[U-Boot] [PATCH 1/2] sunxi: add proper device tree for Lichee Pi One
Signed-off-by: Icenowy Zheng icenowy@aosc.xyz --- arch/arm/dts/Makefile | 1 + arch/arm/dts/sun5i-a13-licheepi-one.dts | 224 ++++++++++++++++++++++++++++++++ 2 files changed, 225 insertions(+) create mode 100644 arch/arm/dts/sun5i-a13-licheepi-one.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 3ee608b5b4..c1ecf72c3d 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -203,6 +203,7 @@ dtb-$(CONFIG_MACH_SUN5I) += \ sun5i-a13-hsg-h702.dtb \ sun5i-a13-inet-86vs.dtb \ sun5i-a13-inet-98v-rev2.dtb \ + sun5i-a13-licheepi-one.dtb \ sun5i-a13-olinuxino.dtb \ sun5i-a13-olinuxino-micro.dtb \ sun5i-a13-q8-tablet.dtb \ diff --git a/arch/arm/dts/sun5i-a13-licheepi-one.dts b/arch/arm/dts/sun5i-a13-licheepi-one.dts new file mode 100644 index 0000000000..54d0fec858 --- /dev/null +++ b/arch/arm/dts/sun5i-a13-licheepi-one.dts @@ -0,0 +1,224 @@ +/* + * Copyright 2016 Icenowy Zheng icenowy@aosc.xyz + * + * Based on sun5i-a13-olinuxino.dts, which is + * Copyright 2012 Maxime Ripard maxime.ripard@free-electrons.com + * Copyright 2013 Hans de Goede hdegoede@redhat.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; +#include "sun5i-a13.dtsi" +#include "sunxi-common-regulators.dtsi" + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> +#include <dt-bindings/pinctrl/sun4i-a10.h> + +/ { + model = "Lichee Pi One"; + compatible = "licheepi,licheepi-one", "allwinner,sun5i-a13"; + + aliases { + serial0 = &uart1; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + leds { + compatible = "gpio-leds"; + + red { + label ="licheepi:red:usr"; + gpios = <&pio 2 5 GPIO_ACTIVE_LOW>; + }; + + green { + label ="licheepi:green:usr"; + gpios = <&pio 2 19 GPIO_ACTIVE_LOW>; + default-state = "on"; + }; + + blue { + label ="licheepi:blue:usr"; + gpios = <&pio 2 4 GPIO_ACTIVE_LOW>; + }; + + }; +}; + +&cpu0 { + cpu-supply = <®_dcdc2>; +}; + +&ehci0 { + status = "okay"; +}; + +&i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c0_pins_a>; + status = "okay"; + + axp209: pmic@34 { + compatible = "x-powers,axp209"; + reg = <0x34>; + interrupts = <0>; + + interrupt-controller; + #interrupt-cells = <1>; + }; +}; + +&i2c1 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c1_pins_a>; + status = "disabled"; +}; + +&i2c2 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c2_pins_a>; + status = "disabled"; +}; + +&lradc { + vref-supply = <®_ldo2>; + status = "okay"; + + button@984 { + label = "Home"; + linux,code = <KEY_HOMEPAGE>; + channel = <0>; + voltage = <984126>; + }; +}; + +&mmc0 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins_a>; + vmmc-supply = <®_vcc3v3>; + bus-width = <4>; + broken-cd; + status = "okay"; +}; + +&mmc2 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc2_pins_a>; + vmmc-supply = <®_vcc3v3>; + bus-width = <4>; + broken-cd; + status = "okay"; +}; + +&ohci0 { + status = "okay"; +}; + +&otg_sram { + status = "okay"; +}; + +#include "axp209.dtsi" + +®_dcdc2 { + regulator-always-on; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1500000>; + regulator-name = "vdd-cpu"; +}; + +®_dcdc3 { + regulator-always-on; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1400000>; + regulator-name = "vdd-int-dll"; +}; + +®_ldo1 { + regulator-name = "vdd-rtc"; +}; + +®_ldo2 { + regulator-always-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-name = "avcc"; +}; + +®_ldo3 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "csi-1.8v"; +}; + +®_ldo4 { + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-name = "csi-2.8v"; +}; + +®_usb0_vbus { + gpio = <&pio 2 12 GPIO_ACTIVE_HIGH>; /* PC12 */ + status = "okay"; +}; + +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&uart1_pins_b>; + status = "okay"; +}; + +&usb_otg { + dr_mode = "otg"; + status = "okay"; +}; + +&usbphy { + pinctrl-names = "default"; + usb0_id_det-gpio = <&pio 6 2 GPIO_ACTIVE_HIGH>; /* PG2 */ + usb0_vbus_det-gpio = <&pio 6 1 GPIO_ACTIVE_HIGH>; /* PG1 */ + usb0_vbus-supply = <®_usb0_vbus>; + usb1_vbus-supply = <®_vcc5v0>; + status = "okay"; +};
Lichee Pi One is a low-cost Allwinner A13 based development board, with two SD slots, a USB2.0 OTG port, a USB2.0 host port (or onboard Wi-Fi card), optional headers for LCD and CSI and two GPIO headers.
Add support for this board.
Signed-off-by: Icenowy Zheng icenowy@aosc.xyz --- configs/LicheePi_One_defconfig | 26 ++++++++++++++++++++++++++ 1 file changed, 26 insertions(+) create mode 100644 configs/LicheePi_One_defconfig
diff --git a/configs/LicheePi_One_defconfig b/configs/LicheePi_One_defconfig new file mode 100644 index 0000000000..ba8894c9ce --- /dev/null +++ b/configs/LicheePi_One_defconfig @@ -0,0 +1,26 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_SPL_I2C_SUPPORT=y +CONFIG_MACH_SUN5I=y +CONFIG_DRAM_CLK=408 +CONFIG_DRAM_MBUS_CLK=204 +CONFIG_DRAM_ZQ=121 +CONFIG_DRAM_ODT_EN=y +CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_USB0_VBUS_PIN="PC12" +CONFIG_USB0_VBUS_DET="PG1" +CONFIG_USB0_ID_DET="PG2" +CONFIG_AXP_GPIO=y +# CONFIG_VIDEO is not set +CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-licheepi-one" +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" +CONFIG_CONSOLE_MUX=y +CONFIG_SPL=y +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +CONFIG_AXP_ALDO3_VOLT=1800 +CONFIG_AXP_ALDO4_VOLT=2800 +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_MUSB_HOST=y
Can't that be squashed together with the first patch?
Why do you need CONSOLE_MUX?
Maxime
A commit log would be welcome.
Once done, Acked-by: Maxime Ripard maxime.ripard@free-electrons.com
Thanks, Maxime
Icenowy Zheng
Maxime Ripard
