[PATCH] tools: kwboot: Change KWBOOT_MSG_RSP_TIMEO_AXP to 10ms
Testing on the theadorable Armada XP platform has shown, thaz using the current value of 1000ms as response timeout does not result in reliable booting via kwboot. Using 10ms seems to be much better. So let's change this value to this 10ms instead.
Signed-off-by: Stefan Roese sr@denx.de --- tools/kwboot.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/kwboot.c b/tools/kwboot.c index 16bcd4d9a778..da4fe32da226 100644 --- a/tools/kwboot.c +++ b/tools/kwboot.c @@ -84,7 +84,7 @@ static unsigned char kwboot_msg_debug[] = { #define KWBOOT_MSG_RSP_TIMEO 50 /* ms */
/* Defines known to work on Armada XP */ -#define KWBOOT_MSG_RSP_TIMEO_AXP 1000 /* ms */ +#define KWBOOT_MSG_RSP_TIMEO_AXP 10 /* ms */
/* * Xmodem Transfers
Acked-by: Pali Rohár pali@kernel.org
- Xmodem Transfers
-- 2.37.2
Hello Stefan! You should update also documentation file doc/kwboot.1 because it mention "1000 ms" for Option \fB-a\fP.
- Xmodem Transfers
-- 2.37.2
Applied to u-boot-marvell/master
Thanks, Stefan
- Xmodem Transfers
Viele Grüße, Stefan Roese
Pali Rohár
Stefan Roese
