[U-Boot] CONFIG_FIT on mx28evk board
24 Apr
2013
24 Apr
'13
6:44 a.m.
Seeing "Booting kernel from Legacy Image" was starting to make me feel bad ;), so I thought I'd try out what's supposed to be the modern u-boot image format, FIT.
My first attempt on the mx28evk board failed with "Wrong Image Format for bootm command", looking into that I discovered the mx28evk config does not include CONFIG_FIT.
After adding CONFIG_FIT to mx28evk.h and recompiling, FIT images seem to work fine. Is there any particular reason it's not enabled for the mx28evk board? Is FIT not the preferred image type for ARM, or at least this variant of it?
BTW, I was working with the u-boot-arm git repo, updated as of today.
Thanks...
4404
Paul B. Henson
