[U-Boot] please pull u-boot-samsung/resolve
Dear Albert,
The following changes since commit fd4d564b3c80b111f18c93adb14233a6a7ddb0e9:
Merge branch 'master' of git://git.denx.de/u-boot-x86 (2012-12-07 08:47:59 -0700)
git://git.denx.de/u-boot-samsung resolve
for you to fetch changes up to fbef8e6e7f1233ed20f8c5045e12c9cf31b43540:
universal_c210: check the NULL pointer when get the PMIC (2012-12-11 17:37:28 +0900)
---------------------------------------------------------------- Albert ARIBAUD (1): Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'
Allen Martin (1): tegra: add CONSOLE_MUX support to tegra-kbc
Ashok Kumar Reddy (1): ARM: arm1176: Define arch_cpu_init() for s3c64xx
Benoît Thébaudeau (17): arm1136: Fix enable_caches() mx31: Move EHCI definitions to ehci-fsl.h ehci-mxc: Clean up ehci-mx5: Clean up ehci-mx5: Fix OC_DIS usage ehci-mx5: Fix OPM usage ehci-mx5: Fix *PM usage for i.MX53 ehci-mx5: Add missing OC_DIS for i.MX53 ehci-mxc: Make EHCI power/oc polarities configurable ehci-mxc: Make i.MX25 EHCI configurable ehci-mxc: Define host offsets ehci-mxc: Add support for i.MX35 mx35pdk: Add support for OTG ehci-mx5/6: Make board_ehci_hcd_init() optional ehci-mxc: Fix host power mask bit for i.MX35 ehci-mxc: Fix host power mask bit for i.MX25 mx5: Mark lowlevel_init board-specific code
Chander Kashyap (1): Exynos5250: Enable PXE Support
Fabio Estevam (24): mx25pdk: Include CONFIG_MX25 mx25pdk: Add esdhc support pmic_fsl: Introduce FSL_PMIC_I2C_LENGTH mx25: Place common functions into sys_proto.h pmic: Add support for mc34704 mx25pdk: Add Ethernet support mx53loco: Allow booting a zImage kernel mx25pdk: Allow booting a zImage kernel mx51evk: Allow booting a zImage kernel mx35pdk: Allow booting a zImage kernel mx6qsabre_common: Allow booting a zImage kernel mx5: Align SPI CS naming with i.MX53 reference manual mx5: Print CSPI clock in 'clock' command spi: mxc_spi: Fix handling of chip select spi: mxc_spi: Fix spi clock glitch durant reset mx6: clock: Only show CSPI clock if CSPI is enabled mx28evk: Configure CONFIG_BOOTDELAY to one second mx53loco: Configure CONFIG_BOOTDELAY to one second mx6qsabrelite: Configure CONFIG_BOOTDELAY to one second mx6qsabre_common: Configure CONFIG_BOOTDELAY to one second mx51evk: Configure CONFIG_BOOTDELAY to one second mx25pdk: Configure CONFIG_BOOTDELAY to one second mx31pdk: Configure CONFIG_BOOTDELAY to one second mx35pdk: Configure CONFIG_BOOTDELAY to one second
Hatim RV (3): EXYNOS: Add clock for SPI EXYNOS5: Add base address for SPI EXYNOS5: Enable SPI
Marek Vasut (3): dm: wdt: Move s5p watchdog timer to drivers/watchdog/ mx28: Fix typo in POWER_MINPWR_VBG_OFF mx28: Fix typo in POWER_DCLIMITS_NEGLIMIT_OFFSET
Mayuresh Kulkarni (1): tegra: Enable display/lcd support on Seaboard
Minkyu Kang (6): ARCH: EXYNOS: add support to match product id EXYNOS: Clock: Add common function for pll rate calculation s3c64xx: fix the compiler error and warning Merge branch 'master' of git://git.denx.de/u-boot into resolve universal_c210: fix compiler error and compiler warning universal_c210: check the NULL pointer when get the PMIC
Piotr Wilczek (12): arm:exynos4:trats: Correct SDRAM configuration for trats arm:exynos4:trats: Fix SDRAM size arm:exynos4:pinmux: Modify the gpio function for mmc arm:exynos4:trats: Use pinmux for mmc configuration arm:exynos4:universal: Use pinmux for mmc configuration arm:exynos4:universal: Eliminated low level init arm: trats: Power down core 1 exynos4: universal_C210: use software SPI misc:max8998 Add LDO macros drivers: video: Add ld9040 video driver drivers: video: fix image position exynos4: universal_C210: add display support
Rajeshwari Shinde (16): PMIC: MAX77686: Add support for MAX77686 SMDK5250: Config: Enable MAX77686 pmic chip SOUND: SAMSUNG: Add I2S driver SOUND: Add WM8994 codec Sound: Add command for audio playback EXYNOS: Add I2S registers EXYNOS: Add parameters required by I2S EXYNOS: Add pinmux for I2S EXYNOS: Add I2S base address EXYNOS: Add clock for I2S SMDK5250: Enable Sound EXYNOS5: Add pinmux support for SPI SPI: Add SPI Driver for EXYNOS. EXYNOS5: Enable SPI booting. POWER: MAX77686: Modified as per the latest Implementation SMDK5250: Enable pmic MAX77686
Simon Glass (17): pxa: Disable dcache on palmld, palmtc, zipitz2 tegra: Use const for pinmux_config_pingroup/table() tegra: Add display support to funcmux tegra: fdt: Add pwm binding and node tegra: fdt: Add LCD definitions for Tegra tegra: Add support for PWM tegra: Add LCD driver tegra: Add LCD support to Nvidia boards arm: Add control over cachability of memory regions lcd: Add CONFIG_LCD_ALIGNMENT to select frame buffer alignment lcd: Add support for flushing LCD fb from dcache after update tegra: Align LCD frame buffer to section boundary tegra: Support control of cache settings for LCD tegra: fdt: Add LCD definitions for Seaboard lcd: Add CONFIG_CONSOLE_SCROLL_LINES option to speed console tegra: Remove unnecessary CONFIG_SYS_NAND_BASE tegra: config: seaboard: Move tegra-common-post to correct place
Stefano Babic (8): ARM: Fix start.S when used with SPL in arm1136 MX35: add LOW_LEVEL_SRAM_STACK to use SPL_FRAMEWORK MX35: Add soc_boot_mode and soc_boot_device to MX35 SPL: Added SPL target for mx35 SOC to SPL Makefile ARM: Add SPL target to arm1136 MX35: add support for woodburn board MX5: added CONFIG_PMIC_FSL_MC13892 to mx53evk Merge git://git.denx.de/u-boot
Stephen Warren (4): ARM: tegra: TrimSlice: add support for USB1 port mmc: tegra: support 4-bit operation too on 8-bit slots ARM: tegra: enable 8-bit SD slots in board files tegra: use generic fs commands in BOOTCOMMAND
Troy Kisky (4): mx6: soc: update get_cpu_rev and get_imx_type for mx6solo/sololite mx6: use CONFIG_MX6 instead of CONFIG_MX6Q imx-common: cpu: add imx_ddr_size arch-mx6: add mx6dl_pins.h
Wei Ni (1): tegra: Add SOC support for display/lcd
Łukasz Majewski (1): gpio:fix: Proper handling of GPIO subsystem parts at Samsung devices
MAINTAINERS | 1 + Makefile | 2 + arch/arm/cpu/arm1136/config.mk | 3 + arch/arm/cpu/arm1136/cpu.c | 22 +- arch/arm/cpu/arm1136/mx35/Makefile | 1 + arch/arm/cpu/arm1136/mx35/generic.c | 75 ++ arch/arm/cpu/arm1136/mx35/mx35_sdram.c | 137 ++++ arch/arm/cpu/arm1136/start.S | 31 +- arch/arm/cpu/arm1136/u-boot-spl.lds | 62 ++ arch/arm/cpu/arm1176/s3c64xx/Makefile | 2 +- arch/arm/cpu/arm1176/s3c64xx/init.c | 26 + arch/arm/cpu/armv7/cache_v7.c | 11 + arch/arm/cpu/armv7/exynos/clock.c | 350 +++++++-- arch/arm/cpu/armv7/exynos/pinmux.c | 122 +++ arch/arm/cpu/armv7/mx5/clock.c | 4 +- arch/arm/cpu/armv7/mx5/lowlevel_init.S | 2 +- arch/arm/cpu/armv7/mx6/clock.c | 2 + arch/arm/cpu/armv7/mx6/soc.c | 32 +- arch/arm/cpu/armv7/s5p-common/Makefile | 1 - arch/arm/cpu/armv7/tegra20/Makefile | 2 + arch/arm/cpu/armv7/tegra20/display.c | 409 ++++++++++ arch/arm/cpu/armv7/tegra20/pwm.c | 101 +++ arch/arm/cpu/tegra20-common/funcmux.c | 37 + arch/arm/cpu/tegra20-common/pinmux.c | 4 +- arch/arm/dts/tegra20.dtsi | 105 +++ arch/arm/imx-common/cpu.c | 66 +- arch/arm/include/asm/arch-exynos/clk.h | 4 + arch/arm/include/asm/arch-exynos/clock.h | 29 + arch/arm/include/asm/arch-exynos/cpu.h | 18 + arch/arm/include/asm/arch-exynos/gpio.h | 19 + arch/arm/include/asm/arch-exynos/i2s-regs.h | 66 ++ arch/arm/include/asm/arch-exynos/periph.h | 7 + arch/arm/include/asm/arch-exynos/sound.h | 44 ++ arch/arm/include/asm/arch-exynos/spi.h | 78 ++ arch/arm/include/asm/arch-mx25/imx-regs.h | 5 +- arch/arm/include/asm/arch-mx25/sys_proto.h | 3 + arch/arm/include/asm/arch-mx31/imx-regs.h | 27 +- arch/arm/include/asm/arch-mx35/imx-regs.h | 4 + arch/arm/include/asm/arch-mx35/mmc_host_def.h | 31 + arch/arm/include/asm/arch-mx35/spl.h | 38 + arch/arm/include/asm/arch-mx35/sys_proto.h | 2 + arch/arm/include/asm/arch-mx5/mx5x_pins.h | 6 +- arch/arm/include/asm/arch-mx5/sys_proto.h | 10 +- arch/arm/include/asm/arch-mx6/imx-regs.h | 2 + arch/arm/include/asm/arch-mx6/mx6dl_pins.h | 149 ++++ arch/arm/include/asm/arch-mx6/sys_proto.h | 10 +- arch/arm/include/asm/arch-mxs/regs-power.h | 4 +- arch/arm/include/asm/arch-s5pc1xx/gpio.h | 7 +- arch/arm/include/asm/arch-tegra20/dc.h | 545 ++++++++++++++ arch/arm/include/asm/arch-tegra20/display.h | 152 ++++ arch/arm/include/asm/arch-tegra20/pinmux.h | 4 +- arch/arm/include/asm/arch-tegra20/pwm.h | 75 ++ arch/arm/include/asm/system.h | 31 + arch/arm/lib/cache-cp15.c | 51 +- board/compal/paz00/paz00.c | 5 +- board/compulab/dts/tegra20-trimslice.dts | 3 +- board/compulab/trimslice/trimslice.c | 8 + board/freescale/mx25pdk/mx25pdk.c | 114 +++ board/freescale/mx31ads/u-boot.lds | 2 + board/freescale/mx35pdk/lowlevel_init.S | 4 + board/freescale/mx35pdk/mx35pdk.c | 21 + board/nvidia/common/board.c | 24 + board/nvidia/dts/tegra20-seaboard.dts | 33 + board/nvidia/harmony/harmony.c | 5 +- board/nvidia/seaboard/seaboard.c | 5 +- board/samsung/smdk5250/Makefile | 2 +- board/samsung/smdk5250/smdk5250.c | 15 + board/samsung/smdk5250/{mmc_boot.c => spl_boot.c} | 31 +- board/samsung/trats/trats.c | 80 +- board/samsung/universal_c210/Makefile | 1 - board/samsung/universal_c210/lowlevel_init.S | 395 ---------- board/samsung/universal_c210/universal.c | 337 +++++++-- board/syteco/zmx25/zmx25.c | 1 + board/woodburn/Makefile | 43 ++ board/woodburn/imximage.cfg | 4 + board/woodburn/lowlevel_init.S | 38 + board/woodburn/woodburn.c | 261 +++++++ boards.cfg | 2 + common/Makefile | 1 + common/cmd_sound.c | 96 +++ common/lcd.c | 89 ++- common/main.c | 12 +- doc/README.imx5 | 5 + doc/device-tree-bindings/pwm/tegra20-pwm.txt | 18 + doc/device-tree-bindings/video/displaymode.txt | 42 ++ doc/device-tree-bindings/video/tegra20-dc.txt | 85 +++ drivers/gpio/mxc_gpio.c | 6 +- drivers/gpio/s5p_gpio.c | 6 +- drivers/input/tegra-kbc.c | 18 +- drivers/mmc/tegra_mmc.c | 7 +- drivers/power/pmic/Makefile | 1 + drivers/power/pmic/pmic_max77686.c | 48 ++ drivers/power/power_fsl.c | 8 +- drivers/serial/s3c64xx.c | 3 +- drivers/sound/Makefile | 48 ++ drivers/sound/samsung-i2s.c | 358 +++++++++ drivers/sound/sound.c | 228 ++++++ drivers/sound/wm8994.c | 792 ++++++++++++++++++++ drivers/sound/wm8994.h | 87 +++ drivers/sound/wm8994_registers.h | 299 ++++++++ drivers/spi/Makefile | 1 + drivers/spi/exynos_spi.c | 367 +++++++++ drivers/spi/mxc_spi.c | 9 +- drivers/usb/host/ehci-mx5.c | 146 +++- drivers/usb/host/ehci-mx6.c | 5 + drivers/usb/host/ehci-mxc.c | 225 ++++-- drivers/video/Makefile | 2 + drivers/video/exynos_fb.c | 15 +- drivers/video/ipu_regs.h | 2 +- drivers/video/ld9040.c | 144 ++++ drivers/video/tegra.c | 379 ++++++++++ drivers/watchdog/Makefile | 1 + .../s5p-common/wdt.c => drivers/watchdog/s5p_wdt.c | 0 include/configs/harmony.h | 4 +- include/configs/mx25pdk.h | 42 +- include/configs/mx28evk.h | 2 +- include/configs/mx31pdk.h | 2 +- include/configs/mx35pdk.h | 18 +- include/configs/mx51_efikamx.h | 1 + include/configs/mx51evk.h | 5 +- include/configs/mx53evk.h | 1 + include/configs/mx53loco.h | 4 +- include/configs/mx6qarm2.h | 1 + include/configs/mx6qsabre_common.h | 4 +- include/configs/mx6qsabrelite.h | 3 +- include/configs/palmld.h | 3 + include/configs/palmtc.h | 3 + include/configs/paz00.h | 3 + include/configs/s5pc210_universal.h | 36 + include/configs/seaboard.h | 21 +- include/configs/smdk5250.h | 48 +- include/configs/tec.h | 1 - include/configs/tegra-common-post.h | 39 +- include/configs/tegra20-common.h | 3 + include/configs/trats.h | 17 +- include/configs/trimslice.h | 4 + include/configs/ventana.h | 3 + include/configs/vision2.h | 1 + include/configs/whistler.h | 3 + include/configs/woodburn.h | 34 + include/configs/woodburn_common.h | 313 ++++++++ include/configs/woodburn_sd.h | 60 ++ include/configs/zipitz2.h | 3 + include/configs/zmx25.h | 6 +- include/fdtdec.h | 2 + include/i2s.h | 127 ++++ include/lcd.h | 11 + include/ld9040.h | 32 + include/mc34704.h | 49 ++ include/power/max77686_pmic.h | 158 ++++ include/power/max8998_pmic.h | 2 + include/sound.h | 62 ++ include/usb/ehci-fsl.h | 28 +- lib/fdtdec.c | 2 + nand_spl/board/freescale/mx31pdk/u-boot.lds | 2 + spl/Makefile | 6 + 156 files changed, 8322 insertions(+), 865 deletions(-) create mode 100644 arch/arm/cpu/arm1136/mx35/mx35_sdram.c create mode 100644 arch/arm/cpu/arm1136/u-boot-spl.lds create mode 100644 arch/arm/cpu/arm1176/s3c64xx/init.c create mode 100644 arch/arm/cpu/armv7/tegra20/display.c create mode 100644 arch/arm/cpu/armv7/tegra20/pwm.c create mode 100644 arch/arm/include/asm/arch-exynos/i2s-regs.h create mode 100644 arch/arm/include/asm/arch-exynos/sound.h create mode 100644 arch/arm/include/asm/arch-exynos/spi.h create mode 100644 arch/arm/include/asm/arch-mx35/mmc_host_def.h create mode 100644 arch/arm/include/asm/arch-mx35/spl.h create mode 100644 arch/arm/include/asm/arch-mx6/mx6dl_pins.h create mode 100644 arch/arm/include/asm/arch-tegra20/dc.h create mode 100644 arch/arm/include/asm/arch-tegra20/display.h create mode 100644 arch/arm/include/asm/arch-tegra20/pwm.h rename board/samsung/smdk5250/{mmc_boot.c => spl_boot.c} (66%) delete mode 100644 board/samsung/universal_c210/lowlevel_init.S create mode 100644 board/woodburn/Makefile create mode 100644 board/woodburn/imximage.cfg create mode 100644 board/woodburn/lowlevel_init.S create mode 100644 board/woodburn/woodburn.c create mode 100644 common/cmd_sound.c create mode 100644 doc/device-tree-bindings/pwm/tegra20-pwm.txt create mode 100644 doc/device-tree-bindings/video/displaymode.txt create mode 100644 doc/device-tree-bindings/video/tegra20-dc.txt create mode 100644 drivers/power/pmic/pmic_max77686.c create mode 100644 drivers/sound/Makefile create mode 100644 drivers/sound/samsung-i2s.c create mode 100644 drivers/sound/sound.c create mode 100644 drivers/sound/wm8994.c create mode 100644 drivers/sound/wm8994.h create mode 100644 drivers/sound/wm8994_registers.h create mode 100644 drivers/spi/exynos_spi.c create mode 100644 drivers/video/ld9040.c create mode 100644 drivers/video/tegra.c rename arch/arm/cpu/armv7/s5p-common/wdt.c => drivers/watchdog/s5p_wdt.c (100%) create mode 100644 include/configs/woodburn.h create mode 100644 include/configs/woodburn_common.h create mode 100644 include/configs/woodburn_sd.h create mode 100644 include/i2s.h create mode 100644 include/ld9040.h create mode 100644 include/mc34704.h create mode 100644 include/power/max77686_pmic.h create mode 100644 include/sound.h
On 12/11/2012 04:10 AM, Minkyu Kang wrote:
Dear Albert,
How come this includes a bunch of Tegra changes; did you just use the wrong base commit when generating the commit list below?
Simon Glass (17):
Hi Minkyu,
On Tue, 11 Dec 2012 20:10:06 +0900, Minkyu Kang mk7.kang@samsung.com wrote:
Dear Albert,
Apart from Stephen's question, why is this pull request not from your master branch?
Amicalement,
On 14/12/12 04:56, Albert ARIBAUD wrote:
Hi Minkyu,
Dear Albert,
For resolve conflicts. Did I misunderstand your suggestion?
"so I suggest that you merge u-boot/master into your tree (with a comment to the effect that you need this to resolve PMIC vs POWER conflicts) or into an ad hoc branch, and resolve the conflicts there, then send a pull request to me for your resolved tree or branch."
Thanks. Minkyu Kang.
Hi Minkyu,
Hi Minkyu,
Dear Albert,
You're right. I was a bit quick to reply when I read Stephen's question. Can you please address it too?
Amicalement,
Dear Albert,
On Saturday, December 15, 2012, Albert ARIBAUD wrote:
Hi Minkyu,
On Fri, 14 Dec 2012 09:14:11 +0900, Minkyu Kang <mk7.kang@samsung.comjavascript:;
Hi Minkyu,
Dear Albert,
08:47:59 -0700)
Fabio Estevam (24): mx25pdk: Include CONFIG_MX25 mx25pdk: Add esdhc support pmic_fsl: Introduce FSL_PMIC_I2C_LENGTH mx25: Place common functions into sys_proto.h pmic: Add support for mc34704 mx25pdk: Add Ethernet support mx53loco: Allow booting a zImage kernel mx25pdk: Allow booting a zImage kernel mx51evk: Allow booting a zImage kernel mx35pdk: Allow booting a zImage kernel mx6qsabre_common: Allow booting a zImage kernel mx5: Align SPI CS naming with i.MX53 reference manual mx5: Print CSPI clock in 'clock' command spi: mxc_spi: Fix handling of chip select spi: mxc_spi: Fix spi clock glitch durant reset mx6: clock: Only show CSPI clock if CSPI is enabled mx28evk: Configure CONFIG_BOOTDELAY to one second mx53loco: Configure CONFIG_BOOTDELAY to one second mx6qsabrelite: Configure CONFIG_BOOTDELAY to one second mx6qsabre_common: Configure CONFIG_BOOTDELAY to one second mx51evk: Configure CONFIG_BOOTDELAY to one second mx25pdk: Configure CONFIG_BOOTDELAY to one sYou're right. I was
Address for what?
Amicalement,
Albert. _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de javascript:; http://lists.denx.de/mailman/listinfo/u-boot
Hi Minkyu,
On Tue, 18 Dec 2012 00:14:34 +0900, Minkyu Kang promsoft@gmail.com wrote:
Dear Albert,
Hi Minkyu,
Hi Minkyu,
Dear Albert,
08:47:59 -0700)
Address for what?
Can you answer the question Stephen has asked on this list on 11/12 ?
http://www.mail-archive.com/u-boot@lists.denx.de/msg101291.html
Amicalement,
Dear Albert and Stephen,
On 20/12/12 01:28, Albert ARIBAUD wrote:
Hi Minkyu,
Dear Albert,
Hi Minkyu,
Hi Minkyu,
Dear Albert,
08:47:59 -0700)
Address for what?
Comes from u-boot-arm tree. The base of this pull request is u-boot tree, hence some u-boot-arm commits are included. But it doesn't matter maybe.. because this pull request is for u-boot-arm tree.
OK, that might explain it, but isn't there a way to list only the new commits?
Hi Stephen,
On Wed, 19 Dec 2012 23:24:07 -0700, Stephen Warren swarren@wwwdotorg.org wrote:
Yes there is, because when doing the pull request, you don't care where commits come from, you only care where they'll be pulled into. IOW, there is no notion of a 'base' for a pull request: you just specify the destination -- here, u-boot-arm -- and that prints only the needed commits.
Since pull requests do nothing more than print on the standard output, and in order to speed my merging, I'll fetch u-boot-samsung and perform a local pull request from -samsung/master onto -arm/master and check that the resulting commits are ok.
Amicalement,
Hi Minkyu,
Dear Albert,
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
Minkyu Kang
Minkyu Kang
Stephen Warren
