible DDR/IOMMU as inbound ranges */ - dma-ranges = <0x42000000 0 0x00000000 0 0x00000000 1 0x00000000>; - interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>; - #interrupt-cells = <1>; - interrupt-map-mask = <0 0 0 0>; - interrupt-map = <0 0 0 0 &gic GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 319>, <&pcie_bus_clk>; - clock-names = "pcie", "pcie_bus"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 319>; - iommu-map = <0 &ipmmu_hc 0 1>; - iommu-map-mask = <0>; - status = "disabled"; - }; - - pciec1: pcie@ee800000 { - compatible = "renesas,pcie-r8a774b1", - "renesas,pcie-rcar-gen3"; - reg = <0 0xee800000 0 0x80000>; - #address-cells = <3>; - #size-cells = <2>; - bus-range = <0x00 0xff>; - device_type = "pci"; - ranges = <0x01000000 0 0x00000000 0 0xee900000 0 0x00100000>, - <0x02000000 0 0xeea00000 0 0xeea00000 0 0x00200000>, - <0x02000000 0 0xc0000000 0 0xc0000000 0 0x08000000>, - <0x42000000 0 0xc8000000 0 0xc8000000 0 0x08000000>; - /* Map all possible DDR/IOMMU as inbound ranges */ - dma-ranges = <0x42000000 0 0x00000000 0 0x00000000 1 0x00000000>; - interrupts = <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 149 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 150 IRQ_TYPE_LEVEL_HIGH>; - #interrupt-cells = <1>; - interrupt-map-mask = <0 0 0 0>; - interrupt-map = <0 0 0 0 &gic GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 318>, <&pcie_bus_clk>; - clock-names = "pcie", "pcie_bus"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 318>; - iommu-map = <0 &ipmmu_hc 1 1>; - iommu-map-mask = <0>; - status = "disabled"; - }; - - pciec0_ep: pcie-ep@fe000000 { - compatible = "renesas,r8a774b1-pcie-ep", - "renesas,rcar-gen3-pcie-ep"; - reg = <0x0 0xfe000000 0 0x80000>, - <0x0 0xfe100000 0 0x100000>, - <0x0 0xfe200000 0 0x200000>, - <0x0 0x30000000 0 0x8000000>, - <0x0 0x38000000 0 0x8000000>; - reg-names = "apb-base", "memory0", "memory1", "memory2", "memory3"; - interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 319>; - clock-names = "pcie"; - resets = <&cpg 319>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - status = "disabled"; - }; - - pciec1_ep: pcie-ep@ee800000 { - compatible = "renesas,r8a774b1-pcie-ep", - "renesas,rcar-gen3-pcie-ep"; - reg = <0x0 0xee800000 0 0x80000>, - <0x0 0xee900000 0 0x100000>, - <0x0 0xeea00000 0 0x200000>, - <0x0 0xc0000000 0 0x8000000>, - <0x0 0xc8000000 0 0x8000000>; - reg-names = "apb-base", "memory0", "memory1", "memory2", "memory3"; - interrupts = <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 149 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 150 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 318>; - clock-names = "pcie"; - resets = <&cpg 318>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - status = "disabled"; - }; - - fdp1@fe940000 { - compatible = "renesas,fdp1"; - reg = <0 0xfe940000 0 0x2400>; - interrupts = <GIC_SPI 262 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 119>; - power-domains = <&sysc R8A774B1_PD_A3VP>; - resets = <&cpg 119>; - renesas,fcp = <&fcpf0>; - }; - - fcpf0: fcp@fe950000 { - compatible = "renesas,fcpf"; - reg = <0 0xfe950000 0 0x200>; - clocks = <&cpg CPG_MOD 615>; - power-domains = <&sysc R8A774B1_PD_A3VP>; - resets = <&cpg 615>; - }; - - vspb: vsp@fe960000 { - compatible = "renesas,vsp2"; - reg = <0 0xfe960000 0 0x8000>; - interrupts = <GIC_SPI 266 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 626>; - power-domains = <&sysc R8A774B1_PD_A3VP>; - resets = <&cpg 626>; - - renesas,fcp = <&fcpvb0>; - }; - - vspi0: vsp@fe9a0000 { - compatible = "renesas,vsp2"; - reg = <0 0xfe9a0000 0 0x8000>; - interrupts = <GIC_SPI 444 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 631>; - power-domains = <&sysc R8A774B1_PD_A3VP>; - resets = <&cpg 631>; - - renesas,fcp = <&fcpvi0>; - }; - - vspd0: vsp@fea20000 { - compatible = "renesas,vsp2"; - reg = <0 0xfea20000 0 0x5000>; - interrupts = <GIC_SPI 466 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 623>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 623>; - - renesas,fcp = <&fcpvd0>; - }; - - vspd1: vsp@fea28000 { - compatible = "renesas,vsp2"; - reg = <0 0xfea28000 0 0x5000>; - interrupts = <GIC_SPI 467 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 622>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 622>; - - renesas,fcp = <&fcpvd1>; - }; - - fcpvb0: fcp@fe96f000 { - compatible = "renesas,fcpv"; - reg = <0 0xfe96f000 0 0x200>; - clocks = <&cpg CPG_MOD 607>; - power-domains = <&sysc R8A774B1_PD_A3VP>; - resets = <&cpg 607>; - }; - - fcpvd0: fcp@fea27000 { - compatible = "renesas,fcpv"; - reg = <0 0xfea27000 0 0x200>; - clocks = <&cpg CPG_MOD 603>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 603>; - }; - - fcpvd1: fcp@fea2f000 { - compatible = "renesas,fcpv"; - reg = <0 0xfea2f000 0 0x200>; - clocks = <&cpg CPG_MOD 602>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 602>; - }; - - fcpvi0: fcp@fe9af000 { - compatible = "renesas,fcpv"; - reg = <0 0xfe9af000 0 0x200>; - clocks = <&cpg CPG_MOD 611>; - power-domains = <&sysc R8A774B1_PD_A3VP>; - resets = <&cpg 611>; - }; - - csi20: csi2@fea80000 { - compatible = "renesas,r8a774b1-csi2"; - reg = <0 0xfea80000 0 0x10000>; - interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 714>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 714>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - csi20vin0: endpoint@0 { - reg = <0>; - remote-endpoint = <&vin0csi20>; - }; - csi20vin1: endpoint@1 { - reg = <1>; - remote-endpoint = <&vin1csi20>; - }; - csi20vin2: endpoint@2 { - reg = <2>; - remote-endpoint = <&vin2csi20>; - }; - csi20vin3: endpoint@3 { - reg = <3>; - remote-endpoint = <&vin3csi20>; - }; - csi20vin4: endpoint@4 { - reg = <4>; - remote-endpoint = <&vin4csi20>; - }; - csi20vin5: endpoint@5 { - reg = <5>; - remote-endpoint = <&vin5csi20>; - }; - csi20vin6: endpoint@6 { - reg = <6>; - remote-endpoint = <&vin6csi20>; - }; - csi20vin7: endpoint@7 { - reg = <7>; - remote-endpoint = <&vin7csi20>; - }; - }; - }; - }; - - csi40: csi2@feaa0000 { - compatible = "renesas,r8a774b1-csi2"; - reg = <0 0xfeaa0000 0 0x10000>; - interrupts = <GIC_SPI 246 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 716>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 716>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - csi40vin0: endpoint@0 { - reg = <0>; - remote-endpoint = <&vin0csi40>; - }; - csi40vin1: endpoint@1 { - reg = <1>; - remote-endpoint = <&vin1csi40>; - }; - csi40vin2: endpoint@2 { - reg = <2>; - remote-endpoint = <&vin2csi40>; - }; - csi40vin3: endpoint@3 { - reg = <3>; - remote-endpoint = <&vin3csi40>; - }; - csi40vin4: endpoint@4 { - reg = <4>; - remote-endpoint = <&vin4csi40>; - }; - csi40vin5: endpoint@5 { - reg = <5>; - remote-endpoint = <&vin5csi40>; - }; - csi40vin6: endpoint@6 { - reg = <6>; - remote-endpoint = <&vin6csi40>; - }; - csi40vin7: endpoint@7 { - reg = <7>; - remote-endpoint = <&vin7csi40>; - }; - }; - }; - }; - - hdmi0: hdmi@fead0000 { - compatible = "renesas,r8a774b1-hdmi", - "renesas,rcar-gen3-hdmi"; - reg = <0 0xfead0000 0 0x10000>; - interrupts = <GIC_SPI 389 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 729>, - <&cpg CPG_CORE R8A774B1_CLK_HDMI>; - clock-names = "iahb", "isfr"; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 729>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - dw_hdmi0_in: endpoint { - remote-endpoint = <&du_out_hdmi0>; - }; - }; - port@1 { - reg = <1>; - }; - port@2 { - /* HDMI sound */ - reg = <2>; - }; - }; - }; - - du: display@feb00000 { - compatible = "renesas,du-r8a774b1"; - reg = <0 0xfeb00000 0 0x80000>; - interrupts = <GIC_SPI 256 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 268 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 270 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 724>, <&cpg CPG_MOD 723>, - <&cpg CPG_MOD 721>; - clock-names = "du.0", "du.1", "du.3"; - resets = <&cpg 724>, <&cpg 722>; - reset-names = "du.0", "du.3"; - status = "disabled"; - - renesas,vsps = <&vspd0 0>, <&vspd1 0>, <&vspd0 1>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - port@1 { - reg = <1>; - du_out_hdmi0: endpoint { - remote-endpoint = <&dw_hdmi0_in>; - }; - }; - port@2 { - reg = <2>; - du_out_lvds0: endpoint { - remote-endpoint = <&lvds0_in>; - }; - }; - }; - }; - - lvds0: lvds@feb90000 { - compatible = "renesas,r8a774b1-lvds"; - reg = <0 0xfeb90000 0 0x14>; - clocks = <&cpg CPG_MOD 727>; - power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>; - resets = <&cpg 727>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - lvds0_in: endpoint { - remote-endpoint = <&du_out_lvds0>; - }; - }; - port@1 { - reg = <1>; - }; - }; - }; - - prr: chipid@fff00044 { - compatible = "renesas,prr"; - reg = <0 0xfff00044 0 4>; - }; - }; - - thermal-zones { - sensor1_thermal: sensor1-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - thermal-sensors = <&tsc 0>; - sustainable-power = <2439>; - - trips { - sensor1_crit: sensor1-crit { - temperature = <120000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - }; - - sensor2_thermal: sensor2-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - thermal-sensors = <&tsc 1>; - sustainable-power = <2439>; - - trips { - sensor2_crit: sensor2-crit { - temperature = <120000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - }; - - sensor3_thermal: sensor3-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - thermal-sensors = <&tsc 2>; - sustainable-power = <2439>; - - cooling-maps { - map0 { - trip = <&target>; - cooling-device = <&a57_0 0 2>; - contribution = <1024>; - }; - }; - trips { - target: trip-point1 { - temperature = <100000>; - hysteresis = <1000>; - type = "passive"; - }; - - sensor3_crit: sensor3-crit { - temperature = <120000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - }; - }; - - timer { - compatible = "arm,armv8-timer"; - interrupts-extended = <&gic GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>; - }; - - /* External USB clocks - can be overridden by the board */ - usb3s0_clk: usb3s0 { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - usb_extal_clk: usb_extal { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; -}; diff --git a/arch/arm/dts/r8a774c0-cat874.dts b/arch/arm/dts/r8a774c0-cat874.dts deleted file mode 100644 index 5a6ea08ffd2..00000000000 --- a/arch/arm/dts/r8a774c0-cat874.dts +++ /dev/null @@ -1,455 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the Silicon Linux RZ/G2E 96board platform (CAT874) - * - * Copyright (C) 2019 Renesas Electronics Corp. - */ - -/dts-v1/; -#include "r8a774c0.dtsi" -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/display/tda998x.h> - -/ { - model = "Silicon Linux RZ/G2E 96board platform (CAT874)"; - compatible = "si-linux,cat874", "renesas,r8a774c0"; - - aliases { - serial0 = &scif2; - serial1 = &hscif2; - mmc0 = &sdhi0; - mmc1 = &sdhi3; - }; - - chosen { - bootargs = "ignore_loglevel rw root=/dev/nfs ip=on"; - stdout-path = "serial0:115200n8"; - }; - - hdmi-out { - compatible = "hdmi-connector"; - type = "a"; - - port { - hdmi_con_out: endpoint { - remote-endpoint = <&tda19988_out>; - }; - }; - }; - - leds { - compatible = "gpio-leds"; - - led0 { - gpios = <&gpio5 19 GPIO_ACTIVE_HIGH>; - label = "LED0"; - }; - - led1 { - gpios = <&gpio3 14 GPIO_ACTIVE_HIGH>; - label = "LED1"; - }; - - led2 { - gpios = <&gpio4 10 GPIO_ACTIVE_HIGH>; - label = "LED2"; - }; - - led3 { - gpios = <&gpio6 4 GPIO_ACTIVE_HIGH>; - label = "LED3"; - }; - }; - - memory@48000000 { - device_type = "memory"; - /* first 128MB is reserved for secure area. */ - reg = <0x0 0x48000000 0x0 0x78000000>; - }; - - reg_12p0v: regulator-12p0v { - compatible = "regulator-fixed"; - regulator-name = "D12.0V"; - regulator-min-microvolt = <12000000>; - regulator-max-microvolt = <12000000>; - regulator-boot-on; - regulator-always-on; - }; - - sound: sound { - compatible = "simple-audio-card"; - - simple-audio-card,name = "CAT874 HDMI sound"; - simple-audio-card,format = "i2s"; - simple-audio-card,bitclock-master = <&sndcpu>; - simple-audio-card,frame-master = <&sndcpu>; - - sndcodec: simple-audio-card,codec { - sound-dai = <&tda19988>; - }; - - sndcpu: simple-audio-card,cpu { - sound-dai = <&rcar_sound>; - }; - }; - - vcc_sdhi0: regulator-vcc-sdhi0 { - compatible = "regulator-fixed"; - - regulator-name = "SDHI0 Vcc"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - regulator-boot-on; - }; - - vccq_sdhi0: regulator-vccq-sdhi0 { - compatible = "regulator-gpio"; - - regulator-name = "SDHI0 VccQ"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - - gpios = <&gpio3 13 GPIO_ACTIVE_HIGH>; - gpios-states = <1>; - states = <3300000 1>, <1800000 0>; - }; - - wlan_en_reg: fixedregulator { - compatible = "regulator-fixed"; - regulator-name = "wlan-en-regulator"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - startup-delay-us = <70000>; - - gpio = <&gpio2 25 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; - - x13_clk: x13 { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <74250000>; - }; - - connector { - compatible = "usb-c-connector"; - label = "USB-C"; - data-role = "dual"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - port@0 { - reg = <0>; - hs_ep: endpoint { - remote-endpoint = <&usb3_hs_ep>; - }; - }; - port@1 { - reg = <1>; - ss_ep: endpoint { - remote-endpoint = <&hd3ss3220_in_ep>; - }; - }; - }; - }; -}; - -&audio_clk_a { - clock-frequency = <22579200>; -}; - -&du { - pinctrl-0 = <&du_pins>; - pinctrl-names = "default"; - status = "okay"; - - clocks = <&cpg CPG_MOD 724>, - <&cpg CPG_MOD 723>, - <&x13_clk>; - clock-names = "du.0", "du.1", "dclkin.0"; - - ports { - port@0 { - du_out_rgb: endpoint { - remote-endpoint = <&tda19988_in>; - }; - }; - }; -}; - -&ehci0 { - dr_mode = "host"; - status = "okay"; -}; - -&extal_clk { - clock-frequency = <48000000>; -}; - -&hscif2 { - pinctrl-0 = <&hscif2_pins>; - pinctrl-names = "default"; - - uart-has-rtscts; - status = "okay"; - - bluetooth { - compatible = "ti,wl1837-st"; - enable-gpios = <&gpio4 6 GPIO_ACTIVE_HIGH>; - }; -}; - -&i2c0 { - status = "okay"; - clock-frequency = <100000>; - - hd3ss3220@47 { - compatible = "ti,hd3ss3220"; - reg = <0x47>; - interrupt-parent = <&gpio6>; - interrupts = <3 IRQ_TYPE_LEVEL_LOW>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - port@0 { - reg = <0>; - hd3ss3220_in_ep: endpoint { - remote-endpoint = <&ss_ep>; - }; - }; - port@1 { - reg = <1>; - hd3ss3220_out_ep: endpoint { - remote-endpoint = <&usb3_role_switch>; - }; - }; - }; - }; - - tda19988: tda19988@70 { - compatible = "nxp,tda998x"; - reg = <0x70>; - interrupt-parent = <&gpio1>; - interrupts = <1 IRQ_TYPE_LEVEL_LOW>; - - video-ports = <0x234501>; - - #sound-dai-cells = <0>; - audio-ports = <TDA998x_I2S 0x03>; - clocks = <&rcar_sound 1>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - tda19988_in: endpoint { - remote-endpoint = <&du_out_rgb>; - }; - }; - - port@1 { - reg = <1>; - tda19988_out: endpoint { - remote-endpoint = <&hdmi_con_out>; - }; - }; - }; - }; -}; - -&i2c1 { - pinctrl-0 = <&i2c1_pins>; - pinctrl-names = "default"; - - status = "okay"; - clock-frequency = <400000>; - - rtc@32 { - compatible = "epson,rx8571"; - reg = <0x32>; - }; -}; - -&lvds0 { - status = "okay"; - - clocks = <&cpg CPG_MOD 727>, <&x13_clk>, <&extal_clk>; - clock-names = "fck", "dclkin.0", "extal"; -}; - -&ohci0 { - dr_mode = "host"; - status = "okay"; -}; - -&pcie_bus_clk { - clock-frequency = <100000000>; -}; - -&pciec0 { - /* Map all possible DDR as inbound ranges */ - dma-ranges = <0x42000000 0 0x40000000 0 0x40000000 0 0x80000000>; -}; - -&pfc { - du_pins: du { - groups = "du_rgb888", "du_clk_out_0", "du_sync", "du_disp", - "du_clk_in_0"; - function = "du"; - }; - - hscif2_pins: hscif2 { - groups = "hscif2_data_a", "hscif2_ctrl_a"; - function = "hscif2"; - }; - - i2c1_pins: i2c1 { - groups = "i2c1_b"; - function = "i2c1"; - }; - - scif2_pins: scif2 { - groups = "scif2_data_a"; - function = "scif2"; - }; - - sdhi0_pins: sd0 { - groups = "sdhi0_data4", "sdhi0_ctrl"; - function = "sdhi0"; - power-source = <3300>; - }; - - sdhi0_pins_uhs: sd0_uhs { - groups = "sdhi0_data4", "sdhi0_ctrl"; - function = "sdhi0"; - power-source = <1800>; - }; - - sdhi3_pins: sd3 { - groups = "sdhi3_data4", "sdhi3_ctrl"; - function = "sdhi3"; - power-source = <1800>; - }; - - sound_clk_pins: sound_clk { - groups = "audio_clkout1_a"; - function = "audio_clk"; - }; - - sound_pins: sound { - groups = "ssi01239_ctrl", "ssi0_data"; - function = "ssi"; - }; - - usb30_pins: usb30 { - groups = "usb30", "usb30_id"; - function = "usb30"; - }; -}; - -&rcar_sound { - pinctrl-0 = <&sound_pins>, <&sound_clk_pins>; - pinctrl-names = "default"; - - /* Single DAI */ - #sound-dai-cells = <0>; - - /* audio_clkout0/1/2/3 */ - #clock-cells = <1>; - clock-frequency = <11289600>; - - status = "okay"; - - rcar_sound,dai { - dai0 { - playback = <&ssi0>, <&src0>, <&dvc0>; - }; - }; -}; - -&rwdt { - timeout-sec = <60>; - status = "okay"; -}; - -&scif2 { - pinctrl-0 = <&scif2_pins>; - pinctrl-names = "default"; - - status = "okay"; -}; - -&sdhi0 { - pinctrl-0 = <&sdhi0_pins>; - pinctrl-1 = <&sdhi0_pins_uhs>; - pinctrl-names = "default", "state_uhs"; - - vmmc-supply = <&vcc_sdhi0>; - vqmmc-supply = <&vccq_sdhi0>; - cd-gpios = <&gpio3 12 GPIO_ACTIVE_LOW>; - bus-width = <4>; - sd-uhs-sdr50; - sd-uhs-sdr104; - status = "okay"; -}; - -&sdhi3 { - status = "okay"; - pinctrl-0 = <&sdhi3_pins>; - pinctrl-names = "default"; - - vmmc-supply = <&wlan_en_reg>; - bus-width = <4>; - non-removable; - cap-power-off-card; - keep-power-in-suspend; - - #address-cells = <1>; - #size-cells = <0>; - wlcore: wlcore@2 { - compatible = "ti,wl1837"; - reg = <2>; - interrupt-parent = <&gpio1>; - interrupts = <0 IRQ_TYPE_LEVEL_HIGH>; - }; -}; - -&usb2_phy0 { - renesas,no-otg-pins; - status = "okay"; -}; - -&usb3_peri0 { - companion = <&xhci0>; - status = "okay"; - usb-role-switch; - - ports { - #address-cells = <1>; - #size-cells = <0>; - port@0 { - reg = <0>; - usb3_hs_ep: endpoint { - remote-endpoint = <&hs_ep>; - }; - }; - port@1 { - reg = <1>; - usb3_role_switch: endpoint { - remote-endpoint = <&hd3ss3220_out_ep>; - }; - }; - }; -}; - -&xhci0 { - pinctrl-0 = <&usb30_pins>; - pinctrl-names = "default"; - - status = "okay"; -}; diff --git a/arch/arm/dts/r8a774c0-ek874.dts b/arch/arm/dts/r8a774c0-ek874.dts deleted file mode 100644 index e7b6619ab22..00000000000 --- a/arch/arm/dts/r8a774c0-ek874.dts +++ /dev/null @@ -1,14 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the Silicon Linux RZ/G2E evaluation kit (EK874) - * - * Copyright (C) 2019 Renesas Electronics Corp. - */ - -#include "r8a774c0-cat874.dts" -#include "cat875.dtsi" - -/ { - model = "Silicon Linux RZ/G2E evaluation kit EK874 (CAT874 + CAT875)"; - compatible = "si-linux,cat875", "si-linux,cat874", "renesas,r8a774c0"; -}; diff --git a/arch/arm/dts/r8a774c0.dtsi b/arch/arm/dts/r8a774c0.dtsi deleted file mode 100644 index ad2e87b039a..00000000000 --- a/arch/arm/dts/r8a774c0.dtsi +++ /dev/null @@ -1,2000 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the RZ/G2E (R8A774C0) SoC - * - * Copyright (C) 2018-2019 Renesas Electronics Corp. - */ - -#include <dt-bindings/clock/r8a774c0-cpg-mssr.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/power/r8a774c0-sysc.h> - -/ { - compatible = "renesas,r8a774c0"; - #address-cells = <2>; - #size-cells = <2>; - - /* - * The external audio clocks are configured as 0 Hz fixed frequency - * clocks by default. - * Boards that provide audio clocks should override them. - */ - audio_clk_a: audio_clk_a { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - audio_clk_b: audio_clk_b { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - audio_clk_c: audio_clk_c { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - /* External CAN clock - to be overridden by boards that provide it */ - can_clk: can { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - cluster1_opp: opp-table-1 { - compatible = "operating-points-v2"; - opp-shared; - opp-800000000 { - opp-hz = /bits/ 64 <800000000>; - clock-latency-ns = <300000>; - }; - opp-1000000000 { - opp-hz = /bits/ 64 <1000000000>; - clock-latency-ns = <300000>; - }; - opp-1200000000 { - opp-hz = /bits/ 64 <1200000000>; - clock-latency-ns = <300000>; - opp-suspend; - }; - }; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - - a53_0: cpu@0 { - compatible = "arm,cortex-a53"; - reg = <0>; - device_type = "cpu"; - #cooling-cells = <2>; - power-domains = <&sysc R8A774C0_PD_CA53_CPU0>; - next-level-cache = <&L2_CA53>; - enable-method = "psci"; - dynamic-power-coefficient = <277>; - clocks = <&cpg CPG_CORE R8A774C0_CLK_Z2>; - operating-points-v2 = <&cluster1_opp>; - }; - - a53_1: cpu@1 { - compatible = "arm,cortex-a53"; - reg = <1>; - device_type = "cpu"; - power-domains = <&sysc R8A774C0_PD_CA53_CPU1>; - next-level-cache = <&L2_CA53>; - enable-method = "psci"; - clocks = <&cpg CPG_CORE R8A774C0_CLK_Z2>; - operating-points-v2 = <&cluster1_opp>; - }; - - L2_CA53: cache-controller-0 { - compatible = "cache"; - power-domains = <&sysc R8A774C0_PD_CA53_SCU>; - cache-unified; - cache-level = <2>; - }; - }; - - extal_clk: extal { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board */ - clock-frequency = <0>; - }; - - /* External PCIe clock - can be overridden by the board */ - pcie_bus_clk: pcie_bus { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - pmu_a53 { - compatible = "arm,cortex-a53-pmu"; - interrupts-extended = <&gic GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&a53_0>, <&a53_1>; - }; - - psci { - compatible = "arm,psci-1.0", "arm,psci-0.2"; - method = "smc"; - }; - - /* External SCIF clock - to be overridden by boards that provide it */ - scif_clk: scif { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - soc: soc { - compatible = "simple-bus"; - interrupt-parent = <&gic>; - #address-cells = <2>; - #size-cells = <2>; - ranges; - - rwdt: watchdog@e6020000 { - compatible = "renesas,r8a774c0-wdt", - "renesas,rcar-gen3-wdt"; - reg = <0 0xe6020000 0 0x0c>; - interrupts = <GIC_SPI 140 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 402>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 402>; - status = "disabled"; - }; - - gpio0: gpio@e6050000 { - compatible = "renesas,gpio-r8a774c0", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6050000 0 0x50>; - interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 0 18>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 912>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 912>; - }; - - gpio1: gpio@e6051000 { - compatible = "renesas,gpio-r8a774c0", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6051000 0 0x50>; - interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 32 23>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 911>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 911>; - }; - - gpio2: gpio@e6052000 { - compatible = "renesas,gpio-r8a774c0", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6052000 0 0x50>; - interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 64 26>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 910>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 910>; - }; - - gpio3: gpio@e6053000 { - compatible = "renesas,gpio-r8a774c0", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6053000 0 0x50>; - interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 96 16>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 909>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 909>; - }; - - gpio4: gpio@e6054000 { - compatible = "renesas,gpio-r8a774c0", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6054000 0 0x50>; - interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 128 11>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 908>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 908>; - }; - - gpio5: gpio@e6055000 { - compatible = "renesas,gpio-r8a774c0", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6055000 0 0x50>; - interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 160 20>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 907>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 907>; - }; - - gpio6: gpio@e6055400 { - compatible = "renesas,gpio-r8a774c0", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6055400 0 0x50>; - interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 192 18>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 906>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 906>; - }; - - pfc: pinctrl@e6060000 { - compatible = "renesas,pfc-r8a774c0"; - reg = <0 0xe6060000 0 0x508>; - }; - - cmt0: timer@e60f0000 { - compatible = "renesas,r8a774c0-cmt0", - "renesas,rcar-gen3-cmt0"; - reg = <0 0xe60f0000 0 0x1004>; - interrupts = <GIC_SPI 142 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 143 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 303>; - clock-names = "fck"; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 303>; - status = "disabled"; - }; - - cmt1: timer@e6130000 { - compatible = "renesas,r8a774c0-cmt1", - "renesas,rcar-gen3-cmt1"; - reg = <0 0xe6130000 0 0x1004>; - interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 127 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 302>; - clock-names = "fck"; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 302>; - status = "disabled"; - }; - - cmt2: timer@e6140000 { - compatible = "renesas,r8a774c0-cmt1", - "renesas,rcar-gen3-cmt1"; - reg = <0 0xe6140000 0 0x1004>; - interrupts = <GIC_SPI 398 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 399 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 400 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 401 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 402 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 403 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 404 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 405 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 301>; - clock-names = "fck"; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 301>; - status = "disabled"; - }; - - cmt3: timer@e6148000 { - compatible = "renesas,r8a774c0-cmt1", - "renesas,rcar-gen3-cmt1"; - reg = <0 0xe6148000 0 0x1004>; - interrupts = <GIC_SPI 470 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 471 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 472 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 473 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 474 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 475 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 476 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 477 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 300>; - clock-names = "fck"; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 300>; - status = "disabled"; - }; - - cpg: clock-controller@e6150000 { - compatible = "renesas,r8a774c0-cpg-mssr"; - reg = <0 0xe6150000 0 0x1000>; - clocks = <&extal_clk>; - clock-names = "extal"; - #clock-cells = <2>; - #power-domain-cells = <0>; - #reset-cells = <1>; - }; - - rst: reset-controller@e6160000 { - compatible = "renesas,r8a774c0-rst"; - reg = <0 0xe6160000 0 0x0200>; - }; - - sysc: system-controller@e6180000 { - compatible = "renesas,r8a774c0-sysc"; - reg = <0 0xe6180000 0 0x0400>; - #power-domain-cells = <1>; - }; - - thermal: thermal@e6190000 { - compatible = "renesas,thermal-r8a774c0"; - reg = <0 0xe6190000 0 0x10>, <0 0xe6190100 0 0x38>; - interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 522>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 522>; - #thermal-sensor-cells = <0>; - }; - - intc_ex: interrupt-controller@e61c0000 { - compatible = "renesas,intc-ex-r8a774c0", "renesas,irqc"; - #interrupt-cells = <2>; - interrupt-controller; - reg = <0 0xe61c0000 0 0x200>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 161 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 407>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 407>; - }; - - tmu0: timer@e61e0000 { - compatible = "renesas,tmu-r8a774c0", "renesas,tmu"; - reg = <0 0xe61e0000 0 0x30>; - interrupts = <GIC_SPI 136 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 137 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 138 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 125>; - clock-names = "fck"; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 125>; - status = "disabled"; - }; - - tmu1: timer@e6fc0000 { - compatible = "renesas,tmu-r8a774c0", "renesas,tmu"; - reg = <0 0xe6fc0000 0 0x30>; - interrupts = <GIC_SPI 128 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 129 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 130 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 124>; - clock-names = "fck"; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 124>; - status = "disabled"; - }; - - tmu2: timer@e6fd0000 { - compatible = "renesas,tmu-r8a774c0", "renesas,tmu"; - reg = <0 0xe6fd0000 0 0x30>; - interrupts = <GIC_SPI 303 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 304 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 305 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 123>; - clock-names = "fck"; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 123>; - status = "disabled"; - }; - - tmu3: timer@e6fe0000 { - compatible = "renesas,tmu-r8a774c0", "renesas,tmu"; - reg = <0 0xe6fe0000 0 0x30>; - interrupts = <GIC_SPI 131 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 132 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 133 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 122>; - clock-names = "fck"; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 122>; - status = "disabled"; - }; - - tmu4: timer@ffc00000 { - compatible = "renesas,tmu-r8a774c0", "renesas,tmu"; - reg = <0 0xffc00000 0 0x30>; - interrupts = <GIC_SPI 406 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 407 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 408 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 121>; - clock-names = "fck"; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 121>; - status = "disabled"; - }; - - i2c0: i2c@e6500000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a774c0", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6500000 0 0x40>; - interrupts = <GIC_SPI 287 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 931>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 931>; - dmas = <&dmac1 0x91>, <&dmac1 0x90>, - <&dmac2 0x91>, <&dmac2 0x90>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - status = "disabled"; - }; - - i2c1: i2c@e6508000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a774c0", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6508000 0 0x40>; - interrupts = <GIC_SPI 288 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 930>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 930>; - dmas = <&dmac1 0x93>, <&dmac1 0x92>, - <&dmac2 0x93>, <&dmac2 0x92>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c2: i2c@e6510000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a774c0", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6510000 0 0x40>; - interrupts = <GIC_SPI 286 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 929>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 929>; - dmas = <&dmac1 0x95>, <&dmac1 0x94>, - <&dmac2 0x95>, <&dmac2 0x94>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c3: i2c@e66d0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a774c0", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66d0000 0 0x40>; - interrupts = <GIC_SPI 290 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 928>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 928>; - dmas = <&dmac0 0x97>, <&dmac0 0x96>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - status = "disabled"; - }; - - i2c4: i2c@e66d8000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a774c0", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66d8000 0 0x40>; - interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 927>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 927>; - dmas = <&dmac0 0x99>, <&dmac0 0x98>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c5: i2c@e66e0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a774c0", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66e0000 0 0x40>; - interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 919>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 919>; - dmas = <&dmac0 0x9b>, <&dmac0 0x9a>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c6: i2c@e66e8000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a774c0", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66e8000 0 0x40>; - interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 918>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 918>; - dmas = <&dmac0 0x9d>, <&dmac0 0x9c>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c7: i2c@e6690000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a774c0", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6690000 0 0x40>; - interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 1003>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 1003>; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - iic_pmic: i2c@e60b0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,iic-r8a774c0", - "renesas,rcar-gen3-iic", - "renesas,rmobile-iic"; - reg = <0 0xe60b0000 0 0x425>; - interrupts = <GIC_SPI 173 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 926>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 926>; - dmas = <&dmac0 0x11>, <&dmac0 0x10>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - hscif0: serial@e6540000 { - compatible = "renesas,hscif-r8a774c0", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe6540000 0 0x60>; - interrupts = <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 520>, - <&cpg CPG_CORE R8A774C0_CLK_S3D1C>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x31>, <&dmac1 0x30>, - <&dmac2 0x31>, <&dmac2 0x30>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 520>; - status = "disabled"; - }; - - hscif1: serial@e6550000 { - compatible = "renesas,hscif-r8a774c0", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe6550000 0 0x60>; - interrupts = <GIC_SPI 155 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 519>, - <&cpg CPG_CORE R8A774C0_CLK_S3D1C>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x33>, <&dmac1 0x32>, - <&dmac2 0x33>, <&dmac2 0x32>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 519>; - status = "disabled"; - }; - - hscif2: serial@e6560000 { - compatible = "renesas,hscif-r8a774c0", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe6560000 0 0x60>; - interrupts = <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 518>, - <&cpg CPG_CORE R8A774C0_CLK_S3D1C>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x35>, <&dmac1 0x34>, - <&dmac2 0x35>, <&dmac2 0x34>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 518>; - status = "disabled"; - }; - - hscif3: serial@e66a0000 { - compatible = "renesas,hscif-r8a774c0", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe66a0000 0 0x60>; - interrupts = <GIC_SPI 145 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 517>, - <&cpg CPG_CORE R8A774C0_CLK_S3D1C>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x37>, <&dmac0 0x36>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 517>; - status = "disabled"; - }; - - hscif4: serial@e66b0000 { - compatible = "renesas,hscif-r8a774c0", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe66b0000 0 0x60>; - interrupts = <GIC_SPI 146 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 516>, - <&cpg CPG_CORE R8A774C0_CLK_S3D1C>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x39>, <&dmac0 0x38>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 516>; - status = "disabled"; - }; - - hsusb: usb@e6590000 { - compatible = "renesas,usbhs-r8a774c0", - "renesas,rcar-gen3-usbhs"; - reg = <0 0xe6590000 0 0x200>; - interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 704>, <&cpg CPG_MOD 703>; - dmas = <&usb_dmac0 0>, <&usb_dmac0 1>, - <&usb_dmac1 0>, <&usb_dmac1 1>; - dma-names = "ch0", "ch1", "ch2", "ch3"; - renesas,buswait = <11>; - phys = <&usb2_phy0 3>; - phy-names = "usb"; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 704>, <&cpg 703>; - status = "disabled"; - }; - - usb_dmac0: dma-controller@e65a0000 { - compatible = "renesas,r8a774c0-usb-dmac", - "renesas,usb-dmac"; - reg = <0 0xe65a0000 0 0x100>; - interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1"; - clocks = <&cpg CPG_MOD 330>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 330>; - #dma-cells = <1>; - dma-channels = <2>; - }; - - usb_dmac1: dma-controller@e65b0000 { - compatible = "renesas,r8a774c0-usb-dmac", - "renesas,usb-dmac"; - reg = <0 0xe65b0000 0 0x100>; - interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1"; - clocks = <&cpg CPG_MOD 331>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 331>; - #dma-cells = <1>; - dma-channels = <2>; - }; - - dmac0: dma-controller@e6700000 { - compatible = "renesas,dmac-r8a774c0", - "renesas,rcar-dmac"; - reg = <0 0xe6700000 0 0x10000>; - interrupts = <GIC_SPI 199 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 200 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 201 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 202 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 203 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 204 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 205 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 206 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 207 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 208 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 209 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 210 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 211 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 212 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 213 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 214 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 215 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 219>; - clock-names = "fck"; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 219>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_ds0 0>, <&ipmmu_ds0 1>, - <&ipmmu_ds0 2>, <&ipmmu_ds0 3>, - <&ipmmu_ds0 4>, <&ipmmu_ds0 5>, - <&ipmmu_ds0 6>, <&ipmmu_ds0 7>, - <&ipmmu_ds0 8>, <&ipmmu_ds0 9>, - <&ipmmu_ds0 10>, <&ipmmu_ds0 11>, - <&ipmmu_ds0 12>, <&ipmmu_ds0 13>, - <&ipmmu_ds0 14>, <&ipmmu_ds0 15>; - }; - - dmac1: dma-controller@e7300000 { - compatible = "renesas,dmac-r8a774c0", - "renesas,rcar-dmac"; - reg = <0 0xe7300000 0 0x10000>; - interrupts = <GIC_SPI 220 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 216 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 217 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 218 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 219 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 308 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 309 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 310 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 311 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 312 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 313 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 314 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 315 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 316 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 317 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 318 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 319 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 218>; - clock-names = "fck"; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 218>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_ds1 0>, <&ipmmu_ds1 1>, - <&ipmmu_ds1 2>, <&ipmmu_ds1 3>, - <&ipmmu_ds1 4>, <&ipmmu_ds1 5>, - <&ipmmu_ds1 6>, <&ipmmu_ds1 7>, - <&ipmmu_ds1 8>, <&ipmmu_ds1 9>, - <&ipmmu_ds1 10>, <&ipmmu_ds1 11>, - <&ipmmu_ds1 12>, <&ipmmu_ds1 13>, - <&ipmmu_ds1 14>, <&ipmmu_ds1 15>; - }; - - dmac2: dma-controller@e7310000 { - compatible = "renesas,dmac-r8a774c0", - "renesas,rcar-dmac"; - reg = <0 0xe7310000 0 0x10000>; - interrupts = <GIC_SPI 416 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 417 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 418 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 419 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 420 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 421 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 422 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 423 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 424 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 425 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 426 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 427 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 428 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 429 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 430 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 431 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 397 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 217>; - clock-names = "fck"; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 217>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_ds1 16>, <&ipmmu_ds1 17>, - <&ipmmu_ds1 18>, <&ipmmu_ds1 19>, - <&ipmmu_ds1 20>, <&ipmmu_ds1 21>, - <&ipmmu_ds1 22>, <&ipmmu_ds1 23>, - <&ipmmu_ds1 24>, <&ipmmu_ds1 25>, - <&ipmmu_ds1 26>, <&ipmmu_ds1 27>, - <&ipmmu_ds1 28>, <&ipmmu_ds1 29>, - <&ipmmu_ds1 30>, <&ipmmu_ds1 31>; - }; - - ipmmu_ds0: iommu@e6740000 { - compatible = "renesas,ipmmu-r8a774c0"; - reg = <0 0xe6740000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 0>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_ds1: iommu@e7740000 { - compatible = "renesas,ipmmu-r8a774c0"; - reg = <0 0xe7740000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 1>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_hc: iommu@e6570000 { - compatible = "renesas,ipmmu-r8a774c0"; - reg = <0 0xe6570000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 2>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_mm: iommu@e67b0000 { - compatible = "renesas,ipmmu-r8a774c0"; - reg = <0 0xe67b0000 0 0x1000>; - interrupts = <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_mp: iommu@ec670000 { - compatible = "renesas,ipmmu-r8a774c0"; - reg = <0 0xec670000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 4>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_pv0: iommu@fd800000 { - compatible = "renesas,ipmmu-r8a774c0"; - reg = <0 0xfd800000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 6>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_vc0: iommu@fe6b0000 { - compatible = "renesas,ipmmu-r8a774c0"; - reg = <0 0xfe6b0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 12>; - power-domains = <&sysc R8A774C0_PD_A3VC>; - #iommu-cells = <1>; - }; - - ipmmu_vi0: iommu@febd0000 { - compatible = "renesas,ipmmu-r8a774c0"; - reg = <0 0xfebd0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 14>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_vp0: iommu@fe990000 { - compatible = "renesas,ipmmu-r8a774c0"; - reg = <0 0xfe990000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 16>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - avb: ethernet@e6800000 { - compatible = "renesas,etheravb-r8a774c0", - "renesas,etheravb-rcar-gen3"; - reg = <0 0xe6800000 0 0x800>; - interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 47 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 63 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15", - "ch16", "ch17", "ch18", "ch19", - "ch20", "ch21", "ch22", "ch23", - "ch24"; - clocks = <&cpg CPG_MOD 812>; - clock-names = "fck"; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 812>; - phy-mode = "rgmii"; - rx-internal-delay-ps = <0>; - iommus = <&ipmmu_ds0 16>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - can0: can@e6c30000 { - compatible = "renesas,can-r8a774c0", - "renesas,rcar-gen3-can"; - reg = <0 0xe6c30000 0 0x1000>; - interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 916>, - <&cpg CPG_CORE R8A774C0_CLK_CANFD>, - <&can_clk>; - clock-names = "clkp1", "clkp2", "can_clk"; - assigned-clocks = <&cpg CPG_CORE R8A774C0_CLK_CANFD>; - assigned-clock-rates = <40000000>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 916>; - status = "disabled"; - }; - - can1: can@e6c38000 { - compatible = "renesas,can-r8a774c0", - "renesas,rcar-gen3-can"; - reg = <0 0xe6c38000 0 0x1000>; - interrupts = <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 915>, - <&cpg CPG_CORE R8A774C0_CLK_CANFD>, - <&can_clk>; - clock-names = "clkp1", "clkp2", "can_clk"; - assigned-clocks = <&cpg CPG_CORE R8A774C0_CLK_CANFD>; - assigned-clock-rates = <40000000>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 915>; - status = "disabled"; - }; - - canfd: can@e66c0000 { - compatible = "renesas,r8a774c0-canfd", - "renesas,rcar-gen3-canfd"; - reg = <0 0xe66c0000 0 0x8000>; - interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch_int", "g_int"; - clocks = <&cpg CPG_MOD 914>, - <&cpg CPG_CORE R8A774C0_CLK_CANFD>, - <&can_clk>; - clock-names = "fck", "canfd", "can_clk"; - assigned-clocks = <&cpg CPG_CORE R8A774C0_CLK_CANFD>; - assigned-clock-rates = <40000000>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 914>; - status = "disabled"; - - channel0 { - status = "disabled"; - }; - - channel1 { - status = "disabled"; - }; - }; - - pwm0: pwm@e6e30000 { - compatible = "renesas,pwm-r8a774c0", "renesas,pwm-rcar"; - reg = <0 0xe6e30000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - pwm1: pwm@e6e31000 { - compatible = "renesas,pwm-r8a774c0", "renesas,pwm-rcar"; - reg = <0 0xe6e31000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - pwm2: pwm@e6e32000 { - compatible = "renesas,pwm-r8a774c0", "renesas,pwm-rcar"; - reg = <0 0xe6e32000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - pwm3: pwm@e6e33000 { - compatible = "renesas,pwm-r8a774c0", "renesas,pwm-rcar"; - reg = <0 0xe6e33000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - pwm4: pwm@e6e34000 { - compatible = "renesas,pwm-r8a774c0", "renesas,pwm-rcar"; - reg = <0 0xe6e34000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - pwm5: pwm@e6e35000 { - compatible = "renesas,pwm-r8a774c0", "renesas,pwm-rcar"; - reg = <0 0xe6e35000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - pwm6: pwm@e6e36000 { - compatible = "renesas,pwm-r8a774c0", "renesas,pwm-rcar"; - reg = <0 0xe6e36000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - scif0: serial@e6e60000 { - compatible = "renesas,scif-r8a774c0", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6e60000 0 64>; - interrupts = <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 207>, - <&cpg CPG_CORE R8A774C0_CLK_S3D1C>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x51>, <&dmac1 0x50>, - <&dmac2 0x51>, <&dmac2 0x50>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 207>; - status = "disabled"; - }; - - scif1: serial@e6e68000 { - compatible = "renesas,scif-r8a774c0", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6e68000 0 64>; - interrupts = <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 206>, - <&cpg CPG_CORE R8A774C0_CLK_S3D1C>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x53>, <&dmac1 0x52>, - <&dmac2 0x53>, <&dmac2 0x52>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 206>; - status = "disabled"; - }; - - scif2: serial@e6e88000 { - compatible = "renesas,scif-r8a774c0", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6e88000 0 64>; - interrupts = <GIC_SPI 164 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 310>, - <&cpg CPG_CORE R8A774C0_CLK_S3D1C>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x13>, <&dmac1 0x12>, - <&dmac2 0x13>, <&dmac2 0x12>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 310>; - status = "disabled"; - }; - - scif3: serial@e6c50000 { - compatible = "renesas,scif-r8a774c0", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6c50000 0 64>; - interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 204>, - <&cpg CPG_CORE R8A774C0_CLK_S3D1C>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x57>, <&dmac0 0x56>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 204>; - status = "disabled"; - }; - - scif4: serial@e6c40000 { - compatible = "renesas,scif-r8a774c0", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6c40000 0 64>; - interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 203>, - <&cpg CPG_CORE R8A774C0_CLK_S3D1C>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x59>, <&dmac0 0x58>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 203>; - status = "disabled"; - }; - - scif5: serial@e6f30000 { - compatible = "renesas,scif-r8a774c0", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6f30000 0 64>; - interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 202>, - <&cpg CPG_CORE R8A774C0_CLK_S3D1C>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x5b>, <&dmac0 0x5a>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 202>; - status = "disabled"; - }; - - msiof0: spi@e6e90000 { - compatible = "renesas,msiof-r8a774c0", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6e90000 0 0x0064>; - interrupts = <GIC_SPI 156 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 211>; - dmas = <&dmac1 0x41>, <&dmac1 0x40>, - <&dmac2 0x41>, <&dmac2 0x40>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 211>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof1: spi@e6ea0000 { - compatible = "renesas,msiof-r8a774c0", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6ea0000 0 0x0064>; - interrupts = <GIC_SPI 157 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 210>; - dmas = <&dmac0 0x43>, <&dmac0 0x42>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 210>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof2: spi@e6c00000 { - compatible = "renesas,msiof-r8a774c0", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6c00000 0 0x0064>; - interrupts = <GIC_SPI 158 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 209>; - dmas = <&dmac0 0x45>, <&dmac0 0x44>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 209>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof3: spi@e6c10000 { - compatible = "renesas,msiof-r8a774c0", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6c10000 0 0x0064>; - interrupts = <GIC_SPI 159 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 208>; - dmas = <&dmac0 0x47>, <&dmac0 0x46>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 208>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - vin4: video@e6ef4000 { - compatible = "renesas,vin-r8a774c0"; - reg = <0 0xe6ef4000 0 0x1000>; - interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 807>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 807>; - renesas,id = <4>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin4csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin4>; - }; - }; - }; - }; - - vin5: video@e6ef5000 { - compatible = "renesas,vin-r8a774c0"; - reg = <0 0xe6ef5000 0 0x1000>; - interrupts = <GIC_SPI 175 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 806>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 806>; - renesas,id = <5>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin5csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin5>; - }; - }; - }; - }; - - rcar_sound: sound@ec500000 { - /* - * #sound-dai-cells is required if simple-card - * - * Single DAI : #sound-dai-cells = <0>; <&rcar_sound>; - * Multi DAI : #sound-dai-cells = <1>; <&rcar_sound N>; - */ - /* - * #clock-cells is required for audio_clkout0/1/2/3 - * - * clkout : #clock-cells = <0>; <&rcar_sound>; - * clkout0/1/2/3: #clock-cells = <1>; <&rcar_sound N>; - */ - compatible = "renesas,rcar_sound-r8a774c0", - "renesas,rcar_sound-gen3"; - reg = <0 0xec500000 0 0x1000>, /* SCU */ - <0 0xec5a0000 0 0x100>, /* ADG */ - <0 0xec540000 0 0x1000>, /* SSIU */ - <0 0xec541000 0 0x280>, /* SSI */ - <0 0xec760000 0 0x200>; /* Audio DMAC peri peri*/ - reg-names = "scu", "adg", "ssiu", "ssi", "audmapp"; - - clocks = <&cpg CPG_MOD 1005>, - <&cpg CPG_MOD 1006>, <&cpg CPG_MOD 1007>, - <&cpg CPG_MOD 1008>, <&cpg CPG_MOD 1009>, - <&cpg CPG_MOD 1010>, <&cpg CPG_MOD 1011>, - <&cpg CPG_MOD 1012>, <&cpg CPG_MOD 1013>, - <&cpg CPG_MOD 1014>, <&cpg CPG_MOD 1015>, - <&cpg CPG_MOD 1022>, <&cpg CPG_MOD 1023>, - <&cpg CPG_MOD 1024>, <&cpg CPG_MOD 1025>, - <&cpg CPG_MOD 1026>, <&cpg CPG_MOD 1027>, - <&cpg CPG_MOD 1028>, <&cpg CPG_MOD 1029>, - <&cpg CPG_MOD 1030>, <&cpg CPG_MOD 1031>, - <&cpg CPG_MOD 1020>, <&cpg CPG_MOD 1021>, - <&cpg CPG_MOD 1020>, <&cpg CPG_MOD 1021>, - <&cpg CPG_MOD 1019>, <&cpg CPG_MOD 1018>, - <&audio_clk_a>, <&audio_clk_b>, - <&audio_clk_c>, - <&cpg CPG_CORE R8A774C0_CLK_ZA2>; - clock-names = "ssi-all", - "ssi.9", "ssi.8", "ssi.7", "ssi.6", - "ssi.5", "ssi.4", "ssi.3", "ssi.2", - "ssi.1", "ssi.0", - "src.9", "src.8", "src.7", "src.6", - "src.5", "src.4", "src.3", "src.2", - "src.1", "src.0", - "mix.1", "mix.0", - "ctu.1", "ctu.0", - "dvc.0", "dvc.1", - "clk_a", "clk_b", "clk_c", "clk_i"; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 1005>, - <&cpg 1006>, <&cpg 1007>, - <&cpg 1008>, <&cpg 1009>, - <&cpg 1010>, <&cpg 1011>, - <&cpg 1012>, <&cpg 1013>, - <&cpg 1014>, <&cpg 1015>; - reset-names = "ssi-all", - "ssi.9", "ssi.8", "ssi.7", "ssi.6", - "ssi.5", "ssi.4", "ssi.3", "ssi.2", - "ssi.1", "ssi.0"; - status = "disabled"; - - rcar_sound,ctu { - ctu00: ctu-0 { }; - ctu01: ctu-1 { }; - ctu02: ctu-2 { }; - ctu03: ctu-3 { }; - ctu10: ctu-4 { }; - ctu11: ctu-5 { }; - ctu12: ctu-6 { }; - ctu13: ctu-7 { }; - }; - - rcar_sound,dvc { - dvc0: dvc-0 { - dmas = <&audma0 0xbc>; - dma-names = "tx"; - }; - dvc1: dvc-1 { - dmas = <&audma0 0xbe>; - dma-names = "tx"; - }; - }; - - rcar_sound,mix { - mix0: mix-0 { }; - mix1: mix-1 { }; - }; - - rcar_sound,src { - src0: src-0 { - interrupts = <GIC_SPI 352 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x85>, <&audma0 0x9a>; - dma-names = "rx", "tx"; - }; - src1: src-1 { - interrupts = <GIC_SPI 353 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x87>, <&audma0 0x9c>; - dma-names = "rx", "tx"; - }; - src2: src-2 { - interrupts = <GIC_SPI 354 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x89>, <&audma0 0x9e>; - dma-names = "rx", "tx"; - }; - src3: src-3 { - interrupts = <GIC_SPI 355 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x8b>, <&audma0 0xa0>; - dma-names = "rx", "tx"; - }; - src4: src-4 { - interrupts = <GIC_SPI 356 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x8d>, <&audma0 0xb0>; - dma-names = "rx", "tx"; - }; - src5: src-5 { - interrupts = <GIC_SPI 357 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x8f>, <&audma0 0xb2>; - dma-names = "rx", "tx"; - }; - src6: src-6 { - interrupts = <GIC_SPI 358 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x91>, <&audma0 0xb4>; - dma-names = "rx", "tx"; - }; - src7: src-7 { - interrupts = <GIC_SPI 359 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x93>, <&audma0 0xb6>; - dma-names = "rx", "tx"; - }; - src8: src-8 { - interrupts = <GIC_SPI 360 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x95>, <&audma0 0xb8>; - dma-names = "rx", "tx"; - }; - src9: src-9 { - interrupts = <GIC_SPI 361 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x97>, <&audma0 0xba>; - dma-names = "rx", "tx"; - }; - }; - - rcar_sound,ssi { - ssi0: ssi-0 { - interrupts = <GIC_SPI 370 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x01>, <&audma0 0x02>, - <&audma0 0x15>, <&audma0 0x16>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi1: ssi-1 { - interrupts = <GIC_SPI 371 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x03>, <&audma0 0x04>, - <&audma0 0x49>, <&audma0 0x4a>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi2: ssi-2 { - interrupts = <GIC_SPI 372 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x05>, <&audma0 0x06>, - <&audma0 0x63>, <&audma0 0x64>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi3: ssi-3 { - interrupts = <GIC_SPI 373 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x07>, <&audma0 0x08>, - <&audma0 0x6f>, <&audma0 0x70>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi4: ssi-4 { - interrupts = <GIC_SPI 374 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x09>, <&audma0 0x0a>, - <&audma0 0x71>, <&audma0 0x72>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi5: ssi-5 { - interrupts = <GIC_SPI 375 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x0b>, <&audma0 0x0c>, - <&audma0 0x73>, <&audma0 0x74>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi6: ssi-6 { - interrupts = <GIC_SPI 376 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x0d>, <&audma0 0x0e>, - <&audma0 0x75>, <&audma0 0x76>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi7: ssi-7 { - interrupts = <GIC_SPI 377 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x0f>, <&audma0 0x10>, - <&audma0 0x79>, <&audma0 0x7a>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi8: ssi-8 { - interrupts = <GIC_SPI 378 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x11>, <&audma0 0x12>, - <&audma0 0x7b>, <&audma0 0x7c>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi9: ssi-9 { - interrupts = <GIC_SPI 379 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x13>, <&audma0 0x14>, - <&audma0 0x7d>, <&audma0 0x7e>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - }; - }; - - audma0: dma-controller@ec700000 { - compatible = "renesas,dmac-r8a774c0", - "renesas,rcar-dmac"; - reg = <0 0xec700000 0 0x10000>; - interrupts = <GIC_SPI 350 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 320 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 321 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 322 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 323 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 324 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 325 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 326 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 327 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 328 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 329 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 330 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 331 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 332 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 333 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 334 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 335 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 502>; - clock-names = "fck"; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 502>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_mp 0>, <&ipmmu_mp 1>, - <&ipmmu_mp 2>, <&ipmmu_mp 3>, - <&ipmmu_mp 4>, <&ipmmu_mp 5>, - <&ipmmu_mp 6>, <&ipmmu_mp 7>, - <&ipmmu_mp 8>, <&ipmmu_mp 9>, - <&ipmmu_mp 10>, <&ipmmu_mp 11>, - <&ipmmu_mp 12>, <&ipmmu_mp 13>, - <&ipmmu_mp 14>, <&ipmmu_mp 15>; - }; - - xhci0: usb@ee000000 { - compatible = "renesas,xhci-r8a774c0", - "renesas,rcar-gen3-xhci"; - reg = <0 0xee000000 0 0xc00>; - interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 328>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 328>; - status = "disabled"; - }; - - usb3_peri0: usb@ee020000 { - compatible = "renesas,r8a774c0-usb3-peri", - "renesas,rcar-gen3-usb3-peri"; - reg = <0 0xee020000 0 0x400>; - interrupts = <GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 328>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 328>; - status = "disabled"; - }; - - ohci0: usb@ee080000 { - compatible = "generic-ohci"; - reg = <0 0xee080000 0 0x100>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>; - phys = <&usb2_phy0 1>; - phy-names = "usb"; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 703>, <&cpg 704>; - status = "disabled"; - }; - - ehci0: usb@ee080100 { - compatible = "generic-ehci"; - reg = <0 0xee080100 0 0x100>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>; - phys = <&usb2_phy0 2>; - phy-names = "usb"; - companion = <&ohci0>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 703>, <&cpg 704>; - status = "disabled"; - }; - - usb2_phy0: usb-phy@ee080200 { - compatible = "renesas,usb2-phy-r8a774c0", - "renesas,rcar-gen3-usb2-phy"; - reg = <0 0xee080200 0 0x700>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 703>, <&cpg 704>; - #phy-cells = <1>; - status = "disabled"; - }; - - sdhi0: mmc@ee100000 { - compatible = "renesas,sdhi-r8a774c0", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee100000 0 0x2000>; - interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 314>, <&cpg CPG_CORE R8A774C0_CLK_SD0H>; - clock-names = "core", "clkh"; - max-frequency = <200000000>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 314>; - status = "disabled"; - }; - - sdhi1: mmc@ee120000 { - compatible = "renesas,sdhi-r8a774c0", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee120000 0 0x2000>; - interrupts = <GIC_SPI 166 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 313>, <&cpg CPG_CORE R8A774C0_CLK_SD1H>; - clock-names = "core", "clkh"; - max-frequency = <200000000>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 313>; - status = "disabled"; - }; - - sdhi3: mmc@ee160000 { - compatible = "renesas,sdhi-r8a774c0", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee160000 0 0x2000>; - interrupts = <GIC_SPI 168 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 311>, <&cpg CPG_CORE R8A774C0_CLK_SD3H>; - clock-names = "core", "clkh"; - max-frequency = <200000000>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 311>; - status = "disabled"; - }; - - rpc: spi@ee200000 { - compatible = "renesas,r8a774c0-rpc-if", - "renesas,rcar-gen3-rpc-if"; - reg = <0 0xee200000 0 0x200>, - <0 0x08000000 0 0x4000000>, - <0 0xee208000 0 0x100>; - reg-names = "regs", "dirmap", "wbuf"; - interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 917>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 917>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - gic: interrupt-controller@f1010000 { - compatible = "arm,gic-400"; - #interrupt-cells = <3>; - #address-cells = <0>; - interrupt-controller; - reg = <0x0 0xf1010000 0 0x1000>, - <0x0 0xf1020000 0 0x20000>, - <0x0 0xf1040000 0 0x20000>, - <0x0 0xf1060000 0 0x20000>; - interrupts = <GIC_PPI 9 - (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_HIGH)>; - clocks = <&cpg CPG_MOD 408>; - clock-names = "clk"; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 408>; - }; - - pciec0: pcie@fe000000 { - compatible = "renesas,pcie-r8a774c0", - "renesas,pcie-rcar-gen3"; - reg = <0 0xfe000000 0 0x80000>; - #address-cells = <3>; - #size-cells = <2>; - bus-range = <0x00 0xff>; - device_type = "pci"; - ranges = <0x01000000 0 0x00000000 0 0xfe100000 0 0x00100000>, - <0x02000000 0 0xfe200000 0 0xfe200000 0 0x00200000>, - <0x02000000 0 0x30000000 0 0x30000000 0 0x08000000>, - <0x42000000 0 0x38000000 0 0x38000000 0 0x08000000>; - /* Map all possible DDR/IOMMU as inbound ranges */ - dma-ranges = <0x42000000 0 0x00000000 0 0x00000000 1 0x00000000>; - interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>; - #interrupt-cells = <1>; - interrupt-map-mask = <0 0 0 0>; - interrupt-map = <0 0 0 0 &gic GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 319>, <&pcie_bus_clk>; - clock-names = "pcie", "pcie_bus"; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 319>; - iommu-map = <0 &ipmmu_hc 0 1>; - iommu-map-mask = <0>; - status = "disabled"; - }; - - pciec0_ep: pcie-ep@fe000000 { - compatible = "renesas,r8a774c0-pcie-ep", - "renesas,rcar-gen3-pcie-ep"; - reg = <0x0 0xfe000000 0 0x80000>, - <0x0 0xfe100000 0 0x100000>, - <0x0 0xfe200000 0 0x200000>, - <0x0 0x30000000 0 0x8000000>, - <0x0 0x38000000 0 0x8000000>; - reg-names = "apb-base", "memory0", "memory1", "memory2", "memory3"; - interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 319>; - clock-names = "pcie"; - resets = <&cpg 319>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - status = "disabled"; - }; - - vspb0: vsp@fe960000 { - compatible = "renesas,vsp2"; - reg = <0 0xfe960000 0 0x8000>; - interrupts = <GIC_SPI 266 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 626>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 626>; - renesas,fcp = <&fcpvb0>; - }; - - vspd0: vsp@fea20000 { - compatible = "renesas,vsp2"; - reg = <0 0xfea20000 0 0x7000>; - interrupts = <GIC_SPI 466 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 623>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 623>; - renesas,fcp = <&fcpvd0>; - }; - - vspd1: vsp@fea28000 { - compatible = "renesas,vsp2"; - reg = <0 0xfea28000 0 0x7000>; - interrupts = <GIC_SPI 467 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 622>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 622>; - renesas,fcp = <&fcpvd1>; - }; - - vspi0: vsp@fe9a0000 { - compatible = "renesas,vsp2"; - reg = <0 0xfe9a0000 0 0x8000>; - interrupts = <GIC_SPI 444 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 631>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 631>; - renesas,fcp = <&fcpvi0>; - }; - - fcpvb0: fcp@fe96f000 { - compatible = "renesas,fcpv"; - reg = <0 0xfe96f000 0 0x200>; - clocks = <&cpg CPG_MOD 607>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 607>; - iommus = <&ipmmu_vp0 5>; - }; - - fcpvd0: fcp@fea27000 { - compatible = "renesas,fcpv"; - reg = <0 0xfea27000 0 0x200>; - clocks = <&cpg CPG_MOD 603>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 603>; - iommus = <&ipmmu_vi0 8>; - }; - - fcpvd1: fcp@fea2f000 { - compatible = "renesas,fcpv"; - reg = <0 0xfea2f000 0 0x200>; - clocks = <&cpg CPG_MOD 602>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 602>; - iommus = <&ipmmu_vi0 9>; - }; - - fcpvi0: fcp@fe9af000 { - compatible = "renesas,fcpv"; - reg = <0 0xfe9af000 0 0x200>; - clocks = <&cpg CPG_MOD 611>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 611>; - iommus = <&ipmmu_vp0 8>; - }; - - csi40: csi2@feaa0000 { - compatible = "renesas,r8a774c0-csi2"; - reg = <0 0xfeaa0000 0 0x10000>; - interrupts = <GIC_SPI 246 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 716>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 716>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - csi40vin4: endpoint@0 { - reg = <0>; - remote-endpoint = <&vin4csi40>; - }; - csi40vin5: endpoint@1 { - reg = <1>; - remote-endpoint = <&vin5csi40>; - }; - }; - }; - }; - - du: display@feb00000 { - compatible = "renesas,du-r8a774c0"; - reg = <0 0xfeb00000 0 0x40000>; - interrupts = <GIC_SPI 256 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 268 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 724>, <&cpg CPG_MOD 723>; - clock-names = "du.0", "du.1"; - resets = <&cpg 724>; - reset-names = "du.0"; - renesas,vsps = <&vspd0 0>, <&vspd1 0>; - - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - - port@1 { - reg = <1>; - du_out_lvds0: endpoint { - remote-endpoint = <&lvds0_in>; - }; - }; - - port@2 { - reg = <2>; - du_out_lvds1: endpoint { - remote-endpoint = <&lvds1_in>; - }; - }; - }; - }; - - lvds0: lvds-encoder@feb90000 { - compatible = "renesas,r8a774c0-lvds"; - reg = <0 0xfeb90000 0 0x20>; - clocks = <&cpg CPG_MOD 727>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 727>; - status = "disabled"; - - renesas,companion = <&lvds1>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - lvds0_in: endpoint { - remote-endpoint = <&du_out_lvds0>; - }; - }; - - port@1 { - reg = <1>; - }; - }; - }; - - lvds1: lvds-encoder@feb90100 { - compatible = "renesas,r8a774c0-lvds"; - reg = <0 0xfeb90100 0 0x20>; - clocks = <&cpg CPG_MOD 727>; - power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>; - resets = <&cpg 726>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - lvds1_in: endpoint { - remote-endpoint = <&du_out_lvds1>; - }; - }; - - port@1 { - reg = <1>; - }; - }; - }; - - prr: chipid@fff00044 { - compatible = "renesas,prr"; - reg = <0 0xfff00044 0 4>; - }; - }; - - thermal-zones { - cpu-thermal { - polling-delay-passive = <250>; - polling-delay = <0>; - thermal-sensors = <&thermal>; - sustainable-power = <717>; - - cooling-maps { - map0 { - trip = <&target>; - cooling-device = <&a53_0 0 2>; - contribution = <1024>; - }; - }; - - trips { - sensor1_crit: sensor1-crit { - temperature = <120000>; - hysteresis = <2000>; - type = "critical"; - }; - - target: trip-point1 { - temperature = <100000>; - hysteresis = <2000>; - type = "passive"; - }; - }; - }; - }; - - timer { - compatible = "arm,armv8-timer"; - interrupts-extended = <&gic GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>; - }; - - /* External USB clocks - can be overridden by the board */ - usb3s0_clk: usb3s0 { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - usb_extal_clk: usb_extal { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; -}; diff --git a/arch/arm/dts/r8a774e1-beacon-rzg2h-kit.dts b/arch/arm/dts/r8a774e1-beacon-rzg2h-kit.dts deleted file mode 100644 index 146f78cb6f1..00000000000 --- a/arch/arm/dts/r8a774e1-beacon-rzg2h-kit.dts +++ /dev/null @@ -1,61 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Copyright 2020, Compass Electronics Group, LLC - */ - -/dts-v1/; - -#include "r8a774e1.dtsi" -#include "beacon-renesom-som.dtsi" -#include "beacon-renesom-baseboard.dtsi" - -/ { - model = "Beacon Embedded Works RZ/G2H Development Kit"; - compatible = "beacon,beacon-rzg2h", "renesas,r8a774e1"; - - aliases { - i2c0 = &i2c0; - i2c1 = &i2c1; - i2c2 = &i2c2; - i2c3 = &i2c3; - i2c4 = &i2c4; - i2c5 = &i2c5; - i2c6 = &i2c6; - i2c7 = &iic_pmic; - serial0 = &scif2; - serial1 = &hscif0; - serial2 = &hscif1; - serial3 = &scif0; - serial4 = &hscif2; - serial5 = &scif5; - serial6 = &scif4; - ethernet0 = &avb; - mmc0 = &sdhi3; - mmc1 = &sdhi0; - mmc2 = &sdhi2; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - memory@500000000 { - device_type = "memory"; - reg = <0x5 0x00000000 0x0 0x80000000>; - }; -}; - -&du { - pinctrl-0 = <&du_pins>; - pinctrl-names = "default"; - status = "okay"; - - clocks = <&cpg CPG_MOD 724>, - <&cpg CPG_MOD 723>, - <&cpg CPG_MOD 721>, - <&versaclock5 1>, - <&x302_clk>, - <&versaclock5 2>; - clock-names = "du.0", "du.1", "du.3", - "dclkin.0", "dclkin.1", "dclkin.3"; -}; diff --git a/arch/arm/dts/r8a774e1-hihope-rzg2h-ex.dts b/arch/arm/dts/r8a774e1-hihope-rzg2h-ex.dts deleted file mode 100644 index 81299593984..00000000000 --- a/arch/arm/dts/r8a774e1-hihope-rzg2h-ex.dts +++ /dev/null @@ -1,20 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the HiHope RZ/G2H sub board - * - * Copyright (C) 2020 Renesas Electronics Corp. - */ - -#include "r8a774e1-hihope-rzg2h.dts" -#include "hihope-rzg2-ex.dtsi" - -/ { - model = "HopeRun HiHope RZ/G2H with sub board"; - compatible = "hoperun,hihope-rzg2-ex", "hoperun,hihope-rzg2h", - "renesas,r8a774e1"; -}; - -/* Set SW43 = ON and SW1001[7] = OFF for SATA port to be activated */ -&sata { - status = "okay"; -}; diff --git a/arch/arm/dts/r8a774e1-hihope-rzg2h.dts b/arch/arm/dts/r8a774e1-hihope-rzg2h.dts deleted file mode 100644 index 9525d5ed6fc..00000000000 --- a/arch/arm/dts/r8a774e1-hihope-rzg2h.dts +++ /dev/null @@ -1,41 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the HiHope RZ/G2H main board - * - * Copyright (C) 2020 Renesas Electronics Corp. - */ - -/dts-v1/; -#include "r8a774e1.dtsi" -#include "hihope-rev4.dtsi" - -/ { - model = "HopeRun HiHope RZ/G2H main board based on r8a774e1"; - compatible = "hoperun,hihope-rzg2h", "renesas,r8a774e1"; - - memory@48000000 { - device_type = "memory"; - /* first 128MB is reserved for secure area. */ - reg = <0x0 0x48000000 0x0 0x78000000>; - }; - - memory@500000000 { - device_type = "memory"; - reg = <0x5 0x00000000 0x0 0x80000000>; - }; -}; - -&du { - clocks = <&cpg CPG_MOD 724>, - <&cpg CPG_MOD 723>, - <&cpg CPG_MOD 721>, - <&versaclock5 1>, - <&x302_clk>, - <&versaclock5 2>; - clock-names = "du.0", "du.1", "du.3", - "dclkin.0", "dclkin.1", "dclkin.3"; -}; - -&sdhi3 { - mmc-hs400-1_8v; -}; diff --git a/arch/arm/dts/r8a774e1.dtsi b/arch/arm/dts/r8a774e1.dtsi deleted file mode 100644 index 2acf4067ab2..00000000000 --- a/arch/arm/dts/r8a774e1.dtsi +++ /dev/null @@ -1,2997 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the r8a774e1 SoC - * - * Copyright (C) 2020 Renesas Electronics Corp. - */ - -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/clock/r8a774e1-cpg-mssr.h> -#include <dt-bindings/power/r8a774e1-sysc.h> - -#define CPG_AUDIO_CLK_I R8A774E1_CLK_S0D4 - -/ { - compatible = "renesas,r8a774e1"; - #address-cells = <2>; - #size-cells = <2>; - - /* - * The external audio clocks are configured as 0 Hz fixed frequency - * clocks by default. - * Boards that provide audio clocks should override them. - */ - audio_clk_a: audio_clk_a { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - audio_clk_b: audio_clk_b { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - audio_clk_c: audio_clk_c { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - /* External CAN clock - to be overridden by boards that provide it */ - can_clk: can { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - cluster0_opp: opp-table-0 { - compatible = "operating-points-v2"; - opp-shared; - - opp-500000000 { - opp-hz = /bits/ 64 <500000000>; - opp-microvolt = <820000>; - clock-latency-ns = <300000>; - }; - opp-1000000000 { - opp-hz = /bits/ 64 <1000000000>; - opp-microvolt = <820000>; - clock-latency-ns = <300000>; - }; - opp-1500000000 { - opp-hz = /bits/ 64 <1500000000>; - opp-microvolt = <820000>; - clock-latency-ns = <300000>; - opp-suspend; - }; - }; - - cluster1_opp: opp-table-1 { - compatible = "operating-points-v2"; - opp-shared; - - opp-800000000 { - opp-hz = /bits/ 64 <800000000>; - opp-microvolt = <820000>; - clock-latency-ns = <300000>; - }; - opp-1000000000 { - opp-hz = /bits/ 64 <1000000000>; - opp-microvolt = <820000>; - clock-latency-ns = <300000>; - }; - opp-1200000000 { - opp-hz = /bits/ 64 <1200000000>; - opp-microvolt = <820000>; - clock-latency-ns = <300000>; - }; - }; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - - cpu-map { - cluster0 { - core0 { - cpu = <&a57_0>; - }; - core1 { - cpu = <&a57_1>; - }; - core2 { - cpu = <&a57_2>; - }; - core3 { - cpu = <&a57_3>; - }; - }; - - cluster1 { - core0 { - cpu = <&a53_0>; - }; - core1 { - cpu = <&a53_1>; - }; - core2 { - cpu = <&a53_2>; - }; - core3 { - cpu = <&a53_3>; - }; - }; - }; - - a57_0: cpu@0 { - compatible = "arm,cortex-a57"; - reg = <0x0>; - device_type = "cpu"; - power-domains = <&sysc R8A774E1_PD_CA57_CPU0>; - next-level-cache = <&L2_CA57>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_0>; - dynamic-power-coefficient = <854>; - clocks = <&cpg CPG_CORE R8A774E1_CLK_Z>; - operating-points-v2 = <&cluster0_opp>; - capacity-dmips-mhz = <1024>; - #cooling-cells = <2>; - }; - - a57_1: cpu@1 { - compatible = "arm,cortex-a57"; - reg = <0x1>; - device_type = "cpu"; - power-domains = <&sysc R8A774E1_PD_CA57_CPU1>; - next-level-cache = <&L2_CA57>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_0>; - clocks = <&cpg CPG_CORE R8A774E1_CLK_Z>; - operating-points-v2 = <&cluster0_opp>; - capacity-dmips-mhz = <1024>; - #cooling-cells = <2>; - }; - - a57_2: cpu@2 { - compatible = "arm,cortex-a57"; - reg = <0x2>; - device_type = "cpu"; - power-domains = <&sysc R8A774E1_PD_CA57_CPU2>; - next-level-cache = <&L2_CA57>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_0>; - clocks = <&cpg CPG_CORE R8A774E1_CLK_Z>; - operating-points-v2 = <&cluster0_opp>; - capacity-dmips-mhz = <1024>; - #cooling-cells = <2>; - }; - - a57_3: cpu@3 { - compatible = "arm,cortex-a57"; - reg = <0x3>; - device_type = "cpu"; - power-domains = <&sysc R8A774E1_PD_CA57_CPU3>; - next-level-cache = <&L2_CA57>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_0>; - clocks = <&cpg CPG_CORE R8A774E1_CLK_Z>; - operating-points-v2 = <&cluster0_opp>; - capacity-dmips-mhz = <1024>; - #cooling-cells = <2>; - }; - - a53_0: cpu@100 { - compatible = "arm,cortex-a53"; - reg = <0x100>; - device_type = "cpu"; - power-domains = <&sysc R8A774E1_PD_CA53_CPU0>; - next-level-cache = <&L2_CA53>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_1>; - #cooling-cells = <2>; - dynamic-power-coefficient = <277>; - clocks = <&cpg CPG_CORE R8A774E1_CLK_Z2>; - operating-points-v2 = <&cluster1_opp>; - capacity-dmips-mhz = <535>; - }; - - a53_1: cpu@101 { - compatible = "arm,cortex-a53"; - reg = <0x101>; - device_type = "cpu"; - power-domains = <&sysc R8A774E1_PD_CA53_CPU1>; - next-level-cache = <&L2_CA53>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_1>; - clocks = <&cpg CPG_CORE R8A774E1_CLK_Z2>; - operating-points-v2 = <&cluster1_opp>; - capacity-dmips-mhz = <535>; - }; - - a53_2: cpu@102 { - compatible = "arm,cortex-a53"; - reg = <0x102>; - device_type = "cpu"; - power-domains = <&sysc R8A774E1_PD_CA53_CPU2>; - next-level-cache = <&L2_CA53>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_1>; - clocks = <&cpg CPG_CORE R8A774E1_CLK_Z2>; - operating-points-v2 = <&cluster1_opp>; - capacity-dmips-mhz = <535>; - }; - - a53_3: cpu@103 { - compatible = "arm,cortex-a53"; - reg = <0x103>; - device_type = "cpu"; - power-domains = <&sysc R8A774E1_PD_CA53_CPU3>; - next-level-cache = <&L2_CA53>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_1>; - clocks = <&cpg CPG_CORE R8A774E1_CLK_Z2>; - operating-points-v2 = <&cluster1_opp>; - capacity-dmips-mhz = <535>; - }; - - L2_CA57: cache-controller-0 { - compatible = "cache"; - power-domains = <&sysc R8A774E1_PD_CA57_SCU>; - cache-unified; - cache-level = <2>; - }; - - L2_CA53: cache-controller-1 { - compatible = "cache"; - power-domains = <&sysc R8A774E1_PD_CA53_SCU>; - cache-unified; - cache-level = <2>; - }; - - idle-states { - entry-method = "psci"; - - CPU_SLEEP_0: cpu-sleep-0 { - compatible = "arm,idle-state"; - arm,psci-suspend-param = <0x0010000>; - local-timer-stop; - entry-latency-us = <400>; - exit-latency-us = <500>; - min-residency-us = <4000>; - }; - - CPU_SLEEP_1: cpu-sleep-1 { - compatible = "arm,idle-state"; - arm,psci-suspend-param = <0x0010000>; - local-timer-stop; - entry-latency-us = <700>; - exit-latency-us = <700>; - min-residency-us = <5000>; - }; - }; - }; - - extal_clk: extal { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board */ - clock-frequency = <0>; - }; - - extalr_clk: extalr { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board */ - clock-frequency = <0>; - }; - - /* External PCIe clock - can be overridden by the board */ - pcie_bus_clk: pcie_bus { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - pmu_a53 { - compatible = "arm,cortex-a53-pmu"; - interrupts-extended = <&gic GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&a53_0>, <&a53_1>, <&a53_2>, <&a53_3>; - }; - - pmu_a57 { - compatible = "arm,cortex-a57-pmu"; - interrupts-extended = <&gic GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 75 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&a57_0>, <&a57_1>, <&a57_2>, <&a57_3>; - }; - - psci { - compatible = "arm,psci-1.0", "arm,psci-0.2"; - method = "smc"; - }; - - /* External SCIF clock - to be overridden by boards that provide it */ - scif_clk: scif { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - soc { - compatible = "simple-bus"; - interrupt-parent = <&gic>; - #address-cells = <2>; - #size-cells = <2>; - ranges; - - rwdt: watchdog@e6020000 { - compatible = "renesas,r8a774e1-wdt", - "renesas,rcar-gen3-wdt"; - reg = <0 0xe6020000 0 0x0c>; - interrupts = <GIC_SPI 140 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 402>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 402>; - status = "disabled"; - }; - - gpio0: gpio@e6050000 { - compatible = "renesas,gpio-r8a774e1", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6050000 0 0x50>; - interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 0 16>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 912>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 912>; - }; - - gpio1: gpio@e6051000 { - compatible = "renesas,gpio-r8a774e1", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6051000 0 0x50>; - interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 32 29>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 911>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 911>; - }; - - gpio2: gpio@e6052000 { - compatible = "renesas,gpio-r8a774e1", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6052000 0 0x50>; - interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 64 15>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 910>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 910>; - }; - - gpio3: gpio@e6053000 { - compatible = "renesas,gpio-r8a774e1", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6053000 0 0x50>; - interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 96 16>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 909>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 909>; - }; - - gpio4: gpio@e6054000 { - compatible = "renesas,gpio-r8a774e1", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6054000 0 0x50>; - interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 128 18>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 908>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 908>; - }; - - gpio5: gpio@e6055000 { - compatible = "renesas,gpio-r8a774e1", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6055000 0 0x50>; - interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 160 26>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 907>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 907>; - }; - - gpio6: gpio@e6055400 { - compatible = "renesas,gpio-r8a774e1", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6055400 0 0x50>; - interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 192 32>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 906>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 906>; - }; - - gpio7: gpio@e6055800 { - compatible = "renesas,gpio-r8a774e1", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6055800 0 0x50>; - interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 224 4>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 905>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 905>; - }; - - pfc: pinctrl@e6060000 { - compatible = "renesas,pfc-r8a774e1"; - reg = <0 0xe6060000 0 0x50c>; - }; - - cmt0: timer@e60f0000 { - compatible = "renesas,r8a774e1-cmt0", - "renesas,rcar-gen3-cmt0"; - reg = <0 0xe60f0000 0 0x1004>; - interrupts = <GIC_SPI 142 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 143 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 303>; - clock-names = "fck"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 303>; - status = "disabled"; - }; - - cmt1: timer@e6130000 { - compatible = "renesas,r8a774e1-cmt1", - "renesas,rcar-gen3-cmt1"; - reg = <0 0xe6130000 0 0x1004>; - interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 127 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 302>; - clock-names = "fck"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 302>; - status = "disabled"; - }; - - cmt2: timer@e6140000 { - compatible = "renesas,r8a774e1-cmt1", - "renesas,rcar-gen3-cmt1"; - reg = <0 0xe6140000 0 0x1004>; - interrupts = <GIC_SPI 398 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 399 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 400 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 401 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 402 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 403 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 404 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 405 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 301>; - clock-names = "fck"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 301>; - status = "disabled"; - }; - - cmt3: timer@e6148000 { - compatible = "renesas,r8a774e1-cmt1", - "renesas,rcar-gen3-cmt1"; - reg = <0 0xe6148000 0 0x1004>; - interrupts = <GIC_SPI 470 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 471 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 472 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 473 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 474 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 475 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 476 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 477 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 300>; - clock-names = "fck"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 300>; - status = "disabled"; - }; - - cpg: clock-controller@e6150000 { - compatible = "renesas,r8a774e1-cpg-mssr"; - reg = <0 0xe6150000 0 0x1000>; - clocks = <&extal_clk>, <&extalr_clk>; - clock-names = "extal", "extalr"; - #clock-cells = <2>; - #power-domain-cells = <0>; - #reset-cells = <1>; - }; - - rst: reset-controller@e6160000 { - compatible = "renesas,r8a774e1-rst"; - reg = <0 0xe6160000 0 0x0200>; - }; - - sysc: system-controller@e6180000 { - compatible = "renesas,r8a774e1-sysc"; - reg = <0 0xe6180000 0 0x0400>; - #power-domain-cells = <1>; - }; - - tsc: thermal@e6198000 { - compatible = "renesas,r8a774e1-thermal"; - reg = <0 0xe6198000 0 0x100>, - <0 0xe61a0000 0 0x100>, - <0 0xe61a8000 0 0x100>; - interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 522>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 522>; - #thermal-sensor-cells = <1>; - }; - - intc_ex: interrupt-controller@e61c0000 { - compatible = "renesas,intc-ex-r8a774e1", "renesas,irqc"; - #interrupt-cells = <2>; - interrupt-controller; - reg = <0 0xe61c0000 0 0x200>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 161 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 407>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 407>; - }; - - tmu0: timer@e61e0000 { - compatible = "renesas,tmu-r8a774e1", "renesas,tmu"; - reg = <0 0xe61e0000 0 0x30>; - interrupts = <GIC_SPI 136 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 137 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 138 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 125>; - clock-names = "fck"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 125>; - status = "disabled"; - }; - - tmu1: timer@e6fc0000 { - compatible = "renesas,tmu-r8a774e1", "renesas,tmu"; - reg = <0 0xe6fc0000 0 0x30>; - interrupts = <GIC_SPI 128 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 129 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 130 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 124>; - clock-names = "fck"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 124>; - status = "disabled"; - }; - - tmu2: timer@e6fd0000 { - compatible = "renesas,tmu-r8a774e1", "renesas,tmu"; - reg = <0 0xe6fd0000 0 0x30>; - interrupts = <GIC_SPI 303 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 304 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 305 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 123>; - clock-names = "fck"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 123>; - status = "disabled"; - }; - - tmu3: timer@e6fe0000 { - compatible = "renesas,tmu-r8a774e1", "renesas,tmu"; - reg = <0 0xe6fe0000 0 0x30>; - interrupts = <GIC_SPI 131 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 132 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 133 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 122>; - clock-names = "fck"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 122>; - status = "disabled"; - }; - - tmu4: timer@ffc00000 { - compatible = "renesas,tmu-r8a774e1", "renesas,tmu"; - reg = <0 0xffc00000 0 0x30>; - interrupts = <GIC_SPI 406 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 407 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 408 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 121>; - clock-names = "fck"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 121>; - status = "disabled"; - }; - - i2c0: i2c@e6500000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a774e1", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6500000 0 0x40>; - interrupts = <GIC_SPI 287 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 931>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 931>; - dmas = <&dmac1 0x91>, <&dmac1 0x90>, - <&dmac2 0x91>, <&dmac2 0x90>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - status = "disabled"; - }; - - i2c1: i2c@e6508000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a774e1", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6508000 0 0x40>; - interrupts = <GIC_SPI 288 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 930>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 930>; - dmas = <&dmac1 0x93>, <&dmac1 0x92>, - <&dmac2 0x93>, <&dmac2 0x92>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c2: i2c@e6510000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a774e1", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6510000 0 0x40>; - interrupts = <GIC_SPI 286 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 929>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 929>; - dmas = <&dmac1 0x95>, <&dmac1 0x94>, - <&dmac2 0x95>, <&dmac2 0x94>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c3: i2c@e66d0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a774e1", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66d0000 0 0x40>; - interrupts = <GIC_SPI 290 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 928>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 928>; - dmas = <&dmac0 0x97>, <&dmac0 0x96>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - status = "disabled"; - }; - - i2c4: i2c@e66d8000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a774e1", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66d8000 0 0x40>; - interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 927>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 927>; - dmas = <&dmac0 0x99>, <&dmac0 0x98>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - status = "disabled"; - }; - - i2c5: i2c@e66e0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a774e1", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66e0000 0 0x40>; - interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 919>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 919>; - dmas = <&dmac0 0x9b>, <&dmac0 0x9a>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - status = "disabled"; - }; - - i2c6: i2c@e66e8000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a774e1", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66e8000 0 0x40>; - interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 918>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 918>; - dmas = <&dmac0 0x9d>, <&dmac0 0x9c>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - iic_pmic: i2c@e60b0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,iic-r8a774e1", - "renesas,rcar-gen3-iic", - "renesas,rmobile-iic"; - reg = <0 0xe60b0000 0 0x425>; - interrupts = <GIC_SPI 173 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 926>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 926>; - dmas = <&dmac0 0x11>, <&dmac0 0x10>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - hscif0: serial@e6540000 { - compatible = "renesas,hscif-r8a774e1", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe6540000 0 0x60>; - interrupts = <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 520>, - <&cpg CPG_CORE R8A774E1_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x31>, <&dmac1 0x30>, - <&dmac2 0x31>, <&dmac2 0x30>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 520>; - status = "disabled"; - }; - - hscif1: serial@e6550000 { - compatible = "renesas,hscif-r8a774e1", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe6550000 0 0x60>; - interrupts = <GIC_SPI 155 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 519>, - <&cpg CPG_CORE R8A774E1_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x33>, <&dmac1 0x32>, - <&dmac2 0x33>, <&dmac2 0x32>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 519>; - status = "disabled"; - }; - - hscif2: serial@e6560000 { - compatible = "renesas,hscif-r8a774e1", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe6560000 0 0x60>; - interrupts = <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 518>, - <&cpg CPG_CORE R8A774E1_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x35>, <&dmac1 0x34>, - <&dmac2 0x35>, <&dmac2 0x34>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 518>; - status = "disabled"; - }; - - hscif3: serial@e66a0000 { - compatible = "renesas,hscif-r8a774e1", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe66a0000 0 0x60>; - interrupts = <GIC_SPI 145 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 517>, - <&cpg CPG_CORE R8A774E1_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x37>, <&dmac0 0x36>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 517>; - status = "disabled"; - }; - - hscif4: serial@e66b0000 { - compatible = "renesas,hscif-r8a774e1", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe66b0000 0 0x60>; - interrupts = <GIC_SPI 146 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 516>, - <&cpg CPG_CORE R8A774E1_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x39>, <&dmac0 0x38>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 516>; - status = "disabled"; - }; - - hsusb: usb@e6590000 { - compatible = "renesas,usbhs-r8a774e1", - "renesas,rcar-gen3-usbhs"; - reg = <0 0xe6590000 0 0x200>; - interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 704>, <&cpg CPG_MOD 703>; - dmas = <&usb_dmac0 0>, <&usb_dmac0 1>, - <&usb_dmac1 0>, <&usb_dmac1 1>; - dma-names = "ch0", "ch1", "ch2", "ch3"; - renesas,buswait = <11>; - phys = <&usb2_phy0 3>; - phy-names = "usb"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 704>, <&cpg 703>; - status = "disabled"; - }; - - usb2_clksel: clock-controller@e6590630 { - compatible = "renesas,r8a774e1-rcar-usb2-clock-sel", - "renesas,rcar-gen3-usb2-clock-sel"; - reg = <0 0xe6590630 0 0x02>; - clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>, - <&usb_extal_clk>, <&usb3s0_clk>; - clock-names = "ehci_ohci", "hs-usb-if", - "usb_extal", "usb_xtal"; - #clock-cells = <0>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 703>, <&cpg 704>; - reset-names = "ehci_ohci", "hs-usb-if"; - status = "disabled"; - }; - - usb_dmac0: dma-controller@e65a0000 { - compatible = "renesas,r8a774e1-usb-dmac", - "renesas,usb-dmac"; - reg = <0 0xe65a0000 0 0x100>; - interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1"; - clocks = <&cpg CPG_MOD 330>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 330>; - #dma-cells = <1>; - dma-channels = <2>; - }; - - usb_dmac1: dma-controller@e65b0000 { - compatible = "renesas,r8a774e1-usb-dmac", - "renesas,usb-dmac"; - reg = <0 0xe65b0000 0 0x100>; - interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1"; - clocks = <&cpg CPG_MOD 331>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 331>; - #dma-cells = <1>; - dma-channels = <2>; - }; - - usb3_phy0: usb-phy@e65ee000 { - compatible = "renesas,r8a774e1-usb3-phy", - "renesas,rcar-gen3-usb3-phy"; - reg = <0 0xe65ee000 0 0x90>; - clocks = <&cpg CPG_MOD 328>, <&usb3s0_clk>, - <&usb_extal_clk>; - clock-names = "usb3-if", "usb3s_clk", "usb_extal"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 328>; - #phy-cells = <0>; - status = "disabled"; - }; - - dmac0: dma-controller@e6700000 { - compatible = "renesas,dmac-r8a774e1", - "renesas,rcar-dmac"; - reg = <0 0xe6700000 0 0x10000>; - interrupts = <GIC_SPI 199 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 200 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 201 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 202 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 203 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 204 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 205 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 206 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 207 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 208 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 209 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 210 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 211 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 212 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 213 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 214 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 215 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 219>; - clock-names = "fck"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 219>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_ds0 0>, <&ipmmu_ds0 1>, - <&ipmmu_ds0 2>, <&ipmmu_ds0 3>, - <&ipmmu_ds0 4>, <&ipmmu_ds0 5>, - <&ipmmu_ds0 6>, <&ipmmu_ds0 7>, - <&ipmmu_ds0 8>, <&ipmmu_ds0 9>, - <&ipmmu_ds0 10>, <&ipmmu_ds0 11>, - <&ipmmu_ds0 12>, <&ipmmu_ds0 13>, - <&ipmmu_ds0 14>, <&ipmmu_ds0 15>; - }; - - dmac1: dma-controller@e7300000 { - compatible = "renesas,dmac-r8a774e1", - "renesas,rcar-dmac"; - reg = <0 0xe7300000 0 0x10000>; - interrupts = <GIC_SPI 220 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 216 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 217 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 218 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 219 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 308 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 309 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 310 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 311 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 312 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 313 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 314 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 315 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 316 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 317 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 318 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 319 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 218>; - clock-names = "fck"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 218>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_ds1 0>, <&ipmmu_ds1 1>, - <&ipmmu_ds1 2>, <&ipmmu_ds1 3>, - <&ipmmu_ds1 4>, <&ipmmu_ds1 5>, - <&ipmmu_ds1 6>, <&ipmmu_ds1 7>, - <&ipmmu_ds1 8>, <&ipmmu_ds1 9>, - <&ipmmu_ds1 10>, <&ipmmu_ds1 11>, - <&ipmmu_ds1 12>, <&ipmmu_ds1 13>, - <&ipmmu_ds1 14>, <&ipmmu_ds1 15>; - }; - - dmac2: dma-controller@e7310000 { - compatible = "renesas,dmac-r8a774e1", - "renesas,rcar-dmac"; - reg = <0 0xe7310000 0 0x10000>; - interrupts = <GIC_SPI 416 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 417 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 418 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 419 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 420 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 421 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 422 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 423 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 424 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 425 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 426 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 427 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 428 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 429 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 430 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 431 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 397 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 217>; - clock-names = "fck"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 217>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_ds1 16>, <&ipmmu_ds1 17>, - <&ipmmu_ds1 18>, <&ipmmu_ds1 19>, - <&ipmmu_ds1 20>, <&ipmmu_ds1 21>, - <&ipmmu_ds1 22>, <&ipmmu_ds1 23>, - <&ipmmu_ds1 24>, <&ipmmu_ds1 25>, - <&ipmmu_ds1 26>, <&ipmmu_ds1 27>, - <&ipmmu_ds1 28>, <&ipmmu_ds1 29>, - <&ipmmu_ds1 30>, <&ipmmu_ds1 31>; - }; - - ipmmu_ds0: iommu@e6740000 { - compatible = "renesas,ipmmu-r8a774e1"; - reg = <0 0xe6740000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 0>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_ds1: iommu@e7740000 { - compatible = "renesas,ipmmu-r8a774e1"; - reg = <0 0xe7740000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 1>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_hc: iommu@e6570000 { - compatible = "renesas,ipmmu-r8a774e1"; - reg = <0 0xe6570000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 2>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_mm: iommu@e67b0000 { - compatible = "renesas,ipmmu-r8a774e1"; - reg = <0 0xe67b0000 0 0x1000>; - interrupts = <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_mp0: iommu@ec670000 { - compatible = "renesas,ipmmu-r8a774e1"; - reg = <0 0xec670000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 4>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_pv0: iommu@fd800000 { - compatible = "renesas,ipmmu-r8a774e1"; - reg = <0 0xfd800000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 6>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_pv1: iommu@fd950000 { - compatible = "renesas,ipmmu-r8a774e1"; - reg = <0 0xfd950000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 7>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_pv2: iommu@fd960000 { - compatible = "renesas,ipmmu-r8a774e1"; - reg = <0 0xfd960000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 8>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_pv3: iommu@fd970000 { - compatible = "renesas,ipmmu-r8a774e1"; - reg = <0 0xfd970000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 9>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_vc0: iommu@fe6b0000 { - compatible = "renesas,ipmmu-r8a774e1"; - reg = <0 0xfe6b0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 12>; - power-domains = <&sysc R8A774E1_PD_A3VC>; - #iommu-cells = <1>; - }; - - ipmmu_vc1: iommu@fe6f0000 { - compatible = "renesas,ipmmu-r8a774e1"; - reg = <0 0xfe6f0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 13>; - power-domains = <&sysc R8A774E1_PD_A3VC>; - #iommu-cells = <1>; - }; - - ipmmu_vi0: iommu@febd0000 { - compatible = "renesas,ipmmu-r8a774e1"; - reg = <0 0xfebd0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 14>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_vi1: iommu@febe0000 { - compatible = "renesas,ipmmu-r8a774e1"; - reg = <0 0xfebe0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 15>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_vp0: iommu@fe990000 { - compatible = "renesas,ipmmu-r8a774e1"; - reg = <0 0xfe990000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 16>; - power-domains = <&sysc R8A774E1_PD_A3VP>; - #iommu-cells = <1>; - }; - - ipmmu_vp1: iommu@fe980000 { - compatible = "renesas,ipmmu-r8a774e1"; - reg = <0 0xfe980000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 17>; - power-domains = <&sysc R8A774E1_PD_A3VP>; - #iommu-cells = <1>; - }; - - avb: ethernet@e6800000 { - compatible = "renesas,etheravb-r8a774e1", - "renesas,etheravb-rcar-gen3"; - reg = <0 0xe6800000 0 0x800>; - interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 47 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 63 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15", - "ch16", "ch17", "ch18", "ch19", - "ch20", "ch21", "ch22", "ch23", - "ch24"; - clocks = <&cpg CPG_MOD 812>; - clock-names = "fck"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 812>; - phy-mode = "rgmii"; - rx-internal-delay-ps = <0>; - tx-internal-delay-ps = <0>; - iommus = <&ipmmu_ds0 16>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - can0: can@e6c30000 { - compatible = "renesas,can-r8a774e1", - "renesas,rcar-gen3-can"; - reg = <0 0xe6c30000 0 0x1000>; - interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 916>, - <&cpg CPG_CORE R8A774E1_CLK_CANFD>, - <&can_clk>; - clock-names = "clkp1", "clkp2", "can_clk"; - assigned-clocks = <&cpg CPG_CORE R8A774E1_CLK_CANFD>; - assigned-clock-rates = <40000000>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 916>; - status = "disabled"; - }; - - can1: can@e6c38000 { - compatible = "renesas,can-r8a774e1", - "renesas,rcar-gen3-can"; - reg = <0 0xe6c38000 0 0x1000>; - interrupts = <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 915>, - <&cpg CPG_CORE R8A774E1_CLK_CANFD>, - <&can_clk>; - clock-names = "clkp1", "clkp2", "can_clk"; - assigned-clocks = <&cpg CPG_CORE R8A774E1_CLK_CANFD>; - assigned-clock-rates = <40000000>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 915>; - status = "disabled"; - }; - - canfd: can@e66c0000 { - compatible = "renesas,r8a774e1-canfd", - "renesas,rcar-gen3-canfd"; - reg = <0 0xe66c0000 0 0x8000>; - interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch_int", "g_int"; - clocks = <&cpg CPG_MOD 914>, - <&cpg CPG_CORE R8A774E1_CLK_CANFD>, - <&can_clk>; - clock-names = "fck", "canfd", "can_clk"; - assigned-clocks = <&cpg CPG_CORE R8A774E1_CLK_CANFD>; - assigned-clock-rates = <40000000>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 914>; - status = "disabled"; - - channel0 { - status = "disabled"; - }; - - channel1 { - status = "disabled"; - }; - }; - - pwm0: pwm@e6e30000 { - compatible = "renesas,pwm-r8a774e1", "renesas,pwm-rcar"; - reg = <0 0xe6e30000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - pwm1: pwm@e6e31000 { - compatible = "renesas,pwm-r8a774e1", "renesas,pwm-rcar"; - reg = <0 0xe6e31000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - pwm2: pwm@e6e32000 { - compatible = "renesas,pwm-r8a774e1", "renesas,pwm-rcar"; - reg = <0 0xe6e32000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - pwm3: pwm@e6e33000 { - compatible = "renesas,pwm-r8a774e1", "renesas,pwm-rcar"; - reg = <0 0xe6e33000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - pwm4: pwm@e6e34000 { - compatible = "renesas,pwm-r8a774e1", "renesas,pwm-rcar"; - reg = <0 0xe6e34000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - pwm5: pwm@e6e35000 { - compatible = "renesas,pwm-r8a774e1", "renesas,pwm-rcar"; - reg = <0 0xe6e35000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - pwm6: pwm@e6e36000 { - compatible = "renesas,pwm-r8a774e1", "renesas,pwm-rcar"; - reg = <0 0xe6e36000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - scif0: serial@e6e60000 { - compatible = "renesas,scif-r8a774e1", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6e60000 0 0x40>; - interrupts = <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 207>, - <&cpg CPG_CORE R8A774E1_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x51>, <&dmac1 0x50>, - <&dmac2 0x51>, <&dmac2 0x50>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 207>; - status = "disabled"; - }; - - scif1: serial@e6e68000 { - compatible = "renesas,scif-r8a774e1", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6e68000 0 0x40>; - interrupts = <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 206>, - <&cpg CPG_CORE R8A774E1_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x53>, <&dmac1 0x52>, - <&dmac2 0x53>, <&dmac2 0x52>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 206>; - status = "disabled"; - }; - - scif2: serial@e6e88000 { - compatible = "renesas,scif-r8a774e1", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6e88000 0 0x40>; - interrupts = <GIC_SPI 164 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 310>, - <&cpg CPG_CORE R8A774E1_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x13>, <&dmac1 0x12>, - <&dmac2 0x13>, <&dmac2 0x12>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 310>; - status = "disabled"; - }; - - scif3: serial@e6c50000 { - compatible = "renesas,scif-r8a774e1", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6c50000 0 0x40>; - interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 204>, - <&cpg CPG_CORE R8A774E1_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x57>, <&dmac0 0x56>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 204>; - status = "disabled"; - }; - - scif4: serial@e6c40000 { - compatible = "renesas,scif-r8a774e1", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6c40000 0 0x40>; - interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 203>, - <&cpg CPG_CORE R8A774E1_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x59>, <&dmac0 0x58>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 203>; - status = "disabled"; - }; - - scif5: serial@e6f30000 { - compatible = "renesas,scif-r8a774e1", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6f30000 0 0x40>; - interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 202>, - <&cpg CPG_CORE R8A774E1_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x5b>, <&dmac1 0x5a>, - <&dmac2 0x5b>, <&dmac2 0x5a>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 202>; - status = "disabled"; - }; - - msiof0: spi@e6e90000 { - compatible = "renesas,msiof-r8a774e1", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6e90000 0 0x0064>; - interrupts = <GIC_SPI 156 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 211>; - dmas = <&dmac1 0x41>, <&dmac1 0x40>, - <&dmac2 0x41>, <&dmac2 0x40>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 211>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof1: spi@e6ea0000 { - compatible = "renesas,msiof-r8a774e1", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6ea0000 0 0x0064>; - interrupts = <GIC_SPI 157 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 210>; - dmas = <&dmac1 0x43>, <&dmac1 0x42>, - <&dmac2 0x43>, <&dmac2 0x42>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 210>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof2: spi@e6c00000 { - compatible = "renesas,msiof-r8a774e1", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6c00000 0 0x0064>; - interrupts = <GIC_SPI 158 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 209>; - dmas = <&dmac0 0x45>, <&dmac0 0x44>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 209>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof3: spi@e6c10000 { - compatible = "renesas,msiof-r8a774e1", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6c10000 0 0x0064>; - interrupts = <GIC_SPI 159 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 208>; - dmas = <&dmac0 0x47>, <&dmac0 0x46>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 208>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - vin0: video@e6ef0000 { - compatible = "renesas,vin-r8a774e1"; - reg = <0 0xe6ef0000 0 0x1000>; - interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 811>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 811>; - renesas,id = <0>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin0csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin0>; - }; - vin0csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin0>; - }; - }; - }; - }; - - vin1: video@e6ef1000 { - compatible = "renesas,vin-r8a774e1"; - reg = <0 0xe6ef1000 0 0x1000>; - interrupts = <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 810>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 810>; - renesas,id = <1>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin1csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin1>; - }; - vin1csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin1>; - }; - }; - }; - }; - - vin2: video@e6ef2000 { - compatible = "renesas,vin-r8a774e1"; - reg = <0 0xe6ef2000 0 0x1000>; - interrupts = <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 809>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 809>; - renesas,id = <2>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin2csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin2>; - }; - vin2csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin2>; - }; - }; - }; - }; - - vin3: video@e6ef3000 { - compatible = "renesas,vin-r8a774e1"; - reg = <0 0xe6ef3000 0 0x1000>; - interrupts = <GIC_SPI 191 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 808>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 808>; - renesas,id = <3>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin3csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin3>; - }; - vin3csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin3>; - }; - }; - }; - }; - - vin4: video@e6ef4000 { - compatible = "renesas,vin-r8a774e1"; - reg = <0 0xe6ef4000 0 0x1000>; - interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 807>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 807>; - renesas,id = <4>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin4csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin4>; - }; - }; - }; - }; - - vin5: video@e6ef5000 { - compatible = "renesas,vin-r8a774e1"; - reg = <0 0xe6ef5000 0 0x1000>; - interrupts = <GIC_SPI 175 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 806>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 806>; - renesas,id = <5>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin5csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin5>; - }; - }; - }; - }; - - vin6: video@e6ef6000 { - compatible = "renesas,vin-r8a774e1"; - reg = <0 0xe6ef6000 0 0x1000>; - interrupts = <GIC_SPI 176 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 805>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 805>; - renesas,id = <6>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin6csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin6>; - }; - }; - }; - }; - - vin7: video@e6ef7000 { - compatible = "renesas,vin-r8a774e1"; - reg = <0 0xe6ef7000 0 0x1000>; - interrupts = <GIC_SPI 171 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 804>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 804>; - renesas,id = <7>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin7csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin7>; - }; - }; - }; - }; - - rcar_sound: sound@ec500000 { - /* - * #sound-dai-cells is required if simple-card - * - * Single DAI : #sound-dai-cells = <0>; <&rcar_sound>; - * Multi DAI : #sound-dai-cells = <1>; <&rcar_sound N>; - */ - /* - * #clock-cells is required for audio_clkout0/1/2/3 - * - * clkout : #clock-cells = <0>; <&rcar_sound>; - * clkout0/1/2/3: #clock-cells = <1>; <&rcar_sound N>; - */ - compatible = "renesas,rcar_sound-r8a774e1", "renesas,rcar_sound-gen3"; - reg = <0 0xec500000 0 0x1000>, /* SCU */ - <0 0xec5a0000 0 0x100>, /* ADG */ - <0 0xec540000 0 0x1000>, /* SSIU */ - <0 0xec541000 0 0x280>, /* SSI */ - <0 0xec760000 0 0x200>; /* Audio DMAC peri peri*/ - reg-names = "scu", "adg", "ssiu", "ssi", "audmapp"; - - clocks = <&cpg CPG_MOD 1005>, - <&cpg CPG_MOD 1006>, <&cpg CPG_MOD 1007>, - <&cpg CPG_MOD 1008>, <&cpg CPG_MOD 1009>, - <&cpg CPG_MOD 1010>, <&cpg CPG_MOD 1011>, - <&cpg CPG_MOD 1012>, <&cpg CPG_MOD 1013>, - <&cpg CPG_MOD 1014>, <&cpg CPG_MOD 1015>, - <&cpg CPG_MOD 1022>, <&cpg CPG_MOD 1023>, - <&cpg CPG_MOD 1024>, <&cpg CPG_MOD 1025>, - <&cpg CPG_MOD 1026>, <&cpg CPG_MOD 1027>, - <&cpg CPG_MOD 1028>, <&cpg CPG_MOD 1029>, - <&cpg CPG_MOD 1030>, <&cpg CPG_MOD 1031>, - <&cpg CPG_MOD 1020>, <&cpg CPG_MOD 1021>, - <&cpg CPG_MOD 1020>, <&cpg CPG_MOD 1021>, - <&cpg CPG_MOD 1019>, <&cpg CPG_MOD 1018>, - <&audio_clk_a>, <&audio_clk_b>, - <&audio_clk_c>, - <&cpg CPG_CORE R8A774E1_CLK_S0D4>; - clock-names = "ssi-all", - "ssi.9", "ssi.8", "ssi.7", "ssi.6", - "ssi.5", "ssi.4", "ssi.3", "ssi.2", - "ssi.1", "ssi.0", - "src.9", "src.8", "src.7", "src.6", - "src.5", "src.4", "src.3", "src.2", - "src.1", "src.0", - "mix.1", "mix.0", - "ctu.1", "ctu.0", - "dvc.0", "dvc.1", - "clk_a", "clk_b", "clk_c", "clk_i"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 1005>, - <&cpg 1006>, <&cpg 1007>, - <&cpg 1008>, <&cpg 1009>, - <&cpg 1010>, <&cpg 1011>, - <&cpg 1012>, <&cpg 1013>, - <&cpg 1014>, <&cpg 1015>; - reset-names = "ssi-all", - "ssi.9", "ssi.8", "ssi.7", "ssi.6", - "ssi.5", "ssi.4", "ssi.3", "ssi.2", - "ssi.1", "ssi.0"; - status = "disabled"; - - rcar_sound,dvc { - dvc0: dvc-0 { - dmas = <&audma1 0xbc>; - dma-names = "tx"; - }; - dvc1: dvc-1 { - dmas = <&audma1 0xbe>; - dma-names = "tx"; - }; - }; - - rcar_sound,mix { - mix0: mix-0 { }; - mix1: mix-1 { }; - }; - - rcar_sound,ctu { - ctu00: ctu-0 { }; - ctu01: ctu-1 { }; - ctu02: ctu-2 { }; - ctu03: ctu-3 { }; - ctu10: ctu-4 { }; - ctu11: ctu-5 { }; - ctu12: ctu-6 { }; - ctu13: ctu-7 { }; - }; - - rcar_sound,src { - src0: src-0 { - interrupts = <GIC_SPI 352 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x85>, <&audma1 0x9a>; - dma-names = "rx", "tx"; - }; - src1: src-1 { - interrupts = <GIC_SPI 353 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x87>, <&audma1 0x9c>; - dma-names = "rx", "tx"; - }; - src2: src-2 { - interrupts = <GIC_SPI 354 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x89>, <&audma1 0x9e>; - dma-names = "rx", "tx"; - }; - src3: src-3 { - interrupts = <GIC_SPI 355 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x8b>, <&audma1 0xa0>; - dma-names = "rx", "tx"; - }; - src4: src-4 { - interrupts = <GIC_SPI 356 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x8d>, <&audma1 0xb0>; - dma-names = "rx", "tx"; - }; - src5: src-5 { - interrupts = <GIC_SPI 357 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x8f>, <&audma1 0xb2>; - dma-names = "rx", "tx"; - }; - src6: src-6 { - interrupts = <GIC_SPI 358 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x91>, <&audma1 0xb4>; - dma-names = "rx", "tx"; - }; - src7: src-7 { - interrupts = <GIC_SPI 359 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x93>, <&audma1 0xb6>; - dma-names = "rx", "tx"; - }; - src8: src-8 { - interrupts = <GIC_SPI 360 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x95>, <&audma1 0xb8>; - dma-names = "rx", "tx"; - }; - src9: src-9 { - interrupts = <GIC_SPI 361 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x97>, <&audma1 0xba>; - dma-names = "rx", "tx"; - }; - }; - - rcar_sound,ssiu { - ssiu00: ssiu-0 { - dmas = <&audma0 0x15>, <&audma1 0x16>; - dma-names = "rx", "tx"; - }; - ssiu01: ssiu-1 { - dmas = <&audma0 0x35>, <&audma1 0x36>; - dma-names = "rx", "tx"; - }; - ssiu02: ssiu-2 { - dmas = <&audma0 0x37>, <&audma1 0x38>; - dma-names = "rx", "tx"; - }; - ssiu03: ssiu-3 { - dmas = <&audma0 0x47>, <&audma1 0x48>; - dma-names = "rx", "tx"; - }; - ssiu04: ssiu-4 { - dmas = <&audma0 0x3F>, <&audma1 0x40>; - dma-names = "rx", "tx"; - }; - ssiu05: ssiu-5 { - dmas = <&audma0 0x43>, <&audma1 0x44>; - dma-names = "rx", "tx"; - }; - ssiu06: ssiu-6 { - dmas = <&audma0 0x4F>, <&audma1 0x50>; - dma-names = "rx", "tx"; - }; - ssiu07: ssiu-7 { - dmas = <&audma0 0x53>, <&audma1 0x54>; - dma-names = "rx", "tx"; - }; - ssiu10: ssiu-8 { - dmas = <&audma0 0x49>, <&audma1 0x4a>; - dma-names = "rx", "tx"; - }; - ssiu11: ssiu-9 { - dmas = <&audma0 0x4B>, <&audma1 0x4C>; - dma-names = "rx", "tx"; - }; - ssiu12: ssiu-10 { - dmas = <&audma0 0x57>, <&audma1 0x58>; - dma-names = "rx", "tx"; - }; - ssiu13: ssiu-11 { - dmas = <&audma0 0x59>, <&audma1 0x5A>; - dma-names = "rx", "tx"; - }; - ssiu14: ssiu-12 { - dmas = <&audma0 0x5F>, <&audma1 0x60>; - dma-names = "rx", "tx"; - }; - ssiu15: ssiu-13 { - dmas = <&audma0 0xC3>, <&audma1 0xC4>; - dma-names = "rx", "tx"; - }; - ssiu16: ssiu-14 { - dmas = <&audma0 0xC7>, <&audma1 0xC8>; - dma-names = "rx", "tx"; - }; - ssiu17: ssiu-15 { - dmas = <&audma0 0xCB>, <&audma1 0xCC>; - dma-names = "rx", "tx"; - }; - ssiu20: ssiu-16 { - dmas = <&audma0 0x63>, <&audma1 0x64>; - dma-names = "rx", "tx"; - }; - ssiu21: ssiu-17 { - dmas = <&audma0 0x67>, <&audma1 0x68>; - dma-names = "rx", "tx"; - }; - ssiu22: ssiu-18 { - dmas = <&audma0 0x6B>, <&audma1 0x6C>; - dma-names = "rx", "tx"; - }; - ssiu23: ssiu-19 { - dmas = <&audma0 0x6D>, <&audma1 0x6E>; - dma-names = "rx", "tx"; - }; - ssiu24: ssiu-20 { - dmas = <&audma0 0xCF>, <&audma1 0xCE>; - dma-names = "rx", "tx"; - }; - ssiu25: ssiu-21 { - dmas = <&audma0 0xEB>, <&audma1 0xEC>; - dma-names = "rx", "tx"; - }; - ssiu26: ssiu-22 { - dmas = <&audma0 0xED>, <&audma1 0xEE>; - dma-names = "rx", "tx"; - }; - ssiu27: ssiu-23 { - dmas = <&audma0 0xEF>, <&audma1 0xF0>; - dma-names = "rx", "tx"; - }; - ssiu30: ssiu-24 { - dmas = <&audma0 0x6f>, <&audma1 0x70>; - dma-names = "rx", "tx"; - }; - ssiu31: ssiu-25 { - dmas = <&audma0 0x21>, <&audma1 0x22>; - dma-names = "rx", "tx"; - }; - ssiu32: ssiu-26 { - dmas = <&audma0 0x23>, <&audma1 0x24>; - dma-names = "rx", "tx"; - }; - ssiu33: ssiu-27 { - dmas = <&audma0 0x25>, <&audma1 0x26>; - dma-names = "rx", "tx"; - }; - ssiu34: ssiu-28 { - dmas = <&audma0 0x27>, <&audma1 0x28>; - dma-names = "rx", "tx"; - }; - ssiu35: ssiu-29 { - dmas = <&audma0 0x29>, <&audma1 0x2A>; - dma-names = "rx", "tx"; - }; - ssiu36: ssiu-30 { - dmas = <&audma0 0x2B>, <&audma1 0x2C>; - dma-names = "rx", "tx"; - }; - ssiu37: ssiu-31 { - dmas = <&audma0 0x2D>, <&audma1 0x2E>; - dma-names = "rx", "tx"; - }; - ssiu40: ssiu-32 { - dmas = <&audma0 0x71>, <&audma1 0x72>; - dma-names = "rx", "tx"; - }; - ssiu41: ssiu-33 { - dmas = <&audma0 0x17>, <&audma1 0x18>; - dma-names = "rx", "tx"; - }; - ssiu42: ssiu-34 { - dmas = <&audma0 0x19>, <&audma1 0x1A>; - dma-names = "rx", "tx"; - }; - ssiu43: ssiu-35 { - dmas = <&audma0 0x1B>, <&audma1 0x1C>; - dma-names = "rx", "tx"; - }; - ssiu44: ssiu-36 { - dmas = <&audma0 0x1D>, <&audma1 0x1E>; - dma-names = "rx", "tx"; - }; - ssiu45: ssiu-37 { - dmas = <&audma0 0x1F>, <&audma1 0x20>; - dma-names = "rx", "tx"; - }; - ssiu46: ssiu-38 { - dmas = <&audma0 0x31>, <&audma1 0x32>; - dma-names = "rx", "tx"; - }; - ssiu47: ssiu-39 { - dmas = <&audma0 0x33>, <&audma1 0x34>; - dma-names = "rx", "tx"; - }; - ssiu50: ssiu-40 { - dmas = <&audma0 0x73>, <&audma1 0x74>; - dma-names = "rx", "tx"; - }; - ssiu60: ssiu-41 { - dmas = <&audma0 0x75>, <&audma1 0x76>; - dma-names = "rx", "tx"; - }; - ssiu70: ssiu-42 { - dmas = <&audma0 0x79>, <&audma1 0x7a>; - dma-names = "rx", "tx"; - }; - ssiu80: ssiu-43 { - dmas = <&audma0 0x7b>, <&audma1 0x7c>; - dma-names = "rx", "tx"; - }; - ssiu90: ssiu-44 { - dmas = <&audma0 0x7d>, <&audma1 0x7e>; - dma-names = "rx", "tx"; - }; - ssiu91: ssiu-45 { - dmas = <&audma0 0x7F>, <&audma1 0x80>; - dma-names = "rx", "tx"; - }; - ssiu92: ssiu-46 { - dmas = <&audma0 0x81>, <&audma1 0x82>; - dma-names = "rx", "tx"; - }; - ssiu93: ssiu-47 { - dmas = <&audma0 0x83>, <&audma1 0x84>; - dma-names = "rx", "tx"; - }; - ssiu94: ssiu-48 { - dmas = <&audma0 0xA3>, <&audma1 0xA4>; - dma-names = "rx", "tx"; - }; - ssiu95: ssiu-49 { - dmas = <&audma0 0xA5>, <&audma1 0xA6>; - dma-names = "rx", "tx"; - }; - ssiu96: ssiu-50 { - dmas = <&audma0 0xA7>, <&audma1 0xA8>; - dma-names = "rx", "tx"; - }; - ssiu97: ssiu-51 { - dmas = <&audma0 0xA9>, <&audma1 0xAA>; - dma-names = "rx", "tx"; - }; - }; - - rcar_sound,ssi { - ssi0: ssi-0 { - interrupts = <GIC_SPI 370 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x01>, <&audma1 0x02>; - dma-names = "rx", "tx"; - }; - ssi1: ssi-1 { - interrupts = <GIC_SPI 371 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x03>, <&audma1 0x04>; - dma-names = "rx", "tx"; - }; - ssi2: ssi-2 { - interrupts = <GIC_SPI 372 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x05>, <&audma1 0x06>; - dma-names = "rx", "tx"; - }; - ssi3: ssi-3 { - interrupts = <GIC_SPI 373 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x07>, <&audma1 0x08>; - dma-names = "rx", "tx"; - }; - ssi4: ssi-4 { - interrupts = <GIC_SPI 374 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x09>, <&audma1 0x0a>; - dma-names = "rx", "tx"; - }; - ssi5: ssi-5 { - interrupts = <GIC_SPI 375 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x0b>, <&audma1 0x0c>; - dma-names = "rx", "tx"; - }; - ssi6: ssi-6 { - interrupts = <GIC_SPI 376 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x0d>, <&audma1 0x0e>; - dma-names = "rx", "tx"; - }; - ssi7: ssi-7 { - interrupts = <GIC_SPI 377 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x0f>, <&audma1 0x10>; - dma-names = "rx", "tx"; - }; - ssi8: ssi-8 { - interrupts = <GIC_SPI 378 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x11>, <&audma1 0x12>; - dma-names = "rx", "tx"; - }; - ssi9: ssi-9 { - interrupts = <GIC_SPI 379 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x13>, <&audma1 0x14>; - dma-names = "rx", "tx"; - }; - }; - }; - - audma0: dma-controller@ec700000 { - compatible = "renesas,dmac-r8a774e1", - "renesas,rcar-dmac"; - reg = <0 0xec700000 0 0x10000>; - interrupts = <GIC_SPI 350 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 320 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 321 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 322 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 323 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 324 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 325 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 326 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 327 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 328 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 329 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 330 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 331 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 332 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 333 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 334 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 335 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 502>; - clock-names = "fck"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 502>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_mp0 0>, <&ipmmu_mp0 1>, - <&ipmmu_mp0 2>, <&ipmmu_mp0 3>, - <&ipmmu_mp0 4>, <&ipmmu_mp0 5>, - <&ipmmu_mp0 6>, <&ipmmu_mp0 7>, - <&ipmmu_mp0 8>, <&ipmmu_mp0 9>, - <&ipmmu_mp0 10>, <&ipmmu_mp0 11>, - <&ipmmu_mp0 12>, <&ipmmu_mp0 13>, - <&ipmmu_mp0 14>, <&ipmmu_mp0 15>; - }; - - audma1: dma-controller@ec720000 { - compatible = "renesas,dmac-r8a774e1", - "renesas,rcar-dmac"; - reg = <0 0xec720000 0 0x10000>; - interrupts = <GIC_SPI 351 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 336 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 337 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 338 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 339 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 340 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 341 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 342 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 343 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 344 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 345 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 346 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 347 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 348 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 349 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 382 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 383 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 501>; - clock-names = "fck"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 501>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_mp0 16>, <&ipmmu_mp0 17>, - <&ipmmu_mp0 18>, <&ipmmu_mp0 19>, - <&ipmmu_mp0 20>, <&ipmmu_mp0 21>, - <&ipmmu_mp0 22>, <&ipmmu_mp0 23>, - <&ipmmu_mp0 24>, <&ipmmu_mp0 25>, - <&ipmmu_mp0 26>, <&ipmmu_mp0 27>, - <&ipmmu_mp0 28>, <&ipmmu_mp0 29>, - <&ipmmu_mp0 30>, <&ipmmu_mp0 31>; - }; - - xhci0: usb@ee000000 { - compatible = "renesas,xhci-r8a774e1", - "renesas,rcar-gen3-xhci"; - reg = <0 0xee000000 0 0xc00>; - interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 328>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 328>; - status = "disabled"; - }; - - usb3_peri0: usb@ee020000 { - compatible = "renesas,r8a774e1-usb3-peri", - "renesas,rcar-gen3-usb3-peri"; - reg = <0 0xee020000 0 0x400>; - interrupts = <GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 328>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 328>; - status = "disabled"; - }; - - ohci0: usb@ee080000 { - compatible = "generic-ohci"; - reg = <0 0xee080000 0 0x100>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>; - phys = <&usb2_phy0 1>; - phy-names = "usb"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 703>, <&cpg 704>; - status = "disabled"; - }; - - ohci1: usb@ee0a0000 { - compatible = "generic-ohci"; - reg = <0 0xee0a0000 0 0x100>; - interrupts = <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 702>; - phys = <&usb2_phy1 1>; - phy-names = "usb"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 702>; - status = "disabled"; - }; - - ehci0: usb@ee080100 { - compatible = "generic-ehci"; - reg = <0 0xee080100 0 0x100>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>; - phys = <&usb2_phy0 2>; - phy-names = "usb"; - companion = <&ohci0>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 703>, <&cpg 704>; - status = "disabled"; - }; - - ehci1: usb@ee0a0100 { - compatible = "generic-ehci"; - reg = <0 0xee0a0100 0 0x100>; - interrupts = <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 702>; - phys = <&usb2_phy1 2>; - phy-names = "usb"; - companion = <&ohci1>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 702>; - status = "disabled"; - }; - - usb2_phy0: usb-phy@ee080200 { - compatible = "renesas,usb2-phy-r8a774e1", - "renesas,rcar-gen3-usb2-phy"; - reg = <0 0xee080200 0 0x700>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 703>, <&cpg 704>; - #phy-cells = <1>; - status = "disabled"; - }; - - usb2_phy1: usb-phy@ee0a0200 { - compatible = "renesas,usb2-phy-r8a774e1", - "renesas,rcar-gen3-usb2-phy"; - reg = <0 0xee0a0200 0 0x700>; - clocks = <&cpg CPG_MOD 702>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 702>; - #phy-cells = <1>; - status = "disabled"; - }; - - sdhi0: mmc@ee100000 { - compatible = "renesas,sdhi-r8a774e1", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee100000 0 0x2000>; - interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 314>, <&cpg CPG_CORE R8A774E1_CLK_SD0H>; - clock-names = "core", "clkh"; - max-frequency = <200000000>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 314>; - iommus = <&ipmmu_ds1 32>; - status = "disabled"; - }; - - sdhi1: mmc@ee120000 { - compatible = "renesas,sdhi-r8a774e1", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee120000 0 0x2000>; - interrupts = <GIC_SPI 166 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 313>, <&cpg CPG_CORE R8A774E1_CLK_SD1H>; - clock-names = "core", "clkh"; - max-frequency = <200000000>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 313>; - iommus = <&ipmmu_ds1 33>; - status = "disabled"; - }; - - sdhi2: mmc@ee140000 { - compatible = "renesas,sdhi-r8a774e1", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee140000 0 0x2000>; - interrupts = <GIC_SPI 167 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 312>, <&cpg CPG_CORE R8A774E1_CLK_SD2H>; - clock-names = "core", "clkh"; - max-frequency = <200000000>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 312>; - iommus = <&ipmmu_ds1 34>; - status = "disabled"; - }; - - sdhi3: mmc@ee160000 { - compatible = "renesas,sdhi-r8a774e1", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee160000 0 0x2000>; - interrupts = <GIC_SPI 168 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 311>, <&cpg CPG_CORE R8A774E1_CLK_SD3H>; - clock-names = "core", "clkh"; - max-frequency = <200000000>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 311>; - iommus = <&ipmmu_ds1 35>; - status = "disabled"; - }; - - rpc: spi@ee200000 { - compatible = "renesas,r8a774e1-rpc-if", - "renesas,rcar-gen3-rpc-if"; - reg = <0 0xee200000 0 0x200>, - <0 0x08000000 0 0x4000000>, - <0 0xee208000 0 0x100>; - reg-names = "regs", "dirmap", "wbuf"; - interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 917>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 917>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - sata: sata@ee300000 { - compatible = "renesas,sata-r8a774e1", - "renesas,rcar-gen3-sata"; - reg = <0 0xee300000 0 0x200000>; - interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 815>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 815>; - iommus = <&ipmmu_hc 2>; - status = "disabled"; - }; - - gic: interrupt-controller@f1010000 { - compatible = "arm,gic-400"; - #interrupt-cells = <3>; - #address-cells = <0>; - interrupt-controller; - reg = <0x0 0xf1010000 0 0x1000>, - <0x0 0xf1020000 0 0x20000>, - <0x0 0xf1040000 0 0x20000>, - <0x0 0xf1060000 0 0x20000>; - interrupts = <GIC_PPI 9 - (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_HIGH)>; - clocks = <&cpg CPG_MOD 408>; - clock-names = "clk"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 408>; - }; - - pciec0: pcie@fe000000 { - compatible = "renesas,pcie-r8a774e1", - "renesas,pcie-rcar-gen3"; - reg = <0 0xfe000000 0 0x80000>; - #address-cells = <3>; - #size-cells = <2>; - bus-range = <0x00 0xff>; - device_type = "pci"; - ranges = <0x01000000 0 0x00000000 0 0xfe100000 0 0x00100000>, - <0x02000000 0 0xfe200000 0 0xfe200000 0 0x00200000>, - <0x02000000 0 0x30000000 0 0x30000000 0 0x08000000>, - <0x42000000 0 0x38000000 0 0x38000000 0 0x08000000>; - /* Map all possible DDR/IOMMU as inbound ranges */ - dma-ranges = <0x42000000 0 0x00000000 0 0x00000000 1 0x00000000>; - interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>; - #interrupt-cells = <1>; - interrupt-map-mask = <0 0 0 0>; - interrupt-map = <0 0 0 0 &gic GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 319>, <&pcie_bus_clk>; - clock-names = "pcie", "pcie_bus"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 319>; - iommu-map = <0 &ipmmu_hc 0 1>; - iommu-map-mask = <0>; - status = "disabled"; - }; - - pciec1: pcie@ee800000 { - compatible = "renesas,pcie-r8a774e1", - "renesas,pcie-rcar-gen3"; - reg = <0 0xee800000 0 0x80000>; - #address-cells = <3>; - #size-cells = <2>; - bus-range = <0x00 0xff>; - device_type = "pci"; - ranges = <0x01000000 0 0x00000000 0 0xee900000 0 0x00100000>, - <0x02000000 0 0xeea00000 0 0xeea00000 0 0x00200000>, - <0x02000000 0 0xc0000000 0 0xc0000000 0 0x08000000>, - <0x42000000 0 0xc8000000 0 0xc8000000 0 0x08000000>; - /* Map all possible DDR/IOMMU as inbound ranges */ - dma-ranges = <0x42000000 0 0x00000000 0 0x00000000 1 0x00000000>; - interrupts = <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 149 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 150 IRQ_TYPE_LEVEL_HIGH>; - #interrupt-cells = <1>; - interrupt-map-mask = <0 0 0 0>; - interrupt-map = <0 0 0 0 &gic GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 318>, <&pcie_bus_clk>; - clock-names = "pcie", "pcie_bus"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 318>; - iommu-map = <0 &ipmmu_hc 1 1>; - iommu-map-mask = <0>; - status = "disabled"; - }; - - pciec0_ep: pcie-ep@fe000000 { - compatible = "renesas,r8a774e1-pcie-ep", - "renesas,rcar-gen3-pcie-ep"; - reg = <0x0 0xfe000000 0 0x80000>, - <0x0 0xfe100000 0 0x100000>, - <0x0 0xfe200000 0 0x200000>, - <0x0 0x30000000 0 0x8000000>, - <0x0 0x38000000 0 0x8000000>; - reg-names = "apb-base", "memory0", "memory1", "memory2", "memory3"; - interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 319>; - clock-names = "pcie"; - resets = <&cpg 319>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - status = "disabled"; - }; - - pciec1_ep: pcie-ep@ee800000 { - compatible = "renesas,r8a774e1-pcie-ep", - "renesas,rcar-gen3-pcie-ep"; - reg = <0x0 0xee800000 0 0x80000>, - <0x0 0xee900000 0 0x100000>, - <0x0 0xeea00000 0 0x200000>, - <0x0 0xc0000000 0 0x8000000>, - <0x0 0xc8000000 0 0x8000000>; - reg-names = "apb-base", "memory0", "memory1", "memory2", "memory3"; - interrupts = <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 149 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 150 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 318>; - clock-names = "pcie"; - resets = <&cpg 318>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - status = "disabled"; - }; - - vspbc: vsp@fe920000 { - compatible = "renesas,vsp2"; - reg = <0 0xfe920000 0 0x8000>; - interrupts = <GIC_SPI 465 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 624>; - power-domains = <&sysc R8A774E1_PD_A3VP>; - resets = <&cpg 624>; - - renesas,fcp = <&fcpvb1>; - }; - - vspbd: vsp@fe960000 { - compatible = "renesas,vsp2"; - reg = <0 0xfe960000 0 0x8000>; - interrupts = <GIC_SPI 266 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 626>; - power-domains = <&sysc R8A774E1_PD_A3VP>; - resets = <&cpg 626>; - - renesas,fcp = <&fcpvb0>; - }; - - vspd0: vsp@fea20000 { - compatible = "renesas,vsp2"; - reg = <0 0xfea20000 0 0x5000>; - interrupts = <GIC_SPI 466 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 623>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 623>; - - renesas,fcp = <&fcpvd0>; - }; - - vspd1: vsp@fea28000 { - compatible = "renesas,vsp2"; - reg = <0 0xfea28000 0 0x5000>; - interrupts = <GIC_SPI 467 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 622>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 622>; - - renesas,fcp = <&fcpvd1>; - }; - - vspi0: vsp@fe9a0000 { - compatible = "renesas,vsp2"; - reg = <0 0xfe9a0000 0 0x8000>; - interrupts = <GIC_SPI 444 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 631>; - power-domains = <&sysc R8A774E1_PD_A3VP>; - resets = <&cpg 631>; - - renesas,fcp = <&fcpvi0>; - }; - - vspi1: vsp@fe9b0000 { - compatible = "renesas,vsp2"; - reg = <0 0xfe9b0000 0 0x8000>; - interrupts = <GIC_SPI 445 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 630>; - power-domains = <&sysc R8A774E1_PD_A3VP>; - resets = <&cpg 630>; - - renesas,fcp = <&fcpvi1>; - }; - - fdp1@fe940000 { - compatible = "renesas,fdp1"; - reg = <0 0xfe940000 0 0x2400>; - interrupts = <GIC_SPI 262 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 119>; - power-domains = <&sysc R8A774E1_PD_A3VP>; - resets = <&cpg 119>; - renesas,fcp = <&fcpf0>; - }; - - fdp1@fe944000 { - compatible = "renesas,fdp1"; - reg = <0 0xfe944000 0 0x2400>; - interrupts = <GIC_SPI 263 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 118>; - power-domains = <&sysc R8A774E1_PD_A3VP>; - resets = <&cpg 118>; - renesas,fcp = <&fcpf1>; - }; - - fcpf0: fcp@fe950000 { - compatible = "renesas,fcpf"; - reg = <0 0xfe950000 0 0x200>; - clocks = <&cpg CPG_MOD 615>; - power-domains = <&sysc R8A774E1_PD_A3VP>; - resets = <&cpg 615>; - }; - - fcpf1: fcp@fe951000 { - compatible = "renesas,fcpf"; - reg = <0 0xfe951000 0 0x200>; - clocks = <&cpg CPG_MOD 614>; - power-domains = <&sysc R8A774E1_PD_A3VP>; - resets = <&cpg 614>; - }; - - fcpvb0: fcp@fe96f000 { - compatible = "renesas,fcpv"; - reg = <0 0xfe96f000 0 0x200>; - clocks = <&cpg CPG_MOD 607>; - power-domains = <&sysc R8A774E1_PD_A3VP>; - resets = <&cpg 607>; - }; - - fcpvb1: fcp@fe92f000 { - compatible = "renesas,fcpv"; - reg = <0 0xfe92f000 0 0x200>; - clocks = <&cpg CPG_MOD 606>; - power-domains = <&sysc R8A774E1_PD_A3VP>; - resets = <&cpg 606>; - }; - - fcpvi0: fcp@fe9af000 { - compatible = "renesas,fcpv"; - reg = <0 0xfe9af000 0 0x200>; - clocks = <&cpg CPG_MOD 611>; - power-domains = <&sysc R8A774E1_PD_A3VP>; - resets = <&cpg 611>; - }; - - fcpvi1: fcp@fe9bf000 { - compatible = "renesas,fcpv"; - reg = <0 0xfe9bf000 0 0x200>; - clocks = <&cpg CPG_MOD 610>; - power-domains = <&sysc R8A774E1_PD_A3VP>; - resets = <&cpg 610>; - }; - - fcpvd0: fcp@fea27000 { - compatible = "renesas,fcpv"; - reg = <0 0xfea27000 0 0x200>; - clocks = <&cpg CPG_MOD 603>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 603>; - }; - - fcpvd1: fcp@fea2f000 { - compatible = "renesas,fcpv"; - reg = <0 0xfea2f000 0 0x200>; - clocks = <&cpg CPG_MOD 602>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 602>; - }; - - csi20: csi2@fea80000 { - compatible = "renesas,r8a774e1-csi2"; - reg = <0 0xfea80000 0 0x10000>; - interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 714>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 714>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - csi20vin0: endpoint@0 { - reg = <0>; - remote-endpoint = <&vin0csi20>; - }; - csi20vin1: endpoint@1 { - reg = <1>; - remote-endpoint = <&vin1csi20>; - }; - csi20vin2: endpoint@2 { - reg = <2>; - remote-endpoint = <&vin2csi20>; - }; - csi20vin3: endpoint@3 { - reg = <3>; - remote-endpoint = <&vin3csi20>; - }; - csi20vin4: endpoint@4 { - reg = <4>; - remote-endpoint = <&vin4csi20>; - }; - csi20vin5: endpoint@5 { - reg = <5>; - remote-endpoint = <&vin5csi20>; - }; - csi20vin6: endpoint@6 { - reg = <6>; - remote-endpoint = <&vin6csi20>; - }; - csi20vin7: endpoint@7 { - reg = <7>; - remote-endpoint = <&vin7csi20>; - }; - }; - }; - }; - - csi40: csi2@feaa0000 { - compatible = "renesas,r8a774e1-csi2"; - reg = <0 0xfeaa0000 0 0x10000>; - interrupts = <GIC_SPI 246 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 716>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 716>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - csi40vin0: endpoint@0 { - reg = <0>; - remote-endpoint = <&vin0csi40>; - }; - csi40vin1: endpoint@1 { - reg = <1>; - remote-endpoint = <&vin1csi40>; - }; - csi40vin2: endpoint@2 { - reg = <2>; - remote-endpoint = <&vin2csi40>; - }; - csi40vin3: endpoint@3 { - reg = <3>; - remote-endpoint = <&vin3csi40>; - }; - }; - }; - }; - - hdmi0: hdmi@fead0000 { - compatible = "renesas,r8a774e1-hdmi", - "renesas,rcar-gen3-hdmi"; - reg = <0 0xfead0000 0 0x10000>; - interrupts = <GIC_SPI 389 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 729>, - <&cpg CPG_CORE R8A774E1_CLK_HDMI>; - clock-names = "iahb", "isfr"; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 729>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - dw_hdmi0_in: endpoint { - remote-endpoint = <&du_out_hdmi0>; - }; - }; - port@1 { - reg = <1>; - }; - port@2 { - /* HDMI sound */ - reg = <2>; - }; - }; - }; - - du: display@feb00000 { - compatible = "renesas,du-r8a774e1"; - reg = <0 0xfeb00000 0 0x80000>; - interrupts = <GIC_SPI 256 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 268 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 270 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 724>, - <&cpg CPG_MOD 723>, - <&cpg CPG_MOD 721>; - clock-names = "du.0", "du.1", "du.3"; - resets = <&cpg 724>, <&cpg 722>; - reset-names = "du.0", "du.3"; - status = "disabled"; - - renesas,vsps = <&vspd0 0>, <&vspd1 0>, <&vspd0 1>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - port@1 { - reg = <1>; - du_out_hdmi0: endpoint { - remote-endpoint = <&dw_hdmi0_in>; - }; - }; - port@2 { - reg = <2>; - du_out_lvds0: endpoint { - remote-endpoint = <&lvds0_in>; - }; - }; - }; - }; - - lvds0: lvds@feb90000 { - compatible = "renesas,r8a774e1-lvds"; - reg = <0 0xfeb90000 0 0x14>; - clocks = <&cpg CPG_MOD 727>; - power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; - resets = <&cpg 727>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - lvds0_in: endpoint { - remote-endpoint = <&du_out_lvds0>; - }; - }; - port@1 { - reg = <1>; - }; - }; - }; - - prr: chipid@fff00044 { - compatible = "renesas,prr"; - reg = <0 0xfff00044 0 4>; - }; - }; - - thermal-zones { - sensor1_thermal: sensor1-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - thermal-sensors = <&tsc 0>; - sustainable-power = <6313>; - - trips { - sensor1_crit: sensor1-crit { - temperature = <120000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - }; - - sensor2_thermal: sensor2-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - thermal-sensors = <&tsc 1>; - sustainable-power = <6313>; - - trips { - sensor2_crit: sensor2-crit { - temperature = <120000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - }; - - sensor3_thermal: sensor3-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - thermal-sensors = <&tsc 2>; - sustainable-power = <6313>; - - trips { - target: trip-point1 { - temperature = <100000>; - hysteresis = <1000>; - type = "passive"; - }; - - sensor3_crit: sensor3-crit { - temperature = <120000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - - cooling-maps { - map0 { - trip = <&target>; - cooling-device = <&a57_0 0 2>; - contribution = <1024>; - }; - - map1 { - trip = <&target>; - cooling-device = <&a53_0 0 2>; - contribution = <1024>; - }; - }; - }; - }; - - timer { - compatible = "arm,armv8-timer"; - interrupts-extended = <&gic GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_LOW)>; - }; - - /* External USB clocks - can be overridden by the board */ - usb3s0_clk: usb3s0 { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - usb_extal_clk: usb_extal { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; -}; diff --git a/arch/arm/dts/r8a7790-lager.dts b/arch/arm/dts/r8a7790-lager.dts deleted file mode 100644 index 5ad5349a50d..00000000000 --- a/arch/arm/dts/r8a7790-lager.dts +++ /dev/null @@ -1,947 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the Lager board - * - * Copyright (C) 2013-2014 Renesas Solutions Corp. - * Copyright (C) 2014 Cogent Embedded, Inc. - * Copyright (C) 2015-2016 Renesas Electronics Corporation - */ - -/* - * SSI-AK4643 - * - * SW1: 1: AK4643 - * 2: CN22 - * 3: ADV7511 - * - * This command is required when Playback/Capture - * - * amixer set "LINEOUT Mixer DACL" on - * amixer set "DVC Out" 100% - * amixer set "DVC In" 100% - * - * You can use Mute - * - * amixer set "DVC Out Mute" on - * amixer set "DVC In Mute" on - * - * You can use Volume Ramp - * - * amixer set "DVC Out Ramp Up Rate" "0.125 dB/64 steps" - * amixer set "DVC Out Ramp Down Rate" "0.125 dB/512 steps" - * amixer set "DVC Out Ramp" on - * aplay xxx.wav & - * amixer set "DVC Out" 80% // Volume Down - * amixer set "DVC Out" 100% // Volume Up - */ - -/dts-v1/; -#include "r8a7790.dtsi" -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/input/input.h> - -/ { - model = "Lager"; - compatible = "renesas,lager", "renesas,r8a7790"; - - aliases { - serial0 = &scif0; - serial1 = &scifa1; - i2c8 = &gpioi2c1; - i2c9 = &gpioi2c2; - i2c10 = &i2cexio0; - i2c11 = &i2cexio1; - i2c12 = &i2chdmi; - i2c13 = &i2cpwr; - mmc0 = &mmcif1; - mmc1 = &sdhi0; - mmc2 = &sdhi2; - }; - - chosen { - bootargs = "ignore_loglevel rw root=/dev/nfs ip=on"; - stdout-path = "serial0:115200n8"; - }; - - memory@40000000 { - device_type = "memory"; - reg = <0 0x40000000 0 0x40000000>; - }; - - memory@140000000 { - device_type = "memory"; - reg = <1 0x40000000 0 0xc0000000>; - }; - - lbsc { - #address-cells = <1>; - #size-cells = <1>; - }; - - keyboard { - compatible = "gpio-keys"; - - pinctrl-0 = <&keyboard_pins>; - pinctrl-names = "default"; - - one { - linux,code = <KEY_1>; - label = "SW2-1"; - wakeup-source; - debounce-interval = <20>; - gpios = <&gpio1 14 GPIO_ACTIVE_LOW>; - }; - two { - linux,code = <KEY_2>; - label = "SW2-2"; - wakeup-source; - debounce-interval = <20>; - gpios = <&gpio1 24 GPIO_ACTIVE_LOW>; - }; - three { - linux,code = <KEY_3>; - label = "SW2-3"; - wakeup-source; - debounce-interval = <20>; - gpios = <&gpio1 26 GPIO_ACTIVE_LOW>; - }; - four { - linux,code = <KEY_4>; - label = "SW2-4"; - wakeup-source; - debounce-interval = <20>; - gpios = <&gpio1 28 GPIO_ACTIVE_LOW>; - }; - }; - - leds { - compatible = "gpio-leds"; - led6 { - gpios = <&gpio4 22 GPIO_ACTIVE_HIGH>; - }; - led7 { - gpios = <&gpio4 23 GPIO_ACTIVE_HIGH>; - }; - led8 { - gpios = <&gpio5 17 GPIO_ACTIVE_HIGH>; - }; - }; - - fixedregulator3v3: regulator-3v3 { - compatible = "regulator-fixed"; - regulator-name = "fixed-3.3V"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - - vcc_sdhi0: regulator-vcc-sdhi0 { - compatible = "regulator-fixed"; - - regulator-name = "SDHI0 Vcc"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - gpio = <&gpio5 24 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; - - vccq_sdhi0: regulator-vccq-sdhi0 { - compatible = "regulator-gpio"; - - regulator-name = "SDHI0 VccQ"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - - gpios = <&gpio5 29 GPIO_ACTIVE_HIGH>; - gpios-states = <1>; - states = <3300000 1>, <1800000 0>; - }; - - vcc_sdhi2: regulator-vcc-sdhi2 { - compatible = "regulator-fixed"; - - regulator-name = "SDHI2 Vcc"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - gpio = <&gpio5 25 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; - - vccq_sdhi2: regulator-vccq-sdhi2 { - compatible = "regulator-gpio"; - - regulator-name = "SDHI2 VccQ"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - - gpios = <&gpio5 30 GPIO_ACTIVE_HIGH>; - gpios-states = <1>; - states = <3300000 1>, <1800000 0>; - }; - - audio_clock: audio_clock { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <11289600>; - }; - - rsnd_ak4643: sound { - compatible = "simple-audio-card"; - - simple-audio-card,format = "left_j"; - simple-audio-card,bitclock-master = <&sndcodec>; - simple-audio-card,frame-master = <&sndcodec>; - - sndcpu: simple-audio-card,cpu { - sound-dai = <&rcar_sound>; - }; - - sndcodec: simple-audio-card,codec { - sound-dai = <&ak4643>; - clocks = <&audio_clock>; - }; - }; - - vga-encoder { - compatible = "adi,adv7123"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - adv7123_in: endpoint { - remote-endpoint = <&du_out_rgb>; - }; - }; - port@1 { - reg = <1>; - adv7123_out: endpoint { - remote-endpoint = <&vga_in>; - }; - }; - }; - }; - - vga { - compatible = "vga-connector"; - - port { - vga_in: endpoint { - remote-endpoint = <&adv7123_out>; - }; - }; - }; - - hdmi-in { - compatible = "hdmi-connector"; - type = "a"; - - port { - hdmi_con_in: endpoint { - remote-endpoint = <&adv7612_in>; - }; - }; - }; - - cec_clock: cec-clock { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <12000000>; - }; - - hdmi-out { - compatible = "hdmi-connector"; - type = "a"; - - port { - hdmi_con_out: endpoint { - remote-endpoint = <&adv7511_out>; - }; - }; - }; - - x2_clk: x2-clock { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <148500000>; - }; - - x13_clk: x13-clock { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <148500000>; - }; - - gpioi2c1: i2c-8 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "i2c-gpio"; - status = "disabled"; - scl-gpios = <&gpio1 16 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; - sda-gpios = <&gpio1 17 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; - i2c-gpio,delay-us = <5>; - }; - - gpioi2c2: i2c-9 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "i2c-gpio"; - status = "disabled"; - scl-gpios = <&gpio5 5 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; - sda-gpios = <&gpio5 6 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; - i2c-gpio,delay-us = <5>; - }; - - /* - * IIC0/I2C0 is routed to EXIO connector A, pins 114 (SCL) + 116 (SDA) only. - * We use the I2C demuxer, so the desired IP core can be selected at runtime - * depending on the use case (e.g. DMA with IIC0 or slave support with I2C0). - * Note: For testing the I2C slave feature, it is convenient to connect this - * bus with IIC3 on pins 110 (SCL) + 112 (SDA), select I2C0 at runtime, and - * instantiate the slave device at runtime according to the documentation. - * You can then communicate with the slave via IIC3. - * - * IIC0/I2C0 does not appear to support fallback to GPIO. - */ - i2cexio0: i2c-10 { - compatible = "i2c-demux-pinctrl"; - i2c-parent = <&iic0>, <&i2c0>; - i2c-bus-name = "i2c-exio0"; - #address-cells = <1>; - #size-cells = <0>; - }; - - /* - * IIC1/I2C1 is routed to EXIO connector A, pins 78 (SCL) + 80 (SDA). - * This is similar to the arangement described for i2cexio0 (above) - * with a fallback to GPIO also provided. - */ - i2cexio1: i2c-11 { - compatible = "i2c-demux-pinctrl"; - i2c-parent = <&iic1>, <&i2c1>, <&gpioi2c1>; - i2c-bus-name = "i2c-exio1"; - #address-cells = <1>; - #size-cells = <0>; - }; - - /* - * IIC2 and I2C2 may be switched using pinmux. - * A fallback to GPIO is also provided. - */ - i2chdmi: i2c-12 { - compatible = "i2c-demux-pinctrl"; - i2c-parent = <&iic2>, <&i2c2>, <&gpioi2c2>; - i2c-bus-name = "i2c-hdmi"; - #address-cells = <1>; - #size-cells = <0>; - - ak4643: codec@12 { - compatible = "asahi-kasei,ak4643"; - #sound-dai-cells = <0>; - reg = <0x12>; - }; - - composite-in@20 { - compatible = "adi,adv7180"; - reg = <0x20>; - - port { - adv7180: endpoint { - bus-width = <8>; - remote-endpoint = <&vin1ep0>; - }; - }; - }; - - hdmi@39 { - compatible = "adi,adv7511w"; - reg = <0x39>; - interrupt-parent = <&gpio1>; - interrupts = <15 IRQ_TYPE_LEVEL_LOW>; - clocks = <&cec_clock>; - clock-names = "cec"; - - adi,input-depth = <8>; - adi,input-colorspace = "rgb"; - adi,input-clock = "1x"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - adv7511_in: endpoint { - remote-endpoint = <&lvds0_out>; - }; - }; - - port@1 { - reg = <1>; - adv7511_out: endpoint { - remote-endpoint = <&hdmi_con_out>; - }; - }; - }; - }; - - hdmi-in@4c { - compatible = "adi,adv7612"; - reg = <0x4c>; - interrupt-parent = <&gpio1>; - interrupts = <20 IRQ_TYPE_LEVEL_LOW>; - default-input = <0>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - adv7612_in: endpoint { - remote-endpoint = <&hdmi_con_in>; - }; - }; - - port@2 { - reg = <2>; - adv7612_out: endpoint { - remote-endpoint = <&vin0ep2>; - }; - }; - }; - }; - }; - - /* - * IIC3 and I2C3 may be switched using pinmux. - * IIC3/I2C3 does not appear to support fallback to GPIO. - */ - i2cpwr: i2c-13 { - compatible = "i2c-demux-pinctrl"; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_irq_pins>; - i2c-parent = <&iic3>, <&i2c3>; - i2c-bus-name = "i2c-pwr"; - #address-cells = <1>; - #size-cells = <0>; - - pmic@58 { - compatible = "dlg,da9063"; - reg = <0x58>; - interrupt-parent = <&irqc0>; - interrupts = <2 IRQ_TYPE_LEVEL_LOW>; - interrupt-controller; - - rtc { - compatible = "dlg,da9063-rtc"; - }; - - watchdog { - compatible = "dlg,da9063-watchdog"; - }; - }; - - vdd_dvfs: regulator@68 { - compatible = "dlg,da9210"; - reg = <0x68>; - interrupt-parent = <&irqc0>; - interrupts = <2 IRQ_TYPE_LEVEL_LOW>; - - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-boot-on; - regulator-always-on; - }; - }; -}; - -&du { - pinctrl-0 = <&du_pins>; - pinctrl-names = "default"; - status = "okay"; - - clocks = <&cpg CPG_MOD 724>, <&cpg CPG_MOD 723>, <&cpg CPG_MOD 722>, - <&x13_clk>, <&x2_clk>; - clock-names = "du.0", "du.1", "du.2", "dclkin.0", "dclkin.1"; - - ports { - port@0 { - endpoint { - remote-endpoint = <&adv7123_in>; - }; - }; - }; -}; - -&lvds0 { - status = "okay"; - - ports { - port@1 { - endpoint { - remote-endpoint = <&adv7511_in>; - }; - }; - }; -}; - -&lvds1 { - ports { - port@1 { - lvds_connector: endpoint { - }; - }; - }; -}; - -&extal_clk { - clock-frequency = <20000000>; -}; - -&pfc { - pinctrl-0 = <&scif_clk_pins>; - pinctrl-names = "default"; - - du_pins: du { - groups = "du_rgb666", "du_sync_1", "du_clk_out_0"; - function = "du"; - }; - - scif0_pins: scif0 { - groups = "scif0_data"; - function = "scif0"; - }; - - scif_clk_pins: scif_clk { - groups = "scif_clk"; - function = "scif_clk"; - }; - - ether_pins: ether { - groups = "eth_link", "eth_mdio", "eth_rmii"; - function = "eth"; - }; - - phy1_pins: phy1 { - groups = "intc_irq0"; - function = "intc"; - }; - - scifa1_pins: scifa1 { - groups = "scifa1_data"; - function = "scifa1"; - }; - - sdhi0_pins: sd0 { - groups = "sdhi0_data4", "sdhi0_ctrl"; - function = "sdhi0"; - power-source = <3300>; - }; - - sdhi0_pins_uhs: sd0_uhs { - groups = "sdhi0_data4", "sdhi0_ctrl"; - function = "sdhi0"; - power-source = <1800>; - }; - - sdhi2_pins: sd2 { - groups = "sdhi2_data4", "sdhi2_ctrl"; - function = "sdhi2"; - power-source = <3300>; - }; - - sdhi2_pins_uhs: sd2_uhs { - groups = "sdhi2_data4", "sdhi2_ctrl"; - function = "sdhi2"; - power-source = <1800>; - }; - - mmc1_pins: mmc1 { - groups = "mmc1_data8", "mmc1_ctrl"; - function = "mmc1"; - }; - - qspi_pins: qspi { - groups = "qspi_ctrl", "qspi_data4"; - function = "qspi"; - }; - - msiof1_pins: msiof1 { - groups = "msiof1_clk", "msiof1_sync", "msiof1_rx", - "msiof1_tx"; - function = "msiof1"; - }; - - i2c0_pins: i2c0 { - groups = "i2c0"; - function = "i2c0"; - }; - - iic0_pins: iic0 { - groups = "iic0"; - function = "iic0"; - }; - - i2c1_pins: i2c1 { - groups = "i2c1"; - function = "i2c1"; - }; - - iic1_pins: iic1 { - groups = "iic1"; - function = "iic1"; - }; - - i2c2_pins: i2c2 { - groups = "i2c2"; - function = "i2c2"; - }; - - iic2_pins: iic2 { - groups = "iic2"; - function = "iic2"; - }; - - i2c3_pins: i2c3 { - groups = "i2c3"; - function = "i2c3"; - }; - - iic3_pins: iic3 { - groups = "iic3"; - function = "iic3"; - }; - - pmic_irq_pins: pmicirq { - groups = "intc_irq2"; - function = "intc"; - }; - - hsusb_pins: hsusb { - groups = "usb0_ovc_vbus"; - function = "usb0"; - }; - - usb0_pins: usb0 { - groups = "usb0"; - function = "usb0"; - }; - - usb1_pins: usb1 { - groups = "usb1"; - function = "usb1"; - }; - - usb2_pins: usb2 { - groups = "usb2"; - function = "usb2"; - }; - - vin0_pins: vin0 { - groups = "vin0_data24", "vin0_sync", "vin0_clkenb", "vin0_clk"; - function = "vin0"; - }; - - vin1_pins: vin1 { - groups = "vin1_data8", "vin1_clk"; - function = "vin1"; - }; - - sound_pins: sound { - groups = "ssi0129_ctrl", "ssi0_data", "ssi1_data"; - function = "ssi"; - }; - - sound_clk_pins: sound_clk { - groups = "audio_clk_a"; - function = "audio_clk"; - }; - - keyboard_pins: keyboard { - pins = "GP_1_14", "GP_1_24", "GP_1_26", "GP_1_28"; - bias-pull-up; - }; -}; - -ðer { - pinctrl-0 = <ðer_pins>, <&phy1_pins>; - pinctrl-names = "default"; - - phy-handle = <&phy1>; - renesas,ether-link-active-low; - status = "okay"; - - phy1: ethernet-phy@1 { - compatible = "ethernet-phy-id0022.1537", - "ethernet-phy-ieee802.3-c22"; - reg = <1>; - interrupt-parent = <&irqc0>; - interrupts = <0 IRQ_TYPE_LEVEL_LOW>; - micrel,led-mode = <1>; - reset-gpios = <&gpio5 31 GPIO_ACTIVE_LOW>; - }; -}; - -&cmt0 { - status = "okay"; -}; - -&mmcif1 { - pinctrl-0 = <&mmc1_pins>; - pinctrl-names = "default"; - - vmmc-supply = <&fixedregulator3v3>; - bus-width = <8>; - non-removable; - status = "okay"; -}; - -&sata1 { - status = "okay"; -}; - -&qspi { - pinctrl-0 = <&qspi_pins>; - pinctrl-names = "default"; - - status = "okay"; - - flash: flash@0 { - compatible = "spansion,s25fl512s", "jedec,spi-nor"; - reg = <0>; - spi-max-frequency = <30000000>; - spi-tx-bus-width = <4>; - spi-rx-bus-width = <4>; - spi-cpha; - spi-cpol; - m25p,fast-read; - - partitions { - compatible = "fixed-partitions"; - #address-cells = <1>; - #size-cells = <1>; - - partition@0 { - label = "loader"; - reg = <0x00000000 0x00040000>; - read-only; - }; - partition@40000 { - label = "user"; - reg = <0x00040000 0x00400000>; - read-only; - }; - partition@440000 { - label = "flash"; - reg = <0x00440000 0x03bc0000>; - }; - }; - }; -}; - -&scif0 { - pinctrl-0 = <&scif0_pins>; - pinctrl-names = "default"; - - status = "okay"; -}; - -&scifa1 { - pinctrl-0 = <&scifa1_pins>; - pinctrl-names = "default"; - - status = "okay"; -}; - -&scif_clk { - clock-frequency = <14745600>; -}; - -&msiof1 { - pinctrl-0 = <&msiof1_pins>; - pinctrl-names = "default"; - - status = "okay"; - - pmic: pmic@0 { - compatible = "renesas,r2a11302ft"; - reg = <0>; - spi-max-frequency = <6000000>; - spi-cpol; - spi-cpha; - }; -}; - -&sdhi0 { - pinctrl-0 = <&sdhi0_pins>; - pinctrl-1 = <&sdhi0_pins_uhs>; - pinctrl-names = "default", "state_uhs"; - - vmmc-supply = <&vcc_sdhi0>; - vqmmc-supply = <&vccq_sdhi0>; - cd-gpios = <&gpio3 6 GPIO_ACTIVE_LOW>; - sd-uhs-sdr50; - sd-uhs-sdr104; - status = "okay"; -}; - -&sdhi2 { - pinctrl-0 = <&sdhi2_pins>; - pinctrl-1 = <&sdhi2_pins_uhs>; - pinctrl-names = "default", "state_uhs"; - - vmmc-supply = <&vcc_sdhi2>; - vqmmc-supply = <&vccq_sdhi2>; - cd-gpios = <&gpio3 22 GPIO_ACTIVE_LOW>; - sd-uhs-sdr50; - status = "okay"; -}; - -&cpu0 { - cpu0-supply = <&vdd_dvfs>; -}; - -&i2c0 { - pinctrl-0 = <&i2c0_pins>; - pinctrl-names = "i2c-exio0"; -}; - -&iic0 { - pinctrl-0 = <&iic0_pins>; - pinctrl-names = "i2c-exio0"; -}; - -&i2c1 { - pinctrl-0 = <&i2c1_pins>; - pinctrl-names = "i2c-exio1"; -}; - -&iic1 { - pinctrl-0 = <&iic1_pins>; - pinctrl-names = "i2c-exio1"; -}; - -&i2c2 { - pinctrl-0 = <&i2c2_pins>; - pinctrl-names = "i2c-hdmi"; - - clock-frequency = <100000>; -}; - -&iic2 { - pinctrl-0 = <&iic2_pins>; - pinctrl-names = "i2c-hdmi"; - - clock-frequency = <100000>; -}; - -&i2c3 { - pinctrl-0 = <&i2c3_pins>; - pinctrl-names = "i2c-pwr"; -}; - -&iic3 { - pinctrl-0 = <&iic3_pins>; - pinctrl-names = "i2c-pwr"; -}; - -&pci0 { - status = "okay"; - pinctrl-0 = <&usb0_pins>; - pinctrl-names = "default"; -}; - -&pci1 { - status = "okay"; - pinctrl-0 = <&usb1_pins>; - pinctrl-names = "default"; -}; - -&xhci { - status = "okay"; - pinctrl-0 = <&usb2_pins>; - pinctrl-names = "default"; -}; - -&pci2 { - status = "okay"; - pinctrl-0 = <&usb2_pins>; - pinctrl-names = "default"; -}; - -&hsusb { - status = "okay"; - pinctrl-0 = <&hsusb_pins>; - pinctrl-names = "default"; - renesas,enable-gpio = <&gpio5 18 GPIO_ACTIVE_HIGH>; -}; - -&usbphy { - status = "okay"; -}; - -/* HDMI video input */ -&vin0 { - pinctrl-0 = <&vin0_pins>; - pinctrl-names = "default"; - - status = "okay"; - - port { - vin0ep2: endpoint { - remote-endpoint = <&adv7612_out>; - bus-width = <24>; - hsync-active = <0>; - vsync-active = <0>; - pclk-sample = <1>; - data-active = <1>; - }; - }; -}; - -/* composite video input */ -&vin1 { - pinctrl-0 = <&vin1_pins>; - pinctrl-names = "default"; - - status = "okay"; - - port { - vin1ep0: endpoint { - remote-endpoint = <&adv7180>; - bus-width = <8>; - }; - }; -}; - -&rcar_sound { - pinctrl-0 = <&sound_pins>, <&sound_clk_pins>; - pinctrl-names = "default"; - - /* Single DAI */ - #sound-dai-cells = <0>; - - status = "okay"; - - rcar_sound,dai { - dai0 { - playback = <&ssi0>, <&src2>, <&dvc0>; - capture = <&ssi1>, <&src3>, <&dvc1>; - }; - }; -}; - -&rwdt { - timeout-sec = <60>; - status = "okay"; -}; - -&ssi1 { - shared-pin; -}; diff --git a/arch/arm/dts/r8a7790-stout.dts b/arch/arm/dts/r8a7790-stout.dts deleted file mode 100644 index fe14727eefe..00000000000 --- a/arch/arm/dts/r8a7790-stout.dts +++ /dev/null @@ -1,382 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the Stout board - * - * Copyright (C) 2018 Marek Vasut marek.vasut@gmail.com - */ - -/dts-v1/; -#include "r8a7790.dtsi" -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/input/input.h> - -/ { - model = "Stout"; - compatible = "renesas,stout", "renesas,r8a7790"; - - aliases { - serial0 = &scifa0; - }; - - chosen { - bootargs = "ignore_loglevel rw root=/dev/nfs ip=on"; - stdout-path = "serial0:115200n8"; - }; - - memory@40000000 { - device_type = "memory"; - reg = <0 0x40000000 0 0x40000000>; - }; - - leds { - compatible = "gpio-leds"; - led1 { - gpios = <&gpio4 22 GPIO_ACTIVE_LOW>; - }; - led2 { - gpios = <&gpio4 23 GPIO_ACTIVE_LOW>; - }; - led3 { - gpios = <&gpio5 17 GPIO_ACTIVE_LOW>; - }; - led5 { - gpios = <&gpio4 24 GPIO_ACTIVE_LOW>; - }; - }; - - fixedregulator3v3: regulator-3v3 { - compatible = "regulator-fixed"; - regulator-name = "fixed-3.3V"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - - vcc_sdhi0: regulator-vcc-sdhi0 { - compatible = "regulator-fixed"; - - regulator-name = "SDHI0 Vcc"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - gpio = <&gpio5 24 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; - - hdmi-out { - compatible = "hdmi-connector"; - type = "a"; - - port { - hdmi_con_out: endpoint { - remote-endpoint = <&adv7511_out>; - }; - }; - }; - - osc1_clk: osc1-clock { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <148500000>; - }; - - osc4_clk: osc4-clock { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <12000000>; - }; -}; - -&du { - pinctrl-0 = <&du_pins>; - pinctrl-names = "default"; - status = "okay"; - - clocks = <&cpg CPG_MOD 724>, <&cpg CPG_MOD 723>, <&cpg CPG_MOD 722>, - <&osc1_clk>; - clock-names = "du.0", "du.1", "du.2", "dclkin.0"; - - ports { - port@0 { - endpoint { - remote-endpoint = <&adv7511_in>; - }; - }; - }; -}; - -&lvds0 { - ports { - port@1 { - lvds_connector0: endpoint { - }; - }; - }; -}; - -&lvds1 { - ports { - port@1 { - lvds_connector1: endpoint { - }; - }; - }; -}; - -&extal_clk { - clock-frequency = <20000000>; -}; - -&pfc { - - pinctrl-0 = <&scif_clk_pins>; - pinctrl-names = "default"; - - du_pins: du { - groups = "du_rgb888", "du_sync_1", "du_clk_out_0"; - function = "du"; - }; - - scifa0_pins: scifa0 { - groups = "scifa0_data_b"; - function = "scifa0"; - }; - - scif_clk_pins: scif_clk { - groups = "scif_clk"; - function = "scif_clk"; - }; - - ether_pins: ether { - groups = "eth_link", "eth_mdio", "eth_rmii"; - function = "eth"; - }; - - phy1_pins: phy1 { - groups = "intc_irq1"; - function = "intc"; - }; - - sdhi0_pins: sd0 { - groups = "sdhi0_data4", "sdhi0_ctrl"; - function = "sdhi0"; - power-source = <3300>; - }; - - qspi_pins: qspi { - groups = "qspi_ctrl", "qspi_data4"; - function = "qspi"; - }; - - iic2_pins: iic2 { - groups = "iic2_b"; - function = "iic2"; - }; - - iic3_pins: iic3 { - groups = "iic3"; - function = "iic3"; - }; - - pmic_irq_pins: pmicirq { - groups = "intc_irq2"; - function = "intc"; - }; - - usb0_pins: usb0 { - groups = "usb0"; - function = "usb0"; - }; -}; - -ðer { - pinctrl-0 = <ðer_pins>, <&phy1_pins>; - pinctrl-names = "default"; - - phy-handle = <&phy1>; - renesas,ether-link-active-low; - status = "okay"; - - phy1: ethernet-phy@1 { - compatible = "ethernet-phy-id0022.1537", - "ethernet-phy-ieee802.3-c22"; - reg = <1>; - interrupt-parent = <&irqc0>; - interrupts = <1 IRQ_TYPE_LEVEL_LOW>; - micrel,led-mode = <1>; - reset-gpios = <&gpio3 31 GPIO_ACTIVE_LOW>; - }; -}; - -&cmt0 { - status = "okay"; -}; - -&qspi { - pinctrl-0 = <&qspi_pins>; - pinctrl-names = "default"; - - status = "okay"; - - flash: flash@0 { - compatible = "spansion,s25fl512s", "jedec,spi-nor"; - reg = <0>; - spi-max-frequency = <30000000>; - spi-tx-bus-width = <4>; - spi-rx-bus-width = <4>; - spi-cpha; - spi-cpol; - m25p,fast-read; - - partitions { - compatible = "fixed-partitions"; - #address-cells = <1>; - #size-cells = <1>; - - partition@0 { - label = "loader"; - reg = <0x00000000 0x00080000>; - read-only; - }; - partition@80000 { - label = "uboot"; - reg = <0x00080000 0x00040000>; - read-only; - }; - partition@c0000 { - label = "uboot-env"; - reg = <0x000c0000 0x00040000>; - read-only; - }; - partition@100000 { - label = "flash"; - reg = <0x00100000 0x03f00000>; - }; - }; - }; -}; - -&scifa0 { - pinctrl-0 = <&scifa0_pins>; - pinctrl-names = "default"; - - status = "okay"; -}; - -&scif_clk { - clock-frequency = <14745600>; -}; - -&sdhi0 { - pinctrl-0 = <&sdhi0_pins>; - pinctrl-names = "default"; - - vmmc-supply = <&vcc_sdhi0>; - cd-gpios = <&gpio3 6 GPIO_ACTIVE_LOW>; - status = "okay"; -}; - -&cpu0 { - cpu0-supply = <&vdd_dvfs>; -}; - -&iic2 { - status = "okay"; - pinctrl-0 = <&iic2_pins>; - pinctrl-names = "default"; - - clock-frequency = <100000>; - - hdmi@39 { - compatible = "adi,adv7511w"; - reg = <0x39>; - interrupt-parent = <&gpio1>; - interrupts = <15 IRQ_TYPE_LEVEL_LOW>; - clocks = <&osc4_clk>; - clock-names = "cec"; - - adi,input-depth = <8>; - adi,input-colorspace = "rgb"; - adi,input-clock = "1x"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - adv7511_in: endpoint { - remote-endpoint = <&du_out_rgb>; - }; - }; - - port@1 { - reg = <1>; - adv7511_out: endpoint { - remote-endpoint = <&hdmi_con_out>; - }; - }; - }; - }; -}; - -&iic3 { - pinctrl-names = "default"; - pinctrl-0 = <&iic3_pins>, <&pmic_irq_pins>; - status = "okay"; - - pmic@58 { - compatible = "dlg,da9063"; - reg = <0x58>; - interrupt-parent = <&irqc0>; - interrupts = <2 IRQ_TYPE_LEVEL_LOW>; - interrupt-controller; - - onkey { - compatible = "dlg,da9063-onkey"; - }; - - rtc { - compatible = "dlg,da9063-rtc"; - }; - - watchdog { - compatible = "dlg,da9063-watchdog"; - }; - }; - - vdd_dvfs: regulator@68 { - compatible = "dlg,da9210"; - reg = <0x68>; - interrupt-parent = <&irqc0>; - interrupts = <2 IRQ_TYPE_LEVEL_LOW>; - - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-boot-on; - regulator-always-on; - }; - - vdd: regulator@70 { - compatible = "dlg,da9210"; - reg = <0x70>; - interrupt-parent = <&irqc0>; - interrupts = <2 IRQ_TYPE_LEVEL_LOW>; - - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-boot-on; - regulator-always-on; - }; -}; - -&pci0 { - status = "okay"; - pinctrl-0 = <&usb0_pins>; - pinctrl-names = "default"; -}; - -&usbphy { - status = "okay"; -}; diff --git a/arch/arm/dts/r8a7790.dtsi b/arch/arm/dts/r8a7790.dtsi deleted file mode 100644 index 46fb81f5062..00000000000 --- a/arch/arm/dts/r8a7790.dtsi +++ /dev/null @@ -1,1965 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the R-Car H2 (R8A77900) SoC - * - * Copyright (C) 2015 Renesas Electronics Corporation - * Copyright (C) 2013-2014 Renesas Solutions Corp. - * Copyright (C) 2014 Cogent Embedded Inc. - */ - -#include <dt-bindings/clock/r8a7790-cpg-mssr.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/power/r8a7790-sysc.h> - -/ { - compatible = "renesas,r8a7790"; - #address-cells = <2>; - #size-cells = <2>; - - aliases { - i2c0 = &i2c0; - i2c1 = &i2c1; - i2c2 = &i2c2; - i2c3 = &i2c3; - i2c4 = &iic0; - i2c5 = &iic1; - i2c6 = &iic2; - i2c7 = &iic3; - spi0 = &qspi; - spi1 = &msiof0; - spi2 = &msiof1; - spi3 = &msiof2; - spi4 = &msiof3; - vin0 = &vin0; - vin1 = &vin1; - vin2 = &vin2; - vin3 = &vin3; - }; - - /* - * The external audio clocks are configured as 0 Hz fixed frequency - * clocks by default. - * Boards that provide audio clocks should override them. - */ - audio_clk_a: audio_clk_a { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - audio_clk_b: audio_clk_b { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - audio_clk_c: audio_clk_c { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - /* External CAN clock */ - can_clk: can { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board. */ - clock-frequency = <0>; - }; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - - cpu0: cpu@0 { - device_type = "cpu"; - compatible = "arm,cortex-a15"; - reg = <0>; - clock-frequency = <1300000000>; - clocks = <&cpg CPG_CORE R8A7790_CLK_Z>; - power-domains = <&sysc R8A7790_PD_CA15_CPU0>; - enable-method = "renesas,apmu"; - next-level-cache = <&L2_CA15>; - capacity-dmips-mhz = <1024>; - voltage-tolerance = <1>; /* 1% */ - clock-latency = <300000>; /* 300 us */ - - /* kHz - uV - OPPs unknown yet */ - operating-points = <1400000 1000000>, - <1225000 1000000>, - <1050000 1000000>, - < 875000 1000000>, - < 700000 1000000>, - < 350000 1000000>; - }; - - cpu1: cpu@1 { - device_type = "cpu"; - compatible = "arm,cortex-a15"; - reg = <1>; - clock-frequency = <1300000000>; - clocks = <&cpg CPG_CORE R8A7790_CLK_Z>; - power-domains = <&sysc R8A7790_PD_CA15_CPU1>; - enable-method = "renesas,apmu"; - next-level-cache = <&L2_CA15>; - capacity-dmips-mhz = <1024>; - voltage-tolerance = <1>; /* 1% */ - clock-latency = <300000>; /* 300 us */ - - /* kHz - uV - OPPs unknown yet */ - operating-points = <1400000 1000000>, - <1225000 1000000>, - <1050000 1000000>, - < 875000 1000000>, - < 700000 1000000>, - < 350000 1000000>; - }; - - cpu2: cpu@2 { - device_type = "cpu"; - compatible = "arm,cortex-a15"; - reg = <2>; - clock-frequency = <1300000000>; - clocks = <&cpg CPG_CORE R8A7790_CLK_Z>; - power-domains = <&sysc R8A7790_PD_CA15_CPU2>; - enable-method = "renesas,apmu"; - next-level-cache = <&L2_CA15>; - capacity-dmips-mhz = <1024>; - voltage-tolerance = <1>; /* 1% */ - clock-latency = <300000>; /* 300 us */ - - /* kHz - uV - OPPs unknown yet */ - operating-points = <1400000 1000000>, - <1225000 1000000>, - <1050000 1000000>, - < 875000 1000000>, - < 700000 1000000>, - < 350000 1000000>; - }; - - cpu3: cpu@3 { - device_type = "cpu"; - compatible = "arm,cortex-a15"; - reg = <3>; - clock-frequency = <1300000000>; - clocks = <&cpg CPG_CORE R8A7790_CLK_Z>; - power-domains = <&sysc R8A7790_PD_CA15_CPU3>; - enable-method = "renesas,apmu"; - next-level-cache = <&L2_CA15>; - capacity-dmips-mhz = <1024>; - voltage-tolerance = <1>; /* 1% */ - clock-latency = <300000>; /* 300 us */ - - /* kHz - uV - OPPs unknown yet */ - operating-points = <1400000 1000000>, - <1225000 1000000>, - <1050000 1000000>, - < 875000 1000000>, - < 700000 1000000>, - < 350000 1000000>; - }; - - cpu4: cpu@100 { - device_type = "cpu"; - compatible = "arm,cortex-a7"; - reg = <0x100>; - clock-frequency = <780000000>; - clocks = <&cpg CPG_CORE R8A7790_CLK_Z2>; - power-domains = <&sysc R8A7790_PD_CA7_CPU0>; - enable-method = "renesas,apmu"; - next-level-cache = <&L2_CA7>; - capacity-dmips-mhz = <539>; - }; - - cpu5: cpu@101 { - device_type = "cpu"; - compatible = "arm,cortex-a7"; - reg = <0x101>; - clock-frequency = <780000000>; - clocks = <&cpg CPG_CORE R8A7790_CLK_Z2>; - power-domains = <&sysc R8A7790_PD_CA7_CPU1>; - enable-method = "renesas,apmu"; - next-level-cache = <&L2_CA7>; - capacity-dmips-mhz = <539>; - }; - - cpu6: cpu@102 { - device_type = "cpu"; - compatible = "arm,cortex-a7"; - reg = <0x102>; - clock-frequency = <780000000>; - clocks = <&cpg CPG_CORE R8A7790_CLK_Z2>; - power-domains = <&sysc R8A7790_PD_CA7_CPU2>; - enable-method = "renesas,apmu"; - next-level-cache = <&L2_CA7>; - capacity-dmips-mhz = <539>; - }; - - cpu7: cpu@103 { - device_type = "cpu"; - compatible = "arm,cortex-a7"; - reg = <0x103>; - clock-frequency = <780000000>; - clocks = <&cpg CPG_CORE R8A7790_CLK_Z2>; - power-domains = <&sysc R8A7790_PD_CA7_CPU3>; - enable-method = "renesas,apmu"; - next-level-cache = <&L2_CA7>; - capacity-dmips-mhz = <539>; - }; - - L2_CA15: cache-controller-0 { - compatible = "cache"; - power-domains = <&sysc R8A7790_PD_CA15_SCU>; - cache-unified; - cache-level = <2>; - }; - - L2_CA7: cache-controller-1 { - compatible = "cache"; - power-domains = <&sysc R8A7790_PD_CA7_SCU>; - cache-unified; - cache-level = <2>; - }; - }; - - /* External root clock */ - extal_clk: extal { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board. */ - clock-frequency = <0>; - }; - - /* External PCIe clock - can be overridden by the board */ - pcie_bus_clk: pcie_bus { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - pmu-0 { - compatible = "arm,cortex-a15-pmu"; - interrupts-extended = <&gic GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 75 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&cpu0>, <&cpu1>, <&cpu2>, <&cpu3>; - }; - - pmu-1 { - compatible = "arm,cortex-a7-pmu"; - interrupts-extended = <&gic GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&cpu4>, <&cpu5>, <&cpu6>, <&cpu7>; - }; - - /* External SCIF clock */ - scif_clk: scif { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board. */ - clock-frequency = <0>; - }; - - soc { - compatible = "simple-bus"; - interrupt-parent = <&gic>; - - #address-cells = <2>; - #size-cells = <2>; - ranges; - - rwdt: watchdog@e6020000 { - compatible = "renesas,r8a7790-wdt", - "renesas,rcar-gen2-wdt"; - reg = <0 0xe6020000 0 0x0c>; - interrupts = <GIC_SPI 140 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 402>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 402>; - status = "disabled"; - }; - - gpio0: gpio@e6050000 { - compatible = "renesas,gpio-r8a7790", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6050000 0 0x50>; - interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 0 32>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 912>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 912>; - }; - - gpio1: gpio@e6051000 { - compatible = "renesas,gpio-r8a7790", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6051000 0 0x50>; - interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 32 30>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 911>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 911>; - }; - - gpio2: gpio@e6052000 { - compatible = "renesas,gpio-r8a7790", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6052000 0 0x50>; - interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 64 30>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 910>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 910>; - }; - - gpio3: gpio@e6053000 { - compatible = "renesas,gpio-r8a7790", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6053000 0 0x50>; - interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 96 32>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 909>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 909>; - }; - - gpio4: gpio@e6054000 { - compatible = "renesas,gpio-r8a7790", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6054000 0 0x50>; - interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 128 32>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 908>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 908>; - }; - - gpio5: gpio@e6055000 { - compatible = "renesas,gpio-r8a7790", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6055000 0 0x50>; - interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 160 32>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 907>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 907>; - }; - - pfc: pinctrl@e6060000 { - compatible = "renesas,pfc-r8a7790"; - reg = <0 0xe6060000 0 0x250>; - }; - - tpu: pwm@e60f0000 { - compatible = "renesas,tpu-r8a7790", "renesas,tpu"; - reg = <0 0xe60f0000 0 0x148>; - interrupts = <GIC_SPI 135 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 304>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 304>; - #pwm-cells = <3>; - status = "disabled"; - }; - - cpg: clock-controller@e6150000 { - compatible = "renesas,r8a7790-cpg-mssr"; - reg = <0 0xe6150000 0 0x1000>; - clocks = <&extal_clk>, <&usb_extal_clk>; - clock-names = "extal", "usb_extal"; - #clock-cells = <2>; - #power-domain-cells = <0>; - #reset-cells = <1>; - }; - - apmu@e6151000 { - compatible = "renesas,r8a7790-apmu", "renesas,apmu"; - reg = <0 0xe6151000 0 0x188>; - cpus = <&cpu4>, <&cpu5>, <&cpu6>, <&cpu7>; - }; - - apmu@e6152000 { - compatible = "renesas,r8a7790-apmu", "renesas,apmu"; - reg = <0 0xe6152000 0 0x188>; - cpus = <&cpu0>, <&cpu1>, <&cpu2>, <&cpu3>; - }; - - rst: reset-controller@e6160000 { - compatible = "renesas,r8a7790-rst"; - reg = <0 0xe6160000 0 0x0100>; - }; - - sysc: system-controller@e6180000 { - compatible = "renesas,r8a7790-sysc"; - reg = <0 0xe6180000 0 0x0200>; - #power-domain-cells = <1>; - }; - - irqc0: interrupt-controller@e61c0000 { - compatible = "renesas,irqc-r8a7790", "renesas,irqc"; - #interrupt-cells = <2>; - interrupt-controller; - reg = <0 0xe61c0000 0 0x200>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 407>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 407>; - }; - - thermal: thermal@e61f0000 { - compatible = "renesas,thermal-r8a7790", - "renesas,rcar-gen2-thermal", - "renesas,rcar-thermal"; - reg = <0 0xe61f0000 0 0x10>, <0 0xe61f0100 0 0x38>; - interrupts = <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 522>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 522>; - #thermal-sensor-cells = <0>; - }; - - ipmmu_sy0: iommu@e6280000 { - compatible = "renesas,ipmmu-r8a7790", - "renesas,ipmmu-vmsa"; - reg = <0 0xe6280000 0 0x1000>; - interrupts = <GIC_SPI 223 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 224 IRQ_TYPE_LEVEL_HIGH>; - #iommu-cells = <1>; - status = "disabled"; - }; - - ipmmu_sy1: iommu@e6290000 { - compatible = "renesas,ipmmu-r8a7790", - "renesas,ipmmu-vmsa"; - reg = <0 0xe6290000 0 0x1000>; - interrupts = <GIC_SPI 225 IRQ_TYPE_LEVEL_HIGH>; - #iommu-cells = <1>; - status = "disabled"; - }; - - ipmmu_ds: iommu@e6740000 { - compatible = "renesas,ipmmu-r8a7790", - "renesas,ipmmu-vmsa"; - reg = <0 0xe6740000 0 0x1000>; - interrupts = <GIC_SPI 198 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 199 IRQ_TYPE_LEVEL_HIGH>; - #iommu-cells = <1>; - status = "disabled"; - }; - - ipmmu_mp: iommu@ec680000 { - compatible = "renesas,ipmmu-r8a7790", - "renesas,ipmmu-vmsa"; - reg = <0 0xec680000 0 0x1000>; - interrupts = <GIC_SPI 226 IRQ_TYPE_LEVEL_HIGH>; - #iommu-cells = <1>; - status = "disabled"; - }; - - ipmmu_mx: iommu@fe951000 { - compatible = "renesas,ipmmu-r8a7790", - "renesas,ipmmu-vmsa"; - reg = <0 0xfe951000 0 0x1000>; - interrupts = <GIC_SPI 222 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 221 IRQ_TYPE_LEVEL_HIGH>; - #iommu-cells = <1>; - status = "disabled"; - }; - - ipmmu_rt: iommu@ffc80000 { - compatible = "renesas,ipmmu-r8a7790", - "renesas,ipmmu-vmsa"; - reg = <0 0xffc80000 0 0x1000>; - interrupts = <GIC_SPI 307 IRQ_TYPE_LEVEL_HIGH>; - #iommu-cells = <1>; - status = "disabled"; - }; - - icram0: sram@e63a0000 { - compatible = "mmio-sram"; - reg = <0 0xe63a0000 0 0x12000>; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0 0xe63a0000 0x12000>; - }; - - icram1: sram@e63c0000 { - compatible = "mmio-sram"; - reg = <0 0xe63c0000 0 0x1000>; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0 0xe63c0000 0x1000>; - - smp-sram@0 { - compatible = "renesas,smp-sram"; - reg = <0 0x100>; - }; - }; - - i2c0: i2c@e6508000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a7790", - "renesas,rcar-gen2-i2c"; - reg = <0 0xe6508000 0 0x40>; - interrupts = <GIC_SPI 287 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 931>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 931>; - i2c-scl-internal-delay-ns = <110>; - status = "disabled"; - }; - - i2c1: i2c@e6518000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a7790", - "renesas,rcar-gen2-i2c"; - reg = <0 0xe6518000 0 0x40>; - interrupts = <GIC_SPI 288 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 930>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 930>; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c2: i2c@e6530000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a7790", - "renesas,rcar-gen2-i2c"; - reg = <0 0xe6530000 0 0x40>; - interrupts = <GIC_SPI 286 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 929>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 929>; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c3: i2c@e6540000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a7790", - "renesas,rcar-gen2-i2c"; - reg = <0 0xe6540000 0 0x40>; - interrupts = <GIC_SPI 290 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 928>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 928>; - i2c-scl-internal-delay-ns = <110>; - status = "disabled"; - }; - - iic0: i2c@e6500000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,iic-r8a7790", - "renesas,rcar-gen2-iic", - "renesas,rmobile-iic"; - reg = <0 0xe6500000 0 0x425>; - interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 318>; - dmas = <&dmac0 0x61>, <&dmac0 0x62>, - <&dmac1 0x61>, <&dmac1 0x62>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 318>; - status = "disabled"; - }; - - iic1: i2c@e6510000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,iic-r8a7790", - "renesas,rcar-gen2-iic", - "renesas,rmobile-iic"; - reg = <0 0xe6510000 0 0x425>; - interrupts = <GIC_SPI 175 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 323>; - dmas = <&dmac0 0x65>, <&dmac0 0x66>, - <&dmac1 0x65>, <&dmac1 0x66>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 323>; - status = "disabled"; - }; - - iic2: i2c@e6520000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,iic-r8a7790", - "renesas,rcar-gen2-iic", - "renesas,rmobile-iic"; - reg = <0 0xe6520000 0 0x425>; - interrupts = <GIC_SPI 176 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 300>; - dmas = <&dmac0 0x69>, <&dmac0 0x6a>, - <&dmac1 0x69>, <&dmac1 0x6a>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 300>; - status = "disabled"; - }; - - iic3: i2c@e60b0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,iic-r8a7790", - "renesas,rcar-gen2-iic", - "renesas,rmobile-iic"; - reg = <0 0xe60b0000 0 0x425>; - interrupts = <GIC_SPI 173 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 926>; - dmas = <&dmac0 0x77>, <&dmac0 0x78>, - <&dmac1 0x77>, <&dmac1 0x78>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 926>; - status = "disabled"; - }; - - hsusb: usb@e6590000 { - compatible = "renesas,usbhs-r8a7790", - "renesas,rcar-gen2-usbhs"; - reg = <0 0xe6590000 0 0x100>; - interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 704>; - dmas = <&usb_dmac0 0>, <&usb_dmac0 1>, - <&usb_dmac1 0>, <&usb_dmac1 1>; - dma-names = "ch0", "ch1", "ch2", "ch3"; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 704>; - renesas,buswait = <4>; - phys = <&usb0 1>; - phy-names = "usb"; - status = "disabled"; - }; - - usbphy: usb-phy-controller@e6590100 { - compatible = "renesas,usb-phy-r8a7790", - "renesas,rcar-gen2-usb-phy"; - reg = <0 0xe6590100 0 0x100>; - #address-cells = <1>; - #size-cells = <0>; - clocks = <&cpg CPG_MOD 704>; - clock-names = "usbhs"; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 704>; - status = "disabled"; - - usb0: usb-phy@0 { - reg = <0>; - #phy-cells = <1>; - }; - usb2: usb-phy@2 { - reg = <2>; - #phy-cells = <1>; - }; - }; - - usb_dmac0: dma-controller@e65a0000 { - compatible = "renesas,r8a7790-usb-dmac", - "renesas,usb-dmac"; - reg = <0 0xe65a0000 0 0x100>; - interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1"; - clocks = <&cpg CPG_MOD 330>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 330>; - #dma-cells = <1>; - dma-channels = <2>; - }; - - usb_dmac1: dma-controller@e65b0000 { - compatible = "renesas,r8a7790-usb-dmac", - "renesas,usb-dmac"; - reg = <0 0xe65b0000 0 0x100>; - interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1"; - clocks = <&cpg CPG_MOD 331>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 331>; - #dma-cells = <1>; - dma-channels = <2>; - }; - - dmac0: dma-controller@e6700000 { - compatible = "renesas,dmac-r8a7790", - "renesas,rcar-dmac"; - reg = <0 0xe6700000 0 0x20000>; - interrupts = <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 200 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 201 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 202 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 203 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 204 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 205 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 206 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 207 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 208 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 209 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 210 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 211 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 212 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 213 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 214 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14"; - clocks = <&cpg CPG_MOD 219>; - clock-names = "fck"; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 219>; - #dma-cells = <1>; - dma-channels = <15>; - }; - - dmac1: dma-controller@e6720000 { - compatible = "renesas,dmac-r8a7790", - "renesas,rcar-dmac"; - reg = <0 0xe6720000 0 0x20000>; - interrupts = <GIC_SPI 220 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 216 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 217 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 218 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 219 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 308 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 309 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 310 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 311 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 312 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 313 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 314 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 315 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 316 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 317 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 318 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14"; - clocks = <&cpg CPG_MOD 218>; - clock-names = "fck"; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 218>; - #dma-cells = <1>; - dma-channels = <15>; - }; - - avb: ethernet@e6800000 { - compatible = "renesas,etheravb-r8a7790", - "renesas,etheravb-rcar-gen2"; - reg = <0 0xe6800000 0 0x800>, <0 0xee0e8000 0 0x4000>; - interrupts = <GIC_SPI 163 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 812>; - clock-names = "fck"; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 812>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - qspi: spi@e6b10000 { - compatible = "renesas,qspi-r8a7790", "renesas,qspi"; - reg = <0 0xe6b10000 0 0x2c>; - interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 917>; - dmas = <&dmac0 0x17>, <&dmac0 0x18>, - <&dmac1 0x17>, <&dmac1 0x18>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 917>; - num-cs = <1>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - scifa0: serial@e6c40000 { - compatible = "renesas,scifa-r8a7790", - "renesas,rcar-gen2-scifa", "renesas,scifa"; - reg = <0 0xe6c40000 0 64>; - interrupts = <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 204>; - clock-names = "fck"; - dmas = <&dmac0 0x21>, <&dmac0 0x22>, - <&dmac1 0x21>, <&dmac1 0x22>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 204>; - status = "disabled"; - }; - - scifa1: serial@e6c50000 { - compatible = "renesas,scifa-r8a7790", - "renesas,rcar-gen2-scifa", "renesas,scifa"; - reg = <0 0xe6c50000 0 64>; - interrupts = <GIC_SPI 145 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 203>; - clock-names = "fck"; - dmas = <&dmac0 0x25>, <&dmac0 0x26>, - <&dmac1 0x25>, <&dmac1 0x26>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 203>; - status = "disabled"; - }; - - scifa2: serial@e6c60000 { - compatible = "renesas,scifa-r8a7790", - "renesas,rcar-gen2-scifa", "renesas,scifa"; - reg = <0 0xe6c60000 0 64>; - interrupts = <GIC_SPI 151 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 202>; - clock-names = "fck"; - dmas = <&dmac0 0x27>, <&dmac0 0x28>, - <&dmac1 0x27>, <&dmac1 0x28>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 202>; - status = "disabled"; - }; - - scifb0: serial@e6c20000 { - compatible = "renesas,scifb-r8a7790", - "renesas,rcar-gen2-scifb", "renesas,scifb"; - reg = <0 0xe6c20000 0 0x100>; - interrupts = <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 206>; - clock-names = "fck"; - dmas = <&dmac0 0x3d>, <&dmac0 0x3e>, - <&dmac1 0x3d>, <&dmac1 0x3e>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 206>; - status = "disabled"; - }; - - scifb1: serial@e6c30000 { - compatible = "renesas,scifb-r8a7790", - "renesas,rcar-gen2-scifb", "renesas,scifb"; - reg = <0 0xe6c30000 0 0x100>; - interrupts = <GIC_SPI 149 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 207>; - clock-names = "fck"; - dmas = <&dmac0 0x19>, <&dmac0 0x1a>, - <&dmac1 0x19>, <&dmac1 0x1a>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 207>; - status = "disabled"; - }; - - scifb2: serial@e6ce0000 { - compatible = "renesas,scifb-r8a7790", - "renesas,rcar-gen2-scifb", "renesas,scifb"; - reg = <0 0xe6ce0000 0 0x100>; - interrupts = <GIC_SPI 150 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 216>; - clock-names = "fck"; - dmas = <&dmac0 0x1d>, <&dmac0 0x1e>, - <&dmac1 0x1d>, <&dmac1 0x1e>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 216>; - status = "disabled"; - }; - - scif0: serial@e6e60000 { - compatible = "renesas,scif-r8a7790", - "renesas,rcar-gen2-scif", - "renesas,scif"; - reg = <0 0xe6e60000 0 64>; - interrupts = <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 721>, - <&cpg CPG_CORE R8A7790_CLK_ZS>, <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x29>, <&dmac0 0x2a>, - <&dmac1 0x29>, <&dmac1 0x2a>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 721>; - status = "disabled"; - }; - - scif1: serial@e6e68000 { - compatible = "renesas,scif-r8a7790", - "renesas,rcar-gen2-scif", - "renesas,scif"; - reg = <0 0xe6e68000 0 64>; - interrupts = <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 720>, - <&cpg CPG_CORE R8A7790_CLK_ZS>, <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x2d>, <&dmac0 0x2e>, - <&dmac1 0x2d>, <&dmac1 0x2e>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 720>; - status = "disabled"; - }; - - scif2: serial@e6e56000 { - compatible = "renesas,scif-r8a7790", - "renesas,rcar-gen2-scif", - "renesas,scif"; - reg = <0 0xe6e56000 0 64>; - interrupts = <GIC_SPI 164 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 310>, - <&cpg CPG_CORE R8A7790_CLK_ZS>, <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x2b>, <&dmac0 0x2c>, - <&dmac1 0x2b>, <&dmac1 0x2c>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 310>; - status = "disabled"; - }; - - hscif0: serial@e62c0000 { - compatible = "renesas,hscif-r8a7790", - "renesas,rcar-gen2-hscif", "renesas,hscif"; - reg = <0 0xe62c0000 0 96>; - interrupts = <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 717>, - <&cpg CPG_CORE R8A7790_CLK_ZS>, <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x39>, <&dmac0 0x3a>, - <&dmac1 0x39>, <&dmac1 0x3a>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 717>; - status = "disabled"; - }; - - hscif1: serial@e62c8000 { - compatible = "renesas,hscif-r8a7790", - "renesas,rcar-gen2-hscif", "renesas,hscif"; - reg = <0 0xe62c8000 0 96>; - interrupts = <GIC_SPI 155 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 716>, - <&cpg CPG_CORE R8A7790_CLK_ZS>, <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x4d>, <&dmac0 0x4e>, - <&dmac1 0x4d>, <&dmac1 0x4e>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 716>; - status = "disabled"; - }; - - msiof0: spi@e6e20000 { - compatible = "renesas,msiof-r8a7790", - "renesas,rcar-gen2-msiof"; - reg = <0 0xe6e20000 0 0x0064>; - interrupts = <GIC_SPI 156 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 0>; - dmas = <&dmac0 0x51>, <&dmac0 0x52>, - <&dmac1 0x51>, <&dmac1 0x52>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 0>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof1: spi@e6e10000 { - compatible = "renesas,msiof-r8a7790", - "renesas,rcar-gen2-msiof"; - reg = <0 0xe6e10000 0 0x0064>; - interrupts = <GIC_SPI 157 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 208>; - dmas = <&dmac0 0x55>, <&dmac0 0x56>, - <&dmac1 0x55>, <&dmac1 0x56>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 208>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof2: spi@e6e00000 { - compatible = "renesas,msiof-r8a7790", - "renesas,rcar-gen2-msiof"; - reg = <0 0xe6e00000 0 0x0064>; - interrupts = <GIC_SPI 158 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 205>; - dmas = <&dmac0 0x41>, <&dmac0 0x42>, - <&dmac1 0x41>, <&dmac1 0x42>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 205>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof3: spi@e6c90000 { - compatible = "renesas,msiof-r8a7790", - "renesas,rcar-gen2-msiof"; - reg = <0 0xe6c90000 0 0x0064>; - interrupts = <GIC_SPI 159 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 215>; - dmas = <&dmac0 0x45>, <&dmac0 0x46>, - <&dmac1 0x45>, <&dmac1 0x46>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 215>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - pwm0: pwm@e6e30000 { - compatible = "renesas,pwm-r8a7790", "renesas,pwm-rcar"; - reg = <0 0xe6e30000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - pwm1: pwm@e6e31000 { - compatible = "renesas,pwm-r8a7790", "renesas,pwm-rcar"; - reg = <0 0xe6e31000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - pwm2: pwm@e6e32000 { - compatible = "renesas,pwm-r8a7790", "renesas,pwm-rcar"; - reg = <0 0xe6e32000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - pwm3: pwm@e6e33000 { - compatible = "renesas,pwm-r8a7790", "renesas,pwm-rcar"; - reg = <0 0xe6e33000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - pwm4: pwm@e6e34000 { - compatible = "renesas,pwm-r8a7790", "renesas,pwm-rcar"; - reg = <0 0xe6e34000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - pwm5: pwm@e6e35000 { - compatible = "renesas,pwm-r8a7790", "renesas,pwm-rcar"; - reg = <0 0xe6e35000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - pwm6: pwm@e6e36000 { - compatible = "renesas,pwm-r8a7790", "renesas,pwm-rcar"; - reg = <0 0xe6e36000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - can0: can@e6e80000 { - compatible = "renesas,can-r8a7790", - "renesas,rcar-gen2-can"; - reg = <0 0xe6e80000 0 0x1000>; - interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 916>, - <&cpg CPG_CORE R8A7790_CLK_RCAN>, <&can_clk>; - clock-names = "clkp1", "clkp2", "can_clk"; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 916>; - status = "disabled"; - }; - - can1: can@e6e88000 { - compatible = "renesas,can-r8a7790", - "renesas,rcar-gen2-can"; - reg = <0 0xe6e88000 0 0x1000>; - interrupts = <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 915>, - <&cpg CPG_CORE R8A7790_CLK_RCAN>, <&can_clk>; - clock-names = "clkp1", "clkp2", "can_clk"; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 915>; - status = "disabled"; - }; - - vin0: video@e6ef0000 { - compatible = "renesas,vin-r8a7790", - "renesas,rcar-gen2-vin"; - reg = <0 0xe6ef0000 0 0x1000>; - interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 811>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 811>; - status = "disabled"; - }; - - vin1: video@e6ef1000 { - compatible = "renesas,vin-r8a7790", - "renesas,rcar-gen2-vin"; - reg = <0 0xe6ef1000 0 0x1000>; - interrupts = <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 810>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 810>; - status = "disabled"; - }; - - vin2: video@e6ef2000 { - compatible = "renesas,vin-r8a7790", - "renesas,rcar-gen2-vin"; - reg = <0 0xe6ef2000 0 0x1000>; - interrupts = <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 809>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 809>; - status = "disabled"; - }; - - vin3: video@e6ef3000 { - compatible = "renesas,vin-r8a7790", - "renesas,rcar-gen2-vin"; - reg = <0 0xe6ef3000 0 0x1000>; - interrupts = <GIC_SPI 191 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 808>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 808>; - status = "disabled"; - }; - - rcar_sound: sound@ec500000 { - /* - * #sound-dai-cells is required if simple-card - * - * Single DAI : #sound-dai-cells = <0>; <&rcar_sound>; - * Multi DAI : #sound-dai-cells = <1>; <&rcar_sound N>; - */ - compatible = "renesas,rcar_sound-r8a7790", - "renesas,rcar_sound-gen2"; - reg = <0 0xec500000 0 0x1000>, /* SCU */ - <0 0xec5a0000 0 0x100>, /* ADG */ - <0 0xec540000 0 0x1000>, /* SSIU */ - <0 0xec541000 0 0x280>, /* SSI */ - <0 0xec740000 0 0x200>; /* Audio DMAC peri peri*/ - reg-names = "scu", "adg", "ssiu", "ssi", "audmapp"; - - clocks = <&cpg CPG_MOD 1005>, - <&cpg CPG_MOD 1006>, <&cpg CPG_MOD 1007>, - <&cpg CPG_MOD 1008>, <&cpg CPG_MOD 1009>, - <&cpg CPG_MOD 1010>, <&cpg CPG_MOD 1011>, - <&cpg CPG_MOD 1012>, <&cpg CPG_MOD 1013>, - <&cpg CPG_MOD 1014>, <&cpg CPG_MOD 1015>, - <&cpg CPG_MOD 1022>, <&cpg CPG_MOD 1023>, - <&cpg CPG_MOD 1024>, <&cpg CPG_MOD 1025>, - <&cpg CPG_MOD 1026>, <&cpg CPG_MOD 1027>, - <&cpg CPG_MOD 1028>, <&cpg CPG_MOD 1029>, - <&cpg CPG_MOD 1030>, <&cpg CPG_MOD 1031>, - <&cpg CPG_MOD 1021>, <&cpg CPG_MOD 1020>, - <&cpg CPG_MOD 1021>, <&cpg CPG_MOD 1020>, - <&cpg CPG_MOD 1019>, <&cpg CPG_MOD 1018>, - <&audio_clk_a>, <&audio_clk_b>, <&audio_clk_c>, - <&cpg CPG_CORE R8A7790_CLK_M2>; - clock-names = "ssi-all", - "ssi.9", "ssi.8", "ssi.7", "ssi.6", - "ssi.5", "ssi.4", "ssi.3", "ssi.2", - "ssi.1", "ssi.0", - "src.9", "src.8", "src.7", "src.6", - "src.5", "src.4", "src.3", "src.2", - "src.1", "src.0", - "ctu.0", "ctu.1", - "mix.0", "mix.1", - "dvc.0", "dvc.1", - "clk_a", "clk_b", "clk_c", "clk_i"; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 1005>, - <&cpg 1006>, <&cpg 1007>, - <&cpg 1008>, <&cpg 1009>, - <&cpg 1010>, <&cpg 1011>, - <&cpg 1012>, <&cpg 1013>, - <&cpg 1014>, <&cpg 1015>; - reset-names = "ssi-all", - "ssi.9", "ssi.8", "ssi.7", "ssi.6", - "ssi.5", "ssi.4", "ssi.3", "ssi.2", - "ssi.1", "ssi.0"; - - status = "disabled"; - - rcar_sound,dvc { - dvc0: dvc-0 { - dmas = <&audma1 0xbc>; - dma-names = "tx"; - }; - dvc1: dvc-1 { - dmas = <&audma1 0xbe>; - dma-names = "tx"; - }; - }; - - rcar_sound,mix { - mix0: mix-0 { }; - mix1: mix-1 { }; - }; - - rcar_sound,ctu { - ctu00: ctu-0 { }; - ctu01: ctu-1 { }; - ctu02: ctu-2 { }; - ctu03: ctu-3 { }; - ctu10: ctu-4 { }; - ctu11: ctu-5 { }; - ctu12: ctu-6 { }; - ctu13: ctu-7 { }; - }; - - rcar_sound,src { - src0: src-0 { - interrupts = <GIC_SPI 352 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x85>, <&audma1 0x9a>; - dma-names = "rx", "tx"; - }; - src1: src-1 { - interrupts = <GIC_SPI 353 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x87>, <&audma1 0x9c>; - dma-names = "rx", "tx"; - }; - src2: src-2 { - interrupts = <GIC_SPI 354 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x89>, <&audma1 0x9e>; - dma-names = "rx", "tx"; - }; - src3: src-3 { - interrupts = <GIC_SPI 355 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x8b>, <&audma1 0xa0>; - dma-names = "rx", "tx"; - }; - src4: src-4 { - interrupts = <GIC_SPI 356 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x8d>, <&audma1 0xb0>; - dma-names = "rx", "tx"; - }; - src5: src-5 { - interrupts = <GIC_SPI 357 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x8f>, <&audma1 0xb2>; - dma-names = "rx", "tx"; - }; - src6: src-6 { - interrupts = <GIC_SPI 358 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x91>, <&audma1 0xb4>; - dma-names = "rx", "tx"; - }; - src7: src-7 { - interrupts = <GIC_SPI 359 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x93>, <&audma1 0xb6>; - dma-names = "rx", "tx"; - }; - src8: src-8 { - interrupts = <GIC_SPI 360 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x95>, <&audma1 0xb8>; - dma-names = "rx", "tx"; - }; - src9: src-9 { - interrupts = <GIC_SPI 361 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x97>, <&audma1 0xba>; - dma-names = "rx", "tx"; - }; - }; - - rcar_sound,ssi { - ssi0: ssi-0 { - interrupts = <GIC_SPI 370 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x01>, <&audma1 0x02>, - <&audma0 0x15>, <&audma1 0x16>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi1: ssi-1 { - interrupts = <GIC_SPI 371 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x03>, <&audma1 0x04>, - <&audma0 0x49>, <&audma1 0x4a>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi2: ssi-2 { - interrupts = <GIC_SPI 372 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x05>, <&audma1 0x06>, - <&audma0 0x63>, <&audma1 0x64>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi3: ssi-3 { - interrupts = <GIC_SPI 373 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x07>, <&audma1 0x08>, - <&audma0 0x6f>, <&audma1 0x70>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi4: ssi-4 { - interrupts = <GIC_SPI 374 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x09>, <&audma1 0x0a>, - <&audma0 0x71>, <&audma1 0x72>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi5: ssi-5 { - interrupts = <GIC_SPI 375 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x0b>, <&audma1 0x0c>, - <&audma0 0x73>, <&audma1 0x74>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi6: ssi-6 { - interrupts = <GIC_SPI 376 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x0d>, <&audma1 0x0e>, - <&audma0 0x75>, <&audma1 0x76>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi7: ssi-7 { - interrupts = <GIC_SPI 377 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x0f>, <&audma1 0x10>, - <&audma0 0x79>, <&audma1 0x7a>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi8: ssi-8 { - interrupts = <GIC_SPI 378 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x11>, <&audma1 0x12>, - <&audma0 0x7b>, <&audma1 0x7c>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi9: ssi-9 { - interrupts = <GIC_SPI 379 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x13>, <&audma1 0x14>, - <&audma0 0x7d>, <&audma1 0x7e>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - }; - }; - - audma0: dma-controller@ec700000 { - compatible = "renesas,dmac-r8a7790", - "renesas,rcar-dmac"; - reg = <0 0xec700000 0 0x10000>; - interrupts = <GIC_SPI 346 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 320 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 321 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 322 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 323 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 324 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 325 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 326 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 327 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 328 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 329 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 330 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 331 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 332 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12"; - clocks = <&cpg CPG_MOD 502>; - clock-names = "fck"; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 502>; - #dma-cells = <1>; - dma-channels = <13>; - }; - - audma1: dma-controller@ec720000 { - compatible = "renesas,dmac-r8a7790", - "renesas,rcar-dmac"; - reg = <0 0xec720000 0 0x10000>; - interrupts = <GIC_SPI 347 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 333 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 334 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 335 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 336 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 337 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 338 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 339 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 340 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 341 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 342 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 343 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 344 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 345 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12"; - clocks = <&cpg CPG_MOD 501>; - clock-names = "fck"; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 501>; - #dma-cells = <1>; - dma-channels = <13>; - }; - - xhci: usb@ee000000 { - compatible = "renesas,xhci-r8a7790", - "renesas,rcar-gen2-xhci"; - reg = <0 0xee000000 0 0xc00>; - interrupts = <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 328>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 328>; - phys = <&usb2 1>; - phy-names = "usb"; - status = "disabled"; - }; - - pci0: pci@ee090000 { - compatible = "renesas,pci-r8a7790", - "renesas,pci-rcar-gen2"; - device_type = "pci"; - reg = <0 0xee090000 0 0xc00>, - <0 0xee080000 0 0x1100>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 703>; - status = "disabled"; - - bus-range = <0 0>; - #address-cells = <3>; - #size-cells = <2>; - #interrupt-cells = <1>; - ranges = <0x02000000 0 0xee080000 0 0xee080000 0 0x00010000>; - interrupt-map-mask = <0xf800 0 0 0x7>; - interrupt-map = <0x0000 0 0 1 &gic GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>, - <0x0800 0 0 1 &gic GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>, - <0x1000 0 0 2 &gic GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - - usb@1,0 { - reg = <0x800 0 0 0 0>; - phys = <&usb0 0>; - phy-names = "usb"; - }; - - usb@2,0 { - reg = <0x1000 0 0 0 0>; - phys = <&usb0 0>; - phy-names = "usb"; - }; - }; - - pci1: pci@ee0b0000 { - compatible = "renesas,pci-r8a7790", - "renesas,pci-rcar-gen2"; - device_type = "pci"; - reg = <0 0xee0b0000 0 0xc00>, - <0 0xee0a0000 0 0x1100>; - interrupts = <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 703>; - status = "disabled"; - - bus-range = <1 1>; - #address-cells = <3>; - #size-cells = <2>; - #interrupt-cells = <1>; - ranges = <0x02000000 0 0xee0a0000 0 0xee0a0000 0 0x00010000>; - interrupt-map-mask = <0xf800 0 0 0x7>; - interrupt-map = <0x0000 0 0 1 &gic GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>, - <0x0800 0 0 1 &gic GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>, - <0x1000 0 0 2 &gic GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>; - }; - - pci2: pci@ee0d0000 { - compatible = "renesas,pci-r8a7790", - "renesas,pci-rcar-gen2"; - device_type = "pci"; - clocks = <&cpg CPG_MOD 703>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 703>; - reg = <0 0xee0d0000 0 0xc00>, - <0 0xee0c0000 0 0x1100>; - interrupts = <GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH>; - status = "disabled"; - - bus-range = <2 2>; - #address-cells = <3>; - #size-cells = <2>; - #interrupt-cells = <1>; - ranges = <0x02000000 0 0xee0c0000 0 0xee0c0000 0 0x00010000>; - interrupt-map-mask = <0xf800 0 0 0x7>; - interrupt-map = <0x0000 0 0 1 &gic GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH>, - <0x0800 0 0 1 &gic GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH>, - <0x1000 0 0 2 &gic GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH>; - - usb@1,0 { - reg = <0x20800 0 0 0 0>; - phys = <&usb2 0>; - phy-names = "usb"; - }; - - usb@2,0 { - reg = <0x21000 0 0 0 0>; - phys = <&usb2 0>; - phy-names = "usb"; - }; - }; - - sdhi0: mmc@ee100000 { - compatible = "renesas,sdhi-r8a7790", - "renesas,rcar-gen2-sdhi"; - reg = <0 0xee100000 0 0x328>; - interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 314>; - dmas = <&dmac0 0xcd>, <&dmac0 0xce>, - <&dmac1 0xcd>, <&dmac1 0xce>; - dma-names = "tx", "rx", "tx", "rx"; - max-frequency = <195000000>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 314>; - status = "disabled"; - }; - - sdhi1: mmc@ee120000 { - compatible = "renesas,sdhi-r8a7790", - "renesas,rcar-gen2-sdhi"; - reg = <0 0xee120000 0 0x328>; - interrupts = <GIC_SPI 166 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 313>; - dmas = <&dmac0 0xc9>, <&dmac0 0xca>, - <&dmac1 0xc9>, <&dmac1 0xca>; - dma-names = "tx", "rx", "tx", "rx"; - max-frequency = <195000000>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 313>; - status = "disabled"; - }; - - sdhi2: mmc@ee140000 { - compatible = "renesas,sdhi-r8a7790", - "renesas,rcar-gen2-sdhi"; - reg = <0 0xee140000 0 0x100>; - interrupts = <GIC_SPI 167 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 312>; - dmas = <&dmac0 0xc1>, <&dmac0 0xc2>, - <&dmac1 0xc1>, <&dmac1 0xc2>; - dma-names = "tx", "rx", "tx", "rx"; - max-frequency = <97500000>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 312>; - status = "disabled"; - }; - - sdhi3: mmc@ee160000 { - compatible = "renesas,sdhi-r8a7790", - "renesas,rcar-gen2-sdhi"; - reg = <0 0xee160000 0 0x100>; - interrupts = <GIC_SPI 168 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 311>; - dmas = <&dmac0 0xd3>, <&dmac0 0xd4>, - <&dmac1 0xd3>, <&dmac1 0xd4>; - dma-names = "tx", "rx", "tx", "rx"; - max-frequency = <97500000>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 311>; - status = "disabled"; - }; - - mmcif0: mmc@ee200000 { - compatible = "renesas,mmcif-r8a7790", - "renesas,sh-mmcif"; - reg = <0 0xee200000 0 0x80>; - interrupts = <GIC_SPI 169 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 315>; - dmas = <&dmac0 0xd1>, <&dmac0 0xd2>, - <&dmac1 0xd1>, <&dmac1 0xd2>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 315>; - reg-io-width = <4>; - status = "disabled"; - max-frequency = <97500000>; - }; - - mmcif1: mmc@ee220000 { - compatible = "renesas,mmcif-r8a7790", - "renesas,sh-mmcif"; - reg = <0 0xee220000 0 0x80>; - interrupts = <GIC_SPI 170 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 305>; - dmas = <&dmac0 0xe1>, <&dmac0 0xe2>, - <&dmac1 0xe1>, <&dmac1 0xe2>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 305>; - reg-io-width = <4>; - status = "disabled"; - max-frequency = <97500000>; - }; - - sata0: sata@ee300000 { - compatible = "renesas,sata-r8a7790", - "renesas,rcar-gen2-sata"; - reg = <0 0xee300000 0 0x200000>; - interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 815>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 815>; - status = "disabled"; - }; - - sata1: sata@ee500000 { - compatible = "renesas,sata-r8a7790", - "renesas,rcar-gen2-sata"; - reg = <0 0xee500000 0 0x200000>; - interrupts = <GIC_SPI 106 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 814>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 814>; - status = "disabled"; - }; - - ether: ethernet@ee700000 { - compatible = "renesas,ether-r8a7790", - "renesas,rcar-gen2-ether"; - reg = <0 0xee700000 0 0x400>; - interrupts = <GIC_SPI 162 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 813>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 813>; - phy-mode = "rmii"; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - gic: interrupt-controller@f1001000 { - compatible = "arm,gic-400"; - #interrupt-cells = <3>; - #address-cells = <0>; - interrupt-controller; - reg = <0 0xf1001000 0 0x1000>, <0 0xf1002000 0 0x2000>, - <0 0xf1004000 0 0x2000>, <0 0xf1006000 0 0x2000>; - interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_HIGH)>; - clocks = <&cpg CPG_MOD 408>; - clock-names = "clk"; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 408>; - }; - - pciec: pcie@fe000000 { - compatible = "renesas,pcie-r8a7790", - "renesas,pcie-rcar-gen2"; - reg = <0 0xfe000000 0 0x80000>; - #address-cells = <3>; - #size-cells = <2>; - bus-range = <0x00 0xff>; - device_type = "pci"; - ranges = <0x01000000 0 0x00000000 0 0xfe100000 0 0x00100000>, - <0x02000000 0 0xfe200000 0 0xfe200000 0 0x00200000>, - <0x02000000 0 0x30000000 0 0x30000000 0 0x08000000>, - <0x42000000 0 0x38000000 0 0x38000000 0 0x08000000>; - /* Map all possible DDR as inbound ranges */ - dma-ranges = <0x42000000 0 0x40000000 0 0x40000000 0 0x80000000>, - <0x43000000 1 0x80000000 1 0x80000000 0 0x80000000>; - interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>; - #interrupt-cells = <1>; - interrupt-map-mask = <0 0 0 0>; - interrupt-map = <0 0 0 0 &gic GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 319>, <&pcie_bus_clk>; - clock-names = "pcie", "pcie_bus"; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 319>; - status = "disabled"; - }; - - vsp@fe920000 { - compatible = "renesas,vsp1"; - reg = <0 0xfe920000 0 0x8000>; - interrupts = <GIC_SPI 266 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 130>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 130>; - }; - - vsp@fe928000 { - compatible = "renesas,vsp1"; - reg = <0 0xfe928000 0 0x8000>; - interrupts = <GIC_SPI 267 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 131>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 131>; - }; - - vsp@fe930000 { - compatible = "renesas,vsp1"; - reg = <0 0xfe930000 0 0x8000>; - interrupts = <GIC_SPI 246 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 128>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 128>; - }; - - vsp@fe938000 { - compatible = "renesas,vsp1"; - reg = <0 0xfe938000 0 0x8000>; - interrupts = <GIC_SPI 247 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 127>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 127>; - }; - - fdp1@fe940000 { - compatible = "renesas,fdp1"; - reg = <0 0xfe940000 0 0x2400>; - interrupts = <GIC_SPI 262 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 119>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 119>; - }; - - fdp1@fe944000 { - compatible = "renesas,fdp1"; - reg = <0 0xfe944000 0 0x2400>; - interrupts = <GIC_SPI 263 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 118>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 118>; - }; - - fdp1@fe948000 { - compatible = "renesas,fdp1"; - reg = <0 0xfe948000 0 0x2400>; - interrupts = <GIC_SPI 264 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 117>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 117>; - }; - - jpu: jpeg-codec@fe980000 { - compatible = "renesas,jpu-r8a7790", - "renesas,rcar-gen2-jpu"; - reg = <0 0xfe980000 0 0x10300>; - interrupts = <GIC_SPI 272 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 106>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 106>; - }; - - du: display@feb00000 { - compatible = "renesas,du-r8a7790"; - reg = <0 0xfeb00000 0 0x70000>; - interrupts = <GIC_SPI 256 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 268 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 269 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 724>, <&cpg CPG_MOD 723>, - <&cpg CPG_MOD 722>; - clock-names = "du.0", "du.1", "du.2"; - resets = <&cpg 724>; - reset-names = "du.0"; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - du_out_rgb: endpoint { - }; - }; - port@1 { - reg = <1>; - du_out_lvds0: endpoint { - remote-endpoint = <&lvds0_in>; - }; - }; - port@2 { - reg = <2>; - du_out_lvds1: endpoint { - remote-endpoint = <&lvds1_in>; - }; - }; - }; - }; - - lvds0: lvds@feb90000 { - compatible = "renesas,r8a7790-lvds"; - reg = <0 0xfeb90000 0 0x1c>; - clocks = <&cpg CPG_MOD 726>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 726>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - lvds0_in: endpoint { - remote-endpoint = <&du_out_lvds0>; - }; - }; - port@1 { - reg = <1>; - lvds0_out: endpoint { - }; - }; - }; - }; - - lvds1: lvds@feb94000 { - compatible = "renesas,r8a7790-lvds"; - reg = <0 0xfeb94000 0 0x1c>; - clocks = <&cpg CPG_MOD 725>; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 725>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - lvds1_in: endpoint { - remote-endpoint = <&du_out_lvds1>; - }; - }; - port@1 { - reg = <1>; - lvds1_out: endpoint { - }; - }; - }; - }; - - prr: chipid@ff000044 { - compatible = "renesas,prr"; - reg = <0 0xff000044 0 4>; - }; - - cmt0: timer@ffca0000 { - compatible = "renesas,r8a7790-cmt0", - "renesas,rcar-gen2-cmt0"; - reg = <0 0xffca0000 0 0x1004>; - interrupts = <GIC_SPI 142 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 143 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 124>; - clock-names = "fck"; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 124>; - - status = "disabled"; - }; - - cmt1: timer@e6130000 { - compatible = "renesas,r8a7790-cmt1", - "renesas,rcar-gen2-cmt1"; - reg = <0 0xe6130000 0 0x1004>; - interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 127 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 329>; - clock-names = "fck"; - power-domains = <&sysc R8A7790_PD_ALWAYS_ON>; - resets = <&cpg 329>; - - status = "disabled"; - }; - }; - - thermal-zones { - cpu_thermal: cpu-thermal { - polling-delay-passive = <0>; - polling-delay = <0>; - - thermal-sensors = <&thermal>; - - trips { - cpu-crit { - temperature = <95000>; - hysteresis = <0>; - type = "critical"; - }; - }; - cooling-maps { - }; - }; - }; - - timer { - compatible = "arm,armv7-timer"; - interrupts-extended = <&gic GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_LOW)>; - }; - - /* External USB clock - can be overridden by the board */ - usb_extal_clk: usb_extal { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <48000000>; - }; -}; diff --git a/arch/arm/dts/r8a7791-koelsch.dts b/arch/arm/dts/r8a7791-koelsch.dts deleted file mode 100644 index 26a40782cc8..00000000000 --- a/arch/arm/dts/r8a7791-koelsch.dts +++ /dev/null @@ -1,912 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the Koelsch board - * - * Copyright (C) 2013 Renesas Electronics Corporation - * Copyright (C) 2013-2014 Renesas Solutions Corp. - * Copyright (C) 2014 Cogent Embedded, Inc. - */ - -/* - * SSI-AK4643 - * - * SW1: 1: AK4643 - * 2: CN22 - * 3: ADV7511 - * - * This command is required when Playback/Capture - * - * amixer set "LINEOUT Mixer DACL" on - * amixer set "DVC Out" 100% - * amixer set "DVC In" 100% - * - * You can use Mute - * - * amixer set "DVC Out Mute" on - * amixer set "DVC In Mute" on - * - * You can use Volume Ramp - * - * amixer set "DVC Out Ramp Up Rate" "0.125 dB/64 steps" - * amixer set "DVC Out Ramp Down Rate" "0.125 dB/512 steps" - * amixer set "DVC Out Ramp" on - * aplay xxx.wav & - * amixer set "DVC Out" 80% // Volume Down - * amixer set "DVC Out" 100% // Volume Up - */ - -/dts-v1/; -#include "r8a7791.dtsi" -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/input/input.h> - -/ { - model = "Koelsch"; - compatible = "renesas,koelsch", "renesas,r8a7791"; - - aliases { - serial0 = &scif0; - serial1 = &scif1; - i2c9 = &gpioi2c1; - i2c10 = &gpioi2c2; - i2c11 = &gpioi2c4; - i2c12 = &i2cexio1; - i2c13 = &i2chdmi; - i2c14 = &i2cexio4; - mmc0 = &sdhi0; - mmc1 = &sdhi1; - mmc2 = &sdhi2; - }; - - chosen { - bootargs = "ignore_loglevel rw root=/dev/nfs ip=on"; - stdout-path = "serial0:115200n8"; - }; - - memory@40000000 { - device_type = "memory"; - reg = <0 0x40000000 0 0x40000000>; - }; - - memory@200000000 { - device_type = "memory"; - reg = <2 0x00000000 0 0x40000000>; - }; - - lbsc { - #address-cells = <1>; - #size-cells = <1>; - }; - - keyboard { - compatible = "gpio-keys"; - - pinctrl-0 = <&keyboard_pins>; - pinctrl-names = "default"; - - key-1 { - gpios = <&gpio5 0 GPIO_ACTIVE_LOW>; - linux,code = <KEY_1>; - label = "SW2-1"; - wakeup-source; - debounce-interval = <20>; - }; - key-2 { - gpios = <&gpio5 1 GPIO_ACTIVE_LOW>; - linux,code = <KEY_2>; - label = "SW2-2"; - wakeup-source; - debounce-interval = <20>; - }; - key-3 { - gpios = <&gpio5 2 GPIO_ACTIVE_LOW>; - linux,code = <KEY_3>; - label = "SW2-3"; - wakeup-source; - debounce-interval = <20>; - }; - key-4 { - gpios = <&gpio5 3 GPIO_ACTIVE_LOW>; - linux,code = <KEY_4>; - label = "SW2-4"; - wakeup-source; - debounce-interval = <20>; - }; - key-a { - gpios = <&gpio7 0 GPIO_ACTIVE_LOW>; - linux,code = <KEY_A>; - label = "SW30"; - wakeup-source; - debounce-interval = <20>; - }; - key-b { - gpios = <&gpio7 1 GPIO_ACTIVE_LOW>; - linux,code = <KEY_B>; - label = "SW31"; - wakeup-source; - debounce-interval = <20>; - }; - key-c { - gpios = <&gpio7 2 GPIO_ACTIVE_LOW>; - linux,code = <KEY_C>; - label = "SW32"; - wakeup-source; - debounce-interval = <20>; - }; - key-d { - gpios = <&gpio7 3 GPIO_ACTIVE_LOW>; - linux,code = <KEY_D>; - label = "SW33"; - wakeup-source; - debounce-interval = <20>; - }; - key-e { - gpios = <&gpio7 4 GPIO_ACTIVE_LOW>; - linux,code = <KEY_E>; - label = "SW34"; - wakeup-source; - debounce-interval = <20>; - }; - key-f { - gpios = <&gpio7 5 GPIO_ACTIVE_LOW>; - linux,code = <KEY_F>; - label = "SW35"; - wakeup-source; - debounce-interval = <20>; - }; - key-g { - gpios = <&gpio7 6 GPIO_ACTIVE_LOW>; - linux,code = <KEY_G>; - label = "SW36"; - wakeup-source; - debounce-interval = <20>; - }; - }; - - leds { - compatible = "gpio-leds"; - led6 { - gpios = <&gpio2 19 GPIO_ACTIVE_HIGH>; - label = "LED6"; - }; - led7 { - gpios = <&gpio2 20 GPIO_ACTIVE_HIGH>; - label = "LED7"; - }; - led8 { - gpios = <&gpio2 21 GPIO_ACTIVE_HIGH>; - label = "LED8"; - }; - }; - - vcc_sdhi0: regulator-vcc-sdhi0 { - compatible = "regulator-fixed"; - - regulator-name = "SDHI0 Vcc"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - gpio = <&gpio7 17 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; - - vccq_sdhi0: regulator-vccq-sdhi0 { - compatible = "regulator-gpio"; - - regulator-name = "SDHI0 VccQ"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - - gpios = <&gpio2 12 GPIO_ACTIVE_HIGH>; - gpios-states = <1>; - states = <3300000 1>, <1800000 0>; - }; - - vcc_sdhi1: regulator-vcc-sdhi1 { - compatible = "regulator-fixed"; - - regulator-name = "SDHI1 Vcc"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - gpio = <&gpio7 18 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; - - vccq_sdhi1: regulator-vccq-sdhi1 { - compatible = "regulator-gpio"; - - regulator-name = "SDHI1 VccQ"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - - gpios = <&gpio2 13 GPIO_ACTIVE_HIGH>; - gpios-states = <1>; - states = <3300000 1>, <1800000 0>; - }; - - vcc_sdhi2: regulator-vcc-sdhi2 { - compatible = "regulator-fixed"; - - regulator-name = "SDHI2 Vcc"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - gpio = <&gpio7 19 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; - - vccq_sdhi2: regulator-vccq-sdhi2 { - compatible = "regulator-gpio"; - - regulator-name = "SDHI2 VccQ"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - - gpios = <&gpio2 26 GPIO_ACTIVE_HIGH>; - gpios-states = <1>; - states = <3300000 1>, <1800000 0>; - }; - - audio_clock: audio_clock { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <11289600>; - }; - - rsnd_ak4643: sound { - compatible = "simple-audio-card"; - - simple-audio-card,format = "left_j"; - simple-audio-card,bitclock-master = <&sndcodec>; - simple-audio-card,frame-master = <&sndcodec>; - - sndcpu: simple-audio-card,cpu { - sound-dai = <&rcar_sound>; - }; - - sndcodec: simple-audio-card,codec { - sound-dai = <&ak4643>; - clocks = <&audio_clock>; - }; - }; - - hdmi-in { - compatible = "hdmi-connector"; - type = "a"; - - port { - hdmi_con_in: endpoint { - remote-endpoint = <&adv7612_in>; - }; - }; - }; - - cec_clock: cec-clock { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <12000000>; - }; - - hdmi-out { - compatible = "hdmi-connector"; - type = "a"; - - port { - hdmi_con_out: endpoint { - remote-endpoint = <&adv7511_out>; - }; - }; - }; - - x2_clk: x2-clock { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <74250000>; - }; - - x13_clk: x13-clock { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <148500000>; - }; - - gpioi2c1: i2c-9 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "i2c-gpio"; - status = "disabled"; - scl-gpios = <&gpio7 15 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; - sda-gpios = <&gpio7 16 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; - i2c-gpio,delay-us = <5>; - }; - - gpioi2c2: i2c-10 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "i2c-gpio"; - status = "disabled"; - scl-gpios = <&gpio2 6 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; - sda-gpios = <&gpio2 7 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; - i2c-gpio,delay-us = <5>; - }; - - gpioi2c4: i2c-11 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "i2c-gpio"; - status = "disabled"; - scl-gpios = <&gpio7 13 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; - sda-gpios = <&gpio7 14 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; - i2c-gpio,delay-us = <5>; - }; - - /* - * I2C1 is routed to EXIO connector B, pins 64 (SCL) + 66 (SDA). - * A fallback to GPIO is provided. - */ - i2cexio1: i2c-12 { - compatible = "i2c-demux-pinctrl"; - i2c-parent = <&i2c1>, <&gpioi2c1>; - i2c-bus-name = "i2c-exio1"; - #address-cells = <1>; - #size-cells = <0>; - }; - - /* - * A fallback to GPIO is provided for I2C2. - */ - i2chdmi: i2c-13 { - compatible = "i2c-demux-pinctrl"; - i2c-parent = <&i2c2>, <&gpioi2c2>; - i2c-bus-name = "i2c-hdmi"; - #address-cells = <1>; - #size-cells = <0>; - - ak4643: codec@12 { - compatible = "asahi-kasei,ak4643"; - #sound-dai-cells = <0>; - reg = <0x12>; - }; - - composite-in@20 { - compatible = "adi,adv7180"; - reg = <0x20>; - - port { - adv7180: endpoint { - bus-width = <8>; - remote-endpoint = <&vin1ep>; - }; - }; - }; - - hdmi@39 { - compatible = "adi,adv7511w"; - reg = <0x39>; - interrupt-parent = <&gpio3>; - interrupts = <29 IRQ_TYPE_LEVEL_LOW>; - clocks = <&cec_clock>; - clock-names = "cec"; - - adi,input-depth = <8>; - adi,input-colorspace = "rgb"; - adi,input-clock = "1x"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - adv7511_in: endpoint { - remote-endpoint = <&du_out_rgb>; - }; - }; - - port@1 { - reg = <1>; - adv7511_out: endpoint { - remote-endpoint = <&hdmi_con_out>; - }; - }; - }; - }; - - hdmi-in@4c { - compatible = "adi,adv7612"; - reg = <0x4c>; - interrupt-parent = <&gpio4>; - interrupts = <2 IRQ_TYPE_LEVEL_LOW>; - default-input = <0>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - adv7612_in: endpoint { - remote-endpoint = <&hdmi_con_in>; - }; - }; - - port@2 { - reg = <2>; - adv7612_out: endpoint { - remote-endpoint = <&vin0ep2>; - }; - }; - }; - }; - - eeprom@50 { - compatible = "renesas,r1ex24002", "atmel,24c02"; - reg = <0x50>; - pagesize = <16>; - }; - }; - - /* - * I2C4 is routed to EXIO connector E, pins 37 (SCL) + 39 (SDA). - * A fallback to GPIO is provided. - */ - i2cexio4: i2c-14 { - compatible = "i2c-demux-pinctrl"; - i2c-parent = <&i2c4>, <&gpioi2c4>; - i2c-bus-name = "i2c-exio4"; - #address-cells = <1>; - #size-cells = <0>; - }; -}; - -&du { - pinctrl-0 = <&du_pins>; - pinctrl-names = "default"; - status = "okay"; - - clocks = <&cpg CPG_MOD 724>, <&cpg CPG_MOD 723>, - <&x13_clk>, <&x2_clk>; - clock-names = "du.0", "du.1", "dclkin.0", "dclkin.1"; - - ports { - port@0 { - endpoint { - remote-endpoint = <&adv7511_in>; - }; - }; - }; -}; - -&lvds0 { - ports { - port@1 { - lvds_connector: endpoint { - }; - }; - }; -}; - -&extal_clk { - clock-frequency = <20000000>; -}; - -&pfc { - pinctrl-0 = <&scif_clk_pins>; - pinctrl-names = "default"; - - i2c1_pins: i2c1 { - groups = "i2c1"; - function = "i2c1"; - }; - - i2c2_pins: i2c2 { - groups = "i2c2"; - function = "i2c2"; - }; - - i2c4_pins: i2c4 { - groups = "i2c4_c"; - function = "i2c4"; - }; - - du_pins: du { - groups = "du_rgb888", "du_sync", "du_disp", "du_clk_out_0"; - function = "du"; - }; - - scif0_pins: scif0 { - groups = "scif0_data_d"; - function = "scif0"; - }; - - scif1_pins: scif1 { - groups = "scif1_data_d"; - function = "scif1"; - }; - - scif_clk_pins: scif_clk { - groups = "scif_clk"; - function = "scif_clk"; - }; - - ether_pins: ether { - groups = "eth_link", "eth_mdio", "eth_rmii"; - function = "eth"; - }; - - phy1_pins: phy1 { - groups = "intc_irq0"; - function = "intc"; - }; - - pmic_irq_pins: pmicirq { - groups = "intc_irq2"; - function = "intc"; - }; - - sdhi0_pins: sd0 { - groups = "sdhi0_data4", "sdhi0_ctrl"; - function = "sdhi0"; - power-source = <3300>; - }; - - sdhi0_pins_uhs: sd0_uhs { - groups = "sdhi0_data4", "sdhi0_ctrl"; - function = "sdhi0"; - power-source = <1800>; - }; - - sdhi1_pins: sd1 { - groups = "sdhi1_data4", "sdhi1_ctrl"; - function = "sdhi1"; - power-source = <3300>; - }; - - sdhi1_pins_uhs: sd1_uhs { - groups = "sdhi1_data4", "sdhi1_ctrl"; - function = "sdhi1"; - power-source = <1800>; - }; - - sdhi2_pins: sd2 { - groups = "sdhi2_data4", "sdhi2_ctrl"; - function = "sdhi2"; - power-source = <3300>; - }; - - sdhi2_pins_uhs: sd2_uhs { - groups = "sdhi2_data4", "sdhi2_ctrl"; - function = "sdhi2"; - power-source = <1800>; - }; - - qspi_pins: qspi { - groups = "qspi_ctrl", "qspi_data4"; - function = "qspi"; - }; - - msiof0_pins: msiof0 { - groups = "msiof0_clk", "msiof0_sync", "msiof0_rx", - "msiof0_tx"; - function = "msiof0"; - }; - - usb0_pins: usb0 { - groups = "usb0"; - function = "usb0"; - }; - - usb1_pins: usb1 { - groups = "usb1"; - function = "usb1"; - }; - - vin0_pins: vin0 { - groups = "vin0_data24", "vin0_sync", "vin0_clkenb", "vin0_clk"; - function = "vin0"; - }; - - vin1_pins: vin1 { - groups = "vin1_data8", "vin1_clk"; - function = "vin1"; - }; - - sound_pins: sound { - groups = "ssi0129_ctrl", "ssi0_data", "ssi1_data"; - function = "ssi"; - }; - - sound_clk_pins: sound_clk { - groups = "audio_clk_a"; - function = "audio_clk"; - }; - - keyboard_pins: keyboard { - pins = "GP_5_0", "GP_5_1", "GP_5_2", "GP_5_3"; - bias-pull-up; - }; -}; - -ðer { - pinctrl-0 = <ðer_pins>, <&phy1_pins>; - pinctrl-names = "default"; - - phy-handle = <&phy1>; - renesas,ether-link-active-low; - status = "okay"; - - phy1: ethernet-phy@1 { - compatible = "ethernet-phy-id0022.1537", - "ethernet-phy-ieee802.3-c22"; - reg = <1>; - interrupt-parent = <&irqc0>; - interrupts = <0 IRQ_TYPE_LEVEL_LOW>; - micrel,led-mode = <1>; - reset-gpios = <&gpio5 22 GPIO_ACTIVE_LOW>; - }; -}; - -&cmt0 { - status = "okay"; -}; - -&rwdt { - timeout-sec = <60>; - status = "okay"; -}; - -&sata0 { - status = "okay"; -}; - -&scif0 { - pinctrl-0 = <&scif0_pins>; - pinctrl-names = "default"; - - status = "okay"; -}; - -&scif1 { - pinctrl-0 = <&scif1_pins>; - pinctrl-names = "default"; - - status = "okay"; -}; - -&scif_clk { - clock-frequency = <14745600>; -}; - -&sdhi0 { - pinctrl-0 = <&sdhi0_pins>; - pinctrl-1 = <&sdhi0_pins_uhs>; - pinctrl-names = "default", "state_uhs"; - - vmmc-supply = <&vcc_sdhi0>; - vqmmc-supply = <&vccq_sdhi0>; - cd-gpios = <&gpio6 6 GPIO_ACTIVE_LOW>; - wp-gpios = <&gpio6 7 GPIO_ACTIVE_HIGH>; - sd-uhs-sdr50; - sd-uhs-sdr104; - status = "okay"; -}; - -&sdhi1 { - pinctrl-0 = <&sdhi1_pins>; - pinctrl-1 = <&sdhi1_pins_uhs>; - pinctrl-names = "default", "state_uhs"; - - vmmc-supply = <&vcc_sdhi1>; - vqmmc-supply = <&vccq_sdhi1>; - cd-gpios = <&gpio6 14 GPIO_ACTIVE_LOW>; - wp-gpios = <&gpio6 15 GPIO_ACTIVE_HIGH>; - sd-uhs-sdr50; - status = "okay"; -}; - -&sdhi2 { - pinctrl-0 = <&sdhi2_pins>; - pinctrl-1 = <&sdhi2_pins_uhs>; - pinctrl-names = "default", "state_uhs"; - - vmmc-supply = <&vcc_sdhi2>; - vqmmc-supply = <&vccq_sdhi2>; - cd-gpios = <&gpio6 22 GPIO_ACTIVE_LOW>; - sd-uhs-sdr50; - status = "okay"; -}; - -&qspi { - pinctrl-0 = <&qspi_pins>; - pinctrl-names = "default"; - - status = "okay"; - - flash: flash@0 { - compatible = "spansion,s25fl512s", "jedec,spi-nor"; - reg = <0>; - spi-max-frequency = <30000000>; - spi-tx-bus-width = <4>; - spi-rx-bus-width = <4>; - spi-cpha; - spi-cpol; - m25p,fast-read; - - partitions { - compatible = "fixed-partitions"; - #address-cells = <1>; - #size-cells = <1>; - - partition@0 { - label = "loader"; - reg = <0x00000000 0x00080000>; - read-only; - }; - partition@80000 { - label = "user"; - reg = <0x00080000 0x00580000>; - read-only; - }; - partition@600000 { - label = "flash"; - reg = <0x00600000 0x03a00000>; - }; - }; - }; -}; - -&msiof0 { - pinctrl-0 = <&msiof0_pins>; - pinctrl-names = "default"; - - status = "okay"; - - pmic: pmic@0 { - compatible = "renesas,r2a11302ft"; - reg = <0>; - spi-max-frequency = <6000000>; - spi-cpol; - spi-cpha; - }; -}; - -&i2c1 { - pinctrl-0 = <&i2c1_pins>; - pinctrl-names = "i2c-exio1"; -}; - -&i2c2 { - pinctrl-0 = <&i2c2_pins>; - pinctrl-names = "i2c-hdmi"; - - clock-frequency = <100000>; -}; - -&i2c4 { - pinctrl-0 = <&i2c4_pins>; - pinctrl-names = "i2c-exio4"; -}; - -&i2c6 { - pinctrl-names = "default"; - pinctrl-0 = <&pmic_irq_pins>; - status = "okay"; - clock-frequency = <100000>; - - pmic@58 { - compatible = "dlg,da9063"; - reg = <0x58>; - interrupt-parent = <&irqc0>; - interrupts = <2 IRQ_TYPE_LEVEL_LOW>; - interrupt-controller; - - rtc { - compatible = "dlg,da9063-rtc"; - }; - - watchdog { - compatible = "dlg,da9063-watchdog"; - }; - }; - - vdd_dvfs: regulator@68 { - compatible = "dlg,da9210"; - reg = <0x68>; - interrupt-parent = <&irqc0>; - interrupts = <2 IRQ_TYPE_LEVEL_LOW>; - - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-boot-on; - regulator-always-on; - }; -}; - -&pci0 { - status = "okay"; - pinctrl-0 = <&usb0_pins>; - pinctrl-names = "default"; -}; - -&pci1 { - status = "okay"; - pinctrl-0 = <&usb1_pins>; - pinctrl-names = "default"; -}; - -&hsusb { - status = "okay"; - pinctrl-0 = <&usb0_pins>; - pinctrl-names = "default"; - renesas,enable-gpio = <&gpio5 31 GPIO_ACTIVE_HIGH>; -}; - -&usbphy { - status = "okay"; -}; - -&pcie_bus_clk { - clock-frequency = <100000000>; -}; - -&pciec { - status = "okay"; -}; - -&cpu0 { - cpu0-supply = <&vdd_dvfs>; -}; - -/* HDMI video input */ -&vin0 { - status = "okay"; - pinctrl-0 = <&vin0_pins>; - pinctrl-names = "default"; - - port { - vin0ep2: endpoint { - remote-endpoint = <&adv7612_out>; - bus-width = <24>; - hsync-active = <0>; - vsync-active = <0>; - pclk-sample = <1>; - data-active = <1>; - }; - }; -}; - -/* composite video input */ -&vin1 { - status = "okay"; - pinctrl-0 = <&vin1_pins>; - pinctrl-names = "default"; - - port { - vin1ep: endpoint { - remote-endpoint = <&adv7180>; - bus-width = <8>; - }; - }; -}; - -&rcar_sound { - pinctrl-0 = <&sound_pins>, <&sound_clk_pins>; - pinctrl-names = "default"; - - /* Single DAI */ - #sound-dai-cells = <0>; - - status = "okay"; - - rcar_sound,dai { - dai0 { - playback = <&ssi0>, <&src2>, <&dvc0>; - capture = <&ssi1>, <&src3>, <&dvc1>; - }; - }; -}; - -&ssi1 { - shared-pin; -}; diff --git a/arch/arm/dts/r8a7791-porter.dts b/arch/arm/dts/r8a7791-porter.dts deleted file mode 100644 index ec0a20d5130..00000000000 --- a/arch/arm/dts/r8a7791-porter.dts +++ /dev/null @@ -1,523 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the Porter board - * - * Copyright (C) 2015 Cogent Embedded, Inc. - */ - -/* - * SSI-AK4642 - * - * JP3: 2-1: AK4642 - * 2-3: ADV7511 - * - * This command is required before playback/capture: - * - * amixer set "LINEOUT Mixer DACL" on - */ - -/dts-v1/; -#include "r8a7791.dtsi" -#include <dt-bindings/gpio/gpio.h> - -/ { - model = "Porter"; - compatible = "renesas,porter", "renesas,r8a7791"; - - aliases { - serial0 = &scif0; - i2c9 = &gpioi2c2; - i2c10 = &i2chdmi; - mmc0 = &sdhi0; - mmc1 = &sdhi2; - }; - - chosen { - bootargs = "ignore_loglevel rw root=/dev/nfs ip=on"; - stdout-path = "serial0:115200n8"; - }; - - memory@40000000 { - device_type = "memory"; - reg = <0 0x40000000 0 0x40000000>; - }; - - memory@200000000 { - device_type = "memory"; - reg = <2 0x00000000 0 0x40000000>; - }; - - vcc_sdhi0: regulator-vcc-sdhi0 { - compatible = "regulator-fixed"; - - regulator-name = "SDHI0 Vcc"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - }; - - vccq_sdhi0: regulator-vccq-sdhi0 { - compatible = "regulator-gpio"; - - regulator-name = "SDHI0 VccQ"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - - gpios = <&gpio2 12 GPIO_ACTIVE_HIGH>; - gpios-states = <1>; - states = <3300000 1>, <1800000 0>; - }; - - vcc_sdhi2: regulator-vcc-sdhi2 { - compatible = "regulator-fixed"; - - regulator-name = "SDHI2 Vcc"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - }; - - vccq_sdhi2: regulator-vccq-sdhi2 { - compatible = "regulator-gpio"; - - regulator-name = "SDHI2 VccQ"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - - gpios = <&gpio2 26 GPIO_ACTIVE_HIGH>; - gpios-states = <1>; - states = <3300000 1>, <1800000 0>; - }; - - hdmi-out { - compatible = "hdmi-connector"; - type = "a"; - - port { - hdmi_con: endpoint { - remote-endpoint = <&adv7511_out>; - }; - }; - }; - - x3_clk: x3-clock { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <148500000>; - }; - - x16_clk: x16-clock { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <74250000>; - }; - - x14_clk: audio_clock { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <11289600>; - }; - - sound { - compatible = "simple-audio-card"; - - simple-audio-card,format = "left_j"; - simple-audio-card,bitclock-master = <&soundcodec>; - simple-audio-card,frame-master = <&soundcodec>; - - simple-audio-card,cpu { - sound-dai = <&rcar_sound>; - }; - - soundcodec: simple-audio-card,codec { - sound-dai = <&ak4642>; - clocks = <&x14_clk>; - }; - }; - - gpioi2c2: i2c-9 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "i2c-gpio"; - status = "disabled"; - scl-gpios = <&gpio2 6 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; - sda-gpios = <&gpio2 7 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; - i2c-gpio,delay-us = <5>; - }; - - /* - * A fallback to GPIO is provided for I2C2. - */ - i2chdmi: i2c-10 { - compatible = "i2c-demux-pinctrl"; - i2c-parent = <&i2c2>, <&gpioi2c2>; - i2c-bus-name = "i2c-hdmi"; - #address-cells = <1>; - #size-cells = <0>; - - ak4642: codec@12 { - compatible = "asahi-kasei,ak4642"; - #sound-dai-cells = <0>; - reg = <0x12>; - }; - - composite-in@20 { - compatible = "adi,adv7180"; - reg = <0x20>; - - port { - adv7180: endpoint { - bus-width = <8>; - remote-endpoint = <&vin0ep>; - }; - }; - }; - - hdmi@39 { - compatible = "adi,adv7511w"; - reg = <0x39>; - interrupt-parent = <&gpio3>; - interrupts = <29 IRQ_TYPE_LEVEL_LOW>; - - adi,input-depth = <8>; - adi,input-colorspace = "rgb"; - adi,input-clock = "1x"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - adv7511_in: endpoint { - remote-endpoint = <&du_out_rgb>; - }; - }; - - port@1 { - reg = <1>; - adv7511_out: endpoint { - remote-endpoint = <&hdmi_con>; - }; - }; - }; - }; - }; -}; - -&extal_clk { - clock-frequency = <20000000>; -}; - -&pfc { - scif0_pins: scif0 { - groups = "scif0_data_d"; - function = "scif0"; - }; - - ether_pins: ether { - groups = "eth_link", "eth_mdio", "eth_rmii"; - function = "eth"; - }; - - phy1_pins: phy1 { - groups = "intc_irq0"; - function = "intc"; - }; - - pmic_irq_pins: pmicirq { - groups = "intc_irq2"; - function = "intc"; - }; - - sdhi0_pins: sd0 { - groups = "sdhi0_data4", "sdhi0_ctrl"; - function = "sdhi0"; - }; - - sdhi2_pins: sd2 { - groups = "sdhi2_data4", "sdhi2_ctrl"; - function = "sdhi2"; - }; - - qspi_pins: qspi { - groups = "qspi_ctrl", "qspi_data4"; - function = "qspi"; - }; - - i2c2_pins: i2c2 { - groups = "i2c2"; - function = "i2c2"; - }; - - usb0_pins: usb0 { - groups = "usb0"; - function = "usb0"; - }; - - usb1_pins: usb1 { - groups = "usb1"; - function = "usb1"; - }; - - vin0_pins: vin0 { - groups = "vin0_data8", "vin0_clk"; - function = "vin0"; - }; - - can0_pins: can0 { - groups = "can0_data"; - function = "can0"; - }; - - du_pins: du { - groups = "du_rgb888", "du_sync", "du_disp", "du_clk_out_0"; - function = "du"; - }; - - ssi_pins: sound { - groups = "ssi0129_ctrl", "ssi0_data", "ssi1_data"; - function = "ssi"; - }; - - audio_clk_pins: audio_clk { - groups = "audio_clk_a"; - function = "audio_clk"; - }; -}; - -&scif0 { - pinctrl-0 = <&scif0_pins>; - pinctrl-names = "default"; - - status = "okay"; -}; - -ðer { - pinctrl-0 = <ðer_pins>, <&phy1_pins>; - pinctrl-names = "default"; - - phy-handle = <&phy1>; - renesas,ether-link-active-low; - status = "okay"; - - phy1: ethernet-phy@1 { - compatible = "ethernet-phy-id0022.1537", - "ethernet-phy-ieee802.3-c22"; - reg = <1>; - interrupt-parent = <&irqc0>; - interrupts = <0 IRQ_TYPE_LEVEL_LOW>; - micrel,led-mode = <1>; - reset-gpios = <&gpio5 22 GPIO_ACTIVE_LOW>; - }; -}; - -&sdhi0 { - pinctrl-0 = <&sdhi0_pins>; - pinctrl-names = "default"; - - vmmc-supply = <&vcc_sdhi0>; - vqmmc-supply = <&vccq_sdhi0>; - cd-gpios = <&gpio6 6 GPIO_ACTIVE_LOW>; - wp-gpios = <&gpio6 7 GPIO_ACTIVE_HIGH>; - status = "okay"; -}; - -&sdhi2 { - pinctrl-0 = <&sdhi2_pins>; - pinctrl-names = "default"; - - vmmc-supply = <&vcc_sdhi2>; - vqmmc-supply = <&vccq_sdhi2>; - cd-gpios = <&gpio6 22 GPIO_ACTIVE_LOW>; - status = "okay"; -}; - -&qspi { - pinctrl-0 = <&qspi_pins>; - pinctrl-names = "default"; - - status = "okay"; - - flash@0 { - compatible = "spansion,s25fl512s", "jedec,spi-nor"; - reg = <0>; - spi-max-frequency = <30000000>; - spi-tx-bus-width = <4>; - spi-rx-bus-width = <4>; - m25p,fast-read; - - partitions { - compatible = "fixed-partitions"; - #address-cells = <1>; - #size-cells = <1>; - - partition@0 { - label = "loader_prg"; - reg = <0x00000000 0x00040000>; - read-only; - }; - partition@40000 { - label = "user_prg"; - reg = <0x00040000 0x00400000>; - read-only; - }; - partition@440000 { - label = "flash_fs"; - reg = <0x00440000 0x03bc0000>; - }; - }; - }; -}; - -&i2c2 { - pinctrl-0 = <&i2c2_pins>; - pinctrl-names = "i2c-hdmi"; - - clock-frequency = <400000>; -}; - -&i2c6 { - pinctrl-names = "default"; - pinctrl-0 = <&pmic_irq_pins>; - status = "okay"; - clock-frequency = <100000>; - - pmic@5a { - compatible = "dlg,da9063l"; - reg = <0x5a>; - interrupt-parent = <&irqc0>; - interrupts = <2 IRQ_TYPE_LEVEL_LOW>; - interrupt-controller; - - watchdog { - compatible = "dlg,da9063-watchdog"; - }; - }; - - vdd_dvfs: regulator@68 { - compatible = "dlg,da9210"; - reg = <0x68>; - interrupt-parent = <&irqc0>; - interrupts = <2 IRQ_TYPE_LEVEL_LOW>; - - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-boot-on; - regulator-always-on; - }; -}; - -&sata0 { - status = "okay"; -}; - -&cpu0 { - cpu0-supply = <&vdd_dvfs>; -}; - -/* composite video input */ -&vin0 { - status = "okay"; - pinctrl-0 = <&vin0_pins>; - pinctrl-names = "default"; - - port { - vin0ep: endpoint { - remote-endpoint = <&adv7180>; - bus-width = <8>; - }; - }; -}; - -&pci0 { - pinctrl-0 = <&usb0_pins>; - pinctrl-names = "default"; - - status = "okay"; -}; - -&pci1 { - pinctrl-0 = <&usb1_pins>; - pinctrl-names = "default"; - - status = "okay"; -}; - -&hsusb { - pinctrl-0 = <&usb0_pins>; - pinctrl-names = "default"; - - status = "okay"; -}; - -&usbphy { - status = "okay"; -}; - -&pcie_bus_clk { - clock-frequency = <100000000>; -}; - -&pciec { - status = "okay"; -}; - -&can0 { - pinctrl-0 = <&can0_pins>; - pinctrl-names = "default"; - - status = "okay"; -}; - -&du { - pinctrl-0 = <&du_pins>; - pinctrl-names = "default"; - status = "okay"; - - clocks = <&cpg CPG_MOD 724>, <&cpg CPG_MOD 723>, - <&x3_clk>, <&x16_clk>; - clock-names = "du.0", "du.1", "dclkin.0", "dclkin.1"; - - ports { - port@0 { - endpoint { - remote-endpoint = <&adv7511_in>; - }; - }; - }; -}; - -&lvds0 { - ports { - port@1 { - lvds_connector: endpoint { - }; - }; - }; -}; - -&rcar_sound { - pinctrl-0 = <&ssi_pins>, <&audio_clk_pins>; - pinctrl-names = "default"; - status = "okay"; - - /* Single DAI */ - #sound-dai-cells = <0>; - - rcar_sound,dai { - dai0 { - playback = <&ssi0>; - capture = <&ssi1>; - }; - }; -}; - -&rwdt { - timeout-sec = <60>; - status = "okay"; -}; - -&ssi1 { - shared-pin; -}; diff --git a/arch/arm/dts/r8a7791.dtsi b/arch/arm/dts/r8a7791.dtsi deleted file mode 100644 index b9d34147628..00000000000 --- a/arch/arm/dts/r8a7791.dtsi +++ /dev/null @@ -1,1891 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the R-Car M2-W (R8A77910) SoC - * - * Copyright (C) 2013-2015 Renesas Electronics Corporation - * Copyright (C) 2013-2014 Renesas Solutions Corp. - * Copyright (C) 2014 Cogent Embedded Inc. - */ - -#include <dt-bindings/clock/r8a7791-cpg-mssr.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/power/r8a7791-sysc.h> - -/ { - compatible = "renesas,r8a7791"; - #address-cells = <2>; - #size-cells = <2>; - - aliases { - i2c0 = &i2c0; - i2c1 = &i2c1; - i2c2 = &i2c2; - i2c3 = &i2c3; - i2c4 = &i2c4; - i2c5 = &i2c5; - i2c6 = &i2c6; - i2c7 = &i2c7; - i2c8 = &i2c8; - spi0 = &qspi; - spi1 = &msiof0; - spi2 = &msiof1; - spi3 = &msiof2; - vin0 = &vin0; - vin1 = &vin1; - vin2 = &vin2; - }; - - /* - * The external audio clocks are configured as 0 Hz fixed frequency - * clocks by default. - * Boards that provide audio clocks should override them. - */ - audio_clk_a: audio_clk_a { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - audio_clk_b: audio_clk_b { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - audio_clk_c: audio_clk_c { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - /* External CAN clock */ - can_clk: can { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board. */ - clock-frequency = <0>; - }; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - - cpu0: cpu@0 { - device_type = "cpu"; - compatible = "arm,cortex-a15"; - reg = <0>; - clock-frequency = <1500000000>; - clocks = <&cpg CPG_CORE R8A7791_CLK_Z>; - power-domains = <&sysc R8A7791_PD_CA15_CPU0>; - enable-method = "renesas,apmu"; - next-level-cache = <&L2_CA15>; - voltage-tolerance = <1>; /* 1% */ - clock-latency = <300000>; /* 300 us */ - - /* kHz - uV - OPPs unknown yet */ - operating-points = <1500000 1000000>, - <1312500 1000000>, - <1125000 1000000>, - < 937500 1000000>, - < 750000 1000000>, - < 375000 1000000>; - }; - - cpu1: cpu@1 { - device_type = "cpu"; - compatible = "arm,cortex-a15"; - reg = <1>; - clock-frequency = <1500000000>; - clocks = <&cpg CPG_CORE R8A7791_CLK_Z>; - power-domains = <&sysc R8A7791_PD_CA15_CPU1>; - enable-method = "renesas,apmu"; - next-level-cache = <&L2_CA15>; - voltage-tolerance = <1>; /* 1% */ - clock-latency = <300000>; /* 300 us */ - - /* kHz - uV - OPPs unknown yet */ - operating-points = <1500000 1000000>, - <1312500 1000000>, - <1125000 1000000>, - < 937500 1000000>, - < 750000 1000000>, - < 375000 1000000>; - }; - - L2_CA15: cache-controller-0 { - compatible = "cache"; - power-domains = <&sysc R8A7791_PD_CA15_SCU>; - cache-unified; - cache-level = <2>; - }; - }; - - /* External root clock */ - extal_clk: extal { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board. */ - clock-frequency = <0>; - }; - - /* External PCIe clock - can be overridden by the board */ - pcie_bus_clk: pcie_bus { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - pmu { - compatible = "arm,cortex-a15-pmu"; - interrupts-extended = <&gic GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&cpu0>, <&cpu1>; - }; - - /* External SCIF clock */ - scif_clk: scif { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board. */ - clock-frequency = <0>; - }; - - soc { - compatible = "simple-bus"; - interrupt-parent = <&gic>; - - #address-cells = <2>; - #size-cells = <2>; - ranges; - - rwdt: watchdog@e6020000 { - compatible = "renesas,r8a7791-wdt", - "renesas,rcar-gen2-wdt"; - reg = <0 0xe6020000 0 0x0c>; - interrupts = <GIC_SPI 140 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 402>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 402>; - status = "disabled"; - }; - - gpio0: gpio@e6050000 { - compatible = "renesas,gpio-r8a7791", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6050000 0 0x50>; - interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 0 32>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 912>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 912>; - }; - - gpio1: gpio@e6051000 { - compatible = "renesas,gpio-r8a7791", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6051000 0 0x50>; - interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 32 26>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 911>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 911>; - }; - - gpio2: gpio@e6052000 { - compatible = "renesas,gpio-r8a7791", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6052000 0 0x50>; - interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 64 32>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 910>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 910>; - }; - - gpio3: gpio@e6053000 { - compatible = "renesas,gpio-r8a7791", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6053000 0 0x50>; - interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 96 32>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 909>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 909>; - }; - - gpio4: gpio@e6054000 { - compatible = "renesas,gpio-r8a7791", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6054000 0 0x50>; - interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 128 32>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 908>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 908>; - }; - - gpio5: gpio@e6055000 { - compatible = "renesas,gpio-r8a7791", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6055000 0 0x50>; - interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 160 32>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 907>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 907>; - }; - - gpio6: gpio@e6055400 { - compatible = "renesas,gpio-r8a7791", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6055400 0 0x50>; - interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 192 32>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 905>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 905>; - }; - - gpio7: gpio@e6055800 { - compatible = "renesas,gpio-r8a7791", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6055800 0 0x50>; - interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 224 26>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 904>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 904>; - }; - - pfc: pinctrl@e6060000 { - compatible = "renesas,pfc-r8a7791"; - reg = <0 0xe6060000 0 0x250>; - }; - - tpu: pwm@e60f0000 { - compatible = "renesas,tpu-r8a7791", "renesas,tpu"; - reg = <0 0xe60f0000 0 0x148>; - interrupts = <GIC_SPI 135 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 304>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 304>; - #pwm-cells = <3>; - status = "disabled"; - }; - - cpg: clock-controller@e6150000 { - compatible = "renesas,r8a7791-cpg-mssr"; - reg = <0 0xe6150000 0 0x1000>; - clocks = <&extal_clk>, <&usb_extal_clk>; - clock-names = "extal", "usb_extal"; - #clock-cells = <2>; - #power-domain-cells = <0>; - #reset-cells = <1>; - }; - - apmu@e6152000 { - compatible = "renesas,r8a7791-apmu", "renesas,apmu"; - reg = <0 0xe6152000 0 0x188>; - cpus = <&cpu0>, <&cpu1>; - }; - - rst: reset-controller@e6160000 { - compatible = "renesas,r8a7791-rst"; - reg = <0 0xe6160000 0 0x0100>; - }; - - sysc: system-controller@e6180000 { - compatible = "renesas,r8a7791-sysc"; - reg = <0 0xe6180000 0 0x0200>; - #power-domain-cells = <1>; - }; - - irqc0: interrupt-controller@e61c0000 { - compatible = "renesas,irqc-r8a7791", "renesas,irqc"; - #interrupt-cells = <2>; - interrupt-controller; - reg = <0 0xe61c0000 0 0x200>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 407>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 407>; - }; - - thermal: thermal@e61f0000 { - compatible = "renesas,thermal-r8a7791", - "renesas,rcar-gen2-thermal", - "renesas,rcar-thermal"; - reg = <0 0xe61f0000 0 0x10>, <0 0xe61f0100 0 0x38>; - interrupts = <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 522>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 522>; - #thermal-sensor-cells = <0>; - }; - - ipmmu_sy0: iommu@e6280000 { - compatible = "renesas,ipmmu-r8a7791", - "renesas,ipmmu-vmsa"; - reg = <0 0xe6280000 0 0x1000>; - interrupts = <GIC_SPI 223 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 224 IRQ_TYPE_LEVEL_HIGH>; - #iommu-cells = <1>; - status = "disabled"; - }; - - ipmmu_sy1: iommu@e6290000 { - compatible = "renesas,ipmmu-r8a7791", - "renesas,ipmmu-vmsa"; - reg = <0 0xe6290000 0 0x1000>; - interrupts = <GIC_SPI 225 IRQ_TYPE_LEVEL_HIGH>; - #iommu-cells = <1>; - status = "disabled"; - }; - - ipmmu_ds: iommu@e6740000 { - compatible = "renesas,ipmmu-r8a7791", - "renesas,ipmmu-vmsa"; - reg = <0 0xe6740000 0 0x1000>; - interrupts = <GIC_SPI 198 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 199 IRQ_TYPE_LEVEL_HIGH>; - #iommu-cells = <1>; - status = "disabled"; - }; - - ipmmu_mp: iommu@ec680000 { - compatible = "renesas,ipmmu-r8a7791", - "renesas,ipmmu-vmsa"; - reg = <0 0xec680000 0 0x1000>; - interrupts = <GIC_SPI 226 IRQ_TYPE_LEVEL_HIGH>; - #iommu-cells = <1>; - status = "disabled"; - }; - - ipmmu_mx: iommu@fe951000 { - compatible = "renesas,ipmmu-r8a7791", - "renesas,ipmmu-vmsa"; - reg = <0 0xfe951000 0 0x1000>; - interrupts = <GIC_SPI 222 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 221 IRQ_TYPE_LEVEL_HIGH>; - #iommu-cells = <1>; - status = "disabled"; - }; - - ipmmu_rt: iommu@ffc80000 { - compatible = "renesas,ipmmu-r8a7791", - "renesas,ipmmu-vmsa"; - reg = <0 0xffc80000 0 0x1000>; - interrupts = <GIC_SPI 307 IRQ_TYPE_LEVEL_HIGH>; - #iommu-cells = <1>; - status = "disabled"; - }; - - ipmmu_gp: iommu@e62a0000 { - compatible = "renesas,ipmmu-r8a7791", - "renesas,ipmmu-vmsa"; - reg = <0 0xe62a0000 0 0x1000>; - interrupts = <GIC_SPI 260 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 261 IRQ_TYPE_LEVEL_HIGH>; - #iommu-cells = <1>; - status = "disabled"; - }; - - icram0: sram@e63a0000 { - compatible = "mmio-sram"; - reg = <0 0xe63a0000 0 0x12000>; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0 0xe63a0000 0x12000>; - }; - - icram1: sram@e63c0000 { - compatible = "mmio-sram"; - reg = <0 0xe63c0000 0 0x1000>; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0 0xe63c0000 0x1000>; - - smp-sram@0 { - compatible = "renesas,smp-sram"; - reg = <0 0x100>; - }; - }; - - /* The memory map in the User's Manual maps the cores to - * bus numbers - */ - i2c0: i2c@e6508000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a7791", - "renesas,rcar-gen2-i2c"; - reg = <0 0xe6508000 0 0x40>; - interrupts = <GIC_SPI 287 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 931>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 931>; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c1: i2c@e6518000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a7791", - "renesas,rcar-gen2-i2c"; - reg = <0 0xe6518000 0 0x40>; - interrupts = <GIC_SPI 288 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 930>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 930>; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c2: i2c@e6530000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a7791", - "renesas,rcar-gen2-i2c"; - reg = <0 0xe6530000 0 0x40>; - interrupts = <GIC_SPI 286 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 929>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 929>; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c3: i2c@e6540000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a7791", - "renesas,rcar-gen2-i2c"; - reg = <0 0xe6540000 0 0x40>; - interrupts = <GIC_SPI 290 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 928>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 928>; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c4: i2c@e6520000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a7791", - "renesas,rcar-gen2-i2c"; - reg = <0 0xe6520000 0 0x40>; - interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 927>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 927>; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c5: i2c@e6528000 { - /* doesn't need pinmux */ - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a7791", - "renesas,rcar-gen2-i2c"; - reg = <0 0xe6528000 0 0x40>; - interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 925>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 925>; - i2c-scl-internal-delay-ns = <110>; - status = "disabled"; - }; - - i2c6: i2c@e60b0000 { - /* doesn't need pinmux */ - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,iic-r8a7791", - "renesas,rcar-gen2-iic", - "renesas,rmobile-iic"; - reg = <0 0xe60b0000 0 0x425>; - interrupts = <GIC_SPI 173 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 926>; - dmas = <&dmac0 0x77>, <&dmac0 0x78>, - <&dmac1 0x77>, <&dmac1 0x78>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 926>; - status = "disabled"; - }; - - i2c7: i2c@e6500000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,iic-r8a7791", - "renesas,rcar-gen2-iic", - "renesas,rmobile-iic"; - reg = <0 0xe6500000 0 0x425>; - interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 318>; - dmas = <&dmac0 0x61>, <&dmac0 0x62>, - <&dmac1 0x61>, <&dmac1 0x62>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 318>; - status = "disabled"; - }; - - i2c8: i2c@e6510000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,iic-r8a7791", - "renesas,rcar-gen2-iic", - "renesas,rmobile-iic"; - reg = <0 0xe6510000 0 0x425>; - interrupts = <GIC_SPI 175 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 323>; - dmas = <&dmac0 0x65>, <&dmac0 0x66>, - <&dmac1 0x65>, <&dmac1 0x66>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 323>; - status = "disabled"; - }; - - hsusb: usb@e6590000 { - compatible = "renesas,usbhs-r8a7791", - "renesas,rcar-gen2-usbhs"; - reg = <0 0xe6590000 0 0x100>; - interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 704>; - dmas = <&usb_dmac0 0>, <&usb_dmac0 1>, - <&usb_dmac1 0>, <&usb_dmac1 1>; - dma-names = "ch0", "ch1", "ch2", "ch3"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 704>; - renesas,buswait = <4>; - phys = <&usb0 1>; - phy-names = "usb"; - status = "disabled"; - }; - - usbphy: usb-phy-controller@e6590100 { - compatible = "renesas,usb-phy-r8a7791", - "renesas,rcar-gen2-usb-phy"; - reg = <0 0xe6590100 0 0x100>; - #address-cells = <1>; - #size-cells = <0>; - clocks = <&cpg CPG_MOD 704>; - clock-names = "usbhs"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 704>; - status = "disabled"; - - usb0: usb-phy@0 { - reg = <0>; - #phy-cells = <1>; - }; - usb2: usb-phy@2 { - reg = <2>; - #phy-cells = <1>; - }; - }; - - usb_dmac0: dma-controller@e65a0000 { - compatible = "renesas,r8a7791-usb-dmac", - "renesas,usb-dmac"; - reg = <0 0xe65a0000 0 0x100>; - interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1"; - clocks = <&cpg CPG_MOD 330>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 330>; - #dma-cells = <1>; - dma-channels = <2>; - }; - - usb_dmac1: dma-controller@e65b0000 { - compatible = "renesas,r8a7791-usb-dmac", - "renesas,usb-dmac"; - reg = <0 0xe65b0000 0 0x100>; - interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1"; - clocks = <&cpg CPG_MOD 331>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 331>; - #dma-cells = <1>; - dma-channels = <2>; - }; - - dmac0: dma-controller@e6700000 { - compatible = "renesas,dmac-r8a7791", - "renesas,rcar-dmac"; - reg = <0 0xe6700000 0 0x20000>; - interrupts = <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 200 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 201 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 202 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 203 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 204 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 205 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 206 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 207 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 208 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 209 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 210 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 211 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 212 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 213 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 214 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14"; - clocks = <&cpg CPG_MOD 219>; - clock-names = "fck"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 219>; - #dma-cells = <1>; - dma-channels = <15>; - }; - - dmac1: dma-controller@e6720000 { - compatible = "renesas,dmac-r8a7791", - "renesas,rcar-dmac"; - reg = <0 0xe6720000 0 0x20000>; - interrupts = <GIC_SPI 220 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 216 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 217 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 218 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 219 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 308 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 309 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 310 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 311 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 312 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 313 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 314 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 315 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 316 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 317 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 318 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14"; - clocks = <&cpg CPG_MOD 218>; - clock-names = "fck"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 218>; - #dma-cells = <1>; - dma-channels = <15>; - }; - - avb: ethernet@e6800000 { - compatible = "renesas,etheravb-r8a7791", - "renesas,etheravb-rcar-gen2"; - reg = <0 0xe6800000 0 0x800>, <0 0xee0e8000 0 0x4000>; - interrupts = <GIC_SPI 163 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 812>; - clock-names = "fck"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 812>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - qspi: spi@e6b10000 { - compatible = "renesas,qspi-r8a7791", "renesas,qspi"; - reg = <0 0xe6b10000 0 0x2c>; - interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 917>; - dmas = <&dmac0 0x17>, <&dmac0 0x18>, - <&dmac1 0x17>, <&dmac1 0x18>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 917>; - num-cs = <1>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - scifa0: serial@e6c40000 { - compatible = "renesas,scifa-r8a7791", - "renesas,rcar-gen2-scifa", "renesas,scifa"; - reg = <0 0xe6c40000 0 64>; - interrupts = <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 204>; - clock-names = "fck"; - dmas = <&dmac0 0x21>, <&dmac0 0x22>, - <&dmac1 0x21>, <&dmac1 0x22>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 204>; - status = "disabled"; - }; - - scifa1: serial@e6c50000 { - compatible = "renesas,scifa-r8a7791", - "renesas,rcar-gen2-scifa", "renesas,scifa"; - reg = <0 0xe6c50000 0 64>; - interrupts = <GIC_SPI 145 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 203>; - clock-names = "fck"; - dmas = <&dmac0 0x25>, <&dmac0 0x26>, - <&dmac1 0x25>, <&dmac1 0x26>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 203>; - status = "disabled"; - }; - - scifa2: serial@e6c60000 { - compatible = "renesas,scifa-r8a7791", - "renesas,rcar-gen2-scifa", "renesas,scifa"; - reg = <0 0xe6c60000 0 64>; - interrupts = <GIC_SPI 151 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 202>; - clock-names = "fck"; - dmas = <&dmac0 0x27>, <&dmac0 0x28>, - <&dmac1 0x27>, <&dmac1 0x28>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 202>; - status = "disabled"; - }; - - scifa3: serial@e6c70000 { - compatible = "renesas,scifa-r8a7791", - "renesas,rcar-gen2-scifa", "renesas,scifa"; - reg = <0 0xe6c70000 0 64>; - interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 1106>; - clock-names = "fck"; - dmas = <&dmac0 0x1b>, <&dmac0 0x1c>, - <&dmac1 0x1b>, <&dmac1 0x1c>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 1106>; - status = "disabled"; - }; - - scifa4: serial@e6c78000 { - compatible = "renesas,scifa-r8a7791", - "renesas,rcar-gen2-scifa", "renesas,scifa"; - reg = <0 0xe6c78000 0 64>; - interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 1107>; - clock-names = "fck"; - dmas = <&dmac0 0x1f>, <&dmac0 0x20>, - <&dmac1 0x1f>, <&dmac1 0x20>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 1107>; - status = "disabled"; - }; - - scifa5: serial@e6c80000 { - compatible = "renesas,scifa-r8a7791", - "renesas,rcar-gen2-scifa", "renesas,scifa"; - reg = <0 0xe6c80000 0 64>; - interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 1108>; - clock-names = "fck"; - dmas = <&dmac0 0x23>, <&dmac0 0x24>, - <&dmac1 0x23>, <&dmac1 0x24>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 1108>; - status = "disabled"; - }; - - scifb0: serial@e6c20000 { - compatible = "renesas,scifb-r8a7791", - "renesas,rcar-gen2-scifb", "renesas,scifb"; - reg = <0 0xe6c20000 0 0x100>; - interrupts = <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 206>; - clock-names = "fck"; - dmas = <&dmac0 0x3d>, <&dmac0 0x3e>, - <&dmac1 0x3d>, <&dmac1 0x3e>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 206>; - status = "disabled"; - }; - - scifb1: serial@e6c30000 { - compatible = "renesas,scifb-r8a7791", - "renesas,rcar-gen2-scifb", "renesas,scifb"; - reg = <0 0xe6c30000 0 0x100>; - interrupts = <GIC_SPI 149 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 207>; - clock-names = "fck"; - dmas = <&dmac0 0x19>, <&dmac0 0x1a>, - <&dmac1 0x19>, <&dmac1 0x1a>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 207>; - status = "disabled"; - }; - - scifb2: serial@e6ce0000 { - compatible = "renesas,scifb-r8a7791", - "renesas,rcar-gen2-scifb", "renesas,scifb"; - reg = <0 0xe6ce0000 0 0x100>; - interrupts = <GIC_SPI 150 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 216>; - clock-names = "fck"; - dmas = <&dmac0 0x1d>, <&dmac0 0x1e>, - <&dmac1 0x1d>, <&dmac1 0x1e>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 216>; - status = "disabled"; - }; - - scif0: serial@e6e60000 { - compatible = "renesas,scif-r8a7791", - "renesas,rcar-gen2-scif", "renesas,scif"; - reg = <0 0xe6e60000 0 64>; - interrupts = <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 721>, <&cpg CPG_CORE R8A7791_CLK_ZS>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x29>, <&dmac0 0x2a>, - <&dmac1 0x29>, <&dmac1 0x2a>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 721>; - status = "disabled"; - }; - - scif1: serial@e6e68000 { - compatible = "renesas,scif-r8a7791", - "renesas,rcar-gen2-scif", "renesas,scif"; - reg = <0 0xe6e68000 0 64>; - interrupts = <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 720>, <&cpg CPG_CORE R8A7791_CLK_ZS>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x2d>, <&dmac0 0x2e>, - <&dmac1 0x2d>, <&dmac1 0x2e>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 720>; - status = "disabled"; - }; - - scif2: serial@e6e58000 { - compatible = "renesas,scif-r8a7791", - "renesas,rcar-gen2-scif", "renesas,scif"; - reg = <0 0xe6e58000 0 64>; - interrupts = <GIC_SPI 22 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 719>, <&cpg CPG_CORE R8A7791_CLK_ZS>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x2b>, <&dmac0 0x2c>, - <&dmac1 0x2b>, <&dmac1 0x2c>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 719>; - status = "disabled"; - }; - - scif3: serial@e6ea8000 { - compatible = "renesas,scif-r8a7791", - "renesas,rcar-gen2-scif", "renesas,scif"; - reg = <0 0xe6ea8000 0 64>; - interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 718>, <&cpg CPG_CORE R8A7791_CLK_ZS>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x2f>, <&dmac0 0x30>, - <&dmac1 0x2f>, <&dmac1 0x30>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 718>; - status = "disabled"; - }; - - scif4: serial@e6ee0000 { - compatible = "renesas,scif-r8a7791", - "renesas,rcar-gen2-scif", "renesas,scif"; - reg = <0 0xe6ee0000 0 64>; - interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 715>, <&cpg CPG_CORE R8A7791_CLK_ZS>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0xfb>, <&dmac0 0xfc>, - <&dmac1 0xfb>, <&dmac1 0xfc>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 715>; - status = "disabled"; - }; - - scif5: serial@e6ee8000 { - compatible = "renesas,scif-r8a7791", - "renesas,rcar-gen2-scif", "renesas,scif"; - reg = <0 0xe6ee8000 0 64>; - interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 714>, <&cpg CPG_CORE R8A7791_CLK_ZS>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0xfd>, <&dmac0 0xfe>, - <&dmac1 0xfd>, <&dmac1 0xfe>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 714>; - status = "disabled"; - }; - - hscif0: serial@e62c0000 { - compatible = "renesas,hscif-r8a7791", - "renesas,rcar-gen2-hscif", "renesas,hscif"; - reg = <0 0xe62c0000 0 96>; - interrupts = <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 717>, <&cpg CPG_CORE R8A7791_CLK_ZS>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x39>, <&dmac0 0x3a>, - <&dmac1 0x39>, <&dmac1 0x3a>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 717>; - status = "disabled"; - }; - - hscif1: serial@e62c8000 { - compatible = "renesas,hscif-r8a7791", - "renesas,rcar-gen2-hscif", "renesas,hscif"; - reg = <0 0xe62c8000 0 96>; - interrupts = <GIC_SPI 155 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 716>, <&cpg CPG_CORE R8A7791_CLK_ZS>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x4d>, <&dmac0 0x4e>, - <&dmac1 0x4d>, <&dmac1 0x4e>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 716>; - status = "disabled"; - }; - - hscif2: serial@e62d0000 { - compatible = "renesas,hscif-r8a7791", - "renesas,rcar-gen2-hscif", "renesas,hscif"; - reg = <0 0xe62d0000 0 96>; - interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 713>, <&cpg CPG_CORE R8A7791_CLK_ZS>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x3b>, <&dmac0 0x3c>, - <&dmac1 0x3b>, <&dmac1 0x3c>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 713>; - status = "disabled"; - }; - - msiof0: spi@e6e20000 { - compatible = "renesas,msiof-r8a7791", - "renesas,rcar-gen2-msiof"; - reg = <0 0xe6e20000 0 0x0064>; - interrupts = <GIC_SPI 156 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 000>; - dmas = <&dmac0 0x51>, <&dmac0 0x52>, - <&dmac1 0x51>, <&dmac1 0x52>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 0>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof1: spi@e6e10000 { - compatible = "renesas,msiof-r8a7791", - "renesas,rcar-gen2-msiof"; - reg = <0 0xe6e10000 0 0x0064>; - interrupts = <GIC_SPI 157 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 208>; - dmas = <&dmac0 0x55>, <&dmac0 0x56>, - <&dmac1 0x55>, <&dmac1 0x56>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 208>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof2: spi@e6e00000 { - compatible = "renesas,msiof-r8a7791", - "renesas,rcar-gen2-msiof"; - reg = <0 0xe6e00000 0 0x0064>; - interrupts = <GIC_SPI 158 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 205>; - dmas = <&dmac0 0x41>, <&dmac0 0x42>, - <&dmac1 0x41>, <&dmac1 0x42>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 205>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - pwm0: pwm@e6e30000 { - compatible = "renesas,pwm-r8a7791", "renesas,pwm-rcar"; - reg = <0 0xe6e30000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - pwm1: pwm@e6e31000 { - compatible = "renesas,pwm-r8a7791", "renesas,pwm-rcar"; - reg = <0 0xe6e31000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - pwm2: pwm@e6e32000 { - compatible = "renesas,pwm-r8a7791", "renesas,pwm-rcar"; - reg = <0 0xe6e32000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - pwm3: pwm@e6e33000 { - compatible = "renesas,pwm-r8a7791", "renesas,pwm-rcar"; - reg = <0 0xe6e33000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - pwm4: pwm@e6e34000 { - compatible = "renesas,pwm-r8a7791", "renesas,pwm-rcar"; - reg = <0 0xe6e34000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - pwm5: pwm@e6e35000 { - compatible = "renesas,pwm-r8a7791", "renesas,pwm-rcar"; - reg = <0 0xe6e35000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - pwm6: pwm@e6e36000 { - compatible = "renesas,pwm-r8a7791", "renesas,pwm-rcar"; - reg = <0 0xe6e36000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - adc: adc@e6e54000 { - compatible = "renesas,r8a7791-gyroadc", - "renesas,rcar-gyroadc"; - reg = <0 0xe6e54000 0 64>; - clocks = <&cpg CPG_MOD 901>; - clock-names = "fck"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 901>; - status = "disabled"; - }; - - can0: can@e6e80000 { - compatible = "renesas,can-r8a7791", - "renesas,rcar-gen2-can"; - reg = <0 0xe6e80000 0 0x1000>; - interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 916>, - <&cpg CPG_CORE R8A7791_CLK_RCAN>, <&can_clk>; - clock-names = "clkp1", "clkp2", "can_clk"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 916>; - status = "disabled"; - }; - - can1: can@e6e88000 { - compatible = "renesas,can-r8a7791", - "renesas,rcar-gen2-can"; - reg = <0 0xe6e88000 0 0x1000>; - interrupts = <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 915>, - <&cpg CPG_CORE R8A7791_CLK_RCAN>, <&can_clk>; - clock-names = "clkp1", "clkp2", "can_clk"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 915>; - status = "disabled"; - }; - - vin0: video@e6ef0000 { - compatible = "renesas,vin-r8a7791", - "renesas,rcar-gen2-vin"; - reg = <0 0xe6ef0000 0 0x1000>; - interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 811>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 811>; - status = "disabled"; - }; - - vin1: video@e6ef1000 { - compatible = "renesas,vin-r8a7791", - "renesas,rcar-gen2-vin"; - reg = <0 0xe6ef1000 0 0x1000>; - interrupts = <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 810>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 810>; - status = "disabled"; - }; - - vin2: video@e6ef2000 { - compatible = "renesas,vin-r8a7791", - "renesas,rcar-gen2-vin"; - reg = <0 0xe6ef2000 0 0x1000>; - interrupts = <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 809>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 809>; - status = "disabled"; - }; - - rcar_sound: sound@ec500000 { - /* - * #sound-dai-cells is required if simple-card - * - * Single DAI : #sound-dai-cells = <0>; <&rcar_sound>; - * Multi DAI : #sound-dai-cells = <1>; <&rcar_sound N>; - */ - compatible = "renesas,rcar_sound-r8a7791", - "renesas,rcar_sound-gen2"; - reg = <0 0xec500000 0 0x1000>, /* SCU */ - <0 0xec5a0000 0 0x100>, /* ADG */ - <0 0xec540000 0 0x1000>, /* SSIU */ - <0 0xec541000 0 0x280>, /* SSI */ - <0 0xec740000 0 0x200>; /* Audio DMAC peri peri*/ - reg-names = "scu", "adg", "ssiu", "ssi", "audmapp"; - - clocks = <&cpg CPG_MOD 1005>, - <&cpg CPG_MOD 1006>, <&cpg CPG_MOD 1007>, - <&cpg CPG_MOD 1008>, <&cpg CPG_MOD 1009>, - <&cpg CPG_MOD 1010>, <&cpg CPG_MOD 1011>, - <&cpg CPG_MOD 1012>, <&cpg CPG_MOD 1013>, - <&cpg CPG_MOD 1014>, <&cpg CPG_MOD 1015>, - <&cpg CPG_MOD 1022>, <&cpg CPG_MOD 1023>, - <&cpg CPG_MOD 1024>, <&cpg CPG_MOD 1025>, - <&cpg CPG_MOD 1026>, <&cpg CPG_MOD 1027>, - <&cpg CPG_MOD 1028>, <&cpg CPG_MOD 1029>, - <&cpg CPG_MOD 1030>, <&cpg CPG_MOD 1031>, - <&cpg CPG_MOD 1021>, <&cpg CPG_MOD 1020>, - <&cpg CPG_MOD 1021>, <&cpg CPG_MOD 1020>, - <&cpg CPG_MOD 1019>, <&cpg CPG_MOD 1018>, - <&audio_clk_a>, <&audio_clk_b>, <&audio_clk_c>, - <&cpg CPG_CORE R8A7791_CLK_M2>; - clock-names = "ssi-all", - "ssi.9", "ssi.8", "ssi.7", "ssi.6", - "ssi.5", "ssi.4", "ssi.3", "ssi.2", - "ssi.1", "ssi.0", "src.9", "src.8", - "src.7", "src.6", "src.5", "src.4", - "src.3", "src.2", "src.1", "src.0", - "ctu.0", "ctu.1", - "mix.0", "mix.1", - "dvc.0", "dvc.1", - "clk_a", "clk_b", "clk_c", "clk_i"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 1005>, - <&cpg 1006>, <&cpg 1007>, - <&cpg 1008>, <&cpg 1009>, - <&cpg 1010>, <&cpg 1011>, - <&cpg 1012>, <&cpg 1013>, - <&cpg 1014>, <&cpg 1015>; - reset-names = "ssi-all", - "ssi.9", "ssi.8", "ssi.7", "ssi.6", - "ssi.5", "ssi.4", "ssi.3", "ssi.2", - "ssi.1", "ssi.0"; - - status = "disabled"; - - rcar_sound,dvc { - dvc0: dvc-0 { - dmas = <&audma1 0xbc>; - dma-names = "tx"; - }; - dvc1: dvc-1 { - dmas = <&audma1 0xbe>; - dma-names = "tx"; - }; - }; - - rcar_sound,mix { - mix0: mix-0 { }; - mix1: mix-1 { }; - }; - - rcar_sound,ctu { - ctu00: ctu-0 { }; - ctu01: ctu-1 { }; - ctu02: ctu-2 { }; - ctu03: ctu-3 { }; - ctu10: ctu-4 { }; - ctu11: ctu-5 { }; - ctu12: ctu-6 { }; - ctu13: ctu-7 { }; - }; - - rcar_sound,src { - src0: src-0 { - interrupts = <GIC_SPI 352 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x85>, <&audma1 0x9a>; - dma-names = "rx", "tx"; - }; - src1: src-1 { - interrupts = <GIC_SPI 353 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x87>, <&audma1 0x9c>; - dma-names = "rx", "tx"; - }; - src2: src-2 { - interrupts = <GIC_SPI 354 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x89>, <&audma1 0x9e>; - dma-names = "rx", "tx"; - }; - src3: src-3 { - interrupts = <GIC_SPI 355 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x8b>, <&audma1 0xa0>; - dma-names = "rx", "tx"; - }; - src4: src-4 { - interrupts = <GIC_SPI 356 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x8d>, <&audma1 0xb0>; - dma-names = "rx", "tx"; - }; - src5: src-5 { - interrupts = <GIC_SPI 357 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x8f>, <&audma1 0xb2>; - dma-names = "rx", "tx"; - }; - src6: src-6 { - interrupts = <GIC_SPI 358 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x91>, <&audma1 0xb4>; - dma-names = "rx", "tx"; - }; - src7: src-7 { - interrupts = <GIC_SPI 359 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x93>, <&audma1 0xb6>; - dma-names = "rx", "tx"; - }; - src8: src-8 { - interrupts = <GIC_SPI 360 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x95>, <&audma1 0xb8>; - dma-names = "rx", "tx"; - }; - src9: src-9 { - interrupts = <GIC_SPI 361 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x97>, <&audma1 0xba>; - dma-names = "rx", "tx"; - }; - }; - - rcar_sound,ssi { - ssi0: ssi-0 { - interrupts = <GIC_SPI 370 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x01>, <&audma1 0x02>, - <&audma0 0x15>, <&audma1 0x16>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi1: ssi-1 { - interrupts = <GIC_SPI 371 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x03>, <&audma1 0x04>, - <&audma0 0x49>, <&audma1 0x4a>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi2: ssi-2 { - interrupts = <GIC_SPI 372 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x05>, <&audma1 0x06>, - <&audma0 0x63>, <&audma1 0x64>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi3: ssi-3 { - interrupts = <GIC_SPI 373 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x07>, <&audma1 0x08>, - <&audma0 0x6f>, <&audma1 0x70>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi4: ssi-4 { - interrupts = <GIC_SPI 374 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x09>, <&audma1 0x0a>, - <&audma0 0x71>, <&audma1 0x72>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi5: ssi-5 { - interrupts = <GIC_SPI 375 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x0b>, <&audma1 0x0c>, - <&audma0 0x73>, <&audma1 0x74>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi6: ssi-6 { - interrupts = <GIC_SPI 376 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x0d>, <&audma1 0x0e>, - <&audma0 0x75>, <&audma1 0x76>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi7: ssi-7 { - interrupts = <GIC_SPI 377 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x0f>, <&audma1 0x10>, - <&audma0 0x79>, <&audma1 0x7a>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi8: ssi-8 { - interrupts = <GIC_SPI 378 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x11>, <&audma1 0x12>, - <&audma0 0x7b>, <&audma1 0x7c>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi9: ssi-9 { - interrupts = <GIC_SPI 379 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x13>, <&audma1 0x14>, - <&audma0 0x7d>, <&audma1 0x7e>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - }; - }; - - audma0: dma-controller@ec700000 { - compatible = "renesas,dmac-r8a7791", - "renesas,rcar-dmac"; - reg = <0 0xec700000 0 0x10000>; - interrupts = <GIC_SPI 346 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 320 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 321 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 322 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 323 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 324 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 325 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 326 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 327 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 328 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 329 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 330 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 331 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 332 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12"; - clocks = <&cpg CPG_MOD 502>; - clock-names = "fck"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 502>; - #dma-cells = <1>; - dma-channels = <13>; - }; - - audma1: dma-controller@ec720000 { - compatible = "renesas,dmac-r8a7791", - "renesas,rcar-dmac"; - reg = <0 0xec720000 0 0x10000>; - interrupts = <GIC_SPI 347 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 333 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 334 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 335 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 336 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 337 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 338 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 339 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 340 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 341 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 342 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 343 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 344 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 345 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12"; - clocks = <&cpg CPG_MOD 501>; - clock-names = "fck"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 501>; - #dma-cells = <1>; - dma-channels = <13>; - }; - - xhci: usb@ee000000 { - compatible = "renesas,xhci-r8a7791", - "renesas,rcar-gen2-xhci"; - reg = <0 0xee000000 0 0xc00>; - interrupts = <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 328>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 328>; - phys = <&usb2 1>; - phy-names = "usb"; - status = "disabled"; - }; - - pci0: pci@ee090000 { - compatible = "renesas,pci-r8a7791", - "renesas,pci-rcar-gen2"; - device_type = "pci"; - reg = <0 0xee090000 0 0xc00>, - <0 0xee080000 0 0x1100>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 703>; - status = "disabled"; - - bus-range = <0 0>; - #address-cells = <3>; - #size-cells = <2>; - #interrupt-cells = <1>; - ranges = <0x02000000 0 0xee080000 0 0xee080000 0 0x00010000>; - interrupt-map-mask = <0xf800 0 0 0x7>; - interrupt-map = <0x0000 0 0 1 &gic GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>, - <0x0800 0 0 1 &gic GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>, - <0x1000 0 0 2 &gic GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - - usb@1,0 { - reg = <0x800 0 0 0 0>; - phys = <&usb0 0>; - phy-names = "usb"; - }; - - usb@2,0 { - reg = <0x1000 0 0 0 0>; - phys = <&usb0 0>; - phy-names = "usb"; - }; - }; - - pci1: pci@ee0d0000 { - compatible = "renesas,pci-r8a7791", - "renesas,pci-rcar-gen2"; - device_type = "pci"; - reg = <0 0xee0d0000 0 0xc00>, - <0 0xee0c0000 0 0x1100>; - interrupts = <GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 703>; - status = "disabled"; - - bus-range = <1 1>; - #address-cells = <3>; - #size-cells = <2>; - #interrupt-cells = <1>; - ranges = <0x02000000 0 0xee0c0000 0 0xee0c0000 0 0x00010000>; - interrupt-map-mask = <0xf800 0 0 0x7>; - interrupt-map = <0x0000 0 0 1 &gic GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH>, - <0x0800 0 0 1 &gic GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH>, - <0x1000 0 0 2 &gic GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH>; - - usb@1,0 { - reg = <0x10800 0 0 0 0>; - phys = <&usb2 0>; - phy-names = "usb"; - }; - - usb@2,0 { - reg = <0x11000 0 0 0 0>; - phys = <&usb2 0>; - phy-names = "usb"; - }; - }; - - sdhi0: mmc@ee100000 { - compatible = "renesas,sdhi-r8a7791", - "renesas,rcar-gen2-sdhi"; - reg = <0 0xee100000 0 0x328>; - interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 314>; - dmas = <&dmac0 0xcd>, <&dmac0 0xce>, - <&dmac1 0xcd>, <&dmac1 0xce>; - dma-names = "tx", "rx", "tx", "rx"; - max-frequency = <195000000>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 314>; - status = "disabled"; - }; - - sdhi1: mmc@ee140000 { - compatible = "renesas,sdhi-r8a7791", - "renesas,rcar-gen2-sdhi"; - reg = <0 0xee140000 0 0x100>; - interrupts = <GIC_SPI 167 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 312>; - dmas = <&dmac0 0xc1>, <&dmac0 0xc2>, - <&dmac1 0xc1>, <&dmac1 0xc2>; - dma-names = "tx", "rx", "tx", "rx"; - max-frequency = <97500000>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 312>; - status = "disabled"; - }; - - sdhi2: mmc@ee160000 { - compatible = "renesas,sdhi-r8a7791", - "renesas,rcar-gen2-sdhi"; - reg = <0 0xee160000 0 0x100>; - interrupts = <GIC_SPI 168 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 311>; - dmas = <&dmac0 0xd3>, <&dmac0 0xd4>, - <&dmac1 0xd3>, <&dmac1 0xd4>; - dma-names = "tx", "rx", "tx", "rx"; - max-frequency = <97500000>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 311>; - status = "disabled"; - }; - - mmcif0: mmc@ee200000 { - compatible = "renesas,mmcif-r8a7791", - "renesas,sh-mmcif"; - reg = <0 0xee200000 0 0x80>; - interrupts = <GIC_SPI 169 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 315>; - dmas = <&dmac0 0xd1>, <&dmac0 0xd2>, - <&dmac1 0xd1>, <&dmac1 0xd2>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 315>; - reg-io-width = <4>; - status = "disabled"; - max-frequency = <97500000>; - }; - - sata0: sata@ee300000 { - compatible = "renesas,sata-r8a7791", - "renesas,rcar-gen2-sata"; - reg = <0 0xee300000 0 0x200000>; - interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 815>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 815>; - status = "disabled"; - }; - - sata1: sata@ee500000 { - compatible = "renesas,sata-r8a7791", - "renesas,rcar-gen2-sata"; - reg = <0 0xee500000 0 0x200000>; - interrupts = <GIC_SPI 106 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 814>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 814>; - status = "disabled"; - }; - - ether: ethernet@ee700000 { - compatible = "renesas,ether-r8a7791", - "renesas,rcar-gen2-ether"; - reg = <0 0xee700000 0 0x400>; - interrupts = <GIC_SPI 162 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 813>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 813>; - phy-mode = "rmii"; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - gic: interrupt-controller@f1001000 { - compatible = "arm,gic-400"; - #interrupt-cells = <3>; - #address-cells = <0>; - interrupt-controller; - reg = <0 0xf1001000 0 0x1000>, <0 0xf1002000 0 0x2000>, - <0 0xf1004000 0 0x2000>, <0 0xf1006000 0 0x2000>; - interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_HIGH)>; - clocks = <&cpg CPG_MOD 408>; - clock-names = "clk"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 408>; - }; - - pciec: pcie@fe000000 { - compatible = "renesas,pcie-r8a7791", - "renesas,pcie-rcar-gen2"; - reg = <0 0xfe000000 0 0x80000>; - #address-cells = <3>; - #size-cells = <2>; - bus-range = <0x00 0xff>; - device_type = "pci"; - ranges = <0x01000000 0 0x00000000 0 0xfe100000 0 0x00100000>, - <0x02000000 0 0xfe200000 0 0xfe200000 0 0x00200000>, - <0x02000000 0 0x30000000 0 0x30000000 0 0x08000000>, - <0x42000000 0 0x38000000 0 0x38000000 0 0x08000000>; - /* Map all possible DDR as inbound ranges */ - dma-ranges = <0x42000000 0 0x40000000 0 0x40000000 0 0x80000000>, - <0x43000000 2 0x00000000 2 0x00000000 1 0x00000000>; - interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>; - #interrupt-cells = <1>; - interrupt-map-mask = <0 0 0 0>; - interrupt-map = <0 0 0 0 &gic GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 319>, <&pcie_bus_clk>; - clock-names = "pcie", "pcie_bus"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 319>; - status = "disabled"; - }; - - vsp@fe928000 { - compatible = "renesas,vsp1"; - reg = <0 0xfe928000 0 0x8000>; - interrupts = <GIC_SPI 267 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 131>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 131>; - }; - - vsp@fe930000 { - compatible = "renesas,vsp1"; - reg = <0 0xfe930000 0 0x8000>; - interrupts = <GIC_SPI 246 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 128>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 128>; - }; - - vsp@fe938000 { - compatible = "renesas,vsp1"; - reg = <0 0xfe938000 0 0x8000>; - interrupts = <GIC_SPI 247 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 127>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 127>; - }; - - fdp1@fe940000 { - compatible = "renesas,fdp1"; - reg = <0 0xfe940000 0 0x2400>; - interrupts = <GIC_SPI 262 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 119>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 119>; - }; - - fdp1@fe944000 { - compatible = "renesas,fdp1"; - reg = <0 0xfe944000 0 0x2400>; - interrupts = <GIC_SPI 263 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 118>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 118>; - }; - - jpu: jpeg-codec@fe980000 { - compatible = "renesas,jpu-r8a7791", - "renesas,rcar-gen2-jpu"; - reg = <0 0xfe980000 0 0x10300>; - interrupts = <GIC_SPI 272 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 106>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 106>; - }; - - du: display@feb00000 { - compatible = "renesas,du-r8a7791"; - reg = <0 0xfeb00000 0 0x40000>; - interrupts = <GIC_SPI 256 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 268 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 724>, <&cpg CPG_MOD 723>; - clock-names = "du.0", "du.1"; - resets = <&cpg 724>; - reset-names = "du.0"; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - du_out_rgb: endpoint { - }; - }; - port@1 { - reg = <1>; - du_out_lvds0: endpoint { - remote-endpoint = <&lvds0_in>; - }; - }; - }; - }; - - lvds0: lvds@feb90000 { - compatible = "renesas,r8a7791-lvds"; - reg = <0 0xfeb90000 0 0x1c>; - clocks = <&cpg CPG_MOD 726>; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 726>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - lvds0_in: endpoint { - remote-endpoint = <&du_out_lvds0>; - }; - }; - port@1 { - reg = <1>; - lvds0_out: endpoint { - }; - }; - }; - }; - - prr: chipid@ff000044 { - compatible = "renesas,prr"; - reg = <0 0xff000044 0 4>; - }; - - cmt0: timer@ffca0000 { - compatible = "renesas,r8a7791-cmt0", - "renesas,rcar-gen2-cmt0"; - reg = <0 0xffca0000 0 0x1004>; - interrupts = <GIC_SPI 142 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 143 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 124>; - clock-names = "fck"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 124>; - - status = "disabled"; - }; - - cmt1: timer@e6130000 { - compatible = "renesas,r8a7791-cmt1", - "renesas,rcar-gen2-cmt1"; - reg = <0 0xe6130000 0 0x1004>; - interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 127 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 329>; - clock-names = "fck"; - power-domains = <&sysc R8A7791_PD_ALWAYS_ON>; - resets = <&cpg 329>; - - status = "disabled"; - }; - }; - - thermal-zones { - cpu_thermal: cpu-thermal { - polling-delay-passive = <0>; - polling-delay = <0>; - - thermal-sensors = <&thermal>; - - trips { - cpu-crit { - temperature = <95000>; - hysteresis = <0>; - type = "critical"; - }; - }; - cooling-maps { - }; - }; - }; - - timer { - compatible = "arm,armv7-timer"; - interrupts-extended = <&gic GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>; - }; - - /* External USB clock - can be overridden by the board */ - usb_extal_clk: usb_extal { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <48000000>; - }; -}; diff --git a/arch/arm/dts/r8a7792-blanche.dts b/arch/arm/dts/r8a7792-blanche.dts deleted file mode 100644 index 6a83923aa46..00000000000 --- a/arch/arm/dts/r8a7792-blanche.dts +++ /dev/null @@ -1,364 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the Blanche board - * - * Copyright (C) 2014 Renesas Electronics Corporation - * Copyright (C) 2016 Cogent Embedded, Inc. - */ - -/dts-v1/; -#include "r8a7792.dtsi" -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/input/input.h> - -/ { - model = "Blanche"; - compatible = "renesas,blanche", "renesas,r8a7792"; - - aliases { - serial0 = &scif0; - serial1 = &scif3; - }; - - chosen { - bootargs = "ignore_loglevel rw root=/dev/nfs ip=on"; - stdout-path = "serial0:115200n8"; - }; - - memory@40000000 { - device_type = "memory"; - reg = <0 0x40000000 0 0x40000000>; - }; - - d3_3v: regulator-3v3 { - compatible = "regulator-fixed"; - regulator-name = "D3.3V"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - - ethernet@18000000 { - compatible = "smsc,lan89218", "smsc,lan9115"; - reg = <0 0x18000000 0 0x100>; - phy-mode = "mii"; - interrupt-parent = <&irqc>; - interrupts = <0 IRQ_TYPE_EDGE_FALLING>; - smsc,irq-push-pull; - reg-io-width = <4>; - vddvario-supply = <&d3_3v>; - vdd33a-supply = <&d3_3v>; - - pinctrl-0 = <&lan89218_pins>; - pinctrl-names = "default"; - }; - - vga-encoder { - compatible = "adi,adv7123"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - adv7123_in: endpoint { - remote-endpoint = <&du_out_rgb1>; - }; - }; - port@1 { - reg = <1>; - adv7123_out: endpoint { - remote-endpoint = <&vga_in>; - }; - }; - }; - }; - - hdmi-out { - compatible = "hdmi-connector"; - type = "a"; - - port { - hdmi_con: endpoint { - remote-endpoint = <&adv7511_out>; - }; - }; - }; - - vga { - compatible = "vga-connector"; - - port { - vga_in: endpoint { - remote-endpoint = <&adv7123_out>; - }; - }; - }; - - x1_clk: x1 { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <74250000>; - }; - - x2_clk: x2 { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <65000000>; - }; - - keyboard { - compatible = "gpio-keys"; - - pinctrl-0 = <&keyboard_pins>; - pinctrl-names = "default"; - - key-1 { - linux,code = <KEY_1>; - label = "SW2-1"; - wakeup-source; - debounce-interval = <20>; - gpios = <&gpio3 10 GPIO_ACTIVE_LOW>; - }; - key-2 { - linux,code = <KEY_2>; - label = "SW2-2"; - wakeup-source; - debounce-interval = <20>; - gpios = <&gpio3 11 GPIO_ACTIVE_LOW>; - }; - key-3 { - linux,code = <KEY_3>; - label = "SW2-3"; - wakeup-source; - debounce-interval = <20>; - gpios = <&gpio3 12 GPIO_ACTIVE_LOW>; - }; - key-4 { - linux,code = <KEY_4>; - label = "SW2-4"; - wakeup-source; - debounce-interval = <20>; - gpios = <&gpio3 15 GPIO_ACTIVE_LOW>; - }; - key-a { - linux,code = <KEY_A>; - label = "SW24"; - wakeup-source; - debounce-interval = <20>; - gpios = <&gpio3 20 GPIO_ACTIVE_LOW>; - }; - key-b { - linux,code = <KEY_B>; - label = "SW25"; - wakeup-source; - debounce-interval = <20>; - gpios = <&gpio11 2 GPIO_ACTIVE_LOW>; - }; - }; - - leds { - compatible = "gpio-leds"; - - led17 { - gpios = <&gpio10 10 GPIO_ACTIVE_HIGH>; - }; - led18 { - gpios = <&gpio10 11 GPIO_ACTIVE_HIGH>; - }; - led19 { - gpios = <&gpio10 12 GPIO_ACTIVE_HIGH>; - }; - led20 { - gpios = <&gpio10 23 GPIO_ACTIVE_HIGH>; - }; - }; - - vcc_sdhi0: regulator-vcc-sdhi0 { - compatible = "regulator-fixed"; - - regulator-name = "SDHI0 Vcc"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - gpio = <&gpio11 12 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; -}; - -&extal_clk { - clock-frequency = <20000000>; -}; - -&can_clk { - clock-frequency = <48000000>; -}; - -&pfc { - scif0_pins: scif0 { - groups = "scif0_data"; - function = "scif0"; - }; - - scif3_pins: scif3 { - groups = "scif3_data"; - function = "scif3"; - }; - - lan89218_pins: lan89218 { - intc { - groups = "intc_irq0"; - function = "intc"; - }; - lbsc { - groups = "lbsc_ex_cs0"; - function = "lbsc"; - }; - }; - - can0_pins: can0 { - groups = "can0_data", "can_clk"; - function = "can0"; - }; - - sdhi0_pins: sdhi0 { - groups = "sdhi0_data4", "sdhi0_ctrl"; - function = "sdhi0"; - }; - - du0_pins: du0 { - groups = "du0_rgb888", "du0_sync", "du0_disp"; - function = "du0"; - }; - - du1_pins: du1 { - groups = "du1_rgb666", "du1_sync", "du1_disp"; - function = "du1"; - }; - - keyboard_pins: keyboard { - pins = "GP_3_10", "GP_3_11", "GP_3_12", "GP_3_15", "GP_11_2"; - bias-pull-up; - }; - - pmic_irq_pins: pmicirq { - groups = "intc_irq2"; - function = "intc"; - }; -}; - -&rwdt { - timeout-sec = <60>; - status = "okay"; -}; - -&scif0 { - pinctrl-0 = <&scif0_pins>; - pinctrl-names = "default"; - - status = "okay"; -}; - -&scif3 { - pinctrl-0 = <&scif3_pins>; - pinctrl-names = "default"; - - status = "okay"; -}; - -&can0 { - pinctrl-0 = <&can0_pins>; - pinctrl-names = "default"; - - status = "okay"; -}; - -&sdhi0 { - pinctrl-0 = <&sdhi0_pins>; - pinctrl-names = "default"; - - vmmc-supply = <&vcc_sdhi0>; - cd-gpios = <&gpio11 11 GPIO_ACTIVE_LOW>; - status = "okay"; -}; - -&i2c1 { - status = "okay"; - clock-frequency = <400000>; - - hdmi@39 { - compatible = "adi,adv7511w"; - reg = <0x39>; - interrupt-parent = <&irqc>; - interrupts = <3 IRQ_TYPE_EDGE_FALLING>; - - adi,input-depth = <8>; - adi,input-colorspace = "rgb"; - adi,input-clock = "1x"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - adv7511_in: endpoint { - remote-endpoint = <&du_out_rgb0>; - }; - }; - - port@1 { - reg = <1>; - adv7511_out: endpoint { - remote-endpoint = <&hdmi_con>; - }; - }; - }; - }; -}; - -&iic3 { - status = "okay"; - - pmic@58 { - compatible = "dlg,da9063"; - reg = <0x58>; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_irq_pins>; - interrupt-parent = <&irqc>; - interrupts = <2 IRQ_TYPE_LEVEL_LOW>; - interrupt-controller; - - rtc { - compatible = "dlg,da9063-rtc"; - }; - - watchdog { - compatible = "dlg,da9063-watchdog"; - }; - }; -}; - -&du { - pinctrl-0 = <&du0_pins>, <&du1_pins>; - pinctrl-names = "default"; - - clocks = <&cpg CPG_MOD 724>, <&cpg CPG_MOD 723>, <&x1_clk>, <&x2_clk>; - clock-names = "du.0", "du.1", "dclkin.0", "dclkin.1"; - status = "okay"; - - ports { - port@0 { - endpoint { - remote-endpoint = <&adv7511_in>; - }; - }; - port@1 { - endpoint { - remote-endpoint = <&adv7123_in>; - }; - }; - }; -}; diff --git a/arch/arm/dts/r8a7792.dtsi b/arch/arm/dts/r8a7792.dtsi deleted file mode 100644 index a6d9367f8fa..00000000000 --- a/arch/arm/dts/r8a7792.dtsi +++ /dev/null @@ -1,928 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the R-Car V2H (R8A77920) SoC - * - * Copyright (C) 2016 Cogent Embedded Inc. - */ - -#include <dt-bindings/clock/r8a7792-cpg-mssr.h> -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/power/r8a7792-sysc.h> - -/ { - compatible = "renesas,r8a7792"; - #address-cells = <2>; - #size-cells = <2>; - - aliases { - i2c0 = &i2c0; - i2c1 = &i2c1; - i2c2 = &i2c2; - i2c3 = &i2c3; - i2c4 = &i2c4; - i2c5 = &i2c5; - i2c6 = &iic3; - spi0 = &qspi; - spi1 = &msiof0; - spi2 = &msiof1; - vin0 = &vin0; - vin1 = &vin1; - vin2 = &vin2; - vin3 = &vin3; - vin4 = &vin4; - vin5 = &vin5; - }; - - /* External CAN clock */ - can_clk: can { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board. */ - clock-frequency = <0>; - }; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - - cpu0: cpu@0 { - device_type = "cpu"; - compatible = "arm,cortex-a15"; - reg = <0>; - clock-frequency = <1000000000>; - clocks = <&cpg CPG_CORE R8A7792_CLK_Z>; - power-domains = <&sysc R8A7792_PD_CA15_CPU0>; - enable-method = "renesas,apmu"; - next-level-cache = <&L2_CA15>; - }; - - cpu1: cpu@1 { - device_type = "cpu"; - compatible = "arm,cortex-a15"; - reg = <1>; - clock-frequency = <1000000000>; - clocks = <&cpg CPG_CORE R8A7792_CLK_Z>; - power-domains = <&sysc R8A7792_PD_CA15_CPU1>; - enable-method = "renesas,apmu"; - next-level-cache = <&L2_CA15>; - }; - - L2_CA15: cache-controller-0 { - compatible = "cache"; - cache-unified; - cache-level = <2>; - power-domains = <&sysc R8A7792_PD_CA15_SCU>; - }; - }; - - /* External root clock */ - extal_clk: extal { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board. */ - clock-frequency = <0>; - }; - - pmu { - compatible = "arm,cortex-a15-pmu"; - interrupts-extended = <&gic GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&cpu0>, <&cpu1>; - }; - - /* External SCIF clock */ - scif_clk: scif { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board. */ - clock-frequency = <0>; - }; - - soc { - compatible = "simple-bus"; - interrupt-parent = <&gic>; - - #address-cells = <2>; - #size-cells = <2>; - ranges; - - rwdt: watchdog@e6020000 { - compatible = "renesas,r8a7792-wdt", - "renesas,rcar-gen2-wdt"; - reg = <0 0xe6020000 0 0x0c>; - interrupts = <GIC_SPI 140 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 402>; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 402>; - status = "disabled"; - }; - - gpio0: gpio@e6050000 { - compatible = "renesas,gpio-r8a7792", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6050000 0 0x50>; - interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 0 29>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 912>; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 912>; - }; - - gpio1: gpio@e6051000 { - compatible = "renesas,gpio-r8a7792", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6051000 0 0x50>; - interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 32 23>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 911>; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 911>; - }; - - gpio2: gpio@e6052000 { - compatible = "renesas,gpio-r8a7792", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6052000 0 0x50>; - interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 64 32>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 910>; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 910>; - }; - - gpio3: gpio@e6053000 { - compatible = "renesas,gpio-r8a7792", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6053000 0 0x50>; - interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 96 28>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 909>; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 909>; - }; - - gpio4: gpio@e6054000 { - compatible = "renesas,gpio-r8a7792", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6054000 0 0x50>; - interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 128 17>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 908>; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 908>; - }; - - gpio5: gpio@e6055000 { - compatible = "renesas,gpio-r8a7792", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6055000 0 0x50>; - interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 160 17>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 907>; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 907>; - }; - - gpio6: gpio@e6055100 { - compatible = "renesas,gpio-r8a7792", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6055100 0 0x50>; - interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 192 17>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 905>; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 905>; - }; - - gpio7: gpio@e6055200 { - compatible = "renesas,gpio-r8a7792", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6055200 0 0x50>; - interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 224 17>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 904>; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 904>; - }; - - gpio8: gpio@e6055300 { - compatible = "renesas,gpio-r8a7792", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6055300 0 0x50>; - interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 256 17>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 921>; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 921>; - }; - - gpio9: gpio@e6055400 { - compatible = "renesas,gpio-r8a7792", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6055400 0 0x50>; - interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 288 17>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 919>; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 919>; - }; - - gpio10: gpio@e6055500 { - compatible = "renesas,gpio-r8a7792", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6055500 0 0x50>; - interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 320 32>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 914>; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 914>; - }; - - gpio11: gpio@e6055600 { - compatible = "renesas,gpio-r8a7792", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6055600 0 0x50>; - interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 352 30>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 913>; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 913>; - }; - - pfc: pinctrl@e6060000 { - compatible = "renesas,pfc-r8a7792"; - reg = <0 0xe6060000 0 0x144>; - }; - - cpg: clock-controller@e6150000 { - compatible = "renesas,r8a7792-cpg-mssr"; - reg = <0 0xe6150000 0 0x1000>; - clocks = <&extal_clk>; - clock-names = "extal"; - #clock-cells = <2>; - #power-domain-cells = <0>; - #reset-cells = <1>; - }; - - apmu@e6152000 { - compatible = "renesas,r8a7792-apmu", "renesas,apmu"; - reg = <0 0xe6152000 0 0x188>; - cpus = <&cpu0>, <&cpu1>; - }; - - rst: reset-controller@e6160000 { - compatible = "renesas,r8a7792-rst"; - reg = <0 0xe6160000 0 0x0100>; - }; - - sysc: system-controller@e6180000 { - compatible = "renesas,r8a7792-sysc"; - reg = <0 0xe6180000 0 0x0200>; - #power-domain-cells = <1>; - }; - - irqc: interrupt-controller@e61c0000 { - compatible = "renesas,irqc-r8a7792", "renesas,irqc"; - #interrupt-cells = <2>; - interrupt-controller; - reg = <0 0xe61c0000 0 0x200>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 407>; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 407>; - }; - - icram0: sram@e63a0000 { - compatible = "mmio-sram"; - reg = <0 0xe63a0000 0 0x12000>; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0 0xe63a0000 0x12000>; - }; - - icram1: sram@e63c0000 { - compatible = "mmio-sram"; - reg = <0 0xe63c0000 0 0x1000>; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0 0xe63c0000 0x1000>; - - smp-sram@0 { - compatible = "renesas,smp-sram"; - reg = <0 0x100>; - }; - }; - - /* I2C doesn't need pinmux */ - i2c0: i2c@e6508000 { - compatible = "renesas,i2c-r8a7792", - "renesas,rcar-gen2-i2c"; - reg = <0 0xe6508000 0 0x40>; - interrupts = <GIC_SPI 287 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 931>; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 931>; - i2c-scl-internal-delay-ns = <6>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c1: i2c@e6518000 { - compatible = "renesas,i2c-r8a7792", - "renesas,rcar-gen2-i2c"; - reg = <0 0xe6518000 0 0x40>; - interrupts = <GIC_SPI 288 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 930>; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 930>; - i2c-scl-internal-delay-ns = <6>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c2: i2c@e6530000 { - compatible = "renesas,i2c-r8a7792", - "renesas,rcar-gen2-i2c"; - reg = <0 0xe6530000 0 0x40>; - interrupts = <GIC_SPI 286 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 929>; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 929>; - i2c-scl-internal-delay-ns = <6>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c3: i2c@e6540000 { - compatible = "renesas,i2c-r8a7792", - "renesas,rcar-gen2-i2c"; - reg = <0 0xe6540000 0 0x40>; - interrupts = <GIC_SPI 290 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 928>; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 928>; - i2c-scl-internal-delay-ns = <6>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c4: i2c@e6520000 { - compatible = "renesas,i2c-r8a7792", - "renesas,rcar-gen2-i2c"; - reg = <0 0xe6520000 0 0x40>; - interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 927>; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 927>; - i2c-scl-internal-delay-ns = <6>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c5: i2c@e6528000 { - compatible = "renesas,i2c-r8a7792", - "renesas,rcar-gen2-i2c"; - reg = <0 0xe6528000 0 0x40>; - interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 925>; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 925>; - i2c-scl-internal-delay-ns = <110>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - iic3: i2c@e60b0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,iic-r8a7792", - "renesas,rcar-gen2-iic", - "renesas,rmobile-iic"; - reg = <0 0xe60b0000 0 0x425>; - interrupts = <GIC_SPI 173 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 926>; - dmas = <&dmac0 0x77>, <&dmac0 0x78>, - <&dmac1 0x77>, <&dmac1 0x78>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 926>; - status = "disabled"; - }; - - dmac0: dma-controller@e6700000 { - compatible = "renesas,dmac-r8a7792", - "renesas,rcar-dmac"; - reg = <0 0xe6700000 0 0x20000>; - interrupts = <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 200 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 201 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 202 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 203 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 204 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 205 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 206 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 207 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 208 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 209 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 210 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 211 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 212 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 213 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 214 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14"; - clocks = <&cpg CPG_MOD 219>; - clock-names = "fck"; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 219>; - #dma-cells = <1>; - dma-channels = <15>; - }; - - dmac1: dma-controller@e6720000 { - compatible = "renesas,dmac-r8a7792", - "renesas,rcar-dmac"; - reg = <0 0xe6720000 0 0x20000>; - interrupts = <GIC_SPI 220 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 216 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 217 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 218 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 219 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 308 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 309 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 310 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 311 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 312 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 313 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 314 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 315 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 316 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 317 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 318 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14"; - clocks = <&cpg CPG_MOD 218>; - clock-names = "fck"; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 218>; - #dma-cells = <1>; - dma-channels = <15>; - }; - - avb: ethernet@e6800000 { - compatible = "renesas,etheravb-r8a7792", - "renesas,etheravb-rcar-gen2"; - reg = <0 0xe6800000 0 0x800>, <0 0xee0e8000 0 0x4000>; - interrupts = <GIC_SPI 163 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 812>; - clock-names = "fck"; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 812>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - qspi: spi@e6b10000 { - compatible = "renesas,qspi-r8a7792", "renesas,qspi"; - reg = <0 0xe6b10000 0 0x2c>; - interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 917>; - dmas = <&dmac0 0x17>, <&dmac0 0x18>, - <&dmac1 0x17>, <&dmac1 0x18>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 917>; - num-cs = <1>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - scif0: serial@e6e60000 { - compatible = "renesas,scif-r8a7792", - "renesas,rcar-gen2-scif", "renesas,scif"; - reg = <0 0xe6e60000 0 64>; - interrupts = <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 721>, - <&cpg CPG_CORE R8A7792_CLK_ZS>, <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x29>, <&dmac0 0x2a>, - <&dmac1 0x29>, <&dmac1 0x2a>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 721>; - status = "disabled"; - }; - - scif1: serial@e6e68000 { - compatible = "renesas,scif-r8a7792", - "renesas,rcar-gen2-scif", "renesas,scif"; - reg = <0 0xe6e68000 0 64>; - interrupts = <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 720>, - <&cpg CPG_CORE R8A7792_CLK_ZS>, <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x2d>, <&dmac0 0x2e>, - <&dmac1 0x2d>, <&dmac1 0x2e>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 720>; - status = "disabled"; - }; - - scif2: serial@e6e58000 { - compatible = "renesas,scif-r8a7792", - "renesas,rcar-gen2-scif", "renesas,scif"; - reg = <0 0xe6e58000 0 64>; - interrupts = <GIC_SPI 22 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 719>, - <&cpg CPG_CORE R8A7792_CLK_ZS>, <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x2b>, <&dmac0 0x2c>, - <&dmac1 0x2b>, <&dmac1 0x2c>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 719>; - status = "disabled"; - }; - - scif3: serial@e6ea8000 { - compatible = "renesas,scif-r8a7792", - "renesas,rcar-gen2-scif", "renesas,scif"; - reg = <0 0xe6ea8000 0 64>; - interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 718>, - <&cpg CPG_CORE R8A7792_CLK_ZS>, <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x2f>, <&dmac0 0x30>, - <&dmac1 0x2f>, <&dmac1 0x30>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 718>; - status = "disabled"; - }; - - hscif0: serial@e62c0000 { - compatible = "renesas,hscif-r8a7792", - "renesas,rcar-gen2-hscif", "renesas,hscif"; - reg = <0 0xe62c0000 0 96>; - interrupts = <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 717>, - <&cpg CPG_CORE R8A7792_CLK_ZS>, <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x39>, <&dmac0 0x3a>, - <&dmac1 0x39>, <&dmac1 0x3a>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 717>; - status = "disabled"; - }; - - hscif1: serial@e62c8000 { - compatible = "renesas,hscif-r8a7792", - "renesas,rcar-gen2-hscif", "renesas,hscif"; - reg = <0 0xe62c8000 0 96>; - interrupts = <GIC_SPI 155 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 716>, - <&cpg CPG_CORE R8A7792_CLK_ZS>, <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x4d>, <&dmac0 0x4e>, - <&dmac1 0x4d>, <&dmac1 0x4e>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 716>; - status = "disabled"; - }; - - msiof0: spi@e6e20000 { - compatible = "renesas,msiof-r8a7792", - "renesas,rcar-gen2-msiof"; - reg = <0 0xe6e20000 0 0x0064>; - interrupts = <GIC_SPI 156 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 000>; - dmas = <&dmac0 0x51>, <&dmac0 0x52>, - <&dmac1 0x51>, <&dmac1 0x52>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 000>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof1: spi@e6e10000 { - compatible = "renesas,msiof-r8a7792", - "renesas,rcar-gen2-msiof"; - reg = <0 0xe6e10000 0 0x0064>; - interrupts = <GIC_SPI 157 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 208>; - dmas = <&dmac0 0x55>, <&dmac0 0x56>, - <&dmac1 0x55>, <&dmac1 0x56>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 208>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - can0: can@e6e80000 { - compatible = "renesas,can-r8a7792", - "renesas,rcar-gen2-can"; - reg = <0 0xe6e80000 0 0x1000>; - interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 916>, - <&cpg CPG_CORE R8A7792_CLK_RCAN>, <&can_clk>; - clock-names = "clkp1", "clkp2", "can_clk"; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 916>; - status = "disabled"; - }; - - can1: can@e6e88000 { - compatible = "renesas,can-r8a7792", - "renesas,rcar-gen2-can"; - reg = <0 0xe6e88000 0 0x1000>; - interrupts = <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 915>, - <&cpg CPG_CORE R8A7792_CLK_RCAN>, <&can_clk>; - clock-names = "clkp1", "clkp2", "can_clk"; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 915>; - status = "disabled"; - }; - - vin0: video@e6ef0000 { - compatible = "renesas,vin-r8a7792", - "renesas,rcar-gen2-vin"; - reg = <0 0xe6ef0000 0 0x1000>; - interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 811>; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 811>; - status = "disabled"; - }; - - vin1: video@e6ef1000 { - compatible = "renesas,vin-r8a7792", - "renesas,rcar-gen2-vin"; - reg = <0 0xe6ef1000 0 0x1000>; - interrupts = <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 810>; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 810>; - status = "disabled"; - }; - - vin2: video@e6ef2000 { - compatible = "renesas,vin-r8a7792", - "renesas,rcar-gen2-vin"; - reg = <0 0xe6ef2000 0 0x1000>; - interrupts = <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 809>; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 809>; - status = "disabled"; - }; - - vin3: video@e6ef3000 { - compatible = "renesas,vin-r8a7792", - "renesas,rcar-gen2-vin"; - reg = <0 0xe6ef3000 0 0x1000>; - interrupts = <GIC_SPI 191 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 808>; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 808>; - status = "disabled"; - }; - - vin4: video@e6ef4000 { - compatible = "renesas,vin-r8a7792", - "renesas,rcar-gen2-vin"; - reg = <0 0xe6ef4000 0 0x1000>; - interrupts = <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 805>; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 805>; - status = "disabled"; - }; - - vin5: video@e6ef5000 { - compatible = "renesas,vin-r8a7792", - "renesas,rcar-gen2-vin"; - reg = <0 0xe6ef5000 0 0x1000>; - interrupts = <GIC_SPI 145 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 804>; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 804>; - status = "disabled"; - }; - - sdhi0: mmc@ee100000 { - compatible = "renesas,sdhi-r8a7792", - "renesas,rcar-gen2-sdhi"; - reg = <0 0xee100000 0 0x328>; - interrupts = <0 165 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&dmac0 0xcd>, <&dmac0 0xce>, - <&dmac1 0xcd>, <&dmac1 0xce>; - dma-names = "tx", "rx", "tx", "rx"; - clocks = <&cpg CPG_MOD 314>; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 314>; - status = "disabled"; - }; - - gic: interrupt-controller@f1001000 { - compatible = "arm,gic-400"; - #interrupt-cells = <3>; - interrupt-controller; - reg = <0 0xf1001000 0 0x1000>, - <0 0xf1002000 0 0x2000>, - <0 0xf1004000 0 0x2000>, - <0 0xf1006000 0 0x2000>; - interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(2) | - IRQ_TYPE_LEVEL_HIGH)>; - clocks = <&cpg CPG_MOD 408>; - clock-names = "clk"; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 408>; - }; - - vsp@fe928000 { - compatible = "renesas,vsp1"; - reg = <0 0xfe928000 0 0x8000>; - interrupts = <GIC_SPI 267 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 131>; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 131>; - }; - - vsp@fe930000 { - compatible = "renesas,vsp1"; - reg = <0 0xfe930000 0 0x8000>; - interrupts = <GIC_SPI 246 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 128>; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 128>; - }; - - vsp@fe938000 { - compatible = "renesas,vsp1"; - reg = <0 0xfe938000 0 0x8000>; - interrupts = <GIC_SPI 247 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 127>; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 127>; - }; - - jpu: jpeg-codec@fe980000 { - compatible = "renesas,jpu-r8a7792", - "renesas,rcar-gen2-jpu"; - reg = <0 0xfe980000 0 0x10300>; - interrupts = <GIC_SPI 272 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 106>; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 106>; - }; - - du: display@feb00000 { - compatible = "renesas,du-r8a7792"; - reg = <0 0xfeb00000 0 0x40000>; - interrupts = <GIC_SPI 256 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 268 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 724>, <&cpg CPG_MOD 723>; - clock-names = "du.0", "du.1"; - resets = <&cpg 724>; - reset-names = "du.0"; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - du_out_rgb0: endpoint { - }; - }; - port@1 { - reg = <1>; - du_out_rgb1: endpoint { - }; - }; - }; - }; - - prr: chipid@ff000044 { - compatible = "renesas,prr"; - reg = <0 0xff000044 0 4>; - }; - - cmt0: timer@ffca0000 { - compatible = "renesas,r8a7792-cmt0", - "renesas,rcar-gen2-cmt0"; - reg = <0 0xffca0000 0 0x1004>; - interrupts = <GIC_SPI 142 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 143 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 124>; - clock-names = "fck"; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 124>; - - status = "disabled"; - }; - - cmt1: timer@e6130000 { - compatible = "renesas,r8a7792-cmt1", - "renesas,rcar-gen2-cmt1"; - reg = <0 0xe6130000 0 0x1004>; - interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 127 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 329>; - clock-names = "fck"; - power-domains = <&sysc R8A7792_PD_ALWAYS_ON>; - resets = <&cpg 329>; - - status = "disabled"; - }; - }; - - timer { - compatible = "arm,armv7-timer"; - interrupts-extended = <&gic GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>; - }; -}; diff --git a/arch/arm/dts/r8a7793-gose.dts b/arch/arm/dts/r8a7793-gose.dts deleted file mode 100644 index 79b537b2464..00000000000 --- a/arch/arm/dts/r8a7793-gose.dts +++ /dev/null @@ -1,818 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the Gose board - * - * Copyright (C) 2014-2015 Renesas Electronics Corporation - */ - -/* - * SSI-AK4643 - * - * SW1: 1: AK4643 - * 2: CN22 - * 3: ADV7511 - * - * This command is required when Playback/Capture - * - * amixer set "LINEOUT Mixer DACL" on - * amixer set "DVC Out" 100% - * amixer set "DVC In" 100% - * - * You can use Mute - * - * amixer set "DVC Out Mute" on - * amixer set "DVC In Mute" on - * - * You can use Volume Ramp - * - * amixer set "DVC Out Ramp Up Rate" "0.125 dB/64 steps" - * amixer set "DVC Out Ramp Down Rate" "0.125 dB/512 steps" - * amixer set "DVC Out Ramp" on - * aplay xxx.wav & - * amixer set "DVC Out" 80% // Volume Down - * amixer set "DVC Out" 100% // Volume Up - */ - -/dts-v1/; -#include "r8a7793.dtsi" -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/input/input.h> - -/ { - model = "Gose"; - compatible = "renesas,gose", "renesas,r8a7793"; - - aliases { - serial0 = &scif0; - serial1 = &scif1; - i2c9 = &gpioi2c2; - i2c10 = &gpioi2c4; - i2c11 = &i2chdmi; - i2c12 = &i2cexio4; - mmc0 = &sdhi0; - mmc1 = &sdhi1; - mmc2 = &sdhi2; - }; - - chosen { - bootargs = "ignore_loglevel rw root=/dev/nfs ip=on"; - stdout-path = "serial0:115200n8"; - }; - - memory@40000000 { - device_type = "memory"; - reg = <0 0x40000000 0 0x40000000>; - }; - - keyboard { - compatible = "gpio-keys"; - - pinctrl-0 = <&keyboard_pins>; - pinctrl-names = "default"; - - key-1 { - gpios = <&gpio5 0 GPIO_ACTIVE_LOW>; - linux,code = <KEY_1>; - label = "SW2-1"; - wakeup-source; - debounce-interval = <20>; - }; - key-2 { - gpios = <&gpio5 1 GPIO_ACTIVE_LOW>; - linux,code = <KEY_2>; - label = "SW2-2"; - wakeup-source; - debounce-interval = <20>; - }; - key-3 { - gpios = <&gpio5 2 GPIO_ACTIVE_LOW>; - linux,code = <KEY_3>; - label = "SW2-3"; - wakeup-source; - debounce-interval = <20>; - }; - key-4 { - gpios = <&gpio5 3 GPIO_ACTIVE_LOW>; - linux,code = <KEY_4>; - label = "SW2-4"; - wakeup-source; - debounce-interval = <20>; - }; - key-a { - gpios = <&gpio7 0 GPIO_ACTIVE_LOW>; - linux,code = <KEY_A>; - label = "SW30"; - wakeup-source; - debounce-interval = <20>; - }; - key-b { - gpios = <&gpio7 1 GPIO_ACTIVE_LOW>; - linux,code = <KEY_B>; - label = "SW31"; - wakeup-source; - debounce-interval = <20>; - }; - key-c { - gpios = <&gpio7 2 GPIO_ACTIVE_LOW>; - linux,code = <KEY_C>; - label = "SW32"; - wakeup-source; - debounce-interval = <20>; - }; - key-d { - gpios = <&gpio7 3 GPIO_ACTIVE_LOW>; - linux,code = <KEY_D>; - label = "SW33"; - wakeup-source; - debounce-interval = <20>; - }; - key-e { - gpios = <&gpio7 4 GPIO_ACTIVE_LOW>; - linux,code = <KEY_E>; - label = "SW34"; - wakeup-source; - debounce-interval = <20>; - }; - key-f { - gpios = <&gpio7 5 GPIO_ACTIVE_LOW>; - linux,code = <KEY_F>; - label = "SW35"; - wakeup-source; - debounce-interval = <20>; - }; - key-g { - gpios = <&gpio7 6 GPIO_ACTIVE_LOW>; - linux,code = <KEY_G>; - label = "SW36"; - wakeup-source; - debounce-interval = <20>; - }; - }; - - leds { - compatible = "gpio-leds"; - led6 { - gpios = <&gpio2 19 GPIO_ACTIVE_HIGH>; - label = "LED6"; - }; - led7 { - gpios = <&gpio2 20 GPIO_ACTIVE_HIGH>; - label = "LED7"; - }; - led8 { - gpios = <&gpio2 21 GPIO_ACTIVE_HIGH>; - label = "LED8"; - }; - }; - - vcc_sdhi0: regulator-vcc-sdhi0 { - compatible = "regulator-fixed"; - - regulator-name = "SDHI0 Vcc"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - gpio = <&gpio7 17 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; - - vccq_sdhi0: regulator-vccq-sdhi0 { - compatible = "regulator-gpio"; - - regulator-name = "SDHI0 VccQ"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - - gpios = <&gpio2 12 GPIO_ACTIVE_HIGH>; - gpios-states = <1>; - states = <3300000 1>, <1800000 0>; - }; - - vcc_sdhi1: regulator-vcc-sdhi1 { - compatible = "regulator-fixed"; - - regulator-name = "SDHI1 Vcc"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - gpio = <&gpio7 18 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; - - vccq_sdhi1: regulator-vccq-sdhi1 { - compatible = "regulator-gpio"; - - regulator-name = "SDHI1 VccQ"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - - gpios = <&gpio2 13 GPIO_ACTIVE_HIGH>; - gpios-states = <1>; - states = <3300000 1>, <1800000 0>; - }; - - vcc_sdhi2: regulator-vcc-sdhi2 { - compatible = "regulator-fixed"; - - regulator-name = "SDHI2 Vcc"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - gpio = <&gpio7 19 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; - - vccq_sdhi2: regulator-vccq-sdhi2 { - compatible = "regulator-gpio"; - - regulator-name = "SDHI2 VccQ"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - - gpios = <&gpio2 26 GPIO_ACTIVE_HIGH>; - gpios-states = <1>; - states = <3300000 1>, <1800000 0>; - }; - - audio_clock: audio_clock { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <11289600>; - }; - - rsnd_ak4643: sound { - compatible = "simple-audio-card"; - - simple-audio-card,format = "left_j"; - simple-audio-card,bitclock-master = <&sndcodec>; - simple-audio-card,frame-master = <&sndcodec>; - - sndcpu: simple-audio-card,cpu { - sound-dai = <&rcar_sound>; - }; - - sndcodec: simple-audio-card,codec { - sound-dai = <&ak4643>; - clocks = <&audio_clock>; - }; - }; - - hdmi-in { - compatible = "hdmi-connector"; - type = "a"; - - port { - hdmi_con_in: endpoint { - remote-endpoint = <&adv7612_in>; - }; - }; - }; - - hdmi-out { - compatible = "hdmi-connector"; - type = "a"; - - port { - hdmi_con_out: endpoint { - remote-endpoint = <&adv7511_out>; - }; - }; - }; - - composite-in { - compatible = "composite-video-connector"; - - port { - composite_con_in: endpoint { - remote-endpoint = <&adv7180_in>; - }; - }; - }; - - x2_clk: x2-clock { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <74250000>; - }; - - x13_clk: x13-clock { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <148500000>; - }; - - gpioi2c2: i2c-9 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "i2c-gpio"; - status = "disabled"; - scl-gpios = <&gpio2 6 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; - sda-gpios = <&gpio2 7 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; - i2c-gpio,delay-us = <5>; - }; - - gpioi2c4: i2c-10 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "i2c-gpio"; - status = "disabled"; - scl-gpios = <&gpio7 13 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; - sda-gpios = <&gpio7 14 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; - i2c-gpio,delay-us = <5>; - }; - - /* - * A fallback to GPIO is provided for I2C2. - */ - i2chdmi: i2c-11 { - compatible = "i2c-demux-pinctrl"; - i2c-parent = <&i2c2>, <&gpioi2c2>; - i2c-bus-name = "i2c-hdmi"; - #address-cells = <1>; - #size-cells = <0>; - - ak4643: codec@12 { - compatible = "asahi-kasei,ak4643"; - #sound-dai-cells = <0>; - reg = <0x12>; - }; - - composite-in@20 { - compatible = "adi,adv7180cp"; - reg = <0x20>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - adv7180_in: endpoint { - remote-endpoint = <&composite_con_in>; - }; - }; - - port@3 { - reg = <3>; - adv7180_out: endpoint { - bus-width = <8>; - remote-endpoint = <&vin1ep>; - }; - }; - }; - }; - - hdmi@39 { - compatible = "adi,adv7511w"; - reg = <0x39>; - interrupt-parent = <&gpio3>; - interrupts = <29 IRQ_TYPE_LEVEL_LOW>; - - adi,input-depth = <8>; - adi,input-colorspace = "rgb"; - adi,input-clock = "1x"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - adv7511_in: endpoint { - remote-endpoint = <&du_out_rgb>; - }; - }; - - port@1 { - reg = <1>; - adv7511_out: endpoint { - remote-endpoint = <&hdmi_con_out>; - }; - }; - }; - }; - - hdmi-in@4c { - compatible = "adi,adv7612"; - reg = <0x4c>; - interrupt-parent = <&gpio4>; - interrupts = <2 IRQ_TYPE_LEVEL_LOW>; - default-input = <0>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - adv7612_in: endpoint { - remote-endpoint = <&hdmi_con_in>; - }; - }; - - port@2 { - reg = <2>; - adv7612_out: endpoint { - remote-endpoint = <&vin0ep2>; - }; - }; - }; - }; - - eeprom@50 { - compatible = "renesas,r1ex24002", "atmel,24c02"; - reg = <0x50>; - pagesize = <16>; - }; - }; - - /* - * I2C4 is routed to EXIO connector E, pins 37 (SCL) + 39 (SDA). - * A fallback to GPIO is provided. - */ - i2cexio4: i2c-12 { - compatible = "i2c-demux-pinctrl"; - i2c-parent = <&i2c4>, <&gpioi2c4>; - i2c-bus-name = "i2c-exio4"; - #address-cells = <1>; - #size-cells = <0>; - }; -}; - -&du { - pinctrl-0 = <&du_pins>; - pinctrl-names = "default"; - status = "okay"; - - clocks = <&cpg CPG_MOD 724>, <&cpg CPG_MOD 723>, - <&x13_clk>, <&x2_clk>; - clock-names = "du.0", "du.1", "dclkin.0", "dclkin.1"; - - ports { - port@0 { - endpoint { - remote-endpoint = <&adv7511_in>; - }; - }; - }; -}; - -&lvds0 { - ports { - port@1 { - lvds_connector: endpoint { - }; - }; - }; -}; - -&extal_clk { - clock-frequency = <20000000>; -}; - -&pfc { - pinctrl-0 = <&scif_clk_pins>; - pinctrl-names = "default"; - - i2c2_pins: i2c2 { - groups = "i2c2"; - function = "i2c2"; - }; - - i2c4_pins: i2c4 { - groups = "i2c4_c"; - function = "i2c4"; - }; - - du_pins: du { - groups = "du_rgb888", "du_sync", "du_disp", "du_clk_out_0"; - function = "du"; - }; - - scif0_pins: scif0 { - groups = "scif0_data_d"; - function = "scif0"; - }; - - scif1_pins: scif1 { - groups = "scif1_data_d"; - function = "scif1"; - }; - - scif_clk_pins: scif_clk { - groups = "scif_clk"; - function = "scif_clk"; - }; - - ether_pins: ether { - groups = "eth_link", "eth_mdio", "eth_rmii"; - function = "eth"; - }; - - phy1_pins: phy1 { - groups = "intc_irq0"; - function = "intc"; - }; - - pmic_irq_pins: pmicirq { - groups = "intc_irq2"; - function = "intc"; - }; - - sdhi0_pins: sd0 { - groups = "sdhi0_data4", "sdhi0_ctrl"; - function = "sdhi0"; - power-source = <3300>; - }; - - sdhi0_pins_uhs: sd0_uhs { - groups = "sdhi0_data4", "sdhi0_ctrl"; - function = "sdhi0"; - power-source = <1800>; - }; - - sdhi1_pins: sd1 { - groups = "sdhi1_data4", "sdhi1_ctrl"; - function = "sdhi1"; - power-source = <3300>; - }; - - sdhi1_pins_uhs: sd1_uhs { - groups = "sdhi1_data4", "sdhi1_ctrl"; - function = "sdhi1"; - power-source = <1800>; - }; - - sdhi2_pins: sd2 { - groups = "sdhi2_data4", "sdhi2_ctrl"; - function = "sdhi2"; - power-source = <3300>; - }; - - sdhi2_pins_uhs: sd2_uhs { - groups = "sdhi2_data4", "sdhi2_ctrl"; - function = "sdhi2"; - power-source = <1800>; - }; - - qspi_pins: qspi { - groups = "qspi_ctrl", "qspi_data4"; - function = "qspi"; - }; - - sound_pins: sound { - groups = "ssi0129_ctrl", "ssi0_data", "ssi1_data"; - function = "ssi"; - }; - - sound_clk_pins: sound_clk { - groups = "audio_clk_a"; - function = "audio_clk"; - }; - - keyboard_pins: keyboard { - pins = "GP_5_0", "GP_5_1", "GP_5_2", "GP_5_3"; - bias-pull-up; - }; - - vin0_pins: vin0 { - groups = "vin0_data24", "vin0_sync", "vin0_clkenb", "vin0_clk"; - function = "vin0"; - }; - - vin1_pins: vin1 { - groups = "vin1_data8", "vin1_clk"; - function = "vin1"; - }; -}; - -ðer { - pinctrl-0 = <ðer_pins>, <&phy1_pins>; - pinctrl-names = "default"; - - phy-handle = <&phy1>; - renesas,ether-link-active-low; - status = "okay"; - - phy1: ethernet-phy@1 { - compatible = "ethernet-phy-id0022.1537", - "ethernet-phy-ieee802.3-c22"; - reg = <1>; - interrupt-parent = <&irqc0>; - interrupts = <0 IRQ_TYPE_LEVEL_LOW>; - micrel,led-mode = <1>; - reset-gpios = <&gpio5 22 GPIO_ACTIVE_LOW>; - }; -}; - -&cmt0 { - status = "okay"; -}; - -&cpu0 { - cpu0-supply = <&vdd_dvfs>; -}; - -&rwdt { - timeout-sec = <60>; - status = "okay"; -}; - -&scif0 { - pinctrl-0 = <&scif0_pins>; - pinctrl-names = "default"; - - status = "okay"; -}; - -&scif1 { - pinctrl-0 = <&scif1_pins>; - pinctrl-names = "default"; - - status = "okay"; -}; - -&scif_clk { - clock-frequency = <14745600>; -}; - -&sdhi0 { - pinctrl-0 = <&sdhi0_pins>; - pinctrl-1 = <&sdhi0_pins_uhs>; - pinctrl-names = "default", "state_uhs"; - - vmmc-supply = <&vcc_sdhi0>; - vqmmc-supply = <&vccq_sdhi0>; - cd-gpios = <&gpio6 6 GPIO_ACTIVE_LOW>; - wp-gpios = <&gpio6 7 GPIO_ACTIVE_HIGH>; - sd-uhs-sdr50; - sd-uhs-sdr104; - status = "okay"; -}; - -&sdhi1 { - pinctrl-0 = <&sdhi1_pins>; - pinctrl-1 = <&sdhi1_pins_uhs>; - pinctrl-names = "default", "state_uhs"; - - vmmc-supply = <&vcc_sdhi1>; - vqmmc-supply = <&vccq_sdhi1>; - cd-gpios = <&gpio6 14 GPIO_ACTIVE_LOW>; - wp-gpios = <&gpio6 15 GPIO_ACTIVE_HIGH>; - sd-uhs-sdr50; - status = "okay"; -}; - -&sdhi2 { - pinctrl-0 = <&sdhi2_pins>; - pinctrl-1 = <&sdhi2_pins_uhs>; - pinctrl-names = "default", "state_uhs"; - - vmmc-supply = <&vcc_sdhi2>; - vqmmc-supply = <&vccq_sdhi2>; - cd-gpios = <&gpio6 22 GPIO_ACTIVE_LOW>; - sd-uhs-sdr50; - status = "okay"; -}; - -&qspi { - pinctrl-0 = <&qspi_pins>; - pinctrl-names = "default"; - - status = "okay"; - - flash@0 { - compatible = "spansion,s25fl512s", "jedec,spi-nor"; - reg = <0>; - spi-max-frequency = <30000000>; - spi-tx-bus-width = <4>; - spi-rx-bus-width = <4>; - spi-cpol; - spi-cpha; - m25p,fast-read; - - partitions { - compatible = "fixed-partitions"; - #address-cells = <1>; - #size-cells = <1>; - - partition@0 { - label = "loader"; - reg = <0x00000000 0x00040000>; - read-only; - }; - partition@40000 { - label = "user"; - reg = <0x00040000 0x00400000>; - read-only; - }; - partition@440000 { - label = "flash"; - reg = <0x00440000 0x03bc0000>; - }; - }; - }; -}; - -&i2c2 { - pinctrl-0 = <&i2c2_pins>; - pinctrl-names = "i2c-hdmi"; - - status = "okay"; - clock-frequency = <100000>; - -}; - -&i2c6 { - pinctrl-names = "default"; - pinctrl-0 = <&pmic_irq_pins>; - status = "okay"; - clock-frequency = <100000>; - - pmic@58 { - compatible = "dlg,da9063"; - reg = <0x58>; - interrupt-parent = <&irqc0>; - interrupts = <2 IRQ_TYPE_LEVEL_LOW>; - interrupt-controller; - - rtc { - compatible = "dlg,da9063-rtc"; - }; - - watchdog { - compatible = "dlg,da9063-watchdog"; - }; - }; - - vdd_dvfs: regulator@68 { - compatible = "dlg,da9210"; - reg = <0x68>; - interrupt-parent = <&irqc0>; - interrupts = <2 IRQ_TYPE_LEVEL_LOW>; - - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-boot-on; - regulator-always-on; - }; -}; - -&i2c4 { - pinctrl-0 = <&i2c4_pins>; - pinctrl-names = "i2c-exio4"; -}; - -&rcar_sound { - pinctrl-0 = <&sound_pins>, <&sound_clk_pins>; - pinctrl-names = "default"; - - /* Single DAI */ - #sound-dai-cells = <0>; - - status = "okay"; - - rcar_sound,dai { - dai0 { - playback = <&ssi0>, <&src2>, <&dvc0>; - capture = <&ssi1>, <&src3>, <&dvc1>; - }; - }; -}; - -&ssi1 { - shared-pin; -}; - -/* HDMI video input */ -&vin0 { - status = "okay"; - pinctrl-0 = <&vin0_pins>; - pinctrl-names = "default"; - - port { - vin0ep2: endpoint { - remote-endpoint = <&adv7612_out>; - bus-width = <24>; - hsync-active = <0>; - vsync-active = <0>; - pclk-sample = <1>; - data-active = <1>; - }; - }; -}; - -/* composite video input */ -&vin1 { - pinctrl-0 = <&vin1_pins>; - pinctrl-names = "default"; - - status = "okay"; - - port { - vin1ep: endpoint { - remote-endpoint = <&adv7180_out>; - bus-width = <8>; - }; - }; -}; diff --git a/arch/arm/dts/r8a7793.dtsi b/arch/arm/dts/r8a7793.dtsi deleted file mode 100644 index f51bf687f4b..00000000000 --- a/arch/arm/dts/r8a7793.dtsi +++ /dev/null @@ -1,1470 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the R-Car M2-N (R8A77930) SoC - * - * Copyright (C) 2014-2015 Renesas Electronics Corporation - */ - -#include <dt-bindings/clock/r8a7793-cpg-mssr.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/power/r8a7793-sysc.h> - -/ { - compatible = "renesas,r8a7793"; - #address-cells = <2>; - #size-cells = <2>; - - aliases { - i2c0 = &i2c0; - i2c1 = &i2c1; - i2c2 = &i2c2; - i2c3 = &i2c3; - i2c4 = &i2c4; - i2c5 = &i2c5; - i2c6 = &i2c6; - i2c7 = &i2c7; - i2c8 = &i2c8; - spi0 = &qspi; - }; - - /* - * The external audio clocks are configured as 0 Hz fixed frequency - * clocks by default. - * Boards that provide audio clocks should override them. - */ - audio_clk_a: audio_clk_a { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - audio_clk_b: audio_clk_b { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - audio_clk_c: audio_clk_c { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - /* External CAN clock */ - can_clk: can { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board. */ - clock-frequency = <0>; - }; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - - cpu0: cpu@0 { - device_type = "cpu"; - compatible = "arm,cortex-a15"; - reg = <0>; - clock-frequency = <1500000000>; - clocks = <&cpg CPG_CORE R8A7793_CLK_Z>; - power-domains = <&sysc R8A7793_PD_CA15_CPU0>; - enable-method = "renesas,apmu"; - voltage-tolerance = <1>; /* 1% */ - clock-latency = <300000>; /* 300 us */ - - /* kHz - uV - OPPs unknown yet */ - operating-points = <1500000 1000000>, - <1312500 1000000>, - <1125000 1000000>, - < 937500 1000000>, - < 750000 1000000>, - < 375000 1000000>; - next-level-cache = <&L2_CA15>; - }; - - cpu1: cpu@1 { - device_type = "cpu"; - compatible = "arm,cortex-a15"; - reg = <1>; - clock-frequency = <1500000000>; - clocks = <&cpg CPG_CORE R8A7793_CLK_Z>; - power-domains = <&sysc R8A7793_PD_CA15_CPU1>; - enable-method = "renesas,apmu"; - voltage-tolerance = <1>; /* 1% */ - clock-latency = <300000>; /* 300 us */ - - /* kHz - uV - OPPs unknown yet */ - operating-points = <1500000 1000000>, - <1312500 1000000>, - <1125000 1000000>, - < 937500 1000000>, - < 750000 1000000>, - < 375000 1000000>; - next-level-cache = <&L2_CA15>; - }; - - L2_CA15: cache-controller-0 { - compatible = "cache"; - power-domains = <&sysc R8A7793_PD_CA15_SCU>; - cache-unified; - cache-level = <2>; - }; - }; - - /* External root clock */ - extal_clk: extal { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board. */ - clock-frequency = <0>; - }; - - pmu { - compatible = "arm,cortex-a15-pmu"; - interrupts-extended = <&gic GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&cpu0>, <&cpu1>; - }; - - /* External SCIF clock */ - scif_clk: scif { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board. */ - clock-frequency = <0>; - }; - - soc { - compatible = "simple-bus"; - interrupt-parent = <&gic>; - - #address-cells = <2>; - #size-cells = <2>; - ranges; - - rwdt: watchdog@e6020000 { - compatible = "renesas,r8a7793-wdt", - "renesas,rcar-gen2-wdt"; - reg = <0 0xe6020000 0 0x0c>; - interrupts = <GIC_SPI 140 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 402>; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 402>; - status = "disabled"; - }; - - gpio0: gpio@e6050000 { - compatible = "renesas,gpio-r8a7793", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6050000 0 0x50>; - interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 0 32>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 912>; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 912>; - }; - - gpio1: gpio@e6051000 { - compatible = "renesas,gpio-r8a7793", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6051000 0 0x50>; - interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 32 26>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 911>; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 911>; - }; - - gpio2: gpio@e6052000 { - compatible = "renesas,gpio-r8a7793", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6052000 0 0x50>; - interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 64 32>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 910>; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 910>; - }; - - gpio3: gpio@e6053000 { - compatible = "renesas,gpio-r8a7793", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6053000 0 0x50>; - interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 96 32>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 909>; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 909>; - }; - - gpio4: gpio@e6054000 { - compatible = "renesas,gpio-r8a7793", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6054000 0 0x50>; - interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 128 32>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 908>; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 908>; - }; - - gpio5: gpio@e6055000 { - compatible = "renesas,gpio-r8a7793", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6055000 0 0x50>; - interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 160 32>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 907>; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 907>; - }; - - gpio6: gpio@e6055400 { - compatible = "renesas,gpio-r8a7793", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6055400 0 0x50>; - interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 192 32>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 905>; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 905>; - }; - - gpio7: gpio@e6055800 { - compatible = "renesas,gpio-r8a7793", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6055800 0 0x50>; - interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 224 26>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 904>; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 904>; - }; - - pfc: pinctrl@e6060000 { - compatible = "renesas,pfc-r8a7793"; - reg = <0 0xe6060000 0 0x250>; - }; - - /* Special CPG clocks */ - cpg: clock-controller@e6150000 { - compatible = "renesas,r8a7793-cpg-mssr"; - reg = <0 0xe6150000 0 0x1000>; - clocks = <&extal_clk>, <&usb_extal_clk>; - clock-names = "extal", "usb_extal"; - #clock-cells = <2>; - #power-domain-cells = <0>; - #reset-cells = <1>; - }; - - apmu@e6152000 { - compatible = "renesas,r8a7793-apmu", "renesas,apmu"; - reg = <0 0xe6152000 0 0x188>; - cpus = <&cpu0>, <&cpu1>; - }; - - rst: reset-controller@e6160000 { - compatible = "renesas,r8a7793-rst"; - reg = <0 0xe6160000 0 0x0100>; - }; - - sysc: system-controller@e6180000 { - compatible = "renesas,r8a7793-sysc"; - reg = <0 0xe6180000 0 0x0200>; - #power-domain-cells = <1>; - }; - - irqc0: interrupt-controller@e61c0000 { - compatible = "renesas,irqc-r8a7793", "renesas,irqc"; - #interrupt-cells = <2>; - interrupt-controller; - reg = <0 0xe61c0000 0 0x200>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 407>; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 407>; - }; - - thermal: thermal@e61f0000 { - compatible = "renesas,thermal-r8a7793", - "renesas,rcar-gen2-thermal", - "renesas,rcar-thermal"; - reg = <0 0xe61f0000 0 0x10>, <0 0xe61f0100 0 0x38>; - interrupts = <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 522>; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 522>; - #thermal-sensor-cells = <0>; - }; - - ipmmu_sy0: iommu@e6280000 { - compatible = "renesas,ipmmu-r8a7793", - "renesas,ipmmu-vmsa"; - reg = <0 0xe6280000 0 0x1000>; - interrupts = <GIC_SPI 223 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 224 IRQ_TYPE_LEVEL_HIGH>; - #iommu-cells = <1>; - status = "disabled"; - }; - - ipmmu_sy1: iommu@e6290000 { - compatible = "renesas,ipmmu-r8a7793", - "renesas,ipmmu-vmsa"; - reg = <0 0xe6290000 0 0x1000>; - interrupts = <GIC_SPI 225 IRQ_TYPE_LEVEL_HIGH>; - #iommu-cells = <1>; - status = "disabled"; - }; - - ipmmu_ds: iommu@e6740000 { - compatible = "renesas,ipmmu-r8a7793", - "renesas,ipmmu-vmsa"; - reg = <0 0xe6740000 0 0x1000>; - interrupts = <GIC_SPI 198 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 199 IRQ_TYPE_LEVEL_HIGH>; - #iommu-cells = <1>; - status = "disabled"; - }; - - ipmmu_mp: iommu@ec680000 { - compatible = "renesas,ipmmu-r8a7793", - "renesas,ipmmu-vmsa"; - reg = <0 0xec680000 0 0x1000>; - interrupts = <GIC_SPI 226 IRQ_TYPE_LEVEL_HIGH>; - #iommu-cells = <1>; - status = "disabled"; - }; - - ipmmu_mx: iommu@fe951000 { - compatible = "renesas,ipmmu-r8a7793", - "renesas,ipmmu-vmsa"; - reg = <0 0xfe951000 0 0x1000>; - interrupts = <GIC_SPI 222 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 221 IRQ_TYPE_LEVEL_HIGH>; - #iommu-cells = <1>; - status = "disabled"; - }; - - ipmmu_rt: iommu@ffc80000 { - compatible = "renesas,ipmmu-r8a7793", - "renesas,ipmmu-vmsa"; - reg = <0 0xffc80000 0 0x1000>; - interrupts = <GIC_SPI 307 IRQ_TYPE_LEVEL_HIGH>; - #iommu-cells = <1>; - status = "disabled"; - }; - - ipmmu_gp: iommu@e62a0000 { - compatible = "renesas,ipmmu-r8a7793", - "renesas,ipmmu-vmsa"; - reg = <0 0xe62a0000 0 0x1000>; - interrupts = <GIC_SPI 260 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 261 IRQ_TYPE_LEVEL_HIGH>; - #iommu-cells = <1>; - status = "disabled"; - }; - - icram0: sram@e63a0000 { - compatible = "mmio-sram"; - reg = <0 0xe63a0000 0 0x12000>; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0 0xe63a0000 0x12000>; - }; - - icram1: sram@e63c0000 { - compatible = "mmio-sram"; - reg = <0 0xe63c0000 0 0x1000>; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0 0xe63c0000 0x1000>; - - smp-sram@0 { - compatible = "renesas,smp-sram"; - reg = <0 0x100>; - }; - }; - - /* The memory map in the User's Manual maps the cores to - * bus numbers - */ - i2c0: i2c@e6508000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a7793", - "renesas,rcar-gen2-i2c"; - reg = <0 0xe6508000 0 0x40>; - interrupts = <GIC_SPI 287 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 931>; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 931>; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c1: i2c@e6518000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a7793", - "renesas,rcar-gen2-i2c"; - reg = <0 0xe6518000 0 0x40>; - interrupts = <GIC_SPI 288 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 930>; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 930>; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c2: i2c@e6530000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a7793", - "renesas,rcar-gen2-i2c"; - reg = <0 0xe6530000 0 0x40>; - interrupts = <GIC_SPI 286 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 929>; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 929>; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c3: i2c@e6540000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a7793", - "renesas,rcar-gen2-i2c"; - reg = <0 0xe6540000 0 0x40>; - interrupts = <GIC_SPI 290 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 928>; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 928>; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c4: i2c@e6520000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a7793", - "renesas,rcar-gen2-i2c"; - reg = <0 0xe6520000 0 0x40>; - interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 927>; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 927>; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c5: i2c@e6528000 { - /* doesn't need pinmux */ - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a7793", - "renesas,rcar-gen2-i2c"; - reg = <0 0xe6528000 0 0x40>; - interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 925>; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 925>; - i2c-scl-internal-delay-ns = <110>; - status = "disabled"; - }; - - i2c6: i2c@e60b0000 { - /* doesn't need pinmux */ - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,iic-r8a7793", - "renesas,rcar-gen2-iic", - "renesas,rmobile-iic"; - reg = <0 0xe60b0000 0 0x425>; - interrupts = <GIC_SPI 173 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 926>; - dmas = <&dmac0 0x77>, <&dmac0 0x78>, - <&dmac1 0x77>, <&dmac1 0x78>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 926>; - status = "disabled"; - }; - - i2c7: i2c@e6500000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,iic-r8a7793", - "renesas,rcar-gen2-iic", - "renesas,rmobile-iic"; - reg = <0 0xe6500000 0 0x425>; - interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 318>; - dmas = <&dmac0 0x61>, <&dmac0 0x62>, - <&dmac1 0x61>, <&dmac1 0x62>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 318>; - status = "disabled"; - }; - - i2c8: i2c@e6510000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,iic-r8a7793", - "renesas,rcar-gen2-iic", - "renesas,rmobile-iic"; - reg = <0 0xe6510000 0 0x425>; - interrupts = <GIC_SPI 175 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 323>; - dmas = <&dmac0 0x65>, <&dmac0 0x66>, - <&dmac1 0x65>, <&dmac1 0x66>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 323>; - status = "disabled"; - }; - - dmac0: dma-controller@e6700000 { - compatible = "renesas,dmac-r8a7793", - "renesas,rcar-dmac"; - reg = <0 0xe6700000 0 0x20000>; - interrupts = <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 200 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 201 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 202 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 203 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 204 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 205 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 206 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 207 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 208 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 209 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 210 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 211 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 212 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 213 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 214 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14"; - clocks = <&cpg CPG_MOD 219>; - clock-names = "fck"; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 219>; - #dma-cells = <1>; - dma-channels = <15>; - }; - - dmac1: dma-controller@e6720000 { - compatible = "renesas,dmac-r8a7793", - "renesas,rcar-dmac"; - reg = <0 0xe6720000 0 0x20000>; - interrupts = <GIC_SPI 220 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 216 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 217 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 218 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 219 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 308 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 309 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 310 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 311 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 312 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 313 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 314 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 315 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 316 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 317 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 318 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14"; - clocks = <&cpg CPG_MOD 218>; - clock-names = "fck"; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 218>; - #dma-cells = <1>; - dma-channels = <15>; - }; - - qspi: spi@e6b10000 { - compatible = "renesas,qspi-r8a7793", "renesas,qspi"; - reg = <0 0xe6b10000 0 0x2c>; - interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 917>; - dmas = <&dmac0 0x17>, <&dmac0 0x18>, - <&dmac1 0x17>, <&dmac1 0x18>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 917>; - num-cs = <1>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - scifa0: serial@e6c40000 { - compatible = "renesas,scifa-r8a7793", - "renesas,rcar-gen2-scifa", "renesas,scifa"; - reg = <0 0xe6c40000 0 64>; - interrupts = <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 204>; - clock-names = "fck"; - dmas = <&dmac0 0x21>, <&dmac0 0x22>, - <&dmac1 0x21>, <&dmac1 0x22>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 204>; - status = "disabled"; - }; - - scifa1: serial@e6c50000 { - compatible = "renesas,scifa-r8a7793", - "renesas,rcar-gen2-scifa", "renesas,scifa"; - reg = <0 0xe6c50000 0 64>; - interrupts = <GIC_SPI 145 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 203>; - clock-names = "fck"; - dmas = <&dmac0 0x25>, <&dmac0 0x26>, - <&dmac1 0x25>, <&dmac1 0x26>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 203>; - status = "disabled"; - }; - - scifa2: serial@e6c60000 { - compatible = "renesas,scifa-r8a7793", - "renesas,rcar-gen2-scifa", "renesas,scifa"; - reg = <0 0xe6c60000 0 64>; - interrupts = <GIC_SPI 151 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 202>; - clock-names = "fck"; - dmas = <&dmac0 0x27>, <&dmac0 0x28>, - <&dmac1 0x27>, <&dmac1 0x28>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 202>; - status = "disabled"; - }; - - scifa3: serial@e6c70000 { - compatible = "renesas,scifa-r8a7793", - "renesas,rcar-gen2-scifa", "renesas,scifa"; - reg = <0 0xe6c70000 0 64>; - interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 1106>; - clock-names = "fck"; - dmas = <&dmac0 0x1b>, <&dmac0 0x1c>, - <&dmac1 0x1b>, <&dmac1 0x1c>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 1106>; - status = "disabled"; - }; - - scifa4: serial@e6c78000 { - compatible = "renesas,scifa-r8a7793", - "renesas,rcar-gen2-scifa", "renesas,scifa"; - reg = <0 0xe6c78000 0 64>; - interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 1107>; - clock-names = "fck"; - dmas = <&dmac0 0x1f>, <&dmac0 0x20>, - <&dmac1 0x1f>, <&dmac1 0x20>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 1107>; - status = "disabled"; - }; - - scifa5: serial@e6c80000 { - compatible = "renesas,scifa-r8a7793", - "renesas,rcar-gen2-scifa", "renesas,scifa"; - reg = <0 0xe6c80000 0 64>; - interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 1108>; - clock-names = "fck"; - dmas = <&dmac0 0x23>, <&dmac0 0x24>, - <&dmac1 0x23>, <&dmac1 0x24>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 1108>; - status = "disabled"; - }; - - scifb0: serial@e6c20000 { - compatible = "renesas,scifb-r8a7793", - "renesas,rcar-gen2-scifb", "renesas,scifb"; - reg = <0 0xe6c20000 0 0x100>; - interrupts = <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 206>; - clock-names = "fck"; - dmas = <&dmac0 0x3d>, <&dmac0 0x3e>, - <&dmac1 0x3d>, <&dmac1 0x3e>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 206>; - status = "disabled"; - }; - - scifb1: serial@e6c30000 { - compatible = "renesas,scifb-r8a7793", - "renesas,rcar-gen2-scifb", "renesas,scifb"; - reg = <0 0xe6c30000 0 0x100>; - interrupts = <GIC_SPI 149 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 207>; - clock-names = "fck"; - dmas = <&dmac0 0x19>, <&dmac0 0x1a>, - <&dmac1 0x19>, <&dmac1 0x1a>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 207>; - status = "disabled"; - }; - - scifb2: serial@e6ce0000 { - compatible = "renesas,scifb-r8a7793", - "renesas,rcar-gen2-scifb", "renesas,scifb"; - reg = <0 0xe6ce0000 0 0x100>; - interrupts = <GIC_SPI 150 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 216>; - clock-names = "fck"; - dmas = <&dmac0 0x1d>, <&dmac0 0x1e>, - <&dmac1 0x1d>, <&dmac1 0x1e>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 216>; - status = "disabled"; - }; - - scif0: serial@e6e60000 { - compatible = "renesas,scif-r8a7793", - "renesas,rcar-gen2-scif", "renesas,scif"; - reg = <0 0xe6e60000 0 64>; - interrupts = <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 721>, <&cpg CPG_CORE R8A7793_CLK_ZS>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x29>, <&dmac0 0x2a>, - <&dmac1 0x29>, <&dmac1 0x2a>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 721>; - status = "disabled"; - }; - - scif1: serial@e6e68000 { - compatible = "renesas,scif-r8a7793", - "renesas,rcar-gen2-scif", "renesas,scif"; - reg = <0 0xe6e68000 0 64>; - interrupts = <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 720>, <&cpg CPG_CORE R8A7793_CLK_ZS>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x2d>, <&dmac0 0x2e>, - <&dmac1 0x2d>, <&dmac1 0x2e>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 720>; - status = "disabled"; - }; - - scif2: serial@e6e58000 { - compatible = "renesas,scif-r8a7793", - "renesas,rcar-gen2-scif", "renesas,scif"; - reg = <0 0xe6e58000 0 64>; - interrupts = <GIC_SPI 22 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 719>, <&cpg CPG_CORE R8A7793_CLK_ZS>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x2b>, <&dmac0 0x2c>, - <&dmac1 0x2b>, <&dmac1 0x2c>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 719>; - status = "disabled"; - }; - - scif3: serial@e6ea8000 { - compatible = "renesas,scif-r8a7793", - "renesas,rcar-gen2-scif", "renesas,scif"; - reg = <0 0xe6ea8000 0 64>; - interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 718>, <&cpg CPG_CORE R8A7793_CLK_ZS>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x2f>, <&dmac0 0x30>, - <&dmac1 0x2f>, <&dmac1 0x30>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 718>; - status = "disabled"; - }; - - scif4: serial@e6ee0000 { - compatible = "renesas,scif-r8a7793", - "renesas,rcar-gen2-scif", "renesas,scif"; - reg = <0 0xe6ee0000 0 64>; - interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 715>, <&cpg CPG_CORE R8A7793_CLK_ZS>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0xfb>, <&dmac0 0xfc>, - <&dmac1 0xfb>, <&dmac1 0xfc>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 715>; - status = "disabled"; - }; - - scif5: serial@e6ee8000 { - compatible = "renesas,scif-r8a7793", - "renesas,rcar-gen2-scif", "renesas,scif"; - reg = <0 0xe6ee8000 0 64>; - interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 714>, <&cpg CPG_CORE R8A7793_CLK_ZS>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0xfd>, <&dmac0 0xfe>, - <&dmac1 0xfd>, <&dmac1 0xfe>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 714>; - status = "disabled"; - }; - - hscif0: serial@e62c0000 { - compatible = "renesas,hscif-r8a7793", - "renesas,rcar-gen2-hscif", "renesas,hscif"; - reg = <0 0xe62c0000 0 96>; - interrupts = <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 717>, <&cpg CPG_CORE R8A7793_CLK_ZS>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x39>, <&dmac0 0x3a>, - <&dmac1 0x39>, <&dmac1 0x3a>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 717>; - status = "disabled"; - }; - - hscif1: serial@e62c8000 { - compatible = "renesas,hscif-r8a7793", - "renesas,rcar-gen2-hscif", "renesas,hscif"; - reg = <0 0xe62c8000 0 96>; - interrupts = <GIC_SPI 155 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 716>, <&cpg CPG_CORE R8A7793_CLK_ZS>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x4d>, <&dmac0 0x4e>, - <&dmac1 0x4d>, <&dmac1 0x4e>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 716>; - status = "disabled"; - }; - - hscif2: serial@e62d0000 { - compatible = "renesas,hscif-r8a7793", - "renesas,rcar-gen2-hscif", "renesas,hscif"; - reg = <0 0xe62d0000 0 96>; - interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 713>, <&cpg CPG_CORE R8A7793_CLK_ZS>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x3b>, <&dmac0 0x3c>, - <&dmac1 0x3b>, <&dmac1 0x3c>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 713>; - status = "disabled"; - }; - - can0: can@e6e80000 { - compatible = "renesas,can-r8a7793", - "renesas,rcar-gen2-can"; - reg = <0 0xe6e80000 0 0x1000>; - interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 916>, <&cpg CPG_CORE R8A7793_CLK_RCAN>, - <&can_clk>; - clock-names = "clkp1", "clkp2", "can_clk"; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 916>; - status = "disabled"; - }; - - can1: can@e6e88000 { - compatible = "renesas,can-r8a7793", - "renesas,rcar-gen2-can"; - reg = <0 0xe6e88000 0 0x1000>; - interrupts = <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 915>, <&cpg CPG_CORE R8A7793_CLK_RCAN>, - <&can_clk>; - clock-names = "clkp1", "clkp2", "can_clk"; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 915>; - status = "disabled"; - }; - - vin0: video@e6ef0000 { - compatible = "renesas,vin-r8a7793", - "renesas,rcar-gen2-vin"; - reg = <0 0xe6ef0000 0 0x1000>; - interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 811>; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 811>; - status = "disabled"; - }; - - vin1: video@e6ef1000 { - compatible = "renesas,vin-r8a7793", - "renesas,rcar-gen2-vin"; - reg = <0 0xe6ef1000 0 0x1000>; - interrupts = <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 810>; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 810>; - status = "disabled"; - }; - - vin2: video@e6ef2000 { - compatible = "renesas,vin-r8a7793", - "renesas,rcar-gen2-vin"; - reg = <0 0xe6ef2000 0 0x1000>; - interrupts = <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 809>; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 809>; - status = "disabled"; - }; - - rcar_sound: sound@ec500000 { - /* - * #sound-dai-cells is required if simple-card - * - * Single DAI : #sound-dai-cells = <0>; <&rcar_sound>; - * Multi DAI : #sound-dai-cells = <1>; <&rcar_sound N>; - */ - compatible = "renesas,rcar_sound-r8a7793", - "renesas,rcar_sound-gen2"; - reg = <0 0xec500000 0 0x1000>, /* SCU */ - <0 0xec5a0000 0 0x100>, /* ADG */ - <0 0xec540000 0 0x1000>, /* SSIU */ - <0 0xec541000 0 0x280>, /* SSI */ - <0 0xec740000 0 0x200>; /* Audio DMAC peri peri*/ - reg-names = "scu", "adg", "ssiu", "ssi", "audmapp"; - - clocks = <&cpg CPG_MOD 1005>, - <&cpg CPG_MOD 1006>, <&cpg CPG_MOD 1007>, - <&cpg CPG_MOD 1008>, <&cpg CPG_MOD 1009>, - <&cpg CPG_MOD 1010>, <&cpg CPG_MOD 1011>, - <&cpg CPG_MOD 1012>, <&cpg CPG_MOD 1013>, - <&cpg CPG_MOD 1014>, <&cpg CPG_MOD 1015>, - <&cpg CPG_MOD 1022>, <&cpg CPG_MOD 1023>, - <&cpg CPG_MOD 1024>, <&cpg CPG_MOD 1025>, - <&cpg CPG_MOD 1026>, <&cpg CPG_MOD 1027>, - <&cpg CPG_MOD 1028>, <&cpg CPG_MOD 1029>, - <&cpg CPG_MOD 1030>, <&cpg CPG_MOD 1031>, - <&cpg CPG_MOD 1019>, <&cpg CPG_MOD 1018>, - <&audio_clk_a>, <&audio_clk_b>, <&audio_clk_c>, - <&cpg CPG_CORE R8A7793_CLK_M2>; - clock-names = "ssi-all", - "ssi.9", "ssi.8", "ssi.7", "ssi.6", - "ssi.5", "ssi.4", "ssi.3", "ssi.2", - "ssi.1", "ssi.0", - "src.9", "src.8", "src.7", "src.6", - "src.5", "src.4", "src.3", "src.2", - "src.1", "src.0", - "dvc.0", "dvc.1", - "clk_a", "clk_b", "clk_c", "clk_i"; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 1005>, - <&cpg 1006>, <&cpg 1007>, - <&cpg 1008>, <&cpg 1009>, - <&cpg 1010>, <&cpg 1011>, - <&cpg 1012>, <&cpg 1013>, - <&cpg 1014>, <&cpg 1015>; - reset-names = "ssi-all", - "ssi.9", "ssi.8", "ssi.7", "ssi.6", - "ssi.5", "ssi.4", "ssi.3", "ssi.2", - "ssi.1", "ssi.0"; - - status = "disabled"; - - rcar_sound,dvc { - dvc0: dvc-0 { - dmas = <&audma1 0xbc>; - dma-names = "tx"; - }; - dvc1: dvc-1 { - dmas = <&audma1 0xbe>; - dma-names = "tx"; - }; - }; - - rcar_sound,src { - src0: src-0 { - interrupts = <GIC_SPI 352 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x85>, <&audma1 0x9a>; - dma-names = "rx", "tx"; - }; - src1: src-1 { - interrupts = <GIC_SPI 353 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x87>, <&audma1 0x9c>; - dma-names = "rx", "tx"; - }; - src2: src-2 { - interrupts = <GIC_SPI 354 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x89>, <&audma1 0x9e>; - dma-names = "rx", "tx"; - }; - src3: src-3 { - interrupts = <GIC_SPI 355 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x8b>, <&audma1 0xa0>; - dma-names = "rx", "tx"; - }; - src4: src-4 { - interrupts = <GIC_SPI 356 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x8d>, <&audma1 0xb0>; - dma-names = "rx", "tx"; - }; - src5: src-5 { - interrupts = <GIC_SPI 357 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x8f>, <&audma1 0xb2>; - dma-names = "rx", "tx"; - }; - src6: src-6 { - interrupts = <GIC_SPI 358 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x91>, <&audma1 0xb4>; - dma-names = "rx", "tx"; - }; - src7: src-7 { - interrupts = <GIC_SPI 359 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x93>, <&audma1 0xb6>; - dma-names = "rx", "tx"; - }; - src8: src-8 { - interrupts = <GIC_SPI 360 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x95>, <&audma1 0xb8>; - dma-names = "rx", "tx"; - }; - src9: src-9 { - interrupts = <GIC_SPI 361 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x97>, <&audma1 0xba>; - dma-names = "rx", "tx"; - }; - }; - - rcar_sound,ssi { - ssi0: ssi-0 { - interrupts = <GIC_SPI 370 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x01>, <&audma1 0x02>, - <&audma0 0x15>, <&audma1 0x16>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi1: ssi-1 { - interrupts = <GIC_SPI 371 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x03>, <&audma1 0x04>, - <&audma0 0x49>, <&audma1 0x4a>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi2: ssi-2 { - interrupts = <GIC_SPI 372 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x05>, <&audma1 0x06>, - <&audma0 0x63>, <&audma1 0x64>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi3: ssi-3 { - interrupts = <GIC_SPI 373 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x07>, <&audma1 0x08>, - <&audma0 0x6f>, <&audma1 0x70>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi4: ssi-4 { - interrupts = <GIC_SPI 374 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x09>, <&audma1 0x0a>, - <&audma0 0x71>, <&audma1 0x72>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi5: ssi-5 { - interrupts = <GIC_SPI 375 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x0b>, <&audma1 0x0c>, - <&audma0 0x73>, <&audma1 0x74>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi6: ssi-6 { - interrupts = <GIC_SPI 376 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x0d>, <&audma1 0x0e>, - <&audma0 0x75>, <&audma1 0x76>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi7: ssi-7 { - interrupts = <GIC_SPI 377 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x0f>, <&audma1 0x10>, - <&audma0 0x79>, <&audma1 0x7a>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi8: ssi-8 { - interrupts = <GIC_SPI 378 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x11>, <&audma1 0x12>, - <&audma0 0x7b>, <&audma1 0x7c>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi9: ssi-9 { - interrupts = <GIC_SPI 379 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x13>, <&audma1 0x14>, - <&audma0 0x7d>, <&audma1 0x7e>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - }; - }; - - audma0: dma-controller@ec700000 { - compatible = "renesas,dmac-r8a7793", - "renesas,rcar-dmac"; - reg = <0 0xec700000 0 0x10000>; - interrupts = <GIC_SPI 346 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 320 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 321 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 322 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 323 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 324 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 325 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 326 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 327 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 328 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 329 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 330 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 331 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 332 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12"; - clocks = <&cpg CPG_MOD 502>; - clock-names = "fck"; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 502>; - #dma-cells = <1>; - dma-channels = <13>; - }; - - audma1: dma-controller@ec720000 { - compatible = "renesas,dmac-r8a7793", - "renesas,rcar-dmac"; - reg = <0 0xec720000 0 0x10000>; - interrupts = <GIC_SPI 347 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 333 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 334 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 335 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 336 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 337 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 338 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 339 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 340 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 341 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 342 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 343 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 344 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 345 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12"; - clocks = <&cpg CPG_MOD 501>; - clock-names = "fck"; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 501>; - #dma-cells = <1>; - dma-channels = <13>; - }; - - sdhi0: mmc@ee100000 { - compatible = "renesas,sdhi-r8a7793", - "renesas,rcar-gen2-sdhi"; - reg = <0 0xee100000 0 0x328>; - interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 314>; - dmas = <&dmac0 0xcd>, <&dmac0 0xce>, - <&dmac1 0xcd>, <&dmac1 0xce>; - dma-names = "tx", "rx", "tx", "rx"; - max-frequency = <195000000>; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 314>; - status = "disabled"; - }; - - sdhi1: mmc@ee140000 { - compatible = "renesas,sdhi-r8a7793", - "renesas,rcar-gen2-sdhi"; - reg = <0 0xee140000 0 0x100>; - interrupts = <GIC_SPI 167 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 312>; - dmas = <&dmac0 0xc1>, <&dmac0 0xc2>, - <&dmac1 0xc1>, <&dmac1 0xc2>; - dma-names = "tx", "rx", "tx", "rx"; - max-frequency = <97500000>; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 312>; - status = "disabled"; - }; - - sdhi2: mmc@ee160000 { - compatible = "renesas,sdhi-r8a7793", - "renesas,rcar-gen2-sdhi"; - reg = <0 0xee160000 0 0x100>; - interrupts = <GIC_SPI 168 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 311>; - dmas = <&dmac0 0xd3>, <&dmac0 0xd4>, - <&dmac1 0xd3>, <&dmac1 0xd4>; - dma-names = "tx", "rx", "tx", "rx"; - max-frequency = <97500000>; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 311>; - status = "disabled"; - }; - - mmcif0: mmc@ee200000 { - compatible = "renesas,mmcif-r8a7793", - "renesas,sh-mmcif"; - reg = <0 0xee200000 0 0x80>; - interrupts = <GIC_SPI 169 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 315>; - dmas = <&dmac0 0xd1>, <&dmac0 0xd2>, - <&dmac1 0xd1>, <&dmac1 0xd2>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 315>; - reg-io-width = <4>; - status = "disabled"; - max-frequency = <97500000>; - }; - - ether: ethernet@ee700000 { - compatible = "renesas,ether-r8a7793", - "renesas,rcar-gen2-ether"; - reg = <0 0xee700000 0 0x400>; - interrupts = <GIC_SPI 162 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 813>; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 813>; - phy-mode = "rmii"; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - gic: interrupt-controller@f1001000 { - compatible = "arm,gic-400"; - #interrupt-cells = <3>; - #address-cells = <0>; - interrupt-controller; - reg = <0 0xf1001000 0 0x1000>, - <0 0xf1002000 0 0x2000>, - <0 0xf1004000 0 0x2000>, - <0 0xf1006000 0 0x2000>; - interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_HIGH)>; - clocks = <&cpg CPG_MOD 408>; - clock-names = "clk"; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 408>; - }; - - fdp1@fe940000 { - compatible = "renesas,fdp1"; - reg = <0 0xfe940000 0 0x2400>; - interrupts = <GIC_SPI 262 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 119>; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 119>; - }; - - fdp1@fe944000 { - compatible = "renesas,fdp1"; - reg = <0 0xfe944000 0 0x2400>; - interrupts = <GIC_SPI 263 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 118>; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 118>; - }; - - du: display@feb00000 { - compatible = "renesas,du-r8a7793"; - reg = <0 0xfeb00000 0 0x40000>; - interrupts = <GIC_SPI 256 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 268 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 724>, <&cpg CPG_MOD 723>; - clock-names = "du.0", "du.1"; - resets = <&cpg 724>; - reset-names = "du.0"; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - du_out_rgb: endpoint { - }; - }; - port@1 { - reg = <1>; - du_out_lvds0: endpoint { - remote-endpoint = <&lvds0_in>; - }; - }; - }; - }; - - lvds0: lvds@feb90000 { - compatible = "renesas,r8a7793-lvds"; - reg = <0 0xfeb90000 0 0x1c>; - clocks = <&cpg CPG_MOD 726>; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 726>; - - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - lvds0_in: endpoint { - remote-endpoint = <&du_out_lvds0>; - }; - }; - port@1 { - reg = <1>; - lvds0_out: endpoint { - }; - }; - }; - }; - - prr: chipid@ff000044 { - compatible = "renesas,prr"; - reg = <0 0xff000044 0 4>; - }; - - cmt0: timer@ffca0000 { - compatible = "renesas,r8a7793-cmt0", - "renesas,rcar-gen2-cmt0"; - reg = <0 0xffca0000 0 0x1004>; - interrupts = <GIC_SPI 142 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 143 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 124>; - clock-names = "fck"; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 124>; - - status = "disabled"; - }; - - cmt1: timer@e6130000 { - compatible = "renesas,r8a7793-cmt1", - "renesas,rcar-gen2-cmt1"; - reg = <0 0xe6130000 0 0x1004>; - interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 127 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 329>; - clock-names = "fck"; - power-domains = <&sysc R8A7793_PD_ALWAYS_ON>; - resets = <&cpg 329>; - - status = "disabled"; - }; - }; - - thermal-zones { - cpu_thermal: cpu-thermal { - polling-delay-passive = <0>; - polling-delay = <0>; - - thermal-sensors = <&thermal>; - - trips { - cpu-crit { - temperature = <95000>; - hysteresis = <0>; - type = "critical"; - }; - }; - cooling-maps { - }; - }; - }; - - timer { - compatible = "arm,armv7-timer"; - interrupts-extended = <&gic GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>; - }; - - /* External USB clock - can be overridden by the board */ - usb_extal_clk: usb_extal { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <48000000>; - }; -}; diff --git a/arch/arm/dts/r8a7794-alt.dts b/arch/arm/dts/r8a7794-alt.dts deleted file mode 100644 index 4d93319674c..00000000000 --- a/arch/arm/dts/r8a7794-alt.dts +++ /dev/null @@ -1,533 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the Alt board - * - * Copyright (C) 2014 Renesas Electronics Corporation - */ - -/dts-v1/; -#include "r8a7794.dtsi" -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/input/input.h> - -/ { - model = "Alt"; - compatible = "renesas,alt", "renesas,r8a7794"; - - aliases { - serial0 = &scif2; - i2c9 = &gpioi2c1; - i2c10 = &gpioi2c4; - i2c11 = &i2chdmi; - i2c12 = &i2cexio4; - mmc0 = &mmcif0; - mmc1 = &sdhi0; - mmc2 = &sdhi1; - }; - - chosen { - bootargs = "ignore_loglevel rw root=/dev/nfs ip=on"; - stdout-path = "serial0:115200n8"; - }; - - memory@40000000 { - device_type = "memory"; - reg = <0 0x40000000 0 0x40000000>; - }; - - d3_3v: regulator-d3-3v { - compatible = "regulator-fixed"; - regulator-name = "D3.3V"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - - vcc_sdhi0: regulator-vcc-sdhi0 { - compatible = "regulator-fixed"; - - regulator-name = "SDHI0 Vcc"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - gpio = <&gpio2 26 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; - - vccq_sdhi0: regulator-vccq-sdhi0 { - compatible = "regulator-gpio"; - - regulator-name = "SDHI0 VccQ"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - - gpios = <&gpio2 29 GPIO_ACTIVE_HIGH>; - gpios-states = <1>; - states = <3300000 1>, <1800000 0>; - }; - - vcc_sdhi1: regulator-vcc-sdhi1 { - compatible = "regulator-fixed"; - - regulator-name = "SDHI1 Vcc"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - gpio = <&gpio4 26 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; - - vccq_sdhi1: regulator-vccq-sdhi1 { - compatible = "regulator-gpio"; - - regulator-name = "SDHI1 VccQ"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - - gpios = <&gpio4 29 GPIO_ACTIVE_HIGH>; - gpios-states = <1>; - states = <3300000 1>, <1800000 0>; - }; - - lbsc { - #address-cells = <1>; - #size-cells = <1>; - }; - - keyboard { - compatible = "gpio-keys"; - - pinctrl-0 = <&keyboard_pins>; - pinctrl-names = "default"; - - one { - linux,code = <KEY_1>; - label = "SW2-1"; - wakeup-source; - debounce-interval = <20>; - gpios = <&gpio3 9 GPIO_ACTIVE_LOW>; - }; - two { - linux,code = <KEY_2>; - label = "SW2-2"; - wakeup-source; - debounce-interval = <20>; - gpios = <&gpio3 10 GPIO_ACTIVE_LOW>; - }; - three { - linux,code = <KEY_3>; - label = "SW2-3"; - wakeup-source; - debounce-interval = <20>; - gpios = <&gpio3 11 GPIO_ACTIVE_LOW>; - }; - four { - linux,code = <KEY_4>; - label = "SW2-4"; - wakeup-source; - debounce-interval = <20>; - gpios = <&gpio3 12 GPIO_ACTIVE_LOW>; - }; - }; - - vga-encoder { - compatible = "adi,adv7123"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - adv7123_in: endpoint { - remote-endpoint = <&du_out_rgb1>; - }; - }; - port@1 { - reg = <1>; - adv7123_out: endpoint { - remote-endpoint = <&vga_in>; - }; - }; - }; - }; - - vga { - compatible = "vga-connector"; - - port { - vga_in: endpoint { - remote-endpoint = <&adv7123_out>; - }; - }; - }; - - x2_clk: x2-clock { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <74250000>; - }; - - x13_clk: x13-clock { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <148500000>; - }; - - gpioi2c1: i2c-9 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "i2c-gpio"; - status = "disabled"; - scl-gpios = <&gpio4 0 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; - sda-gpios = <&gpio4 1 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; - }; - - gpioi2c4: i2c-10 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "i2c-gpio"; - status = "disabled"; - scl-gpios = <&gpio4 8 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; - sda-gpios = <&gpio4 9 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; - i2c-gpio,delay-us = <5>; - }; - - /* - * A fallback to GPIO is provided for I2C1. - */ - i2chdmi: i2c-11 { - compatible = "i2c-demux-pinctrl"; - i2c-parent = <&i2c1>, <&gpioi2c1>; - i2c-bus-name = "i2c-hdmi"; - #address-cells = <1>; - #size-cells = <0>; - - composite-in@20 { - compatible = "adi,adv7180"; - reg = <0x20>; - - port { - adv7180: endpoint { - bus-width = <8>; - remote-endpoint = <&vin0ep>; - }; - }; - }; - - eeprom@50 { - compatible = "renesas,r1ex24002", "atmel,24c02"; - reg = <0x50>; - pagesize = <16>; - }; - }; - - /* - * I2C4 is routed to EXIO connector B, pins 73 (SCL) + 74 (SDA). - * A fallback to GPIO is provided. - */ - i2cexio4: i2c-14 { - compatible = "i2c-demux-pinctrl"; - i2c-parent = <&i2c4>, <&gpioi2c4>; - i2c-bus-name = "i2c-exio4"; - #address-cells = <1>; - #size-cells = <0>; - }; -}; - -&pci0 { - status = "okay"; - pinctrl-0 = <&usb0_pins>; - pinctrl-names = "default"; -}; - -&pci1 { - status = "okay"; - pinctrl-0 = <&usb1_pins>; - pinctrl-names = "default"; -}; - -&usbphy { - status = "okay"; -}; - -&du { - pinctrl-0 = <&du_pins>; - pinctrl-names = "default"; - status = "okay"; - - clocks = <&cpg CPG_MOD 724>, <&cpg CPG_MOD 723>, - <&x13_clk>, <&x2_clk>; - clock-names = "du.0", "du.1", "dclkin.0", "dclkin.1"; - - ports { - port@1 { - endpoint { - remote-endpoint = <&adv7123_in>; - }; - }; - }; -}; - -&extal_clk { - clock-frequency = <20000000>; -}; - -&pfc { - pinctrl-0 = <&scif_clk_pins>; - pinctrl-names = "default"; - - du_pins: du { - groups = "du1_rgb666", "du1_sync", "du1_disp", "du1_clk0_out"; - function = "du1"; - }; - - scif2_pins: scif2 { - groups = "scif2_data"; - function = "scif2"; - }; - - scif_clk_pins: scif_clk { - groups = "scif_clk"; - function = "scif_clk"; - }; - - ether_pins: ether { - groups = "eth_link", "eth_mdio", "eth_rmii"; - function = "eth"; - }; - - phy1_pins: phy1 { - groups = "intc_irq8"; - function = "intc"; - }; - - i2c1_pins: i2c1 { - groups = "i2c1"; - function = "i2c1"; - }; - - i2c4_pins: i2c4 { - groups = "i2c4"; - function = "i2c4"; - }; - - vin0_pins: vin0 { - groups = "vin0_data8", "vin0_clk"; - function = "vin0"; - }; - - mmcif0_pins: mmcif0 { - groups = "mmc_data8", "mmc_ctrl"; - function = "mmc"; - }; - - sdhi0_pins: sd0 { - groups = "sdhi0_data4", "sdhi0_ctrl"; - function = "sdhi0"; - power-source = <3300>; - }; - - sdhi0_pins_uhs: sd0_uhs { - groups = "sdhi0_data4", "sdhi0_ctrl"; - function = "sdhi0"; - power-source = <1800>; - }; - - sdhi1_pins: sd1 { - groups = "sdhi1_data4", "sdhi1_ctrl"; - function = "sdhi1"; - power-source = <3300>; - }; - - sdhi1_pins_uhs: sd1_uhs { - groups = "sdhi1_data4", "sdhi1_ctrl"; - function = "sdhi1"; - power-source = <1800>; - }; - - usb0_pins: usb0 { - groups = "usb0"; - function = "usb0"; - }; - - usb1_pins: usb1 { - groups = "usb1"; - function = "usb1"; - }; - - keyboard_pins: keyboard { - pins = "GP_3_9", "GP_3_10", "GP_3_11", "GP_3_12"; - bias-pull-up; - }; -}; - -&cmt0 { - status = "okay"; -}; - -&pfc { - qspi_pins: qspi { - groups = "qspi_ctrl", "qspi_data4"; - function = "qspi"; - }; -}; - -ðer { - pinctrl-0 = <ðer_pins>, <&phy1_pins>; - pinctrl-names = "default"; - - phy-handle = <&phy1>; - renesas,ether-link-active-low; - status = "okay"; - - phy1: ethernet-phy@1 { - compatible = "ethernet-phy-id0022.1537", - "ethernet-phy-ieee802.3-c22"; - reg = <1>; - interrupt-parent = <&irqc0>; - interrupts = <8 IRQ_TYPE_LEVEL_LOW>; - micrel,led-mode = <1>; - reset-gpios = <&gpio1 24 GPIO_ACTIVE_LOW>; - }; -}; - -&mmcif0 { - pinctrl-0 = <&mmcif0_pins>; - pinctrl-names = "default"; - - vmmc-supply = <&d3_3v>; - vqmmc-supply = <&d3_3v>; - bus-width = <8>; - non-removable; - status = "okay"; -}; - -&rwdt { - timeout-sec = <60>; - status = "okay"; -}; - -&sdhi0 { - pinctrl-0 = <&sdhi0_pins>; - pinctrl-1 = <&sdhi0_pins_uhs>; - pinctrl-names = "default", "state_uhs"; - - vmmc-supply = <&vcc_sdhi0>; - vqmmc-supply = <&vccq_sdhi0>; - cd-gpios = <&gpio6 6 GPIO_ACTIVE_LOW>; - wp-gpios = <&gpio6 7 GPIO_ACTIVE_HIGH>; - sd-uhs-sdr50; - sd-uhs-sdr104; - status = "okay"; -}; - -&sdhi1 { - pinctrl-0 = <&sdhi1_pins>; - pinctrl-1 = <&sdhi1_pins_uhs>; - pinctrl-names = "default", "state_uhs"; - - vmmc-supply = <&vcc_sdhi1>; - vqmmc-supply = <&vccq_sdhi1>; - cd-gpios = <&gpio6 14 GPIO_ACTIVE_LOW>; - wp-gpios = <&gpio6 15 GPIO_ACTIVE_HIGH>; - sd-uhs-sdr50; - status = "okay"; -}; - -&i2c1 { - pinctrl-0 = <&i2c1_pins>; - pinctrl-names = "i2c-hdmi"; - - clock-frequency = <400000>; -}; - -&i2c4 { - pinctrl-0 = <&i2c4_pins>; - pinctrl-names = "i2c-exio4"; -}; - -&i2c7 { - status = "okay"; - clock-frequency = <100000>; - - pmic@58 { - compatible = "dlg,da9063"; - reg = <0x58>; - interrupt-parent = <&gpio3>; - interrupts = <31 IRQ_TYPE_LEVEL_LOW>; - interrupt-controller; - - rtc { - compatible = "dlg,da9063-rtc"; - }; - - watchdog { - compatible = "dlg,da9063-watchdog"; - }; - }; -}; - -&vin0 { - status = "okay"; - pinctrl-0 = <&vin0_pins>; - pinctrl-names = "default"; - - port { - vin0ep: endpoint { - remote-endpoint = <&adv7180>; - bus-width = <8>; - }; - }; -}; - -&scif2 { - pinctrl-0 = <&scif2_pins>; - pinctrl-names = "default"; - - status = "okay"; -}; - -&scif_clk { - clock-frequency = <14745600>; -}; - -&qspi { - pinctrl-0 = <&qspi_pins>; - pinctrl-names = "default"; - - status = "okay"; - - flash@0 { - compatible = "spansion,s25fl512s", "jedec,spi-nor"; - reg = <0>; - spi-max-frequency = <30000000>; - spi-tx-bus-width = <4>; - spi-rx-bus-width = <4>; - spi-cpol; - spi-cpha; - m25p,fast-read; - - partitions { - compatible = "fixed-partitions"; - #address-cells = <1>; - #size-cells = <1>; - - partition@0 { - label = "loader"; - reg = <0x00000000 0x00040000>; - read-only; - }; - partition@40000 { - label = "system"; - reg = <0x00040000 0x00040000>; - read-only; - }; - partition@80000 { - label = "user"; - reg = <0x00080000 0x03f80000>; - }; - }; - }; -}; diff --git a/arch/arm/dts/r8a7794-silk.dts b/arch/arm/dts/r8a7794-silk.dts deleted file mode 100644 index b7af1befa12..00000000000 --- a/arch/arm/dts/r8a7794-silk.dts +++ /dev/null @@ -1,578 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the SILK board - * - * Copyright (C) 2014 Renesas Electronics Corporation - * Copyright (C) 2014-2015 Renesas Solutions Corp. - * Copyright (C) 2014-2015 Cogent Embedded, Inc. - */ - -/* - * SSI-AK4643 - * - * SW1: 2-1: AK4643 - * 2-3: ADV7511 - * - * This command is required before playback/capture: - * - * amixer set "LINEOUT Mixer DACL" on - */ - -/dts-v1/; -#include "r8a7794.dtsi" -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/input/input.h> - -/ { - model = "SILK"; - compatible = "renesas,silk", "renesas,r8a7794"; - - aliases { - serial0 = &scif2; - i2c9 = &gpioi2c1; - i2c10 = &i2chdmi; - mmc0 = &mmcif0; - mmc1 = &sdhi1; - }; - - chosen { - bootargs = "ignore_loglevel rw root=/dev/nfs ip=on"; - stdout-path = "serial0:115200n8"; - }; - - memory@40000000 { - device_type = "memory"; - reg = <0 0x40000000 0 0x40000000>; - }; - - keyboard { - compatible = "gpio-keys"; - - pinctrl-0 = <&keyboard_pins>; - pinctrl-names = "default"; - - key-3 { - gpios = <&gpio5 10 GPIO_ACTIVE_LOW>; - linux,code = <KEY_3>; - label = "SW3"; - wakeup-source; - debounce-interval = <20>; - }; - key-4 { - gpios = <&gpio5 11 GPIO_ACTIVE_LOW>; - linux,code = <KEY_4>; - label = "SW4"; - wakeup-source; - debounce-interval = <20>; - }; - key-6 { - gpios = <&gpio5 12 GPIO_ACTIVE_LOW>; - linux,code = <KEY_6>; - label = "SW6"; - wakeup-source; - debounce-interval = <20>; - }; - key-a { - gpios = <&gpio3 9 GPIO_ACTIVE_LOW>; - linux,code = <KEY_A>; - label = "SW12-1"; - wakeup-source; - debounce-interval = <20>; - }; - key-b { - gpios = <&gpio3 10 GPIO_ACTIVE_LOW>; - linux,code = <KEY_B>; - label = "SW12-2"; - wakeup-source; - debounce-interval = <20>; - }; - key-c { - gpios = <&gpio3 11 GPIO_ACTIVE_LOW>; - linux,code = <KEY_C>; - label = "SW12-3"; - wakeup-source; - debounce-interval = <20>; - }; - key-d { - gpios = <&gpio3 12 GPIO_ACTIVE_LOW>; - linux,code = <KEY_D>; - label = "SW12-4"; - wakeup-source; - debounce-interval = <20>; - }; - }; - - d3_3v: regulator-d3-3v { - compatible = "regulator-fixed"; - regulator-name = "D3.3V"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - - vcc_sdhi1: regulator-vcc-sdhi1 { - compatible = "regulator-fixed"; - - regulator-name = "SDHI1 Vcc"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - gpio = <&gpio4 26 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; - - vccq_sdhi1: regulator-vccq-sdhi1 { - compatible = "regulator-gpio"; - - regulator-name = "SDHI1 VccQ"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - - gpios = <&gpio4 29 GPIO_ACTIVE_HIGH>; - gpios-states = <1>; - states = <3300000 1>, <1800000 0>; - }; - - vga-encoder { - compatible = "adi,adv7123"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - adv7123_in: endpoint { - remote-endpoint = <&du_out_rgb1>; - }; - }; - port@1 { - reg = <1>; - adv7123_out: endpoint { - remote-endpoint = <&vga_in>; - }; - }; - }; - }; - - hdmi-out { - compatible = "hdmi-connector"; - type = "a"; - - port { - hdmi_con: endpoint { - remote-endpoint = <&adv7511_out>; - }; - }; - }; - - vga { - compatible = "vga-connector"; - - port { - vga_in: endpoint { - remote-endpoint = <&adv7123_out>; - }; - }; - }; - - x2_clk: x2-clock { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <148500000>; - }; - - x3_clk: x3-clock { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <74250000>; - }; - - x9_clk: audio_clock { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <12288000>; - }; - - sound { - compatible = "simple-audio-card"; - - simple-audio-card,format = "left_j"; - simple-audio-card,bitclock-master = <&soundcodec>; - simple-audio-card,frame-master = <&soundcodec>; - - simple-audio-card,cpu { - sound-dai = <&rcar_sound>; - }; - - soundcodec: simple-audio-card,codec { - sound-dai = <&ak4643>; - clocks = <&x9_clk>; - }; - }; - - gpioi2c1: i2c-9 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "i2c-gpio"; - status = "disabled"; - scl-gpios = <&gpio4 0 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; - sda-gpios = <&gpio4 1 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; - i2c-gpio,delay-us = <5>; - }; - - /* - * A fallback to GPIO is provided for I2C1. - */ - i2chdmi: i2c-10 { - compatible = "i2c-demux-pinctrl"; - i2c-parent = <&i2c1>, <&gpioi2c1>; - i2c-bus-name = "i2c-hdmi"; - #address-cells = <1>; - #size-cells = <0>; - - ak4643: codec@12 { - compatible = "asahi-kasei,ak4643"; - #sound-dai-cells = <0>; - reg = <0x12>; - }; - - composite-in@20 { - compatible = "adi,adv7180"; - reg = <0x20>; - - port { - adv7180: endpoint { - bus-width = <8>; - remote-endpoint = <&vin0ep>; - }; - }; - }; - - hdmi@39 { - compatible = "adi,adv7511w"; - reg = <0x39>; - interrupt-parent = <&gpio5>; - interrupts = <23 IRQ_TYPE_LEVEL_LOW>; - - adi,input-depth = <8>; - adi,input-colorspace = "rgb"; - adi,input-clock = "1x"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - adv7511_in: endpoint { - remote-endpoint = <&du_out_rgb0>; - }; - }; - - port@1 { - reg = <1>; - adv7511_out: endpoint { - remote-endpoint = <&hdmi_con>; - }; - }; - }; - }; - - eeprom@50 { - compatible = "renesas,r1ex24002", "atmel,24c02"; - reg = <0x50>; - pagesize = <16>; - }; - }; -}; - -&extal_clk { - clock-frequency = <20000000>; -}; - -&pfc { - pinctrl-0 = <&scif_clk_pins>; - pinctrl-names = "default"; - - scif2_pins: scif2 { - groups = "scif2_data"; - function = "scif2"; - }; - - scif_clk_pins: scif_clk { - groups = "scif_clk"; - function = "scif_clk"; - }; - - ether_pins: ether { - groups = "eth_link", "eth_mdio", "eth_rmii"; - function = "eth"; - }; - - phy1_pins: phy1 { - groups = "intc_irq8"; - function = "intc"; - }; - - i2c1_pins: i2c1 { - groups = "i2c1"; - function = "i2c1"; - }; - - mmcif0_pins: mmcif0 { - groups = "mmc_data8", "mmc_ctrl"; - function = "mmc"; - }; - - sdhi1_pins: sd1 { - groups = "sdhi1_data4", "sdhi1_ctrl"; - function = "sdhi1"; - }; - - qspi_pins: qspi { - groups = "qspi_ctrl", "qspi_data4"; - function = "qspi"; - }; - - vin0_pins: vin0 { - groups = "vin0_data8", "vin0_clk"; - function = "vin0"; - }; - - usb0_pins: usb0 { - groups = "usb0"; - function = "usb0"; - }; - - usb1_pins: usb1 { - groups = "usb1"; - function = "usb1"; - }; - - du0_pins: du0 { - groups = "du0_rgb888", "du0_sync", "du0_disp", "du0_clk0_out"; - function = "du0"; - }; - - du1_pins: du1 { - groups = "du1_rgb666", "du1_sync", "du1_disp", "du1_clk0_out"; - function = "du1"; - }; - - keyboard_pins: keyboard { - pins = "GP_3_9", "GP_3_10", "GP_3_11", "GP_3_12"; - bias-pull-up; - }; - - ssi_pins: sound { - groups = "ssi0129_ctrl", "ssi0_data", "ssi1_data"; - function = "ssi"; - }; - - audio_clk_pins: audio_clk { - groups = "audio_clkc"; - function = "audio_clk"; - }; -}; - -&scif2 { - pinctrl-0 = <&scif2_pins>; - pinctrl-names = "default"; - - status = "okay"; -}; - -&scif_clk { - clock-frequency = <14745600>; -}; - -ðer { - pinctrl-0 = <ðer_pins>, <&phy1_pins>; - pinctrl-names = "default"; - - phy-handle = <&phy1>; - renesas,ether-link-active-low; - status = "okay"; - - phy1: ethernet-phy@1 { - compatible = "ethernet-phy-id0022.1537", - "ethernet-phy-ieee802.3-c22"; - reg = <1>; - interrupt-parent = <&irqc0>; - interrupts = <8 IRQ_TYPE_LEVEL_LOW>; - micrel,led-mode = <1>; - reset-gpios = <&gpio1 24 GPIO_ACTIVE_LOW>; - }; -}; - -&i2c1 { - pinctrl-0 = <&i2c1_pins>; - pinctrl-names = "i2c-hdmi"; - - clock-frequency = <400000>; -}; - -&i2c7 { - status = "okay"; - clock-frequency = <100000>; - - pmic@58 { - compatible = "dlg,da9063"; - reg = <0x58>; - interrupt-parent = <&gpio3>; - interrupts = <31 IRQ_TYPE_LEVEL_LOW>; - interrupt-controller; - - onkey { - compatible = "dlg,da9063-onkey"; - }; - - rtc { - compatible = "dlg,da9063-rtc"; - }; - - watchdog { - compatible = "dlg,da9063-watchdog"; - }; - }; -}; - -&mmcif0 { - pinctrl-0 = <&mmcif0_pins>; - pinctrl-names = "default"; - - vmmc-supply = <&d3_3v>; - vqmmc-supply = <&d3_3v>; - bus-width = <8>; - non-removable; - status = "okay"; -}; - -&sdhi1 { - pinctrl-0 = <&sdhi1_pins>; - pinctrl-names = "default"; - - vmmc-supply = <&vcc_sdhi1>; - vqmmc-supply = <&vccq_sdhi1>; - cd-gpios = <&gpio6 14 GPIO_ACTIVE_LOW>; - status = "okay"; -}; - -&qspi { - pinctrl-0 = <&qspi_pins>; - pinctrl-names = "default"; - - status = "okay"; - - flash@0 { - compatible = "spansion,s25fl512s", "jedec,spi-nor"; - reg = <0>; - spi-max-frequency = <30000000>; - spi-tx-bus-width = <4>; - spi-rx-bus-width = <4>; - spi-cpol; - spi-cpha; - m25p,fast-read; - - partitions { - compatible = "fixed-partitions"; - #address-cells = <1>; - #size-cells = <1>; - - partition@0 { - label = "loader"; - reg = <0x00000000 0x00040000>; - read-only; - }; - partition@40000 { - label = "user"; - reg = <0x00040000 0x00400000>; - read-only; - }; - partition@440000 { - label = "flash"; - reg = <0x00440000 0x03bc0000>; - }; - }; - }; -}; - -/* composite video input */ -&vin0 { - status = "okay"; - pinctrl-0 = <&vin0_pins>; - pinctrl-names = "default"; - - port { - vin0ep: endpoint { - remote-endpoint = <&adv7180>; - bus-width = <8>; - }; - }; -}; - -&pci0 { - status = "okay"; - pinctrl-0 = <&usb0_pins>; - pinctrl-names = "default"; -}; - -&pci1 { - status = "okay"; - pinctrl-0 = <&usb1_pins>; - pinctrl-names = "default"; -}; - -&usbphy { - status = "okay"; -}; - -&du { - pinctrl-0 = <&du0_pins>, <&du1_pins>; - pinctrl-names = "default"; - status = "okay"; - - clocks = <&cpg CPG_MOD 724>, <&cpg CPG_MOD 723>, - <&x2_clk>, <&x3_clk>; - clock-names = "du.0", "du.1", "dclkin.0", "dclkin.1"; - - ports { - port@0 { - endpoint { - remote-endpoint = <&adv7511_in>; - }; - }; - port@1 { - endpoint { - remote-endpoint = <&adv7123_in>; - }; - }; - }; -}; - -&rcar_sound { - pinctrl-0 = <&ssi_pins>, <&audio_clk_pins>; - pinctrl-names = "default"; - status = "okay"; - - /* Single DAI */ - #sound-dai-cells = <0>; - - rcar_sound,dai { - dai0 { - playback = <&ssi0>; - capture = <&ssi1>; - }; - }; -}; - -&rwdt { - timeout-sec = <60>; - status = "okay"; -}; - -&ssi1 { - shared-pin; -}; diff --git a/arch/arm/dts/r8a7794.dtsi b/arch/arm/dts/r8a7794.dtsi deleted file mode 100644 index 371dd4715dd..00000000000 --- a/arch/arm/dts/r8a7794.dtsi +++ /dev/null @@ -1,1437 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the R-Car E2 (R8A77940) SoC - * - * Copyright (C) 2014 Renesas Electronics Corporation - * Copyright (C) 2014 Ulrich Hecht - */ - -#include <dt-bindings/clock/r8a7794-cpg-mssr.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/power/r8a7794-sysc.h> - -/ { - compatible = "renesas,r8a7794"; - #address-cells = <2>; - #size-cells = <2>; - - aliases { - i2c0 = &i2c0; - i2c1 = &i2c1; - i2c2 = &i2c2; - i2c3 = &i2c3; - i2c4 = &i2c4; - i2c5 = &i2c5; - i2c6 = &i2c6; - i2c7 = &i2c7; - spi0 = &qspi; - vin0 = &vin0; - vin1 = &vin1; - }; - - /* - * The external audio clocks are configured as 0 Hz fixed frequency - * clocks by default. - * Boards that provide audio clocks should override them. - */ - audio_clka: audio_clka { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - audio_clkb: audio_clkb { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - audio_clkc: audio_clkc { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - /* External CAN clock */ - can_clk: can { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board. */ - clock-frequency = <0>; - }; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - - cpu0: cpu@0 { - device_type = "cpu"; - compatible = "arm,cortex-a7"; - reg = <0>; - clock-frequency = <1000000000>; - clocks = <&cpg CPG_CORE R8A7794_CLK_Z2>; - power-domains = <&sysc R8A7794_PD_CA7_CPU0>; - enable-method = "renesas,apmu"; - next-level-cache = <&L2_CA7>; - }; - - cpu1: cpu@1 { - device_type = "cpu"; - compatible = "arm,cortex-a7"; - reg = <1>; - clock-frequency = <1000000000>; - clocks = <&cpg CPG_CORE R8A7794_CLK_Z2>; - power-domains = <&sysc R8A7794_PD_CA7_CPU1>; - enable-method = "renesas,apmu"; - next-level-cache = <&L2_CA7>; - }; - - L2_CA7: cache-controller-0 { - compatible = "cache"; - power-domains = <&sysc R8A7794_PD_CA7_SCU>; - cache-unified; - cache-level = <2>; - }; - }; - - /* External root clock */ - extal_clk: extal { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board. */ - clock-frequency = <0>; - }; - - pmu { - compatible = "arm,cortex-a7-pmu"; - interrupts-extended = <&gic GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&cpu0>, <&cpu1>; - }; - - /* External SCIF clock */ - scif_clk: scif { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board. */ - clock-frequency = <0>; - }; - - soc { - compatible = "simple-bus"; - interrupt-parent = <&gic>; - - #address-cells = <2>; - #size-cells = <2>; - ranges; - - rwdt: watchdog@e6020000 { - compatible = "renesas,r8a7794-wdt", - "renesas,rcar-gen2-wdt"; - reg = <0 0xe6020000 0 0x0c>; - interrupts = <GIC_SPI 140 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 402>; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 402>; - status = "disabled"; - }; - - gpio0: gpio@e6050000 { - compatible = "renesas,gpio-r8a7794", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6050000 0 0x50>; - interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 0 32>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 912>; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 912>; - }; - - gpio1: gpio@e6051000 { - compatible = "renesas,gpio-r8a7794", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6051000 0 0x50>; - interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 32 26>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 911>; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 911>; - }; - - gpio2: gpio@e6052000 { - compatible = "renesas,gpio-r8a7794", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6052000 0 0x50>; - interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 64 32>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 910>; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 910>; - }; - - gpio3: gpio@e6053000 { - compatible = "renesas,gpio-r8a7794", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6053000 0 0x50>; - interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 96 32>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 909>; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 909>; - }; - - gpio4: gpio@e6054000 { - compatible = "renesas,gpio-r8a7794", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6054000 0 0x50>; - interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 128 32>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 908>; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 908>; - }; - - gpio5: gpio@e6055000 { - compatible = "renesas,gpio-r8a7794", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6055000 0 0x50>; - interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 160 28>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 907>; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 907>; - }; - - gpio6: gpio@e6055400 { - compatible = "renesas,gpio-r8a7794", - "renesas,rcar-gen2-gpio"; - reg = <0 0xe6055400 0 0x50>; - interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 192 26>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 905>; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 905>; - }; - - pfc: pinctrl@e6060000 { - compatible = "renesas,pfc-r8a7794"; - reg = <0 0xe6060000 0 0x11c>; - }; - - cpg: clock-controller@e6150000 { - compatible = "renesas,r8a7794-cpg-mssr"; - reg = <0 0xe6150000 0 0x1000>; - clocks = <&extal_clk>, <&usb_extal_clk>; - clock-names = "extal", "usb_extal"; - #clock-cells = <2>; - #power-domain-cells = <0>; - #reset-cells = <1>; - }; - - apmu@e6151000 { - compatible = "renesas,r8a7794-apmu", "renesas,apmu"; - reg = <0 0xe6151000 0 0x188>; - cpus = <&cpu0>, <&cpu1>; - }; - - rst: reset-controller@e6160000 { - compatible = "renesas,r8a7794-rst"; - reg = <0 0xe6160000 0 0x0100>; - }; - - sysc: system-controller@e6180000 { - compatible = "renesas,r8a7794-sysc"; - reg = <0 0xe6180000 0 0x0200>; - #power-domain-cells = <1>; - }; - - irqc0: interrupt-controller@e61c0000 { - compatible = "renesas,irqc-r8a7794", "renesas,irqc"; - #interrupt-cells = <2>; - interrupt-controller; - reg = <0 0xe61c0000 0 0x200>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 407>; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 407>; - }; - - ipmmu_sy0: iommu@e6280000 { - compatible = "renesas,ipmmu-r8a7794", - "renesas,ipmmu-vmsa"; - reg = <0 0xe6280000 0 0x1000>; - interrupts = <GIC_SPI 223 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 224 IRQ_TYPE_LEVEL_HIGH>; - #iommu-cells = <1>; - status = "disabled"; - }; - - ipmmu_sy1: iommu@e6290000 { - compatible = "renesas,ipmmu-r8a7794", - "renesas,ipmmu-vmsa"; - reg = <0 0xe6290000 0 0x1000>; - interrupts = <GIC_SPI 225 IRQ_TYPE_LEVEL_HIGH>; - #iommu-cells = <1>; - status = "disabled"; - }; - - ipmmu_ds: iommu@e6740000 { - compatible = "renesas,ipmmu-r8a7794", - "renesas,ipmmu-vmsa"; - reg = <0 0xe6740000 0 0x1000>; - interrupts = <GIC_SPI 198 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 199 IRQ_TYPE_LEVEL_HIGH>; - #iommu-cells = <1>; - status = "disabled"; - }; - - ipmmu_mp: iommu@ec680000 { - compatible = "renesas,ipmmu-r8a7794", - "renesas,ipmmu-vmsa"; - reg = <0 0xec680000 0 0x1000>; - interrupts = <GIC_SPI 226 IRQ_TYPE_LEVEL_HIGH>; - #iommu-cells = <1>; - status = "disabled"; - }; - - ipmmu_mx: iommu@fe951000 { - compatible = "renesas,ipmmu-r8a7794", - "renesas,ipmmu-vmsa"; - reg = <0 0xfe951000 0 0x1000>; - interrupts = <GIC_SPI 222 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 221 IRQ_TYPE_LEVEL_HIGH>; - #iommu-cells = <1>; - status = "disabled"; - }; - - ipmmu_gp: iommu@e62a0000 { - compatible = "renesas,ipmmu-r8a7794", - "renesas,ipmmu-vmsa"; - reg = <0 0xe62a0000 0 0x1000>; - interrupts = <GIC_SPI 260 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 261 IRQ_TYPE_LEVEL_HIGH>; - #iommu-cells = <1>; - status = "disabled"; - }; - - icram0: sram@e63a0000 { - compatible = "mmio-sram"; - reg = <0 0xe63a0000 0 0x12000>; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0 0xe63a0000 0x12000>; - }; - - icram1: sram@e63c0000 { - compatible = "mmio-sram"; - reg = <0 0xe63c0000 0 0x1000>; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0 0xe63c0000 0x1000>; - - smp-sram@0 { - compatible = "renesas,smp-sram"; - reg = <0 0x100>; - }; - }; - - /* The memory map in the User's Manual maps the cores to - * bus numbers - */ - i2c0: i2c@e6508000 { - compatible = "renesas,i2c-r8a7794", - "renesas,rcar-gen2-i2c"; - reg = <0 0xe6508000 0 0x40>; - interrupts = <GIC_SPI 287 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 931>; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 931>; - #address-cells = <1>; - #size-cells = <0>; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c1: i2c@e6518000 { - compatible = "renesas,i2c-r8a7794", - "renesas,rcar-gen2-i2c"; - reg = <0 0xe6518000 0 0x40>; - interrupts = <GIC_SPI 288 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 930>; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 930>; - #address-cells = <1>; - #size-cells = <0>; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c2: i2c@e6530000 { - compatible = "renesas,i2c-r8a7794", - "renesas,rcar-gen2-i2c"; - reg = <0 0xe6530000 0 0x40>; - interrupts = <GIC_SPI 286 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 929>; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 929>; - #address-cells = <1>; - #size-cells = <0>; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c3: i2c@e6540000 { - compatible = "renesas,i2c-r8a7794", - "renesas,rcar-gen2-i2c"; - reg = <0 0xe6540000 0 0x40>; - interrupts = <GIC_SPI 290 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 928>; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 928>; - #address-cells = <1>; - #size-cells = <0>; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c4: i2c@e6520000 { - compatible = "renesas,i2c-r8a7794", - "renesas,rcar-gen2-i2c"; - reg = <0 0xe6520000 0 0x40>; - interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 927>; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 927>; - #address-cells = <1>; - #size-cells = <0>; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c5: i2c@e6528000 { - compatible = "renesas,i2c-r8a7794", - "renesas,rcar-gen2-i2c"; - reg = <0 0xe6528000 0 0x40>; - interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 925>; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 925>; - #address-cells = <1>; - #size-cells = <0>; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c6: i2c@e6500000 { - compatible = "renesas,iic-r8a7794", - "renesas,rcar-gen2-iic", - "renesas,rmobile-iic"; - reg = <0 0xe6500000 0 0x425>; - interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 318>; - dmas = <&dmac0 0x61>, <&dmac0 0x62>, - <&dmac1 0x61>, <&dmac1 0x62>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 318>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c7: i2c@e6510000 { - compatible = "renesas,iic-r8a7794", - "renesas,rcar-gen2-iic", - "renesas,rmobile-iic"; - reg = <0 0xe6510000 0 0x425>; - interrupts = <GIC_SPI 175 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 323>; - dmas = <&dmac0 0x65>, <&dmac0 0x66>, - <&dmac1 0x65>, <&dmac1 0x66>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 323>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - hsusb: usb@e6590000 { - compatible = "renesas,usbhs-r8a7794", - "renesas,rcar-gen2-usbhs"; - reg = <0 0xe6590000 0 0x100>; - interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 704>; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 704>; - renesas,buswait = <4>; - phys = <&usb0 1>; - phy-names = "usb"; - status = "disabled"; - }; - - usbphy: usb-phy-controller@e6590100 { - compatible = "renesas,usb-phy-r8a7794", - "renesas,rcar-gen2-usb-phy"; - reg = <0 0xe6590100 0 0x100>; - #address-cells = <1>; - #size-cells = <0>; - clocks = <&cpg CPG_MOD 704>; - clock-names = "usbhs"; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 704>; - status = "disabled"; - - usb0: usb-phy@0 { - reg = <0>; - #phy-cells = <1>; - }; - usb2: usb-phy@2 { - reg = <2>; - #phy-cells = <1>; - }; - }; - - dmac0: dma-controller@e6700000 { - compatible = "renesas,dmac-r8a7794", - "renesas,rcar-dmac"; - reg = <0 0xe6700000 0 0x20000>; - interrupts = <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 200 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 201 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 202 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 203 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 204 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 205 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 206 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 207 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 208 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 209 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 210 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 211 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 212 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 213 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 214 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14"; - clocks = <&cpg CPG_MOD 219>; - clock-names = "fck"; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 219>; - #dma-cells = <1>; - dma-channels = <15>; - }; - - dmac1: dma-controller@e6720000 { - compatible = "renesas,dmac-r8a7794", - "renesas,rcar-dmac"; - reg = <0 0xe6720000 0 0x20000>; - interrupts = <GIC_SPI 220 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 216 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 217 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 218 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 219 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 308 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 309 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 310 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 311 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 312 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 313 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 314 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 315 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 316 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 317 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 318 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14"; - clocks = <&cpg CPG_MOD 218>; - clock-names = "fck"; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 218>; - #dma-cells = <1>; - dma-channels = <15>; - }; - - avb: ethernet@e6800000 { - compatible = "renesas,etheravb-r8a7794", - "renesas,etheravb-rcar-gen2"; - reg = <0 0xe6800000 0 0x800>, <0 0xee0e8000 0 0x4000>; - interrupts = <GIC_SPI 163 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 812>; - clock-names = "fck"; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 812>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - qspi: spi@e6b10000 { - compatible = "renesas,qspi-r8a7794", "renesas,qspi"; - reg = <0 0xe6b10000 0 0x2c>; - interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 917>; - dmas = <&dmac0 0x17>, <&dmac0 0x18>, - <&dmac1 0x17>, <&dmac1 0x18>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 917>; - num-cs = <1>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - scifa0: serial@e6c40000 { - compatible = "renesas,scifa-r8a7794", - "renesas,rcar-gen2-scifa", "renesas,scifa"; - reg = <0 0xe6c40000 0 64>; - interrupts = <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 204>; - clock-names = "fck"; - dmas = <&dmac0 0x21>, <&dmac0 0x22>, - <&dmac1 0x21>, <&dmac1 0x22>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 204>; - status = "disabled"; - }; - - scifa1: serial@e6c50000 { - compatible = "renesas,scifa-r8a7794", - "renesas,rcar-gen2-scifa", "renesas,scifa"; - reg = <0 0xe6c50000 0 64>; - interrupts = <GIC_SPI 145 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 203>; - clock-names = "fck"; - dmas = <&dmac0 0x25>, <&dmac0 0x26>, - <&dmac1 0x25>, <&dmac1 0x26>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 203>; - status = "disabled"; - }; - - scifa2: serial@e6c60000 { - compatible = "renesas,scifa-r8a7794", - "renesas,rcar-gen2-scifa", "renesas,scifa"; - reg = <0 0xe6c60000 0 64>; - interrupts = <GIC_SPI 151 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 202>; - clock-names = "fck"; - dmas = <&dmac0 0x27>, <&dmac0 0x28>, - <&dmac1 0x27>, <&dmac1 0x28>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 202>; - status = "disabled"; - }; - - scifa3: serial@e6c70000 { - compatible = "renesas,scifa-r8a7794", - "renesas,rcar-gen2-scifa", "renesas,scifa"; - reg = <0 0xe6c70000 0 64>; - interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 1106>; - clock-names = "fck"; - dmas = <&dmac0 0x1b>, <&dmac0 0x1c>, - <&dmac1 0x1b>, <&dmac1 0x1c>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 1106>; - status = "disabled"; - }; - - scifa4: serial@e6c78000 { - compatible = "renesas,scifa-r8a7794", - "renesas,rcar-gen2-scifa", "renesas,scifa"; - reg = <0 0xe6c78000 0 64>; - interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 1107>; - clock-names = "fck"; - dmas = <&dmac0 0x1f>, <&dmac0 0x20>, - <&dmac1 0x1f>, <&dmac1 0x20>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 1107>; - status = "disabled"; - }; - - scifa5: serial@e6c80000 { - compatible = "renesas,scifa-r8a7794", - "renesas,rcar-gen2-scifa", "renesas,scifa"; - reg = <0 0xe6c80000 0 64>; - interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 1108>; - clock-names = "fck"; - dmas = <&dmac0 0x23>, <&dmac0 0x24>, - <&dmac1 0x23>, <&dmac1 0x24>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 1108>; - status = "disabled"; - }; - - scifb0: serial@e6c20000 { - compatible = "renesas,scifb-r8a7794", - "renesas,rcar-gen2-scifb", "renesas,scifb"; - reg = <0 0xe6c20000 0 0x100>; - interrupts = <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 206>; - clock-names = "fck"; - dmas = <&dmac0 0x3d>, <&dmac0 0x3e>, - <&dmac1 0x3d>, <&dmac1 0x3e>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 206>; - status = "disabled"; - }; - - scifb1: serial@e6c30000 { - compatible = "renesas,scifb-r8a7794", - "renesas,rcar-gen2-scifb", "renesas,scifb"; - reg = <0 0xe6c30000 0 0x100>; - interrupts = <GIC_SPI 149 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 207>; - clock-names = "fck"; - dmas = <&dmac0 0x19>, <&dmac0 0x1a>, - <&dmac1 0x19>, <&dmac1 0x1a>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 207>; - status = "disabled"; - }; - - scifb2: serial@e6ce0000 { - compatible = "renesas,scifb-r8a7794", - "renesas,rcar-gen2-scifb", "renesas,scifb"; - reg = <0 0xe6ce0000 0 0x100>; - interrupts = <GIC_SPI 150 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 216>; - clock-names = "fck"; - dmas = <&dmac0 0x1d>, <&dmac0 0x1e>, - <&dmac1 0x1d>, <&dmac1 0x1e>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 216>; - status = "disabled"; - }; - - scif0: serial@e6e60000 { - compatible = "renesas,scif-r8a7794", - "renesas,rcar-gen2-scif", - "renesas,scif"; - reg = <0 0xe6e60000 0 64>; - interrupts = <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 721>, <&cpg CPG_CORE R8A7794_CLK_ZS>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x29>, <&dmac0 0x2a>, - <&dmac1 0x29>, <&dmac1 0x2a>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 721>; - status = "disabled"; - }; - - scif1: serial@e6e68000 { - compatible = "renesas,scif-r8a7794", - "renesas,rcar-gen2-scif", - "renesas,scif"; - reg = <0 0xe6e68000 0 64>; - interrupts = <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 720>, <&cpg CPG_CORE R8A7794_CLK_ZS>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x2d>, <&dmac0 0x2e>, - <&dmac1 0x2d>, <&dmac1 0x2e>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 720>; - status = "disabled"; - }; - - scif2: serial@e6e58000 { - compatible = "renesas,scif-r8a7794", - "renesas,rcar-gen2-scif", "renesas,scif"; - reg = <0 0xe6e58000 0 64>; - interrupts = <GIC_SPI 22 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 719>, <&cpg CPG_CORE R8A7794_CLK_ZS>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x2b>, <&dmac0 0x2c>, - <&dmac1 0x2b>, <&dmac1 0x2c>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 719>; - status = "disabled"; - }; - - scif3: serial@e6ea8000 { - compatible = "renesas,scif-r8a7794", - "renesas,rcar-gen2-scif", "renesas,scif"; - reg = <0 0xe6ea8000 0 64>; - interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 718>, <&cpg CPG_CORE R8A7794_CLK_ZS>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x2f>, <&dmac0 0x30>, - <&dmac1 0x2f>, <&dmac1 0x30>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 718>; - status = "disabled"; - }; - - scif4: serial@e6ee0000 { - compatible = "renesas,scif-r8a7794", - "renesas,rcar-gen2-scif", "renesas,scif"; - reg = <0 0xe6ee0000 0 64>; - interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 715>, <&cpg CPG_CORE R8A7794_CLK_ZS>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0xfb>, <&dmac0 0xfc>, - <&dmac1 0xfb>, <&dmac1 0xfc>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 715>; - status = "disabled"; - }; - - scif5: serial@e6ee8000 { - compatible = "renesas,scif-r8a7794", - "renesas,rcar-gen2-scif", "renesas,scif"; - reg = <0 0xe6ee8000 0 64>; - interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 714>, <&cpg CPG_CORE R8A7794_CLK_ZS>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0xfd>, <&dmac0 0xfe>, - <&dmac1 0xfd>, <&dmac1 0xfe>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 714>; - status = "disabled"; - }; - - hscif0: serial@e62c0000 { - compatible = "renesas,hscif-r8a7794", - "renesas,rcar-gen2-hscif", "renesas,hscif"; - reg = <0 0xe62c0000 0 96>; - interrupts = <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 717>, - <&cpg CPG_CORE R8A7794_CLK_ZS>, <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x39>, <&dmac0 0x3a>, - <&dmac1 0x39>, <&dmac1 0x3a>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 717>; - status = "disabled"; - }; - - hscif1: serial@e62c8000 { - compatible = "renesas,hscif-r8a7794", - "renesas,rcar-gen2-hscif", "renesas,hscif"; - reg = <0 0xe62c8000 0 96>; - interrupts = <GIC_SPI 155 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 716>, - <&cpg CPG_CORE R8A7794_CLK_ZS>, <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x4d>, <&dmac0 0x4e>, - <&dmac1 0x4d>, <&dmac1 0x4e>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 716>; - status = "disabled"; - }; - - hscif2: serial@e62d0000 { - compatible = "renesas,hscif-r8a7794", - "renesas,rcar-gen2-hscif", "renesas,hscif"; - reg = <0 0xe62d0000 0 96>; - interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 713>, <&cpg CPG_CORE R8A7794_CLK_ZS>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x3b>, <&dmac0 0x3c>, - <&dmac1 0x3b>, <&dmac1 0x3c>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 713>; - status = "disabled"; - }; - - can0: can@e6e80000 { - compatible = "renesas,can-r8a7794", - "renesas,rcar-gen2-can"; - reg = <0 0xe6e80000 0 0x1000>; - interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 916>, <&cpg CPG_CORE R8A7794_CLK_RCAN>, - <&can_clk>; - clock-names = "clkp1", "clkp2", "can_clk"; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 916>; - status = "disabled"; - }; - - can1: can@e6e88000 { - compatible = "renesas,can-r8a7794", - "renesas,rcar-gen2-can"; - reg = <0 0xe6e88000 0 0x1000>; - interrupts = <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 915>, <&cpg CPG_CORE R8A7794_CLK_RCAN>, - <&can_clk>; - clock-names = "clkp1", "clkp2", "can_clk"; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 915>; - status = "disabled"; - }; - - vin0: video@e6ef0000 { - compatible = "renesas,vin-r8a7794", - "renesas,rcar-gen2-vin"; - reg = <0 0xe6ef0000 0 0x1000>; - interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 811>; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 811>; - status = "disabled"; - }; - - vin1: video@e6ef1000 { - compatible = "renesas,vin-r8a7794", - "renesas,rcar-gen2-vin"; - reg = <0 0xe6ef1000 0 0x1000>; - interrupts = <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 810>; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 810>; - status = "disabled"; - }; - - rcar_sound: sound@ec500000 { - /* - * #sound-dai-cells is required if simple-card - * - * Single DAI : #sound-dai-cells = <0>; <&rcar_sound>; - * Multi DAI : #sound-dai-cells = <1>; <&rcar_sound N>; - */ - compatible = "renesas,rcar_sound-r8a7794", - "renesas,rcar_sound-gen2"; - reg = <0 0xec500000 0 0x1000>, /* SCU */ - <0 0xec5a0000 0 0x100>, /* ADG */ - <0 0xec540000 0 0x1000>, /* SSIU */ - <0 0xec541000 0 0x280>, /* SSI */ - <0 0xec740000 0 0x200>; /* Audio DMAC peri peri */ - reg-names = "scu", "adg", "ssiu", "ssi", "audmapp"; - - clocks = <&cpg CPG_MOD 1005>, - <&cpg CPG_MOD 1006>, <&cpg CPG_MOD 1007>, - <&cpg CPG_MOD 1008>, <&cpg CPG_MOD 1009>, - <&cpg CPG_MOD 1010>, <&cpg CPG_MOD 1011>, - <&cpg CPG_MOD 1012>, <&cpg CPG_MOD 1013>, - <&cpg CPG_MOD 1014>, <&cpg CPG_MOD 1015>, - <&cpg CPG_MOD 1025>, <&cpg CPG_MOD 1026>, - <&cpg CPG_MOD 1027>, <&cpg CPG_MOD 1028>, - <&cpg CPG_MOD 1029>, <&cpg CPG_MOD 1030>, - <&cpg CPG_MOD 1021>, <&cpg CPG_MOD 1020>, - <&cpg CPG_MOD 1021>, <&cpg CPG_MOD 1020>, - <&cpg CPG_MOD 1019>, <&cpg CPG_MOD 1018>, - <&audio_clka>, <&audio_clkb>, <&audio_clkc>, - <&cpg CPG_CORE R8A7794_CLK_M2>; - clock-names = "ssi-all", - "ssi.9", "ssi.8", "ssi.7", "ssi.6", - "ssi.5", "ssi.4", "ssi.3", "ssi.2", - "ssi.1", "ssi.0", - "src.6", "src.5", "src.4", "src.3", - "src.2", "src.1", - "ctu.0", "ctu.1", - "mix.0", "mix.1", - "dvc.0", "dvc.1", - "clk_a", "clk_b", "clk_c", "clk_i"; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 1005>, - <&cpg 1006>, <&cpg 1007>, - <&cpg 1008>, <&cpg 1009>, - <&cpg 1010>, <&cpg 1011>, - <&cpg 1012>, <&cpg 1013>, - <&cpg 1014>, <&cpg 1015>; - reset-names = "ssi-all", - "ssi.9", "ssi.8", "ssi.7", "ssi.6", - "ssi.5", "ssi.4", "ssi.3", "ssi.2", - "ssi.1", "ssi.0"; - - status = "disabled"; - - rcar_sound,dvc { - dvc0: dvc-0 { - dmas = <&audma0 0xbc>; - dma-names = "tx"; - }; - dvc1: dvc-1 { - dmas = <&audma0 0xbe>; - dma-names = "tx"; - }; - }; - - rcar_sound,mix { - mix0: mix-0 { }; - mix1: mix-1 { }; - }; - - rcar_sound,ctu { - ctu00: ctu-0 { }; - ctu01: ctu-1 { }; - ctu02: ctu-2 { }; - ctu03: ctu-3 { }; - ctu10: ctu-4 { }; - ctu11: ctu-5 { }; - ctu12: ctu-6 { }; - ctu13: ctu-7 { }; - }; - - rcar_sound,src { - src-0 { - status = "disabled"; - }; - src1: src-1 { - interrupts = <GIC_SPI 353 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x87>, <&audma0 0x9c>; - dma-names = "rx", "tx"; - }; - src2: src-2 { - interrupts = <GIC_SPI 354 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x89>, <&audma0 0x9e>; - dma-names = "rx", "tx"; - }; - src3: src-3 { - interrupts = <GIC_SPI 355 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x8b>, <&audma0 0xa0>; - dma-names = "rx", "tx"; - }; - src4: src-4 { - interrupts = <GIC_SPI 356 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x8d>, <&audma0 0xb0>; - dma-names = "rx", "tx"; - }; - src5: src-5 { - interrupts = <GIC_SPI 357 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x8f>, <&audma0 0xb2>; - dma-names = "rx", "tx"; - }; - src6: src-6 { - interrupts = <GIC_SPI 358 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x91>, <&audma0 0xb4>; - dma-names = "rx", "tx"; - }; - }; - - rcar_sound,ssi { - ssi0: ssi-0 { - interrupts = <GIC_SPI 370 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x01>, <&audma0 0x02>, - <&audma0 0x15>, <&audma0 0x16>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi1: ssi-1 { - interrupts = <GIC_SPI 371 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x03>, <&audma0 0x04>, - <&audma0 0x49>, <&audma0 0x4a>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi2: ssi-2 { - interrupts = <GIC_SPI 372 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x05>, <&audma0 0x06>, - <&audma0 0x63>, <&audma0 0x64>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi3: ssi-3 { - interrupts = <GIC_SPI 373 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x07>, <&audma0 0x08>, - <&audma0 0x6f>, <&audma0 0x70>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi4: ssi-4 { - interrupts = <GIC_SPI 374 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x09>, <&audma0 0x0a>, - <&audma0 0x71>, <&audma0 0x72>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi5: ssi-5 { - interrupts = <GIC_SPI 375 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x0b>, <&audma0 0x0c>, - <&audma0 0x73>, <&audma0 0x74>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi6: ssi-6 { - interrupts = <GIC_SPI 376 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x0d>, <&audma0 0x0e>, - <&audma0 0x75>, <&audma0 0x76>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi7: ssi-7 { - interrupts = <GIC_SPI 377 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x0f>, <&audma0 0x10>, - <&audma0 0x79>, <&audma0 0x7a>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi8: ssi-8 { - interrupts = <GIC_SPI 378 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x11>, <&audma0 0x12>, - <&audma0 0x7b>, <&audma0 0x7c>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi9: ssi-9 { - interrupts = <GIC_SPI 379 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x13>, <&audma0 0x14>, - <&audma0 0x7d>, <&audma0 0x7e>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - }; - }; - - audma0: dma-controller@ec700000 { - compatible = "renesas,dmac-r8a7794", - "renesas,rcar-dmac"; - reg = <0 0xec700000 0 0x10000>; - interrupts = <GIC_SPI 346 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 320 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 321 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 322 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 323 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 324 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 325 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 326 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 327 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 328 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 329 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 330 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 331 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 332 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", "ch4", - "ch5", "ch6", "ch7", "ch8", "ch9", - "ch10", "ch11", - "ch12"; - clocks = <&cpg CPG_MOD 502>; - clock-names = "fck"; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 502>; - #dma-cells = <1>; - dma-channels = <13>; - }; - - pci0: pci@ee090000 { - compatible = "renesas,pci-r8a7794", - "renesas,pci-rcar-gen2"; - device_type = "pci"; - reg = <0 0xee090000 0 0xc00>, - <0 0xee080000 0 0x1100>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 703>; - status = "disabled"; - - bus-range = <0 0>; - #address-cells = <3>; - #size-cells = <2>; - #interrupt-cells = <1>; - ranges = <0x02000000 0 0xee080000 0 0xee080000 0 0x00010000>; - interrupt-map-mask = <0xf800 0 0 0x7>; - interrupt-map = <0x0000 0 0 1 &gic GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>, - <0x0800 0 0 1 &gic GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>, - <0x1000 0 0 2 &gic GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - - usb@1,0 { - reg = <0x800 0 0 0 0>; - phys = <&usb0 0>; - phy-names = "usb"; - }; - - usb@2,0 { - reg = <0x1000 0 0 0 0>; - phys = <&usb0 0>; - phy-names = "usb"; - }; - }; - - pci1: pci@ee0d0000 { - compatible = "renesas,pci-r8a7794", - "renesas,pci-rcar-gen2"; - device_type = "pci"; - reg = <0 0xee0d0000 0 0xc00>, - <0 0xee0c0000 0 0x1100>; - interrupts = <GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 703>; - status = "disabled"; - - bus-range = <1 1>; - #address-cells = <3>; - #size-cells = <2>; - #interrupt-cells = <1>; - ranges = <0x02000000 0 0xee0c0000 0 0xee0c0000 0 0x00010000>; - interrupt-map-mask = <0xf800 0 0 0x7>; - interrupt-map = <0x0000 0 0 1 &gic GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH>, - <0x0800 0 0 1 &gic GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH>, - <0x1000 0 0 2 &gic GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH>; - - usb@1,0 { - reg = <0x10800 0 0 0 0>; - phys = <&usb2 0>; - phy-names = "usb"; - }; - - usb@2,0 { - reg = <0x11000 0 0 0 0>; - phys = <&usb2 0>; - phy-names = "usb"; - }; - }; - - sdhi0: mmc@ee100000 { - compatible = "renesas,sdhi-r8a7794", - "renesas,rcar-gen2-sdhi"; - reg = <0 0xee100000 0 0x328>; - interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 314>; - dmas = <&dmac0 0xcd>, <&dmac0 0xce>, - <&dmac1 0xcd>, <&dmac1 0xce>; - dma-names = "tx", "rx", "tx", "rx"; - max-frequency = <195000000>; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 314>; - status = "disabled"; - }; - - sdhi1: mmc@ee140000 { - compatible = "renesas,sdhi-r8a7794", - "renesas,rcar-gen2-sdhi"; - reg = <0 0xee140000 0 0x100>; - interrupts = <GIC_SPI 167 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 312>; - dmas = <&dmac0 0xc1>, <&dmac0 0xc2>, - <&dmac1 0xc1>, <&dmac1 0xc2>; - dma-names = "tx", "rx", "tx", "rx"; - max-frequency = <97500000>; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 312>; - status = "disabled"; - }; - - sdhi2: mmc@ee160000 { - compatible = "renesas,sdhi-r8a7794", - "renesas,rcar-gen2-sdhi"; - reg = <0 0xee160000 0 0x100>; - interrupts = <GIC_SPI 168 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 311>; - dmas = <&dmac0 0xd3>, <&dmac0 0xd4>, - <&dmac1 0xd3>, <&dmac1 0xd4>; - dma-names = "tx", "rx", "tx", "rx"; - max-frequency = <97500000>; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 311>; - status = "disabled"; - }; - - mmcif0: mmc@ee200000 { - compatible = "renesas,mmcif-r8a7794", - "renesas,sh-mmcif"; - reg = <0 0xee200000 0 0x80>; - interrupts = <GIC_SPI 169 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 315>; - dmas = <&dmac0 0xd1>, <&dmac0 0xd2>, - <&dmac1 0xd1>, <&dmac1 0xd2>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 315>; - reg-io-width = <4>; - status = "disabled"; - }; - - ether: ethernet@ee700000 { - compatible = "renesas,ether-r8a7794", - "renesas,rcar-gen2-ether"; - reg = <0 0xee700000 0 0x400>; - interrupts = <GIC_SPI 162 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 813>; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 813>; - phy-mode = "rmii"; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - gic: interrupt-controller@f1001000 { - compatible = "arm,gic-400"; - #interrupt-cells = <3>; - #address-cells = <0>; - interrupt-controller; - reg = <0 0xf1001000 0 0x1000>, - <0 0xf1002000 0 0x2000>, - <0 0xf1004000 0 0x2000>, - <0 0xf1006000 0 0x2000>; - interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_HIGH)>; - clocks = <&cpg CPG_MOD 408>; - clock-names = "clk"; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 408>; - }; - - vsp@fe928000 { - compatible = "renesas,vsp1"; - reg = <0 0xfe928000 0 0x8000>; - interrupts = <GIC_SPI 267 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 131>; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 131>; - }; - - vsp@fe930000 { - compatible = "renesas,vsp1"; - reg = <0 0xfe930000 0 0x8000>; - interrupts = <GIC_SPI 246 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 128>; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 128>; - }; - - fdp1@fe940000 { - compatible = "renesas,fdp1"; - reg = <0 0xfe940000 0 0x2400>; - interrupts = <GIC_SPI 262 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 119>; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 119>; - }; - - du: display@feb00000 { - compatible = "renesas,du-r8a7794"; - reg = <0 0xfeb00000 0 0x40000>; - interrupts = <GIC_SPI 256 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 268 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 724>, <&cpg CPG_MOD 723>; - clock-names = "du.0", "du.1"; - resets = <&cpg 724>; - reset-names = "du.0"; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - du_out_rgb0: endpoint { - }; - }; - port@1 { - reg = <1>; - du_out_rgb1: endpoint { - }; - }; - }; - }; - - prr: chipid@ff000044 { - compatible = "renesas,prr"; - reg = <0 0xff000044 0 4>; - }; - - cmt0: timer@ffca0000 { - compatible = "renesas,r8a7794-cmt0", - "renesas,rcar-gen2-cmt0"; - reg = <0 0xffca0000 0 0x1004>; - interrupts = <GIC_SPI 142 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 143 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 124>; - clock-names = "fck"; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 124>; - - status = "disabled"; - }; - - cmt1: timer@e6130000 { - compatible = "renesas,r8a7794-cmt1", - "renesas,rcar-gen2-cmt1"; - reg = <0 0xe6130000 0 0x1004>; - interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 127 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 329>; - clock-names = "fck"; - power-domains = <&sysc R8A7794_PD_ALWAYS_ON>; - resets = <&cpg 329>; - - status = "disabled"; - }; - }; - - timer { - compatible = "arm,armv7-timer"; - interrupts-extended = <&gic GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>; - }; - - /* External USB clock - can be overridden by the board */ - usb_extal_clk: usb_extal { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <48000000>; - }; -}; diff --git a/arch/arm/dts/r8a77950-salvator-x.dts b/arch/arm/dts/r8a77950-salvator-x.dts deleted file mode 100644 index c6ca61a8ed4..00000000000 --- a/arch/arm/dts/r8a77950-salvator-x.dts +++ /dev/null @@ -1,49 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the Salvator-X board with R-Car H3 ES1.x - * - * Copyright (C) 2015 Renesas Electronics Corp. - */ - -/dts-v1/; -#include "r8a77950.dtsi" -#include "salvator-x.dtsi" - -/ { - model = "Renesas Salvator-X board based on r8a77950"; - compatible = "renesas,salvator-x", "renesas,r8a7795"; - - memory@48000000 { - device_type = "memory"; - /* first 128MB is reserved for secure area. */ - reg = <0x0 0x48000000 0x0 0x38000000>; - }; - - memory@500000000 { - device_type = "memory"; - reg = <0x5 0x00000000 0x0 0x40000000>; - }; - - memory@600000000 { - device_type = "memory"; - reg = <0x6 0x00000000 0x0 0x40000000>; - }; - - memory@700000000 { - device_type = "memory"; - reg = <0x7 0x00000000 0x0 0x40000000>; - }; -}; - -&du { - clocks = <&cpg CPG_MOD 724>, - <&cpg CPG_MOD 723>, - <&cpg CPG_MOD 722>, - <&cpg CPG_MOD 721>, - <&versaclock5 1>, - <&x21_clk>, - <&x22_clk>, - <&versaclock5 2>; - clock-names = "du.0", "du.1", "du.2", "du.3", - "dclkin.0", "dclkin.1", "dclkin.2", "dclkin.3"; -}; diff --git a/arch/arm/dts/r8a77950-ulcb.dts b/arch/arm/dts/r8a77950-ulcb.dts deleted file mode 100644 index 5340579931e..00000000000 --- a/arch/arm/dts/r8a77950-ulcb.dts +++ /dev/null @@ -1,37 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the H3ULCB (R-Car Starter Kit Premier) board with R-Car H3 ES1.x - * - * Copyright (C) 2016 Renesas Electronics Corp. - * Copyright (C) 2016 Cogent Embedded, Inc. - */ - -/dts-v1/; -#include "r8a77950.dtsi" -#include "ulcb.dtsi" - -/ { - model = "Renesas H3ULCB board based on r8a77950"; - compatible = "renesas,h3ulcb", "renesas,r8a7795"; - - memory@48000000 { - device_type = "memory"; - /* first 128MB is reserved for secure area. */ - reg = <0x0 0x48000000 0x0 0x38000000>; - }; - - memory@500000000 { - device_type = "memory"; - reg = <0x5 0x00000000 0x0 0x40000000>; - }; - - memory@600000000 { - device_type = "memory"; - reg = <0x6 0x00000000 0x0 0x40000000>; - }; - - memory@700000000 { - device_type = "memory"; - reg = <0x7 0x00000000 0x0 0x40000000>; - }; -}; diff --git a/arch/arm/dts/r8a77950.dtsi b/arch/arm/dts/r8a77950.dtsi deleted file mode 100644 index 57eb88177e9..00000000000 --- a/arch/arm/dts/r8a77950.dtsi +++ /dev/null @@ -1,330 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the R-Car H3 (R8A77950) SoC - * - * Copyright (C) 2015 Renesas Electronics Corp. - */ - -#include "r8a77951.dtsi" - -#undef SOC_HAS_USB2_CH3 - -&audma0 { - iommus = <&ipmmu_mp1 0>, <&ipmmu_mp1 1>, - <&ipmmu_mp1 2>, <&ipmmu_mp1 3>, - <&ipmmu_mp1 4>, <&ipmmu_mp1 5>, - <&ipmmu_mp1 6>, <&ipmmu_mp1 7>, - <&ipmmu_mp1 8>, <&ipmmu_mp1 9>, - <&ipmmu_mp1 10>, <&ipmmu_mp1 11>, - <&ipmmu_mp1 12>, <&ipmmu_mp1 13>, - <&ipmmu_mp1 14>, <&ipmmu_mp1 15>; -}; - -&audma1 { - iommus = <&ipmmu_mp1 16>, <&ipmmu_mp1 17>, - <&ipmmu_mp1 18>, <&ipmmu_mp1 19>, - <&ipmmu_mp1 20>, <&ipmmu_mp1 21>, - <&ipmmu_mp1 22>, <&ipmmu_mp1 23>, - <&ipmmu_mp1 24>, <&ipmmu_mp1 25>, - <&ipmmu_mp1 26>, <&ipmmu_mp1 27>, - <&ipmmu_mp1 28>, <&ipmmu_mp1 29>, - <&ipmmu_mp1 30>, <&ipmmu_mp1 31>; -}; - -&cluster0_opp { - /delete-node/ opp-1600000000; - /delete-node/ opp-1700000000; -}; - -&du { - renesas,vsps = <&vspd0 0>, <&vspd1 0>, <&vspd2 0>, <&vspd3 0>; -}; - -&fcpvb1 { - iommus = <&ipmmu_vp0 7>; -}; - -&fcpf1 { - iommus = <&ipmmu_vp0 1>; -}; - -&fcpvi1 { - iommus = <&ipmmu_vp0 9>; -}; - -&fcpvd2 { - iommus = <&ipmmu_vi0 10>; -}; - -&gpio1 { - gpio-ranges = <&pfc 0 32 28>; -}; - -&ipmmu_vi0 { - renesas,ipmmu-main = <&ipmmu_mm 11>; -}; - -&ipmmu_vp0 { - renesas,ipmmu-main = <&ipmmu_mm 12>; -}; - -&ipmmu_vc0 { - renesas,ipmmu-main = <&ipmmu_mm 9>; -}; - -&ipmmu_vc1 { - renesas,ipmmu-main = <&ipmmu_mm 10>; -}; - -&ipmmu_rt { - renesas,ipmmu-main = <&ipmmu_mm 7>; -}; - -&soc { - /delete-node/ dma-controller@e6460000; - /delete-node/ dma-controller@e6470000; - - ipmmu_mp1: iommu@ec680000 { - compatible = "renesas,ipmmu-r8a7795"; - reg = <0 0xec680000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 5>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_sy: iommu@e7730000 { - compatible = "renesas,ipmmu-r8a7795"; - reg = <0 0xe7730000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 8>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - /delete-node/ iommu@fd950000; - /delete-node/ iommu@fd960000; - /delete-node/ iommu@fd970000; - /delete-node/ iommu@febe0000; - /delete-node/ iommu@fe980000; - - xhci1: usb@ee040000 { - compatible = "renesas,xhci-r8a7795", "renesas,rcar-gen3-xhci"; - reg = <0 0xee040000 0 0xc00>; - interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 327>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 327>; - status = "disabled"; - }; - - /delete-node/ usb@e659c000; - /delete-node/ usb@ee0e0000; - /delete-node/ usb@ee0e0100; - - /delete-node/ usb-phy@ee0e0200; - - fdp1@fe948000 { - compatible = "renesas,fdp1"; - reg = <0 0xfe948000 0 0x2400>; - interrupts = <GIC_SPI 264 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 117>; - power-domains = <&sysc R8A7795_PD_A3VP>; - resets = <&cpg 117>; - renesas,fcp = <&fcpf2>; - }; - - fcpf2: fcp@fe952000 { - compatible = "renesas,fcpf"; - reg = <0 0xfe952000 0 0x200>; - clocks = <&cpg CPG_MOD 613>; - power-domains = <&sysc R8A7795_PD_A3VP>; - resets = <&cpg 613>; - iommus = <&ipmmu_vp0 2>; - }; - - fcpvd3: fcp@fea3f000 { - compatible = "renesas,fcpv"; - reg = <0 0xfea3f000 0 0x200>; - clocks = <&cpg CPG_MOD 600>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 600>; - iommus = <&ipmmu_vi0 11>; - }; - - fcpvi2: fcp@fe9cf000 { - compatible = "renesas,fcpv"; - reg = <0 0xfe9cf000 0 0x200>; - clocks = <&cpg CPG_MOD 609>; - power-domains = <&sysc R8A7795_PD_A3VP>; - resets = <&cpg 609>; - iommus = <&ipmmu_vp0 10>; - }; - - vspd3: vsp@fea38000 { - compatible = "renesas,vsp2"; - reg = <0 0xfea38000 0 0x5000>; - interrupts = <GIC_SPI 469 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 620>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 620>; - - renesas,fcp = <&fcpvd3>; - }; - - vspi2: vsp@fe9c0000 { - compatible = "renesas,vsp2"; - reg = <0 0xfe9c0000 0 0x8000>; - interrupts = <GIC_SPI 446 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 629>; - power-domains = <&sysc R8A7795_PD_A3VP>; - resets = <&cpg 629>; - - renesas,fcp = <&fcpvi2>; - }; - - csi21: csi2@fea90000 { - compatible = "renesas,r8a7795-csi2"; - reg = <0 0xfea90000 0 0x10000>; - interrupts = <GIC_SPI 185 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 713>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 713>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - csi21vin0: endpoint@0 { - reg = <0>; - remote-endpoint = <&vin0csi21>; - }; - csi21vin1: endpoint@1 { - reg = <1>; - remote-endpoint = <&vin1csi21>; - }; - csi21vin2: endpoint@2 { - reg = <2>; - remote-endpoint = <&vin2csi21>; - }; - csi21vin3: endpoint@3 { - reg = <3>; - remote-endpoint = <&vin3csi21>; - }; - csi21vin4: endpoint@4 { - reg = <4>; - remote-endpoint = <&vin4csi21>; - }; - csi21vin5: endpoint@5 { - reg = <5>; - remote-endpoint = <&vin5csi21>; - }; - csi21vin6: endpoint@6 { - reg = <6>; - remote-endpoint = <&vin6csi21>; - }; - csi21vin7: endpoint@7 { - reg = <7>; - remote-endpoint = <&vin7csi21>; - }; - }; - }; - }; -}; - -&vin0 { - ports { - port@1 { - vin0csi21: endpoint@1 { - reg = <1>; - remote-endpoint = <&csi21vin0>; - }; - }; - }; -}; - -&vin1 { - ports { - port@1 { - vin1csi21: endpoint@1 { - reg = <1>; - remote-endpoint = <&csi21vin1>; - }; - }; - }; -}; - -&vin2 { - ports { - port@1 { - vin2csi21: endpoint@1 { - reg = <1>; - remote-endpoint = <&csi21vin2>; - }; - }; - }; -}; - -&vin3 { - ports { - port@1 { - vin3csi21: endpoint@1 { - reg = <1>; - remote-endpoint = <&csi21vin3>; - }; - }; - }; -}; - -&vin4 { - ports { - port@1 { - vin4csi21: endpoint@1 { - reg = <1>; - remote-endpoint = <&csi21vin4>; - }; - }; - }; -}; - -&vin5 { - ports { - port@1 { - vin5csi21: endpoint@1 { - reg = <1>; - remote-endpoint = <&csi21vin5>; - }; - }; - }; -}; - -&vin6 { - ports { - port@1 { - vin6csi21: endpoint@1 { - reg = <1>; - remote-endpoint = <&csi21vin6>; - }; - }; - }; -}; - -&vin7 { - ports { - port@1 { - vin7csi21: endpoint@1 { - reg = <1>; - remote-endpoint = <&csi21vin7>; - }; - }; - }; -}; diff --git a/arch/arm/dts/r8a77951.dtsi b/arch/arm/dts/r8a77951.dtsi deleted file mode 100644 index 6d15229d25a..00000000000 --- a/arch/arm/dts/r8a77951.dtsi +++ /dev/null @@ -1,3485 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the R-Car H3 (R8A77951) SoC - * - * Copyright (C) 2015 Renesas Electronics Corp. - */ - -#include <dt-bindings/clock/r8a7795-cpg-mssr.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/power/r8a7795-sysc.h> - -#define CPG_AUDIO_CLK_I R8A7795_CLK_S0D4 - -#define SOC_HAS_HDMI1 -#define SOC_HAS_SATA -#define SOC_HAS_USB2_CH2 -#define SOC_HAS_USB2_CH3 - -/ { - compatible = "renesas,r8a7795"; - #address-cells = <2>; - #size-cells = <2>; - - /* - * The external audio clocks are configured as 0 Hz fixed frequency - * clocks by default. - * Boards that provide audio clocks should override them. - */ - audio_clk_a: audio_clk_a { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - audio_clk_b: audio_clk_b { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - audio_clk_c: audio_clk_c { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - /* External CAN clock - to be overridden by boards that provide it */ - can_clk: can { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - cluster0_opp: opp-table-0 { - compatible = "operating-points-v2"; - opp-shared; - - opp-500000000 { - opp-hz = /bits/ 64 <500000000>; - opp-microvolt = <830000>; - clock-latency-ns = <300000>; - }; - opp-1000000000 { - opp-hz = /bits/ 64 <1000000000>; - opp-microvolt = <830000>; - clock-latency-ns = <300000>; - }; - opp-1500000000 { - opp-hz = /bits/ 64 <1500000000>; - opp-microvolt = <830000>; - clock-latency-ns = <300000>; - opp-suspend; - }; - opp-1600000000 { - opp-hz = /bits/ 64 <1600000000>; - opp-microvolt = <900000>; - clock-latency-ns = <300000>; - }; - opp-1700000000 { - opp-hz = /bits/ 64 <1700000000>; - opp-microvolt = <960000>; - clock-latency-ns = <300000>; - turbo-mode; - }; - }; - - cluster1_opp: opp-table-1 { - compatible = "operating-points-v2"; - opp-shared; - - opp-800000000 { - opp-hz = /bits/ 64 <800000000>; - opp-microvolt = <820000>; - clock-latency-ns = <300000>; - }; - opp-1000000000 { - opp-hz = /bits/ 64 <1000000000>; - opp-microvolt = <820000>; - clock-latency-ns = <300000>; - }; - opp-1200000000 { - opp-hz = /bits/ 64 <1200000000>; - opp-microvolt = <820000>; - clock-latency-ns = <300000>; - }; - }; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - - cpu-map { - cluster0 { - core0 { - cpu = <&a57_0>; - }; - core1 { - cpu = <&a57_1>; - }; - core2 { - cpu = <&a57_2>; - }; - core3 { - cpu = <&a57_3>; - }; - }; - - cluster1 { - core0 { - cpu = <&a53_0>; - }; - core1 { - cpu = <&a53_1>; - }; - core2 { - cpu = <&a53_2>; - }; - core3 { - cpu = <&a53_3>; - }; - }; - }; - - a57_0: cpu@0 { - compatible = "arm,cortex-a57"; - reg = <0x0>; - device_type = "cpu"; - power-domains = <&sysc R8A7795_PD_CA57_CPU0>; - next-level-cache = <&L2_CA57>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_0>; - dynamic-power-coefficient = <854>; - clocks = <&cpg CPG_CORE R8A7795_CLK_Z>; - operating-points-v2 = <&cluster0_opp>; - capacity-dmips-mhz = <1024>; - #cooling-cells = <2>; - }; - - a57_1: cpu@1 { - compatible = "arm,cortex-a57"; - reg = <0x1>; - device_type = "cpu"; - power-domains = <&sysc R8A7795_PD_CA57_CPU1>; - next-level-cache = <&L2_CA57>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_0>; - clocks = <&cpg CPG_CORE R8A7795_CLK_Z>; - operating-points-v2 = <&cluster0_opp>; - capacity-dmips-mhz = <1024>; - #cooling-cells = <2>; - }; - - a57_2: cpu@2 { - compatible = "arm,cortex-a57"; - reg = <0x2>; - device_type = "cpu"; - power-domains = <&sysc R8A7795_PD_CA57_CPU2>; - next-level-cache = <&L2_CA57>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_0>; - clocks = <&cpg CPG_CORE R8A7795_CLK_Z>; - operating-points-v2 = <&cluster0_opp>; - capacity-dmips-mhz = <1024>; - #cooling-cells = <2>; - }; - - a57_3: cpu@3 { - compatible = "arm,cortex-a57"; - reg = <0x3>; - device_type = "cpu"; - power-domains = <&sysc R8A7795_PD_CA57_CPU3>; - next-level-cache = <&L2_CA57>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_0>; - clocks = <&cpg CPG_CORE R8A7795_CLK_Z>; - operating-points-v2 = <&cluster0_opp>; - capacity-dmips-mhz = <1024>; - #cooling-cells = <2>; - }; - - a53_0: cpu@100 { - compatible = "arm,cortex-a53"; - reg = <0x100>; - device_type = "cpu"; - power-domains = <&sysc R8A7795_PD_CA53_CPU0>; - next-level-cache = <&L2_CA53>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_1>; - #cooling-cells = <2>; - dynamic-power-coefficient = <277>; - clocks = <&cpg CPG_CORE R8A7795_CLK_Z2>; - operating-points-v2 = <&cluster1_opp>; - capacity-dmips-mhz = <535>; - }; - - a53_1: cpu@101 { - compatible = "arm,cortex-a53"; - reg = <0x101>; - device_type = "cpu"; - power-domains = <&sysc R8A7795_PD_CA53_CPU1>; - next-level-cache = <&L2_CA53>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_1>; - clocks = <&cpg CPG_CORE R8A7795_CLK_Z2>; - operating-points-v2 = <&cluster1_opp>; - capacity-dmips-mhz = <535>; - }; - - a53_2: cpu@102 { - compatible = "arm,cortex-a53"; - reg = <0x102>; - device_type = "cpu"; - power-domains = <&sysc R8A7795_PD_CA53_CPU2>; - next-level-cache = <&L2_CA53>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_1>; - clocks = <&cpg CPG_CORE R8A7795_CLK_Z2>; - operating-points-v2 = <&cluster1_opp>; - capacity-dmips-mhz = <535>; - }; - - a53_3: cpu@103 { - compatible = "arm,cortex-a53"; - reg = <0x103>; - device_type = "cpu"; - power-domains = <&sysc R8A7795_PD_CA53_CPU3>; - next-level-cache = <&L2_CA53>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_1>; - clocks = <&cpg CPG_CORE R8A7795_CLK_Z2>; - operating-points-v2 = <&cluster1_opp>; - capacity-dmips-mhz = <535>; - }; - - L2_CA57: cache-controller-0 { - compatible = "cache"; - power-domains = <&sysc R8A7795_PD_CA57_SCU>; - cache-unified; - cache-level = <2>; - }; - - L2_CA53: cache-controller-1 { - compatible = "cache"; - power-domains = <&sysc R8A7795_PD_CA53_SCU>; - cache-unified; - cache-level = <2>; - }; - - idle-states { - entry-method = "psci"; - - CPU_SLEEP_0: cpu-sleep-0 { - compatible = "arm,idle-state"; - arm,psci-suspend-param = <0x0010000>; - local-timer-stop; - entry-latency-us = <400>; - exit-latency-us = <500>; - min-residency-us = <4000>; - }; - - CPU_SLEEP_1: cpu-sleep-1 { - compatible = "arm,idle-state"; - arm,psci-suspend-param = <0x0010000>; - local-timer-stop; - entry-latency-us = <700>; - exit-latency-us = <700>; - min-residency-us = <5000>; - }; - }; - }; - - extal_clk: extal { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board */ - clock-frequency = <0>; - }; - - extalr_clk: extalr { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board */ - clock-frequency = <0>; - }; - - /* External PCIe clock - can be overridden by the board */ - pcie_bus_clk: pcie_bus { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - pmu_a53 { - compatible = "arm,cortex-a53-pmu"; - interrupts-extended = <&gic GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&a53_0>, - <&a53_1>, - <&a53_2>, - <&a53_3>; - }; - - pmu_a57 { - compatible = "arm,cortex-a57-pmu"; - interrupts-extended = <&gic GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 75 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&a57_0>, - <&a57_1>, - <&a57_2>, - <&a57_3>; - }; - - psci { - compatible = "arm,psci-1.0", "arm,psci-0.2"; - method = "smc"; - }; - - /* External SCIF clock - to be overridden by boards that provide it */ - scif_clk: scif { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - soc: soc { - compatible = "simple-bus"; - interrupt-parent = <&gic>; - - #address-cells = <2>; - #size-cells = <2>; - ranges; - - rwdt: watchdog@e6020000 { - compatible = "renesas,r8a7795-wdt", "renesas,rcar-gen3-wdt"; - reg = <0 0xe6020000 0 0x0c>; - interrupts = <GIC_SPI 140 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 402>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 402>; - status = "disabled"; - }; - - gpio0: gpio@e6050000 { - compatible = "renesas,gpio-r8a7795", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6050000 0 0x50>; - interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 0 16>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 912>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 912>; - }; - - gpio1: gpio@e6051000 { - compatible = "renesas,gpio-r8a7795", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6051000 0 0x50>; - interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 32 29>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 911>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 911>; - }; - - gpio2: gpio@e6052000 { - compatible = "renesas,gpio-r8a7795", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6052000 0 0x50>; - interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 64 15>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 910>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 910>; - }; - - gpio3: gpio@e6053000 { - compatible = "renesas,gpio-r8a7795", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6053000 0 0x50>; - interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 96 16>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 909>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 909>; - }; - - gpio4: gpio@e6054000 { - compatible = "renesas,gpio-r8a7795", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6054000 0 0x50>; - interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 128 18>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 908>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 908>; - }; - - gpio5: gpio@e6055000 { - compatible = "renesas,gpio-r8a7795", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6055000 0 0x50>; - interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 160 26>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 907>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 907>; - }; - - gpio6: gpio@e6055400 { - compatible = "renesas,gpio-r8a7795", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6055400 0 0x50>; - interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 192 32>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 906>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 906>; - }; - - gpio7: gpio@e6055800 { - compatible = "renesas,gpio-r8a7795", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6055800 0 0x50>; - interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 224 4>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 905>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 905>; - }; - - pfc: pinctrl@e6060000 { - compatible = "renesas,pfc-r8a7795"; - reg = <0 0xe6060000 0 0x50c>; - }; - - cmt0: timer@e60f0000 { - compatible = "renesas,r8a7795-cmt0", - "renesas,rcar-gen3-cmt0"; - reg = <0 0xe60f0000 0 0x1004>; - interrupts = <GIC_SPI 142 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 143 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 303>; - clock-names = "fck"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 303>; - status = "disabled"; - }; - - cmt1: timer@e6130000 { - compatible = "renesas,r8a7795-cmt1", - "renesas,rcar-gen3-cmt1"; - reg = <0 0xe6130000 0 0x1004>; - interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 127 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 302>; - clock-names = "fck"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 302>; - status = "disabled"; - }; - - cmt2: timer@e6140000 { - compatible = "renesas,r8a7795-cmt1", - "renesas,rcar-gen3-cmt1"; - reg = <0 0xe6140000 0 0x1004>; - interrupts = <GIC_SPI 398 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 399 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 400 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 401 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 402 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 403 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 404 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 405 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 301>; - clock-names = "fck"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 301>; - status = "disabled"; - }; - - cmt3: timer@e6148000 { - compatible = "renesas,r8a7795-cmt1", - "renesas,rcar-gen3-cmt1"; - reg = <0 0xe6148000 0 0x1004>; - interrupts = <GIC_SPI 470 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 471 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 472 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 473 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 474 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 475 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 476 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 477 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 300>; - clock-names = "fck"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 300>; - status = "disabled"; - }; - - cpg: clock-controller@e6150000 { - compatible = "renesas,r8a7795-cpg-mssr"; - reg = <0 0xe6150000 0 0x1000>; - clocks = <&extal_clk>, <&extalr_clk>; - clock-names = "extal", "extalr"; - #clock-cells = <2>; - #power-domain-cells = <0>; - #reset-cells = <1>; - }; - - rst: reset-controller@e6160000 { - compatible = "renesas,r8a7795-rst"; - reg = <0 0xe6160000 0 0x0200>; - }; - - sysc: system-controller@e6180000 { - compatible = "renesas,r8a7795-sysc"; - reg = <0 0xe6180000 0 0x0400>; - #power-domain-cells = <1>; - }; - - tsc: thermal@e6198000 { - compatible = "renesas,r8a7795-thermal"; - reg = <0 0xe6198000 0 0x100>, - <0 0xe61a0000 0 0x100>, - <0 0xe61a8000 0 0x100>; - interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 522>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 522>; - #thermal-sensor-cells = <1>; - }; - - intc_ex: interrupt-controller@e61c0000 { - compatible = "renesas,intc-ex-r8a7795", "renesas,irqc"; - #interrupt-cells = <2>; - interrupt-controller; - reg = <0 0xe61c0000 0 0x200>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 161 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 407>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 407>; - }; - - tmu0: timer@e61e0000 { - compatible = "renesas,tmu-r8a7795", "renesas,tmu"; - reg = <0 0xe61e0000 0 0x30>; - interrupts = <GIC_SPI 136 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 137 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 138 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 125>; - clock-names = "fck"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 125>; - status = "disabled"; - }; - - tmu1: timer@e6fc0000 { - compatible = "renesas,tmu-r8a7795", "renesas,tmu"; - reg = <0 0xe6fc0000 0 0x30>; - interrupts = <GIC_SPI 128 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 129 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 130 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 124>; - clock-names = "fck"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 124>; - status = "disabled"; - }; - - tmu2: timer@e6fd0000 { - compatible = "renesas,tmu-r8a7795", "renesas,tmu"; - reg = <0 0xe6fd0000 0 0x30>; - interrupts = <GIC_SPI 303 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 304 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 305 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 123>; - clock-names = "fck"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 123>; - status = "disabled"; - }; - - tmu3: timer@e6fe0000 { - compatible = "renesas,tmu-r8a7795", "renesas,tmu"; - reg = <0 0xe6fe0000 0 0x30>; - interrupts = <GIC_SPI 131 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 132 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 133 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 122>; - clock-names = "fck"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 122>; - status = "disabled"; - }; - - tmu4: timer@ffc00000 { - compatible = "renesas,tmu-r8a7795", "renesas,tmu"; - reg = <0 0xffc00000 0 0x30>; - interrupts = <GIC_SPI 406 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 407 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 408 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 121>; - clock-names = "fck"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 121>; - status = "disabled"; - }; - - i2c0: i2c@e6500000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a7795", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6500000 0 0x40>; - interrupts = <GIC_SPI 287 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 931>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 931>; - dmas = <&dmac1 0x91>, <&dmac1 0x90>, - <&dmac2 0x91>, <&dmac2 0x90>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - status = "disabled"; - }; - - i2c1: i2c@e6508000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a7795", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6508000 0 0x40>; - interrupts = <GIC_SPI 288 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 930>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 930>; - dmas = <&dmac1 0x93>, <&dmac1 0x92>, - <&dmac2 0x93>, <&dmac2 0x92>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c2: i2c@e6510000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a7795", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6510000 0 0x40>; - interrupts = <GIC_SPI 286 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 929>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 929>; - dmas = <&dmac1 0x95>, <&dmac1 0x94>, - <&dmac2 0x95>, <&dmac2 0x94>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c3: i2c@e66d0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a7795", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66d0000 0 0x40>; - interrupts = <GIC_SPI 290 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 928>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 928>; - dmas = <&dmac0 0x97>, <&dmac0 0x96>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - status = "disabled"; - }; - - i2c4: i2c@e66d8000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a7795", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66d8000 0 0x40>; - interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 927>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 927>; - dmas = <&dmac0 0x99>, <&dmac0 0x98>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - status = "disabled"; - }; - - i2c5: i2c@e66e0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a7795", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66e0000 0 0x40>; - interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 919>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 919>; - dmas = <&dmac0 0x9b>, <&dmac0 0x9a>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - status = "disabled"; - }; - - i2c6: i2c@e66e8000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a7795", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66e8000 0 0x40>; - interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 918>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 918>; - dmas = <&dmac0 0x9d>, <&dmac0 0x9c>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c_dvfs: i2c@e60b0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,iic-r8a7795", - "renesas,rcar-gen3-iic", - "renesas,rmobile-iic"; - reg = <0 0xe60b0000 0 0x425>; - interrupts = <GIC_SPI 173 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 926>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 926>; - dmas = <&dmac0 0x11>, <&dmac0 0x10>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - hscif0: serial@e6540000 { - compatible = "renesas,hscif-r8a7795", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe6540000 0 96>; - interrupts = <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 520>, - <&cpg CPG_CORE R8A7795_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x31>, <&dmac1 0x30>, - <&dmac2 0x31>, <&dmac2 0x30>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 520>; - status = "disabled"; - }; - - hscif1: serial@e6550000 { - compatible = "renesas,hscif-r8a7795", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe6550000 0 96>; - interrupts = <GIC_SPI 155 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 519>, - <&cpg CPG_CORE R8A7795_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x33>, <&dmac1 0x32>, - <&dmac2 0x33>, <&dmac2 0x32>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 519>; - status = "disabled"; - }; - - hscif2: serial@e6560000 { - compatible = "renesas,hscif-r8a7795", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe6560000 0 96>; - interrupts = <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 518>, - <&cpg CPG_CORE R8A7795_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x35>, <&dmac1 0x34>, - <&dmac2 0x35>, <&dmac2 0x34>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 518>; - status = "disabled"; - }; - - hscif3: serial@e66a0000 { - compatible = "renesas,hscif-r8a7795", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe66a0000 0 96>; - interrupts = <GIC_SPI 145 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 517>, - <&cpg CPG_CORE R8A7795_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x37>, <&dmac0 0x36>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 517>; - status = "disabled"; - }; - - hscif4: serial@e66b0000 { - compatible = "renesas,hscif-r8a7795", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe66b0000 0 96>; - interrupts = <GIC_SPI 146 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 516>, - <&cpg CPG_CORE R8A7795_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x39>, <&dmac0 0x38>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 516>; - status = "disabled"; - }; - - hsusb: usb@e6590000 { - compatible = "renesas,usbhs-r8a7795", - "renesas,rcar-gen3-usbhs"; - reg = <0 0xe6590000 0 0x200>; - interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 704>, <&cpg CPG_MOD 703>; - dmas = <&usb_dmac0 0>, <&usb_dmac0 1>, - <&usb_dmac1 0>, <&usb_dmac1 1>; - dma-names = "ch0", "ch1", "ch2", "ch3"; - renesas,buswait = <11>; - phys = <&usb2_phy0 3>; - phy-names = "usb"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 704>, <&cpg 703>; - status = "disabled"; - }; - - hsusb3: usb@e659c000 { - compatible = "renesas,usbhs-r8a7795", - "renesas,rcar-gen3-usbhs"; - reg = <0 0xe659c000 0 0x200>; - interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 705>, <&cpg CPG_MOD 700>; - dmas = <&usb_dmac2 0>, <&usb_dmac2 1>, - <&usb_dmac3 0>, <&usb_dmac3 1>; - dma-names = "ch0", "ch1", "ch2", "ch3"; - renesas,buswait = <11>; - phys = <&usb2_phy3 3>; - phy-names = "usb"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 705>, <&cpg 700>; - status = "disabled"; - }; - - usb_dmac0: dma-controller@e65a0000 { - compatible = "renesas,r8a7795-usb-dmac", - "renesas,usb-dmac"; - reg = <0 0xe65a0000 0 0x100>; - interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1"; - clocks = <&cpg CPG_MOD 330>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 330>; - #dma-cells = <1>; - dma-channels = <2>; - }; - - usb_dmac1: dma-controller@e65b0000 { - compatible = "renesas,r8a7795-usb-dmac", - "renesas,usb-dmac"; - reg = <0 0xe65b0000 0 0x100>; - interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1"; - clocks = <&cpg CPG_MOD 331>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 331>; - #dma-cells = <1>; - dma-channels = <2>; - }; - - usb_dmac2: dma-controller@e6460000 { - compatible = "renesas,r8a7795-usb-dmac", - "renesas,usb-dmac"; - reg = <0 0xe6460000 0 0x100>; - interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1"; - clocks = <&cpg CPG_MOD 326>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 326>; - #dma-cells = <1>; - dma-channels = <2>; - }; - - usb_dmac3: dma-controller@e6470000 { - compatible = "renesas,r8a7795-usb-dmac", - "renesas,usb-dmac"; - reg = <0 0xe6470000 0 0x100>; - interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1"; - clocks = <&cpg CPG_MOD 329>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 329>; - #dma-cells = <1>; - dma-channels = <2>; - }; - - usb3_phy0: usb-phy@e65ee000 { - compatible = "renesas,r8a7795-usb3-phy", - "renesas,rcar-gen3-usb3-phy"; - reg = <0 0xe65ee000 0 0x90>; - clocks = <&cpg CPG_MOD 328>, <&usb3s0_clk>, - <&usb_extal_clk>; - clock-names = "usb3-if", "usb3s_clk", "usb_extal"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 328>; - #phy-cells = <0>; - status = "disabled"; - }; - - arm_cc630p: crypto@e6601000 { - compatible = "arm,cryptocell-630p-ree"; - interrupts = <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x0 0xe6601000 0 0x1000>; - clocks = <&cpg CPG_MOD 229>; - resets = <&cpg 229>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - }; - - dmac0: dma-controller@e6700000 { - compatible = "renesas,dmac-r8a7795", - "renesas,rcar-dmac"; - reg = <0 0xe6700000 0 0x10000>; - interrupts = <GIC_SPI 199 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 200 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 201 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 202 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 203 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 204 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 205 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 206 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 207 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 208 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 209 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 210 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 211 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 212 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 213 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 214 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 215 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 219>; - clock-names = "fck"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 219>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_ds0 0>, <&ipmmu_ds0 1>, - <&ipmmu_ds0 2>, <&ipmmu_ds0 3>, - <&ipmmu_ds0 4>, <&ipmmu_ds0 5>, - <&ipmmu_ds0 6>, <&ipmmu_ds0 7>, - <&ipmmu_ds0 8>, <&ipmmu_ds0 9>, - <&ipmmu_ds0 10>, <&ipmmu_ds0 11>, - <&ipmmu_ds0 12>, <&ipmmu_ds0 13>, - <&ipmmu_ds0 14>, <&ipmmu_ds0 15>; - }; - - dmac1: dma-controller@e7300000 { - compatible = "renesas,dmac-r8a7795", - "renesas,rcar-dmac"; - reg = <0 0xe7300000 0 0x10000>; - interrupts = <GIC_SPI 220 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 216 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 217 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 218 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 219 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 308 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 309 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 310 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 311 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 312 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 313 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 314 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 315 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 316 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 317 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 318 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 319 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 218>; - clock-names = "fck"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 218>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_ds1 0>, <&ipmmu_ds1 1>, - <&ipmmu_ds1 2>, <&ipmmu_ds1 3>, - <&ipmmu_ds1 4>, <&ipmmu_ds1 5>, - <&ipmmu_ds1 6>, <&ipmmu_ds1 7>, - <&ipmmu_ds1 8>, <&ipmmu_ds1 9>, - <&ipmmu_ds1 10>, <&ipmmu_ds1 11>, - <&ipmmu_ds1 12>, <&ipmmu_ds1 13>, - <&ipmmu_ds1 14>, <&ipmmu_ds1 15>; - }; - - dmac2: dma-controller@e7310000 { - compatible = "renesas,dmac-r8a7795", - "renesas,rcar-dmac"; - reg = <0 0xe7310000 0 0x10000>; - interrupts = <GIC_SPI 416 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 417 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 418 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 419 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 420 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 421 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 422 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 423 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 424 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 425 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 426 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 427 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 428 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 429 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 430 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 431 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 397 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 217>; - clock-names = "fck"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 217>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_ds1 16>, <&ipmmu_ds1 17>, - <&ipmmu_ds1 18>, <&ipmmu_ds1 19>, - <&ipmmu_ds1 20>, <&ipmmu_ds1 21>, - <&ipmmu_ds1 22>, <&ipmmu_ds1 23>, - <&ipmmu_ds1 24>, <&ipmmu_ds1 25>, - <&ipmmu_ds1 26>, <&ipmmu_ds1 27>, - <&ipmmu_ds1 28>, <&ipmmu_ds1 29>, - <&ipmmu_ds1 30>, <&ipmmu_ds1 31>; - }; - - ipmmu_ds0: iommu@e6740000 { - compatible = "renesas,ipmmu-r8a7795"; - reg = <0 0xe6740000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 0>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_ds1: iommu@e7740000 { - compatible = "renesas,ipmmu-r8a7795"; - reg = <0 0xe7740000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 1>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_hc: iommu@e6570000 { - compatible = "renesas,ipmmu-r8a7795"; - reg = <0 0xe6570000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 2>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_ir: iommu@ff8b0000 { - compatible = "renesas,ipmmu-r8a7795"; - reg = <0 0xff8b0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 3>; - power-domains = <&sysc R8A7795_PD_A3IR>; - #iommu-cells = <1>; - }; - - ipmmu_mm: iommu@e67b0000 { - compatible = "renesas,ipmmu-r8a7795"; - reg = <0 0xe67b0000 0 0x1000>; - interrupts = <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_mp0: iommu@ec670000 { - compatible = "renesas,ipmmu-r8a7795"; - reg = <0 0xec670000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 4>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_pv0: iommu@fd800000 { - compatible = "renesas,ipmmu-r8a7795"; - reg = <0 0xfd800000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 6>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_pv1: iommu@fd950000 { - compatible = "renesas,ipmmu-r8a7795"; - reg = <0 0xfd950000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 7>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_pv2: iommu@fd960000 { - compatible = "renesas,ipmmu-r8a7795"; - reg = <0 0xfd960000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 8>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_pv3: iommu@fd970000 { - compatible = "renesas,ipmmu-r8a7795"; - reg = <0 0xfd970000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 9>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_rt: iommu@ffc80000 { - compatible = "renesas,ipmmu-r8a7795"; - reg = <0 0xffc80000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 10>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_vc0: iommu@fe6b0000 { - compatible = "renesas,ipmmu-r8a7795"; - reg = <0 0xfe6b0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 12>; - power-domains = <&sysc R8A7795_PD_A3VC>; - #iommu-cells = <1>; - }; - - ipmmu_vc1: iommu@fe6f0000 { - compatible = "renesas,ipmmu-r8a7795"; - reg = <0 0xfe6f0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 13>; - power-domains = <&sysc R8A7795_PD_A3VC>; - #iommu-cells = <1>; - }; - - ipmmu_vi0: iommu@febd0000 { - compatible = "renesas,ipmmu-r8a7795"; - reg = <0 0xfebd0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 14>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_vi1: iommu@febe0000 { - compatible = "renesas,ipmmu-r8a7795"; - reg = <0 0xfebe0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 15>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_vp0: iommu@fe990000 { - compatible = "renesas,ipmmu-r8a7795"; - reg = <0 0xfe990000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 16>; - power-domains = <&sysc R8A7795_PD_A3VP>; - #iommu-cells = <1>; - }; - - ipmmu_vp1: iommu@fe980000 { - compatible = "renesas,ipmmu-r8a7795"; - reg = <0 0xfe980000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 17>; - power-domains = <&sysc R8A7795_PD_A3VP>; - #iommu-cells = <1>; - }; - - avb: ethernet@e6800000 { - compatible = "renesas,etheravb-r8a7795", - "renesas,etheravb-rcar-gen3"; - reg = <0 0xe6800000 0 0x800>, <0 0xe6a00000 0 0x10000>; - interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 47 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 63 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15", - "ch16", "ch17", "ch18", "ch19", - "ch20", "ch21", "ch22", "ch23", - "ch24"; - clocks = <&cpg CPG_MOD 812>; - clock-names = "fck"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 812>; - phy-mode = "rgmii"; - rx-internal-delay-ps = <0>; - tx-internal-delay-ps = <0>; - iommus = <&ipmmu_ds0 16>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - can0: can@e6c30000 { - compatible = "renesas,can-r8a7795", - "renesas,rcar-gen3-can"; - reg = <0 0xe6c30000 0 0x1000>; - interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 916>, - <&cpg CPG_CORE R8A7795_CLK_CANFD>, - <&can_clk>; - clock-names = "clkp1", "clkp2", "can_clk"; - assigned-clocks = <&cpg CPG_CORE R8A7795_CLK_CANFD>; - assigned-clock-rates = <40000000>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 916>; - status = "disabled"; - }; - - can1: can@e6c38000 { - compatible = "renesas,can-r8a7795", - "renesas,rcar-gen3-can"; - reg = <0 0xe6c38000 0 0x1000>; - interrupts = <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 915>, - <&cpg CPG_CORE R8A7795_CLK_CANFD>, - <&can_clk>; - clock-names = "clkp1", "clkp2", "can_clk"; - assigned-clocks = <&cpg CPG_CORE R8A7795_CLK_CANFD>; - assigned-clock-rates = <40000000>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 915>; - status = "disabled"; - }; - - canfd: can@e66c0000 { - compatible = "renesas,r8a7795-canfd", - "renesas,rcar-gen3-canfd"; - reg = <0 0xe66c0000 0 0x8000>; - interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch_int", "g_int"; - clocks = <&cpg CPG_MOD 914>, - <&cpg CPG_CORE R8A7795_CLK_CANFD>, - <&can_clk>; - clock-names = "fck", "canfd", "can_clk"; - assigned-clocks = <&cpg CPG_CORE R8A7795_CLK_CANFD>; - assigned-clock-rates = <40000000>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 914>; - status = "disabled"; - - channel0 { - status = "disabled"; - }; - - channel1 { - status = "disabled"; - }; - }; - - pwm0: pwm@e6e30000 { - compatible = "renesas,pwm-r8a7795", "renesas,pwm-rcar"; - reg = <0 0xe6e30000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - pwm1: pwm@e6e31000 { - compatible = "renesas,pwm-r8a7795", "renesas,pwm-rcar"; - reg = <0 0xe6e31000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - pwm2: pwm@e6e32000 { - compatible = "renesas,pwm-r8a7795", "renesas,pwm-rcar"; - reg = <0 0xe6e32000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - pwm3: pwm@e6e33000 { - compatible = "renesas,pwm-r8a7795", "renesas,pwm-rcar"; - reg = <0 0xe6e33000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - pwm4: pwm@e6e34000 { - compatible = "renesas,pwm-r8a7795", "renesas,pwm-rcar"; - reg = <0 0xe6e34000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - pwm5: pwm@e6e35000 { - compatible = "renesas,pwm-r8a7795", "renesas,pwm-rcar"; - reg = <0 0xe6e35000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - pwm6: pwm@e6e36000 { - compatible = "renesas,pwm-r8a7795", "renesas,pwm-rcar"; - reg = <0 0xe6e36000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - scif0: serial@e6e60000 { - compatible = "renesas,scif-r8a7795", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6e60000 0 64>; - interrupts = <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 207>, - <&cpg CPG_CORE R8A7795_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x51>, <&dmac1 0x50>, - <&dmac2 0x51>, <&dmac2 0x50>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 207>; - status = "disabled"; - }; - - scif1: serial@e6e68000 { - compatible = "renesas,scif-r8a7795", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6e68000 0 64>; - interrupts = <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 206>, - <&cpg CPG_CORE R8A7795_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x53>, <&dmac1 0x52>, - <&dmac2 0x53>, <&dmac2 0x52>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 206>; - status = "disabled"; - }; - - scif2: serial@e6e88000 { - compatible = "renesas,scif-r8a7795", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6e88000 0 64>; - interrupts = <GIC_SPI 164 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 310>, - <&cpg CPG_CORE R8A7795_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x13>, <&dmac1 0x12>, - <&dmac2 0x13>, <&dmac2 0x12>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 310>; - status = "disabled"; - }; - - scif3: serial@e6c50000 { - compatible = "renesas,scif-r8a7795", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6c50000 0 64>; - interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 204>, - <&cpg CPG_CORE R8A7795_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x57>, <&dmac0 0x56>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 204>; - status = "disabled"; - }; - - scif4: serial@e6c40000 { - compatible = "renesas,scif-r8a7795", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6c40000 0 64>; - interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 203>, - <&cpg CPG_CORE R8A7795_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x59>, <&dmac0 0x58>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 203>; - status = "disabled"; - }; - - scif5: serial@e6f30000 { - compatible = "renesas,scif-r8a7795", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6f30000 0 64>; - interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 202>, - <&cpg CPG_CORE R8A7795_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x5b>, <&dmac1 0x5a>, - <&dmac2 0x5b>, <&dmac2 0x5a>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 202>; - status = "disabled"; - }; - - tpu: pwm@e6e80000 { - compatible = "renesas,tpu-r8a7795", "renesas,tpu"; - reg = <0 0xe6e80000 0 0x148>; - interrupts = <GIC_SPI 135 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 304>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 304>; - #pwm-cells = <3>; - status = "disabled"; - }; - - msiof0: spi@e6e90000 { - compatible = "renesas,msiof-r8a7795", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6e90000 0 0x0064>; - interrupts = <GIC_SPI 156 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 211>; - dmas = <&dmac1 0x41>, <&dmac1 0x40>, - <&dmac2 0x41>, <&dmac2 0x40>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 211>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof1: spi@e6ea0000 { - compatible = "renesas,msiof-r8a7795", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6ea0000 0 0x0064>; - interrupts = <GIC_SPI 157 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 210>; - dmas = <&dmac1 0x43>, <&dmac1 0x42>, - <&dmac2 0x43>, <&dmac2 0x42>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 210>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof2: spi@e6c00000 { - compatible = "renesas,msiof-r8a7795", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6c00000 0 0x0064>; - interrupts = <GIC_SPI 158 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 209>; - dmas = <&dmac0 0x45>, <&dmac0 0x44>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 209>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof3: spi@e6c10000 { - compatible = "renesas,msiof-r8a7795", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6c10000 0 0x0064>; - interrupts = <GIC_SPI 159 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 208>; - dmas = <&dmac0 0x47>, <&dmac0 0x46>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 208>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - vin0: video@e6ef0000 { - compatible = "renesas,vin-r8a7795"; - reg = <0 0xe6ef0000 0 0x1000>; - interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 811>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 811>; - renesas,id = <0>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin0csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin0>; - }; - vin0csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin0>; - }; - }; - }; - }; - - vin1: video@e6ef1000 { - compatible = "renesas,vin-r8a7795"; - reg = <0 0xe6ef1000 0 0x1000>; - interrupts = <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 810>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 810>; - renesas,id = <1>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin1csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin1>; - }; - vin1csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin1>; - }; - }; - }; - }; - - vin2: video@e6ef2000 { - compatible = "renesas,vin-r8a7795"; - reg = <0 0xe6ef2000 0 0x1000>; - interrupts = <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 809>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 809>; - renesas,id = <2>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin2csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin2>; - }; - vin2csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin2>; - }; - }; - }; - }; - - vin3: video@e6ef3000 { - compatible = "renesas,vin-r8a7795"; - reg = <0 0xe6ef3000 0 0x1000>; - interrupts = <GIC_SPI 191 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 808>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 808>; - renesas,id = <3>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin3csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin3>; - }; - vin3csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin3>; - }; - }; - }; - }; - - vin4: video@e6ef4000 { - compatible = "renesas,vin-r8a7795"; - reg = <0 0xe6ef4000 0 0x1000>; - interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 807>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 807>; - renesas,id = <4>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin4csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin4>; - }; - vin4csi41: endpoint@3 { - reg = <3>; - remote-endpoint = <&csi41vin4>; - }; - }; - }; - }; - - vin5: video@e6ef5000 { - compatible = "renesas,vin-r8a7795"; - reg = <0 0xe6ef5000 0 0x1000>; - interrupts = <GIC_SPI 175 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 806>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 806>; - renesas,id = <5>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin5csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin5>; - }; - vin5csi41: endpoint@3 { - reg = <3>; - remote-endpoint = <&csi41vin5>; - }; - }; - }; - }; - - vin6: video@e6ef6000 { - compatible = "renesas,vin-r8a7795"; - reg = <0 0xe6ef6000 0 0x1000>; - interrupts = <GIC_SPI 176 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 805>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 805>; - renesas,id = <6>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin6csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin6>; - }; - vin6csi41: endpoint@3 { - reg = <3>; - remote-endpoint = <&csi41vin6>; - }; - }; - }; - }; - - vin7: video@e6ef7000 { - compatible = "renesas,vin-r8a7795"; - reg = <0 0xe6ef7000 0 0x1000>; - interrupts = <GIC_SPI 171 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 804>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 804>; - renesas,id = <7>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin7csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin7>; - }; - vin7csi41: endpoint@3 { - reg = <3>; - remote-endpoint = <&csi41vin7>; - }; - }; - }; - }; - - drif00: rif@e6f40000 { - compatible = "renesas,r8a7795-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6f40000 0 0x64>; - interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 515>; - clock-names = "fck"; - dmas = <&dmac1 0x20>, <&dmac2 0x20>; - dma-names = "rx", "rx"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 515>; - renesas,bonding = <&drif01>; - status = "disabled"; - }; - - drif01: rif@e6f50000 { - compatible = "renesas,r8a7795-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6f50000 0 0x64>; - interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 514>; - clock-names = "fck"; - dmas = <&dmac1 0x22>, <&dmac2 0x22>; - dma-names = "rx", "rx"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 514>; - renesas,bonding = <&drif00>; - status = "disabled"; - }; - - drif10: rif@e6f60000 { - compatible = "renesas,r8a7795-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6f60000 0 0x64>; - interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 513>; - clock-names = "fck"; - dmas = <&dmac1 0x24>, <&dmac2 0x24>; - dma-names = "rx", "rx"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 513>; - renesas,bonding = <&drif11>; - status = "disabled"; - }; - - drif11: rif@e6f70000 { - compatible = "renesas,r8a7795-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6f70000 0 0x64>; - interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 512>; - clock-names = "fck"; - dmas = <&dmac1 0x26>, <&dmac2 0x26>; - dma-names = "rx", "rx"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 512>; - renesas,bonding = <&drif10>; - status = "disabled"; - }; - - drif20: rif@e6f80000 { - compatible = "renesas,r8a7795-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6f80000 0 0x64>; - interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 511>; - clock-names = "fck"; - dmas = <&dmac1 0x28>, <&dmac2 0x28>; - dma-names = "rx", "rx"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 511>; - renesas,bonding = <&drif21>; - status = "disabled"; - }; - - drif21: rif@e6f90000 { - compatible = "renesas,r8a7795-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6f90000 0 0x64>; - interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 510>; - clock-names = "fck"; - dmas = <&dmac1 0x2a>, <&dmac2 0x2a>; - dma-names = "rx", "rx"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 510>; - renesas,bonding = <&drif20>; - status = "disabled"; - }; - - drif30: rif@e6fa0000 { - compatible = "renesas,r8a7795-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6fa0000 0 0x64>; - interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 509>; - clock-names = "fck"; - dmas = <&dmac1 0x2c>, <&dmac2 0x2c>; - dma-names = "rx", "rx"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 509>; - renesas,bonding = <&drif31>; - status = "disabled"; - }; - - drif31: rif@e6fb0000 { - compatible = "renesas,r8a7795-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6fb0000 0 0x64>; - interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 508>; - clock-names = "fck"; - dmas = <&dmac1 0x2e>, <&dmac2 0x2e>; - dma-names = "rx", "rx"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 508>; - renesas,bonding = <&drif30>; - status = "disabled"; - }; - - rcar_sound: sound@ec500000 { - /* - * #sound-dai-cells is required if simple-card - * - * Single DAI : #sound-dai-cells = <0>; <&rcar_sound>; - * Multi DAI : #sound-dai-cells = <1>; <&rcar_sound N>; - */ - /* - * #clock-cells is required for audio_clkout0/1/2/3 - * - * clkout : #clock-cells = <0>; <&rcar_sound>; - * clkout0/1/2/3: #clock-cells = <1>; <&rcar_sound N>; - */ - compatible = "renesas,rcar_sound-r8a7795", "renesas,rcar_sound-gen3"; - reg = <0 0xec500000 0 0x1000>, /* SCU */ - <0 0xec5a0000 0 0x100>, /* ADG */ - <0 0xec540000 0 0x1000>, /* SSIU */ - <0 0xec541000 0 0x280>, /* SSI */ - <0 0xec760000 0 0x200>; /* Audio DMAC peri peri*/ - reg-names = "scu", "adg", "ssiu", "ssi", "audmapp"; - - clocks = <&cpg CPG_MOD 1005>, - <&cpg CPG_MOD 1006>, <&cpg CPG_MOD 1007>, - <&cpg CPG_MOD 1008>, <&cpg CPG_MOD 1009>, - <&cpg CPG_MOD 1010>, <&cpg CPG_MOD 1011>, - <&cpg CPG_MOD 1012>, <&cpg CPG_MOD 1013>, - <&cpg CPG_MOD 1014>, <&cpg CPG_MOD 1015>, - <&cpg CPG_MOD 1022>, <&cpg CPG_MOD 1023>, - <&cpg CPG_MOD 1024>, <&cpg CPG_MOD 1025>, - <&cpg CPG_MOD 1026>, <&cpg CPG_MOD 1027>, - <&cpg CPG_MOD 1028>, <&cpg CPG_MOD 1029>, - <&cpg CPG_MOD 1030>, <&cpg CPG_MOD 1031>, - <&cpg CPG_MOD 1020>, <&cpg CPG_MOD 1021>, - <&cpg CPG_MOD 1020>, <&cpg CPG_MOD 1021>, - <&cpg CPG_MOD 1019>, <&cpg CPG_MOD 1018>, - <&audio_clk_a>, <&audio_clk_b>, - <&audio_clk_c>, - <&cpg CPG_CORE R8A7795_CLK_S0D4>; - clock-names = "ssi-all", - "ssi.9", "ssi.8", "ssi.7", "ssi.6", - "ssi.5", "ssi.4", "ssi.3", "ssi.2", - "ssi.1", "ssi.0", - "src.9", "src.8", "src.7", "src.6", - "src.5", "src.4", "src.3", "src.2", - "src.1", "src.0", - "mix.1", "mix.0", - "ctu.1", "ctu.0", - "dvc.0", "dvc.1", - "clk_a", "clk_b", "clk_c", "clk_i"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 1005>, - <&cpg 1006>, <&cpg 1007>, - <&cpg 1008>, <&cpg 1009>, - <&cpg 1010>, <&cpg 1011>, - <&cpg 1012>, <&cpg 1013>, - <&cpg 1014>, <&cpg 1015>; - reset-names = "ssi-all", - "ssi.9", "ssi.8", "ssi.7", "ssi.6", - "ssi.5", "ssi.4", "ssi.3", "ssi.2", - "ssi.1", "ssi.0"; - status = "disabled"; - - rcar_sound,dvc { - dvc0: dvc-0 { - dmas = <&audma1 0xbc>; - dma-names = "tx"; - }; - dvc1: dvc-1 { - dmas = <&audma1 0xbe>; - dma-names = "tx"; - }; - }; - - rcar_sound,mix { - mix0: mix-0 { }; - mix1: mix-1 { }; - }; - - rcar_sound,ctu { - ctu00: ctu-0 { }; - ctu01: ctu-1 { }; - ctu02: ctu-2 { }; - ctu03: ctu-3 { }; - ctu10: ctu-4 { }; - ctu11: ctu-5 { }; - ctu12: ctu-6 { }; - ctu13: ctu-7 { }; - }; - - rcar_sound,src { - src0: src-0 { - interrupts = <GIC_SPI 352 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x85>, <&audma1 0x9a>; - dma-names = "rx", "tx"; - }; - src1: src-1 { - interrupts = <GIC_SPI 353 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x87>, <&audma1 0x9c>; - dma-names = "rx", "tx"; - }; - src2: src-2 { - interrupts = <GIC_SPI 354 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x89>, <&audma1 0x9e>; - dma-names = "rx", "tx"; - }; - src3: src-3 { - interrupts = <GIC_SPI 355 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x8b>, <&audma1 0xa0>; - dma-names = "rx", "tx"; - }; - src4: src-4 { - interrupts = <GIC_SPI 356 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x8d>, <&audma1 0xb0>; - dma-names = "rx", "tx"; - }; - src5: src-5 { - interrupts = <GIC_SPI 357 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x8f>, <&audma1 0xb2>; - dma-names = "rx", "tx"; - }; - src6: src-6 { - interrupts = <GIC_SPI 358 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x91>, <&audma1 0xb4>; - dma-names = "rx", "tx"; - }; - src7: src-7 { - interrupts = <GIC_SPI 359 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x93>, <&audma1 0xb6>; - dma-names = "rx", "tx"; - }; - src8: src-8 { - interrupts = <GIC_SPI 360 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x95>, <&audma1 0xb8>; - dma-names = "rx", "tx"; - }; - src9: src-9 { - interrupts = <GIC_SPI 361 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x97>, <&audma1 0xba>; - dma-names = "rx", "tx"; - }; - }; - - rcar_sound,ssiu { - ssiu00: ssiu-0 { - dmas = <&audma0 0x15>, <&audma1 0x16>; - dma-names = "rx", "tx"; - }; - ssiu01: ssiu-1 { - dmas = <&audma0 0x35>, <&audma1 0x36>; - dma-names = "rx", "tx"; - }; - ssiu02: ssiu-2 { - dmas = <&audma0 0x37>, <&audma1 0x38>; - dma-names = "rx", "tx"; - }; - ssiu03: ssiu-3 { - dmas = <&audma0 0x47>, <&audma1 0x48>; - dma-names = "rx", "tx"; - }; - ssiu04: ssiu-4 { - dmas = <&audma0 0x3F>, <&audma1 0x40>; - dma-names = "rx", "tx"; - }; - ssiu05: ssiu-5 { - dmas = <&audma0 0x43>, <&audma1 0x44>; - dma-names = "rx", "tx"; - }; - ssiu06: ssiu-6 { - dmas = <&audma0 0x4F>, <&audma1 0x50>; - dma-names = "rx", "tx"; - }; - ssiu07: ssiu-7 { - dmas = <&audma0 0x53>, <&audma1 0x54>; - dma-names = "rx", "tx"; - }; - ssiu10: ssiu-8 { - dmas = <&audma0 0x49>, <&audma1 0x4a>; - dma-names = "rx", "tx"; - }; - ssiu11: ssiu-9 { - dmas = <&audma0 0x4B>, <&audma1 0x4C>; - dma-names = "rx", "tx"; - }; - ssiu12: ssiu-10 { - dmas = <&audma0 0x57>, <&audma1 0x58>; - dma-names = "rx", "tx"; - }; - ssiu13: ssiu-11 { - dmas = <&audma0 0x59>, <&audma1 0x5A>; - dma-names = "rx", "tx"; - }; - ssiu14: ssiu-12 { - dmas = <&audma0 0x5F>, <&audma1 0x60>; - dma-names = "rx", "tx"; - }; - ssiu15: ssiu-13 { - dmas = <&audma0 0xC3>, <&audma1 0xC4>; - dma-names = "rx", "tx"; - }; - ssiu16: ssiu-14 { - dmas = <&audma0 0xC7>, <&audma1 0xC8>; - dma-names = "rx", "tx"; - }; - ssiu17: ssiu-15 { - dmas = <&audma0 0xCB>, <&audma1 0xCC>; - dma-names = "rx", "tx"; - }; - ssiu20: ssiu-16 { - dmas = <&audma0 0x63>, <&audma1 0x64>; - dma-names = "rx", "tx"; - }; - ssiu21: ssiu-17 { - dmas = <&audma0 0x67>, <&audma1 0x68>; - dma-names = "rx", "tx"; - }; - ssiu22: ssiu-18 { - dmas = <&audma0 0x6B>, <&audma1 0x6C>; - dma-names = "rx", "tx"; - }; - ssiu23: ssiu-19 { - dmas = <&audma0 0x6D>, <&audma1 0x6E>; - dma-names = "rx", "tx"; - }; - ssiu24: ssiu-20 { - dmas = <&audma0 0xCF>, <&audma1 0xCE>; - dma-names = "rx", "tx"; - }; - ssiu25: ssiu-21 { - dmas = <&audma0 0xEB>, <&audma1 0xEC>; - dma-names = "rx", "tx"; - }; - ssiu26: ssiu-22 { - dmas = <&audma0 0xED>, <&audma1 0xEE>; - dma-names = "rx", "tx"; - }; - ssiu27: ssiu-23 { - dmas = <&audma0 0xEF>, <&audma1 0xF0>; - dma-names = "rx", "tx"; - }; - ssiu30: ssiu-24 { - dmas = <&audma0 0x6f>, <&audma1 0x70>; - dma-names = "rx", "tx"; - }; - ssiu31: ssiu-25 { - dmas = <&audma0 0x21>, <&audma1 0x22>; - dma-names = "rx", "tx"; - }; - ssiu32: ssiu-26 { - dmas = <&audma0 0x23>, <&audma1 0x24>; - dma-names = "rx", "tx"; - }; - ssiu33: ssiu-27 { - dmas = <&audma0 0x25>, <&audma1 0x26>; - dma-names = "rx", "tx"; - }; - ssiu34: ssiu-28 { - dmas = <&audma0 0x27>, <&audma1 0x28>; - dma-names = "rx", "tx"; - }; - ssiu35: ssiu-29 { - dmas = <&audma0 0x29>, <&audma1 0x2A>; - dma-names = "rx", "tx"; - }; - ssiu36: ssiu-30 { - dmas = <&audma0 0x2B>, <&audma1 0x2C>; - dma-names = "rx", "tx"; - }; - ssiu37: ssiu-31 { - dmas = <&audma0 0x2D>, <&audma1 0x2E>; - dma-names = "rx", "tx"; - }; - ssiu40: ssiu-32 { - dmas = <&audma0 0x71>, <&audma1 0x72>; - dma-names = "rx", "tx"; - }; - ssiu41: ssiu-33 { - dmas = <&audma0 0x17>, <&audma1 0x18>; - dma-names = "rx", "tx"; - }; - ssiu42: ssiu-34 { - dmas = <&audma0 0x19>, <&audma1 0x1A>; - dma-names = "rx", "tx"; - }; - ssiu43: ssiu-35 { - dmas = <&audma0 0x1B>, <&audma1 0x1C>; - dma-names = "rx", "tx"; - }; - ssiu44: ssiu-36 { - dmas = <&audma0 0x1D>, <&audma1 0x1E>; - dma-names = "rx", "tx"; - }; - ssiu45: ssiu-37 { - dmas = <&audma0 0x1F>, <&audma1 0x20>; - dma-names = "rx", "tx"; - }; - ssiu46: ssiu-38 { - dmas = <&audma0 0x31>, <&audma1 0x32>; - dma-names = "rx", "tx"; - }; - ssiu47: ssiu-39 { - dmas = <&audma0 0x33>, <&audma1 0x34>; - dma-names = "rx", "tx"; - }; - ssiu50: ssiu-40 { - dmas = <&audma0 0x73>, <&audma1 0x74>; - dma-names = "rx", "tx"; - }; - ssiu60: ssiu-41 { - dmas = <&audma0 0x75>, <&audma1 0x76>; - dma-names = "rx", "tx"; - }; - ssiu70: ssiu-42 { - dmas = <&audma0 0x79>, <&audma1 0x7a>; - dma-names = "rx", "tx"; - }; - ssiu80: ssiu-43 { - dmas = <&audma0 0x7b>, <&audma1 0x7c>; - dma-names = "rx", "tx"; - }; - ssiu90: ssiu-44 { - dmas = <&audma0 0x7d>, <&audma1 0x7e>; - dma-names = "rx", "tx"; - }; - ssiu91: ssiu-45 { - dmas = <&audma0 0x7F>, <&audma1 0x80>; - dma-names = "rx", "tx"; - }; - ssiu92: ssiu-46 { - dmas = <&audma0 0x81>, <&audma1 0x82>; - dma-names = "rx", "tx"; - }; - ssiu93: ssiu-47 { - dmas = <&audma0 0x83>, <&audma1 0x84>; - dma-names = "rx", "tx"; - }; - ssiu94: ssiu-48 { - dmas = <&audma0 0xA3>, <&audma1 0xA4>; - dma-names = "rx", "tx"; - }; - ssiu95: ssiu-49 { - dmas = <&audma0 0xA5>, <&audma1 0xA6>; - dma-names = "rx", "tx"; - }; - ssiu96: ssiu-50 { - dmas = <&audma0 0xA7>, <&audma1 0xA8>; - dma-names = "rx", "tx"; - }; - ssiu97: ssiu-51 { - dmas = <&audma0 0xA9>, <&audma1 0xAA>; - dma-names = "rx", "tx"; - }; - }; - - rcar_sound,ssi { - ssi0: ssi-0 { - interrupts = <GIC_SPI 370 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x01>, <&audma1 0x02>; - dma-names = "rx", "tx"; - }; - ssi1: ssi-1 { - interrupts = <GIC_SPI 371 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x03>, <&audma1 0x04>; - dma-names = "rx", "tx"; - }; - ssi2: ssi-2 { - interrupts = <GIC_SPI 372 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x05>, <&audma1 0x06>; - dma-names = "rx", "tx"; - }; - ssi3: ssi-3 { - interrupts = <GIC_SPI 373 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x07>, <&audma1 0x08>; - dma-names = "rx", "tx"; - }; - ssi4: ssi-4 { - interrupts = <GIC_SPI 374 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x09>, <&audma1 0x0a>; - dma-names = "rx", "tx"; - }; - ssi5: ssi-5 { - interrupts = <GIC_SPI 375 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x0b>, <&audma1 0x0c>; - dma-names = "rx", "tx"; - }; - ssi6: ssi-6 { - interrupts = <GIC_SPI 376 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x0d>, <&audma1 0x0e>; - dma-names = "rx", "tx"; - }; - ssi7: ssi-7 { - interrupts = <GIC_SPI 377 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x0f>, <&audma1 0x10>; - dma-names = "rx", "tx"; - }; - ssi8: ssi-8 { - interrupts = <GIC_SPI 378 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x11>, <&audma1 0x12>; - dma-names = "rx", "tx"; - }; - ssi9: ssi-9 { - interrupts = <GIC_SPI 379 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x13>, <&audma1 0x14>; - dma-names = "rx", "tx"; - }; - }; - }; - - mlp: mlp@ec520000 { - compatible = "renesas,r8a7795-mlp", - "renesas,rcar-gen3-mlp"; - reg = <0 0xec520000 0 0x800>; - interrupts = <GIC_SPI 384 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 385 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 802>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 802>; - status = "disabled"; - }; - - audma0: dma-controller@ec700000 { - compatible = "renesas,dmac-r8a7795", - "renesas,rcar-dmac"; - reg = <0 0xec700000 0 0x10000>; - interrupts = <GIC_SPI 350 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 320 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 321 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 322 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 323 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 324 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 325 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 326 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 327 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 328 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 329 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 330 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 331 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 332 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 333 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 334 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 335 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 502>; - clock-names = "fck"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 502>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_mp0 0>, <&ipmmu_mp0 1>, - <&ipmmu_mp0 2>, <&ipmmu_mp0 3>, - <&ipmmu_mp0 4>, <&ipmmu_mp0 5>, - <&ipmmu_mp0 6>, <&ipmmu_mp0 7>, - <&ipmmu_mp0 8>, <&ipmmu_mp0 9>, - <&ipmmu_mp0 10>, <&ipmmu_mp0 11>, - <&ipmmu_mp0 12>, <&ipmmu_mp0 13>, - <&ipmmu_mp0 14>, <&ipmmu_mp0 15>; - }; - - audma1: dma-controller@ec720000 { - compatible = "renesas,dmac-r8a7795", - "renesas,rcar-dmac"; - reg = <0 0xec720000 0 0x10000>; - interrupts = <GIC_SPI 351 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 336 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 337 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 338 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 339 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 340 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 341 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 342 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 343 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 344 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 345 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 346 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 347 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 348 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 349 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 382 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 383 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 501>; - clock-names = "fck"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 501>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_mp0 16>, <&ipmmu_mp0 17>, - <&ipmmu_mp0 18>, <&ipmmu_mp0 19>, - <&ipmmu_mp0 20>, <&ipmmu_mp0 21>, - <&ipmmu_mp0 22>, <&ipmmu_mp0 23>, - <&ipmmu_mp0 24>, <&ipmmu_mp0 25>, - <&ipmmu_mp0 26>, <&ipmmu_mp0 27>, - <&ipmmu_mp0 28>, <&ipmmu_mp0 29>, - <&ipmmu_mp0 30>, <&ipmmu_mp0 31>; - }; - - xhci0: usb@ee000000 { - compatible = "renesas,xhci-r8a7795", "renesas,rcar-gen3-xhci"; - reg = <0 0xee000000 0 0xc00>; - interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 328>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 328>; - status = "disabled"; - }; - - usb3_peri0: usb@ee020000 { - compatible = "renesas,r8a7795-usb3-peri", - "renesas,rcar-gen3-usb3-peri"; - reg = <0 0xee020000 0 0x400>; - interrupts = <GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 328>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 328>; - status = "disabled"; - }; - - ohci0: usb@ee080000 { - compatible = "generic-ohci"; - reg = <0 0xee080000 0 0x100>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>; - phys = <&usb2_phy0 1>; - phy-names = "usb"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 703>, <&cpg 704>; - status = "disabled"; - }; - - ohci1: usb@ee0a0000 { - compatible = "generic-ohci"; - reg = <0 0xee0a0000 0 0x100>; - interrupts = <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 702>; - phys = <&usb2_phy1 1>; - phy-names = "usb"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 702>; - status = "disabled"; - }; - - ohci2: usb@ee0c0000 { - compatible = "generic-ohci"; - reg = <0 0xee0c0000 0 0x100>; - interrupts = <GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 701>; - phys = <&usb2_phy2 1>; - phy-names = "usb"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 701>; - status = "disabled"; - }; - - ohci3: usb@ee0e0000 { - compatible = "generic-ohci"; - reg = <0 0xee0e0000 0 0x100>; - interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 700>, <&cpg CPG_MOD 705>; - phys = <&usb2_phy3 1>; - phy-names = "usb"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 700>, <&cpg 705>; - status = "disabled"; - }; - - ehci0: usb@ee080100 { - compatible = "generic-ehci"; - reg = <0 0xee080100 0 0x100>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>; - phys = <&usb2_phy0 2>; - phy-names = "usb"; - companion = <&ohci0>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 703>, <&cpg 704>; - status = "disabled"; - }; - - ehci1: usb@ee0a0100 { - compatible = "generic-ehci"; - reg = <0 0xee0a0100 0 0x100>; - interrupts = <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 702>; - phys = <&usb2_phy1 2>; - phy-names = "usb"; - companion = <&ohci1>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 702>; - status = "disabled"; - }; - - ehci2: usb@ee0c0100 { - compatible = "generic-ehci"; - reg = <0 0xee0c0100 0 0x100>; - interrupts = <GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 701>; - phys = <&usb2_phy2 2>; - phy-names = "usb"; - companion = <&ohci2>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 701>; - status = "disabled"; - }; - - ehci3: usb@ee0e0100 { - compatible = "generic-ehci"; - reg = <0 0xee0e0100 0 0x100>; - interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 700>, <&cpg CPG_MOD 705>; - phys = <&usb2_phy3 2>; - phy-names = "usb"; - companion = <&ohci3>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 700>, <&cpg 705>; - status = "disabled"; - }; - - usb2_phy0: usb-phy@ee080200 { - compatible = "renesas,usb2-phy-r8a7795", - "renesas,rcar-gen3-usb2-phy"; - reg = <0 0xee080200 0 0x700>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 703>, <&cpg 704>; - #phy-cells = <1>; - status = "disabled"; - }; - - usb2_phy1: usb-phy@ee0a0200 { - compatible = "renesas,usb2-phy-r8a7795", - "renesas,rcar-gen3-usb2-phy"; - reg = <0 0xee0a0200 0 0x700>; - clocks = <&cpg CPG_MOD 702>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 702>; - #phy-cells = <1>; - status = "disabled"; - }; - - usb2_phy2: usb-phy@ee0c0200 { - compatible = "renesas,usb2-phy-r8a7795", - "renesas,rcar-gen3-usb2-phy"; - reg = <0 0xee0c0200 0 0x700>; - clocks = <&cpg CPG_MOD 701>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 701>; - #phy-cells = <1>; - status = "disabled"; - }; - - usb2_phy3: usb-phy@ee0e0200 { - compatible = "renesas,usb2-phy-r8a7795", - "renesas,rcar-gen3-usb2-phy"; - reg = <0 0xee0e0200 0 0x700>; - interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 700>, <&cpg CPG_MOD 705>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 700>, <&cpg 705>; - #phy-cells = <1>; - status = "disabled"; - }; - - sdhi0: mmc@ee100000 { - compatible = "renesas,sdhi-r8a7795", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee100000 0 0x2000>; - interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 314>, <&cpg CPG_CORE R8A7795_CLK_SD0H>; - clock-names = "core", "clkh"; - max-frequency = <200000000>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 314>; - iommus = <&ipmmu_ds1 32>; - status = "disabled"; - }; - - sdhi1: mmc@ee120000 { - compatible = "renesas,sdhi-r8a7795", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee120000 0 0x2000>; - interrupts = <GIC_SPI 166 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 313>, <&cpg CPG_CORE R8A7795_CLK_SD1H>; - clock-names = "core", "clkh"; - max-frequency = <200000000>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 313>; - iommus = <&ipmmu_ds1 33>; - status = "disabled"; - }; - - sdhi2: mmc@ee140000 { - compatible = "renesas,sdhi-r8a7795", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee140000 0 0x2000>; - interrupts = <GIC_SPI 167 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 312>, <&cpg CPG_CORE R8A7795_CLK_SD2H>; - clock-names = "core", "clkh"; - max-frequency = <200000000>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 312>; - iommus = <&ipmmu_ds1 34>; - status = "disabled"; - }; - - sdhi3: mmc@ee160000 { - compatible = "renesas,sdhi-r8a7795", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee160000 0 0x2000>; - interrupts = <GIC_SPI 168 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 311>, <&cpg CPG_CORE R8A7795_CLK_SD3H>; - clock-names = "core", "clkh"; - max-frequency = <200000000>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 311>; - iommus = <&ipmmu_ds1 35>; - status = "disabled"; - }; - - rpc: spi@ee200000 { - compatible = "renesas,r8a7795-rpc-if", - "renesas,rcar-gen3-rpc-if"; - reg = <0 0xee200000 0 0x200>, - <0 0x08000000 0 0x04000000>, - <0 0xee208000 0 0x100>; - reg-names = "regs", "dirmap", "wbuf"; - interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 917>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 917>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - sata: sata@ee300000 { - compatible = "renesas,sata-r8a7795", - "renesas,rcar-gen3-sata"; - reg = <0 0xee300000 0 0x200000>; - interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 815>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 815>; - status = "disabled"; - iommus = <&ipmmu_hc 2>; - }; - - gic: interrupt-controller@f1010000 { - compatible = "arm,gic-400"; - #interrupt-cells = <3>; - #address-cells = <0>; - interrupt-controller; - reg = <0x0 0xf1010000 0 0x1000>, - <0x0 0xf1020000 0 0x20000>, - <0x0 0xf1040000 0 0x20000>, - <0x0 0xf1060000 0 0x20000>; - interrupts = <GIC_PPI 9 - (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_HIGH)>; - clocks = <&cpg CPG_MOD 408>; - clock-names = "clk"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 408>; - }; - - pciec0: pcie@fe000000 { - compatible = "renesas,pcie-r8a7795", - "renesas,pcie-rcar-gen3"; - reg = <0 0xfe000000 0 0x80000>; - #address-cells = <3>; - #size-cells = <2>; - bus-range = <0x00 0xff>; - device_type = "pci"; - ranges = <0x01000000 0 0x00000000 0 0xfe100000 0 0x00100000>, - <0x02000000 0 0xfe200000 0 0xfe200000 0 0x00200000>, - <0x02000000 0 0x30000000 0 0x30000000 0 0x08000000>, - <0x42000000 0 0x38000000 0 0x38000000 0 0x08000000>; - /* Map all possible DDR/IOMMU as inbound ranges */ - dma-ranges = <0x42000000 0 0x00000000 0 0x00000000 1 0x00000000>; - interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>; - #interrupt-cells = <1>; - interrupt-map-mask = <0 0 0 0>; - interrupt-map = <0 0 0 0 &gic GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 319>, <&pcie_bus_clk>; - clock-names = "pcie", "pcie_bus"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 319>; - iommu-map = <0 &ipmmu_hc 0 1>; - iommu-map-mask = <0>; - status = "disabled"; - }; - - pciec1: pcie@ee800000 { - compatible = "renesas,pcie-r8a7795", - "renesas,pcie-rcar-gen3"; - reg = <0 0xee800000 0 0x80000>; - #address-cells = <3>; - #size-cells = <2>; - bus-range = <0x00 0xff>; - device_type = "pci"; - ranges = <0x01000000 0 0x00000000 0 0xee900000 0 0x00100000>, - <0x02000000 0 0xeea00000 0 0xeea00000 0 0x00200000>, - <0x02000000 0 0xc0000000 0 0xc0000000 0 0x08000000>, - <0x42000000 0 0xc8000000 0 0xc8000000 0 0x08000000>; - /* Map all possible DDR/IOMMU as inbound ranges */ - dma-ranges = <0x42000000 0 0x00000000 0 0x00000000 1 0x00000000>; - interrupts = <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 149 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 150 IRQ_TYPE_LEVEL_HIGH>; - #interrupt-cells = <1>; - interrupt-map-mask = <0 0 0 0>; - interrupt-map = <0 0 0 0 &gic GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 318>, <&pcie_bus_clk>; - clock-names = "pcie", "pcie_bus"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 318>; - iommu-map = <0 &ipmmu_hc 1 1>; - iommu-map-mask = <0>; - status = "disabled"; - }; - - pciec0_ep: pcie-ep@fe000000 { - compatible = "renesas,r8a7795-pcie-ep", - "renesas,rcar-gen3-pcie-ep"; - reg = <0x0 0xfe000000 0 0x80000>, - <0x0 0xfe100000 0 0x100000>, - <0x0 0xfe200000 0 0x200000>, - <0x0 0x30000000 0 0x8000000>, - <0x0 0x38000000 0 0x8000000>; - reg-names = "apb-base", "memory0", "memory1", "memory2", "memory3"; - interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 319>; - clock-names = "pcie"; - resets = <&cpg 319>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - status = "disabled"; - }; - - pciec1_ep: pcie-ep@ee800000 { - compatible = "renesas,r8a7795-pcie-ep", - "renesas,rcar-gen3-pcie-ep"; - reg = <0x0 0xee800000 0 0x80000>, - <0x0 0xee900000 0 0x100000>, - <0x0 0xeea00000 0 0x200000>, - <0x0 0xc0000000 0 0x8000000>, - <0x0 0xc8000000 0 0x8000000>; - reg-names = "apb-base", "memory0", "memory1", "memory2", "memory3"; - interrupts = <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 149 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 150 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 318>; - clock-names = "pcie"; - resets = <&cpg 318>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - status = "disabled"; - }; - - imr-lx4@fe860000 { - compatible = "renesas,r8a7795-imr-lx4", - "renesas,imr-lx4"; - reg = <0 0xfe860000 0 0x2000>; - interrupts = <GIC_SPI 192 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 823>; - power-domains = <&sysc R8A7795_PD_A3VC>; - resets = <&cpg 823>; - }; - - imr-lx4@fe870000 { - compatible = "renesas,r8a7795-imr-lx4", - "renesas,imr-lx4"; - reg = <0 0xfe870000 0 0x2000>; - interrupts = <GIC_SPI 193 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 822>; - power-domains = <&sysc R8A7795_PD_A3VC>; - resets = <&cpg 822>; - }; - - imr-lx4@fe880000 { - compatible = "renesas,r8a7795-imr-lx4", - "renesas,imr-lx4"; - reg = <0 0xfe880000 0 0x2000>; - interrupts = <GIC_SPI 194 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 821>; - power-domains = <&sysc R8A7795_PD_A3VC>; - resets = <&cpg 821>; - }; - - imr-lx4@fe890000 { - compatible = "renesas,r8a7795-imr-lx4", - "renesas,imr-lx4"; - reg = <0 0xfe890000 0 0x2000>; - interrupts = <GIC_SPI 195 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 820>; - power-domains = <&sysc R8A7795_PD_A3VC>; - resets = <&cpg 820>; - }; - - vspbc: vsp@fe920000 { - compatible = "renesas,vsp2"; - reg = <0 0xfe920000 0 0x8000>; - interrupts = <GIC_SPI 465 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 624>; - power-domains = <&sysc R8A7795_PD_A3VP>; - resets = <&cpg 624>; - - renesas,fcp = <&fcpvb1>; - }; - - vspbd: vsp@fe960000 { - compatible = "renesas,vsp2"; - reg = <0 0xfe960000 0 0x8000>; - interrupts = <GIC_SPI 266 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 626>; - power-domains = <&sysc R8A7795_PD_A3VP>; - resets = <&cpg 626>; - - renesas,fcp = <&fcpvb0>; - }; - - vspd0: vsp@fea20000 { - compatible = "renesas,vsp2"; - reg = <0 0xfea20000 0 0x5000>; - interrupts = <GIC_SPI 466 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 623>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 623>; - - renesas,fcp = <&fcpvd0>; - }; - - vspd1: vsp@fea28000 { - compatible = "renesas,vsp2"; - reg = <0 0xfea28000 0 0x5000>; - interrupts = <GIC_SPI 467 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 622>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 622>; - - renesas,fcp = <&fcpvd1>; - }; - - vspd2: vsp@fea30000 { - compatible = "renesas,vsp2"; - reg = <0 0xfea30000 0 0x5000>; - interrupts = <GIC_SPI 468 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 621>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 621>; - - renesas,fcp = <&fcpvd2>; - }; - - vspi0: vsp@fe9a0000 { - compatible = "renesas,vsp2"; - reg = <0 0xfe9a0000 0 0x8000>; - interrupts = <GIC_SPI 444 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 631>; - power-domains = <&sysc R8A7795_PD_A3VP>; - resets = <&cpg 631>; - - renesas,fcp = <&fcpvi0>; - }; - - vspi1: vsp@fe9b0000 { - compatible = "renesas,vsp2"; - reg = <0 0xfe9b0000 0 0x8000>; - interrupts = <GIC_SPI 445 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 630>; - power-domains = <&sysc R8A7795_PD_A3VP>; - resets = <&cpg 630>; - - renesas,fcp = <&fcpvi1>; - }; - - fdp1@fe940000 { - compatible = "renesas,fdp1"; - reg = <0 0xfe940000 0 0x2400>; - interrupts = <GIC_SPI 262 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 119>; - power-domains = <&sysc R8A7795_PD_A3VP>; - resets = <&cpg 119>; - renesas,fcp = <&fcpf0>; - }; - - fdp1@fe944000 { - compatible = "renesas,fdp1"; - reg = <0 0xfe944000 0 0x2400>; - interrupts = <GIC_SPI 263 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 118>; - power-domains = <&sysc R8A7795_PD_A3VP>; - resets = <&cpg 118>; - renesas,fcp = <&fcpf1>; - }; - - fcpf0: fcp@fe950000 { - compatible = "renesas,fcpf"; - reg = <0 0xfe950000 0 0x200>; - clocks = <&cpg CPG_MOD 615>; - power-domains = <&sysc R8A7795_PD_A3VP>; - resets = <&cpg 615>; - iommus = <&ipmmu_vp0 0>; - }; - - fcpf1: fcp@fe951000 { - compatible = "renesas,fcpf"; - reg = <0 0xfe951000 0 0x200>; - clocks = <&cpg CPG_MOD 614>; - power-domains = <&sysc R8A7795_PD_A3VP>; - resets = <&cpg 614>; - iommus = <&ipmmu_vp1 1>; - }; - - fcpvb0: fcp@fe96f000 { - compatible = "renesas,fcpv"; - reg = <0 0xfe96f000 0 0x200>; - clocks = <&cpg CPG_MOD 607>; - power-domains = <&sysc R8A7795_PD_A3VP>; - resets = <&cpg 607>; - iommus = <&ipmmu_vp0 5>; - }; - - fcpvb1: fcp@fe92f000 { - compatible = "renesas,fcpv"; - reg = <0 0xfe92f000 0 0x200>; - clocks = <&cpg CPG_MOD 606>; - power-domains = <&sysc R8A7795_PD_A3VP>; - resets = <&cpg 606>; - iommus = <&ipmmu_vp1 7>; - }; - - fcpvi0: fcp@fe9af000 { - compatible = "renesas,fcpv"; - reg = <0 0xfe9af000 0 0x200>; - clocks = <&cpg CPG_MOD 611>; - power-domains = <&sysc R8A7795_PD_A3VP>; - resets = <&cpg 611>; - iommus = <&ipmmu_vp0 8>; - }; - - fcpvi1: fcp@fe9bf000 { - compatible = "renesas,fcpv"; - reg = <0 0xfe9bf000 0 0x200>; - clocks = <&cpg CPG_MOD 610>; - power-domains = <&sysc R8A7795_PD_A3VP>; - resets = <&cpg 610>; - iommus = <&ipmmu_vp1 9>; - }; - - fcpvd0: fcp@fea27000 { - compatible = "renesas,fcpv"; - reg = <0 0xfea27000 0 0x200>; - clocks = <&cpg CPG_MOD 603>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 603>; - iommus = <&ipmmu_vi0 8>; - }; - - fcpvd1: fcp@fea2f000 { - compatible = "renesas,fcpv"; - reg = <0 0xfea2f000 0 0x200>; - clocks = <&cpg CPG_MOD 602>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 602>; - iommus = <&ipmmu_vi0 9>; - }; - - fcpvd2: fcp@fea37000 { - compatible = "renesas,fcpv"; - reg = <0 0xfea37000 0 0x200>; - clocks = <&cpg CPG_MOD 601>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 601>; - iommus = <&ipmmu_vi1 10>; - }; - - cmm0: cmm@fea40000 { - compatible = "renesas,r8a7795-cmm", - "renesas,rcar-gen3-cmm"; - reg = <0 0xfea40000 0 0x1000>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - clocks = <&cpg CPG_MOD 711>; - resets = <&cpg 711>; - }; - - cmm1: cmm@fea50000 { - compatible = "renesas,r8a7795-cmm", - "renesas,rcar-gen3-cmm"; - reg = <0 0xfea50000 0 0x1000>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - clocks = <&cpg CPG_MOD 710>; - resets = <&cpg 710>; - }; - - cmm2: cmm@fea60000 { - compatible = "renesas,r8a7795-cmm", - "renesas,rcar-gen3-cmm"; - reg = <0 0xfea60000 0 0x1000>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - clocks = <&cpg CPG_MOD 709>; - resets = <&cpg 709>; - }; - - cmm3: cmm@fea70000 { - compatible = "renesas,r8a7795-cmm", - "renesas,rcar-gen3-cmm"; - reg = <0 0xfea70000 0 0x1000>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - clocks = <&cpg CPG_MOD 708>; - resets = <&cpg 708>; - }; - - csi20: csi2@fea80000 { - compatible = "renesas,r8a7795-csi2"; - reg = <0 0xfea80000 0 0x10000>; - interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 714>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 714>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - csi20vin0: endpoint@0 { - reg = <0>; - remote-endpoint = <&vin0csi20>; - }; - csi20vin1: endpoint@1 { - reg = <1>; - remote-endpoint = <&vin1csi20>; - }; - csi20vin2: endpoint@2 { - reg = <2>; - remote-endpoint = <&vin2csi20>; - }; - csi20vin3: endpoint@3 { - reg = <3>; - remote-endpoint = <&vin3csi20>; - }; - csi20vin4: endpoint@4 { - reg = <4>; - remote-endpoint = <&vin4csi20>; - }; - csi20vin5: endpoint@5 { - reg = <5>; - remote-endpoint = <&vin5csi20>; - }; - csi20vin6: endpoint@6 { - reg = <6>; - remote-endpoint = <&vin6csi20>; - }; - csi20vin7: endpoint@7 { - reg = <7>; - remote-endpoint = <&vin7csi20>; - }; - }; - }; - }; - - csi40: csi2@feaa0000 { - compatible = "renesas,r8a7795-csi2"; - reg = <0 0xfeaa0000 0 0x10000>; - interrupts = <GIC_SPI 246 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 716>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 716>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - csi40vin0: endpoint@0 { - reg = <0>; - remote-endpoint = <&vin0csi40>; - }; - csi40vin1: endpoint@1 { - reg = <1>; - remote-endpoint = <&vin1csi40>; - }; - csi40vin2: endpoint@2 { - reg = <2>; - remote-endpoint = <&vin2csi40>; - }; - csi40vin3: endpoint@3 { - reg = <3>; - remote-endpoint = <&vin3csi40>; - }; - }; - }; - }; - - csi41: csi2@feab0000 { - compatible = "renesas,r8a7795-csi2"; - reg = <0 0xfeab0000 0 0x10000>; - interrupts = <GIC_SPI 247 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 715>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 715>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - csi41vin4: endpoint@0 { - reg = <0>; - remote-endpoint = <&vin4csi41>; - }; - csi41vin5: endpoint@1 { - reg = <1>; - remote-endpoint = <&vin5csi41>; - }; - csi41vin6: endpoint@2 { - reg = <2>; - remote-endpoint = <&vin6csi41>; - }; - csi41vin7: endpoint@3 { - reg = <3>; - remote-endpoint = <&vin7csi41>; - }; - }; - }; - }; - - hdmi0: hdmi@fead0000 { - compatible = "renesas,r8a7795-hdmi", "renesas,rcar-gen3-hdmi"; - reg = <0 0xfead0000 0 0x10000>; - interrupts = <GIC_SPI 389 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 729>, <&cpg CPG_CORE R8A7795_CLK_HDMI>; - clock-names = "iahb", "isfr"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 729>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - port@0 { - reg = <0>; - dw_hdmi0_in: endpoint { - remote-endpoint = <&du_out_hdmi0>; - }; - }; - port@1 { - reg = <1>; - }; - port@2 { - /* HDMI sound */ - reg = <2>; - }; - }; - }; - - hdmi1: hdmi@feae0000 { - compatible = "renesas,r8a7795-hdmi", "renesas,rcar-gen3-hdmi"; - reg = <0 0xfeae0000 0 0x10000>; - interrupts = <GIC_SPI 436 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 728>, <&cpg CPG_CORE R8A7795_CLK_HDMI>; - clock-names = "iahb", "isfr"; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 728>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - port@0 { - reg = <0>; - dw_hdmi1_in: endpoint { - remote-endpoint = <&du_out_hdmi1>; - }; - }; - port@1 { - reg = <1>; - }; - port@2 { - /* HDMI sound */ - reg = <2>; - }; - }; - }; - - du: display@feb00000 { - compatible = "renesas,du-r8a7795"; - reg = <0 0xfeb00000 0 0x80000>; - interrupts = <GIC_SPI 256 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 268 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 269 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 270 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 724>, <&cpg CPG_MOD 723>, - <&cpg CPG_MOD 722>, <&cpg CPG_MOD 721>; - clock-names = "du.0", "du.1", "du.2", "du.3"; - resets = <&cpg 724>, <&cpg 722>; - reset-names = "du.0", "du.2"; - - renesas,cmms = <&cmm0>, <&cmm1>, <&cmm2>, <&cmm3>; - renesas,vsps = <&vspd0 0>, <&vspd1 0>, <&vspd2 0>, - <&vspd0 1>; - - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - port@1 { - reg = <1>; - du_out_hdmi0: endpoint { - remote-endpoint = <&dw_hdmi0_in>; - }; - }; - port@2 { - reg = <2>; - du_out_hdmi1: endpoint { - remote-endpoint = <&dw_hdmi1_in>; - }; - }; - port@3 { - reg = <3>; - du_out_lvds0: endpoint { - remote-endpoint = <&lvds0_in>; - }; - }; - }; - }; - - lvds0: lvds@feb90000 { - compatible = "renesas,r8a7795-lvds"; - reg = <0 0xfeb90000 0 0x14>; - clocks = <&cpg CPG_MOD 727>; - power-domains = <&sysc R8A7795_PD_ALWAYS_ON>; - resets = <&cpg 727>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - lvds0_in: endpoint { - remote-endpoint = <&du_out_lvds0>; - }; - }; - port@1 { - reg = <1>; - }; - }; - }; - - prr: chipid@fff00044 { - compatible = "renesas,prr"; - reg = <0 0xfff00044 0 4>; - }; - }; - - thermal-zones { - sensor1_thermal: sensor1-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - thermal-sensors = <&tsc 0>; - sustainable-power = <6313>; - - trips { - sensor1_crit: sensor1-crit { - temperature = <120000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - }; - - sensor2_thermal: sensor2-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - thermal-sensors = <&tsc 1>; - sustainable-power = <6313>; - - trips { - sensor2_crit: sensor2-crit { - temperature = <120000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - }; - - sensor3_thermal: sensor3-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - thermal-sensors = <&tsc 2>; - - trips { - target: trip-point1 { - temperature = <100000>; - hysteresis = <1000>; - type = "passive"; - }; - - sensor3_crit: sensor3-crit { - temperature = <120000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - - cooling-maps { - map0 { - trip = <&target>; - cooling-device = <&a57_0 2 4>; - contribution = <1024>; - }; - - map1 { - trip = <&target>; - cooling-device = <&a53_0 0 2>; - contribution = <1024>; - }; - }; - }; - }; - - timer { - compatible = "arm,armv8-timer"; - interrupts-extended = <&gic GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_LOW)>; - }; - - /* External USB clocks - can be overridden by the board */ - usb3s0_clk: usb3s0 { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - usb_extal_clk: usb_extal { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; -}; diff --git a/arch/arm/dts/r8a77960-salvator-x.dts b/arch/arm/dts/r8a77960-salvator-x.dts deleted file mode 100644 index d5543f26c47..00000000000 --- a/arch/arm/dts/r8a77960-salvator-x.dts +++ /dev/null @@ -1,37 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the Salvator-X board with R-Car M3-W - * - * Copyright (C) 2016 Renesas Electronics Corp. - */ - -/dts-v1/; -#include "r8a77960.dtsi" -#include "salvator-x.dtsi" - -/ { - model = "Renesas Salvator-X board based on r8a77960"; - compatible = "renesas,salvator-x", "renesas,r8a7796"; - - memory@48000000 { - device_type = "memory"; - /* first 128MB is reserved for secure area. */ - reg = <0x0 0x48000000 0x0 0x78000000>; - }; - - memory@600000000 { - device_type = "memory"; - reg = <0x6 0x00000000 0x0 0x80000000>; - }; -}; - -&du { - clocks = <&cpg CPG_MOD 724>, - <&cpg CPG_MOD 723>, - <&cpg CPG_MOD 722>, - <&versaclock5 1>, - <&x21_clk>, - <&versaclock5 2>; - clock-names = "du.0", "du.1", "du.2", - "dclkin.0", "dclkin.1", "dclkin.2"; -}; diff --git a/arch/arm/dts/r8a77960-ulcb.dts b/arch/arm/dts/r8a77960-ulcb.dts deleted file mode 100644 index 4bfeb1df048..00000000000 --- a/arch/arm/dts/r8a77960-ulcb.dts +++ /dev/null @@ -1,38 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the M3ULCB (R-Car Starter Kit Pro) board with R-Car M3-W - * - * Copyright (C) 2016 Renesas Electronics Corp. - * Copyright (C) 2016 Cogent Embedded, Inc. - */ - -/dts-v1/; -#include "r8a77960.dtsi" -#include "ulcb.dtsi" - -/ { - model = "Renesas M3ULCB board based on r8a77960"; - compatible = "renesas,m3ulcb", "renesas,r8a7796"; - - memory@48000000 { - device_type = "memory"; - /* first 128MB is reserved for secure area. */ - reg = <0x0 0x48000000 0x0 0x38000000>; - }; - - memory@600000000 { - device_type = "memory"; - reg = <0x6 0x00000000 0x0 0x40000000>; - }; -}; - -&du { - clocks = <&cpg CPG_MOD 724>, - <&cpg CPG_MOD 723>, - <&cpg CPG_MOD 722>, - <&versaclock5 1>, - <&versaclock5 3>, - <&versaclock5 2>; - clock-names = "du.0", "du.1", "du.2", - "dclkin.0", "dclkin.1", "dclkin.2"; -}; diff --git a/arch/arm/dts/r8a77960.dtsi b/arch/arm/dts/r8a77960.dtsi deleted file mode 100644 index 17062ec506b..00000000000 --- a/arch/arm/dts/r8a77960.dtsi +++ /dev/null @@ -1,3080 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the R-Car M3-W (R8A77960) SoC - * - * Copyright (C) 2016-2017 Renesas Electronics Corp. - */ - -#include <dt-bindings/clock/r8a7796-cpg-mssr.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/power/r8a7796-sysc.h> - -#define CPG_AUDIO_CLK_I R8A7796_CLK_S0D4 - -/ { - compatible = "renesas,r8a7796"; - #address-cells = <2>; - #size-cells = <2>; - - /* - * The external audio clocks are configured as 0 Hz fixed frequency - * clocks by default. - * Boards that provide audio clocks should override them. - */ - audio_clk_a: audio_clk_a { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - audio_clk_b: audio_clk_b { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - audio_clk_c: audio_clk_c { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - /* External CAN clock - to be overridden by boards that provide it */ - can_clk: can { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - cluster0_opp: opp-table-0 { - compatible = "operating-points-v2"; - opp-shared; - - opp-500000000 { - opp-hz = /bits/ 64 <500000000>; - opp-microvolt = <830000>; - clock-latency-ns = <300000>; - }; - opp-1000000000 { - opp-hz = /bits/ 64 <1000000000>; - opp-microvolt = <830000>; - clock-latency-ns = <300000>; - }; - opp-1500000000 { - opp-hz = /bits/ 64 <1500000000>; - opp-microvolt = <830000>; - clock-latency-ns = <300000>; - opp-suspend; - }; - opp-1600000000 { - opp-hz = /bits/ 64 <1600000000>; - opp-microvolt = <900000>; - clock-latency-ns = <300000>; - }; - opp-1700000000 { - opp-hz = /bits/ 64 <1700000000>; - opp-microvolt = <900000>; - clock-latency-ns = <300000>; - }; - opp-1800000000 { - opp-hz = /bits/ 64 <1800000000>; - opp-microvolt = <960000>; - clock-latency-ns = <300000>; - turbo-mode; - }; - }; - - cluster1_opp: opp-table-1 { - compatible = "operating-points-v2"; - opp-shared; - - opp-800000000 { - opp-hz = /bits/ 64 <800000000>; - opp-microvolt = <820000>; - clock-latency-ns = <300000>; - }; - opp-1000000000 { - opp-hz = /bits/ 64 <1000000000>; - opp-microvolt = <820000>; - clock-latency-ns = <300000>; - }; - opp-1200000000 { - opp-hz = /bits/ 64 <1200000000>; - opp-microvolt = <820000>; - clock-latency-ns = <300000>; - }; - opp-1300000000 { - opp-hz = /bits/ 64 <1300000000>; - opp-microvolt = <820000>; - clock-latency-ns = <300000>; - turbo-mode; - }; - }; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - - cpu-map { - cluster0 { - core0 { - cpu = <&a57_0>; - }; - core1 { - cpu = <&a57_1>; - }; - }; - - cluster1 { - core0 { - cpu = <&a53_0>; - }; - core1 { - cpu = <&a53_1>; - }; - core2 { - cpu = <&a53_2>; - }; - core3 { - cpu = <&a53_3>; - }; - }; - }; - - a57_0: cpu@0 { - compatible = "arm,cortex-a57"; - reg = <0x0>; - device_type = "cpu"; - power-domains = <&sysc R8A7796_PD_CA57_CPU0>; - next-level-cache = <&L2_CA57>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_0>; - dynamic-power-coefficient = <854>; - clocks = <&cpg CPG_CORE R8A7796_CLK_Z>; - operating-points-v2 = <&cluster0_opp>; - capacity-dmips-mhz = <1024>; - #cooling-cells = <2>; - }; - - a57_1: cpu@1 { - compatible = "arm,cortex-a57"; - reg = <0x1>; - device_type = "cpu"; - power-domains = <&sysc R8A7796_PD_CA57_CPU1>; - next-level-cache = <&L2_CA57>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_0>; - clocks = <&cpg CPG_CORE R8A7796_CLK_Z>; - operating-points-v2 = <&cluster0_opp>; - capacity-dmips-mhz = <1024>; - #cooling-cells = <2>; - }; - - a53_0: cpu@100 { - compatible = "arm,cortex-a53"; - reg = <0x100>; - device_type = "cpu"; - power-domains = <&sysc R8A7796_PD_CA53_CPU0>; - next-level-cache = <&L2_CA53>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_1>; - #cooling-cells = <2>; - dynamic-power-coefficient = <277>; - clocks = <&cpg CPG_CORE R8A7796_CLK_Z2>; - operating-points-v2 = <&cluster1_opp>; - capacity-dmips-mhz = <535>; - }; - - a53_1: cpu@101 { - compatible = "arm,cortex-a53"; - reg = <0x101>; - device_type = "cpu"; - power-domains = <&sysc R8A7796_PD_CA53_CPU1>; - next-level-cache = <&L2_CA53>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_1>; - clocks = <&cpg CPG_CORE R8A7796_CLK_Z2>; - operating-points-v2 = <&cluster1_opp>; - capacity-dmips-mhz = <535>; - }; - - a53_2: cpu@102 { - compatible = "arm,cortex-a53"; - reg = <0x102>; - device_type = "cpu"; - power-domains = <&sysc R8A7796_PD_CA53_CPU2>; - next-level-cache = <&L2_CA53>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_1>; - clocks = <&cpg CPG_CORE R8A7796_CLK_Z2>; - operating-points-v2 = <&cluster1_opp>; - capacity-dmips-mhz = <535>; - }; - - a53_3: cpu@103 { - compatible = "arm,cortex-a53"; - reg = <0x103>; - device_type = "cpu"; - power-domains = <&sysc R8A7796_PD_CA53_CPU3>; - next-level-cache = <&L2_CA53>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_1>; - clocks = <&cpg CPG_CORE R8A7796_CLK_Z2>; - operating-points-v2 = <&cluster1_opp>; - capacity-dmips-mhz = <535>; - }; - - L2_CA57: cache-controller-0 { - compatible = "cache"; - power-domains = <&sysc R8A7796_PD_CA57_SCU>; - cache-unified; - cache-level = <2>; - }; - - L2_CA53: cache-controller-1 { - compatible = "cache"; - power-domains = <&sysc R8A7796_PD_CA53_SCU>; - cache-unified; - cache-level = <2>; - }; - - idle-states { - entry-method = "psci"; - - CPU_SLEEP_0: cpu-sleep-0 { - compatible = "arm,idle-state"; - arm,psci-suspend-param = <0x0010000>; - local-timer-stop; - entry-latency-us = <400>; - exit-latency-us = <500>; - min-residency-us = <4000>; - }; - - CPU_SLEEP_1: cpu-sleep-1 { - compatible = "arm,idle-state"; - arm,psci-suspend-param = <0x0010000>; - local-timer-stop; - entry-latency-us = <700>; - exit-latency-us = <700>; - min-residency-us = <5000>; - }; - }; - }; - - extal_clk: extal { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board */ - clock-frequency = <0>; - }; - - extalr_clk: extalr { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board */ - clock-frequency = <0>; - }; - - /* External PCIe clock - can be overridden by the board */ - pcie_bus_clk: pcie_bus { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - pmu_a53 { - compatible = "arm,cortex-a53-pmu"; - interrupts-extended = <&gic GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&a53_0>, <&a53_1>, <&a53_2>, <&a53_3>; - }; - - pmu_a57 { - compatible = "arm,cortex-a57-pmu"; - interrupts-extended = <&gic GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&a57_0>, <&a57_1>; - }; - - psci { - compatible = "arm,psci-1.0", "arm,psci-0.2"; - method = "smc"; - }; - - /* External SCIF clock - to be overridden by boards that provide it */ - scif_clk: scif { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - soc { - compatible = "simple-bus"; - interrupt-parent = <&gic>; - #address-cells = <2>; - #size-cells = <2>; - ranges; - - rwdt: watchdog@e6020000 { - compatible = "renesas,r8a7796-wdt", - "renesas,rcar-gen3-wdt"; - reg = <0 0xe6020000 0 0x0c>; - interrupts = <GIC_SPI 140 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 402>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 402>; - status = "disabled"; - }; - - gpio0: gpio@e6050000 { - compatible = "renesas,gpio-r8a7796", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6050000 0 0x50>; - interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 0 16>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 912>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 912>; - }; - - gpio1: gpio@e6051000 { - compatible = "renesas,gpio-r8a7796", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6051000 0 0x50>; - interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 32 29>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 911>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 911>; - }; - - gpio2: gpio@e6052000 { - compatible = "renesas,gpio-r8a7796", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6052000 0 0x50>; - interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 64 15>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 910>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 910>; - }; - - gpio3: gpio@e6053000 { - compatible = "renesas,gpio-r8a7796", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6053000 0 0x50>; - interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 96 16>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 909>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 909>; - }; - - gpio4: gpio@e6054000 { - compatible = "renesas,gpio-r8a7796", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6054000 0 0x50>; - interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 128 18>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 908>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 908>; - }; - - gpio5: gpio@e6055000 { - compatible = "renesas,gpio-r8a7796", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6055000 0 0x50>; - interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 160 26>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 907>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 907>; - }; - - gpio6: gpio@e6055400 { - compatible = "renesas,gpio-r8a7796", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6055400 0 0x50>; - interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 192 32>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 906>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 906>; - }; - - gpio7: gpio@e6055800 { - compatible = "renesas,gpio-r8a7796", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6055800 0 0x50>; - interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 224 4>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 905>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 905>; - }; - - pfc: pinctrl@e6060000 { - compatible = "renesas,pfc-r8a7796"; - reg = <0 0xe6060000 0 0x50c>; - }; - - cmt0: timer@e60f0000 { - compatible = "renesas,r8a7796-cmt0", - "renesas,rcar-gen3-cmt0"; - reg = <0 0xe60f0000 0 0x1004>; - interrupts = <GIC_SPI 142 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 143 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 303>; - clock-names = "fck"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 303>; - status = "disabled"; - }; - - cmt1: timer@e6130000 { - compatible = "renesas,r8a7796-cmt1", - "renesas,rcar-gen3-cmt1"; - reg = <0 0xe6130000 0 0x1004>; - interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 127 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 302>; - clock-names = "fck"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 302>; - status = "disabled"; - }; - - cmt2: timer@e6140000 { - compatible = "renesas,r8a7796-cmt1", - "renesas,rcar-gen3-cmt1"; - reg = <0 0xe6140000 0 0x1004>; - interrupts = <GIC_SPI 398 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 399 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 400 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 401 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 402 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 403 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 404 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 405 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 301>; - clock-names = "fck"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 301>; - status = "disabled"; - }; - - cmt3: timer@e6148000 { - compatible = "renesas,r8a7796-cmt1", - "renesas,rcar-gen3-cmt1"; - reg = <0 0xe6148000 0 0x1004>; - interrupts = <GIC_SPI 470 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 471 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 472 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 473 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 474 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 475 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 476 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 477 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 300>; - clock-names = "fck"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 300>; - status = "disabled"; - }; - - cpg: clock-controller@e6150000 { - compatible = "renesas,r8a7796-cpg-mssr"; - reg = <0 0xe6150000 0 0x1000>; - clocks = <&extal_clk>, <&extalr_clk>; - clock-names = "extal", "extalr"; - #clock-cells = <2>; - #power-domain-cells = <0>; - #reset-cells = <1>; - }; - - rst: reset-controller@e6160000 { - compatible = "renesas,r8a7796-rst"; - reg = <0 0xe6160000 0 0x0200>; - }; - - sysc: system-controller@e6180000 { - compatible = "renesas,r8a7796-sysc"; - reg = <0 0xe6180000 0 0x0400>; - #power-domain-cells = <1>; - }; - - tsc: thermal@e6198000 { - compatible = "renesas,r8a7796-thermal"; - reg = <0 0xe6198000 0 0x100>, - <0 0xe61a0000 0 0x100>, - <0 0xe61a8000 0 0x100>; - interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 522>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 522>; - #thermal-sensor-cells = <1>; - }; - - intc_ex: interrupt-controller@e61c0000 { - compatible = "renesas,intc-ex-r8a7796", "renesas,irqc"; - #interrupt-cells = <2>; - interrupt-controller; - reg = <0 0xe61c0000 0 0x200>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 161 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 407>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 407>; - }; - - tmu0: timer@e61e0000 { - compatible = "renesas,tmu-r8a7796", "renesas,tmu"; - reg = <0 0xe61e0000 0 0x30>; - interrupts = <GIC_SPI 136 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 137 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 138 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 125>; - clock-names = "fck"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 125>; - status = "disabled"; - }; - - tmu1: timer@e6fc0000 { - compatible = "renesas,tmu-r8a7796", "renesas,tmu"; - reg = <0 0xe6fc0000 0 0x30>; - interrupts = <GIC_SPI 128 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 129 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 130 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 124>; - clock-names = "fck"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 124>; - status = "disabled"; - }; - - tmu2: timer@e6fd0000 { - compatible = "renesas,tmu-r8a7796", "renesas,tmu"; - reg = <0 0xe6fd0000 0 0x30>; - interrupts = <GIC_SPI 303 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 304 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 305 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 123>; - clock-names = "fck"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 123>; - status = "disabled"; - }; - - tmu3: timer@e6fe0000 { - compatible = "renesas,tmu-r8a7796", "renesas,tmu"; - reg = <0 0xe6fe0000 0 0x30>; - interrupts = <GIC_SPI 131 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 132 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 133 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 122>; - clock-names = "fck"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 122>; - status = "disabled"; - }; - - tmu4: timer@ffc00000 { - compatible = "renesas,tmu-r8a7796", "renesas,tmu"; - reg = <0 0xffc00000 0 0x30>; - interrupts = <GIC_SPI 406 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 407 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 408 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 121>; - clock-names = "fck"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 121>; - status = "disabled"; - }; - - i2c0: i2c@e6500000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a7796", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6500000 0 0x40>; - interrupts = <GIC_SPI 287 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 931>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 931>; - dmas = <&dmac1 0x91>, <&dmac1 0x90>, - <&dmac2 0x91>, <&dmac2 0x90>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - status = "disabled"; - }; - - i2c1: i2c@e6508000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a7796", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6508000 0 0x40>; - interrupts = <GIC_SPI 288 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 930>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 930>; - dmas = <&dmac1 0x93>, <&dmac1 0x92>, - <&dmac2 0x93>, <&dmac2 0x92>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c2: i2c@e6510000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a7796", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6510000 0 0x40>; - interrupts = <GIC_SPI 286 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 929>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 929>; - dmas = <&dmac1 0x95>, <&dmac1 0x94>, - <&dmac2 0x95>, <&dmac2 0x94>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c3: i2c@e66d0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a7796", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66d0000 0 0x40>; - interrupts = <GIC_SPI 290 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 928>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 928>; - dmas = <&dmac0 0x97>, <&dmac0 0x96>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - status = "disabled"; - }; - - i2c4: i2c@e66d8000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a7796", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66d8000 0 0x40>; - interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 927>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 927>; - dmas = <&dmac0 0x99>, <&dmac0 0x98>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - status = "disabled"; - }; - - i2c5: i2c@e66e0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a7796", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66e0000 0 0x40>; - interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 919>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 919>; - dmas = <&dmac0 0x9b>, <&dmac0 0x9a>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - status = "disabled"; - }; - - i2c6: i2c@e66e8000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a7796", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66e8000 0 0x40>; - interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 918>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 918>; - dmas = <&dmac0 0x9d>, <&dmac0 0x9c>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c_dvfs: i2c@e60b0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,iic-r8a7796", - "renesas,rcar-gen3-iic", - "renesas,rmobile-iic"; - reg = <0 0xe60b0000 0 0x425>; - interrupts = <GIC_SPI 173 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 926>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 926>; - dmas = <&dmac0 0x11>, <&dmac0 0x10>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - hscif0: serial@e6540000 { - compatible = "renesas,hscif-r8a7796", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe6540000 0 0x60>; - interrupts = <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 520>, - <&cpg CPG_CORE R8A7796_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x31>, <&dmac1 0x30>, - <&dmac2 0x31>, <&dmac2 0x30>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 520>; - status = "disabled"; - }; - - hscif1: serial@e6550000 { - compatible = "renesas,hscif-r8a7796", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe6550000 0 0x60>; - interrupts = <GIC_SPI 155 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 519>, - <&cpg CPG_CORE R8A7796_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x33>, <&dmac1 0x32>, - <&dmac2 0x33>, <&dmac2 0x32>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 519>; - status = "disabled"; - }; - - hscif2: serial@e6560000 { - compatible = "renesas,hscif-r8a7796", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe6560000 0 0x60>; - interrupts = <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 518>, - <&cpg CPG_CORE R8A7796_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x35>, <&dmac1 0x34>, - <&dmac2 0x35>, <&dmac2 0x34>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 518>; - status = "disabled"; - }; - - hscif3: serial@e66a0000 { - compatible = "renesas,hscif-r8a7796", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe66a0000 0 0x60>; - interrupts = <GIC_SPI 145 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 517>, - <&cpg CPG_CORE R8A7796_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x37>, <&dmac0 0x36>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 517>; - status = "disabled"; - }; - - hscif4: serial@e66b0000 { - compatible = "renesas,hscif-r8a7796", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe66b0000 0 0x60>; - interrupts = <GIC_SPI 146 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 516>, - <&cpg CPG_CORE R8A7796_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x39>, <&dmac0 0x38>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 516>; - status = "disabled"; - }; - - hsusb: usb@e6590000 { - compatible = "renesas,usbhs-r8a7796", - "renesas,rcar-gen3-usbhs"; - reg = <0 0xe6590000 0 0x200>; - interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 704>, <&cpg CPG_MOD 703>; - dmas = <&usb_dmac0 0>, <&usb_dmac0 1>, - <&usb_dmac1 0>, <&usb_dmac1 1>; - dma-names = "ch0", "ch1", "ch2", "ch3"; - renesas,buswait = <11>; - phys = <&usb2_phy0 3>; - phy-names = "usb"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 704>, <&cpg 703>; - status = "disabled"; - }; - - usb_dmac0: dma-controller@e65a0000 { - compatible = "renesas,r8a7796-usb-dmac", - "renesas,usb-dmac"; - reg = <0 0xe65a0000 0 0x100>; - interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1"; - clocks = <&cpg CPG_MOD 330>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 330>; - #dma-cells = <1>; - dma-channels = <2>; - }; - - usb_dmac1: dma-controller@e65b0000 { - compatible = "renesas,r8a7796-usb-dmac", - "renesas,usb-dmac"; - reg = <0 0xe65b0000 0 0x100>; - interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1"; - clocks = <&cpg CPG_MOD 331>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 331>; - #dma-cells = <1>; - dma-channels = <2>; - }; - - usb3_phy0: usb-phy@e65ee000 { - compatible = "renesas,r8a7796-usb3-phy", - "renesas,rcar-gen3-usb3-phy"; - reg = <0 0xe65ee000 0 0x90>; - clocks = <&cpg CPG_MOD 328>, <&usb3s0_clk>, - <&usb_extal_clk>; - clock-names = "usb3-if", "usb3s_clk", "usb_extal"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 328>; - #phy-cells = <0>; - status = "disabled"; - }; - - arm_cc630p: crypto@e6601000 { - compatible = "arm,cryptocell-630p-ree"; - interrupts = <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x0 0xe6601000 0 0x1000>; - clocks = <&cpg CPG_MOD 229>; - resets = <&cpg 229>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - }; - - dmac0: dma-controller@e6700000 { - compatible = "renesas,dmac-r8a7796", - "renesas,rcar-dmac"; - reg = <0 0xe6700000 0 0x10000>; - interrupts = <GIC_SPI 199 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 200 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 201 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 202 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 203 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 204 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 205 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 206 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 207 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 208 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 209 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 210 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 211 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 212 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 213 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 214 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 215 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 219>; - clock-names = "fck"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 219>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_ds0 0>, <&ipmmu_ds0 1>, - <&ipmmu_ds0 2>, <&ipmmu_ds0 3>, - <&ipmmu_ds0 4>, <&ipmmu_ds0 5>, - <&ipmmu_ds0 6>, <&ipmmu_ds0 7>, - <&ipmmu_ds0 8>, <&ipmmu_ds0 9>, - <&ipmmu_ds0 10>, <&ipmmu_ds0 11>, - <&ipmmu_ds0 12>, <&ipmmu_ds0 13>, - <&ipmmu_ds0 14>, <&ipmmu_ds0 15>; - }; - - dmac1: dma-controller@e7300000 { - compatible = "renesas,dmac-r8a7796", - "renesas,rcar-dmac"; - reg = <0 0xe7300000 0 0x10000>; - interrupts = <GIC_SPI 220 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 216 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 217 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 218 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 219 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 308 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 309 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 310 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 311 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 312 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 313 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 314 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 315 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 316 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 317 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 318 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 319 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 218>; - clock-names = "fck"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 218>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_ds1 0>, <&ipmmu_ds1 1>, - <&ipmmu_ds1 2>, <&ipmmu_ds1 3>, - <&ipmmu_ds1 4>, <&ipmmu_ds1 5>, - <&ipmmu_ds1 6>, <&ipmmu_ds1 7>, - <&ipmmu_ds1 8>, <&ipmmu_ds1 9>, - <&ipmmu_ds1 10>, <&ipmmu_ds1 11>, - <&ipmmu_ds1 12>, <&ipmmu_ds1 13>, - <&ipmmu_ds1 14>, <&ipmmu_ds1 15>; - }; - - dmac2: dma-controller@e7310000 { - compatible = "renesas,dmac-r8a7796", - "renesas,rcar-dmac"; - reg = <0 0xe7310000 0 0x10000>; - interrupts = <GIC_SPI 416 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 417 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 418 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 419 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 420 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 421 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 422 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 423 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 424 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 425 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 426 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 427 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 428 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 429 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 430 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 431 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 397 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 217>; - clock-names = "fck"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 217>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_ds1 16>, <&ipmmu_ds1 17>, - <&ipmmu_ds1 18>, <&ipmmu_ds1 19>, - <&ipmmu_ds1 20>, <&ipmmu_ds1 21>, - <&ipmmu_ds1 22>, <&ipmmu_ds1 23>, - <&ipmmu_ds1 24>, <&ipmmu_ds1 25>, - <&ipmmu_ds1 26>, <&ipmmu_ds1 27>, - <&ipmmu_ds1 28>, <&ipmmu_ds1 29>, - <&ipmmu_ds1 30>, <&ipmmu_ds1 31>; - }; - - ipmmu_ds0: iommu@e6740000 { - compatible = "renesas,ipmmu-r8a7796"; - reg = <0 0xe6740000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 0>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_ds1: iommu@e7740000 { - compatible = "renesas,ipmmu-r8a7796"; - reg = <0 0xe7740000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 1>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_hc: iommu@e6570000 { - compatible = "renesas,ipmmu-r8a7796"; - reg = <0 0xe6570000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 2>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_ir: iommu@ff8b0000 { - compatible = "renesas,ipmmu-r8a7796"; - reg = <0 0xff8b0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 3>; - power-domains = <&sysc R8A7796_PD_A3IR>; - #iommu-cells = <1>; - }; - - ipmmu_mm: iommu@e67b0000 { - compatible = "renesas,ipmmu-r8a7796"; - reg = <0 0xe67b0000 0 0x1000>; - interrupts = <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_mp: iommu@ec670000 { - compatible = "renesas,ipmmu-r8a7796"; - reg = <0 0xec670000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 4>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_pv0: iommu@fd800000 { - compatible = "renesas,ipmmu-r8a7796"; - reg = <0 0xfd800000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 5>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_pv1: iommu@fd950000 { - compatible = "renesas,ipmmu-r8a7796"; - reg = <0 0xfd950000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 6>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_rt: iommu@ffc80000 { - compatible = "renesas,ipmmu-r8a7796"; - reg = <0 0xffc80000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 7>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_vc0: iommu@fe6b0000 { - compatible = "renesas,ipmmu-r8a7796"; - reg = <0 0xfe6b0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 8>; - power-domains = <&sysc R8A7796_PD_A3VC>; - #iommu-cells = <1>; - }; - - ipmmu_vi0: iommu@febd0000 { - compatible = "renesas,ipmmu-r8a7796"; - reg = <0 0xfebd0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 9>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - avb: ethernet@e6800000 { - compatible = "renesas,etheravb-r8a7796", - "renesas,etheravb-rcar-gen3"; - reg = <0 0xe6800000 0 0x800>, <0 0xe6a00000 0 0x10000>; - interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 47 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 63 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15", - "ch16", "ch17", "ch18", "ch19", - "ch20", "ch21", "ch22", "ch23", - "ch24"; - clocks = <&cpg CPG_MOD 812>; - clock-names = "fck"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 812>; - phy-mode = "rgmii"; - rx-internal-delay-ps = <0>; - tx-internal-delay-ps = <0>; - iommus = <&ipmmu_ds0 16>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - can0: can@e6c30000 { - compatible = "renesas,can-r8a7796", - "renesas,rcar-gen3-can"; - reg = <0 0xe6c30000 0 0x1000>; - interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 916>, - <&cpg CPG_CORE R8A7796_CLK_CANFD>, - <&can_clk>; - clock-names = "clkp1", "clkp2", "can_clk"; - assigned-clocks = <&cpg CPG_CORE R8A7796_CLK_CANFD>; - assigned-clock-rates = <40000000>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 916>; - status = "disabled"; - }; - - can1: can@e6c38000 { - compatible = "renesas,can-r8a7796", - "renesas,rcar-gen3-can"; - reg = <0 0xe6c38000 0 0x1000>; - interrupts = <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 915>, - <&cpg CPG_CORE R8A7796_CLK_CANFD>, - <&can_clk>; - clock-names = "clkp1", "clkp2", "can_clk"; - assigned-clocks = <&cpg CPG_CORE R8A7796_CLK_CANFD>; - assigned-clock-rates = <40000000>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 915>; - status = "disabled"; - }; - - canfd: can@e66c0000 { - compatible = "renesas,r8a7796-canfd", - "renesas,rcar-gen3-canfd"; - reg = <0 0xe66c0000 0 0x8000>; - interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch_int", "g_int"; - clocks = <&cpg CPG_MOD 914>, - <&cpg CPG_CORE R8A7796_CLK_CANFD>, - <&can_clk>; - clock-names = "fck", "canfd", "can_clk"; - assigned-clocks = <&cpg CPG_CORE R8A7796_CLK_CANFD>; - assigned-clock-rates = <40000000>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 914>; - status = "disabled"; - - channel0 { - status = "disabled"; - }; - - channel1 { - status = "disabled"; - }; - }; - - pwm0: pwm@e6e30000 { - compatible = "renesas,pwm-r8a7796", "renesas,pwm-rcar"; - reg = <0 0xe6e30000 0 8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - resets = <&cpg 523>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - status = "disabled"; - }; - - pwm1: pwm@e6e31000 { - compatible = "renesas,pwm-r8a7796", "renesas,pwm-rcar"; - reg = <0 0xe6e31000 0 8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - resets = <&cpg 523>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - status = "disabled"; - }; - - pwm2: pwm@e6e32000 { - compatible = "renesas,pwm-r8a7796", "renesas,pwm-rcar"; - reg = <0 0xe6e32000 0 8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - resets = <&cpg 523>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - status = "disabled"; - }; - - pwm3: pwm@e6e33000 { - compatible = "renesas,pwm-r8a7796", "renesas,pwm-rcar"; - reg = <0 0xe6e33000 0 8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - resets = <&cpg 523>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - status = "disabled"; - }; - - pwm4: pwm@e6e34000 { - compatible = "renesas,pwm-r8a7796", "renesas,pwm-rcar"; - reg = <0 0xe6e34000 0 8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - resets = <&cpg 523>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - status = "disabled"; - }; - - pwm5: pwm@e6e35000 { - compatible = "renesas,pwm-r8a7796", "renesas,pwm-rcar"; - reg = <0 0xe6e35000 0 8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - resets = <&cpg 523>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - status = "disabled"; - }; - - pwm6: pwm@e6e36000 { - compatible = "renesas,pwm-r8a7796", "renesas,pwm-rcar"; - reg = <0 0xe6e36000 0 8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - resets = <&cpg 523>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - status = "disabled"; - }; - - scif0: serial@e6e60000 { - compatible = "renesas,scif-r8a7796", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6e60000 0 64>; - interrupts = <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 207>, - <&cpg CPG_CORE R8A7796_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x51>, <&dmac1 0x50>, - <&dmac2 0x51>, <&dmac2 0x50>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 207>; - status = "disabled"; - }; - - scif1: serial@e6e68000 { - compatible = "renesas,scif-r8a7796", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6e68000 0 64>; - interrupts = <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 206>, - <&cpg CPG_CORE R8A7796_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x53>, <&dmac1 0x52>, - <&dmac2 0x53>, <&dmac2 0x52>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 206>; - status = "disabled"; - }; - - scif2: serial@e6e88000 { - compatible = "renesas,scif-r8a7796", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6e88000 0 64>; - interrupts = <GIC_SPI 164 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 310>, - <&cpg CPG_CORE R8A7796_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x13>, <&dmac1 0x12>, - <&dmac2 0x13>, <&dmac2 0x12>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 310>; - status = "disabled"; - }; - - scif3: serial@e6c50000 { - compatible = "renesas,scif-r8a7796", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6c50000 0 64>; - interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 204>, - <&cpg CPG_CORE R8A7796_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x57>, <&dmac0 0x56>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 204>; - status = "disabled"; - }; - - scif4: serial@e6c40000 { - compatible = "renesas,scif-r8a7796", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6c40000 0 64>; - interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 203>, - <&cpg CPG_CORE R8A7796_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x59>, <&dmac0 0x58>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 203>; - status = "disabled"; - }; - - scif5: serial@e6f30000 { - compatible = "renesas,scif-r8a7796", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6f30000 0 64>; - interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 202>, - <&cpg CPG_CORE R8A7796_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x5b>, <&dmac1 0x5a>, - <&dmac2 0x5b>, <&dmac2 0x5a>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 202>; - status = "disabled"; - }; - - tpu: pwm@e6e80000 { - compatible = "renesas,tpu-r8a7796", "renesas,tpu"; - reg = <0 0xe6e80000 0 0x148>; - interrupts = <GIC_SPI 135 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 304>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 304>; - #pwm-cells = <3>; - status = "disabled"; - }; - - msiof0: spi@e6e90000 { - compatible = "renesas,msiof-r8a7796", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6e90000 0 0x0064>; - interrupts = <GIC_SPI 156 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 211>; - dmas = <&dmac1 0x41>, <&dmac1 0x40>, - <&dmac2 0x41>, <&dmac2 0x40>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 211>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof1: spi@e6ea0000 { - compatible = "renesas,msiof-r8a7796", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6ea0000 0 0x0064>; - interrupts = <GIC_SPI 157 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 210>; - dmas = <&dmac1 0x43>, <&dmac1 0x42>, - <&dmac2 0x43>, <&dmac2 0x42>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 210>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof2: spi@e6c00000 { - compatible = "renesas,msiof-r8a7796", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6c00000 0 0x0064>; - interrupts = <GIC_SPI 158 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 209>; - dmas = <&dmac0 0x45>, <&dmac0 0x44>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 209>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof3: spi@e6c10000 { - compatible = "renesas,msiof-r8a7796", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6c10000 0 0x0064>; - interrupts = <GIC_SPI 159 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 208>; - dmas = <&dmac0 0x47>, <&dmac0 0x46>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 208>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - vin0: video@e6ef0000 { - compatible = "renesas,vin-r8a7796"; - reg = <0 0xe6ef0000 0 0x1000>; - interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 811>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 811>; - renesas,id = <0>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin0csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin0>; - }; - vin0csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin0>; - }; - }; - }; - }; - - vin1: video@e6ef1000 { - compatible = "renesas,vin-r8a7796"; - reg = <0 0xe6ef1000 0 0x1000>; - interrupts = <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 810>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 810>; - renesas,id = <1>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin1csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin1>; - }; - vin1csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin1>; - }; - }; - }; - }; - - vin2: video@e6ef2000 { - compatible = "renesas,vin-r8a7796"; - reg = <0 0xe6ef2000 0 0x1000>; - interrupts = <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 809>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 809>; - renesas,id = <2>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin2csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin2>; - }; - vin2csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin2>; - }; - }; - }; - }; - - vin3: video@e6ef3000 { - compatible = "renesas,vin-r8a7796"; - reg = <0 0xe6ef3000 0 0x1000>; - interrupts = <GIC_SPI 191 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 808>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 808>; - renesas,id = <3>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin3csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin3>; - }; - vin3csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin3>; - }; - }; - }; - }; - - vin4: video@e6ef4000 { - compatible = "renesas,vin-r8a7796"; - reg = <0 0xe6ef4000 0 0x1000>; - interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 807>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 807>; - renesas,id = <4>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin4csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin4>; - }; - vin4csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin4>; - }; - }; - }; - }; - - vin5: video@e6ef5000 { - compatible = "renesas,vin-r8a7796"; - reg = <0 0xe6ef5000 0 0x1000>; - interrupts = <GIC_SPI 175 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 806>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 806>; - renesas,id = <5>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin5csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin5>; - }; - vin5csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin5>; - }; - }; - }; - }; - - vin6: video@e6ef6000 { - compatible = "renesas,vin-r8a7796"; - reg = <0 0xe6ef6000 0 0x1000>; - interrupts = <GIC_SPI 176 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 805>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 805>; - renesas,id = <6>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin6csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin6>; - }; - vin6csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin6>; - }; - }; - }; - }; - - vin7: video@e6ef7000 { - compatible = "renesas,vin-r8a7796"; - reg = <0 0xe6ef7000 0 0x1000>; - interrupts = <GIC_SPI 171 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 804>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 804>; - renesas,id = <7>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin7csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin7>; - }; - vin7csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin7>; - }; - }; - }; - }; - - drif00: rif@e6f40000 { - compatible = "renesas,r8a7796-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6f40000 0 0x64>; - interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 515>; - clock-names = "fck"; - dmas = <&dmac1 0x20>, <&dmac2 0x20>; - dma-names = "rx", "rx"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 515>; - renesas,bonding = <&drif01>; - status = "disabled"; - }; - - drif01: rif@e6f50000 { - compatible = "renesas,r8a7796-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6f50000 0 0x64>; - interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 514>; - clock-names = "fck"; - dmas = <&dmac1 0x22>, <&dmac2 0x22>; - dma-names = "rx", "rx"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 514>; - renesas,bonding = <&drif00>; - status = "disabled"; - }; - - drif10: rif@e6f60000 { - compatible = "renesas,r8a7796-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6f60000 0 0x64>; - interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 513>; - clock-names = "fck"; - dmas = <&dmac1 0x24>, <&dmac2 0x24>; - dma-names = "rx", "rx"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 513>; - renesas,bonding = <&drif11>; - status = "disabled"; - }; - - drif11: rif@e6f70000 { - compatible = "renesas,r8a7796-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6f70000 0 0x64>; - interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 512>; - clock-names = "fck"; - dmas = <&dmac1 0x26>, <&dmac2 0x26>; - dma-names = "rx", "rx"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 512>; - renesas,bonding = <&drif10>; - status = "disabled"; - }; - - drif20: rif@e6f80000 { - compatible = "renesas,r8a7796-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6f80000 0 0x64>; - interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 511>; - clock-names = "fck"; - dmas = <&dmac1 0x28>, <&dmac2 0x28>; - dma-names = "rx", "rx"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 511>; - renesas,bonding = <&drif21>; - status = "disabled"; - }; - - drif21: rif@e6f90000 { - compatible = "renesas,r8a7796-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6f90000 0 0x64>; - interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 510>; - clock-names = "fck"; - dmas = <&dmac1 0x2a>, <&dmac2 0x2a>; - dma-names = "rx", "rx"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 510>; - renesas,bonding = <&drif20>; - status = "disabled"; - }; - - drif30: rif@e6fa0000 { - compatible = "renesas,r8a7796-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6fa0000 0 0x64>; - interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 509>; - clock-names = "fck"; - dmas = <&dmac1 0x2c>, <&dmac2 0x2c>; - dma-names = "rx", "rx"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 509>; - renesas,bonding = <&drif31>; - status = "disabled"; - }; - - drif31: rif@e6fb0000 { - compatible = "renesas,r8a7796-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6fb0000 0 0x64>; - interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 508>; - clock-names = "fck"; - dmas = <&dmac1 0x2e>, <&dmac2 0x2e>; - dma-names = "rx", "rx"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 508>; - renesas,bonding = <&drif30>; - status = "disabled"; - }; - - rcar_sound: sound@ec500000 { - /* - * #sound-dai-cells is required if simple-card - * - * Single DAI : #sound-dai-cells = <0>; <&rcar_sound>; - * Multi DAI : #sound-dai-cells = <1>; <&rcar_sound N>; - */ - /* - * #clock-cells is required for audio_clkout0/1/2/3 - * - * clkout : #clock-cells = <0>; <&rcar_sound>; - * clkout0/1/2/3: #clock-cells = <1>; <&rcar_sound N>; - */ - compatible = "renesas,rcar_sound-r8a7796", "renesas,rcar_sound-gen3"; - reg = <0 0xec500000 0 0x1000>, /* SCU */ - <0 0xec5a0000 0 0x100>, /* ADG */ - <0 0xec540000 0 0x1000>, /* SSIU */ - <0 0xec541000 0 0x280>, /* SSI */ - <0 0xec760000 0 0x200>; /* Audio DMAC peri peri*/ - reg-names = "scu", "adg", "ssiu", "ssi", "audmapp"; - - clocks = <&cpg CPG_MOD 1005>, - <&cpg CPG_MOD 1006>, <&cpg CPG_MOD 1007>, - <&cpg CPG_MOD 1008>, <&cpg CPG_MOD 1009>, - <&cpg CPG_MOD 1010>, <&cpg CPG_MOD 1011>, - <&cpg CPG_MOD 1012>, <&cpg CPG_MOD 1013>, - <&cpg CPG_MOD 1014>, <&cpg CPG_MOD 1015>, - <&cpg CPG_MOD 1022>, <&cpg CPG_MOD 1023>, - <&cpg CPG_MOD 1024>, <&cpg CPG_MOD 1025>, - <&cpg CPG_MOD 1026>, <&cpg CPG_MOD 1027>, - <&cpg CPG_MOD 1028>, <&cpg CPG_MOD 1029>, - <&cpg CPG_MOD 1030>, <&cpg CPG_MOD 1031>, - <&cpg CPG_MOD 1020>, <&cpg CPG_MOD 1021>, - <&cpg CPG_MOD 1020>, <&cpg CPG_MOD 1021>, - <&cpg CPG_MOD 1019>, <&cpg CPG_MOD 1018>, - <&audio_clk_a>, <&audio_clk_b>, - <&audio_clk_c>, - <&cpg CPG_CORE R8A7796_CLK_S0D4>; - clock-names = "ssi-all", - "ssi.9", "ssi.8", "ssi.7", "ssi.6", - "ssi.5", "ssi.4", "ssi.3", "ssi.2", - "ssi.1", "ssi.0", - "src.9", "src.8", "src.7", "src.6", - "src.5", "src.4", "src.3", "src.2", - "src.1", "src.0", - "mix.1", "mix.0", - "ctu.1", "ctu.0", - "dvc.0", "dvc.1", - "clk_a", "clk_b", "clk_c", "clk_i"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 1005>, - <&cpg 1006>, <&cpg 1007>, - <&cpg 1008>, <&cpg 1009>, - <&cpg 1010>, <&cpg 1011>, - <&cpg 1012>, <&cpg 1013>, - <&cpg 1014>, <&cpg 1015>; - reset-names = "ssi-all", - "ssi.9", "ssi.8", "ssi.7", "ssi.6", - "ssi.5", "ssi.4", "ssi.3", "ssi.2", - "ssi.1", "ssi.0"; - status = "disabled"; - - rcar_sound,ctu { - ctu00: ctu-0 { }; - ctu01: ctu-1 { }; - ctu02: ctu-2 { }; - ctu03: ctu-3 { }; - ctu10: ctu-4 { }; - ctu11: ctu-5 { }; - ctu12: ctu-6 { }; - ctu13: ctu-7 { }; - }; - - rcar_sound,dvc { - dvc0: dvc-0 { - dmas = <&audma1 0xbc>; - dma-names = "tx"; - }; - dvc1: dvc-1 { - dmas = <&audma1 0xbe>; - dma-names = "tx"; - }; - }; - - rcar_sound,mix { - mix0: mix-0 { }; - mix1: mix-1 { }; - }; - - rcar_sound,src { - src0: src-0 { - interrupts = <GIC_SPI 352 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x85>, <&audma1 0x9a>; - dma-names = "rx", "tx"; - }; - src1: src-1 { - interrupts = <GIC_SPI 353 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x87>, <&audma1 0x9c>; - dma-names = "rx", "tx"; - }; - src2: src-2 { - interrupts = <GIC_SPI 354 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x89>, <&audma1 0x9e>; - dma-names = "rx", "tx"; - }; - src3: src-3 { - interrupts = <GIC_SPI 355 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x8b>, <&audma1 0xa0>; - dma-names = "rx", "tx"; - }; - src4: src-4 { - interrupts = <GIC_SPI 356 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x8d>, <&audma1 0xb0>; - dma-names = "rx", "tx"; - }; - src5: src-5 { - interrupts = <GIC_SPI 357 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x8f>, <&audma1 0xb2>; - dma-names = "rx", "tx"; - }; - src6: src-6 { - interrupts = <GIC_SPI 358 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x91>, <&audma1 0xb4>; - dma-names = "rx", "tx"; - }; - src7: src-7 { - interrupts = <GIC_SPI 359 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x93>, <&audma1 0xb6>; - dma-names = "rx", "tx"; - }; - src8: src-8 { - interrupts = <GIC_SPI 360 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x95>, <&audma1 0xb8>; - dma-names = "rx", "tx"; - }; - src9: src-9 { - interrupts = <GIC_SPI 361 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x97>, <&audma1 0xba>; - dma-names = "rx", "tx"; - }; - }; - - rcar_sound,ssi { - ssi0: ssi-0 { - interrupts = <GIC_SPI 370 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x01>, <&audma1 0x02>; - dma-names = "rx", "tx"; - }; - ssi1: ssi-1 { - interrupts = <GIC_SPI 371 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x03>, <&audma1 0x04>; - dma-names = "rx", "tx"; - }; - ssi2: ssi-2 { - interrupts = <GIC_SPI 372 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x05>, <&audma1 0x06>; - dma-names = "rx", "tx"; - }; - ssi3: ssi-3 { - interrupts = <GIC_SPI 373 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x07>, <&audma1 0x08>; - dma-names = "rx", "tx"; - }; - ssi4: ssi-4 { - interrupts = <GIC_SPI 374 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x09>, <&audma1 0x0a>; - dma-names = "rx", "tx"; - }; - ssi5: ssi-5 { - interrupts = <GIC_SPI 375 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x0b>, <&audma1 0x0c>; - dma-names = "rx", "tx"; - }; - ssi6: ssi-6 { - interrupts = <GIC_SPI 376 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x0d>, <&audma1 0x0e>; - dma-names = "rx", "tx"; - }; - ssi7: ssi-7 { - interrupts = <GIC_SPI 377 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x0f>, <&audma1 0x10>; - dma-names = "rx", "tx"; - }; - ssi8: ssi-8 { - interrupts = <GIC_SPI 378 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x11>, <&audma1 0x12>; - dma-names = "rx", "tx"; - }; - ssi9: ssi-9 { - interrupts = <GIC_SPI 379 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x13>, <&audma1 0x14>; - dma-names = "rx", "tx"; - }; - }; - - rcar_sound,ssiu { - ssiu00: ssiu-0 { - dmas = <&audma0 0x15>, <&audma1 0x16>; - dma-names = "rx", "tx"; - }; - ssiu01: ssiu-1 { - dmas = <&audma0 0x35>, <&audma1 0x36>; - dma-names = "rx", "tx"; - }; - ssiu02: ssiu-2 { - dmas = <&audma0 0x37>, <&audma1 0x38>; - dma-names = "rx", "tx"; - }; - ssiu03: ssiu-3 { - dmas = <&audma0 0x47>, <&audma1 0x48>; - dma-names = "rx", "tx"; - }; - ssiu04: ssiu-4 { - dmas = <&audma0 0x3F>, <&audma1 0x40>; - dma-names = "rx", "tx"; - }; - ssiu05: ssiu-5 { - dmas = <&audma0 0x43>, <&audma1 0x44>; - dma-names = "rx", "tx"; - }; - ssiu06: ssiu-6 { - dmas = <&audma0 0x4F>, <&audma1 0x50>; - dma-names = "rx", "tx"; - }; - ssiu07: ssiu-7 { - dmas = <&audma0 0x53>, <&audma1 0x54>; - dma-names = "rx", "tx"; - }; - ssiu10: ssiu-8 { - dmas = <&audma0 0x49>, <&audma1 0x4a>; - dma-names = "rx", "tx"; - }; - ssiu11: ssiu-9 { - dmas = <&audma0 0x4B>, <&audma1 0x4C>; - dma-names = "rx", "tx"; - }; - ssiu12: ssiu-10 { - dmas = <&audma0 0x57>, <&audma1 0x58>; - dma-names = "rx", "tx"; - }; - ssiu13: ssiu-11 { - dmas = <&audma0 0x59>, <&audma1 0x5A>; - dma-names = "rx", "tx"; - }; - ssiu14: ssiu-12 { - dmas = <&audma0 0x5F>, <&audma1 0x60>; - dma-names = "rx", "tx"; - }; - ssiu15: ssiu-13 { - dmas = <&audma0 0xC3>, <&audma1 0xC4>; - dma-names = "rx", "tx"; - }; - ssiu16: ssiu-14 { - dmas = <&audma0 0xC7>, <&audma1 0xC8>; - dma-names = "rx", "tx"; - }; - ssiu17: ssiu-15 { - dmas = <&audma0 0xCB>, <&audma1 0xCC>; - dma-names = "rx", "tx"; - }; - ssiu20: ssiu-16 { - dmas = <&audma0 0x63>, <&audma1 0x64>; - dma-names = "rx", "tx"; - }; - ssiu21: ssiu-17 { - dmas = <&audma0 0x67>, <&audma1 0x68>; - dma-names = "rx", "tx"; - }; - ssiu22: ssiu-18 { - dmas = <&audma0 0x6B>, <&audma1 0x6C>; - dma-names = "rx", "tx"; - }; - ssiu23: ssiu-19 { - dmas = <&audma0 0x6D>, <&audma1 0x6E>; - dma-names = "rx", "tx"; - }; - ssiu24: ssiu-20 { - dmas = <&audma0 0xCF>, <&audma1 0xCE>; - dma-names = "rx", "tx"; - }; - ssiu25: ssiu-21 { - dmas = <&audma0 0xEB>, <&audma1 0xEC>; - dma-names = "rx", "tx"; - }; - ssiu26: ssiu-22 { - dmas = <&audma0 0xED>, <&audma1 0xEE>; - dma-names = "rx", "tx"; - }; - ssiu27: ssiu-23 { - dmas = <&audma0 0xEF>, <&audma1 0xF0>; - dma-names = "rx", "tx"; - }; - ssiu30: ssiu-24 { - dmas = <&audma0 0x6f>, <&audma1 0x70>; - dma-names = "rx", "tx"; - }; - ssiu31: ssiu-25 { - dmas = <&audma0 0x21>, <&audma1 0x22>; - dma-names = "rx", "tx"; - }; - ssiu32: ssiu-26 { - dmas = <&audma0 0x23>, <&audma1 0x24>; - dma-names = "rx", "tx"; - }; - ssiu33: ssiu-27 { - dmas = <&audma0 0x25>, <&audma1 0x26>; - dma-names = "rx", "tx"; - }; - ssiu34: ssiu-28 { - dmas = <&audma0 0x27>, <&audma1 0x28>; - dma-names = "rx", "tx"; - }; - ssiu35: ssiu-29 { - dmas = <&audma0 0x29>, <&audma1 0x2A>; - dma-names = "rx", "tx"; - }; - ssiu36: ssiu-30 { - dmas = <&audma0 0x2B>, <&audma1 0x2C>; - dma-names = "rx", "tx"; - }; - ssiu37: ssiu-31 { - dmas = <&audma0 0x2D>, <&audma1 0x2E>; - dma-names = "rx", "tx"; - }; - ssiu40: ssiu-32 { - dmas = <&audma0 0x71>, <&audma1 0x72>; - dma-names = "rx", "tx"; - }; - ssiu41: ssiu-33 { - dmas = <&audma0 0x17>, <&audma1 0x18>; - dma-names = "rx", "tx"; - }; - ssiu42: ssiu-34 { - dmas = <&audma0 0x19>, <&audma1 0x1A>; - dma-names = "rx", "tx"; - }; - ssiu43: ssiu-35 { - dmas = <&audma0 0x1B>, <&audma1 0x1C>; - dma-names = "rx", "tx"; - }; - ssiu44: ssiu-36 { - dmas = <&audma0 0x1D>, <&audma1 0x1E>; - dma-names = "rx", "tx"; - }; - ssiu45: ssiu-37 { - dmas = <&audma0 0x1F>, <&audma1 0x20>; - dma-names = "rx", "tx"; - }; - ssiu46: ssiu-38 { - dmas = <&audma0 0x31>, <&audma1 0x32>; - dma-names = "rx", "tx"; - }; - ssiu47: ssiu-39 { - dmas = <&audma0 0x33>, <&audma1 0x34>; - dma-names = "rx", "tx"; - }; - ssiu50: ssiu-40 { - dmas = <&audma0 0x73>, <&audma1 0x74>; - dma-names = "rx", "tx"; - }; - ssiu60: ssiu-41 { - dmas = <&audma0 0x75>, <&audma1 0x76>; - dma-names = "rx", "tx"; - }; - ssiu70: ssiu-42 { - dmas = <&audma0 0x79>, <&audma1 0x7a>; - dma-names = "rx", "tx"; - }; - ssiu80: ssiu-43 { - dmas = <&audma0 0x7b>, <&audma1 0x7c>; - dma-names = "rx", "tx"; - }; - ssiu90: ssiu-44 { - dmas = <&audma0 0x7d>, <&audma1 0x7e>; - dma-names = "rx", "tx"; - }; - ssiu91: ssiu-45 { - dmas = <&audma0 0x7F>, <&audma1 0x80>; - dma-names = "rx", "tx"; - }; - ssiu92: ssiu-46 { - dmas = <&audma0 0x81>, <&audma1 0x82>; - dma-names = "rx", "tx"; - }; - ssiu93: ssiu-47 { - dmas = <&audma0 0x83>, <&audma1 0x84>; - dma-names = "rx", "tx"; - }; - ssiu94: ssiu-48 { - dmas = <&audma0 0xA3>, <&audma1 0xA4>; - dma-names = "rx", "tx"; - }; - ssiu95: ssiu-49 { - dmas = <&audma0 0xA5>, <&audma1 0xA6>; - dma-names = "rx", "tx"; - }; - ssiu96: ssiu-50 { - dmas = <&audma0 0xA7>, <&audma1 0xA8>; - dma-names = "rx", "tx"; - }; - ssiu97: ssiu-51 { - dmas = <&audma0 0xA9>, <&audma1 0xAA>; - dma-names = "rx", "tx"; - }; - }; - }; - - mlp: mlp@ec520000 { - compatible = "renesas,r8a7796-mlp", - "renesas,rcar-gen3-mlp"; - reg = <0 0xec520000 0 0x800>; - interrupts = <GIC_SPI 384 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 385 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 802>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 802>; - status = "disabled"; - }; - - audma0: dma-controller@ec700000 { - compatible = "renesas,dmac-r8a7796", - "renesas,rcar-dmac"; - reg = <0 0xec700000 0 0x10000>; - interrupts = <GIC_SPI 350 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 320 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 321 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 322 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 323 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 324 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 325 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 326 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 327 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 328 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 329 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 330 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 331 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 332 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 333 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 334 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 335 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 502>; - clock-names = "fck"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 502>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_mp 0>, <&ipmmu_mp 1>, - <&ipmmu_mp 2>, <&ipmmu_mp 3>, - <&ipmmu_mp 4>, <&ipmmu_mp 5>, - <&ipmmu_mp 6>, <&ipmmu_mp 7>, - <&ipmmu_mp 8>, <&ipmmu_mp 9>, - <&ipmmu_mp 10>, <&ipmmu_mp 11>, - <&ipmmu_mp 12>, <&ipmmu_mp 13>, - <&ipmmu_mp 14>, <&ipmmu_mp 15>; - }; - - audma1: dma-controller@ec720000 { - compatible = "renesas,dmac-r8a7796", - "renesas,rcar-dmac"; - reg = <0 0xec720000 0 0x10000>; - interrupts = <GIC_SPI 351 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 336 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 337 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 338 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 339 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 340 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 341 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 342 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 343 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 344 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 345 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 346 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 347 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 348 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 349 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 382 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 383 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 501>; - clock-names = "fck"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 501>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_mp 16>, <&ipmmu_mp 17>, - <&ipmmu_mp 18>, <&ipmmu_mp 19>, - <&ipmmu_mp 20>, <&ipmmu_mp 21>, - <&ipmmu_mp 22>, <&ipmmu_mp 23>, - <&ipmmu_mp 24>, <&ipmmu_mp 25>, - <&ipmmu_mp 26>, <&ipmmu_mp 27>, - <&ipmmu_mp 28>, <&ipmmu_mp 29>, - <&ipmmu_mp 30>, <&ipmmu_mp 31>; - }; - - xhci0: usb@ee000000 { - compatible = "renesas,xhci-r8a7796", - "renesas,rcar-gen3-xhci"; - reg = <0 0xee000000 0 0xc00>; - interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 328>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 328>; - status = "disabled"; - }; - - usb3_peri0: usb@ee020000 { - compatible = "renesas,r8a7796-usb3-peri", - "renesas,rcar-gen3-usb3-peri"; - reg = <0 0xee020000 0 0x400>; - interrupts = <GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 328>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 328>; - status = "disabled"; - }; - - ohci0: usb@ee080000 { - compatible = "generic-ohci"; - reg = <0 0xee080000 0 0x100>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>; - phys = <&usb2_phy0 1>; - phy-names = "usb"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 703>, <&cpg 704>; - status = "disabled"; - }; - - ohci1: usb@ee0a0000 { - compatible = "generic-ohci"; - reg = <0 0xee0a0000 0 0x100>; - interrupts = <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 702>; - phys = <&usb2_phy1 1>; - phy-names = "usb"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 702>; - status = "disabled"; - }; - - ehci0: usb@ee080100 { - compatible = "generic-ehci"; - reg = <0 0xee080100 0 0x100>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>; - phys = <&usb2_phy0 2>; - phy-names = "usb"; - companion = <&ohci0>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 703>, <&cpg 704>; - status = "disabled"; - }; - - ehci1: usb@ee0a0100 { - compatible = "generic-ehci"; - reg = <0 0xee0a0100 0 0x100>; - interrupts = <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 702>; - phys = <&usb2_phy1 2>; - phy-names = "usb"; - companion = <&ohci1>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 702>; - status = "disabled"; - }; - - usb2_phy0: usb-phy@ee080200 { - compatible = "renesas,usb2-phy-r8a7796", - "renesas,rcar-gen3-usb2-phy"; - reg = <0 0xee080200 0 0x700>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 703>, <&cpg 704>; - #phy-cells = <1>; - status = "disabled"; - }; - - usb2_phy1: usb-phy@ee0a0200 { - compatible = "renesas,usb2-phy-r8a7796", - "renesas,rcar-gen3-usb2-phy"; - reg = <0 0xee0a0200 0 0x700>; - clocks = <&cpg CPG_MOD 702>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 702>; - #phy-cells = <1>; - status = "disabled"; - }; - - sdhi0: mmc@ee100000 { - compatible = "renesas,sdhi-r8a7796", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee100000 0 0x2000>; - interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 314>, <&cpg CPG_CORE R8A7796_CLK_SD0H>; - clock-names = "core", "clkh"; - max-frequency = <200000000>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 314>; - iommus = <&ipmmu_ds1 32>; - status = "disabled"; - }; - - sdhi1: mmc@ee120000 { - compatible = "renesas,sdhi-r8a7796", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee120000 0 0x2000>; - interrupts = <GIC_SPI 166 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 313>, <&cpg CPG_CORE R8A7796_CLK_SD1H>; - clock-names = "core", "clkh"; - max-frequency = <200000000>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 313>; - iommus = <&ipmmu_ds1 33>; - status = "disabled"; - }; - - sdhi2: mmc@ee140000 { - compatible = "renesas,sdhi-r8a7796", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee140000 0 0x2000>; - interrupts = <GIC_SPI 167 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 312>, <&cpg CPG_CORE R8A7796_CLK_SD2H>; - clock-names = "core", "clkh"; - max-frequency = <200000000>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 312>; - iommus = <&ipmmu_ds1 34>; - status = "disabled"; - }; - - sdhi3: mmc@ee160000 { - compatible = "renesas,sdhi-r8a7796", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee160000 0 0x2000>; - interrupts = <GIC_SPI 168 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 311>, <&cpg CPG_CORE R8A7796_CLK_SD3H>; - clock-names = "core", "clkh"; - max-frequency = <200000000>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 311>; - iommus = <&ipmmu_ds1 35>; - status = "disabled"; - }; - - rpc: spi@ee200000 { - compatible = "renesas,r8a7796-rpc-if", - "renesas,rcar-gen3-rpc-if"; - reg = <0 0xee200000 0 0x200>, - <0 0x08000000 0 0x04000000>, - <0 0xee208000 0 0x100>; - reg-names = "regs", "dirmap", "wbuf"; - interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 917>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 917>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - gic: interrupt-controller@f1010000 { - compatible = "arm,gic-400"; - #interrupt-cells = <3>; - #address-cells = <0>; - interrupt-controller; - reg = <0x0 0xf1010000 0 0x1000>, - <0x0 0xf1020000 0 0x20000>, - <0x0 0xf1040000 0 0x20000>, - <0x0 0xf1060000 0 0x20000>; - interrupts = <GIC_PPI 9 - (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_HIGH)>; - clocks = <&cpg CPG_MOD 408>; - clock-names = "clk"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 408>; - }; - - pciec0: pcie@fe000000 { - compatible = "renesas,pcie-r8a7796", - "renesas,pcie-rcar-gen3"; - reg = <0 0xfe000000 0 0x80000>; - #address-cells = <3>; - #size-cells = <2>; - bus-range = <0x00 0xff>; - device_type = "pci"; - ranges = <0x01000000 0 0x00000000 0 0xfe100000 0 0x00100000>, - <0x02000000 0 0xfe200000 0 0xfe200000 0 0x00200000>, - <0x02000000 0 0x30000000 0 0x30000000 0 0x08000000>, - <0x42000000 0 0x38000000 0 0x38000000 0 0x08000000>; - /* Map all possible DDR/IOMMU as inbound ranges */ - dma-ranges = <0x42000000 0 0x00000000 0 0x00000000 1 0x00000000>; - interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>; - #interrupt-cells = <1>; - interrupt-map-mask = <0 0 0 0>; - interrupt-map = <0 0 0 0 &gic GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 319>, <&pcie_bus_clk>; - clock-names = "pcie", "pcie_bus"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 319>; - iommu-map = <0 &ipmmu_hc 0 1>; - iommu-map-mask = <0>; - status = "disabled"; - }; - - pciec1: pcie@ee800000 { - compatible = "renesas,pcie-r8a7796", - "renesas,pcie-rcar-gen3"; - reg = <0 0xee800000 0 0x80000>; - #address-cells = <3>; - #size-cells = <2>; - bus-range = <0x00 0xff>; - device_type = "pci"; - ranges = <0x01000000 0 0x00000000 0 0xee900000 0 0x00100000>, - <0x02000000 0 0xeea00000 0 0xeea00000 0 0x00200000>, - <0x02000000 0 0xc0000000 0 0xc0000000 0 0x08000000>, - <0x42000000 0 0xc8000000 0 0xc8000000 0 0x08000000>; - /* Map all possible DDR/IOMMU as inbound ranges */ - dma-ranges = <0x42000000 0 0x00000000 0 0x00000000 1 0x00000000>; - interrupts = <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 149 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 150 IRQ_TYPE_LEVEL_HIGH>; - #interrupt-cells = <1>; - interrupt-map-mask = <0 0 0 0>; - interrupt-map = <0 0 0 0 &gic GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 318>, <&pcie_bus_clk>; - clock-names = "pcie", "pcie_bus"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 318>; - iommu-map = <0 &ipmmu_hc 1 1>; - iommu-map-mask = <0>; - status = "disabled"; - }; - - imr-lx4@fe860000 { - compatible = "renesas,r8a7796-imr-lx4", - "renesas,imr-lx4"; - reg = <0 0xfe860000 0 0x2000>; - interrupts = <GIC_SPI 192 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 823>; - power-domains = <&sysc R8A7796_PD_A3VC>; - resets = <&cpg 823>; - }; - - imr-lx4@fe870000 { - compatible = "renesas,r8a7796-imr-lx4", - "renesas,imr-lx4"; - reg = <0 0xfe870000 0 0x2000>; - interrupts = <GIC_SPI 193 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 822>; - power-domains = <&sysc R8A7796_PD_A3VC>; - resets = <&cpg 822>; - }; - - fdp1@fe940000 { - compatible = "renesas,fdp1"; - reg = <0 0xfe940000 0 0x2400>; - interrupts = <GIC_SPI 262 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 119>; - power-domains = <&sysc R8A7796_PD_A3VC>; - resets = <&cpg 119>; - renesas,fcp = <&fcpf0>; - }; - - fcpf0: fcp@fe950000 { - compatible = "renesas,fcpf"; - reg = <0 0xfe950000 0 0x200>; - clocks = <&cpg CPG_MOD 615>; - power-domains = <&sysc R8A7796_PD_A3VC>; - resets = <&cpg 615>; - }; - - fcpvb0: fcp@fe96f000 { - compatible = "renesas,fcpv"; - reg = <0 0xfe96f000 0 0x200>; - clocks = <&cpg CPG_MOD 607>; - power-domains = <&sysc R8A7796_PD_A3VC>; - resets = <&cpg 607>; - }; - - fcpvi0: fcp@fe9af000 { - compatible = "renesas,fcpv"; - reg = <0 0xfe9af000 0 0x200>; - clocks = <&cpg CPG_MOD 611>; - power-domains = <&sysc R8A7796_PD_A3VC>; - resets = <&cpg 611>; - iommus = <&ipmmu_vc0 19>; - }; - - fcpvd0: fcp@fea27000 { - compatible = "renesas,fcpv"; - reg = <0 0xfea27000 0 0x200>; - clocks = <&cpg CPG_MOD 603>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 603>; - iommus = <&ipmmu_vi0 8>; - }; - - fcpvd1: fcp@fea2f000 { - compatible = "renesas,fcpv"; - reg = <0 0xfea2f000 0 0x200>; - clocks = <&cpg CPG_MOD 602>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 602>; - iommus = <&ipmmu_vi0 9>; - }; - - fcpvd2: fcp@fea37000 { - compatible = "renesas,fcpv"; - reg = <0 0xfea37000 0 0x200>; - clocks = <&cpg CPG_MOD 601>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 601>; - iommus = <&ipmmu_vi0 10>; - }; - - vspb: vsp@fe960000 { - compatible = "renesas,vsp2"; - reg = <0 0xfe960000 0 0x8000>; - interrupts = <GIC_SPI 266 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 626>; - power-domains = <&sysc R8A7796_PD_A3VC>; - resets = <&cpg 626>; - - renesas,fcp = <&fcpvb0>; - }; - - vspd0: vsp@fea20000 { - compatible = "renesas,vsp2"; - reg = <0 0xfea20000 0 0x5000>; - interrupts = <GIC_SPI 466 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 623>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 623>; - - renesas,fcp = <&fcpvd0>; - }; - - vspd1: vsp@fea28000 { - compatible = "renesas,vsp2"; - reg = <0 0xfea28000 0 0x5000>; - interrupts = <GIC_SPI 467 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 622>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 622>; - - renesas,fcp = <&fcpvd1>; - }; - - vspd2: vsp@fea30000 { - compatible = "renesas,vsp2"; - reg = <0 0xfea30000 0 0x5000>; - interrupts = <GIC_SPI 468 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 621>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 621>; - - renesas,fcp = <&fcpvd2>; - }; - - vspi0: vsp@fe9a0000 { - compatible = "renesas,vsp2"; - reg = <0 0xfe9a0000 0 0x8000>; - interrupts = <GIC_SPI 444 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 631>; - power-domains = <&sysc R8A7796_PD_A3VC>; - resets = <&cpg 631>; - - renesas,fcp = <&fcpvi0>; - }; - - cmm0: cmm@fea40000 { - compatible = "renesas,r8a7796-cmm", - "renesas,rcar-gen3-cmm"; - reg = <0 0xfea40000 0 0x1000>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - clocks = <&cpg CPG_MOD 711>; - resets = <&cpg 711>; - }; - - cmm1: cmm@fea50000 { - compatible = "renesas,r8a7796-cmm", - "renesas,rcar-gen3-cmm"; - reg = <0 0xfea50000 0 0x1000>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - clocks = <&cpg CPG_MOD 710>; - resets = <&cpg 710>; - }; - - cmm2: cmm@fea60000 { - compatible = "renesas,r8a7796-cmm", - "renesas,rcar-gen3-cmm"; - reg = <0 0xfea60000 0 0x1000>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - clocks = <&cpg CPG_MOD 709>; - resets = <&cpg 709>; - }; - - csi20: csi2@fea80000 { - compatible = "renesas,r8a7796-csi2"; - reg = <0 0xfea80000 0 0x10000>; - interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 714>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 714>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - csi20vin0: endpoint@0 { - reg = <0>; - remote-endpoint = <&vin0csi20>; - }; - csi20vin1: endpoint@1 { - reg = <1>; - remote-endpoint = <&vin1csi20>; - }; - csi20vin2: endpoint@2 { - reg = <2>; - remote-endpoint = <&vin2csi20>; - }; - csi20vin3: endpoint@3 { - reg = <3>; - remote-endpoint = <&vin3csi20>; - }; - csi20vin4: endpoint@4 { - reg = <4>; - remote-endpoint = <&vin4csi20>; - }; - csi20vin5: endpoint@5 { - reg = <5>; - remote-endpoint = <&vin5csi20>; - }; - csi20vin6: endpoint@6 { - reg = <6>; - remote-endpoint = <&vin6csi20>; - }; - csi20vin7: endpoint@7 { - reg = <7>; - remote-endpoint = <&vin7csi20>; - }; - }; - }; - }; - - csi40: csi2@feaa0000 { - compatible = "renesas,r8a7796-csi2"; - reg = <0 0xfeaa0000 0 0x10000>; - interrupts = <GIC_SPI 246 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 716>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 716>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - csi40vin0: endpoint@0 { - reg = <0>; - remote-endpoint = <&vin0csi40>; - }; - csi40vin1: endpoint@1 { - reg = <1>; - remote-endpoint = <&vin1csi40>; - }; - csi40vin2: endpoint@2 { - reg = <2>; - remote-endpoint = <&vin2csi40>; - }; - csi40vin3: endpoint@3 { - reg = <3>; - remote-endpoint = <&vin3csi40>; - }; - csi40vin4: endpoint@4 { - reg = <4>; - remote-endpoint = <&vin4csi40>; - }; - csi40vin5: endpoint@5 { - reg = <5>; - remote-endpoint = <&vin5csi40>; - }; - csi40vin6: endpoint@6 { - reg = <6>; - remote-endpoint = <&vin6csi40>; - }; - csi40vin7: endpoint@7 { - reg = <7>; - remote-endpoint = <&vin7csi40>; - }; - }; - - }; - }; - - hdmi0: hdmi@fead0000 { - compatible = "renesas,r8a7796-hdmi", "renesas,rcar-gen3-hdmi"; - reg = <0 0xfead0000 0 0x10000>; - interrupts = <GIC_SPI 389 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 729>, <&cpg CPG_CORE R8A7796_CLK_HDMI>; - clock-names = "iahb", "isfr"; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 729>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - port@0 { - reg = <0>; - dw_hdmi0_in: endpoint { - remote-endpoint = <&du_out_hdmi0>; - }; - }; - port@1 { - reg = <1>; - }; - port@2 { - /* HDMI sound */ - reg = <2>; - }; - }; - }; - - du: display@feb00000 { - compatible = "renesas,du-r8a7796"; - reg = <0 0xfeb00000 0 0x70000>; - interrupts = <GIC_SPI 256 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 268 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 269 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 724>, <&cpg CPG_MOD 723>, - <&cpg CPG_MOD 722>; - clock-names = "du.0", "du.1", "du.2"; - resets = <&cpg 724>, <&cpg 722>; - reset-names = "du.0", "du.2"; - - renesas,cmms = <&cmm0>, <&cmm1>, <&cmm2>; - renesas,vsps = <&vspd0 0>, <&vspd1 0>, <&vspd2 0>; - - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - port@1 { - reg = <1>; - du_out_hdmi0: endpoint { - remote-endpoint = <&dw_hdmi0_in>; - }; - }; - port@2 { - reg = <2>; - du_out_lvds0: endpoint { - remote-endpoint = <&lvds0_in>; - }; - }; - }; - }; - - lvds0: lvds@feb90000 { - compatible = "renesas,r8a7796-lvds"; - reg = <0 0xfeb90000 0 0x14>; - clocks = <&cpg CPG_MOD 727>; - power-domains = <&sysc R8A7796_PD_ALWAYS_ON>; - resets = <&cpg 727>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - lvds0_in: endpoint { - remote-endpoint = <&du_out_lvds0>; - }; - }; - port@1 { - reg = <1>; - }; - }; - }; - - prr: chipid@fff00044 { - compatible = "renesas,prr"; - reg = <0 0xfff00044 0 4>; - }; - }; - - thermal-zones { - sensor1_thermal: sensor1-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - thermal-sensors = <&tsc 0>; - sustainable-power = <3874>; - - trips { - sensor1_crit: sensor1-crit { - temperature = <120000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - }; - - sensor2_thermal: sensor2-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - thermal-sensors = <&tsc 1>; - sustainable-power = <3874>; - - trips { - sensor2_crit: sensor2-crit { - temperature = <120000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - }; - - sensor3_thermal: sensor3-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - thermal-sensors = <&tsc 2>; - sustainable-power = <3874>; - - cooling-maps { - map0 { - trip = <&target>; - cooling-device = <&a57_0 2 4>; - contribution = <1024>; - }; - map1 { - trip = <&target>; - cooling-device = <&a53_0 0 2>; - contribution = <1024>; - }; - }; - trips { - target: trip-point1 { - temperature = <100000>; - hysteresis = <1000>; - type = "passive"; - }; - - sensor3_crit: sensor3-crit { - temperature = <120000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - }; - }; - - timer { - compatible = "arm,armv8-timer"; - interrupts-extended = <&gic GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>; - }; - - /* External USB clocks - can be overridden by the board */ - usb3s0_clk: usb3s0 { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - usb_extal_clk: usb_extal { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; -}; diff --git a/arch/arm/dts/r8a77965-salvator-x.dts b/arch/arm/dts/r8a77965-salvator-x.dts deleted file mode 100644 index f84c64ed4df..00000000000 --- a/arch/arm/dts/r8a77965-salvator-x.dts +++ /dev/null @@ -1,32 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the Salvator-X board with R-Car M3-N - * - * Copyright (C) 2018 Jacopo Mondi jacopo+renesas@jmondi.org - */ - -/dts-v1/; -#include "r8a77965.dtsi" -#include "salvator-x.dtsi" - -/ { - model = "Renesas Salvator-X board based on r8a77965"; - compatible = "renesas,salvator-x", "renesas,r8a77965"; - - memory@48000000 { - device_type = "memory"; - /* first 128MB is reserved for secure area. */ - reg = <0x0 0x48000000 0x0 0x78000000>; - }; -}; - -&du { - clocks = <&cpg CPG_MOD 724>, - <&cpg CPG_MOD 723>, - <&cpg CPG_MOD 721>, - <&versaclock5 1>, - <&x21_clk>, - <&versaclock5 2>; - clock-names = "du.0", "du.1", "du.3", - "dclkin.0", "dclkin.1", "dclkin.3"; -}; diff --git a/arch/arm/dts/r8a77965-ulcb.dts b/arch/arm/dts/r8a77965-ulcb.dts deleted file mode 100644 index 71704b67a20..00000000000 --- a/arch/arm/dts/r8a77965-ulcb.dts +++ /dev/null @@ -1,33 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the M3NULCB (R-Car Starter Kit Pro) board with R-Car M3-N - * - * Copyright (C) 2018 Renesas Electronics Corp. - * Copyright (C) 2018 Cogent Embedded, Inc. - */ - -/dts-v1/; -#include "r8a77965.dtsi" -#include "ulcb.dtsi" - -/ { - model = "Renesas M3NULCB board based on r8a77965"; - compatible = "renesas,m3nulcb", "renesas,r8a77965"; - - memory@48000000 { - device_type = "memory"; - /* first 128MB is reserved for secure area. */ - reg = <0x0 0x48000000 0x0 0x78000000>; - }; -}; - -&du { - clocks = <&cpg CPG_MOD 724>, - <&cpg CPG_MOD 723>, - <&cpg CPG_MOD 721>, - <&versaclock5 1>, - <&versaclock5 3>, - <&versaclock5 2>; - clock-names = "du.0", "du.1", "du.3", - "dclkin.0", "dclkin.1", "dclkin.3"; -}; diff --git a/arch/arm/dts/r8a77965.dtsi b/arch/arm/dts/r8a77965.dtsi deleted file mode 100644 index c7582003849..00000000000 --- a/arch/arm/dts/r8a77965.dtsi +++ /dev/null @@ -1,2889 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the R-Car M3-N (R8A77965) SoC - * - * Copyright (C) 2018 Jacopo Mondi jacopo+renesas@jmondi.org - * - * Based on r8a7796.dtsi - * Copyright (C) 2016 Renesas Electronics Corp. - */ - -#include <dt-bindings/clock/r8a77965-cpg-mssr.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/power/r8a77965-sysc.h> - -#define CPG_AUDIO_CLK_I R8A77965_CLK_S0D4 - -#define SOC_HAS_SATA - -/ { - compatible = "renesas,r8a77965"; - #address-cells = <2>; - #size-cells = <2>; - - /* - * The external audio clocks are configured as 0 Hz fixed frequency - * clocks by default. - * Boards that provide audio clocks should override them. - */ - audio_clk_a: audio_clk_a { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - audio_clk_b: audio_clk_b { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - audio_clk_c: audio_clk_c { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - /* External CAN clock - to be overridden by boards that provide it */ - can_clk: can { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - cluster0_opp: opp-table-0 { - compatible = "operating-points-v2"; - opp-shared; - - opp-500000000 { - opp-hz = /bits/ 64 <500000000>; - opp-microvolt = <830000>; - clock-latency-ns = <300000>; - }; - opp-1000000000 { - opp-hz = /bits/ 64 <1000000000>; - opp-microvolt = <830000>; - clock-latency-ns = <300000>; - }; - opp-1500000000 { - opp-hz = /bits/ 64 <1500000000>; - opp-microvolt = <830000>; - clock-latency-ns = <300000>; - opp-suspend; - }; - opp-1600000000 { - opp-hz = /bits/ 64 <1600000000>; - opp-microvolt = <900000>; - clock-latency-ns = <300000>; - }; - opp-1700000000 { - opp-hz = /bits/ 64 <1700000000>; - opp-microvolt = <900000>; - clock-latency-ns = <300000>; - }; - opp-1800000000 { - opp-hz = /bits/ 64 <1800000000>; - opp-microvolt = <960000>; - clock-latency-ns = <300000>; - turbo-mode; - }; - }; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - - a57_0: cpu@0 { - compatible = "arm,cortex-a57"; - reg = <0x0>; - device_type = "cpu"; - power-domains = <&sysc R8A77965_PD_CA57_CPU0>; - next-level-cache = <&L2_CA57>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_0>; - #cooling-cells = <2>; - dynamic-power-coefficient = <854>; - clocks = <&cpg CPG_CORE R8A77965_CLK_Z>; - operating-points-v2 = <&cluster0_opp>; - }; - - a57_1: cpu@1 { - compatible = "arm,cortex-a57"; - reg = <0x1>; - device_type = "cpu"; - power-domains = <&sysc R8A77965_PD_CA57_CPU1>; - next-level-cache = <&L2_CA57>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_0>; - clocks = <&cpg CPG_CORE R8A77965_CLK_Z>; - operating-points-v2 = <&cluster0_opp>; - }; - - L2_CA57: cache-controller-0 { - compatible = "cache"; - power-domains = <&sysc R8A77965_PD_CA57_SCU>; - cache-unified; - cache-level = <2>; - }; - - idle-states { - entry-method = "psci"; - - CPU_SLEEP_0: cpu-sleep-0 { - compatible = "arm,idle-state"; - arm,psci-suspend-param = <0x0010000>; - local-timer-stop; - entry-latency-us = <400>; - exit-latency-us = <500>; - min-residency-us = <4000>; - }; - }; - }; - - extal_clk: extal { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board */ - clock-frequency = <0>; - }; - - extalr_clk: extalr { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board */ - clock-frequency = <0>; - }; - - /* External PCIe clock - can be overridden by the board */ - pcie_bus_clk: pcie_bus { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - pmu_a57 { - compatible = "arm,cortex-a57-pmu"; - interrupts-extended = <&gic GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&a57_0>, - <&a57_1>; - }; - - psci { - compatible = "arm,psci-1.0", "arm,psci-0.2"; - method = "smc"; - }; - - /* External SCIF clock - to be overridden by boards that provide it */ - scif_clk: scif { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - soc { - compatible = "simple-bus"; - interrupt-parent = <&gic>; - #address-cells = <2>; - #size-cells = <2>; - ranges; - - rwdt: watchdog@e6020000 { - compatible = "renesas,r8a77965-wdt", - "renesas,rcar-gen3-wdt"; - reg = <0 0xe6020000 0 0x0c>; - interrupts = <GIC_SPI 140 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 402>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 402>; - status = "disabled"; - }; - - gpio0: gpio@e6050000 { - compatible = "renesas,gpio-r8a77965", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6050000 0 0x50>; - interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 0 16>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 912>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 912>; - }; - - gpio1: gpio@e6051000 { - compatible = "renesas,gpio-r8a77965", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6051000 0 0x50>; - interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 32 29>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 911>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 911>; - }; - - gpio2: gpio@e6052000 { - compatible = "renesas,gpio-r8a77965", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6052000 0 0x50>; - interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 64 15>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 910>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 910>; - }; - - gpio3: gpio@e6053000 { - compatible = "renesas,gpio-r8a77965", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6053000 0 0x50>; - interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 96 16>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 909>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 909>; - }; - - gpio4: gpio@e6054000 { - compatible = "renesas,gpio-r8a77965", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6054000 0 0x50>; - interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 128 18>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 908>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 908>; - }; - - gpio5: gpio@e6055000 { - compatible = "renesas,gpio-r8a77965", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6055000 0 0x50>; - interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 160 26>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 907>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 907>; - }; - - gpio6: gpio@e6055400 { - compatible = "renesas,gpio-r8a77965", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6055400 0 0x50>; - interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 192 32>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 906>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 906>; - }; - - gpio7: gpio@e6055800 { - compatible = "renesas,gpio-r8a77965", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6055800 0 0x50>; - interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 224 4>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 905>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 905>; - }; - - pfc: pinctrl@e6060000 { - compatible = "renesas,pfc-r8a77965"; - reg = <0 0xe6060000 0 0x50c>; - }; - - cmt0: timer@e60f0000 { - compatible = "renesas,r8a77965-cmt0", - "renesas,rcar-gen3-cmt0"; - reg = <0 0xe60f0000 0 0x1004>; - interrupts = <GIC_SPI 142 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 143 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 303>; - clock-names = "fck"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 303>; - status = "disabled"; - }; - - cmt1: timer@e6130000 { - compatible = "renesas,r8a77965-cmt1", - "renesas,rcar-gen3-cmt1"; - reg = <0 0xe6130000 0 0x1004>; - interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 127 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 302>; - clock-names = "fck"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 302>; - status = "disabled"; - }; - - cmt2: timer@e6140000 { - compatible = "renesas,r8a77965-cmt1", - "renesas,rcar-gen3-cmt1"; - reg = <0 0xe6140000 0 0x1004>; - interrupts = <GIC_SPI 398 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 399 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 400 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 401 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 402 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 403 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 404 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 405 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 301>; - clock-names = "fck"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 301>; - status = "disabled"; - }; - - cmt3: timer@e6148000 { - compatible = "renesas,r8a77965-cmt1", - "renesas,rcar-gen3-cmt1"; - reg = <0 0xe6148000 0 0x1004>; - interrupts = <GIC_SPI 470 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 471 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 472 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 473 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 474 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 475 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 476 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 477 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 300>; - clock-names = "fck"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 300>; - status = "disabled"; - }; - - cpg: clock-controller@e6150000 { - compatible = "renesas,r8a77965-cpg-mssr"; - reg = <0 0xe6150000 0 0x1000>; - clocks = <&extal_clk>, <&extalr_clk>; - clock-names = "extal", "extalr"; - #clock-cells = <2>; - #power-domain-cells = <0>; - #reset-cells = <1>; - }; - - rst: reset-controller@e6160000 { - compatible = "renesas,r8a77965-rst"; - reg = <0 0xe6160000 0 0x0200>; - }; - - sysc: system-controller@e6180000 { - compatible = "renesas,r8a77965-sysc"; - reg = <0 0xe6180000 0 0x0400>; - #power-domain-cells = <1>; - }; - - tsc: thermal@e6198000 { - compatible = "renesas,r8a77965-thermal"; - reg = <0 0xe6198000 0 0x100>, - <0 0xe61a0000 0 0x100>, - <0 0xe61a8000 0 0x100>; - interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 522>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 522>; - #thermal-sensor-cells = <1>; - }; - - intc_ex: interrupt-controller@e61c0000 { - compatible = "renesas,intc-ex-r8a77965", "renesas,irqc"; - #interrupt-cells = <2>; - interrupt-controller; - reg = <0 0xe61c0000 0 0x200>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 161 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 407>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 407>; - }; - - tmu0: timer@e61e0000 { - compatible = "renesas,tmu-r8a77965", "renesas,tmu"; - reg = <0 0xe61e0000 0 0x30>; - interrupts = <GIC_SPI 136 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 137 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 138 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 125>; - clock-names = "fck"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 125>; - status = "disabled"; - }; - - tmu1: timer@e6fc0000 { - compatible = "renesas,tmu-r8a77965", "renesas,tmu"; - reg = <0 0xe6fc0000 0 0x30>; - interrupts = <GIC_SPI 128 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 129 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 130 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 124>; - clock-names = "fck"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 124>; - status = "disabled"; - }; - - tmu2: timer@e6fd0000 { - compatible = "renesas,tmu-r8a77965", "renesas,tmu"; - reg = <0 0xe6fd0000 0 0x30>; - interrupts = <GIC_SPI 303 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 304 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 305 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 123>; - clock-names = "fck"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 123>; - status = "disabled"; - }; - - tmu3: timer@e6fe0000 { - compatible = "renesas,tmu-r8a77965", "renesas,tmu"; - reg = <0 0xe6fe0000 0 0x30>; - interrupts = <GIC_SPI 131 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 132 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 133 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 122>; - clock-names = "fck"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 122>; - status = "disabled"; - }; - - tmu4: timer@ffc00000 { - compatible = "renesas,tmu-r8a77965", "renesas,tmu"; - reg = <0 0xffc00000 0 0x30>; - interrupts = <GIC_SPI 406 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 407 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 408 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 121>; - clock-names = "fck"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 121>; - status = "disabled"; - }; - - i2c0: i2c@e6500000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a77965", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6500000 0 0x40>; - interrupts = <GIC_SPI 287 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 931>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 931>; - dmas = <&dmac1 0x91>, <&dmac1 0x90>, - <&dmac2 0x91>, <&dmac2 0x90>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - status = "disabled"; - }; - - i2c1: i2c@e6508000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a77965", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6508000 0 0x40>; - interrupts = <GIC_SPI 288 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 930>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 930>; - dmas = <&dmac1 0x93>, <&dmac1 0x92>, - <&dmac2 0x93>, <&dmac2 0x92>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c2: i2c@e6510000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a77965", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6510000 0 0x40>; - interrupts = <GIC_SPI 286 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 929>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 929>; - dmas = <&dmac1 0x95>, <&dmac1 0x94>, - <&dmac2 0x95>, <&dmac2 0x94>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c3: i2c@e66d0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a77965", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66d0000 0 0x40>; - interrupts = <GIC_SPI 290 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 928>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 928>; - dmas = <&dmac0 0x97>, <&dmac0 0x96>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - status = "disabled"; - }; - - i2c4: i2c@e66d8000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a77965", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66d8000 0 0x40>; - interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 927>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 927>; - dmas = <&dmac0 0x99>, <&dmac0 0x98>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - status = "disabled"; - }; - - i2c5: i2c@e66e0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a77965", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66e0000 0 0x40>; - interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 919>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 919>; - dmas = <&dmac0 0x9b>, <&dmac0 0x9a>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - status = "disabled"; - }; - - i2c6: i2c@e66e8000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a77965", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66e8000 0 0x40>; - interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 918>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 918>; - dmas = <&dmac0 0x9d>, <&dmac0 0x9c>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c_dvfs: i2c@e60b0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,iic-r8a77965", - "renesas,rcar-gen3-iic", - "renesas,rmobile-iic"; - reg = <0 0xe60b0000 0 0x425>; - interrupts = <GIC_SPI 173 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 926>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 926>; - dmas = <&dmac0 0x11>, <&dmac0 0x10>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - hscif0: serial@e6540000 { - compatible = "renesas,hscif-r8a77965", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe6540000 0 0x60>; - interrupts = <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 520>, - <&cpg CPG_CORE R8A77965_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x31>, <&dmac1 0x30>, - <&dmac2 0x31>, <&dmac2 0x30>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 520>; - status = "disabled"; - }; - - hscif1: serial@e6550000 { - compatible = "renesas,hscif-r8a77965", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe6550000 0 0x60>; - interrupts = <GIC_SPI 155 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 519>, - <&cpg CPG_CORE R8A77965_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x33>, <&dmac1 0x32>, - <&dmac2 0x33>, <&dmac2 0x32>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 519>; - status = "disabled"; - }; - - hscif2: serial@e6560000 { - compatible = "renesas,hscif-r8a77965", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe6560000 0 0x60>; - interrupts = <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 518>, - <&cpg CPG_CORE R8A77965_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x35>, <&dmac1 0x34>, - <&dmac2 0x35>, <&dmac2 0x34>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 518>; - status = "disabled"; - }; - - hscif3: serial@e66a0000 { - compatible = "renesas,hscif-r8a77965", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe66a0000 0 0x60>; - interrupts = <GIC_SPI 145 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 517>, - <&cpg CPG_CORE R8A77965_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x37>, <&dmac0 0x36>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 517>; - status = "disabled"; - }; - - hscif4: serial@e66b0000 { - compatible = "renesas,hscif-r8a77965", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe66b0000 0 0x60>; - interrupts = <GIC_SPI 146 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 516>, - <&cpg CPG_CORE R8A77965_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x39>, <&dmac0 0x38>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 516>; - status = "disabled"; - }; - - hsusb: usb@e6590000 { - compatible = "renesas,usbhs-r8a77965", - "renesas,rcar-gen3-usbhs"; - reg = <0 0xe6590000 0 0x200>; - interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 704>, <&cpg CPG_MOD 703>; - dmas = <&usb_dmac0 0>, <&usb_dmac0 1>, - <&usb_dmac1 0>, <&usb_dmac1 1>; - dma-names = "ch0", "ch1", "ch2", "ch3"; - renesas,buswait = <11>; - phys = <&usb2_phy0 3>; - phy-names = "usb"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 704>, <&cpg 703>; - status = "disabled"; - }; - - usb_dmac0: dma-controller@e65a0000 { - compatible = "renesas,r8a77965-usb-dmac", - "renesas,usb-dmac"; - reg = <0 0xe65a0000 0 0x100>; - interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1"; - clocks = <&cpg CPG_MOD 330>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 330>; - #dma-cells = <1>; - dma-channels = <2>; - }; - - usb_dmac1: dma-controller@e65b0000 { - compatible = "renesas,r8a77965-usb-dmac", - "renesas,usb-dmac"; - reg = <0 0xe65b0000 0 0x100>; - interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1"; - clocks = <&cpg CPG_MOD 331>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 331>; - #dma-cells = <1>; - dma-channels = <2>; - }; - - usb3_phy0: usb-phy@e65ee000 { - compatible = "renesas,r8a77965-usb3-phy", - "renesas,rcar-gen3-usb3-phy"; - reg = <0 0xe65ee000 0 0x90>; - clocks = <&cpg CPG_MOD 328>, <&usb3s0_clk>, - <&usb_extal_clk>; - clock-names = "usb3-if", "usb3s_clk", "usb_extal"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 328>; - #phy-cells = <0>; - status = "disabled"; - }; - - arm_cc630p: crypto@e6601000 { - compatible = "arm,cryptocell-630p-ree"; - interrupts = <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x0 0xe6601000 0 0x1000>; - clocks = <&cpg CPG_MOD 229>; - resets = <&cpg 229>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - }; - - dmac0: dma-controller@e6700000 { - compatible = "renesas,dmac-r8a77965", - "renesas,rcar-dmac"; - reg = <0 0xe6700000 0 0x10000>; - interrupts = <GIC_SPI 199 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 200 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 201 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 202 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 203 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 204 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 205 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 206 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 207 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 208 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 209 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 210 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 211 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 212 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 213 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 214 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 215 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 219>; - clock-names = "fck"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 219>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_ds0 0>, <&ipmmu_ds0 1>, - <&ipmmu_ds0 2>, <&ipmmu_ds0 3>, - <&ipmmu_ds0 4>, <&ipmmu_ds0 5>, - <&ipmmu_ds0 6>, <&ipmmu_ds0 7>, - <&ipmmu_ds0 8>, <&ipmmu_ds0 9>, - <&ipmmu_ds0 10>, <&ipmmu_ds0 11>, - <&ipmmu_ds0 12>, <&ipmmu_ds0 13>, - <&ipmmu_ds0 14>, <&ipmmu_ds0 15>; - }; - - dmac1: dma-controller@e7300000 { - compatible = "renesas,dmac-r8a77965", - "renesas,rcar-dmac"; - reg = <0 0xe7300000 0 0x10000>; - interrupts = <GIC_SPI 220 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 216 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 217 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 218 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 219 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 308 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 309 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 310 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 311 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 312 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 313 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 314 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 315 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 316 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 317 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 318 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 319 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 218>; - clock-names = "fck"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 218>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_ds1 0>, <&ipmmu_ds1 1>, - <&ipmmu_ds1 2>, <&ipmmu_ds1 3>, - <&ipmmu_ds1 4>, <&ipmmu_ds1 5>, - <&ipmmu_ds1 6>, <&ipmmu_ds1 7>, - <&ipmmu_ds1 8>, <&ipmmu_ds1 9>, - <&ipmmu_ds1 10>, <&ipmmu_ds1 11>, - <&ipmmu_ds1 12>, <&ipmmu_ds1 13>, - <&ipmmu_ds1 14>, <&ipmmu_ds1 15>; - }; - - dmac2: dma-controller@e7310000 { - compatible = "renesas,dmac-r8a77965", - "renesas,rcar-dmac"; - reg = <0 0xe7310000 0 0x10000>; - interrupts = <GIC_SPI 416 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 417 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 418 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 419 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 420 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 421 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 422 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 423 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 424 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 425 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 426 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 427 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 428 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 429 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 430 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 431 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 397 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 217>; - clock-names = "fck"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 217>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_ds1 16>, <&ipmmu_ds1 17>, - <&ipmmu_ds1 18>, <&ipmmu_ds1 19>, - <&ipmmu_ds1 20>, <&ipmmu_ds1 21>, - <&ipmmu_ds1 22>, <&ipmmu_ds1 23>, - <&ipmmu_ds1 24>, <&ipmmu_ds1 25>, - <&ipmmu_ds1 26>, <&ipmmu_ds1 27>, - <&ipmmu_ds1 28>, <&ipmmu_ds1 29>, - <&ipmmu_ds1 30>, <&ipmmu_ds1 31>; - }; - - ipmmu_ds0: iommu@e6740000 { - compatible = "renesas,ipmmu-r8a77965"; - reg = <0 0xe6740000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 0>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_ds1: iommu@e7740000 { - compatible = "renesas,ipmmu-r8a77965"; - reg = <0 0xe7740000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 1>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_hc: iommu@e6570000 { - compatible = "renesas,ipmmu-r8a77965"; - reg = <0 0xe6570000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 2>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_mm: iommu@e67b0000 { - compatible = "renesas,ipmmu-r8a77965"; - reg = <0 0xe67b0000 0 0x1000>; - interrupts = <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_mp: iommu@ec670000 { - compatible = "renesas,ipmmu-r8a77965"; - reg = <0 0xec670000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 4>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_pv0: iommu@fd800000 { - compatible = "renesas,ipmmu-r8a77965"; - reg = <0 0xfd800000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 6>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_rt: iommu@ffc80000 { - compatible = "renesas,ipmmu-r8a77965"; - reg = <0 0xffc80000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 10>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_vc0: iommu@fe6b0000 { - compatible = "renesas,ipmmu-r8a77965"; - reg = <0 0xfe6b0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 12>; - power-domains = <&sysc R8A77965_PD_A3VC>; - #iommu-cells = <1>; - }; - - ipmmu_vi0: iommu@febd0000 { - compatible = "renesas,ipmmu-r8a77965"; - reg = <0 0xfebd0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 14>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_vp0: iommu@fe990000 { - compatible = "renesas,ipmmu-r8a77965"; - reg = <0 0xfe990000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 16>; - power-domains = <&sysc R8A77965_PD_A3VP>; - #iommu-cells = <1>; - }; - - avb: ethernet@e6800000 { - compatible = "renesas,etheravb-r8a77965", - "renesas,etheravb-rcar-gen3"; - reg = <0 0xe6800000 0 0x800>, <0 0xe6a00000 0 0x10000>; - interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 47 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 63 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15", - "ch16", "ch17", "ch18", "ch19", - "ch20", "ch21", "ch22", "ch23", - "ch24"; - clocks = <&cpg CPG_MOD 812>; - clock-names = "fck"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 812>; - phy-mode = "rgmii"; - rx-internal-delay-ps = <0>; - tx-internal-delay-ps = <0>; - iommus = <&ipmmu_ds0 16>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - can0: can@e6c30000 { - compatible = "renesas,can-r8a77965", - "renesas,rcar-gen3-can"; - reg = <0 0xe6c30000 0 0x1000>; - interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 916>, - <&cpg CPG_CORE R8A77965_CLK_CANFD>, - <&can_clk>; - clock-names = "clkp1", "clkp2", "can_clk"; - assigned-clocks = <&cpg CPG_CORE R8A77965_CLK_CANFD>; - assigned-clock-rates = <40000000>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 916>; - status = "disabled"; - }; - - can1: can@e6c38000 { - compatible = "renesas,can-r8a77965", - "renesas,rcar-gen3-can"; - reg = <0 0xe6c38000 0 0x1000>; - interrupts = <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 915>, - <&cpg CPG_CORE R8A77965_CLK_CANFD>, - <&can_clk>; - clock-names = "clkp1", "clkp2", "can_clk"; - assigned-clocks = <&cpg CPG_CORE R8A77965_CLK_CANFD>; - assigned-clock-rates = <40000000>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 915>; - status = "disabled"; - }; - - canfd: can@e66c0000 { - compatible = "renesas,r8a77965-canfd", - "renesas,rcar-gen3-canfd"; - reg = <0 0xe66c0000 0 0x8000>; - interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch_int", "g_int"; - clocks = <&cpg CPG_MOD 914>, - <&cpg CPG_CORE R8A77965_CLK_CANFD>, - <&can_clk>; - clock-names = "fck", "canfd", "can_clk"; - assigned-clocks = <&cpg CPG_CORE R8A77965_CLK_CANFD>; - assigned-clock-rates = <40000000>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 914>; - status = "disabled"; - - channel0 { - status = "disabled"; - }; - - channel1 { - status = "disabled"; - }; - }; - - pwm0: pwm@e6e30000 { - compatible = "renesas,pwm-r8a77965", "renesas,pwm-rcar"; - reg = <0 0xe6e30000 0 8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - resets = <&cpg 523>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - status = "disabled"; - }; - - pwm1: pwm@e6e31000 { - compatible = "renesas,pwm-r8a77965", "renesas,pwm-rcar"; - reg = <0 0xe6e31000 0 8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - resets = <&cpg 523>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - status = "disabled"; - }; - - pwm2: pwm@e6e32000 { - compatible = "renesas,pwm-r8a77965", "renesas,pwm-rcar"; - reg = <0 0xe6e32000 0 8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - resets = <&cpg 523>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - status = "disabled"; - }; - - pwm3: pwm@e6e33000 { - compatible = "renesas,pwm-r8a77965", "renesas,pwm-rcar"; - reg = <0 0xe6e33000 0 8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - resets = <&cpg 523>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - status = "disabled"; - }; - - pwm4: pwm@e6e34000 { - compatible = "renesas,pwm-r8a77965", "renesas,pwm-rcar"; - reg = <0 0xe6e34000 0 8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - resets = <&cpg 523>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - status = "disabled"; - }; - - pwm5: pwm@e6e35000 { - compatible = "renesas,pwm-r8a77965", "renesas,pwm-rcar"; - reg = <0 0xe6e35000 0 8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - resets = <&cpg 523>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - status = "disabled"; - }; - - pwm6: pwm@e6e36000 { - compatible = "renesas,pwm-r8a77965", "renesas,pwm-rcar"; - reg = <0 0xe6e36000 0 8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - resets = <&cpg 523>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - status = "disabled"; - }; - - scif0: serial@e6e60000 { - compatible = "renesas,scif-r8a77965", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6e60000 0 64>; - interrupts = <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 207>, - <&cpg CPG_CORE R8A77965_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x51>, <&dmac1 0x50>, - <&dmac2 0x51>, <&dmac2 0x50>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 207>; - status = "disabled"; - }; - - scif1: serial@e6e68000 { - compatible = "renesas,scif-r8a77965", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6e68000 0 64>; - interrupts = <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 206>, - <&cpg CPG_CORE R8A77965_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x53>, <&dmac1 0x52>, - <&dmac2 0x53>, <&dmac2 0x52>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 206>; - status = "disabled"; - }; - - scif2: serial@e6e88000 { - compatible = "renesas,scif-r8a77965", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6e88000 0 64>; - interrupts = <GIC_SPI 164 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 310>, - <&cpg CPG_CORE R8A77965_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x13>, <&dmac1 0x12>, - <&dmac2 0x13>, <&dmac2 0x12>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 310>; - status = "disabled"; - }; - - scif3: serial@e6c50000 { - compatible = "renesas,scif-r8a77965", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6c50000 0 64>; - interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 204>, - <&cpg CPG_CORE R8A77965_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x57>, <&dmac0 0x56>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 204>; - status = "disabled"; - }; - - scif4: serial@e6c40000 { - compatible = "renesas,scif-r8a77965", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6c40000 0 64>; - interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 203>, - <&cpg CPG_CORE R8A77965_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x59>, <&dmac0 0x58>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 203>; - status = "disabled"; - }; - - scif5: serial@e6f30000 { - compatible = "renesas,scif-r8a77965", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6f30000 0 64>; - interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 202>, - <&cpg CPG_CORE R8A77965_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x5b>, <&dmac1 0x5a>, - <&dmac2 0x5b>, <&dmac2 0x5a>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 202>; - status = "disabled"; - }; - - tpu: pwm@e6e80000 { - compatible = "renesas,tpu-r8a77965", "renesas,tpu"; - reg = <0 0xe6e80000 0 0x148>; - interrupts = <GIC_SPI 135 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 304>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 304>; - #pwm-cells = <3>; - status = "disabled"; - }; - - msiof0: spi@e6e90000 { - compatible = "renesas,msiof-r8a77965", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6e90000 0 0x0064>; - interrupts = <GIC_SPI 156 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 211>; - dmas = <&dmac1 0x41>, <&dmac1 0x40>, - <&dmac2 0x41>, <&dmac2 0x40>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 211>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof1: spi@e6ea0000 { - compatible = "renesas,msiof-r8a77965", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6ea0000 0 0x0064>; - interrupts = <GIC_SPI 157 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 210>; - dmas = <&dmac1 0x43>, <&dmac1 0x42>, - <&dmac2 0x43>, <&dmac2 0x42>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 210>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof2: spi@e6c00000 { - compatible = "renesas,msiof-r8a77965", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6c00000 0 0x0064>; - interrupts = <GIC_SPI 158 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 209>; - dmas = <&dmac0 0x45>, <&dmac0 0x44>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 209>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof3: spi@e6c10000 { - compatible = "renesas,msiof-r8a77965", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6c10000 0 0x0064>; - interrupts = <GIC_SPI 159 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 208>; - dmas = <&dmac0 0x47>, <&dmac0 0x46>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 208>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - vin0: video@e6ef0000 { - compatible = "renesas,vin-r8a77965"; - reg = <0 0xe6ef0000 0 0x1000>; - interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 811>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 811>; - renesas,id = <0>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin0csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin0>; - }; - vin0csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin0>; - }; - }; - }; - }; - - vin1: video@e6ef1000 { - compatible = "renesas,vin-r8a77965"; - reg = <0 0xe6ef1000 0 0x1000>; - interrupts = <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 810>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 810>; - renesas,id = <1>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin1csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin1>; - }; - vin1csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin1>; - }; - }; - }; - }; - - vin2: video@e6ef2000 { - compatible = "renesas,vin-r8a77965"; - reg = <0 0xe6ef2000 0 0x1000>; - interrupts = <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 809>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 809>; - renesas,id = <2>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin2csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin2>; - }; - vin2csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin2>; - }; - }; - }; - }; - - vin3: video@e6ef3000 { - compatible = "renesas,vin-r8a77965"; - reg = <0 0xe6ef3000 0 0x1000>; - interrupts = <GIC_SPI 191 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 808>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 808>; - renesas,id = <3>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin3csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin3>; - }; - vin3csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin3>; - }; - }; - }; - }; - - vin4: video@e6ef4000 { - compatible = "renesas,vin-r8a77965"; - reg = <0 0xe6ef4000 0 0x1000>; - interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 807>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 807>; - renesas,id = <4>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin4csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin4>; - }; - vin4csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin4>; - }; - }; - }; - }; - - vin5: video@e6ef5000 { - compatible = "renesas,vin-r8a77965"; - reg = <0 0xe6ef5000 0 0x1000>; - interrupts = <GIC_SPI 175 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 806>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 806>; - renesas,id = <5>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin5csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin5>; - }; - vin5csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin5>; - }; - }; - }; - }; - - vin6: video@e6ef6000 { - compatible = "renesas,vin-r8a77965"; - reg = <0 0xe6ef6000 0 0x1000>; - interrupts = <GIC_SPI 176 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 805>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 805>; - renesas,id = <6>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin6csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin6>; - }; - vin6csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin6>; - }; - }; - }; - }; - - vin7: video@e6ef7000 { - compatible = "renesas,vin-r8a77965"; - reg = <0 0xe6ef7000 0 0x1000>; - interrupts = <GIC_SPI 171 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 804>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 804>; - renesas,id = <7>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin7csi20: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi20vin7>; - }; - vin7csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin7>; - }; - }; - }; - }; - - drif00: rif@e6f40000 { - compatible = "renesas,r8a77965-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6f40000 0 0x84>; - interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 515>; - clock-names = "fck"; - dmas = <&dmac1 0x20>, <&dmac2 0x20>; - dma-names = "rx", "rx"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 515>; - renesas,bonding = <&drif01>; - status = "disabled"; - }; - - drif01: rif@e6f50000 { - compatible = "renesas,r8a77965-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6f50000 0 0x84>; - interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 514>; - clock-names = "fck"; - dmas = <&dmac1 0x22>, <&dmac2 0x22>; - dma-names = "rx", "rx"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 514>; - renesas,bonding = <&drif00>; - status = "disabled"; - }; - - drif10: rif@e6f60000 { - compatible = "renesas,r8a77965-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6f60000 0 0x84>; - interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 513>; - clock-names = "fck"; - dmas = <&dmac1 0x24>, <&dmac2 0x24>; - dma-names = "rx", "rx"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 513>; - renesas,bonding = <&drif11>; - status = "disabled"; - }; - - drif11: rif@e6f70000 { - compatible = "renesas,r8a77965-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6f70000 0 0x84>; - interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 512>; - clock-names = "fck"; - dmas = <&dmac1 0x26>, <&dmac2 0x26>; - dma-names = "rx", "rx"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 512>; - renesas,bonding = <&drif10>; - status = "disabled"; - }; - - drif20: rif@e6f80000 { - compatible = "renesas,r8a77965-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6f80000 0 0x84>; - interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 511>; - clock-names = "fck"; - dmas = <&dmac1 0x28>, <&dmac2 0x28>; - dma-names = "rx", "rx"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 511>; - renesas,bonding = <&drif21>; - status = "disabled"; - }; - - drif21: rif@e6f90000 { - compatible = "renesas,r8a77965-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6f90000 0 0x84>; - interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 510>; - clock-names = "fck"; - dmas = <&dmac1 0x2a>, <&dmac2 0x2a>; - dma-names = "rx", "rx"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 510>; - renesas,bonding = <&drif20>; - status = "disabled"; - }; - - drif30: rif@e6fa0000 { - compatible = "renesas,r8a77965-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6fa0000 0 0x84>; - interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 509>; - clock-names = "fck"; - dmas = <&dmac1 0x2c>, <&dmac2 0x2c>; - dma-names = "rx", "rx"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 509>; - renesas,bonding = <&drif31>; - status = "disabled"; - }; - - drif31: rif@e6fb0000 { - compatible = "renesas,r8a77965-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6fb0000 0 0x84>; - interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 508>; - clock-names = "fck"; - dmas = <&dmac1 0x2e>, <&dmac2 0x2e>; - dma-names = "rx", "rx"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 508>; - renesas,bonding = <&drif30>; - status = "disabled"; - }; - - rcar_sound: sound@ec500000 { - /* - * #sound-dai-cells is required if simple-card - * - * Single DAI : #sound-dai-cells = <0>; <&rcar_sound>; - * Multi DAI : #sound-dai-cells = <1>; <&rcar_sound N>; - */ - /* - * #clock-cells is required for audio_clkout0/1/2/3 - * - * clkout : #clock-cells = <0>; <&rcar_sound>; - * clkout0/1/2/3: #clock-cells = <1>; <&rcar_sound N>; - */ - compatible = "renesas,rcar_sound-r8a77965", "renesas,rcar_sound-gen3"; - reg = <0 0xec500000 0 0x1000>, /* SCU */ - <0 0xec5a0000 0 0x100>, /* ADG */ - <0 0xec540000 0 0x1000>, /* SSIU */ - <0 0xec541000 0 0x280>, /* SSI */ - <0 0xec760000 0 0x200>; /* Audio DMAC peri peri*/ - reg-names = "scu", "adg", "ssiu", "ssi", "audmapp"; - - clocks = <&cpg CPG_MOD 1005>, - <&cpg CPG_MOD 1006>, <&cpg CPG_MOD 1007>, - <&cpg CPG_MOD 1008>, <&cpg CPG_MOD 1009>, - <&cpg CPG_MOD 1010>, <&cpg CPG_MOD 1011>, - <&cpg CPG_MOD 1012>, <&cpg CPG_MOD 1013>, - <&cpg CPG_MOD 1014>, <&cpg CPG_MOD 1015>, - <&cpg CPG_MOD 1022>, <&cpg CPG_MOD 1023>, - <&cpg CPG_MOD 1024>, <&cpg CPG_MOD 1025>, - <&cpg CPG_MOD 1026>, <&cpg CPG_MOD 1027>, - <&cpg CPG_MOD 1028>, <&cpg CPG_MOD 1029>, - <&cpg CPG_MOD 1030>, <&cpg CPG_MOD 1031>, - <&cpg CPG_MOD 1020>, <&cpg CPG_MOD 1021>, - <&cpg CPG_MOD 1020>, <&cpg CPG_MOD 1021>, - <&cpg CPG_MOD 1019>, <&cpg CPG_MOD 1018>, - <&audio_clk_a>, <&audio_clk_b>, - <&audio_clk_c>, - <&cpg CPG_CORE R8A77965_CLK_S0D4>; - clock-names = "ssi-all", - "ssi.9", "ssi.8", "ssi.7", "ssi.6", - "ssi.5", "ssi.4", "ssi.3", "ssi.2", - "ssi.1", "ssi.0", - "src.9", "src.8", "src.7", "src.6", - "src.5", "src.4", "src.3", "src.2", - "src.1", "src.0", - "mix.1", "mix.0", - "ctu.1", "ctu.0", - "dvc.0", "dvc.1", - "clk_a", "clk_b", "clk_c", "clk_i"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 1005>, - <&cpg 1006>, <&cpg 1007>, - <&cpg 1008>, <&cpg 1009>, - <&cpg 1010>, <&cpg 1011>, - <&cpg 1012>, <&cpg 1013>, - <&cpg 1014>, <&cpg 1015>; - reset-names = "ssi-all", - "ssi.9", "ssi.8", "ssi.7", "ssi.6", - "ssi.5", "ssi.4", "ssi.3", "ssi.2", - "ssi.1", "ssi.0"; - status = "disabled"; - - rcar_sound,dvc { - dvc0: dvc-0 { - dmas = <&audma1 0xbc>; - dma-names = "tx"; - }; - dvc1: dvc-1 { - dmas = <&audma1 0xbe>; - dma-names = "tx"; - }; - }; - - rcar_sound,mix { - mix0: mix-0 { }; - mix1: mix-1 { }; - }; - - rcar_sound,ctu { - ctu00: ctu-0 { }; - ctu01: ctu-1 { }; - ctu02: ctu-2 { }; - ctu03: ctu-3 { }; - ctu10: ctu-4 { }; - ctu11: ctu-5 { }; - ctu12: ctu-6 { }; - ctu13: ctu-7 { }; - }; - - rcar_sound,src { - src0: src-0 { - interrupts = <GIC_SPI 352 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x85>, <&audma1 0x9a>; - dma-names = "rx", "tx"; - }; - src1: src-1 { - interrupts = <GIC_SPI 353 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x87>, <&audma1 0x9c>; - dma-names = "rx", "tx"; - }; - src2: src-2 { - interrupts = <GIC_SPI 354 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x89>, <&audma1 0x9e>; - dma-names = "rx", "tx"; - }; - src3: src-3 { - interrupts = <GIC_SPI 355 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x8b>, <&audma1 0xa0>; - dma-names = "rx", "tx"; - }; - src4: src-4 { - interrupts = <GIC_SPI 356 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x8d>, <&audma1 0xb0>; - dma-names = "rx", "tx"; - }; - src5: src-5 { - interrupts = <GIC_SPI 357 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x8f>, <&audma1 0xb2>; - dma-names = "rx", "tx"; - }; - src6: src-6 { - interrupts = <GIC_SPI 358 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x91>, <&audma1 0xb4>; - dma-names = "rx", "tx"; - }; - src7: src-7 { - interrupts = <GIC_SPI 359 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x93>, <&audma1 0xb6>; - dma-names = "rx", "tx"; - }; - src8: src-8 { - interrupts = <GIC_SPI 360 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x95>, <&audma1 0xb8>; - dma-names = "rx", "tx"; - }; - src9: src-9 { - interrupts = <GIC_SPI 361 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x97>, <&audma1 0xba>; - dma-names = "rx", "tx"; - }; - }; - - rcar_sound,ssiu { - ssiu00: ssiu-0 { - dmas = <&audma0 0x15>, <&audma1 0x16>; - dma-names = "rx", "tx"; - }; - ssiu01: ssiu-1 { - dmas = <&audma0 0x35>, <&audma1 0x36>; - dma-names = "rx", "tx"; - }; - ssiu02: ssiu-2 { - dmas = <&audma0 0x37>, <&audma1 0x38>; - dma-names = "rx", "tx"; - }; - ssiu03: ssiu-3 { - dmas = <&audma0 0x47>, <&audma1 0x48>; - dma-names = "rx", "tx"; - }; - ssiu04: ssiu-4 { - dmas = <&audma0 0x3F>, <&audma1 0x40>; - dma-names = "rx", "tx"; - }; - ssiu05: ssiu-5 { - dmas = <&audma0 0x43>, <&audma1 0x44>; - dma-names = "rx", "tx"; - }; - ssiu06: ssiu-6 { - dmas = <&audma0 0x4F>, <&audma1 0x50>; - dma-names = "rx", "tx"; - }; - ssiu07: ssiu-7 { - dmas = <&audma0 0x53>, <&audma1 0x54>; - dma-names = "rx", "tx"; - }; - ssiu10: ssiu-8 { - dmas = <&audma0 0x49>, <&audma1 0x4a>; - dma-names = "rx", "tx"; - }; - ssiu11: ssiu-9 { - dmas = <&audma0 0x4B>, <&audma1 0x4C>; - dma-names = "rx", "tx"; - }; - ssiu12: ssiu-10 { - dmas = <&audma0 0x57>, <&audma1 0x58>; - dma-names = "rx", "tx"; - }; - ssiu13: ssiu-11 { - dmas = <&audma0 0x59>, <&audma1 0x5A>; - dma-names = "rx", "tx"; - }; - ssiu14: ssiu-12 { - dmas = <&audma0 0x5F>, <&audma1 0x60>; - dma-names = "rx", "tx"; - }; - ssiu15: ssiu-13 { - dmas = <&audma0 0xC3>, <&audma1 0xC4>; - dma-names = "rx", "tx"; - }; - ssiu16: ssiu-14 { - dmas = <&audma0 0xC7>, <&audma1 0xC8>; - dma-names = "rx", "tx"; - }; - ssiu17: ssiu-15 { - dmas = <&audma0 0xCB>, <&audma1 0xCC>; - dma-names = "rx", "tx"; - }; - ssiu20: ssiu-16 { - dmas = <&audma0 0x63>, <&audma1 0x64>; - dma-names = "rx", "tx"; - }; - ssiu21: ssiu-17 { - dmas = <&audma0 0x67>, <&audma1 0x68>; - dma-names = "rx", "tx"; - }; - ssiu22: ssiu-18 { - dmas = <&audma0 0x6B>, <&audma1 0x6C>; - dma-names = "rx", "tx"; - }; - ssiu23: ssiu-19 { - dmas = <&audma0 0x6D>, <&audma1 0x6E>; - dma-names = "rx", "tx"; - }; - ssiu24: ssiu-20 { - dmas = <&audma0 0xCF>, <&audma1 0xCE>; - dma-names = "rx", "tx"; - }; - ssiu25: ssiu-21 { - dmas = <&audma0 0xEB>, <&audma1 0xEC>; - dma-names = "rx", "tx"; - }; - ssiu26: ssiu-22 { - dmas = <&audma0 0xED>, <&audma1 0xEE>; - dma-names = "rx", "tx"; - }; - ssiu27: ssiu-23 { - dmas = <&audma0 0xEF>, <&audma1 0xF0>; - dma-names = "rx", "tx"; - }; - ssiu30: ssiu-24 { - dmas = <&audma0 0x6f>, <&audma1 0x70>; - dma-names = "rx", "tx"; - }; - ssiu31: ssiu-25 { - dmas = <&audma0 0x21>, <&audma1 0x22>; - dma-names = "rx", "tx"; - }; - ssiu32: ssiu-26 { - dmas = <&audma0 0x23>, <&audma1 0x24>; - dma-names = "rx", "tx"; - }; - ssiu33: ssiu-27 { - dmas = <&audma0 0x25>, <&audma1 0x26>; - dma-names = "rx", "tx"; - }; - ssiu34: ssiu-28 { - dmas = <&audma0 0x27>, <&audma1 0x28>; - dma-names = "rx", "tx"; - }; - ssiu35: ssiu-29 { - dmas = <&audma0 0x29>, <&audma1 0x2A>; - dma-names = "rx", "tx"; - }; - ssiu36: ssiu-30 { - dmas = <&audma0 0x2B>, <&audma1 0x2C>; - dma-names = "rx", "tx"; - }; - ssiu37: ssiu-31 { - dmas = <&audma0 0x2D>, <&audma1 0x2E>; - dma-names = "rx", "tx"; - }; - ssiu40: ssiu-32 { - dmas = <&audma0 0x71>, <&audma1 0x72>; - dma-names = "rx", "tx"; - }; - ssiu41: ssiu-33 { - dmas = <&audma0 0x17>, <&audma1 0x18>; - dma-names = "rx", "tx"; - }; - ssiu42: ssiu-34 { - dmas = <&audma0 0x19>, <&audma1 0x1A>; - dma-names = "rx", "tx"; - }; - ssiu43: ssiu-35 { - dmas = <&audma0 0x1B>, <&audma1 0x1C>; - dma-names = "rx", "tx"; - }; - ssiu44: ssiu-36 { - dmas = <&audma0 0x1D>, <&audma1 0x1E>; - dma-names = "rx", "tx"; - }; - ssiu45: ssiu-37 { - dmas = <&audma0 0x1F>, <&audma1 0x20>; - dma-names = "rx", "tx"; - }; - ssiu46: ssiu-38 { - dmas = <&audma0 0x31>, <&audma1 0x32>; - dma-names = "rx", "tx"; - }; - ssiu47: ssiu-39 { - dmas = <&audma0 0x33>, <&audma1 0x34>; - dma-names = "rx", "tx"; - }; - ssiu50: ssiu-40 { - dmas = <&audma0 0x73>, <&audma1 0x74>; - dma-names = "rx", "tx"; - }; - ssiu60: ssiu-41 { - dmas = <&audma0 0x75>, <&audma1 0x76>; - dma-names = "rx", "tx"; - }; - ssiu70: ssiu-42 { - dmas = <&audma0 0x79>, <&audma1 0x7a>; - dma-names = "rx", "tx"; - }; - ssiu80: ssiu-43 { - dmas = <&audma0 0x7b>, <&audma1 0x7c>; - dma-names = "rx", "tx"; - }; - ssiu90: ssiu-44 { - dmas = <&audma0 0x7d>, <&audma1 0x7e>; - dma-names = "rx", "tx"; - }; - ssiu91: ssiu-45 { - dmas = <&audma0 0x7F>, <&audma1 0x80>; - dma-names = "rx", "tx"; - }; - ssiu92: ssiu-46 { - dmas = <&audma0 0x81>, <&audma1 0x82>; - dma-names = "rx", "tx"; - }; - ssiu93: ssiu-47 { - dmas = <&audma0 0x83>, <&audma1 0x84>; - dma-names = "rx", "tx"; - }; - ssiu94: ssiu-48 { - dmas = <&audma0 0xA3>, <&audma1 0xA4>; - dma-names = "rx", "tx"; - }; - ssiu95: ssiu-49 { - dmas = <&audma0 0xA5>, <&audma1 0xA6>; - dma-names = "rx", "tx"; - }; - ssiu96: ssiu-50 { - dmas = <&audma0 0xA7>, <&audma1 0xA8>; - dma-names = "rx", "tx"; - }; - ssiu97: ssiu-51 { - dmas = <&audma0 0xA9>, <&audma1 0xAA>; - dma-names = "rx", "tx"; - }; - }; - - rcar_sound,ssi { - ssi0: ssi-0 { - interrupts = <GIC_SPI 370 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x01>, <&audma1 0x02>; - dma-names = "rx", "tx"; - }; - ssi1: ssi-1 { - interrupts = <GIC_SPI 371 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x03>, <&audma1 0x04>; - dma-names = "rx", "tx"; - }; - ssi2: ssi-2 { - interrupts = <GIC_SPI 372 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x05>, <&audma1 0x06>; - dma-names = "rx", "tx"; - }; - ssi3: ssi-3 { - interrupts = <GIC_SPI 373 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x07>, <&audma1 0x08>; - dma-names = "rx", "tx"; - }; - ssi4: ssi-4 { - interrupts = <GIC_SPI 374 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x09>, <&audma1 0x0a>; - dma-names = "rx", "tx"; - }; - ssi5: ssi-5 { - interrupts = <GIC_SPI 375 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x0b>, <&audma1 0x0c>; - dma-names = "rx", "tx"; - }; - ssi6: ssi-6 { - interrupts = <GIC_SPI 376 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x0d>, <&audma1 0x0e>; - dma-names = "rx", "tx"; - }; - ssi7: ssi-7 { - interrupts = <GIC_SPI 377 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x0f>, <&audma1 0x10>; - dma-names = "rx", "tx"; - }; - ssi8: ssi-8 { - interrupts = <GIC_SPI 378 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x11>, <&audma1 0x12>; - dma-names = "rx", "tx"; - }; - ssi9: ssi-9 { - interrupts = <GIC_SPI 379 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x13>, <&audma1 0x14>; - dma-names = "rx", "tx"; - }; - }; - }; - - mlp: mlp@ec520000 { - compatible = "renesas,r8a77965-mlp", - "renesas,rcar-gen3-mlp"; - reg = <0 0xec520000 0 0x800>; - interrupts = <GIC_SPI 384 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 385 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 802>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 802>; - status = "disabled"; - }; - - audma0: dma-controller@ec700000 { - compatible = "renesas,dmac-r8a77965", - "renesas,rcar-dmac"; - reg = <0 0xec700000 0 0x10000>; - interrupts = <GIC_SPI 350 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 320 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 321 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 322 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 323 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 324 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 325 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 326 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 327 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 328 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 329 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 330 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 331 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 332 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 333 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 334 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 335 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 502>; - clock-names = "fck"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 502>; - #dma-cells = <1>; - dma-channels = <16>; - }; - - audma1: dma-controller@ec720000 { - compatible = "renesas,dmac-r8a77965", - "renesas,rcar-dmac"; - reg = <0 0xec720000 0 0x10000>; - interrupts = <GIC_SPI 351 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 336 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 337 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 338 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 339 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 340 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 341 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 342 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 343 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 344 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 345 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 346 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 347 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 348 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 349 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 382 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 383 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 501>; - clock-names = "fck"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 501>; - #dma-cells = <1>; - dma-channels = <16>; - }; - - xhci0: usb@ee000000 { - compatible = "renesas,xhci-r8a77965", - "renesas,rcar-gen3-xhci"; - reg = <0 0xee000000 0 0xc00>; - interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 328>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 328>; - status = "disabled"; - }; - - usb3_peri0: usb@ee020000 { - compatible = "renesas,r8a77965-usb3-peri", - "renesas,rcar-gen3-usb3-peri"; - reg = <0 0xee020000 0 0x400>; - interrupts = <GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 328>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 328>; - status = "disabled"; - }; - - ohci0: usb@ee080000 { - compatible = "generic-ohci"; - reg = <0 0xee080000 0 0x100>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>; - phys = <&usb2_phy0 1>; - phy-names = "usb"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 703>, <&cpg 704>; - status = "disabled"; - }; - - ohci1: usb@ee0a0000 { - compatible = "generic-ohci"; - reg = <0 0xee0a0000 0 0x100>; - interrupts = <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 702>; - phys = <&usb2_phy1 1>; - phy-names = "usb"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 702>; - status = "disabled"; - }; - - ehci0: usb@ee080100 { - compatible = "generic-ehci"; - reg = <0 0xee080100 0 0x100>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>; - phys = <&usb2_phy0 2>; - phy-names = "usb"; - companion = <&ohci0>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 703>, <&cpg 704>; - status = "disabled"; - }; - - ehci1: usb@ee0a0100 { - compatible = "generic-ehci"; - reg = <0 0xee0a0100 0 0x100>; - interrupts = <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 702>; - phys = <&usb2_phy1 2>; - phy-names = "usb"; - companion = <&ohci1>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 702>; - status = "disabled"; - }; - - usb2_phy0: usb-phy@ee080200 { - compatible = "renesas,usb2-phy-r8a77965", - "renesas,rcar-gen3-usb2-phy"; - reg = <0 0xee080200 0 0x700>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 703>, <&cpg 704>; - #phy-cells = <1>; - status = "disabled"; - }; - - usb2_phy1: usb-phy@ee0a0200 { - compatible = "renesas,usb2-phy-r8a77965", - "renesas,rcar-gen3-usb2-phy"; - reg = <0 0xee0a0200 0 0x700>; - clocks = <&cpg CPG_MOD 702>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 702>; - #phy-cells = <1>; - status = "disabled"; - }; - - sdhi0: mmc@ee100000 { - compatible = "renesas,sdhi-r8a77965", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee100000 0 0x2000>; - interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 314>, <&cpg CPG_CORE R8A77965_CLK_SD0H>; - clock-names = "core", "clkh"; - max-frequency = <200000000>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 314>; - iommus = <&ipmmu_ds1 32>; - status = "disabled"; - }; - - sdhi1: mmc@ee120000 { - compatible = "renesas,sdhi-r8a77965", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee120000 0 0x2000>; - interrupts = <GIC_SPI 166 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 313>, <&cpg CPG_CORE R8A77965_CLK_SD1H>; - clock-names = "core", "clkh"; - max-frequency = <200000000>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 313>; - iommus = <&ipmmu_ds1 33>; - status = "disabled"; - }; - - sdhi2: mmc@ee140000 { - compatible = "renesas,sdhi-r8a77965", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee140000 0 0x2000>; - interrupts = <GIC_SPI 167 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 312>, <&cpg CPG_CORE R8A77965_CLK_SD2H>; - clock-names = "core", "clkh"; - max-frequency = <200000000>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 312>; - iommus = <&ipmmu_ds1 34>; - status = "disabled"; - }; - - sdhi3: mmc@ee160000 { - compatible = "renesas,sdhi-r8a77965", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee160000 0 0x2000>; - interrupts = <GIC_SPI 168 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 311>, <&cpg CPG_CORE R8A77965_CLK_SD3H>; - clock-names = "core", "clkh"; - max-frequency = <200000000>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 311>; - iommus = <&ipmmu_ds1 35>; - status = "disabled"; - }; - - rpc: spi@ee200000 { - compatible = "renesas,r8a77965-rpc-if", - "renesas,rcar-gen3-rpc-if"; - reg = <0 0xee200000 0 0x200>, - <0 0x08000000 0 0x04000000>, - <0 0xee208000 0 0x100>; - reg-names = "regs", "dirmap", "wbuf"; - interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 917>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 917>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - sata: sata@ee300000 { - compatible = "renesas,sata-r8a77965", - "renesas,rcar-gen3-sata"; - reg = <0 0xee300000 0 0x200000>; - interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 815>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 815>; - status = "disabled"; - }; - - gic: interrupt-controller@f1010000 { - compatible = "arm,gic-400"; - #interrupt-cells = <3>; - #address-cells = <0>; - interrupt-controller; - reg = <0x0 0xf1010000 0 0x1000>, - <0x0 0xf1020000 0 0x20000>, - <0x0 0xf1040000 0 0x20000>, - <0x0 0xf1060000 0 0x20000>; - interrupts = <GIC_PPI 9 - (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_HIGH)>; - clocks = <&cpg CPG_MOD 408>; - clock-names = "clk"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 408>; - }; - - pciec0: pcie@fe000000 { - compatible = "renesas,pcie-r8a77965", - "renesas,pcie-rcar-gen3"; - reg = <0 0xfe000000 0 0x80000>; - #address-cells = <3>; - #size-cells = <2>; - bus-range = <0x00 0xff>; - device_type = "pci"; - ranges = <0x01000000 0 0x00000000 0 0xfe100000 0 0x00100000>, - <0x02000000 0 0xfe200000 0 0xfe200000 0 0x00200000>, - <0x02000000 0 0x30000000 0 0x30000000 0 0x08000000>, - <0x42000000 0 0x38000000 0 0x38000000 0 0x08000000>; - /* Map all possible DDR/IOMMU as inbound ranges */ - dma-ranges = <0x42000000 0 0x00000000 0 0x00000000 1 0x00000000>; - interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>; - #interrupt-cells = <1>; - interrupt-map-mask = <0 0 0 0>; - interrupt-map = <0 0 0 0 &gic GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 319>, <&pcie_bus_clk>; - clock-names = "pcie", "pcie_bus"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 319>; - iommu-map = <0 &ipmmu_hc 0 1>; - iommu-map-mask = <0>; - status = "disabled"; - }; - - pciec1: pcie@ee800000 { - compatible = "renesas,pcie-r8a77965", - "renesas,pcie-rcar-gen3"; - reg = <0 0xee800000 0 0x80000>; - #address-cells = <3>; - #size-cells = <2>; - bus-range = <0x00 0xff>; - device_type = "pci"; - ranges = <0x01000000 0 0x00000000 0 0xee900000 0 0x00100000>, - <0x02000000 0 0xeea00000 0 0xeea00000 0 0x00200000>, - <0x02000000 0 0xc0000000 0 0xc0000000 0 0x08000000>, - <0x42000000 0 0xc8000000 0 0xc8000000 0 0x08000000>; - /* Map all possible DDR/IOMMU as inbound ranges */ - dma-ranges = <0x42000000 0 0x00000000 0 0x00000000 1 0x00000000>; - interrupts = <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 149 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 150 IRQ_TYPE_LEVEL_HIGH>; - #interrupt-cells = <1>; - interrupt-map-mask = <0 0 0 0>; - interrupt-map = <0 0 0 0 &gic GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 318>, <&pcie_bus_clk>; - clock-names = "pcie", "pcie_bus"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 318>; - iommu-map = <0 &ipmmu_hc 1 1>; - iommu-map-mask = <0>; - status = "disabled"; - }; - - fdp1@fe940000 { - compatible = "renesas,fdp1"; - reg = <0 0xfe940000 0 0x2400>; - interrupts = <GIC_SPI 262 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 119>; - power-domains = <&sysc R8A77965_PD_A3VP>; - resets = <&cpg 119>; - renesas,fcp = <&fcpf0>; - }; - - fcpf0: fcp@fe950000 { - compatible = "renesas,fcpf"; - reg = <0 0xfe950000 0 0x200>; - clocks = <&cpg CPG_MOD 615>; - power-domains = <&sysc R8A77965_PD_A3VP>; - resets = <&cpg 615>; - }; - - vspb: vsp@fe960000 { - compatible = "renesas,vsp2"; - reg = <0 0xfe960000 0 0x8000>; - interrupts = <GIC_SPI 266 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 626>; - power-domains = <&sysc R8A77965_PD_A3VP>; - resets = <&cpg 626>; - - renesas,fcp = <&fcpvb0>; - }; - - vspi0: vsp@fe9a0000 { - compatible = "renesas,vsp2"; - reg = <0 0xfe9a0000 0 0x8000>; - interrupts = <GIC_SPI 444 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 631>; - power-domains = <&sysc R8A77965_PD_A3VP>; - resets = <&cpg 631>; - - renesas,fcp = <&fcpvi0>; - }; - - vspd0: vsp@fea20000 { - compatible = "renesas,vsp2"; - reg = <0 0xfea20000 0 0x5000>; - interrupts = <GIC_SPI 466 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 623>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 623>; - - renesas,fcp = <&fcpvd0>; - }; - - vspd1: vsp@fea28000 { - compatible = "renesas,vsp2"; - reg = <0 0xfea28000 0 0x5000>; - interrupts = <GIC_SPI 467 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 622>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 622>; - - renesas,fcp = <&fcpvd1>; - }; - - fcpvb0: fcp@fe96f000 { - compatible = "renesas,fcpv"; - reg = <0 0xfe96f000 0 0x200>; - clocks = <&cpg CPG_MOD 607>; - power-domains = <&sysc R8A77965_PD_A3VP>; - resets = <&cpg 607>; - }; - - fcpvd0: fcp@fea27000 { - compatible = "renesas,fcpv"; - reg = <0 0xfea27000 0 0x200>; - clocks = <&cpg CPG_MOD 603>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 603>; - }; - - fcpvd1: fcp@fea2f000 { - compatible = "renesas,fcpv"; - reg = <0 0xfea2f000 0 0x200>; - clocks = <&cpg CPG_MOD 602>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 602>; - }; - - fcpvi0: fcp@fe9af000 { - compatible = "renesas,fcpv"; - reg = <0 0xfe9af000 0 0x200>; - clocks = <&cpg CPG_MOD 611>; - power-domains = <&sysc R8A77965_PD_A3VP>; - resets = <&cpg 611>; - }; - - cmm0: cmm@fea40000 { - compatible = "renesas,r8a77965-cmm", - "renesas,rcar-gen3-cmm"; - reg = <0 0xfea40000 0 0x1000>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - clocks = <&cpg CPG_MOD 711>; - resets = <&cpg 711>; - }; - - cmm1: cmm@fea50000 { - compatible = "renesas,r8a77965-cmm", - "renesas,rcar-gen3-cmm"; - reg = <0 0xfea50000 0 0x1000>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - clocks = <&cpg CPG_MOD 710>; - resets = <&cpg 710>; - }; - - cmm3: cmm@fea70000 { - compatible = "renesas,r8a77965-cmm", - "renesas,rcar-gen3-cmm"; - reg = <0 0xfea70000 0 0x1000>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - clocks = <&cpg CPG_MOD 708>; - resets = <&cpg 708>; - }; - - csi20: csi2@fea80000 { - compatible = "renesas,r8a77965-csi2"; - reg = <0 0xfea80000 0 0x10000>; - interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 714>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 714>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - csi20vin0: endpoint@0 { - reg = <0>; - remote-endpoint = <&vin0csi20>; - }; - csi20vin1: endpoint@1 { - reg = <1>; - remote-endpoint = <&vin1csi20>; - }; - csi20vin2: endpoint@2 { - reg = <2>; - remote-endpoint = <&vin2csi20>; - }; - csi20vin3: endpoint@3 { - reg = <3>; - remote-endpoint = <&vin3csi20>; - }; - csi20vin4: endpoint@4 { - reg = <4>; - remote-endpoint = <&vin4csi20>; - }; - csi20vin5: endpoint@5 { - reg = <5>; - remote-endpoint = <&vin5csi20>; - }; - csi20vin6: endpoint@6 { - reg = <6>; - remote-endpoint = <&vin6csi20>; - }; - csi20vin7: endpoint@7 { - reg = <7>; - remote-endpoint = <&vin7csi20>; - }; - }; - }; - }; - - csi40: csi2@feaa0000 { - compatible = "renesas,r8a77965-csi2"; - reg = <0 0xfeaa0000 0 0x10000>; - interrupts = <GIC_SPI 246 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 716>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 716>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - csi40vin0: endpoint@0 { - reg = <0>; - remote-endpoint = <&vin0csi40>; - }; - csi40vin1: endpoint@1 { - reg = <1>; - remote-endpoint = <&vin1csi40>; - }; - csi40vin2: endpoint@2 { - reg = <2>; - remote-endpoint = <&vin2csi40>; - }; - csi40vin3: endpoint@3 { - reg = <3>; - remote-endpoint = <&vin3csi40>; - }; - csi40vin4: endpoint@4 { - reg = <4>; - remote-endpoint = <&vin4csi40>; - }; - csi40vin5: endpoint@5 { - reg = <5>; - remote-endpoint = <&vin5csi40>; - }; - csi40vin6: endpoint@6 { - reg = <6>; - remote-endpoint = <&vin6csi40>; - }; - csi40vin7: endpoint@7 { - reg = <7>; - remote-endpoint = <&vin7csi40>; - }; - }; - }; - }; - - hdmi0: hdmi@fead0000 { - compatible = "renesas,r8a77965-hdmi", - "renesas,rcar-gen3-hdmi"; - reg = <0 0xfead0000 0 0x10000>; - interrupts = <GIC_SPI 389 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 729>, - <&cpg CPG_CORE R8A77965_CLK_HDMI>; - clock-names = "iahb", "isfr"; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 729>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - port@0 { - reg = <0>; - dw_hdmi0_in: endpoint { - remote-endpoint = <&du_out_hdmi0>; - }; - }; - port@1 { - reg = <1>; - }; - }; - }; - - du: display@feb00000 { - compatible = "renesas,du-r8a77965"; - reg = <0 0xfeb00000 0 0x80000>; - interrupts = <GIC_SPI 256 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 268 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 270 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 724>, <&cpg CPG_MOD 723>, - <&cpg CPG_MOD 721>; - clock-names = "du.0", "du.1", "du.3"; - resets = <&cpg 724>, <&cpg 722>; - reset-names = "du.0", "du.3"; - - renesas,cmms = <&cmm0>, <&cmm1>, <&cmm3>; - renesas,vsps = <&vspd0 0>, <&vspd1 0>, <&vspd0 1>; - - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - port@1 { - reg = <1>; - du_out_hdmi0: endpoint { - remote-endpoint = <&dw_hdmi0_in>; - }; - }; - port@2 { - reg = <2>; - du_out_lvds0: endpoint { - remote-endpoint = <&lvds0_in>; - }; - }; - }; - }; - - lvds0: lvds@feb90000 { - compatible = "renesas,r8a77965-lvds"; - reg = <0 0xfeb90000 0 0x14>; - clocks = <&cpg CPG_MOD 727>; - power-domains = <&sysc R8A77965_PD_ALWAYS_ON>; - resets = <&cpg 727>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - lvds0_in: endpoint { - remote-endpoint = <&du_out_lvds0>; - }; - }; - port@1 { - reg = <1>; - }; - }; - }; - - prr: chipid@fff00044 { - compatible = "renesas,prr"; - reg = <0 0xfff00044 0 4>; - }; - }; - - thermal-zones { - sensor1_thermal: sensor1-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - thermal-sensors = <&tsc 0>; - sustainable-power = <2439>; - - trips { - sensor1_crit: sensor1-crit { - temperature = <120000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - }; - - sensor2_thermal: sensor2-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - thermal-sensors = <&tsc 1>; - sustainable-power = <2439>; - - trips { - sensor2_crit: sensor2-crit { - temperature = <120000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - }; - - sensor3_thermal: sensor3-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - thermal-sensors = <&tsc 2>; - sustainable-power = <2439>; - - trips { - target: trip-point1 { - /* miliCelsius */ - temperature = <100000>; - hysteresis = <1000>; - type = "passive"; - }; - - sensor3_crit: sensor3-crit { - temperature = <120000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - - cooling-maps { - map0 { - trip = <&target>; - cooling-device = <&a57_0 2 4>; - contribution = <1024>; - }; - }; - }; - }; - - timer { - compatible = "arm,armv8-timer"; - interrupts-extended = <&gic GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>; - }; - - /* External USB clocks - can be overridden by the board */ - usb3s0_clk: usb3s0 { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - usb_extal_clk: usb_extal { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; -}; diff --git a/arch/arm/dts/r8a77970-eagle.dts b/arch/arm/dts/r8a77970-eagle.dts deleted file mode 100644 index 405404c0843..00000000000 --- a/arch/arm/dts/r8a77970-eagle.dts +++ /dev/null @@ -1,405 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the Eagle board with R-Car V3M - * - * Copyright (C) 2016-2017 Renesas Electronics Corp. - * Copyright (C) 2017 Cogent Embedded, Inc. - */ - -/dts-v1/; -#include "r8a77970.dtsi" -#include <dt-bindings/gpio/gpio.h> - -/ { - model = "Renesas Eagle board based on r8a77970"; - compatible = "renesas,eagle", "renesas,r8a77970"; - - aliases { - i2c0 = &i2c0; - i2c1 = &i2c1; - i2c2 = &i2c2; - i2c3 = &i2c3; - i2c4 = &i2c4; - serial0 = &scif0; - ethernet0 = &avb; - }; - - chosen { - bootargs = "ignore_loglevel rw root=/dev/nfs ip=on"; - stdout-path = "serial0:115200n8"; - }; - - d3p3: regulator-fixed { - compatible = "regulator-fixed"; - regulator-name = "fixed-3.3V"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - - hdmi-out { - compatible = "hdmi-connector"; - type = "a"; - - port { - hdmi_con_out: endpoint { - remote-endpoint = <&adv7511_out>; - }; - }; - }; - - lvds-decoder { - compatible = "thine,thc63lvd1024"; - - vcc-supply = <&d3p3>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - thc63lvd1024_in: endpoint { - remote-endpoint = <&lvds0_out>; - }; - }; - - port@2 { - reg = <2>; - thc63lvd1024_out: endpoint { - remote-endpoint = <&adv7511_in>; - }; - }; - }; - }; - - memory@48000000 { - device_type = "memory"; - /* first 128MB is reserved for secure area. */ - reg = <0x0 0x48000000 0x0 0x38000000>; - }; - - x1_clk: x1-clock { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <148500000>; - }; -}; - -&avb { - pinctrl-0 = <&avb_pins>; - pinctrl-names = "default"; - - renesas,no-ether-link; - phy-handle = <&phy0>; - rx-internal-delay-ps = <1800>; - tx-internal-delay-ps = <2000>; - status = "okay"; - - phy0: ethernet-phy@0 { - compatible = "ethernet-phy-id0022.1622", - "ethernet-phy-ieee802.3-c22"; - rxc-skew-ps = <1500>; - reg = <0>; - interrupt-parent = <&gpio1>; - interrupts = <17 IRQ_TYPE_LEVEL_LOW>; - reset-gpios = <&gpio1 16 GPIO_ACTIVE_LOW>; - }; -}; - -&canfd { - pinctrl-0 = <&canfd0_pins>; - pinctrl-names = "default"; - status = "okay"; - - channel0 { - status = "okay"; - }; -}; - -&csi40 { - status = "okay"; - - ports { - port@0 { - csi40_in: endpoint { - clock-lanes = <0>; - data-lanes = <1 2 3 4>; - remote-endpoint = <&max9286_out0>; - }; - }; - }; -}; - -&du { - clocks = <&cpg CPG_MOD 724>, <&x1_clk>; - clock-names = "du.0", "dclkin.0"; - status = "okay"; -}; - -&extal_clk { - clock-frequency = <16666666>; -}; - -&extalr_clk { - clock-frequency = <32768>; -}; - -&i2c0 { - pinctrl-0 = <&i2c0_pins>; - pinctrl-names = "default"; - - status = "okay"; - clock-frequency = <400000>; - - io_expander: gpio@20 { - compatible = "onnn,pca9654"; - reg = <0x20>; - gpio-controller; - #gpio-cells = <2>; - }; - - hdmi@39 { - compatible = "adi,adv7511w"; - reg = <0x39>; - interrupt-parent = <&gpio1>; - interrupts = <20 IRQ_TYPE_LEVEL_LOW>; - - adi,input-depth = <8>; - adi,input-colorspace = "rgb"; - adi,input-clock = "1x"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - adv7511_in: endpoint { - remote-endpoint = <&thc63lvd1024_out>; - }; - }; - - port@1 { - reg = <1>; - adv7511_out: endpoint { - remote-endpoint = <&hdmi_con_out>; - }; - }; - }; - }; -}; - -&i2c3 { - pinctrl-0 = <&i2c3_pins>; - pinctrl-names = "default"; - - status = "okay"; - clock-frequency = <400000>; - - gmsl0: gmsl-deserializer@48 { - compatible = "maxim,max9286"; - reg = <0x48>; - - maxim,gpio-poc = <0 GPIO_ACTIVE_LOW>; - enable-gpios = <&io_expander 0 GPIO_ACTIVE_HIGH>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - - port@1 { - reg = <1>; - }; - - port@2 { - reg = <2>; - }; - - port@3 { - reg = <3>; - }; - - port@4 { - reg = <4>; - max9286_out0: endpoint { - clock-lanes = <0>; - data-lanes = <1 2 3 4>; - remote-endpoint = <&csi40_in>; - }; - }; - }; - - i2c-mux { - #address-cells = <1>; - #size-cells = <0>; - - i2c@0 { - #address-cells = <1>; - #size-cells = <0>; - reg = <0>; - - status = "disabled"; - }; - - i2c@1 { - #address-cells = <1>; - #size-cells = <0>; - reg = <1>; - - status = "disabled"; - }; - - i2c@2 { - #address-cells = <1>; - #size-cells = <0>; - reg = <2>; - - status = "disabled"; - }; - - i2c@3 { - #address-cells = <1>; - #size-cells = <0>; - reg = <3>; - - status = "disabled"; - }; - }; - }; -}; - -&lvds0 { - status = "okay"; - - ports { - port@1 { - lvds0_out: endpoint { - remote-endpoint = <&thc63lvd1024_in>; - }; - }; - }; -}; - -&pfc { - pinctrl-0 = <&scif_clk_pins>; - pinctrl-names = "default"; - - avb_pins: avb0 { - groups = "avb0_mdio", "avb0_rgmii", "avb0_txcrefclk"; - function = "avb0"; - }; - - canfd0_pins: canfd0 { - groups = "canfd0_data_a"; - function = "canfd0"; - }; - - i2c0_pins: i2c0 { - groups = "i2c0"; - function = "i2c0"; - }; - - i2c3_pins: i2c3 { - groups = "i2c3_a"; - function = "i2c3"; - }; - - qspi0_pins: qspi0 { - groups = "qspi0_ctrl", "qspi0_data4"; - function = "qspi0"; - }; - - scif0_pins: scif0 { - groups = "scif0_data"; - function = "scif0"; - }; - - scif_clk_pins: scif_clk { - groups = "scif_clk_b"; - function = "scif_clk"; - }; -}; - -&rpc { - pinctrl-0 = <&qspi0_pins>; - pinctrl-names = "default"; - - status = "okay"; - - flash@0 { - compatible = "spansion,s25fs512s", "jedec,spi-nor"; - reg = <0>; - spi-max-frequency = <50000000>; - spi-rx-bus-width = <4>; - - partitions { - compatible = "fixed-partitions"; - #address-cells = <1>; - #size-cells = <1>; - - bootparam@0 { - reg = <0x00000000 0x040000>; - read-only; - }; - cr7@40000 { - reg = <0x00040000 0x080000>; - read-only; - }; - cert_header_sa3@c0000 { - reg = <0x000c0000 0x080000>; - read-only; - }; - bl2@140000 { - reg = <0x00140000 0x040000>; - read-only; - }; - cert_header_sa6@180000 { - reg = <0x00180000 0x040000>; - read-only; - }; - bl31@1c0000 { - reg = <0x001c0000 0x460000>; - read-only; - }; - uboot@640000 { - reg = <0x00640000 0x0c0000>; - read-only; - }; - uboot-env@700000 { - reg = <0x00700000 0x040000>; - read-only; - }; - dtb@740000 { - reg = <0x00740000 0x080000>; - }; - kernel@7c0000 { - reg = <0x007c0000 0x1400000>; - }; - user@1bc0000 { - reg = <0x01bc0000 0x2440000>; - }; - }; - }; -}; - -&rwdt { - timeout-sec = <60>; - status = "okay"; -}; - -&scif0 { - pinctrl-0 = <&scif0_pins>; - pinctrl-names = "default"; - - status = "okay"; -}; - -&scif_clk { - clock-frequency = <14745600>; -}; diff --git a/arch/arm/dts/r8a77970-v3msk.dts b/arch/arm/dts/r8a77970-v3msk.dts deleted file mode 100644 index e36999e91af..00000000000 --- a/arch/arm/dts/r8a77970-v3msk.dts +++ /dev/null @@ -1,303 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the V3M Starter Kit board - * - * Copyright (C) 2017 Renesas Electronics Corp. - * Copyright (C) 2017 Cogent Embedded, Inc. - */ - -/dts-v1/; -#include "r8a77970.dtsi" -#include <dt-bindings/gpio/gpio.h> - -/ { - model = "Renesas V3M Starter Kit board"; - compatible = "renesas,v3msk", "renesas,r8a77970"; - - aliases { - i2c0 = &i2c0; - i2c1 = &i2c1; - i2c2 = &i2c2; - i2c3 = &i2c3; - i2c4 = &i2c4; - serial0 = &scif0; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - hdmi-out { - compatible = "hdmi-connector"; - type = "a"; - - port { - hdmi_con: endpoint { - remote-endpoint = <&adv7511_out>; - }; - }; - }; - - lvds-decoder { - compatible = "thine,thc63lvd1024"; - vcc-supply = <&vcc_d3_3v>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - thc63lvd1024_in: endpoint { - remote-endpoint = <&lvds0_out>; - }; - }; - - port@2 { - reg = <2>; - thc63lvd1024_out: endpoint { - remote-endpoint = <&adv7511_in>; - }; - }; - }; - }; - - memory@48000000 { - device_type = "memory"; - /* first 128MB is reserved for secure area. */ - reg = <0x0 0x48000000 0x0 0x78000000>; - }; - - osc5_clk: osc5-clock { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <148500000>; - }; - - vcc_d1_8v: regulator-0 { - compatible = "regulator-fixed"; - regulator-name = "VCC_D1.8V"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-boot-on; - regulator-always-on; - }; - - vcc_d3_3v: regulator-1 { - compatible = "regulator-fixed"; - regulator-name = "VCC_D3.3V"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - - vcc_vddq_vin0: regulator-2 { - compatible = "regulator-fixed"; - regulator-name = "VCC_VDDQ_VIN0"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; -}; - -&avb { - pinctrl-0 = <&avb_pins>; - pinctrl-names = "default"; - - renesas,no-ether-link; - phy-handle = <&phy0>; - rx-internal-delay-ps = <1800>; - tx-internal-delay-ps = <2000>; - status = "okay"; - - phy0: ethernet-phy@0 { - compatible = "ethernet-phy-id0022.1622", - "ethernet-phy-ieee802.3-c22"; - rxc-skew-ps = <1500>; - reg = <0>; - interrupt-parent = <&gpio1>; - interrupts = <17 IRQ_TYPE_LEVEL_LOW>; - reset-gpios = <&gpio1 16 GPIO_ACTIVE_LOW>; - }; -}; - -&du { - clocks = <&cpg CPG_MOD 724>, - <&osc5_clk>; - clock-names = "du.0", "dclkin.0"; - status = "okay"; -}; - -&extal_clk { - clock-frequency = <16666666>; -}; - -&extalr_clk { - clock-frequency = <32768>; -}; - -&i2c0 { - pinctrl-0 = <&i2c0_pins>; - pinctrl-names = "default"; - - status = "okay"; - clock-frequency = <400000>; - - hdmi@39 { - compatible = "adi,adv7511w"; - #sound-dai-cells = <0>; - reg = <0x39>; - interrupt-parent = <&gpio1>; - interrupts = <20 IRQ_TYPE_LEVEL_LOW>; - avdd-supply = <&vcc_d1_8v>; - dvdd-supply = <&vcc_d1_8v>; - pvdd-supply = <&vcc_d1_8v>; - bgvdd-supply = <&vcc_d1_8v>; - dvdd-3v-supply = <&vcc_d3_3v>; - - adi,input-depth = <8>; - adi,input-colorspace = "rgb"; - adi,input-clock = "1x"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - adv7511_in: endpoint { - remote-endpoint = <&thc63lvd1024_out>; - }; - }; - - port@1 { - reg = <1>; - adv7511_out: endpoint { - remote-endpoint = <&hdmi_con>; - }; - }; - }; - }; -}; - -&lvds0 { - status = "okay"; - - ports { - port@1 { - lvds0_out: endpoint { - remote-endpoint = <&thc63lvd1024_in>; - }; - }; - }; -}; - -&mmc0 { - pinctrl-0 = <&mmc_pins>; - pinctrl-names = "default"; - - vmmc-supply = <&vcc_d3_3v>; - vqmmc-supply = <&vcc_vddq_vin0>; - bus-width = <8>; - non-removable; - status = "okay"; -}; - -&pfc { - avb_pins: avb0 { - groups = "avb0_mdio", "avb0_rgmii", "avb0_txcrefclk"; - function = "avb0"; - }; - - i2c0_pins: i2c0 { - groups = "i2c0"; - function = "i2c0"; - }; - - mmc_pins: mmc_3_3v { - groups = "mmc_data8", "mmc_ctrl"; - function = "mmc"; - power-source = <3300>; - }; - - qspi0_pins: qspi0 { - groups = "qspi0_ctrl", "qspi0_data4"; - function = "qspi0"; - }; - - scif0_pins: scif0 { - groups = "scif0_data"; - function = "scif0"; - }; -}; - -&rpc { - pinctrl-0 = <&qspi0_pins>; - pinctrl-names = "default"; - - status = "okay"; - - flash@0 { - compatible = "spansion,s25fs512s", "jedec,spi-nor"; - reg = <0>; - spi-max-frequency = <50000000>; - spi-rx-bus-width = <4>; - - partitions { - compatible = "fixed-partitions"; - #address-cells = <1>; - #size-cells = <1>; - - bootparam@0 { - reg = <0x00000000 0x040000>; - read-only; - }; - cr7@40000 { - reg = <0x00040000 0x080000>; - read-only; - }; - cert_header_sa3@c0000 { - reg = <0x000c0000 0x080000>; - read-only; - }; - bl2@140000 { - reg = <0x00140000 0x040000>; - read-only; - }; - cert_header_sa6@180000 { - reg = <0x00180000 0x040000>; - read-only; - }; - bl31@1c0000 { - reg = <0x001c0000 0x460000>; - read-only; - }; - uboot@640000 { - reg = <0x00640000 0x0c0000>; - read-only; - }; - uboot-env@700000 { - reg = <0x00700000 0x040000>; - read-only; - }; - dtb@740000 { - reg = <0x00740000 0x080000>; - }; - kernel@7c0000 { - reg = <0x007c0000 0x1400000>; - }; - user@1bc0000 { - reg = <0x01bc0000 0x2440000>; - }; - }; - }; -}; - -&scif0 { - pinctrl-0 = <&scif0_pins>; - pinctrl-names = "default"; - - status = "okay"; -}; diff --git a/arch/arm/dts/r8a77970.dtsi b/arch/arm/dts/r8a77970.dtsi deleted file mode 100644 index ed6e2e47c60..00000000000 --- a/arch/arm/dts/r8a77970.dtsi +++ /dev/null @@ -1,1220 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the R-Car V3M (R8A77970) SoC - * - * Copyright (C) 2016-2017 Renesas Electronics Corp. - * Copyright (C) 2017 Cogent Embedded, Inc. - */ - -#include <dt-bindings/clock/r8a77970-cpg-mssr.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/power/r8a77970-sysc.h> - -/ { - compatible = "renesas,r8a77970"; - #address-cells = <2>; - #size-cells = <2>; - - /* External CAN clock - to be overridden by boards that provide it */ - can_clk: can { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - - a53_0: cpu@0 { - device_type = "cpu"; - compatible = "arm,cortex-a53"; - reg = <0>; - clocks = <&cpg CPG_CORE R8A77970_CLK_Z2>; - power-domains = <&sysc R8A77970_PD_CA53_CPU0>; - next-level-cache = <&L2_CA53>; - enable-method = "psci"; - }; - - a53_1: cpu@1 { - device_type = "cpu"; - compatible = "arm,cortex-a53"; - reg = <1>; - clocks = <&cpg CPG_CORE R8A77970_CLK_Z2>; - power-domains = <&sysc R8A77970_PD_CA53_CPU1>; - next-level-cache = <&L2_CA53>; - enable-method = "psci"; - }; - - L2_CA53: cache-controller { - compatible = "cache"; - power-domains = <&sysc R8A77970_PD_CA53_SCU>; - cache-unified; - cache-level = <2>; - }; - }; - - extal_clk: extal { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board */ - clock-frequency = <0>; - }; - - extalr_clk: extalr { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board */ - clock-frequency = <0>; - }; - - pmu_a53 { - compatible = "arm,cortex-a53-pmu"; - interrupts-extended = <&gic GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&a53_0>, <&a53_1>; - }; - - psci { - compatible = "arm,psci-1.0", "arm,psci-0.2"; - method = "smc"; - }; - - /* External SCIF clock - to be overridden by boards that provide it */ - scif_clk: scif { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - soc { - compatible = "simple-bus"; - interrupt-parent = <&gic>; - - #address-cells = <2>; - #size-cells = <2>; - ranges; - - rwdt: watchdog@e6020000 { - compatible = "renesas,r8a77970-wdt", - "renesas,rcar-gen3-wdt"; - reg = <0 0xe6020000 0 0x0c>; - interrupts = <GIC_SPI 140 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 402>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 402>; - status = "disabled"; - }; - - gpio0: gpio@e6050000 { - compatible = "renesas,gpio-r8a77970", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6050000 0 0x50>; - interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 0 22>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 912>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 912>; - }; - - gpio1: gpio@e6051000 { - compatible = "renesas,gpio-r8a77970", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6051000 0 0x50>; - interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 32 28>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 911>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 911>; - }; - - gpio2: gpio@e6052000 { - compatible = "renesas,gpio-r8a77970", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6052000 0 0x50>; - interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 64 17>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 910>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 910>; - }; - - gpio3: gpio@e6053000 { - compatible = "renesas,gpio-r8a77970", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6053000 0 0x50>; - interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 96 17>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 909>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 909>; - }; - - gpio4: gpio@e6054000 { - compatible = "renesas,gpio-r8a77970", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6054000 0 0x50>; - interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 128 6>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 908>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 908>; - }; - - gpio5: gpio@e6055000 { - compatible = "renesas,gpio-r8a77970", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6055000 0 0x50>; - interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 160 15>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 907>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 907>; - }; - - pfc: pinctrl@e6060000 { - compatible = "renesas,pfc-r8a77970"; - reg = <0 0xe6060000 0 0x504>; - }; - - cmt0: timer@e60f0000 { - compatible = "renesas,r8a77970-cmt0", - "renesas,rcar-gen3-cmt0"; - reg = <0 0xe60f0000 0 0x1004>; - interrupts = <GIC_SPI 142 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 143 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 303>; - clock-names = "fck"; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 303>; - status = "disabled"; - }; - - cmt1: timer@e6130000 { - compatible = "renesas,r8a77970-cmt1", - "renesas,rcar-gen3-cmt1"; - reg = <0 0xe6130000 0 0x1004>; - interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 127 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 302>; - clock-names = "fck"; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 302>; - status = "disabled"; - }; - - cmt2: timer@e6140000 { - compatible = "renesas,r8a77970-cmt1", - "renesas,rcar-gen3-cmt1"; - reg = <0 0xe6140000 0 0x1004>; - interrupts = <GIC_SPI 258 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 259 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 260 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 261 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 262 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 263 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 264 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 265 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 301>; - clock-names = "fck"; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 301>; - status = "disabled"; - }; - - cmt3: timer@e6148000 { - compatible = "renesas,r8a77970-cmt1", - "renesas,rcar-gen3-cmt1"; - reg = <0 0xe6148000 0 0x1004>; - interrupts = <GIC_SPI 273 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 274 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 275 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 276 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 277 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 278 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 279 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 280 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 300>; - clock-names = "fck"; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 300>; - status = "disabled"; - }; - - cpg: clock-controller@e6150000 { - compatible = "renesas,r8a77970-cpg-mssr"; - reg = <0 0xe6150000 0 0x1000>; - clocks = <&extal_clk>, <&extalr_clk>; - clock-names = "extal", "extalr"; - #clock-cells = <2>; - #power-domain-cells = <0>; - #reset-cells = <1>; - }; - - rst: reset-controller@e6160000 { - compatible = "renesas,r8a77970-rst"; - reg = <0 0xe6160000 0 0x200>; - }; - - sysc: system-controller@e6180000 { - compatible = "renesas,r8a77970-sysc"; - reg = <0 0xe6180000 0 0x440>; - #power-domain-cells = <1>; - }; - - thermal: thermal@e6190000 { - compatible = "renesas,thermal-r8a77970"; - reg = <0 0xe6190000 0 0x10>, - <0 0xe6190100 0 0x120>; - interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 522>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 522>; - #thermal-sensor-cells = <0>; - }; - - intc_ex: interrupt-controller@e61c0000 { - compatible = "renesas,intc-ex-r8a77970", "renesas,irqc"; - #interrupt-cells = <2>; - interrupt-controller; - reg = <0 0xe61c0000 0 0x200>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 161 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 407>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 407>; - }; - - tmu0: timer@e61e0000 { - compatible = "renesas,tmu-r8a77970", "renesas,tmu"; - reg = <0 0xe61e0000 0 0x30>; - interrupts = <GIC_SPI 136 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 137 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 138 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 125>; - clock-names = "fck"; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 125>; - status = "disabled"; - }; - - tmu1: timer@e6fc0000 { - compatible = "renesas,tmu-r8a77970", "renesas,tmu"; - reg = <0 0xe6fc0000 0 0x30>; - interrupts = <GIC_SPI 128 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 129 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 130 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 124>; - clock-names = "fck"; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 124>; - status = "disabled"; - }; - - tmu2: timer@e6fd0000 { - compatible = "renesas,tmu-r8a77970", "renesas,tmu"; - reg = <0 0xe6fd0000 0 0x30>; - interrupts = <GIC_SPI 303 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 304 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 305 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 123>; - clock-names = "fck"; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 123>; - status = "disabled"; - }; - - tmu3: timer@e6fe0000 { - compatible = "renesas,tmu-r8a77970", "renesas,tmu"; - reg = <0 0xe6fe0000 0 0x30>; - interrupts = <GIC_SPI 131 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 132 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 133 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 122>; - clock-names = "fck"; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 122>; - status = "disabled"; - }; - - tmu4: timer@ffc00000 { - compatible = "renesas,tmu-r8a77970", "renesas,tmu"; - reg = <0 0xffc00000 0 0x30>; - interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 121>; - clock-names = "fck"; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 121>; - status = "disabled"; - }; - - i2c0: i2c@e6500000 { - compatible = "renesas,i2c-r8a77970", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6500000 0 0x40>; - interrupts = <GIC_SPI 287 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 931>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 931>; - dmas = <&dmac1 0x91>, <&dmac1 0x90>, - <&dmac2 0x91>, <&dmac2 0x90>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c1: i2c@e6508000 { - compatible = "renesas,i2c-r8a77970", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6508000 0 0x40>; - interrupts = <GIC_SPI 288 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 930>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 930>; - dmas = <&dmac1 0x93>, <&dmac1 0x92>, - <&dmac2 0x93>, <&dmac2 0x92>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c2: i2c@e6510000 { - compatible = "renesas,i2c-r8a77970", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6510000 0 0x40>; - interrupts = <GIC_SPI 286 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 929>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 929>; - dmas = <&dmac1 0x95>, <&dmac1 0x94>, - <&dmac2 0x95>, <&dmac2 0x94>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c3: i2c@e66d0000 { - compatible = "renesas,i2c-r8a77970", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66d0000 0 0x40>; - interrupts = <GIC_SPI 290 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 928>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 928>; - dmas = <&dmac1 0x97>, <&dmac1 0x96>, - <&dmac2 0x97>, <&dmac2 0x96>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c4: i2c@e66d8000 { - compatible = "renesas,i2c-r8a77970", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66d8000 0 0x40>; - interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 927>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 927>; - dmas = <&dmac1 0x99>, <&dmac1 0x98>, - <&dmac2 0x99>, <&dmac2 0x98>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - hscif0: serial@e6540000 { - compatible = "renesas,hscif-r8a77970", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe6540000 0 96>; - interrupts = <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 520>, - <&cpg CPG_CORE R8A77970_CLK_S2D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x31>, <&dmac1 0x30>, - <&dmac2 0x31>, <&dmac2 0x30>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 520>; - status = "disabled"; - }; - - hscif1: serial@e6550000 { - compatible = "renesas,hscif-r8a77970", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe6550000 0 96>; - interrupts = <GIC_SPI 155 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 519>, - <&cpg CPG_CORE R8A77970_CLK_S2D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x33>, <&dmac1 0x32>, - <&dmac2 0x33>, <&dmac2 0x32>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 519>; - status = "disabled"; - }; - - hscif2: serial@e6560000 { - compatible = "renesas,hscif-r8a77970", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe6560000 0 96>; - interrupts = <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 518>, - <&cpg CPG_CORE R8A77970_CLK_S2D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x35>, <&dmac1 0x34>, - <&dmac2 0x35>, <&dmac2 0x34>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 518>; - status = "disabled"; - }; - - hscif3: serial@e66a0000 { - compatible = "renesas,hscif-r8a77970", - "renesas,rcar-gen3-hscif", "renesas,hscif"; - reg = <0 0xe66a0000 0 96>; - interrupts = <GIC_SPI 145 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 517>, - <&cpg CPG_CORE R8A77970_CLK_S2D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x37>, <&dmac1 0x36>, - <&dmac2 0x37>, <&dmac2 0x36>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 517>; - status = "disabled"; - }; - - canfd: can@e66c0000 { - compatible = "renesas,r8a77970-canfd", - "renesas,rcar-gen3-canfd"; - reg = <0 0xe66c0000 0 0x8000>; - interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch_int", "g_int"; - clocks = <&cpg CPG_MOD 914>, - <&cpg CPG_CORE R8A77970_CLK_CANFD>, - <&can_clk>; - clock-names = "fck", "canfd", "can_clk"; - assigned-clocks = <&cpg CPG_CORE R8A77970_CLK_CANFD>; - assigned-clock-rates = <40000000>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 914>; - status = "disabled"; - - channel0 { - status = "disabled"; - }; - - channel1 { - status = "disabled"; - }; - }; - - avb: ethernet@e6800000 { - compatible = "renesas,etheravb-r8a77970", - "renesas,etheravb-rcar-gen3"; - reg = <0 0xe6800000 0 0x800>; - interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 47 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 63 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15", - "ch16", "ch17", "ch18", "ch19", - "ch20", "ch21", "ch22", "ch23", - "ch24"; - clocks = <&cpg CPG_MOD 812>; - clock-names = "fck"; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 812>; - phy-mode = "rgmii"; - rx-internal-delay-ps = <0>; - tx-internal-delay-ps = <0>; - iommus = <&ipmmu_rt 3>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - pwm0: pwm@e6e30000 { - compatible = "renesas,pwm-r8a77970", "renesas,pwm-rcar"; - reg = <0 0xe6e30000 0 8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 523>; - status = "disabled"; - }; - - pwm1: pwm@e6e31000 { - compatible = "renesas,pwm-r8a77970", "renesas,pwm-rcar"; - reg = <0 0xe6e31000 0 8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 523>; - status = "disabled"; - }; - - pwm2: pwm@e6e32000 { - compatible = "renesas,pwm-r8a77970", "renesas,pwm-rcar"; - reg = <0 0xe6e32000 0 8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 523>; - status = "disabled"; - }; - - pwm3: pwm@e6e33000 { - compatible = "renesas,pwm-r8a77970", "renesas,pwm-rcar"; - reg = <0 0xe6e33000 0 8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 523>; - status = "disabled"; - }; - - pwm4: pwm@e6e34000 { - compatible = "renesas,pwm-r8a77970", "renesas,pwm-rcar"; - reg = <0 0xe6e34000 0 8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 523>; - status = "disabled"; - }; - - scif0: serial@e6e60000 { - compatible = "renesas,scif-r8a77970", - "renesas,rcar-gen3-scif", - "renesas,scif"; - reg = <0 0xe6e60000 0 64>; - interrupts = <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 207>, - <&cpg CPG_CORE R8A77970_CLK_S2D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x51>, <&dmac1 0x50>, - <&dmac2 0x51>, <&dmac2 0x50>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 207>; - status = "disabled"; - }; - - scif1: serial@e6e68000 { - compatible = "renesas,scif-r8a77970", - "renesas,rcar-gen3-scif", - "renesas,scif"; - reg = <0 0xe6e68000 0 64>; - interrupts = <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 206>, - <&cpg CPG_CORE R8A77970_CLK_S2D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x53>, <&dmac1 0x52>, - <&dmac2 0x53>, <&dmac2 0x52>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 206>; - status = "disabled"; - }; - - scif3: serial@e6c50000 { - compatible = "renesas,scif-r8a77970", - "renesas,rcar-gen3-scif", - "renesas,scif"; - reg = <0 0xe6c50000 0 64>; - interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 204>, - <&cpg CPG_CORE R8A77970_CLK_S2D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x57>, <&dmac1 0x56>, - <&dmac2 0x57>, <&dmac2 0x56>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 204>; - status = "disabled"; - }; - - scif4: serial@e6c40000 { - compatible = "renesas,scif-r8a77970", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6c40000 0 64>; - interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 203>, - <&cpg CPG_CORE R8A77970_CLK_S2D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x59>, <&dmac1 0x58>, - <&dmac2 0x59>, <&dmac2 0x58>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 203>; - status = "disabled"; - }; - - tpu: pwm@e6e80000 { - compatible = "renesas,tpu-r8a77970", "renesas,tpu"; - reg = <0 0xe6e80000 0 0x148>; - interrupts = <GIC_SPI 135 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 304>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 304>; - #pwm-cells = <3>; - status = "disabled"; - }; - - msiof0: spi@e6e90000 { - compatible = "renesas,msiof-r8a77970", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6e90000 0 0x64>; - interrupts = <GIC_SPI 156 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 211>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 211>; - dmas = <&dmac1 0x41>, <&dmac1 0x40>, - <&dmac2 0x41>, <&dmac2 0x40>; - dma-names = "tx", "rx", "tx", "rx"; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof1: spi@e6ea0000 { - compatible = "renesas,msiof-r8a77970", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6ea0000 0 0x0064>; - interrupts = <GIC_SPI 157 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 210>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 210>; - dmas = <&dmac1 0x43>, <&dmac1 0x42>, - <&dmac2 0x43>, <&dmac2 0x42>; - dma-names = "tx", "rx", "tx", "rx"; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof2: spi@e6c00000 { - compatible = "renesas,msiof-r8a77970", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6c00000 0 0x0064>; - interrupts = <GIC_SPI 158 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 209>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 209>; - dmas = <&dmac1 0x45>, <&dmac1 0x44>, - <&dmac2 0x45>, <&dmac2 0x44>; - dma-names = "tx", "rx", "tx", "rx"; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof3: spi@e6c10000 { - compatible = "renesas,msiof-r8a77970", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6c10000 0 0x0064>; - interrupts = <GIC_SPI 159 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 208>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 208>; - dmas = <&dmac1 0x47>, <&dmac1 0x46>, - <&dmac2 0x47>, <&dmac2 0x46>; - dma-names = "tx", "rx", "tx", "rx"; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - vin0: video@e6ef0000 { - compatible = "renesas,vin-r8a77970"; - reg = <0 0xe6ef0000 0 0x1000>; - interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 811>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 811>; - renesas,id = <0>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin0csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin0>; - }; - }; - }; - }; - - vin1: video@e6ef1000 { - compatible = "renesas,vin-r8a77970"; - reg = <0 0xe6ef1000 0 0x1000>; - interrupts = <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 810>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 810>; - renesas,id = <1>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin1csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin1>; - }; - }; - }; - }; - - vin2: video@e6ef2000 { - compatible = "renesas,vin-r8a77970"; - reg = <0 0xe6ef2000 0 0x1000>; - interrupts = <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 809>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 809>; - renesas,id = <2>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin2csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin2>; - }; - }; - }; - }; - - vin3: video@e6ef3000 { - compatible = "renesas,vin-r8a77970"; - reg = <0 0xe6ef3000 0 0x1000>; - interrupts = <GIC_SPI 191 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 808>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 808>; - renesas,id = <3>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin3csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin3>; - }; - }; - }; - }; - - dmac1: dma-controller@e7300000 { - compatible = "renesas,dmac-r8a77970", - "renesas,rcar-dmac"; - reg = <0 0xe7300000 0 0x10000>; - interrupts = <GIC_SPI 220 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 216 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 217 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 218 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 219 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 308 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 309 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 310 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 311 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7"; - clocks = <&cpg CPG_MOD 218>; - clock-names = "fck"; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 218>; - #dma-cells = <1>; - dma-channels = <8>; - iommus = <&ipmmu_ds1 0>, <&ipmmu_ds1 1>, - <&ipmmu_ds1 2>, <&ipmmu_ds1 3>, - <&ipmmu_ds1 4>, <&ipmmu_ds1 5>, - <&ipmmu_ds1 6>, <&ipmmu_ds1 7>; - }; - - dmac2: dma-controller@e7310000 { - compatible = "renesas,dmac-r8a77970", - "renesas,rcar-dmac"; - reg = <0 0xe7310000 0 0x10000>; - interrupts = <GIC_SPI 307 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 312 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 313 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 314 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 315 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 316 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 317 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 318 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 319 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7"; - clocks = <&cpg CPG_MOD 217>; - clock-names = "fck"; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 217>; - #dma-cells = <1>; - dma-channels = <8>; - iommus = <&ipmmu_ds1 16>, <&ipmmu_ds1 17>, - <&ipmmu_ds1 18>, <&ipmmu_ds1 19>, - <&ipmmu_ds1 20>, <&ipmmu_ds1 21>, - <&ipmmu_ds1 22>, <&ipmmu_ds1 23>; - }; - - ipmmu_ds1: iommu@e7740000 { - compatible = "renesas,ipmmu-r8a77970"; - reg = <0 0xe7740000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 0>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_ir: iommu@ff8b0000 { - compatible = "renesas,ipmmu-r8a77970"; - reg = <0 0xff8b0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 3>; - power-domains = <&sysc R8A77970_PD_A3IR>; - #iommu-cells = <1>; - }; - - ipmmu_mm: iommu@e67b0000 { - compatible = "renesas,ipmmu-r8a77970"; - reg = <0 0xe67b0000 0 0x1000>; - interrupts = <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_rt: iommu@ffc80000 { - compatible = "renesas,ipmmu-r8a77970"; - reg = <0 0xffc80000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 7>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_vi0: iommu@febd0000 { - compatible = "renesas,ipmmu-r8a77970"; - reg = <0 0xfebd0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 9>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - mmc0: mmc@ee140000 { - compatible = "renesas,sdhi-r8a77970", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee140000 0 0x2000>; - interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 314>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 314>; - max-frequency = <200000000>; - iommus = <&ipmmu_ds1 32>; - status = "disabled"; - }; - - rpc: spi@ee200000 { - compatible = "renesas,r8a77970-rpc-if", - "renesas,rcar-gen3-rpc-if"; - reg = <0 0xee200000 0 0x200>, - <0 0x08000000 0 0x4000000>, - <0 0xee208000 0 0x100>; - reg-names = "regs", "dirmap", "wbuf"; - interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 917>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 917>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - gic: interrupt-controller@f1010000 { - compatible = "arm,gic-400"; - #interrupt-cells = <3>; - #address-cells = <0>; - interrupt-controller; - reg = <0 0xf1010000 0 0x1000>, - <0 0xf1020000 0 0x20000>, - <0 0xf1040000 0 0x20000>, - <0 0xf1060000 0 0x20000>; - interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(2) | - IRQ_TYPE_LEVEL_HIGH)>; - clocks = <&cpg CPG_MOD 408>; - clock-names = "clk"; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 408>; - }; - - vspd0: vsp@fea20000 { - compatible = "renesas,vsp2"; - reg = <0 0xfea20000 0 0x5000>; - interrupts = <GIC_SPI 169 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 623>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 623>; - renesas,fcp = <&fcpvd0>; - }; - - fcpvd0: fcp@fea27000 { - compatible = "renesas,fcpv"; - reg = <0 0xfea27000 0 0x200>; - clocks = <&cpg CPG_MOD 603>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 603>; - }; - - csi40: csi2@feaa0000 { - compatible = "renesas,r8a77970-csi2"; - reg = <0 0xfeaa0000 0 0x10000>; - interrupts = <GIC_SPI 246 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 716>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 716>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - csi40vin0: endpoint@0 { - reg = <0>; - remote-endpoint = <&vin0csi40>; - }; - csi40vin1: endpoint@1 { - reg = <1>; - remote-endpoint = <&vin1csi40>; - }; - csi40vin2: endpoint@2 { - reg = <2>; - remote-endpoint = <&vin2csi40>; - }; - csi40vin3: endpoint@3 { - reg = <3>; - remote-endpoint = <&vin3csi40>; - }; - }; - }; - }; - - du: display@feb00000 { - compatible = "renesas,du-r8a77970"; - reg = <0 0xfeb00000 0 0x80000>; - interrupts = <GIC_SPI 256 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 724>; - clock-names = "du.0"; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 724>; - reset-names = "du.0"; - renesas,vsps = <&vspd0 0>; - - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - - port@1 { - reg = <1>; - du_out_lvds0: endpoint { - remote-endpoint = <&lvds0_in>; - }; - }; - }; - }; - - lvds0: lvds-encoder@feb90000 { - compatible = "renesas,r8a77970-lvds"; - reg = <0 0xfeb90000 0 0x14>; - clocks = <&cpg CPG_MOD 727>; - power-domains = <&sysc R8A77970_PD_ALWAYS_ON>; - resets = <&cpg 727>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - lvds0_in: endpoint { - remote-endpoint = - <&du_out_lvds0>; - }; - }; - port@1 { - reg = <1>; - }; - }; - }; - - prr: chipid@fff00044 { - compatible = "renesas,prr"; - reg = <0 0xfff00044 0 4>; - }; - }; - - thermal-zones { - cpu-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - thermal-sensors = <&thermal>; - - cooling-maps { - }; - - trips { - cpu-crit { - temperature = <120000>; - hysteresis = <2000>; - type = "critical"; - }; - }; - }; - }; - - timer { - compatible = "arm,armv8-timer"; - interrupts-extended = <&gic GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>; - }; -}; diff --git a/arch/arm/dts/r8a77980-condor.dts b/arch/arm/dts/r8a77980-condor.dts deleted file mode 100644 index 68d1f1d53b3..00000000000 --- a/arch/arm/dts/r8a77980-condor.dts +++ /dev/null @@ -1,24 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the Condor board with R-Car V3H - * - * Copyright (C) 2018 Renesas Electronics Corp. - * Copyright (C) 2018 Cogent Embedded, Inc. - */ - -/dts-v1/; -#include "r8a77980.dtsi" -#include "condor-common.dtsi" - -/ { - model = "Renesas Condor board based on r8a77980"; - compatible = "renesas,condor", "renesas,r8a77980"; -}; - -&i2c0 { - eeprom@50 { - compatible = "rohm,br24t01", "atmel,24c01"; - reg = <0x50>; - pagesize = <8>; - }; -}; diff --git a/arch/arm/dts/r8a77980-v3hsk.dts b/arch/arm/dts/r8a77980-v3hsk.dts deleted file mode 100644 index 77d22df25ff..00000000000 --- a/arch/arm/dts/r8a77980-v3hsk.dts +++ /dev/null @@ -1,293 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the V3H Starter Kit board - * - * Copyright (C) 2018 Renesas Electronics Corp. - * Copyright (C) 2018 Cogent Embedded, Inc. - */ - -/dts-v1/; -#include "r8a77980.dtsi" -#include <dt-bindings/gpio/gpio.h> - -/ { - model = "Renesas V3H Starter Kit board"; - compatible = "renesas,v3hsk", "renesas,r8a77980"; - - aliases { - i2c0 = &i2c0; - i2c1 = &i2c1; - i2c2 = &i2c2; - i2c3 = &i2c3; - i2c4 = &i2c4; - i2c5 = &i2c5; - serial0 = &scif0; - ethernet0 = &gether; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - hdmi-out { - compatible = "hdmi-connector"; - type = "a"; - - port { - hdmi_con: endpoint { - remote-endpoint = <&adv7511_out>; - }; - }; - }; - - lvds-decoder { - compatible = "thine,thc63lvd1024"; - vcc-supply = <&vcc3v3_d5>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - thc63lvd1024_in: endpoint { - remote-endpoint = <&lvds0_out>; - }; - }; - - port@2 { - reg = <2>; - thc63lvd1024_out: endpoint { - remote-endpoint = <&adv7511_in>; - }; - }; - }; - }; - - memory@48000000 { - device_type = "memory"; - /* first 128MB is reserved for secure area. */ - reg = <0 0x48000000 0 0x78000000>; - }; - - osc1_clk: osc1-clock { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <148500000>; - }; - - vcc1v8_d4: regulator-0 { - compatible = "regulator-fixed"; - regulator-name = "VCC1V8_D4"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-boot-on; - regulator-always-on; - }; - - vcc3v3_d5: regulator-1 { - compatible = "regulator-fixed"; - regulator-name = "VCC3V3_D5"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; -}; - -&du { - clocks = <&cpg CPG_MOD 724>, - <&osc1_clk>; - clock-names = "du.0", "dclkin.0"; - status = "okay"; -}; - -&extal_clk { - clock-frequency = <16666666>; -}; - -&extalr_clk { - clock-frequency = <32768>; -}; - -&gether { - pinctrl-0 = <&gether_pins>; - pinctrl-names = "default"; - - phy-mode = "rgmii"; - phy-handle = <&phy0>; - renesas,no-ether-link; - status = "okay"; - - phy0: ethernet-phy@0 { - compatible = "ethernet-phy-id0022.1622", - "ethernet-phy-ieee802.3-c22"; - rxc-skew-ps = <1500>; - reg = <0>; - interrupt-parent = <&gpio4>; - interrupts = <23 IRQ_TYPE_LEVEL_LOW>; - reset-gpios = <&gpio4 22 GPIO_ACTIVE_LOW>; - }; -}; - -&i2c0 { - pinctrl-0 = <&i2c0_pins>; - pinctrl-names = "default"; - - status = "okay"; - clock-frequency = <400000>; - - hdmi@39 { - compatible = "adi,adv7511w"; - #sound-dai-cells = <0>; - reg = <0x39>; - interrupt-parent = <&gpio1>; - interrupts = <20 IRQ_TYPE_LEVEL_LOW>; - avdd-supply = <&vcc1v8_d4>; - dvdd-supply = <&vcc1v8_d4>; - pvdd-supply = <&vcc1v8_d4>; - bgvdd-supply = <&vcc1v8_d4>; - dvdd-3v-supply = <&vcc3v3_d5>; - - adi,input-depth = <8>; - adi,input-colorspace = "rgb"; - adi,input-clock = "1x"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - adv7511_in: endpoint { - remote-endpoint = <&thc63lvd1024_out>; - }; - }; - - port@1 { - reg = <1>; - adv7511_out: endpoint { - remote-endpoint = <&hdmi_con>; - }; - }; - }; - }; -}; - -&lvds0 { - status = "okay"; - - ports { - port@1 { - lvds0_out: endpoint { - remote-endpoint = <&thc63lvd1024_in>; - }; - }; - }; -}; - -&pfc { - gether_pins: gether { - groups = "gether_mdio_a", "gether_rgmii", - "gether_txcrefclk", "gether_txcrefclk_mega"; - function = "gether"; - }; - - i2c0_pins: i2c0 { - groups = "i2c0"; - function = "i2c0"; - }; - - qspi0_pins: qspi0 { - groups = "qspi0_ctrl", "qspi0_data4"; - function = "qspi0"; - }; - - scif0_pins: scif0 { - groups = "scif0_data"; - function = "scif0"; - }; - - scif_clk_pins: scif_clk { - groups = "scif_clk_b"; - function = "scif_clk"; - }; -}; - -&rpc { - pinctrl-0 = <&qspi0_pins>; - pinctrl-names = "default"; - - status = "okay"; - - flash@0 { - compatible = "spansion,s25fs512s", "jedec,spi-nor"; - reg = <0>; - spi-max-frequency = <50000000>; - spi-rx-bus-width = <4>; - - partitions { - compatible = "fixed-partitions"; - #address-cells = <1>; - #size-cells = <1>; - - bootparam@0 { - reg = <0x00000000 0x040000>; - read-only; - }; - cr7@40000 { - reg = <0x00040000 0x080000>; - read-only; - }; - cert_header_sa3@c0000 { - reg = <0x000c0000 0x080000>; - read-only; - }; - bl2@140000 { - reg = <0x00140000 0x040000>; - read-only; - }; - cert_header_sa6@180000 { - reg = <0x00180000 0x040000>; - read-only; - }; - bl31@1c0000 { - reg = <0x001c0000 0x460000>; - read-only; - }; - uboot@640000 { - reg = <0x00640000 0x0c0000>; - read-only; - }; - uboot-env@700000 { - reg = <0x00700000 0x040000>; - read-only; - }; - dtb@740000 { - reg = <0x00740000 0x080000>; - }; - kernel@7c0000 { - reg = <0x007c0000 0x1400000>; - }; - user@1bc0000 { - reg = <0x01bc0000 0x2440000>; - }; - }; - }; -}; - -&rwdt { - timeout-sec = <60>; - status = "okay"; -}; - -&scif0 { - pinctrl-0 = <&scif0_pins>, <&scif_clk_pins>; - pinctrl-names = "default"; - - status = "okay"; -}; - -&scif_clk { - clock-frequency = <14745600>; -}; diff --git a/arch/arm/dts/r8a77980.dtsi b/arch/arm/dts/r8a77980.dtsi deleted file mode 100644 index 5ed2daaca1f..00000000000 --- a/arch/arm/dts/r8a77980.dtsi +++ /dev/null @@ -1,1625 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the R-Car V3H (R8A77980) SoC - * - * Copyright (C) 2018 Renesas Electronics Corp. - * Copyright (C) 2018 Cogent Embedded, Inc. - */ - -#include <dt-bindings/clock/r8a77980-cpg-mssr.h> -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/power/r8a77980-sysc.h> - -/ { - compatible = "renesas,r8a77980"; - #address-cells = <2>; - #size-cells = <2>; - - /* External CAN clock - to be overridden by boards that provide it */ - can_clk: can { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - - a53_0: cpu@0 { - device_type = "cpu"; - compatible = "arm,cortex-a53"; - reg = <0>; - clocks = <&cpg CPG_CORE R8A77980_CLK_Z2>; - power-domains = <&sysc R8A77980_PD_CA53_CPU0>; - next-level-cache = <&L2_CA53>; - enable-method = "psci"; - }; - - a53_1: cpu@1 { - device_type = "cpu"; - compatible = "arm,cortex-a53"; - reg = <1>; - clocks = <&cpg CPG_CORE R8A77980_CLK_Z2>; - power-domains = <&sysc R8A77980_PD_CA53_CPU1>; - next-level-cache = <&L2_CA53>; - enable-method = "psci"; - }; - - a53_2: cpu@2 { - device_type = "cpu"; - compatible = "arm,cortex-a53"; - reg = <2>; - clocks = <&cpg CPG_CORE R8A77980_CLK_Z2>; - power-domains = <&sysc R8A77980_PD_CA53_CPU2>; - next-level-cache = <&L2_CA53>; - enable-method = "psci"; - }; - - a53_3: cpu@3 { - device_type = "cpu"; - compatible = "arm,cortex-a53"; - reg = <3>; - clocks = <&cpg CPG_CORE R8A77980_CLK_Z2>; - power-domains = <&sysc R8A77980_PD_CA53_CPU3>; - next-level-cache = <&L2_CA53>; - enable-method = "psci"; - }; - - L2_CA53: cache-controller { - compatible = "cache"; - power-domains = <&sysc R8A77980_PD_CA53_SCU>; - cache-unified; - cache-level = <2>; - }; - }; - - extal_clk: extal { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board */ - clock-frequency = <0>; - }; - - extalr_clk: extalr { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board */ - clock-frequency = <0>; - }; - - /* External PCIe clock - can be overridden by the board */ - pcie_bus_clk: pcie_bus { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - pmu_a53 { - compatible = "arm,cortex-a53-pmu"; - interrupts-extended = <&gic GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&a53_0>, <&a53_1>, <&a53_2>, <&a53_3>; - }; - - psci { - compatible = "arm,psci-1.0", "arm,psci-0.2"; - method = "smc"; - }; - - /* External SCIF clock - to be overridden by boards that provide it */ - scif_clk: scif { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - soc { - compatible = "simple-bus"; - interrupt-parent = <&gic>; - - #address-cells = <2>; - #size-cells = <2>; - ranges; - - rwdt: watchdog@e6020000 { - compatible = "renesas,r8a77980-wdt", - "renesas,rcar-gen3-wdt"; - reg = <0 0xe6020000 0 0x0c>; - interrupts = <GIC_SPI 140 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 402>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 402>; - status = "disabled"; - }; - - gpio0: gpio@e6050000 { - compatible = "renesas,gpio-r8a77980", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6050000 0 0x50>; - interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 0 22>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 912>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 912>; - }; - - gpio1: gpio@e6051000 { - compatible = "renesas,gpio-r8a77980", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6051000 0 0x50>; - interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 32 28>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 911>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 911>; - }; - - gpio2: gpio@e6052000 { - compatible = "renesas,gpio-r8a77980", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6052000 0 0x50>; - interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 64 30>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 910>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 910>; - }; - - gpio3: gpio@e6053000 { - compatible = "renesas,gpio-r8a77980", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6053000 0 0x50>; - interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 96 17>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 909>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 909>; - }; - - gpio4: gpio@e6054000 { - compatible = "renesas,gpio-r8a77980", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6054000 0 0x50>; - interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 128 25>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 908>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 908>; - }; - - gpio5: gpio@e6055000 { - compatible = "renesas,gpio-r8a77980", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6055000 0 0x50>; - interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 160 15>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 907>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 907>; - }; - - pfc: pinctrl@e6060000 { - compatible = "renesas,pfc-r8a77980"; - reg = <0 0xe6060000 0 0x50c>; - }; - - cmt0: timer@e60f0000 { - compatible = "renesas,r8a77980-cmt0", - "renesas,rcar-gen3-cmt0"; - reg = <0 0xe60f0000 0 0x1004>; - interrupts = <GIC_SPI 142 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 143 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 303>; - clock-names = "fck"; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 303>; - status = "disabled"; - }; - - cmt1: timer@e6130000 { - compatible = "renesas,r8a77980-cmt1", - "renesas,rcar-gen3-cmt1"; - reg = <0 0xe6130000 0 0x1004>; - interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 127 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 302>; - clock-names = "fck"; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 302>; - status = "disabled"; - }; - - cmt2: timer@e6140000 { - compatible = "renesas,r8a77980-cmt1", - "renesas,rcar-gen3-cmt1"; - reg = <0 0xe6140000 0 0x1004>; - interrupts = <GIC_SPI 258 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 259 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 260 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 261 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 262 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 263 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 264 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 265 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 301>; - clock-names = "fck"; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 301>; - status = "disabled"; - }; - - cmt3: timer@e6148000 { - compatible = "renesas,r8a77980-cmt1", - "renesas,rcar-gen3-cmt1"; - reg = <0 0xe6148000 0 0x1004>; - interrupts = <GIC_SPI 273 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 274 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 275 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 276 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 277 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 278 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 279 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 280 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 300>; - clock-names = "fck"; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 300>; - status = "disabled"; - }; - - cpg: clock-controller@e6150000 { - compatible = "renesas,r8a77980-cpg-mssr"; - reg = <0 0xe6150000 0 0x1000>; - clocks = <&extal_clk>, <&extalr_clk>; - clock-names = "extal", "extalr"; - #clock-cells = <2>; - #power-domain-cells = <0>; - #reset-cells = <1>; - }; - - rst: reset-controller@e6160000 { - compatible = "renesas,r8a77980-rst"; - reg = <0 0xe6160000 0 0x200>; - }; - - sysc: system-controller@e6180000 { - compatible = "renesas,r8a77980-sysc"; - reg = <0 0xe6180000 0 0x440>; - #power-domain-cells = <1>; - }; - - tsc: thermal@e6198000 { - compatible = "renesas,r8a77980-thermal"; - reg = <0 0xe6198000 0 0x100>, - <0 0xe61a0000 0 0x100>; - interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 522>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 522>; - #thermal-sensor-cells = <1>; - }; - - intc_ex: interrupt-controller@e61c0000 { - compatible = "renesas,intc-ex-r8a77980", "renesas,irqc"; - #interrupt-cells = <2>; - interrupt-controller; - reg = <0 0xe61c0000 0 0x200>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 161 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 407>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 407>; - }; - - tmu0: timer@e61e0000 { - compatible = "renesas,tmu-r8a77980", "renesas,tmu"; - reg = <0 0xe61e0000 0 0x30>; - interrupts = <GIC_SPI 136 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 137 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 138 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 125>; - clock-names = "fck"; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 125>; - status = "disabled"; - }; - - tmu1: timer@e6fc0000 { - compatible = "renesas,tmu-r8a77980", "renesas,tmu"; - reg = <0 0xe6fc0000 0 0x30>; - interrupts = <GIC_SPI 128 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 129 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 130 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 124>; - clock-names = "fck"; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 124>; - status = "disabled"; - }; - - tmu2: timer@e6fd0000 { - compatible = "renesas,tmu-r8a77980", "renesas,tmu"; - reg = <0 0xe6fd0000 0 0x30>; - interrupts = <GIC_SPI 303 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 304 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 305 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 123>; - clock-names = "fck"; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 123>; - status = "disabled"; - }; - - tmu3: timer@e6fe0000 { - compatible = "renesas,tmu-r8a77980", "renesas,tmu"; - reg = <0 0xe6fe0000 0 0x30>; - interrupts = <GIC_SPI 131 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 132 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 133 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 122>; - clock-names = "fck"; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 122>; - status = "disabled"; - }; - - tmu4: timer@ffc00000 { - compatible = "renesas,tmu-r8a77980", "renesas,tmu"; - reg = <0 0xffc00000 0 0x30>; - interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 121>; - clock-names = "fck"; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 121>; - status = "disabled"; - }; - - i2c0: i2c@e6500000 { - compatible = "renesas,i2c-r8a77980", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6500000 0 0x40>; - interrupts = <GIC_SPI 287 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 931>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 931>; - dmas = <&dmac1 0x91>, <&dmac1 0x90>, - <&dmac2 0x91>, <&dmac2 0x90>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c1: i2c@e6508000 { - compatible = "renesas,i2c-r8a77980", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6508000 0 0x40>; - interrupts = <GIC_SPI 288 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 930>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 930>; - dmas = <&dmac1 0x93>, <&dmac1 0x92>, - <&dmac2 0x93>, <&dmac2 0x92>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c2: i2c@e6510000 { - compatible = "renesas,i2c-r8a77980", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6510000 0 0x40>; - interrupts = <GIC_SPI 286 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 929>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 929>; - dmas = <&dmac1 0x95>, <&dmac1 0x94>, - <&dmac2 0x95>, <&dmac2 0x94>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c3: i2c@e66d0000 { - compatible = "renesas,i2c-r8a77980", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66d0000 0 0x40>; - interrupts = <GIC_SPI 290 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 928>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 928>; - i2c-scl-internal-delay-ns = <6>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c4: i2c@e66d8000 { - compatible = "renesas,i2c-r8a77980", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66d8000 0 0x40>; - interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 927>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 927>; - i2c-scl-internal-delay-ns = <6>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c5: i2c@e66e0000 { - compatible = "renesas,i2c-r8a77980", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66e0000 0 0x40>; - interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 919>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 919>; - dmas = <&dmac1 0x9b>, <&dmac1 0x9a>, - <&dmac2 0x9b>, <&dmac2 0x9a>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - hscif0: serial@e6540000 { - compatible = "renesas,hscif-r8a77980", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe6540000 0 0x60>; - interrupts = <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 520>, - <&cpg CPG_CORE R8A77980_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x31>, <&dmac1 0x30>, - <&dmac2 0x31>, <&dmac2 0x30>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 520>; - status = "disabled"; - }; - - hscif1: serial@e6550000 { - compatible = "renesas,hscif-r8a77980", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe6550000 0 0x60>; - interrupts = <GIC_SPI 155 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 519>, - <&cpg CPG_CORE R8A77980_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x33>, <&dmac1 0x32>, - <&dmac2 0x33>, <&dmac2 0x32>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 519>; - status = "disabled"; - }; - - hscif2: serial@e6560000 { - compatible = "renesas,hscif-r8a77980", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe6560000 0 0x60>; - interrupts = <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 518>, - <&cpg CPG_CORE R8A77980_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x35>, <&dmac1 0x34>, - <&dmac2 0x35>, <&dmac2 0x34>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 518>; - status = "disabled"; - }; - - hscif3: serial@e66a0000 { - compatible = "renesas,hscif-r8a77980", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe66a0000 0 0x60>; - interrupts = <GIC_SPI 145 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 517>, - <&cpg CPG_CORE R8A77980_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x37>, <&dmac1 0x36>, - <&dmac2 0x37>, <&dmac2 0x36>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 517>; - status = "disabled"; - }; - - pcie_phy: pcie-phy@e65d0000 { - compatible = "renesas,r8a77980-pcie-phy"; - reg = <0 0xe65d0000 0 0x8000>; - #phy-cells = <0>; - clocks = <&cpg CPG_MOD 319>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 319>; - status = "disabled"; - }; - - canfd: can@e66c0000 { - compatible = "renesas,r8a77980-canfd", - "renesas,rcar-gen3-canfd"; - reg = <0 0xe66c0000 0 0x8000>; - interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch_int", "g_int"; - clocks = <&cpg CPG_MOD 914>, - <&cpg CPG_CORE R8A77980_CLK_CANFD>, - <&can_clk>; - clock-names = "fck", "canfd", "can_clk"; - assigned-clocks = <&cpg CPG_CORE R8A77980_CLK_CANFD>; - assigned-clock-rates = <40000000>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 914>; - status = "disabled"; - - channel0 { - status = "disabled"; - }; - - channel1 { - status = "disabled"; - }; - }; - - avb: ethernet@e6800000 { - compatible = "renesas,etheravb-r8a77980", - "renesas,etheravb-rcar-gen3"; - reg = <0 0xe6800000 0 0x800>; - interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 47 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 63 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15", - "ch16", "ch17", "ch18", "ch19", - "ch20", "ch21", "ch22", "ch23", - "ch24"; - clocks = <&cpg CPG_MOD 812>; - clock-names = "fck"; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 812>; - phy-mode = "rgmii"; - rx-internal-delay-ps = <0>; - tx-internal-delay-ps = <2000>; - iommus = <&ipmmu_ds1 33>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - pwm0: pwm@e6e30000 { - compatible = "renesas,pwm-r8a77980", "renesas,pwm-rcar"; - reg = <0 0xe6e30000 0 0x10>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 523>; - status = "disabled"; - }; - - pwm1: pwm@e6e31000 { - compatible = "renesas,pwm-r8a77980", "renesas,pwm-rcar"; - reg = <0 0xe6e31000 0 0x10>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 523>; - status = "disabled"; - }; - - pwm2: pwm@e6e32000 { - compatible = "renesas,pwm-r8a77980", "renesas,pwm-rcar"; - reg = <0 0xe6e32000 0 0x10>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 523>; - status = "disabled"; - }; - - pwm3: pwm@e6e33000 { - compatible = "renesas,pwm-r8a77980", "renesas,pwm-rcar"; - reg = <0 0xe6e33000 0 0x10>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 523>; - status = "disabled"; - }; - - pwm4: pwm@e6e34000 { - compatible = "renesas,pwm-r8a77980", "renesas,pwm-rcar"; - reg = <0 0xe6e34000 0 0x10>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 523>; - status = "disabled"; - }; - - scif0: serial@e6e60000 { - compatible = "renesas,scif-r8a77980", - "renesas,rcar-gen3-scif", - "renesas,scif"; - reg = <0 0xe6e60000 0 0x40>; - interrupts = <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 207>, - <&cpg CPG_CORE R8A77980_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x51>, <&dmac1 0x50>, - <&dmac2 0x51>, <&dmac2 0x50>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 207>; - status = "disabled"; - }; - - scif1: serial@e6e68000 { - compatible = "renesas,scif-r8a77980", - "renesas,rcar-gen3-scif", - "renesas,scif"; - reg = <0 0xe6e68000 0 0x40>; - interrupts = <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 206>, - <&cpg CPG_CORE R8A77980_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x53>, <&dmac1 0x52>, - <&dmac2 0x53>, <&dmac2 0x52>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 206>; - status = "disabled"; - }; - - scif3: serial@e6c50000 { - compatible = "renesas,scif-r8a77980", - "renesas,rcar-gen3-scif", - "renesas,scif"; - reg = <0 0xe6c50000 0 0x40>; - interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 204>, - <&cpg CPG_CORE R8A77980_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x57>, <&dmac1 0x56>, - <&dmac2 0x57>, <&dmac2 0x56>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 204>; - status = "disabled"; - }; - - scif4: serial@e6c40000 { - compatible = "renesas,scif-r8a77980", - "renesas,rcar-gen3-scif", - "renesas,scif"; - reg = <0 0xe6c40000 0 0x40>; - interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 203>, - <&cpg CPG_CORE R8A77980_CLK_S3D1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x59>, <&dmac1 0x58>, - <&dmac2 0x59>, <&dmac2 0x58>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 203>; - status = "disabled"; - }; - - tpu: pwm@e6e80000 { - compatible = "renesas,tpu-r8a77980", "renesas,tpu"; - reg = <0 0xe6e80000 0 0x148>; - interrupts = <GIC_SPI 135 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 304>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 304>; - #pwm-cells = <3>; - status = "disabled"; - }; - - msiof0: spi@e6e90000 { - compatible = "renesas,msiof-r8a77980", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6e90000 0 0x64>; - interrupts = <GIC_SPI 156 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 211>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 211>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof1: spi@e6ea0000 { - compatible = "renesas,msiof-r8a77980", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6ea0000 0 0x0064>; - interrupts = <GIC_SPI 157 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 210>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 210>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof2: spi@e6c00000 { - compatible = "renesas,msiof-r8a77980", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6c00000 0 0x0064>; - interrupts = <GIC_SPI 158 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 209>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 209>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof3: spi@e6c10000 { - compatible = "renesas,msiof-r8a77980", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6c10000 0 0x0064>; - interrupts = <GIC_SPI 159 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 208>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 208>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - vin0: video@e6ef0000 { - compatible = "renesas,vin-r8a77980"; - reg = <0 0xe6ef0000 0 0x1000>; - interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 811>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 811>; - renesas,id = <0>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin0csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin0>; - }; - }; - }; - }; - - vin1: video@e6ef1000 { - compatible = "renesas,vin-r8a77980"; - reg = <0 0xe6ef1000 0 0x1000>; - interrupts = <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 810>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - status = "disabled"; - renesas,id = <1>; - resets = <&cpg 810>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin1csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin1>; - }; - }; - }; - }; - - vin2: video@e6ef2000 { - compatible = "renesas,vin-r8a77980"; - reg = <0 0xe6ef2000 0 0x1000>; - interrupts = <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 809>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 809>; - renesas,id = <2>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin2csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin2>; - }; - }; - }; - }; - - vin3: video@e6ef3000 { - compatible = "renesas,vin-r8a77980"; - reg = <0 0xe6ef3000 0 0x1000>; - interrupts = <GIC_SPI 191 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 808>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 808>; - renesas,id = <3>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin3csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin3>; - }; - }; - }; - }; - - vin4: video@e6ef4000 { - compatible = "renesas,vin-r8a77980"; - reg = <0 0xe6ef4000 0 0x1000>; - interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 807>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 807>; - renesas,id = <4>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin4csi41: endpoint@3 { - reg = <3>; - remote-endpoint = <&csi41vin4>; - }; - }; - }; - }; - - vin5: video@e6ef5000 { - compatible = "renesas,vin-r8a77980"; - reg = <0 0xe6ef5000 0 0x1000>; - interrupts = <GIC_SPI 175 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 806>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 806>; - renesas,id = <5>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin5csi41: endpoint@3 { - reg = <3>; - remote-endpoint = <&csi41vin5>; - }; - }; - }; - }; - - vin6: video@e6ef6000 { - compatible = "renesas,vin-r8a77980"; - reg = <0 0xe6ef6000 0 0x1000>; - interrupts = <GIC_SPI 176 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 805>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 805>; - renesas,id = <6>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin6csi41: endpoint@3 { - reg = <3>; - remote-endpoint = <&csi41vin6>; - }; - }; - }; - }; - - vin7: video@e6ef7000 { - compatible = "renesas,vin-r8a77980"; - reg = <0 0xe6ef7000 0 0x1000>; - interrupts = <GIC_SPI 171 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 804>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 804>; - renesas,id = <7>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin7csi41: endpoint@3 { - reg = <3>; - remote-endpoint = <&csi41vin7>; - }; - }; - }; - }; - - vin8: video@e6ef8000 { - compatible = "renesas,vin-r8a77980"; - reg = <0 0xe6ef8000 0 0x1000>; - interrupts = <GIC_SPI 268 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 628>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 628>; - renesas,id = <8>; - status = "disabled"; - }; - - vin9: video@e6ef9000 { - compatible = "renesas,vin-r8a77980"; - reg = <0 0xe6ef9000 0 0x1000>; - interrupts = <GIC_SPI 269 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 627>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 627>; - renesas,id = <9>; - status = "disabled"; - }; - - vin10: video@e6efa000 { - compatible = "renesas,vin-r8a77980"; - reg = <0 0xe6efa000 0 0x1000>; - interrupts = <GIC_SPI 289 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 625>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 625>; - renesas,id = <10>; - status = "disabled"; - }; - - vin11: video@e6efb000 { - compatible = "renesas,vin-r8a77980"; - reg = <0 0xe6efb000 0 0x1000>; - interrupts = <GIC_SPI 296 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 618>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 618>; - renesas,id = <11>; - status = "disabled"; - }; - - vin12: video@e6efc000 { - compatible = "renesas,vin-r8a77980"; - reg = <0 0xe6efc000 0 0x1000>; - interrupts = <GIC_SPI 298 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 612>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 612>; - renesas,id = <12>; - status = "disabled"; - }; - - vin13: video@e6efd000 { - compatible = "renesas,vin-r8a77980"; - reg = <0 0xe6efd000 0 0x1000>; - interrupts = <GIC_SPI 299 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 608>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 608>; - renesas,id = <13>; - status = "disabled"; - }; - - vin14: video@e6efe000 { - compatible = "renesas,vin-r8a77980"; - reg = <0 0xe6efe000 0 0x1000>; - interrupts = <GIC_SPI 301 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 605>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 605>; - renesas,id = <14>; - status = "disabled"; - }; - - vin15: video@e6eff000 { - compatible = "renesas,vin-r8a77980"; - reg = <0 0xe6eff000 0 0x1000>; - interrupts = <GIC_SPI 302 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 604>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 604>; - renesas,id = <15>; - status = "disabled"; - }; - - dmac1: dma-controller@e7300000 { - compatible = "renesas,dmac-r8a77980", - "renesas,rcar-dmac"; - reg = <0 0xe7300000 0 0x10000>; - interrupts = <GIC_SPI 220 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 216 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 217 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 218 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 219 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 308 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 309 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 310 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 311 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 353 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 354 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 355 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 356 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 357 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 358 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 359 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 360 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 218>; - clock-names = "fck"; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 218>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_ds1 0>, <&ipmmu_ds1 1>, - <&ipmmu_ds1 2>, <&ipmmu_ds1 3>, - <&ipmmu_ds1 4>, <&ipmmu_ds1 5>, - <&ipmmu_ds1 6>, <&ipmmu_ds1 7>, - <&ipmmu_ds1 8>, <&ipmmu_ds1 9>, - <&ipmmu_ds1 10>, <&ipmmu_ds1 11>, - <&ipmmu_ds1 12>, <&ipmmu_ds1 13>, - <&ipmmu_ds1 14>, <&ipmmu_ds1 15>; - }; - - dmac2: dma-controller@e7310000 { - compatible = "renesas,dmac-r8a77980", - "renesas,rcar-dmac"; - reg = <0 0xe7310000 0 0x10000>; - interrupts = <GIC_SPI 307 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 312 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 313 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 314 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 315 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 316 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 317 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 318 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 319 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 361 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 362 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 363 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 364 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 365 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 366 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 367 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 368 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 217>; - clock-names = "fck"; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 217>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_ds1 16>, <&ipmmu_ds1 17>, - <&ipmmu_ds1 18>, <&ipmmu_ds1 19>, - <&ipmmu_ds1 20>, <&ipmmu_ds1 21>, - <&ipmmu_ds1 22>, <&ipmmu_ds1 23>, - <&ipmmu_ds1 24>, <&ipmmu_ds1 25>, - <&ipmmu_ds1 26>, <&ipmmu_ds1 27>, - <&ipmmu_ds1 28>, <&ipmmu_ds1 29>, - <&ipmmu_ds1 30>, <&ipmmu_ds1 31>; - }; - - gether: ethernet@e7400000 { - compatible = "renesas,gether-r8a77980"; - reg = <0 0xe7400000 0 0x1000>; - interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 813>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 813>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - ipmmu_ds1: iommu@e7740000 { - compatible = "renesas,ipmmu-r8a77980"; - reg = <0 0xe7740000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 0>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_ir: iommu@ff8b0000 { - compatible = "renesas,ipmmu-r8a77980"; - reg = <0 0xff8b0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 3>; - power-domains = <&sysc R8A77980_PD_A3IR>; - #iommu-cells = <1>; - }; - - ipmmu_mm: iommu@e67b0000 { - compatible = "renesas,ipmmu-r8a77980"; - reg = <0 0xe67b0000 0 0x1000>; - interrupts = <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_rt: iommu@ffc80000 { - compatible = "renesas,ipmmu-r8a77980"; - reg = <0 0xffc80000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 10>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_vc0: iommu@fe990000 { - compatible = "renesas,ipmmu-r8a77980"; - reg = <0 0xfe990000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 12>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_vi0: iommu@febd0000 { - compatible = "renesas,ipmmu-r8a77980"; - reg = <0 0xfebd0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 14>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_vip0: iommu@e7b00000 { - compatible = "renesas,ipmmu-r8a77980"; - reg = <0 0xe7b00000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 4>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_vip1: iommu@e7960000 { - compatible = "renesas,ipmmu-r8a77980"; - reg = <0 0xe7960000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 11>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - mmc0: mmc@ee140000 { - compatible = "renesas,sdhi-r8a77980", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee140000 0 0x2000>; - interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 314>, <&cpg CPG_CORE R8A77980_CLK_SD0H>; - clock-names = "core", "clkh"; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 314>; - max-frequency = <200000000>; - iommus = <&ipmmu_ds1 32>; - status = "disabled"; - }; - - rpc: spi@ee200000 { - compatible = "renesas,r8a77980-rpc-if", - "renesas,rcar-gen3-rpc-if"; - reg = <0 0xee200000 0 0x200>, - <0 0x08000000 0 0x4000000>, - <0 0xee208000 0 0x100>; - reg-names = "regs", "dirmap", "wbuf"; - interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 917>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 917>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - gic: interrupt-controller@f1010000 { - compatible = "arm,gic-400"; - #interrupt-cells = <3>; - #address-cells = <0>; - interrupt-controller; - reg = <0x0 0xf1010000 0 0x1000>, - <0x0 0xf1020000 0 0x20000>, - <0x0 0xf1040000 0 0x20000>, - <0x0 0xf1060000 0 0x20000>; - interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(4) | - IRQ_TYPE_LEVEL_HIGH)>; - clocks = <&cpg CPG_MOD 408>; - clock-names = "clk"; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 408>; - }; - - pciec: pcie@fe000000 { - compatible = "renesas,pcie-r8a77980", - "renesas,pcie-rcar-gen3"; - reg = <0 0xfe000000 0 0x80000>; - #address-cells = <3>; - #size-cells = <2>; - bus-range = <0x00 0xff>; - device_type = "pci"; - ranges = <0x01000000 0 0x00000000 0 0xfe100000 0 0x0100000>, - <0x02000000 0 0xfe200000 0 0xfe200000 0 0x0200000>, - <0x02000000 0 0x30000000 0 0x30000000 0 0x8000000>, - <0x42000000 0 0x38000000 0 0x38000000 0 0x8000000>; - /* Map all possible DDR/IOMMU as inbound ranges */ - dma-ranges = <0x42000000 0 0x00000000 0 0x00000000 1 0x00000000>; - interrupts = <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 149 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 150 IRQ_TYPE_LEVEL_HIGH>; - #interrupt-cells = <1>; - interrupt-map-mask = <0 0 0 0>; - interrupt-map = <0 0 0 0 &gic GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 319>, <&pcie_bus_clk>; - clock-names = "pcie", "pcie_bus"; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 319>; - phys = <&pcie_phy>; - phy-names = "pcie"; - iommu-map = <0 &ipmmu_vi0 5 1>; - iommu-map-mask = <0>; - status = "disabled"; - }; - - vspd0: vsp@fea20000 { - compatible = "renesas,vsp2"; - reg = <0 0xfea20000 0 0x5000>; - interrupts = <GIC_SPI 169 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 623>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 623>; - renesas,fcp = <&fcpvd0>; - }; - - fcpvd0: fcp@fea27000 { - compatible = "renesas,fcpv"; - reg = <0 0xfea27000 0 0x200>; - clocks = <&cpg CPG_MOD 603>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 603>; - }; - - csi40: csi2@feaa0000 { - compatible = "renesas,r8a77980-csi2"; - reg = <0 0xfeaa0000 0 0x10000>; - interrupts = <GIC_SPI 246 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 716>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 716>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - csi40vin0: endpoint@0 { - reg = <0>; - remote-endpoint = <&vin0csi40>; - }; - csi40vin1: endpoint@1 { - reg = <1>; - remote-endpoint = <&vin1csi40>; - }; - csi40vin2: endpoint@2 { - reg = <2>; - remote-endpoint = <&vin2csi40>; - }; - csi40vin3: endpoint@3 { - reg = <3>; - remote-endpoint = <&vin3csi40>; - }; - }; - }; - }; - - csi41: csi2@feab0000 { - compatible = "renesas,r8a77980-csi2"; - reg = <0 0xfeab0000 0 0x10000>; - interrupts = <GIC_SPI 241 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 715>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 715>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - csi41vin4: endpoint@0 { - reg = <0>; - remote-endpoint = <&vin4csi41>; - }; - csi41vin5: endpoint@1 { - reg = <1>; - remote-endpoint = <&vin5csi41>; - }; - csi41vin6: endpoint@2 { - reg = <2>; - remote-endpoint = <&vin6csi41>; - }; - csi41vin7: endpoint@3 { - reg = <3>; - remote-endpoint = <&vin7csi41>; - }; - }; - }; - }; - - du: display@feb00000 { - compatible = "renesas,du-r8a77980"; - reg = <0 0xfeb00000 0 0x80000>; - interrupts = <GIC_SPI 256 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 724>; - clock-names = "du.0"; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 724>; - reset-names = "du.0"; - renesas,vsps = <&vspd0 0>; - - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - - port@1 { - reg = <1>; - du_out_lvds0: endpoint { - remote-endpoint = <&lvds0_in>; - }; - }; - }; - }; - - lvds0: lvds-encoder@feb90000 { - compatible = "renesas,r8a77980-lvds"; - reg = <0 0xfeb90000 0 0x14>; - clocks = <&cpg CPG_MOD 727>; - power-domains = <&sysc R8A77980_PD_ALWAYS_ON>; - resets = <&cpg 727>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - lvds0_in: endpoint { - remote-endpoint = - <&du_out_lvds0>; - }; - }; - - port@1 { - reg = <1>; - }; - }; - }; - - prr: chipid@fff00044 { - compatible = "renesas,prr"; - reg = <0 0xfff00044 0 4>; - }; - }; - - thermal-zones { - sensor1_thermal: sensor1-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - thermal-sensors = <&tsc 0>; - - trips { - sensor1-passive { - temperature = <95000>; - hysteresis = <1000>; - type = "passive"; - }; - sensor1-critical { - temperature = <120000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - }; - - sensor2_thermal: sensor2-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - thermal-sensors = <&tsc 1>; - - trips { - sensor2-passive { - temperature = <95000>; - hysteresis = <1000>; - type = "passive"; - }; - sensor2-critical { - temperature = <120000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - }; - }; - - timer { - compatible = "arm,armv8-timer"; - interrupts-extended = <&gic GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | - IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | - IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | - IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | - IRQ_TYPE_LEVEL_LOW)>; - }; -}; diff --git a/arch/arm/dts/r8a77990-ebisu.dts b/arch/arm/dts/r8a77990-ebisu.dts deleted file mode 100644 index 9da0fd08f8c..00000000000 --- a/arch/arm/dts/r8a77990-ebisu.dts +++ /dev/null @@ -1,15 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the Ebisu board with R-Car E3 - * - * Copyright (C) 2018 Renesas Electronics Corp. - */ - -/dts-v1/; -#include "r8a77990.dtsi" -#include "ebisu.dtsi" - -/ { - model = "Renesas Ebisu board based on r8a77990"; - compatible = "renesas,ebisu", "renesas,r8a77990"; -}; diff --git a/arch/arm/dts/r8a77990.dtsi b/arch/arm/dts/r8a77990.dtsi deleted file mode 100644 index 4c545eff9b4..00000000000 --- a/arch/arm/dts/r8a77990.dtsi +++ /dev/null @@ -1,2154 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the R-Car E3 (R8A77990) SoC - * - * Copyright (C) 2018-2019 Renesas Electronics Corp. - */ - -#include <dt-bindings/clock/r8a77990-cpg-mssr.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/power/r8a77990-sysc.h> - -/ { - compatible = "renesas,r8a77990"; - #address-cells = <2>; - #size-cells = <2>; - - /* - * The external audio clocks are configured as 0 Hz fixed frequency - * clocks by default. - * Boards that provide audio clocks should override them. - */ - audio_clk_a: audio_clk_a { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - audio_clk_b: audio_clk_b { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - audio_clk_c: audio_clk_c { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - /* External CAN clock - to be overridden by boards that provide it */ - can_clk: can { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - cluster1_opp: opp-table-1 { - compatible = "operating-points-v2"; - opp-shared; - opp-800000000 { - opp-hz = /bits/ 64 <800000000>; - clock-latency-ns = <300000>; - }; - opp-1000000000 { - opp-hz = /bits/ 64 <1000000000>; - clock-latency-ns = <300000>; - }; - opp-1200000000 { - opp-hz = /bits/ 64 <1200000000>; - clock-latency-ns = <300000>; - opp-suspend; - }; - }; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - - a53_0: cpu@0 { - compatible = "arm,cortex-a53"; - reg = <0>; - device_type = "cpu"; - #cooling-cells = <2>; - power-domains = <&sysc R8A77990_PD_CA53_CPU0>; - next-level-cache = <&L2_CA53>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_0>; - dynamic-power-coefficient = <277>; - clocks = <&cpg CPG_CORE R8A77990_CLK_Z2>; - operating-points-v2 = <&cluster1_opp>; - }; - - a53_1: cpu@1 { - compatible = "arm,cortex-a53"; - reg = <1>; - device_type = "cpu"; - power-domains = <&sysc R8A77990_PD_CA53_CPU1>; - next-level-cache = <&L2_CA53>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_0>; - clocks = <&cpg CPG_CORE R8A77990_CLK_Z2>; - operating-points-v2 = <&cluster1_opp>; - }; - - L2_CA53: cache-controller-0 { - compatible = "cache"; - power-domains = <&sysc R8A77990_PD_CA53_SCU>; - cache-unified; - cache-level = <2>; - }; - - idle-states { - entry-method = "psci"; - - CPU_SLEEP_0: cpu-sleep-0 { - compatible = "arm,idle-state"; - arm,psci-suspend-param = <0x0010000>; - local-timer-stop; - entry-latency-us = <700>; - exit-latency-us = <700>; - min-residency-us = <5000>; - }; - }; - }; - - extal_clk: extal { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board */ - clock-frequency = <0>; - }; - - /* External PCIe clock - can be overridden by the board */ - pcie_bus_clk: pcie_bus { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - pmu_a53 { - compatible = "arm,cortex-a53-pmu"; - interrupts-extended = <&gic GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>, - <&gic GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&a53_0>, <&a53_1>; - }; - - psci { - compatible = "arm,psci-1.0", "arm,psci-0.2"; - method = "smc"; - }; - - /* External SCIF clock - to be overridden by boards that provide it */ - scif_clk: scif { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - soc: soc { - compatible = "simple-bus"; - interrupt-parent = <&gic>; - #address-cells = <2>; - #size-cells = <2>; - ranges; - - rwdt: watchdog@e6020000 { - compatible = "renesas,r8a77990-wdt", - "renesas,rcar-gen3-wdt"; - reg = <0 0xe6020000 0 0x0c>; - interrupts = <GIC_SPI 140 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 402>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 402>; - status = "disabled"; - }; - - gpio0: gpio@e6050000 { - compatible = "renesas,gpio-r8a77990", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6050000 0 0x50>; - interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 0 18>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 912>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 912>; - }; - - gpio1: gpio@e6051000 { - compatible = "renesas,gpio-r8a77990", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6051000 0 0x50>; - interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 32 23>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 911>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 911>; - }; - - gpio2: gpio@e6052000 { - compatible = "renesas,gpio-r8a77990", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6052000 0 0x50>; - interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 64 26>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 910>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 910>; - }; - - gpio3: gpio@e6053000 { - compatible = "renesas,gpio-r8a77990", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6053000 0 0x50>; - interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 96 16>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 909>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 909>; - }; - - gpio4: gpio@e6054000 { - compatible = "renesas,gpio-r8a77990", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6054000 0 0x50>; - interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 128 11>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 908>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 908>; - }; - - gpio5: gpio@e6055000 { - compatible = "renesas,gpio-r8a77990", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6055000 0 0x50>; - interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 160 20>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 907>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 907>; - }; - - gpio6: gpio@e6055400 { - compatible = "renesas,gpio-r8a77990", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6055400 0 0x50>; - interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 192 18>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 906>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 906>; - }; - - pfc: pinctrl@e6060000 { - compatible = "renesas,pfc-r8a77990"; - reg = <0 0xe6060000 0 0x508>; - }; - - i2c_dvfs: i2c@e60b0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,iic-r8a77990", - "renesas,rcar-gen3-iic", - "renesas,rmobile-iic"; - reg = <0 0xe60b0000 0 0x425>; - interrupts = <GIC_SPI 173 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 926>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 926>; - dmas = <&dmac0 0x11>, <&dmac0 0x10>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - cmt0: timer@e60f0000 { - compatible = "renesas,r8a77990-cmt0", - "renesas,rcar-gen3-cmt0"; - reg = <0 0xe60f0000 0 0x1004>; - interrupts = <GIC_SPI 142 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 143 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 303>; - clock-names = "fck"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 303>; - status = "disabled"; - }; - - cmt1: timer@e6130000 { - compatible = "renesas,r8a77990-cmt1", - "renesas,rcar-gen3-cmt1"; - reg = <0 0xe6130000 0 0x1004>; - interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 127 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 302>; - clock-names = "fck"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 302>; - status = "disabled"; - }; - - cmt2: timer@e6140000 { - compatible = "renesas,r8a77990-cmt1", - "renesas,rcar-gen3-cmt1"; - reg = <0 0xe6140000 0 0x1004>; - interrupts = <GIC_SPI 398 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 399 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 400 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 401 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 402 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 403 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 404 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 405 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 301>; - clock-names = "fck"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 301>; - status = "disabled"; - }; - - cmt3: timer@e6148000 { - compatible = "renesas,r8a77990-cmt1", - "renesas,rcar-gen3-cmt1"; - reg = <0 0xe6148000 0 0x1004>; - interrupts = <GIC_SPI 470 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 471 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 472 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 473 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 474 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 475 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 476 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 477 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 300>; - clock-names = "fck"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 300>; - status = "disabled"; - }; - - cpg: clock-controller@e6150000 { - compatible = "renesas,r8a77990-cpg-mssr"; - reg = <0 0xe6150000 0 0x1000>; - clocks = <&extal_clk>; - clock-names = "extal"; - #clock-cells = <2>; - #power-domain-cells = <0>; - #reset-cells = <1>; - }; - - rst: reset-controller@e6160000 { - compatible = "renesas,r8a77990-rst"; - reg = <0 0xe6160000 0 0x0200>; - }; - - sysc: system-controller@e6180000 { - compatible = "renesas,r8a77990-sysc"; - reg = <0 0xe6180000 0 0x0400>; - #power-domain-cells = <1>; - }; - - thermal: thermal@e6190000 { - compatible = "renesas,thermal-r8a77990"; - reg = <0 0xe6190000 0 0x10>, <0 0xe6190100 0 0x38>; - interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 522>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 522>; - #thermal-sensor-cells = <0>; - }; - - intc_ex: interrupt-controller@e61c0000 { - compatible = "renesas,intc-ex-r8a77990", "renesas,irqc"; - #interrupt-cells = <2>; - interrupt-controller; - reg = <0 0xe61c0000 0 0x200>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 161 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 407>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 407>; - }; - - tmu0: timer@e61e0000 { - compatible = "renesas,tmu-r8a77990", "renesas,tmu"; - reg = <0 0xe61e0000 0 0x30>; - interrupts = <GIC_SPI 136 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 137 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 138 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 125>; - clock-names = "fck"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 125>; - status = "disabled"; - }; - - tmu1: timer@e6fc0000 { - compatible = "renesas,tmu-r8a77990", "renesas,tmu"; - reg = <0 0xe6fc0000 0 0x30>; - interrupts = <GIC_SPI 128 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 129 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 130 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 124>; - clock-names = "fck"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 124>; - status = "disabled"; - }; - - tmu2: timer@e6fd0000 { - compatible = "renesas,tmu-r8a77990", "renesas,tmu"; - reg = <0 0xe6fd0000 0 0x30>; - interrupts = <GIC_SPI 303 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 304 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 305 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 123>; - clock-names = "fck"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 123>; - status = "disabled"; - }; - - tmu3: timer@e6fe0000 { - compatible = "renesas,tmu-r8a77990", "renesas,tmu"; - reg = <0 0xe6fe0000 0 0x30>; - interrupts = <GIC_SPI 131 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 132 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 133 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 122>; - clock-names = "fck"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 122>; - status = "disabled"; - }; - - tmu4: timer@ffc00000 { - compatible = "renesas,tmu-r8a77990", "renesas,tmu"; - reg = <0 0xffc00000 0 0x30>; - interrupts = <GIC_SPI 406 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 407 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 408 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 121>; - clock-names = "fck"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 121>; - status = "disabled"; - }; - - i2c0: i2c@e6500000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a77990", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6500000 0 0x40>; - interrupts = <GIC_SPI 287 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 931>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 931>; - dmas = <&dmac1 0x91>, <&dmac1 0x90>, - <&dmac2 0x91>, <&dmac2 0x90>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - status = "disabled"; - }; - - i2c1: i2c@e6508000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a77990", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6508000 0 0x40>; - interrupts = <GIC_SPI 288 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 930>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 930>; - dmas = <&dmac1 0x93>, <&dmac1 0x92>, - <&dmac2 0x93>, <&dmac2 0x92>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c2: i2c@e6510000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a77990", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6510000 0 0x40>; - interrupts = <GIC_SPI 286 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 929>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 929>; - dmas = <&dmac1 0x95>, <&dmac1 0x94>, - <&dmac2 0x95>, <&dmac2 0x94>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c3: i2c@e66d0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a77990", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66d0000 0 0x40>; - interrupts = <GIC_SPI 290 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 928>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 928>; - dmas = <&dmac0 0x97>, <&dmac0 0x96>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - status = "disabled"; - }; - - i2c4: i2c@e66d8000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a77990", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66d8000 0 0x40>; - interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 927>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 927>; - dmas = <&dmac0 0x99>, <&dmac0 0x98>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c5: i2c@e66e0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a77990", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66e0000 0 0x40>; - interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 919>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 919>; - dmas = <&dmac0 0x9b>, <&dmac0 0x9a>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c6: i2c@e66e8000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a77990", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66e8000 0 0x40>; - interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 918>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 918>; - dmas = <&dmac0 0x9d>, <&dmac0 0x9c>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c7: i2c@e6690000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a77990", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6690000 0 0x40>; - interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 1003>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 1003>; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - hscif0: serial@e6540000 { - compatible = "renesas,hscif-r8a77990", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe6540000 0 0x60>; - interrupts = <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 520>, - <&cpg CPG_CORE R8A77990_CLK_S3D1C>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x31>, <&dmac1 0x30>, - <&dmac2 0x31>, <&dmac2 0x30>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 520>; - status = "disabled"; - }; - - hscif1: serial@e6550000 { - compatible = "renesas,hscif-r8a77990", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe6550000 0 0x60>; - interrupts = <GIC_SPI 155 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 519>, - <&cpg CPG_CORE R8A77990_CLK_S3D1C>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x33>, <&dmac1 0x32>, - <&dmac2 0x33>, <&dmac2 0x32>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 519>; - status = "disabled"; - }; - - hscif2: serial@e6560000 { - compatible = "renesas,hscif-r8a77990", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe6560000 0 0x60>; - interrupts = <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 518>, - <&cpg CPG_CORE R8A77990_CLK_S3D1C>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x35>, <&dmac1 0x34>, - <&dmac2 0x35>, <&dmac2 0x34>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 518>; - status = "disabled"; - }; - - hscif3: serial@e66a0000 { - compatible = "renesas,hscif-r8a77990", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe66a0000 0 0x60>; - interrupts = <GIC_SPI 145 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 517>, - <&cpg CPG_CORE R8A77990_CLK_S3D1C>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x37>, <&dmac0 0x36>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 517>; - status = "disabled"; - }; - - hscif4: serial@e66b0000 { - compatible = "renesas,hscif-r8a77990", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe66b0000 0 0x60>; - interrupts = <GIC_SPI 146 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 516>, - <&cpg CPG_CORE R8A77990_CLK_S3D1C>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x39>, <&dmac0 0x38>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 516>; - status = "disabled"; - }; - - hsusb: usb@e6590000 { - compatible = "renesas,usbhs-r8a77990", - "renesas,rcar-gen3-usbhs"; - reg = <0 0xe6590000 0 0x200>; - interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 704>, <&cpg CPG_MOD 703>; - dmas = <&usb_dmac0 0>, <&usb_dmac0 1>, - <&usb_dmac1 0>, <&usb_dmac1 1>; - dma-names = "ch0", "ch1", "ch2", "ch3"; - renesas,buswait = <11>; - phys = <&usb2_phy0 3>; - phy-names = "usb"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 704>, <&cpg 703>; - status = "disabled"; - }; - - usb_dmac0: dma-controller@e65a0000 { - compatible = "renesas,r8a77990-usb-dmac", - "renesas,usb-dmac"; - reg = <0 0xe65a0000 0 0x100>; - interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1"; - clocks = <&cpg CPG_MOD 330>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 330>; - #dma-cells = <1>; - dma-channels = <2>; - }; - - usb_dmac1: dma-controller@e65b0000 { - compatible = "renesas,r8a77990-usb-dmac", - "renesas,usb-dmac"; - reg = <0 0xe65b0000 0 0x100>; - interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1"; - clocks = <&cpg CPG_MOD 331>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 331>; - #dma-cells = <1>; - dma-channels = <2>; - }; - - arm_cc630p: crypto@e6601000 { - compatible = "arm,cryptocell-630p-ree"; - interrupts = <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x0 0xe6601000 0 0x1000>; - clocks = <&cpg CPG_MOD 229>; - resets = <&cpg 229>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - }; - - dmac0: dma-controller@e6700000 { - compatible = "renesas,dmac-r8a77990", - "renesas,rcar-dmac"; - reg = <0 0xe6700000 0 0x10000>; - interrupts = <GIC_SPI 199 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 200 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 201 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 202 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 203 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 204 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 205 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 206 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 207 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 208 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 209 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 210 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 211 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 212 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 213 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 214 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 215 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 219>; - clock-names = "fck"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 219>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_ds0 0>, <&ipmmu_ds0 1>, - <&ipmmu_ds0 2>, <&ipmmu_ds0 3>, - <&ipmmu_ds0 4>, <&ipmmu_ds0 5>, - <&ipmmu_ds0 6>, <&ipmmu_ds0 7>, - <&ipmmu_ds0 8>, <&ipmmu_ds0 9>, - <&ipmmu_ds0 10>, <&ipmmu_ds0 11>, - <&ipmmu_ds0 12>, <&ipmmu_ds0 13>, - <&ipmmu_ds0 14>, <&ipmmu_ds0 15>; - }; - - dmac1: dma-controller@e7300000 { - compatible = "renesas,dmac-r8a77990", - "renesas,rcar-dmac"; - reg = <0 0xe7300000 0 0x10000>; - interrupts = <GIC_SPI 220 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 216 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 217 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 218 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 219 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 308 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 309 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 310 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 311 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 312 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 313 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 314 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 315 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 316 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 317 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 318 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 319 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 218>; - clock-names = "fck"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 218>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_ds1 0>, <&ipmmu_ds1 1>, - <&ipmmu_ds1 2>, <&ipmmu_ds1 3>, - <&ipmmu_ds1 4>, <&ipmmu_ds1 5>, - <&ipmmu_ds1 6>, <&ipmmu_ds1 7>, - <&ipmmu_ds1 8>, <&ipmmu_ds1 9>, - <&ipmmu_ds1 10>, <&ipmmu_ds1 11>, - <&ipmmu_ds1 12>, <&ipmmu_ds1 13>, - <&ipmmu_ds1 14>, <&ipmmu_ds1 15>; - }; - - dmac2: dma-controller@e7310000 { - compatible = "renesas,dmac-r8a77990", - "renesas,rcar-dmac"; - reg = <0 0xe7310000 0 0x10000>; - interrupts = <GIC_SPI 416 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 417 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 418 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 419 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 420 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 421 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 422 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 423 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 424 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 425 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 426 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 427 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 428 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 429 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 430 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 431 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 397 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 217>; - clock-names = "fck"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 217>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_ds1 16>, <&ipmmu_ds1 17>, - <&ipmmu_ds1 18>, <&ipmmu_ds1 19>, - <&ipmmu_ds1 20>, <&ipmmu_ds1 21>, - <&ipmmu_ds1 22>, <&ipmmu_ds1 23>, - <&ipmmu_ds1 24>, <&ipmmu_ds1 25>, - <&ipmmu_ds1 26>, <&ipmmu_ds1 27>, - <&ipmmu_ds1 28>, <&ipmmu_ds1 29>, - <&ipmmu_ds1 30>, <&ipmmu_ds1 31>; - }; - - ipmmu_ds0: iommu@e6740000 { - compatible = "renesas,ipmmu-r8a77990"; - reg = <0 0xe6740000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 0>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_ds1: iommu@e7740000 { - compatible = "renesas,ipmmu-r8a77990"; - reg = <0 0xe7740000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 1>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_hc: iommu@e6570000 { - compatible = "renesas,ipmmu-r8a77990"; - reg = <0 0xe6570000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 2>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_mm: iommu@e67b0000 { - compatible = "renesas,ipmmu-r8a77990"; - reg = <0 0xe67b0000 0 0x1000>; - interrupts = <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_mp: iommu@ec670000 { - compatible = "renesas,ipmmu-r8a77990"; - reg = <0 0xec670000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 4>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_pv0: iommu@fd800000 { - compatible = "renesas,ipmmu-r8a77990"; - reg = <0 0xfd800000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 6>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_rt: iommu@ffc80000 { - compatible = "renesas,ipmmu-r8a77990"; - reg = <0 0xffc80000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 10>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_vc0: iommu@fe6b0000 { - compatible = "renesas,ipmmu-r8a77990"; - reg = <0 0xfe6b0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 12>; - power-domains = <&sysc R8A77990_PD_A3VC>; - #iommu-cells = <1>; - }; - - ipmmu_vi0: iommu@febd0000 { - compatible = "renesas,ipmmu-r8a77990"; - reg = <0 0xfebd0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 14>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_vp0: iommu@fe990000 { - compatible = "renesas,ipmmu-r8a77990"; - reg = <0 0xfe990000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 16>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - avb: ethernet@e6800000 { - compatible = "renesas,etheravb-r8a77990", - "renesas,etheravb-rcar-gen3"; - reg = <0 0xe6800000 0 0x800>; - interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 47 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 63 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15", - "ch16", "ch17", "ch18", "ch19", - "ch20", "ch21", "ch22", "ch23", - "ch24"; - clocks = <&cpg CPG_MOD 812>; - clock-names = "fck"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 812>; - phy-mode = "rgmii"; - rx-internal-delay-ps = <0>; - iommus = <&ipmmu_ds0 16>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - can0: can@e6c30000 { - compatible = "renesas,can-r8a77990", - "renesas,rcar-gen3-can"; - reg = <0 0xe6c30000 0 0x1000>; - interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 916>, - <&cpg CPG_CORE R8A77990_CLK_CANFD>, - <&can_clk>; - clock-names = "clkp1", "clkp2", "can_clk"; - assigned-clocks = <&cpg CPG_CORE R8A77990_CLK_CANFD>; - assigned-clock-rates = <40000000>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 916>; - status = "disabled"; - }; - - can1: can@e6c38000 { - compatible = "renesas,can-r8a77990", - "renesas,rcar-gen3-can"; - reg = <0 0xe6c38000 0 0x1000>; - interrupts = <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 915>, - <&cpg CPG_CORE R8A77990_CLK_CANFD>, - <&can_clk>; - clock-names = "clkp1", "clkp2", "can_clk"; - assigned-clocks = <&cpg CPG_CORE R8A77990_CLK_CANFD>; - assigned-clock-rates = <40000000>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 915>; - status = "disabled"; - }; - - canfd: can@e66c0000 { - compatible = "renesas,r8a77990-canfd", - "renesas,rcar-gen3-canfd"; - reg = <0 0xe66c0000 0 0x8000>; - interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch_int", "g_int"; - clocks = <&cpg CPG_MOD 914>, - <&cpg CPG_CORE R8A77990_CLK_CANFD>, - <&can_clk>; - clock-names = "fck", "canfd", "can_clk"; - assigned-clocks = <&cpg CPG_CORE R8A77990_CLK_CANFD>; - assigned-clock-rates = <40000000>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 914>; - status = "disabled"; - - channel0 { - status = "disabled"; - }; - - channel1 { - status = "disabled"; - }; - }; - - pwm0: pwm@e6e30000 { - compatible = "renesas,pwm-r8a77990", "renesas,pwm-rcar"; - reg = <0 0xe6e30000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - pwm1: pwm@e6e31000 { - compatible = "renesas,pwm-r8a77990", "renesas,pwm-rcar"; - reg = <0 0xe6e31000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - pwm2: pwm@e6e32000 { - compatible = "renesas,pwm-r8a77990", "renesas,pwm-rcar"; - reg = <0 0xe6e32000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - pwm3: pwm@e6e33000 { - compatible = "renesas,pwm-r8a77990", "renesas,pwm-rcar"; - reg = <0 0xe6e33000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - pwm4: pwm@e6e34000 { - compatible = "renesas,pwm-r8a77990", "renesas,pwm-rcar"; - reg = <0 0xe6e34000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - pwm5: pwm@e6e35000 { - compatible = "renesas,pwm-r8a77990", "renesas,pwm-rcar"; - reg = <0 0xe6e35000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - pwm6: pwm@e6e36000 { - compatible = "renesas,pwm-r8a77990", "renesas,pwm-rcar"; - reg = <0 0xe6e36000 0 0x8>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 523>; - #pwm-cells = <2>; - status = "disabled"; - }; - - scif0: serial@e6e60000 { - compatible = "renesas,scif-r8a77990", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6e60000 0 64>; - interrupts = <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 207>, - <&cpg CPG_CORE R8A77990_CLK_S3D1C>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x51>, <&dmac1 0x50>, - <&dmac2 0x51>, <&dmac2 0x50>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 207>; - status = "disabled"; - }; - - scif1: serial@e6e68000 { - compatible = "renesas,scif-r8a77990", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6e68000 0 64>; - interrupts = <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 206>, - <&cpg CPG_CORE R8A77990_CLK_S3D1C>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x53>, <&dmac1 0x52>, - <&dmac2 0x53>, <&dmac2 0x52>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 206>; - status = "disabled"; - }; - - scif2: serial@e6e88000 { - compatible = "renesas,scif-r8a77990", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6e88000 0 64>; - interrupts = <GIC_SPI 164 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 310>, - <&cpg CPG_CORE R8A77990_CLK_S3D1C>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x13>, <&dmac1 0x12>, - <&dmac2 0x13>, <&dmac2 0x12>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 310>; - status = "disabled"; - }; - - scif3: serial@e6c50000 { - compatible = "renesas,scif-r8a77990", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6c50000 0 64>; - interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 204>, - <&cpg CPG_CORE R8A77990_CLK_S3D1C>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x57>, <&dmac0 0x56>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 204>; - status = "disabled"; - }; - - scif4: serial@e6c40000 { - compatible = "renesas,scif-r8a77990", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6c40000 0 64>; - interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 203>, - <&cpg CPG_CORE R8A77990_CLK_S3D1C>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x59>, <&dmac0 0x58>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 203>; - status = "disabled"; - }; - - scif5: serial@e6f30000 { - compatible = "renesas,scif-r8a77990", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6f30000 0 64>; - interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 202>, - <&cpg CPG_CORE R8A77990_CLK_S3D1C>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x5b>, <&dmac0 0x5a>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 202>; - status = "disabled"; - }; - - msiof0: spi@e6e90000 { - compatible = "renesas,msiof-r8a77990", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6e90000 0 0x0064>; - interrupts = <GIC_SPI 156 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 211>; - dmas = <&dmac1 0x41>, <&dmac1 0x40>, - <&dmac2 0x41>, <&dmac2 0x40>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 211>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof1: spi@e6ea0000 { - compatible = "renesas,msiof-r8a77990", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6ea0000 0 0x0064>; - interrupts = <GIC_SPI 157 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 210>; - dmas = <&dmac0 0x43>, <&dmac0 0x42>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 210>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof2: spi@e6c00000 { - compatible = "renesas,msiof-r8a77990", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6c00000 0 0x0064>; - interrupts = <GIC_SPI 158 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 209>; - dmas = <&dmac0 0x45>, <&dmac0 0x44>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 209>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof3: spi@e6c10000 { - compatible = "renesas,msiof-r8a77990", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6c10000 0 0x0064>; - interrupts = <GIC_SPI 159 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 208>; - dmas = <&dmac0 0x47>, <&dmac0 0x46>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 208>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - vin4: video@e6ef4000 { - compatible = "renesas,vin-r8a77990"; - reg = <0 0xe6ef4000 0 0x1000>; - interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 807>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 807>; - renesas,id = <4>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin4csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin4>; - }; - }; - }; - }; - - vin5: video@e6ef5000 { - compatible = "renesas,vin-r8a77990"; - reg = <0 0xe6ef5000 0 0x1000>; - interrupts = <GIC_SPI 175 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 806>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 806>; - renesas,id = <5>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - vin5csi40: endpoint@2 { - reg = <2>; - remote-endpoint = <&csi40vin5>; - }; - }; - }; - }; - - drif00: rif@e6f40000 { - compatible = "renesas,r8a77990-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6f40000 0 0x84>; - interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 515>; - clock-names = "fck"; - dmas = <&dmac1 0x20>, <&dmac2 0x20>; - dma-names = "rx", "rx"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 515>; - renesas,bonding = <&drif01>; - status = "disabled"; - }; - - drif01: rif@e6f50000 { - compatible = "renesas,r8a77990-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6f50000 0 0x84>; - interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 514>; - clock-names = "fck"; - dmas = <&dmac1 0x22>, <&dmac2 0x22>; - dma-names = "rx", "rx"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 514>; - renesas,bonding = <&drif00>; - status = "disabled"; - }; - - drif10: rif@e6f60000 { - compatible = "renesas,r8a77990-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6f60000 0 0x84>; - interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 513>; - clock-names = "fck"; - dmas = <&dmac1 0x24>, <&dmac2 0x24>; - dma-names = "rx", "rx"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 513>; - renesas,bonding = <&drif11>; - status = "disabled"; - }; - - drif11: rif@e6f70000 { - compatible = "renesas,r8a77990-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6f70000 0 0x84>; - interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 512>; - clock-names = "fck"; - dmas = <&dmac1 0x26>, <&dmac2 0x26>; - dma-names = "rx", "rx"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 512>; - renesas,bonding = <&drif10>; - status = "disabled"; - }; - - drif20: rif@e6f80000 { - compatible = "renesas,r8a77990-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6f80000 0 0x84>; - interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 511>; - clock-names = "fck"; - dmas = <&dmac0 0x28>; - dma-names = "rx"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 511>; - renesas,bonding = <&drif21>; - status = "disabled"; - }; - - drif21: rif@e6f90000 { - compatible = "renesas,r8a77990-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6f90000 0 0x84>; - interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 510>; - clock-names = "fck"; - dmas = <&dmac0 0x2a>; - dma-names = "rx"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 510>; - renesas,bonding = <&drif20>; - status = "disabled"; - }; - - drif30: rif@e6fa0000 { - compatible = "renesas,r8a77990-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6fa0000 0 0x84>; - interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 509>; - clock-names = "fck"; - dmas = <&dmac0 0x2c>; - dma-names = "rx"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 509>; - renesas,bonding = <&drif31>; - status = "disabled"; - }; - - drif31: rif@e6fb0000 { - compatible = "renesas,r8a77990-drif", - "renesas,rcar-gen3-drif"; - reg = <0 0xe6fb0000 0 0x84>; - interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 508>; - clock-names = "fck"; - dmas = <&dmac0 0x2e>; - dma-names = "rx"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 508>; - renesas,bonding = <&drif30>; - status = "disabled"; - }; - - rcar_sound: sound@ec500000 { - /* - * #sound-dai-cells is required if simple-card - * - * Single DAI : #sound-dai-cells = <0>; <&rcar_sound>; - * Multi DAI : #sound-dai-cells = <1>; <&rcar_sound N>; - */ - /* - * #clock-cells is required for audio_clkout0/1/2/3 - * - * clkout : #clock-cells = <0>; <&rcar_sound>; - * clkout0/1/2/3: #clock-cells = <1>; <&rcar_sound N>; - */ - compatible = "renesas,rcar_sound-r8a77990", "renesas,rcar_sound-gen3"; - reg = <0 0xec500000 0 0x1000>, /* SCU */ - <0 0xec5a0000 0 0x100>, /* ADG */ - <0 0xec540000 0 0x1000>, /* SSIU */ - <0 0xec541000 0 0x280>, /* SSI */ - <0 0xec760000 0 0x200>; /* Audio DMAC peri peri*/ - reg-names = "scu", "adg", "ssiu", "ssi", "audmapp"; - - clocks = <&cpg CPG_MOD 1005>, - <&cpg CPG_MOD 1006>, <&cpg CPG_MOD 1007>, - <&cpg CPG_MOD 1008>, <&cpg CPG_MOD 1009>, - <&cpg CPG_MOD 1010>, <&cpg CPG_MOD 1011>, - <&cpg CPG_MOD 1012>, <&cpg CPG_MOD 1013>, - <&cpg CPG_MOD 1014>, <&cpg CPG_MOD 1015>, - <&cpg CPG_MOD 1022>, <&cpg CPG_MOD 1023>, - <&cpg CPG_MOD 1024>, <&cpg CPG_MOD 1025>, - <&cpg CPG_MOD 1026>, <&cpg CPG_MOD 1027>, - <&cpg CPG_MOD 1028>, <&cpg CPG_MOD 1029>, - <&cpg CPG_MOD 1030>, <&cpg CPG_MOD 1031>, - <&cpg CPG_MOD 1020>, <&cpg CPG_MOD 1021>, - <&cpg CPG_MOD 1020>, <&cpg CPG_MOD 1021>, - <&cpg CPG_MOD 1019>, <&cpg CPG_MOD 1018>, - <&audio_clk_a>, <&audio_clk_b>, - <&audio_clk_c>, - <&cpg CPG_CORE R8A77990_CLK_ZA2>; - clock-names = "ssi-all", - "ssi.9", "ssi.8", "ssi.7", "ssi.6", - "ssi.5", "ssi.4", "ssi.3", "ssi.2", - "ssi.1", "ssi.0", - "src.9", "src.8", "src.7", "src.6", - "src.5", "src.4", "src.3", "src.2", - "src.1", "src.0", - "mix.1", "mix.0", - "ctu.1", "ctu.0", - "dvc.0", "dvc.1", - "clk_a", "clk_b", "clk_c", "clk_i"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 1005>, - <&cpg 1006>, <&cpg 1007>, - <&cpg 1008>, <&cpg 1009>, - <&cpg 1010>, <&cpg 1011>, - <&cpg 1012>, <&cpg 1013>, - <&cpg 1014>, <&cpg 1015>; - reset-names = "ssi-all", - "ssi.9", "ssi.8", "ssi.7", "ssi.6", - "ssi.5", "ssi.4", "ssi.3", "ssi.2", - "ssi.1", "ssi.0"; - status = "disabled"; - - rcar_sound,ctu { - ctu00: ctu-0 { }; - ctu01: ctu-1 { }; - ctu02: ctu-2 { }; - ctu03: ctu-3 { }; - ctu10: ctu-4 { }; - ctu11: ctu-5 { }; - ctu12: ctu-6 { }; - ctu13: ctu-7 { }; - }; - - rcar_sound,dvc { - dvc0: dvc-0 { - dmas = <&audma0 0xbc>; - dma-names = "tx"; - }; - dvc1: dvc-1 { - dmas = <&audma0 0xbe>; - dma-names = "tx"; - }; - }; - - rcar_sound,mix { - mix0: mix-0 { }; - mix1: mix-1 { }; - }; - - rcar_sound,src { - src0: src-0 { - interrupts = <GIC_SPI 352 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x85>, <&audma0 0x9a>; - dma-names = "rx", "tx"; - }; - src1: src-1 { - interrupts = <GIC_SPI 353 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x87>, <&audma0 0x9c>; - dma-names = "rx", "tx"; - }; - src2: src-2 { - interrupts = <GIC_SPI 354 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x89>, <&audma0 0x9e>; - dma-names = "rx", "tx"; - }; - src3: src-3 { - interrupts = <GIC_SPI 355 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x8b>, <&audma0 0xa0>; - dma-names = "rx", "tx"; - }; - src4: src-4 { - interrupts = <GIC_SPI 356 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x8d>, <&audma0 0xb0>; - dma-names = "rx", "tx"; - }; - src5: src-5 { - interrupts = <GIC_SPI 357 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x8f>, <&audma0 0xb2>; - dma-names = "rx", "tx"; - }; - src6: src-6 { - interrupts = <GIC_SPI 358 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x91>, <&audma0 0xb4>; - dma-names = "rx", "tx"; - }; - src7: src-7 { - interrupts = <GIC_SPI 359 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x93>, <&audma0 0xb6>; - dma-names = "rx", "tx"; - }; - src8: src-8 { - interrupts = <GIC_SPI 360 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x95>, <&audma0 0xb8>; - dma-names = "rx", "tx"; - }; - src9: src-9 { - interrupts = <GIC_SPI 361 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x97>, <&audma0 0xba>; - dma-names = "rx", "tx"; - }; - }; - - rcar_sound,ssi { - ssi0: ssi-0 { - interrupts = <GIC_SPI 370 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x01>, <&audma0 0x02>, - <&audma0 0x15>, <&audma0 0x16>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi1: ssi-1 { - interrupts = <GIC_SPI 371 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x03>, <&audma0 0x04>, - <&audma0 0x49>, <&audma0 0x4a>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi2: ssi-2 { - interrupts = <GIC_SPI 372 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x05>, <&audma0 0x06>, - <&audma0 0x63>, <&audma0 0x64>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi3: ssi-3 { - interrupts = <GIC_SPI 373 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x07>, <&audma0 0x08>, - <&audma0 0x6f>, <&audma0 0x70>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi4: ssi-4 { - interrupts = <GIC_SPI 374 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x09>, <&audma0 0x0a>, - <&audma0 0x71>, <&audma0 0x72>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi5: ssi-5 { - interrupts = <GIC_SPI 375 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x0b>, <&audma0 0x0c>, - <&audma0 0x73>, <&audma0 0x74>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi6: ssi-6 { - interrupts = <GIC_SPI 376 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x0d>, <&audma0 0x0e>, - <&audma0 0x75>, <&audma0 0x76>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi7: ssi-7 { - interrupts = <GIC_SPI 377 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x0f>, <&audma0 0x10>, - <&audma0 0x79>, <&audma0 0x7a>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi8: ssi-8 { - interrupts = <GIC_SPI 378 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x11>, <&audma0 0x12>, - <&audma0 0x7b>, <&audma0 0x7c>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi9: ssi-9 { - interrupts = <GIC_SPI 379 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x13>, <&audma0 0x14>, - <&audma0 0x7d>, <&audma0 0x7e>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - }; - }; - - mlp: mlp@ec520000 { - compatible = "renesas,r8a77990-mlp", - "renesas,rcar-gen3-mlp"; - reg = <0 0xec520000 0 0x800>; - interrupts = <GIC_SPI 384 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 385 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 802>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 802>; - status = "disabled"; - }; - - audma0: dma-controller@ec700000 { - compatible = "renesas,dmac-r8a77990", - "renesas,rcar-dmac"; - reg = <0 0xec700000 0 0x10000>; - interrupts = <GIC_SPI 350 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 320 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 321 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 322 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 323 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 324 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 325 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 326 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 327 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 328 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 329 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 330 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 331 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 332 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 333 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 334 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 335 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 502>; - clock-names = "fck"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 502>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_mp 0>, <&ipmmu_mp 1>, - <&ipmmu_mp 2>, <&ipmmu_mp 3>, - <&ipmmu_mp 4>, <&ipmmu_mp 5>, - <&ipmmu_mp 6>, <&ipmmu_mp 7>, - <&ipmmu_mp 8>, <&ipmmu_mp 9>, - <&ipmmu_mp 10>, <&ipmmu_mp 11>, - <&ipmmu_mp 12>, <&ipmmu_mp 13>, - <&ipmmu_mp 14>, <&ipmmu_mp 15>; - }; - - xhci0: usb@ee000000 { - compatible = "renesas,xhci-r8a77990", - "renesas,rcar-gen3-xhci"; - reg = <0 0xee000000 0 0xc00>; - interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 328>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 328>; - status = "disabled"; - }; - - usb3_peri0: usb@ee020000 { - compatible = "renesas,r8a77990-usb3-peri", - "renesas,rcar-gen3-usb3-peri"; - reg = <0 0xee020000 0 0x400>; - interrupts = <GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 328>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 328>; - status = "disabled"; - }; - - ohci0: usb@ee080000 { - compatible = "generic-ohci"; - reg = <0 0xee080000 0 0x100>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>; - phys = <&usb2_phy0 1>; - phy-names = "usb"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 703>, <&cpg 704>; - status = "disabled"; - }; - - ehci0: usb@ee080100 { - compatible = "generic-ehci"; - reg = <0 0xee080100 0 0x100>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>; - phys = <&usb2_phy0 2>; - phy-names = "usb"; - companion = <&ohci0>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 703>, <&cpg 704>; - status = "disabled"; - }; - - usb2_phy0: usb-phy@ee080200 { - compatible = "renesas,usb2-phy-r8a77990", - "renesas,rcar-gen3-usb2-phy"; - reg = <0 0xee080200 0 0x700>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 703>, <&cpg 704>; - #phy-cells = <1>; - status = "disabled"; - }; - - sdhi0: mmc@ee100000 { - compatible = "renesas,sdhi-r8a77990", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee100000 0 0x2000>; - interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 314>, <&cpg CPG_CORE R8A77990_CLK_SD0H>; - clock-names = "core", "clkh"; - max-frequency = <200000000>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 314>; - iommus = <&ipmmu_ds1 32>; - status = "disabled"; - }; - - sdhi1: mmc@ee120000 { - compatible = "renesas,sdhi-r8a77990", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee120000 0 0x2000>; - interrupts = <GIC_SPI 166 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 313>, <&cpg CPG_CORE R8A77990_CLK_SD1H>; - clock-names = "core", "clkh"; - max-frequency = <200000000>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 313>; - iommus = <&ipmmu_ds1 33>; - status = "disabled"; - }; - - sdhi3: mmc@ee160000 { - compatible = "renesas,sdhi-r8a77990", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee160000 0 0x2000>; - interrupts = <GIC_SPI 168 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 311>, <&cpg CPG_CORE R8A77990_CLK_SD3H>; - clock-names = "core", "clkh"; - max-frequency = <200000000>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 311>; - iommus = <&ipmmu_ds1 35>; - status = "disabled"; - }; - - rpc: spi@ee200000 { - compatible = "renesas,r8a77990-rpc-if", - "renesas,rcar-gen3-rpc-if"; - reg = <0 0xee200000 0 0x200>, - <0 0x08000000 0 0x04000000>, - <0 0xee208000 0 0x100>; - reg-names = "regs", "dirmap", "wbuf"; - interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 917>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 917>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - gic: interrupt-controller@f1010000 { - compatible = "arm,gic-400"; - #interrupt-cells = <3>; - #address-cells = <0>; - interrupt-controller; - reg = <0x0 0xf1010000 0 0x1000>, - <0x0 0xf1020000 0 0x20000>, - <0x0 0xf1040000 0 0x20000>, - <0x0 0xf1060000 0 0x20000>; - interrupts = <GIC_PPI 9 - (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_HIGH)>; - clocks = <&cpg CPG_MOD 408>; - clock-names = "clk"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 408>; - }; - - pciec0: pcie@fe000000 { - compatible = "renesas,pcie-r8a77990", - "renesas,pcie-rcar-gen3"; - reg = <0 0xfe000000 0 0x80000>; - #address-cells = <3>; - #size-cells = <2>; - bus-range = <0x00 0xff>; - device_type = "pci"; - ranges = <0x01000000 0 0x00000000 0 0xfe100000 0 0x00100000>, - <0x02000000 0 0xfe200000 0 0xfe200000 0 0x00200000>, - <0x02000000 0 0x30000000 0 0x30000000 0 0x08000000>, - <0x42000000 0 0x38000000 0 0x38000000 0 0x08000000>; - /* Map all possible DDR/IOMMU as inbound ranges */ - dma-ranges = <0x42000000 0 0x00000000 0 0x00000000 1 0x00000000>; - interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>; - #interrupt-cells = <1>; - interrupt-map-mask = <0 0 0 0>; - interrupt-map = <0 0 0 0 &gic GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 319>, <&pcie_bus_clk>; - clock-names = "pcie", "pcie_bus"; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 319>; - iommu-map = <0 &ipmmu_hc 0 1>; - iommu-map-mask = <0>; - status = "disabled"; - }; - - vspb0: vsp@fe960000 { - compatible = "renesas,vsp2"; - reg = <0 0xfe960000 0 0x8000>; - interrupts = <GIC_SPI 266 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 626>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 626>; - renesas,fcp = <&fcpvb0>; - }; - - fcpvb0: fcp@fe96f000 { - compatible = "renesas,fcpv"; - reg = <0 0xfe96f000 0 0x200>; - clocks = <&cpg CPG_MOD 607>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 607>; - iommus = <&ipmmu_vp0 5>; - }; - - vspi0: vsp@fe9a0000 { - compatible = "renesas,vsp2"; - reg = <0 0xfe9a0000 0 0x8000>; - interrupts = <GIC_SPI 444 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 631>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 631>; - renesas,fcp = <&fcpvi0>; - }; - - fcpvi0: fcp@fe9af000 { - compatible = "renesas,fcpv"; - reg = <0 0xfe9af000 0 0x200>; - clocks = <&cpg CPG_MOD 611>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 611>; - iommus = <&ipmmu_vp0 8>; - }; - - vspd0: vsp@fea20000 { - compatible = "renesas,vsp2"; - reg = <0 0xfea20000 0 0x7000>; - interrupts = <GIC_SPI 466 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 623>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 623>; - renesas,fcp = <&fcpvd0>; - }; - - fcpvd0: fcp@fea27000 { - compatible = "renesas,fcpv"; - reg = <0 0xfea27000 0 0x200>; - clocks = <&cpg CPG_MOD 603>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 603>; - iommus = <&ipmmu_vi0 8>; - }; - - vspd1: vsp@fea28000 { - compatible = "renesas,vsp2"; - reg = <0 0xfea28000 0 0x7000>; - interrupts = <GIC_SPI 467 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 622>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 622>; - renesas,fcp = <&fcpvd1>; - }; - - fcpvd1: fcp@fea2f000 { - compatible = "renesas,fcpv"; - reg = <0 0xfea2f000 0 0x200>; - clocks = <&cpg CPG_MOD 602>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 602>; - iommus = <&ipmmu_vi0 9>; - }; - - cmm0: cmm@fea40000 { - compatible = "renesas,r8a77990-cmm", - "renesas,rcar-gen3-cmm"; - reg = <0 0xfea40000 0 0x1000>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - clocks = <&cpg CPG_MOD 711>; - resets = <&cpg 711>; - }; - - cmm1: cmm@fea50000 { - compatible = "renesas,r8a77990-cmm", - "renesas,rcar-gen3-cmm"; - reg = <0 0xfea50000 0 0x1000>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - clocks = <&cpg CPG_MOD 710>; - resets = <&cpg 710>; - }; - - csi40: csi2@feaa0000 { - compatible = "renesas,r8a77990-csi2"; - reg = <0 0xfeaa0000 0 0x10000>; - interrupts = <GIC_SPI 246 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 716>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 716>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - - csi40vin4: endpoint@0 { - reg = <0>; - remote-endpoint = <&vin4csi40>; - }; - csi40vin5: endpoint@1 { - reg = <1>; - remote-endpoint = <&vin5csi40>; - }; - }; - }; - }; - - du: display@feb00000 { - compatible = "renesas,du-r8a77990"; - reg = <0 0xfeb00000 0 0x40000>; - interrupts = <GIC_SPI 256 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 268 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 724>, <&cpg CPG_MOD 723>; - clock-names = "du.0", "du.1"; - resets = <&cpg 724>; - reset-names = "du.0"; - - renesas,cmms = <&cmm0>, <&cmm1>; - renesas,vsps = <&vspd0 0>, <&vspd1 0>; - - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - - port@1 { - reg = <1>; - du_out_lvds0: endpoint { - remote-endpoint = <&lvds0_in>; - }; - }; - - port@2 { - reg = <2>; - du_out_lvds1: endpoint { - remote-endpoint = <&lvds1_in>; - }; - }; - }; - }; - - lvds0: lvds-encoder@feb90000 { - compatible = "renesas,r8a77990-lvds"; - reg = <0 0xfeb90000 0 0x20>; - clocks = <&cpg CPG_MOD 727>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 727>; - status = "disabled"; - - renesas,companion = <&lvds1>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - lvds0_in: endpoint { - remote-endpoint = <&du_out_lvds0>; - }; - }; - - port@1 { - reg = <1>; - }; - }; - }; - - lvds1: lvds-encoder@feb90100 { - compatible = "renesas,r8a77990-lvds"; - reg = <0 0xfeb90100 0 0x20>; - clocks = <&cpg CPG_MOD 727>; - power-domains = <&sysc R8A77990_PD_ALWAYS_ON>; - resets = <&cpg 726>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - lvds1_in: endpoint { - remote-endpoint = <&du_out_lvds1>; - }; - }; - - port@1 { - reg = <1>; - }; - }; - }; - - prr: chipid@fff00044 { - compatible = "renesas,prr"; - reg = <0 0xfff00044 0 4>; - }; - }; - - thermal-zones { - cpu-thermal { - polling-delay-passive = <250>; - polling-delay = <0>; - thermal-sensors = <&thermal>; - sustainable-power = <717>; - - cooling-maps { - map0 { - trip = <&target>; - cooling-device = <&a53_0 0 2>; - contribution = <1024>; - }; - }; - - trips { - sensor1_crit: sensor1-crit { - temperature = <120000>; - hysteresis = <2000>; - type = "critical"; - }; - - target: trip-point1 { - temperature = <100000>; - hysteresis = <2000>; - type = "passive"; - }; - }; - }; - }; - - timer { - compatible = "arm,armv8-timer"; - interrupts-extended = <&gic GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>; - }; -}; diff --git a/arch/arm/dts/r8a77995-draak.dts b/arch/arm/dts/r8a77995-draak.dts deleted file mode 100644 index 384825617fc..00000000000 --- a/arch/arm/dts/r8a77995-draak.dts +++ /dev/null @@ -1,16 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the Draak board with R-Car D3 - * - * Copyright (C) 2016-2018 Renesas Electronics Corp. - * Copyright (C) 2017 Glider bvba - */ - -/dts-v1/; -#include "r8a77995.dtsi" -#include "draak.dtsi" - -/ { - model = "Renesas Draak board based on r8a77995"; - compatible = "renesas,draak", "renesas,r8a77995"; -}; diff --git a/arch/arm/dts/r8a77995.dtsi b/arch/arm/dts/r8a77995.dtsi deleted file mode 100644 index e25024a7b66..00000000000 --- a/arch/arm/dts/r8a77995.dtsi +++ /dev/null @@ -1,1473 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the R-Car D3 (R8A77995) SoC - * - * Copyright (C) 2016 Renesas Electronics Corp. - * Copyright (C) 2017 Glider bvba - */ - -#include <dt-bindings/clock/r8a77995-cpg-mssr.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/power/r8a77995-sysc.h> - -/ { - compatible = "renesas,r8a77995"; - #address-cells = <2>; - #size-cells = <2>; - - /* - * The external audio clocks are configured as 0 Hz fixed frequency - * clocks by default. - * Boards that provide audio clocks should override them. - */ - audio_clk_a: audio_clk_a { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - audio_clk_b: audio_clk_b { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - /* External CAN clock - to be overridden by boards that provide it */ - can_clk: can { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - - a53_0: cpu@0 { - compatible = "arm,cortex-a53"; - reg = <0x0>; - device_type = "cpu"; - power-domains = <&sysc R8A77995_PD_CA53_CPU0>; - next-level-cache = <&L2_CA53>; - enable-method = "psci"; - }; - - L2_CA53: cache-controller-1 { - compatible = "cache"; - power-domains = <&sysc R8A77995_PD_CA53_SCU>; - cache-unified; - cache-level = <2>; - }; - }; - - extal_clk: extal { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board */ - clock-frequency = <0>; - }; - - pmu_a53 { - compatible = "arm,cortex-a53-pmu"; - interrupts-extended = <&gic GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>; - }; - - psci { - compatible = "arm,psci-1.0", "arm,psci-0.2"; - method = "smc"; - }; - - scif_clk: scif { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - soc { - compatible = "simple-bus"; - interrupt-parent = <&gic>; - #address-cells = <2>; - #size-cells = <2>; - ranges; - - rwdt: watchdog@e6020000 { - compatible = "renesas,r8a77995-wdt", - "renesas,rcar-gen3-wdt"; - reg = <0 0xe6020000 0 0x0c>; - interrupts = <GIC_SPI 140 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 402>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 402>; - status = "disabled"; - }; - - gpio0: gpio@e6050000 { - compatible = "renesas,gpio-r8a77995", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6050000 0 0x50>; - interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 0 9>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 912>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 912>; - }; - - gpio1: gpio@e6051000 { - compatible = "renesas,gpio-r8a77995", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6051000 0 0x50>; - interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 32 32>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 911>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 911>; - }; - - gpio2: gpio@e6052000 { - compatible = "renesas,gpio-r8a77995", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6052000 0 0x50>; - interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 64 32>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 910>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 910>; - }; - - gpio3: gpio@e6053000 { - compatible = "renesas,gpio-r8a77995", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6053000 0 0x50>; - interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 96 10>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 909>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 909>; - }; - - gpio4: gpio@e6054000 { - compatible = "renesas,gpio-r8a77995", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6054000 0 0x50>; - interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 128 32>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 908>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 908>; - }; - - gpio5: gpio@e6055000 { - compatible = "renesas,gpio-r8a77995", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6055000 0 0x50>; - interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 160 21>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 907>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 907>; - }; - - gpio6: gpio@e6055400 { - compatible = "renesas,gpio-r8a77995", - "renesas,rcar-gen3-gpio"; - reg = <0 0xe6055400 0 0x50>; - interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; - #gpio-cells = <2>; - gpio-controller; - gpio-ranges = <&pfc 0 192 14>; - #interrupt-cells = <2>; - interrupt-controller; - clocks = <&cpg CPG_MOD 906>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 906>; - }; - - pfc: pinctrl@e6060000 { - compatible = "renesas,pfc-r8a77995"; - reg = <0 0xe6060000 0 0x508>; - }; - - cmt0: timer@e60f0000 { - compatible = "renesas,r8a77995-cmt0", - "renesas,rcar-gen3-cmt0"; - reg = <0 0xe60f0000 0 0x1004>; - interrupts = <GIC_SPI 142 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 143 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 303>; - clock-names = "fck"; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 303>; - status = "disabled"; - }; - - cmt1: timer@e6130000 { - compatible = "renesas,r8a77995-cmt1", - "renesas,rcar-gen3-cmt1"; - reg = <0 0xe6130000 0 0x1004>; - interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 127 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 302>; - clock-names = "fck"; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 302>; - status = "disabled"; - }; - - cmt2: timer@e6140000 { - compatible = "renesas,r8a77995-cmt1", - "renesas,rcar-gen3-cmt1"; - reg = <0 0xe6140000 0 0x1004>; - interrupts = <GIC_SPI 398 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 399 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 400 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 401 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 402 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 403 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 404 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 405 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 301>; - clock-names = "fck"; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 301>; - status = "disabled"; - }; - - cmt3: timer@e6148000 { - compatible = "renesas,r8a77995-cmt1", - "renesas,rcar-gen3-cmt1"; - reg = <0 0xe6148000 0 0x1004>; - interrupts = <GIC_SPI 470 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 471 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 472 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 473 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 474 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 475 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 476 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 477 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 300>; - clock-names = "fck"; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 300>; - status = "disabled"; - }; - - cpg: clock-controller@e6150000 { - compatible = "renesas,r8a77995-cpg-mssr"; - reg = <0 0xe6150000 0 0x1000>; - clocks = <&extal_clk>; - clock-names = "extal"; - #clock-cells = <2>; - #power-domain-cells = <0>; - #reset-cells = <1>; - }; - - rst: reset-controller@e6160000 { - compatible = "renesas,r8a77995-rst"; - reg = <0 0xe6160000 0 0x0200>; - }; - - sysc: system-controller@e6180000 { - compatible = "renesas,r8a77995-sysc"; - reg = <0 0xe6180000 0 0x0400>; - #power-domain-cells = <1>; - }; - - thermal: thermal@e6190000 { - compatible = "renesas,thermal-r8a77995"; - reg = <0 0xe6190000 0 0x10>, <0 0xe6190100 0 0x38>; - interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 522>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 522>; - #thermal-sensor-cells = <0>; - }; - - intc_ex: interrupt-controller@e61c0000 { - compatible = "renesas,intc-ex-r8a77995", "renesas,irqc"; - #interrupt-cells = <2>; - interrupt-controller; - reg = <0 0xe61c0000 0 0x200>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 161 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 407>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 407>; - }; - - tmu0: timer@e61e0000 { - compatible = "renesas,tmu-r8a77995", "renesas,tmu"; - reg = <0 0xe61e0000 0 0x30>; - interrupts = <GIC_SPI 136 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 137 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 138 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 125>; - clock-names = "fck"; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 125>; - status = "disabled"; - }; - - tmu1: timer@e6fc0000 { - compatible = "renesas,tmu-r8a77995", "renesas,tmu"; - reg = <0 0xe6fc0000 0 0x30>; - interrupts = <GIC_SPI 128 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 129 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 130 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 124>; - clock-names = "fck"; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 124>; - status = "disabled"; - }; - - tmu2: timer@e6fd0000 { - compatible = "renesas,tmu-r8a77995", "renesas,tmu"; - reg = <0 0xe6fd0000 0 0x30>; - interrupts = <GIC_SPI 303 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 304 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 305 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 123>; - clock-names = "fck"; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 123>; - status = "disabled"; - }; - - tmu3: timer@e6fe0000 { - compatible = "renesas,tmu-r8a77995", "renesas,tmu"; - reg = <0 0xe6fe0000 0 0x30>; - interrupts = <GIC_SPI 131 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 132 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 133 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 122>; - clock-names = "fck"; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 122>; - status = "disabled"; - }; - - tmu4: timer@ffc00000 { - compatible = "renesas,tmu-r8a77995", "renesas,tmu"; - reg = <0 0xffc00000 0 0x30>; - interrupts = <GIC_SPI 406 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 407 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 408 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 121>; - clock-names = "fck"; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 121>; - status = "disabled"; - }; - - i2c0: i2c@e6500000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a77995", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6500000 0 0x40>; - interrupts = <GIC_SPI 287 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 931>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 931>; - dmas = <&dmac1 0x91>, <&dmac1 0x90>, - <&dmac2 0x91>, <&dmac2 0x90>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c1: i2c@e6508000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a77995", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6508000 0 0x40>; - interrupts = <GIC_SPI 288 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 930>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 930>; - dmas = <&dmac1 0x93>, <&dmac1 0x92>, - <&dmac2 0x93>, <&dmac2 0x92>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c2: i2c@e6510000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a77995", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe6510000 0 0x40>; - interrupts = <GIC_SPI 286 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 929>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 929>; - dmas = <&dmac1 0x95>, <&dmac1 0x94>, - <&dmac2 0x95>, <&dmac2 0x94>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - i2c3: i2c@e66d0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,i2c-r8a77995", - "renesas,rcar-gen3-i2c"; - reg = <0 0xe66d0000 0 0x40>; - interrupts = <GIC_SPI 290 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 928>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 928>; - dmas = <&dmac0 0x97>, <&dmac0 0x96>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <6>; - status = "disabled"; - }; - - hscif0: serial@e6540000 { - compatible = "renesas,hscif-r8a77995", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe6540000 0 0x60>; - interrupts = <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 520>, - <&cpg CPG_CORE R8A77995_CLK_S3D1C>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x31>, <&dmac1 0x30>, - <&dmac2 0x31>, <&dmac2 0x30>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 520>; - status = "disabled"; - }; - - hscif3: serial@e66a0000 { - compatible = "renesas,hscif-r8a77995", - "renesas,rcar-gen3-hscif", - "renesas,hscif"; - reg = <0 0xe66a0000 0 0x60>; - interrupts = <GIC_SPI 145 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 517>, - <&cpg CPG_CORE R8A77995_CLK_S3D1C>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x37>, <&dmac0 0x36>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 517>; - status = "disabled"; - }; - - hsusb: usb@e6590000 { - compatible = "renesas,usbhs-r8a77995", - "renesas,rcar-gen3-usbhs"; - reg = <0 0xe6590000 0 0x200>; - interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 704>, <&cpg CPG_MOD 703>; - dmas = <&usb_dmac0 0>, <&usb_dmac0 1>, - <&usb_dmac1 0>, <&usb_dmac1 1>; - dma-names = "ch0", "ch1", "ch2", "ch3"; - renesas,buswait = <11>; - phys = <&usb2_phy0 3>; - phy-names = "usb"; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 704>, <&cpg 703>; - status = "disabled"; - }; - - usb_dmac0: dma-controller@e65a0000 { - compatible = "renesas,r8a77995-usb-dmac", - "renesas,usb-dmac"; - reg = <0 0xe65a0000 0 0x100>; - interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1"; - clocks = <&cpg CPG_MOD 330>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 330>; - #dma-cells = <1>; - dma-channels = <2>; - }; - - usb_dmac1: dma-controller@e65b0000 { - compatible = "renesas,r8a77995-usb-dmac", - "renesas,usb-dmac"; - reg = <0 0xe65b0000 0 0x100>; - interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1"; - clocks = <&cpg CPG_MOD 331>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 331>; - #dma-cells = <1>; - dma-channels = <2>; - }; - - arm_cc630p: crypto@e6601000 { - compatible = "arm,cryptocell-630p-ree"; - interrupts = <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x0 0xe6601000 0 0x1000>; - clocks = <&cpg CPG_MOD 229>; - resets = <&cpg 229>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - }; - - canfd: can@e66c0000 { - compatible = "renesas,r8a77995-canfd", - "renesas,rcar-gen3-canfd"; - reg = <0 0xe66c0000 0 0x8000>; - interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch_int", "g_int"; - clocks = <&cpg CPG_MOD 914>, - <&cpg CPG_CORE R8A77995_CLK_CANFD>, - <&can_clk>; - clock-names = "fck", "canfd", "can_clk"; - assigned-clocks = <&cpg CPG_CORE R8A77995_CLK_CANFD>; - assigned-clock-rates = <40000000>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 914>; - status = "disabled"; - - channel0 { - status = "disabled"; - }; - - channel1 { - status = "disabled"; - }; - }; - - dmac0: dma-controller@e6700000 { - compatible = "renesas,dmac-r8a77995", - "renesas,rcar-dmac"; - reg = <0 0xe6700000 0 0x10000>; - interrupts = <GIC_SPI 199 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 200 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 201 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 202 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 203 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 204 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 205 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 206 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 207 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7"; - clocks = <&cpg CPG_MOD 219>; - clock-names = "fck"; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 219>; - #dma-cells = <1>; - dma-channels = <8>; - iommus = <&ipmmu_ds0 0>, <&ipmmu_ds0 1>, - <&ipmmu_ds0 2>, <&ipmmu_ds0 3>, - <&ipmmu_ds0 4>, <&ipmmu_ds0 5>, - <&ipmmu_ds0 6>, <&ipmmu_ds0 7>; - }; - - dmac1: dma-controller@e7300000 { - compatible = "renesas,dmac-r8a77995", - "renesas,rcar-dmac"; - reg = <0 0xe7300000 0 0x10000>; - interrupts = <GIC_SPI 220 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 216 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 217 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 218 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 219 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 308 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 309 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 310 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 311 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7"; - clocks = <&cpg CPG_MOD 218>; - clock-names = "fck"; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 218>; - #dma-cells = <1>; - dma-channels = <8>; - iommus = <&ipmmu_ds1 0>, <&ipmmu_ds1 1>, - <&ipmmu_ds1 2>, <&ipmmu_ds1 3>, - <&ipmmu_ds1 4>, <&ipmmu_ds1 5>, - <&ipmmu_ds1 6>, <&ipmmu_ds1 7>; - }; - - dmac2: dma-controller@e7310000 { - compatible = "renesas,dmac-r8a77995", - "renesas,rcar-dmac"; - reg = <0 0xe7310000 0 0x10000>; - interrupts = <GIC_SPI 416 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 417 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 418 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 419 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 420 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 421 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 422 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 423 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 424 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7"; - clocks = <&cpg CPG_MOD 217>; - clock-names = "fck"; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 217>; - #dma-cells = <1>; - dma-channels = <8>; - iommus = <&ipmmu_ds1 16>, <&ipmmu_ds1 17>, - <&ipmmu_ds1 18>, <&ipmmu_ds1 19>, - <&ipmmu_ds1 20>, <&ipmmu_ds1 21>, - <&ipmmu_ds1 22>, <&ipmmu_ds1 23>; - }; - - ipmmu_ds0: iommu@e6740000 { - compatible = "renesas,ipmmu-r8a77995"; - reg = <0 0xe6740000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 0>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_ds1: iommu@e7740000 { - compatible = "renesas,ipmmu-r8a77995"; - reg = <0 0xe7740000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 1>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_hc: iommu@e6570000 { - compatible = "renesas,ipmmu-r8a77995"; - reg = <0 0xe6570000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 2>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_mm: iommu@e67b0000 { - compatible = "renesas,ipmmu-r8a77995"; - reg = <0 0xe67b0000 0 0x1000>; - interrupts = <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_mp: iommu@ec670000 { - compatible = "renesas,ipmmu-r8a77995"; - reg = <0 0xec670000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 4>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_pv0: iommu@fd800000 { - compatible = "renesas,ipmmu-r8a77995"; - reg = <0 0xfd800000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 6>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_rt: iommu@ffc80000 { - compatible = "renesas,ipmmu-r8a77995"; - reg = <0 0xffc80000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 10>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_vc0: iommu@fe6b0000 { - compatible = "renesas,ipmmu-r8a77995"; - reg = <0 0xfe6b0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 12>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_vi0: iommu@febd0000 { - compatible = "renesas,ipmmu-r8a77995"; - reg = <0 0xfebd0000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 14>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_vp0: iommu@fe990000 { - compatible = "renesas,ipmmu-r8a77995"; - reg = <0 0xfe990000 0 0x1000>; - renesas,ipmmu-main = <&ipmmu_mm 16>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - avb: ethernet@e6800000 { - compatible = "renesas,etheravb-r8a77995", - "renesas,etheravb-rcar-gen3"; - reg = <0 0xe6800000 0 0x800>; - interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 47 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 63 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15", - "ch16", "ch17", "ch18", "ch19", - "ch20", "ch21", "ch22", "ch23", - "ch24"; - clocks = <&cpg CPG_MOD 812>; - clock-names = "fck"; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 812>; - phy-mode = "rgmii"; - rx-internal-delay-ps = <1800>; - iommus = <&ipmmu_ds0 16>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - can0: can@e6c30000 { - compatible = "renesas,can-r8a77995", - "renesas,rcar-gen3-can"; - reg = <0 0xe6c30000 0 0x1000>; - interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 916>, - <&cpg CPG_CORE R8A77995_CLK_CANFD>, - <&can_clk>; - clock-names = "clkp1", "clkp2", "can_clk"; - assigned-clocks = <&cpg CPG_CORE R8A77995_CLK_CANFD>; - assigned-clock-rates = <40000000>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 916>; - status = "disabled"; - }; - - can1: can@e6c38000 { - compatible = "renesas,can-r8a77995", - "renesas,rcar-gen3-can"; - reg = <0 0xe6c38000 0 0x1000>; - interrupts = <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 915>, - <&cpg CPG_CORE R8A77995_CLK_CANFD>, - <&can_clk>; - clock-names = "clkp1", "clkp2", "can_clk"; - assigned-clocks = <&cpg CPG_CORE R8A77995_CLK_CANFD>; - assigned-clock-rates = <40000000>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 915>; - status = "disabled"; - }; - - pwm0: pwm@e6e30000 { - compatible = "renesas,pwm-r8a77995", "renesas,pwm-rcar"; - reg = <0 0xe6e30000 0 0x8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 523>; - status = "disabled"; - }; - - pwm1: pwm@e6e31000 { - compatible = "renesas,pwm-r8a77995", "renesas,pwm-rcar"; - reg = <0 0xe6e31000 0 0x8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 523>; - status = "disabled"; - }; - - pwm2: pwm@e6e32000 { - compatible = "renesas,pwm-r8a77995", "renesas,pwm-rcar"; - reg = <0 0xe6e32000 0 0x8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 523>; - status = "disabled"; - }; - - pwm3: pwm@e6e33000 { - compatible = "renesas,pwm-r8a77995", "renesas,pwm-rcar"; - reg = <0 0xe6e33000 0 0x8>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 523>; - status = "disabled"; - }; - - scif0: serial@e6e60000 { - compatible = "renesas,scif-r8a77995", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6e60000 0 64>; - interrupts = <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 207>, - <&cpg CPG_CORE R8A77995_CLK_S3D1C>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x51>, <&dmac1 0x50>, - <&dmac2 0x51>, <&dmac2 0x50>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 207>; - status = "disabled"; - }; - - scif1: serial@e6e68000 { - compatible = "renesas,scif-r8a77995", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6e68000 0 64>; - interrupts = <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 206>, - <&cpg CPG_CORE R8A77995_CLK_S3D1C>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x53>, <&dmac1 0x52>, - <&dmac2 0x53>, <&dmac2 0x52>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 206>; - status = "disabled"; - }; - - scif2: serial@e6e88000 { - compatible = "renesas,scif-r8a77995", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6e88000 0 64>; - interrupts = <GIC_SPI 164 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 310>, - <&cpg CPG_CORE R8A77995_CLK_S3D1C>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x13>, <&dmac1 0x12>, - <&dmac2 0x13>, <&dmac2 0x12>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 310>; - status = "disabled"; - }; - - scif3: serial@e6c50000 { - compatible = "renesas,scif-r8a77995", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6c50000 0 64>; - interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 204>, - <&cpg CPG_CORE R8A77995_CLK_S3D1C>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x57>, <&dmac0 0x56>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 204>; - status = "disabled"; - }; - - scif4: serial@e6c40000 { - compatible = "renesas,scif-r8a77995", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6c40000 0 64>; - interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 203>, - <&cpg CPG_CORE R8A77995_CLK_S3D1C>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x59>, <&dmac0 0x58>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 203>; - status = "disabled"; - }; - - scif5: serial@e6f30000 { - compatible = "renesas,scif-r8a77995", - "renesas,rcar-gen3-scif", "renesas,scif"; - reg = <0 0xe6f30000 0 64>; - interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 202>, - <&cpg CPG_CORE R8A77995_CLK_S3D1C>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x5b>, <&dmac1 0x5a>, - <&dmac2 0x5b>, <&dmac2 0x5a>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 202>; - status = "disabled"; - }; - - msiof0: spi@e6e90000 { - compatible = "renesas,msiof-r8a77995", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6e90000 0 0x64>; - interrupts = <GIC_SPI 156 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 211>; - dmas = <&dmac1 0x41>, <&dmac1 0x40>, - <&dmac2 0x41>, <&dmac2 0x40>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 211>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof1: spi@e6ea0000 { - compatible = "renesas,msiof-r8a77995", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6ea0000 0 0x64>; - interrupts = <GIC_SPI 157 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 210>; - dmas = <&dmac1 0x43>, <&dmac1 0x42>, - <&dmac2 0x43>, <&dmac2 0x42>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 210>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof2: spi@e6c00000 { - compatible = "renesas,msiof-r8a77995", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6c00000 0 0x64>; - interrupts = <GIC_SPI 158 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 209>; - dmas = <&dmac0 0x45>, <&dmac0 0x44>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 209>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof3: spi@e6c10000 { - compatible = "renesas,msiof-r8a77995", - "renesas,rcar-gen3-msiof"; - reg = <0 0xe6c10000 0 0x64>; - interrupts = <GIC_SPI 159 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 208>; - dmas = <&dmac0 0x47>, <&dmac0 0x46>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 208>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - vin4: video@e6ef4000 { - compatible = "renesas,vin-r8a77995"; - reg = <0 0xe6ef4000 0 0x1000>; - interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 807>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 807>; - renesas,id = <4>; - status = "disabled"; - }; - - rcar_sound: sound@ec500000 { - /* - * #sound-dai-cells is required if simple-card - * - * Single DAI : #sound-dai-cells = <0>; <&rcar_sound>; - * Multi DAI : #sound-dai-cells = <1>; <&rcar_sound N>; - */ - /* - * #clock-cells is required for audio_clkout0/1/2/3 - * - * clkout : #clock-cells = <0>; <&rcar_sound>; - * clkout0/1/2/3: #clock-cells = <1>; <&rcar_sound N>; - */ - compatible = "renesas,rcar_sound-r8a77995", "renesas,rcar_sound-gen3"; - reg = <0 0xec500000 0 0x1000>, /* SCU */ - <0 0xec5a0000 0 0x100>, /* ADG */ - <0 0xec540000 0 0x1000>, /* SSIU */ - <0 0xec541000 0 0x280>, /* SSI */ - <0 0xec740000 0 0x200>; /* Audio DMAC peri peri*/ - reg-names = "scu", "adg", "ssiu", "ssi", "audmapp"; - - clocks = <&cpg CPG_MOD 1005>, - <&cpg CPG_MOD 1011>, <&cpg CPG_MOD 1012>, - <&cpg CPG_MOD 1025>, <&cpg CPG_MOD 1026>, - <&cpg CPG_MOD 1020>, <&cpg CPG_MOD 1021>, - <&cpg CPG_MOD 1020>, <&cpg CPG_MOD 1021>, - <&cpg CPG_MOD 1019>, <&cpg CPG_MOD 1018>, - <&audio_clk_a>, <&audio_clk_b>, - <&cpg CPG_CORE R8A77995_CLK_ZA2>; - clock-names = "ssi-all", - "ssi.4", "ssi.3", - "src.6", "src.5", - "mix.1", "mix.0", - "ctu.1", "ctu.0", - "dvc.0", "dvc.1", - "clk_a", "clk_b", "clk_i"; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 1005>, - <&cpg 1011>, <&cpg 1012>; - reset-names = "ssi-all", - "ssi.4", "ssi.3"; - status = "disabled"; - - rcar_sound,ctu { - ctu00: ctu-0 { }; - ctu01: ctu-1 { }; - ctu02: ctu-2 { }; - ctu03: ctu-3 { }; - ctu10: ctu-4 { }; - ctu11: ctu-5 { }; - ctu12: ctu-6 { }; - ctu13: ctu-7 { }; - }; - - rcar_sound,dvc { - dvc0: dvc-0 { - dmas = <&audma0 0xbc>; - dma-names = "tx"; - }; - dvc1: dvc-1 { - dmas = <&audma0 0xbe>; - dma-names = "tx"; - }; - }; - - rcar_sound,mix { - mix0: mix-0 { }; - mix1: mix-1 { }; - }; - - rcar_sound,src { - src5: src-5 { - interrupts = <GIC_SPI 357 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x8f>, <&audma0 0xb2>; - dma-names = "rx", "tx"; - }; - src6: src-6 { - interrupts = <GIC_SPI 358 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x91>, <&audma0 0xb4>; - dma-names = "rx", "tx"; - }; - }; - - rcar_sound,ssi { - ssi3: ssi-3 { - interrupts = <GIC_SPI 373 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x07>, <&audma0 0x08>, - <&audma0 0x6f>, <&audma0 0x70>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - ssi4: ssi-4 { - interrupts = <GIC_SPI 374 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&audma0 0x09>, <&audma0 0x0a>, - <&audma0 0x71>, <&audma0 0x72>; - dma-names = "rx", "tx", "rxu", "txu"; - }; - }; - }; - - mlp: mlp@ec520000 { - compatible = "renesas,r8a77995-mlp", - "renesas,rcar-gen3-mlp"; - reg = <0 0xec520000 0 0x800>; - interrupts = <GIC_SPI 384 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 385 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 802>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 802>; - status = "disabled"; - }; - - audma0: dma-controller@ec700000 { - compatible = "renesas,dmac-r8a77995", - "renesas,rcar-dmac"; - reg = <0 0xec700000 0 0x10000>; - interrupts = <GIC_SPI 350 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 320 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 321 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 322 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 323 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 324 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 325 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 326 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 327 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 328 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 329 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 330 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 331 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 332 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 333 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 334 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 335 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD 502>; - clock-names = "fck"; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 502>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_mp 0>, <&ipmmu_mp 1>, - <&ipmmu_mp 2>, <&ipmmu_mp 3>, - <&ipmmu_mp 4>, <&ipmmu_mp 5>, - <&ipmmu_mp 6>, <&ipmmu_mp 7>, - <&ipmmu_mp 8>, <&ipmmu_mp 9>, - <&ipmmu_mp 10>, <&ipmmu_mp 11>, - <&ipmmu_mp 12>, <&ipmmu_mp 13>, - <&ipmmu_mp 14>, <&ipmmu_mp 15>; - }; - - ohci0: usb@ee080000 { - compatible = "generic-ohci"; - reg = <0 0xee080000 0 0x100>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>; - phys = <&usb2_phy0 1>; - phy-names = "usb"; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 703>, <&cpg 704>; - status = "disabled"; - }; - - ehci0: usb@ee080100 { - compatible = "generic-ehci"; - reg = <0 0xee080100 0 0x100>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>; - phys = <&usb2_phy0 2>; - phy-names = "usb"; - companion = <&ohci0>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 703>, <&cpg 704>; - status = "disabled"; - }; - - usb2_phy0: usb-phy@ee080200 { - compatible = "renesas,usb2-phy-r8a77995", - "renesas,rcar-gen3-usb2-phy"; - reg = <0 0xee080200 0 0x700>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 703>, <&cpg 704>; - #phy-cells = <1>; - status = "disabled"; - }; - - sdhi2: mmc@ee140000 { - compatible = "renesas,sdhi-r8a77995", - "renesas,rcar-gen3-sdhi"; - reg = <0 0xee140000 0 0x2000>; - interrupts = <GIC_SPI 167 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 312>, <&cpg CPG_CORE R8A77995_CLK_SD0H>; - clock-names = "core", "clkh"; - max-frequency = <200000000>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 312>; - iommus = <&ipmmu_ds1 34>; - status = "disabled"; - }; - - rpc: spi@ee200000 { - compatible = "renesas,r8a77995-rpc-if", - "renesas,rcar-gen3-rpc-if"; - reg = <0 0xee200000 0 0x200>, - <0 0x08000000 0 0x04000000>, - <0 0xee208000 0 0x100>; - reg-names = "regs", "dirmap", "wbuf"; - interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 917>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 917>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - gic: interrupt-controller@f1010000 { - compatible = "arm,gic-400"; - #interrupt-cells = <3>; - #address-cells = <0>; - interrupt-controller; - reg = <0x0 0xf1010000 0 0x1000>, - <0x0 0xf1020000 0 0x20000>, - <0x0 0xf1040000 0 0x20000>, - <0x0 0xf1060000 0 0x20000>; - interrupts = <GIC_PPI 9 - (GIC_CPU_MASK_SIMPLE(1) | IRQ_TYPE_LEVEL_HIGH)>; - clocks = <&cpg CPG_MOD 408>; - clock-names = "clk"; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 408>; - }; - - vspbs: vsp@fe960000 { - compatible = "renesas,vsp2"; - reg = <0 0xfe960000 0 0x8000>; - interrupts = <GIC_SPI 465 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 627>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 627>; - renesas,fcp = <&fcpvb0>; - }; - - vspd0: vsp@fea20000 { - compatible = "renesas,vsp2"; - reg = <0 0xfea20000 0 0x5000>; - interrupts = <GIC_SPI 466 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 623>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 623>; - renesas,fcp = <&fcpvd0>; - }; - - vspd1: vsp@fea28000 { - compatible = "renesas,vsp2"; - reg = <0 0xfea28000 0 0x5000>; - interrupts = <GIC_SPI 467 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 622>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 622>; - renesas,fcp = <&fcpvd1>; - }; - - fcpvb0: fcp@fe96f000 { - compatible = "renesas,fcpv"; - reg = <0 0xfe96f000 0 0x200>; - clocks = <&cpg CPG_MOD 607>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 607>; - iommus = <&ipmmu_vp0 5>; - }; - - fcpvd0: fcp@fea27000 { - compatible = "renesas,fcpv"; - reg = <0 0xfea27000 0 0x200>; - clocks = <&cpg CPG_MOD 603>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 603>; - iommus = <&ipmmu_vi0 8>; - }; - - fcpvd1: fcp@fea2f000 { - compatible = "renesas,fcpv"; - reg = <0 0xfea2f000 0 0x200>; - clocks = <&cpg CPG_MOD 602>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 602>; - iommus = <&ipmmu_vi0 9>; - }; - - cmm0: cmm@fea40000 { - compatible = "renesas,r8a77995-cmm", - "renesas,rcar-gen3-cmm"; - reg = <0 0xfea40000 0 0x1000>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - clocks = <&cpg CPG_MOD 711>; - resets = <&cpg 711>; - }; - - cmm1: cmm@fea50000 { - compatible = "renesas,r8a77995-cmm", - "renesas,rcar-gen3-cmm"; - reg = <0 0xfea50000 0 0x1000>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - clocks = <&cpg CPG_MOD 710>; - resets = <&cpg 710>; - }; - - du: display@feb00000 { - compatible = "renesas,du-r8a77995"; - reg = <0 0xfeb00000 0 0x40000>; - interrupts = <GIC_SPI 256 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 268 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 724>, <&cpg CPG_MOD 723>; - clock-names = "du.0", "du.1"; - resets = <&cpg 724>; - reset-names = "du.0"; - - renesas,cmms = <&cmm0>, <&cmm1>; - renesas,vsps = <&vspd0 0>, <&vspd1 0>; - - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - - port@1 { - reg = <1>; - du_out_lvds0: endpoint { - remote-endpoint = <&lvds0_in>; - }; - }; - - port@2 { - reg = <2>; - du_out_lvds1: endpoint { - remote-endpoint = <&lvds1_in>; - }; - }; - }; - }; - - lvds0: lvds-encoder@feb90000 { - compatible = "renesas,r8a77995-lvds"; - reg = <0 0xfeb90000 0 0x20>; - clocks = <&cpg CPG_MOD 727>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 727>; - status = "disabled"; - - renesas,companion = <&lvds1>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - lvds0_in: endpoint { - remote-endpoint = <&du_out_lvds0>; - }; - }; - - port@1 { - reg = <1>; - }; - }; - }; - - lvds1: lvds-encoder@feb90100 { - compatible = "renesas,r8a77995-lvds"; - reg = <0 0xfeb90100 0 0x20>; - clocks = <&cpg CPG_MOD 727>; - power-domains = <&sysc R8A77995_PD_ALWAYS_ON>; - resets = <&cpg 726>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - lvds1_in: endpoint { - remote-endpoint = <&du_out_lvds1>; - }; - }; - - port@1 { - reg = <1>; - }; - }; - }; - - prr: chipid@fff00044 { - compatible = "renesas,prr"; - reg = <0 0xfff00044 0 4>; - }; - }; - - thermal-zones { - cpu_thermal: cpu-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - thermal-sensors = <&thermal>; - - cooling-maps { - }; - - trips { - cpu-crit { - temperature = <120000>; - hysteresis = <2000>; - type = "critical"; - }; - }; - }; - }; - - timer { - compatible = "arm,armv8-timer"; - interrupts-extended = <&gic GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(1) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(1) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(1) | IRQ_TYPE_LEVEL_LOW)>, - <&gic GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(1) | IRQ_TYPE_LEVEL_LOW)>; - }; -}; diff --git a/arch/arm/dts/r8a779a0-falcon-cpu.dtsi b/arch/arm/dts/r8a779a0-falcon-cpu.dtsi deleted file mode 100644 index 99b73e21c82..00000000000 --- a/arch/arm/dts/r8a779a0-falcon-cpu.dtsi +++ /dev/null @@ -1,359 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the Falcon CPU board - * - * Copyright (C) 2020 Renesas Electronics Corp. - */ - -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/input/input.h> -#include <dt-bindings/leds/common.h> - -#include "r8a779a0.dtsi" - -/ { - model = "Renesas Falcon CPU board"; - compatible = "renesas,falcon-cpu", "renesas,r8a779a0"; - - aliases { - i2c0 = &i2c0; - i2c1 = &i2c1; - i2c2 = &i2c2; - i2c3 = &i2c3; - i2c4 = &i2c4; - i2c5 = &i2c5; - i2c6 = &i2c6; - serial0 = &scif0; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - keys { - compatible = "gpio-keys"; - - pinctrl-0 = <&keys_pins>; - pinctrl-names = "default"; - - key-1 { - gpios = <&gpio6 18 GPIO_ACTIVE_LOW>; - linux,code = <KEY_1>; - label = "SW47"; - wakeup-source; - debounce-interval = <20>; - }; - - key-2 { - gpios = <&gpio6 19 GPIO_ACTIVE_LOW>; - linux,code = <KEY_2>; - label = "SW48"; - wakeup-source; - debounce-interval = <20>; - }; - - key-3 { - gpios = <&gpio6 20 GPIO_ACTIVE_LOW>; - linux,code = <KEY_3>; - label = "SW49"; - wakeup-source; - debounce-interval = <20>; - }; - }; - - leds { - compatible = "gpio-leds"; - - led-1 { - gpios = <&gpio4 18 GPIO_ACTIVE_HIGH>; - color = <LED_COLOR_ID_GREEN>; - function = LED_FUNCTION_INDICATOR; - function-enumerator = <1>; - }; - led-2 { - gpios = <&gpio4 19 GPIO_ACTIVE_HIGH>; - color = <LED_COLOR_ID_GREEN>; - function = LED_FUNCTION_INDICATOR; - function-enumerator = <2>; - }; - led-3 { - gpios = <&gpio4 20 GPIO_ACTIVE_HIGH>; - color = <LED_COLOR_ID_GREEN>; - function = LED_FUNCTION_INDICATOR; - function-enumerator = <3>; - }; - }; - - memory@48000000 { - device_type = "memory"; - /* first 128MB is reserved for secure area. */ - reg = <0x0 0x48000000 0x0 0x78000000>; - }; - - memory@500000000 { - device_type = "memory"; - reg = <0x5 0x00000000 0x0 0x80000000>; - }; - - memory@600000000 { - device_type = "memory"; - reg = <0x6 0x00000000 0x0 0x80000000>; - }; - - memory@700000000 { - device_type = "memory"; - reg = <0x7 0x00000000 0x0 0x80000000>; - }; - - mini-dp-con { - compatible = "dp-connector"; - label = "CN5"; - type = "mini"; - - port { - mini_dp_con_in: endpoint { - remote-endpoint = <&sn65dsi86_out>; - }; - }; - }; - - reg_1p2v: regulator-1p2v { - compatible = "regulator-fixed"; - regulator-name = "fixed-1.2V"; - regulator-min-microvolt = <1200000>; - regulator-max-microvolt = <1200000>; - regulator-boot-on; - regulator-always-on; - }; - - reg_1p8v: regulator-1p8v { - compatible = "regulator-fixed"; - regulator-name = "fixed-1.8V"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-boot-on; - regulator-always-on; - }; - - reg_3p3v: regulator-3p3v { - compatible = "regulator-fixed"; - regulator-name = "fixed-3.3V"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - - sn65dsi86_refclk: clk-x6 { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <38400000>; - }; -}; - -&dsi0 { - status = "okay"; - - ports { - port@1 { - dsi0_out: endpoint { - remote-endpoint = <&sn65dsi86_in>; - data-lanes = <1 2 3 4>; - }; - }; - }; -}; - -&du { - status = "okay"; -}; - -&extal_clk { - clock-frequency = <16666666>; -}; - -&extalr_clk { - clock-frequency = <32768>; -}; - -&i2c0 { - pinctrl-0 = <&i2c0_pins>; - pinctrl-names = "default"; - - status = "okay"; - clock-frequency = <400000>; - - eeprom@50 { - compatible = "rohm,br24g01", "atmel,24c01"; - label = "cpu-board"; - reg = <0x50>; - pagesize = <8>; - }; -}; - -&i2c1 { - pinctrl-0 = <&i2c1_pins>; - pinctrl-names = "default"; - - status = "okay"; - clock-frequency = <400000>; - - bridge@2c { - pinctrl-0 = <&irq0_pins>; - pinctrl-names = "default"; - - compatible = "ti,sn65dsi86"; - reg = <0x2c>; - - clocks = <&sn65dsi86_refclk>; - clock-names = "refclk"; - - interrupt-parent = <&intc_ex>; - interrupts = <0 IRQ_TYPE_LEVEL_HIGH>; - - vccio-supply = <®_1p8v>; - vpll-supply = <®_1p8v>; - vcca-supply = <®_1p2v>; - vcc-supply = <®_1p2v>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - sn65dsi86_in: endpoint { - remote-endpoint = <&dsi0_out>; - }; - }; - - port@1 { - reg = <1>; - sn65dsi86_out: endpoint { - remote-endpoint = <&mini_dp_con_in>; - }; - }; - }; - }; -}; - -&i2c6 { - pinctrl-0 = <&i2c6_pins>; - pinctrl-names = "default"; - - status = "okay"; - clock-frequency = <400000>; -}; - -&mmc0 { - pinctrl-0 = <&mmc_pins>; - pinctrl-1 = <&mmc_pins>; - pinctrl-names = "default", "state_uhs"; - - vmmc-supply = <®_3p3v>; - vqmmc-supply = <®_1p8v>; - mmc-hs200-1_8v; - mmc-hs400-1_8v; - bus-width = <8>; - no-sd; - no-sdio; - non-removable; - full-pwr-cycle-in-suspend; - status = "okay"; -}; - -&pfc { - pinctrl-0 = <&scif_clk_pins>; - pinctrl-names = "default"; - - i2c0_pins: i2c0 { - groups = "i2c0"; - function = "i2c0"; - }; - - i2c1_pins: i2c1 { - groups = "i2c1"; - function = "i2c1"; - }; - - i2c6_pins: i2c6 { - groups = "i2c6"; - function = "i2c6"; - }; - - irq0_pins: irq0 { - groups = "intc_ex_irq0"; - function = "intc_ex"; - }; - - keys_pins: keys { - pins = "GP_6_18", "GP_6_19", "GP_6_20"; - bias-pull-up; - }; - - mmc_pins: mmc { - groups = "mmc_data8", "mmc_ctrl", "mmc_ds"; - function = "mmc"; - power-source = <1800>; - }; - - qspi0_pins: qspi0 { - groups = "qspi0_ctrl", "qspi0_data4"; - function = "qspi0"; - }; - - scif0_pins: scif0 { - groups = "scif0_data", "scif0_ctrl"; - function = "scif0"; - }; - - scif_clk_pins: scif_clk { - groups = "scif_clk"; - function = "scif_clk"; - }; -}; - -&rpc { - pinctrl-0 = <&qspi0_pins>; - pinctrl-names = "default"; - - status = "okay"; - - flash@0 { - compatible = "spansion,s25fs512s", "jedec,spi-nor"; - reg = <0>; - spi-max-frequency = <40000000>; - spi-rx-bus-width = <4>; - - partitions { - compatible = "fixed-partitions"; - #address-cells = <1>; - #size-cells = <1>; - - boot@0 { - reg = <0x0 0xcc0000>; - read-only; - }; - user@cc0000 { - reg = <0xcc0000 0x3340000>; - }; - }; - }; -}; - -&rwdt { - timeout-sec = <60>; - status = "okay"; -}; - -&scif0 { - pinctrl-0 = <&scif0_pins>; - pinctrl-names = "default"; - - uart-has-rtscts; - status = "okay"; -}; - -&scif_clk { - clock-frequency = <24000000>; -}; diff --git a/arch/arm/dts/r8a779a0-falcon-csi-dsi.dtsi b/arch/arm/dts/r8a779a0-falcon-csi-dsi.dtsi deleted file mode 100644 index dbc8dcab109..00000000000 --- a/arch/arm/dts/r8a779a0-falcon-csi-dsi.dtsi +++ /dev/null @@ -1,270 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the Falcon CSI/DSI sub-board - * - * Copyright (C) 2021 Glider bv - */ - -#include <dt-bindings/media/video-interfaces.h> - -&csi40 { - status = "okay"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - - csi40_in: endpoint { - clock-lanes = <0>; - data-lanes = <1 2 3 4>; - remote-endpoint = <&max96712_out0>; - }; - }; - }; -}; - -&csi42 { - status = "okay"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - - csi42_in: endpoint { - clock-lanes = <0>; - data-lanes = <1 2 3 4>; - remote-endpoint = <&max96712_out1>; - }; - }; - }; -}; - -&csi43 { - status = "okay"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - - csi43_in: endpoint { - clock-lanes = <0>; - data-lanes = <1 2 3 4>; - remote-endpoint = <&max96712_out2>; - }; - }; - }; -}; - -&i2c0 { - pca9654_a: gpio@21 { - compatible = "onnn,pca9654"; - reg = <0x21>; - gpio-controller; - #gpio-cells = <2>; - }; - - pca9654_b: gpio@22 { - compatible = "onnn,pca9654"; - reg = <0x22>; - gpio-controller; - #gpio-cells = <2>; - }; - - pca9654_c: gpio@23 { - compatible = "onnn,pca9654"; - reg = <0x23>; - gpio-controller; - #gpio-cells = <2>; - }; - - eeprom@52 { - compatible = "rohm,br24g01", "atmel,24c01"; - label = "csi-dsi-sub-board-id"; - reg = <0x52>; - pagesize = <8>; - }; -}; - -&i2c1 { - gmsl0: gmsl-deserializer@49 { - compatible = "maxim,max96712"; - reg = <0x49>; - enable-gpios = <&pca9654_a 0 GPIO_ACTIVE_HIGH>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@4 { - reg = <4>; - max96712_out0: endpoint { - bus-type = <MEDIA_BUS_TYPE_CSI2_DPHY>; - clock-lanes = <0>; - data-lanes = <1 2 3 4>; - remote-endpoint = <&csi40_in>; - }; - }; - }; - }; - - gmsl1: gmsl-deserializer@4b { - compatible = "maxim,max96712"; - reg = <0x4b>; - enable-gpios = <&pca9654_b 0 GPIO_ACTIVE_HIGH>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@4 { - reg = <4>; - max96712_out1: endpoint { - bus-type = <MEDIA_BUS_TYPE_CSI2_DPHY>; - clock-lanes = <0>; - data-lanes = <1 2 3 4>; - lane-polarities = <0 0 0 0 1>; - remote-endpoint = <&csi42_in>; - }; - }; - }; - }; - - gmsl2: gmsl-deserializer@6b { - compatible = "maxim,max96712"; - reg = <0x6b>; - enable-gpios = <&pca9654_c 0 GPIO_ACTIVE_HIGH>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@4 { - reg = <4>; - max96712_out2: endpoint { - bus-type = <MEDIA_BUS_TYPE_CSI2_DPHY>; - clock-lanes = <0>; - data-lanes = <1 2 3 4>; - lane-polarities = <0 0 0 0 1>; - remote-endpoint = <&csi43_in>; - }; - }; - }; - }; -}; - -&isp0 { - status = "okay"; -}; - -&isp2 { - status = "okay"; -}; - -&isp3 { - status = "okay"; -}; - -&vin00 { - status = "okay"; -}; - -&vin01 { - status = "okay"; -}; - -&vin02 { - status = "okay"; -}; - -&vin03 { - status = "okay"; -}; - -&vin04 { - status = "okay"; -}; - -&vin05 { - status = "okay"; -}; - -&vin06 { - status = "okay"; -}; - -&vin07 { - status = "okay"; -}; - -&vin16 { - status = "okay"; -}; - -&vin17 { - status = "okay"; -}; - -&vin18 { - status = "okay"; -}; - -&vin19 { - status = "okay"; -}; - -&vin20 { - status = "okay"; -}; - -&vin21 { - status = "okay"; -}; - -&vin22 { - status = "okay"; -}; - -&vin23 { - status = "okay"; -}; - -&vin24 { - status = "okay"; -}; - -&vin25 { - status = "okay"; -}; - -&vin26 { - status = "okay"; -}; - -&vin27 { - status = "okay"; -}; - -&vin28 { - status = "okay"; -}; - -&vin29 { - status = "okay"; -}; - -&vin30 { - status = "okay"; -}; - -&vin31 { - status = "okay"; -}; diff --git a/arch/arm/dts/r8a779a0-falcon-ethernet.dtsi b/arch/arm/dts/r8a779a0-falcon-ethernet.dtsi deleted file mode 100644 index e11bf9ace77..00000000000 --- a/arch/arm/dts/r8a779a0-falcon-ethernet.dtsi +++ /dev/null @@ -1,15 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the Falcon Ethernet sub-board - * - * Copyright (C) 2021 Glider bv - */ - -&i2c0 { - eeprom@53 { - compatible = "rohm,br24g01", "atmel,24c01"; - label = "ethernet-sub-board-id"; - reg = <0x53>; - pagesize = <8>; - }; -}; diff --git a/arch/arm/dts/r8a779a0-falcon.dts b/arch/arm/dts/r8a779a0-falcon.dts deleted file mode 100644 index 63db822e5f4..00000000000 --- a/arch/arm/dts/r8a779a0-falcon.dts +++ /dev/null @@ -1,101 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the Falcon CPU and BreakOut boards with R-Car V3U - * - * Copyright (C) 2020 Renesas Electronics Corp. - */ - -/dts-v1/; -#include "r8a779a0-falcon-cpu.dtsi" -#include "r8a779a0-falcon-csi-dsi.dtsi" -#include "r8a779a0-falcon-ethernet.dtsi" - -/ { - model = "Renesas Falcon CPU and Breakout boards based on r8a779a0"; - compatible = "renesas,falcon-breakout", "renesas,falcon-cpu", "renesas,r8a779a0"; - - aliases { - ethernet0 = &avb0; - }; -}; - -&avb0 { - pinctrl-0 = <&avb0_pins>; - pinctrl-names = "default"; - phy-handle = <&phy0>; - tx-internal-delay-ps = <2000>; - status = "okay"; - - phy0: ethernet-phy@0 { - compatible = "ethernet-phy-id0022.1622", - "ethernet-phy-ieee802.3-c22"; - rxc-skew-ps = <1500>; - reg = <0>; - interrupt-parent = <&gpio4>; - interrupts = <16 IRQ_TYPE_LEVEL_LOW>; - reset-gpios = <&gpio4 15 GPIO_ACTIVE_LOW>; - }; -}; - -&can_clk { - clock-frequency = <40000000>; -}; - -&canfd { - pinctrl-0 = <&canfd0_pins>, <&canfd1_pins>, <&can_clk_pins>; - pinctrl-names = "default"; - status = "okay"; - - channel0 { - status = "okay"; - }; - - channel1 { - status = "okay"; - }; -}; - -&i2c0 { - eeprom@51 { - compatible = "rohm,br24g01", "atmel,24c01"; - label = "breakout-board"; - reg = <0x51>; - pagesize = <8>; - }; -}; - -&pfc { - avb0_pins: avb0 { - mux { - groups = "avb0_link", "avb0_mdio", "avb0_rgmii", - "avb0_txcrefclk"; - function = "avb0"; - }; - - pins_mdio { - groups = "avb0_mdio"; - drive-strength = <21>; - }; - - pins_mii { - groups = "avb0_rgmii"; - drive-strength = <21>; - }; - - }; - - can_clk_pins: can-clk { - groups = "can_clk"; - function = "can_clk"; - }; - - canfd0_pins: canfd0 { - groups = "canfd0_data"; - function = "canfd0"; - }; - - canfd1_pins: canfd1 { - groups = "canfd1_data"; - function = "canfd1"; - }; -}; diff --git a/arch/arm/dts/r8a779a0.dtsi b/arch/arm/dts/r8a779a0.dtsi deleted file mode 100644 index 4e67a035649..00000000000 --- a/arch/arm/dts/r8a779a0.dtsi +++ /dev/null @@ -1,2915 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the R-Car V3U (R8A779A0) SoC - * - * Copyright (C) 2020 Renesas Electronics Corp. - */ - -#include <dt-bindings/clock/r8a779a0-cpg-mssr.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/power/r8a779a0-sysc.h> - -/ { - compatible = "renesas,r8a779a0"; - #address-cells = <2>; - #size-cells = <2>; - - /* External CAN clock - to be overridden by boards that provide it */ - can_clk: can { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - - a76_0: cpu@0 { - compatible = "arm,cortex-a76"; - reg = <0>; - device_type = "cpu"; - power-domains = <&sysc R8A779A0_PD_A1E0D0C0>; - next-level-cache = <&L3_CA76_0>; - clocks = <&cpg CPG_CORE R8A779A0_CLK_Z0>; - }; - - L3_CA76_0: cache-controller-0 { - compatible = "cache"; - power-domains = <&sysc R8A779A0_PD_A2E0D0>; - cache-unified; - cache-level = <3>; - }; - }; - - extal_clk: extal { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board */ - clock-frequency = <0>; - }; - - extalr_clk: extalr { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board */ - clock-frequency = <0>; - }; - - pmu_a76 { - compatible = "arm,cortex-a76-pmu"; - interrupts-extended = <&gic GIC_PPI 7 IRQ_TYPE_LEVEL_LOW>; - }; - - /* External SCIF clock - to be overridden by boards that provide it */ - scif_clk: scif { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - soc: soc { - compatible = "simple-bus"; - interrupt-parent = <&gic>; - #address-cells = <2>; - #size-cells = <2>; - ranges; - - rwdt: watchdog@e6020000 { - compatible = "renesas,r8a779a0-wdt", - "renesas,rcar-gen4-wdt"; - reg = <0 0xe6020000 0 0x0c>; - interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 907>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 907>; - status = "disabled"; - }; - - pfc: pinctrl@e6050000 { - compatible = "renesas,pfc-r8a779a0"; - reg = <0 0xe6050000 0 0x16c>, <0 0xe6050800 0 0x16c>, - <0 0xe6058000 0 0x16c>, <0 0xe6058800 0 0x16c>, - <0 0xe6060000 0 0x16c>, <0 0xe6060800 0 0x16c>, - <0 0xe6068000 0 0x16c>, <0 0xe6068800 0 0x16c>, - <0 0xe6069000 0 0x16c>, <0 0xe6069800 0 0x16c>; - }; - - gpio0: gpio@e6058180 { - compatible = "renesas,gpio-r8a779a0", - "renesas,rcar-gen4-gpio"; - reg = <0 0xe6058180 0 0x54>; - interrupts = <GIC_SPI 832 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 916>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 916>; - gpio-controller; - #gpio-cells = <2>; - gpio-ranges = <&pfc 0 0 28>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio1: gpio@e6050180 { - compatible = "renesas,gpio-r8a779a0", - "renesas,rcar-gen4-gpio"; - reg = <0 0xe6050180 0 0x54>; - interrupts = <GIC_SPI 836 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 915>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 915>; - gpio-controller; - #gpio-cells = <2>; - gpio-ranges = <&pfc 0 32 31>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio2: gpio@e6050980 { - compatible = "renesas,gpio-r8a779a0", - "renesas,rcar-gen4-gpio"; - reg = <0 0xe6050980 0 0x54>; - interrupts = <GIC_SPI 840 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 915>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 915>; - gpio-controller; - #gpio-cells = <2>; - gpio-ranges = <&pfc 0 64 25>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio3: gpio@e6058980 { - compatible = "renesas,gpio-r8a779a0", - "renesas,rcar-gen4-gpio"; - reg = <0 0xe6058980 0 0x54>; - interrupts = <GIC_SPI 844 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 916>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 916>; - gpio-controller; - #gpio-cells = <2>; - gpio-ranges = <&pfc 0 96 17>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio4: gpio@e6060180 { - compatible = "renesas,gpio-r8a779a0", - "renesas,rcar-gen4-gpio"; - reg = <0 0xe6060180 0 0x54>; - interrupts = <GIC_SPI 848 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 917>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 917>; - gpio-controller; - #gpio-cells = <2>; - gpio-ranges = <&pfc 0 128 27>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio5: gpio@e6060980 { - compatible = "renesas,gpio-r8a779a0", - "renesas,rcar-gen4-gpio"; - reg = <0 0xe6060980 0 0x54>; - interrupts = <GIC_SPI 852 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 917>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 917>; - gpio-controller; - #gpio-cells = <2>; - gpio-ranges = <&pfc 0 160 21>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio6: gpio@e6068180 { - compatible = "renesas,gpio-r8a779a0", - "renesas,rcar-gen4-gpio"; - reg = <0 0xe6068180 0 0x54>; - interrupts = <GIC_SPI 856 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 918>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 918>; - gpio-controller; - #gpio-cells = <2>; - gpio-ranges = <&pfc 0 192 21>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio7: gpio@e6068980 { - compatible = "renesas,gpio-r8a779a0", - "renesas,rcar-gen4-gpio"; - reg = <0 0xe6068980 0 0x54>; - interrupts = <GIC_SPI 860 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 918>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 918>; - gpio-controller; - #gpio-cells = <2>; - gpio-ranges = <&pfc 0 224 21>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio8: gpio@e6069180 { - compatible = "renesas,gpio-r8a779a0", - "renesas,rcar-gen4-gpio"; - reg = <0 0xe6069180 0 0x54>; - interrupts = <GIC_SPI 864 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 918>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 918>; - gpio-controller; - #gpio-cells = <2>; - gpio-ranges = <&pfc 0 256 21>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio9: gpio@e6069980 { - compatible = "renesas,gpio-r8a779a0", - "renesas,rcar-gen4-gpio"; - reg = <0 0xe6069980 0 0x54>; - interrupts = <GIC_SPI 868 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 918>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 918>; - gpio-controller; - #gpio-cells = <2>; - gpio-ranges = <&pfc 0 288 21>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - cmt0: timer@e60f0000 { - compatible = "renesas,r8a779a0-cmt0", - "renesas,rcar-gen4-cmt0"; - reg = <0 0xe60f0000 0 0x1004>; - interrupts = <GIC_SPI 500 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 501 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 910>; - clock-names = "fck"; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 910>; - status = "disabled"; - }; - - cmt1: timer@e6130000 { - compatible = "renesas,r8a779a0-cmt1", - "renesas,rcar-gen4-cmt1"; - reg = <0 0xe6130000 0 0x1004>; - interrupts = <GIC_SPI 448 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 449 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 450 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 451 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 452 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 453 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 454 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 455 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 911>; - clock-names = "fck"; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 911>; - status = "disabled"; - }; - - cmt2: timer@e6140000 { - compatible = "renesas,r8a779a0-cmt1", - "renesas,rcar-gen4-cmt1"; - reg = <0 0xe6140000 0 0x1004>; - interrupts = <GIC_SPI 456 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 457 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 458 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 459 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 460 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 461 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 462 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 463 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 912>; - clock-names = "fck"; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 912>; - status = "disabled"; - }; - - cmt3: timer@e6148000 { - compatible = "renesas,r8a779a0-cmt1", - "renesas,rcar-gen4-cmt1"; - reg = <0 0xe6148000 0 0x1004>; - interrupts = <GIC_SPI 464 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 465 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 466 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 467 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 468 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 469 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 470 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 471 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 913>; - clock-names = "fck"; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 913>; - status = "disabled"; - }; - - cpg: clock-controller@e6150000 { - compatible = "renesas,r8a779a0-cpg-mssr"; - reg = <0 0xe6150000 0 0x4000>; - clocks = <&extal_clk>, <&extalr_clk>; - clock-names = "extal", "extalr"; - #clock-cells = <2>; - #power-domain-cells = <0>; - #reset-cells = <1>; - }; - - rst: reset-controller@e6160000 { - compatible = "renesas,r8a779a0-rst"; - reg = <0 0xe6160000 0 0x4000>; - }; - - sysc: system-controller@e6180000 { - compatible = "renesas,r8a779a0-sysc"; - reg = <0 0xe6180000 0 0x4000>; - #power-domain-cells = <1>; - }; - - tsc: thermal@e6190000 { - compatible = "renesas,r8a779a0-thermal"; - reg = <0 0xe6190000 0 0x200>, - <0 0xe6198000 0 0x200>, - <0 0xe61a0000 0 0x200>, - <0 0xe61a8000 0 0x200>, - <0 0xe61b0000 0 0x200>; - clocks = <&cpg CPG_MOD 919>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 919>; - #thermal-sensor-cells = <1>; - }; - - intc_ex: interrupt-controller@e61c0000 { - compatible = "renesas,intc-ex-r8a779a0", "renesas,irqc"; - #interrupt-cells = <2>; - interrupt-controller; - reg = <0 0xe61c0000 0 0x200>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_CORE R8A779A0_CLK_CP>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - }; - - tmu0: timer@e61e0000 { - compatible = "renesas,tmu-r8a779a0", "renesas,tmu"; - reg = <0 0xe61e0000 0 0x30>; - interrupts = <GIC_SPI 512 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 513 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 514 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 713>; - clock-names = "fck"; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 713>; - status = "disabled"; - }; - - tmu1: timer@e6fc0000 { - compatible = "renesas,tmu-r8a779a0", "renesas,tmu"; - reg = <0 0xe6fc0000 0 0x30>; - interrupts = <GIC_SPI 504 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 505 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 506 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 714>; - clock-names = "fck"; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 714>; - status = "disabled"; - }; - - tmu2: timer@e6fd0000 { - compatible = "renesas,tmu-r8a779a0", "renesas,tmu"; - reg = <0 0xe6fd0000 0 0x30>; - interrupts = <GIC_SPI 508 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 509 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 510 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 715>; - clock-names = "fck"; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 715>; - status = "disabled"; - }; - - tmu3: timer@e6fe0000 { - compatible = "renesas,tmu-r8a779a0", "renesas,tmu"; - reg = <0 0xe6fe0000 0 0x30>; - interrupts = <GIC_SPI 472 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 473 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 474 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 716>; - clock-names = "fck"; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 716>; - status = "disabled"; - }; - - tmu4: timer@ffc00000 { - compatible = "renesas,tmu-r8a779a0", "renesas,tmu"; - reg = <0 0xffc00000 0 0x30>; - interrupts = <GIC_SPI 476 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 477 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 478 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 717>; - clock-names = "fck"; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 717>; - status = "disabled"; - }; - - i2c0: i2c@e6500000 { - compatible = "renesas,i2c-r8a779a0", - "renesas,rcar-gen4-i2c"; - reg = <0 0xe6500000 0 0x40>; - interrupts = <GIC_SPI 238 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 518>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 518>; - dmas = <&dmac1 0x91>, <&dmac1 0x90>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c1: i2c@e6508000 { - compatible = "renesas,i2c-r8a779a0", - "renesas,rcar-gen4-i2c"; - reg = <0 0xe6508000 0 0x40>; - interrupts = <GIC_SPI 239 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 519>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 519>; - dmas = <&dmac1 0x93>, <&dmac1 0x92>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c2: i2c@e6510000 { - compatible = "renesas,i2c-r8a779a0", - "renesas,rcar-gen4-i2c"; - reg = <0 0xe6510000 0 0x40>; - interrupts = <GIC_SPI 240 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 520>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 520>; - dmas = <&dmac1 0x95>, <&dmac1 0x94>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c3: i2c@e66d0000 { - compatible = "renesas,i2c-r8a779a0", - "renesas,rcar-gen4-i2c"; - reg = <0 0xe66d0000 0 0x40>; - interrupts = <GIC_SPI 241 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 521>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 521>; - dmas = <&dmac1 0x97>, <&dmac1 0x96>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c4: i2c@e66d8000 { - compatible = "renesas,i2c-r8a779a0", - "renesas,rcar-gen4-i2c"; - reg = <0 0xe66d8000 0 0x40>; - interrupts = <GIC_SPI 242 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 522>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 522>; - dmas = <&dmac1 0x99>, <&dmac1 0x98>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c5: i2c@e66e0000 { - compatible = "renesas,i2c-r8a779a0", - "renesas,rcar-gen4-i2c"; - reg = <0 0xe66e0000 0 0x40>; - interrupts = <GIC_SPI 243 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 523>; - dmas = <&dmac1 0x9b>, <&dmac1 0x9a>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c6: i2c@e66e8000 { - compatible = "renesas,i2c-r8a779a0", - "renesas,rcar-gen4-i2c"; - reg = <0 0xe66e8000 0 0x40>; - interrupts = <GIC_SPI 244 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 524>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 524>; - dmas = <&dmac1 0x9d>, <&dmac1 0x9c>; - dma-names = "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - hscif0: serial@e6540000 { - compatible = "renesas,hscif-r8a779a0", - "renesas,rcar-gen4-hscif", "renesas,hscif"; - reg = <0 0xe6540000 0 0x60>; - interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 514>, - <&cpg CPG_CORE R8A779A0_CLK_S1D2>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x31>, <&dmac1 0x30>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 514>; - status = "disabled"; - }; - - hscif1: serial@e6550000 { - compatible = "renesas,hscif-r8a779a0", - "renesas,rcar-gen4-hscif", "renesas,hscif"; - reg = <0 0xe6550000 0 0x60>; - interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 515>, - <&cpg CPG_CORE R8A779A0_CLK_S1D2>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x33>, <&dmac1 0x32>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 515>; - status = "disabled"; - }; - - hscif2: serial@e6560000 { - compatible = "renesas,hscif-r8a779a0", - "renesas,rcar-gen4-hscif", "renesas,hscif"; - reg = <0 0xe6560000 0 0x60>; - interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 516>, - <&cpg CPG_CORE R8A779A0_CLK_S1D2>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x35>, <&dmac1 0x34>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 516>; - status = "disabled"; - }; - - hscif3: serial@e66a0000 { - compatible = "renesas,hscif-r8a779a0", - "renesas,rcar-gen4-hscif", "renesas,hscif"; - reg = <0 0xe66a0000 0 0x60>; - interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 517>, - <&cpg CPG_CORE R8A779A0_CLK_S1D2>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x37>, <&dmac1 0x36>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 517>; - status = "disabled"; - }; - - canfd: can@e6660000 { - compatible = "renesas,r8a779a0-canfd", - "renesas,rcar-gen4-canfd"; - reg = <0 0xe6660000 0 0x8000>; - interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch_int", "g_int"; - clocks = <&cpg CPG_MOD 328>, - <&cpg CPG_CORE R8A779A0_CLK_CANFD>, - <&can_clk>; - clock-names = "fck", "canfd", "can_clk"; - assigned-clocks = <&cpg CPG_CORE R8A779A0_CLK_CANFD>; - assigned-clock-rates = <80000000>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 328>; - status = "disabled"; - - channel0 { - status = "disabled"; - }; - - channel1 { - status = "disabled"; - }; - - channel2 { - status = "disabled"; - }; - - channel3 { - status = "disabled"; - }; - - channel4 { - status = "disabled"; - }; - - channel5 { - status = "disabled"; - }; - - channel6 { - status = "disabled"; - }; - - channel7 { - status = "disabled"; - }; - }; - - avb0: ethernet@e6800000 { - compatible = "renesas,etheravb-r8a779a0", - "renesas,etheravb-rcar-gen4"; - reg = <0 0xe6800000 0 0x800>; - interrupts = <GIC_SPI 256 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 257 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 258 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 259 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 260 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 261 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 262 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 263 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 264 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 265 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 266 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 267 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 268 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 269 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 270 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 271 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 272 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 273 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 274 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 275 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 276 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 277 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 278 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 279 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 280 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15", - "ch16", "ch17", "ch18", "ch19", - "ch20", "ch21", "ch22", "ch23", - "ch24"; - clocks = <&cpg CPG_MOD 211>; - clock-names = "fck"; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 211>; - phy-mode = "rgmii"; - rx-internal-delay-ps = <0>; - tx-internal-delay-ps = <0>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - avb1: ethernet@e6810000 { - compatible = "renesas,etheravb-r8a779a0", - "renesas,etheravb-rcar-gen4"; - reg = <0 0xe6810000 0 0x800>; - interrupts = <GIC_SPI 281 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 282 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 283 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 284 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 285 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 286 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 287 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 288 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 289 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 290 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 291 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 292 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 293 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 294 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 295 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 296 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 297 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 298 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 299 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 300 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 301 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 302 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 303 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 304 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 305 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15", - "ch16", "ch17", "ch18", "ch19", - "ch20", "ch21", "ch22", "ch23", - "ch24"; - clocks = <&cpg CPG_MOD 212>; - clock-names = "fck"; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 212>; - phy-mode = "rgmii"; - rx-internal-delay-ps = <0>; - tx-internal-delay-ps = <0>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - avb2: ethernet@e6820000 { - compatible = "renesas,etheravb-r8a779a0", - "renesas,etheravb-rcar-gen4"; - reg = <0 0xe6820000 0 0x1000>; - interrupts = <GIC_SPI 306 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 307 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 308 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 309 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 310 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 311 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 312 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 313 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 314 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 315 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 316 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 317 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 318 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 319 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 320 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 321 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 322 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 323 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 324 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 325 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 326 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 327 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 328 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 329 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 330 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15", - "ch16", "ch17", "ch18", "ch19", - "ch20", "ch21", "ch22", "ch23", - "ch24"; - clocks = <&cpg CPG_MOD 213>; - clock-names = "fck"; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 213>; - phy-mode = "rgmii"; - rx-internal-delay-ps = <0>; - tx-internal-delay-ps = <0>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - avb3: ethernet@e6830000 { - compatible = "renesas,etheravb-r8a779a0", - "renesas,etheravb-rcar-gen4"; - reg = <0 0xe6830000 0 0x1000>; - interrupts = <GIC_SPI 331 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 332 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 333 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 334 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 335 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 336 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 337 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 338 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 339 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 340 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 341 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 342 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 343 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 344 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 345 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 346 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 347 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 348 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 349 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 350 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 351 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 352 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 353 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 354 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 355 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15", - "ch16", "ch17", "ch18", "ch19", - "ch20", "ch21", "ch22", "ch23", - "ch24"; - clocks = <&cpg CPG_MOD 214>; - clock-names = "fck"; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 214>; - phy-mode = "rgmii"; - rx-internal-delay-ps = <0>; - tx-internal-delay-ps = <0>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - avb4: ethernet@e6840000 { - compatible = "renesas,etheravb-r8a779a0", - "renesas,etheravb-rcar-gen4"; - reg = <0 0xe6840000 0 0x1000>; - interrupts = <GIC_SPI 356 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 357 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 358 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 359 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 360 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 361 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 362 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 363 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 364 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 365 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 366 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 367 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 368 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 369 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 370 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 371 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 372 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 373 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 374 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 375 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 376 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 377 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 378 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 379 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 380 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15", - "ch16", "ch17", "ch18", "ch19", - "ch20", "ch21", "ch22", "ch23", - "ch24"; - clocks = <&cpg CPG_MOD 215>; - clock-names = "fck"; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 215>; - phy-mode = "rgmii"; - rx-internal-delay-ps = <0>; - tx-internal-delay-ps = <0>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - avb5: ethernet@e6850000 { - compatible = "renesas,etheravb-r8a779a0", - "renesas,etheravb-rcar-gen4"; - reg = <0 0xe6850000 0 0x1000>; - interrupts = <GIC_SPI 381 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 382 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 383 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 384 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 385 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 386 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 387 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 388 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 389 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 390 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 391 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 392 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 393 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 394 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 395 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 396 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 397 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 398 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 399 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 400 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 401 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 402 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 403 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 404 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 405 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15", - "ch16", "ch17", "ch18", "ch19", - "ch20", "ch21", "ch22", "ch23", - "ch24"; - clocks = <&cpg CPG_MOD 216>; - clock-names = "fck"; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 216>; - phy-mode = "rgmii"; - rx-internal-delay-ps = <0>; - tx-internal-delay-ps = <0>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - pwm0: pwm@e6e30000 { - compatible = "renesas,pwm-r8a779a0", "renesas,pwm-rcar"; - reg = <0 0xe6e30000 0 0x10>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 628>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 628>; - status = "disabled"; - }; - - pwm1: pwm@e6e31000 { - compatible = "renesas,pwm-r8a779a0", "renesas,pwm-rcar"; - reg = <0 0xe6e31000 0 0x10>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 628>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 628>; - status = "disabled"; - }; - - pwm2: pwm@e6e32000 { - compatible = "renesas,pwm-r8a779a0", "renesas,pwm-rcar"; - reg = <0 0xe6e32000 0 0x10>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 628>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 628>; - status = "disabled"; - }; - - pwm3: pwm@e6e33000 { - compatible = "renesas,pwm-r8a779a0", "renesas,pwm-rcar"; - reg = <0 0xe6e33000 0 0x10>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 628>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 628>; - status = "disabled"; - }; - - pwm4: pwm@e6e34000 { - compatible = "renesas,pwm-r8a779a0", "renesas,pwm-rcar"; - reg = <0 0xe6e34000 0 0x10>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 628>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 628>; - status = "disabled"; - }; - - scif0: serial@e6e60000 { - compatible = "renesas,scif-r8a779a0", - "renesas,rcar-gen4-scif", "renesas,scif"; - reg = <0 0xe6e60000 0 64>; - interrupts = <GIC_SPI 251 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 702>, - <&cpg CPG_CORE R8A779A0_CLK_S1D2>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x51>, <&dmac1 0x50>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 702>; - status = "disabled"; - }; - - scif1: serial@e6e68000 { - compatible = "renesas,scif-r8a779a0", - "renesas,rcar-gen4-scif", "renesas,scif"; - reg = <0 0xe6e68000 0 64>; - interrupts = <GIC_SPI 252 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>, - <&cpg CPG_CORE R8A779A0_CLK_S1D2>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x53>, <&dmac1 0x52>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 703>; - status = "disabled"; - }; - - scif3: serial@e6c50000 { - compatible = "renesas,scif-r8a779a0", - "renesas,rcar-gen4-scif", "renesas,scif"; - reg = <0 0xe6c50000 0 64>; - interrupts = <GIC_SPI 253 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 704>, - <&cpg CPG_CORE R8A779A0_CLK_S1D2>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x57>, <&dmac1 0x56>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 704>; - status = "disabled"; - }; - - scif4: serial@e6c40000 { - compatible = "renesas,scif-r8a779a0", - "renesas,rcar-gen4-scif", "renesas,scif"; - reg = <0 0xe6c40000 0 64>; - interrupts = <GIC_SPI 254 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 705>, - <&cpg CPG_CORE R8A779A0_CLK_S1D2>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac1 0x59>, <&dmac1 0x58>; - dma-names = "tx", "rx"; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 705>; - status = "disabled"; - }; - - tpu: pwm@e6e80000 { - compatible = "renesas,tpu-r8a779a0", "renesas,tpu"; - reg = <0 0xe6e80000 0 0x148>; - interrupts = <GIC_SPI 515 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 718>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 718>; - #pwm-cells = <3>; - status = "disabled"; - }; - - msiof0: spi@e6e90000 { - compatible = "renesas,msiof-r8a779a0", - "renesas,rcar-gen4-msiof"; - reg = <0 0xe6e90000 0 0x0064>; - interrupts = <GIC_SPI 245 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 618>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 618>; - dmas = <&dmac1 0x41>, <&dmac1 0x40>; - dma-names = "tx", "rx"; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof1: spi@e6ea0000 { - compatible = "renesas,msiof-r8a779a0", - "renesas,rcar-gen4-msiof"; - reg = <0 0xe6ea0000 0 0x0064>; - interrupts = <GIC_SPI 246 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 619>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 619>; - dmas = <&dmac1 0x43>, <&dmac1 0x42>; - dma-names = "tx", "rx"; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof2: spi@e6c00000 { - compatible = "renesas,msiof-r8a779a0", - "renesas,rcar-gen4-msiof"; - reg = <0 0xe6c00000 0 0x0064>; - interrupts = <GIC_SPI 247 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 620>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 620>; - dmas = <&dmac1 0x45>, <&dmac1 0x44>; - dma-names = "tx", "rx"; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof3: spi@e6c10000 { - compatible = "renesas,msiof-r8a779a0", - "renesas,rcar-gen4-msiof"; - reg = <0 0xe6c10000 0 0x0064>; - interrupts = <GIC_SPI 248 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 621>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 621>; - dmas = <&dmac1 0x47>, <&dmac1 0x46>; - dma-names = "tx", "rx"; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof4: spi@e6c20000 { - compatible = "renesas,msiof-r8a779a0", - "renesas,rcar-gen4-msiof"; - reg = <0 0xe6c20000 0 0x0064>; - interrupts = <GIC_SPI 249 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 622>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 622>; - dmas = <&dmac1 0x49>, <&dmac1 0x48>; - dma-names = "tx", "rx"; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof5: spi@e6c28000 { - compatible = "renesas,msiof-r8a779a0", - "renesas,rcar-gen4-msiof"; - reg = <0 0xe6c28000 0 0x0064>; - interrupts = <GIC_SPI 250 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 623>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 623>; - dmas = <&dmac1 0x4b>, <&dmac1 0x4a>; - dma-names = "tx", "rx"; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - vin00: video@e6ef0000 { - compatible = "renesas,vin-r8a779a0"; - reg = <0 0xe6ef0000 0 0x1000>; - interrupts = <GIC_SPI 160 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 730>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 730>; - renesas,id = <0>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin00isp0: endpoint@0 { - reg = <0>; - remote-endpoint = <&isp0vin00>; - }; - }; - }; - }; - - vin01: video@e6ef1000 { - compatible = "renesas,vin-r8a779a0"; - reg = <0 0xe6ef1000 0 0x1000>; - interrupts = <GIC_SPI 161 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 731>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 731>; - renesas,id = <1>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin01isp0: endpoint@0 { - reg = <0>; - remote-endpoint = <&isp0vin01>; - }; - }; - }; - }; - - vin02: video@e6ef2000 { - compatible = "renesas,vin-r8a779a0"; - reg = <0 0xe6ef2000 0 0x1000>; - interrupts = <GIC_SPI 162 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 800>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 800>; - renesas,id = <2>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin02isp0: endpoint@0 { - reg = <0>; - remote-endpoint = <&isp0vin02>; - }; - }; - }; - }; - - vin03: video@e6ef3000 { - compatible = "renesas,vin-r8a779a0"; - reg = <0 0xe6ef3000 0 0x1000>; - interrupts = <GIC_SPI 163 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 801>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 801>; - renesas,id = <3>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin03isp0: endpoint@0 { - reg = <0>; - remote-endpoint = <&isp0vin03>; - }; - }; - }; - }; - - vin04: video@e6ef4000 { - compatible = "renesas,vin-r8a779a0"; - reg = <0 0xe6ef4000 0 0x1000>; - interrupts = <GIC_SPI 164 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 802>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 802>; - renesas,id = <4>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin04isp0: endpoint@0 { - reg = <0>; - remote-endpoint = <&isp0vin04>; - }; - }; - }; - }; - - vin05: video@e6ef5000 { - compatible = "renesas,vin-r8a779a0"; - reg = <0 0xe6ef5000 0 0x1000>; - interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 803>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 803>; - renesas,id = <5>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin05isp0: endpoint@0 { - reg = <0>; - remote-endpoint = <&isp0vin05>; - }; - }; - }; - }; - - vin06: video@e6ef6000 { - compatible = "renesas,vin-r8a779a0"; - reg = <0 0xe6ef6000 0 0x1000>; - interrupts = <GIC_SPI 166 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 804>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 804>; - renesas,id = <6>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin06isp0: endpoint@0 { - reg = <0>; - remote-endpoint = <&isp0vin06>; - }; - }; - }; - }; - - vin07: video@e6ef7000 { - compatible = "renesas,vin-r8a779a0"; - reg = <0 0xe6ef7000 0 0x1000>; - interrupts = <GIC_SPI 167 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 805>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 805>; - renesas,id = <7>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin07isp0: endpoint@0 { - reg = <0>; - remote-endpoint = <&isp0vin07>; - }; - }; - }; - }; - - vin08: video@e6ef8000 { - compatible = "renesas,vin-r8a779a0"; - reg = <0 0xe6ef8000 0 0x1000>; - interrupts = <GIC_SPI 168 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 806>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 806>; - renesas,id = <8>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin08isp1: endpoint@1 { - reg = <1>; - remote-endpoint = <&isp1vin08>; - }; - }; - }; - }; - - vin09: video@e6ef9000 { - compatible = "renesas,vin-r8a779a0"; - reg = <0 0xe6ef9000 0 0x1000>; - interrupts = <GIC_SPI 169 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 807>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 807>; - renesas,id = <9>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin09isp1: endpoint@1 { - reg = <1>; - remote-endpoint = <&isp1vin09>; - }; - }; - }; - }; - - vin10: video@e6efa000 { - compatible = "renesas,vin-r8a779a0"; - reg = <0 0xe6efa000 0 0x1000>; - interrupts = <GIC_SPI 170 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 808>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 808>; - renesas,id = <10>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin10isp1: endpoint@1 { - reg = <1>; - remote-endpoint = <&isp1vin10>; - }; - }; - }; - }; - - vin11: video@e6efb000 { - compatible = "renesas,vin-r8a779a0"; - reg = <0 0xe6efb000 0 0x1000>; - interrupts = <GIC_SPI 171 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 809>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 809>; - renesas,id = <11>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin11isp1: endpoint@1 { - reg = <1>; - remote-endpoint = <&isp1vin11>; - }; - }; - }; - }; - - vin12: video@e6efc000 { - compatible = "renesas,vin-r8a779a0"; - reg = <0 0xe6efc000 0 0x1000>; - interrupts = <GIC_SPI 172 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 810>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 810>; - renesas,id = <12>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin12isp1: endpoint@1 { - reg = <1>; - remote-endpoint = <&isp1vin12>; - }; - }; - }; - }; - - vin13: video@e6efd000 { - compatible = "renesas,vin-r8a779a0"; - reg = <0 0xe6efd000 0 0x1000>; - interrupts = <GIC_SPI 173 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 811>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 811>; - renesas,id = <13>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin13isp1: endpoint@1 { - reg = <1>; - remote-endpoint = <&isp1vin13>; - }; - }; - }; - }; - - vin14: video@e6efe000 { - compatible = "renesas,vin-r8a779a0"; - reg = <0 0xe6efe000 0 0x1000>; - interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 812>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 812>; - renesas,id = <14>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin14isp1: endpoint@1 { - reg = <1>; - remote-endpoint = <&isp1vin14>; - }; - }; - }; - }; - - vin15: video@e6eff000 { - compatible = "renesas,vin-r8a779a0"; - reg = <0 0xe6eff000 0 0x1000>; - interrupts = <GIC_SPI 175 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 813>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 813>; - renesas,id = <15>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin15isp1: endpoint@1 { - reg = <1>; - remote-endpoint = <&isp1vin15>; - }; - }; - }; - }; - - vin16: video@e6ed0000 { - compatible = "renesas,vin-r8a779a0"; - reg = <0 0xe6ed0000 0 0x1000>; - interrupts = <GIC_SPI 176 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 814>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 814>; - renesas,id = <16>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin16isp2: endpoint@2 { - reg = <2>; - remote-endpoint = <&isp2vin16>; - }; - }; - }; - }; - - vin17: video@e6ed1000 { - compatible = "renesas,vin-r8a779a0"; - reg = <0 0xe6ed1000 0 0x1000>; - interrupts = <GIC_SPI 177 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 815>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 815>; - renesas,id = <17>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin17isp2: endpoint@2 { - reg = <2>; - remote-endpoint = <&isp2vin17>; - }; - }; - }; - }; - - vin18: video@e6ed2000 { - compatible = "renesas,vin-r8a779a0"; - reg = <0 0xe6ed2000 0 0x1000>; - interrupts = <GIC_SPI 178 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 816>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 816>; - renesas,id = <18>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin18isp2: endpoint@2 { - reg = <2>; - remote-endpoint = <&isp2vin18>; - }; - }; - }; - }; - - vin19: video@e6ed3000 { - compatible = "renesas,vin-r8a779a0"; - reg = <0 0xe6ed3000 0 0x1000>; - interrupts = <GIC_SPI 179 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 817>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 817>; - renesas,id = <19>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin19isp2: endpoint@2 { - reg = <2>; - remote-endpoint = <&isp2vin19>; - }; - }; - }; - }; - - vin20: video@e6ed4000 { - compatible = "renesas,vin-r8a779a0"; - reg = <0 0xe6ed4000 0 0x1000>; - interrupts = <GIC_SPI 180 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 818>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 818>; - renesas,id = <20>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin20isp2: endpoint@2 { - reg = <2>; - remote-endpoint = <&isp2vin20>; - }; - }; - }; - }; - - vin21: video@e6ed5000 { - compatible = "renesas,vin-r8a779a0"; - reg = <0 0xe6ed5000 0 0x1000>; - interrupts = <GIC_SPI 181 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 819>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 819>; - renesas,id = <21>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin21isp2: endpoint@2 { - reg = <2>; - remote-endpoint = <&isp2vin21>; - }; - }; - }; - }; - - vin22: video@e6ed6000 { - compatible = "renesas,vin-r8a779a0"; - reg = <0 0xe6ed6000 0 0x1000>; - interrupts = <GIC_SPI 182 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 820>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 820>; - renesas,id = <22>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin22isp2: endpoint@2 { - reg = <2>; - remote-endpoint = <&isp2vin22>; - }; - }; - }; - }; - - vin23: video@e6ed7000 { - compatible = "renesas,vin-r8a779a0"; - reg = <0 0xe6ed7000 0 0x1000>; - interrupts = <GIC_SPI 183 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 821>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 821>; - renesas,id = <23>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin23isp2: endpoint@2 { - reg = <2>; - remote-endpoint = <&isp2vin23>; - }; - }; - }; - }; - - vin24: video@e6ed8000 { - compatible = "renesas,vin-r8a779a0"; - reg = <0 0xe6ed8000 0 0x1000>; - interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 822>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 822>; - renesas,id = <24>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin24isp3: endpoint@3 { - reg = <3>; - remote-endpoint = <&isp3vin24>; - }; - }; - }; - }; - - vin25: video@e6ed9000 { - compatible = "renesas,vin-r8a779a0"; - reg = <0 0xe6ed9000 0 0x1000>; - interrupts = <GIC_SPI 185 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 823>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 823>; - renesas,id = <25>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin25isp3: endpoint@3 { - reg = <3>; - remote-endpoint = <&isp3vin25>; - }; - }; - }; - }; - - vin26: video@e6eda000 { - compatible = "renesas,vin-r8a779a0"; - reg = <0 0xe6eda000 0 0x1000>; - interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 824>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 824>; - renesas,id = <26>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin26isp3: endpoint@3 { - reg = <3>; - remote-endpoint = <&isp3vin26>; - }; - }; - }; - }; - - vin27: video@e6edb000 { - compatible = "renesas,vin-r8a779a0"; - reg = <0 0xe6edb000 0 0x1000>; - interrupts = <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 825>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 825>; - renesas,id = <27>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin27isp3: endpoint@3 { - reg = <3>; - remote-endpoint = <&isp3vin27>; - }; - }; - }; - }; - - vin28: video@e6edc000 { - compatible = "renesas,vin-r8a779a0"; - reg = <0 0xe6edc000 0 0x1000>; - interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 826>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 826>; - renesas,id = <28>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin28isp3: endpoint@3 { - reg = <3>; - remote-endpoint = <&isp3vin28>; - }; - }; - }; - }; - - vin29: video@e6edd000 { - compatible = "renesas,vin-r8a779a0"; - reg = <0 0xe6edd000 0 0x1000>; - interrupts = <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 827>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 827>; - renesas,id = <29>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin29isp3: endpoint@3 { - reg = <3>; - remote-endpoint = <&isp3vin29>; - }; - }; - }; - }; - - vin30: video@e6ede000 { - compatible = "renesas,vin-r8a779a0"; - reg = <0 0xe6ede000 0 0x1000>; - interrupts = <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 828>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 828>; - renesas,id = <30>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin30isp3: endpoint@3 { - reg = <3>; - remote-endpoint = <&isp3vin30>; - }; - }; - }; - }; - - vin31: video@e6edf000 { - compatible = "renesas,vin-r8a779a0"; - reg = <0 0xe6edf000 0 0x1000>; - interrupts = <GIC_SPI 191 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 829>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 829>; - renesas,id = <31>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin31isp3: endpoint@3 { - reg = <3>; - remote-endpoint = <&isp3vin31>; - }; - }; - }; - }; - - dmac1: dma-controller@e7350000 { - compatible = "renesas,dmac-r8a779a0", - "renesas,rcar-gen4-dmac"; - reg = <0 0xe7350000 0 0x1000>, - <0 0xe7300000 0 0x10000>; - interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 47 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", "ch4", - "ch5", "ch6", "ch7", "ch8", "ch9", - "ch10", "ch11", "ch12", "ch13", - "ch14", "ch15"; - clocks = <&cpg CPG_MOD 709>; - clock-names = "fck"; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 709>; - #dma-cells = <1>; - dma-channels = <16>; - }; - - dmac2: dma-controller@e7351000 { - compatible = "renesas,dmac-r8a779a0", - "renesas,rcar-gen4-dmac"; - reg = <0 0xe7351000 0 0x1000>, - <0 0xe7310000 0 0x10000>; - interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", "ch4", - "ch5", "ch6", "ch7"; - clocks = <&cpg CPG_MOD 710>; - clock-names = "fck"; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 710>; - #dma-cells = <1>; - dma-channels = <8>; - }; - - mmc0: mmc@ee140000 { - compatible = "renesas,sdhi-r8a779a0", - "renesas,rcar-gen4-sdhi"; - reg = <0 0xee140000 0 0x2000>; - interrupts = <GIC_SPI 236 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 706>, <&cpg CPG_CORE R8A779A0_CLK_SD0H>; - clock-names = "core", "clkh"; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 706>; - max-frequency = <200000000>; - iommus = <&ipmmu_ds0 32>; - status = "disabled"; - }; - - rpc: spi@ee200000 { - compatible = "renesas,r8a779a0-rpc-if", - "renesas,rcar-gen3-rpc-if"; - reg = <0 0xee200000 0 0x200>, - <0 0x08000000 0 0x04000000>, - <0 0xee208000 0 0x100>; - reg-names = "regs", "dirmap", "wbuf"; - interrupts = <GIC_SPI 135 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 629>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 629>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - ipmmu_rt0: iommu@ee480000 { - compatible = "renesas,ipmmu-r8a779a0", - "renesas,rcar-gen4-ipmmu-vmsa"; - reg = <0 0xee480000 0 0x20000>; - renesas,ipmmu-main = <&ipmmu_mm>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_rt1: iommu@ee4c0000 { - compatible = "renesas,ipmmu-r8a779a0", - "renesas,rcar-gen4-ipmmu-vmsa"; - reg = <0 0xee4c0000 0 0x20000>; - renesas,ipmmu-main = <&ipmmu_mm>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_ds0: iommu@eed00000 { - compatible = "renesas,ipmmu-r8a779a0", - "renesas,rcar-gen4-ipmmu-vmsa"; - reg = <0 0xeed00000 0 0x20000>; - renesas,ipmmu-main = <&ipmmu_mm>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_ds1: iommu@eed40000 { - compatible = "renesas,ipmmu-r8a779a0", - "renesas,rcar-gen4-ipmmu-vmsa"; - reg = <0 0xeed40000 0 0x20000>; - renesas,ipmmu-main = <&ipmmu_mm>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_ir: iommu@eed80000 { - compatible = "renesas,ipmmu-r8a779a0", - "renesas,rcar-gen4-ipmmu-vmsa"; - reg = <0 0xeed80000 0 0x20000>; - renesas,ipmmu-main = <&ipmmu_mm>; - power-domains = <&sysc R8A779A0_PD_A3IR>; - #iommu-cells = <1>; - }; - - ipmmu_vc0: iommu@eedc0000 { - compatible = "renesas,ipmmu-r8a779a0", - "renesas,rcar-gen4-ipmmu-vmsa"; - reg = <0 0xeedc0000 0 0x20000>; - renesas,ipmmu-main = <&ipmmu_mm>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_vi0: iommu@eee80000 { - compatible = "renesas,ipmmu-r8a779a0", - "renesas,rcar-gen4-ipmmu-vmsa"; - reg = <0 0xeee80000 0 0x20000>; - renesas,ipmmu-main = <&ipmmu_mm>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_vi1: iommu@eeec0000 { - compatible = "renesas,ipmmu-r8a779a0", - "renesas,rcar-gen4-ipmmu-vmsa"; - reg = <0 0xeeec0000 0 0x20000>; - renesas,ipmmu-main = <&ipmmu_mm>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_3dg: iommu@eee00000 { - compatible = "renesas,ipmmu-r8a779a0", - "renesas,rcar-gen4-ipmmu-vmsa"; - reg = <0 0xeee00000 0 0x20000>; - renesas,ipmmu-main = <&ipmmu_mm>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_vip0: iommu@eef00000 { - compatible = "renesas,ipmmu-r8a779a0", - "renesas,rcar-gen4-ipmmu-vmsa"; - reg = <0 0xeef00000 0 0x20000>; - renesas,ipmmu-main = <&ipmmu_mm>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_vip1: iommu@eef40000 { - compatible = "renesas,ipmmu-r8a779a0", - "renesas,rcar-gen4-ipmmu-vmsa"; - reg = <0 0xeef40000 0 0x20000>; - renesas,ipmmu-main = <&ipmmu_mm>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_mm: iommu@eefc0000 { - compatible = "renesas,ipmmu-r8a779a0", - "renesas,rcar-gen4-ipmmu-vmsa"; - reg = <0 0xeefc0000 0 0x20000>; - interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 22 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - gic: interrupt-controller@f1000000 { - compatible = "arm,gic-v3"; - #interrupt-cells = <3>; - #address-cells = <0>; - interrupt-controller; - reg = <0x0 0xf1000000 0 0x20000>, - <0x0 0xf1060000 0 0x110000>; - interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>; - }; - - fcpvd0: fcp@fea10000 { - compatible = "renesas,fcpv"; - reg = <0 0xfea10000 0 0x200>; - clocks = <&cpg CPG_MOD 508>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 508>; - }; - - fcpvd1: fcp@fea11000 { - compatible = "renesas,fcpv"; - reg = <0 0xfea11000 0 0x200>; - clocks = <&cpg CPG_MOD 509>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 509>; - }; - - vspd0: vsp@fea20000 { - compatible = "renesas,vsp2"; - reg = <0 0xfea20000 0 0x5000>; - interrupts = <GIC_SPI 128 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 830>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 830>; - - renesas,fcp = <&fcpvd0>; - }; - - vspd1: vsp@fea28000 { - compatible = "renesas,vsp2"; - reg = <0 0xfea28000 0 0x5000>; - interrupts = <GIC_SPI 129 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 831>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 831>; - - renesas,fcp = <&fcpvd1>; - }; - - csi40: csi2@feaa0000 { - compatible = "renesas,r8a779a0-csi2"; - reg = <0 0xfeaa0000 0 0x10000>; - interrupts = <GIC_SPI 192 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 331>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 331>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - - port@1 { - reg = <1>; - csi40isp0: endpoint { - remote-endpoint = <&isp0csi40>; - }; - }; - }; - }; - - csi41: csi2@feab0000 { - compatible = "renesas,r8a779a0-csi2"; - reg = <0 0xfeab0000 0 0x10000>; - interrupts = <GIC_SPI 193 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 400>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 400>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - - port@1 { - reg = <1>; - csi41isp1: endpoint { - remote-endpoint = <&isp1csi41>; - }; - }; - }; - }; - - csi42: csi2@fed60000 { - compatible = "renesas,r8a779a0-csi2"; - reg = <0 0xfed60000 0 0x10000>; - interrupts = <GIC_SPI 194 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 401>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 401>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - - port@1 { - reg = <1>; - csi42isp2: endpoint { - remote-endpoint = <&isp2csi42>; - }; - }; - }; - }; - - csi43: csi2@fed70000 { - compatible = "renesas,r8a779a0-csi2"; - reg = <0 0xfed70000 0 0x10000>; - interrupts = <GIC_SPI 195 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 402>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 402>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - - port@1 { - reg = <1>; - csi43isp3: endpoint { - remote-endpoint = <&isp3csi43>; - }; - }; - }; - }; - - du: display@feb00000 { - compatible = "renesas,du-r8a779a0"; - reg = <0 0xfeb00000 0 0x40000>; - interrupts = <GIC_SPI 143 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 411>; - clock-names = "du.0"; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - resets = <&cpg 411>; - reset-names = "du.0"; - renesas,vsps = <&vspd0 0>, <&vspd1 0>; - - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - du_out_dsi0: endpoint { - remote-endpoint = <&dsi0_in>; - }; - }; - - port@1 { - reg = <1>; - du_out_dsi1: endpoint { - remote-endpoint = <&dsi1_in>; - }; - }; - }; - }; - - isp0: isp@fed00000 { - compatible = "renesas,r8a779a0-isp"; - reg = <0 0xfed00000 0 0x10000>; - interrupts = <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 612>; - power-domains = <&sysc R8A779A0_PD_A3ISP01>; - resets = <&cpg 612>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <0>; - - isp0csi40: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi40isp0>; - }; - }; - - port@1 { - reg = <1>; - isp0vin00: endpoint { - remote-endpoint = <&vin00isp0>; - }; - }; - - port@2 { - reg = <2>; - isp0vin01: endpoint { - remote-endpoint = <&vin01isp0>; - }; - }; - - port@3 { - reg = <3>; - isp0vin02: endpoint { - remote-endpoint = <&vin02isp0>; - }; - }; - - port@4 { - reg = <4>; - isp0vin03: endpoint { - remote-endpoint = <&vin03isp0>; - }; - }; - - port@5 { - reg = <5>; - isp0vin04: endpoint { - remote-endpoint = <&vin04isp0>; - }; - }; - - port@6 { - reg = <6>; - isp0vin05: endpoint { - remote-endpoint = <&vin05isp0>; - }; - }; - - port@7 { - reg = <7>; - isp0vin06: endpoint { - remote-endpoint = <&vin06isp0>; - }; - }; - - port@8 { - reg = <8>; - isp0vin07: endpoint { - remote-endpoint = <&vin07isp0>; - }; - }; - }; - }; - - isp1: isp@fed20000 { - compatible = "renesas,r8a779a0-isp"; - reg = <0 0xfed20000 0 0x10000>; - interrupts = <GIC_SPI 155 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 613>; - power-domains = <&sysc R8A779A0_PD_A3ISP01>; - resets = <&cpg 613>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <0>; - - isp1csi41: endpoint@1 { - reg = <1>; - remote-endpoint = <&csi41isp1>; - }; - }; - - port@1 { - reg = <1>; - isp1vin08: endpoint { - remote-endpoint = <&vin08isp1>; - }; - }; - - port@2 { - reg = <2>; - isp1vin09: endpoint { - remote-endpoint = <&vin09isp1>; - }; - }; - - port@3 { - reg = <3>; - isp1vin10: endpoint { - remote-endpoint = <&vin10isp1>; - }; - }; - - port@4 { - reg = <4>; - isp1vin11: endpoint { - remote-endpoint = <&vin11isp1>; - }; - }; - - port@5 { - reg = <5>; - isp1vin12: endpoint { - remote-endpoint = <&vin12isp1>; - }; - }; - - port@6 { - reg = <6>; - isp1vin13: endpoint { - remote-endpoint = <&vin13isp1>; - }; - }; - - port@7 { - reg = <7>; - isp1vin14: endpoint { - remote-endpoint = <&vin14isp1>; - }; - }; - - port@8 { - reg = <8>; - isp1vin15: endpoint { - remote-endpoint = <&vin15isp1>; - }; - }; - }; - }; - - isp2: isp@fed30000 { - compatible = "renesas,r8a779a0-isp"; - reg = <0 0xfed30000 0 0x10000>; - interrupts = <GIC_SPI 157 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 614>; - power-domains = <&sysc R8A779A0_PD_A3ISP23>; - resets = <&cpg 614>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <0>; - - isp2csi42: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi42isp2>; - }; - }; - - port@1 { - reg = <1>; - isp2vin16: endpoint { - remote-endpoint = <&vin16isp2>; - }; - }; - - port@2 { - reg = <2>; - isp2vin17: endpoint { - remote-endpoint = <&vin17isp2>; - }; - }; - - port@3 { - reg = <3>; - isp2vin18: endpoint { - remote-endpoint = <&vin18isp2>; - }; - }; - - port@4 { - reg = <4>; - isp2vin19: endpoint { - remote-endpoint = <&vin19isp2>; - }; - }; - - port@5 { - reg = <5>; - isp2vin20: endpoint { - remote-endpoint = <&vin20isp2>; - }; - }; - - port@6 { - reg = <6>; - isp2vin21: endpoint { - remote-endpoint = <&vin21isp2>; - }; - }; - - port@7 { - reg = <7>; - isp2vin22: endpoint { - remote-endpoint = <&vin22isp2>; - }; - }; - - port@8 { - reg = <8>; - isp2vin23: endpoint { - remote-endpoint = <&vin23isp2>; - }; - }; - }; - }; - - isp3: isp@fed40000 { - compatible = "renesas,r8a779a0-isp"; - reg = <0 0xfed40000 0 0x10000>; - interrupts = <GIC_SPI 159 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 615>; - power-domains = <&sysc R8A779A0_PD_A3ISP23>; - resets = <&cpg 615>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <0>; - - isp3csi43: endpoint@1 { - reg = <1>; - remote-endpoint = <&csi43isp3>; - }; - }; - - port@1 { - reg = <1>; - isp3vin24: endpoint { - remote-endpoint = <&vin24isp3>; - }; - }; - - port@2 { - reg = <2>; - isp3vin25: endpoint { - remote-endpoint = <&vin25isp3>; - }; - }; - - port@3 { - reg = <3>; - isp3vin26: endpoint { - remote-endpoint = <&vin26isp3>; - }; - }; - - port@4 { - reg = <4>; - isp3vin27: endpoint { - remote-endpoint = <&vin27isp3>; - }; - }; - - port@5 { - reg = <5>; - isp3vin28: endpoint { - remote-endpoint = <&vin28isp3>; - }; - }; - - port@6 { - reg = <6>; - isp3vin29: endpoint { - remote-endpoint = <&vin29isp3>; - }; - }; - - port@7 { - reg = <7>; - isp3vin30: endpoint { - remote-endpoint = <&vin30isp3>; - }; - }; - - port@8 { - reg = <8>; - isp3vin31: endpoint { - remote-endpoint = <&vin31isp3>; - }; - }; - }; - }; - - dsi0: dsi-encoder@fed80000 { - compatible = "renesas,r8a779a0-dsi-csi2-tx"; - reg = <0 0xfed80000 0 0x10000>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - clocks = <&cpg CPG_MOD 415>, - <&cpg CPG_CORE R8A779A0_CLK_DSI>, - <&cpg CPG_CORE R8A779A0_CLK_CL16MCK>; - clock-names = "fck", "dsi", "pll"; - resets = <&cpg 415>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - dsi0_in: endpoint { - remote-endpoint = <&du_out_dsi0>; - }; - }; - - port@1 { - reg = <1>; - }; - }; - }; - - dsi1: dsi-encoder@fed90000 { - compatible = "renesas,r8a779a0-dsi-csi2-tx"; - reg = <0 0xfed90000 0 0x10000>; - power-domains = <&sysc R8A779A0_PD_ALWAYS_ON>; - clocks = <&cpg CPG_MOD 416>, - <&cpg CPG_CORE R8A779A0_CLK_DSI>, - <&cpg CPG_CORE R8A779A0_CLK_CL16MCK>; - clock-names = "fck", "dsi", "pll"; - resets = <&cpg 416>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - dsi1_in: endpoint { - remote-endpoint = <&du_out_dsi1>; - }; - }; - - port@1 { - reg = <1>; - }; - }; - }; - - prr: chipid@fff00044 { - compatible = "renesas,prr"; - reg = <0 0xfff00044 0 4>; - }; - }; - - thermal-zones { - sensor1_thermal: sensor1-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - thermal-sensors = <&tsc 0>; - - trips { - sensor1_crit: sensor1-crit { - temperature = <120000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - }; - - sensor2_thermal: sensor2-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - thermal-sensors = <&tsc 1>; - - trips { - sensor2_crit: sensor2-crit { - temperature = <120000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - }; - - sensor3_thermal: sensor3-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - thermal-sensors = <&tsc 2>; - - trips { - sensor3_crit: sensor3-crit { - temperature = <120000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - }; - - sensor4_thermal: sensor4-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - thermal-sensors = <&tsc 3>; - - trips { - sensor4_crit: sensor4-crit { - temperature = <120000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - }; - - sensor5_thermal: sensor5-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - thermal-sensors = <&tsc 4>; - - trips { - sensor5_crit: sensor5-crit { - temperature = <120000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - }; - }; - - timer { - compatible = "arm,armv8-timer"; - interrupts-extended = <&gic GIC_PPI 13 IRQ_TYPE_LEVEL_LOW>, - <&gic GIC_PPI 14 IRQ_TYPE_LEVEL_LOW>, - <&gic GIC_PPI 11 IRQ_TYPE_LEVEL_LOW>, - <&gic GIC_PPI 10 IRQ_TYPE_LEVEL_LOW>; - }; -}; diff --git a/arch/arm/dts/r8a779f0-spider-cpu.dtsi b/arch/arm/dts/r8a779f0-spider-cpu.dtsi deleted file mode 100644 index 5cbde8e8fcd..00000000000 --- a/arch/arm/dts/r8a779f0-spider-cpu.dtsi +++ /dev/null @@ -1,210 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0 OR MIT) -/* - * Device Tree Source for the Spider CPU board - * - * Copyright (C) 2021 Renesas Electronics Corp. - */ - -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/leds/common.h> - -#include "r8a779f0.dtsi" - -/ { - model = "Renesas Spider CPU board"; - compatible = "renesas,spider-cpu", "renesas,r8a779f0"; - - aliases { - serial0 = &hscif0; - serial1 = &scif0; - }; - - chosen { - bootargs = "ignore_loglevel rw root=/dev/nfs ip=on"; - stdout-path = "serial0:1843200n8"; - }; - - leds { - compatible = "gpio-leds"; - - led-7 { - gpios = <&gpio0 11 GPIO_ACTIVE_HIGH>; - color = <LED_COLOR_ID_GREEN>; - function = LED_FUNCTION_INDICATOR; - function-enumerator = <7>; - }; - - led-8 { - gpios = <&gpio0 14 GPIO_ACTIVE_HIGH>; - color = <LED_COLOR_ID_GREEN>; - function = LED_FUNCTION_INDICATOR; - function-enumerator = <8>; - }; - }; - - memory@48000000 { - device_type = "memory"; - /* first 128MB is reserved for secure area. */ - reg = <0x0 0x48000000 0x0 0x78000000>; - }; - - memory@480000000 { - device_type = "memory"; - reg = <0x4 0x80000000 0x0 0x80000000>; - }; - - rc21012_ufs: clk-rc21012-ufs { - compatible = "fixed-clock"; - clock-frequency = <38400000>; - #clock-cells = <0>; - }; - - reg_1p8v: regulator-1p8v { - compatible = "regulator-fixed"; - regulator-name = "fixed-1.8V"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-boot-on; - regulator-always-on; - }; - - reg_3p3v: regulator-3p3v { - compatible = "regulator-fixed"; - regulator-name = "fixed-3.3V"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; -}; - -&extal_clk { - clock-frequency = <20000000>; -}; - -&extalr_clk { - clock-frequency = <32768>; -}; - -&hscif0 { - pinctrl-0 = <&hscif0_pins>; - pinctrl-names = "default"; - - uart-has-rtscts; - status = "okay"; -}; - -&i2c0 { - pinctrl-0 = <&i2c0_pins>; - pinctrl-names = "default"; - - status = "okay"; - clock-frequency = <400000>; - - gpio_exp_20: gpio@20 { - compatible = "ti,tca9554"; - reg = <0x20>; - gpio-controller; - #gpio-cells = <2>; - }; -}; - -&i2c4 { - pinctrl-0 = <&i2c4_pins>; - pinctrl-names = "default"; - - status = "okay"; - clock-frequency = <400000>; - - eeprom@50 { - compatible = "rohm,br24g01", "atmel,24c01"; - label = "cpu-board"; - reg = <0x50>; - pagesize = <8>; - }; -}; - -/* - * This board also has a microSD slot which we will not support upstream - * because we cannot directly switch voltages in software. - */ -&mmc0 { - pinctrl-0 = <&mmc_pins>; - pinctrl-1 = <&mmc_pins>; - pinctrl-names = "default", "state_uhs"; - - vmmc-supply = <®_3p3v>; - vqmmc-supply = <®_1p8v>; - mmc-hs200-1_8v; - mmc-hs400-1_8v; - bus-width = <8>; - no-sd; - no-sdio; - non-removable; - full-pwr-cycle-in-suspend; - status = "okay"; -}; - -&pfc { - pinctrl-0 = <&scif_clk_pins>; - pinctrl-names = "default"; - - hscif0_pins: hscif0 { - groups = "hscif0_data", "hscif0_ctrl"; - function = "hscif0"; - }; - - i2c0_pins: i2c0 { - groups = "i2c0"; - function = "i2c0"; - }; - - i2c4_pins: i2c4 { - groups = "i2c4"; - function = "i2c4"; - }; - - mmc_pins: mmc { - groups = "mmc_data8", "mmc_ctrl", "mmc_ds"; - function = "mmc"; - power-source = <1800>; - }; - - scif0_pins: scif0 { - groups = "scif0_data", "scif0_ctrl"; - function = "scif0"; - }; - - scif_clk_pins: scif_clk { - groups = "scif_clk"; - function = "scif_clk"; - }; -}; - -&rwdt { - timeout-sec = <60>; - status = "okay"; -}; - -&scif0 { - pinctrl-0 = <&scif0_pins>; - pinctrl-names = "default"; - - uart-has-rtscts; - status = "okay"; -}; - -&scif_clk { - clock-frequency = <24000000>; -}; - -&ufs { - status = "okay"; -}; - -&ufs30_clk { - compatible = "gpio-gate-clock"; - clocks = <&rc21012_ufs>; - enable-gpios = <&gpio_exp_20 4 GPIO_ACTIVE_LOW>; - /delete-property/ clock-frequency; -}; diff --git a/arch/arm/dts/r8a779f0-spider-ethernet.dtsi b/arch/arm/dts/r8a779f0-spider-ethernet.dtsi deleted file mode 100644 index 33c1015e9ab..00000000000 --- a/arch/arm/dts/r8a779f0-spider-ethernet.dtsi +++ /dev/null @@ -1,105 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Device Tree Source for the Spider Ethernet sub-board - * - * Copyright (C) 2021 Renesas Electronics Corp. - */ - -ð_serdes { - status = "okay"; -}; - -&i2c4 { - eeprom@52 { - compatible = "rohm,br24g01", "atmel,24c01"; - label = "ethernet-sub-board"; - reg = <0x52>; - pagesize = <8>; - }; -}; - -&pfc { - tsn0_pins: tsn0 { - groups = "tsn0_mdio_b", "tsn0_link_b"; - function = "tsn0"; - power-source = <1800>; - }; - - tsn1_pins: tsn1 { - groups = "tsn1_mdio_b", "tsn1_link_b"; - function = "tsn1"; - power-source = <1800>; - }; - - tsn2_pins: tsn2 { - groups = "tsn2_mdio_b", "tsn2_link_b"; - function = "tsn2"; - power-source = <1800>; - }; -}; - -&rswitch { - pinctrl-0 = <&tsn0_pins>, <&tsn1_pins>, <&tsn2_pins>; - pinctrl-names = "default"; - status = "okay"; - - ethernet-ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - phy-handle = <&u101>; - phy-mode = "sgmii"; - phys = <ð_serdes 0>; - - mdio { - #address-cells = <1>; - #size-cells = <0>; - - u101: ethernet-phy@1 { - reg = <1>; - compatible = "ethernet-phy-ieee802.3-c45"; - interrupt-parent = <&gpio3>; - interrupts = <10 IRQ_TYPE_LEVEL_LOW>; - }; - }; - }; - port@1 { - reg = <1>; - phy-handle = <&u201>; - phy-mode = "sgmii"; - phys = <ð_serdes 1>; - - mdio { - #address-cells = <1>; - #size-cells = <0>; - - u201: ethernet-phy@2 { - reg = <2>; - compatible = "ethernet-phy-ieee802.3-c45"; - interrupt-parent = <&gpio3>; - interrupts = <11 IRQ_TYPE_LEVEL_LOW>; - }; - }; - }; - port@2 { - reg = <2>; - phy-handle = <&u301>; - phy-mode = "sgmii"; - phys = <ð_serdes 2>; - - mdio { - #address-cells = <1>; - #size-cells = <0>; - - u301: ethernet-phy@3 { - reg = <3>; - compatible = "ethernet-phy-ieee802.3-c45"; - interrupt-parent = <&gpio3>; - interrupts = <9 IRQ_TYPE_LEVEL_LOW>; - }; - }; - }; - }; -}; diff --git a/arch/arm/dts/r8a779f0-spider.dts b/arch/arm/dts/r8a779f0-spider.dts deleted file mode 100644 index f139cc4feb3..00000000000 --- a/arch/arm/dts/r8a779f0-spider.dts +++ /dev/null @@ -1,24 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0 OR MIT) -/* - * Device Tree Source for the Spider CPU and BreakOut boards - * - * Copyright (C) 2021 Renesas Electronics Corp. - */ - -/dts-v1/; -#include "r8a779f0-spider-cpu.dtsi" -#include "r8a779f0-spider-ethernet.dtsi" - -/ { - model = "Renesas Spider CPU and Breakout boards based on r8a779f0"; - compatible = "renesas,spider-breakout", "renesas,spider-cpu", "renesas,r8a779f0"; -}; - -&i2c4 { - eeprom@51 { - compatible = "rohm,br24g01", "atmel,24c01"; - label = "breakout-board"; - reg = <0x51>; - pagesize = <8>; - }; -}; diff --git a/arch/arm/dts/r8a779f0.dtsi b/arch/arm/dts/r8a779f0.dtsi deleted file mode 100644 index ecdd5a523fa..00000000000 --- a/arch/arm/dts/r8a779f0.dtsi +++ /dev/null @@ -1,1193 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0 OR MIT) -/* - * Device Tree Source for the R-Car S4-8 (R8A779F0) SoC - * - * Copyright (C) 2021 Renesas Electronics Corp. - */ - -#include <dt-bindings/clock/r8a779f0-cpg-mssr.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/power/r8a779f0-sysc.h> - -/ { - compatible = "renesas,r8a779f0"; - #address-cells = <2>; - #size-cells = <2>; - - cluster01_opp: opp-table-0 { - compatible = "operating-points-v2"; - opp-shared; - - opp-500000000 { - opp-hz = /bits/ 64 <500000000>; - opp-microvolt = <880000>; - clock-latency-ns = <500000>; - }; - opp-800000000 { - opp-hz = /bits/ 64 <800000000>; - opp-microvolt = <880000>; - clock-latency-ns = <500000>; - }; - opp-1000000000 { - opp-hz = /bits/ 64 <1000000000>; - opp-microvolt = <880000>; - clock-latency-ns = <500000>; - }; - opp-1200000000 { - opp-hz = /bits/ 64 <1200000000>; - opp-microvolt = <880000>; - clock-latency-ns = <500000>; - opp-suspend; - }; - }; - - cluster23_opp: opp-table-1 { - compatible = "operating-points-v2"; - opp-shared; - - opp-500000000 { - opp-hz = /bits/ 64 <500000000>; - opp-microvolt = <880000>; - clock-latency-ns = <500000>; - }; - opp-800000000 { - opp-hz = /bits/ 64 <800000000>; - opp-microvolt = <880000>; - clock-latency-ns = <500000>; - }; - opp-1000000000 { - opp-hz = /bits/ 64 <1000000000>; - opp-microvolt = <880000>; - clock-latency-ns = <500000>; - }; - opp-1200000000 { - opp-hz = /bits/ 64 <1200000000>; - opp-microvolt = <880000>; - clock-latency-ns = <500000>; - opp-suspend; - }; - }; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - - cpu-map { - cluster0 { - core0 { - cpu = <&a55_0>; - }; - core1 { - cpu = <&a55_1>; - }; - }; - - cluster1 { - core0 { - cpu = <&a55_2>; - }; - core1 { - cpu = <&a55_3>; - }; - }; - - cluster2 { - core0 { - cpu = <&a55_4>; - }; - core1 { - cpu = <&a55_5>; - }; - }; - - cluster3 { - core0 { - cpu = <&a55_6>; - }; - core1 { - cpu = <&a55_7>; - }; - }; - }; - - a55_0: cpu@0 { - compatible = "arm,cortex-a55"; - reg = <0>; - device_type = "cpu"; - power-domains = <&sysc R8A779F0_PD_A1E0D0C0>; - next-level-cache = <&L3_CA55_0>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_0>; - clocks = <&cpg CPG_CORE R8A779F0_CLK_Z0>; - operating-points-v2 = <&cluster01_opp>; - }; - - a55_1: cpu@100 { - compatible = "arm,cortex-a55"; - reg = <0x100>; - device_type = "cpu"; - power-domains = <&sysc R8A779F0_PD_A1E0D0C1>; - next-level-cache = <&L3_CA55_0>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_0>; - clocks = <&cpg CPG_CORE R8A779F0_CLK_Z0>; - operating-points-v2 = <&cluster01_opp>; - }; - - a55_2: cpu@10000 { - compatible = "arm,cortex-a55"; - reg = <0x10000>; - device_type = "cpu"; - power-domains = <&sysc R8A779F0_PD_A1E0D1C0>; - next-level-cache = <&L3_CA55_1>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_0>; - clocks = <&cpg CPG_CORE R8A779F0_CLK_Z0>; - operating-points-v2 = <&cluster01_opp>; - }; - - a55_3: cpu@10100 { - compatible = "arm,cortex-a55"; - reg = <0x10100>; - device_type = "cpu"; - power-domains = <&sysc R8A779F0_PD_A1E0D1C1>; - next-level-cache = <&L3_CA55_1>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_0>; - clocks = <&cpg CPG_CORE R8A779F0_CLK_Z0>; - operating-points-v2 = <&cluster01_opp>; - }; - - a55_4: cpu@20000 { - compatible = "arm,cortex-a55"; - reg = <0x20000>; - device_type = "cpu"; - power-domains = <&sysc R8A779F0_PD_A1E1D0C0>; - next-level-cache = <&L3_CA55_2>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_0>; - clocks = <&cpg CPG_CORE R8A779F0_CLK_Z1>; - operating-points-v2 = <&cluster23_opp>; - }; - - a55_5: cpu@20100 { - compatible = "arm,cortex-a55"; - reg = <0x20100>; - device_type = "cpu"; - power-domains = <&sysc R8A779F0_PD_A1E1D0C1>; - next-level-cache = <&L3_CA55_2>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_0>; - clocks = <&cpg CPG_CORE R8A779F0_CLK_Z1>; - operating-points-v2 = <&cluster23_opp>; - }; - - a55_6: cpu@30000 { - compatible = "arm,cortex-a55"; - reg = <0x30000>; - device_type = "cpu"; - power-domains = <&sysc R8A779F0_PD_A1E1D1C0>; - next-level-cache = <&L3_CA55_3>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_0>; - clocks = <&cpg CPG_CORE R8A779F0_CLK_Z1>; - operating-points-v2 = <&cluster23_opp>; - }; - - a55_7: cpu@30100 { - compatible = "arm,cortex-a55"; - reg = <0x30100>; - device_type = "cpu"; - power-domains = <&sysc R8A779F0_PD_A1E1D1C1>; - next-level-cache = <&L3_CA55_3>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_0>; - clocks = <&cpg CPG_CORE R8A779F0_CLK_Z1>; - operating-points-v2 = <&cluster23_opp>; - }; - - L3_CA55_0: cache-controller-0 { - compatible = "cache"; - power-domains = <&sysc R8A779F0_PD_A2E0D0>; - cache-unified; - cache-level = <3>; - }; - - L3_CA55_1: cache-controller-1 { - compatible = "cache"; - power-domains = <&sysc R8A779F0_PD_A2E0D1>; - cache-unified; - cache-level = <3>; - }; - - L3_CA55_2: cache-controller-2 { - compatible = "cache"; - power-domains = <&sysc R8A779F0_PD_A2E1D0>; - cache-unified; - cache-level = <3>; - }; - - L3_CA55_3: cache-controller-3 { - compatible = "cache"; - power-domains = <&sysc R8A779F0_PD_A2E1D1>; - cache-unified; - cache-level = <3>; - }; - - idle-states { - entry-method = "psci"; - - CPU_SLEEP_0: cpu-sleep-0 { - compatible = "arm,idle-state"; - arm,psci-suspend-param = <0x0010000>; - local-timer-stop; - entry-latency-us = <400>; - exit-latency-us = <500>; - min-residency-us = <4000>; - }; - }; - }; - - extal_clk: extal { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board */ - clock-frequency = <0>; - }; - - extalr_clk: extalr { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board */ - clock-frequency = <0>; - }; - - pmu_a55 { - compatible = "arm,cortex-a55-pmu"; - interrupts-extended = <&gic GIC_PPI 7 IRQ_TYPE_LEVEL_LOW>; - }; - - psci { - compatible = "arm,psci-1.0", "arm,psci-0.2"; - method = "smc"; - }; - - /* External SCIF clock - to be overridden by boards that provide it */ - scif_clk: scif { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - soc: soc { - compatible = "simple-bus"; - interrupt-parent = <&gic>; - #address-cells = <2>; - #size-cells = <2>; - ranges; - - rwdt: watchdog@e6020000 { - compatible = "renesas,r8a779f0-wdt", - "renesas,rcar-gen4-wdt"; - reg = <0 0xe6020000 0 0x0c>; - interrupts = <GIC_SPI 515 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 907>; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 907>; - status = "disabled"; - }; - - pfc: pinctrl@e6050000 { - compatible = "renesas,pfc-r8a779f0"; - reg = <0 0xe6050000 0 0x16c>, <0 0xe6050800 0 0x16c>, - <0 0xe6051000 0 0x16c>, <0 0xe6051800 0 0x16c>; - }; - - gpio0: gpio@e6050180 { - compatible = "renesas,gpio-r8a779f0", - "renesas,rcar-gen4-gpio"; - reg = <0 0xe6050180 0 0x54>; - interrupts = <GIC_SPI 822 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 915>; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 915>; - gpio-controller; - #gpio-cells = <2>; - gpio-ranges = <&pfc 0 0 21>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio1: gpio@e6050980 { - compatible = "renesas,gpio-r8a779f0", - "renesas,rcar-gen4-gpio"; - reg = <0 0xe6050980 0 0x54>; - interrupts = <GIC_SPI 823 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 915>; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 915>; - gpio-controller; - #gpio-cells = <2>; - gpio-ranges = <&pfc 0 32 25>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio2: gpio@e6051180 { - compatible = "renesas,gpio-r8a779f0", - "renesas,rcar-gen4-gpio"; - reg = <0 0xe6051180 0 0x54>; - interrupts = <GIC_SPI 824 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 915>; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 915>; - gpio-controller; - #gpio-cells = <2>; - gpio-ranges = <&pfc 0 64 17>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio3: gpio@e6051980 { - compatible = "renesas,gpio-r8a779f0", - "renesas,rcar-gen4-gpio"; - reg = <0 0xe6051980 0 0x54>; - interrupts = <GIC_SPI 825 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 915>; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 915>; - gpio-controller; - #gpio-cells = <2>; - gpio-ranges = <&pfc 0 96 19>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - cmt0: timer@e60f0000 { - compatible = "renesas,r8a779f0-cmt0", - "renesas,rcar-gen4-cmt0"; - reg = <0 0xe60f0000 0 0x1004>; - interrupts = <GIC_SPI 448 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 449 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 910>; - clock-names = "fck"; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 910>; - status = "disabled"; - }; - - cmt1: timer@e6130000 { - compatible = "renesas,r8a779f0-cmt1", - "renesas,rcar-gen4-cmt1"; - reg = <0 0xe6130000 0 0x1004>; - interrupts = <GIC_SPI 450 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 451 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 452 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 453 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 454 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 455 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 456 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 457 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 911>; - clock-names = "fck"; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 911>; - status = "disabled"; - }; - - cmt2: timer@e6140000 { - compatible = "renesas,r8a779f0-cmt1", - "renesas,rcar-gen4-cmt1"; - reg = <0 0xe6140000 0 0x1004>; - interrupts = <GIC_SPI 458 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 459 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 460 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 461 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 462 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 463 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 464 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 465 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 912>; - clock-names = "fck"; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 912>; - status = "disabled"; - }; - - cmt3: timer@e6148000 { - compatible = "renesas,r8a779f0-cmt1", - "renesas,rcar-gen4-cmt1"; - reg = <0 0xe6148000 0 0x1004>; - interrupts = <GIC_SPI 466 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 467 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 468 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 469 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 470 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 471 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 472 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 473 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 913>; - clock-names = "fck"; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 913>; - status = "disabled"; - }; - - cpg: clock-controller@e6150000 { - compatible = "renesas,r8a779f0-cpg-mssr"; - reg = <0 0xe6150000 0 0x4000>; - clocks = <&extal_clk>, <&extalr_clk>; - clock-names = "extal", "extalr"; - #clock-cells = <2>; - #power-domain-cells = <0>; - #reset-cells = <1>; - }; - - rst: reset-controller@e6160000 { - compatible = "renesas,r8a779f0-rst"; - reg = <0 0xe6160000 0 0x4000>; - }; - - sysc: system-controller@e6180000 { - compatible = "renesas,r8a779f0-sysc"; - reg = <0 0xe6180000 0 0x4000>; - #power-domain-cells = <1>; - }; - - tsc: thermal@e6198000 { - compatible = "renesas,r8a779f0-thermal"; - /* The 4th sensor is in control domain and not for Linux */ - reg = <0 0xe6198000 0 0x200>, - <0 0xe61a0000 0 0x200>, - <0 0xe61a8000 0 0x200>; - clocks = <&cpg CPG_MOD 919>; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 919>; - #thermal-sensor-cells = <1>; - }; - - intc_ex: interrupt-controller@e61c0000 { - compatible = "renesas,intc-ex-r8a779f0", "renesas,irqc"; - #interrupt-cells = <2>; - interrupt-controller; - reg = <0 0xe61c0000 0 0x200>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_CORE R8A779F0_CLK_CL16M>; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - }; - - tmu0: timer@e61e0000 { - compatible = "renesas,tmu-r8a779f0", "renesas,tmu"; - reg = <0 0xe61e0000 0 0x30>; - interrupts = <GIC_SPI 474 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 475 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 476 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 713>; - clock-names = "fck"; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 713>; - status = "disabled"; - }; - - tmu1: timer@e6fc0000 { - compatible = "renesas,tmu-r8a779f0", "renesas,tmu"; - reg = <0 0xe6fc0000 0 0x30>; - interrupts = <GIC_SPI 477 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 478 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 479 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 714>; - clock-names = "fck"; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 714>; - status = "disabled"; - }; - - tmu2: timer@e6fd0000 { - compatible = "renesas,tmu-r8a779f0", "renesas,tmu"; - reg = <0 0xe6fd0000 0 0x30>; - interrupts = <GIC_SPI 481 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 482 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 483 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 715>; - clock-names = "fck"; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 715>; - status = "disabled"; - }; - - tmu3: timer@e6fe0000 { - compatible = "renesas,tmu-r8a779f0", "renesas,tmu"; - reg = <0 0xe6fe0000 0 0x30>; - interrupts = <GIC_SPI 485 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 486 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 487 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 716>; - clock-names = "fck"; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 716>; - status = "disabled"; - }; - - tmu4: timer@ffc00000 { - compatible = "renesas,tmu-r8a779f0", "renesas,tmu"; - reg = <0 0xffc00000 0 0x30>; - interrupts = <GIC_SPI 489 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 490 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 491 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 717>; - clock-names = "fck"; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 717>; - status = "disabled"; - }; - - eth_serdes: phy@e6444000 { - compatible = "renesas,r8a779f0-ether-serdes"; - reg = <0 0xe6444000 0 0x2800>; - clocks = <&cpg CPG_MOD 1506>; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 1506>; - #phy-cells = <1>; - status = "disabled"; - }; - - i2c0: i2c@e6500000 { - compatible = "renesas,i2c-r8a779f0", - "renesas,rcar-gen4-i2c"; - reg = <0 0xe6500000 0 0x40>; - interrupts = <GIC_SPI 238 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 518>; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 518>; - dmas = <&dmac0 0x91>, <&dmac0 0x90>, - <&dmac1 0x91>, <&dmac1 0x90>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c1: i2c@e6508000 { - compatible = "renesas,i2c-r8a779f0", - "renesas,rcar-gen4-i2c"; - reg = <0 0xe6508000 0 0x40>; - interrupts = <GIC_SPI 239 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 519>; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 519>; - dmas = <&dmac0 0x93>, <&dmac0 0x92>, - <&dmac1 0x93>, <&dmac1 0x92>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c2: i2c@e6510000 { - compatible = "renesas,i2c-r8a779f0", - "renesas,rcar-gen4-i2c"; - reg = <0 0xe6510000 0 0x40>; - interrupts = <0 240 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 520>; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 520>; - dmas = <&dmac0 0x95>, <&dmac0 0x94>, - <&dmac1 0x95>, <&dmac1 0x94>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c3: i2c@e66d0000 { - compatible = "renesas,i2c-r8a779f0", - "renesas,rcar-gen4-i2c"; - reg = <0 0xe66d0000 0 0x40>; - interrupts = <GIC_SPI 241 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 521>; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 521>; - dmas = <&dmac0 0x97>, <&dmac0 0x96>, - <&dmac1 0x97>, <&dmac1 0x96>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c4: i2c@e66d8000 { - compatible = "renesas,i2c-r8a779f0", - "renesas,rcar-gen4-i2c"; - reg = <0 0xe66d8000 0 0x40>; - interrupts = <GIC_SPI 242 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 522>; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 522>; - dmas = <&dmac0 0x99>, <&dmac0 0x98>, - <&dmac1 0x99>, <&dmac1 0x98>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c5: i2c@e66e0000 { - compatible = "renesas,i2c-r8a779f0", - "renesas,rcar-gen4-i2c"; - reg = <0 0xe66e0000 0 0x40>; - interrupts = <GIC_SPI 243 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 523>; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 523>; - dmas = <&dmac0 0x9b>, <&dmac0 0x9a>, - <&dmac1 0x9b>, <&dmac1 0x9a>; - dma-names = "tx", "rx", "tx", "rx"; - i2c-scl-internal-delay-ns = <110>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - hscif0: serial@e6540000 { - compatible = "renesas,hscif-r8a779f0", - "renesas,rcar-gen4-hscif", "renesas,hscif"; - reg = <0 0xe6540000 0 0x60>; - interrupts = <GIC_SPI 245 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 514>, - <&cpg CPG_CORE R8A779F0_CLK_SASYNCPERD1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x31>, <&dmac0 0x30>, - <&dmac1 0x31>, <&dmac1 0x30>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 514>; - status = "disabled"; - }; - - hscif1: serial@e6550000 { - compatible = "renesas,hscif-r8a779f0", - "renesas,rcar-gen4-hscif", "renesas,hscif"; - reg = <0 0xe6550000 0 0x60>; - interrupts = <GIC_SPI 246 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 515>, - <&cpg CPG_CORE R8A779F0_CLK_SASYNCPERD1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x33>, <&dmac0 0x32>, - <&dmac1 0x33>, <&dmac1 0x32>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 515>; - status = "disabled"; - }; - - hscif2: serial@e6560000 { - compatible = "renesas,hscif-r8a779f0", - "renesas,rcar-gen4-hscif", "renesas,hscif"; - reg = <0 0xe6560000 0 0x60>; - interrupts = <GIC_SPI 247 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 516>, - <&cpg CPG_CORE R8A779F0_CLK_SASYNCPERD1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x35>, <&dmac0 0x34>, - <&dmac1 0x35>, <&dmac1 0x34>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 516>; - status = "disabled"; - }; - - hscif3: serial@e66a0000 { - compatible = "renesas,hscif-r8a779f0", - "renesas,rcar-gen4-hscif", "renesas,hscif"; - reg = <0 0xe66a0000 0 0x60>; - interrupts = <GIC_SPI 248 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 517>, - <&cpg CPG_CORE R8A779F0_CLK_SASYNCPERD1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x37>, <&dmac0 0x36>, - <&dmac1 0x37>, <&dmac1 0x36>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 517>; - status = "disabled"; - }; - - ufs: ufs@e6860000 { - compatible = "renesas,r8a779f0-ufs"; - reg = <0 0xe6860000 0 0x100>; - interrupts = <GIC_SPI 235 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 1514>, <&ufs30_clk>; - clock-names = "fck", "ref_clk"; - freq-table-hz = <200000000 200000000>, <38400000 38400000>; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 1514>; - status = "disabled"; - }; - - rswitch: ethernet@e6880000 { - compatible = "renesas,r8a779f0-ether-switch"; - reg = <0 0xe6880000 0 0x20000>, <0 0xe68c0000 0 0x20000>; - reg-names = "base", "secure_base"; - interrupts = <GIC_SPI 256 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 257 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 258 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 259 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 260 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 261 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 262 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 263 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 265 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 266 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 267 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 268 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 269 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 270 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 271 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 272 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 273 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 274 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 276 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 277 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 278 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 280 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 281 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 282 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 283 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 284 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 285 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 286 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 287 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 288 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 289 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 290 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 291 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 292 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 293 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 294 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 295 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 296 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 297 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 298 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 299 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 300 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 301 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 302 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 304 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 305 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 306 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "mfwd_error", "race_error", - "coma_error", "gwca0_error", - "gwca1_error", "etha0_error", - "etha1_error", "etha2_error", - "gptp0_status", "gptp1_status", - "mfwd_status", "race_status", - "coma_status", "gwca0_status", - "gwca1_status", "etha0_status", - "etha1_status", "etha2_status", - "rmac0_status", "rmac1_status", - "rmac2_status", - "gwca0_rxtx0", "gwca0_rxtx1", - "gwca0_rxtx2", "gwca0_rxtx3", - "gwca0_rxtx4", "gwca0_rxtx5", - "gwca0_rxtx6", "gwca0_rxtx7", - "gwca1_rxtx0", "gwca1_rxtx1", - "gwca1_rxtx2", "gwca1_rxtx3", - "gwca1_rxtx4", "gwca1_rxtx5", - "gwca1_rxtx6", "gwca1_rxtx7", - "gwca0_rxts0", "gwca0_rxts1", - "gwca1_rxts0", "gwca1_rxts1", - "rmac0_mdio", "rmac1_mdio", - "rmac2_mdio", - "rmac0_phy", "rmac1_phy", - "rmac2_phy"; - clocks = <&cpg CPG_MOD 1505>; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 1505>; - status = "disabled"; - - ethernet-ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - phys = <ð_serdes 0>; - }; - port@1 { - reg = <1>; - phys = <ð_serdes 1>; - }; - port@2 { - reg = <2>; - phys = <ð_serdes 2>; - }; - }; - }; - - scif0: serial@e6e60000 { - compatible = "renesas,scif-r8a779f0", - "renesas,rcar-gen4-scif", "renesas,scif"; - reg = <0 0xe6e60000 0 64>; - interrupts = <GIC_SPI 249 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 702>, - <&cpg CPG_CORE R8A779F0_CLK_SASYNCPERD1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x51>, <&dmac0 0x50>, - <&dmac1 0x51>, <&dmac1 0x50>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 702>; - status = "disabled"; - }; - - scif1: serial@e6e68000 { - compatible = "renesas,scif-r8a779f0", - "renesas,rcar-gen4-scif", "renesas,scif"; - reg = <0 0xe6e68000 0 64>; - interrupts = <GIC_SPI 250 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>, - <&cpg CPG_CORE R8A779F0_CLK_SASYNCPERD1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x53>, <&dmac0 0x52>, - <&dmac1 0x53>, <&dmac1 0x52>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 703>; - status = "disabled"; - }; - - scif3: serial@e6c50000 { - compatible = "renesas,scif-r8a779f0", - "renesas,rcar-gen4-scif", "renesas,scif"; - reg = <0 0xe6c50000 0 64>; - interrupts = <GIC_SPI 252 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 704>, - <&cpg CPG_CORE R8A779F0_CLK_SASYNCPERD1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x57>, <&dmac0 0x56>, - <&dmac1 0x57>, <&dmac1 0x56>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 704>; - status = "disabled"; - }; - - scif4: serial@e6c40000 { - compatible = "renesas,scif-r8a779f0", - "renesas,rcar-gen4-scif", "renesas,scif"; - reg = <0 0xe6c40000 0 64>; - interrupts = <GIC_SPI 253 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 705>, - <&cpg CPG_CORE R8A779F0_CLK_SASYNCPERD1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x59>, <&dmac0 0x58>, - <&dmac1 0x59>, <&dmac1 0x58>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 705>; - status = "disabled"; - }; - - msiof0: spi@e6e90000 { - compatible = "renesas,msiof-r8a779f0", - "renesas,rcar-gen4-msiof"; - reg = <0 0xe6e90000 0 0x0064>; - interrupts = <GIC_SPI 230 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 618>; - dmas = <&dmac0 0x41>, <&dmac0 0x40>, - <&dmac1 0x41>, <&dmac1 0x40>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 618>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof1: spi@e6ea0000 { - compatible = "renesas,msiof-r8a779f0", - "renesas,rcar-gen4-msiof"; - reg = <0 0xe6ea0000 0 0x0064>; - interrupts = <GIC_SPI 231 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 619>; - dmas = <&dmac0 0x43>, <&dmac0 0x42>, - <&dmac1 0x43>, <&dmac1 0x42>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 619>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof2: spi@e6c00000 { - compatible = "renesas,msiof-r8a779f0", - "renesas,rcar-gen4-msiof"; - reg = <0 0xe6c00000 0 0x0064>; - interrupts = <GIC_SPI 232 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 620>; - dmas = <&dmac0 0x45>, <&dmac0 0x44>, - <&dmac1 0x45>, <&dmac1 0x44>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 620>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof3: spi@e6c10000 { - compatible = "renesas,msiof-r8a779f0", - "renesas,rcar-gen4-msiof"; - reg = <0 0xe6c10000 0 0x0064>; - interrupts = <GIC_SPI 233 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 621>; - dmas = <&dmac0 0x47>, <&dmac0 0x46>, - <&dmac1 0x47>, <&dmac1 0x46>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 621>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - dmac0: dma-controller@e7350000 { - compatible = "renesas,dmac-r8a779f0", - "renesas,rcar-gen4-dmac"; - reg = <0 0xe7350000 0 0x1000>, - <0 0xe7300000 0 0x10000>; - interrupts = <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 106 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 111 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 114 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 115 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", "ch4", - "ch5", "ch6", "ch7", "ch8", "ch9", - "ch10", "ch11", "ch12", "ch13", - "ch14", "ch15"; - clocks = <&cpg CPG_MOD 709>; - clock-names = "fck"; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 709>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_ds0 0>, <&ipmmu_ds0 1>, - <&ipmmu_ds0 2>, <&ipmmu_ds0 3>, - <&ipmmu_ds0 4>, <&ipmmu_ds0 5>, - <&ipmmu_ds0 6>, <&ipmmu_ds0 7>, - <&ipmmu_ds0 8>, <&ipmmu_ds0 9>, - <&ipmmu_ds0 10>, <&ipmmu_ds0 11>, - <&ipmmu_ds0 12>, <&ipmmu_ds0 13>, - <&ipmmu_ds0 14>, <&ipmmu_ds0 15>; - }; - - dmac1: dma-controller@e7351000 { - compatible = "renesas,dmac-r8a779f0", - "renesas,rcar-gen4-dmac"; - reg = <0 0xe7351000 0 0x1000>, - <0 0xe7310000 0 0x10000>; - interrupts = <GIC_SPI 119 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 127 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 147 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 149 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 150 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 151 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", "ch4", - "ch5", "ch6", "ch7", "ch8", "ch9", - "ch10", "ch11", "ch12", "ch13", - "ch14", "ch15"; - clocks = <&cpg CPG_MOD 710>; - clock-names = "fck"; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 710>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_ds0 16>, <&ipmmu_ds0 17>, - <&ipmmu_ds0 18>, <&ipmmu_ds0 19>, - <&ipmmu_ds0 20>, <&ipmmu_ds0 21>, - <&ipmmu_ds0 22>, <&ipmmu_ds0 23>, - <&ipmmu_ds0 24>, <&ipmmu_ds0 25>, - <&ipmmu_ds0 26>, <&ipmmu_ds0 27>, - <&ipmmu_ds0 28>, <&ipmmu_ds0 29>, - <&ipmmu_ds0 30>, <&ipmmu_ds0 31>; - }; - - mmc0: mmc@ee140000 { - compatible = "renesas,sdhi-r8a779f0", - "renesas,rcar-gen4-sdhi"; - reg = <0 0xee140000 0 0x2000>; - interrupts = <GIC_SPI 236 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 706>, <&cpg CPG_CORE R8A779F0_CLK_SD0H>; - clock-names = "core", "clkh"; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - resets = <&cpg 706>; - max-frequency = <200000000>; - iommus = <&ipmmu_ds0 32>; - status = "disabled"; - }; - - ipmmu_rt0: iommu@ee480000 { - compatible = "renesas,ipmmu-r8a779f0", - "renesas,rcar-gen4-ipmmu-vmsa"; - reg = <0 0xee480000 0 0x20000>; - renesas,ipmmu-main = <&ipmmu_mm>; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_rt1: iommu@ee4c0000 { - compatible = "renesas,ipmmu-r8a779f0", - "renesas,rcar-gen4-ipmmu-vmsa"; - reg = <0 0xee4c0000 0 0x20000>; - renesas,ipmmu-main = <&ipmmu_mm>; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_ds0: iommu@eed00000 { - compatible = "renesas,ipmmu-r8a779f0", - "renesas,rcar-gen4-ipmmu-vmsa"; - reg = <0 0xeed00000 0 0x20000>; - renesas,ipmmu-main = <&ipmmu_mm>; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_hc: iommu@eed40000 { - compatible = "renesas,ipmmu-r8a779f0", - "renesas,rcar-gen4-ipmmu-vmsa"; - reg = <0 0xeed40000 0 0x20000>; - renesas,ipmmu-main = <&ipmmu_mm>; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_mm: iommu@eefc0000 { - compatible = "renesas,ipmmu-r8a779f0", - "renesas,rcar-gen4-ipmmu-vmsa"; - reg = <0 0xeefc0000 0 0x20000>; - interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 22 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&sysc R8A779F0_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - gic: interrupt-controller@f1000000 { - compatible = "arm,gic-v3"; - #interrupt-cells = <3>; - #address-cells = <0>; - interrupt-controller; - reg = <0x0 0xf1000000 0 0x20000>, - <0x0 0xf1060000 0 0x110000>; - interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>; - }; - - prr: chipid@fff00044 { - compatible = "renesas,prr"; - reg = <0 0xfff00044 0 4>; - }; - }; - - thermal-zones { - sensor_thermal_rtcore: sensor1-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - thermal-sensors = <&tsc 0>; - - trips { - sensor1_crit: sensor1-crit { - temperature = <120000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - }; - - sensor_thermal_apcore0: sensor2-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - thermal-sensors = <&tsc 1>; - - trips { - sensor2_crit: sensor2-crit { - temperature = <120000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - }; - - sensor_thermal_apcore4: sensor3-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - thermal-sensors = <&tsc 2>; - - trips { - sensor3_crit: sensor3-crit { - temperature = <120000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - }; - }; - - timer { - compatible = "arm,armv8-timer"; - interrupts-extended = <&gic GIC_PPI 13 IRQ_TYPE_LEVEL_LOW>, - <&gic GIC_PPI 14 IRQ_TYPE_LEVEL_LOW>, - <&gic GIC_PPI 11 IRQ_TYPE_LEVEL_LOW>, - <&gic GIC_PPI 10 IRQ_TYPE_LEVEL_LOW>; - }; - - ufs30_clk: ufs30-clk { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board */ - clock-frequency = <0>; - }; -}; diff --git a/arch/arm/dts/r8a779g0-white-hawk-cpu.dtsi b/arch/arm/dts/r8a779g0-white-hawk-cpu.dtsi deleted file mode 100644 index bb4a5270f71..00000000000 --- a/arch/arm/dts/r8a779g0-white-hawk-cpu.dtsi +++ /dev/null @@ -1,375 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0-only OR BSD-2-Clause) -/* - * Device Tree Source for the White Hawk CPU board - * - * Copyright (C) 2022 Renesas Electronics Corp. - */ - -#include "r8a779g0.dtsi" - -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/input/input.h> -#include <dt-bindings/leds/common.h> - -/ { - model = "Renesas White Hawk CPU board"; - compatible = "renesas,white-hawk-cpu", "renesas,r8a779g0"; - - aliases { - ethernet0 = &avb0; - serial0 = &hscif0; - }; - - chosen { - bootargs = "ignore_loglevel rw root=/dev/nfs ip=on"; - stdout-path = "serial0:921600n8"; - }; - - keys { - compatible = "gpio-keys"; - - pinctrl-0 = <&keys_pins>; - pinctrl-names = "default"; - - key-1 { - gpios = <&gpio5 0 GPIO_ACTIVE_LOW>; - linux,code = <KEY_1>; - label = "SW47"; - wakeup-source; - debounce-interval = <20>; - }; - - key-2 { - gpios = <&gpio5 1 GPIO_ACTIVE_LOW>; - linux,code = <KEY_2>; - label = "SW48"; - wakeup-source; - debounce-interval = <20>; - }; - - key-3 { - gpios = <&gpio5 2 GPIO_ACTIVE_LOW>; - linux,code = <KEY_3>; - label = "SW49"; - wakeup-source; - debounce-interval = <20>; - }; - }; - - leds { - compatible = "gpio-leds"; - - led-1 { - gpios = <&gpio7 0 GPIO_ACTIVE_HIGH>; - color = <LED_COLOR_ID_GREEN>; - function = LED_FUNCTION_INDICATOR; - function-enumerator = <1>; - }; - - led-2 { - gpios = <&gpio7 1 GPIO_ACTIVE_HIGH>; - color = <LED_COLOR_ID_GREEN>; - function = LED_FUNCTION_INDICATOR; - function-enumerator = <2>; - }; - - led-3 { - gpios = <&gpio7 2 GPIO_ACTIVE_HIGH>; - color = <LED_COLOR_ID_GREEN>; - function = LED_FUNCTION_INDICATOR; - function-enumerator = <3>; - }; - }; - - memory@48000000 { - device_type = "memory"; - /* first 128MB is reserved for secure area. */ - reg = <0x0 0x48000000 0x0 0x78000000>; - }; - - memory@480000000 { - device_type = "memory"; - reg = <0x4 0x80000000 0x0 0x80000000>; - }; - - memory@600000000 { - device_type = "memory"; - reg = <0x6 0x00000000 0x1 0x00000000>; - }; - - mini-dp-con { - compatible = "dp-connector"; - label = "CN5"; - type = "mini"; - - port { - mini_dp_con_in: endpoint { - remote-endpoint = <&sn65dsi86_out>; - }; - }; - }; - - reg_1p2v: regulator-1p2v { - compatible = "regulator-fixed"; - regulator-name = "fixed-1.2V"; - regulator-min-microvolt = <1200000>; - regulator-max-microvolt = <1200000>; - regulator-boot-on; - regulator-always-on; - }; - - reg_1p8v: regulator-1p8v { - compatible = "regulator-fixed"; - regulator-name = "fixed-1.8V"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-boot-on; - regulator-always-on; - }; - - reg_3p3v: regulator-3p3v { - compatible = "regulator-fixed"; - regulator-name = "fixed-3.3V"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - - sn65dsi86_refclk: clk-x6 { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <38400000>; - }; -}; - -&avb0 { - pinctrl-0 = <&avb0_pins>; - pinctrl-names = "default"; - phy-handle = <&phy0>; - tx-internal-delay-ps = <2000>; - status = "okay"; - - phy0: ethernet-phy@0 { - compatible = "ethernet-phy-id0022.1622", - "ethernet-phy-ieee802.3-c22"; - rxc-skew-ps = <1500>; - reg = <0>; - interrupt-parent = <&gpio7>; - interrupts = <5 IRQ_TYPE_LEVEL_LOW>; - reset-gpios = <&gpio7 10 GPIO_ACTIVE_LOW>; - }; -}; - -&dsi0 { - status = "okay"; - - ports { - port@1 { - dsi0_out: endpoint { - remote-endpoint = <&sn65dsi86_in>; - data-lanes = <1 2 3 4>; - }; - }; - }; -}; - -&du { - status = "okay"; -}; - -&extal_clk { - clock-frequency = <16666666>; -}; - -&extalr_clk { - clock-frequency = <32768>; -}; - -&hscif0 { - status = "okay"; -}; - -&i2c0 { - pinctrl-0 = <&i2c0_pins>; - pinctrl-names = "default"; - - status = "okay"; - clock-frequency = <400000>; - - io_expander_a: gpio@20 { - compatible = "onnn,pca9654"; - reg = <0x20>; - interrupt-parent = <&gpio0>; - interrupts = <0 IRQ_TYPE_LEVEL_LOW>; - gpio-controller; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - eeprom@50 { - compatible = "rohm,br24g01", "atmel,24c01"; - label = "cpu-board"; - reg = <0x50>; - pagesize = <8>; - }; -}; - -&i2c1 { - pinctrl-0 = <&i2c1_pins>; - pinctrl-names = "default"; - - status = "okay"; - clock-frequency = <400000>; - - bridge@2c { - compatible = "ti,sn65dsi86"; - reg = <0x2c>; - - clocks = <&sn65dsi86_refclk>; - clock-names = "refclk"; - - interrupt-parent = <&intc_ex>; - interrupts = <0 IRQ_TYPE_LEVEL_HIGH>; - - enable-gpios = <&gpio1 26 GPIO_ACTIVE_HIGH>; - - vccio-supply = <®_1p8v>; - vpll-supply = <®_1p8v>; - vcca-supply = <®_1p2v>; - vcc-supply = <®_1p2v>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - sn65dsi86_in: endpoint { - remote-endpoint = <&dsi0_out>; - }; - }; - - port@1 { - reg = <1>; - sn65dsi86_out: endpoint { - remote-endpoint = <&mini_dp_con_in>; - }; - }; - }; - }; -}; - -&mmc0 { - pinctrl-0 = <&mmc_pins>; - pinctrl-1 = <&mmc_pins>; - pinctrl-names = "default", "state_uhs"; - - vmmc-supply = <®_3p3v>; - vqmmc-supply = <®_1p8v>; - mmc-hs200-1_8v; - mmc-hs400-1_8v; - bus-width = <8>; - no-sd; - no-sdio; - non-removable; - full-pwr-cycle-in-suspend; - status = "okay"; -}; - -&pfc { - pinctrl-0 = <&scif_clk_pins>; - pinctrl-names = "default"; - - avb0_pins: avb0 { - mux { - groups = "avb0_link", "avb0_mdio", "avb0_rgmii", - "avb0_txcrefclk"; - function = "avb0"; - }; - - pins_mdio { - groups = "avb0_mdio"; - drive-strength = <21>; - }; - - pins_mii { - groups = "avb0_rgmii"; - drive-strength = <21>; - }; - - }; - hscif0_pins: hscif0 { - groups = "hscif0_data"; - function = "hscif0"; - }; - - i2c0_pins: i2c0 { - groups = "i2c0"; - function = "i2c0"; - }; - - i2c1_pins: i2c1 { - groups = "i2c1"; - function = "i2c1"; - }; - - keys_pins: keys { - pins = "GP_5_0", "GP_5_1", "GP_5_2"; - bias-pull-up; - }; - - mmc_pins: mmc { - groups = "mmc_data8", "mmc_ctrl", "mmc_ds"; - function = "mmc"; - power-source = <1800>; - }; - - qspi0_pins: qspi0 { - groups = "qspi0_ctrl", "qspi0_data4"; - function = "qspi0"; - }; - - scif_clk_pins: scif_clk { - groups = "scif_clk"; - function = "scif_clk"; - }; -}; - -&rpc { - pinctrl-0 = <&qspi0_pins>; - pinctrl-names = "default"; - - status = "okay"; - - flash@0 { - compatible = "spansion,s25fs512s", "jedec,spi-nor"; - reg = <0>; - spi-max-frequency = <40000000>; - spi-rx-bus-width = <4>; - - partitions { - compatible = "fixed-partitions"; - #address-cells = <1>; - #size-cells = <1>; - - boot@0 { - reg = <0x0 0x1200000>; - read-only; - }; - user@1200000 { - reg = <0x1200000 0x2e00000>; - }; - }; - }; -}; - -&rwdt { - timeout-sec = <60>; - status = "okay"; -}; - -&scif_clk { - clock-frequency = <24000000>; -}; diff --git a/arch/arm/dts/r8a779g0-white-hawk-csi-dsi.dtsi b/arch/arm/dts/r8a779g0-white-hawk-csi-dsi.dtsi deleted file mode 100644 index f8537f7ea4d..00000000000 --- a/arch/arm/dts/r8a779g0-white-hawk-csi-dsi.dtsi +++ /dev/null @@ -1,187 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0-only OR BSD-2-Clause) -/* - * Device Tree Source for the R-Car V4H White Hawk CSI/DSI sub-board - * - * Copyright (C) 2022 Glider bv - */ - -#include <dt-bindings/media/video-interfaces.h> - -&csi40 { - status = "okay"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - - csi40_in: endpoint { - bus-type = <MEDIA_BUS_TYPE_CSI2_CPHY>; - clock-lanes = <0>; - data-lanes = <1 2 3>; - remote-endpoint = <&max96712_out0>; - }; - }; - }; -}; - -&csi41 { - status = "okay"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - - csi41_in: endpoint { - bus-type = <MEDIA_BUS_TYPE_CSI2_CPHY>; - clock-lanes = <0>; - data-lanes = <1 2 3>; - remote-endpoint = <&max96712_out1>; - }; - }; - }; -}; - -&i2c0 { - pca9654_a: gpio@21 { - compatible = "onnn,pca9654"; - reg = <0x21>; - gpio-controller; - #gpio-cells = <2>; - }; - - pca9654_b: gpio@22 { - compatible = "onnn,pca9654"; - reg = <0x22>; - gpio-controller; - #gpio-cells = <2>; - }; - - eeprom@52 { - compatible = "rohm,br24g01", "atmel,24c01"; - label = "csi-dsi-sub-board-id"; - reg = <0x52>; - pagesize = <8>; - }; -}; - -&i2c1 { - gmsl0: gmsl-deserializer@49 { - compatible = "maxim,max96712"; - reg = <0x49>; - enable-gpios = <&pca9654_a 0 GPIO_ACTIVE_HIGH>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@4 { - reg = <4>; - max96712_out0: endpoint { - bus-type = <MEDIA_BUS_TYPE_CSI2_CPHY>; - clock-lanes = <0>; - data-lanes = <1 2 3>; - remote-endpoint = <&csi40_in>; - }; - }; - }; - }; - - gmsl1: gmsl-deserializer@4b { - compatible = "maxim,max96712"; - reg = <0x4b>; - enable-gpios = <&pca9654_b 0 GPIO_ACTIVE_HIGH>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@4 { - reg = <4>; - max96712_out1: endpoint { - bus-type = <MEDIA_BUS_TYPE_CSI2_CPHY>; - clock-lanes = <0>; - data-lanes = <1 2 3>; - remote-endpoint = <&csi41_in>; - }; - }; - }; - }; -}; - -&isp0 { - status = "okay"; -}; - -&isp1 { - status = "okay"; -}; - -&vin00 { - status = "okay"; -}; - -&vin01 { - status = "okay"; -}; - -&vin02 { - status = "okay"; -}; - -&vin03 { - status = "okay"; -}; - -&vin04 { - status = "okay"; -}; - -&vin05 { - status = "okay"; -}; - -&vin06 { - status = "okay"; -}; - -&vin07 { - status = "okay"; -}; - -&vin08 { - status = "okay"; -}; - -&vin09 { - status = "okay"; -}; - -&vin10 { - status = "okay"; -}; - -&vin11 { - status = "okay"; -}; - -&vin12 { - status = "okay"; -}; - -&vin13 { - status = "okay"; -}; - -&vin14 { - status = "okay"; -}; - -&vin15 { - status = "okay"; -}; diff --git a/arch/arm/dts/r8a779g0-white-hawk-ethernet.dtsi b/arch/arm/dts/r8a779g0-white-hawk-ethernet.dtsi deleted file mode 100644 index 4f411f95c67..00000000000 --- a/arch/arm/dts/r8a779g0-white-hawk-ethernet.dtsi +++ /dev/null @@ -1,16 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0-only OR BSD-2-Clause) -/* - * Device Tree Source for the R-Car V4H White Hawk RAVB/Ethernet(1000Base-T1) - * sub-board - * - * Copyright (C) 2022 Glider bv - */ - -&i2c0 { - eeprom@53 { - compatible = "rohm,br24g01", "atmel,24c01"; - label = "ethernet-sub-board-id"; - reg = <0x53>; - pagesize = <8>; - }; -}; diff --git a/arch/arm/dts/r8a779g0-white-hawk.dts b/arch/arm/dts/r8a779g0-white-hawk.dts deleted file mode 100644 index eff1ef6e2cc..00000000000 --- a/arch/arm/dts/r8a779g0-white-hawk.dts +++ /dev/null @@ -1,69 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0-only OR BSD-2-Clause) -/* - * Device Tree Source for the White Hawk CPU and BreakOut boards - * - * Copyright (C) 2022 Renesas Electronics Corp. - */ - -/dts-v1/; -#include "r8a779g0-white-hawk-cpu.dtsi" -#include "r8a779g0-white-hawk-csi-dsi.dtsi" -#include "r8a779g0-white-hawk-ethernet.dtsi" - -/ { - model = "Renesas White Hawk CPU and Breakout boards based on r8a779g0"; - compatible = "renesas,white-hawk-breakout", "renesas,white-hawk-cpu", "renesas,r8a779g0"; - - can_transceiver0: can-phy0 { - compatible = "nxp,tjr1443"; - #phy-cells = <0>; - enable-gpios = <&gpio1 3 GPIO_ACTIVE_HIGH>; - max-bitrate = <5000000>; - }; -}; - -&can_clk { - clock-frequency = <40000000>; -}; - -&canfd { - pinctrl-0 = <&canfd0_pins>, <&canfd1_pins>, <&can_clk_pins>; - pinctrl-names = "default"; - - status = "okay"; - - channel0 { - status = "okay"; - phys = <&can_transceiver0>; - }; - - channel1 { - status = "okay"; - }; -}; - -&i2c0 { - eeprom@51 { - compatible = "rohm,br24g01", "atmel,24c01"; - label = "breakout-board"; - reg = <0x51>; - pagesize = <8>; - }; -}; - -&pfc { - can_clk_pins: can-clk { - groups = "can_clk"; - function = "can_clk"; - }; - - canfd0_pins: canfd0 { - groups = "canfd0_data"; - function = "canfd0"; - }; - - canfd1_pins: canfd1 { - groups = "canfd1_data"; - function = "canfd1"; - }; -}; diff --git a/arch/arm/dts/r8a779g0.dtsi b/arch/arm/dts/r8a779g0.dtsi deleted file mode 100644 index d3d25e077c5..00000000000 --- a/arch/arm/dts/r8a779g0.dtsi +++ /dev/null @@ -1,2349 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0-only OR BSD-2-Clause) -/* - * Device Tree Source for the R-Car V4H (R8A779G0) SoC - * - * Copyright (C) 2022 Renesas Electronics Corp. - */ - -#include <dt-bindings/clock/r8a779g0-cpg-mssr.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/power/r8a779g0-sysc.h> - -/ { - compatible = "renesas,r8a779g0"; - #address-cells = <2>; - #size-cells = <2>; - - /* External Audio clock - to be overridden by boards that provide it */ - audio_clkin: audio_clkin { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - /* External CAN clock - to be overridden by boards that provide it */ - can_clk: can { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - cluster0_opp: opp-table-0 { - compatible = "operating-points-v2"; - opp-shared; - - opp-500000000 { - opp-hz = /bits/ 64 <500000000>; - opp-microvolt = <825000>; - clock-latency-ns = <500000>; - }; - opp-1000000000 { - opp-hz = /bits/ 64 <1000000000>; - opp-microvolt = <825000>; - clock-latency-ns = <500000>; - }; - opp-1500000000 { - opp-hz = /bits/ 64 <1500000000>; - opp-microvolt = <825000>; - clock-latency-ns = <500000>; - }; - opp-1700000000 { - opp-hz = /bits/ 64 <1700000000>; - opp-microvolt = <825000>; - clock-latency-ns = <500000>; - opp-suspend; - }; - opp-1800000000 { - opp-hz = /bits/ 64 <1800000000>; - opp-microvolt = <880000>; - clock-latency-ns = <500000>; - turbo-mode; - }; - }; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - - cpu-map { - cluster0 { - core0 { - cpu = <&a76_0>; - }; - core1 { - cpu = <&a76_1>; - }; - }; - - cluster1 { - core0 { - cpu = <&a76_2>; - }; - core1 { - cpu = <&a76_3>; - }; - }; - }; - - a76_0: cpu@0 { - compatible = "arm,cortex-a76"; - reg = <0>; - device_type = "cpu"; - power-domains = <&sysc R8A779G0_PD_A1E0D0C0>; - next-level-cache = <&L3_CA76_0>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_0>; - clocks = <&cpg CPG_CORE R8A779G0_CLK_Z0>; - operating-points-v2 = <&cluster0_opp>; - }; - - a76_1: cpu@100 { - compatible = "arm,cortex-a76"; - reg = <0x100>; - device_type = "cpu"; - power-domains = <&sysc R8A779G0_PD_A1E0D0C1>; - next-level-cache = <&L3_CA76_0>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_0>; - clocks = <&cpg CPG_CORE R8A779G0_CLK_Z0>; - operating-points-v2 = <&cluster0_opp>; - }; - - a76_2: cpu@10000 { - compatible = "arm,cortex-a76"; - reg = <0x10000>; - device_type = "cpu"; - power-domains = <&sysc R8A779G0_PD_A1E0D1C0>; - next-level-cache = <&L3_CA76_1>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_0>; - clocks = <&cpg CPG_CORE R8A779G0_CLK_Z0>; - operating-points-v2 = <&cluster0_opp>; - }; - - a76_3: cpu@10100 { - compatible = "arm,cortex-a76"; - reg = <0x10100>; - device_type = "cpu"; - power-domains = <&sysc R8A779G0_PD_A1E0D1C1>; - next-level-cache = <&L3_CA76_1>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_0>; - clocks = <&cpg CPG_CORE R8A779G0_CLK_Z0>; - operating-points-v2 = <&cluster0_opp>; - }; - - idle-states { - entry-method = "psci"; - - CPU_SLEEP_0: cpu-sleep-0 { - compatible = "arm,idle-state"; - arm,psci-suspend-param = <0x0010000>; - local-timer-stop; - entry-latency-us = <400>; - exit-latency-us = <500>; - min-residency-us = <4000>; - }; - }; - - L3_CA76_0: cache-controller-0 { - compatible = "cache"; - power-domains = <&sysc R8A779G0_PD_A2E0D0>; - cache-unified; - cache-level = <3>; - }; - - L3_CA76_1: cache-controller-1 { - compatible = "cache"; - power-domains = <&sysc R8A779G0_PD_A2E0D1>; - cache-unified; - cache-level = <3>; - }; - }; - - psci { - compatible = "arm,psci-1.0", "arm,psci-0.2"; - method = "smc"; - }; - - extal_clk: extal { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board */ - clock-frequency = <0>; - }; - - extalr_clk: extalr { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board */ - clock-frequency = <0>; - }; - - pmu_a76 { - compatible = "arm,cortex-a76-pmu"; - interrupts-extended = <&gic GIC_PPI 7 IRQ_TYPE_LEVEL_LOW>; - }; - - /* External SCIF clock - to be overridden by boards that provide it */ - scif_clk: scif { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - soc: soc { - compatible = "simple-bus"; - interrupt-parent = <&gic>; - #address-cells = <2>; - #size-cells = <2>; - ranges; - - rwdt: watchdog@e6020000 { - compatible = "renesas,r8a779g0-wdt", - "renesas,rcar-gen4-wdt"; - reg = <0 0xe6020000 0 0x0c>; - interrupts = <GIC_SPI 330 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 907>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 907>; - status = "disabled"; - }; - - pfc: pinctrl@e6050000 { - compatible = "renesas,pfc-r8a779g0"; - reg = <0 0xe6050000 0 0x16c>, <0 0xe6050800 0 0x16c>, - <0 0xe6058000 0 0x16c>, <0 0xe6058800 0 0x16c>, - <0 0xe6060000 0 0x16c>, <0 0xe6060800 0 0x16c>, - <0 0xe6061000 0 0x16c>, <0 0xe6061800 0 0x16c>, - <0 0xe6068000 0 0x16c>; - }; - - gpio0: gpio@e6050180 { - compatible = "renesas,gpio-r8a779g0", - "renesas,rcar-gen4-gpio"; - reg = <0 0xe6050180 0 0x54>; - interrupts = <GIC_SPI 619 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 915>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 915>; - gpio-controller; - #gpio-cells = <2>; - gpio-ranges = <&pfc 0 0 19>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio1: gpio@e6050980 { - compatible = "renesas,gpio-r8a779g0", - "renesas,rcar-gen4-gpio"; - reg = <0 0xe6050980 0 0x54>; - interrupts = <GIC_SPI 623 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 915>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 915>; - gpio-controller; - #gpio-cells = <2>; - gpio-ranges = <&pfc 0 32 29>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio2: gpio@e6058180 { - compatible = "renesas,gpio-r8a779g0", - "renesas,rcar-gen4-gpio"; - reg = <0 0xe6058180 0 0x54>; - interrupts = <GIC_SPI 627 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 916>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 916>; - gpio-controller; - #gpio-cells = <2>; - gpio-ranges = <&pfc 0 64 20>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio3: gpio@e6058980 { - compatible = "renesas,gpio-r8a779g0", - "renesas,rcar-gen4-gpio"; - reg = <0 0xe6058980 0 0x54>; - interrupts = <GIC_SPI 631 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 916>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 916>; - gpio-controller; - #gpio-cells = <2>; - gpio-ranges = <&pfc 0 96 30>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio4: gpio@e6060180 { - compatible = "renesas,gpio-r8a779g0", - "renesas,rcar-gen4-gpio"; - reg = <0 0xe6060180 0 0x54>; - interrupts = <GIC_SPI 635 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 917>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 917>; - gpio-controller; - #gpio-cells = <2>; - gpio-ranges = <&pfc 0 128 25>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio5: gpio@e6060980 { - compatible = "renesas,gpio-r8a779g0", - "renesas,rcar-gen4-gpio"; - reg = <0 0xe6060980 0 0x54>; - interrupts = <GIC_SPI 639 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 917>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 917>; - gpio-controller; - #gpio-cells = <2>; - gpio-ranges = <&pfc 0 160 21>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio6: gpio@e6061180 { - compatible = "renesas,gpio-r8a779g0", - "renesas,rcar-gen4-gpio"; - reg = <0 0xe6061180 0 0x54>; - interrupts = <GIC_SPI 643 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 917>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 917>; - gpio-controller; - #gpio-cells = <2>; - gpio-ranges = <&pfc 0 192 21>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio7: gpio@e6061980 { - compatible = "renesas,gpio-r8a779g0", - "renesas,rcar-gen4-gpio"; - reg = <0 0xe6061980 0 0x54>; - interrupts = <GIC_SPI 647 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 917>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 917>; - gpio-controller; - #gpio-cells = <2>; - gpio-ranges = <&pfc 0 224 21>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio8: gpio@e6068180 { - compatible = "renesas,gpio-r8a779g0", - "renesas,rcar-gen4-gpio"; - reg = <0 0xe6068180 0 0x54>; - interrupts = <GIC_SPI 651 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 918>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 918>; - gpio-controller; - #gpio-cells = <2>; - gpio-ranges = <&pfc 0 256 14>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - cmt0: timer@e60f0000 { - compatible = "renesas,r8a779g0-cmt0", - "renesas,rcar-gen4-cmt0"; - reg = <0 0xe60f0000 0 0x1004>; - interrupts = <GIC_SPI 260 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 261 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 910>; - clock-names = "fck"; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 910>; - status = "disabled"; - }; - - cmt1: timer@e6130000 { - compatible = "renesas,r8a779g0-cmt1", - "renesas,rcar-gen4-cmt1"; - reg = <0 0xe6130000 0 0x1004>; - interrupts = <GIC_SPI 262 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 263 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 264 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 265 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 266 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 267 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 268 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 269 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 911>; - clock-names = "fck"; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 911>; - status = "disabled"; - }; - - cmt2: timer@e6140000 { - compatible = "renesas,r8a779g0-cmt1", - "renesas,rcar-gen4-cmt1"; - reg = <0 0xe6140000 0 0x1004>; - interrupts = <GIC_SPI 270 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 271 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 272 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 273 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 274 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 275 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 276 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 277 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 912>; - clock-names = "fck"; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 912>; - status = "disabled"; - }; - - cmt3: timer@e6148000 { - compatible = "renesas,r8a779g0-cmt1", - "renesas,rcar-gen4-cmt1"; - reg = <0 0xe6148000 0 0x1004>; - interrupts = <GIC_SPI 278 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 279 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 280 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 281 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 282 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 283 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 284 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 285 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 913>; - clock-names = "fck"; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 913>; - status = "disabled"; - }; - - cpg: clock-controller@e6150000 { - compatible = "renesas,r8a779g0-cpg-mssr"; - reg = <0 0xe6150000 0 0x4000>; - clocks = <&extal_clk>, <&extalr_clk>; - clock-names = "extal", "extalr"; - #clock-cells = <2>; - #power-domain-cells = <0>; - #reset-cells = <1>; - }; - - rst: reset-controller@e6160000 { - compatible = "renesas,r8a779g0-rst"; - reg = <0 0xe6160000 0 0x4000>; - }; - - sysc: system-controller@e6180000 { - compatible = "renesas,r8a779g0-sysc"; - reg = <0 0xe6180000 0 0x4000>; - #power-domain-cells = <1>; - }; - - tsc: thermal@e6198000 { - compatible = "renesas,r8a779g0-thermal"; - reg = <0 0xe6198000 0 0x200>, - <0 0xe61a0000 0 0x200>, - <0 0xe61a8000 0 0x200>, - <0 0xe61b0000 0 0x200>; - clocks = <&cpg CPG_MOD 919>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 919>; - #thermal-sensor-cells = <1>; - }; - - intc_ex: interrupt-controller@e61c0000 { - compatible = "renesas,intc-ex-r8a779g0", "renesas,irqc"; - #interrupt-cells = <2>; - interrupt-controller; - reg = <0 0xe61c0000 0 0x200>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 611>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 611>; - }; - - tmu0: timer@e61e0000 { - compatible = "renesas,tmu-r8a779g0", "renesas,tmu"; - reg = <0 0xe61e0000 0 0x30>; - interrupts = <GIC_SPI 289 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 290 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 291 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 713>; - clock-names = "fck"; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 713>; - status = "disabled"; - }; - - tmu1: timer@e6fc0000 { - compatible = "renesas,tmu-r8a779g0", "renesas,tmu"; - reg = <0 0xe6fc0000 0 0x30>; - interrupts = <GIC_SPI 292 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 293 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 294 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 714>; - clock-names = "fck"; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 714>; - status = "disabled"; - }; - - tmu2: timer@e6fd0000 { - compatible = "renesas,tmu-r8a779g0", "renesas,tmu"; - reg = <0 0xe6fd0000 0 0x30>; - interrupts = <GIC_SPI 296 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 297 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 298 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 715>; - clock-names = "fck"; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 715>; - status = "disabled"; - }; - - tmu3: timer@e6fe0000 { - compatible = "renesas,tmu-r8a779g0", "renesas,tmu"; - reg = <0 0xe6fe0000 0 0x30>; - interrupts = <GIC_SPI 300 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 301 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 302 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 716>; - clock-names = "fck"; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 716>; - status = "disabled"; - }; - - tmu4: timer@ffc00000 { - compatible = "renesas,tmu-r8a779g0", "renesas,tmu"; - reg = <0 0xffc00000 0 0x30>; - interrupts = <GIC_SPI 304 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 305 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 306 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 717>; - clock-names = "fck"; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 717>; - status = "disabled"; - }; - - i2c0: i2c@e6500000 { - compatible = "renesas,i2c-r8a779g0", - "renesas,rcar-gen4-i2c"; - reg = <0 0xe6500000 0 0x40>; - interrupts = <GIC_SPI 610 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 518>; - dmas = <&dmac0 0x91>, <&dmac0 0x90>, - <&dmac1 0x91>, <&dmac1 0x90>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 518>; - i2c-scl-internal-delay-ns = <110>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c1: i2c@e6508000 { - compatible = "renesas,i2c-r8a779g0", - "renesas,rcar-gen4-i2c"; - reg = <0 0xe6508000 0 0x40>; - interrupts = <GIC_SPI 611 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 519>; - dmas = <&dmac0 0x93>, <&dmac0 0x92>, - <&dmac1 0x93>, <&dmac1 0x92>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 519>; - i2c-scl-internal-delay-ns = <110>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c2: i2c@e6510000 { - compatible = "renesas,i2c-r8a779g0", - "renesas,rcar-gen4-i2c"; - reg = <0 0xe6510000 0 0x40>; - interrupts = <GIC_SPI 612 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 520>; - dmas = <&dmac0 0x95>, <&dmac0 0x94>, - <&dmac1 0x95>, <&dmac1 0x94>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 520>; - i2c-scl-internal-delay-ns = <110>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c3: i2c@e66d0000 { - compatible = "renesas,i2c-r8a779g0", - "renesas,rcar-gen4-i2c"; - reg = <0 0xe66d0000 0 0x40>; - interrupts = <GIC_SPI 613 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 521>; - dmas = <&dmac0 0x97>, <&dmac0 0x96>, - <&dmac1 0x97>, <&dmac1 0x96>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 521>; - i2c-scl-internal-delay-ns = <110>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c4: i2c@e66d8000 { - compatible = "renesas,i2c-r8a779g0", - "renesas,rcar-gen4-i2c"; - reg = <0 0xe66d8000 0 0x40>; - interrupts = <GIC_SPI 614 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 522>; - dma-names = "tx", "rx", "tx", "rx"; - dmas = <&dmac0 0x99>, <&dmac0 0x98>, - <&dmac1 0x99>, <&dmac1 0x98>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 522>; - i2c-scl-internal-delay-ns = <110>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c5: i2c@e66e0000 { - compatible = "renesas,i2c-r8a779g0", - "renesas,rcar-gen4-i2c"; - reg = <0 0xe66e0000 0 0x40>; - interrupts = <GIC_SPI 615 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 523>; - dmas = <&dmac0 0x9b>, <&dmac0 0x9a>, - <&dmac1 0x9b>, <&dmac1 0x9a>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 523>; - i2c-scl-internal-delay-ns = <110>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - hscif0: serial@e6540000 { - compatible = "renesas,hscif-r8a779g0", - "renesas,rcar-gen4-hscif", "renesas,hscif"; - reg = <0 0xe6540000 0 0x60>; - interrupts = <GIC_SPI 246 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 514>, - <&cpg CPG_CORE R8A779G0_CLK_SASYNCPERD1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x31>, <&dmac0 0x30>, - <&dmac1 0x31>, <&dmac1 0x30>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 514>; - status = "disabled"; - }; - - hscif1: serial@e6550000 { - compatible = "renesas,hscif-r8a779g0", - "renesas,rcar-gen4-hscif", "renesas,hscif"; - reg = <0 0xe6550000 0 0x60>; - interrupts = <GIC_SPI 247 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 515>, - <&cpg CPG_CORE R8A779G0_CLK_SASYNCPERD1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x33>, <&dmac0 0x32>, - <&dmac1 0x33>, <&dmac1 0x32>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 515>; - status = "disabled"; - }; - - hscif2: serial@e6560000 { - compatible = "renesas,hscif-r8a779g0", - "renesas,rcar-gen4-hscif", "renesas,hscif"; - reg = <0 0xe6560000 0 0x60>; - interrupts = <GIC_SPI 248 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 516>, - <&cpg CPG_CORE R8A779G0_CLK_SASYNCPERD1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x35>, <&dmac0 0x34>, - <&dmac1 0x35>, <&dmac1 0x34>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 516>; - status = "disabled"; - }; - - hscif3: serial@e66a0000 { - compatible = "renesas,hscif-r8a779g0", - "renesas,rcar-gen4-hscif", "renesas,hscif"; - reg = <0 0xe66a0000 0 0x60>; - interrupts = <GIC_SPI 249 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 517>, - <&cpg CPG_CORE R8A779G0_CLK_SASYNCPERD1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x37>, <&dmac0 0x36>, - <&dmac1 0x37>, <&dmac1 0x36>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 517>; - status = "disabled"; - }; - - canfd: can@e6660000 { - compatible = "renesas,r8a779g0-canfd", - "renesas,rcar-gen4-canfd"; - reg = <0 0xe6660000 0 0x8500>; - interrupts = <GIC_SPI 412 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 413 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch_int", "g_int"; - clocks = <&cpg CPG_MOD 328>, - <&cpg CPG_CORE R8A779G0_CLK_CANFD>, - <&can_clk>; - clock-names = "fck", "canfd", "can_clk"; - assigned-clocks = <&cpg CPG_CORE R8A779G0_CLK_CANFD>; - assigned-clock-rates = <80000000>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 328>; - status = "disabled"; - - channel0 { - status = "disabled"; - }; - - channel1 { - status = "disabled"; - }; - - channel2 { - status = "disabled"; - }; - - channel3 { - status = "disabled"; - }; - - channel4 { - status = "disabled"; - }; - - channel5 { - status = "disabled"; - }; - - channel6 { - status = "disabled"; - }; - - channel7 { - status = "disabled"; - }; - }; - - avb0: ethernet@e6800000 { - compatible = "renesas,etheravb-r8a779g0", - "renesas,etheravb-rcar-gen4"; - reg = <0 0xe6800000 0 0x800>; - interrupts = <GIC_SPI 335 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 336 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 337 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 338 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 339 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 340 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 341 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 342 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 343 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 344 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 345 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 346 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 347 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 348 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 349 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 350 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 351 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 352 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 353 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 354 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 355 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 356 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 357 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 358 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 359 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1", "ch2", "ch3", "ch4", - "ch5", "ch6", "ch7", "ch8", "ch9", - "ch10", "ch11", "ch12", "ch13", - "ch14", "ch15", "ch16", "ch17", - "ch18", "ch19", "ch20", "ch21", - "ch22", "ch23", "ch24"; - clocks = <&cpg CPG_MOD 211>; - clock-names = "fck"; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 211>; - phy-mode = "rgmii"; - rx-internal-delay-ps = <0>; - tx-internal-delay-ps = <0>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - avb1: ethernet@e6810000 { - compatible = "renesas,etheravb-r8a779g0", - "renesas,etheravb-rcar-gen4"; - reg = <0 0xe6810000 0 0x800>; - interrupts = <GIC_SPI 360 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 361 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 362 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 363 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 364 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 365 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 366 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 367 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 368 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 369 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 370 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 371 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 372 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 373 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 374 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 375 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 376 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 377 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 378 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 379 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 380 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 381 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 382 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 383 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 384 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1", "ch2", "ch3", "ch4", - "ch5", "ch6", "ch7", "ch8", "ch9", - "ch10", "ch11", "ch12", "ch13", - "ch14", "ch15", "ch16", "ch17", - "ch18", "ch19", "ch20", "ch21", - "ch22", "ch23", "ch24"; - clocks = <&cpg CPG_MOD 212>; - clock-names = "fck"; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 212>; - phy-mode = "rgmii"; - rx-internal-delay-ps = <0>; - tx-internal-delay-ps = <0>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - avb2: ethernet@e6820000 { - compatible = "renesas,etheravb-r8a779g0", - "renesas,etheravb-rcar-gen4"; - reg = <0 0xe6820000 0 0x1000>; - interrupts = <GIC_SPI 385 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 386 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 387 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 388 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 389 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 390 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 391 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 392 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 393 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 394 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 395 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 396 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 397 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 398 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 399 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 400 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 401 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 402 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 403 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 404 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 405 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 406 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 407 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 408 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 409 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "ch0", "ch1", "ch2", "ch3", "ch4", - "ch5", "ch6", "ch7", "ch8", "ch9", - "ch10", "ch11", "ch12", "ch13", - "ch14", "ch15", "ch16", "ch17", - "ch18", "ch19", "ch20", "ch21", - "ch22", "ch23", "ch24"; - clocks = <&cpg CPG_MOD 213>; - clock-names = "fck"; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 213>; - phy-mode = "rgmii"; - rx-internal-delay-ps = <0>; - tx-internal-delay-ps = <0>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - pwm0: pwm@e6e30000 { - compatible = "renesas,pwm-r8a779g0", "renesas,pwm-rcar"; - reg = <0 0xe6e30000 0 0x10>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 628>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 628>; - status = "disabled"; - }; - - pwm1: pwm@e6e31000 { - compatible = "renesas,pwm-r8a779g0", "renesas,pwm-rcar"; - reg = <0 0xe6e31000 0 0x10>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 628>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 628>; - status = "disabled"; - }; - - pwm2: pwm@e6e32000 { - compatible = "renesas,pwm-r8a779g0", "renesas,pwm-rcar"; - reg = <0 0xe6e32000 0 0x10>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 628>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 628>; - status = "disabled"; - }; - - pwm3: pwm@e6e33000 { - compatible = "renesas,pwm-r8a779g0", "renesas,pwm-rcar"; - reg = <0 0xe6e33000 0 0x10>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 628>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 628>; - status = "disabled"; - }; - - pwm4: pwm@e6e34000 { - compatible = "renesas,pwm-r8a779g0", "renesas,pwm-rcar"; - reg = <0 0xe6e34000 0 0x10>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 628>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 628>; - status = "disabled"; - }; - - pwm5: pwm@e6e35000 { - compatible = "renesas,pwm-r8a779g0", "renesas,pwm-rcar"; - reg = <0 0xe6e35000 0 0x10>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 628>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 628>; - status = "disabled"; - }; - - pwm6: pwm@e6e36000 { - compatible = "renesas,pwm-r8a779g0", "renesas,pwm-rcar"; - reg = <0 0xe6e36000 0 0x10>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 628>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 628>; - status = "disabled"; - }; - - pwm7: pwm@e6e37000 { - compatible = "renesas,pwm-r8a779g0", "renesas,pwm-rcar"; - reg = <0 0xe6e37000 0 0x10>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 628>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 628>; - status = "disabled"; - }; - - pwm8: pwm@e6e38000 { - compatible = "renesas,pwm-r8a779g0", "renesas,pwm-rcar"; - reg = <0 0xe6e38000 0 0x10>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 628>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 628>; - status = "disabled"; - }; - - pwm9: pwm@e6e39000 { - compatible = "renesas,pwm-r8a779g0", "renesas,pwm-rcar"; - reg = <0 0xe6e39000 0 0x10>; - #pwm-cells = <2>; - clocks = <&cpg CPG_MOD 628>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 628>; - status = "disabled"; - }; - - scif0: serial@e6e60000 { - compatible = "renesas,scif-r8a779g0", - "renesas,rcar-gen4-scif", "renesas,scif"; - reg = <0 0xe6e60000 0 64>; - interrupts = <GIC_SPI 251 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 702>, - <&cpg CPG_CORE R8A779G0_CLK_SASYNCPERD1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x51>, <&dmac0 0x50>, - <&dmac1 0x51>, <&dmac1 0x50>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 702>; - status = "disabled"; - }; - - scif1: serial@e6e68000 { - compatible = "renesas,scif-r8a779g0", - "renesas,rcar-gen4-scif", "renesas,scif"; - reg = <0 0xe6e68000 0 64>; - interrupts = <GIC_SPI 252 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 703>, - <&cpg CPG_CORE R8A779G0_CLK_SASYNCPERD1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x53>, <&dmac0 0x52>, - <&dmac1 0x53>, <&dmac1 0x52>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 703>; - status = "disabled"; - }; - - scif3: serial@e6c50000 { - compatible = "renesas,scif-r8a779g0", - "renesas,rcar-gen4-scif", "renesas,scif"; - reg = <0 0xe6c50000 0 64>; - interrupts = <GIC_SPI 253 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 704>, - <&cpg CPG_CORE R8A779G0_CLK_SASYNCPERD1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x57>, <&dmac0 0x56>, - <&dmac1 0x57>, <&dmac1 0x56>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 704>; - status = "disabled"; - }; - - scif4: serial@e6c40000 { - compatible = "renesas,scif-r8a779g0", - "renesas,rcar-gen4-scif", "renesas,scif"; - reg = <0 0xe6c40000 0 64>; - interrupts = <GIC_SPI 254 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 705>, - <&cpg CPG_CORE R8A779G0_CLK_SASYNCPERD1>, - <&scif_clk>; - clock-names = "fck", "brg_int", "scif_clk"; - dmas = <&dmac0 0x59>, <&dmac0 0x58>, - <&dmac1 0x59>, <&dmac1 0x58>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 705>; - status = "disabled"; - }; - - tpu: pwm@e6e80000 { - compatible = "renesas,tpu-r8a779g0", "renesas,tpu"; - reg = <0 0xe6e80000 0 0x148>; - interrupts = <GIC_SPI 308 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 718>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 718>; - #pwm-cells = <3>; - status = "disabled"; - }; - - msiof0: spi@e6e90000 { - compatible = "renesas,msiof-r8a779g0", - "renesas,rcar-gen4-msiof"; - reg = <0 0xe6e90000 0 0x0064>; - interrupts = <GIC_SPI 239 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 618>; - dmas = <&dmac0 0x41>, <&dmac0 0x40>, - <&dmac1 0x41>, <&dmac1 0x40>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 618>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof1: spi@e6ea0000 { - compatible = "renesas,msiof-r8a779g0", - "renesas,rcar-gen4-msiof"; - reg = <0 0xe6ea0000 0 0x0064>; - interrupts = <GIC_SPI 240 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 619>; - dmas = <&dmac0 0x43>, <&dmac0 0x42>, - <&dmac1 0x43>, <&dmac1 0x42>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 619>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof2: spi@e6c00000 { - compatible = "renesas,msiof-r8a779g0", - "renesas,rcar-gen4-msiof"; - reg = <0 0xe6c00000 0 0x0064>; - interrupts = <GIC_SPI 241 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 620>; - dmas = <&dmac0 0x45>, <&dmac0 0x44>, - <&dmac1 0x45>, <&dmac1 0x44>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 620>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof3: spi@e6c10000 { - compatible = "renesas,msiof-r8a779g0", - "renesas,rcar-gen4-msiof"; - reg = <0 0xe6c10000 0 0x0064>; - interrupts = <GIC_SPI 242 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 621>; - dmas = <&dmac0 0x47>, <&dmac0 0x46>, - <&dmac1 0x47>, <&dmac1 0x46>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 621>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof4: spi@e6c20000 { - compatible = "renesas,msiof-r8a779g0", - "renesas,rcar-gen4-msiof"; - reg = <0 0xe6c20000 0 0x0064>; - interrupts = <GIC_SPI 243 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 622>; - dmas = <&dmac0 0x49>, <&dmac0 0x48>, - <&dmac1 0x49>, <&dmac1 0x48>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 622>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - msiof5: spi@e6c28000 { - compatible = "renesas,msiof-r8a779g0", - "renesas,rcar-gen4-msiof"; - reg = <0 0xe6c28000 0 0x0064>; - interrupts = <GIC_SPI 244 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 623>; - dmas = <&dmac0 0x4b>, <&dmac0 0x4a>, - <&dmac1 0x4b>, <&dmac1 0x4a>; - dma-names = "tx", "rx", "tx", "rx"; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 623>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - vin00: video@e6ef0000 { - compatible = "renesas,vin-r8a779g0"; - reg = <0 0xe6ef0000 0 0x1000>; - interrupts = <GIC_SPI 529 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 730>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 730>; - renesas,id = <0>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin00isp0: endpoint@0 { - reg = <0>; - remote-endpoint = <&isp0vin00>; - }; - }; - }; - }; - - vin01: video@e6ef1000 { - compatible = "renesas,vin-r8a779g0"; - reg = <0 0xe6ef1000 0 0x1000>; - interrupts = <GIC_SPI 530 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 731>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 731>; - renesas,id = <1>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin01isp0: endpoint@0 { - reg = <0>; - remote-endpoint = <&isp0vin01>; - }; - }; - }; - }; - - vin02: video@e6ef2000 { - compatible = "renesas,vin-r8a779g0"; - reg = <0 0xe6ef2000 0 0x1000>; - interrupts = <GIC_SPI 531 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 800>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 800>; - renesas,id = <2>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin02isp0: endpoint@0 { - reg = <0>; - remote-endpoint = <&isp0vin02>; - }; - }; - }; - }; - - vin03: video@e6ef3000 { - compatible = "renesas,vin-r8a779g0"; - reg = <0 0xe6ef3000 0 0x1000>; - interrupts = <GIC_SPI 532 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 801>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 801>; - renesas,id = <3>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin03isp0: endpoint@0 { - reg = <0>; - remote-endpoint = <&isp0vin03>; - }; - }; - }; - }; - - vin04: video@e6ef4000 { - compatible = "renesas,vin-r8a779g0"; - reg = <0 0xe6ef4000 0 0x1000>; - interrupts = <GIC_SPI 533 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 802>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 802>; - renesas,id = <4>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin04isp0: endpoint@0 { - reg = <0>; - remote-endpoint = <&isp0vin04>; - }; - }; - }; - }; - - vin05: video@e6ef5000 { - compatible = "renesas,vin-r8a779g0"; - reg = <0 0xe6ef5000 0 0x1000>; - interrupts = <GIC_SPI 534 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 803>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 803>; - renesas,id = <5>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin05isp0: endpoint@0 { - reg = <0>; - remote-endpoint = <&isp0vin05>; - }; - }; - }; - }; - - vin06: video@e6ef6000 { - compatible = "renesas,vin-r8a779g0"; - reg = <0 0xe6ef6000 0 0x1000>; - interrupts = <GIC_SPI 535 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 804>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 804>; - renesas,id = <6>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin06isp0: endpoint@0 { - reg = <0>; - remote-endpoint = <&isp0vin06>; - }; - }; - }; - }; - - vin07: video@e6ef7000 { - compatible = "renesas,vin-r8a779g0"; - reg = <0 0xe6ef7000 0 0x1000>; - interrupts = <GIC_SPI 536 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 805>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 805>; - renesas,id = <7>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin07isp0: endpoint@0 { - reg = <0>; - remote-endpoint = <&isp0vin07>; - }; - }; - }; - }; - - vin08: video@e6ef8000 { - compatible = "renesas,vin-r8a779g0"; - reg = <0 0xe6ef8000 0 0x1000>; - interrupts = <GIC_SPI 537 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 806>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 806>; - renesas,id = <8>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin08isp1: endpoint@1 { - reg = <1>; - remote-endpoint = <&isp1vin08>; - }; - }; - }; - }; - - vin09: video@e6ef9000 { - compatible = "renesas,vin-r8a779g0"; - reg = <0 0xe6ef9000 0 0x1000>; - interrupts = <GIC_SPI 538 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 807>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 807>; - renesas,id = <9>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin09isp1: endpoint@1 { - reg = <1>; - remote-endpoint = <&isp1vin09>; - }; - }; - }; - }; - - vin10: video@e6efa000 { - compatible = "renesas,vin-r8a779g0"; - reg = <0 0xe6efa000 0 0x1000>; - interrupts = <GIC_SPI 539 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 808>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 808>; - renesas,id = <10>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin10isp1: endpoint@1 { - reg = <1>; - remote-endpoint = <&isp1vin10>; - }; - }; - }; - }; - - vin11: video@e6efb000 { - compatible = "renesas,vin-r8a779g0"; - reg = <0 0xe6efb000 0 0x1000>; - interrupts = <GIC_SPI 540 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 809>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 809>; - renesas,id = <11>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin11isp1: endpoint@1 { - reg = <1>; - remote-endpoint = <&isp1vin11>; - }; - }; - }; - }; - - vin12: video@e6efc000 { - compatible = "renesas,vin-r8a779g0"; - reg = <0 0xe6efc000 0 0x1000>; - interrupts = <GIC_SPI 541 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 810>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 810>; - renesas,id = <12>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin12isp1: endpoint@1 { - reg = <1>; - remote-endpoint = <&isp1vin12>; - }; - }; - }; - }; - - vin13: video@e6efd000 { - compatible = "renesas,vin-r8a779g0"; - reg = <0 0xe6efd000 0 0x1000>; - interrupts = <GIC_SPI 542 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 811>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 811>; - renesas,id = <13>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin13isp1: endpoint@1 { - reg = <1>; - remote-endpoint = <&isp1vin13>; - }; - }; - }; - }; - - vin14: video@e6efe000 { - compatible = "renesas,vin-r8a779g0"; - reg = <0 0xe6efe000 0 0x1000>; - interrupts = <GIC_SPI 543 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 812>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 812>; - renesas,id = <14>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin14isp1: endpoint@1 { - reg = <1>; - remote-endpoint = <&isp1vin14>; - }; - }; - }; - }; - - vin15: video@e6eff000 { - compatible = "renesas,vin-r8a779g0"; - reg = <0 0xe6eff000 0 0x1000>; - interrupts = <GIC_SPI 544 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 813>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 813>; - renesas,id = <15>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@2 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <2>; - - vin15isp1: endpoint@1 { - reg = <1>; - remote-endpoint = <&isp1vin15>; - }; - }; - }; - }; - - dmac0: dma-controller@e7350000 { - compatible = "renesas,dmac-r8a779g0", - "renesas,rcar-gen4-dmac"; - reg = <0 0xe7350000 0 0x1000>, - <0 0xe7300000 0 0x10000>; - interrupts = <GIC_SPI 80 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 90 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 91 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 92 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 93 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 94 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 97 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", "ch4", - "ch5", "ch6", "ch7", "ch8", "ch9", - "ch10", "ch11", "ch12", "ch13", - "ch14", "ch15"; - clocks = <&cpg CPG_MOD 709>; - clock-names = "fck"; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 709>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_ds0 0>, <&ipmmu_ds0 1>, - <&ipmmu_ds0 2>, <&ipmmu_ds0 3>, - <&ipmmu_ds0 4>, <&ipmmu_ds0 5>, - <&ipmmu_ds0 6>, <&ipmmu_ds0 7>, - <&ipmmu_ds0 8>, <&ipmmu_ds0 9>, - <&ipmmu_ds0 10>, <&ipmmu_ds0 11>, - <&ipmmu_ds0 12>, <&ipmmu_ds0 13>, - <&ipmmu_ds0 14>, <&ipmmu_ds0 15>; - }; - - dmac1: dma-controller@e7351000 { - compatible = "renesas,dmac-r8a779g0", - "renesas,rcar-gen4-dmac"; - reg = <0 0xe7351000 0 0x1000>, - <0 0xe7310000 0 0x10000>; - interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 106 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 111 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 114 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 115 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", "ch4", - "ch5", "ch6", "ch7", "ch8", "ch9", - "ch10", "ch11", "ch12", "ch13", - "ch14", "ch15"; - clocks = <&cpg CPG_MOD 710>; - clock-names = "fck"; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 710>; - #dma-cells = <1>; - dma-channels = <16>; - iommus = <&ipmmu_ds0 16>, <&ipmmu_ds0 17>, - <&ipmmu_ds0 18>, <&ipmmu_ds0 19>, - <&ipmmu_ds0 20>, <&ipmmu_ds0 21>, - <&ipmmu_ds0 22>, <&ipmmu_ds0 23>, - <&ipmmu_ds0 24>, <&ipmmu_ds0 25>, - <&ipmmu_ds0 26>, <&ipmmu_ds0 27>, - <&ipmmu_ds0 28>, <&ipmmu_ds0 29>, - <&ipmmu_ds0 30>, <&ipmmu_ds0 31>; - }; - - rcar_sound: sound@ec5a0000 { - /* - * #sound-dai-cells is required - * - * Single DAI : #sound-dai-cells = <0>; <&rcar_sound>; - * Multi DAI : #sound-dai-cells = <1>; <&rcar_sound N>; - */ - /* - * #clock-cells is required - * - * clkout : #clock-cells = <0>; <&rcar_sound>; - * audio_clkout0/1/2/3 : #clock-cells = <1>; <&rcar_sound N>; - */ - compatible = "renesas,rcar_sound-r8a779g0", "renesas,rcar_sound-gen4"; - reg = <0 0xec5a0000 0 0x020>, - <0 0xec540000 0 0x1000>, - <0 0xec541000 0 0x050>, - <0 0xec400000 0 0x40000>; - reg-names = "adg", "ssiu", "ssi", "sdmc"; - - clocks = <&cpg CPG_MOD 2926>, <&cpg CPG_MOD 2927>, <&audio_clkin>; - clock-names = "ssiu.0", "ssi.0", "clkin"; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 2926>, <&cpg 2927>; - reset-names = "ssiu.0", "ssi.0"; - status = "disabled"; - - rcar_sound,ssiu { - ssiu00: ssiu-0 { - dmas = <&dmac0 0x6e>, <&dmac0 0x6f>; - dma-names = "tx", "rx"; - }; - ssiu01: ssiu-1 { - dmas = <&dmac0 0x6c>, <&dmac0 0x6d>; - dma-names = "tx", "rx"; - }; - ssiu02: ssiu-2 { - dmas = <&dmac0 0x6a>, <&dmac0 0x6b>; - dma-names = "tx", "rx"; - }; - ssiu03: ssiu-3 { - dmas = <&dmac0 0x68>, <&dmac0 0x69>; - dma-names = "tx", "rx"; - }; - ssiu04: ssiu-4 { - dmas = <&dmac0 0x66>, <&dmac0 0x67>; - dma-names = "tx", "rx"; - }; - ssiu05: ssiu-5 { - dmas = <&dmac0 0x64>, <&dmac0 0x65>; - dma-names = "tx", "rx"; - }; - ssiu06: ssiu-6 { - dmas = <&dmac0 0x62>, <&dmac0 0x63>; - dma-names = "tx", "rx"; - }; - ssiu07: ssiu-7 { - dmas = <&dmac0 0x60>, <&dmac0 0x61>; - dma-names = "tx", "rx"; - }; - }; - - rcar_sound,ssi { - ssi0: ssi-0 { - interrupts = <GIC_SPI 258 IRQ_TYPE_LEVEL_HIGH>; - }; - }; - }; - - ipmmu_rt0: iommu@ee480000 { - compatible = "renesas,ipmmu-r8a779g0", - "renesas,rcar-gen4-ipmmu-vmsa"; - reg = <0 0xee480000 0 0x20000>; - renesas,ipmmu-main = <&ipmmu_mm>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_rt1: iommu@ee4c0000 { - compatible = "renesas,ipmmu-r8a779g0", - "renesas,rcar-gen4-ipmmu-vmsa"; - reg = <0 0xee4c0000 0 0x20000>; - renesas,ipmmu-main = <&ipmmu_mm>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_ds0: iommu@eed00000 { - compatible = "renesas,ipmmu-r8a779g0", - "renesas,rcar-gen4-ipmmu-vmsa"; - reg = <0 0xeed00000 0 0x20000>; - renesas,ipmmu-main = <&ipmmu_mm>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_hc: iommu@eed40000 { - compatible = "renesas,ipmmu-r8a779g0", - "renesas,rcar-gen4-ipmmu-vmsa"; - reg = <0 0xeed40000 0 0x20000>; - renesas,ipmmu-main = <&ipmmu_mm>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_ir: iommu@eed80000 { - compatible = "renesas,ipmmu-r8a779g0", - "renesas,rcar-gen4-ipmmu-vmsa"; - reg = <0 0xeed80000 0 0x20000>; - renesas,ipmmu-main = <&ipmmu_mm>; - power-domains = <&sysc R8A779G0_PD_A3IR>; - #iommu-cells = <1>; - }; - - ipmmu_vc: iommu@eedc0000 { - compatible = "renesas,ipmmu-r8a779g0", - "renesas,rcar-gen4-ipmmu-vmsa"; - reg = <0 0xeedc0000 0 0x20000>; - renesas,ipmmu-main = <&ipmmu_mm>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_3dg: iommu@eee00000 { - compatible = "renesas,ipmmu-r8a779g0", - "renesas,rcar-gen4-ipmmu-vmsa"; - reg = <0 0xeee00000 0 0x20000>; - renesas,ipmmu-main = <&ipmmu_mm>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_vi0: iommu@eee80000 { - compatible = "renesas,ipmmu-r8a779g0", - "renesas,rcar-gen4-ipmmu-vmsa"; - reg = <0 0xeee80000 0 0x20000>; - renesas,ipmmu-main = <&ipmmu_mm>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_vi1: iommu@eeec0000 { - compatible = "renesas,ipmmu-r8a779g0", - "renesas,rcar-gen4-ipmmu-vmsa"; - reg = <0 0xeeec0000 0 0x20000>; - renesas,ipmmu-main = <&ipmmu_mm>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_vip0: iommu@eef00000 { - compatible = "renesas,ipmmu-r8a779g0", - "renesas,rcar-gen4-ipmmu-vmsa"; - reg = <0 0xeef00000 0 0x20000>; - renesas,ipmmu-main = <&ipmmu_mm>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_vip1: iommu@eef40000 { - compatible = "renesas,ipmmu-r8a779g0", - "renesas,rcar-gen4-ipmmu-vmsa"; - reg = <0 0xeef40000 0 0x20000>; - renesas,ipmmu-main = <&ipmmu_mm>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - ipmmu_mm: iommu@eefc0000 { - compatible = "renesas,ipmmu-r8a779g0", - "renesas,rcar-gen4-ipmmu-vmsa"; - reg = <0 0xeefc0000 0 0x20000>; - interrupts = <GIC_SPI 210 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 211 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - #iommu-cells = <1>; - }; - - mmc0: mmc@ee140000 { - compatible = "renesas,sdhi-r8a779g0", - "renesas,rcar-gen4-sdhi"; - reg = <0 0xee140000 0 0x2000>; - interrupts = <GIC_SPI 440 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 706>, - <&cpg CPG_CORE R8A779G0_CLK_SD0H>; - clock-names = "core", "clkh"; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 706>; - max-frequency = <200000000>; - iommus = <&ipmmu_ds0 32>; - status = "disabled"; - }; - - rpc: spi@ee200000 { - compatible = "renesas,r8a779g0-rpc-if", - "renesas,rcar-gen4-rpc-if"; - reg = <0 0xee200000 0 0x200>, - <0 0x08000000 0 0x04000000>, - <0 0xee208000 0 0x100>; - reg-names = "regs", "dirmap", "wbuf"; - interrupts = <GIC_SPI 225 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 629>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 629>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - gic: interrupt-controller@f1000000 { - compatible = "arm,gic-v3"; - #interrupt-cells = <3>; - #address-cells = <0>; - interrupt-controller; - reg = <0x0 0xf1000000 0 0x20000>, - <0x0 0xf1060000 0 0x110000>; - interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>; - }; - - csi40: csi2@fe500000 { - compatible = "renesas,r8a779g0-csi2"; - reg = <0 0xfe500000 0 0x40000>; - interrupts = <GIC_SPI 499 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 331>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 331>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - - port@1 { - reg = <1>; - csi40isp0: endpoint { - remote-endpoint = <&isp0csi40>; - }; - }; - }; - }; - - csi41: csi2@fe540000 { - compatible = "renesas,r8a779g0-csi2"; - reg = <0 0xfe540000 0 0x40000>; - interrupts = <GIC_SPI 500 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 400>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 400>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - - port@1 { - reg = <1>; - csi41isp1: endpoint { - remote-endpoint = <&isp1csi41>; - }; - }; - }; - }; - - fcpvd0: fcp@fea10000 { - compatible = "renesas,fcpv"; - reg = <0 0xfea10000 0 0x200>; - clocks = <&cpg CPG_MOD 508>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 508>; - }; - - fcpvd1: fcp@fea11000 { - compatible = "renesas,fcpv"; - reg = <0 0xfea11000 0 0x200>; - clocks = <&cpg CPG_MOD 509>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 509>; - }; - - vspd0: vsp@fea20000 { - compatible = "renesas,vsp2"; - reg = <0 0xfea20000 0 0x7000>; - interrupts = <GIC_SPI 546 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 830>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 830>; - - renesas,fcp = <&fcpvd0>; - }; - - vspd1: vsp@fea28000 { - compatible = "renesas,vsp2"; - reg = <0 0xfea28000 0 0x7000>; - interrupts = <GIC_SPI 551 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 831>; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 831>; - - renesas,fcp = <&fcpvd1>; - }; - - du: display@feb00000 { - compatible = "renesas,du-r8a779g0"; - reg = <0 0xfeb00000 0 0x40000>; - interrupts = <GIC_SPI 523 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 524 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD 411>; - clock-names = "du.0"; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 411>; - reset-names = "du.0"; - renesas,vsps = <&vspd0 0>, <&vspd1 0>; - - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - du_out_dsi0: endpoint { - remote-endpoint = <&dsi0_in>; - }; - }; - - port@1 { - reg = <1>; - du_out_dsi1: endpoint { - remote-endpoint = <&dsi1_in>; - }; - }; - }; - }; - - isp0: isp@fed00000 { - compatible = "renesas,r8a779g0-isp"; - reg = <0 0xfed00000 0 0x10000>; - interrupts = <GIC_SPI 473 IRQ_TYPE_LEVEL_LOW>; - clocks = <&cpg CPG_MOD 612>; - power-domains = <&sysc R8A779G0_PD_A3ISP0>; - resets = <&cpg 612>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <0>; - - isp0csi40: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi40isp0>; - }; - }; - - port@1 { - reg = <1>; - isp0vin00: endpoint { - remote-endpoint = <&vin00isp0>; - }; - }; - - port@2 { - reg = <2>; - isp0vin01: endpoint { - remote-endpoint = <&vin01isp0>; - }; - }; - - port@3 { - reg = <3>; - isp0vin02: endpoint { - remote-endpoint = <&vin02isp0>; - }; - }; - - port@4 { - reg = <4>; - isp0vin03: endpoint { - remote-endpoint = <&vin03isp0>; - }; - }; - - port@5 { - reg = <5>; - isp0vin04: endpoint { - remote-endpoint = <&vin04isp0>; - }; - }; - - port@6 { - reg = <6>; - isp0vin05: endpoint { - remote-endpoint = <&vin05isp0>; - }; - }; - - port@7 { - reg = <7>; - isp0vin06: endpoint { - remote-endpoint = <&vin06isp0>; - }; - }; - - port@8 { - reg = <8>; - isp0vin07: endpoint { - remote-endpoint = <&vin07isp0>; - }; - }; - }; - }; - - isp1: isp@fed20000 { - compatible = "renesas,r8a779g0-isp"; - reg = <0 0xfed20000 0 0x10000>; - interrupts = <GIC_SPI 474 IRQ_TYPE_LEVEL_LOW>; - clocks = <&cpg CPG_MOD 613>; - power-domains = <&sysc R8A779G0_PD_A3ISP1>; - resets = <&cpg 613>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <0>; - - isp1csi41: endpoint@1 { - reg = <1>; - remote-endpoint = <&csi41isp1>; - }; - }; - - port@1 { - reg = <1>; - isp1vin08: endpoint { - remote-endpoint = <&vin08isp1>; - }; - }; - - port@2 { - reg = <2>; - isp1vin09: endpoint { - remote-endpoint = <&vin09isp1>; - }; - }; - - port@3 { - reg = <3>; - isp1vin10: endpoint { - remote-endpoint = <&vin10isp1>; - }; - }; - - port@4 { - reg = <4>; - isp1vin11: endpoint { - remote-endpoint = <&vin11isp1>; - }; - }; - - port@5 { - reg = <5>; - isp1vin12: endpoint { - remote-endpoint = <&vin12isp1>; - }; - }; - - port@6 { - reg = <6>; - isp1vin13: endpoint { - remote-endpoint = <&vin13isp1>; - }; - }; - - port@7 { - reg = <7>; - isp1vin14: endpoint { - remote-endpoint = <&vin14isp1>; - }; - }; - - port@8 { - reg = <8>; - isp1vin15: endpoint { - remote-endpoint = <&vin15isp1>; - }; - }; - }; - }; - - dsi0: dsi-encoder@fed80000 { - compatible = "renesas,r8a779g0-dsi-csi2-tx"; - reg = <0 0xfed80000 0 0x10000>; - clocks = <&cpg CPG_MOD 415>, - <&cpg CPG_CORE R8A779G0_CLK_DSIEXT>, - <&cpg CPG_CORE R8A779G0_CLK_DSIREF>; - clock-names = "fck", "dsi", "pll"; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 415>; - - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - dsi0_in: endpoint { - remote-endpoint = <&du_out_dsi0>; - }; - }; - - port@1 { - reg = <1>; - }; - }; - }; - - dsi1: dsi-encoder@fed90000 { - compatible = "renesas,r8a779g0-dsi-csi2-tx"; - reg = <0 0xfed90000 0 0x10000>; - clocks = <&cpg CPG_MOD 416>, - <&cpg CPG_CORE R8A779G0_CLK_DSIEXT>, - <&cpg CPG_CORE R8A779G0_CLK_DSIREF>; - clock-names = "fck", "dsi", "pll"; - power-domains = <&sysc R8A779G0_PD_ALWAYS_ON>; - resets = <&cpg 416>; - - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - dsi1_in: endpoint { - remote-endpoint = <&du_out_dsi1>; - }; - }; - - port@1 { - reg = <1>; - }; - }; - }; - - prr: chipid@fff00044 { - compatible = "renesas,prr"; - reg = <0 0xfff00044 0 4>; - }; - }; - - thermal-zones { - sensor_thermal_cr52: sensor1-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - thermal-sensors = <&tsc 0>; - - trips { - sensor1_crit: sensor1-crit { - temperature = <120000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - }; - - sensor_thermal_cnn: sensor2-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - thermal-sensors = <&tsc 1>; - - trips { - sensor2_crit: sensor2-crit { - temperature = <120000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - }; - - sensor_thermal_ca76: sensor3-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - thermal-sensors = <&tsc 2>; - - trips { - sensor3_crit: sensor3-crit { - temperature = <120000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - }; - - sensor_thermal_ddr1: sensor4-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - thermal-sensors = <&tsc 3>; - - trips { - sensor4_crit: sensor4-crit { - temperature = <120000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - }; - }; - - timer { - compatible = "arm,armv8-timer"; - interrupts-extended = <&gic GIC_PPI 13 IRQ_TYPE_LEVEL_LOW>, - <&gic GIC_PPI 14 IRQ_TYPE_LEVEL_LOW>, - <&gic GIC_PPI 11 IRQ_TYPE_LEVEL_LOW>, - <&gic GIC_PPI 10 IRQ_TYPE_LEVEL_LOW>; - }; -};
On Sat, Apr 27, 2024 at 2:00 PM Marek Vasut marek.vasut+renesas@mailbox.org wrote:
Remove DTs which are now replaced by OF_UPSTREAM counterparts. No functional change expected.
Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org
Acked-by: Adam Ford aford173@gmail.com #beacon boards
Cc: "Cogent Embedded, Inc." source@cogentembedded.com Cc: Adam Ford aford173@gmail.com Cc: Hai Pham hai.pham.ud@renesas.com Cc: Masakazu Mochizuki masakazu.mochizuki.wd@hitachi.com Cc: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com Cc: Tam Nguyen tam.nguyen.xa@renesas.com Cc: Tom Rini trini@konsulko.com
arch/arm/dts/Makefile | 34 - arch/arm/dts/r8a774a1-beacon-rzg2m-kit.dts | 60 - arch/arm/dts/r8a774a1-hihope-rzg2m-ex.dts | 21 - arch/arm/dts/r8a774a1-hihope-rzg2m.dts | 37 - arch/arm/dts/r8a774a1.dtsi | 2865 -------------- arch/arm/dts/r8a774b1-beacon-rzg2n-kit.dts | 56 - arch/arm/dts/r8a774b1-hihope-rzg2n-ex.dts | 21 - arch/arm/dts/r8a774b1-hihope-rzg2n.dts | 41 - arch/arm/dts/r8a774b1.dtsi | 2716 ------------- arch/arm/dts/r8a774c0-cat874.dts | 455 --- arch/arm/dts/r8a774c0-ek874.dts | 14 - arch/arm/dts/r8a774c0.dtsi | 2000 ---------- arch/arm/dts/r8a774e1-beacon-rzg2h-kit.dts | 61 - arch/arm/dts/r8a774e1-hihope-rzg2h-ex.dts | 20 - arch/arm/dts/r8a774e1-hihope-rzg2h.dts | 41 - arch/arm/dts/r8a774e1.dtsi | 2997 -------------- arch/arm/dts/r8a7790-lager.dts | 947 ----- arch/arm/dts/r8a7790-stout.dts | 382 -- arch/arm/dts/r8a7790.dtsi | 1965 ---------- arch/arm/dts/r8a7791-koelsch.dts | 912 ----- arch/arm/dts/r8a7791-porter.dts | 523 --- arch/arm/dts/r8a7791.dtsi | 1891 --------- arch/arm/dts/r8a7792-blanche.dts | 364 -- arch/arm/dts/r8a7792.dtsi | 928 ----- arch/arm/dts/r8a7793-gose.dts | 818 ---- arch/arm/dts/r8a7793.dtsi | 1470 ------- arch/arm/dts/r8a7794-alt.dts | 533 --- arch/arm/dts/r8a7794-silk.dts | 578 --- arch/arm/dts/r8a7794.dtsi | 1437 ------- arch/arm/dts/r8a77950-salvator-x.dts | 49 - arch/arm/dts/r8a77950-ulcb.dts | 37 - arch/arm/dts/r8a77950.dtsi | 330 -- arch/arm/dts/r8a77951.dtsi | 3485 ----------------- arch/arm/dts/r8a77960-salvator-x.dts | 37 - arch/arm/dts/r8a77960-ulcb.dts | 38 - arch/arm/dts/r8a77960.dtsi | 3080 --------------- arch/arm/dts/r8a77965-salvator-x.dts | 32 - arch/arm/dts/r8a77965-ulcb.dts | 33 - arch/arm/dts/r8a77965.dtsi | 2889 -------------- arch/arm/dts/r8a77970-eagle.dts | 405 -- arch/arm/dts/r8a77970-v3msk.dts | 303 -- arch/arm/dts/r8a77970.dtsi | 1220 ------ arch/arm/dts/r8a77980-condor.dts | 24 - arch/arm/dts/r8a77980-v3hsk.dts | 293 -- arch/arm/dts/r8a77980.dtsi | 1625 -------- arch/arm/dts/r8a77990-ebisu.dts | 15 - arch/arm/dts/r8a77990.dtsi | 2154 ---------- arch/arm/dts/r8a77995-draak.dts | 16 - arch/arm/dts/r8a77995.dtsi | 1473 ------- arch/arm/dts/r8a779a0-falcon-cpu.dtsi | 359 -- arch/arm/dts/r8a779a0-falcon-csi-dsi.dtsi | 270 -- arch/arm/dts/r8a779a0-falcon-ethernet.dtsi | 15 - arch/arm/dts/r8a779a0-falcon.dts | 101 - arch/arm/dts/r8a779a0.dtsi | 2915 -------------- arch/arm/dts/r8a779f0-spider-cpu.dtsi | 210 - arch/arm/dts/r8a779f0-spider-ethernet.dtsi | 105 - arch/arm/dts/r8a779f0-spider.dts | 24 - arch/arm/dts/r8a779f0.dtsi | 1193 ------ arch/arm/dts/r8a779g0-white-hawk-cpu.dtsi | 375 -- arch/arm/dts/r8a779g0-white-hawk-csi-dsi.dtsi | 187 - .../arm/dts/r8a779g0-white-hawk-ethernet.dtsi | 16 - arch/arm/dts/r8a779g0-white-hawk.dts | 69 - arch/arm/dts/r8a779g0.dtsi | 2349 ----------- 63 files changed, 49913 deletions(-) delete mode 100644 arch/arm/dts/r8a774a1-beacon-rzg2m-kit.dts delete mode 100644 arch/arm/dts/r8a774a1-hihope-rzg2m-ex.dts delete mode 100644 arch/arm/dts/r8a774a1-hihope-rzg2m.dts delete mode 100644 arch/arm/dts/r8a774a1.dtsi delete mode 100644 arch/arm/dts/r8a774b1-beacon-rzg2n-kit.dts delete mode 100644 arch/arm/dts/r8a774b1-hihope-rzg2n-ex.dts delete mode 100644 arch/arm/dts/r8a774b1-hihope-rzg2n.dts delete mode 100644 arch/arm/dts/r8a774b1.dtsi delete mode 100644 arch/arm/dts/r8a774c0-cat874.dts delete mode 100644 arch/arm/dts/r8a774c0-ek874.dts delete mode 100644 arch/arm/dts/r8a774c0.dtsi delete mode 100644 arch/arm/dts/r8a774e1-beacon-rzg2h-kit.dts delete mode 100644 arch/arm/dts/r8a774e1-hihope-rzg2h-ex.dts delete mode 100644 arch/arm/dts/r8a774e1-hihope-rzg2h.dts delete mode 100644 arch/arm/dts/r8a774e1.dtsi delete mode 100644 arch/arm/dts/r8a7790-lager.dts delete mode 100644 arch/arm/dts/r8a7790-stout.dts delete mode 100644 arch/arm/dts/r8a7790.dtsi delete mode 100644 arch/arm/dts/r8a7791-koelsch.dts delete mode 100644 arch/arm/dts/r8a7791-porter.dts delete mode 100644 arch/arm/dts/r8a7791.dtsi delete mode 100644 arch/arm/dts/r8a7792-blanche.dts delete mode 100644 arch/arm/dts/r8a7792.dtsi delete mode 100644 arch/arm/dts/r8a7793-gose.dts delete mode 100644 arch/arm/dts/r8a7793.dtsi delete mode 100644 arch/arm/dts/r8a7794-alt.dts delete mode 100644 arch/arm/dts/r8a7794-silk.dts delete mode 100644 arch/arm/dts/r8a7794.dtsi delete mode 100644 arch/arm/dts/r8a77950-salvator-x.dts delete mode 100644 arch/arm/dts/r8a77950-ulcb.dts delete mode 100644 arch/arm/dts/r8a77950.dtsi delete mode 100644 arch/arm/dts/r8a77951.dtsi delete mode 100644 arch/arm/dts/r8a77960-salvator-x.dts delete mode 100644 arch/arm/dts/r8a77960-ulcb.dts delete mode 100644 arch/arm/dts/r8a77960.dtsi delete mode 100644 arch/arm/dts/r8a77965-salvator-x.dts delete mode 100644 arch/arm/dts/r8a77965-ulcb.dts delete mode 100644 arch/arm/dts/r8a77965.dtsi delete mode 100644 arch/arm/dts/r8a77970-eagle.dts delete mode 100644 arch/arm/dts/r8a77970-v3msk.dts delete mode 100644 arch/arm/dts/r8a77970.dtsi delete mode 100644 arch/arm/dts/r8a77980-condor.dts delete mode 100644 arch/arm/dts/r8a77980-v3hsk.dts delete mode 100644 arch/arm/dts/r8a77980.dtsi delete mode 100644 arch/arm/dts/r8a77990-ebisu.dts delete mode 100644 arch/arm/dts/r8a77990.dtsi delete mode 100644 arch/arm/dts/r8a77995-draak.dts delete mode 100644 arch/arm/dts/r8a77995.dtsi delete mode 100644 arch/arm/dts/r8a779a0-falcon-cpu.dtsi delete mode 100644 arch/arm/dts/r8a779a0-falcon-csi-dsi.dtsi delete mode 100644 arch/arm/dts/r8a779a0-falcon-ethernet.dtsi delete mode 100644 arch/arm/dts/r8a779a0-falcon.dts delete mode 100644 arch/arm/dts/r8a779a0.dtsi delete mode 100644 arch/arm/dts/r8a779f0-spider-cpu.dtsi delete mode 100644 arch/arm/dts/r8a779f0-spider-ethernet.dtsi delete mode 100644 arch/arm/dts/r8a779f0-spider.dts delete mode 100644 arch/arm/dts/r8a779f0.dtsi delete mode 100644 arch/arm/dts/r8a779g0-white-hawk-cpu.dtsi delete mode 100644 arch/arm/dts/r8a779g0-white-hawk-csi-dsi.dtsi delete mode 100644 arch/arm/dts/r8a779g0-white-hawk-ethernet.dtsi delete mode 100644 arch/arm/dts/r8a779g0-white-hawk.dts delete mode 100644 arch/arm/dts/r8a779g0.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 0c6f0221b77..f1d22ee7cf2 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1050,41 +1050,7 @@ dtb-$(CONFIG_ARCH_IMXRT) += imxrt1050-evk.dtb \ imxrt1020-evk.dtb \ imxrt1170-evk.dtb \
-dtb-$(CONFIG_RCAR_GEN2) += \
r8a7790-lager.dtb \
r8a7790-stout.dtb \
r8a7791-koelsch.dtb \
r8a7791-porter.dtb \
r8a7792-blanche.dtb \
r8a7793-gose.dtb \
r8a7794-alt.dtb \
r8a7794-silk.dtb
-dtb-$(CONFIG_RCAR_GEN3) += \
r8a774a1-beacon-rzg2m-kit.dtb \
r8a774b1-beacon-rzg2n-kit.dtb \
r8a774e1-beacon-rzg2h-kit.dtb \
r8a774a1-hihope-rzg2m.dtb \
r8a774b1-hihope-rzg2n.dtb \
r8a774c0-ek874.dtb \
r8a774e1-hihope-rzg2h.dtb \
r8a77951-ulcb.dtb \
r8a77951-salvator-x.dtb \
r8a77960-ulcb.dtb \
r8a77960-salvator-x.dtb \
r8a77965-ulcb.dtb \
r8a77965-salvator-x.dtb \
r8a77970-eagle.dtb \
r8a77970-v3msk.dtb \
r8a77980-condor.dtb \
r8a77980-v3hsk.dtb \
r8a77990-ebisu.dtb \
r8a77995-draak.dtb
dtb-$(CONFIG_RCAR_GEN4) += \
r8a779a0-falcon.dtb \
r8a779f0-spider.dtb \
r8a779g0-white-hawk.dtb \ r8a779h0-gray-hawk.dtb
dtb-$(CONFIG_TARGET_RZG2L) += \ diff --git a/arch/arm/dts/r8a774a1-beacon-rzg2m-kit.dts b/arch/arm/dts/r8a774a1-beacon-rzg2m-kit.dts deleted file mode 100644 index 24da6ee6ecc..00000000000 --- a/arch/arm/dts/r8a774a1-beacon-rzg2m-kit.dts +++ /dev/null @@ -1,60 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Copyright 2020, Compass Electronics Group, LLC
-/dts-v1/;
-#include "r8a774a1.dtsi" -#include "beacon-renesom-som.dtsi" -#include "beacon-renesom-baseboard.dtsi"
model = "Beacon EmbeddedWorks RZ/G2M Development Kit";
compatible = "beacon,beacon-rzg2m", "renesas,r8a774a1";
aliases {
i2c0 = &i2c0;
i2c1 = &i2c1;
i2c2 = &i2c2;
i2c3 = &i2c3;
i2c4 = &i2c4;
i2c5 = &i2c5;
i2c6 = &i2c6;
i2c7 = &iic_pmic;
serial0 = &scif2;
serial1 = &hscif0;
serial2 = &hscif1;
serial3 = &scif0;
serial4 = &hscif2;
serial5 = &scif5;
ethernet0 = &avb;
mmc0 = &sdhi3;
mmc1 = &sdhi0;
mmc2 = &sdhi2;
chosen {
stdout-path = "serial0:115200n8";
memory@600000000 {
device_type = "memory";
reg = <0x6 0x00000000 0x0 0x80000000>;
-&du {
pinctrl-0 = <&du_pins>;
pinctrl-names = "default";
status = "okay";
clocks = <&cpg CPG_MOD 724>,
<&cpg CPG_MOD 723>,
<&cpg CPG_MOD 722>,
<&versaclock5 1>,
<&x302_clk>,
<&versaclock5 2>;
clock-names = "du.0", "du.1", "du.2",
"dclkin.0", "dclkin.1", "dclkin.2";
-}; diff --git a/arch/arm/dts/r8a774a1-hihope-rzg2m-ex.dts b/arch/arm/dts/r8a774a1-hihope-rzg2m-ex.dts deleted file mode 100644 index a5ca86196a7..00000000000 --- a/arch/arm/dts/r8a774a1-hihope-rzg2m-ex.dts +++ /dev/null @@ -1,21 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Device Tree Source for the HiHope RZ/G2M Rev.3.0/4.0 connected to
- sub board
- Copyright (C) 2020 Renesas Electronics Corp.
-#include "r8a774a1-hihope-rzg2m.dts" -#include "hihope-rzg2-ex.dtsi"
model = "HopeRun HiHope RZ/G2M with sub board";
compatible = "hoperun,hihope-rzg2-ex", "hoperun,hihope-rzg2m",
"renesas,r8a774a1";
-/* SW43 should be OFF, if in ON state SATA port will be activated */ -&pciec1 {
status = "okay";
-}; diff --git a/arch/arm/dts/r8a774a1-hihope-rzg2m.dts b/arch/arm/dts/r8a774a1-hihope-rzg2m.dts deleted file mode 100644 index 25ae255de0f..00000000000 --- a/arch/arm/dts/r8a774a1-hihope-rzg2m.dts +++ /dev/null @@ -1,37 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Device Tree Source for the HiHope RZ/G2M Rev.3.0/4.0 main board
-/dts-v1/; -#include "r8a774a1.dtsi" -#include "hihope-rev4.dtsi"
model = "HopeRun HiHope RZ/G2M main board based on r8a774a1";
compatible = "hoperun,hihope-rzg2m", "renesas,r8a774a1";
memory@48000000 {
/* first 128MB is reserved for secure area. */
reg = <0x0 0x48000000 0x0 0x78000000>;
memory@600000000 {
-&du {
<&cpg CPG_MOD 723>,
<&cpg CPG_MOD 722>,
<&versaclock5 1>,
<&x302_clk>,
<&versaclock5 2>;
-}; diff --git a/arch/arm/dts/r8a774a1.dtsi b/arch/arm/dts/r8a774a1.dtsi deleted file mode 100644 index 9065dc24342..00000000000 --- a/arch/arm/dts/r8a774a1.dtsi +++ /dev/null @@ -1,2865 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Device Tree Source for the r8a774a1 SoC
- Copyright (C) 2018 Renesas Electronics Corp.
-#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/clock/r8a774a1-cpg-mssr.h> -#include <dt-bindings/power/r8a774a1-sysc.h>
-#define CPG_AUDIO_CLK_I R8A774A1_CLK_S0D4
compatible = "renesas,r8a774a1";
#address-cells = <2>;
#size-cells = <2>;
* The external audio clocks are configured as 0 Hz fixed frequency
* clocks by default.
* Boards that provide audio clocks should override them.
audio_clk_a: audio_clk_a {
compatible = "fixed-clock";
#clock-cells = <0>;
clock-frequency = <0>;
audio_clk_b: audio_clk_b {
#clock-cells = <0>;
audio_clk_c: audio_clk_c {
#clock-cells = <0>;
/* External CAN clock - to be overridden by boards that provide it */
can_clk: can {
#clock-cells = <0>;
cluster0_opp: opp-table-0 {
compatible = "operating-points-v2";
opp-shared;
opp-500000000 {
opp-hz = /bits/ 64 <500000000>;
opp-microvolt = <820000>;
clock-latency-ns = <300000>;
opp-1000000000 {
opp-hz = /bits/ 64 <1000000000>;
opp-1500000000 {
opp-hz = /bits/ 64 <1500000000>;
opp-suspend;
cluster1_opp: opp-table-1 {
opp-shared;
opp-800000000 {
opp-hz = /bits/ 64 <800000000>;
opp-1000000000 {
opp-1200000000 {
opp-hz = /bits/ 64 <1200000000>;
cpus {
#size-cells = <0>;
cpu-map {
cluster0 {
core0 {
cpu = <&a57_0>;
core1 {
cpu = <&a57_1>;
cluster1 {
core0 {
cpu = <&a53_0>;
core1 {
cpu = <&a53_1>;
core2 {
cpu = <&a53_2>;
core3 {
cpu = <&a53_3>;
a57_0: cpu@0 {
compatible = "arm,cortex-a57";
reg = <0x0>;
device_type = "cpu";
power-domains = <&sysc R8A774A1_PD_CA57_CPU0>;
next-level-cache = <&L2_CA57>;
enable-method = "psci";
dynamic-power-coefficient = <854>;
clocks = <&cpg CPG_CORE R8A774A1_CLK_Z>;
operating-points-v2 = <&cluster0_opp>;
capacity-dmips-mhz = <1024>;
#cooling-cells = <2>;
a57_1: cpu@1 {
reg = <0x1>;
power-domains = <&sysc R8A774A1_PD_CA57_CPU1>;
a53_0: cpu@100 {
compatible = "arm,cortex-a53";
reg = <0x100>;
power-domains = <&sysc R8A774A1_PD_CA53_CPU0>;
next-level-cache = <&L2_CA53>;
dynamic-power-coefficient = <277>;
clocks = <&cpg CPG_CORE R8A774A1_CLK_Z2>;
operating-points-v2 = <&cluster1_opp>;
capacity-dmips-mhz = <560>;
a53_1: cpu@101 {
reg = <0x101>;
power-domains = <&sysc R8A774A1_PD_CA53_CPU1>;
a53_2: cpu@102 {
reg = <0x102>;
power-domains = <&sysc R8A774A1_PD_CA53_CPU2>;
a53_3: cpu@103 {
reg = <0x103>;
power-domains = <&sysc R8A774A1_PD_CA53_CPU3>;
L2_CA57: cache-controller-0 {
compatible = "cache";
power-domains = <&sysc R8A774A1_PD_CA57_SCU>;
cache-unified;
cache-level = <2>;
L2_CA53: cache-controller-1 {
power-domains = <&sysc R8A774A1_PD_CA53_SCU>;
cache-unified;
cache-level = <2>;
extal_clk: extal {
#clock-cells = <0>;
/* This value must be overridden by the board */
extalr_clk: extalr {
#clock-cells = <0>;
/* External PCIe clock - can be overridden by the board */
pcie_bus_clk: pcie_bus {
#clock-cells = <0>;
pmu_a53 {
compatible = "arm,cortex-a53-pmu";
interrupts-extended = <&gic GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>,
<&gic GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>,
<&gic GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>,
<&gic GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>;
interrupt-affinity = <&a53_0>, <&a53_1>, <&a53_2>, <&a53_3>;
pmu_a57 {
compatible = "arm,cortex-a57-pmu";
interrupts-extended = <&gic GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>,
<&gic GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>;
interrupt-affinity = <&a57_0>, <&a57_1>;
psci {
compatible = "arm,psci-1.0", "arm,psci-0.2";
method = "smc";
/* External SCIF clock - to be overridden by boards that provide it */
scif_clk: scif {
#clock-cells = <0>;
soc {
compatible = "simple-bus";
interrupt-parent = <&gic>;
#size-cells = <2>;
ranges;
rwdt: watchdog@e6020000 {
compatible = "renesas,r8a774a1-wdt",
"renesas,rcar-gen3-wdt";
reg = <0 0xe6020000 0 0x0c>;
interrupts = <GIC_SPI 140 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 402>;
power-domains = <&sysc R8A774A1_PD_ALWAYS_ON>;
resets = <&cpg 402>;
gpio0: gpio@e6050000 {
compatible = "renesas,gpio-r8a774a1",
"renesas,rcar-gen3-gpio";
reg = <0 0xe6050000 0 0x50>;
interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 0 16>;
#interrupt-cells = <2>;
clocks = <&cpg CPG_MOD 912>;
resets = <&cpg 912>;
gpio1: gpio@e6051000 {
reg = <0 0xe6051000 0 0x50>;
interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 32 29>;
clocks = <&cpg CPG_MOD 911>;
resets = <&cpg 911>;
gpio2: gpio@e6052000 {
reg = <0 0xe6052000 0 0x50>;
interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 64 15>;
clocks = <&cpg CPG_MOD 910>;
resets = <&cpg 910>;
gpio3: gpio@e6053000 {
reg = <0 0xe6053000 0 0x50>;
interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 96 16>;
clocks = <&cpg CPG_MOD 909>;
resets = <&cpg 909>;
gpio4: gpio@e6054000 {
reg = <0 0xe6054000 0 0x50>;
interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 128 18>;
clocks = <&cpg CPG_MOD 908>;
resets = <&cpg 908>;
gpio5: gpio@e6055000 {
reg = <0 0xe6055000 0 0x50>;
interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 160 26>;
clocks = <&cpg CPG_MOD 907>;
resets = <&cpg 907>;
gpio6: gpio@e6055400 {
reg = <0 0xe6055400 0 0x50>;
interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 192 32>;
clocks = <&cpg CPG_MOD 906>;
resets = <&cpg 906>;
gpio7: gpio@e6055800 {
reg = <0 0xe6055800 0 0x50>;
interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 224 4>;
clocks = <&cpg CPG_MOD 905>;
resets = <&cpg 905>;
pfc: pinctrl@e6060000 {
compatible = "renesas,pfc-r8a774a1";
reg = <0 0xe6060000 0 0x50c>;
cmt0: timer@e60f0000 {
compatible = "renesas,r8a774a1-cmt0",
"renesas,rcar-gen3-cmt0";
reg = <0 0xe60f0000 0 0x1004>;
interrupts = <GIC_SPI 142 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 143 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 303>;
resets = <&cpg 303>;
cmt1: timer@e6130000 {
compatible = "renesas,r8a774a1-cmt1",
"renesas,rcar-gen3-cmt1";
reg = <0 0xe6130000 0 0x1004>;
interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 127 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 302>;
resets = <&cpg 302>;
cmt2: timer@e6140000 {
reg = <0 0xe6140000 0 0x1004>;
interrupts = <GIC_SPI 398 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 405 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 301>;
resets = <&cpg 301>;
cmt3: timer@e6148000 {
reg = <0 0xe6148000 0 0x1004>;
interrupts = <GIC_SPI 470 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 471 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 472 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 473 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 474 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 475 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 476 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 477 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 300>;
resets = <&cpg 300>;
cpg: clock-controller@e6150000 {
compatible = "renesas,r8a774a1-cpg-mssr";
reg = <0 0xe6150000 0 0x0bb0>;
clocks = <&extal_clk>, <&extalr_clk>;
clock-names = "extal", "extalr";
#clock-cells = <2>;
#power-domain-cells = <0>;
#reset-cells = <1>;
rst: reset-controller@e6160000 {
compatible = "renesas,r8a774a1-rst";
reg = <0 0xe6160000 0 0x018c>;
sysc: system-controller@e6180000 {
compatible = "renesas,r8a774a1-sysc";
reg = <0 0xe6180000 0 0x0400>;
#power-domain-cells = <1>;
tsc: thermal@e6198000 {
compatible = "renesas,r8a774a1-thermal";
reg = <0 0xe6198000 0 0x100>,
<0 0xe61a0000 0 0x100>,
<0 0xe61a8000 0 0x100>;
interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>;
#thermal-sensor-cells = <1>;
intc_ex: interrupt-controller@e61c0000 {
compatible = "renesas,intc-ex-r8a774a1", "renesas,irqc";
reg = <0 0xe61c0000 0 0x200>;
interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 161 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 407>;
resets = <&cpg 407>;
tmu0: timer@e61e0000 {
compatible = "renesas,tmu-r8a774a1", "renesas,tmu";
reg = <0 0xe61e0000 0 0x30>;
interrupts = <GIC_SPI 136 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 137 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 138 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 125>;
resets = <&cpg 125>;
tmu1: timer@e6fc0000 {
reg = <0 0xe6fc0000 0 0x30>;
interrupts = <GIC_SPI 128 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 129 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 130 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 124>;
resets = <&cpg 124>;
tmu2: timer@e6fd0000 {
reg = <0 0xe6fd0000 0 0x30>;
interrupts = <GIC_SPI 303 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 304 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 305 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 123>;
resets = <&cpg 123>;
tmu3: timer@e6fe0000 {
reg = <0 0xe6fe0000 0 0x30>;
interrupts = <GIC_SPI 131 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 132 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 133 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 122>;
resets = <&cpg 122>;
tmu4: timer@ffc00000 {
reg = <0 0xffc00000 0 0x30>;
interrupts = <GIC_SPI 406 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 408 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 121>;
resets = <&cpg 121>;
i2c0: i2c@e6500000 {
#size-cells = <0>;
compatible = "renesas,i2c-r8a774a1",
"renesas,rcar-gen3-i2c";
reg = <0 0xe6500000 0 0x40>;
interrupts = <GIC_SPI 287 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 931>;
resets = <&cpg 931>;
dmas = <&dmac1 0x91>, <&dmac1 0x90>,
<&dmac2 0x91>, <&dmac2 0x90>;
i2c-scl-internal-delay-ns = <110>;
i2c1: i2c@e6508000 {
#size-cells = <0>;
reg = <0 0xe6508000 0 0x40>;
interrupts = <GIC_SPI 288 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 930>;
resets = <&cpg 930>;
dmas = <&dmac1 0x93>, <&dmac1 0x92>,
<&dmac2 0x93>, <&dmac2 0x92>;
i2c-scl-internal-delay-ns = <6>;
i2c2: i2c@e6510000 {
#size-cells = <0>;
reg = <0 0xe6510000 0 0x40>;
interrupts = <GIC_SPI 286 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 929>;
resets = <&cpg 929>;
dmas = <&dmac1 0x95>, <&dmac1 0x94>,
<&dmac2 0x95>, <&dmac2 0x94>;
i2c3: i2c@e66d0000 {
#size-cells = <0>;
reg = <0 0xe66d0000 0 0x40>;
interrupts = <GIC_SPI 290 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 928>;
resets = <&cpg 928>;
dmas = <&dmac0 0x97>, <&dmac0 0x96>;
i2c4: i2c@e66d8000 {
#size-cells = <0>;
reg = <0 0xe66d8000 0 0x40>;
interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 927>;
resets = <&cpg 927>;
dmas = <&dmac0 0x99>, <&dmac0 0x98>;
i2c5: i2c@e66e0000 {
#size-cells = <0>;
reg = <0 0xe66e0000 0 0x40>;
interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 919>;
resets = <&cpg 919>;
dmas = <&dmac0 0x9b>, <&dmac0 0x9a>;
i2c6: i2c@e66e8000 {
#size-cells = <0>;
reg = <0 0xe66e8000 0 0x40>;
interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 918>;
resets = <&cpg 918>;
dmas = <&dmac0 0x9d>, <&dmac0 0x9c>;
iic_pmic: i2c@e60b0000 {
#size-cells = <0>;
compatible = "renesas,iic-r8a774a1",
"renesas,rcar-gen3-iic",
"renesas,rmobile-iic";
reg = <0 0xe60b0000 0 0x425>;
interrupts = <GIC_SPI 173 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 926>;
resets = <&cpg 926>;
dmas = <&dmac0 0x11>, <&dmac0 0x10>;
hscif0: serial@e6540000 {
compatible = "renesas,hscif-r8a774a1",
"renesas,rcar-gen3-hscif",
"renesas,hscif";
reg = <0 0xe6540000 0 0x60>;
interrupts = <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 520>,
<&cpg CPG_CORE R8A774A1_CLK_S3D1>,
<&scif_clk>;
dmas = <&dmac1 0x31>, <&dmac1 0x30>,
<&dmac2 0x31>, <&dmac2 0x30>;
resets = <&cpg 520>;
hscif1: serial@e6550000 {
"renesas,hscif";
reg = <0 0xe6550000 0 0x60>;
interrupts = <GIC_SPI 155 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 519>,
<&scif_clk>;
dmas = <&dmac1 0x33>, <&dmac1 0x32>,
<&dmac2 0x33>, <&dmac2 0x32>;
resets = <&cpg 519>;
hscif2: serial@e6560000 {
"renesas,hscif";
reg = <0 0xe6560000 0 0x60>;
interrupts = <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 518>,
<&scif_clk>;
dmas = <&dmac1 0x35>, <&dmac1 0x34>,
<&dmac2 0x35>, <&dmac2 0x34>;
resets = <&cpg 518>;
hscif3: serial@e66a0000 {
"renesas,hscif";
reg = <0 0xe66a0000 0 0x60>;
interrupts = <GIC_SPI 145 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 517>,
<&scif_clk>;
dmas = <&dmac0 0x37>, <&dmac0 0x36>;
resets = <&cpg 517>;
hscif4: serial@e66b0000 {
"renesas,hscif";
reg = <0 0xe66b0000 0 0x60>;
interrupts = <GIC_SPI 146 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 516>,
<&scif_clk>;
dmas = <&dmac0 0x39>, <&dmac0 0x38>;
resets = <&cpg 516>;
hsusb: usb@e6590000 {
compatible = "renesas,usbhs-r8a774a1",
"renesas,rcar-gen3-usbhs";
reg = <0 0xe6590000 0 0x200>;
interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 704>, <&cpg CPG_MOD 703>;
dmas = <&usb_dmac0 0>, <&usb_dmac0 1>,
<&usb_dmac1 0>, <&usb_dmac1 1>;
dma-names = "ch0", "ch1", "ch2", "ch3";
renesas,buswait = <11>;
phys = <&usb2_phy0 3>;
phy-names = "usb";
resets = <&cpg 704>, <&cpg 703>;
usb2_clksel: clock-controller@e6590630 {
compatible = "renesas,r8a774a1-rcar-usb2-clock-sel",
"renesas,rcar-gen3-usb2-clock-sel";
reg = <0 0xe6590630 0 0x02>;
clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>,
<&usb_extal_clk>, <&usb3s0_clk>;
clock-names = "ehci_ohci", "hs-usb-if",
"usb_extal", "usb_xtal";
#clock-cells = <0>;
resets = <&cpg 703>, <&cpg 704>;
reset-names = "ehci_ohci", "hs-usb-if";
usb_dmac0: dma-controller@e65a0000 {
compatible = "renesas,r8a774a1-usb-dmac",
"renesas,usb-dmac";
reg = <0 0xe65a0000 0 0x100>;
interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "ch0", "ch1";
clocks = <&cpg CPG_MOD 330>;
resets = <&cpg 330>;
#dma-cells = <1>;
dma-channels = <2>;
usb_dmac1: dma-controller@e65b0000 {
"renesas,usb-dmac";
reg = <0 0xe65b0000 0 0x100>;
interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>;
#dma-cells = <1>;
dma-channels = <2>;
usb3_phy0: usb-phy@e65ee000 {
compatible = "renesas,r8a774a1-usb3-phy",
"renesas,rcar-gen3-usb3-phy";
reg = <0 0xe65ee000 0 0x90>;
clocks = <&cpg CPG_MOD 328>, <&usb3s0_clk>,
<&usb_extal_clk>;
clock-names = "usb3-if", "usb3s_clk", "usb_extal";
resets = <&cpg 328>;
#phy-cells = <0>;
dmac0: dma-controller@e6700000 {
compatible = "renesas,dmac-r8a774a1",
"renesas,rcar-dmac";
reg = <0 0xe6700000 0 0x10000>;
interrupts = <GIC_SPI 199 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 200 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 201 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 202 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 203 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 204 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 205 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 206 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 207 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 208 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 209 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 211 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 212 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 213 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 214 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 215 IRQ_TYPE_LEVEL_HIGH>;
"ch4", "ch5", "ch6", "ch7",
"ch8", "ch9", "ch10", "ch11",
"ch12", "ch13", "ch14", "ch15";
clocks = <&cpg CPG_MOD 219>;
resets = <&cpg 219>;
#dma-cells = <1>;
dmac1: dma-controller@e7300000 {
reg = <0 0xe7300000 0 0x10000>;
interrupts = <GIC_SPI 220 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 216 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 217 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 218 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 219 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 308 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 309 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 310 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 311 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 312 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 313 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 314 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 315 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 316 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 317 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 318 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 319 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 218>;
resets = <&cpg 218>;
#dma-cells = <1>;
iommus = <&ipmmu_ds1 0>, <&ipmmu_ds1 1>,
<&ipmmu_ds1 2>, <&ipmmu_ds1 3>,
<&ipmmu_ds1 4>, <&ipmmu_ds1 5>,
<&ipmmu_ds1 6>, <&ipmmu_ds1 7>,
<&ipmmu_ds1 8>, <&ipmmu_ds1 9>,
<&ipmmu_ds1 10>, <&ipmmu_ds1 11>,
<&ipmmu_ds1 12>, <&ipmmu_ds1 13>,
<&ipmmu_ds1 14>, <&ipmmu_ds1 15>;
dmac2: dma-controller@e7310000 {
reg = <0 0xe7310000 0 0x10000>;
interrupts = <GIC_SPI 416 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 417 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 418 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 419 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 420 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 421 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 422 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 423 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 424 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 425 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 426 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 427 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 428 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 429 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 430 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 431 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 397 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 217>;
resets = <&cpg 217>;
#dma-cells = <1>;
iommus = <&ipmmu_ds1 16>, <&ipmmu_ds1 17>,
<&ipmmu_ds1 18>, <&ipmmu_ds1 19>,
<&ipmmu_ds1 20>, <&ipmmu_ds1 21>,
<&ipmmu_ds1 22>, <&ipmmu_ds1 23>,
<&ipmmu_ds1 24>, <&ipmmu_ds1 25>,
<&ipmmu_ds1 26>, <&ipmmu_ds1 27>,
<&ipmmu_ds1 28>, <&ipmmu_ds1 29>,
<&ipmmu_ds1 30>, <&ipmmu_ds1 31>;
ipmmu_ds0: iommu@e6740000 {
compatible = "renesas,ipmmu-r8a774a1";
reg = <0 0xe6740000 0 0x1000>;
renesas,ipmmu-main = <&ipmmu_mm 0>;
#iommu-cells = <1>;
ipmmu_ds1: iommu@e7740000 {
reg = <0 0xe7740000 0 0x1000>;
renesas,ipmmu-main = <&ipmmu_mm 1>;
#iommu-cells = <1>;
ipmmu_hc: iommu@e6570000 {
reg = <0 0xe6570000 0 0x1000>;
renesas,ipmmu-main = <&ipmmu_mm 2>;
#iommu-cells = <1>;
ipmmu_mm: iommu@e67b0000 {
reg = <0 0xe67b0000 0 0x1000>;
interrupts = <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>;
#iommu-cells = <1>;
ipmmu_mp: iommu@ec670000 {
reg = <0 0xec670000 0 0x1000>;
renesas,ipmmu-main = <&ipmmu_mm 4>;
#iommu-cells = <1>;
ipmmu_pv0: iommu@fd800000 {
reg = <0 0xfd800000 0 0x1000>;
renesas,ipmmu-main = <&ipmmu_mm 5>;
#iommu-cells = <1>;
ipmmu_pv1: iommu@fd950000 {
reg = <0 0xfd950000 0 0x1000>;
renesas,ipmmu-main = <&ipmmu_mm 6>;
#iommu-cells = <1>;
ipmmu_vc0: iommu@fe6b0000 {
reg = <0 0xfe6b0000 0 0x1000>;
renesas,ipmmu-main = <&ipmmu_mm 8>;
power-domains = <&sysc R8A774A1_PD_A3VC>;
#iommu-cells = <1>;
ipmmu_vi0: iommu@febd0000 {
reg = <0 0xfebd0000 0 0x1000>;
renesas,ipmmu-main = <&ipmmu_mm 9>;
#iommu-cells = <1>;
avb: ethernet@e6800000 {
compatible = "renesas,etheravb-r8a774a1",
"renesas,etheravb-rcar-gen3";
reg = <0 0xe6800000 0 0x800>;
interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 47 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 63 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "ch0", "ch1", "ch2", "ch3",
"ch12", "ch13", "ch14", "ch15",
"ch16", "ch17", "ch18", "ch19",
"ch20", "ch21", "ch22", "ch23",
"ch24";
phy-mode = "rgmii";
rx-internal-delay-ps = <0>;
tx-internal-delay-ps = <0>;
iommus = <&ipmmu_ds0 16>;
#size-cells = <0>;
can0: can@e6c30000 {
compatible = "renesas,can-r8a774a1",
"renesas,rcar-gen3-can";
reg = <0 0xe6c30000 0 0x1000>;
interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 916>,
<&cpg CPG_CORE R8A774A1_CLK_CANFD>,
<&can_clk>;
clock-names = "clkp1", "clkp2", "can_clk";
assigned-clocks = <&cpg CPG_CORE R8A774A1_CLK_CANFD>;
assigned-clock-rates = <40000000>;
resets = <&cpg 916>;
can1: can@e6c38000 {
reg = <0 0xe6c38000 0 0x1000>;
interrupts = <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 915>,
<&can_clk>;
resets = <&cpg 915>;
canfd: can@e66c0000 {
compatible = "renesas,r8a774a1-canfd",
"renesas,rcar-gen3-canfd";
reg = <0 0xe66c0000 0 0x8000>;
interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "ch_int", "g_int";
clocks = <&cpg CPG_MOD 914>,
<&can_clk>;
clock-names = "fck", "canfd", "can_clk";
resets = <&cpg 914>;
channel0 {
channel1 {
pwm0: pwm@e6e30000 {
compatible = "renesas,pwm-r8a774a1", "renesas,pwm-rcar";
reg = <0 0xe6e30000 0 0x8>;
#pwm-cells = <2>;
clocks = <&cpg CPG_MOD 523>;
resets = <&cpg 523>;
pwm1: pwm@e6e31000 {
reg = <0 0xe6e31000 0 0x8>;
#pwm-cells = <2>;
pwm2: pwm@e6e32000 {
reg = <0 0xe6e32000 0 0x8>;
#pwm-cells = <2>;
pwm3: pwm@e6e33000 {
reg = <0 0xe6e33000 0 0x8>;
#pwm-cells = <2>;
pwm4: pwm@e6e34000 {
reg = <0 0xe6e34000 0 0x8>;
#pwm-cells = <2>;
pwm5: pwm@e6e35000 {
reg = <0 0xe6e35000 0 0x8>;
#pwm-cells = <2>;
pwm6: pwm@e6e36000 {
reg = <0 0xe6e36000 0 0x8>;
#pwm-cells = <2>;
scif0: serial@e6e60000 {
compatible = "renesas,scif-r8a774a1",
"renesas,rcar-gen3-scif", "renesas,scif";
reg = <0 0xe6e60000 0 0x40>;
interrupts = <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 207>,
<&scif_clk>;
dmas = <&dmac1 0x51>, <&dmac1 0x50>,
<&dmac2 0x51>, <&dmac2 0x50>;
resets = <&cpg 207>;
scif1: serial@e6e68000 {
reg = <0 0xe6e68000 0 0x40>;
interrupts = <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 206>,
<&scif_clk>;
clock-names = "fck", "brg_int", "scif_clk";
dmas = <&dmac1 0x53>, <&dmac1 0x52>,
<&dmac2 0x53>, <&dmac2 0x52>;
resets = <&cpg 206>;
scif2: serial@e6e88000 {
reg = <0 0xe6e88000 0 0x40>;
interrupts = <GIC_SPI 164 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 310>,
<&scif_clk>;
dmas = <&dmac1 0x13>, <&dmac1 0x12>,
<&dmac2 0x13>, <&dmac2 0x12>;
resets = <&cpg 310>;
scif3: serial@e6c50000 {
reg = <0 0xe6c50000 0 0x40>;
interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 204>,
<&scif_clk>;
dmas = <&dmac0 0x57>, <&dmac0 0x56>;
resets = <&cpg 204>;
scif4: serial@e6c40000 {
reg = <0 0xe6c40000 0 0x40>;
interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 203>,
<&scif_clk>;
dmas = <&dmac0 0x59>, <&dmac0 0x58>;
resets = <&cpg 203>;
scif5: serial@e6f30000 {
reg = <0 0xe6f30000 0 0x40>;
interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 202>,
<&scif_clk>;
dmas = <&dmac1 0x5b>, <&dmac1 0x5a>,
<&dmac2 0x5b>, <&dmac2 0x5a>;
resets = <&cpg 202>;
msiof0: spi@e6e90000 {
compatible = "renesas,msiof-r8a774a1",
"renesas,rcar-gen3-msiof";
reg = <0 0xe6e90000 0 0x0064>;
interrupts = <GIC_SPI 156 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 211>;
dmas = <&dmac1 0x41>, <&dmac1 0x40>,
<&dmac2 0x41>, <&dmac2 0x40>;
resets = <&cpg 211>;
#size-cells = <0>;
msiof1: spi@e6ea0000 {
reg = <0 0xe6ea0000 0 0x0064>;
interrupts = <GIC_SPI 157 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 210>;
dmas = <&dmac1 0x43>, <&dmac1 0x42>,
<&dmac2 0x43>, <&dmac2 0x42>;
resets = <&cpg 210>;
#size-cells = <0>;
msiof2: spi@e6c00000 {
reg = <0 0xe6c00000 0 0x0064>;
interrupts = <GIC_SPI 158 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 209>;
dmas = <&dmac0 0x45>, <&dmac0 0x44>;
resets = <&cpg 209>;
#size-cells = <0>;
interrupts = <GIC_SPI 159 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 208>;
dmas = <&dmac0 0x47>, <&dmac0 0x46>;
resets = <&cpg 208>;
#size-cells = <0>;
vin0: video@e6ef0000 {
compatible = "renesas,vin-r8a774a1";
interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>;
renesas,id = <0>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
vin0csi20: endpoint@0 {
reg = <0>;
remote-endpoint = <&csi20vin0>;
vin0csi40: endpoint@2 {
reg = <2>;
remote-endpoint = <&csi40vin0>;
vin1: video@e6ef1000 {
interrupts = <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH>;
renesas,id = <1>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
vin1csi20: endpoint@0 {
reg = <0>;
remote-endpoint = <&csi20vin1>;
vin1csi40: endpoint@2 {
reg = <2>;
remote-endpoint = <&csi40vin1>;
vin2: video@e6ef2000 {
interrupts = <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>;
renesas,id = <2>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
vin2csi20: endpoint@0 {
reg = <0>;
remote-endpoint = <&csi20vin2>;
vin2csi40: endpoint@2 {
reg = <2>;
remote-endpoint = <&csi40vin2>;
vin3: video@e6ef3000 {
interrupts = <GIC_SPI 191 IRQ_TYPE_LEVEL_HIGH>;
renesas,id = <3>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
vin3csi20: endpoint@0 {
reg = <0>;
remote-endpoint = <&csi20vin3>;
vin3csi40: endpoint@2 {
reg = <2>;
remote-endpoint = <&csi40vin3>;
vin4: video@e6ef4000 {
interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>;
renesas,id = <4>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
vin4csi20: endpoint@0 {
reg = <0>;
remote-endpoint = <&csi20vin4>;
vin4csi40: endpoint@2 {
reg = <2>;
remote-endpoint = <&csi40vin4>;
vin5: video@e6ef5000 {
interrupts = <GIC_SPI 175 IRQ_TYPE_LEVEL_HIGH>;
renesas,id = <5>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
vin5csi20: endpoint@0 {
reg = <0>;
remote-endpoint = <&csi20vin5>;
vin5csi40: endpoint@2 {
reg = <2>;
remote-endpoint = <&csi40vin5>;
vin6: video@e6ef6000 {
interrupts = <GIC_SPI 176 IRQ_TYPE_LEVEL_HIGH>;
renesas,id = <6>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
vin6csi20: endpoint@0 {
reg = <0>;
remote-endpoint = <&csi20vin6>;
vin6csi40: endpoint@2 {
reg = <2>;
remote-endpoint = <&csi40vin6>;
vin7: video@e6ef7000 {
interrupts = <GIC_SPI 171 IRQ_TYPE_LEVEL_HIGH>;
renesas,id = <7>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
vin7csi20: endpoint@0 {
reg = <0>;
remote-endpoint = <&csi20vin7>;
vin7csi40: endpoint@2 {
reg = <2>;
remote-endpoint = <&csi40vin7>;
rcar_sound: sound@ec500000 {
* #sound-dai-cells is required if simple-card
* #clock-cells is required for audio_clkout0/1/2/3
* clkout0/1/2/3: #clock-cells = <1>; <&rcar_sound N>;
compatible = "renesas,rcar_sound-r8a774a1", "renesas,rcar_sound-gen3";
reg = <0 0xec500000 0 0x1000>, /* SCU */
<0 0xec5a0000 0 0x100>, /* ADG */
<0 0xec540000 0 0x1000>, /* SSIU */
<0 0xec541000 0 0x280>, /* SSI */
<0 0xec760000 0 0x200>; /* Audio DMAC peri peri*/
reg-names = "scu", "adg", "ssiu", "ssi", "audmapp";
clocks = <&cpg CPG_MOD 1005>,
<&cpg CPG_MOD 1006>, <&cpg CPG_MOD 1007>,
<&cpg CPG_MOD 1008>, <&cpg CPG_MOD 1009>,
<&cpg CPG_MOD 1010>, <&cpg CPG_MOD 1011>,
<&cpg CPG_MOD 1012>, <&cpg CPG_MOD 1013>,
<&cpg CPG_MOD 1014>, <&cpg CPG_MOD 1015>,
<&cpg CPG_MOD 1022>, <&cpg CPG_MOD 1023>,
<&cpg CPG_MOD 1024>, <&cpg CPG_MOD 1025>,
<&cpg CPG_MOD 1026>, <&cpg CPG_MOD 1027>,
<&cpg CPG_MOD 1028>, <&cpg CPG_MOD 1029>,
<&cpg CPG_MOD 1030>, <&cpg CPG_MOD 1031>,
<&cpg CPG_MOD 1020>, <&cpg CPG_MOD 1021>,
<&cpg CPG_MOD 1019>, <&cpg CPG_MOD 1018>,
<&audio_clk_a>, <&audio_clk_b>,
<&audio_clk_c>,
<&cpg CPG_CORE R8A774A1_CLK_S0D4>;
clock-names = "ssi-all",
"ssi.9", "ssi.8", "ssi.7", "ssi.6",
"ssi.5", "ssi.4", "ssi.3", "ssi.2",
"ssi.1", "ssi.0",
"src.9", "src.8", "src.7", "src.6",
"src.5", "src.4", "src.3", "src.2",
"src.1", "src.0",
"mix.1", "mix.0",
"ctu.1", "ctu.0",
"dvc.0", "dvc.1",
"clk_a", "clk_b", "clk_c", "clk_i";
resets = <&cpg 1005>,
<&cpg 1006>, <&cpg 1007>,
<&cpg 1008>, <&cpg 1009>,
<&cpg 1010>, <&cpg 1011>,
<&cpg 1012>, <&cpg 1013>,
<&cpg 1014>, <&cpg 1015>;
reset-names = "ssi-all",
"ssi.1", "ssi.0";
rcar_sound,ctu {
ctu00: ctu-0 { };
ctu01: ctu-1 { };
ctu02: ctu-2 { };
ctu03: ctu-3 { };
ctu10: ctu-4 { };
ctu11: ctu-5 { };
ctu12: ctu-6 { };
ctu13: ctu-7 { };
rcar_sound,dvc {
dvc0: dvc-0 {
dmas = <&audma1 0xbc>;
dma-names = "tx";
dvc1: dvc-1 {
dmas = <&audma1 0xbe>;
dma-names = "tx";
rcar_sound,mix {
mix0: mix-0 { };
mix1: mix-1 { };
rcar_sound,src {
src0: src-0 {
interrupts = <GIC_SPI 352 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x85>, <&audma1 0x9a>;
dma-names = "rx", "tx";
src1: src-1 {
interrupts = <GIC_SPI 353 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x87>, <&audma1 0x9c>;
src2: src-2 {
interrupts = <GIC_SPI 354 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x89>, <&audma1 0x9e>;
src3: src-3 {
interrupts = <GIC_SPI 355 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x8b>, <&audma1 0xa0>;
src4: src-4 {
interrupts = <GIC_SPI 356 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x8d>, <&audma1 0xb0>;
src5: src-5 {
interrupts = <GIC_SPI 357 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x8f>, <&audma1 0xb2>;
src6: src-6 {
interrupts = <GIC_SPI 358 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x91>, <&audma1 0xb4>;
src7: src-7 {
interrupts = <GIC_SPI 359 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x93>, <&audma1 0xb6>;
src8: src-8 {
interrupts = <GIC_SPI 360 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x95>, <&audma1 0xb8>;
src9: src-9 {
interrupts = <GIC_SPI 361 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x97>, <&audma1 0xba>;
rcar_sound,ssi {
ssi0: ssi-0 {
interrupts = <GIC_SPI 370 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x01>, <&audma1 0x02>;
ssi1: ssi-1 {
interrupts = <GIC_SPI 371 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x03>, <&audma1 0x04>;
ssi2: ssi-2 {
interrupts = <GIC_SPI 372 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x05>, <&audma1 0x06>;
ssi3: ssi-3 {
interrupts = <GIC_SPI 373 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x07>, <&audma1 0x08>;
ssi4: ssi-4 {
interrupts = <GIC_SPI 374 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x09>, <&audma1 0x0a>;
ssi5: ssi-5 {
interrupts = <GIC_SPI 375 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x0b>, <&audma1 0x0c>;
ssi6: ssi-6 {
interrupts = <GIC_SPI 376 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x0d>, <&audma1 0x0e>;
ssi7: ssi-7 {
interrupts = <GIC_SPI 377 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x0f>, <&audma1 0x10>;
ssi8: ssi-8 {
interrupts = <GIC_SPI 378 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x11>, <&audma1 0x12>;
ssi9: ssi-9 {
interrupts = <GIC_SPI 379 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x13>, <&audma1 0x14>;
rcar_sound,ssiu {
ssiu00: ssiu-0 {
dmas = <&audma0 0x15>, <&audma1 0x16>;
ssiu01: ssiu-1 {
dmas = <&audma0 0x35>, <&audma1 0x36>;
ssiu02: ssiu-2 {
dmas = <&audma0 0x37>, <&audma1 0x38>;
ssiu03: ssiu-3 {
dmas = <&audma0 0x47>, <&audma1 0x48>;
ssiu04: ssiu-4 {
dmas = <&audma0 0x3F>, <&audma1 0x40>;
ssiu05: ssiu-5 {
dmas = <&audma0 0x43>, <&audma1 0x44>;
ssiu06: ssiu-6 {
dmas = <&audma0 0x4F>, <&audma1 0x50>;
ssiu07: ssiu-7 {
dmas = <&audma0 0x53>, <&audma1 0x54>;
ssiu10: ssiu-8 {
dmas = <&audma0 0x49>, <&audma1 0x4a>;
ssiu11: ssiu-9 {
dmas = <&audma0 0x4B>, <&audma1 0x4C>;
ssiu12: ssiu-10 {
dmas = <&audma0 0x57>, <&audma1 0x58>;
ssiu13: ssiu-11 {
dmas = <&audma0 0x59>, <&audma1 0x5A>;
ssiu14: ssiu-12 {
dmas = <&audma0 0x5F>, <&audma1 0x60>;
ssiu15: ssiu-13 {
dmas = <&audma0 0xC3>, <&audma1 0xC4>;
ssiu16: ssiu-14 {
dmas = <&audma0 0xC7>, <&audma1 0xC8>;
ssiu17: ssiu-15 {
dmas = <&audma0 0xCB>, <&audma1 0xCC>;
ssiu20: ssiu-16 {
dmas = <&audma0 0x63>, <&audma1 0x64>;
ssiu21: ssiu-17 {
dmas = <&audma0 0x67>, <&audma1 0x68>;
ssiu22: ssiu-18 {
dmas = <&audma0 0x6B>, <&audma1 0x6C>;
ssiu23: ssiu-19 {
dmas = <&audma0 0x6D>, <&audma1 0x6E>;
ssiu24: ssiu-20 {
dmas = <&audma0 0xCF>, <&audma1 0xCE>;
ssiu25: ssiu-21 {
dmas = <&audma0 0xEB>, <&audma1 0xEC>;
ssiu26: ssiu-22 {
dmas = <&audma0 0xED>, <&audma1 0xEE>;
ssiu27: ssiu-23 {
dmas = <&audma0 0xEF>, <&audma1 0xF0>;
ssiu30: ssiu-24 {
dmas = <&audma0 0x6f>, <&audma1 0x70>;
ssiu31: ssiu-25 {
dmas = <&audma0 0x21>, <&audma1 0x22>;
ssiu32: ssiu-26 {
dmas = <&audma0 0x23>, <&audma1 0x24>;
ssiu33: ssiu-27 {
dmas = <&audma0 0x25>, <&audma1 0x26>;
ssiu34: ssiu-28 {
dmas = <&audma0 0x27>, <&audma1 0x28>;
ssiu35: ssiu-29 {
dmas = <&audma0 0x29>, <&audma1 0x2A>;
ssiu36: ssiu-30 {
dmas = <&audma0 0x2B>, <&audma1 0x2C>;
ssiu37: ssiu-31 {
dmas = <&audma0 0x2D>, <&audma1 0x2E>;
ssiu40: ssiu-32 {
dmas = <&audma0 0x71>, <&audma1 0x72>;
ssiu41: ssiu-33 {
dmas = <&audma0 0x17>, <&audma1 0x18>;
ssiu42: ssiu-34 {
dmas = <&audma0 0x19>, <&audma1 0x1A>;
ssiu43: ssiu-35 {
dmas = <&audma0 0x1B>, <&audma1 0x1C>;
ssiu44: ssiu-36 {
dmas = <&audma0 0x1D>, <&audma1 0x1E>;
ssiu45: ssiu-37 {
dmas = <&audma0 0x1F>, <&audma1 0x20>;
ssiu46: ssiu-38 {
dmas = <&audma0 0x31>, <&audma1 0x32>;
ssiu47: ssiu-39 {
dmas = <&audma0 0x33>, <&audma1 0x34>;
ssiu50: ssiu-40 {
dmas = <&audma0 0x73>, <&audma1 0x74>;
ssiu60: ssiu-41 {
dmas = <&audma0 0x75>, <&audma1 0x76>;
ssiu70: ssiu-42 {
dmas = <&audma0 0x79>, <&audma1 0x7a>;
ssiu80: ssiu-43 {
dmas = <&audma0 0x7b>, <&audma1 0x7c>;
ssiu90: ssiu-44 {
dmas = <&audma0 0x7d>, <&audma1 0x7e>;
ssiu91: ssiu-45 {
dmas = <&audma0 0x7F>, <&audma1 0x80>;
ssiu92: ssiu-46 {
dmas = <&audma0 0x81>, <&audma1 0x82>;
ssiu93: ssiu-47 {
dmas = <&audma0 0x83>, <&audma1 0x84>;
ssiu94: ssiu-48 {
dmas = <&audma0 0xA3>, <&audma1 0xA4>;
ssiu95: ssiu-49 {
dmas = <&audma0 0xA5>, <&audma1 0xA6>;
ssiu96: ssiu-50 {
dmas = <&audma0 0xA7>, <&audma1 0xA8>;
ssiu97: ssiu-51 {
dmas = <&audma0 0xA9>, <&audma1 0xAA>;
audma0: dma-controller@ec700000 {
reg = <0 0xec700000 0 0x10000>;
interrupts = <GIC_SPI 350 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 320 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 321 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 322 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 323 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 324 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 325 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 326 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 327 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 328 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 329 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 330 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 331 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 332 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 333 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 334 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 335 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 502>;
resets = <&cpg 502>;
#dma-cells = <1>;
iommus = <&ipmmu_mp 0>, <&ipmmu_mp 1>,
<&ipmmu_mp 2>, <&ipmmu_mp 3>,
<&ipmmu_mp 4>, <&ipmmu_mp 5>,
<&ipmmu_mp 6>, <&ipmmu_mp 7>,
<&ipmmu_mp 8>, <&ipmmu_mp 9>,
<&ipmmu_mp 10>, <&ipmmu_mp 11>,
<&ipmmu_mp 12>, <&ipmmu_mp 13>,
<&ipmmu_mp 14>, <&ipmmu_mp 15>;
audma1: dma-controller@ec720000 {
reg = <0 0xec720000 0 0x10000>;
interrupts = <GIC_SPI 351 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 336 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 337 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 338 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 339 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 340 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 341 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 342 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 343 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 344 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 345 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 346 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 347 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 348 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 349 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 382 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 383 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 501>;
resets = <&cpg 501>;
#dma-cells = <1>;
iommus = <&ipmmu_mp 16>, <&ipmmu_mp 17>,
<&ipmmu_mp 18>, <&ipmmu_mp 19>,
<&ipmmu_mp 20>, <&ipmmu_mp 21>,
<&ipmmu_mp 22>, <&ipmmu_mp 23>,
<&ipmmu_mp 24>, <&ipmmu_mp 25>,
<&ipmmu_mp 26>, <&ipmmu_mp 27>,
<&ipmmu_mp 28>, <&ipmmu_mp 29>,
<&ipmmu_mp 30>, <&ipmmu_mp 31>;
xhci0: usb@ee000000 {
compatible = "renesas,xhci-r8a774a1",
"renesas,rcar-gen3-xhci";
reg = <0 0xee000000 0 0xc00>;
interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 328>;
usb3_peri0: usb@ee020000 {
compatible = "renesas,r8a774a1-usb3-peri",
"renesas,rcar-gen3-usb3-peri";
reg = <0 0xee020000 0 0x400>;
interrupts = <GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH>;
ohci0: usb@ee080000 {
compatible = "generic-ohci";
reg = <0 0xee080000 0 0x100>;
interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>;
phys = <&usb2_phy0 1>;
phy-names = "usb";
ohci1: usb@ee0a0000 {
reg = <0 0xee0a0000 0 0x100>;
interrupts = <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 702>;
phys = <&usb2_phy1 1>;
phy-names = "usb";
resets = <&cpg 702>;
ehci0: usb@ee080100 {
compatible = "generic-ehci";
reg = <0 0xee080100 0 0x100>;
phys = <&usb2_phy0 2>;
phy-names = "usb";
companion = <&ohci0>;
ehci1: usb@ee0a0100 {
reg = <0 0xee0a0100 0 0x100>;
phys = <&usb2_phy1 2>;
phy-names = "usb";
companion = <&ohci1>;
usb2_phy0: usb-phy@ee080200 {
compatible = "renesas,usb2-phy-r8a774a1",
"renesas,rcar-gen3-usb2-phy";
reg = <0 0xee080200 0 0x700>;
#phy-cells = <1>;
usb2_phy1: usb-phy@ee0a0200 {
reg = <0 0xee0a0200 0 0x700>;
#phy-cells = <1>;
sdhi0: mmc@ee100000 {
compatible = "renesas,sdhi-r8a774a1",
"renesas,rcar-gen3-sdhi";
reg = <0 0xee100000 0 0x2000>;
interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 314>, <&cpg CPG_CORE R8A774A1_CLK_SD0H>;
resets = <&cpg 314>;
sdhi1: mmc@ee120000 {
reg = <0 0xee120000 0 0x2000>;
interrupts = <GIC_SPI 166 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 313>, <&cpg CPG_CORE R8A774A1_CLK_SD1H>;
resets = <&cpg 313>;
sdhi2: mmc@ee140000 {
interrupts = <GIC_SPI 167 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 312>, <&cpg CPG_CORE R8A774A1_CLK_SD2H>;
resets = <&cpg 312>;
sdhi3: mmc@ee160000 {
reg = <0 0xee160000 0 0x2000>;
interrupts = <GIC_SPI 168 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 311>, <&cpg CPG_CORE R8A774A1_CLK_SD3H>;
resets = <&cpg 311>;
rpc: spi@ee200000 {
compatible = "renesas,r8a774a1-rpc-if",
"renesas,rcar-gen3-rpc-if";
<0 0x08000000 0 0x4000000>,
interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 917>;
resets = <&cpg 917>;
#size-cells = <0>;
gic: interrupt-controller@f1010000 {
compatible = "arm,gic-400";
reg = <0x0 0xf1010000 0 0x1000>,
<0x0 0xf1020000 0 0x20000>,
<0x0 0xf1040000 0 0x20000>,
<0x0 0xf1060000 0 0x20000>;
(GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_HIGH)>;
clocks = <&cpg CPG_MOD 408>;
clock-names = "clk";
resets = <&cpg 408>;
pciec0: pcie@fe000000 {
compatible = "renesas,pcie-r8a774a1",
"renesas,pcie-rcar-gen3";
reg = <0 0xfe000000 0 0x80000>;
#address-cells = <3>;
#size-cells = <2>;
bus-range = <0x00 0xff>;
device_type = "pci";
ranges = <0x01000000 0 0x00000000 0 0xfe100000 0 0x00100000>,
<0x02000000 0 0xfe200000 0 0xfe200000 0 0x00200000>,
<0x02000000 0 0x30000000 0 0x30000000 0 0x08000000>,
<0x42000000 0 0x38000000 0 0x38000000 0 0x08000000>;
/* Map all possible DDR/IOMMU as inbound ranges */
dma-ranges = <0x42000000 0 0x00000000 0 0x00000000 1 0x00000000>;
interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>;
#interrupt-cells = <1>;
interrupt-map-mask = <0 0 0 0>;
interrupt-map = <0 0 0 0 &gic GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 319>, <&pcie_bus_clk>;
clock-names = "pcie", "pcie_bus";
resets = <&cpg 319>;
iommu-map = <0 &ipmmu_hc 0 1>;
iommu-map-mask = <0>;
pciec1: pcie@ee800000 {
reg = <0 0xee800000 0 0x80000>;
#size-cells = <2>;
ranges = <0x01000000 0 0x00000000 0 0xee900000 0 0x00100000>,
<0x02000000 0 0xeea00000 0 0xeea00000 0 0x00200000>,
<0x02000000 0 0xc0000000 0 0xc0000000 0 0x08000000>,
<0x42000000 0 0xc8000000 0 0xc8000000 0 0x08000000>;
interrupts = <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 149 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 150 IRQ_TYPE_LEVEL_HIGH>;
interrupt-map = <0 0 0 0 &gic GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 318>, <&pcie_bus_clk>;
resets = <&cpg 318>;
iommu-map = <0 &ipmmu_hc 1 1>;
pciec0_ep: pcie-ep@fe000000 {
compatible = "renesas,r8a774a1-pcie-ep",
"renesas,rcar-gen3-pcie-ep";
reg = <0x0 0xfe000000 0 0x80000>,
<0x0 0xfe100000 0 0x100000>,
<0x0 0xfe200000 0 0x200000>,
<0x0 0x30000000 0 0x8000000>,
<0x0 0x38000000 0 0x8000000>;
reg-names = "apb-base", "memory0", "memory1", "memory2", "memory3";
clocks = <&cpg CPG_MOD 319>;
clock-names = "pcie";
pciec1_ep: pcie-ep@ee800000 {
reg = <0x0 0xee800000 0 0x80000>,
<0x0 0xee900000 0 0x100000>,
<0x0 0xeea00000 0 0x200000>,
<0x0 0xc0000000 0 0x8000000>,
<0x0 0xc8000000 0 0x8000000>;
clocks = <&cpg CPG_MOD 318>;
fdp1@fe940000 {
compatible = "renesas,fdp1";
reg = <0 0xfe940000 0 0x2400>;
interrupts = <GIC_SPI 262 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 119>;
resets = <&cpg 119>;
renesas,fcp = <&fcpf0>;
fcpf0: fcp@fe950000 {
compatible = "renesas,fcpf";
reg = <0 0xfe950000 0 0x200>;
clocks = <&cpg CPG_MOD 615>;
resets = <&cpg 615>;
fcpvb0: fcp@fe96f000 {
reg = <0 0xfe96f000 0 0x200>;
clocks = <&cpg CPG_MOD 607>;
resets = <&cpg 607>;
fcpvd0: fcp@fea27000 {
reg = <0 0xfea27000 0 0x200>;
clocks = <&cpg CPG_MOD 603>;
resets = <&cpg 603>;
iommus = <&ipmmu_vi0 8>;
fcpvd1: fcp@fea2f000 {
reg = <0 0xfea2f000 0 0x200>;
clocks = <&cpg CPG_MOD 602>;
resets = <&cpg 602>;
iommus = <&ipmmu_vi0 9>;
fcpvd2: fcp@fea37000 {
reg = <0 0xfea37000 0 0x200>;
clocks = <&cpg CPG_MOD 601>;
resets = <&cpg 601>;
iommus = <&ipmmu_vi0 10>;
fcpvi0: fcp@fe9af000 {
reg = <0 0xfe9af000 0 0x200>;
clocks = <&cpg CPG_MOD 611>;
resets = <&cpg 611>;
iommus = <&ipmmu_vc0 19>;
vspb: vsp@fe960000 {
reg = <0 0xfe960000 0 0x8000>;
interrupts = <GIC_SPI 266 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 626>;
resets = <&cpg 626>;
renesas,fcp = <&fcpvb0>;
reg = <0 0xfea20000 0 0x5000>;
interrupts = <GIC_SPI 466 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 623>;
resets = <&cpg 623>;
reg = <0 0xfea28000 0 0x5000>;
interrupts = <GIC_SPI 467 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 622>;
resets = <&cpg 622>;
vspd2: vsp@fea30000 {
reg = <0 0xfea30000 0 0x5000>;
interrupts = <GIC_SPI 468 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 621>;
resets = <&cpg 621>;
renesas,fcp = <&fcpvd2>;
vspi0: vsp@fe9a0000 {
reg = <0 0xfe9a0000 0 0x8000>;
interrupts = <GIC_SPI 444 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 631>;
resets = <&cpg 631>;
renesas,fcp = <&fcpvi0>;
csi20: csi2@fea80000 {
compatible = "renesas,r8a774a1-csi2";
reg = <0 0xfea80000 0 0x10000>;
interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 714>;
resets = <&cpg 714>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
csi20vin0: endpoint@0 {
reg = <0>;
remote-endpoint = <&vin0csi20>;
csi20vin1: endpoint@1 {
reg = <1>;
remote-endpoint = <&vin1csi20>;
csi20vin2: endpoint@2 {
reg = <2>;
remote-endpoint = <&vin2csi20>;
csi20vin3: endpoint@3 {
reg = <3>;
remote-endpoint = <&vin3csi20>;
csi20vin4: endpoint@4 {
reg = <4>;
remote-endpoint = <&vin4csi20>;
csi20vin5: endpoint@5 {
reg = <5>;
remote-endpoint = <&vin5csi20>;
csi20vin6: endpoint@6 {
reg = <6>;
remote-endpoint = <&vin6csi20>;
csi20vin7: endpoint@7 {
reg = <7>;
remote-endpoint = <&vin7csi20>;
csi40: csi2@feaa0000 {
reg = <0 0xfeaa0000 0 0x10000>;
interrupts = <GIC_SPI 246 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 716>;
resets = <&cpg 716>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
csi40vin0: endpoint@0 {
reg = <0>;
remote-endpoint = <&vin0csi40>;
csi40vin1: endpoint@1 {
reg = <1>;
remote-endpoint = <&vin1csi40>;
csi40vin2: endpoint@2 {
reg = <2>;
remote-endpoint = <&vin2csi40>;
csi40vin3: endpoint@3 {
reg = <3>;
remote-endpoint = <&vin3csi40>;
csi40vin4: endpoint@4 {
reg = <4>;
remote-endpoint = <&vin4csi40>;
csi40vin5: endpoint@5 {
reg = <5>;
remote-endpoint = <&vin5csi40>;
csi40vin6: endpoint@6 {
reg = <6>;
remote-endpoint = <&vin6csi40>;
csi40vin7: endpoint@7 {
reg = <7>;
remote-endpoint = <&vin7csi40>;
hdmi0: hdmi@fead0000 {
compatible = "renesas,r8a774a1-hdmi",
"renesas,rcar-gen3-hdmi";
reg = <0 0xfead0000 0 0x10000>;
interrupts = <GIC_SPI 389 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 729>,
<&cpg CPG_CORE R8A774A1_CLK_HDMI>;
clock-names = "iahb", "isfr";
resets = <&cpg 729>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
dw_hdmi0_in: endpoint {
remote-endpoint = <&du_out_hdmi0>;
port@1 {
reg = <1>;
port@2 {
/* HDMI sound */
reg = <2>;
compatible = "renesas,du-r8a774a1";
reg = <0 0xfeb00000 0 0x70000>;
interrupts = <GIC_SPI 256 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 268 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 269 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 724>, <&cpg CPG_MOD 723>,
<&cpg CPG_MOD 722>;
clock-names = "du.0", "du.1", "du.2";
resets = <&cpg 724>, <&cpg 722>;
reset-names = "du.0", "du.2";
renesas,vsps = <&vspd0 0>, <&vspd1 0>, <&vspd2 0>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port@1 {
reg = <1>;
du_out_hdmi0: endpoint {
remote-endpoint = <&dw_hdmi0_in>;
port@2 {
reg = <2>;
du_out_lvds0: endpoint {
remote-endpoint = <&lvds0_in>;
lvds0: lvds@feb90000 {
compatible = "renesas,r8a774a1-lvds";
reg = <0 0xfeb90000 0 0x14>;
clocks = <&cpg CPG_MOD 727>;
resets = <&cpg 727>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
lvds0_in: endpoint {
remote-endpoint = <&du_out_lvds0>;
port@1 {
reg = <1>;
thermal-zones {
sensor1_thermal: sensor1-thermal {
sustainable-power = <3874>;
trips {
type = "critical";
sensor2_thermal: sensor2-thermal {
trips {
type = "critical";
sensor3_thermal: sensor3-thermal {
cooling-maps {
map0 {
trip = <&target>;
cooling-device = <&a57_0 0 2>;
contribution = <1024>;
map1 {
trip = <&target>;
cooling-device = <&a53_0 0 2>;
trips {
target: trip-point1 {
temperature = <100000>;
type = "passive";
type = "critical";
timer {
interrupts-extended = <&gic GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>,
<&gic GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>,
<&gic GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>,
<&gic GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>;
/* External USB clocks - can be overridden by the board */
usb3s0_clk: usb3s0 {
#clock-cells = <0>;
usb_extal_clk: usb_extal {
#clock-cells = <0>;
-}; diff --git a/arch/arm/dts/r8a774b1-beacon-rzg2n-kit.dts b/arch/arm/dts/r8a774b1-beacon-rzg2n-kit.dts deleted file mode 100644 index 8b9df6afffd..00000000000 --- a/arch/arm/dts/r8a774b1-beacon-rzg2n-kit.dts +++ /dev/null @@ -1,56 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
-/dts-v1/;
-#include "r8a774b1.dtsi" -#include "beacon-renesom-som.dtsi" -#include "beacon-renesom-baseboard.dtsi"
model = "Beacon Embedded Works RZ/G2N Development Kit";
compatible = "beacon,beacon-rzg2n", "renesas,r8a774b1";
aliases {
i2c0 = &i2c0;
i2c1 = &i2c1;
i2c2 = &i2c2;
i2c3 = &i2c3;
i2c4 = &i2c4;
i2c5 = &i2c5;
i2c6 = &i2c6;
i2c7 = &iic_pmic;
serial0 = &scif2;
serial1 = &hscif0;
serial2 = &hscif1;
serial3 = &scif0;
serial4 = &hscif2;
serial5 = &scif5;
serial6 = &scif4;
ethernet0 = &avb;
mmc0 = &sdhi3;
mmc1 = &sdhi0;
mmc2 = &sdhi2;
chosen {
-&du {
status = "okay";
<&cpg CPG_MOD 723>,
<&cpg CPG_MOD 721>,
<&versaclock5 1>,
<&x302_clk>,
<&versaclock5 2>;
clock-names = "du.0", "du.1", "du.3",
"dclkin.0", "dclkin.1", "dclkin.3";
-}; diff --git a/arch/arm/dts/r8a774b1-hihope-rzg2n-ex.dts b/arch/arm/dts/r8a774b1-hihope-rzg2n-ex.dts deleted file mode 100644 index 60d7c8adea0..00000000000 --- a/arch/arm/dts/r8a774b1-hihope-rzg2n-ex.dts +++ /dev/null @@ -1,21 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Device Tree Source for the HiHope RZ/G2N Rev.3.0/4.0 connected to
- sub board
-#include "r8a774b1-hihope-rzg2n.dts" -#include "hihope-rzg2-ex.dtsi"
model = "HopeRun HiHope RZ/G2N with sub board";
compatible = "hoperun,hihope-rzg2-ex", "hoperun,hihope-rzg2n",
"renesas,r8a774b1";
-/* Set SW43 = ON and SW1001[7] = OFF for SATA port to be activated */ -&sata {
status = "okay";
-}; diff --git a/arch/arm/dts/r8a774b1-hihope-rzg2n.dts b/arch/arm/dts/r8a774b1-hihope-rzg2n.dts deleted file mode 100644 index f1883cbd1a8..00000000000 --- a/arch/arm/dts/r8a774b1-hihope-rzg2n.dts +++ /dev/null @@ -1,41 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Device Tree Source for the HiHope RZ/G2N main board Rev.3.0/4.0
-/dts-v1/; -#include "r8a774b1.dtsi" -#include "hihope-rev4.dtsi"
model = "HopeRun HiHope RZ/G2N main board based on r8a774b1";
compatible = "hoperun,hihope-rzg2n", "renesas,r8a774b1";
memory@48000000 {
memory@480000000 {
reg = <0x4 0x80000000 0x0 0x80000000>;
-&du {
<&cpg CPG_MOD 723>,
<&cpg CPG_MOD 721>,
<&versaclock5 1>,
<&x302_clk>,
<&versaclock5 2>;
-&sdhi3 {
mmc-hs400-1_8v;
-}; diff --git a/arch/arm/dts/r8a774b1.dtsi b/arch/arm/dts/r8a774b1.dtsi deleted file mode 100644 index 75776decd21..00000000000 --- a/arch/arm/dts/r8a774b1.dtsi +++ /dev/null @@ -1,2716 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Device Tree Source for the r8a774b1 SoC
- Copyright (C) 2019 Renesas Electronics Corp.
-#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/clock/r8a774b1-cpg-mssr.h> -#include <dt-bindings/power/r8a774b1-sysc.h>
-#define CPG_AUDIO_CLK_I R8A774B1_CLK_S0D4
compatible = "renesas,r8a774b1";
#size-cells = <2>;
#clock-cells = <0>;
#clock-cells = <0>;
#clock-cells = <0>;
can_clk: can {
#clock-cells = <0>;
opp-shared;
opp-500000000 {
opp-microvolt = <830000>;
opp-1000000000 {
opp-1500000000 {
opp-suspend;
cpus {
#address-cells = <1>;
#size-cells = <0>;
a57_0: cpu@0 {
reg = <0x0>;
power-domains = <&sysc R8A774B1_PD_CA57_CPU0>;
clocks = <&cpg CPG_CORE R8A774B1_CLK_Z>;
a57_1: cpu@1 {
reg = <0x1>;
power-domains = <&sysc R8A774B1_PD_CA57_CPU1>;
power-domains = <&sysc R8A774B1_PD_CA57_SCU>;
cache-unified;
cache-level = <2>;
extal_clk: extal {
#clock-cells = <0>;
#clock-cells = <0>;
#clock-cells = <0>;
pmu_a57 {
psci {
method = "smc";
scif_clk: scif {
#clock-cells = <0>;
soc {
#size-cells = <2>;
ranges;
compatible = "renesas,r8a774b1-wdt",
power-domains = <&sysc R8A774B1_PD_ALWAYS_ON>;
status = "disabled";
compatible = "renesas,gpio-r8a774b1",
#gpio-cells = <2>;
gpio-controller;
interrupt-controller;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
compatible = "renesas,pfc-r8a774b1";
compatible = "renesas,r8a774b1-cmt0",
clock-names = "fck";
compatible = "renesas,r8a774b1-cmt1",
<GIC_SPI 399 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 400 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 401 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 402 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 403 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 404 IRQ_TYPE_LEVEL_HIGH>,
compatible = "renesas,r8a774b1-cpg-mssr";
reg = <0 0xe6150000 0 0x1000>;
#clock-cells = <2>;
#reset-cells = <1>;
compatible = "renesas,r8a774b1-rst";
reg = <0 0xe6160000 0 0x0200>;
compatible = "renesas,r8a774b1-sysc";
compatible = "renesas,r8a774b1-thermal";
clocks = <&cpg CPG_MOD 522>;
resets = <&cpg 522>;
compatible = "renesas,intc-ex-r8a774b1", "renesas,irqc";
compatible = "renesas,tmu-r8a774b1", "renesas,tmu";
<GIC_SPI 407 IRQ_TYPE_LEVEL_HIGH>,
#size-cells = <0>;
compatible = "renesas,i2c-r8a774b1",
dma-names = "tx", "rx", "tx", "rx";
#size-cells = <0>;
#size-cells = <0>;
#size-cells = <0>;
dma-names = "tx", "rx";
#size-cells = <0>;
#size-cells = <0>;
#size-cells = <0>;
#size-cells = <0>;
compatible = "renesas,iic-r8a774b1",
compatible = "renesas,hscif-r8a774b1",
"renesas,hscif";
<&cpg CPG_CORE R8A774B1_CLK_S3D1>,
<&scif_clk>;
"renesas,hscif";
<&scif_clk>;
"renesas,hscif";
<&scif_clk>;
"renesas,hscif";
<&scif_clk>;
"renesas,hscif";
<&scif_clk>;
compatible = "renesas,usbhs-r8a774b1",
phy-names = "usb";
compatible = "renesas,r8a774b1-rcar-usb2-clock-sel",
#clock-cells = <0>;
compatible = "renesas,r8a774b1-usb-dmac",
"renesas,usb-dmac";
#dma-cells = <1>;
dma-channels = <2>;
"renesas,usb-dmac";
clocks = <&cpg CPG_MOD 331>;
resets = <&cpg 331>;
#dma-cells = <1>;
dma-channels = <2>;
compatible = "renesas,r8a774b1-usb3-phy",
<&usb_extal_clk>;
#phy-cells = <0>;
compatible = "renesas,dmac-r8a774b1",
<GIC_SPI 210 IRQ_TYPE_LEVEL_HIGH>,
interrupt-names = "error",
#dma-cells = <1>;
dma-channels = <16>;
iommus = <&ipmmu_ds0 0>, <&ipmmu_ds0 1>,
<&ipmmu_ds0 2>, <&ipmmu_ds0 3>,
<&ipmmu_ds0 4>, <&ipmmu_ds0 5>,
<&ipmmu_ds0 6>, <&ipmmu_ds0 7>,
<&ipmmu_ds0 8>, <&ipmmu_ds0 9>,
<&ipmmu_ds0 10>, <&ipmmu_ds0 11>,
<&ipmmu_ds0 12>, <&ipmmu_ds0 13>,
<&ipmmu_ds0 14>, <&ipmmu_ds0 15>;
#dma-cells = <1>;
#dma-cells = <1>;
compatible = "renesas,ipmmu-r8a774b1";
#iommu-cells = <1>;
#iommu-cells = <1>;
#iommu-cells = <1>;
#iommu-cells = <1>;
#iommu-cells = <1>;
#iommu-cells = <1>;
renesas,ipmmu-main = <&ipmmu_mm 12>;
power-domains = <&sysc R8A774B1_PD_A3VC>;
#iommu-cells = <1>;
renesas,ipmmu-main = <&ipmmu_mm 14>;
#iommu-cells = <1>;
ipmmu_vp0: iommu@fe990000 {
reg = <0 0xfe990000 0 0x1000>;
renesas,ipmmu-main = <&ipmmu_mm 16>;
power-domains = <&sysc R8A774B1_PD_A3VP>;
#iommu-cells = <1>;
compatible = "renesas,etheravb-r8a774b1",
"ch24";
clocks = <&cpg CPG_MOD 812>;
resets = <&cpg 812>;
phy-mode = "rgmii";
#size-cells = <0>;
compatible = "renesas,can-r8a774b1",
<&cpg CPG_CORE R8A774B1_CLK_CANFD>,
<&can_clk>;
assigned-clocks = <&cpg CPG_CORE R8A774B1_CLK_CANFD>;
<&can_clk>;
compatible = "renesas,r8a774b1-canfd",
<&can_clk>;
channel0 {
channel1 {
compatible = "renesas,pwm-r8a774b1", "renesas,pwm-rcar";
#pwm-cells = <2>;
#pwm-cells = <2>;
#pwm-cells = <2>;
#pwm-cells = <2>;
#pwm-cells = <2>;
#pwm-cells = <2>;
#pwm-cells = <2>;
compatible = "renesas,scif-r8a774b1",
<&scif_clk>;
<&scif_clk>;
<&scif_clk>;
<&scif_clk>;
<&scif_clk>;
<&scif_clk>;
compatible = "renesas,msiof-r8a774b1",
#size-cells = <0>;
#size-cells = <0>;
#size-cells = <0>;
msiof3: spi@e6c10000 {
reg = <0 0xe6c10000 0 0x0064>;
#size-cells = <0>;
compatible = "renesas,vin-r8a774b1";
reg = <0 0xe6ef0000 0 0x1000>;
clocks = <&cpg CPG_MOD 811>;
resets = <&cpg 811>;
renesas,id = <0>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
reg = <0>;
reg = <2>;
reg = <0 0xe6ef1000 0 0x1000>;
clocks = <&cpg CPG_MOD 810>;
resets = <&cpg 810>;
renesas,id = <1>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
reg = <0>;
reg = <2>;
reg = <0 0xe6ef2000 0 0x1000>;
clocks = <&cpg CPG_MOD 809>;
resets = <&cpg 809>;
renesas,id = <2>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
reg = <0>;
reg = <2>;
reg = <0 0xe6ef3000 0 0x1000>;
clocks = <&cpg CPG_MOD 808>;
resets = <&cpg 808>;
renesas,id = <3>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
reg = <0>;
reg = <2>;
reg = <0 0xe6ef4000 0 0x1000>;
clocks = <&cpg CPG_MOD 807>;
resets = <&cpg 807>;
renesas,id = <4>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
reg = <0>;
reg = <2>;
reg = <0 0xe6ef5000 0 0x1000>;
clocks = <&cpg CPG_MOD 806>;
resets = <&cpg 806>;
renesas,id = <5>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
reg = <0>;
reg = <2>;
reg = <0 0xe6ef6000 0 0x1000>;
clocks = <&cpg CPG_MOD 805>;
resets = <&cpg 805>;
renesas,id = <6>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
reg = <0>;
reg = <2>;
reg = <0 0xe6ef7000 0 0x1000>;
clocks = <&cpg CPG_MOD 804>;
resets = <&cpg 804>;
renesas,id = <7>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
reg = <0>;
reg = <2>;
* Single DAI : #sound-dai-cells = <0>; <&rcar_sound>;
* Multi DAI : #sound-dai-cells = <1>; <&rcar_sound N>;
* clkout : #clock-cells = <0>; <&rcar_sound>;
compatible = "renesas,rcar_sound-r8a774b1", "renesas,rcar_sound-gen3";
<&audio_clk_c>,
<&cpg CPG_CORE R8A774B1_CLK_S0D4>;
"ssi.1", "ssi.0",
"src.1", "src.0",
"mix.1", "mix.0",
"ctu.1", "ctu.0",
"dvc.0", "dvc.1",
"ssi.1", "ssi.0";
rcar_sound,ctu {
ctu00: ctu-0 { };
ctu01: ctu-1 { };
ctu02: ctu-2 { };
ctu03: ctu-3 { };
ctu10: ctu-4 { };
ctu11: ctu-5 { };
ctu12: ctu-6 { };
ctu13: ctu-7 { };
rcar_sound,dvc {
dvc0: dvc-0 {
dma-names = "tx";
dvc1: dvc-1 {
dma-names = "tx";
rcar_sound,mix {
mix0: mix-0 { };
mix1: mix-1 { };
rcar_sound,src {
src0: src-0 {
src1: src-1 {
src2: src-2 {
src3: src-3 {
src4: src-4 {
src5: src-5 {
src6: src-6 {
src7: src-7 {
src8: src-8 {
src9: src-9 {
rcar_sound,ssi {
ssi0: ssi-0 {
ssi1: ssi-1 {
ssi2: ssi-2 {
ssi3: ssi-3 {
ssi4: ssi-4 {
ssi5: ssi-5 {
ssi6: ssi-6 {
ssi7: ssi-7 {
ssi8: ssi-8 {
ssi9: ssi-9 {
rcar_sound,ssiu {
ssiu00: ssiu-0 {
ssiu01: ssiu-1 {
ssiu02: ssiu-2 {
ssiu03: ssiu-3 {
ssiu04: ssiu-4 {
ssiu05: ssiu-5 {
ssiu06: ssiu-6 {
ssiu07: ssiu-7 {
ssiu10: ssiu-8 {
ssiu11: ssiu-9 {
ssiu12: ssiu-10 {
ssiu13: ssiu-11 {
ssiu14: ssiu-12 {
ssiu15: ssiu-13 {
ssiu16: ssiu-14 {
ssiu17: ssiu-15 {
ssiu20: ssiu-16 {
ssiu21: ssiu-17 {
ssiu22: ssiu-18 {
ssiu23: ssiu-19 {
ssiu24: ssiu-20 {
ssiu25: ssiu-21 {
ssiu26: ssiu-22 {
ssiu27: ssiu-23 {
ssiu30: ssiu-24 {
ssiu31: ssiu-25 {
ssiu32: ssiu-26 {
ssiu33: ssiu-27 {
ssiu34: ssiu-28 {
ssiu35: ssiu-29 {
ssiu36: ssiu-30 {
ssiu37: ssiu-31 {
ssiu40: ssiu-32 {
ssiu41: ssiu-33 {
ssiu42: ssiu-34 {
ssiu43: ssiu-35 {
ssiu44: ssiu-36 {
ssiu45: ssiu-37 {
ssiu46: ssiu-38 {
ssiu47: ssiu-39 {
ssiu50: ssiu-40 {
ssiu60: ssiu-41 {
ssiu70: ssiu-42 {
ssiu80: ssiu-43 {
ssiu90: ssiu-44 {
ssiu91: ssiu-45 {
ssiu92: ssiu-46 {
ssiu93: ssiu-47 {
ssiu94: ssiu-48 {
ssiu95: ssiu-49 {
ssiu96: ssiu-50 {
ssiu97: ssiu-51 {
#dma-cells = <1>;
#dma-cells = <1>;
compatible = "renesas,xhci-r8a774b1",
compatible = "renesas,r8a774b1-usb3-peri",
phy-names = "usb";
phy-names = "usb";
phy-names = "usb";
phy-names = "usb";
compatible = "renesas,usb2-phy-r8a774b1",
#phy-cells = <1>;
#phy-cells = <1>;
compatible = "renesas,sdhi-r8a774b1",
clocks = <&cpg CPG_MOD 314>, <&cpg CPG_CORE R8A774B1_CLK_SD0H>;
clock-names = "core", "clkh";
max-frequency = <200000000>;
clocks = <&cpg CPG_MOD 313>, <&cpg CPG_CORE R8A774B1_CLK_SD1H>;
reg = <0 0xee140000 0 0x2000>;
clocks = <&cpg CPG_MOD 312>, <&cpg CPG_CORE R8A774B1_CLK_SD2H>;
clocks = <&cpg CPG_MOD 311>, <&cpg CPG_CORE R8A774B1_CLK_SD3H>;
rpc: spi@ee200000 {
compatible = "renesas,r8a774b1-rpc-if",
reg = <0 0xee200000 0 0x200>,
<0 0xee208000 0 0x100>;
reg-names = "regs", "dirmap", "wbuf";
#size-cells = <0>;
sata: sata@ee300000 {
compatible = "renesas,sata-r8a774b1",
"renesas,rcar-gen3-sata";
reg = <0 0xee300000 0 0x200000>;
interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 815>;
resets = <&cpg 815>;
#interrupt-cells = <3>;
#address-cells = <0>;
interrupts = <GIC_PPI 9
(GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_HIGH)>;
compatible = "renesas,pcie-r8a774b1",
#size-cells = <2>;
#size-cells = <2>;
compatible = "renesas,r8a774b1-pcie-ep",
fdp1@fe940000 {
compatible = "renesas,vsp2";
vspd0: vsp@fea20000 {
renesas,fcp = <&fcpvd0>;
vspd1: vsp@fea28000 {
renesas,fcp = <&fcpvd1>;
compatible = "renesas,fcpv";
compatible = "renesas,r8a774b1-csi2";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
reg = <0>;
reg = <1>;
reg = <2>;
reg = <3>;
reg = <4>;
reg = <5>;
reg = <6>;
reg = <7>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
reg = <0>;
reg = <1>;
reg = <2>;
reg = <3>;
reg = <4>;
reg = <5>;
reg = <6>;
reg = <7>;
compatible = "renesas,r8a774b1-hdmi",
<&cpg CPG_CORE R8A774B1_CLK_HDMI>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port@1 {
reg = <1>;
port@2 {
/* HDMI sound */
reg = <2>;
du: display@feb00000 {
compatible = "renesas,du-r8a774b1";
reg = <0 0xfeb00000 0 0x80000>;
<GIC_SPI 270 IRQ_TYPE_LEVEL_HIGH>;
<&cpg CPG_MOD 721>;
clock-names = "du.0", "du.1", "du.3";
reset-names = "du.0", "du.3";
renesas,vsps = <&vspd0 0>, <&vspd1 0>, <&vspd0 1>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port@1 {
reg = <1>;
port@2 {
reg = <2>;
compatible = "renesas,r8a774b1-lvds";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port@1 {
reg = <1>;
prr: chipid@fff00044 {
compatible = "renesas,prr";
reg = <0 0xfff00044 0 4>;
thermal-zones {
polling-delay-passive = <250>;
polling-delay = <1000>;
thermal-sensors = <&tsc 0>;
sustainable-power = <2439>;
trips {
sensor1_crit: sensor1-crit {
temperature = <120000>;
hysteresis = <1000>;
type = "critical";
thermal-sensors = <&tsc 1>;
trips {
sensor2_crit: sensor2-crit {
type = "critical";
thermal-sensors = <&tsc 2>;
cooling-maps {
map0 {
trip = <&target>;
trips {
type = "passive";
sensor3_crit: sensor3-crit {
type = "critical";
timer {
compatible = "arm,armv8-timer";
interrupts-extended = <&gic GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>,
<&gic GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>,
<&gic GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>,
<&gic GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>;
#clock-cells = <0>;
#clock-cells = <0>;
-}; diff --git a/arch/arm/dts/r8a774c0-cat874.dts b/arch/arm/dts/r8a774c0-cat874.dts deleted file mode 100644 index 5a6ea08ffd2..00000000000 --- a/arch/arm/dts/r8a774c0-cat874.dts +++ /dev/null @@ -1,455 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Device Tree Source for the Silicon Linux RZ/G2E 96board platform (CAT874)
-/dts-v1/; -#include "r8a774c0.dtsi" -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/display/tda998x.h>
model = "Silicon Linux RZ/G2E 96board platform (CAT874)";
compatible = "si-linux,cat874", "renesas,r8a774c0";
aliases {
serial0 = &scif2;
serial1 = &hscif2;
mmc0 = &sdhi0;
mmc1 = &sdhi3;
chosen {
bootargs = "ignore_loglevel rw root=/dev/nfs ip=on";
stdout-path = "serial0:115200n8";
hdmi-out {
compatible = "hdmi-connector";
type = "a";
port {
hdmi_con_out: endpoint {
remote-endpoint = <&tda19988_out>;
leds {
compatible = "gpio-leds";
led0 {
gpios = <&gpio5 19 GPIO_ACTIVE_HIGH>;
label = "LED0";
led1 {
gpios = <&gpio3 14 GPIO_ACTIVE_HIGH>;
label = "LED1";
led2 {
gpios = <&gpio4 10 GPIO_ACTIVE_HIGH>;
label = "LED2";
led3 {
gpios = <&gpio6 4 GPIO_ACTIVE_HIGH>;
label = "LED3";
memory@48000000 {
device_type = "memory";
/* first 128MB is reserved for secure area. */
reg = <0x0 0x48000000 0x0 0x78000000>;
reg_12p0v: regulator-12p0v {
compatible = "regulator-fixed";
regulator-name = "D12.0V";
regulator-min-microvolt = <12000000>;
regulator-max-microvolt = <12000000>;
regulator-boot-on;
regulator-always-on;
sound: sound {
compatible = "simple-audio-card";
simple-audio-card,name = "CAT874 HDMI sound";
simple-audio-card,format = "i2s";
simple-audio-card,bitclock-master = <&sndcpu>;
simple-audio-card,frame-master = <&sndcpu>;
sndcodec: simple-audio-card,codec {
sound-dai = <&tda19988>;
sndcpu: simple-audio-card,cpu {
sound-dai = <&rcar_sound>;
vcc_sdhi0: regulator-vcc-sdhi0 {
regulator-name = "SDHI0 Vcc";
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
regulator-boot-on;
vccq_sdhi0: regulator-vccq-sdhi0 {
compatible = "regulator-gpio";
regulator-name = "SDHI0 VccQ";
regulator-min-microvolt = <1800000>;
gpios = <&gpio3 13 GPIO_ACTIVE_HIGH>;
gpios-states = <1>;
states = <3300000 1>, <1800000 0>;
wlan_en_reg: fixedregulator {
regulator-name = "wlan-en-regulator";
regulator-max-microvolt = <1800000>;
startup-delay-us = <70000>;
gpio = <&gpio2 25 GPIO_ACTIVE_HIGH>;
enable-active-high;
x13_clk: x13 {
compatible = "fixed-clock";
#clock-cells = <0>;
clock-frequency = <74250000>;
connector {
compatible = "usb-c-connector";
label = "USB-C";
data-role = "dual";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
hs_ep: endpoint {
remote-endpoint = <&usb3_hs_ep>;
port@1 {
reg = <1>;
ss_ep: endpoint {
remote-endpoint = <&hd3ss3220_in_ep>;
-&audio_clk_a {
clock-frequency = <22579200>;
-&du {
pinctrl-0 = <&du_pins>;
pinctrl-names = "default";
status = "okay";
<&cpg CPG_MOD 723>,
<&x13_clk>;
clock-names = "du.0", "du.1", "dclkin.0";
ports {
port@0 {
du_out_rgb: endpoint {
remote-endpoint = <&tda19988_in>;
-&ehci0 {
dr_mode = "host";
status = "okay";
-&extal_clk {
clock-frequency = <48000000>;
-&hscif2 {
pinctrl-0 = <&hscif2_pins>;
uart-has-rtscts;
status = "okay";
bluetooth {
compatible = "ti,wl1837-st";
enable-gpios = <&gpio4 6 GPIO_ACTIVE_HIGH>;
-&i2c0 {
status = "okay";
clock-frequency = <100000>;
hd3ss3220@47 {
compatible = "ti,hd3ss3220";
reg = <0x47>;
interrupt-parent = <&gpio6>;
interrupts = <3 IRQ_TYPE_LEVEL_LOW>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
hd3ss3220_in_ep: endpoint {
remote-endpoint = <&ss_ep>;
port@1 {
reg = <1>;
hd3ss3220_out_ep: endpoint {
remote-endpoint = <&usb3_role_switch>;
tda19988: tda19988@70 {
compatible = "nxp,tda998x";
reg = <0x70>;
interrupt-parent = <&gpio1>;
interrupts = <1 IRQ_TYPE_LEVEL_LOW>;
video-ports = <0x234501>;
audio-ports = <TDA998x_I2S 0x03>;
clocks = <&rcar_sound 1>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
tda19988_in: endpoint {
remote-endpoint = <&du_out_rgb>;
port@1 {
reg = <1>;
tda19988_out: endpoint {
remote-endpoint = <&hdmi_con_out>;
-&i2c1 {
pinctrl-0 = <&i2c1_pins>;
status = "okay";
clock-frequency = <400000>;
rtc@32 {
compatible = "epson,rx8571";
reg = <0x32>;
-&lvds0 {
status = "okay";
clocks = <&cpg CPG_MOD 727>, <&x13_clk>, <&extal_clk>;
clock-names = "fck", "dclkin.0", "extal";
-&ohci0 {
dr_mode = "host";
status = "okay";
-&pcie_bus_clk {
clock-frequency = <100000000>;
-&pciec0 {
/* Map all possible DDR as inbound ranges */
dma-ranges = <0x42000000 0 0x40000000 0 0x40000000 0 0x80000000>;
-&pfc {
du_pins: du {
groups = "du_rgb888", "du_clk_out_0", "du_sync", "du_disp",
"du_clk_in_0";
function = "du";
hscif2_pins: hscif2 {
groups = "hscif2_data_a", "hscif2_ctrl_a";
function = "hscif2";
i2c1_pins: i2c1 {
groups = "i2c1_b";
function = "i2c1";
scif2_pins: scif2 {
groups = "scif2_data_a";
function = "scif2";
sdhi0_pins: sd0 {
groups = "sdhi0_data4", "sdhi0_ctrl";
function = "sdhi0";
power-source = <3300>;
sdhi0_pins_uhs: sd0_uhs {
function = "sdhi0";
power-source = <1800>;
sdhi3_pins: sd3 {
groups = "sdhi3_data4", "sdhi3_ctrl";
function = "sdhi3";
sound_clk_pins: sound_clk {
groups = "audio_clkout1_a";
function = "audio_clk";
sound_pins: sound {
groups = "ssi01239_ctrl", "ssi0_data";
function = "ssi";
usb30_pins: usb30 {
groups = "usb30", "usb30_id";
function = "usb30";
-&rcar_sound {
pinctrl-0 = <&sound_pins>, <&sound_clk_pins>;
/* Single DAI */
/* audio_clkout0/1/2/3 */
#clock-cells = <1>;
clock-frequency = <11289600>;
status = "okay";
rcar_sound,dai {
dai0 {
playback = <&ssi0>, <&src0>, <&dvc0>;
-&rwdt {
timeout-sec = <60>;
status = "okay";
-&scif2 {
pinctrl-0 = <&scif2_pins>;
status = "okay";
-&sdhi0 {
pinctrl-0 = <&sdhi0_pins>;
pinctrl-1 = <&sdhi0_pins_uhs>;
pinctrl-names = "default", "state_uhs";
vmmc-supply = <&vcc_sdhi0>;
vqmmc-supply = <&vccq_sdhi0>;
cd-gpios = <&gpio3 12 GPIO_ACTIVE_LOW>;
bus-width = <4>;
sd-uhs-sdr50;
sd-uhs-sdr104;
status = "okay";
-&sdhi3 {
status = "okay";
pinctrl-0 = <&sdhi3_pins>;
vmmc-supply = <&wlan_en_reg>;
bus-width = <4>;
non-removable;
cap-power-off-card;
keep-power-in-suspend;
#size-cells = <0>;
wlcore: wlcore@2 {
compatible = "ti,wl1837";
reg = <2>;
interrupts = <0 IRQ_TYPE_LEVEL_HIGH>;
-&usb2_phy0 {
renesas,no-otg-pins;
status = "okay";
-&usb3_peri0 {
companion = <&xhci0>;
status = "okay";
usb-role-switch;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
usb3_hs_ep: endpoint {
remote-endpoint = <&hs_ep>;
port@1 {
reg = <1>;
usb3_role_switch: endpoint {
remote-endpoint = <&hd3ss3220_out_ep>;
-&xhci0 {
pinctrl-0 = <&usb30_pins>;
status = "okay";
-}; diff --git a/arch/arm/dts/r8a774c0-ek874.dts b/arch/arm/dts/r8a774c0-ek874.dts deleted file mode 100644 index e7b6619ab22..00000000000 --- a/arch/arm/dts/r8a774c0-ek874.dts +++ /dev/null @@ -1,14 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Device Tree Source for the Silicon Linux RZ/G2E evaluation kit (EK874)
-#include "r8a774c0-cat874.dts" -#include "cat875.dtsi"
model = "Silicon Linux RZ/G2E evaluation kit EK874 (CAT874 + CAT875)";
compatible = "si-linux,cat875", "si-linux,cat874", "renesas,r8a774c0";
-}; diff --git a/arch/arm/dts/r8a774c0.dtsi b/arch/arm/dts/r8a774c0.dtsi deleted file mode 100644 index ad2e87b039a..00000000000 --- a/arch/arm/dts/r8a774c0.dtsi +++ /dev/null @@ -1,2000 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Device Tree Source for the RZ/G2E (R8A774C0) SoC
- Copyright (C) 2018-2019 Renesas Electronics Corp.
-#include <dt-bindings/clock/r8a774c0-cpg-mssr.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/power/r8a774c0-sysc.h>
compatible = "renesas,r8a774c0";
#address-cells = <2>;
#size-cells = <2>;
* The external audio clocks are configured as 0 Hz fixed frequency
* clocks by default.
* Boards that provide audio clocks should override them.
audio_clk_a: audio_clk_a {
#clock-cells = <0>;
clock-frequency = <0>;
audio_clk_b: audio_clk_b {
#clock-cells = <0>;
audio_clk_c: audio_clk_c {
#clock-cells = <0>;
/* External CAN clock - to be overridden by boards that provide it */
can_clk: can {
#clock-cells = <0>;
cluster1_opp: opp-table-1 {
compatible = "operating-points-v2";
opp-shared;
opp-800000000 {
opp-hz = /bits/ 64 <800000000>;
clock-latency-ns = <300000>;
opp-1000000000 {
opp-hz = /bits/ 64 <1000000000>;
opp-1200000000 {
opp-hz = /bits/ 64 <1200000000>;
opp-suspend;
cpus {
#size-cells = <0>;
a53_0: cpu@0 {
compatible = "arm,cortex-a53";
reg = <0>;
device_type = "cpu";
#cooling-cells = <2>;
power-domains = <&sysc R8A774C0_PD_CA53_CPU0>;
next-level-cache = <&L2_CA53>;
enable-method = "psci";
dynamic-power-coefficient = <277>;
clocks = <&cpg CPG_CORE R8A774C0_CLK_Z2>;
operating-points-v2 = <&cluster1_opp>;
a53_1: cpu@1 {
reg = <1>;
power-domains = <&sysc R8A774C0_PD_CA53_CPU1>;
L2_CA53: cache-controller-0 {
compatible = "cache";
power-domains = <&sysc R8A774C0_PD_CA53_SCU>;
cache-unified;
cache-level = <2>;
extal_clk: extal {
#clock-cells = <0>;
/* This value must be overridden by the board */
/* External PCIe clock - can be overridden by the board */
pcie_bus_clk: pcie_bus {
#clock-cells = <0>;
pmu_a53 {
compatible = "arm,cortex-a53-pmu";
interrupts-extended = <&gic GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>,
<&gic GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>;
interrupt-affinity = <&a53_0>, <&a53_1>;
psci {
compatible = "arm,psci-1.0", "arm,psci-0.2";
method = "smc";
/* External SCIF clock - to be overridden by boards that provide it */
scif_clk: scif {
#clock-cells = <0>;
soc: soc {
compatible = "simple-bus";
interrupt-parent = <&gic>;
#size-cells = <2>;
ranges;
rwdt: watchdog@e6020000 {
compatible = "renesas,r8a774c0-wdt",
"renesas,rcar-gen3-wdt";
reg = <0 0xe6020000 0 0x0c>;
interrupts = <GIC_SPI 140 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 402>;
power-domains = <&sysc R8A774C0_PD_ALWAYS_ON>;
resets = <&cpg 402>;
gpio0: gpio@e6050000 {
compatible = "renesas,gpio-r8a774c0",
"renesas,rcar-gen3-gpio";
reg = <0 0xe6050000 0 0x50>;
interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 0 18>;
#interrupt-cells = <2>;
clocks = <&cpg CPG_MOD 912>;
resets = <&cpg 912>;
gpio1: gpio@e6051000 {
reg = <0 0xe6051000 0 0x50>;
interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 32 23>;
clocks = <&cpg CPG_MOD 911>;
resets = <&cpg 911>;
gpio2: gpio@e6052000 {
reg = <0 0xe6052000 0 0x50>;
interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 64 26>;
clocks = <&cpg CPG_MOD 910>;
resets = <&cpg 910>;
gpio3: gpio@e6053000 {
reg = <0 0xe6053000 0 0x50>;
interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 96 16>;
clocks = <&cpg CPG_MOD 909>;
resets = <&cpg 909>;
gpio4: gpio@e6054000 {
reg = <0 0xe6054000 0 0x50>;
interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 128 11>;
clocks = <&cpg CPG_MOD 908>;
resets = <&cpg 908>;
gpio5: gpio@e6055000 {
reg = <0 0xe6055000 0 0x50>;
interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 160 20>;
clocks = <&cpg CPG_MOD 907>;
resets = <&cpg 907>;
gpio6: gpio@e6055400 {
reg = <0 0xe6055400 0 0x50>;
interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 192 18>;
clocks = <&cpg CPG_MOD 906>;
resets = <&cpg 906>;
pfc: pinctrl@e6060000 {
compatible = "renesas,pfc-r8a774c0";
reg = <0 0xe6060000 0 0x508>;
cmt0: timer@e60f0000 {
compatible = "renesas,r8a774c0-cmt0",
"renesas,rcar-gen3-cmt0";
reg = <0 0xe60f0000 0 0x1004>;
interrupts = <GIC_SPI 142 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 143 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 303>;
resets = <&cpg 303>;
cmt1: timer@e6130000 {
compatible = "renesas,r8a774c0-cmt1",
"renesas,rcar-gen3-cmt1";
reg = <0 0xe6130000 0 0x1004>;
interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 127 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 302>;
resets = <&cpg 302>;
cmt2: timer@e6140000 {
reg = <0 0xe6140000 0 0x1004>;
interrupts = <GIC_SPI 398 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 405 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 301>;
resets = <&cpg 301>;
cmt3: timer@e6148000 {
reg = <0 0xe6148000 0 0x1004>;
interrupts = <GIC_SPI 470 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 471 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 472 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 473 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 474 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 475 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 476 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 477 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 300>;
resets = <&cpg 300>;
cpg: clock-controller@e6150000 {
compatible = "renesas,r8a774c0-cpg-mssr";
clocks = <&extal_clk>;
clock-names = "extal";
#clock-cells = <2>;
#power-domain-cells = <0>;
#reset-cells = <1>;
rst: reset-controller@e6160000 {
compatible = "renesas,r8a774c0-rst";
sysc: system-controller@e6180000 {
compatible = "renesas,r8a774c0-sysc";
reg = <0 0xe6180000 0 0x0400>;
#power-domain-cells = <1>;
thermal: thermal@e6190000 {
compatible = "renesas,thermal-r8a774c0";
reg = <0 0xe6190000 0 0x10>, <0 0xe6190100 0 0x38>;
interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>;
#thermal-sensor-cells = <0>;
intc_ex: interrupt-controller@e61c0000 {
compatible = "renesas,intc-ex-r8a774c0", "renesas,irqc";
reg = <0 0xe61c0000 0 0x200>;
interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 161 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 407>;
resets = <&cpg 407>;
tmu0: timer@e61e0000 {
compatible = "renesas,tmu-r8a774c0", "renesas,tmu";
reg = <0 0xe61e0000 0 0x30>;
interrupts = <GIC_SPI 136 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 137 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 138 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 125>;
resets = <&cpg 125>;
tmu1: timer@e6fc0000 {
reg = <0 0xe6fc0000 0 0x30>;
interrupts = <GIC_SPI 128 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 129 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 130 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 124>;
resets = <&cpg 124>;
tmu2: timer@e6fd0000 {
reg = <0 0xe6fd0000 0 0x30>;
interrupts = <GIC_SPI 303 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 304 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 305 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 123>;
resets = <&cpg 123>;
tmu3: timer@e6fe0000 {
reg = <0 0xe6fe0000 0 0x30>;
interrupts = <GIC_SPI 131 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 132 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 133 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 122>;
resets = <&cpg 122>;
tmu4: timer@ffc00000 {
reg = <0 0xffc00000 0 0x30>;
interrupts = <GIC_SPI 406 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 408 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 121>;
resets = <&cpg 121>;
i2c0: i2c@e6500000 {
#size-cells = <0>;
compatible = "renesas,i2c-r8a774c0",
"renesas,rcar-gen3-i2c";
reg = <0 0xe6500000 0 0x40>;
interrupts = <GIC_SPI 287 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 931>;
resets = <&cpg 931>;
dmas = <&dmac1 0x91>, <&dmac1 0x90>,
<&dmac2 0x91>, <&dmac2 0x90>;
i2c-scl-internal-delay-ns = <110>;
i2c1: i2c@e6508000 {
#size-cells = <0>;
reg = <0 0xe6508000 0 0x40>;
interrupts = <GIC_SPI 288 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 930>;
resets = <&cpg 930>;
dmas = <&dmac1 0x93>, <&dmac1 0x92>,
<&dmac2 0x93>, <&dmac2 0x92>;
i2c-scl-internal-delay-ns = <6>;
i2c2: i2c@e6510000 {
#size-cells = <0>;
reg = <0 0xe6510000 0 0x40>;
interrupts = <GIC_SPI 286 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 929>;
resets = <&cpg 929>;
dmas = <&dmac1 0x95>, <&dmac1 0x94>,
<&dmac2 0x95>, <&dmac2 0x94>;
i2c3: i2c@e66d0000 {
#size-cells = <0>;
reg = <0 0xe66d0000 0 0x40>;
interrupts = <GIC_SPI 290 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 928>;
resets = <&cpg 928>;
dmas = <&dmac0 0x97>, <&dmac0 0x96>;
i2c4: i2c@e66d8000 {
#size-cells = <0>;
reg = <0 0xe66d8000 0 0x40>;
interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 927>;
resets = <&cpg 927>;
dmas = <&dmac0 0x99>, <&dmac0 0x98>;
i2c5: i2c@e66e0000 {
#size-cells = <0>;
reg = <0 0xe66e0000 0 0x40>;
interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 919>;
resets = <&cpg 919>;
dmas = <&dmac0 0x9b>, <&dmac0 0x9a>;
i2c6: i2c@e66e8000 {
#size-cells = <0>;
reg = <0 0xe66e8000 0 0x40>;
interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 918>;
resets = <&cpg 918>;
dmas = <&dmac0 0x9d>, <&dmac0 0x9c>;
i2c7: i2c@e6690000 {
#size-cells = <0>;
reg = <0 0xe6690000 0 0x40>;
interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 1003>;
resets = <&cpg 1003>;
iic_pmic: i2c@e60b0000 {
#size-cells = <0>;
compatible = "renesas,iic-r8a774c0",
"renesas,rcar-gen3-iic",
"renesas,rmobile-iic";
reg = <0 0xe60b0000 0 0x425>;
interrupts = <GIC_SPI 173 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 926>;
resets = <&cpg 926>;
dmas = <&dmac0 0x11>, <&dmac0 0x10>;
hscif0: serial@e6540000 {
compatible = "renesas,hscif-r8a774c0",
"renesas,rcar-gen3-hscif",
"renesas,hscif";
reg = <0 0xe6540000 0 0x60>;
interrupts = <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 520>,
<&cpg CPG_CORE R8A774C0_CLK_S3D1C>,
<&scif_clk>;
dmas = <&dmac1 0x31>, <&dmac1 0x30>,
<&dmac2 0x31>, <&dmac2 0x30>;
resets = <&cpg 520>;
hscif1: serial@e6550000 {
"renesas,hscif";
reg = <0 0xe6550000 0 0x60>;
interrupts = <GIC_SPI 155 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 519>,
<&scif_clk>;
dmas = <&dmac1 0x33>, <&dmac1 0x32>,
<&dmac2 0x33>, <&dmac2 0x32>;
resets = <&cpg 519>;
hscif2: serial@e6560000 {
"renesas,hscif";
reg = <0 0xe6560000 0 0x60>;
interrupts = <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 518>,
<&scif_clk>;
dmas = <&dmac1 0x35>, <&dmac1 0x34>,
<&dmac2 0x35>, <&dmac2 0x34>;
resets = <&cpg 518>;
hscif3: serial@e66a0000 {
"renesas,hscif";
reg = <0 0xe66a0000 0 0x60>;
interrupts = <GIC_SPI 145 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 517>,
<&scif_clk>;
dmas = <&dmac0 0x37>, <&dmac0 0x36>;
resets = <&cpg 517>;
hscif4: serial@e66b0000 {
"renesas,hscif";
reg = <0 0xe66b0000 0 0x60>;
interrupts = <GIC_SPI 146 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 516>,
<&scif_clk>;
dmas = <&dmac0 0x39>, <&dmac0 0x38>;
resets = <&cpg 516>;
hsusb: usb@e6590000 {
compatible = "renesas,usbhs-r8a774c0",
"renesas,rcar-gen3-usbhs";
reg = <0 0xe6590000 0 0x200>;
interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 704>, <&cpg CPG_MOD 703>;
dmas = <&usb_dmac0 0>, <&usb_dmac0 1>,
<&usb_dmac1 0>, <&usb_dmac1 1>;
dma-names = "ch0", "ch1", "ch2", "ch3";
renesas,buswait = <11>;
phys = <&usb2_phy0 3>;
phy-names = "usb";
resets = <&cpg 704>, <&cpg 703>;
usb_dmac0: dma-controller@e65a0000 {
compatible = "renesas,r8a774c0-usb-dmac",
"renesas,usb-dmac";
reg = <0 0xe65a0000 0 0x100>;
interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "ch0", "ch1";
clocks = <&cpg CPG_MOD 330>;
resets = <&cpg 330>;
#dma-cells = <1>;
dma-channels = <2>;
usb_dmac1: dma-controller@e65b0000 {
"renesas,usb-dmac";
reg = <0 0xe65b0000 0 0x100>;
interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>;
#dma-cells = <1>;
dma-channels = <2>;
dmac0: dma-controller@e6700000 {
compatible = "renesas,dmac-r8a774c0",
"renesas,rcar-dmac";
reg = <0 0xe6700000 0 0x10000>;
interrupts = <GIC_SPI 199 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 200 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 201 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 202 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 203 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 204 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 205 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 206 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 207 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 208 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 209 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 211 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 212 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 213 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 214 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 215 IRQ_TYPE_LEVEL_HIGH>;
"ch0", "ch1", "ch2", "ch3",
"ch4", "ch5", "ch6", "ch7",
"ch8", "ch9", "ch10", "ch11",
"ch12", "ch13", "ch14", "ch15";
clocks = <&cpg CPG_MOD 219>;
resets = <&cpg 219>;
#dma-cells = <1>;
dmac1: dma-controller@e7300000 {
reg = <0 0xe7300000 0 0x10000>;
interrupts = <GIC_SPI 220 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 216 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 217 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 218 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 219 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 308 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 309 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 310 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 311 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 312 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 313 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 314 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 315 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 316 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 317 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 318 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 319 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 218>;
resets = <&cpg 218>;
#dma-cells = <1>;
iommus = <&ipmmu_ds1 0>, <&ipmmu_ds1 1>,
<&ipmmu_ds1 2>, <&ipmmu_ds1 3>,
<&ipmmu_ds1 4>, <&ipmmu_ds1 5>,
<&ipmmu_ds1 6>, <&ipmmu_ds1 7>,
<&ipmmu_ds1 8>, <&ipmmu_ds1 9>,
<&ipmmu_ds1 10>, <&ipmmu_ds1 11>,
<&ipmmu_ds1 12>, <&ipmmu_ds1 13>,
<&ipmmu_ds1 14>, <&ipmmu_ds1 15>;
dmac2: dma-controller@e7310000 {
reg = <0 0xe7310000 0 0x10000>;
interrupts = <GIC_SPI 416 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 417 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 418 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 419 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 420 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 421 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 422 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 423 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 424 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 425 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 426 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 427 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 428 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 429 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 430 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 431 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 397 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 217>;
resets = <&cpg 217>;
#dma-cells = <1>;
iommus = <&ipmmu_ds1 16>, <&ipmmu_ds1 17>,
<&ipmmu_ds1 18>, <&ipmmu_ds1 19>,
<&ipmmu_ds1 20>, <&ipmmu_ds1 21>,
<&ipmmu_ds1 22>, <&ipmmu_ds1 23>,
<&ipmmu_ds1 24>, <&ipmmu_ds1 25>,
<&ipmmu_ds1 26>, <&ipmmu_ds1 27>,
<&ipmmu_ds1 28>, <&ipmmu_ds1 29>,
<&ipmmu_ds1 30>, <&ipmmu_ds1 31>;
ipmmu_ds0: iommu@e6740000 {
compatible = "renesas,ipmmu-r8a774c0";
reg = <0 0xe6740000 0 0x1000>;
renesas,ipmmu-main = <&ipmmu_mm 0>;
#iommu-cells = <1>;
ipmmu_ds1: iommu@e7740000 {
reg = <0 0xe7740000 0 0x1000>;
renesas,ipmmu-main = <&ipmmu_mm 1>;
#iommu-cells = <1>;
ipmmu_hc: iommu@e6570000 {
reg = <0 0xe6570000 0 0x1000>;
renesas,ipmmu-main = <&ipmmu_mm 2>;
#iommu-cells = <1>;
ipmmu_mm: iommu@e67b0000 {
reg = <0 0xe67b0000 0 0x1000>;
interrupts = <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>;
#iommu-cells = <1>;
ipmmu_mp: iommu@ec670000 {
reg = <0 0xec670000 0 0x1000>;
renesas,ipmmu-main = <&ipmmu_mm 4>;
#iommu-cells = <1>;
ipmmu_pv0: iommu@fd800000 {
reg = <0 0xfd800000 0 0x1000>;
renesas,ipmmu-main = <&ipmmu_mm 6>;
#iommu-cells = <1>;
ipmmu_vc0: iommu@fe6b0000 {
reg = <0 0xfe6b0000 0 0x1000>;
power-domains = <&sysc R8A774C0_PD_A3VC>;
#iommu-cells = <1>;
ipmmu_vi0: iommu@febd0000 {
reg = <0 0xfebd0000 0 0x1000>;
#iommu-cells = <1>;
#iommu-cells = <1>;
avb: ethernet@e6800000 {
compatible = "renesas,etheravb-r8a774c0",
"renesas,etheravb-rcar-gen3";
reg = <0 0xe6800000 0 0x800>;
interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 47 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 63 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "ch0", "ch1", "ch2", "ch3",
"ch12", "ch13", "ch14", "ch15",
"ch16", "ch17", "ch18", "ch19",
"ch20", "ch21", "ch22", "ch23",
"ch24";
phy-mode = "rgmii";
rx-internal-delay-ps = <0>;
iommus = <&ipmmu_ds0 16>;
#size-cells = <0>;
can0: can@e6c30000 {
compatible = "renesas,can-r8a774c0",
"renesas,rcar-gen3-can";
reg = <0 0xe6c30000 0 0x1000>;
interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 916>,
<&cpg CPG_CORE R8A774C0_CLK_CANFD>,
<&can_clk>;
clock-names = "clkp1", "clkp2", "can_clk";
assigned-clocks = <&cpg CPG_CORE R8A774C0_CLK_CANFD>;
assigned-clock-rates = <40000000>;
resets = <&cpg 916>;
can1: can@e6c38000 {
reg = <0 0xe6c38000 0 0x1000>;
interrupts = <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 915>,
<&can_clk>;
resets = <&cpg 915>;
canfd: can@e66c0000 {
compatible = "renesas,r8a774c0-canfd",
"renesas,rcar-gen3-canfd";
reg = <0 0xe66c0000 0 0x8000>;
interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "ch_int", "g_int";
clocks = <&cpg CPG_MOD 914>,
<&can_clk>;
clock-names = "fck", "canfd", "can_clk";
resets = <&cpg 914>;
channel0 {
channel1 {
pwm0: pwm@e6e30000 {
compatible = "renesas,pwm-r8a774c0", "renesas,pwm-rcar";
reg = <0 0xe6e30000 0 0x8>;
clocks = <&cpg CPG_MOD 523>;
resets = <&cpg 523>;
#pwm-cells = <2>;
pwm1: pwm@e6e31000 {
reg = <0 0xe6e31000 0 0x8>;
#pwm-cells = <2>;
pwm2: pwm@e6e32000 {
reg = <0 0xe6e32000 0 0x8>;
#pwm-cells = <2>;
pwm3: pwm@e6e33000 {
reg = <0 0xe6e33000 0 0x8>;
#pwm-cells = <2>;
pwm4: pwm@e6e34000 {
reg = <0 0xe6e34000 0 0x8>;
#pwm-cells = <2>;
pwm5: pwm@e6e35000 {
reg = <0 0xe6e35000 0 0x8>;
#pwm-cells = <2>;
pwm6: pwm@e6e36000 {
reg = <0 0xe6e36000 0 0x8>;
#pwm-cells = <2>;
scif0: serial@e6e60000 {
compatible = "renesas,scif-r8a774c0",
"renesas,rcar-gen3-scif", "renesas,scif";
reg = <0 0xe6e60000 0 64>;
interrupts = <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 207>,
<&scif_clk>;
clock-names = "fck", "brg_int", "scif_clk";
dmas = <&dmac1 0x51>, <&dmac1 0x50>,
<&dmac2 0x51>, <&dmac2 0x50>;
resets = <&cpg 207>;
scif1: serial@e6e68000 {
reg = <0 0xe6e68000 0 64>;
interrupts = <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 206>,
<&scif_clk>;
dmas = <&dmac1 0x53>, <&dmac1 0x52>,
<&dmac2 0x53>, <&dmac2 0x52>;
resets = <&cpg 206>;
scif2: serial@e6e88000 {
reg = <0 0xe6e88000 0 64>;
interrupts = <GIC_SPI 164 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 310>,
<&scif_clk>;
dmas = <&dmac1 0x13>, <&dmac1 0x12>,
<&dmac2 0x13>, <&dmac2 0x12>;
resets = <&cpg 310>;
scif3: serial@e6c50000 {
reg = <0 0xe6c50000 0 64>;
interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 204>,
<&scif_clk>;
dmas = <&dmac0 0x57>, <&dmac0 0x56>;
resets = <&cpg 204>;
scif4: serial@e6c40000 {
reg = <0 0xe6c40000 0 64>;
interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 203>,
<&scif_clk>;
dmas = <&dmac0 0x59>, <&dmac0 0x58>;
resets = <&cpg 203>;
scif5: serial@e6f30000 {
reg = <0 0xe6f30000 0 64>;
interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 202>,
<&scif_clk>;
dmas = <&dmac0 0x5b>, <&dmac0 0x5a>;
resets = <&cpg 202>;
msiof0: spi@e6e90000 {
compatible = "renesas,msiof-r8a774c0",
"renesas,rcar-gen3-msiof";
reg = <0 0xe6e90000 0 0x0064>;
interrupts = <GIC_SPI 156 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 211>;
dmas = <&dmac1 0x41>, <&dmac1 0x40>,
<&dmac2 0x41>, <&dmac2 0x40>;
resets = <&cpg 211>;
#size-cells = <0>;
msiof1: spi@e6ea0000 {
reg = <0 0xe6ea0000 0 0x0064>;
interrupts = <GIC_SPI 157 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 210>;
dmas = <&dmac0 0x43>, <&dmac0 0x42>;
resets = <&cpg 210>;
#size-cells = <0>;
msiof2: spi@e6c00000 {
reg = <0 0xe6c00000 0 0x0064>;
interrupts = <GIC_SPI 158 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 209>;
dmas = <&dmac0 0x45>, <&dmac0 0x44>;
resets = <&cpg 209>;
#size-cells = <0>;
interrupts = <GIC_SPI 159 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 208>;
dmas = <&dmac0 0x47>, <&dmac0 0x46>;
resets = <&cpg 208>;
#size-cells = <0>;
vin4: video@e6ef4000 {
compatible = "renesas,vin-r8a774c0";
interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>;
renesas,id = <4>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
vin4csi40: endpoint@2 {
reg = <2>;
remote-endpoint = <&csi40vin4>;
vin5: video@e6ef5000 {
interrupts = <GIC_SPI 175 IRQ_TYPE_LEVEL_HIGH>;
renesas,id = <5>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
vin5csi40: endpoint@2 {
reg = <2>;
remote-endpoint = <&csi40vin5>;
rcar_sound: sound@ec500000 {
* #sound-dai-cells is required if simple-card
* #clock-cells is required for audio_clkout0/1/2/3
* clkout0/1/2/3: #clock-cells = <1>; <&rcar_sound N>;
compatible = "renesas,rcar_sound-r8a774c0",
reg = <0 0xec500000 0 0x1000>, /* SCU */
<0 0xec5a0000 0 0x100>, /* ADG */
<0 0xec540000 0 0x1000>, /* SSIU */
<0 0xec541000 0 0x280>, /* SSI */
<0 0xec760000 0 0x200>; /* Audio DMAC peri peri*/
reg-names = "scu", "adg", "ssiu", "ssi", "audmapp";
clocks = <&cpg CPG_MOD 1005>,
<&cpg CPG_MOD 1006>, <&cpg CPG_MOD 1007>,
<&cpg CPG_MOD 1008>, <&cpg CPG_MOD 1009>,
<&cpg CPG_MOD 1010>, <&cpg CPG_MOD 1011>,
<&cpg CPG_MOD 1012>, <&cpg CPG_MOD 1013>,
<&cpg CPG_MOD 1014>, <&cpg CPG_MOD 1015>,
<&cpg CPG_MOD 1022>, <&cpg CPG_MOD 1023>,
<&cpg CPG_MOD 1024>, <&cpg CPG_MOD 1025>,
<&cpg CPG_MOD 1026>, <&cpg CPG_MOD 1027>,
<&cpg CPG_MOD 1028>, <&cpg CPG_MOD 1029>,
<&cpg CPG_MOD 1030>, <&cpg CPG_MOD 1031>,
<&cpg CPG_MOD 1020>, <&cpg CPG_MOD 1021>,
<&cpg CPG_MOD 1019>, <&cpg CPG_MOD 1018>,
<&audio_clk_a>, <&audio_clk_b>,
<&audio_clk_c>,
<&cpg CPG_CORE R8A774C0_CLK_ZA2>;
clock-names = "ssi-all",
"ssi.9", "ssi.8", "ssi.7", "ssi.6",
"ssi.5", "ssi.4", "ssi.3", "ssi.2",
"ssi.1", "ssi.0",
"src.9", "src.8", "src.7", "src.6",
"src.5", "src.4", "src.3", "src.2",
"src.1", "src.0",
"mix.1", "mix.0",
"ctu.1", "ctu.0",
"dvc.0", "dvc.1",
"clk_a", "clk_b", "clk_c", "clk_i";
resets = <&cpg 1005>,
<&cpg 1006>, <&cpg 1007>,
<&cpg 1008>, <&cpg 1009>,
<&cpg 1010>, <&cpg 1011>,
<&cpg 1012>, <&cpg 1013>,
<&cpg 1014>, <&cpg 1015>;
reset-names = "ssi-all",
"ssi.1", "ssi.0";
rcar_sound,ctu {
ctu00: ctu-0 { };
ctu01: ctu-1 { };
ctu02: ctu-2 { };
ctu03: ctu-3 { };
ctu10: ctu-4 { };
ctu11: ctu-5 { };
ctu12: ctu-6 { };
ctu13: ctu-7 { };
rcar_sound,dvc {
dvc0: dvc-0 {
dmas = <&audma0 0xbc>;
dma-names = "tx";
dvc1: dvc-1 {
dmas = <&audma0 0xbe>;
dma-names = "tx";
rcar_sound,mix {
mix0: mix-0 { };
mix1: mix-1 { };
rcar_sound,src {
src0: src-0 {
interrupts = <GIC_SPI 352 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x85>, <&audma0 0x9a>;
dma-names = "rx", "tx";
src1: src-1 {
interrupts = <GIC_SPI 353 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x87>, <&audma0 0x9c>;
src2: src-2 {
interrupts = <GIC_SPI 354 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x89>, <&audma0 0x9e>;
src3: src-3 {
interrupts = <GIC_SPI 355 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x8b>, <&audma0 0xa0>;
src4: src-4 {
interrupts = <GIC_SPI 356 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x8d>, <&audma0 0xb0>;
src5: src-5 {
interrupts = <GIC_SPI 357 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x8f>, <&audma0 0xb2>;
src6: src-6 {
interrupts = <GIC_SPI 358 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x91>, <&audma0 0xb4>;
src7: src-7 {
interrupts = <GIC_SPI 359 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x93>, <&audma0 0xb6>;
src8: src-8 {
interrupts = <GIC_SPI 360 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x95>, <&audma0 0xb8>;
src9: src-9 {
interrupts = <GIC_SPI 361 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x97>, <&audma0 0xba>;
rcar_sound,ssi {
ssi0: ssi-0 {
interrupts = <GIC_SPI 370 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x01>, <&audma0 0x02>,
<&audma0 0x15>, <&audma0 0x16>;
dma-names = "rx", "tx", "rxu", "txu";
ssi1: ssi-1 {
interrupts = <GIC_SPI 371 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x03>, <&audma0 0x04>,
<&audma0 0x49>, <&audma0 0x4a>;
ssi2: ssi-2 {
interrupts = <GIC_SPI 372 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x05>, <&audma0 0x06>,
<&audma0 0x63>, <&audma0 0x64>;
ssi3: ssi-3 {
interrupts = <GIC_SPI 373 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x07>, <&audma0 0x08>,
<&audma0 0x6f>, <&audma0 0x70>;
ssi4: ssi-4 {
interrupts = <GIC_SPI 374 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x09>, <&audma0 0x0a>,
<&audma0 0x71>, <&audma0 0x72>;
ssi5: ssi-5 {
interrupts = <GIC_SPI 375 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x0b>, <&audma0 0x0c>,
<&audma0 0x73>, <&audma0 0x74>;
ssi6: ssi-6 {
interrupts = <GIC_SPI 376 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x0d>, <&audma0 0x0e>,
<&audma0 0x75>, <&audma0 0x76>;
ssi7: ssi-7 {
interrupts = <GIC_SPI 377 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x0f>, <&audma0 0x10>,
<&audma0 0x79>, <&audma0 0x7a>;
ssi8: ssi-8 {
interrupts = <GIC_SPI 378 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x11>, <&audma0 0x12>,
<&audma0 0x7b>, <&audma0 0x7c>;
ssi9: ssi-9 {
interrupts = <GIC_SPI 379 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x13>, <&audma0 0x14>,
<&audma0 0x7d>, <&audma0 0x7e>;
#dma-cells = <1>;
compatible = "renesas,xhci-r8a774c0",
resets = <&cpg 328>;
compatible = "renesas,r8a774c0-usb3-peri",
phy-names = "usb";
resets = <&cpg 703>, <&cpg 704>;
phy-names = "usb";
compatible = "renesas,usb2-phy-r8a774c0",
#phy-cells = <1>;
compatible = "renesas,sdhi-r8a774c0",
clocks = <&cpg CPG_MOD 314>, <&cpg CPG_CORE R8A774C0_CLK_SD0H>;
clocks = <&cpg CPG_MOD 313>, <&cpg CPG_CORE R8A774C0_CLK_SD1H>;
clocks = <&cpg CPG_MOD 311>, <&cpg CPG_CORE R8A774C0_CLK_SD3H>;
rpc: spi@ee200000 {
compatible = "renesas,r8a774c0-rpc-if",
#size-cells = <0>;
compatible = "renesas,pcie-r8a774c0",
#size-cells = <2>;
compatible = "renesas,r8a774c0-pcie-ep",
vspb0: vsp@fe960000 {
reg = <0 0xfea20000 0 0x7000>;
reg = <0 0xfea28000 0 0x7000>;
iommus = <&ipmmu_vp0 5>;
iommus = <&ipmmu_vp0 8>;
compatible = "renesas,r8a774c0-csi2";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
csi40vin4: endpoint@0 {
reg = <0>;
csi40vin5: endpoint@1 {
reg = <1>;
compatible = "renesas,du-r8a774c0";
reg = <0 0xfeb00000 0 0x40000>;
<GIC_SPI 268 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 724>, <&cpg CPG_MOD 723>;
clock-names = "du.0", "du.1";
resets = <&cpg 724>;
reset-names = "du.0";
renesas,vsps = <&vspd0 0>, <&vspd1 0>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port@1 {
reg = <1>;
port@2 {
reg = <2>;
du_out_lvds1: endpoint {
remote-endpoint = <&lvds1_in>;
lvds0: lvds-encoder@feb90000 {
compatible = "renesas,r8a774c0-lvds";
reg = <0 0xfeb90000 0 0x20>;
renesas,companion = <&lvds1>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port@1 {
reg = <1>;
lvds1: lvds-encoder@feb90100 {
reg = <0 0xfeb90100 0 0x20>;
resets = <&cpg 726>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
lvds1_in: endpoint {
remote-endpoint = <&du_out_lvds1>;
port@1 {
reg = <1>;
thermal-zones {
cpu-thermal {
polling-delay = <0>;
thermal-sensors = <&thermal>;
sustainable-power = <717>;
cooling-maps {
map0 {
trip = <&target>;
trips {
hysteresis = <2000>;
type = "critical";
type = "passive";
timer {
#clock-cells = <0>;
#clock-cells = <0>;
-}; diff --git a/arch/arm/dts/r8a774e1-beacon-rzg2h-kit.dts b/arch/arm/dts/r8a774e1-beacon-rzg2h-kit.dts deleted file mode 100644 index 146f78cb6f1..00000000000 --- a/arch/arm/dts/r8a774e1-beacon-rzg2h-kit.dts +++ /dev/null @@ -1,61 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Copyright 2020, Compass Electronics Group, LLC
-/dts-v1/;
-#include "r8a774e1.dtsi" -#include "beacon-renesom-som.dtsi" -#include "beacon-renesom-baseboard.dtsi"
model = "Beacon Embedded Works RZ/G2H Development Kit";
compatible = "beacon,beacon-rzg2h", "renesas,r8a774e1";
aliases {
i2c0 = &i2c0;
i2c1 = &i2c1;
i2c2 = &i2c2;
i2c3 = &i2c3;
i2c4 = &i2c4;
i2c5 = &i2c5;
i2c6 = &i2c6;
i2c7 = &iic_pmic;
serial0 = &scif2;
serial1 = &hscif0;
serial2 = &hscif1;
serial3 = &scif0;
serial4 = &hscif2;
serial5 = &scif5;
serial6 = &scif4;
ethernet0 = &avb;
mmc0 = &sdhi3;
mmc1 = &sdhi0;
mmc2 = &sdhi2;
chosen {
memory@500000000 {
reg = <0x5 0x00000000 0x0 0x80000000>;
-&du {
status = "okay";
<&cpg CPG_MOD 723>,
<&cpg CPG_MOD 721>,
<&versaclock5 1>,
<&x302_clk>,
<&versaclock5 2>;
-}; diff --git a/arch/arm/dts/r8a774e1-hihope-rzg2h-ex.dts b/arch/arm/dts/r8a774e1-hihope-rzg2h-ex.dts deleted file mode 100644 index 81299593984..00000000000 --- a/arch/arm/dts/r8a774e1-hihope-rzg2h-ex.dts +++ /dev/null @@ -1,20 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Device Tree Source for the HiHope RZ/G2H sub board
- Copyright (C) 2020 Renesas Electronics Corp.
-#include "r8a774e1-hihope-rzg2h.dts" -#include "hihope-rzg2-ex.dtsi"
model = "HopeRun HiHope RZ/G2H with sub board";
compatible = "hoperun,hihope-rzg2-ex", "hoperun,hihope-rzg2h",
"renesas,r8a774e1";
status = "okay";
-}; diff --git a/arch/arm/dts/r8a774e1-hihope-rzg2h.dts b/arch/arm/dts/r8a774e1-hihope-rzg2h.dts deleted file mode 100644 index 9525d5ed6fc..00000000000 --- a/arch/arm/dts/r8a774e1-hihope-rzg2h.dts +++ /dev/null @@ -1,41 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Device Tree Source for the HiHope RZ/G2H main board
-/dts-v1/; -#include "r8a774e1.dtsi" -#include "hihope-rev4.dtsi"
model = "HopeRun HiHope RZ/G2H main board based on r8a774e1";
compatible = "hoperun,hihope-rzg2h", "renesas,r8a774e1";
memory@48000000 {
memory@500000000 {
-&du {
<&cpg CPG_MOD 723>,
<&cpg CPG_MOD 721>,
<&versaclock5 1>,
<&x302_clk>,
<&versaclock5 2>;
-&sdhi3 {
mmc-hs400-1_8v;
-}; diff --git a/arch/arm/dts/r8a774e1.dtsi b/arch/arm/dts/r8a774e1.dtsi deleted file mode 100644 index 2acf4067ab2..00000000000 --- a/arch/arm/dts/r8a774e1.dtsi +++ /dev/null @@ -1,2997 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Device Tree Source for the r8a774e1 SoC
-#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/clock/r8a774e1-cpg-mssr.h> -#include <dt-bindings/power/r8a774e1-sysc.h>
-#define CPG_AUDIO_CLK_I R8A774E1_CLK_S0D4
compatible = "renesas,r8a774e1";
#size-cells = <2>;
#clock-cells = <0>;
#clock-cells = <0>;
#clock-cells = <0>;
can_clk: can {
#clock-cells = <0>;
cluster0_opp: opp-table-0 {
opp-shared;
opp-500000000 {
opp-hz = /bits/ 64 <500000000>;
opp-microvolt = <820000>;
opp-1000000000 {
opp-1500000000 {
opp-hz = /bits/ 64 <1500000000>;
opp-suspend;
opp-shared;
opp-800000000 {
opp-1000000000 {
opp-1200000000 {
cpus {
#size-cells = <0>;
cpu-map {
cluster0 {
core0 {
cpu = <&a57_0>;
core1 {
cpu = <&a57_1>;
core2 {
cpu = <&a57_2>;
core3 {
cpu = <&a57_3>;
cluster1 {
core0 {
cpu = <&a53_0>;
core1 {
cpu = <&a53_1>;
core2 {
cpu = <&a53_2>;
core3 {
cpu = <&a53_3>;
a57_0: cpu@0 {
compatible = "arm,cortex-a57";
reg = <0x0>;
power-domains = <&sysc R8A774E1_PD_CA57_CPU0>;
next-level-cache = <&L2_CA57>;
cpu-idle-states = <&CPU_SLEEP_0>;
dynamic-power-coefficient = <854>;
clocks = <&cpg CPG_CORE R8A774E1_CLK_Z>;
operating-points-v2 = <&cluster0_opp>;
capacity-dmips-mhz = <1024>;
a57_1: cpu@1 {
reg = <0x1>;
power-domains = <&sysc R8A774E1_PD_CA57_CPU1>;
a57_2: cpu@2 {
reg = <0x2>;
power-domains = <&sysc R8A774E1_PD_CA57_CPU2>;
a57_3: cpu@3 {
reg = <0x3>;
power-domains = <&sysc R8A774E1_PD_CA57_CPU3>;
a53_0: cpu@100 {
reg = <0x100>;
power-domains = <&sysc R8A774E1_PD_CA53_CPU0>;
cpu-idle-states = <&CPU_SLEEP_1>;
clocks = <&cpg CPG_CORE R8A774E1_CLK_Z2>;
capacity-dmips-mhz = <535>;
a53_1: cpu@101 {
reg = <0x101>;
power-domains = <&sysc R8A774E1_PD_CA53_CPU1>;
a53_2: cpu@102 {
reg = <0x102>;
power-domains = <&sysc R8A774E1_PD_CA53_CPU2>;
a53_3: cpu@103 {
reg = <0x103>;
power-domains = <&sysc R8A774E1_PD_CA53_CPU3>;
L2_CA57: cache-controller-0 {
power-domains = <&sysc R8A774E1_PD_CA57_SCU>;
cache-unified;
cache-level = <2>;
L2_CA53: cache-controller-1 {
power-domains = <&sysc R8A774E1_PD_CA53_SCU>;
cache-unified;
cache-level = <2>;
idle-states {
entry-method = "psci";
CPU_SLEEP_0: cpu-sleep-0 {
compatible = "arm,idle-state";
arm,psci-suspend-param = <0x0010000>;
local-timer-stop;
entry-latency-us = <400>;
exit-latency-us = <500>;
min-residency-us = <4000>;
CPU_SLEEP_1: cpu-sleep-1 {
local-timer-stop;
entry-latency-us = <700>;
exit-latency-us = <700>;
min-residency-us = <5000>;
extal_clk: extal {
#clock-cells = <0>;
extalr_clk: extalr {
#clock-cells = <0>;
#clock-cells = <0>;
pmu_a53 {
<&gic GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>,
<&gic GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>,
<&gic GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>;
interrupt-affinity = <&a53_0>, <&a53_1>, <&a53_2>, <&a53_3>;
pmu_a57 {
compatible = "arm,cortex-a57-pmu";
interrupts-extended = <&gic GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>,
<&gic GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>,
<&gic GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>,
<&gic GIC_SPI 75 IRQ_TYPE_LEVEL_HIGH>;
interrupt-affinity = <&a57_0>, <&a57_1>, <&a57_2>, <&a57_3>;
psci {
method = "smc";
scif_clk: scif {
#clock-cells = <0>;
soc {
#size-cells = <2>;
ranges;
compatible = "renesas,r8a774e1-wdt",
power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>;
compatible = "renesas,gpio-r8a774e1",
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 0 16>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 32 29>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 64 15>;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 128 18>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 160 26>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 192 32>;
gpio7: gpio@e6055800 {
reg = <0 0xe6055800 0 0x50>;
interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 224 4>;
clocks = <&cpg CPG_MOD 905>;
resets = <&cpg 905>;
compatible = "renesas,pfc-r8a774e1";
reg = <0 0xe6060000 0 0x50c>;
compatible = "renesas,r8a774e1-cmt0",
compatible = "renesas,r8a774e1-cmt1",
compatible = "renesas,r8a774e1-cpg-mssr";
clocks = <&extal_clk>, <&extalr_clk>;
clock-names = "extal", "extalr";
#clock-cells = <2>;
#reset-cells = <1>;
compatible = "renesas,r8a774e1-rst";
compatible = "renesas,r8a774e1-sysc";
tsc: thermal@e6198000 {
compatible = "renesas,r8a774e1-thermal";
reg = <0 0xe6198000 0 0x100>,
<0 0xe61a0000 0 0x100>,
<0 0xe61a8000 0 0x100>;
#thermal-sensor-cells = <1>;
compatible = "renesas,intc-ex-r8a774e1", "renesas,irqc";
compatible = "renesas,tmu-r8a774e1", "renesas,tmu";
#size-cells = <0>;
compatible = "renesas,i2c-r8a774e1",
#size-cells = <0>;
#size-cells = <0>;
#size-cells = <0>;
#size-cells = <0>;
#size-cells = <0>;
#size-cells = <0>;
#size-cells = <0>;
compatible = "renesas,iic-r8a774e1",
compatible = "renesas,hscif-r8a774e1",
"renesas,hscif";
<&cpg CPG_CORE R8A774E1_CLK_S3D1>,
<&scif_clk>;
"renesas,hscif";
<&scif_clk>;
"renesas,hscif";
<&scif_clk>;
"renesas,hscif";
<&scif_clk>;
"renesas,hscif";
<&scif_clk>;
compatible = "renesas,usbhs-r8a774e1",
phy-names = "usb";
usb2_clksel: clock-controller@e6590630 {
compatible = "renesas,r8a774e1-rcar-usb2-clock-sel",
"renesas,rcar-gen3-usb2-clock-sel";
reg = <0 0xe6590630 0 0x02>;
clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>,
<&usb_extal_clk>, <&usb3s0_clk>;
clock-names = "ehci_ohci", "hs-usb-if",
"usb_extal", "usb_xtal";
#clock-cells = <0>;
reset-names = "ehci_ohci", "hs-usb-if";
compatible = "renesas,r8a774e1-usb-dmac",
"renesas,usb-dmac";
#dma-cells = <1>;
dma-channels = <2>;
"renesas,usb-dmac";
#dma-cells = <1>;
dma-channels = <2>;
usb3_phy0: usb-phy@e65ee000 {
compatible = "renesas,r8a774e1-usb3-phy",
"renesas,rcar-gen3-usb3-phy";
reg = <0 0xe65ee000 0 0x90>;
clocks = <&cpg CPG_MOD 328>, <&usb3s0_clk>,
<&usb_extal_clk>;
clock-names = "usb3-if", "usb3s_clk", "usb_extal";
#phy-cells = <0>;
compatible = "renesas,dmac-r8a774e1",
#dma-cells = <1>;
#dma-cells = <1>;
#dma-cells = <1>;
compatible = "renesas,ipmmu-r8a774e1";
#iommu-cells = <1>;
#iommu-cells = <1>;
#iommu-cells = <1>;
#iommu-cells = <1>;
ipmmu_mp0: iommu@ec670000 {
#iommu-cells = <1>;
#iommu-cells = <1>;
ipmmu_pv1: iommu@fd950000 {
reg = <0 0xfd950000 0 0x1000>;
renesas,ipmmu-main = <&ipmmu_mm 7>;
#iommu-cells = <1>;
ipmmu_pv2: iommu@fd960000 {
reg = <0 0xfd960000 0 0x1000>;
renesas,ipmmu-main = <&ipmmu_mm 8>;
#iommu-cells = <1>;
ipmmu_pv3: iommu@fd970000 {
reg = <0 0xfd970000 0 0x1000>;
renesas,ipmmu-main = <&ipmmu_mm 9>;
#iommu-cells = <1>;
power-domains = <&sysc R8A774E1_PD_A3VC>;
#iommu-cells = <1>;
ipmmu_vc1: iommu@fe6f0000 {
reg = <0 0xfe6f0000 0 0x1000>;
renesas,ipmmu-main = <&ipmmu_mm 13>;
#iommu-cells = <1>;
#iommu-cells = <1>;
ipmmu_vi1: iommu@febe0000 {
reg = <0 0xfebe0000 0 0x1000>;
renesas,ipmmu-main = <&ipmmu_mm 15>;
#iommu-cells = <1>;
power-domains = <&sysc R8A774E1_PD_A3VP>;
#iommu-cells = <1>;
ipmmu_vp1: iommu@fe980000 {
reg = <0 0xfe980000 0 0x1000>;
renesas,ipmmu-main = <&ipmmu_mm 17>;
#iommu-cells = <1>;
compatible = "renesas,etheravb-r8a774e1",
"ch24";
phy-mode = "rgmii";
tx-internal-delay-ps = <0>;
#size-cells = <0>;
compatible = "renesas,can-r8a774e1",
<&cpg CPG_CORE R8A774E1_CLK_CANFD>,
<&can_clk>;
assigned-clocks = <&cpg CPG_CORE R8A774E1_CLK_CANFD>;
<&can_clk>;
compatible = "renesas,r8a774e1-canfd",
<&can_clk>;
channel0 {
channel1 {
compatible = "renesas,pwm-r8a774e1", "renesas,pwm-rcar";
#pwm-cells = <2>;
#pwm-cells = <2>;
#pwm-cells = <2>;
#pwm-cells = <2>;
#pwm-cells = <2>;
#pwm-cells = <2>;
#pwm-cells = <2>;
compatible = "renesas,scif-r8a774e1",
reg = <0 0xe6e60000 0 0x40>;
<&scif_clk>;
reg = <0 0xe6e68000 0 0x40>;
<&scif_clk>;
reg = <0 0xe6e88000 0 0x40>;
<&scif_clk>;
reg = <0 0xe6c50000 0 0x40>;
<&scif_clk>;
reg = <0 0xe6c40000 0 0x40>;
<&scif_clk>;
reg = <0 0xe6f30000 0 0x40>;
<&scif_clk>;
dmas = <&dmac1 0x5b>, <&dmac1 0x5a>,
<&dmac2 0x5b>, <&dmac2 0x5a>;
compatible = "renesas,msiof-r8a774e1",
#size-cells = <0>;
dmas = <&dmac1 0x43>, <&dmac1 0x42>,
<&dmac2 0x43>, <&dmac2 0x42>;
#size-cells = <0>;
#size-cells = <0>;
#size-cells = <0>;
vin0: video@e6ef0000 {
compatible = "renesas,vin-r8a774e1";
interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>;
renesas,id = <0>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
vin0csi20: endpoint@0 {
reg = <0>;
remote-endpoint = <&csi20vin0>;
vin0csi40: endpoint@2 {
reg = <2>;
remote-endpoint = <&csi40vin0>;
vin1: video@e6ef1000 {
interrupts = <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH>;
renesas,id = <1>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
vin1csi20: endpoint@0 {
reg = <0>;
remote-endpoint = <&csi20vin1>;
vin1csi40: endpoint@2 {
reg = <2>;
remote-endpoint = <&csi40vin1>;
vin2: video@e6ef2000 {
interrupts = <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>;
renesas,id = <2>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
vin2csi20: endpoint@0 {
reg = <0>;
remote-endpoint = <&csi20vin2>;
vin2csi40: endpoint@2 {
reg = <2>;
remote-endpoint = <&csi40vin2>;
vin3: video@e6ef3000 {
interrupts = <GIC_SPI 191 IRQ_TYPE_LEVEL_HIGH>;
renesas,id = <3>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
vin3csi20: endpoint@0 {
reg = <0>;
remote-endpoint = <&csi20vin3>;
vin3csi40: endpoint@2 {
reg = <2>;
remote-endpoint = <&csi40vin3>;
renesas,id = <4>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
vin4csi20: endpoint@0 {
reg = <0>;
remote-endpoint = <&csi20vin4>;
renesas,id = <5>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
vin5csi20: endpoint@0 {
reg = <0>;
remote-endpoint = <&csi20vin5>;
vin6: video@e6ef6000 {
interrupts = <GIC_SPI 176 IRQ_TYPE_LEVEL_HIGH>;
renesas,id = <6>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
vin6csi20: endpoint@0 {
reg = <0>;
remote-endpoint = <&csi20vin6>;
vin7: video@e6ef7000 {
interrupts = <GIC_SPI 171 IRQ_TYPE_LEVEL_HIGH>;
renesas,id = <7>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
vin7csi20: endpoint@0 {
reg = <0>;
remote-endpoint = <&csi20vin7>;
compatible = "renesas,rcar_sound-r8a774e1", "renesas,rcar_sound-gen3";
<&audio_clk_c>,
<&cpg CPG_CORE R8A774E1_CLK_S0D4>;
"ssi.1", "ssi.0",
"src.1", "src.0",
"mix.1", "mix.0",
"ctu.1", "ctu.0",
"dvc.0", "dvc.1",
"ssi.1", "ssi.0";
rcar_sound,dvc {
dvc0: dvc-0 {
dmas = <&audma1 0xbc>;
dma-names = "tx";
dvc1: dvc-1 {
dmas = <&audma1 0xbe>;
dma-names = "tx";
rcar_sound,mix {
mix0: mix-0 { };
mix1: mix-1 { };
rcar_sound,ctu {
ctu00: ctu-0 { };
ctu01: ctu-1 { };
ctu02: ctu-2 { };
ctu03: ctu-3 { };
ctu10: ctu-4 { };
ctu11: ctu-5 { };
ctu12: ctu-6 { };
ctu13: ctu-7 { };
rcar_sound,src {
src0: src-0 {
dmas = <&audma0 0x85>, <&audma1 0x9a>;
src1: src-1 {
dmas = <&audma0 0x87>, <&audma1 0x9c>;
src2: src-2 {
dmas = <&audma0 0x89>, <&audma1 0x9e>;
src3: src-3 {
dmas = <&audma0 0x8b>, <&audma1 0xa0>;
src4: src-4 {
dmas = <&audma0 0x8d>, <&audma1 0xb0>;
src5: src-5 {
dmas = <&audma0 0x8f>, <&audma1 0xb2>;
src6: src-6 {
dmas = <&audma0 0x91>, <&audma1 0xb4>;
src7: src-7 {
dmas = <&audma0 0x93>, <&audma1 0xb6>;
src8: src-8 {
dmas = <&audma0 0x95>, <&audma1 0xb8>;
src9: src-9 {
dmas = <&audma0 0x97>, <&audma1 0xba>;
rcar_sound,ssiu {
ssiu00: ssiu-0 {
dmas = <&audma0 0x15>, <&audma1 0x16>;
ssiu01: ssiu-1 {
dmas = <&audma0 0x35>, <&audma1 0x36>;
ssiu02: ssiu-2 {
dmas = <&audma0 0x37>, <&audma1 0x38>;
ssiu03: ssiu-3 {
dmas = <&audma0 0x47>, <&audma1 0x48>;
ssiu04: ssiu-4 {
dmas = <&audma0 0x3F>, <&audma1 0x40>;
ssiu05: ssiu-5 {
dmas = <&audma0 0x43>, <&audma1 0x44>;
ssiu06: ssiu-6 {
dmas = <&audma0 0x4F>, <&audma1 0x50>;
ssiu07: ssiu-7 {
dmas = <&audma0 0x53>, <&audma1 0x54>;
ssiu10: ssiu-8 {
dmas = <&audma0 0x49>, <&audma1 0x4a>;
ssiu11: ssiu-9 {
dmas = <&audma0 0x4B>, <&audma1 0x4C>;
ssiu12: ssiu-10 {
dmas = <&audma0 0x57>, <&audma1 0x58>;
ssiu13: ssiu-11 {
dmas = <&audma0 0x59>, <&audma1 0x5A>;
ssiu14: ssiu-12 {
dmas = <&audma0 0x5F>, <&audma1 0x60>;
ssiu15: ssiu-13 {
dmas = <&audma0 0xC3>, <&audma1 0xC4>;
ssiu16: ssiu-14 {
dmas = <&audma0 0xC7>, <&audma1 0xC8>;
ssiu17: ssiu-15 {
dmas = <&audma0 0xCB>, <&audma1 0xCC>;
ssiu20: ssiu-16 {
dmas = <&audma0 0x63>, <&audma1 0x64>;
ssiu21: ssiu-17 {
dmas = <&audma0 0x67>, <&audma1 0x68>;
ssiu22: ssiu-18 {
dmas = <&audma0 0x6B>, <&audma1 0x6C>;
ssiu23: ssiu-19 {
dmas = <&audma0 0x6D>, <&audma1 0x6E>;
ssiu24: ssiu-20 {
dmas = <&audma0 0xCF>, <&audma1 0xCE>;
ssiu25: ssiu-21 {
dmas = <&audma0 0xEB>, <&audma1 0xEC>;
ssiu26: ssiu-22 {
dmas = <&audma0 0xED>, <&audma1 0xEE>;
ssiu27: ssiu-23 {
dmas = <&audma0 0xEF>, <&audma1 0xF0>;
ssiu30: ssiu-24 {
dmas = <&audma0 0x6f>, <&audma1 0x70>;
ssiu31: ssiu-25 {
dmas = <&audma0 0x21>, <&audma1 0x22>;
ssiu32: ssiu-26 {
dmas = <&audma0 0x23>, <&audma1 0x24>;
ssiu33: ssiu-27 {
dmas = <&audma0 0x25>, <&audma1 0x26>;
ssiu34: ssiu-28 {
dmas = <&audma0 0x27>, <&audma1 0x28>;
ssiu35: ssiu-29 {
dmas = <&audma0 0x29>, <&audma1 0x2A>;
ssiu36: ssiu-30 {
dmas = <&audma0 0x2B>, <&audma1 0x2C>;
ssiu37: ssiu-31 {
dmas = <&audma0 0x2D>, <&audma1 0x2E>;
ssiu40: ssiu-32 {
dmas = <&audma0 0x71>, <&audma1 0x72>;
ssiu41: ssiu-33 {
dmas = <&audma0 0x17>, <&audma1 0x18>;
ssiu42: ssiu-34 {
dmas = <&audma0 0x19>, <&audma1 0x1A>;
ssiu43: ssiu-35 {
dmas = <&audma0 0x1B>, <&audma1 0x1C>;
ssiu44: ssiu-36 {
dmas = <&audma0 0x1D>, <&audma1 0x1E>;
ssiu45: ssiu-37 {
dmas = <&audma0 0x1F>, <&audma1 0x20>;
ssiu46: ssiu-38 {
dmas = <&audma0 0x31>, <&audma1 0x32>;
ssiu47: ssiu-39 {
dmas = <&audma0 0x33>, <&audma1 0x34>;
ssiu50: ssiu-40 {
dmas = <&audma0 0x73>, <&audma1 0x74>;
ssiu60: ssiu-41 {
dmas = <&audma0 0x75>, <&audma1 0x76>;
ssiu70: ssiu-42 {
dmas = <&audma0 0x79>, <&audma1 0x7a>;
ssiu80: ssiu-43 {
dmas = <&audma0 0x7b>, <&audma1 0x7c>;
ssiu90: ssiu-44 {
dmas = <&audma0 0x7d>, <&audma1 0x7e>;
ssiu91: ssiu-45 {
dmas = <&audma0 0x7F>, <&audma1 0x80>;
ssiu92: ssiu-46 {
dmas = <&audma0 0x81>, <&audma1 0x82>;
ssiu93: ssiu-47 {
dmas = <&audma0 0x83>, <&audma1 0x84>;
ssiu94: ssiu-48 {
dmas = <&audma0 0xA3>, <&audma1 0xA4>;
ssiu95: ssiu-49 {
dmas = <&audma0 0xA5>, <&audma1 0xA6>;
ssiu96: ssiu-50 {
dmas = <&audma0 0xA7>, <&audma1 0xA8>;
ssiu97: ssiu-51 {
dmas = <&audma0 0xA9>, <&audma1 0xAA>;
rcar_sound,ssi {
ssi0: ssi-0 {
dmas = <&audma0 0x01>, <&audma1 0x02>;
ssi1: ssi-1 {
dmas = <&audma0 0x03>, <&audma1 0x04>;
ssi2: ssi-2 {
dmas = <&audma0 0x05>, <&audma1 0x06>;
ssi3: ssi-3 {
dmas = <&audma0 0x07>, <&audma1 0x08>;
ssi4: ssi-4 {
dmas = <&audma0 0x09>, <&audma1 0x0a>;
ssi5: ssi-5 {
dmas = <&audma0 0x0b>, <&audma1 0x0c>;
ssi6: ssi-6 {
dmas = <&audma0 0x0d>, <&audma1 0x0e>;
ssi7: ssi-7 {
dmas = <&audma0 0x0f>, <&audma1 0x10>;
ssi8: ssi-8 {
dmas = <&audma0 0x11>, <&audma1 0x12>;
ssi9: ssi-9 {
dmas = <&audma0 0x13>, <&audma1 0x14>;
audma0: dma-controller@ec700000 {
reg = <0 0xec700000 0 0x10000>;
interrupts = <GIC_SPI 350 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 320 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 321 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 322 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 323 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 324 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 325 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 326 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 327 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 328 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 329 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 330 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 331 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 332 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 333 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 334 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 335 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "error",
clocks = <&cpg CPG_MOD 502>;
clock-names = "fck";
resets = <&cpg 502>;
#dma-cells = <1>;
dma-channels = <16>;
iommus = <&ipmmu_mp0 0>, <&ipmmu_mp0 1>,
<&ipmmu_mp0 2>, <&ipmmu_mp0 3>,
<&ipmmu_mp0 4>, <&ipmmu_mp0 5>,
<&ipmmu_mp0 6>, <&ipmmu_mp0 7>,
<&ipmmu_mp0 8>, <&ipmmu_mp0 9>,
<&ipmmu_mp0 10>, <&ipmmu_mp0 11>,
<&ipmmu_mp0 12>, <&ipmmu_mp0 13>,
<&ipmmu_mp0 14>, <&ipmmu_mp0 15>;
audma1: dma-controller@ec720000 {
reg = <0 0xec720000 0 0x10000>;
interrupts = <GIC_SPI 351 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 336 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 337 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 338 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 339 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 340 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 341 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 342 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 343 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 344 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 345 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 346 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 347 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 348 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 349 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 382 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 383 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 501>;
resets = <&cpg 501>;
#dma-cells = <1>;
iommus = <&ipmmu_mp0 16>, <&ipmmu_mp0 17>,
<&ipmmu_mp0 18>, <&ipmmu_mp0 19>,
<&ipmmu_mp0 20>, <&ipmmu_mp0 21>,
<&ipmmu_mp0 22>, <&ipmmu_mp0 23>,
<&ipmmu_mp0 24>, <&ipmmu_mp0 25>,
<&ipmmu_mp0 26>, <&ipmmu_mp0 27>,
<&ipmmu_mp0 28>, <&ipmmu_mp0 29>,
<&ipmmu_mp0 30>, <&ipmmu_mp0 31>;
xhci0: usb@ee000000 {
compatible = "renesas,xhci-r8a774e1",
"renesas,rcar-gen3-xhci";
reg = <0 0xee000000 0 0xc00>;
interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 328>;
status = "disabled";
usb3_peri0: usb@ee020000 {
compatible = "renesas,r8a774e1-usb3-peri",
"renesas,rcar-gen3-usb3-peri";
reg = <0 0xee020000 0 0x400>;
interrupts = <GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH>;
ohci0: usb@ee080000 {
compatible = "generic-ohci";
reg = <0 0xee080000 0 0x100>;
interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>;
phys = <&usb2_phy0 1>;
phy-names = "usb";
ohci1: usb@ee0a0000 {
reg = <0 0xee0a0000 0 0x100>;
interrupts = <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 702>;
phys = <&usb2_phy1 1>;
phy-names = "usb";
resets = <&cpg 702>;
ehci0: usb@ee080100 {
compatible = "generic-ehci";
reg = <0 0xee080100 0 0x100>;
phys = <&usb2_phy0 2>;
phy-names = "usb";
companion = <&ohci0>;
ehci1: usb@ee0a0100 {
reg = <0 0xee0a0100 0 0x100>;
phys = <&usb2_phy1 2>;
phy-names = "usb";
companion = <&ohci1>;
usb2_phy0: usb-phy@ee080200 {
compatible = "renesas,usb2-phy-r8a774e1",
"renesas,rcar-gen3-usb2-phy";
reg = <0 0xee080200 0 0x700>;
#phy-cells = <1>;
usb2_phy1: usb-phy@ee0a0200 {
reg = <0 0xee0a0200 0 0x700>;
#phy-cells = <1>;
sdhi0: mmc@ee100000 {
compatible = "renesas,sdhi-r8a774e1",
"renesas,rcar-gen3-sdhi";
reg = <0 0xee100000 0 0x2000>;
interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 314>, <&cpg CPG_CORE R8A774E1_CLK_SD0H>;
resets = <&cpg 314>;
iommus = <&ipmmu_ds1 32>;
sdhi1: mmc@ee120000 {
reg = <0 0xee120000 0 0x2000>;
interrupts = <GIC_SPI 166 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 313>, <&cpg CPG_CORE R8A774E1_CLK_SD1H>;
resets = <&cpg 313>;
iommus = <&ipmmu_ds1 33>;
sdhi2: mmc@ee140000 {
interrupts = <GIC_SPI 167 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 312>, <&cpg CPG_CORE R8A774E1_CLK_SD2H>;
resets = <&cpg 312>;
iommus = <&ipmmu_ds1 34>;
sdhi3: mmc@ee160000 {
reg = <0 0xee160000 0 0x2000>;
interrupts = <GIC_SPI 168 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 311>, <&cpg CPG_CORE R8A774E1_CLK_SD3H>;
resets = <&cpg 311>;
iommus = <&ipmmu_ds1 35>;
rpc: spi@ee200000 {
compatible = "renesas,r8a774e1-rpc-if",
"renesas,rcar-gen3-rpc-if";
<0 0x08000000 0 0x4000000>,
interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 917>;
resets = <&cpg 917>;
#address-cells = <1>;
#size-cells = <0>;
compatible = "renesas,sata-r8a774e1",
iommus = <&ipmmu_hc 2>;
gic: interrupt-controller@f1010000 {
compatible = "arm,gic-400";
interrupt-controller;
reg = <0x0 0xf1010000 0 0x1000>,
<0x0 0xf1020000 0 0x20000>,
<0x0 0xf1040000 0 0x20000>,
<0x0 0xf1060000 0 0x20000>;
(GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_HIGH)>;
clocks = <&cpg CPG_MOD 408>;
clock-names = "clk";
resets = <&cpg 408>;
pciec0: pcie@fe000000 {
compatible = "renesas,pcie-r8a774e1",
"renesas,pcie-rcar-gen3";
reg = <0 0xfe000000 0 0x80000>;
#address-cells = <3>;
#size-cells = <2>;
bus-range = <0x00 0xff>;
device_type = "pci";
ranges = <0x01000000 0 0x00000000 0 0xfe100000 0 0x00100000>,
<0x02000000 0 0xfe200000 0 0xfe200000 0 0x00200000>,
<0x02000000 0 0x30000000 0 0x30000000 0 0x08000000>,
<0x42000000 0 0x38000000 0 0x38000000 0 0x08000000>;
/* Map all possible DDR/IOMMU as inbound ranges */
dma-ranges = <0x42000000 0 0x00000000 0 0x00000000 1 0x00000000>;
interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>;
#interrupt-cells = <1>;
interrupt-map-mask = <0 0 0 0>;
interrupt-map = <0 0 0 0 &gic GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 319>, <&pcie_bus_clk>;
clock-names = "pcie", "pcie_bus";
resets = <&cpg 319>;
iommu-map = <0 &ipmmu_hc 0 1>;
iommu-map-mask = <0>;
pciec1: pcie@ee800000 {
reg = <0 0xee800000 0 0x80000>;
#size-cells = <2>;
ranges = <0x01000000 0 0x00000000 0 0xee900000 0 0x00100000>,
<0x02000000 0 0xeea00000 0 0xeea00000 0 0x00200000>,
<0x02000000 0 0xc0000000 0 0xc0000000 0 0x08000000>,
<0x42000000 0 0xc8000000 0 0xc8000000 0 0x08000000>;
interrupts = <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 149 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 150 IRQ_TYPE_LEVEL_HIGH>;
interrupt-map = <0 0 0 0 &gic GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 318>, <&pcie_bus_clk>;
resets = <&cpg 318>;
iommu-map = <0 &ipmmu_hc 1 1>;
pciec0_ep: pcie-ep@fe000000 {
compatible = "renesas,r8a774e1-pcie-ep",
"renesas,rcar-gen3-pcie-ep";
reg = <0x0 0xfe000000 0 0x80000>,
<0x0 0xfe100000 0 0x100000>,
<0x0 0xfe200000 0 0x200000>,
<0x0 0x30000000 0 0x8000000>,
<0x0 0x38000000 0 0x8000000>;
reg-names = "apb-base", "memory0", "memory1", "memory2", "memory3";
clocks = <&cpg CPG_MOD 319>;
clock-names = "pcie";
pciec1_ep: pcie-ep@ee800000 {
reg = <0x0 0xee800000 0 0x80000>,
<0x0 0xee900000 0 0x100000>,
<0x0 0xeea00000 0 0x200000>,
<0x0 0xc0000000 0 0x8000000>,
<0x0 0xc8000000 0 0x8000000>;
clocks = <&cpg CPG_MOD 318>;
vspbc: vsp@fe920000 {
compatible = "renesas,vsp2";
reg = <0 0xfe920000 0 0x8000>;
interrupts = <GIC_SPI 465 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 624>;
resets = <&cpg 624>;
renesas,fcp = <&fcpvb1>;
vspbd: vsp@fe960000 {
reg = <0 0xfe960000 0 0x8000>;
interrupts = <GIC_SPI 266 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 626>;
resets = <&cpg 626>;
renesas,fcp = <&fcpvb0>;
vspd0: vsp@fea20000 {
reg = <0 0xfea20000 0 0x5000>;
interrupts = <GIC_SPI 466 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 623>;
resets = <&cpg 623>;
renesas,fcp = <&fcpvd0>;
vspd1: vsp@fea28000 {
reg = <0 0xfea28000 0 0x5000>;
interrupts = <GIC_SPI 467 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 622>;
resets = <&cpg 622>;
renesas,fcp = <&fcpvd1>;
vspi0: vsp@fe9a0000 {
reg = <0 0xfe9a0000 0 0x8000>;
interrupts = <GIC_SPI 444 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 631>;
resets = <&cpg 631>;
renesas,fcp = <&fcpvi0>;
vspi1: vsp@fe9b0000 {
reg = <0 0xfe9b0000 0 0x8000>;
interrupts = <GIC_SPI 445 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 630>;
resets = <&cpg 630>;
renesas,fcp = <&fcpvi1>;
fdp1@fe940000 {
compatible = "renesas,fdp1";
reg = <0 0xfe940000 0 0x2400>;
interrupts = <GIC_SPI 262 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 119>;
resets = <&cpg 119>;
renesas,fcp = <&fcpf0>;
fdp1@fe944000 {
reg = <0 0xfe944000 0 0x2400>;
interrupts = <GIC_SPI 263 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 118>;
resets = <&cpg 118>;
renesas,fcp = <&fcpf1>;
fcpf0: fcp@fe950000 {
compatible = "renesas,fcpf";
reg = <0 0xfe950000 0 0x200>;
clocks = <&cpg CPG_MOD 615>;
resets = <&cpg 615>;
fcpf1: fcp@fe951000 {
reg = <0 0xfe951000 0 0x200>;
clocks = <&cpg CPG_MOD 614>;
resets = <&cpg 614>;
fcpvb0: fcp@fe96f000 {
compatible = "renesas,fcpv";
reg = <0 0xfe96f000 0 0x200>;
clocks = <&cpg CPG_MOD 607>;
resets = <&cpg 607>;
fcpvb1: fcp@fe92f000 {
reg = <0 0xfe92f000 0 0x200>;
clocks = <&cpg CPG_MOD 606>;
resets = <&cpg 606>;
fcpvi0: fcp@fe9af000 {
reg = <0 0xfe9af000 0 0x200>;
clocks = <&cpg CPG_MOD 611>;
resets = <&cpg 611>;
fcpvi1: fcp@fe9bf000 {
reg = <0 0xfe9bf000 0 0x200>;
clocks = <&cpg CPG_MOD 610>;
resets = <&cpg 610>;
fcpvd0: fcp@fea27000 {
reg = <0 0xfea27000 0 0x200>;
clocks = <&cpg CPG_MOD 603>;
resets = <&cpg 603>;
fcpvd1: fcp@fea2f000 {
reg = <0 0xfea2f000 0 0x200>;
clocks = <&cpg CPG_MOD 602>;
resets = <&cpg 602>;
csi20: csi2@fea80000 {
compatible = "renesas,r8a774e1-csi2";
reg = <0 0xfea80000 0 0x10000>;
interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 714>;
resets = <&cpg 714>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
csi20vin0: endpoint@0 {
reg = <0>;
remote-endpoint = <&vin0csi20>;
csi20vin1: endpoint@1 {
reg = <1>;
remote-endpoint = <&vin1csi20>;
csi20vin2: endpoint@2 {
reg = <2>;
remote-endpoint = <&vin2csi20>;
csi20vin3: endpoint@3 {
reg = <3>;
remote-endpoint = <&vin3csi20>;
csi20vin4: endpoint@4 {
reg = <4>;
remote-endpoint = <&vin4csi20>;
csi20vin5: endpoint@5 {
reg = <5>;
remote-endpoint = <&vin5csi20>;
csi20vin6: endpoint@6 {
reg = <6>;
remote-endpoint = <&vin6csi20>;
csi20vin7: endpoint@7 {
reg = <7>;
remote-endpoint = <&vin7csi20>;
csi40: csi2@feaa0000 {
reg = <0 0xfeaa0000 0 0x10000>;
interrupts = <GIC_SPI 246 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 716>;
resets = <&cpg 716>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
csi40vin0: endpoint@0 {
reg = <0>;
remote-endpoint = <&vin0csi40>;
csi40vin1: endpoint@1 {
reg = <1>;
remote-endpoint = <&vin1csi40>;
csi40vin2: endpoint@2 {
reg = <2>;
remote-endpoint = <&vin2csi40>;
csi40vin3: endpoint@3 {
reg = <3>;
remote-endpoint = <&vin3csi40>;
hdmi0: hdmi@fead0000 {
compatible = "renesas,r8a774e1-hdmi",
"renesas,rcar-gen3-hdmi";
reg = <0 0xfead0000 0 0x10000>;
interrupts = <GIC_SPI 389 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 729>,
<&cpg CPG_CORE R8A774E1_CLK_HDMI>;
clock-names = "iahb", "isfr";
resets = <&cpg 729>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
dw_hdmi0_in: endpoint {
remote-endpoint = <&du_out_hdmi0>;
port@1 {
reg = <1>;
port@2 {
/* HDMI sound */
reg = <2>;
du: display@feb00000 {
compatible = "renesas,du-r8a774e1";
reg = <0 0xfeb00000 0 0x80000>;
interrupts = <GIC_SPI 256 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 268 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 270 IRQ_TYPE_LEVEL_HIGH>;
<&cpg CPG_MOD 723>,
<&cpg CPG_MOD 721>;
clock-names = "du.0", "du.1", "du.3";
resets = <&cpg 724>, <&cpg 722>;
reset-names = "du.0", "du.3";
renesas,vsps = <&vspd0 0>, <&vspd1 0>, <&vspd0 1>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port@1 {
reg = <1>;
du_out_hdmi0: endpoint {
remote-endpoint = <&dw_hdmi0_in>;
port@2 {
reg = <2>;
du_out_lvds0: endpoint {
remote-endpoint = <&lvds0_in>;
lvds0: lvds@feb90000 {
compatible = "renesas,r8a774e1-lvds";
reg = <0 0xfeb90000 0 0x14>;
clocks = <&cpg CPG_MOD 727>;
resets = <&cpg 727>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
lvds0_in: endpoint {
remote-endpoint = <&du_out_lvds0>;
port@1 {
reg = <1>;
prr: chipid@fff00044 {
compatible = "renesas,prr";
reg = <0 0xfff00044 0 4>;
thermal-zones {
sensor1_thermal: sensor1-thermal {
polling-delay-passive = <250>;
polling-delay = <1000>;
thermal-sensors = <&tsc 0>;
sustainable-power = <6313>;
trips {
sensor1_crit: sensor1-crit {
temperature = <120000>;
hysteresis = <1000>;
type = "critical";
sensor2_thermal: sensor2-thermal {
thermal-sensors = <&tsc 1>;
trips {
sensor2_crit: sensor2-crit {
type = "critical";
sensor3_thermal: sensor3-thermal {
thermal-sensors = <&tsc 2>;
trips {
target: trip-point1 {
temperature = <100000>;
type = "passive";
sensor3_crit: sensor3-crit {
type = "critical";
cooling-maps {
map0 {
trip = <&target>;
cooling-device = <&a57_0 0 2>;
contribution = <1024>;
map1 {
trip = <&target>;
cooling-device = <&a53_0 0 2>;
timer {
compatible = "arm,armv8-timer";
interrupts-extended = <&gic GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_LOW)>,
<&gic GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_LOW)>,
<&gic GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_LOW)>,
<&gic GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_LOW)>;
/* External USB clocks - can be overridden by the board */
usb3s0_clk: usb3s0 {
compatible = "fixed-clock";
#clock-cells = <0>;
usb_extal_clk: usb_extal {
#clock-cells = <0>;
-}; diff --git a/arch/arm/dts/r8a7790-lager.dts b/arch/arm/dts/r8a7790-lager.dts deleted file mode 100644 index 5ad5349a50d..00000000000 --- a/arch/arm/dts/r8a7790-lager.dts +++ /dev/null @@ -1,947 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Device Tree Source for the Lager board
- Copyright (C) 2013-2014 Renesas Solutions Corp.
- Copyright (C) 2014 Cogent Embedded, Inc.
- Copyright (C) 2015-2016 Renesas Electronics Corporation
- SSI-AK4643
- SW1: 1: AK4643
2: CN22
3: ADV7511
- This command is required when Playback/Capture
amixer set "LINEOUT Mixer DACL" on
amixer set "DVC Out" 100%
amixer set "DVC In" 100%
- You can use Mute
amixer set "DVC Out Mute" on
amixer set "DVC In Mute" on
- You can use Volume Ramp
amixer set "DVC Out Ramp Up Rate" "0.125 dB/64 steps"
amixer set "DVC Out Ramp Down Rate" "0.125 dB/512 steps"
amixer set "DVC Out Ramp" on
aplay xxx.wav &
amixer set "DVC Out" 80% // Volume Down
amixer set "DVC Out" 100% // Volume Up
-/dts-v1/; -#include "r8a7790.dtsi" -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/input/input.h>
model = "Lager";
compatible = "renesas,lager", "renesas,r8a7790";
aliases {
serial0 = &scif0;
serial1 = &scifa1;
i2c8 = &gpioi2c1;
i2c9 = &gpioi2c2;
i2c10 = &i2cexio0;
i2c11 = &i2cexio1;
i2c12 = &i2chdmi;
i2c13 = &i2cpwr;
mmc0 = &mmcif1;
mmc1 = &sdhi0;
mmc2 = &sdhi2;
chosen {
bootargs = "ignore_loglevel rw root=/dev/nfs ip=on";
stdout-path = "serial0:115200n8";
memory@40000000 {
device_type = "memory";
reg = <0 0x40000000 0 0x40000000>;
memory@140000000 {
reg = <1 0x40000000 0 0xc0000000>;
lbsc {
#size-cells = <1>;
keyboard {
compatible = "gpio-keys";
pinctrl-0 = <&keyboard_pins>;
pinctrl-names = "default";
one {
linux,code = <KEY_1>;
label = "SW2-1";
wakeup-source;
debounce-interval = <20>;
gpios = <&gpio1 14 GPIO_ACTIVE_LOW>;
two {
linux,code = <KEY_2>;
label = "SW2-2";
wakeup-source;
gpios = <&gpio1 24 GPIO_ACTIVE_LOW>;
three {
linux,code = <KEY_3>;
label = "SW2-3";
wakeup-source;
gpios = <&gpio1 26 GPIO_ACTIVE_LOW>;
four {
linux,code = <KEY_4>;
label = "SW2-4";
wakeup-source;
gpios = <&gpio1 28 GPIO_ACTIVE_LOW>;
leds {
compatible = "gpio-leds";
led6 {
gpios = <&gpio4 22 GPIO_ACTIVE_HIGH>;
led7 {
gpios = <&gpio4 23 GPIO_ACTIVE_HIGH>;
led8 {
gpios = <&gpio5 17 GPIO_ACTIVE_HIGH>;
fixedregulator3v3: regulator-3v3 {
compatible = "regulator-fixed";
regulator-name = "fixed-3.3V";
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
regulator-boot-on;
regulator-always-on;
vcc_sdhi0: regulator-vcc-sdhi0 {
regulator-name = "SDHI0 Vcc";
gpio = <&gpio5 24 GPIO_ACTIVE_HIGH>;
enable-active-high;
vccq_sdhi0: regulator-vccq-sdhi0 {
compatible = "regulator-gpio";
regulator-name = "SDHI0 VccQ";
regulator-min-microvolt = <1800000>;
gpios = <&gpio5 29 GPIO_ACTIVE_HIGH>;
gpios-states = <1>;
states = <3300000 1>, <1800000 0>;
vcc_sdhi2: regulator-vcc-sdhi2 {
regulator-name = "SDHI2 Vcc";
gpio = <&gpio5 25 GPIO_ACTIVE_HIGH>;
enable-active-high;
vccq_sdhi2: regulator-vccq-sdhi2 {
regulator-name = "SDHI2 VccQ";
gpios = <&gpio5 30 GPIO_ACTIVE_HIGH>;
gpios-states = <1>;
audio_clock: audio_clock {
#clock-cells = <0>;
clock-frequency = <11289600>;
rsnd_ak4643: sound {
compatible = "simple-audio-card";
simple-audio-card,format = "left_j";
simple-audio-card,bitclock-master = <&sndcodec>;
simple-audio-card,frame-master = <&sndcodec>;
sndcpu: simple-audio-card,cpu {
sound-dai = <&rcar_sound>;
sndcodec: simple-audio-card,codec {
sound-dai = <&ak4643>;
clocks = <&audio_clock>;
vga-encoder {
compatible = "adi,adv7123";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
adv7123_in: endpoint {
remote-endpoint = <&du_out_rgb>;
port@1 {
reg = <1>;
adv7123_out: endpoint {
remote-endpoint = <&vga_in>;
vga {
compatible = "vga-connector";
port {
vga_in: endpoint {
remote-endpoint = <&adv7123_out>;
hdmi-in {
compatible = "hdmi-connector";
type = "a";
port {
hdmi_con_in: endpoint {
remote-endpoint = <&adv7612_in>;
cec_clock: cec-clock {
#clock-cells = <0>;
clock-frequency = <12000000>;
hdmi-out {
type = "a";
port {
hdmi_con_out: endpoint {
remote-endpoint = <&adv7511_out>;
x2_clk: x2-clock {
#clock-cells = <0>;
clock-frequency = <148500000>;
x13_clk: x13-clock {
#clock-cells = <0>;
gpioi2c1: i2c-8 {
#size-cells = <0>;
compatible = "i2c-gpio";
scl-gpios = <&gpio1 16 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>;
sda-gpios = <&gpio1 17 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>;
i2c-gpio,delay-us = <5>;
gpioi2c2: i2c-9 {
#size-cells = <0>;
scl-gpios = <&gpio5 5 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>;
sda-gpios = <&gpio5 6 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>;
* IIC0/I2C0 is routed to EXIO connector A, pins 114 (SCL) + 116 (SDA) only.
* We use the I2C demuxer, so the desired IP core can be selected at runtime
* depending on the use case (e.g. DMA with IIC0 or slave support with I2C0).
* Note: For testing the I2C slave feature, it is convenient to connect this
* bus with IIC3 on pins 110 (SCL) + 112 (SDA), select I2C0 at runtime, and
* instantiate the slave device at runtime according to the documentation.
* You can then communicate with the slave via IIC3.
* IIC0/I2C0 does not appear to support fallback to GPIO.
i2cexio0: i2c-10 {
compatible = "i2c-demux-pinctrl";
i2c-parent = <&iic0>, <&i2c0>;
i2c-bus-name = "i2c-exio0";
#size-cells = <0>;
* IIC1/I2C1 is routed to EXIO connector A, pins 78 (SCL) + 80 (SDA).
* This is similar to the arangement described for i2cexio0 (above)
* with a fallback to GPIO also provided.
i2cexio1: i2c-11 {
i2c-parent = <&iic1>, <&i2c1>, <&gpioi2c1>;
i2c-bus-name = "i2c-exio1";
#size-cells = <0>;
* IIC2 and I2C2 may be switched using pinmux.
* A fallback to GPIO is also provided.
i2chdmi: i2c-12 {
i2c-parent = <&iic2>, <&i2c2>, <&gpioi2c2>;
i2c-bus-name = "i2c-hdmi";
#size-cells = <0>;
ak4643: codec@12 {
compatible = "asahi-kasei,ak4643";
#sound-dai-cells = <0>;
reg = <0x12>;
composite-in@20 {
compatible = "adi,adv7180";
reg = <0x20>;
port {
adv7180: endpoint {
bus-width = <8>;
remote-endpoint = <&vin1ep0>;
hdmi@39 {
compatible = "adi,adv7511w";
reg = <0x39>;
interrupt-parent = <&gpio1>;
interrupts = <15 IRQ_TYPE_LEVEL_LOW>;
clocks = <&cec_clock>;
clock-names = "cec";
adi,input-depth = <8>;
adi,input-colorspace = "rgb";
adi,input-clock = "1x";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
adv7511_in: endpoint {
remote-endpoint = <&lvds0_out>;
port@1 {
reg = <1>;
adv7511_out: endpoint {
remote-endpoint = <&hdmi_con_out>;
hdmi-in@4c {
compatible = "adi,adv7612";
reg = <0x4c>;
interrupts = <20 IRQ_TYPE_LEVEL_LOW>;
default-input = <0>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
adv7612_in: endpoint {
remote-endpoint = <&hdmi_con_in>;
port@2 {
reg = <2>;
adv7612_out: endpoint {
remote-endpoint = <&vin0ep2>;
* IIC3 and I2C3 may be switched using pinmux.
* IIC3/I2C3 does not appear to support fallback to GPIO.
i2cpwr: i2c-13 {
pinctrl-0 = <&pmic_irq_pins>;
i2c-parent = <&iic3>, <&i2c3>;
i2c-bus-name = "i2c-pwr";
#size-cells = <0>;
pmic@58 {
compatible = "dlg,da9063";
reg = <0x58>;
interrupt-parent = <&irqc0>;
interrupts = <2 IRQ_TYPE_LEVEL_LOW>;
rtc {
compatible = "dlg,da9063-rtc";
watchdog {
compatible = "dlg,da9063-watchdog";
vdd_dvfs: regulator@68 {
compatible = "dlg,da9210";
reg = <0x68>;
regulator-min-microvolt = <1000000>;
regulator-max-microvolt = <1000000>;
regulator-boot-on;
-&du {
pinctrl-0 = <&du_pins>;
status = "okay";
clocks = <&cpg CPG_MOD 724>, <&cpg CPG_MOD 723>, <&cpg CPG_MOD 722>,
<&x13_clk>, <&x2_clk>;
clock-names = "du.0", "du.1", "du.2", "dclkin.0", "dclkin.1";
ports {
port@0 {
endpoint {
remote-endpoint = <&adv7123_in>;
-&lvds0 {
status = "okay";
ports {
port@1 {
endpoint {
remote-endpoint = <&adv7511_in>;
-&lvds1 {
ports {
port@1 {
lvds_connector: endpoint {
-&extal_clk {
clock-frequency = <20000000>;
-&pfc {
pinctrl-0 = <&scif_clk_pins>;
du_pins: du {
groups = "du_rgb666", "du_sync_1", "du_clk_out_0";
function = "du";
scif0_pins: scif0 {
groups = "scif0_data";
function = "scif0";
scif_clk_pins: scif_clk {
groups = "scif_clk";
function = "scif_clk";
ether_pins: ether {
groups = "eth_link", "eth_mdio", "eth_rmii";
function = "eth";
phy1_pins: phy1 {
groups = "intc_irq0";
function = "intc";
scifa1_pins: scifa1 {
groups = "scifa1_data";
function = "scifa1";
sdhi0_pins: sd0 {
groups = "sdhi0_data4", "sdhi0_ctrl";
function = "sdhi0";
power-source = <3300>;
sdhi0_pins_uhs: sd0_uhs {
function = "sdhi0";
power-source = <1800>;
sdhi2_pins: sd2 {
groups = "sdhi2_data4", "sdhi2_ctrl";
function = "sdhi2";
sdhi2_pins_uhs: sd2_uhs {
function = "sdhi2";
mmc1_pins: mmc1 {
groups = "mmc1_data8", "mmc1_ctrl";
function = "mmc1";
qspi_pins: qspi {
groups = "qspi_ctrl", "qspi_data4";
function = "qspi";
msiof1_pins: msiof1 {
groups = "msiof1_clk", "msiof1_sync", "msiof1_rx",
"msiof1_tx";
function = "msiof1";
i2c0_pins: i2c0 {
groups = "i2c0";
function = "i2c0";
iic0_pins: iic0 {
groups = "iic0";
function = "iic0";
i2c1_pins: i2c1 {
groups = "i2c1";
function = "i2c1";
iic1_pins: iic1 {
groups = "iic1";
function = "iic1";
i2c2_pins: i2c2 {
groups = "i2c2";
function = "i2c2";
iic2_pins: iic2 {
groups = "iic2";
function = "iic2";
i2c3_pins: i2c3 {
groups = "i2c3";
function = "i2c3";
iic3_pins: iic3 {
groups = "iic3";
function = "iic3";
pmic_irq_pins: pmicirq {
groups = "intc_irq2";
function = "intc";
hsusb_pins: hsusb {
groups = "usb0_ovc_vbus";
function = "usb0";
usb0_pins: usb0 {
groups = "usb0";
function = "usb0";
usb1_pins: usb1 {
groups = "usb1";
function = "usb1";
usb2_pins: usb2 {
groups = "usb2";
function = "usb2";
vin0_pins: vin0 {
groups = "vin0_data24", "vin0_sync", "vin0_clkenb", "vin0_clk";
function = "vin0";
vin1_pins: vin1 {
groups = "vin1_data8", "vin1_clk";
function = "vin1";
sound_pins: sound {
groups = "ssi0129_ctrl", "ssi0_data", "ssi1_data";
function = "ssi";
sound_clk_pins: sound_clk {
groups = "audio_clk_a";
function = "audio_clk";
keyboard_pins: keyboard {
pins = "GP_1_14", "GP_1_24", "GP_1_26", "GP_1_28";
bias-pull-up;
-ðer {
pinctrl-0 = <ðer_pins>, <&phy1_pins>;
phy-handle = <&phy1>;
renesas,ether-link-active-low;
status = "okay";
phy1: ethernet-phy@1 {
compatible = "ethernet-phy-id0022.1537",
"ethernet-phy-ieee802.3-c22";
reg = <1>;
interrupts = <0 IRQ_TYPE_LEVEL_LOW>;
micrel,led-mode = <1>;
reset-gpios = <&gpio5 31 GPIO_ACTIVE_LOW>;
-&cmt0 {
status = "okay";
-&mmcif1 {
pinctrl-0 = <&mmc1_pins>;
vmmc-supply = <&fixedregulator3v3>;
bus-width = <8>;
non-removable;
status = "okay";
-&sata1 {
status = "okay";
-&qspi {
pinctrl-0 = <&qspi_pins>;
status = "okay";
flash: flash@0 {
compatible = "spansion,s25fl512s", "jedec,spi-nor";
reg = <0>;
spi-max-frequency = <30000000>;
spi-tx-bus-width = <4>;
spi-rx-bus-width = <4>;
spi-cpha;
spi-cpol;
m25p,fast-read;
partitions {
compatible = "fixed-partitions";
#size-cells = <1>;
partition@0 {
label = "loader";
reg = <0x00000000 0x00040000>;
read-only;
partition@40000 {
label = "user";
reg = <0x00040000 0x00400000>;
read-only;
partition@440000 {
label = "flash";
reg = <0x00440000 0x03bc0000>;
-&scif0 {
pinctrl-0 = <&scif0_pins>;
status = "okay";
-&scifa1 {
pinctrl-0 = <&scifa1_pins>;
status = "okay";
-&scif_clk {
clock-frequency = <14745600>;
-&msiof1 {
pinctrl-0 = <&msiof1_pins>;
status = "okay";
pmic: pmic@0 {
compatible = "renesas,r2a11302ft";
reg = <0>;
spi-max-frequency = <6000000>;
spi-cpol;
spi-cpha;
-&sdhi0 {
pinctrl-0 = <&sdhi0_pins>;
pinctrl-1 = <&sdhi0_pins_uhs>;
pinctrl-names = "default", "state_uhs";
vmmc-supply = <&vcc_sdhi0>;
vqmmc-supply = <&vccq_sdhi0>;
cd-gpios = <&gpio3 6 GPIO_ACTIVE_LOW>;
sd-uhs-sdr50;
sd-uhs-sdr104;
status = "okay";
-&sdhi2 {
pinctrl-0 = <&sdhi2_pins>;
pinctrl-1 = <&sdhi2_pins_uhs>;
vmmc-supply = <&vcc_sdhi2>;
vqmmc-supply = <&vccq_sdhi2>;
cd-gpios = <&gpio3 22 GPIO_ACTIVE_LOW>;
sd-uhs-sdr50;
status = "okay";
-&cpu0 {
cpu0-supply = <&vdd_dvfs>;
-&i2c0 {
pinctrl-0 = <&i2c0_pins>;
pinctrl-names = "i2c-exio0";
-&iic0 {
pinctrl-0 = <&iic0_pins>;
-&i2c1 {
pinctrl-0 = <&i2c1_pins>;
pinctrl-names = "i2c-exio1";
-&iic1 {
pinctrl-0 = <&iic1_pins>;
-&i2c2 {
pinctrl-0 = <&i2c2_pins>;
pinctrl-names = "i2c-hdmi";
clock-frequency = <100000>;
-&iic2 {
pinctrl-0 = <&iic2_pins>;
-&i2c3 {
pinctrl-0 = <&i2c3_pins>;
pinctrl-names = "i2c-pwr";
-&iic3 {
pinctrl-0 = <&iic3_pins>;
-&pci0 {
status = "okay";
pinctrl-0 = <&usb0_pins>;
-&pci1 {
status = "okay";
pinctrl-0 = <&usb1_pins>;
-&xhci {
status = "okay";
pinctrl-0 = <&usb2_pins>;
-&pci2 {
status = "okay";
-&hsusb {
status = "okay";
pinctrl-0 = <&hsusb_pins>;
renesas,enable-gpio = <&gpio5 18 GPIO_ACTIVE_HIGH>;
-&usbphy {
status = "okay";
-/* HDMI video input */ -&vin0 {
pinctrl-0 = <&vin0_pins>;
status = "okay";
port {
vin0ep2: endpoint {
remote-endpoint = <&adv7612_out>;
bus-width = <24>;
hsync-active = <0>;
vsync-active = <0>;
pclk-sample = <1>;
data-active = <1>;
-/* composite video input */ -&vin1 {
pinctrl-0 = <&vin1_pins>;
status = "okay";
port {
vin1ep0: endpoint {
remote-endpoint = <&adv7180>;
bus-width = <8>;
-&rcar_sound {
pinctrl-0 = <&sound_pins>, <&sound_clk_pins>;
/* Single DAI */
status = "okay";
rcar_sound,dai {
dai0 {
playback = <&ssi0>, <&src2>, <&dvc0>;
capture = <&ssi1>, <&src3>, <&dvc1>;
-&rwdt {
timeout-sec = <60>;
status = "okay";
-&ssi1 {
shared-pin;
-}; diff --git a/arch/arm/dts/r8a7790-stout.dts b/arch/arm/dts/r8a7790-stout.dts deleted file mode 100644 index fe14727eefe..00000000000 --- a/arch/arm/dts/r8a7790-stout.dts +++ /dev/null @@ -1,382 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Device Tree Source for the Stout board
- Copyright (C) 2018 Marek Vasut marek.vasut@gmail.com
model = "Stout";
compatible = "renesas,stout", "renesas,r8a7790";
aliases {
serial0 = &scifa0;
chosen {
memory@40000000 {
leds {
led1 {
gpios = <&gpio4 22 GPIO_ACTIVE_LOW>;
led2 {
gpios = <&gpio4 23 GPIO_ACTIVE_LOW>;
led3 {
gpios = <&gpio5 17 GPIO_ACTIVE_LOW>;
led5 {
gpios = <&gpio4 24 GPIO_ACTIVE_LOW>;
regulator-boot-on;
enable-active-high;
hdmi-out {
type = "a";
port {
osc1_clk: osc1-clock {
#clock-cells = <0>;
osc4_clk: osc4-clock {
#clock-cells = <0>;
-&du {
status = "okay";
<&osc1_clk>;
clock-names = "du.0", "du.1", "du.2", "dclkin.0";
ports {
port@0 {
endpoint {
-&lvds0 {
ports {
port@1 {
lvds_connector0: endpoint {
-&lvds1 {
ports {
port@1 {
lvds_connector1: endpoint {
-&extal_clk {
-&pfc {
du_pins: du {
groups = "du_rgb888", "du_sync_1", "du_clk_out_0";
function = "du";
scifa0_pins: scifa0 {
groups = "scifa0_data_b";
function = "scifa0";
ether_pins: ether {
function = "eth";
phy1_pins: phy1 {
groups = "intc_irq1";
function = "intc";
sdhi0_pins: sd0 {
function = "sdhi0";
qspi_pins: qspi {
function = "qspi";
iic2_pins: iic2 {
groups = "iic2_b";
function = "iic2";
iic3_pins: iic3 {
groups = "iic3";
function = "iic3";
function = "intc";
usb0_pins: usb0 {
groups = "usb0";
function = "usb0";
-ðer {
status = "okay";
reg = <1>;
interrupts = <1 IRQ_TYPE_LEVEL_LOW>;
reset-gpios = <&gpio3 31 GPIO_ACTIVE_LOW>;
-&cmt0 {
status = "okay";
-&qspi {
status = "okay";
flash: flash@0 {
reg = <0>;
spi-cpha;
spi-cpol;
m25p,fast-read;
partitions {
#size-cells = <1>;
partition@0 {
label = "loader";
reg = <0x00000000 0x00080000>;
read-only;
partition@80000 {
label = "uboot";
reg = <0x00080000 0x00040000>;
read-only;
partition@c0000 {
label = "uboot-env";
reg = <0x000c0000 0x00040000>;
read-only;
partition@100000 {
label = "flash";
reg = <0x00100000 0x03f00000>;
-&scifa0 {
pinctrl-0 = <&scifa0_pins>;
status = "okay";
-&scif_clk {
-&sdhi0 {
status = "okay";
-&cpu0 {
-&iic2 {
status = "okay";
hdmi@39 {
reg = <0x39>;
clocks = <&osc4_clk>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port@1 {
reg = <1>;
-&iic3 {
pinctrl-0 = <&iic3_pins>, <&pmic_irq_pins>;
status = "okay";
pmic@58 {
reg = <0x58>;
onkey {
compatible = "dlg,da9063-onkey";
rtc {
watchdog {
reg = <0x68>;
regulator-boot-on;
vdd: regulator@70 {
reg = <0x70>;
regulator-boot-on;
-&pci0 {
status = "okay";
-&usbphy {
status = "okay";
-}; diff --git a/arch/arm/dts/r8a7790.dtsi b/arch/arm/dts/r8a7790.dtsi deleted file mode 100644 index 46fb81f5062..00000000000 --- a/arch/arm/dts/r8a7790.dtsi +++ /dev/null @@ -1,1965 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Device Tree Source for the R-Car H2 (R8A77900) SoC
- Copyright (C) 2015 Renesas Electronics Corporation
- Copyright (C) 2014 Cogent Embedded Inc.
-#include <dt-bindings/clock/r8a7790-cpg-mssr.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/power/r8a7790-sysc.h>
compatible = "renesas,r8a7790";
#address-cells = <2>;
#size-cells = <2>;
aliases {
i2c0 = &i2c0;
i2c1 = &i2c1;
i2c2 = &i2c2;
i2c3 = &i2c3;
i2c4 = &iic0;
i2c5 = &iic1;
i2c6 = &iic2;
i2c7 = &iic3;
spi0 = &qspi;
spi1 = &msiof0;
spi2 = &msiof1;
spi3 = &msiof2;
spi4 = &msiof3;
vin0 = &vin0;
vin1 = &vin1;
vin2 = &vin2;
vin3 = &vin3;
* The external audio clocks are configured as 0 Hz fixed frequency
* clocks by default.
* Boards that provide audio clocks should override them.
audio_clk_a: audio_clk_a {
#clock-cells = <0>;
clock-frequency = <0>;
audio_clk_b: audio_clk_b {
#clock-cells = <0>;
audio_clk_c: audio_clk_c {
#clock-cells = <0>;
/* External CAN clock */
can_clk: can {
#clock-cells = <0>;
/* This value must be overridden by the board. */
cpus {
#size-cells = <0>;
cpu0: cpu@0 {
device_type = "cpu";
compatible = "arm,cortex-a15";
reg = <0>;
clock-frequency = <1300000000>;
clocks = <&cpg CPG_CORE R8A7790_CLK_Z>;
power-domains = <&sysc R8A7790_PD_CA15_CPU0>;
enable-method = "renesas,apmu";
next-level-cache = <&L2_CA15>;
voltage-tolerance = <1>; /* 1% */
clock-latency = <300000>; /* 300 us */
/* kHz - uV - OPPs unknown yet */
operating-points = <1400000 1000000>,
<1225000 1000000>,
<1050000 1000000>,
< 875000 1000000>,
< 700000 1000000>,
< 350000 1000000>;
cpu1: cpu@1 {
reg = <1>;
power-domains = <&sysc R8A7790_PD_CA15_CPU1>;
<1225000 1000000>,
<1050000 1000000>,
< 875000 1000000>,
< 700000 1000000>,
< 350000 1000000>;
cpu2: cpu@2 {
reg = <2>;
power-domains = <&sysc R8A7790_PD_CA15_CPU2>;
<1225000 1000000>,
<1050000 1000000>,
< 875000 1000000>,
< 700000 1000000>,
< 350000 1000000>;
cpu3: cpu@3 {
reg = <3>;
power-domains = <&sysc R8A7790_PD_CA15_CPU3>;
<1225000 1000000>,
<1050000 1000000>,
< 875000 1000000>,
< 700000 1000000>,
< 350000 1000000>;
cpu4: cpu@100 {
compatible = "arm,cortex-a7";
reg = <0x100>;
clock-frequency = <780000000>;
clocks = <&cpg CPG_CORE R8A7790_CLK_Z2>;
power-domains = <&sysc R8A7790_PD_CA7_CPU0>;
next-level-cache = <&L2_CA7>;
capacity-dmips-mhz = <539>;
cpu5: cpu@101 {
reg = <0x101>;
power-domains = <&sysc R8A7790_PD_CA7_CPU1>;
cpu6: cpu@102 {
reg = <0x102>;
power-domains = <&sysc R8A7790_PD_CA7_CPU2>;
cpu7: cpu@103 {
reg = <0x103>;
power-domains = <&sysc R8A7790_PD_CA7_CPU3>;
L2_CA15: cache-controller-0 {
compatible = "cache";
power-domains = <&sysc R8A7790_PD_CA15_SCU>;
cache-unified;
cache-level = <2>;
L2_CA7: cache-controller-1 {
power-domains = <&sysc R8A7790_PD_CA7_SCU>;
cache-unified;
cache-level = <2>;
/* External root clock */
extal_clk: extal {
#clock-cells = <0>;
/* External PCIe clock - can be overridden by the board */
pcie_bus_clk: pcie_bus {
#clock-cells = <0>;
pmu-0 {
compatible = "arm,cortex-a15-pmu";
interrupt-affinity = <&cpu0>, <&cpu1>, <&cpu2>, <&cpu3>;
pmu-1 {
compatible = "arm,cortex-a7-pmu";
interrupts-extended = <&gic GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>,
<&gic GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>,
<&gic GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>,
<&gic GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>;
interrupt-affinity = <&cpu4>, <&cpu5>, <&cpu6>, <&cpu7>;
/* External SCIF clock */
scif_clk: scif {
#clock-cells = <0>;
soc {
compatible = "simple-bus";
interrupt-parent = <&gic>;
#size-cells = <2>;
ranges;
rwdt: watchdog@e6020000 {
compatible = "renesas,r8a7790-wdt",
"renesas,rcar-gen2-wdt";
reg = <0 0xe6020000 0 0x0c>;
interrupts = <GIC_SPI 140 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 402>;
power-domains = <&sysc R8A7790_PD_ALWAYS_ON>;
resets = <&cpg 402>;
gpio0: gpio@e6050000 {
compatible = "renesas,gpio-r8a7790",
"renesas,rcar-gen2-gpio";
reg = <0 0xe6050000 0 0x50>;
interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 0 32>;
#interrupt-cells = <2>;
clocks = <&cpg CPG_MOD 912>;
resets = <&cpg 912>;
gpio1: gpio@e6051000 {
reg = <0 0xe6051000 0 0x50>;
interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 32 30>;
clocks = <&cpg CPG_MOD 911>;
resets = <&cpg 911>;
gpio2: gpio@e6052000 {
reg = <0 0xe6052000 0 0x50>;
interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 64 30>;
clocks = <&cpg CPG_MOD 910>;
resets = <&cpg 910>;
gpio3: gpio@e6053000 {
reg = <0 0xe6053000 0 0x50>;
interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 96 32>;
clocks = <&cpg CPG_MOD 909>;
resets = <&cpg 909>;
gpio4: gpio@e6054000 {
reg = <0 0xe6054000 0 0x50>;
interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 128 32>;
clocks = <&cpg CPG_MOD 908>;
resets = <&cpg 908>;
gpio5: gpio@e6055000 {
reg = <0 0xe6055000 0 0x50>;
interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 160 32>;
clocks = <&cpg CPG_MOD 907>;
resets = <&cpg 907>;
pfc: pinctrl@e6060000 {
compatible = "renesas,pfc-r8a7790";
reg = <0 0xe6060000 0 0x250>;
tpu: pwm@e60f0000 {
compatible = "renesas,tpu-r8a7790", "renesas,tpu";
reg = <0 0xe60f0000 0 0x148>;
interrupts = <GIC_SPI 135 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 304>;
resets = <&cpg 304>;
#pwm-cells = <3>;
cpg: clock-controller@e6150000 {
compatible = "renesas,r8a7790-cpg-mssr";
reg = <0 0xe6150000 0 0x1000>;
clocks = <&extal_clk>, <&usb_extal_clk>;
clock-names = "extal", "usb_extal";
#clock-cells = <2>;
#power-domain-cells = <0>;
#reset-cells = <1>;
apmu@e6151000 {
compatible = "renesas,r8a7790-apmu", "renesas,apmu";
reg = <0 0xe6151000 0 0x188>;
cpus = <&cpu4>, <&cpu5>, <&cpu6>, <&cpu7>;
apmu@e6152000 {
reg = <0 0xe6152000 0 0x188>;
cpus = <&cpu0>, <&cpu1>, <&cpu2>, <&cpu3>;
rst: reset-controller@e6160000 {
compatible = "renesas,r8a7790-rst";
reg = <0 0xe6160000 0 0x0100>;
sysc: system-controller@e6180000 {
compatible = "renesas,r8a7790-sysc";
reg = <0 0xe6180000 0 0x0200>;
#power-domain-cells = <1>;
irqc0: interrupt-controller@e61c0000 {
compatible = "renesas,irqc-r8a7790", "renesas,irqc";
reg = <0 0xe61c0000 0 0x200>;
interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 407>;
resets = <&cpg 407>;
thermal: thermal@e61f0000 {
compatible = "renesas,thermal-r8a7790",
"renesas,rcar-gen2-thermal",
"renesas,rcar-thermal";
reg = <0 0xe61f0000 0 0x10>, <0 0xe61f0100 0 0x38>;
interrupts = <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 522>;
resets = <&cpg 522>;
#thermal-sensor-cells = <0>;
ipmmu_sy0: iommu@e6280000 {
compatible = "renesas,ipmmu-r8a7790",
"renesas,ipmmu-vmsa";
reg = <0 0xe6280000 0 0x1000>;
interrupts = <GIC_SPI 223 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 224 IRQ_TYPE_LEVEL_HIGH>;
#iommu-cells = <1>;
ipmmu_sy1: iommu@e6290000 {
reg = <0 0xe6290000 0 0x1000>;
interrupts = <GIC_SPI 225 IRQ_TYPE_LEVEL_HIGH>;
#iommu-cells = <1>;
ipmmu_ds: iommu@e6740000 {
reg = <0 0xe6740000 0 0x1000>;
interrupts = <GIC_SPI 198 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 199 IRQ_TYPE_LEVEL_HIGH>;
#iommu-cells = <1>;
ipmmu_mp: iommu@ec680000 {
reg = <0 0xec680000 0 0x1000>;
interrupts = <GIC_SPI 226 IRQ_TYPE_LEVEL_HIGH>;
#iommu-cells = <1>;
ipmmu_mx: iommu@fe951000 {
reg = <0 0xfe951000 0 0x1000>;
interrupts = <GIC_SPI 222 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 221 IRQ_TYPE_LEVEL_HIGH>;
#iommu-cells = <1>;
ipmmu_rt: iommu@ffc80000 {
reg = <0 0xffc80000 0 0x1000>;
interrupts = <GIC_SPI 307 IRQ_TYPE_LEVEL_HIGH>;
#iommu-cells = <1>;
icram0: sram@e63a0000 {
compatible = "mmio-sram";
reg = <0 0xe63a0000 0 0x12000>;
#size-cells = <1>;
ranges = <0 0 0xe63a0000 0x12000>;
icram1: sram@e63c0000 {
reg = <0 0xe63c0000 0 0x1000>;
#size-cells = <1>;
ranges = <0 0 0xe63c0000 0x1000>;
smp-sram@0 {
compatible = "renesas,smp-sram";
reg = <0 0x100>;
i2c0: i2c@e6508000 {
#size-cells = <0>;
compatible = "renesas,i2c-r8a7790",
"renesas,rcar-gen2-i2c";
reg = <0 0xe6508000 0 0x40>;
interrupts = <GIC_SPI 287 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 931>;
resets = <&cpg 931>;
i2c-scl-internal-delay-ns = <110>;
i2c1: i2c@e6518000 {
#size-cells = <0>;
reg = <0 0xe6518000 0 0x40>;
interrupts = <GIC_SPI 288 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 930>;
resets = <&cpg 930>;
i2c-scl-internal-delay-ns = <6>;
i2c2: i2c@e6530000 {
#size-cells = <0>;
reg = <0 0xe6530000 0 0x40>;
interrupts = <GIC_SPI 286 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 929>;
resets = <&cpg 929>;
i2c3: i2c@e6540000 {
#size-cells = <0>;
reg = <0 0xe6540000 0 0x40>;
interrupts = <GIC_SPI 290 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 928>;
resets = <&cpg 928>;
iic0: i2c@e6500000 {
#size-cells = <0>;
compatible = "renesas,iic-r8a7790",
"renesas,rcar-gen2-iic",
"renesas,rmobile-iic";
reg = <0 0xe6500000 0 0x425>;
interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&dmac0 0x61>, <&dmac0 0x62>,
<&dmac1 0x61>, <&dmac1 0x62>;
dma-names = "tx", "rx", "tx", "rx";
iic1: i2c@e6510000 {
#size-cells = <0>;
reg = <0 0xe6510000 0 0x425>;
interrupts = <GIC_SPI 175 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 323>;
dmas = <&dmac0 0x65>, <&dmac0 0x66>,
<&dmac1 0x65>, <&dmac1 0x66>;
resets = <&cpg 323>;
iic2: i2c@e6520000 {
#size-cells = <0>;
reg = <0 0xe6520000 0 0x425>;
clocks = <&cpg CPG_MOD 300>;
dmas = <&dmac0 0x69>, <&dmac0 0x6a>,
<&dmac1 0x69>, <&dmac1 0x6a>;
resets = <&cpg 300>;
iic3: i2c@e60b0000 {
#size-cells = <0>;
reg = <0 0xe60b0000 0 0x425>;
interrupts = <GIC_SPI 173 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 926>;
dmas = <&dmac0 0x77>, <&dmac0 0x78>,
<&dmac1 0x77>, <&dmac1 0x78>;
resets = <&cpg 926>;
hsusb: usb@e6590000 {
compatible = "renesas,usbhs-r8a7790",
"renesas,rcar-gen2-usbhs";
reg = <0 0xe6590000 0 0x100>;
interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 704>;
dmas = <&usb_dmac0 0>, <&usb_dmac0 1>,
<&usb_dmac1 0>, <&usb_dmac1 1>;
dma-names = "ch0", "ch1", "ch2", "ch3";
resets = <&cpg 704>;
renesas,buswait = <4>;
phys = <&usb0 1>;
phy-names = "usb";
usbphy: usb-phy-controller@e6590100 {
compatible = "renesas,usb-phy-r8a7790",
"renesas,rcar-gen2-usb-phy";
reg = <0 0xe6590100 0 0x100>;
#size-cells = <0>;
clock-names = "usbhs";
usb0: usb-phy@0 {
reg = <0>;
#phy-cells = <1>;
usb2: usb-phy@2 {
reg = <2>;
#phy-cells = <1>;
usb_dmac0: dma-controller@e65a0000 {
compatible = "renesas,r8a7790-usb-dmac",
"renesas,usb-dmac";
reg = <0 0xe65a0000 0 0x100>;
interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "ch0", "ch1";
clocks = <&cpg CPG_MOD 330>;
resets = <&cpg 330>;
#dma-cells = <1>;
dma-channels = <2>;
usb_dmac1: dma-controller@e65b0000 {
"renesas,usb-dmac";
reg = <0 0xe65b0000 0 0x100>;
interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 331>;
resets = <&cpg 331>;
#dma-cells = <1>;
dma-channels = <2>;
dmac0: dma-controller@e6700000 {
compatible = "renesas,dmac-r8a7790",
"renesas,rcar-dmac";
reg = <0 0xe6700000 0 0x20000>;
interrupts = <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 200 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 201 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 202 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 203 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 204 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 205 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 206 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 207 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 208 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 209 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 210 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 211 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 212 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 213 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 214 IRQ_TYPE_LEVEL_HIGH>;
"ch0", "ch1", "ch2", "ch3",
"ch4", "ch5", "ch6", "ch7",
"ch8", "ch9", "ch10", "ch11",
"ch12", "ch13", "ch14";
clocks = <&cpg CPG_MOD 219>;
resets = <&cpg 219>;
#dma-cells = <1>;
dma-channels = <15>;
dmac1: dma-controller@e6720000 {
reg = <0 0xe6720000 0 0x20000>;
interrupts = <GIC_SPI 220 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 216 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 217 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 218 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 219 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 308 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 309 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 310 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 311 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 312 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 313 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 314 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 315 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 316 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 317 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 318 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 218>;
resets = <&cpg 218>;
#dma-cells = <1>;
avb: ethernet@e6800000 {
compatible = "renesas,etheravb-r8a7790",
"renesas,etheravb-rcar-gen2";
reg = <0 0xe6800000 0 0x800>, <0 0xee0e8000 0 0x4000>;
interrupts = <GIC_SPI 163 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 812>;
resets = <&cpg 812>;
#size-cells = <0>;
qspi: spi@e6b10000 {
compatible = "renesas,qspi-r8a7790", "renesas,qspi";
reg = <0 0xe6b10000 0 0x2c>;
dmas = <&dmac0 0x17>, <&dmac0 0x18>,
<&dmac1 0x17>, <&dmac1 0x18>;
num-cs = <1>;
#size-cells = <0>;
scifa0: serial@e6c40000 {
compatible = "renesas,scifa-r8a7790",
"renesas,rcar-gen2-scifa", "renesas,scifa";
reg = <0 0xe6c40000 0 64>;
interrupts = <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 204>;
dmas = <&dmac0 0x21>, <&dmac0 0x22>,
<&dmac1 0x21>, <&dmac1 0x22>;
resets = <&cpg 204>;
scifa1: serial@e6c50000 {
reg = <0 0xe6c50000 0 64>;
interrupts = <GIC_SPI 145 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 203>;
dmas = <&dmac0 0x25>, <&dmac0 0x26>,
<&dmac1 0x25>, <&dmac1 0x26>;
resets = <&cpg 203>;
scifa2: serial@e6c60000 {
reg = <0 0xe6c60000 0 64>;
interrupts = <GIC_SPI 151 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 202>;
dmas = <&dmac0 0x27>, <&dmac0 0x28>,
<&dmac1 0x27>, <&dmac1 0x28>;
resets = <&cpg 202>;
scifb0: serial@e6c20000 {
compatible = "renesas,scifb-r8a7790",
"renesas,rcar-gen2-scifb", "renesas,scifb";
reg = <0 0xe6c20000 0 0x100>;
interrupts = <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 206>;
dmas = <&dmac0 0x3d>, <&dmac0 0x3e>,
<&dmac1 0x3d>, <&dmac1 0x3e>;
resets = <&cpg 206>;
scifb1: serial@e6c30000 {
reg = <0 0xe6c30000 0 0x100>;
interrupts = <GIC_SPI 149 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 207>;
dmas = <&dmac0 0x19>, <&dmac0 0x1a>,
<&dmac1 0x19>, <&dmac1 0x1a>;
resets = <&cpg 207>;
scifb2: serial@e6ce0000 {
reg = <0 0xe6ce0000 0 0x100>;
interrupts = <GIC_SPI 150 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 216>;
dmas = <&dmac0 0x1d>, <&dmac0 0x1e>,
<&dmac1 0x1d>, <&dmac1 0x1e>;
resets = <&cpg 216>;
scif0: serial@e6e60000 {
compatible = "renesas,scif-r8a7790",
"renesas,rcar-gen2-scif",
"renesas,scif";
reg = <0 0xe6e60000 0 64>;
interrupts = <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 721>,
<&cpg CPG_CORE R8A7790_CLK_ZS>, <&scif_clk>;
clock-names = "fck", "brg_int", "scif_clk";
dmas = <&dmac0 0x29>, <&dmac0 0x2a>,
<&dmac1 0x29>, <&dmac1 0x2a>;
resets = <&cpg 721>;
scif1: serial@e6e68000 {
"renesas,scif";
reg = <0 0xe6e68000 0 64>;
interrupts = <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 720>,
dmas = <&dmac0 0x2d>, <&dmac0 0x2e>,
<&dmac1 0x2d>, <&dmac1 0x2e>;
resets = <&cpg 720>;
scif2: serial@e6e56000 {
"renesas,scif";
reg = <0 0xe6e56000 0 64>;
interrupts = <GIC_SPI 164 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 310>,
dmas = <&dmac0 0x2b>, <&dmac0 0x2c>,
<&dmac1 0x2b>, <&dmac1 0x2c>;
resets = <&cpg 310>;
hscif0: serial@e62c0000 {
compatible = "renesas,hscif-r8a7790",
"renesas,rcar-gen2-hscif", "renesas,hscif";
reg = <0 0xe62c0000 0 96>;
interrupts = <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 717>,
dmas = <&dmac0 0x39>, <&dmac0 0x3a>,
<&dmac1 0x39>, <&dmac1 0x3a>;
resets = <&cpg 717>;
hscif1: serial@e62c8000 {
reg = <0 0xe62c8000 0 96>;
interrupts = <GIC_SPI 155 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 716>,
dmas = <&dmac0 0x4d>, <&dmac0 0x4e>,
<&dmac1 0x4d>, <&dmac1 0x4e>;
msiof0: spi@e6e20000 {
compatible = "renesas,msiof-r8a7790",
"renesas,rcar-gen2-msiof";
reg = <0 0xe6e20000 0 0x0064>;
interrupts = <GIC_SPI 156 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 0>;
dmas = <&dmac0 0x51>, <&dmac0 0x52>,
<&dmac1 0x51>, <&dmac1 0x52>;
resets = <&cpg 0>;
#size-cells = <0>;
msiof1: spi@e6e10000 {
reg = <0 0xe6e10000 0 0x0064>;
interrupts = <GIC_SPI 157 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 208>;
dmas = <&dmac0 0x55>, <&dmac0 0x56>,
<&dmac1 0x55>, <&dmac1 0x56>;
resets = <&cpg 208>;
#size-cells = <0>;
msiof2: spi@e6e00000 {
reg = <0 0xe6e00000 0 0x0064>;
interrupts = <GIC_SPI 158 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 205>;
dmas = <&dmac0 0x41>, <&dmac0 0x42>,
<&dmac1 0x41>, <&dmac1 0x42>;
resets = <&cpg 205>;
#size-cells = <0>;
msiof3: spi@e6c90000 {
reg = <0 0xe6c90000 0 0x0064>;
interrupts = <GIC_SPI 159 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 215>;
dmas = <&dmac0 0x45>, <&dmac0 0x46>,
<&dmac1 0x45>, <&dmac1 0x46>;
resets = <&cpg 215>;
#size-cells = <0>;
pwm0: pwm@e6e30000 {
compatible = "renesas,pwm-r8a7790", "renesas,pwm-rcar";
reg = <0 0xe6e30000 0 0x8>;
clocks = <&cpg CPG_MOD 523>;
resets = <&cpg 523>;
#pwm-cells = <2>;
pwm1: pwm@e6e31000 {
reg = <0 0xe6e31000 0 0x8>;
#pwm-cells = <2>;
pwm2: pwm@e6e32000 {
reg = <0 0xe6e32000 0 0x8>;
#pwm-cells = <2>;
pwm3: pwm@e6e33000 {
reg = <0 0xe6e33000 0 0x8>;
#pwm-cells = <2>;
pwm4: pwm@e6e34000 {
reg = <0 0xe6e34000 0 0x8>;
#pwm-cells = <2>;
pwm5: pwm@e6e35000 {
reg = <0 0xe6e35000 0 0x8>;
#pwm-cells = <2>;
pwm6: pwm@e6e36000 {
reg = <0 0xe6e36000 0 0x8>;
#pwm-cells = <2>;
can0: can@e6e80000 {
compatible = "renesas,can-r8a7790",
"renesas,rcar-gen2-can";
reg = <0 0xe6e80000 0 0x1000>;
interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 916>,
<&cpg CPG_CORE R8A7790_CLK_RCAN>, <&can_clk>;
clock-names = "clkp1", "clkp2", "can_clk";
resets = <&cpg 916>;
can1: can@e6e88000 {
reg = <0 0xe6e88000 0 0x1000>;
interrupts = <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 915>,
resets = <&cpg 915>;
compatible = "renesas,vin-r8a7790",
"renesas,rcar-gen2-vin";
reg = <0 0xe6ef0000 0 0x1000>;
clocks = <&cpg CPG_MOD 811>;
resets = <&cpg 811>;
reg = <0 0xe6ef1000 0 0x1000>;
clocks = <&cpg CPG_MOD 810>;
resets = <&cpg 810>;
reg = <0 0xe6ef2000 0 0x1000>;
clocks = <&cpg CPG_MOD 809>;
resets = <&cpg 809>;
reg = <0 0xe6ef3000 0 0x1000>;
clocks = <&cpg CPG_MOD 808>;
resets = <&cpg 808>;
rcar_sound: sound@ec500000 {
* #sound-dai-cells is required if simple-card
* Single DAI : #sound-dai-cells = <0>; <&rcar_sound>;
* Multi DAI : #sound-dai-cells = <1>; <&rcar_sound N>;
compatible = "renesas,rcar_sound-r8a7790",
"renesas,rcar_sound-gen2";
reg = <0 0xec500000 0 0x1000>, /* SCU */
<0 0xec5a0000 0 0x100>, /* ADG */
<0 0xec540000 0 0x1000>, /* SSIU */
<0 0xec541000 0 0x280>, /* SSI */
<0 0xec740000 0 0x200>; /* Audio DMAC peri peri*/
reg-names = "scu", "adg", "ssiu", "ssi", "audmapp";
clocks = <&cpg CPG_MOD 1005>,
<&cpg CPG_MOD 1006>, <&cpg CPG_MOD 1007>,
<&cpg CPG_MOD 1008>, <&cpg CPG_MOD 1009>,
<&cpg CPG_MOD 1010>, <&cpg CPG_MOD 1011>,
<&cpg CPG_MOD 1012>, <&cpg CPG_MOD 1013>,
<&cpg CPG_MOD 1014>, <&cpg CPG_MOD 1015>,
<&cpg CPG_MOD 1022>, <&cpg CPG_MOD 1023>,
<&cpg CPG_MOD 1024>, <&cpg CPG_MOD 1025>,
<&cpg CPG_MOD 1026>, <&cpg CPG_MOD 1027>,
<&cpg CPG_MOD 1028>, <&cpg CPG_MOD 1029>,
<&cpg CPG_MOD 1030>, <&cpg CPG_MOD 1031>,
<&cpg CPG_MOD 1021>, <&cpg CPG_MOD 1020>,
<&cpg CPG_MOD 1019>, <&cpg CPG_MOD 1018>,
<&audio_clk_a>, <&audio_clk_b>, <&audio_clk_c>,
<&cpg CPG_CORE R8A7790_CLK_M2>;
clock-names = "ssi-all",
"ssi.9", "ssi.8", "ssi.7", "ssi.6",
"ssi.5", "ssi.4", "ssi.3", "ssi.2",
"ssi.1", "ssi.0",
"src.9", "src.8", "src.7", "src.6",
"src.5", "src.4", "src.3", "src.2",
"src.1", "src.0",
"ctu.0", "ctu.1",
"mix.0", "mix.1",
"dvc.0", "dvc.1",
"clk_a", "clk_b", "clk_c", "clk_i";
resets = <&cpg 1005>,
<&cpg 1006>, <&cpg 1007>,
<&cpg 1008>, <&cpg 1009>,
<&cpg 1010>, <&cpg 1011>,
<&cpg 1012>, <&cpg 1013>,
<&cpg 1014>, <&cpg 1015>;
reset-names = "ssi-all",
"ssi.1", "ssi.0";
rcar_sound,dvc {
dvc0: dvc-0 {
dma-names = "tx";
dvc1: dvc-1 {
dma-names = "tx";
rcar_sound,mix {
mix0: mix-0 { };
mix1: mix-1 { };
rcar_sound,ctu {
ctu00: ctu-0 { };
ctu01: ctu-1 { };
ctu02: ctu-2 { };
ctu03: ctu-3 { };
ctu10: ctu-4 { };
ctu11: ctu-5 { };
ctu12: ctu-6 { };
ctu13: ctu-7 { };
rcar_sound,src {
src0: src-0 {
interrupts = <GIC_SPI 352 IRQ_TYPE_LEVEL_HIGH>;
dma-names = "rx", "tx";
src1: src-1 {
interrupts = <GIC_SPI 353 IRQ_TYPE_LEVEL_HIGH>;
src2: src-2 {
interrupts = <GIC_SPI 354 IRQ_TYPE_LEVEL_HIGH>;
src3: src-3 {
interrupts = <GIC_SPI 355 IRQ_TYPE_LEVEL_HIGH>;
src4: src-4 {
interrupts = <GIC_SPI 356 IRQ_TYPE_LEVEL_HIGH>;
src5: src-5 {
interrupts = <GIC_SPI 357 IRQ_TYPE_LEVEL_HIGH>;
src6: src-6 {
interrupts = <GIC_SPI 358 IRQ_TYPE_LEVEL_HIGH>;
src7: src-7 {
interrupts = <GIC_SPI 359 IRQ_TYPE_LEVEL_HIGH>;
src8: src-8 {
interrupts = <GIC_SPI 360 IRQ_TYPE_LEVEL_HIGH>;
src9: src-9 {
interrupts = <GIC_SPI 361 IRQ_TYPE_LEVEL_HIGH>;
rcar_sound,ssi {
ssi0: ssi-0 {
interrupts = <GIC_SPI 370 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x01>, <&audma1 0x02>,
dma-names = "rx", "tx", "rxu", "txu";
ssi1: ssi-1 {
interrupts = <GIC_SPI 371 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x03>, <&audma1 0x04>,
ssi2: ssi-2 {
interrupts = <GIC_SPI 372 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x05>, <&audma1 0x06>,
ssi3: ssi-3 {
interrupts = <GIC_SPI 373 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x07>, <&audma1 0x08>,
ssi4: ssi-4 {
interrupts = <GIC_SPI 374 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x09>, <&audma1 0x0a>,
ssi5: ssi-5 {
interrupts = <GIC_SPI 375 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x0b>, <&audma1 0x0c>,
ssi6: ssi-6 {
interrupts = <GIC_SPI 376 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x0d>, <&audma1 0x0e>,
ssi7: ssi-7 {
interrupts = <GIC_SPI 377 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x0f>, <&audma1 0x10>,
ssi8: ssi-8 {
interrupts = <GIC_SPI 378 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x11>, <&audma1 0x12>,
ssi9: ssi-9 {
interrupts = <GIC_SPI 379 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x13>, <&audma1 0x14>,
interrupts = <GIC_SPI 346 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 332 IRQ_TYPE_LEVEL_HIGH>;
"ch12";
#dma-cells = <1>;
dma-channels = <13>;
interrupts = <GIC_SPI 347 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 335 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 345 IRQ_TYPE_LEVEL_HIGH>;
"ch12";
#dma-cells = <1>;
xhci: usb@ee000000 {
compatible = "renesas,xhci-r8a7790",
"renesas,rcar-gen2-xhci";
interrupts = <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>;
resets = <&cpg 328>;
phys = <&usb2 1>;
phy-names = "usb";
pci0: pci@ee090000 {
compatible = "renesas,pci-r8a7790",
"renesas,pci-rcar-gen2";
reg = <0 0xee090000 0 0xc00>,
<0 0xee080000 0 0x1100>;
clocks = <&cpg CPG_MOD 703>;
resets = <&cpg 703>;
bus-range = <0 0>;
#size-cells = <2>;
ranges = <0x02000000 0 0xee080000 0 0xee080000 0 0x00010000>;
interrupt-map-mask = <0xf800 0 0 0x7>;
interrupt-map = <0x0000 0 0 1 &gic GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>,
<0x0800 0 0 1 &gic GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>,
<0x1000 0 0 2 &gic GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>;
usb@1,0 {
reg = <0x800 0 0 0 0>;
phys = <&usb0 0>;
phy-names = "usb";
usb@2,0 {
reg = <0x1000 0 0 0 0>;
phys = <&usb0 0>;
phy-names = "usb";
pci1: pci@ee0b0000 {
reg = <0 0xee0b0000 0 0xc00>,
<0 0xee0a0000 0 0x1100>;
bus-range = <1 1>;
#size-cells = <2>;
ranges = <0x02000000 0 0xee0a0000 0 0xee0a0000 0 0x00010000>;
interrupt-map = <0x0000 0 0 1 &gic GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>,
<0x0800 0 0 1 &gic GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>,
<0x1000 0 0 2 &gic GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>;
pci2: pci@ee0d0000 {
reg = <0 0xee0d0000 0 0xc00>,
<0 0xee0c0000 0 0x1100>;
interrupts = <GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH>;
bus-range = <2 2>;
#size-cells = <2>;
ranges = <0x02000000 0 0xee0c0000 0 0xee0c0000 0 0x00010000>;
interrupt-map = <0x0000 0 0 1 &gic GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH>,
<0x0800 0 0 1 &gic GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH>,
<0x1000 0 0 2 &gic GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH>;
usb@1,0 {
reg = <0x20800 0 0 0 0>;
phys = <&usb2 0>;
phy-names = "usb";
usb@2,0 {
reg = <0x21000 0 0 0 0>;
phys = <&usb2 0>;
phy-names = "usb";
compatible = "renesas,sdhi-r8a7790",
"renesas,rcar-gen2-sdhi";
reg = <0 0xee100000 0 0x328>;
clocks = <&cpg CPG_MOD 314>;
dmas = <&dmac0 0xcd>, <&dmac0 0xce>,
<&dmac1 0xcd>, <&dmac1 0xce>;
max-frequency = <195000000>;
reg = <0 0xee120000 0 0x328>;
clocks = <&cpg CPG_MOD 313>;
dmas = <&dmac0 0xc9>, <&dmac0 0xca>,
<&dmac1 0xc9>, <&dmac1 0xca>;
reg = <0 0xee140000 0 0x100>;
clocks = <&cpg CPG_MOD 312>;
dmas = <&dmac0 0xc1>, <&dmac0 0xc2>,
<&dmac1 0xc1>, <&dmac1 0xc2>;
max-frequency = <97500000>;
reg = <0 0xee160000 0 0x100>;
clocks = <&cpg CPG_MOD 311>;
dmas = <&dmac0 0xd3>, <&dmac0 0xd4>,
<&dmac1 0xd3>, <&dmac1 0xd4>;
mmcif0: mmc@ee200000 {
compatible = "renesas,mmcif-r8a7790",
"renesas,sh-mmcif";
reg = <0 0xee200000 0 0x80>;
interrupts = <GIC_SPI 169 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 315>;
dmas = <&dmac0 0xd1>, <&dmac0 0xd2>,
<&dmac1 0xd1>, <&dmac1 0xd2>;
resets = <&cpg 315>;
reg-io-width = <4>;
mmcif1: mmc@ee220000 {
"renesas,sh-mmcif";
reg = <0 0xee220000 0 0x80>;
interrupts = <GIC_SPI 170 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 305>;
dmas = <&dmac0 0xe1>, <&dmac0 0xe2>,
<&dmac1 0xe1>, <&dmac1 0xe2>;
resets = <&cpg 305>;
reg-io-width = <4>;
sata0: sata@ee300000 {
compatible = "renesas,sata-r8a7790",
"renesas,rcar-gen2-sata";
reg = <0 0xee300000 0 0x200000>;
interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 815>;
resets = <&cpg 815>;
sata1: sata@ee500000 {
reg = <0 0xee500000 0 0x200000>;
interrupts = <GIC_SPI 106 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 814>;
resets = <&cpg 814>;
ether: ethernet@ee700000 {
compatible = "renesas,ether-r8a7790",
"renesas,rcar-gen2-ether";
reg = <0 0xee700000 0 0x400>;
interrupts = <GIC_SPI 162 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 813>;
resets = <&cpg 813>;
phy-mode = "rmii";
#size-cells = <0>;
gic: interrupt-controller@f1001000 {
#interrupt-cells = <3>;
#address-cells = <0>;
reg = <0 0xf1001000 0 0x1000>, <0 0xf1002000 0 0x2000>,
<0 0xf1004000 0 0x2000>, <0 0xf1006000 0 0x2000>;
interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_HIGH)>;
pciec: pcie@fe000000 {
compatible = "renesas,pcie-r8a7790",
"renesas,pcie-rcar-gen2";
#size-cells = <2>;
/* Map all possible DDR as inbound ranges */
dma-ranges = <0x42000000 0 0x40000000 0 0x40000000 0 0x80000000>,
<0x43000000 1 0x80000000 1 0x80000000 0 0x80000000>;
vsp@fe920000 {
compatible = "renesas,vsp1";
clocks = <&cpg CPG_MOD 130>;
resets = <&cpg 130>;
vsp@fe928000 {
reg = <0 0xfe928000 0 0x8000>;
interrupts = <GIC_SPI 267 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 131>;
resets = <&cpg 131>;
vsp@fe930000 {
reg = <0 0xfe930000 0 0x8000>;
clocks = <&cpg CPG_MOD 128>;
resets = <&cpg 128>;
vsp@fe938000 {
reg = <0 0xfe938000 0 0x8000>;
interrupts = <GIC_SPI 247 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 127>;
resets = <&cpg 127>;
fdp1@fe940000 {
fdp1@fe944000 {
fdp1@fe948000 {
reg = <0 0xfe948000 0 0x2400>;
interrupts = <GIC_SPI 264 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 117>;
resets = <&cpg 117>;
jpu: jpeg-codec@fe980000 {
compatible = "renesas,jpu-r8a7790",
"renesas,rcar-gen2-jpu";
reg = <0 0xfe980000 0 0x10300>;
interrupts = <GIC_SPI 272 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 106>;
resets = <&cpg 106>;
compatible = "renesas,du-r8a7790";
reg = <0 0xfeb00000 0 0x70000>;
<GIC_SPI 269 IRQ_TYPE_LEVEL_HIGH>;
<&cpg CPG_MOD 722>;
clock-names = "du.0", "du.1", "du.2";
resets = <&cpg 724>;
reset-names = "du.0";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
du_out_rgb: endpoint {
port@1 {
reg = <1>;
port@2 {
reg = <2>;
du_out_lvds1: endpoint {
remote-endpoint = <&lvds1_in>;
compatible = "renesas,r8a7790-lvds";
reg = <0 0xfeb90000 0 0x1c>;
clocks = <&cpg CPG_MOD 726>;
resets = <&cpg 726>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port@1 {
reg = <1>;
lvds0_out: endpoint {
lvds1: lvds@feb94000 {
reg = <0 0xfeb94000 0 0x1c>;
clocks = <&cpg CPG_MOD 725>;
resets = <&cpg 725>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
lvds1_in: endpoint {
remote-endpoint = <&du_out_lvds1>;
port@1 {
reg = <1>;
lvds1_out: endpoint {
prr: chipid@ff000044 {
reg = <0 0xff000044 0 4>;
cmt0: timer@ffca0000 {
compatible = "renesas,r8a7790-cmt0",
"renesas,rcar-gen2-cmt0";
reg = <0 0xffca0000 0 0x1004>;
interrupts = <GIC_SPI 142 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 143 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 124>;
resets = <&cpg 124>;
cmt1: timer@e6130000 {
compatible = "renesas,r8a7790-cmt1",
"renesas,rcar-gen2-cmt1";
reg = <0 0xe6130000 0 0x1004>;
interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 127 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 329>;
resets = <&cpg 329>;
thermal-zones {
cpu_thermal: cpu-thermal {
polling-delay-passive = <0>;
polling-delay = <0>;
thermal-sensors = <&thermal>;
trips {
cpu-crit {
temperature = <95000>;
hysteresis = <0>;
type = "critical";
cooling-maps {
timer {
compatible = "arm,armv7-timer";
/* External USB clock - can be overridden by the board */
#clock-cells = <0>;
clock-frequency = <48000000>;
-}; diff --git a/arch/arm/dts/r8a7791-koelsch.dts b/arch/arm/dts/r8a7791-koelsch.dts deleted file mode 100644 index 26a40782cc8..00000000000 --- a/arch/arm/dts/r8a7791-koelsch.dts +++ /dev/null @@ -1,912 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Device Tree Source for the Koelsch board
- Copyright (C) 2013 Renesas Electronics Corporation
- SSI-AK4643
- SW1: 1: AK4643
2: CN22
3: ADV7511
- You can use Mute
aplay xxx.wav &
-/dts-v1/; -#include "r8a7791.dtsi" -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/input/input.h>
model = "Koelsch";
compatible = "renesas,koelsch", "renesas,r8a7791";
aliases {
serial0 = &scif0;
serial1 = &scif1;
i2c9 = &gpioi2c1;
i2c10 = &gpioi2c2;
i2c11 = &gpioi2c4;
i2c12 = &i2cexio1;
i2c13 = &i2chdmi;
i2c14 = &i2cexio4;
mmc0 = &sdhi0;
mmc1 = &sdhi1;
mmc2 = &sdhi2;
chosen {
memory@40000000 {
memory@200000000 {
reg = <2 0x00000000 0 0x40000000>;
lbsc {
#size-cells = <1>;
keyboard {
key-1 {
gpios = <&gpio5 0 GPIO_ACTIVE_LOW>;
label = "SW2-1";
wakeup-source;
key-2 {
gpios = <&gpio5 1 GPIO_ACTIVE_LOW>;
label = "SW2-2";
wakeup-source;
key-3 {
gpios = <&gpio5 2 GPIO_ACTIVE_LOW>;
label = "SW2-3";
wakeup-source;
key-4 {
gpios = <&gpio5 3 GPIO_ACTIVE_LOW>;
label = "SW2-4";
wakeup-source;
key-a {
gpios = <&gpio7 0 GPIO_ACTIVE_LOW>;
linux,code = <KEY_A>;
label = "SW30";
wakeup-source;
key-b {
gpios = <&gpio7 1 GPIO_ACTIVE_LOW>;
linux,code = <KEY_B>;
label = "SW31";
wakeup-source;
key-c {
gpios = <&gpio7 2 GPIO_ACTIVE_LOW>;
linux,code = <KEY_C>;
label = "SW32";
wakeup-source;
key-d {
gpios = <&gpio7 3 GPIO_ACTIVE_LOW>;
linux,code = <KEY_D>;
label = "SW33";
wakeup-source;
key-e {
gpios = <&gpio7 4 GPIO_ACTIVE_LOW>;
linux,code = <KEY_E>;
label = "SW34";
wakeup-source;
key-f {
gpios = <&gpio7 5 GPIO_ACTIVE_LOW>;
linux,code = <KEY_F>;
label = "SW35";
wakeup-source;
key-g {
gpios = <&gpio7 6 GPIO_ACTIVE_LOW>;
linux,code = <KEY_G>;
label = "SW36";
wakeup-source;
leds {
led6 {
gpios = <&gpio2 19 GPIO_ACTIVE_HIGH>;
label = "LED6";
led7 {
gpios = <&gpio2 20 GPIO_ACTIVE_HIGH>;
label = "LED7";
led8 {
gpios = <&gpio2 21 GPIO_ACTIVE_HIGH>;
label = "LED8";
gpio = <&gpio7 17 GPIO_ACTIVE_HIGH>;
enable-active-high;
gpios = <&gpio2 12 GPIO_ACTIVE_HIGH>;
gpios-states = <1>;
vcc_sdhi1: regulator-vcc-sdhi1 {
regulator-name = "SDHI1 Vcc";
gpio = <&gpio7 18 GPIO_ACTIVE_HIGH>;
enable-active-high;
vccq_sdhi1: regulator-vccq-sdhi1 {
regulator-name = "SDHI1 VccQ";
gpios = <&gpio2 13 GPIO_ACTIVE_HIGH>;
gpios-states = <1>;
gpio = <&gpio7 19 GPIO_ACTIVE_HIGH>;
enable-active-high;
gpios = <&gpio2 26 GPIO_ACTIVE_HIGH>;
gpios-states = <1>;
#clock-cells = <0>;
hdmi-in {
type = "a";
port {
#clock-cells = <0>;
hdmi-out {
type = "a";
port {
x2_clk: x2-clock {
#clock-cells = <0>;
clock-frequency = <74250000>;
#clock-cells = <0>;
gpioi2c1: i2c-9 {
#size-cells = <0>;
scl-gpios = <&gpio7 15 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>;
sda-gpios = <&gpio7 16 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>;
gpioi2c2: i2c-10 {
#size-cells = <0>;
scl-gpios = <&gpio2 6 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>;
sda-gpios = <&gpio2 7 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>;
gpioi2c4: i2c-11 {
#size-cells = <0>;
scl-gpios = <&gpio7 13 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>;
sda-gpios = <&gpio7 14 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>;
* I2C1 is routed to EXIO connector B, pins 64 (SCL) + 66 (SDA).
* A fallback to GPIO is provided.
i2cexio1: i2c-12 {
i2c-parent = <&i2c1>, <&gpioi2c1>;
#size-cells = <0>;
* A fallback to GPIO is provided for I2C2.
i2chdmi: i2c-13 {
i2c-parent = <&i2c2>, <&gpioi2c2>;
#size-cells = <0>;
ak4643: codec@12 {
reg = <0x12>;
composite-in@20 {
reg = <0x20>;
port {
adv7180: endpoint {
bus-width = <8>;
remote-endpoint = <&vin1ep>;
hdmi@39 {
reg = <0x39>;
interrupt-parent = <&gpio3>;
interrupts = <29 IRQ_TYPE_LEVEL_LOW>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port@1 {
reg = <1>;
hdmi-in@4c {
reg = <0x4c>;
interrupt-parent = <&gpio4>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port@2 {
reg = <2>;
eeprom@50 {
compatible = "renesas,r1ex24002", "atmel,24c02";
reg = <0x50>;
pagesize = <16>;
* I2C4 is routed to EXIO connector E, pins 37 (SCL) + 39 (SDA).
i2cexio4: i2c-14 {
i2c-parent = <&i2c4>, <&gpioi2c4>;
i2c-bus-name = "i2c-exio4";
#size-cells = <0>;
-&du {
status = "okay";
clock-names = "du.0", "du.1", "dclkin.0", "dclkin.1";
ports {
port@0 {
endpoint {
-&lvds0 {
ports {
port@1 {
-&extal_clk {
-&pfc {
i2c1_pins: i2c1 {
groups = "i2c1";
function = "i2c1";
i2c2_pins: i2c2 {
groups = "i2c2";
function = "i2c2";
i2c4_pins: i2c4 {
groups = "i2c4_c";
function = "i2c4";
du_pins: du {
groups = "du_rgb888", "du_sync", "du_disp", "du_clk_out_0";
function = "du";
scif0_pins: scif0 {
groups = "scif0_data_d";
function = "scif0";
scif1_pins: scif1 {
groups = "scif1_data_d";
function = "scif1";
ether_pins: ether {
function = "eth";
phy1_pins: phy1 {
function = "intc";
function = "intc";
sdhi0_pins: sd0 {
function = "sdhi0";
function = "sdhi0";
sdhi1_pins: sd1 {
groups = "sdhi1_data4", "sdhi1_ctrl";
function = "sdhi1";
sdhi1_pins_uhs: sd1_uhs {
function = "sdhi1";
sdhi2_pins: sd2 {
function = "sdhi2";
function = "sdhi2";
qspi_pins: qspi {
function = "qspi";
msiof0_pins: msiof0 {
groups = "msiof0_clk", "msiof0_sync", "msiof0_rx",
"msiof0_tx";
function = "msiof0";
usb0_pins: usb0 {
groups = "usb0";
function = "usb0";
usb1_pins: usb1 {
groups = "usb1";
function = "usb1";
vin0_pins: vin0 {
function = "vin0";
vin1_pins: vin1 {
function = "vin1";
sound_pins: sound {
function = "ssi";
pins = "GP_5_0", "GP_5_1", "GP_5_2", "GP_5_3";
bias-pull-up;
-ðer {
status = "okay";
reg = <1>;
reset-gpios = <&gpio5 22 GPIO_ACTIVE_LOW>;
-&cmt0 {
status = "okay";
-&rwdt {
timeout-sec = <60>;
status = "okay";
-&sata0 {
status = "okay";
-&scif0 {
status = "okay";
-&scif1 {
pinctrl-0 = <&scif1_pins>;
status = "okay";
-&scif_clk {
-&sdhi0 {
cd-gpios = <&gpio6 6 GPIO_ACTIVE_LOW>;
wp-gpios = <&gpio6 7 GPIO_ACTIVE_HIGH>;
sd-uhs-sdr50;
sd-uhs-sdr104;
status = "okay";
-&sdhi1 {
pinctrl-0 = <&sdhi1_pins>;
pinctrl-1 = <&sdhi1_pins_uhs>;
vmmc-supply = <&vcc_sdhi1>;
vqmmc-supply = <&vccq_sdhi1>;
cd-gpios = <&gpio6 14 GPIO_ACTIVE_LOW>;
wp-gpios = <&gpio6 15 GPIO_ACTIVE_HIGH>;
sd-uhs-sdr50;
status = "okay";
-&sdhi2 {
cd-gpios = <&gpio6 22 GPIO_ACTIVE_LOW>;
sd-uhs-sdr50;
status = "okay";
-&qspi {
status = "okay";
flash: flash@0 {
reg = <0>;
spi-cpha;
spi-cpol;
m25p,fast-read;
partitions {
#address-cells = <1>;
#size-cells = <1>;
partition@0 {
label = "loader";
read-only;
partition@80000 {
label = "user";
reg = <0x00080000 0x00580000>;
read-only;
partition@600000 {
label = "flash";
reg = <0x00600000 0x03a00000>;
-&msiof0 {
pinctrl-0 = <&msiof0_pins>;
status = "okay";
pmic: pmic@0 {
reg = <0>;
spi-cpol;
spi-cpha;
-&i2c1 {
-&i2c2 {
-&i2c4 {
pinctrl-0 = <&i2c4_pins>;
pinctrl-names = "i2c-exio4";
-&i2c6 {
status = "okay";
pmic@58 {
reg = <0x58>;
interrupt-controller;
rtc {
watchdog {
reg = <0x68>;
regulator-boot-on;
-&pci0 {
status = "okay";
-&pci1 {
status = "okay";
-&hsusb {
status = "okay";
renesas,enable-gpio = <&gpio5 31 GPIO_ACTIVE_HIGH>;
-&usbphy {
status = "okay";
-&pcie_bus_clk {
clock-frequency = <100000000>;
-&pciec {
status = "okay";
-&cpu0 {
status = "okay";
port {
vin0ep2: endpoint {
bus-width = <24>;
hsync-active = <0>;
vsync-active = <0>;
pclk-sample = <1>;
data-active = <1>;
status = "okay";
port {
vin1ep: endpoint {
bus-width = <8>;
-&rcar_sound {
/* Single DAI */
status = "okay";
rcar_sound,dai {
dai0 {
-&ssi1 {
shared-pin;
-}; diff --git a/arch/arm/dts/r8a7791-porter.dts b/arch/arm/dts/r8a7791-porter.dts deleted file mode 100644 index ec0a20d5130..00000000000 --- a/arch/arm/dts/r8a7791-porter.dts +++ /dev/null @@ -1,523 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Device Tree Source for the Porter board
- Copyright (C) 2015 Cogent Embedded, Inc.
- SSI-AK4642
- JP3: 2-1: AK4642
2-3: ADV7511
- This command is required before playback/capture:
model = "Porter";
compatible = "renesas,porter", "renesas,r8a7791";
aliases {
serial0 = &scif0;
i2c9 = &gpioi2c2;
i2c10 = &i2chdmi;
mmc0 = &sdhi0;
mmc1 = &sdhi2;
chosen {
memory@40000000 {
memory@200000000 {
gpios-states = <1>;
gpios-states = <1>;
hdmi-out {
type = "a";
port {
hdmi_con: endpoint {
x3_clk: x3-clock {
#clock-cells = <0>;
x16_clk: x16-clock {
#clock-cells = <0>;
x14_clk: audio_clock {
#clock-cells = <0>;
sound {
simple-audio-card,bitclock-master = <&soundcodec>;
simple-audio-card,frame-master = <&soundcodec>;
soundcodec: simple-audio-card,codec {
sound-dai = <&ak4642>;
clocks = <&x14_clk>;
gpioi2c2: i2c-9 {
#size-cells = <0>;
status = "disabled";
i2chdmi: i2c-10 {
#size-cells = <0>;
ak4642: codec@12 {
compatible = "asahi-kasei,ak4642";
reg = <0x12>;
composite-in@20 {
reg = <0x20>;
port {
adv7180: endpoint {
bus-width = <8>;
remote-endpoint = <&vin0ep>;
hdmi@39 {
reg = <0x39>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port@1 {
reg = <1>;
remote-endpoint = <&hdmi_con>;
-&extal_clk {
-&pfc {
scif0_pins: scif0 {
function = "scif0";
ether_pins: ether {
function = "eth";
phy1_pins: phy1 {
function = "intc";
function = "intc";
sdhi0_pins: sd0 {
function = "sdhi0";
sdhi2_pins: sd2 {
function = "sdhi2";
qspi_pins: qspi {
function = "qspi";
i2c2_pins: i2c2 {
groups = "i2c2";
function = "i2c2";
usb0_pins: usb0 {
groups = "usb0";
function = "usb0";
usb1_pins: usb1 {
groups = "usb1";
function = "usb1";
vin0_pins: vin0 {
groups = "vin0_data8", "vin0_clk";
function = "vin0";
can0_pins: can0 {
groups = "can0_data";
function = "can0";
du_pins: du {
function = "du";
ssi_pins: sound {
function = "ssi";
audio_clk_pins: audio_clk {
-&scif0 {
status = "okay";
-ðer {
status = "okay";
reg = <1>;
-&sdhi0 {
status = "okay";
-&sdhi2 {
status = "okay";
-&qspi {
status = "okay";
flash@0 {
reg = <0>;
m25p,fast-read;
partitions {
#size-cells = <1>;
partition@0 {
label = "loader_prg";
read-only;
partition@40000 {
label = "user_prg";
read-only;
partition@440000 {
label = "flash_fs";
-&i2c2 {
clock-frequency = <400000>;
-&i2c6 {
status = "okay";
pmic@5a {
compatible = "dlg,da9063l";
reg = <0x5a>;
watchdog {
reg = <0x68>;
regulator-boot-on;
-&sata0 {
status = "okay";
-&cpu0 {
-/* composite video input */ -&vin0 {
status = "okay";
port {
vin0ep: endpoint {
bus-width = <8>;
-&pci0 {
status = "okay";
-&pci1 {
status = "okay";
-&hsusb {
status = "okay";
-&usbphy {
status = "okay";
-&pcie_bus_clk {
-&pciec {
status = "okay";
-&can0 {
pinctrl-0 = <&can0_pins>;
status = "okay";
-&du {
status = "okay";
<&x3_clk>, <&x16_clk>;
ports {
port@0 {
endpoint {
-&lvds0 {
ports {
port@1 {
-&rcar_sound {
pinctrl-0 = <&ssi_pins>, <&audio_clk_pins>;
status = "okay";
/* Single DAI */
rcar_sound,dai {
dai0 {
playback = <&ssi0>;
capture = <&ssi1>;
-&rwdt {
timeout-sec = <60>;
status = "okay";
-&ssi1 {
shared-pin;
-}; diff --git a/arch/arm/dts/r8a7791.dtsi b/arch/arm/dts/r8a7791.dtsi deleted file mode 100644 index b9d34147628..00000000000 --- a/arch/arm/dts/r8a7791.dtsi +++ /dev/null @@ -1,1891 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Device Tree Source for the R-Car M2-W (R8A77910) SoC
- Copyright (C) 2013-2015 Renesas Electronics Corporation
-#include <dt-bindings/clock/r8a7791-cpg-mssr.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/power/r8a7791-sysc.h>
compatible = "renesas,r8a7791";
#size-cells = <2>;
aliases {
i2c0 = &i2c0;
i2c1 = &i2c1;
i2c2 = &i2c2;
i2c3 = &i2c3;
i2c4 = &i2c4;
i2c5 = &i2c5;
i2c6 = &i2c6;
i2c7 = &i2c7;
i2c8 = &i2c8;
spi0 = &qspi;
spi1 = &msiof0;
spi2 = &msiof1;
spi3 = &msiof2;
vin0 = &vin0;
vin1 = &vin1;
vin2 = &vin2;
#clock-cells = <0>;
#clock-cells = <0>;
#clock-cells = <0>;
can_clk: can {
#clock-cells = <0>;
cpus {
#size-cells = <0>;
cpu0: cpu@0 {
reg = <0>;
clock-frequency = <1500000000>;
clocks = <&cpg CPG_CORE R8A7791_CLK_Z>;
power-domains = <&sysc R8A7791_PD_CA15_CPU0>;
operating-points = <1500000 1000000>,
<1312500 1000000>,
<1125000 1000000>,
< 937500 1000000>,
< 750000 1000000>,
< 375000 1000000>;
cpu1: cpu@1 {
reg = <1>;
power-domains = <&sysc R8A7791_PD_CA15_CPU1>;
<1312500 1000000>,
<1125000 1000000>,
< 937500 1000000>,
< 750000 1000000>,
< 375000 1000000>;
power-domains = <&sysc R8A7791_PD_CA15_SCU>;
cache-unified;
cache-level = <2>;
extal_clk: extal {
#clock-cells = <0>;
#clock-cells = <0>;
pmu {
interrupts-extended = <&gic GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>,
<&gic GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>;
interrupt-affinity = <&cpu0>, <&cpu1>;
scif_clk: scif {
#clock-cells = <0>;
soc {
#size-cells = <2>;
ranges;
compatible = "renesas,r8a7791-wdt",
power-domains = <&sysc R8A7791_PD_ALWAYS_ON>;
compatible = "renesas,gpio-r8a7791",
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 32 26>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 64 32>;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
gpio6: gpio@e6055400 {
reg = <0 0xe6055400 0 0x50>;
interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 192 32>;
clocks = <&cpg CPG_MOD 905>;
resets = <&cpg 905>;
gpio7: gpio@e6055800 {
reg = <0 0xe6055800 0 0x50>;
interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 224 26>;
clocks = <&cpg CPG_MOD 904>;
resets = <&cpg 904>;
compatible = "renesas,pfc-r8a7791";
tpu: pwm@e60f0000 {
compatible = "renesas,tpu-r8a7791", "renesas,tpu";
#pwm-cells = <3>;
compatible = "renesas,r8a7791-cpg-mssr";
#clock-cells = <2>;
#reset-cells = <1>;
apmu@e6152000 {
compatible = "renesas,r8a7791-apmu", "renesas,apmu";
cpus = <&cpu0>, <&cpu1>;
compatible = "renesas,r8a7791-rst";
compatible = "renesas,r8a7791-sysc";
compatible = "renesas,irqc-r8a7791", "renesas,irqc";
<GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>;
compatible = "renesas,thermal-r8a7791",
compatible = "renesas,ipmmu-r8a7791",
#iommu-cells = <1>;
#iommu-cells = <1>;
#iommu-cells = <1>;
#iommu-cells = <1>;
#iommu-cells = <1>;
#iommu-cells = <1>;
ipmmu_gp: iommu@e62a0000 {
reg = <0 0xe62a0000 0 0x1000>;
interrupts = <GIC_SPI 260 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 261 IRQ_TYPE_LEVEL_HIGH>;
#iommu-cells = <1>;
#size-cells = <1>;
#size-cells = <1>;
smp-sram@0 {
reg = <0 0x100>;
/* The memory map in the User's Manual maps the cores to
* bus numbers
#size-cells = <0>;
compatible = "renesas,i2c-r8a7791",
#size-cells = <0>;
#size-cells = <0>;
#size-cells = <0>;
i2c4: i2c@e6520000 {
#size-cells = <0>;
reg = <0 0xe6520000 0 0x40>;
interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 927>;
resets = <&cpg 927>;
i2c5: i2c@e6528000 {
/* doesn't need pinmux */
#size-cells = <0>;
reg = <0 0xe6528000 0 0x40>;
interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 925>;
resets = <&cpg 925>;
i2c6: i2c@e60b0000 {
#size-cells = <0>;
compatible = "renesas,iic-r8a7791",
i2c7: i2c@e6500000 {
#size-cells = <0>;
clocks = <&cpg CPG_MOD 318>;
resets = <&cpg 318>;
i2c8: i2c@e6510000 {
#size-cells = <0>;
compatible = "renesas,usbhs-r8a7791",
phys = <&usb0 1>;
phy-names = "usb";
compatible = "renesas,usb-phy-r8a7791",
#size-cells = <0>;
usb0: usb-phy@0 {
reg = <0>;
#phy-cells = <1>;
usb2: usb-phy@2 {
reg = <2>;
#phy-cells = <1>;
compatible = "renesas,r8a7791-usb-dmac",
"renesas,usb-dmac";
#dma-cells = <1>;
dma-channels = <2>;
"renesas,usb-dmac";
#dma-cells = <1>;
dma-channels = <2>;
compatible = "renesas,dmac-r8a7791",
interrupt-names = "error",
clock-names = "fck";
#dma-cells = <1>;
#dma-cells = <1>;
compatible = "renesas,etheravb-r8a7791",
#size-cells = <0>;
compatible = "renesas,qspi-r8a7791", "renesas,qspi";
interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 917>;
resets = <&cpg 917>;
num-cs = <1>;
#size-cells = <0>;
compatible = "renesas,scifa-r8a7791",
scifa3: serial@e6c70000 {
reg = <0 0xe6c70000 0 64>;
interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 1106>;
dmas = <&dmac0 0x1b>, <&dmac0 0x1c>,
<&dmac1 0x1b>, <&dmac1 0x1c>;
resets = <&cpg 1106>;
scifa4: serial@e6c78000 {
reg = <0 0xe6c78000 0 64>;
interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 1107>;
dmas = <&dmac0 0x1f>, <&dmac0 0x20>,
<&dmac1 0x1f>, <&dmac1 0x20>;
resets = <&cpg 1107>;
scifa5: serial@e6c80000 {
reg = <0 0xe6c80000 0 64>;
interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 1108>;
dmas = <&dmac0 0x23>, <&dmac0 0x24>,
<&dmac1 0x23>, <&dmac1 0x24>;
resets = <&cpg 1108>;
compatible = "renesas,scifb-r8a7791",
compatible = "renesas,scif-r8a7791",
"renesas,rcar-gen2-scif", "renesas,scif";
clocks = <&cpg CPG_MOD 721>, <&cpg CPG_CORE R8A7791_CLK_ZS>,
<&scif_clk>;
clocks = <&cpg CPG_MOD 720>, <&cpg CPG_CORE R8A7791_CLK_ZS>,
<&scif_clk>;
scif2: serial@e6e58000 {
reg = <0 0xe6e58000 0 64>;
interrupts = <GIC_SPI 22 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 719>, <&cpg CPG_CORE R8A7791_CLK_ZS>,
<&scif_clk>;
resets = <&cpg 719>;
scif3: serial@e6ea8000 {
reg = <0 0xe6ea8000 0 64>;
interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 718>, <&cpg CPG_CORE R8A7791_CLK_ZS>,
<&scif_clk>;
dmas = <&dmac0 0x2f>, <&dmac0 0x30>,
<&dmac1 0x2f>, <&dmac1 0x30>;
resets = <&cpg 718>;
scif4: serial@e6ee0000 {
reg = <0 0xe6ee0000 0 64>;
interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 715>, <&cpg CPG_CORE R8A7791_CLK_ZS>,
<&scif_clk>;
dmas = <&dmac0 0xfb>, <&dmac0 0xfc>,
<&dmac1 0xfb>, <&dmac1 0xfc>;
resets = <&cpg 715>;
scif5: serial@e6ee8000 {
reg = <0 0xe6ee8000 0 64>;
interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 714>, <&cpg CPG_CORE R8A7791_CLK_ZS>,
<&scif_clk>;
dmas = <&dmac0 0xfd>, <&dmac0 0xfe>,
<&dmac1 0xfd>, <&dmac1 0xfe>;
resets = <&cpg 714>;
compatible = "renesas,hscif-r8a7791",
clocks = <&cpg CPG_MOD 717>, <&cpg CPG_CORE R8A7791_CLK_ZS>,
<&scif_clk>;
clocks = <&cpg CPG_MOD 716>, <&cpg CPG_CORE R8A7791_CLK_ZS>,
<&scif_clk>;
resets = <&cpg 716>;
hscif2: serial@e62d0000 {
reg = <0 0xe62d0000 0 96>;
interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 713>, <&cpg CPG_CORE R8A7791_CLK_ZS>,
<&scif_clk>;
dmas = <&dmac0 0x3b>, <&dmac0 0x3c>,
<&dmac1 0x3b>, <&dmac1 0x3c>;
resets = <&cpg 713>;
compatible = "renesas,msiof-r8a7791",
clocks = <&cpg CPG_MOD 000>;
resets = <&cpg 0>;
#size-cells = <0>;
#size-cells = <0>;
#size-cells = <0>;
compatible = "renesas,pwm-r8a7791", "renesas,pwm-rcar";
#pwm-cells = <2>;
#pwm-cells = <2>;
#pwm-cells = <2>;
#pwm-cells = <2>;
#pwm-cells = <2>;
#pwm-cells = <2>;
#pwm-cells = <2>;
adc: adc@e6e54000 {
compatible = "renesas,r8a7791-gyroadc",
"renesas,rcar-gyroadc";
reg = <0 0xe6e54000 0 64>;
clocks = <&cpg CPG_MOD 901>;
resets = <&cpg 901>;
compatible = "renesas,can-r8a7791",
<&cpg CPG_CORE R8A7791_CLK_RCAN>, <&can_clk>;
vin0: video@e6ef0000 {
compatible = "renesas,vin-r8a7791",
interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>;
vin1: video@e6ef1000 {
interrupts = <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH>;
vin2: video@e6ef2000 {
interrupts = <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>;
compatible = "renesas,rcar_sound-r8a7791",
<&cpg CPG_CORE R8A7791_CLK_M2>;
"ssi.1", "ssi.0", "src.9", "src.8",
"src.7", "src.6", "src.5", "src.4",
"src.3", "src.2", "src.1", "src.0",
"ctu.0", "ctu.1",
"mix.0", "mix.1",
"dvc.0", "dvc.1",
"ssi.1", "ssi.0";
rcar_sound,dvc {
dvc0: dvc-0 {
dmas = <&audma1 0xbc>;
dma-names = "tx";
dvc1: dvc-1 {
dmas = <&audma1 0xbe>;
dma-names = "tx";
rcar_sound,mix {
mix0: mix-0 { };
mix1: mix-1 { };
rcar_sound,ctu {
ctu00: ctu-0 { };
ctu01: ctu-1 { };
ctu02: ctu-2 { };
ctu03: ctu-3 { };
ctu10: ctu-4 { };
ctu11: ctu-5 { };
ctu12: ctu-6 { };
ctu13: ctu-7 { };
rcar_sound,src {
src0: src-0 {
dmas = <&audma0 0x85>, <&audma1 0x9a>;
src1: src-1 {
dmas = <&audma0 0x87>, <&audma1 0x9c>;
src2: src-2 {
dmas = <&audma0 0x89>, <&audma1 0x9e>;
src3: src-3 {
dmas = <&audma0 0x8b>, <&audma1 0xa0>;
src4: src-4 {
dmas = <&audma0 0x8d>, <&audma1 0xb0>;
src5: src-5 {
dmas = <&audma0 0x8f>, <&audma1 0xb2>;
src6: src-6 {
dmas = <&audma0 0x91>, <&audma1 0xb4>;
src7: src-7 {
dmas = <&audma0 0x93>, <&audma1 0xb6>;
src8: src-8 {
dmas = <&audma0 0x95>, <&audma1 0xb8>;
src9: src-9 {
dmas = <&audma0 0x97>, <&audma1 0xba>;
rcar_sound,ssi {
ssi0: ssi-0 {
<&audma0 0x15>, <&audma1 0x16>;
ssi1: ssi-1 {
<&audma0 0x49>, <&audma1 0x4a>;
ssi2: ssi-2 {
<&audma0 0x63>, <&audma1 0x64>;
ssi3: ssi-3 {
<&audma0 0x6f>, <&audma1 0x70>;
ssi4: ssi-4 {
<&audma0 0x71>, <&audma1 0x72>;
ssi5: ssi-5 {
<&audma0 0x73>, <&audma1 0x74>;
ssi6: ssi-6 {
<&audma0 0x75>, <&audma1 0x76>;
ssi7: ssi-7 {
<&audma0 0x79>, <&audma1 0x7a>;
ssi8: ssi-8 {
<&audma0 0x7b>, <&audma1 0x7c>;
ssi9: ssi-9 {
<&audma0 0x7d>, <&audma1 0x7e>;
audma0: dma-controller@ec700000 {
reg = <0 0xec700000 0 0x10000>;
<GIC_SPI 320 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 321 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 322 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 323 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 324 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 325 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 326 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 327 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 328 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 329 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 330 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 331 IRQ_TYPE_LEVEL_HIGH>,
"ch12";
clocks = <&cpg CPG_MOD 502>;
resets = <&cpg 502>;
#dma-cells = <1>;
audma1: dma-controller@ec720000 {
reg = <0 0xec720000 0 0x10000>;
<GIC_SPI 333 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 334 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 336 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 337 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 338 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 339 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 340 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 341 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 342 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 343 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 344 IRQ_TYPE_LEVEL_HIGH>,
"ch12";
clocks = <&cpg CPG_MOD 501>;
resets = <&cpg 501>;
#dma-cells = <1>;
compatible = "renesas,xhci-r8a7791",
reg = <0 0xee000000 0 0xc00>;
clocks = <&cpg CPG_MOD 328>;
phys = <&usb2 1>;
phy-names = "usb";
compatible = "renesas,pci-r8a7791",
device_type = "pci";
interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>;
bus-range = <0 0>;
#address-cells = <3>;
#size-cells = <2>;
#interrupt-cells = <1>;
usb@1,0 {
phys = <&usb0 0>;
phy-names = "usb";
usb@2,0 {
phys = <&usb0 0>;
phy-names = "usb";
pci1: pci@ee0d0000 {
bus-range = <1 1>;
#size-cells = <2>;
usb@1,0 {
reg = <0x10800 0 0 0 0>;
phys = <&usb2 0>;
phy-names = "usb";
usb@2,0 {
reg = <0x11000 0 0 0 0>;
phys = <&usb2 0>;
phy-names = "usb";
sdhi0: mmc@ee100000 {
compatible = "renesas,sdhi-r8a7791",
interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>;
resets = <&cpg 314>;
sdhi1: mmc@ee140000 {
interrupts = <GIC_SPI 167 IRQ_TYPE_LEVEL_HIGH>;
resets = <&cpg 312>;
sdhi2: mmc@ee160000 {
interrupts = <GIC_SPI 168 IRQ_TYPE_LEVEL_HIGH>;
resets = <&cpg 311>;
compatible = "renesas,mmcif-r8a7791",
"renesas,sh-mmcif";
reg-io-width = <4>;
compatible = "renesas,sata-r8a7791",
compatible = "renesas,ether-r8a7791",
phy-mode = "rmii";
#size-cells = <0>;
compatible = "arm,gic-400";
interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_HIGH)>;
clocks = <&cpg CPG_MOD 408>;
clock-names = "clk";
resets = <&cpg 408>;
compatible = "renesas,pcie-r8a7791",
reg = <0 0xfe000000 0 0x80000>;
#size-cells = <2>;
bus-range = <0x00 0xff>;
ranges = <0x01000000 0 0x00000000 0 0xfe100000 0 0x00100000>,
<0x02000000 0 0xfe200000 0 0xfe200000 0 0x00200000>,
<0x02000000 0 0x30000000 0 0x30000000 0 0x08000000>,
<0x42000000 0 0x38000000 0 0x38000000 0 0x08000000>;
<0x43000000 2 0x00000000 2 0x00000000 1 0x00000000>;
interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>;
interrupt-map-mask = <0 0 0 0>;
interrupt-map = <0 0 0 0 &gic GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 319>, <&pcie_bus_clk>;
clock-names = "pcie", "pcie_bus";
resets = <&cpg 319>;
vsp@fe928000 {
vsp@fe930000 {
interrupts = <GIC_SPI 246 IRQ_TYPE_LEVEL_HIGH>;
vsp@fe938000 {
fdp1@fe940000 {
compatible = "renesas,fdp1";
reg = <0 0xfe940000 0 0x2400>;
interrupts = <GIC_SPI 262 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 119>;
resets = <&cpg 119>;
fdp1@fe944000 {
reg = <0 0xfe944000 0 0x2400>;
interrupts = <GIC_SPI 263 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 118>;
resets = <&cpg 118>;
compatible = "renesas,jpu-r8a7791",
du: display@feb00000 {
compatible = "renesas,du-r8a7791";
reg = <0 0xfeb00000 0 0x40000>;
interrupts = <GIC_SPI 256 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 268 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 724>, <&cpg CPG_MOD 723>;
clock-names = "du.0", "du.1";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port@1 {
reg = <1>;
du_out_lvds0: endpoint {
remote-endpoint = <&lvds0_in>;
lvds0: lvds@feb90000 {
compatible = "renesas,r8a7791-lvds";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
lvds0_in: endpoint {
remote-endpoint = <&du_out_lvds0>;
port@1 {
reg = <1>;
compatible = "renesas,prr";
compatible = "renesas,r8a7791-cmt0",
compatible = "renesas,r8a7791-cmt1",
thermal-zones {
trips {
cpu-crit {
hysteresis = <0>;
type = "critical";
cooling-maps {
timer {
interrupts-extended = <&gic GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>,
<&gic GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>,
<&gic GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>,
<&gic GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>;
usb_extal_clk: usb_extal {
compatible = "fixed-clock";
#clock-cells = <0>;
-}; diff --git a/arch/arm/dts/r8a7792-blanche.dts b/arch/arm/dts/r8a7792-blanche.dts deleted file mode 100644 index 6a83923aa46..00000000000 --- a/arch/arm/dts/r8a7792-blanche.dts +++ /dev/null @@ -1,364 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Device Tree Source for the Blanche board
- Copyright (C) 2014 Renesas Electronics Corporation
- Copyright (C) 2016 Cogent Embedded, Inc.
-/dts-v1/; -#include "r8a7792.dtsi" -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/input/input.h>
model = "Blanche";
compatible = "renesas,blanche", "renesas,r8a7792";
aliases {
serial0 = &scif0;
serial1 = &scif3;
chosen {
bootargs = "ignore_loglevel rw root=/dev/nfs ip=on";
stdout-path = "serial0:115200n8";
memory@40000000 {
device_type = "memory";
reg = <0 0x40000000 0 0x40000000>;
d3_3v: regulator-3v3 {
compatible = "regulator-fixed";
regulator-name = "D3.3V";
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
regulator-boot-on;
regulator-always-on;
ethernet@18000000 {
compatible = "smsc,lan89218", "smsc,lan9115";
reg = <0 0x18000000 0 0x100>;
phy-mode = "mii";
interrupt-parent = <&irqc>;
interrupts = <0 IRQ_TYPE_EDGE_FALLING>;
smsc,irq-push-pull;
reg-io-width = <4>;
vddvario-supply = <&d3_3v>;
vdd33a-supply = <&d3_3v>;
pinctrl-0 = <&lan89218_pins>;
pinctrl-names = "default";
vga-encoder {
compatible = "adi,adv7123";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
adv7123_in: endpoint {
remote-endpoint = <&du_out_rgb1>;
port@1 {
reg = <1>;
adv7123_out: endpoint {
remote-endpoint = <&vga_in>;
hdmi-out {
compatible = "hdmi-connector";
type = "a";
port {
remote-endpoint = <&adv7511_out>;
vga {
compatible = "vga-connector";
port {
vga_in: endpoint {
remote-endpoint = <&adv7123_out>;
x1_clk: x1 {
#clock-cells = <0>;
x2_clk: x2 {
#clock-cells = <0>;
clock-frequency = <65000000>;
keyboard {
compatible = "gpio-keys";
pinctrl-0 = <&keyboard_pins>;
key-1 {
linux,code = <KEY_1>;
label = "SW2-1";
wakeup-source;
debounce-interval = <20>;
gpios = <&gpio3 10 GPIO_ACTIVE_LOW>;
key-2 {
linux,code = <KEY_2>;
label = "SW2-2";
wakeup-source;
gpios = <&gpio3 11 GPIO_ACTIVE_LOW>;
key-3 {
linux,code = <KEY_3>;
label = "SW2-3";
wakeup-source;
gpios = <&gpio3 12 GPIO_ACTIVE_LOW>;
key-4 {
linux,code = <KEY_4>;
label = "SW2-4";
wakeup-source;
gpios = <&gpio3 15 GPIO_ACTIVE_LOW>;
key-a {
label = "SW24";
wakeup-source;
gpios = <&gpio3 20 GPIO_ACTIVE_LOW>;
key-b {
label = "SW25";
wakeup-source;
gpios = <&gpio11 2 GPIO_ACTIVE_LOW>;
leds {
compatible = "gpio-leds";
led17 {
gpios = <&gpio10 10 GPIO_ACTIVE_HIGH>;
led18 {
gpios = <&gpio10 11 GPIO_ACTIVE_HIGH>;
led19 {
gpios = <&gpio10 12 GPIO_ACTIVE_HIGH>;
led20 {
gpios = <&gpio10 23 GPIO_ACTIVE_HIGH>;
vcc_sdhi0: regulator-vcc-sdhi0 {
regulator-name = "SDHI0 Vcc";
gpio = <&gpio11 12 GPIO_ACTIVE_HIGH>;
enable-active-high;
-&extal_clk {
clock-frequency = <20000000>;
-&can_clk {
-&pfc {
scif0_pins: scif0 {
groups = "scif0_data";
function = "scif0";
scif3_pins: scif3 {
groups = "scif3_data";
function = "scif3";
lan89218_pins: lan89218 {
intc {
groups = "intc_irq0";
function = "intc";
lbsc {
groups = "lbsc_ex_cs0";
function = "lbsc";
can0_pins: can0 {
groups = "can0_data", "can_clk";
function = "can0";
sdhi0_pins: sdhi0 {
groups = "sdhi0_data4", "sdhi0_ctrl";
function = "sdhi0";
du0_pins: du0 {
groups = "du0_rgb888", "du0_sync", "du0_disp";
function = "du0";
du1_pins: du1 {
groups = "du1_rgb666", "du1_sync", "du1_disp";
function = "du1";
keyboard_pins: keyboard {
pins = "GP_3_10", "GP_3_11", "GP_3_12", "GP_3_15", "GP_11_2";
bias-pull-up;
pmic_irq_pins: pmicirq {
groups = "intc_irq2";
function = "intc";
-&rwdt {
timeout-sec = <60>;
status = "okay";
-&scif0 {
pinctrl-0 = <&scif0_pins>;
status = "okay";
-&scif3 {
pinctrl-0 = <&scif3_pins>;
status = "okay";
-&can0 {
status = "okay";
-&sdhi0 {
pinctrl-0 = <&sdhi0_pins>;
vmmc-supply = <&vcc_sdhi0>;
cd-gpios = <&gpio11 11 GPIO_ACTIVE_LOW>;
status = "okay";
-&i2c1 {
status = "okay";
hdmi@39 {
compatible = "adi,adv7511w";
reg = <0x39>;
interrupts = <3 IRQ_TYPE_EDGE_FALLING>;
adi,input-depth = <8>;
adi,input-colorspace = "rgb";
adi,input-clock = "1x";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
adv7511_in: endpoint {
remote-endpoint = <&du_out_rgb0>;
port@1 {
reg = <1>;
adv7511_out: endpoint {
-&iic3 {
status = "okay";
pmic@58 {
compatible = "dlg,da9063";
reg = <0x58>;
pinctrl-0 = <&pmic_irq_pins>;
interrupts = <2 IRQ_TYPE_LEVEL_LOW>;
rtc {
compatible = "dlg,da9063-rtc";
watchdog {
compatible = "dlg,da9063-watchdog";
-&du {
pinctrl-0 = <&du0_pins>, <&du1_pins>;
clocks = <&cpg CPG_MOD 724>, <&cpg CPG_MOD 723>, <&x1_clk>, <&x2_clk>;
status = "okay";
ports {
port@0 {
endpoint {
remote-endpoint = <&adv7511_in>;
port@1 {
endpoint {
remote-endpoint = <&adv7123_in>;
-}; diff --git a/arch/arm/dts/r8a7792.dtsi b/arch/arm/dts/r8a7792.dtsi deleted file mode 100644 index a6d9367f8fa..00000000000 --- a/arch/arm/dts/r8a7792.dtsi +++ /dev/null @@ -1,928 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Device Tree Source for the R-Car V2H (R8A77920) SoC
- Copyright (C) 2016 Cogent Embedded Inc.
-#include <dt-bindings/clock/r8a7792-cpg-mssr.h> -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/power/r8a7792-sysc.h>
compatible = "renesas,r8a7792";
#size-cells = <2>;
aliases {
i2c0 = &i2c0;
i2c1 = &i2c1;
i2c2 = &i2c2;
i2c3 = &i2c3;
i2c4 = &i2c4;
i2c5 = &i2c5;
i2c6 = &iic3;
spi0 = &qspi;
spi1 = &msiof0;
spi2 = &msiof1;
vin0 = &vin0;
vin1 = &vin1;
vin2 = &vin2;
vin3 = &vin3;
vin4 = &vin4;
vin5 = &vin5;
can_clk: can {
#clock-cells = <0>;
cpus {
#size-cells = <0>;
cpu0: cpu@0 {
reg = <0>;
clock-frequency = <1000000000>;
clocks = <&cpg CPG_CORE R8A7792_CLK_Z>;
power-domains = <&sysc R8A7792_PD_CA15_CPU0>;
cpu1: cpu@1 {
reg = <1>;
power-domains = <&sysc R8A7792_PD_CA15_CPU1>;
cache-unified;
cache-level = <2>;
power-domains = <&sysc R8A7792_PD_CA15_SCU>;
extal_clk: extal {
#clock-cells = <0>;
pmu {
scif_clk: scif {
#clock-cells = <0>;
soc {
#address-cells = <2>;
#size-cells = <2>;
ranges;
compatible = "renesas,r8a7792-wdt",
power-domains = <&sysc R8A7792_PD_ALWAYS_ON>;
compatible = "renesas,gpio-r8a7792",
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 0 29>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 32 23>;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 96 28>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 128 17>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 160 17>;
gpio6: gpio@e6055100 {
reg = <0 0xe6055100 0 0x50>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 192 17>;
gpio7: gpio@e6055200 {
reg = <0 0xe6055200 0 0x50>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 224 17>;
gpio8: gpio@e6055300 {
reg = <0 0xe6055300 0 0x50>;
interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 256 17>;
clocks = <&cpg CPG_MOD 921>;
resets = <&cpg 921>;
gpio9: gpio@e6055400 {
interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 288 17>;
clocks = <&cpg CPG_MOD 919>;
resets = <&cpg 919>;
gpio10: gpio@e6055500 {
reg = <0 0xe6055500 0 0x50>;
interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 320 32>;
clocks = <&cpg CPG_MOD 914>;
resets = <&cpg 914>;
gpio11: gpio@e6055600 {
reg = <0 0xe6055600 0 0x50>;
interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 352 30>;
clocks = <&cpg CPG_MOD 913>;
resets = <&cpg 913>;
compatible = "renesas,pfc-r8a7792";
reg = <0 0xe6060000 0 0x144>;
compatible = "renesas,r8a7792-cpg-mssr";
clocks = <&extal_clk>;
clock-names = "extal";
#clock-cells = <2>;
#reset-cells = <1>;
apmu@e6152000 {
compatible = "renesas,r8a7792-apmu", "renesas,apmu";
compatible = "renesas,r8a7792-rst";
compatible = "renesas,r8a7792-sysc";
irqc: interrupt-controller@e61c0000 {
compatible = "renesas,irqc-r8a7792", "renesas,irqc";
#size-cells = <1>;
#size-cells = <1>;
smp-sram@0 {
reg = <0 0x100>;
/* I2C doesn't need pinmux */
compatible = "renesas,i2c-r8a7792",
#size-cells = <0>;
#size-cells = <0>;
#size-cells = <0>;
#size-cells = <0>;
#size-cells = <0>;
#size-cells = <0>;
#size-cells = <0>;
compatible = "renesas,iic-r8a7792",
compatible = "renesas,dmac-r8a7792",
#dma-cells = <1>;
#dma-cells = <1>;
compatible = "renesas,etheravb-r8a7792",
#size-cells = <0>;
compatible = "renesas,qspi-r8a7792", "renesas,qspi";
num-cs = <1>;
#size-cells = <0>;
compatible = "renesas,scif-r8a7792",
<&cpg CPG_CORE R8A7792_CLK_ZS>, <&scif_clk>;
compatible = "renesas,hscif-r8a7792",
compatible = "renesas,msiof-r8a7792",
resets = <&cpg 000>;
#size-cells = <0>;
#size-cells = <0>;
compatible = "renesas,can-r8a7792",
<&cpg CPG_CORE R8A7792_CLK_RCAN>, <&can_clk>;
compatible = "renesas,vin-r8a7792",
vin3: video@e6ef3000 {
interrupts = <GIC_SPI 191 IRQ_TYPE_LEVEL_HIGH>;
vin4: video@e6ef4000 {
reg = <0 0xe6ef4000 0 0x1000>;
clocks = <&cpg CPG_MOD 805>;
resets = <&cpg 805>;
vin5: video@e6ef5000 {
reg = <0 0xe6ef5000 0 0x1000>;
clocks = <&cpg CPG_MOD 804>;
resets = <&cpg 804>;
compatible = "renesas,sdhi-r8a7792",
interrupts = <0 165 IRQ_TYPE_LEVEL_HIGH>;
vsp@fe928000 {
vsp@fe930000 {
vsp@fe938000 {
compatible = "renesas,jpu-r8a7792",
compatible = "renesas,du-r8a7792";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
du_out_rgb0: endpoint {
port@1 {
reg = <1>;
du_out_rgb1: endpoint {
compatible = "renesas,r8a7792-cmt0",
compatible = "renesas,r8a7792-cmt1",
timer {
-}; diff --git a/arch/arm/dts/r8a7793-gose.dts b/arch/arm/dts/r8a7793-gose.dts deleted file mode 100644 index 79b537b2464..00000000000 --- a/arch/arm/dts/r8a7793-gose.dts +++ /dev/null @@ -1,818 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Device Tree Source for the Gose board
- Copyright (C) 2014-2015 Renesas Electronics Corporation
- SSI-AK4643
- SW1: 1: AK4643
2: CN22
3: ADV7511
- This command is required when Playback/Capture
amixer set "LINEOUT Mixer DACL" on
amixer set "DVC Out" 100%
amixer set "DVC In" 100%
- You can use Mute
amixer set "DVC Out Mute" on
amixer set "DVC In Mute" on
- You can use Volume Ramp
amixer set "DVC Out Ramp Up Rate" "0.125 dB/64 steps"
amixer set "DVC Out Ramp Down Rate" "0.125 dB/512 steps"
amixer set "DVC Out Ramp" on
aplay xxx.wav &
amixer set "DVC Out" 80% // Volume Down
amixer set "DVC Out" 100% // Volume Up
-/dts-v1/; -#include "r8a7793.dtsi" -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/input/input.h>
model = "Gose";
compatible = "renesas,gose", "renesas,r8a7793";
aliases {
serial0 = &scif0;
serial1 = &scif1;
i2c9 = &gpioi2c2;
i2c10 = &gpioi2c4;
i2c11 = &i2chdmi;
i2c12 = &i2cexio4;
mmc0 = &sdhi0;
mmc1 = &sdhi1;
mmc2 = &sdhi2;
chosen {
memory@40000000 {
keyboard {
key-1 {
label = "SW2-1";
wakeup-source;
key-2 {
label = "SW2-2";
wakeup-source;
key-3 {
label = "SW2-3";
wakeup-source;
key-4 {
label = "SW2-4";
wakeup-source;
key-a {
label = "SW30";
wakeup-source;
key-b {
label = "SW31";
wakeup-source;
key-c {
label = "SW32";
wakeup-source;
key-d {
label = "SW33";
wakeup-source;
key-e {
label = "SW34";
wakeup-source;
key-f {
label = "SW35";
wakeup-source;
key-g {
label = "SW36";
wakeup-source;
leds {
led6 {
label = "LED6";
led7 {
label = "LED7";
led8 {
label = "LED8";
enable-active-high;
vccq_sdhi0: regulator-vccq-sdhi0 {
compatible = "regulator-gpio";
regulator-name = "SDHI0 VccQ";
regulator-min-microvolt = <1800000>;
gpios-states = <1>;
states = <3300000 1>, <1800000 0>;
enable-active-high;
gpios-states = <1>;
vcc_sdhi2: regulator-vcc-sdhi2 {
regulator-name = "SDHI2 Vcc";
enable-active-high;
vccq_sdhi2: regulator-vccq-sdhi2 {
regulator-name = "SDHI2 VccQ";
gpios-states = <1>;
audio_clock: audio_clock {
#clock-cells = <0>;
clock-frequency = <11289600>;
rsnd_ak4643: sound {
compatible = "simple-audio-card";
simple-audio-card,format = "left_j";
simple-audio-card,bitclock-master = <&sndcodec>;
simple-audio-card,frame-master = <&sndcodec>;
sndcpu: simple-audio-card,cpu {
sound-dai = <&rcar_sound>;
sndcodec: simple-audio-card,codec {
sound-dai = <&ak4643>;
clocks = <&audio_clock>;
hdmi-in {
type = "a";
port {
hdmi_con_in: endpoint {
remote-endpoint = <&adv7612_in>;
hdmi-out {
type = "a";
port {
hdmi_con_out: endpoint {
composite-in {
compatible = "composite-video-connector";
port {
composite_con_in: endpoint {
remote-endpoint = <&adv7180_in>;
x2_clk: x2-clock {
#clock-cells = <0>;
x13_clk: x13-clock {
#clock-cells = <0>;
clock-frequency = <148500000>;
gpioi2c2: i2c-9 {
#size-cells = <0>;
compatible = "i2c-gpio";
i2c-gpio,delay-us = <5>;
gpioi2c4: i2c-10 {
#size-cells = <0>;
i2chdmi: i2c-11 {
compatible = "i2c-demux-pinctrl";
i2c-bus-name = "i2c-hdmi";
#size-cells = <0>;
ak4643: codec@12 {
compatible = "asahi-kasei,ak4643";
reg = <0x12>;
composite-in@20 {
compatible = "adi,adv7180cp";
reg = <0x20>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
adv7180_in: endpoint {
remote-endpoint = <&composite_con_in>;
port@3 {
reg = <3>;
adv7180_out: endpoint {
bus-width = <8>;
hdmi@39 {
reg = <0x39>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
remote-endpoint = <&du_out_rgb>;
port@1 {
reg = <1>;
remote-endpoint = <&hdmi_con_out>;
hdmi-in@4c {
compatible = "adi,adv7612";
reg = <0x4c>;
default-input = <0>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
adv7612_in: endpoint {
remote-endpoint = <&hdmi_con_in>;
port@2 {
reg = <2>;
adv7612_out: endpoint {
remote-endpoint = <&vin0ep2>;
eeprom@50 {
reg = <0x50>;
pagesize = <16>;
i2cexio4: i2c-12 {
#size-cells = <0>;
-&du {
pinctrl-0 = <&du_pins>;
status = "okay";
<&x13_clk>, <&x2_clk>;
ports {
port@0 {
endpoint {
-&lvds0 {
ports {
port@1 {
lvds_connector: endpoint {
-&extal_clk {
-&pfc {
pinctrl-0 = <&scif_clk_pins>;
i2c2_pins: i2c2 {
groups = "i2c2";
function = "i2c2";
i2c4_pins: i2c4 {
groups = "i2c4_c";
function = "i2c4";
du_pins: du {
function = "du";
scif0_pins: scif0 {
function = "scif0";
scif1_pins: scif1 {
function = "scif1";
scif_clk_pins: scif_clk {
groups = "scif_clk";
function = "scif_clk";
ether_pins: ether {
groups = "eth_link", "eth_mdio", "eth_rmii";
function = "eth";
phy1_pins: phy1 {
function = "intc";
function = "intc";
sdhi0_pins: sd0 {
function = "sdhi0";
power-source = <3300>;
sdhi0_pins_uhs: sd0_uhs {
function = "sdhi0";
power-source = <1800>;
sdhi1_pins: sd1 {
function = "sdhi1";
function = "sdhi1";
sdhi2_pins: sd2 {
groups = "sdhi2_data4", "sdhi2_ctrl";
function = "sdhi2";
sdhi2_pins_uhs: sd2_uhs {
function = "sdhi2";
qspi_pins: qspi {
groups = "qspi_ctrl", "qspi_data4";
function = "qspi";
sound_pins: sound {
groups = "ssi0129_ctrl", "ssi0_data", "ssi1_data";
function = "ssi";
sound_clk_pins: sound_clk {
groups = "audio_clk_a";
function = "audio_clk";
bias-pull-up;
vin0_pins: vin0 {
groups = "vin0_data24", "vin0_sync", "vin0_clkenb", "vin0_clk";
function = "vin0";
vin1_pins: vin1 {
groups = "vin1_data8", "vin1_clk";
function = "vin1";
-ðer {
pinctrl-0 = <ðer_pins>, <&phy1_pins>;
phy-handle = <&phy1>;
renesas,ether-link-active-low;
status = "okay";
phy1: ethernet-phy@1 {
compatible = "ethernet-phy-id0022.1537",
"ethernet-phy-ieee802.3-c22";
reg = <1>;
interrupt-parent = <&irqc0>;
interrupts = <0 IRQ_TYPE_LEVEL_LOW>;
micrel,led-mode = <1>;
-&cmt0 {
status = "okay";
-&cpu0 {
cpu0-supply = <&vdd_dvfs>;
-&rwdt {
timeout-sec = <60>;
status = "okay";
-&scif0 {
status = "okay";
-&scif1 {
status = "okay";
-&scif_clk {
clock-frequency = <14745600>;
-&sdhi0 {
pinctrl-1 = <&sdhi0_pins_uhs>;
pinctrl-names = "default", "state_uhs";
vqmmc-supply = <&vccq_sdhi0>;
sd-uhs-sdr50;
sd-uhs-sdr104;
status = "okay";
-&sdhi1 {
sd-uhs-sdr50;
status = "okay";
-&sdhi2 {
pinctrl-0 = <&sdhi2_pins>;
pinctrl-1 = <&sdhi2_pins_uhs>;
vmmc-supply = <&vcc_sdhi2>;
vqmmc-supply = <&vccq_sdhi2>;
sd-uhs-sdr50;
status = "okay";
-&qspi {
pinctrl-0 = <&qspi_pins>;
status = "okay";
flash@0 {
compatible = "spansion,s25fl512s", "jedec,spi-nor";
reg = <0>;
spi-max-frequency = <30000000>;
spi-tx-bus-width = <4>;
spi-rx-bus-width = <4>;
spi-cpol;
spi-cpha;
m25p,fast-read;
partitions {
compatible = "fixed-partitions";
#size-cells = <1>;
partition@0 {
label = "loader";
reg = <0x00000000 0x00040000>;
read-only;
partition@40000 {
label = "user";
reg = <0x00040000 0x00400000>;
read-only;
partition@440000 {
label = "flash";
reg = <0x00440000 0x03bc0000>;
-&i2c2 {
pinctrl-0 = <&i2c2_pins>;
pinctrl-names = "i2c-hdmi";
status = "okay";
clock-frequency = <100000>;
-&i2c6 {
status = "okay";
pmic@58 {
reg = <0x58>;
rtc {
watchdog {
vdd_dvfs: regulator@68 {
compatible = "dlg,da9210";
reg = <0x68>;
regulator-min-microvolt = <1000000>;
regulator-max-microvolt = <1000000>;
regulator-boot-on;
-&i2c4 {
-&rcar_sound {
pinctrl-0 = <&sound_pins>, <&sound_clk_pins>;
/* Single DAI */
status = "okay";
rcar_sound,dai {
dai0 {
playback = <&ssi0>, <&src2>, <&dvc0>;
capture = <&ssi1>, <&src3>, <&dvc1>;
-&ssi1 {
shared-pin;
-/* HDMI video input */ -&vin0 {
status = "okay";
pinctrl-0 = <&vin0_pins>;
port {
vin0ep2: endpoint {
remote-endpoint = <&adv7612_out>;
bus-width = <24>;
hsync-active = <0>;
vsync-active = <0>;
pclk-sample = <1>;
data-active = <1>;
-/* composite video input */ -&vin1 {
pinctrl-0 = <&vin1_pins>;
status = "okay";
port {
vin1ep: endpoint {
remote-endpoint = <&adv7180_out>;
bus-width = <8>;
-}; diff --git a/arch/arm/dts/r8a7793.dtsi b/arch/arm/dts/r8a7793.dtsi deleted file mode 100644 index f51bf687f4b..00000000000 --- a/arch/arm/dts/r8a7793.dtsi +++ /dev/null @@ -1,1470 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Device Tree Source for the R-Car M2-N (R8A77930) SoC
-#include <dt-bindings/clock/r8a7793-cpg-mssr.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/power/r8a7793-sysc.h>
compatible = "renesas,r8a7793";
#size-cells = <2>;
aliases {
i2c0 = &i2c0;
i2c1 = &i2c1;
i2c2 = &i2c2;
i2c3 = &i2c3;
i2c4 = &i2c4;
i2c5 = &i2c5;
i2c6 = &i2c6;
i2c7 = &i2c7;
i2c8 = &i2c8;
spi0 = &qspi;
* The external audio clocks are configured as 0 Hz fixed frequency
* clocks by default.
* Boards that provide audio clocks should override them.
audio_clk_a: audio_clk_a {
#clock-cells = <0>;
clock-frequency = <0>;
audio_clk_b: audio_clk_b {
#clock-cells = <0>;
audio_clk_c: audio_clk_c {
#clock-cells = <0>;
/* External CAN clock */
can_clk: can {
#clock-cells = <0>;
/* This value must be overridden by the board. */
cpus {
#size-cells = <0>;
cpu0: cpu@0 {
device_type = "cpu";
compatible = "arm,cortex-a15";
reg = <0>;
clocks = <&cpg CPG_CORE R8A7793_CLK_Z>;
power-domains = <&sysc R8A7793_PD_CA15_CPU0>;
enable-method = "renesas,apmu";
voltage-tolerance = <1>; /* 1% */
clock-latency = <300000>; /* 300 us */
/* kHz - uV - OPPs unknown yet */
<1312500 1000000>,
<1125000 1000000>,
< 937500 1000000>,
< 750000 1000000>,
< 375000 1000000>;
next-level-cache = <&L2_CA15>;
cpu1: cpu@1 {
reg = <1>;
power-domains = <&sysc R8A7793_PD_CA15_CPU1>;
<1312500 1000000>,
<1125000 1000000>,
< 937500 1000000>,
< 750000 1000000>,
< 375000 1000000>;
L2_CA15: cache-controller-0 {
compatible = "cache";
power-domains = <&sysc R8A7793_PD_CA15_SCU>;
cache-unified;
cache-level = <2>;
/* External root clock */
extal_clk: extal {
#clock-cells = <0>;
pmu {
compatible = "arm,cortex-a15-pmu";
/* External SCIF clock */
scif_clk: scif {
#clock-cells = <0>;
soc {
compatible = "simple-bus";
interrupt-parent = <&gic>;
#size-cells = <2>;
ranges;
rwdt: watchdog@e6020000 {
compatible = "renesas,r8a7793-wdt",
"renesas,rcar-gen2-wdt";
reg = <0 0xe6020000 0 0x0c>;
interrupts = <GIC_SPI 140 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 402>;
power-domains = <&sysc R8A7793_PD_ALWAYS_ON>;
resets = <&cpg 402>;
gpio0: gpio@e6050000 {
compatible = "renesas,gpio-r8a7793",
"renesas,rcar-gen2-gpio";
reg = <0 0xe6050000 0 0x50>;
interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 0 32>;
#interrupt-cells = <2>;
clocks = <&cpg CPG_MOD 912>;
resets = <&cpg 912>;
gpio1: gpio@e6051000 {
reg = <0 0xe6051000 0 0x50>;
interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
clocks = <&cpg CPG_MOD 911>;
resets = <&cpg 911>;
gpio2: gpio@e6052000 {
reg = <0 0xe6052000 0 0x50>;
interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
clocks = <&cpg CPG_MOD 910>;
resets = <&cpg 910>;
gpio3: gpio@e6053000 {
reg = <0 0xe6053000 0 0x50>;
interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 96 32>;
clocks = <&cpg CPG_MOD 909>;
resets = <&cpg 909>;
gpio4: gpio@e6054000 {
reg = <0 0xe6054000 0 0x50>;
interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 128 32>;
clocks = <&cpg CPG_MOD 908>;
resets = <&cpg 908>;
gpio5: gpio@e6055000 {
reg = <0 0xe6055000 0 0x50>;
interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 160 32>;
clocks = <&cpg CPG_MOD 907>;
resets = <&cpg 907>;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
pfc: pinctrl@e6060000 {
compatible = "renesas,pfc-r8a7793";
reg = <0 0xe6060000 0 0x250>;
/* Special CPG clocks */
cpg: clock-controller@e6150000 {
compatible = "renesas,r8a7793-cpg-mssr";
reg = <0 0xe6150000 0 0x1000>;
clocks = <&extal_clk>, <&usb_extal_clk>;
clock-names = "extal", "usb_extal";
#clock-cells = <2>;
#power-domain-cells = <0>;
#reset-cells = <1>;
apmu@e6152000 {
compatible = "renesas,r8a7793-apmu", "renesas,apmu";
reg = <0 0xe6152000 0 0x188>;
rst: reset-controller@e6160000 {
compatible = "renesas,r8a7793-rst";
reg = <0 0xe6160000 0 0x0100>;
sysc: system-controller@e6180000 {
compatible = "renesas,r8a7793-sysc";
reg = <0 0xe6180000 0 0x0200>;
#power-domain-cells = <1>;
irqc0: interrupt-controller@e61c0000 {
compatible = "renesas,irqc-r8a7793", "renesas,irqc";
reg = <0 0xe61c0000 0 0x200>;
interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>,
clocks = <&cpg CPG_MOD 407>;
resets = <&cpg 407>;
thermal: thermal@e61f0000 {
compatible = "renesas,thermal-r8a7793",
"renesas,rcar-gen2-thermal",
"renesas,rcar-thermal";
reg = <0 0xe61f0000 0 0x10>, <0 0xe61f0100 0 0x38>;
interrupts = <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 522>;
resets = <&cpg 522>;
#thermal-sensor-cells = <0>;
ipmmu_sy0: iommu@e6280000 {
compatible = "renesas,ipmmu-r8a7793",
"renesas,ipmmu-vmsa";
reg = <0 0xe6280000 0 0x1000>;
interrupts = <GIC_SPI 223 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 224 IRQ_TYPE_LEVEL_HIGH>;
#iommu-cells = <1>;
ipmmu_sy1: iommu@e6290000 {
reg = <0 0xe6290000 0 0x1000>;
interrupts = <GIC_SPI 225 IRQ_TYPE_LEVEL_HIGH>;
#iommu-cells = <1>;
ipmmu_ds: iommu@e6740000 {
reg = <0 0xe6740000 0 0x1000>;
interrupts = <GIC_SPI 198 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 199 IRQ_TYPE_LEVEL_HIGH>;
#iommu-cells = <1>;
ipmmu_mp: iommu@ec680000 {
reg = <0 0xec680000 0 0x1000>;
interrupts = <GIC_SPI 226 IRQ_TYPE_LEVEL_HIGH>;
#iommu-cells = <1>;
ipmmu_mx: iommu@fe951000 {
reg = <0 0xfe951000 0 0x1000>;
interrupts = <GIC_SPI 222 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 221 IRQ_TYPE_LEVEL_HIGH>;
#iommu-cells = <1>;
ipmmu_rt: iommu@ffc80000 {
reg = <0 0xffc80000 0 0x1000>;
interrupts = <GIC_SPI 307 IRQ_TYPE_LEVEL_HIGH>;
#iommu-cells = <1>;
#iommu-cells = <1>;
icram0: sram@e63a0000 {
compatible = "mmio-sram";
reg = <0 0xe63a0000 0 0x12000>;
#size-cells = <1>;
ranges = <0 0 0xe63a0000 0x12000>;
icram1: sram@e63c0000 {
reg = <0 0xe63c0000 0 0x1000>;
#size-cells = <1>;
ranges = <0 0 0xe63c0000 0x1000>;
smp-sram@0 {
compatible = "renesas,smp-sram";
reg = <0 0x100>;
* bus numbers
i2c0: i2c@e6508000 {
#size-cells = <0>;
compatible = "renesas,i2c-r8a7793",
"renesas,rcar-gen2-i2c";
reg = <0 0xe6508000 0 0x40>;
interrupts = <GIC_SPI 287 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 931>;
resets = <&cpg 931>;
i2c-scl-internal-delay-ns = <6>;
i2c1: i2c@e6518000 {
#size-cells = <0>;
reg = <0 0xe6518000 0 0x40>;
interrupts = <GIC_SPI 288 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 930>;
resets = <&cpg 930>;
i2c2: i2c@e6530000 {
#size-cells = <0>;
reg = <0 0xe6530000 0 0x40>;
interrupts = <GIC_SPI 286 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 929>;
resets = <&cpg 929>;
i2c3: i2c@e6540000 {
#size-cells = <0>;
reg = <0 0xe6540000 0 0x40>;
interrupts = <GIC_SPI 290 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 928>;
resets = <&cpg 928>;
#size-cells = <0>;
#size-cells = <0>;
i2c-scl-internal-delay-ns = <110>;
#size-cells = <0>;
compatible = "renesas,iic-r8a7793",
"renesas,rcar-gen2-iic",
"renesas,rmobile-iic";
reg = <0 0xe60b0000 0 0x425>;
interrupts = <GIC_SPI 173 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 926>;
dmas = <&dmac0 0x77>, <&dmac0 0x78>,
<&dmac1 0x77>, <&dmac1 0x78>;
dma-names = "tx", "rx", "tx", "rx";
resets = <&cpg 926>;
#size-cells = <0>;
reg = <0 0xe6500000 0 0x425>;
interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&dmac0 0x61>, <&dmac0 0x62>,
<&dmac1 0x61>, <&dmac1 0x62>;
#size-cells = <0>;
reg = <0 0xe6510000 0 0x425>;
interrupts = <GIC_SPI 175 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 323>;
dmas = <&dmac0 0x65>, <&dmac0 0x66>,
<&dmac1 0x65>, <&dmac1 0x66>;
resets = <&cpg 323>;
dmac0: dma-controller@e6700000 {
compatible = "renesas,dmac-r8a7793",
"renesas,rcar-dmac";
reg = <0 0xe6700000 0 0x20000>;
interrupts = <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 200 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 201 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 202 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 203 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 204 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 205 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 206 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 207 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 208 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 209 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 210 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 211 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 212 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 213 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 214 IRQ_TYPE_LEVEL_HIGH>;
"ch0", "ch1", "ch2", "ch3",
"ch4", "ch5", "ch6", "ch7",
"ch8", "ch9", "ch10", "ch11",
"ch12", "ch13", "ch14";
clocks = <&cpg CPG_MOD 219>;
resets = <&cpg 219>;
#dma-cells = <1>;
dma-channels = <15>;
dmac1: dma-controller@e6720000 {
reg = <0 0xe6720000 0 0x20000>;
interrupts = <GIC_SPI 220 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 216 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 217 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 218 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 219 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 308 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 309 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 310 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 311 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 312 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 313 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 314 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 315 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 316 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 317 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 318 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 218>;
resets = <&cpg 218>;
#dma-cells = <1>;
qspi: spi@e6b10000 {
compatible = "renesas,qspi-r8a7793", "renesas,qspi";
reg = <0 0xe6b10000 0 0x2c>;
dmas = <&dmac0 0x17>, <&dmac0 0x18>,
<&dmac1 0x17>, <&dmac1 0x18>;
num-cs = <1>;
#size-cells = <0>;
scifa0: serial@e6c40000 {
compatible = "renesas,scifa-r8a7793",
"renesas,rcar-gen2-scifa", "renesas,scifa";
reg = <0 0xe6c40000 0 64>;
interrupts = <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 204>;
dmas = <&dmac0 0x21>, <&dmac0 0x22>,
<&dmac1 0x21>, <&dmac1 0x22>;
resets = <&cpg 204>;
scifa1: serial@e6c50000 {
reg = <0 0xe6c50000 0 64>;
interrupts = <GIC_SPI 145 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 203>;
dmas = <&dmac0 0x25>, <&dmac0 0x26>,
<&dmac1 0x25>, <&dmac1 0x26>;
resets = <&cpg 203>;
scifa2: serial@e6c60000 {
reg = <0 0xe6c60000 0 64>;
interrupts = <GIC_SPI 151 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 202>;
dmas = <&dmac0 0x27>, <&dmac0 0x28>,
<&dmac1 0x27>, <&dmac1 0x28>;
resets = <&cpg 202>;
scifb0: serial@e6c20000 {
compatible = "renesas,scifb-r8a7793",
"renesas,rcar-gen2-scifb", "renesas,scifb";
reg = <0 0xe6c20000 0 0x100>;
interrupts = <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 206>;
dmas = <&dmac0 0x3d>, <&dmac0 0x3e>,
<&dmac1 0x3d>, <&dmac1 0x3e>;
resets = <&cpg 206>;
scifb1: serial@e6c30000 {
reg = <0 0xe6c30000 0 0x100>;
interrupts = <GIC_SPI 149 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 207>;
dmas = <&dmac0 0x19>, <&dmac0 0x1a>,
<&dmac1 0x19>, <&dmac1 0x1a>;
resets = <&cpg 207>;
scifb2: serial@e6ce0000 {
reg = <0 0xe6ce0000 0 0x100>;
interrupts = <GIC_SPI 150 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 216>;
dmas = <&dmac0 0x1d>, <&dmac0 0x1e>,
<&dmac1 0x1d>, <&dmac1 0x1e>;
resets = <&cpg 216>;
scif0: serial@e6e60000 {
compatible = "renesas,scif-r8a7793",
reg = <0 0xe6e60000 0 64>;
interrupts = <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 721>, <&cpg CPG_CORE R8A7793_CLK_ZS>,
<&scif_clk>;
clock-names = "fck", "brg_int", "scif_clk";
dmas = <&dmac0 0x29>, <&dmac0 0x2a>,
<&dmac1 0x29>, <&dmac1 0x2a>;
resets = <&cpg 721>;
scif1: serial@e6e68000 {
reg = <0 0xe6e68000 0 64>;
interrupts = <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 720>, <&cpg CPG_CORE R8A7793_CLK_ZS>,
<&scif_clk>;
dmas = <&dmac0 0x2d>, <&dmac0 0x2e>,
<&dmac1 0x2d>, <&dmac1 0x2e>;
resets = <&cpg 720>;
clocks = <&cpg CPG_MOD 719>, <&cpg CPG_CORE R8A7793_CLK_ZS>,
<&scif_clk>;
dmas = <&dmac0 0x2b>, <&dmac0 0x2c>,
<&dmac1 0x2b>, <&dmac1 0x2c>;
clocks = <&cpg CPG_MOD 718>, <&cpg CPG_CORE R8A7793_CLK_ZS>,
<&scif_clk>;
clocks = <&cpg CPG_MOD 715>, <&cpg CPG_CORE R8A7793_CLK_ZS>,
<&scif_clk>;
clocks = <&cpg CPG_MOD 714>, <&cpg CPG_CORE R8A7793_CLK_ZS>,
<&scif_clk>;
hscif0: serial@e62c0000 {
compatible = "renesas,hscif-r8a7793",
"renesas,rcar-gen2-hscif", "renesas,hscif";
reg = <0 0xe62c0000 0 96>;
interrupts = <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 717>, <&cpg CPG_CORE R8A7793_CLK_ZS>,
<&scif_clk>;
dmas = <&dmac0 0x39>, <&dmac0 0x3a>,
<&dmac1 0x39>, <&dmac1 0x3a>;
resets = <&cpg 717>;
hscif1: serial@e62c8000 {
reg = <0 0xe62c8000 0 96>;
interrupts = <GIC_SPI 155 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 716>, <&cpg CPG_CORE R8A7793_CLK_ZS>,
<&scif_clk>;
dmas = <&dmac0 0x4d>, <&dmac0 0x4e>,
<&dmac1 0x4d>, <&dmac1 0x4e>;
clocks = <&cpg CPG_MOD 713>, <&cpg CPG_CORE R8A7793_CLK_ZS>,
<&scif_clk>;
can0: can@e6e80000 {
compatible = "renesas,can-r8a7793",
"renesas,rcar-gen2-can";
reg = <0 0xe6e80000 0 0x1000>;
interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 916>, <&cpg CPG_CORE R8A7793_CLK_RCAN>,
<&can_clk>;
clock-names = "clkp1", "clkp2", "can_clk";
resets = <&cpg 916>;
can1: can@e6e88000 {
reg = <0 0xe6e88000 0 0x1000>;
interrupts = <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 915>, <&cpg CPG_CORE R8A7793_CLK_RCAN>,
<&can_clk>;
resets = <&cpg 915>;
compatible = "renesas,vin-r8a7793",
"renesas,rcar-gen2-vin";
reg = <0 0xe6ef0000 0 0x1000>;
clocks = <&cpg CPG_MOD 811>;
resets = <&cpg 811>;
reg = <0 0xe6ef1000 0 0x1000>;
clocks = <&cpg CPG_MOD 810>;
resets = <&cpg 810>;
reg = <0 0xe6ef2000 0 0x1000>;
clocks = <&cpg CPG_MOD 809>;
resets = <&cpg 809>;
rcar_sound: sound@ec500000 {
* #sound-dai-cells is required if simple-card
* Single DAI : #sound-dai-cells = <0>; <&rcar_sound>;
* Multi DAI : #sound-dai-cells = <1>; <&rcar_sound N>;
compatible = "renesas,rcar_sound-r8a7793",
"renesas,rcar_sound-gen2";
reg = <0 0xec500000 0 0x1000>, /* SCU */
<0 0xec5a0000 0 0x100>, /* ADG */
<0 0xec540000 0 0x1000>, /* SSIU */
<0 0xec541000 0 0x280>, /* SSI */
<0 0xec740000 0 0x200>; /* Audio DMAC peri peri*/
reg-names = "scu", "adg", "ssiu", "ssi", "audmapp";
clocks = <&cpg CPG_MOD 1005>,
<&cpg CPG_MOD 1006>, <&cpg CPG_MOD 1007>,
<&cpg CPG_MOD 1008>, <&cpg CPG_MOD 1009>,
<&cpg CPG_MOD 1010>, <&cpg CPG_MOD 1011>,
<&cpg CPG_MOD 1012>, <&cpg CPG_MOD 1013>,
<&cpg CPG_MOD 1014>, <&cpg CPG_MOD 1015>,
<&cpg CPG_MOD 1022>, <&cpg CPG_MOD 1023>,
<&cpg CPG_MOD 1024>, <&cpg CPG_MOD 1025>,
<&cpg CPG_MOD 1026>, <&cpg CPG_MOD 1027>,
<&cpg CPG_MOD 1028>, <&cpg CPG_MOD 1029>,
<&cpg CPG_MOD 1030>, <&cpg CPG_MOD 1031>,
<&cpg CPG_MOD 1019>, <&cpg CPG_MOD 1018>,
<&audio_clk_a>, <&audio_clk_b>, <&audio_clk_c>,
<&cpg CPG_CORE R8A7793_CLK_M2>;
clock-names = "ssi-all",
"ssi.9", "ssi.8", "ssi.7", "ssi.6",
"ssi.5", "ssi.4", "ssi.3", "ssi.2",
"ssi.1", "ssi.0",
"src.9", "src.8", "src.7", "src.6",
"src.5", "src.4", "src.3", "src.2",
"src.1", "src.0",
"dvc.0", "dvc.1",
"clk_a", "clk_b", "clk_c", "clk_i";
resets = <&cpg 1005>,
<&cpg 1006>, <&cpg 1007>,
<&cpg 1008>, <&cpg 1009>,
<&cpg 1010>, <&cpg 1011>,
<&cpg 1012>, <&cpg 1013>,
<&cpg 1014>, <&cpg 1015>;
reset-names = "ssi-all",
"ssi.1", "ssi.0";
rcar_sound,dvc {
dvc0: dvc-0 {
dma-names = "tx";
dvc1: dvc-1 {
dma-names = "tx";
rcar_sound,src {
src0: src-0 {
interrupts = <GIC_SPI 352 IRQ_TYPE_LEVEL_HIGH>;
dma-names = "rx", "tx";
src1: src-1 {
interrupts = <GIC_SPI 353 IRQ_TYPE_LEVEL_HIGH>;
src2: src-2 {
interrupts = <GIC_SPI 354 IRQ_TYPE_LEVEL_HIGH>;
src3: src-3 {
interrupts = <GIC_SPI 355 IRQ_TYPE_LEVEL_HIGH>;
src4: src-4 {
interrupts = <GIC_SPI 356 IRQ_TYPE_LEVEL_HIGH>;
src5: src-5 {
interrupts = <GIC_SPI 357 IRQ_TYPE_LEVEL_HIGH>;
src6: src-6 {
interrupts = <GIC_SPI 358 IRQ_TYPE_LEVEL_HIGH>;
src7: src-7 {
interrupts = <GIC_SPI 359 IRQ_TYPE_LEVEL_HIGH>;
src8: src-8 {
interrupts = <GIC_SPI 360 IRQ_TYPE_LEVEL_HIGH>;
src9: src-9 {
interrupts = <GIC_SPI 361 IRQ_TYPE_LEVEL_HIGH>;
rcar_sound,ssi {
ssi0: ssi-0 {
interrupts = <GIC_SPI 370 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x01>, <&audma1 0x02>,
dma-names = "rx", "tx", "rxu", "txu";
ssi1: ssi-1 {
interrupts = <GIC_SPI 371 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x03>, <&audma1 0x04>,
ssi2: ssi-2 {
interrupts = <GIC_SPI 372 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x05>, <&audma1 0x06>,
ssi3: ssi-3 {
interrupts = <GIC_SPI 373 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x07>, <&audma1 0x08>,
ssi4: ssi-4 {
interrupts = <GIC_SPI 374 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x09>, <&audma1 0x0a>,
ssi5: ssi-5 {
interrupts = <GIC_SPI 375 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x0b>, <&audma1 0x0c>,
ssi6: ssi-6 {
interrupts = <GIC_SPI 376 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x0d>, <&audma1 0x0e>,
ssi7: ssi-7 {
interrupts = <GIC_SPI 377 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x0f>, <&audma1 0x10>,
ssi8: ssi-8 {
interrupts = <GIC_SPI 378 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x11>, <&audma1 0x12>,
ssi9: ssi-9 {
interrupts = <GIC_SPI 379 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x13>, <&audma1 0x14>,
interrupts = <GIC_SPI 346 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 332 IRQ_TYPE_LEVEL_HIGH>;
"ch12";
#dma-cells = <1>;
dma-channels = <13>;
interrupts = <GIC_SPI 347 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 335 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 345 IRQ_TYPE_LEVEL_HIGH>;
"ch12";
#dma-cells = <1>;
compatible = "renesas,sdhi-r8a7793",
"renesas,rcar-gen2-sdhi";
reg = <0 0xee100000 0 0x328>;
clocks = <&cpg CPG_MOD 314>;
dmas = <&dmac0 0xcd>, <&dmac0 0xce>,
<&dmac1 0xcd>, <&dmac1 0xce>;
max-frequency = <195000000>;
reg = <0 0xee140000 0 0x100>;
clocks = <&cpg CPG_MOD 312>;
dmas = <&dmac0 0xc1>, <&dmac0 0xc2>,
<&dmac1 0xc1>, <&dmac1 0xc2>;
max-frequency = <97500000>;
reg = <0 0xee160000 0 0x100>;
clocks = <&cpg CPG_MOD 311>;
dmas = <&dmac0 0xd3>, <&dmac0 0xd4>,
<&dmac1 0xd3>, <&dmac1 0xd4>;
mmcif0: mmc@ee200000 {
compatible = "renesas,mmcif-r8a7793",
"renesas,sh-mmcif";
reg = <0 0xee200000 0 0x80>;
interrupts = <GIC_SPI 169 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 315>;
dmas = <&dmac0 0xd1>, <&dmac0 0xd2>,
<&dmac1 0xd1>, <&dmac1 0xd2>;
resets = <&cpg 315>;
reg-io-width = <4>;
ether: ethernet@ee700000 {
compatible = "renesas,ether-r8a7793",
"renesas,rcar-gen2-ether";
reg = <0 0xee700000 0 0x400>;
interrupts = <GIC_SPI 162 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 813>;
resets = <&cpg 813>;
phy-mode = "rmii";
#size-cells = <0>;
gic: interrupt-controller@f1001000 {
#interrupt-cells = <3>;
#address-cells = <0>;
reg = <0 0xf1001000 0 0x1000>,
<0 0xf1002000 0 0x2000>,
<0 0xf1004000 0 0x2000>,
<0 0xf1006000 0 0x2000>;
fdp1@fe940000 {
fdp1@fe944000 {
compatible = "renesas,du-r8a7793";
resets = <&cpg 724>;
reset-names = "du.0";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
du_out_rgb: endpoint {
port@1 {
reg = <1>;
compatible = "renesas,r8a7793-lvds";
reg = <0 0xfeb90000 0 0x1c>;
clocks = <&cpg CPG_MOD 726>;
resets = <&cpg 726>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port@1 {
reg = <1>;
lvds0_out: endpoint {
prr: chipid@ff000044 {
reg = <0 0xff000044 0 4>;
cmt0: timer@ffca0000 {
compatible = "renesas,r8a7793-cmt0",
"renesas,rcar-gen2-cmt0";
reg = <0 0xffca0000 0 0x1004>;
interrupts = <GIC_SPI 142 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 143 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 124>;
resets = <&cpg 124>;
cmt1: timer@e6130000 {
compatible = "renesas,r8a7793-cmt1",
"renesas,rcar-gen2-cmt1";
reg = <0 0xe6130000 0 0x1004>;
interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 127 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 329>;
resets = <&cpg 329>;
thermal-zones {
cpu_thermal: cpu-thermal {
polling-delay-passive = <0>;
polling-delay = <0>;
thermal-sensors = <&thermal>;
trips {
cpu-crit {
temperature = <95000>;
hysteresis = <0>;
type = "critical";
cooling-maps {
timer {
compatible = "arm,armv7-timer";
/* External USB clock - can be overridden by the board */
#clock-cells = <0>;
clock-frequency = <48000000>;
-}; diff --git a/arch/arm/dts/r8a7794-alt.dts b/arch/arm/dts/r8a7794-alt.dts deleted file mode 100644 index 4d93319674c..00000000000 --- a/arch/arm/dts/r8a7794-alt.dts +++ /dev/null @@ -1,533 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Device Tree Source for the Alt board
-/dts-v1/; -#include "r8a7794.dtsi" -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/input/input.h>
model = "Alt";
compatible = "renesas,alt", "renesas,r8a7794";
aliases {
serial0 = &scif2;
i2c9 = &gpioi2c1;
i2c10 = &gpioi2c4;
i2c11 = &i2chdmi;
i2c12 = &i2cexio4;
mmc0 = &mmcif0;
mmc1 = &sdhi0;
mmc2 = &sdhi1;
chosen {
memory@40000000 {
d3_3v: regulator-d3-3v {
regulator-boot-on;
gpio = <&gpio2 26 GPIO_ACTIVE_HIGH>;
enable-active-high;
gpios = <&gpio2 29 GPIO_ACTIVE_HIGH>;
gpios-states = <1>;
vcc_sdhi1: regulator-vcc-sdhi1 {
regulator-name = "SDHI1 Vcc";
gpio = <&gpio4 26 GPIO_ACTIVE_HIGH>;
enable-active-high;
vccq_sdhi1: regulator-vccq-sdhi1 {
regulator-name = "SDHI1 VccQ";
gpios = <&gpio4 29 GPIO_ACTIVE_HIGH>;
gpios-states = <1>;
lbsc {
#size-cells = <1>;
keyboard {
one {
label = "SW2-1";
wakeup-source;
gpios = <&gpio3 9 GPIO_ACTIVE_LOW>;
two {
label = "SW2-2";
wakeup-source;
three {
label = "SW2-3";
wakeup-source;
four {
label = "SW2-4";
wakeup-source;
vga-encoder {
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port@1 {
reg = <1>;
vga {
port {
vga_in: endpoint {
x2_clk: x2-clock {
#clock-cells = <0>;
clock-frequency = <74250000>;
#clock-cells = <0>;
gpioi2c1: i2c-9 {
#size-cells = <0>;
scl-gpios = <&gpio4 0 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>;
sda-gpios = <&gpio4 1 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>;
gpioi2c4: i2c-10 {
#size-cells = <0>;
scl-gpios = <&gpio4 8 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>;
sda-gpios = <&gpio4 9 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>;
* A fallback to GPIO is provided for I2C1.
i2chdmi: i2c-11 {
i2c-parent = <&i2c1>, <&gpioi2c1>;
#size-cells = <0>;
composite-in@20 {
compatible = "adi,adv7180";
reg = <0x20>;
port {
adv7180: endpoint {
bus-width = <8>;
eeprom@50 {
compatible = "renesas,r1ex24002", "atmel,24c02";
reg = <0x50>;
pagesize = <16>;
* I2C4 is routed to EXIO connector B, pins 73 (SCL) + 74 (SDA).
* A fallback to GPIO is provided.
i2cexio4: i2c-14 {
i2c-parent = <&i2c4>, <&gpioi2c4>;
i2c-bus-name = "i2c-exio4";
#size-cells = <0>;
-&pci0 {
status = "okay";
pinctrl-0 = <&usb0_pins>;
-&pci1 {
status = "okay";
pinctrl-0 = <&usb1_pins>;
-&usbphy {
status = "okay";
-&du {
status = "okay";
clock-names = "du.0", "du.1", "dclkin.0", "dclkin.1";
ports {
port@1 {
endpoint {
-&extal_clk {
-&pfc {
du_pins: du {
groups = "du1_rgb666", "du1_sync", "du1_disp", "du1_clk0_out";
function = "du1";
scif2_pins: scif2 {
groups = "scif2_data";
function = "scif2";
ether_pins: ether {
function = "eth";
phy1_pins: phy1 {
groups = "intc_irq8";
function = "intc";
i2c1_pins: i2c1 {
groups = "i2c1";
function = "i2c1";
i2c4_pins: i2c4 {
groups = "i2c4";
function = "i2c4";
vin0_pins: vin0 {
function = "vin0";
mmcif0_pins: mmcif0 {
groups = "mmc_data8", "mmc_ctrl";
function = "mmc";
sdhi0_pins: sd0 {
function = "sdhi0";
function = "sdhi0";
sdhi1_pins: sd1 {
groups = "sdhi1_data4", "sdhi1_ctrl";
function = "sdhi1";
sdhi1_pins_uhs: sd1_uhs {
function = "sdhi1";
usb0_pins: usb0 {
groups = "usb0";
function = "usb0";
usb1_pins: usb1 {
groups = "usb1";
function = "usb1";
pins = "GP_3_9", "GP_3_10", "GP_3_11", "GP_3_12";
bias-pull-up;
-&cmt0 {
status = "okay";
-&pfc {
qspi_pins: qspi {
function = "qspi";
-ðer {
status = "okay";
reg = <1>;
interrupts = <8 IRQ_TYPE_LEVEL_LOW>;
reset-gpios = <&gpio1 24 GPIO_ACTIVE_LOW>;
-&mmcif0 {
pinctrl-0 = <&mmcif0_pins>;
vmmc-supply = <&d3_3v>;
vqmmc-supply = <&d3_3v>;
bus-width = <8>;
non-removable;
status = "okay";
-&rwdt {
timeout-sec = <60>;
status = "okay";
-&sdhi0 {
cd-gpios = <&gpio6 6 GPIO_ACTIVE_LOW>;
wp-gpios = <&gpio6 7 GPIO_ACTIVE_HIGH>;
sd-uhs-sdr50;
sd-uhs-sdr104;
status = "okay";
-&sdhi1 {
pinctrl-0 = <&sdhi1_pins>;
pinctrl-1 = <&sdhi1_pins_uhs>;
vmmc-supply = <&vcc_sdhi1>;
vqmmc-supply = <&vccq_sdhi1>;
cd-gpios = <&gpio6 14 GPIO_ACTIVE_LOW>;
wp-gpios = <&gpio6 15 GPIO_ACTIVE_HIGH>;
sd-uhs-sdr50;
status = "okay";
-&i2c1 {
pinctrl-0 = <&i2c1_pins>;
-&i2c4 {
-&i2c7 {
status = "okay";
pmic@58 {
reg = <0x58>;
interrupt-parent = <&gpio3>;
interrupts = <31 IRQ_TYPE_LEVEL_LOW>;
rtc {
watchdog {
-&vin0 {
status = "okay";
port {
vin0ep: endpoint {
remote-endpoint = <&adv7180>;
bus-width = <8>;
-&scif2 {
pinctrl-0 = <&scif2_pins>;
status = "okay";
-&scif_clk {
-&qspi {
status = "okay";
flash@0 {
reg = <0>;
spi-cpol;
spi-cpha;
m25p,fast-read;
partitions {
#address-cells = <1>;
#size-cells = <1>;
partition@0 {
label = "loader";
read-only;
partition@40000 {
label = "system";
reg = <0x00040000 0x00040000>;
read-only;
partition@80000 {
label = "user";
reg = <0x00080000 0x03f80000>;
-}; diff --git a/arch/arm/dts/r8a7794-silk.dts b/arch/arm/dts/r8a7794-silk.dts deleted file mode 100644 index b7af1befa12..00000000000 --- a/arch/arm/dts/r8a7794-silk.dts +++ /dev/null @@ -1,578 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Device Tree Source for the SILK board
- Copyright (C) 2014-2015 Renesas Solutions Corp.
- Copyright (C) 2014-2015 Cogent Embedded, Inc.
- SSI-AK4643
- SW1: 2-1: AK4643
2-3: ADV7511
model = "SILK";
compatible = "renesas,silk", "renesas,r8a7794";
aliases {
serial0 = &scif2;
i2c9 = &gpioi2c1;
i2c10 = &i2chdmi;
mmc0 = &mmcif0;
mmc1 = &sdhi1;
chosen {
memory@40000000 {
keyboard {
key-3 {
gpios = <&gpio5 10 GPIO_ACTIVE_LOW>;
label = "SW3";
wakeup-source;
key-4 {
gpios = <&gpio5 11 GPIO_ACTIVE_LOW>;
label = "SW4";
wakeup-source;
key-6 {
gpios = <&gpio5 12 GPIO_ACTIVE_LOW>;
linux,code = <KEY_6>;
label = "SW6";
wakeup-source;
key-a {
linux,code = <KEY_A>;
label = "SW12-1";
wakeup-source;
key-b {
linux,code = <KEY_B>;
label = "SW12-2";
wakeup-source;
key-c {
linux,code = <KEY_C>;
label = "SW12-3";
wakeup-source;
key-d {
linux,code = <KEY_D>;
label = "SW12-4";
wakeup-source;
regulator-boot-on;
enable-active-high;
gpios-states = <1>;
vga-encoder {
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port@1 {
reg = <1>;
hdmi-out {
type = "a";
port {
hdmi_con: endpoint {
vga {
port {
vga_in: endpoint {
x2_clk: x2-clock {
#clock-cells = <0>;
x3_clk: x3-clock {
#clock-cells = <0>;
x9_clk: audio_clock {
#clock-cells = <0>;
clock-frequency = <12288000>;
sound {
simple-audio-card,bitclock-master = <&soundcodec>;
simple-audio-card,frame-master = <&soundcodec>;
soundcodec: simple-audio-card,codec {
clocks = <&x9_clk>;
gpioi2c1: i2c-9 {
#size-cells = <0>;
status = "disabled";
i2chdmi: i2c-10 {
#size-cells = <0>;
ak4643: codec@12 {
reg = <0x12>;
composite-in@20 {
reg = <0x20>;
port {
adv7180: endpoint {
bus-width = <8>;
remote-endpoint = <&vin0ep>;
hdmi@39 {
reg = <0x39>;
interrupt-parent = <&gpio5>;
interrupts = <23 IRQ_TYPE_LEVEL_LOW>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port@1 {
reg = <1>;
remote-endpoint = <&hdmi_con>;
eeprom@50 {
reg = <0x50>;
pagesize = <16>;
-&extal_clk {
-&pfc {
scif2_pins: scif2 {
function = "scif2";
ether_pins: ether {
function = "eth";
phy1_pins: phy1 {
function = "intc";
i2c1_pins: i2c1 {
groups = "i2c1";
function = "i2c1";
function = "mmc";
sdhi1_pins: sd1 {
function = "sdhi1";
qspi_pins: qspi {
function = "qspi";
vin0_pins: vin0 {
groups = "vin0_data8", "vin0_clk";
function = "vin0";
usb0_pins: usb0 {
groups = "usb0";
function = "usb0";
usb1_pins: usb1 {
groups = "usb1";
function = "usb1";
du0_pins: du0 {
groups = "du0_rgb888", "du0_sync", "du0_disp", "du0_clk0_out";
function = "du0";
du1_pins: du1 {
function = "du1";
bias-pull-up;
ssi_pins: sound {
function = "ssi";
audio_clk_pins: audio_clk {
groups = "audio_clkc";
-&scif2 {
status = "okay";
-&scif_clk {
-ðer {
status = "okay";
reg = <1>;
-&i2c1 {
clock-frequency = <400000>;
-&i2c7 {
status = "okay";
pmic@58 {
reg = <0x58>;
interrupt-controller;
onkey {
compatible = "dlg,da9063-onkey";
rtc {
watchdog {
-&mmcif0 {
bus-width = <8>;
non-removable;
status = "okay";
-&sdhi1 {
status = "okay";
-&qspi {
status = "okay";
flash@0 {
reg = <0>;
spi-cpol;
spi-cpha;
m25p,fast-read;
partitions {
#size-cells = <1>;
partition@0 {
label = "loader";
read-only;
partition@40000 {
label = "user";
read-only;
partition@440000 {
label = "flash";
-/* composite video input */ -&vin0 {
status = "okay";
port {
vin0ep: endpoint {
bus-width = <8>;
-&pci0 {
status = "okay";
-&pci1 {
status = "okay";
-&usbphy {
status = "okay";
-&du {
status = "okay";
<&x2_clk>, <&x3_clk>;
ports {
port@0 {
endpoint {
port@1 {
endpoint {
-&rcar_sound {
pinctrl-0 = <&ssi_pins>, <&audio_clk_pins>;
status = "okay";
/* Single DAI */
rcar_sound,dai {
dai0 {
playback = <&ssi0>;
capture = <&ssi1>;
-&rwdt {
timeout-sec = <60>;
status = "okay";
-&ssi1 {
shared-pin;
-}; diff --git a/arch/arm/dts/r8a7794.dtsi b/arch/arm/dts/r8a7794.dtsi deleted file mode 100644 index 371dd4715dd..00000000000 --- a/arch/arm/dts/r8a7794.dtsi +++ /dev/null @@ -1,1437 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Device Tree Source for the R-Car E2 (R8A77940) SoC
- Copyright (C) 2014 Ulrich Hecht
-#include <dt-bindings/clock/r8a7794-cpg-mssr.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/power/r8a7794-sysc.h>
compatible = "renesas,r8a7794";
#size-cells = <2>;
aliases {
i2c0 = &i2c0;
i2c1 = &i2c1;
i2c2 = &i2c2;
i2c3 = &i2c3;
i2c4 = &i2c4;
i2c5 = &i2c5;
i2c6 = &i2c6;
i2c7 = &i2c7;
spi0 = &qspi;
vin0 = &vin0;
vin1 = &vin1;
audio_clka: audio_clka {
#clock-cells = <0>;
audio_clkb: audio_clkb {
#clock-cells = <0>;
audio_clkc: audio_clkc {
#clock-cells = <0>;
can_clk: can {
#clock-cells = <0>;
cpus {
#size-cells = <0>;
cpu0: cpu@0 {
compatible = "arm,cortex-a7";
reg = <0>;
clocks = <&cpg CPG_CORE R8A7794_CLK_Z2>;
power-domains = <&sysc R8A7794_PD_CA7_CPU0>;
next-level-cache = <&L2_CA7>;
cpu1: cpu@1 {
reg = <1>;
power-domains = <&sysc R8A7794_PD_CA7_CPU1>;
L2_CA7: cache-controller-0 {
power-domains = <&sysc R8A7794_PD_CA7_SCU>;
cache-unified;
cache-level = <2>;
extal_clk: extal {
#clock-cells = <0>;
pmu {
compatible = "arm,cortex-a7-pmu";
interrupts-extended = <&gic GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>,
<&gic GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>;
interrupt-affinity = <&cpu0>, <&cpu1>;
scif_clk: scif {
#clock-cells = <0>;
soc {
#size-cells = <2>;
ranges;
compatible = "renesas,r8a7794-wdt",
power-domains = <&sysc R8A7794_PD_ALWAYS_ON>;
compatible = "renesas,gpio-r8a7794",
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 32 26>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 64 32>;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 160 28>;
gpio6: gpio@e6055400 {
reg = <0 0xe6055400 0 0x50>;
interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 192 26>;
clocks = <&cpg CPG_MOD 905>;
resets = <&cpg 905>;
compatible = "renesas,pfc-r8a7794";
reg = <0 0xe6060000 0 0x11c>;
compatible = "renesas,r8a7794-cpg-mssr";
#clock-cells = <2>;
#reset-cells = <1>;
apmu@e6151000 {
compatible = "renesas,r8a7794-apmu", "renesas,apmu";
reg = <0 0xe6151000 0 0x188>;
cpus = <&cpu0>, <&cpu1>;
compatible = "renesas,r8a7794-rst";
compatible = "renesas,r8a7794-sysc";
compatible = "renesas,irqc-r8a7794", "renesas,irqc";
<GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>;
compatible = "renesas,ipmmu-r8a7794",
#iommu-cells = <1>;
#iommu-cells = <1>;
#iommu-cells = <1>;
#iommu-cells = <1>;
#iommu-cells = <1>;
ipmmu_gp: iommu@e62a0000 {
reg = <0 0xe62a0000 0 0x1000>;
interrupts = <GIC_SPI 260 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 261 IRQ_TYPE_LEVEL_HIGH>;
#iommu-cells = <1>;
#size-cells = <1>;
#size-cells = <1>;
smp-sram@0 {
reg = <0 0x100>;
/* The memory map in the User's Manual maps the cores to
* bus numbers
compatible = "renesas,i2c-r8a7794",
#size-cells = <0>;
#size-cells = <0>;
#size-cells = <0>;
#size-cells = <0>;
i2c4: i2c@e6520000 {
reg = <0 0xe6520000 0 0x40>;
interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 927>;
resets = <&cpg 927>;
#size-cells = <0>;
i2c5: i2c@e6528000 {
#size-cells = <0>;
i2c6: i2c@e6500000 {
compatible = "renesas,iic-r8a7794",
#size-cells = <0>;
i2c7: i2c@e6510000 {
#size-cells = <0>;
hsusb: usb@e6590000 {
compatible = "renesas,usbhs-r8a7794",
"renesas,rcar-gen2-usbhs";
reg = <0 0xe6590000 0 0x100>;
interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 704>;
resets = <&cpg 704>;
renesas,buswait = <4>;
phys = <&usb0 1>;
phy-names = "usb";
usbphy: usb-phy-controller@e6590100 {
compatible = "renesas,usb-phy-r8a7794",
"renesas,rcar-gen2-usb-phy";
reg = <0 0xe6590100 0 0x100>;
#size-cells = <0>;
clock-names = "usbhs";
usb0: usb-phy@0 {
reg = <0>;
#phy-cells = <1>;
usb2: usb-phy@2 {
reg = <2>;
#phy-cells = <1>;
compatible = "renesas,dmac-r8a7794",
#dma-cells = <1>;
#dma-cells = <1>;
avb: ethernet@e6800000 {
compatible = "renesas,etheravb-r8a7794",
"renesas,etheravb-rcar-gen2";
reg = <0 0xe6800000 0 0x800>, <0 0xee0e8000 0 0x4000>;
interrupts = <GIC_SPI 163 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 812>;
clock-names = "fck";
resets = <&cpg 812>;
#size-cells = <0>;
compatible = "renesas,qspi-r8a7794", "renesas,qspi";
interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 917>;
resets = <&cpg 917>;
num-cs = <1>;
#size-cells = <0>;
compatible = "renesas,scifa-r8a7794",
scifa3: serial@e6c70000 {
reg = <0 0xe6c70000 0 64>;
interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 1106>;
dmas = <&dmac0 0x1b>, <&dmac0 0x1c>,
<&dmac1 0x1b>, <&dmac1 0x1c>;
resets = <&cpg 1106>;
scifa4: serial@e6c78000 {
reg = <0 0xe6c78000 0 64>;
interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 1107>;
dmas = <&dmac0 0x1f>, <&dmac0 0x20>,
<&dmac1 0x1f>, <&dmac1 0x20>;
resets = <&cpg 1107>;
scifa5: serial@e6c80000 {
reg = <0 0xe6c80000 0 64>;
interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 1108>;
dmas = <&dmac0 0x23>, <&dmac0 0x24>,
<&dmac1 0x23>, <&dmac1 0x24>;
resets = <&cpg 1108>;
compatible = "renesas,scifb-r8a7794",
compatible = "renesas,scif-r8a7794",
"renesas,rcar-gen2-scif",
"renesas,scif";
clocks = <&cpg CPG_MOD 721>, <&cpg CPG_CORE R8A7794_CLK_ZS>,
<&scif_clk>;
"renesas,scif";
clocks = <&cpg CPG_MOD 720>, <&cpg CPG_CORE R8A7794_CLK_ZS>,
<&scif_clk>;
scif2: serial@e6e58000 {
"renesas,rcar-gen2-scif", "renesas,scif";
reg = <0 0xe6e58000 0 64>;
interrupts = <GIC_SPI 22 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 719>, <&cpg CPG_CORE R8A7794_CLK_ZS>,
<&scif_clk>;
resets = <&cpg 719>;
scif3: serial@e6ea8000 {
reg = <0 0xe6ea8000 0 64>;
interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 718>, <&cpg CPG_CORE R8A7794_CLK_ZS>,
<&scif_clk>;
dmas = <&dmac0 0x2f>, <&dmac0 0x30>,
<&dmac1 0x2f>, <&dmac1 0x30>;
resets = <&cpg 718>;
scif4: serial@e6ee0000 {
reg = <0 0xe6ee0000 0 64>;
interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 715>, <&cpg CPG_CORE R8A7794_CLK_ZS>,
<&scif_clk>;
dmas = <&dmac0 0xfb>, <&dmac0 0xfc>,
<&dmac1 0xfb>, <&dmac1 0xfc>;
resets = <&cpg 715>;
scif5: serial@e6ee8000 {
reg = <0 0xe6ee8000 0 64>;
interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 714>, <&cpg CPG_CORE R8A7794_CLK_ZS>,
<&scif_clk>;
dmas = <&dmac0 0xfd>, <&dmac0 0xfe>,
<&dmac1 0xfd>, <&dmac1 0xfe>;
resets = <&cpg 714>;
compatible = "renesas,hscif-r8a7794",
<&cpg CPG_CORE R8A7794_CLK_ZS>, <&scif_clk>;
resets = <&cpg 716>;
hscif2: serial@e62d0000 {
reg = <0 0xe62d0000 0 96>;
interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 713>, <&cpg CPG_CORE R8A7794_CLK_ZS>,
<&scif_clk>;
dmas = <&dmac0 0x3b>, <&dmac0 0x3c>,
<&dmac1 0x3b>, <&dmac1 0x3c>;
resets = <&cpg 713>;
compatible = "renesas,can-r8a7794",
clocks = <&cpg CPG_MOD 916>, <&cpg CPG_CORE R8A7794_CLK_RCAN>,
<&can_clk>;
clocks = <&cpg CPG_MOD 915>, <&cpg CPG_CORE R8A7794_CLK_RCAN>,
<&can_clk>;
compatible = "renesas,vin-r8a7794",
compatible = "renesas,rcar_sound-r8a7794",
<0 0xec740000 0 0x200>; /* Audio DMAC peri peri */
<&cpg CPG_MOD 1025>, <&cpg CPG_MOD 1026>,
<&cpg CPG_MOD 1027>, <&cpg CPG_MOD 1028>,
<&cpg CPG_MOD 1029>, <&cpg CPG_MOD 1030>,
<&cpg CPG_MOD 1021>, <&cpg CPG_MOD 1020>,
<&audio_clka>, <&audio_clkb>, <&audio_clkc>,
<&cpg CPG_CORE R8A7794_CLK_M2>;
"ssi.1", "ssi.0",
"src.6", "src.5", "src.4", "src.3",
"src.2", "src.1",
"ctu.0", "ctu.1",
"mix.0", "mix.1",
"dvc.0", "dvc.1",
"ssi.1", "ssi.0";
rcar_sound,dvc {
dvc0: dvc-0 {
dmas = <&audma0 0xbc>;
dma-names = "tx";
dvc1: dvc-1 {
dmas = <&audma0 0xbe>;
dma-names = "tx";
rcar_sound,mix {
mix0: mix-0 { };
mix1: mix-1 { };
rcar_sound,ctu {
ctu00: ctu-0 { };
ctu01: ctu-1 { };
ctu02: ctu-2 { };
ctu03: ctu-3 { };
ctu10: ctu-4 { };
ctu11: ctu-5 { };
ctu12: ctu-6 { };
ctu13: ctu-7 { };
rcar_sound,src {
src-0 {
src1: src-1 {
dmas = <&audma0 0x87>, <&audma0 0x9c>;
src2: src-2 {
dmas = <&audma0 0x89>, <&audma0 0x9e>;
src3: src-3 {
dmas = <&audma0 0x8b>, <&audma0 0xa0>;
src4: src-4 {
dmas = <&audma0 0x8d>, <&audma0 0xb0>;
src5: src-5 {
dmas = <&audma0 0x8f>, <&audma0 0xb2>;
src6: src-6 {
dmas = <&audma0 0x91>, <&audma0 0xb4>;
rcar_sound,ssi {
ssi0: ssi-0 {
dmas = <&audma0 0x01>, <&audma0 0x02>,
<&audma0 0x15>, <&audma0 0x16>;
ssi1: ssi-1 {
dmas = <&audma0 0x03>, <&audma0 0x04>,
<&audma0 0x49>, <&audma0 0x4a>;
ssi2: ssi-2 {
dmas = <&audma0 0x05>, <&audma0 0x06>,
<&audma0 0x63>, <&audma0 0x64>;
ssi3: ssi-3 {
dmas = <&audma0 0x07>, <&audma0 0x08>,
<&audma0 0x6f>, <&audma0 0x70>;
ssi4: ssi-4 {
dmas = <&audma0 0x09>, <&audma0 0x0a>,
<&audma0 0x71>, <&audma0 0x72>;
ssi5: ssi-5 {
dmas = <&audma0 0x0b>, <&audma0 0x0c>,
<&audma0 0x73>, <&audma0 0x74>;
ssi6: ssi-6 {
dmas = <&audma0 0x0d>, <&audma0 0x0e>,
<&audma0 0x75>, <&audma0 0x76>;
ssi7: ssi-7 {
dmas = <&audma0 0x0f>, <&audma0 0x10>,
<&audma0 0x79>, <&audma0 0x7a>;
ssi8: ssi-8 {
dmas = <&audma0 0x11>, <&audma0 0x12>,
<&audma0 0x7b>, <&audma0 0x7c>;
ssi9: ssi-9 {
dmas = <&audma0 0x13>, <&audma0 0x14>,
<&audma0 0x7d>, <&audma0 0x7e>;
interrupt-names = "error",
"ch0", "ch1", "ch2", "ch3", "ch4",
"ch5", "ch6", "ch7", "ch8", "ch9",
"ch10", "ch11",
"ch12";
#dma-cells = <1>;
pci0: pci@ee090000 {
compatible = "renesas,pci-r8a7794",
"renesas,pci-rcar-gen2";
reg = <0 0xee090000 0 0xc00>,
<0 0xee080000 0 0x1100>;
clocks = <&cpg CPG_MOD 703>;
resets = <&cpg 703>;
bus-range = <0 0>;
#size-cells = <2>;
ranges = <0x02000000 0 0xee080000 0 0xee080000 0 0x00010000>;
interrupt-map-mask = <0xf800 0 0 0x7>;
interrupt-map = <0x0000 0 0 1 &gic GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>,
<0x0800 0 0 1 &gic GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>,
<0x1000 0 0 2 &gic GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>;
usb@1,0 {
reg = <0x800 0 0 0 0>;
phys = <&usb0 0>;
phy-names = "usb";
usb@2,0 {
reg = <0x1000 0 0 0 0>;
phys = <&usb0 0>;
phy-names = "usb";
reg = <0 0xee0d0000 0 0xc00>,
<0 0xee0c0000 0 0x1100>;
interrupts = <GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH>;
bus-range = <1 1>;
#size-cells = <2>;
ranges = <0x02000000 0 0xee0c0000 0 0xee0c0000 0 0x00010000>;
interrupt-map = <0x0000 0 0 1 &gic GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH>,
<0x0800 0 0 1 &gic GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH>,
<0x1000 0 0 2 &gic GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH>;
usb@1,0 {
phys = <&usb2 0>;
phy-names = "usb";
usb@2,0 {
phys = <&usb2 0>;
phy-names = "usb";
compatible = "renesas,sdhi-r8a7794",
compatible = "renesas,mmcif-r8a7794",
"renesas,sh-mmcif";
reg-io-width = <4>;
compatible = "renesas,ether-r8a7794",
phy-mode = "rmii";
#size-cells = <0>;
vsp@fe928000 {
compatible = "renesas,vsp1";
reg = <0 0xfe928000 0 0x8000>;
interrupts = <GIC_SPI 267 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 131>;
resets = <&cpg 131>;
vsp@fe930000 {
reg = <0 0xfe930000 0 0x8000>;
clocks = <&cpg CPG_MOD 128>;
resets = <&cpg 128>;
fdp1@fe940000 {
compatible = "renesas,du-r8a7794";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port@1 {
reg = <1>;
compatible = "renesas,r8a7794-cmt0",
compatible = "renesas,r8a7794-cmt1",
timer {
#clock-cells = <0>;
-}; diff --git a/arch/arm/dts/r8a77950-salvator-x.dts b/arch/arm/dts/r8a77950-salvator-x.dts deleted file mode 100644 index c6ca61a8ed4..00000000000 --- a/arch/arm/dts/r8a77950-salvator-x.dts +++ /dev/null @@ -1,49 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Device Tree Source for the Salvator-X board with R-Car H3 ES1.x
- Copyright (C) 2015 Renesas Electronics Corp.
-/dts-v1/; -#include "r8a77950.dtsi" -#include "salvator-x.dtsi"
model = "Renesas Salvator-X board based on r8a77950";
compatible = "renesas,salvator-x", "renesas,r8a7795";
memory@48000000 {
/* first 128MB is reserved for secure area. */
reg = <0x0 0x48000000 0x0 0x38000000>;
memory@500000000 {
reg = <0x5 0x00000000 0x0 0x40000000>;
memory@600000000 {
reg = <0x6 0x00000000 0x0 0x40000000>;
memory@700000000 {
reg = <0x7 0x00000000 0x0 0x40000000>;
-&du {
<&cpg CPG_MOD 723>,
<&cpg CPG_MOD 722>,
<&cpg CPG_MOD 721>,
<&versaclock5 1>,
<&x21_clk>,
<&x22_clk>,
<&versaclock5 2>;
clock-names = "du.0", "du.1", "du.2", "du.3",
"dclkin.0", "dclkin.1", "dclkin.2", "dclkin.3";
-}; diff --git a/arch/arm/dts/r8a77950-ulcb.dts b/arch/arm/dts/r8a77950-ulcb.dts deleted file mode 100644 index 5340579931e..00000000000 --- a/arch/arm/dts/r8a77950-ulcb.dts +++ /dev/null @@ -1,37 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Device Tree Source for the H3ULCB (R-Car Starter Kit Premier) board with R-Car H3 ES1.x
- Copyright (C) 2016 Renesas Electronics Corp.
-/dts-v1/; -#include "r8a77950.dtsi" -#include "ulcb.dtsi"
model = "Renesas H3ULCB board based on r8a77950";
compatible = "renesas,h3ulcb", "renesas,r8a7795";
memory@48000000 {
memory@500000000 {
memory@600000000 {
memory@700000000 {
-}; diff --git a/arch/arm/dts/r8a77950.dtsi b/arch/arm/dts/r8a77950.dtsi deleted file mode 100644 index 57eb88177e9..00000000000 --- a/arch/arm/dts/r8a77950.dtsi +++ /dev/null @@ -1,330 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Device Tree Source for the R-Car H3 (R8A77950) SoC
-#include "r8a77951.dtsi"
-#undef SOC_HAS_USB2_CH3
-&audma0 {
iommus = <&ipmmu_mp1 0>, <&ipmmu_mp1 1>,
<&ipmmu_mp1 2>, <&ipmmu_mp1 3>,
<&ipmmu_mp1 4>, <&ipmmu_mp1 5>,
<&ipmmu_mp1 6>, <&ipmmu_mp1 7>,
<&ipmmu_mp1 8>, <&ipmmu_mp1 9>,
<&ipmmu_mp1 10>, <&ipmmu_mp1 11>,
<&ipmmu_mp1 12>, <&ipmmu_mp1 13>,
<&ipmmu_mp1 14>, <&ipmmu_mp1 15>;
-&audma1 {
iommus = <&ipmmu_mp1 16>, <&ipmmu_mp1 17>,
<&ipmmu_mp1 18>, <&ipmmu_mp1 19>,
<&ipmmu_mp1 20>, <&ipmmu_mp1 21>,
<&ipmmu_mp1 22>, <&ipmmu_mp1 23>,
<&ipmmu_mp1 24>, <&ipmmu_mp1 25>,
<&ipmmu_mp1 26>, <&ipmmu_mp1 27>,
<&ipmmu_mp1 28>, <&ipmmu_mp1 29>,
<&ipmmu_mp1 30>, <&ipmmu_mp1 31>;
-&cluster0_opp {
/delete-node/ opp-1600000000;
/delete-node/ opp-1700000000;
-&du {
renesas,vsps = <&vspd0 0>, <&vspd1 0>, <&vspd2 0>, <&vspd3 0>;
-&fcpvb1 {
iommus = <&ipmmu_vp0 7>;
-&fcpf1 {
iommus = <&ipmmu_vp0 1>;
-&fcpvi1 {
iommus = <&ipmmu_vp0 9>;
-&fcpvd2 {
iommus = <&ipmmu_vi0 10>;
-&gpio1 {
gpio-ranges = <&pfc 0 32 28>;
-&ipmmu_vi0 {
renesas,ipmmu-main = <&ipmmu_mm 11>;
-&ipmmu_vp0 {
renesas,ipmmu-main = <&ipmmu_mm 12>;
-&ipmmu_vc0 {
renesas,ipmmu-main = <&ipmmu_mm 9>;
-&ipmmu_vc1 {
renesas,ipmmu-main = <&ipmmu_mm 10>;
-&ipmmu_rt {
renesas,ipmmu-main = <&ipmmu_mm 7>;
-&soc {
/delete-node/ dma-controller@e6460000;
/delete-node/ dma-controller@e6470000;
ipmmu_mp1: iommu@ec680000 {
compatible = "renesas,ipmmu-r8a7795";
renesas,ipmmu-main = <&ipmmu_mm 5>;
power-domains = <&sysc R8A7795_PD_ALWAYS_ON>;
#iommu-cells = <1>;
ipmmu_sy: iommu@e7730000 {
reg = <0 0xe7730000 0 0x1000>;
renesas,ipmmu-main = <&ipmmu_mm 8>;
#iommu-cells = <1>;
/delete-node/ iommu@fd950000;
/delete-node/ iommu@fd960000;
/delete-node/ iommu@fd970000;
/delete-node/ iommu@febe0000;
/delete-node/ iommu@fe980000;
xhci1: usb@ee040000 {
compatible = "renesas,xhci-r8a7795", "renesas,rcar-gen3-xhci";
reg = <0 0xee040000 0 0xc00>;
interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 327>;
resets = <&cpg 327>;
/delete-node/ usb@e659c000;
/delete-node/ usb@ee0e0000;
/delete-node/ usb@ee0e0100;
/delete-node/ usb-phy@ee0e0200;
fdp1@fe948000 {
compatible = "renesas,fdp1";
reg = <0 0xfe948000 0 0x2400>;
interrupts = <GIC_SPI 264 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 117>;
power-domains = <&sysc R8A7795_PD_A3VP>;
resets = <&cpg 117>;
renesas,fcp = <&fcpf2>;
fcpf2: fcp@fe952000 {
compatible = "renesas,fcpf";
reg = <0 0xfe952000 0 0x200>;
clocks = <&cpg CPG_MOD 613>;
resets = <&cpg 613>;
iommus = <&ipmmu_vp0 2>;
fcpvd3: fcp@fea3f000 {
compatible = "renesas,fcpv";
reg = <0 0xfea3f000 0 0x200>;
clocks = <&cpg CPG_MOD 600>;
resets = <&cpg 600>;
iommus = <&ipmmu_vi0 11>;
fcpvi2: fcp@fe9cf000 {
reg = <0 0xfe9cf000 0 0x200>;
clocks = <&cpg CPG_MOD 609>;
resets = <&cpg 609>;
iommus = <&ipmmu_vp0 10>;
vspd3: vsp@fea38000 {
compatible = "renesas,vsp2";
reg = <0 0xfea38000 0 0x5000>;
interrupts = <GIC_SPI 469 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 620>;
resets = <&cpg 620>;
renesas,fcp = <&fcpvd3>;
vspi2: vsp@fe9c0000 {
reg = <0 0xfe9c0000 0 0x8000>;
interrupts = <GIC_SPI 446 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 629>;
resets = <&cpg 629>;
renesas,fcp = <&fcpvi2>;
csi21: csi2@fea90000 {
compatible = "renesas,r8a7795-csi2";
reg = <0 0xfea90000 0 0x10000>;
interrupts = <GIC_SPI 185 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 713>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
csi21vin0: endpoint@0 {
reg = <0>;
remote-endpoint = <&vin0csi21>;
csi21vin1: endpoint@1 {
reg = <1>;
remote-endpoint = <&vin1csi21>;
csi21vin2: endpoint@2 {
reg = <2>;
remote-endpoint = <&vin2csi21>;
csi21vin3: endpoint@3 {
reg = <3>;
remote-endpoint = <&vin3csi21>;
csi21vin4: endpoint@4 {
reg = <4>;
remote-endpoint = <&vin4csi21>;
csi21vin5: endpoint@5 {
reg = <5>;
remote-endpoint = <&vin5csi21>;
csi21vin6: endpoint@6 {
reg = <6>;
remote-endpoint = <&vin6csi21>;
csi21vin7: endpoint@7 {
reg = <7>;
remote-endpoint = <&vin7csi21>;
-&vin0 {
ports {
port@1 {
vin0csi21: endpoint@1 {
reg = <1>;
remote-endpoint = <&csi21vin0>;
-&vin1 {
ports {
port@1 {
vin1csi21: endpoint@1 {
reg = <1>;
remote-endpoint = <&csi21vin1>;
-&vin2 {
ports {
port@1 {
vin2csi21: endpoint@1 {
reg = <1>;
remote-endpoint = <&csi21vin2>;
-&vin3 {
ports {
port@1 {
vin3csi21: endpoint@1 {
reg = <1>;
remote-endpoint = <&csi21vin3>;
-&vin4 {
ports {
port@1 {
vin4csi21: endpoint@1 {
reg = <1>;
remote-endpoint = <&csi21vin4>;
-&vin5 {
ports {
port@1 {
vin5csi21: endpoint@1 {
reg = <1>;
remote-endpoint = <&csi21vin5>;
-&vin6 {
ports {
port@1 {
vin6csi21: endpoint@1 {
reg = <1>;
remote-endpoint = <&csi21vin6>;
-&vin7 {
ports {
port@1 {
vin7csi21: endpoint@1 {
reg = <1>;
remote-endpoint = <&csi21vin7>;
-}; diff --git a/arch/arm/dts/r8a77951.dtsi b/arch/arm/dts/r8a77951.dtsi deleted file mode 100644 index 6d15229d25a..00000000000 --- a/arch/arm/dts/r8a77951.dtsi +++ /dev/null @@ -1,3485 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Device Tree Source for the R-Car H3 (R8A77951) SoC
-#include <dt-bindings/clock/r8a7795-cpg-mssr.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/power/r8a7795-sysc.h>
-#define CPG_AUDIO_CLK_I R8A7795_CLK_S0D4
-#define SOC_HAS_HDMI1 -#define SOC_HAS_SATA -#define SOC_HAS_USB2_CH2 -#define SOC_HAS_USB2_CH3
compatible = "renesas,r8a7795";
#size-cells = <2>;
compatible = "fixed-clock";
#clock-cells = <0>;
#clock-cells = <0>;
#clock-cells = <0>;
/* External CAN clock - to be overridden by boards that provide it */
can_clk: can {
#clock-cells = <0>;
cluster0_opp: opp-table-0 {
compatible = "operating-points-v2";
opp-shared;
opp-500000000 {
opp-hz = /bits/ 64 <500000000>;
opp-microvolt = <830000>;
clock-latency-ns = <300000>;
opp-1000000000 {
opp-hz = /bits/ 64 <1000000000>;
opp-1500000000 {
opp-hz = /bits/ 64 <1500000000>;
opp-suspend;
opp-1600000000 {
opp-hz = /bits/ 64 <1600000000>;
opp-microvolt = <900000>;
opp-1700000000 {
opp-hz = /bits/ 64 <1700000000>;
opp-microvolt = <960000>;
turbo-mode;
cluster1_opp: opp-table-1 {
opp-shared;
opp-800000000 {
opp-hz = /bits/ 64 <800000000>;
opp-microvolt = <820000>;
opp-1000000000 {
opp-1200000000 {
opp-hz = /bits/ 64 <1200000000>;
cpus {
#size-cells = <0>;
cpu-map {
cluster0 {
core0 {
cpu = <&a57_0>;
core1 {
cpu = <&a57_1>;
core2 {
cpu = <&a57_2>;
core3 {
cpu = <&a57_3>;
cluster1 {
core0 {
cpu = <&a53_0>;
core1 {
cpu = <&a53_1>;
core2 {
cpu = <&a53_2>;
core3 {
cpu = <&a53_3>;
a57_0: cpu@0 {
compatible = "arm,cortex-a57";
reg = <0x0>;
power-domains = <&sysc R8A7795_PD_CA57_CPU0>;
next-level-cache = <&L2_CA57>;
enable-method = "psci";
cpu-idle-states = <&CPU_SLEEP_0>;
dynamic-power-coefficient = <854>;
clocks = <&cpg CPG_CORE R8A7795_CLK_Z>;
operating-points-v2 = <&cluster0_opp>;
capacity-dmips-mhz = <1024>;
#cooling-cells = <2>;
a57_1: cpu@1 {
reg = <0x1>;
power-domains = <&sysc R8A7795_PD_CA57_CPU1>;
a57_2: cpu@2 {
reg = <0x2>;
power-domains = <&sysc R8A7795_PD_CA57_CPU2>;
a57_3: cpu@3 {
reg = <0x3>;
power-domains = <&sysc R8A7795_PD_CA57_CPU3>;
a53_0: cpu@100 {
compatible = "arm,cortex-a53";
reg = <0x100>;
power-domains = <&sysc R8A7795_PD_CA53_CPU0>;
next-level-cache = <&L2_CA53>;
cpu-idle-states = <&CPU_SLEEP_1>;
dynamic-power-coefficient = <277>;
clocks = <&cpg CPG_CORE R8A7795_CLK_Z2>;
operating-points-v2 = <&cluster1_opp>;
capacity-dmips-mhz = <535>;
a53_1: cpu@101 {
reg = <0x101>;
power-domains = <&sysc R8A7795_PD_CA53_CPU1>;
a53_2: cpu@102 {
reg = <0x102>;
power-domains = <&sysc R8A7795_PD_CA53_CPU2>;
a53_3: cpu@103 {
reg = <0x103>;
power-domains = <&sysc R8A7795_PD_CA53_CPU3>;
L2_CA57: cache-controller-0 {
power-domains = <&sysc R8A7795_PD_CA57_SCU>;
cache-unified;
cache-level = <2>;
L2_CA53: cache-controller-1 {
power-domains = <&sysc R8A7795_PD_CA53_SCU>;
cache-unified;
cache-level = <2>;
idle-states {
entry-method = "psci";
CPU_SLEEP_0: cpu-sleep-0 {
compatible = "arm,idle-state";
arm,psci-suspend-param = <0x0010000>;
local-timer-stop;
entry-latency-us = <400>;
exit-latency-us = <500>;
min-residency-us = <4000>;
CPU_SLEEP_1: cpu-sleep-1 {
local-timer-stop;
entry-latency-us = <700>;
exit-latency-us = <700>;
min-residency-us = <5000>;
extal_clk: extal {
#clock-cells = <0>;
/* This value must be overridden by the board */
extalr_clk: extalr {
#clock-cells = <0>;
/* External PCIe clock - can be overridden by the board */
pcie_bus_clk: pcie_bus {
#clock-cells = <0>;
pmu_a53 {
compatible = "arm,cortex-a53-pmu";
interrupts-extended = <&gic GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>,
<&gic GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>,
<&gic GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>,
<&gic GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>;
interrupt-affinity = <&a53_0>,
<&a53_1>,
<&a53_2>,
<&a53_3>;
pmu_a57 {
compatible = "arm,cortex-a57-pmu";
interrupts-extended = <&gic GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>,
<&gic GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>,
<&gic GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>,
<&gic GIC_SPI 75 IRQ_TYPE_LEVEL_HIGH>;
interrupt-affinity = <&a57_0>,
<&a57_1>,
<&a57_2>,
<&a57_3>;
psci {
compatible = "arm,psci-1.0", "arm,psci-0.2";
method = "smc";
/* External SCIF clock - to be overridden by boards that provide it */
scif_clk: scif {
#clock-cells = <0>;
soc: soc {
#address-cells = <2>;
#size-cells = <2>;
ranges;
compatible = "renesas,r8a7795-wdt", "renesas,rcar-gen3-wdt";
compatible = "renesas,gpio-r8a7795",
"renesas,rcar-gen3-gpio";
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 0 16>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 32 29>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 64 15>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 96 16>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 128 18>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 160 26>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 192 32>;
clocks = <&cpg CPG_MOD 906>;
resets = <&cpg 906>;
gpio7: gpio@e6055800 {
reg = <0 0xe6055800 0 0x50>;
interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
gpio-ranges = <&pfc 0 224 4>;
compatible = "renesas,pfc-r8a7795";
reg = <0 0xe6060000 0 0x50c>;
cmt0: timer@e60f0000 {
compatible = "renesas,r8a7795-cmt0",
"renesas,rcar-gen3-cmt0";
reg = <0 0xe60f0000 0 0x1004>;
clocks = <&cpg CPG_MOD 303>;
resets = <&cpg 303>;
compatible = "renesas,r8a7795-cmt1",
"renesas,rcar-gen3-cmt1";
clocks = <&cpg CPG_MOD 302>;
resets = <&cpg 302>;
cmt2: timer@e6140000 {
reg = <0 0xe6140000 0 0x1004>;
interrupts = <GIC_SPI 398 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 399 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 400 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 401 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 402 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 403 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 404 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 405 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 301>;
resets = <&cpg 301>;
cmt3: timer@e6148000 {
reg = <0 0xe6148000 0 0x1004>;
interrupts = <GIC_SPI 470 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 471 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 472 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 473 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 474 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 475 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 476 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 477 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 300>;
resets = <&cpg 300>;
compatible = "renesas,r8a7795-cpg-mssr";
clocks = <&extal_clk>, <&extalr_clk>;
clock-names = "extal", "extalr";
#clock-cells = <2>;
#reset-cells = <1>;
compatible = "renesas,r8a7795-rst";
reg = <0 0xe6160000 0 0x0200>;
compatible = "renesas,r8a7795-sysc";
reg = <0 0xe6180000 0 0x0400>;
tsc: thermal@e6198000 {
compatible = "renesas,r8a7795-thermal";
reg = <0 0xe6198000 0 0x100>,
<0 0xe61a0000 0 0x100>,
<0 0xe61a8000 0 0x100>;
interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>,
#thermal-sensor-cells = <1>;
intc_ex: interrupt-controller@e61c0000 {
compatible = "renesas,intc-ex-r8a7795", "renesas,irqc";
<GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 161 IRQ_TYPE_LEVEL_HIGH>;
tmu0: timer@e61e0000 {
compatible = "renesas,tmu-r8a7795", "renesas,tmu";
reg = <0 0xe61e0000 0 0x30>;
interrupts = <GIC_SPI 136 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 137 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 138 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 125>;
resets = <&cpg 125>;
tmu1: timer@e6fc0000 {
reg = <0 0xe6fc0000 0 0x30>;
interrupts = <GIC_SPI 128 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 129 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 130 IRQ_TYPE_LEVEL_HIGH>;
tmu2: timer@e6fd0000 {
reg = <0 0xe6fd0000 0 0x30>;
interrupts = <GIC_SPI 303 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 304 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 305 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 123>;
resets = <&cpg 123>;
tmu3: timer@e6fe0000 {
reg = <0 0xe6fe0000 0 0x30>;
interrupts = <GIC_SPI 131 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 132 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 133 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 122>;
resets = <&cpg 122>;
tmu4: timer@ffc00000 {
reg = <0 0xffc00000 0 0x30>;
interrupts = <GIC_SPI 406 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 407 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 408 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 121>;
resets = <&cpg 121>;
i2c0: i2c@e6500000 {
#size-cells = <0>;
compatible = "renesas,i2c-r8a7795",
"renesas,rcar-gen3-i2c";
reg = <0 0xe6500000 0 0x40>;
dmas = <&dmac1 0x91>, <&dmac1 0x90>,
<&dmac2 0x91>, <&dmac2 0x90>;
i2c1: i2c@e6508000 {
#size-cells = <0>;
dmas = <&dmac1 0x93>, <&dmac1 0x92>,
<&dmac2 0x93>, <&dmac2 0x92>;
i2c2: i2c@e6510000 {
#size-cells = <0>;
reg = <0 0xe6510000 0 0x40>;
dmas = <&dmac1 0x95>, <&dmac1 0x94>,
<&dmac2 0x95>, <&dmac2 0x94>;
i2c3: i2c@e66d0000 {
#size-cells = <0>;
reg = <0 0xe66d0000 0 0x40>;
dmas = <&dmac0 0x97>, <&dmac0 0x96>;
dma-names = "tx", "rx";
i2c4: i2c@e66d8000 {
#size-cells = <0>;
reg = <0 0xe66d8000 0 0x40>;
dmas = <&dmac0 0x99>, <&dmac0 0x98>;
i2c5: i2c@e66e0000 {
#size-cells = <0>;
reg = <0 0xe66e0000 0 0x40>;
interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 919>;
resets = <&cpg 919>;
dmas = <&dmac0 0x9b>, <&dmac0 0x9a>;
i2c6: i2c@e66e8000 {
#size-cells = <0>;
reg = <0 0xe66e8000 0 0x40>;
clocks = <&cpg CPG_MOD 918>;
resets = <&cpg 918>;
dmas = <&dmac0 0x9d>, <&dmac0 0x9c>;
i2c_dvfs: i2c@e60b0000 {
#size-cells = <0>;
compatible = "renesas,iic-r8a7795",
"renesas,rcar-gen3-iic",
dmas = <&dmac0 0x11>, <&dmac0 0x10>;
hscif0: serial@e6540000 {
compatible = "renesas,hscif-r8a7795",
"renesas,rcar-gen3-hscif",
"renesas,hscif";
reg = <0 0xe6540000 0 96>;
clocks = <&cpg CPG_MOD 520>,
<&cpg CPG_CORE R8A7795_CLK_S3D1>,
<&scif_clk>;
dmas = <&dmac1 0x31>, <&dmac1 0x30>,
<&dmac2 0x31>, <&dmac2 0x30>;
resets = <&cpg 520>;
hscif1: serial@e6550000 {
"renesas,hscif";
reg = <0 0xe6550000 0 96>;
clocks = <&cpg CPG_MOD 519>,
<&scif_clk>;
dmas = <&dmac1 0x33>, <&dmac1 0x32>,
<&dmac2 0x33>, <&dmac2 0x32>;
resets = <&cpg 519>;
hscif2: serial@e6560000 {
"renesas,hscif";
reg = <0 0xe6560000 0 96>;
clocks = <&cpg CPG_MOD 518>,
<&scif_clk>;
dmas = <&dmac1 0x35>, <&dmac1 0x34>,
<&dmac2 0x35>, <&dmac2 0x34>;
resets = <&cpg 518>;
hscif3: serial@e66a0000 {
"renesas,hscif";
reg = <0 0xe66a0000 0 96>;
clocks = <&cpg CPG_MOD 517>,
<&scif_clk>;
dmas = <&dmac0 0x37>, <&dmac0 0x36>;
resets = <&cpg 517>;
hscif4: serial@e66b0000 {
"renesas,hscif";
reg = <0 0xe66b0000 0 96>;
interrupts = <GIC_SPI 146 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 516>,
<&scif_clk>;
dmas = <&dmac0 0x39>, <&dmac0 0x38>;
resets = <&cpg 516>;
compatible = "renesas,usbhs-r8a7795",
"renesas,rcar-gen3-usbhs";
reg = <0 0xe6590000 0 0x200>;
clocks = <&cpg CPG_MOD 704>, <&cpg CPG_MOD 703>;
dmas = <&usb_dmac0 0>, <&usb_dmac0 1>,
<&usb_dmac1 0>, <&usb_dmac1 1>;
dma-names = "ch0", "ch1", "ch2", "ch3";
renesas,buswait = <11>;
phys = <&usb2_phy0 3>;
phy-names = "usb";
resets = <&cpg 704>, <&cpg 703>;
hsusb3: usb@e659c000 {
reg = <0 0xe659c000 0 0x200>;
interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 705>, <&cpg CPG_MOD 700>;
dmas = <&usb_dmac2 0>, <&usb_dmac2 1>,
<&usb_dmac3 0>, <&usb_dmac3 1>;
phys = <&usb2_phy3 3>;
phy-names = "usb";
resets = <&cpg 705>, <&cpg 700>;
usb_dmac0: dma-controller@e65a0000 {
compatible = "renesas,r8a7795-usb-dmac",
"renesas,usb-dmac";
reg = <0 0xe65a0000 0 0x100>;
interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "ch0", "ch1";
clocks = <&cpg CPG_MOD 330>;
resets = <&cpg 330>;
#dma-cells = <1>;
dma-channels = <2>;
usb_dmac1: dma-controller@e65b0000 {
"renesas,usb-dmac";
reg = <0 0xe65b0000 0 0x100>;
interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 331>;
resets = <&cpg 331>;
#dma-cells = <1>;
dma-channels = <2>;
usb_dmac2: dma-controller@e6460000 {
"renesas,usb-dmac";
reg = <0 0xe6460000 0 0x100>;
interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 326>;
resets = <&cpg 326>;
#dma-cells = <1>;
dma-channels = <2>;
usb_dmac3: dma-controller@e6470000 {
"renesas,usb-dmac";
reg = <0 0xe6470000 0 0x100>;
interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>;
#dma-cells = <1>;
dma-channels = <2>;
usb3_phy0: usb-phy@e65ee000 {
compatible = "renesas,r8a7795-usb3-phy",
"renesas,rcar-gen3-usb3-phy";
reg = <0 0xe65ee000 0 0x90>;
clocks = <&cpg CPG_MOD 328>, <&usb3s0_clk>,
<&usb_extal_clk>;
clock-names = "usb3-if", "usb3s_clk", "usb_extal";
resets = <&cpg 328>;
#phy-cells = <0>;
arm_cc630p: crypto@e6601000 {
compatible = "arm,cryptocell-630p-ree";
interrupts = <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>;
reg = <0x0 0xe6601000 0 0x1000>;
clocks = <&cpg CPG_MOD 229>;
resets = <&cpg 229>;
compatible = "renesas,dmac-r8a7795",
reg = <0 0xe6700000 0 0x10000>;
interrupts = <GIC_SPI 199 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 214 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 215 IRQ_TYPE_LEVEL_HIGH>;
"ch12", "ch13", "ch14", "ch15";
#dma-cells = <1>;
dma-channels = <16>;
iommus = <&ipmmu_ds0 0>, <&ipmmu_ds0 1>,
<&ipmmu_ds0 2>, <&ipmmu_ds0 3>,
<&ipmmu_ds0 4>, <&ipmmu_ds0 5>,
<&ipmmu_ds0 6>, <&ipmmu_ds0 7>,
<&ipmmu_ds0 8>, <&ipmmu_ds0 9>,
<&ipmmu_ds0 10>, <&ipmmu_ds0 11>,
<&ipmmu_ds0 12>, <&ipmmu_ds0 13>,
<&ipmmu_ds0 14>, <&ipmmu_ds0 15>;
dmac1: dma-controller@e7300000 {
reg = <0 0xe7300000 0 0x10000>;
<GIC_SPI 318 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 319 IRQ_TYPE_LEVEL_HIGH>;
#dma-cells = <1>;
iommus = <&ipmmu_ds1 0>, <&ipmmu_ds1 1>,
<&ipmmu_ds1 2>, <&ipmmu_ds1 3>,
<&ipmmu_ds1 4>, <&ipmmu_ds1 5>,
<&ipmmu_ds1 6>, <&ipmmu_ds1 7>,
<&ipmmu_ds1 8>, <&ipmmu_ds1 9>,
<&ipmmu_ds1 10>, <&ipmmu_ds1 11>,
<&ipmmu_ds1 12>, <&ipmmu_ds1 13>,
<&ipmmu_ds1 14>, <&ipmmu_ds1 15>;
dmac2: dma-controller@e7310000 {
reg = <0 0xe7310000 0 0x10000>;
interrupts = <GIC_SPI 416 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 417 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 418 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 419 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 420 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 421 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 422 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 423 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 424 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 425 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 426 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 427 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 428 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 429 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 430 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 431 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 397 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 217>;
resets = <&cpg 217>;
#dma-cells = <1>;
iommus = <&ipmmu_ds1 16>, <&ipmmu_ds1 17>,
<&ipmmu_ds1 18>, <&ipmmu_ds1 19>,
<&ipmmu_ds1 20>, <&ipmmu_ds1 21>,
<&ipmmu_ds1 22>, <&ipmmu_ds1 23>,
<&ipmmu_ds1 24>, <&ipmmu_ds1 25>,
<&ipmmu_ds1 26>, <&ipmmu_ds1 27>,
<&ipmmu_ds1 28>, <&ipmmu_ds1 29>,
<&ipmmu_ds1 30>, <&ipmmu_ds1 31>;
ipmmu_ds0: iommu@e6740000 {
renesas,ipmmu-main = <&ipmmu_mm 0>;
#iommu-cells = <1>;
ipmmu_ds1: iommu@e7740000 {
reg = <0 0xe7740000 0 0x1000>;
renesas,ipmmu-main = <&ipmmu_mm 1>;
#iommu-cells = <1>;
ipmmu_hc: iommu@e6570000 {
reg = <0 0xe6570000 0 0x1000>;
renesas,ipmmu-main = <&ipmmu_mm 2>;
#iommu-cells = <1>;
ipmmu_ir: iommu@ff8b0000 {
reg = <0 0xff8b0000 0 0x1000>;
renesas,ipmmu-main = <&ipmmu_mm 3>;
power-domains = <&sysc R8A7795_PD_A3IR>;
#iommu-cells = <1>;
ipmmu_mm: iommu@e67b0000 {
reg = <0 0xe67b0000 0 0x1000>;
interrupts = <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>;
#iommu-cells = <1>;
ipmmu_mp0: iommu@ec670000 {
reg = <0 0xec670000 0 0x1000>;
renesas,ipmmu-main = <&ipmmu_mm 4>;
#iommu-cells = <1>;
ipmmu_pv0: iommu@fd800000 {
reg = <0 0xfd800000 0 0x1000>;
renesas,ipmmu-main = <&ipmmu_mm 6>;
#iommu-cells = <1>;
ipmmu_pv1: iommu@fd950000 {
reg = <0 0xfd950000 0 0x1000>;
#iommu-cells = <1>;
ipmmu_pv2: iommu@fd960000 {
reg = <0 0xfd960000 0 0x1000>;
#iommu-cells = <1>;
ipmmu_pv3: iommu@fd970000 {
reg = <0 0xfd970000 0 0x1000>;
#iommu-cells = <1>;
#iommu-cells = <1>;
ipmmu_vc0: iommu@fe6b0000 {
reg = <0 0xfe6b0000 0 0x1000>;
power-domains = <&sysc R8A7795_PD_A3VC>;
#iommu-cells = <1>;
ipmmu_vc1: iommu@fe6f0000 {
reg = <0 0xfe6f0000 0 0x1000>;
renesas,ipmmu-main = <&ipmmu_mm 13>;
#iommu-cells = <1>;
ipmmu_vi0: iommu@febd0000 {
reg = <0 0xfebd0000 0 0x1000>;
renesas,ipmmu-main = <&ipmmu_mm 14>;
#iommu-cells = <1>;
ipmmu_vi1: iommu@febe0000 {
reg = <0 0xfebe0000 0 0x1000>;
renesas,ipmmu-main = <&ipmmu_mm 15>;
#iommu-cells = <1>;
ipmmu_vp0: iommu@fe990000 {
reg = <0 0xfe990000 0 0x1000>;
renesas,ipmmu-main = <&ipmmu_mm 16>;
#iommu-cells = <1>;
ipmmu_vp1: iommu@fe980000 {
reg = <0 0xfe980000 0 0x1000>;
renesas,ipmmu-main = <&ipmmu_mm 17>;
#iommu-cells = <1>;
compatible = "renesas,etheravb-r8a7795",
"renesas,etheravb-rcar-gen3";
reg = <0 0xe6800000 0 0x800>, <0 0xe6a00000 0 0x10000>;
interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 47 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 63 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "ch0", "ch1", "ch2", "ch3",
"ch12", "ch13", "ch14", "ch15",
"ch16", "ch17", "ch18", "ch19",
"ch20", "ch21", "ch22", "ch23",
"ch24";
phy-mode = "rgmii";
rx-internal-delay-ps = <0>;
tx-internal-delay-ps = <0>;
iommus = <&ipmmu_ds0 16>;
#size-cells = <0>;
can0: can@e6c30000 {
compatible = "renesas,can-r8a7795",
"renesas,rcar-gen3-can";
reg = <0 0xe6c30000 0 0x1000>;
<&cpg CPG_CORE R8A7795_CLK_CANFD>,
<&can_clk>;
assigned-clocks = <&cpg CPG_CORE R8A7795_CLK_CANFD>;
assigned-clock-rates = <40000000>;
can1: can@e6c38000 {
reg = <0 0xe6c38000 0 0x1000>;
<&can_clk>;
canfd: can@e66c0000 {
compatible = "renesas,r8a7795-canfd",
"renesas,rcar-gen3-canfd";
reg = <0 0xe66c0000 0 0x8000>;
interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>,
interrupt-names = "ch_int", "g_int";
clocks = <&cpg CPG_MOD 914>,
<&can_clk>;
clock-names = "fck", "canfd", "can_clk";
resets = <&cpg 914>;
channel0 {
channel1 {
pwm0: pwm@e6e30000 {
compatible = "renesas,pwm-r8a7795", "renesas,pwm-rcar";
reg = <0 0xe6e30000 0 0x8>;
clocks = <&cpg CPG_MOD 523>;
resets = <&cpg 523>;
#pwm-cells = <2>;
pwm1: pwm@e6e31000 {
reg = <0 0xe6e31000 0 0x8>;
#pwm-cells = <2>;
pwm2: pwm@e6e32000 {
reg = <0 0xe6e32000 0 0x8>;
#pwm-cells = <2>;
pwm3: pwm@e6e33000 {
reg = <0 0xe6e33000 0 0x8>;
#pwm-cells = <2>;
pwm4: pwm@e6e34000 {
reg = <0 0xe6e34000 0 0x8>;
#pwm-cells = <2>;
pwm5: pwm@e6e35000 {
reg = <0 0xe6e35000 0 0x8>;
#pwm-cells = <2>;
pwm6: pwm@e6e36000 {
reg = <0 0xe6e36000 0 0x8>;
#pwm-cells = <2>;
compatible = "renesas,scif-r8a7795",
"renesas,rcar-gen3-scif", "renesas,scif";
clocks = <&cpg CPG_MOD 207>,
<&scif_clk>;
dmas = <&dmac1 0x51>, <&dmac1 0x50>,
<&dmac2 0x51>, <&dmac2 0x50>;
clocks = <&cpg CPG_MOD 206>,
<&scif_clk>;
dmas = <&dmac1 0x53>, <&dmac1 0x52>,
<&dmac2 0x53>, <&dmac2 0x52>;
scif2: serial@e6e88000 {
reg = <0 0xe6e88000 0 64>;
interrupts = <GIC_SPI 164 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 310>,
<&scif_clk>;
dmas = <&dmac1 0x13>, <&dmac1 0x12>,
<&dmac2 0x13>, <&dmac2 0x12>;
resets = <&cpg 310>;
scif3: serial@e6c50000 {
clocks = <&cpg CPG_MOD 204>,
<&scif_clk>;
dmas = <&dmac0 0x57>, <&dmac0 0x56>;
scif4: serial@e6c40000 {
interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 203>,
<&scif_clk>;
dmas = <&dmac0 0x59>, <&dmac0 0x58>;
scif5: serial@e6f30000 {
reg = <0 0xe6f30000 0 64>;
interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 202>,
<&scif_clk>;
dmas = <&dmac1 0x5b>, <&dmac1 0x5a>,
<&dmac2 0x5b>, <&dmac2 0x5a>;
tpu: pwm@e6e80000 {
compatible = "renesas,tpu-r8a7795", "renesas,tpu";
reg = <0 0xe6e80000 0 0x148>;
interrupts = <GIC_SPI 135 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 304>;
resets = <&cpg 304>;
#pwm-cells = <3>;
msiof0: spi@e6e90000 {
compatible = "renesas,msiof-r8a7795",
"renesas,rcar-gen3-msiof";
reg = <0 0xe6e90000 0 0x0064>;
interrupts = <GIC_SPI 156 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 211>;
dmas = <&dmac1 0x41>, <&dmac1 0x40>,
<&dmac2 0x41>, <&dmac2 0x40>;
resets = <&cpg 211>;
#size-cells = <0>;
msiof1: spi@e6ea0000 {
reg = <0 0xe6ea0000 0 0x0064>;
interrupts = <GIC_SPI 157 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 210>;
dmas = <&dmac1 0x43>, <&dmac1 0x42>,
<&dmac2 0x43>, <&dmac2 0x42>;
resets = <&cpg 210>;
#size-cells = <0>;
msiof2: spi@e6c00000 {
reg = <0 0xe6c00000 0 0x0064>;
interrupts = <GIC_SPI 158 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 209>;
dmas = <&dmac0 0x45>, <&dmac0 0x44>;
resets = <&cpg 209>;
#size-cells = <0>;
msiof3: spi@e6c10000 {
reg = <0 0xe6c10000 0 0x0064>;
interrupts = <GIC_SPI 159 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 208>;
dmas = <&dmac0 0x47>, <&dmac0 0x46>;
resets = <&cpg 208>;
#size-cells = <0>;
vin0: video@e6ef0000 {
compatible = "renesas,vin-r8a7795";
interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>;
renesas,id = <0>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
vin0csi20: endpoint@0 {
reg = <0>;
remote-endpoint = <&csi20vin0>;
vin0csi40: endpoint@2 {
reg = <2>;
remote-endpoint = <&csi40vin0>;
vin1: video@e6ef1000 {
interrupts = <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH>;
renesas,id = <1>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
vin1csi20: endpoint@0 {
reg = <0>;
remote-endpoint = <&csi20vin1>;
vin1csi40: endpoint@2 {
reg = <2>;
remote-endpoint = <&csi40vin1>;
vin2: video@e6ef2000 {
interrupts = <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>;
renesas,id = <2>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
vin2csi20: endpoint@0 {
reg = <0>;
remote-endpoint = <&csi20vin2>;
vin2csi40: endpoint@2 {
reg = <2>;
remote-endpoint = <&csi40vin2>;
vin3: video@e6ef3000 {
reg = <0 0xe6ef3000 0 0x1000>;
interrupts = <GIC_SPI 191 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 808>;
resets = <&cpg 808>;
renesas,id = <3>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
vin3csi20: endpoint@0 {
reg = <0>;
remote-endpoint = <&csi20vin3>;
vin3csi40: endpoint@2 {
reg = <2>;
remote-endpoint = <&csi40vin3>;
vin4: video@e6ef4000 {
reg = <0 0xe6ef4000 0 0x1000>;
interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 807>;
resets = <&cpg 807>;
renesas,id = <4>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
vin4csi20: endpoint@0 {
reg = <0>;
remote-endpoint = <&csi20vin4>;
vin4csi41: endpoint@3 {
reg = <3>;
remote-endpoint = <&csi41vin4>;
vin5: video@e6ef5000 {
reg = <0 0xe6ef5000 0 0x1000>;
interrupts = <GIC_SPI 175 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 806>;
resets = <&cpg 806>;
renesas,id = <5>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
vin5csi20: endpoint@0 {
reg = <0>;
remote-endpoint = <&csi20vin5>;
vin5csi41: endpoint@3 {
reg = <3>;
remote-endpoint = <&csi41vin5>;
vin6: video@e6ef6000 {
reg = <0 0xe6ef6000 0 0x1000>;
interrupts = <GIC_SPI 176 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 805>;
resets = <&cpg 805>;
renesas,id = <6>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
vin6csi20: endpoint@0 {
reg = <0>;
remote-endpoint = <&csi20vin6>;
vin6csi41: endpoint@3 {
reg = <3>;
remote-endpoint = <&csi41vin6>;
vin7: video@e6ef7000 {
reg = <0 0xe6ef7000 0 0x1000>;
interrupts = <GIC_SPI 171 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 804>;
resets = <&cpg 804>;
renesas,id = <7>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
vin7csi20: endpoint@0 {
reg = <0>;
remote-endpoint = <&csi20vin7>;
vin7csi41: endpoint@3 {
reg = <3>;
remote-endpoint = <&csi41vin7>;
drif00: rif@e6f40000 {
compatible = "renesas,r8a7795-drif",
"renesas,rcar-gen3-drif";
reg = <0 0xe6f40000 0 0x64>;
interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 515>;
dmas = <&dmac1 0x20>, <&dmac2 0x20>;
dma-names = "rx", "rx";
resets = <&cpg 515>;
renesas,bonding = <&drif01>;
drif01: rif@e6f50000 {
reg = <0 0xe6f50000 0 0x64>;
interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 514>;
dmas = <&dmac1 0x22>, <&dmac2 0x22>;
resets = <&cpg 514>;
renesas,bonding = <&drif00>;
drif10: rif@e6f60000 {
reg = <0 0xe6f60000 0 0x64>;
interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 513>;
dmas = <&dmac1 0x24>, <&dmac2 0x24>;
resets = <&cpg 513>;
renesas,bonding = <&drif11>;
drif11: rif@e6f70000 {
reg = <0 0xe6f70000 0 0x64>;
interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 512>;
dmas = <&dmac1 0x26>, <&dmac2 0x26>;
resets = <&cpg 512>;
renesas,bonding = <&drif10>;
drif20: rif@e6f80000 {
reg = <0 0xe6f80000 0 0x64>;
clocks = <&cpg CPG_MOD 511>;
dmas = <&dmac1 0x28>, <&dmac2 0x28>;
resets = <&cpg 511>;
renesas,bonding = <&drif21>;
drif21: rif@e6f90000 {
reg = <0 0xe6f90000 0 0x64>;
clocks = <&cpg CPG_MOD 510>;
dmas = <&dmac1 0x2a>, <&dmac2 0x2a>;
resets = <&cpg 510>;
renesas,bonding = <&drif20>;
drif30: rif@e6fa0000 {
reg = <0 0xe6fa0000 0 0x64>;
interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 509>;
dmas = <&dmac1 0x2c>, <&dmac2 0x2c>;
resets = <&cpg 509>;
renesas,bonding = <&drif31>;
drif31: rif@e6fb0000 {
reg = <0 0xe6fb0000 0 0x64>;
interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 508>;
dmas = <&dmac1 0x2e>, <&dmac2 0x2e>;
resets = <&cpg 508>;
renesas,bonding = <&drif30>;
* #clock-cells is required for audio_clkout0/1/2/3
* clkout : #clock-cells = <0>; <&rcar_sound>;
* clkout0/1/2/3: #clock-cells = <1>; <&rcar_sound N>;
compatible = "renesas,rcar_sound-r8a7795", "renesas,rcar_sound-gen3";
<0 0xec760000 0 0x200>; /* Audio DMAC peri peri*/
<&cpg CPG_MOD 1020>, <&cpg CPG_MOD 1021>,
<&audio_clk_c>,
<&cpg CPG_CORE R8A7795_CLK_S0D4>;
"ssi.1", "ssi.0",
"src.1", "src.0",
"mix.1", "mix.0",
"ctu.1", "ctu.0",
"dvc.0", "dvc.1",
"ssi.1", "ssi.0";
rcar_sound,dvc {
dvc0: dvc-0 {
dmas = <&audma1 0xbc>;
dma-names = "tx";
dvc1: dvc-1 {
dmas = <&audma1 0xbe>;
dma-names = "tx";
rcar_sound,mix {
mix0: mix-0 { };
mix1: mix-1 { };
rcar_sound,ctu {
ctu00: ctu-0 { };
ctu01: ctu-1 { };
ctu02: ctu-2 { };
ctu03: ctu-3 { };
ctu10: ctu-4 { };
ctu11: ctu-5 { };
ctu12: ctu-6 { };
ctu13: ctu-7 { };
rcar_sound,src {
src0: src-0 {
dmas = <&audma0 0x85>, <&audma1 0x9a>;
src1: src-1 {
dmas = <&audma0 0x87>, <&audma1 0x9c>;
src2: src-2 {
dmas = <&audma0 0x89>, <&audma1 0x9e>;
src3: src-3 {
dmas = <&audma0 0x8b>, <&audma1 0xa0>;
src4: src-4 {
dmas = <&audma0 0x8d>, <&audma1 0xb0>;
src5: src-5 {
dmas = <&audma0 0x8f>, <&audma1 0xb2>;
src6: src-6 {
dmas = <&audma0 0x91>, <&audma1 0xb4>;
src7: src-7 {
dmas = <&audma0 0x93>, <&audma1 0xb6>;
src8: src-8 {
dmas = <&audma0 0x95>, <&audma1 0xb8>;
src9: src-9 {
dmas = <&audma0 0x97>, <&audma1 0xba>;
rcar_sound,ssiu {
ssiu00: ssiu-0 {
dmas = <&audma0 0x15>, <&audma1 0x16>;
ssiu01: ssiu-1 {
dmas = <&audma0 0x35>, <&audma1 0x36>;
ssiu02: ssiu-2 {
dmas = <&audma0 0x37>, <&audma1 0x38>;
ssiu03: ssiu-3 {
dmas = <&audma0 0x47>, <&audma1 0x48>;
ssiu04: ssiu-4 {
dmas = <&audma0 0x3F>, <&audma1 0x40>;
ssiu05: ssiu-5 {
dmas = <&audma0 0x43>, <&audma1 0x44>;
ssiu06: ssiu-6 {
dmas = <&audma0 0x4F>, <&audma1 0x50>;
ssiu07: ssiu-7 {
dmas = <&audma0 0x53>, <&audma1 0x54>;
ssiu10: ssiu-8 {
dmas = <&audma0 0x49>, <&audma1 0x4a>;
ssiu11: ssiu-9 {
dmas = <&audma0 0x4B>, <&audma1 0x4C>;
ssiu12: ssiu-10 {
dmas = <&audma0 0x57>, <&audma1 0x58>;
ssiu13: ssiu-11 {
dmas = <&audma0 0x59>, <&audma1 0x5A>;
ssiu14: ssiu-12 {
dmas = <&audma0 0x5F>, <&audma1 0x60>;
ssiu15: ssiu-13 {
dmas = <&audma0 0xC3>, <&audma1 0xC4>;
ssiu16: ssiu-14 {
dmas = <&audma0 0xC7>, <&audma1 0xC8>;
ssiu17: ssiu-15 {
dmas = <&audma0 0xCB>, <&audma1 0xCC>;
ssiu20: ssiu-16 {
dmas = <&audma0 0x63>, <&audma1 0x64>;
ssiu21: ssiu-17 {
dmas = <&audma0 0x67>, <&audma1 0x68>;
ssiu22: ssiu-18 {
dmas = <&audma0 0x6B>, <&audma1 0x6C>;
ssiu23: ssiu-19 {
dmas = <&audma0 0x6D>, <&audma1 0x6E>;
ssiu24: ssiu-20 {
dmas = <&audma0 0xCF>, <&audma1 0xCE>;
ssiu25: ssiu-21 {
dmas = <&audma0 0xEB>, <&audma1 0xEC>;
ssiu26: ssiu-22 {
dmas = <&audma0 0xED>, <&audma1 0xEE>;
ssiu27: ssiu-23 {
dmas = <&audma0 0xEF>, <&audma1 0xF0>;
ssiu30: ssiu-24 {
dmas = <&audma0 0x6f>, <&audma1 0x70>;
ssiu31: ssiu-25 {
dmas = <&audma0 0x21>, <&audma1 0x22>;
ssiu32: ssiu-26 {
dmas = <&audma0 0x23>, <&audma1 0x24>;
ssiu33: ssiu-27 {
dmas = <&audma0 0x25>, <&audma1 0x26>;
ssiu34: ssiu-28 {
dmas = <&audma0 0x27>, <&audma1 0x28>;
ssiu35: ssiu-29 {
dmas = <&audma0 0x29>, <&audma1 0x2A>;
ssiu36: ssiu-30 {
dmas = <&audma0 0x2B>, <&audma1 0x2C>;
ssiu37: ssiu-31 {
dmas = <&audma0 0x2D>, <&audma1 0x2E>;
dma-names = "rx", "tx";
ssiu40: ssiu-32 {
dmas = <&audma0 0x71>, <&audma1 0x72>;
ssiu41: ssiu-33 {
dmas = <&audma0 0x17>, <&audma1 0x18>;
ssiu42: ssiu-34 {
dmas = <&audma0 0x19>, <&audma1 0x1A>;
ssiu43: ssiu-35 {
dmas = <&audma0 0x1B>, <&audma1 0x1C>;
ssiu44: ssiu-36 {
dmas = <&audma0 0x1D>, <&audma1 0x1E>;
ssiu45: ssiu-37 {
dmas = <&audma0 0x1F>, <&audma1 0x20>;
ssiu46: ssiu-38 {
dmas = <&audma0 0x31>, <&audma1 0x32>;
ssiu47: ssiu-39 {
dmas = <&audma0 0x33>, <&audma1 0x34>;
ssiu50: ssiu-40 {
dmas = <&audma0 0x73>, <&audma1 0x74>;
ssiu60: ssiu-41 {
dmas = <&audma0 0x75>, <&audma1 0x76>;
ssiu70: ssiu-42 {
dmas = <&audma0 0x79>, <&audma1 0x7a>;
ssiu80: ssiu-43 {
dmas = <&audma0 0x7b>, <&audma1 0x7c>;
ssiu90: ssiu-44 {
dmas = <&audma0 0x7d>, <&audma1 0x7e>;
ssiu91: ssiu-45 {
dmas = <&audma0 0x7F>, <&audma1 0x80>;
ssiu92: ssiu-46 {
dmas = <&audma0 0x81>, <&audma1 0x82>;
ssiu93: ssiu-47 {
dmas = <&audma0 0x83>, <&audma1 0x84>;
ssiu94: ssiu-48 {
dmas = <&audma0 0xA3>, <&audma1 0xA4>;
ssiu95: ssiu-49 {
dmas = <&audma0 0xA5>, <&audma1 0xA6>;
ssiu96: ssiu-50 {
dmas = <&audma0 0xA7>, <&audma1 0xA8>;
ssiu97: ssiu-51 {
dmas = <&audma0 0xA9>, <&audma1 0xAA>;
rcar_sound,ssi {
ssi0: ssi-0 {
interrupts = <GIC_SPI 370 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x01>, <&audma1 0x02>;
ssi1: ssi-1 {
interrupts = <GIC_SPI 371 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x03>, <&audma1 0x04>;
ssi2: ssi-2 {
interrupts = <GIC_SPI 372 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x05>, <&audma1 0x06>;
ssi3: ssi-3 {
interrupts = <GIC_SPI 373 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x07>, <&audma1 0x08>;
ssi4: ssi-4 {
interrupts = <GIC_SPI 374 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x09>, <&audma1 0x0a>;
ssi5: ssi-5 {
interrupts = <GIC_SPI 375 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x0b>, <&audma1 0x0c>;
ssi6: ssi-6 {
interrupts = <GIC_SPI 376 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x0d>, <&audma1 0x0e>;
ssi7: ssi-7 {
interrupts = <GIC_SPI 377 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x0f>, <&audma1 0x10>;
ssi8: ssi-8 {
interrupts = <GIC_SPI 378 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x11>, <&audma1 0x12>;
ssi9: ssi-9 {
interrupts = <GIC_SPI 379 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&audma0 0x13>, <&audma1 0x14>;
mlp: mlp@ec520000 {
compatible = "renesas,r8a7795-mlp",
"renesas,rcar-gen3-mlp";
reg = <0 0xec520000 0 0x800>;
interrupts = <GIC_SPI 384 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 385 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 802>;
resets = <&cpg 802>;
audma0: dma-controller@ec700000 {
"renesas,rcar-dmac";
reg = <0 0xec700000 0 0x10000>;
interrupts = <GIC_SPI 350 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 320 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 321 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 322 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 323 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 324 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 325 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 326 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 327 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 328 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 329 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 330 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 331 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 332 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 333 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 334 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 335 IRQ_TYPE_LEVEL_HIGH>;
"ch4", "ch5", "ch6", "ch7",
"ch8", "ch9", "ch10", "ch11",
clocks = <&cpg CPG_MOD 502>;
resets = <&cpg 502>;
#dma-cells = <1>;
iommus = <&ipmmu_mp0 0>, <&ipmmu_mp0 1>,
<&ipmmu_mp0 2>, <&ipmmu_mp0 3>,
<&ipmmu_mp0 4>, <&ipmmu_mp0 5>,
<&ipmmu_mp0 6>, <&ipmmu_mp0 7>,
<&ipmmu_mp0 8>, <&ipmmu_mp0 9>,
<&ipmmu_mp0 10>, <&ipmmu_mp0 11>,
<&ipmmu_mp0 12>, <&ipmmu_mp0 13>,
<&ipmmu_mp0 14>, <&ipmmu_mp0 15>;
audma1: dma-controller@ec720000 {
reg = <0 0xec720000 0 0x10000>;
interrupts = <GIC_SPI 351 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 336 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 337 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 338 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 339 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 340 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 341 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 342 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 343 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 344 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 345 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 346 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 347 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 348 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 349 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 382 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 383 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 501>;
resets = <&cpg 501>;
#dma-cells = <1>;
iommus = <&ipmmu_mp0 16>, <&ipmmu_mp0 17>,
<&ipmmu_mp0 18>, <&ipmmu_mp0 19>,
<&ipmmu_mp0 20>, <&ipmmu_mp0 21>,
<&ipmmu_mp0 22>, <&ipmmu_mp0 23>,
<&ipmmu_mp0 24>, <&ipmmu_mp0 25>,
<&ipmmu_mp0 26>, <&ipmmu_mp0 27>,
<&ipmmu_mp0 28>, <&ipmmu_mp0 29>,
<&ipmmu_mp0 30>, <&ipmmu_mp0 31>;
xhci0: usb@ee000000 {
reg = <0 0xee000000 0 0xc00>;
interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 328>;
usb3_peri0: usb@ee020000 {
compatible = "renesas,r8a7795-usb3-peri",
"renesas,rcar-gen3-usb3-peri";
reg = <0 0xee020000 0 0x400>;
interrupts = <GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH>;
ohci0: usb@ee080000 {
compatible = "generic-ohci";
reg = <0 0xee080000 0 0x100>;
interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>;
phys = <&usb2_phy0 1>;
phy-names = "usb";
resets = <&cpg 703>, <&cpg 704>;
ohci1: usb@ee0a0000 {
reg = <0 0xee0a0000 0 0x100>;
interrupts = <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 702>;
phys = <&usb2_phy1 1>;
phy-names = "usb";
resets = <&cpg 702>;
ohci2: usb@ee0c0000 {
reg = <0 0xee0c0000 0 0x100>;
clocks = <&cpg CPG_MOD 701>;
phys = <&usb2_phy2 1>;
phy-names = "usb";
resets = <&cpg 701>;
ohci3: usb@ee0e0000 {
reg = <0 0xee0e0000 0 0x100>;
interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 700>, <&cpg CPG_MOD 705>;
phys = <&usb2_phy3 1>;
phy-names = "usb";
resets = <&cpg 700>, <&cpg 705>;
ehci0: usb@ee080100 {
compatible = "generic-ehci";
reg = <0 0xee080100 0 0x100>;
phys = <&usb2_phy0 2>;
phy-names = "usb";
companion = <&ohci0>;
ehci1: usb@ee0a0100 {
reg = <0 0xee0a0100 0 0x100>;
phys = <&usb2_phy1 2>;
phy-names = "usb";
companion = <&ohci1>;
ehci2: usb@ee0c0100 {
reg = <0 0xee0c0100 0 0x100>;
phys = <&usb2_phy2 2>;
phy-names = "usb";
companion = <&ohci2>;
ehci3: usb@ee0e0100 {
reg = <0 0xee0e0100 0 0x100>;
phys = <&usb2_phy3 2>;
phy-names = "usb";
companion = <&ohci3>;
usb2_phy0: usb-phy@ee080200 {
compatible = "renesas,usb2-phy-r8a7795",
"renesas,rcar-gen3-usb2-phy";
reg = <0 0xee080200 0 0x700>;
#phy-cells = <1>;
usb2_phy1: usb-phy@ee0a0200 {
reg = <0 0xee0a0200 0 0x700>;
#phy-cells = <1>;
usb2_phy2: usb-phy@ee0c0200 {
reg = <0 0xee0c0200 0 0x700>;
#phy-cells = <1>;
usb2_phy3: usb-phy@ee0e0200 {
reg = <0 0xee0e0200 0 0x700>;
#phy-cells = <1>;
sdhi0: mmc@ee100000 {
compatible = "renesas,sdhi-r8a7795",
"renesas,rcar-gen3-sdhi";
reg = <0 0xee100000 0 0x2000>;
interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 314>, <&cpg CPG_CORE R8A7795_CLK_SD0H>;
clock-names = "core", "clkh";
max-frequency = <200000000>;
resets = <&cpg 314>;
iommus = <&ipmmu_ds1 32>;
sdhi1: mmc@ee120000 {
reg = <0 0xee120000 0 0x2000>;
interrupts = <GIC_SPI 166 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 313>, <&cpg CPG_CORE R8A7795_CLK_SD1H>;
resets = <&cpg 313>;
iommus = <&ipmmu_ds1 33>;
sdhi2: mmc@ee140000 {
reg = <0 0xee140000 0 0x2000>;
interrupts = <GIC_SPI 167 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 312>, <&cpg CPG_CORE R8A7795_CLK_SD2H>;
resets = <&cpg 312>;
iommus = <&ipmmu_ds1 34>;
sdhi3: mmc@ee160000 {
reg = <0 0xee160000 0 0x2000>;
interrupts = <GIC_SPI 168 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 311>, <&cpg CPG_CORE R8A7795_CLK_SD3H>;
resets = <&cpg 311>;
iommus = <&ipmmu_ds1 35>;
rpc: spi@ee200000 {
compatible = "renesas,r8a7795-rpc-if",
"renesas,rcar-gen3-rpc-if";
reg = <0 0xee200000 0 0x200>,
<0 0x08000000 0 0x04000000>,
<0 0xee208000 0 0x100>;
reg-names = "regs", "dirmap", "wbuf";
interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
sata: sata@ee300000 {
compatible = "renesas,sata-r8a7795",
"renesas,rcar-gen3-sata";
reg = <0 0xee300000 0 0x200000>;
interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 815>;
resets = <&cpg 815>;
iommus = <&ipmmu_hc 2>;
gic: interrupt-controller@f1010000 {
compatible = "arm,gic-400";
#interrupt-cells = <3>;
#address-cells = <0>;
reg = <0x0 0xf1010000 0 0x1000>,
<0x0 0xf1020000 0 0x20000>,
<0x0 0xf1040000 0 0x20000>,
<0x0 0xf1060000 0 0x20000>;
interrupts = <GIC_PPI 9
(GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_HIGH)>;
clocks = <&cpg CPG_MOD 408>;
clock-names = "clk";
resets = <&cpg 408>;
pciec0: pcie@fe000000 {
compatible = "renesas,pcie-r8a7795",
"renesas,pcie-rcar-gen3";
reg = <0 0xfe000000 0 0x80000>;
#address-cells = <3>;
#size-cells = <2>;
bus-range = <0x00 0xff>;
device_type = "pci";
ranges = <0x01000000 0 0x00000000 0 0xfe100000 0 0x00100000>,
<0x02000000 0 0xfe200000 0 0xfe200000 0 0x00200000>,
<0x02000000 0 0x30000000 0 0x30000000 0 0x08000000>,
<0x42000000 0 0x38000000 0 0x38000000 0 0x08000000>;
/* Map all possible DDR/IOMMU as inbound ranges */
dma-ranges = <0x42000000 0 0x00000000 0 0x00000000 1 0x00000000>;
interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>;
#interrupt-cells = <1>;
interrupt-map-mask = <0 0 0 0>;
interrupt-map = <0 0 0 0 &gic GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 319>, <&pcie_bus_clk>;
clock-names = "pcie", "pcie_bus";
resets = <&cpg 319>;
iommu-map = <0 &ipmmu_hc 0 1>;
iommu-map-mask = <0>;
pciec1: pcie@ee800000 {
reg = <0 0xee800000 0 0x80000>;
#size-cells = <2>;
ranges = <0x01000000 0 0x00000000 0 0xee900000 0 0x00100000>,
<0x02000000 0 0xeea00000 0 0xeea00000 0 0x00200000>,
<0x02000000 0 0xc0000000 0 0xc0000000 0 0x08000000>,
<0x42000000 0 0xc8000000 0 0xc8000000 0 0x08000000>;
interrupts = <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 149 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 150 IRQ_TYPE_LEVEL_HIGH>;
interrupt-map = <0 0 0 0 &gic GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 318>, <&pcie_bus_clk>;
resets = <&cpg 318>;
iommu-map = <0 &ipmmu_hc 1 1>;
pciec0_ep: pcie-ep@fe000000 {
compatible = "renesas,r8a7795-pcie-ep",
"renesas,rcar-gen3-pcie-ep";
reg = <0x0 0xfe000000 0 0x80000>,
<0x0 0xfe100000 0 0x100000>,
<0x0 0xfe200000 0 0x200000>,
<0x0 0x30000000 0 0x8000000>,
<0x0 0x38000000 0 0x8000000>;
reg-names = "apb-base", "memory0", "memory1", "memory2", "memory3";
clocks = <&cpg CPG_MOD 319>;
clock-names = "pcie";
pciec1_ep: pcie-ep@ee800000 {
reg = <0x0 0xee800000 0 0x80000>,
<0x0 0xee900000 0 0x100000>,
<0x0 0xeea00000 0 0x200000>,
<0x0 0xc0000000 0 0x8000000>,
<0x0 0xc8000000 0 0x8000000>;
clocks = <&cpg CPG_MOD 318>;
imr-lx4@fe860000 {
compatible = "renesas,r8a7795-imr-lx4",
"renesas,imr-lx4";
reg = <0 0xfe860000 0 0x2000>;
interrupts = <GIC_SPI 192 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 823>;
resets = <&cpg 823>;
imr-lx4@fe870000 {
"renesas,imr-lx4";
reg = <0 0xfe870000 0 0x2000>;
interrupts = <GIC_SPI 193 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 822>;
resets = <&cpg 822>;
imr-lx4@fe880000 {
"renesas,imr-lx4";
reg = <0 0xfe880000 0 0x2000>;
interrupts = <GIC_SPI 194 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 821>;
resets = <&cpg 821>;
imr-lx4@fe890000 {
"renesas,imr-lx4";
reg = <0 0xfe890000 0 0x2000>;
interrupts = <GIC_SPI 195 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 820>;
resets = <&cpg 820>;
vspbc: vsp@fe920000 {
reg = <0 0xfe920000 0 0x8000>;
interrupts = <GIC_SPI 465 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 624>;
resets = <&cpg 624>;
renesas,fcp = <&fcpvb1>;
vspbd: vsp@fe960000 {
reg = <0 0xfe960000 0 0x8000>;
interrupts = <GIC_SPI 266 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 626>;
resets = <&cpg 626>;
renesas,fcp = <&fcpvb0>;
vspd0: vsp@fea20000 {
reg = <0 0xfea20000 0 0x5000>;
interrupts = <GIC_SPI 466 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 623>;
resets = <&cpg 623>;
renesas,fcp = <&fcpvd0>;
vspd1: vsp@fea28000 {
reg = <0 0xfea28000 0 0x5000>;
interrupts = <GIC_SPI 467 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 622>;
resets = <&cpg 622>;
renesas,fcp = <&fcpvd1>;
vspd2: vsp@fea30000 {
reg = <0 0xfea30000 0 0x5000>;
interrupts = <GIC_SPI 468 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 621>;
resets = <&cpg 621>;
renesas,fcp = <&fcpvd2>;
vspi0: vsp@fe9a0000 {
reg = <0 0xfe9a0000 0 0x8000>;
interrupts = <GIC_SPI 444 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 631>;
resets = <&cpg 631>;
renesas,fcp = <&fcpvi0>;
vspi1: vsp@fe9b0000 {
reg = <0 0xfe9b0000 0 0x8000>;
interrupts = <GIC_SPI 445 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 630>;
resets = <&cpg 630>;
renesas,fcp = <&fcpvi1>;
fdp1@fe940000 {
reg = <0 0xfe940000 0 0x2400>;
interrupts = <GIC_SPI 262 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 119>;
resets = <&cpg 119>;
renesas,fcp = <&fcpf0>;
fdp1@fe944000 {
reg = <0 0xfe944000 0 0x2400>;
interrupts = <GIC_SPI 263 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 118>;
resets = <&cpg 118>;
renesas,fcp = <&fcpf1>;
fcpf0: fcp@fe950000 {
reg = <0 0xfe950000 0 0x200>;
clocks = <&cpg CPG_MOD 615>;
resets = <&cpg 615>;
iommus = <&ipmmu_vp0 0>;
fcpf1: fcp@fe951000 {
reg = <0 0xfe951000 0 0x200>;
clocks = <&cpg CPG_MOD 614>;
resets = <&cpg 614>;
iommus = <&ipmmu_vp1 1>;
fcpvb0: fcp@fe96f000 {
reg = <0 0xfe96f000 0 0x200>;
clocks = <&cpg CPG_MOD 607>;
resets = <&cpg 607>;
iommus = <&ipmmu_vp0 5>;
fcpvb1: fcp@fe92f000 {
reg = <0 0xfe92f000 0 0x200>;
clocks = <&cpg CPG_MOD 606>;
resets = <&cpg 606>;
iommus = <&ipmmu_vp1 7>;
fcpvi0: fcp@fe9af000 {
reg = <0 0xfe9af000 0 0x200>;
clocks = <&cpg CPG_MOD 611>;
resets = <&cpg 611>;
iommus = <&ipmmu_vp0 8>;
fcpvi1: fcp@fe9bf000 {
reg = <0 0xfe9bf000 0 0x200>;
clocks = <&cpg CPG_MOD 610>;
resets = <&cpg 610>;
iommus = <&ipmmu_vp1 9>;
fcpvd0: fcp@fea27000 {
reg = <0 0xfea27000 0 0x200>;
clocks = <&cpg CPG_MOD 603>;
resets = <&cpg 603>;
iommus = <&ipmmu_vi0 8>;
fcpvd1: fcp@fea2f000 {
reg = <0 0xfea2f000 0 0x200>;
clocks = <&cpg CPG_MOD 602>;
resets = <&cpg 602>;
iommus = <&ipmmu_vi0 9>;
fcpvd2: fcp@fea37000 {
reg = <0 0xfea37000 0 0x200>;
clocks = <&cpg CPG_MOD 601>;
resets = <&cpg 601>;
iommus = <&ipmmu_vi1 10>;
cmm0: cmm@fea40000 {
compatible = "renesas,r8a7795-cmm",
"renesas,rcar-gen3-cmm";
reg = <0 0xfea40000 0 0x1000>;
clocks = <&cpg CPG_MOD 711>;
resets = <&cpg 711>;
cmm1: cmm@fea50000 {
reg = <0 0xfea50000 0 0x1000>;
clocks = <&cpg CPG_MOD 710>;
resets = <&cpg 710>;
cmm2: cmm@fea60000 {
reg = <0 0xfea60000 0 0x1000>;
clocks = <&cpg CPG_MOD 709>;
resets = <&cpg 709>;
cmm3: cmm@fea70000 {
reg = <0 0xfea70000 0 0x1000>;
clocks = <&cpg CPG_MOD 708>;
resets = <&cpg 708>;
csi20: csi2@fea80000 {
reg = <0 0xfea80000 0 0x10000>;
clocks = <&cpg CPG_MOD 714>;
status = "disabled";
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
csi20vin0: endpoint@0 {
reg = <0>;
remote-endpoint = <&vin0csi20>;
csi20vin1: endpoint@1 {
reg = <1>;
remote-endpoint = <&vin1csi20>;
csi20vin2: endpoint@2 {
reg = <2>;
remote-endpoint = <&vin2csi20>;
csi20vin3: endpoint@3 {
reg = <3>;
remote-endpoint = <&vin3csi20>;
csi20vin4: endpoint@4 {
reg = <4>;
remote-endpoint = <&vin4csi20>;
csi20vin5: endpoint@5 {
reg = <5>;
remote-endpoint = <&vin5csi20>;
csi20vin6: endpoint@6 {
reg = <6>;
remote-endpoint = <&vin6csi20>;
csi20vin7: endpoint@7 {
reg = <7>;
remote-endpoint = <&vin7csi20>;
csi40: csi2@feaa0000 {
reg = <0 0xfeaa0000 0 0x10000>;
interrupts = <GIC_SPI 246 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 716>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
csi40vin0: endpoint@0 {
reg = <0>;
remote-endpoint = <&vin0csi40>;
csi40vin1: endpoint@1 {
reg = <1>;
remote-endpoint = <&vin1csi40>;
csi40vin2: endpoint@2 {
reg = <2>;
remote-endpoint = <&vin2csi40>;
csi40vin3: endpoint@3 {
reg = <3>;
remote-endpoint = <&vin3csi40>;
csi41: csi2@feab0000 {
reg = <0 0xfeab0000 0 0x10000>;
interrupts = <GIC_SPI 247 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 715>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
csi41vin4: endpoint@0 {
reg = <0>;
remote-endpoint = <&vin4csi41>;
csi41vin5: endpoint@1 {
reg = <1>;
remote-endpoint = <&vin5csi41>;
csi41vin6: endpoint@2 {
reg = <2>;
remote-endpoint = <&vin6csi41>;
csi41vin7: endpoint@3 {
reg = <3>;
remote-endpoint = <&vin7csi41>;
hdmi0: hdmi@fead0000 {
compatible = "renesas,r8a7795-hdmi", "renesas,rcar-gen3-hdmi";
reg = <0 0xfead0000 0 0x10000>;
interrupts = <GIC_SPI 389 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 729>, <&cpg CPG_CORE R8A7795_CLK_HDMI>;
clock-names = "iahb", "isfr";
resets = <&cpg 729>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
dw_hdmi0_in: endpoint {
remote-endpoint = <&du_out_hdmi0>;
port@1 {
reg = <1>;
port@2 {
/* HDMI sound */
reg = <2>;
hdmi1: hdmi@feae0000 {
reg = <0 0xfeae0000 0 0x10000>;
interrupts = <GIC_SPI 436 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 728>, <&cpg CPG_CORE R8A7795_CLK_HDMI>;
resets = <&cpg 728>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
dw_hdmi1_in: endpoint {
remote-endpoint = <&du_out_hdmi1>;
port@1 {
reg = <1>;
port@2 {
/* HDMI sound */
reg = <2>;
du: display@feb00000 {
compatible = "renesas,du-r8a7795";
reg = <0 0xfeb00000 0 0x80000>;
interrupts = <GIC_SPI 256 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 268 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 269 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 270 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 724>, <&cpg CPG_MOD 723>,
<&cpg CPG_MOD 722>, <&cpg CPG_MOD 721>;
clock-names = "du.0", "du.1", "du.2", "du.3";
resets = <&cpg 724>, <&cpg 722>;
reset-names = "du.0", "du.2";
renesas,cmms = <&cmm0>, <&cmm1>, <&cmm2>, <&cmm3>;
<&vspd0 1>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port@1 {
reg = <1>;
du_out_hdmi0: endpoint {
remote-endpoint = <&dw_hdmi0_in>;
port@2 {
reg = <2>;
du_out_hdmi1: endpoint {
remote-endpoint = <&dw_hdmi1_in>;
port@3 {
reg = <3>;
du_out_lvds0: endpoint {
remote-endpoint = <&lvds0_in>;
lvds0: lvds@feb90000 {
compatible = "renesas,r8a7795-lvds";
reg = <0 0xfeb90000 0 0x14>;
clocks = <&cpg CPG_MOD 727>;
resets = <&cpg 727>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
lvds0_in: endpoint {
remote-endpoint = <&du_out_lvds0>;
port@1 {
reg = <1>;
prr: chipid@fff00044 {
compatible = "renesas,prr";
reg = <0 0xfff00044 0 4>;
thermal-zones {
sensor1_thermal: sensor1-thermal {
polling-delay-passive = <250>;
polling-delay = <1000>;
thermal-sensors = <&tsc 0>;
sustainable-power = <6313>;
trips {
sensor1_crit: sensor1-crit {
temperature = <120000>;
hysteresis = <1000>;
type = "critical";
sensor2_thermal: sensor2-thermal {
thermal-sensors = <&tsc 1>;
trips {
sensor2_crit: sensor2-crit {
type = "critical";
sensor3_thermal: sensor3-thermal {
thermal-sensors = <&tsc 2>;
trips {
target: trip-point1 {
temperature = <100000>;
type = "passive";
sensor3_crit: sensor3-crit {
type = "critical";
cooling-maps {
map0 {
trip = <&target>;
cooling-device = <&a57_0 2 4>;
contribution = <1024>;
map1 {
trip = <&target>;
cooling-device = <&a53_0 0 2>;
timer {
compatible = "arm,armv8-timer";
interrupts-extended = <&gic GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_LOW)>,
<&gic GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_LOW)>,
<&gic GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_LOW)>,
<&gic GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_LOW)>;
/* External USB clocks - can be overridden by the board */
usb3s0_clk: usb3s0 {
#clock-cells = <0>;
clock-frequency = <0>;
usb_extal_clk: usb_extal {
#clock-cells = <0>;
-}; diff --git a/arch/arm/dts/r8a77960-salvator-x.dts b/arch/arm/dts/r8a77960-salvator-x.dts deleted file mode 100644 index d5543f26c47..00000000000 --- a/arch/arm/dts/r8a77960-salvator-x.dts +++ /dev/null @@ -1,37 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Device Tree Source for the Salvator-X board with R-Car M3-W
-/dts-v1/; -#include "r8a77960.dtsi" -#include "salvator-x.dtsi"
model = "Renesas Salvator-X board based on r8a77960";
compatible = "renesas,salvator-x", "renesas,r8a7796";
memory@48000000 {
device_type = "memory";
reg = <0x0 0x48000000 0x0 0x78000000>;
memory@600000000 {
reg = <0x6 0x00000000 0x0 0x80000000>;
-&du {
<&cpg CPG_MOD 723>,
<&cpg CPG_MOD 722>,
<&versaclock5 1>,
<&x21_clk>,
<&versaclock5 2>;
"dclkin.0", "dclkin.1", "dclkin.2";
-}; diff --git a/arch/arm/dts/r8a77960-ulcb.dts b/arch/arm/dts/r8a77960-ulcb.dts deleted file mode 100644 index 4bfeb1df048..00000000000 --- a/arch/arm/dts/r8a77960-ulcb.dts +++ /dev/null @@ -1,38 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Device Tree Source for the M3ULCB (R-Car Starter Kit Pro) board with R-Car M3-W
- Copyright (C) 2016 Cogent Embedded, Inc.
-/dts-v1/; -#include "r8a77960.dtsi" -#include "ulcb.dtsi"
model = "Renesas M3ULCB board based on r8a77960";
compatible = "renesas,m3ulcb", "renesas,r8a7796";
memory@48000000 {
memory@600000000 {
-&du {
<&cpg CPG_MOD 723>,
<&cpg CPG_MOD 722>,
<&versaclock5 1>,
<&versaclock5 3>,
<&versaclock5 2>;
-}; diff --git a/arch/arm/dts/r8a77960.dtsi b/arch/arm/dts/r8a77960.dtsi deleted file mode 100644 index 17062ec506b..00000000000 --- a/arch/arm/dts/r8a77960.dtsi +++ /dev/null @@ -1,3080 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Device Tree Source for the R-Car M3-W (R8A77960) SoC
- Copyright (C) 2016-2017 Renesas Electronics Corp.
-#include <dt-bindings/clock/r8a7796-cpg-mssr.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/power/r8a7796-sysc.h>
-#define CPG_AUDIO_CLK_I R8A7796_CLK_S0D4
compatible = "renesas,r8a7796";
#size-cells = <2>;
* The external audio clocks are configured as 0 Hz fixed frequency
* clocks by default.
* Boards that provide audio clocks should override them.
audio_clk_a: audio_clk_a {
#clock-cells = <0>;
audio_clk_b: audio_clk_b {
#clock-cells = <0>;
audio_clk_c: audio_clk_c {
#clock-cells = <0>;
can_clk: can {
#clock-cells = <0>;
opp-shared;
opp-500000000 {
opp-1000000000 {
opp-1500000000 {
opp-suspend;
opp-1600000000 {
opp-1700000000 {
opp-1800000000 {
opp-hz = /bits/ 64 <1800000000>;
turbo-mode;
opp-shared;
opp-800000000 {
opp-1000000000 {
opp-1200000000 {
opp-1300000000 {
opp-hz = /bits/ 64 <1300000000>;
turbo-mode;
cpus {
#size-cells = <0>;
cpu-map {
cluster0 {
core0 {
cpu = <&a57_0>;
core1 {
cpu = <&a57_1>;
cluster1 {
core0 {
cpu = <&a53_0>;
core1 {
cpu = <&a53_1>;
core2 {
cpu = <&a53_2>;
core3 {
cpu = <&a53_3>;
a57_0: cpu@0 {
reg = <0x0>;
device_type = "cpu";
power-domains = <&sysc R8A7796_PD_CA57_CPU0>;
clocks = <&cpg CPG_CORE R8A7796_CLK_Z>;
a57_1: cpu@1 {
reg = <0x1>;
power-domains = <&sysc R8A7796_PD_CA57_CPU1>;
a53_0: cpu@100 {
reg = <0x100>;
power-domains = <&sysc R8A7796_PD_CA53_CPU0>;
clocks = <&cpg CPG_CORE R8A7796_CLK_Z2>;
a53_1: cpu@101 {
reg = <0x101>;
power-domains = <&sysc R8A7796_PD_CA53_CPU1>;
a53_2: cpu@102 {
reg = <0x102>;
power-domains = <&sysc R8A7796_PD_CA53_CPU2>;
a53_3: cpu@103 {
reg = <0x103>;
power-domains = <&sysc R8A7796_PD_CA53_CPU3>;
compatible = "cache";
power-domains = <&sysc R8A7796_PD_CA57_SCU>;
cache-unified;
cache-level = <2>;
power-domains = <&sysc R8A7796_PD_CA53_SCU>;
cache-unified;
cache-level = <2>;
idle-states {
local-timer-stop;
local-timer-stop;
extal_clk: extal {
#clock-cells = <0>;
#clock-cells = <0>;
#clock-cells = <0>;
pmu_a53 {
interrupt-affinity = <&a53_0>, <&a53_1>, <&a53_2>, <&a53_3>;
pmu_a57 {
<&gic GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>;
interrupt-affinity = <&a57_0>, <&a57_1>;
psci {
method = "smc";
scif_clk: scif {
#clock-cells = <0>;
soc {
compatible = "simple-bus";
interrupt-parent = <&gic>;
#size-cells = <2>;
ranges;
rwdt: watchdog@e6020000 {
compatible = "renesas,r8a7796-wdt",
reg = <0 0xe6020000 0 0x0c>;
interrupts = <GIC_SPI 140 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 402>;
power-domains = <&sysc R8A7796_PD_ALWAYS_ON>;
resets = <&cpg 402>;
gpio0: gpio@e6050000 {
compatible = "renesas,gpio-r8a7796",
reg = <0 0xe6050000 0 0x50>;
interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
#interrupt-cells = <2>;
interrupt-controller;
clocks = <&cpg CPG_MOD 912>;
resets = <&cpg 912>;
gpio1: gpio@e6051000 {
reg = <0 0xe6051000 0 0x50>;
interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
clocks = <&cpg CPG_MOD 911>;
resets = <&cpg 911>;
gpio2: gpio@e6052000 {
reg = <0 0xe6052000 0 0x50>;
interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
clocks = <&cpg CPG_MOD 910>;
resets = <&cpg 910>;
gpio3: gpio@e6053000 {
reg = <0 0xe6053000 0 0x50>;
interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
clocks = <&cpg CPG_MOD 909>;
resets = <&cpg 909>;
gpio4: gpio@e6054000 {
reg = <0 0xe6054000 0 0x50>;
interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
clocks = <&cpg CPG_MOD 908>;
resets = <&cpg 908>;
gpio5: gpio@e6055000 {
reg = <0 0xe6055000 0 0x50>;
interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
clocks = <&cpg CPG_MOD 907>;
resets = <&cpg 907>;
gpio6: gpio@e6055400 {
reg = <0 0xe6055400 0 0x50>;
interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
clocks = <&cpg CPG_MOD 905>;
resets = <&cpg 905>;
pfc: pinctrl@e6060000 {
compatible = "renesas,pfc-r8a7796";
compatible = "renesas,r8a7796-cmt0",
interrupts = <GIC_SPI 142 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 143 IRQ_TYPE_LEVEL_HIGH>;
clock-names = "fck";
cmt1: timer@e6130000 {
compatible = "renesas,r8a7796-cmt1",
reg = <0 0xe6130000 0 0x1004>;
interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 127 IRQ_TYPE_LEVEL_HIGH>;
cpg: clock-controller@e6150000 {
compatible = "renesas,r8a7796-cpg-mssr";
reg = <0 0xe6150000 0 0x1000>;
#clock-cells = <2>;
#power-domain-cells = <0>;
#reset-cells = <1>;
rst: reset-controller@e6160000 {
compatible = "renesas,r8a7796-rst";
sysc: system-controller@e6180000 {
compatible = "renesas,r8a7796-sysc";
#power-domain-cells = <1>;
compatible = "renesas,r8a7796-thermal";
<GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 522>;
resets = <&cpg 522>;
compatible = "renesas,intc-ex-r8a7796", "renesas,irqc";
reg = <0 0xe61c0000 0 0x200>;
interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>,
clocks = <&cpg CPG_MOD 407>;
resets = <&cpg 407>;
compatible = "renesas,tmu-r8a7796", "renesas,tmu";
clocks = <&cpg CPG_MOD 124>;
resets = <&cpg 124>;
#size-cells = <0>;
compatible = "renesas,i2c-r8a7796",
interrupts = <GIC_SPI 287 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 931>;
resets = <&cpg 931>;
dma-names = "tx", "rx", "tx", "rx";
i2c-scl-internal-delay-ns = <110>;
#size-cells = <0>;
reg = <0 0xe6508000 0 0x40>;
interrupts = <GIC_SPI 288 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 930>;
resets = <&cpg 930>;
i2c-scl-internal-delay-ns = <6>;
#size-cells = <0>;
interrupts = <GIC_SPI 286 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 929>;
resets = <&cpg 929>;
#size-cells = <0>;
interrupts = <GIC_SPI 290 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 928>;
resets = <&cpg 928>;
#size-cells = <0>;
interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 927>;
resets = <&cpg 927>;
#size-cells = <0>;
#size-cells = <0>;
interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
compatible = "renesas,iic-r8a7796",
"renesas,rmobile-iic";
reg = <0 0xe60b0000 0 0x425>;
interrupts = <GIC_SPI 173 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 926>;
resets = <&cpg 926>;
compatible = "renesas,hscif-r8a7796",
"renesas,hscif";
reg = <0 0xe6540000 0 0x60>;
interrupts = <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>;
<&cpg CPG_CORE R8A7796_CLK_S3D1>,
<&scif_clk>;
clock-names = "fck", "brg_int", "scif_clk";
"renesas,hscif";
reg = <0 0xe6550000 0 0x60>;
interrupts = <GIC_SPI 155 IRQ_TYPE_LEVEL_HIGH>;
<&scif_clk>;
"renesas,hscif";
reg = <0 0xe6560000 0 0x60>;
interrupts = <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>;
<&scif_clk>;
"renesas,hscif";
reg = <0 0xe66a0000 0 0x60>;
interrupts = <GIC_SPI 145 IRQ_TYPE_LEVEL_HIGH>;
<&scif_clk>;
"renesas,hscif";
reg = <0 0xe66b0000 0 0x60>;
<&scif_clk>;
hsusb: usb@e6590000 {
compatible = "renesas,usbhs-r8a7796",
interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>;
phy-names = "usb";
compatible = "renesas,r8a7796-usb-dmac",
"renesas,usb-dmac";
#dma-cells = <1>;
dma-channels = <2>;
"renesas,usb-dmac";
#dma-cells = <1>;
dma-channels = <2>;
compatible = "renesas,r8a7796-usb3-phy",
<&usb_extal_clk>;
#phy-cells = <0>;
dmac0: dma-controller@e6700000 {
compatible = "renesas,dmac-r8a7796",
<GIC_SPI 200 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 201 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 202 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 203 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 204 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 205 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 206 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 207 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 208 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 209 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 210 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 211 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 212 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 213 IRQ_TYPE_LEVEL_HIGH>,
interrupt-names = "error",
clocks = <&cpg CPG_MOD 219>;
resets = <&cpg 219>;
#dma-cells = <1>;
interrupts = <GIC_SPI 220 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 216 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 217 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 218 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 219 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 308 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 309 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 310 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 311 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 312 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 313 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 314 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 315 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 316 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 317 IRQ_TYPE_LEVEL_HIGH>,
clocks = <&cpg CPG_MOD 218>;
resets = <&cpg 218>;
#dma-cells = <1>;
#dma-cells = <1>;
compatible = "renesas,ipmmu-r8a7796";
reg = <0 0xe6740000 0 0x1000>;
#iommu-cells = <1>;
#iommu-cells = <1>;
#iommu-cells = <1>;
power-domains = <&sysc R8A7796_PD_A3IR>;
#iommu-cells = <1>;
#iommu-cells = <1>;
ipmmu_mp: iommu@ec670000 {
#iommu-cells = <1>;
renesas,ipmmu-main = <&ipmmu_mm 5>;
#iommu-cells = <1>;
#iommu-cells = <1>;
ipmmu_rt: iommu@ffc80000 {
reg = <0 0xffc80000 0 0x1000>;
renesas,ipmmu-main = <&ipmmu_mm 7>;
#iommu-cells = <1>;
renesas,ipmmu-main = <&ipmmu_mm 8>;
power-domains = <&sysc R8A7796_PD_A3VC>;
#iommu-cells = <1>;
renesas,ipmmu-main = <&ipmmu_mm 9>;
#iommu-cells = <1>;
avb: ethernet@e6800000 {
compatible = "renesas,etheravb-r8a7796",
"ch24";
clocks = <&cpg CPG_MOD 812>;
resets = <&cpg 812>;
phy-mode = "rgmii";
#size-cells = <0>;
compatible = "renesas,can-r8a7796",
interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 916>,
<&cpg CPG_CORE R8A7796_CLK_CANFD>,
<&can_clk>;
clock-names = "clkp1", "clkp2", "can_clk";
assigned-clocks = <&cpg CPG_CORE R8A7796_CLK_CANFD>;
resets = <&cpg 916>;
interrupts = <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cpg CPG_MOD 915>,
<&can_clk>;
resets = <&cpg 915>;
compatible = "renesas,r8a7796-canfd",
<GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>;
<&can_clk>;
channel0 {
channel1 {
compatible = "renesas,pwm-r8a7796", "renesas,pwm-rcar";
reg = <0 0xe6e30000 0 8>;
#pwm-cells = <2>;
reg = <0 0xe6e31000 0 8>;
#pwm-cells = <2>;
reg = <0 0xe6e32000 0 8>;
#pwm-cells = <2>;
reg = <0 0xe6e33000 0 8>;
#pwm-cells = <2>;
reg = <0 0xe6e34000 0 8>;
#pwm-cells = <2>;
reg = <0 0xe6e35000 0 8>;
#pwm-cells = <2>;
reg = <0 0xe6e36000 0 8>;
#pwm-cells = <2>;
scif0: serial@e6e60000 {
compatible = "renesas,scif-r8a7796",
reg = <0 0xe6e60000 0 64>;
interrupts = <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>;
<&scif_clk>;
resets = <&cpg 207>;
scif1: serial@e6e68000 {
reg = <0 0xe6e68000 0 64>;
interrupts = <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>;
<&scif_clk>;
resets = <&cpg 206>;
<&scif_clk>;
reg = <0 0xe6c50000 0 64>;
interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>;
<&scif_clk>;
resets = <&cpg 204>;
reg = <0 0xe6c40000 0 64>;
<&scif_clk>;
resets = <&cpg 203>;
<&scif_clk>;
resets = <&cpg 202>;
tpu: pwm@e6e80000 {
compatible = "renesas,tpu-r8a7796", "renesas,tpu";
#pwm-cells = <3>;
compatible = "renesas,msiof-r8a7796",
#size-cells = <0>;
#size-cells = <0>;
#size-cells = <0>;
#size-cells = <0>;
compatible = "renesas,vin-r8a7796";
reg = <0 0xe6ef0000 0 0x1000>;
clocks = <&cpg CPG_MOD 811>;
resets = <&cpg 811>;
renesas,id = <0>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
reg = <0>;
reg = <2>;
reg = <0 0xe6ef1000 0 0x1000>;
clocks = <&cpg CPG_MOD 810>;
resets = <&cpg 810>;
renesas,id = <1>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
reg = <0>;
reg = <2>;
reg = <0 0xe6ef2000 0 0x1000>;
clocks = <&cpg CPG_MOD 809>;
resets = <&cpg 809>;
renesas,id = <2>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
reg = <0>;
reg = <2>;
renesas,id = <3>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
reg = <0>;
reg = <2>;
renesas,id = <4>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
reg = <0>;
vin4csi40: endpoint@2 {
reg = <2>;
remote-endpoint = <&csi40vin4>;
renesas,id = <5>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
reg = <0>;
vin5csi40: endpoint@2 {
reg = <2>;
remote-endpoint = <&csi40vin5>;
renesas,id = <6>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
reg = <0>;
vin6csi40: endpoint@2 {
reg = <2>;
remote-endpoint = <&csi40vin6>;
renesas,id = <7>;
ports {
#size-cells = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
reg = <0>;
vin7csi40: endpoint@2 {
reg = <2>;
remote-endpoint = <&csi40vin7>;
compatible = "renesas,r8a7796-drif",
interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>;
interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>;
rcar_sound: sound@ec500000 {
* #sound-dai-cells is required if simple-card
* Single DAI : #sound-dai-cells = <0>; <&rcar_sound>;
* Multi DAI : #sound-dai-cells = <1>; <&rcar_sound N>;
compatible = "renesas,rcar_sound-r8a7796", "renesas,rcar_sound-gen3";
reg = <0 0xec500000 0 0x1000>, /* SCU */
<0 0xec5a0000 0 0x100>, /* ADG */
<0 0xec540000 0 0x1000>, /* SSIU */
<0 0xec541000 0 0x280>, /* SSI */
reg-names = "scu", "adg", "ssiu", "ssi", "audmapp";
clocks = <&cpg CPG_MOD 1005>,
<&cpg CPG_MOD 1006>, <&cpg CPG_MOD 1007>,
<&cpg CPG_MOD 1008>, <&cpg CPG_MOD 1009>,
<&cpg CPG_MOD 1010>, <&cpg CPG_MOD 1011>,
<&cpg CPG_MOD 1012>, <&cpg CPG_MOD 1013>,
<&cpg CPG_MOD 1014>, <&cpg CPG_MOD 1015>,
<&cpg CPG_MOD 1022>, <&cpg CPG_MOD 1023>,
<&cpg CPG_MOD 1024>, <&cpg CPG_MOD 1025>,
<&cpg CPG_MOD 1026>, <&cpg CPG_MOD 1027>,
<&cpg CPG_MOD 1028>, <&cpg CPG_MOD 1029>,
<&cpg CPG_MOD 1030>, <&cpg CPG_MOD 1031>,
<&cpg CPG_MOD 1019>, <&cpg CPG_MOD 1018>,
<&audio_clk_a>, <&audio_clk_b>,
<&audio_clk_c>,
<&cpg CPG_CORE R8A7796_CLK_S0D4>;
clock-names = "ssi-all",
"ssi.9", "ssi.8", "ssi.7", "ssi.6",
"ssi.5", "ssi.4", "ssi.3", "ssi.2",
"ssi.1", "ssi.0",
"src.9", "src.8", "src.7", "src.6",
"src.5", "src.4", "src.3", "src.2",
"src.1", "src.0",
"mix.1", "mix.0",
"ctu.1", "ctu.0",
"dvc.0", "dvc.1",
"clk_a", "clk_b", "clk_c", "clk_i";
resets = <&cpg 1005>,
<&cpg 1006>, <&cpg 1007>,
<&cpg 1008>, <&cpg 1009>,
<&cpg 1010>, <&cpg 1011>,
<&cpg 1012>, <&cpg 1013>,
<&cpg 1014>, <&cpg 1015>;
reset-names = "ssi-all",
"ssi.1", "ssi.0";
rcar_sound,ctu {
ctu00: ctu-0 { };
ctu01: ctu-1 { };
ctu02: ctu-2 { };
ctu03: ctu-3 { };
ctu10: ctu-4 { };
ctu11: ctu-5 { };
ctu12: ctu-6 { };
ctu13: ctu-7 { };
rcar_sound,dvc {
dvc0: dvc-0 {
dma-names = "tx";
dvc1: dvc-1 {
dma-names = "tx";
rcar_sound,mix {
mix0: mix-0 { };
mix1: mix-1 { };
rcar_sound,src {
src0: src-0 {
interrupts = <GIC_SPI 352 IRQ_TYPE_LEVEL_HIGH>;
src1: src-1 {
interrupts = <GIC_SPI 353 IRQ_TYPE_LEVEL_HIGH>;
src2: src-2 {
interrupts = <GIC_SPI 354 IRQ_TYPE_LEVEL_HIGH>;
src3: src-3 {
interrupts = <GIC_SPI 355 IRQ_TYPE_LEVEL_HIGH>;
src4: src-4 {
interrupts = <GIC_SPI 356 IRQ_TYPE_LEVEL_HIGH>;
src5: src-5 {
interrupts = <GIC_SPI 357 IRQ_TYPE_LEVEL_HIGH>;
src6: src-6 {
interrupts = <GIC_SPI 358 IRQ_TYPE_LEVEL_HIGH>;
src7: src-7 {
interrupts = <GIC_SPI 359 IRQ_TYPE_LEVEL_HIGH>;
src8: src-8 {
interrupts = <GIC_SPI 360 IRQ_TYPE_LEVEL_HIGH>;
src9: src-9 {
interrupts = <GIC_SPI 361 IRQ_TYPE_LEVEL_HIGH>;
rcar_sound,ssi {
ssi0: ssi-0 {
ssi1: ssi-1 {
ssi2: ssi-2 {
ssi3: ssi-3 {
ssi4: ssi-4 {
ssi5: ssi-5 {
ssi6: ssi-6 {
ssi7: ssi-7 {
ssi8: ssi-8 {
ssi9: ssi-9 {
rcar_sound,ssiu {
ssiu00: ssiu-0 {
ssiu01: ssiu-1 {
ssiu02: ssiu-2 {
ssiu03: ssiu-3 {
ssiu04: ssiu-4 {
ssiu05: ssiu-5 {
ssiu06: ssiu-6 {
ssiu07: ssiu-7 {
ssiu10: ssiu-8 {
ssiu11: ssiu-9 {
ssiu12: ssiu-10 {
ssiu13: ssiu-11 {
ssiu14: ssiu-12 {
ssiu15: ssiu-13 {
ssiu16: ssiu-14 {
ssiu17: ssiu-15 {
ssiu20: ssiu-16 {
ssiu21: ssiu-17 {
ssiu22: ssiu-18 {
ssiu23: ssiu-19 {
ssiu24: ssiu-20 {
ssiu25: ssiu-21 {
ssiu26: ssiu-22 {
ssiu27: ssiu-23 {
ssiu30: ssiu-24 {
ssiu31: ssiu-25 {
ssiu32: ssiu-26 {
ssiu33: ssiu-27 {
ssiu34: ssiu-28 {
ssiu35: ssiu-29 {
ssiu36: ssiu-30 {
ssiu37: ssiu-31 {
ssiu40: ssiu-32 {
ssiu41: ssiu-33 {
ssiu42: ssiu-34 {
ssiu43: ssiu-35 {
ssiu44: ssiu-36 {
ssiu45: ssiu-37 {
ssiu46: ssiu-38 {
ssiu47: ssiu-39 {
ssiu50: ssiu-40 {
ssiu60: ssiu-41 {
ssiu70: ssiu-42 {
ssiu80: ssiu-43 {
ssiu90: ssiu-44 {
ssiu91: ssiu-45 {
ssiu92: ssiu-46 {
ssiu93: ssiu-47 {
ssiu94: ssiu-48 {
ssiu95: ssiu-49 {
ssiu96: ssiu-50 {
ssiu97: ssiu-51 {
mlp: mlp@ec520000 {
compatible = "renesas,r8a7796-mlp",
#dma-cells = <1>;
iommus = <&ipmmu_mp 0>, <&ipmmu_mp 1>,
<&ipmmu_mp 2>, <&ipmmu_mp 3>,
<&ipmmu_mp 4>, <&ipmmu_mp 5>,
<&ipmmu_mp 6>, <&ipmmu_mp 7>,
<&ipmmu_mp 8>, <&ipmmu_mp 9>,
<&ipmmu_mp 10>, <&ipmmu_mp 11>,
<&ipmmu_mp 12>, <&ipmmu_mp 13>,
<&ipmmu_mp 14>, <&ipmmu_mp 15>;
#dma-cells = <1>;
iommus = <&ipmmu_mp 16>, <&ipmmu_mp 17>,
<&ipmmu_mp 18>, <&ipmmu_mp 19>,
<&ipmmu_mp 20>, <&ipmmu_mp 21>,
<&ipmmu_mp 22>, <&ipmmu_mp 23>,
<&ipmmu_mp 24>, <&ipmmu_mp 25>,
<&ipmmu_mp 26>, <&ipmmu_mp 27>,
<&ipmmu_mp 28>, <&ipmmu_mp 29>,
<&ipmmu_mp 30>, <&ipmmu_mp 31>;
compatible = "renesas,xhci-r8a7796",
"renesas,rcar-gen3-xhci";
compatible = "renesas,r8a7796-usb3-peri",
phy-names = "usb";
phy-names = "usb";
phy-names = "usb";
phy-names = "usb";
compatible = "renesas,usb2-phy-r8a7796",
#phy-cells = <1>;
#phy-cells = <1>;
compatible = "renesas,sdhi-r8a7796",
clocks = <&cpg CPG_MOD 314>, <&cpg CPG_CORE R8A7796_CLK_SD0H>;
clocks = <&cpg CPG_MOD 313>, <&cpg CPG_CORE R8A7796_CLK_SD1H>;
clocks = <&cpg CPG_MOD 312>, <&cpg CPG_CORE R8A7796_CLK_SD2H>;
clocks = <&cpg CPG_MOD 311>, <&cpg CPG_CORE R8A7796_CLK_SD3H>;
rpc: spi@ee200000 {
compatible = "renesas,r8a7796-rpc-if",
clocks = <&cpg CPG_MOD 917>;
resets = <&cpg 917>;
#size-cells = <0>;
(GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_HIGH)>;
compatible = "renesas,pcie-r8a7796",
#size-cells = <2>;
#size-cells = <2>;
imr-lx4@fe860000 {
compatible = "renesas,r8a7796-imr-lx4",
"renesas,imr-lx4";
imr-lx4@fe870000 {
"renesas,imr-lx4";
fdp1@fe940000 {
compatible = "renesas,fdp1";
compatible = "renesas,fcpf";
compatible = "renesas,fcpv";
iommus = <&ipmmu_vc0 19>;
iommus = <&ipmmu_vi0 10>;
vspb: vsp@fe960000 {
compatible = "renesas,vsp2";
compatible = "renesas,r8a7796-cmm",
compatible = "renesas,r8a7796-csi2";
interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>;
resets = <&cpg 714>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
reg = <0>;
reg = <1>;
reg = <2>;
reg = <3>;
reg = <4>;
reg = <5>;
reg = <6>;
reg = <7>;
resets = <&cpg 716>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port@1 {
#size-cells = <0>;
reg = <1>;
reg = <0>;
reg = <1>;
reg = <2>;
reg = <3>;
csi40vin4: endpoint@4 {
reg = <4>;
remote-endpoint = <&vin4csi40>;
csi40vin5: endpoint@5 {
reg = <5>;
remote-endpoint = <&vin5csi40>;
csi40vin6: endpoint@6 {
reg = <6>;
remote-endpoint = <&vin6csi40>;
csi40vin7: endpoint@7 {
reg = <7>;
remote-endpoint = <&vin7csi40>;
compatible = "renesas,r8a7796-hdmi", "renesas,rcar-gen3-hdmi";
clocks = <&cpg CPG_MOD 729>, <&cpg CPG_CORE R8A7796_CLK_HDMI>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port@1 {
reg = <1>;
port@2 {
/* HDMI sound */
reg = <2>;
compatible = "renesas,du-r8a7796";
reg = <0 0xfeb00000 0 0x70000>;
<GIC_SPI 269 IRQ_TYPE_LEVEL_HIGH>;
<&cpg CPG_MOD 722>;
clock-names = "du.0", "du.1", "du.2";
renesas,cmms = <&cmm0>, <&cmm1>, <&cmm2>;
renesas,vsps = <&vspd0 0>, <&vspd1 0>, <&vspd2 0>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port@1 {
reg = <1>;
port@2 {
reg = <2>;
compatible = "renesas,r8a7796-lvds";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port@1 {
reg = <1>;
thermal-zones {
sustainable-power = <3874>;
trips {
type = "critical";
trips {
type = "critical";
cooling-maps {
map0 {
trip = <&target>;
map1 {
trip = <&target>;
trips {
type = "passive";
type = "critical";
timer {
interrupts-extended = <&gic GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>,
<&gic GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>,
<&gic GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>,
<&gic GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>;
compatible = "fixed-clock";
#clock-cells = <0>;
#clock-cells = <0>;
-}; diff --git a/arch/arm/dts/r8a77965-salvator-x.dts b/arch/arm/dts/r8a77965-salvator-x.dts deleted file mode 100644 index f84c64ed4df..00000000000 --- a/arch/arm/dts/r8a77965-salvator-x.dts +++ /dev/null @@ -1,32 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Device Tree Source for the Salvator-X board with R-Car M3-N
- Copyright (C) 2018 Jacopo Mondi jacopo+renesas@jmondi.org
-/dts-v1/; -#include "r8a77965.dtsi" -#include "salvator-x.dtsi"
model = "Renesas Salvator-X board based on r8a77965";
compatible = "renesas,salvator-x", "renesas,r8a77965";
memory@48000000 {
/* first 128MB is reserved for secure area. */
-&du {
<&cpg CPG_MOD 723>,
<&cpg CPG_MOD 721>,
<&versaclock5 1>,
<&x21_clk>,
<&versaclock5 2>;
clock-names = "du.0", "du.1", "du.3",
"dclkin.0", "dclkin.1", "dclkin.3";
-}; diff --git a/arch/arm/dts/r8a77965-ulcb.dts b/arch/arm/dts/r8a77965-ulcb.dts deleted file mode 100644 index 71704b67a20..00000000000 --- a/arch/arm/dts/r8a77965-ulcb.dts +++ /dev/null @@ -1,33 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Device Tree Source for the M3NULCB (R-Car Starter Kit Pro) board with R-Car M3-N
- Copyright (C) 2018 Renesas Electronics Corp.
- Copyright (C) 2018 Cogent Embedded, Inc.
-/dts-v1/; -#include "r8a77965.dtsi" -#include "ulcb.dtsi"
model = "Renesas M3NULCB board based on r8a77965";
compatible = "renesas,m3nulcb", "renesas,r8a77965";
memory@48000000 {
-&du {
<&cpg CPG_MOD 723>,
<&cpg CPG_MOD 721>,
<&versaclock5 1>,
<&versaclock5 3>,
<&versaclock5 2>;
-}; diff --git a/arch/arm/dts/r8a77965.dtsi b/arch/arm/dts/r8a77965.dtsi deleted file mode 100644 index c7582003849..00000000000 --- a/arch/arm/dts/r8a77965.dtsi +++ /dev/null @@ -1,2889 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/*
- Device Tree Source for the R-Car M3-N (R8A77965) SoC
- Based on r8a7796.dtsi
- Copyright (C) 2016 Renesas Electronics Corp.
-#include <dt-bindings/clock/r8a77965-cpg-mssr.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/power/r8a77965-sysc.h>
-#define CPG_AUDIO_CLK_I R8A77965_CLK_S0D4
-#define SOC_HAS_SATA
compatible = "renesas,r8a77965";
#address-cells = <2>;
#size-cells = <2>;
#clock-cells = <0>;
#clock-cells = <0>;
#clock-cells = <0>;
/* External CAN clock - to be overridden by boards that provide it */
can_clk: can {
#clock-cells = <0>;
cluster0_opp: opp-table-0 {
compatible = "operating-points-v2";
opp-shared;
opp-500000000 {
opp-hz = /bits/ 64 <500000000>;
opp-microvolt = <830000>;
clock-latency-ns = <300000>;
opp-1000000000 {
opp-hz = /bits/ 64 <1000000000>;
opp-1500000000 {
opp-hz = /bits/ 64 <1500000000>;
opp-suspend;
opp-1600000000 {
opp-hz = /bits/ 64 <1600000000>;
opp-microvolt = <900000>;
opp-1700000000 {
opp-hz = /bits/ 64 <1700000000>;
opp-1800000000 {
opp-microvolt = <960000>;
turbo-mode;
cpus {
#size-cells = <0>;
a57_0: cpu@0 {
compatible = "arm,cortex-a57";
reg = <0x0>;
power-domains = <&sysc R8A77965_PD_CA57_CPU0>;
next-level-cache = <&L2_CA57>;
enable-method = "psci";
cpu-idle-states = <&CPU_SLEEP_0>;
#cooling-cells = <2>;
dynamic-power-coefficient = <854>;
clocks = <&cpg CPG_CORE R8A77965_CLK_Z>;
operating-points-v2 = <&cluster0_opp>;
a57_1: cpu@1 {
reg = <0x1>;
power-domains = <&sysc R8A77965_PD_CA57_CPU1>;
L2_CA57: cache-controller-0 {
power-domains = <&sysc R8A77965_PD_CA57_SCU>;
cache-unified;
cache-level = <2>;
idle-states {
entry-method = "psci";
CPU_SLEEP_0: cpu-sleep-0 {
compatible = "arm,idle-state";
arm,psci-suspend-param = <0x0010000>;
local-timer-stop;
entry-latency-us = <400>;
exit-latency-us = <500>;
min-residency-us = <4000>;
extal_clk: extal {
#clock-cells = <0>;
/* This value must be overridden by the board */
extalr_clk: extalr {
#clock-cells = <0>;
/* External PCIe clock - can be overridden by the board */
pcie_bus_clk: pcie_bus {
#clock-cells = <0>;
pmu_a57 {
compatible = "arm,cortex-a57-pmu";
interrupts-extended = <&gic GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>,
<&a57_1>;
psci {
compatible = "arm,psci-1.0", "arm,psci-0.2";
method = "smc";
/* External SCIF clock - to be overridden by boards that provide it */
scif_clk: scif {
#clock-cells = <0>;
soc {
#size-cells = <2>;
ranges;
compatible = "renesas,r8a77965-wdt",
"renesas,rcar-gen3-wdt";
power-domains = <&sysc R8A77965_PD_ALWAYS_ON>;
compatible = "renesas,gpio-r8a77965",
"renesas,rcar-gen3-gpio";
in
