[U-Boot] [PATCH 1/6] ARM: tegra: allow pinmux mux option not to be set by init tables
Define enum PMUX_FUNC_DEFAULT, which indicates that a table entry passed to pinmux_config_pingrp()/pinmux_config_pingrp_table() shouldn't change the mux option in HW.
For pins that will be used as GPIOs, the mux option is irrelevant, so we simply don't want to define any mux option in the pinmux initialization table.
Signed-off-by: Stephen Warren swarren@nvidia.com --- arch/arm/cpu/tegra-common/pinmux-common.c | 3 +++ arch/arm/include/asm/arch-tegra114/pinmux.h | 1 + arch/arm/include/asm/arch-tegra124/pinmux.h | 1 + arch/arm/include/asm/arch-tegra20/pinmux.h | 1 + arch/arm/include/asm/arch-tegra30/pinmux.h | 1 + 5 files changed, 7 insertions(+)
diff --git a/arch/arm/cpu/tegra-common/pinmux-common.c b/arch/arm/cpu/tegra-common/pinmux-common.c index d62618cd0f61..6d7a7d907b16 100644 --- a/arch/arm/cpu/tegra-common/pinmux-common.c +++ b/arch/arm/cpu/tegra-common/pinmux-common.c @@ -92,6 +92,9 @@ void pinmux_set_func(enum pmux_pingrp pin, enum pmux_func func) int i, mux = -1; u32 val;
+ if (func == PMUX_FUNC_DEFAULT) + return; + /* Error check on pin and func */ assert(pmux_pingrp_isvalid(pin)); assert(pmux_func_isvalid(func)); diff --git a/arch/arm/include/asm/arch-tegra114/pinmux.h b/arch/arm/include/asm/arch-tegra114/pinmux.h index c1cb3ef16b1a..b86562ac6dee 100644 --- a/arch/arm/include/asm/arch-tegra114/pinmux.h +++ b/arch/arm/include/asm/arch-tegra114/pinmux.h @@ -231,6 +231,7 @@ enum pmux_drvgrp { };
enum pmux_func { + PMUX_FUNC_DEFAULT, PMUX_FUNC_BLINK, PMUX_FUNC_CEC, PMUX_FUNC_CLDVFS, diff --git a/arch/arm/include/asm/arch-tegra124/pinmux.h b/arch/arm/include/asm/arch-tegra124/pinmux.h index c49801c21d07..1884935a579e 100644 --- a/arch/arm/include/asm/arch-tegra124/pinmux.h +++ b/arch/arm/include/asm/arch-tegra124/pinmux.h @@ -247,6 +247,7 @@ enum pmux_drvgrp { };
enum pmux_func { + PMUX_FUNC_DEFAULT, PMUX_FUNC_BLINK, PMUX_FUNC_CCLA, PMUX_FUNC_CEC, diff --git a/arch/arm/include/asm/arch-tegra20/pinmux.h b/arch/arm/include/asm/arch-tegra20/pinmux.h index 11c0104ff3e0..f7bc97fe5f73 100644 --- a/arch/arm/include/asm/arch-tegra20/pinmux.h +++ b/arch/arm/include/asm/arch-tegra20/pinmux.h @@ -166,6 +166,7 @@ enum pmux_pingrp { * purely a convenience. The translation is done through a table search. */ enum pmux_func { + PMUX_FUNC_DEFAULT, PMUX_FUNC_AHB_CLK, PMUX_FUNC_APB_CLK, PMUX_FUNC_AUDIO_SYNC, diff --git a/arch/arm/include/asm/arch-tegra30/pinmux.h b/arch/arm/include/asm/arch-tegra30/pinmux.h index 6d83061dc1e9..a42e00990f0c 100644 --- a/arch/arm/include/asm/arch-tegra30/pinmux.h +++ b/arch/arm/include/asm/arch-tegra30/pinmux.h @@ -306,6 +306,7 @@ enum pmux_drvgrp { };
enum pmux_func { + PMUX_FUNC_DEFAULT, PMUX_FUNC_BLINK, PMUX_FUNC_CEC, PMUX_FUNC_CLK_12M_OUT,
The HW-defined procedure for booting Tegra requires that some pins be set up as GPIOs immediately at boot in order to avoid glitches on those pins, when the pinmux is programmed. Add a feature to the GPIO driver which executes a GPIO configuration table. Board files will use this to implement the correct HW initialization procedure.
Signed-off-by: Stephen Warren swarren@nvidia.com --- arch/arm/include/asm/arch-tegra/gpio.h | 20 ++++++++++++++++++++ drivers/gpio/tegra_gpio.c | 20 ++++++++++++++++++++ 2 files changed, 40 insertions(+)
diff --git a/arch/arm/include/asm/arch-tegra/gpio.h b/arch/arm/include/asm/arch-tegra/gpio.h index d97190dd7cf5..44cd455699e7 100644 --- a/arch/arm/include/asm/arch-tegra/gpio.h +++ b/arch/arm/include/asm/arch-tegra/gpio.h @@ -14,11 +14,31 @@ #define GPIO_FULLPORT(x) ((x) >> 3) #define GPIO_BIT(x) ((x) & 0x7)
+enum tegra_gpio_init { + TEGRA_GPIO_INIT_IN, + TEGRA_GPIO_INIT_OUT0, + TEGRA_GPIO_INIT_OUT1, +}; + +struct tegra_gpio_config { + u32 gpio:16; + u32 init:2; +}; + /* * Tegra-specific GPIO API */
+/** + * Configure a list of GPIOs + * + * @param config List of GPIO configurations + * @param len Number of config items in list + */ +void gpio_config_table(const struct tegra_gpio_config *config, int len); + void gpio_info(void);
#define gpio_status() gpio_info() + #endif /* TEGRA_GPIO_H_ */ diff --git a/drivers/gpio/tegra_gpio.c b/drivers/gpio/tegra_gpio.c index 82b30d5ab682..fea9d17f8e62 100644 --- a/drivers/gpio/tegra_gpio.c +++ b/drivers/gpio/tegra_gpio.c @@ -221,6 +221,26 @@ int gpio_set_value(unsigned gpio, int value) return 0; }
+void gpio_config_table(const struct tegra_gpio_config *config, int len) +{ + int i; + + for (i = 0; i < len; i++) { + switch (config[i].init) { + case TEGRA_GPIO_INIT_IN: + gpio_direction_input(config[i].gpio); + break; + case TEGRA_GPIO_INIT_OUT0: + gpio_direction_output(config[i].gpio, 0); + break; + case TEGRA_GPIO_INIT_OUT1: + gpio_direction_output(config[i].gpio, 1); + break; + } + set_config(config[i].gpio, 1); + } +} + /* * Display Tegra GPIO information */
The HW-defined procedure for booting Tegra requires that CLAMP_INPUTS_WHEN_TRISTATED be enabled before programming the pinmux. Add a function to the pinmux driver to allow boards to do this.
Signed-off-by: Stephen Warren swarren@nvidia.com --- arch/arm/cpu/tegra-common/pinmux-common.c | 16 ++++++++++++++++ arch/arm/include/asm/arch-tegra/pinmux.h | 5 +++++ 2 files changed, 21 insertions(+)
diff --git a/arch/arm/cpu/tegra-common/pinmux-common.c b/arch/arm/cpu/tegra-common/pinmux-common.c index 6d7a7d907b16..6e3ab0c14ca2 100644 --- a/arch/arm/cpu/tegra-common/pinmux-common.c +++ b/arch/arm/cpu/tegra-common/pinmux-common.c @@ -86,6 +86,22 @@ #define IO_RESET_SHIFT 8 #define RCV_SEL_SHIFT 9
+#if !defined(CONFIG_TEGRA20) && !defined(CONFIG_TEGRA30) +/* This register/field only exists on Tegra114 and later */ +#define APB_MISC_PP_PINMUX_GLOBAL_0 0x40 +#define CLAMP_INPUTS_WHEN_TRISTATED 1 + +void pinmux_set_tristate_input_clamping(void) +{ + u32 *reg = _R(APB_MISC_PP_PINMUX_GLOBAL_0); + u32 val; + + val = readl(reg); + val |= CLAMP_INPUTS_WHEN_TRISTATED; + writel(val, reg); +} +#endif + void pinmux_set_func(enum pmux_pingrp pin, enum pmux_func func) { u32 *reg = MUX_REG(pin); diff --git a/arch/arm/include/asm/arch-tegra/pinmux.h b/arch/arm/include/asm/arch-tegra/pinmux.h index 035159d66537..da477697bf02 100644 --- a/arch/arm/include/asm/arch-tegra/pinmux.h +++ b/arch/arm/include/asm/arch-tegra/pinmux.h @@ -80,6 +80,11 @@ struct pmux_pingrp_config { #endif };
+#if !defined(CONFIG_TEGRA20) && !defined(CONFIG_TEGRA30) +/* Set the pinmux CLAMP_INPUTS_WHEN_TRISTATED bit */ +void pinmux_set_tristate_input_clamping(void); +#endif + /* Set the mux function for a pin group */ void pinmux_set_func(enum pmux_pingrp pin, enum pmux_func func);
The HW-defined procedure for booting Tegra requires that some pins be set up as GPIOs immediately at boot in order to avoid glitches on those pins, when the pinmux is programmed. This patch implements this procedure for Jetson TK1. For pins which are to be used as GPIOs, the pinmux mux function need not be programmed, so the pinmux table is also adjusted.
Signed-off-by: Stephen Warren swarren@nvidia.com --- board/nvidia/jetson-tk1/jetson-tk1.c | 4 + board/nvidia/jetson-tk1/pinmux-config-jetson-tk1.h | 256 ++++++++++++++------- 2 files changed, 178 insertions(+), 82 deletions(-)
diff --git a/board/nvidia/jetson-tk1/jetson-tk1.c b/board/nvidia/jetson-tk1/jetson-tk1.c index f97aafad422b..9c54bd64c479 100644 --- a/board/nvidia/jetson-tk1/jetson-tk1.c +++ b/board/nvidia/jetson-tk1/jetson-tk1.c @@ -6,6 +6,7 @@ */
#include <common.h> +#include <asm/arch/gpio.h> #include <asm/arch/pinmux.h> #include "pinmux-config-jetson-tk1.h"
@@ -15,6 +16,9 @@ */ void pinmux_init(void) { + gpio_config_table(jetson_tk1_gpio_inits, + ARRAY_SIZE(jetson_tk1_gpio_inits)); + pinmux_config_pingrp_table(jetson_tk1_pingrps, ARRAY_SIZE(jetson_tk1_pingrps));
diff --git a/board/nvidia/jetson-tk1/pinmux-config-jetson-tk1.h b/board/nvidia/jetson-tk1/pinmux-config-jetson-tk1.h index 1adcae4bdded..d338818a64eb 100644 --- a/board/nvidia/jetson-tk1/pinmux-config-jetson-tk1.h +++ b/board/nvidia/jetson-tk1/pinmux-config-jetson-tk1.h @@ -7,6 +7,98 @@ #ifndef _PINMUX_CONFIG_JETSON_TK1_H_ #define _PINMUX_CONFIG_JETSON_TK1_H_
+#define GPIO_INIT(_gpio, _init) \ + { \ + .gpio = GPIO_P##_gpio, \ + .init = TEGRA_GPIO_INIT_##_init, \ + } + +static const struct tegra_gpio_config jetson_tk1_gpio_inits[] = { + /* gpio, init_val */ + GPIO_INIT(C7, IN), + GPIO_INIT(G0, OUT0), + GPIO_INIT(G1, OUT0), + GPIO_INIT(G2, IN), + GPIO_INIT(G3, IN), + GPIO_INIT(H2, OUT0), + GPIO_INIT(H3, OUT0), + GPIO_INIT(H4, IN), + GPIO_INIT(H5, OUT0), + GPIO_INIT(H6, IN), + GPIO_INIT(H7, OUT0), + GPIO_INIT(I0, OUT0), + GPIO_INIT(I2, OUT0), + GPIO_INIT(I4, OUT0), + GPIO_INIT(I5, IN), + GPIO_INIT(I6, IN), + GPIO_INIT(J0, IN), + GPIO_INIT(J2, IN), + GPIO_INIT(K1, OUT0), + GPIO_INIT(K2, IN), + GPIO_INIT(K3, IN), + GPIO_INIT(K4, OUT0), + GPIO_INIT(K5, OUT0), + GPIO_INIT(K6, OUT0), + GPIO_INIT(N7, IN), + GPIO_INIT(O0, IN), + GPIO_INIT(O1, IN), + GPIO_INIT(O2, IN), + GPIO_INIT(O3, IN), + GPIO_INIT(O4, IN), + GPIO_INIT(O5, IN), + GPIO_INIT(O6, OUT0), + GPIO_INIT(O7, IN), + GPIO_INIT(P0, OUT0), + GPIO_INIT(P1, OUT0), + GPIO_INIT(P2, OUT0), + GPIO_INIT(Q0, IN), + GPIO_INIT(Q1, IN), + GPIO_INIT(Q2, IN), + GPIO_INIT(Q5, IN), + GPIO_INIT(Q6, IN), + GPIO_INIT(Q7, IN), + GPIO_INIT(R0, OUT0), + GPIO_INIT(R1, OUT0), + GPIO_INIT(R2, OUT0), + GPIO_INIT(R4, IN), + GPIO_INIT(R5, OUT0), + GPIO_INIT(R7, IN), + GPIO_INIT(S0, IN), + GPIO_INIT(S3, OUT0), + GPIO_INIT(S4, OUT0), + GPIO_INIT(S5, IN), + GPIO_INIT(S6, OUT0), + GPIO_INIT(T0, OUT0), + GPIO_INIT(T1, OUT0), + GPIO_INIT(U0, OUT0), + GPIO_INIT(U1, IN), + GPIO_INIT(U2, IN), + GPIO_INIT(U3, OUT0), + GPIO_INIT(U4, OUT0), + GPIO_INIT(U5, IN), + GPIO_INIT(U6, IN), + GPIO_INIT(V0, IN), + GPIO_INIT(V1, IN), + GPIO_INIT(W2, IN), + GPIO_INIT(W3, IN), + GPIO_INIT(X1, OUT0), + GPIO_INIT(X3, IN), + GPIO_INIT(X4, OUT0), + GPIO_INIT(X5, IN), + GPIO_INIT(X6, IN), + GPIO_INIT(X7, OUT0), + GPIO_INIT(BB3, OUT0), + GPIO_INIT(BB5, OUT0), + GPIO_INIT(BB6, OUT0), + GPIO_INIT(BB7, OUT0), + GPIO_INIT(CC1, IN), + GPIO_INIT(CC2, IN), + GPIO_INIT(CC5, OUT0), + GPIO_INIT(EE1, OUT0), + GPIO_INIT(FF1, OUT0), + GPIO_INIT(FF2, IN), +}; + #define PINCFG(_pingrp, _mux, _pull, _tri, _io, _od, _rcv_sel) \ { \ .pingrp = PMUX_PINGRP_##_pingrp, \ @@ -41,43 +133,43 @@ static const struct pmux_pingrp_config jetson_tk1_pingrps[] = { PINCFG(UART2_RXD_PC3, IRDA, UP, NORMAL, INPUT, DEFAULT, DEFAULT), PINCFG(GEN1_I2C_SCL_PC4, I2C1, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), PINCFG(GEN1_I2C_SDA_PC5, I2C1, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), - PINCFG(PC7, RSVD1, UP, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(PG0, RSVD1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), - PINCFG(PG1, RSVD1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), - PINCFG(PG2, RSVD1, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(PG3, RSVD1, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PC7, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PG0, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PG1, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PG2, DEFAULT, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PG3, DEFAULT, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), PINCFG(PG4, SPI4, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), PINCFG(PG5, SPI4, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), PINCFG(PG6, SPI4, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), PINCFG(PG7, SPI4, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), PINCFG(PH0, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), PINCFG(PH1, PWM1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), - PINCFG(PH2, GMI, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), - PINCFG(PH3, GMI, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), - PINCFG(PH4, RSVD2, UP, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(PH5, RSVD2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), - PINCFG(PH6, GMI, UP, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(PH7, GMI, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), - PINCFG(PI0, RSVD1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH2, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH3, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH4, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PH5, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH6, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PH7, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PI0, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), PINCFG(PI1, RSVD1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), - PINCFG(PI2, RSVD4, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PI2, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), PINCFG(PI3, SPI4, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), - PINCFG(PI4, GMI, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), - PINCFG(PI5, RSVD2, UP, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(PI6, RSVD1, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PI4, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PI5, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PI6, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), PINCFG(PI7, RSVD1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), - PINCFG(PJ0, RSVD1, UP, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(PJ2, RSVD1, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PJ0, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PJ2, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), PINCFG(UART2_CTS_N_PJ5, UARTB, UP, NORMAL, INPUT, DEFAULT, DEFAULT), PINCFG(UART2_RTS_N_PJ6, UARTB, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), PINCFG(PJ7, UARTD, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), PINCFG(PK0, SOC, UP, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(PK1, RSVD4, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), - PINCFG(PK2, RSVD1, UP, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(PK3, GMI, UP, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(PK4, RSVD2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), - PINCFG(SPDIF_OUT_PK5, RSVD2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), - PINCFG(SPDIF_IN_PK6, RSVD2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PK1, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PK2, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PK3, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PK4, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SPDIF_OUT_PK5, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SPDIF_IN_PK6, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), PINCFG(PK7, UARTD, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), PINCFG(DAP1_FS_PN0, I2S0, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), PINCFG(DAP1_DIN_PN1, I2S0, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), @@ -85,79 +177,79 @@ static const struct pmux_pingrp_config jetson_tk1_pingrps[] = { PINCFG(DAP1_SCLK_PN3, I2S0, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), PINCFG(USB_VBUS_EN0_PN4, USB, UP, NORMAL, INPUT, ENABLE, DEFAULT), PINCFG(USB_VBUS_EN1_PN5, USB, UP, NORMAL, INPUT, ENABLE, DEFAULT), - PINCFG(HDMI_INT_PN7, RSVD1, DOWN, NORMAL, INPUT, DEFAULT, NORMAL), - PINCFG(ULPI_DATA7_PO0, ULPI, UP, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(ULPI_DATA0_PO1, ULPI, UP, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(ULPI_DATA1_PO2, ULPI, UP, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(ULPI_DATA2_PO3, ULPI, UP, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(ULPI_DATA3_PO4, ULPI, UP, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(ULPI_DATA4_PO5, ULPI, UP, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(ULPI_DATA5_PO6, ULPI, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), - PINCFG(ULPI_DATA6_PO7, ULPI, UP, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(DAP3_FS_PP0, I2S2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), - PINCFG(DAP3_DIN_PP1, I2S2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), - PINCFG(DAP3_DOUT_PP2, RSVD4, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(HDMI_INT_PN7, DEFAULT, DOWN, NORMAL, INPUT, DEFAULT, NORMAL), + PINCFG(ULPI_DATA7_PO0, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA0_PO1, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA1_PO2, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA2_PO3, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA3_PO4, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA4_PO5, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA5_PO6, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA6_PO7, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP3_FS_PP0, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP3_DIN_PP1, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP3_DOUT_PP2, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), PINCFG(DAP3_SCLK_PP3, RSVD3, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), PINCFG(DAP4_FS_PP4, I2S3, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), PINCFG(DAP4_DIN_PP5, I2S3, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), PINCFG(DAP4_DOUT_PP6, I2S3, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), PINCFG(DAP4_SCLK_PP7, I2S3, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(KB_COL0_PQ0, RSVD2, UP, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(KB_COL1_PQ1, RSVD2, UP, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(KB_COL2_PQ2, RSVD2, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL0_PQ0, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL1_PQ1, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL2_PQ2, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), PINCFG(KB_COL3_PQ3, KBC, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), PINCFG(KB_COL4_PQ4, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(KB_COL5_PQ5, RSVD2, UP, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(KB_COL6_PQ6, RSVD2, UP, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(KB_COL7_PQ7, RSVD2, UP, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(KB_ROW0_PR0, RSVD2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), - PINCFG(KB_ROW1_PR1, RSVD2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), - PINCFG(KB_ROW2_PR2, RSVD2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL5_PQ5, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL6_PQ6, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL7_PQ7, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW0_PR0, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW1_PR1, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW2_PR2, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), PINCFG(KB_ROW3_PR3, SYS, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), - PINCFG(KB_ROW4_PR4, RSVD3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(KB_ROW5_PR5, RSVD3, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW4_PR4, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW5_PR5, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), PINCFG(KB_ROW6_PR6, DISPLAYA_ALT, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(KB_ROW7_PR7, RSVD2, UP, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(KB_ROW8_PS0, RSVD2, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW7_PR7, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW8_PS0, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), PINCFG(KB_ROW9_PS1, RSVD2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), PINCFG(KB_ROW10_PS2, RSVD2, UP, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(KB_ROW11_PS3, RSVD2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), - PINCFG(KB_ROW12_PS4, RSVD2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), - PINCFG(KB_ROW13_PS5, RSVD2, UP, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(KB_ROW14_PS6, RSVD2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW11_PS3, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW12_PS4, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW13_PS5, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW14_PS6, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), PINCFG(KB_ROW15_PS7, SOC, UP, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(KB_ROW16_PT0, RSVD2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), - PINCFG(KB_ROW17_PT1, RSVD2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW16_PT0, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW17_PT1, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), PINCFG(GEN2_I2C_SCL_PT5, I2C2, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), PINCFG(GEN2_I2C_SDA_PT6, I2C2, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), PINCFG(SDMMC4_CMD_PT7, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(PU0, RSVD4, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), - PINCFG(PU1, RSVD1, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(PU2, RSVD1, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(PU3, GMI, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), - PINCFG(PU4, GMI, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), - PINCFG(PU5, GMI, UP, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(PU6, RSVD3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(PV0, RSVD1, UP, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(PV1, RSVD1, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PU0, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PU1, DEFAULT, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PU2, DEFAULT, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PU3, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PU4, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PU5, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PU6, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PV0, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PV1, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), PINCFG(SDMMC3_CD_N_PV2, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), PINCFG(SDMMC1_WP_N_PV3, SDMMC1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), PINCFG(DDC_SCL_PV4, I2C4, NORMAL, NORMAL, INPUT, DEFAULT, NORMAL), PINCFG(DDC_SDA_PV5, I2C4, NORMAL, NORMAL, INPUT, DEFAULT, NORMAL), - PINCFG(GPIO_W2_AUD_PW2, RSVD2, UP, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(GPIO_W3_AUD_PW3, SPI6, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_W2_AUD_PW2, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_W3_AUD_PW3, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), PINCFG(DAP_MCLK1_PW4, EXTPERIPH1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), PINCFG(CLK2_OUT_PW5, EXTPERIPH2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), PINCFG(UART3_TXD_PW6, UARTC, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), PINCFG(UART3_RXD_PW7, UARTC, UP, NORMAL, INPUT, DEFAULT, DEFAULT), PINCFG(DVFS_PWM_PX0, CLDVFS, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), - PINCFG(GPIO_X1_AUD_PX1, RSVD2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X1_AUD_PX1, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), PINCFG(DVFS_CLK_PX2, CLDVFS, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), - PINCFG(GPIO_X3_AUD_PX3, RSVD4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(GPIO_X4_AUD_PX4, GMI, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), - PINCFG(GPIO_X5_AUD_PX5, RSVD4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(GPIO_X6_AUD_PX6, GMI, UP, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(GPIO_X7_AUD_PX7, RSVD1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X3_AUD_PX3, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X4_AUD_PX4, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X5_AUD_PX5, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X6_AUD_PX6, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X7_AUD_PX7, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), PINCFG(ULPI_CLK_PY0, SPI1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), PINCFG(ULPI_DIR_PY1, SPI1, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), PINCFG(ULPI_NXT_PY2, SPI1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), @@ -181,25 +273,25 @@ static const struct pmux_pingrp_config jetson_tk1_pingrps[] = { PINCFG(PBB0, VIMCLK2_ALT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), PINCFG(CAM_I2C_SCL_PBB1, I2C3, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), PINCFG(CAM_I2C_SDA_PBB2, I2C3, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), - PINCFG(PBB3, VGP3, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PBB3, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), PINCFG(PBB4, VGP4, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), - PINCFG(PBB5, RSVD3, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), - PINCFG(PBB6, RSVD2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), - PINCFG(PBB7, RSVD2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PBB5, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PBB6, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PBB7, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), PINCFG(CAM_MCLK_PCC0, VI_ALT3, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), - PINCFG(PCC1, RSVD2, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(PCC2, RSVD2, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PCC1, DEFAULT, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PCC2, DEFAULT, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), PINCFG(SDMMC4_CLK_PCC4, SDMMC4, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(CLK2_REQ_PCC5, RSVD2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(CLK2_REQ_PCC5, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), PINCFG(CLK3_OUT_PEE0, EXTPERIPH3, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), - PINCFG(CLK3_REQ_PEE1, RSVD2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(CLK3_REQ_PEE1, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), PINCFG(DAP_MCLK1_REQ_PEE2, SATA, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), PINCFG(HDMI_CEC_PEE3, CEC, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), PINCFG(SDMMC3_CLK_LB_OUT_PEE4, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), PINCFG(SDMMC3_CLK_LB_IN_PEE5, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), PINCFG(DP_HPD_PFF0, DP, UP, NORMAL, INPUT, DEFAULT, DEFAULT), - PINCFG(USB_VBUS_EN2_PFF1, RSVD2, NORMAL, NORMAL, OUTPUT, DISABLE, DEFAULT), - PINCFG(PFF2, RSVD2, UP, NORMAL, INPUT, DISABLE, DEFAULT), + PINCFG(USB_VBUS_EN2_PFF1, DEFAULT, NORMAL, NORMAL, OUTPUT, DISABLE, DEFAULT), + PINCFG(PFF2, DEFAULT, UP, NORMAL, INPUT, DISABLE, DEFAULT), PINCFG(CORE_PWR_REQ, PWRON, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), PINCFG(CPU_PWR_REQ, RSVD2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), PINCFG(PWR_INT_N, PMI, UP, NORMAL, INPUT, DEFAULT, DEFAULT),
The HW-defined procedure for booting Tegra requires that CLAMP_INPUTS_WHEN_TRISTATED be enabled before programming the pinmux. Modify the Jetson TK1 board to do this.
Signed-off-by: Stephen Warren swarren@nvidia.com --- board/nvidia/jetson-tk1/jetson-tk1.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/board/nvidia/jetson-tk1/jetson-tk1.c b/board/nvidia/jetson-tk1/jetson-tk1.c index 9c54bd64c479..5d37718f3b89 100644 --- a/board/nvidia/jetson-tk1/jetson-tk1.c +++ b/board/nvidia/jetson-tk1/jetson-tk1.c @@ -16,6 +16,8 @@ */ void pinmux_init(void) { + pinmux_set_tristate_input_clamping(); + gpio_config_table(jetson_tk1_gpio_inits, ARRAY_SIZE(jetson_tk1_gpio_inits));
This re-imports the entire Venice2 pinmux data from the board's master spreadsheet, and makes use of the new IO clamping GPIO initialization table features. This makes the board port fully compliant with the required HW-defined pinmux initialization sequence.
Signed-off-by: Stephen Warren swarren@nvidia.com --- board/nvidia/venice2/pinmux-config-venice2.h | 563 ++++++++++++--------------- board/nvidia/venice2/venice2.c | 19 +- 2 files changed, 266 insertions(+), 316 deletions(-)
diff --git a/board/nvidia/venice2/pinmux-config-venice2.h b/board/nvidia/venice2/pinmux-config-venice2.h index 2f79ec75237e..05f3dab89dcd 100644 --- a/board/nvidia/venice2/pinmux-config-venice2.h +++ b/board/nvidia/venice2/pinmux-config-venice2.h @@ -1,76 +1,282 @@ /* - * (C) Copyright 2013 - * NVIDIA Corporation <www.nvidia.com> + * Copyright (c) 2013-2014, NVIDIA CORPORATION. All rights reserved. * - * SPDX-License-Identifier: GPL-2.0+ + * SPDX-License-Identifier: GPL-2.0+ */
#ifndef _PINMUX_CONFIG_VENICE2_H_ #define _PINMUX_CONFIG_VENICE2_H_
-#define DEFAULT_PINMUX(_pingrp, _mux, _pull, _tri, _io) \ - { \ - .pingrp = PMUX_PINGRP_##_pingrp, \ - .func = PMUX_FUNC_##_mux, \ - .pull = PMUX_PULL_##_pull, \ - .tristate = PMUX_TRI_##_tri, \ - .io = PMUX_PIN_##_io, \ - .lock = PMUX_PIN_LOCK_DEFAULT, \ - .od = PMUX_PIN_OD_DEFAULT, \ - .ioreset = PMUX_PIN_IO_RESET_DEFAULT, \ +#define GPIO_INIT(_gpio, _init) \ + { \ + .gpio = GPIO_P##_gpio, \ + .init = TEGRA_GPIO_INIT_##_init, \ }
-#define I2C_PINMUX(_pingrp, _mux, _pull, _tri, _io, _lock, _od) \ - { \ - .pingrp = PMUX_PINGRP_##_pingrp, \ - .func = PMUX_FUNC_##_mux, \ - .pull = PMUX_PULL_##_pull, \ - .tristate = PMUX_TRI_##_tri, \ - .io = PMUX_PIN_##_io, \ - .lock = PMUX_PIN_LOCK_##_lock, \ - .od = PMUX_PIN_OD_##_od, \ - .ioreset = PMUX_PIN_IO_RESET_DEFAULT, \ - } +static const struct tegra_gpio_config venice2_gpio_inits[] = { + /* gpio, init_val */ + GPIO_INIT(A0, IN), + GPIO_INIT(C7, IN), + GPIO_INIT(G0, IN), + GPIO_INIT(G1, IN), + GPIO_INIT(G2, IN), + GPIO_INIT(G3, IN), + GPIO_INIT(H2, IN), + GPIO_INIT(H4, IN), + GPIO_INIT(H5, OUT0), + GPIO_INIT(H6, IN), + GPIO_INIT(H7, OUT1), + GPIO_INIT(I0, IN), + GPIO_INIT(I1, IN), + GPIO_INIT(I2, OUT0), + GPIO_INIT(I4, OUT0), + GPIO_INIT(I6, IN), + GPIO_INIT(J0, IN), + GPIO_INIT(J7, IN), + GPIO_INIT(K0, IN), + GPIO_INIT(K1, OUT0), + GPIO_INIT(K2, IN), + GPIO_INIT(K3, IN), + GPIO_INIT(K4, OUT0), + GPIO_INIT(K6, OUT0), + GPIO_INIT(K7, IN), + GPIO_INIT(N7, IN), + GPIO_INIT(O2, IN), + GPIO_INIT(O5, IN), + GPIO_INIT(O6, OUT0), + GPIO_INIT(O7, IN), + GPIO_INIT(P2, OUT0), + GPIO_INIT(Q0, IN), + GPIO_INIT(Q3, IN), + GPIO_INIT(R0, OUT0), + GPIO_INIT(R1, IN), + GPIO_INIT(R4, IN), + GPIO_INIT(S0, IN), + GPIO_INIT(S3, OUT0), + GPIO_INIT(S4, OUT0), + GPIO_INIT(S7, IN), + GPIO_INIT(T1, IN), + GPIO_INIT(U4, IN), + GPIO_INIT(U5, IN), + GPIO_INIT(U6, IN), + GPIO_INIT(V0, IN), + GPIO_INIT(V1, IN), + GPIO_INIT(W3, IN), + GPIO_INIT(X1, IN), + GPIO_INIT(X3, IN), + GPIO_INIT(X4, IN), + GPIO_INIT(X7, OUT0), + GPIO_INIT(CC5, OUT0), +};
-#define DDC_PINMUX(_pingrp, _mux, _pull, _tri, _io, _lock, _rcv_sel) \ +#define PINCFG(_pingrp, _mux, _pull, _tri, _io, _od, _rcv_sel) \ { \ .pingrp = PMUX_PINGRP_##_pingrp, \ .func = PMUX_FUNC_##_mux, \ .pull = PMUX_PULL_##_pull, \ .tristate = PMUX_TRI_##_tri, \ .io = PMUX_PIN_##_io, \ - .lock = PMUX_PIN_LOCK_##_lock, \ + .od = PMUX_PIN_OD_##_od, \ .rcv_sel = PMUX_PIN_RCV_SEL_##_rcv_sel, \ + .lock = PMUX_PIN_LOCK_DEFAULT, \ .ioreset = PMUX_PIN_IO_RESET_DEFAULT, \ }
-#define VI_PINMUX(_pingrp, _mux, _pull, _tri, _io, _lock, _ioreset) \ - { \ - .pingrp = PMUX_PINGRP_##_pingrp, \ - .func = PMUX_FUNC_##_mux, \ - .pull = PMUX_PULL_##_pull, \ - .tristate = PMUX_TRI_##_tri, \ - .io = PMUX_PIN_##_io, \ - .lock = PMUX_PIN_LOCK_##_lock, \ - .od = PMUX_PIN_OD_DEFAULT, \ - .ioreset = PMUX_PIN_IO_RESET_##_ioreset \ - } - -#define CEC_PINMUX(_pingrp, _mux, _pull, _tri, _io, _lock, _od) \ - { \ - .pingrp = PMUX_PINGRP_##_pingrp, \ - .func = PMUX_FUNC_##_mux, \ - .pull = PMUX_PULL_##_pull, \ - .tristate = PMUX_TRI_##_tri, \ - .io = PMUX_PIN_##_io, \ - .lock = PMUX_PIN_LOCK_##_lock, \ - .od = PMUX_PIN_OD_##_od, \ - .ioreset = PMUX_PIN_IO_RESET_DEFAULT, \ - } - -#define USB_PINMUX CEC_PINMUX +static const struct pmux_pingrp_config venice2_pingrps[] = { + /* pingrp, mux, pull, tri, e_input, od, rcv_sel */ + PINCFG(CLK_32K_OUT_PA0, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(UART3_CTS_N_PA1, UARTC, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP2_FS_PA2, I2S1, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP2_SCLK_PA3, I2S1, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP2_DIN_PA4, I2S1, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP2_DOUT_PA5, I2S1, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_CLK_PA6, SDMMC3, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_CMD_PA7, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PB0, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PB1, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_DAT3_PB4, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_DAT2_PB5, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_DAT1_PB6, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_DAT0_PB7, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(UART3_RTS_N_PC0, UARTC, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(UART2_TXD_PC2, IRDA, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(UART2_RXD_PC3, IRDA, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(GEN1_I2C_SCL_PC4, I2C1, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(GEN1_I2C_SDA_PC5, I2C1, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(PC7, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PG0, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PG1, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PG2, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PG3, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PG4, SPI4, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PG5, SPI4, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PG6, SPI4, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PG7, SPI4, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PH0, PWM0, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH1, PWM1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH2, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PH3, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH4, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PH5, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH6, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PH7, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PI0, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PI1, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PI2, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PI3, SPI4, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PI4, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PI5, RSVD2, UP, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PI6, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PI7, RSVD1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PJ0, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PJ2, RSVD1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(UART2_CTS_N_PJ5, UARTB, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(UART2_RTS_N_PJ6, UARTB, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PJ7, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PK0, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PK1, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PK2, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PK3, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PK4, DEFAULT, UP, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SPDIF_OUT_PK5, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SPDIF_IN_PK6, DEFAULT, DOWN, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PK7, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP1_FS_PN0, I2S0, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP1_DIN_PN1, I2S0, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP1_DOUT_PN2, I2S0, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP1_SCLK_PN3, I2S0, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(USB_VBUS_EN0_PN4, USB, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(USB_VBUS_EN1_PN5, USB, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(HDMI_INT_PN7, DEFAULT, DOWN, NORMAL, INPUT, DEFAULT, NORMAL), + PINCFG(ULPI_DATA7_PO0, ULPI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA0_PO1, ULPI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA1_PO2, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA2_PO3, ULPI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA3_PO4, ULPI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA4_PO5, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA5_PO6, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA6_PO7, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP3_FS_PP0, I2S2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP3_DIN_PP1, I2S2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP3_DOUT_PP2, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP3_SCLK_PP3, RSVD3, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP4_FS_PP4, I2S3, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP4_DIN_PP5, I2S3, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP4_DOUT_PP6, I2S3, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP4_SCLK_PP7, I2S3, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL0_PQ0, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL1_PQ1, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL2_PQ2, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL3_PQ3, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL4_PQ4, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL5_PQ5, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL6_PQ6, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL7_PQ7, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW0_PR0, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW1_PR1, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW2_PR2, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW3_PR3, KBC, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW4_PR4, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW5_PR5, RSVD3, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW6_PR6, KBC, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW7_PR7, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW8_PS0, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW9_PS1, UARTA, DOWN, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW10_PS2, UARTA, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW11_PS3, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW12_PS4, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW13_PS5, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW14_PS6, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW15_PS7, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW16_PT0, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW17_PT1, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(GEN2_I2C_SCL_PT5, I2C2, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(GEN2_I2C_SDA_PT6, I2C2, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(SDMMC4_CMD_PT7, SDMMC4, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PU0, UARTA, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PU1, UARTA, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PU2, UARTA, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PU3, UARTA, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PU4, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PU5, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PU6, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PV0, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PV1, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_CD_N_PV2, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_WP_N_PV3, SDMMC1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DDC_SCL_PV4, I2C4, NORMAL, NORMAL, INPUT, DEFAULT, NORMAL), + PINCFG(DDC_SDA_PV5, I2C4, NORMAL, NORMAL, INPUT, DEFAULT, NORMAL), + PINCFG(GPIO_W2_AUD_PW2, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_W3_AUD_PW3, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP_MCLK1_PW4, EXTPERIPH1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(CLK2_OUT_PW5, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(UART3_TXD_PW6, UARTC, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(UART3_RXD_PW7, UARTC, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DVFS_PWM_PX0, CLDVFS, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X1_AUD_PX1, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DVFS_CLK_PX2, CLDVFS, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X3_AUD_PX3, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X4_AUD_PX4, DEFAULT, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X5_AUD_PX5, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X6_AUD_PX6, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X7_AUD_PX7, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_CLK_PY0, SPI1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DIR_PY1, SPI1, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_NXT_PY2, SPI1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_STP_PY3, SPI1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_DAT3_PY4, SDMMC1, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_DAT2_PY5, SDMMC1, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_DAT1_PY6, SDMMC1, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_DAT0_PY7, SDMMC1, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_CLK_PZ0, SDMMC1, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_CMD_PZ1, SDMMC1, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PWR_I2C_SCL_PZ6, I2CPWR, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(PWR_I2C_SDA_PZ7, I2CPWR, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(SDMMC4_DAT0_PAA0, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT1_PAA1, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT2_PAA2, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT3_PAA3, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT4_PAA4, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT5_PAA5, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT6_PAA6, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT7_PAA7, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PBB0, VGP6, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(CAM_I2C_SCL_PBB1, I2C3, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(CAM_I2C_SDA_PBB2, I2C3, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(PBB3, VGP3, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PBB4, VGP4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PBB5, RSVD3, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PBB6, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PBB7, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(CAM_MCLK_PCC0, VI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PCC1, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PCC2, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_CLK_PCC4, SDMMC4, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(CLK2_REQ_PCC5, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PEX_L0_RST_N_PDD1, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PEX_L0_CLKREQ_N_PDD2, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PEX_WAKE_N_PDD3, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PEX_L1_RST_N_PDD5, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PEX_L1_CLKREQ_N_PDD6, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(CLK3_OUT_PEE0, EXTPERIPH3, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(CLK3_REQ_PEE1, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP_MCLK1_REQ_PEE2, RSVD4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(HDMI_CEC_PEE3, CEC, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(SDMMC3_CLK_LB_OUT_PEE4, SDMMC3, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_CLK_LB_IN_PEE5, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DP_HPD_PFF0, DP, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(USB_VBUS_EN2_PFF1, RSVD2, DOWN, TRISTATE, OUTPUT, DISABLE, DEFAULT), + PINCFG(PFF2, RSVD2, DOWN, TRISTATE, OUTPUT, DISABLE, DEFAULT), + PINCFG(CORE_PWR_REQ, PWRON, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(CPU_PWR_REQ, CPU, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PWR_INT_N, PMI, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(RESET_OUT_N, RESET_OUT_N, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(OWR, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, NORMAL), + PINCFG(CLK_32K_IN, CLK, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(JTAG_RTCK, RTCK, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), +};
-#define DEFAULT_PADCFG(_drvgrp, _slwf, _slwr, _drvup, _drvdn, _lpmd, _schmt, _hsm) \ +#define DRVCFG(_drvgrp, _slwf, _slwr, _drvup, _drvdn, _lpmd, _schmt, _hsm) \ { \ .drvgrp = PMUX_DRVGRP_##_drvgrp, \ .slwf = _slwf, \ @@ -82,258 +288,7 @@ .hsm = PMUX_HSM_##_hsm, \ }
-static struct pmux_pingrp_config tegra124_pinmux_common[] = { - /* EXTPERIPH1 pinmux */ - DEFAULT_PINMUX(DAP_MCLK1_PW4, EXTPERIPH1, NORMAL, NORMAL, OUTPUT), - - /* I2S0 pinmux */ - DEFAULT_PINMUX(DAP1_DIN_PN1, I2S0, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(DAP1_DOUT_PN2, I2S0, NORMAL, NORMAL, INPUT), - DEFAULT_PINMUX(DAP1_FS_PN0, I2S0, NORMAL, NORMAL, INPUT), - DEFAULT_PINMUX(DAP1_SCLK_PN3, I2S0, NORMAL, NORMAL, INPUT), - - /* I2S1 pinmux */ - DEFAULT_PINMUX(DAP2_DIN_PA4, I2S1, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(DAP2_DOUT_PA5, I2S1, NORMAL, NORMAL, INPUT), - DEFAULT_PINMUX(DAP2_FS_PA2, I2S1, NORMAL, NORMAL, INPUT), - DEFAULT_PINMUX(DAP2_SCLK_PA3, I2S1, NORMAL, NORMAL, INPUT), - - /* I2S3 pinmux */ - DEFAULT_PINMUX(DAP4_DIN_PP5, I2S3, NORMAL, NORMAL, INPUT), - DEFAULT_PINMUX(DAP4_DOUT_PP6, I2S3, NORMAL, NORMAL, INPUT), - DEFAULT_PINMUX(DAP4_FS_PP4, I2S3, NORMAL, NORMAL, INPUT), - DEFAULT_PINMUX(DAP4_SCLK_PP7, I2S3, NORMAL, NORMAL, INPUT), - - /* CLDVFS pinmux */ - DEFAULT_PINMUX(DVFS_PWM_PX0, CLDVFS, NORMAL, NORMAL, OUTPUT), - DEFAULT_PINMUX(DVFS_CLK_PX2, CLDVFS, NORMAL, NORMAL, OUTPUT), - - /* ULPI pinmux */ - DEFAULT_PINMUX(ULPI_DATA0_PO1, ULPI, NORMAL, NORMAL, INPUT), - DEFAULT_PINMUX(ULPI_DATA1_PO2, ULPI, NORMAL, NORMAL, INPUT), - DEFAULT_PINMUX(ULPI_DATA2_PO3, ULPI, NORMAL, NORMAL, INPUT), - DEFAULT_PINMUX(ULPI_DATA3_PO4, ULPI, NORMAL, NORMAL, INPUT), - DEFAULT_PINMUX(ULPI_DATA4_PO5, ULPI, UP, NORMAL, INPUT), - DEFAULT_PINMUX(ULPI_DATA5_PO6, ULPI, UP, NORMAL, INPUT), - DEFAULT_PINMUX(ULPI_DATA6_PO7, ULPI, NORMAL, NORMAL, INPUT), - - /* EC KBC/SPI */ - DEFAULT_PINMUX(ULPI_CLK_PY0, SPI1, UP, NORMAL, INPUT), - DEFAULT_PINMUX(ULPI_DIR_PY1, SPI1, UP, NORMAL, INPUT), - DEFAULT_PINMUX(ULPI_NXT_PY2, SPI1, NORMAL, NORMAL, INPUT), - DEFAULT_PINMUX(ULPI_STP_PY3, SPI1, NORMAL, NORMAL, INPUT), - - /* I2C3 (TPM) pinmux */ - I2C_PINMUX(CAM_I2C_SCL_PBB1, I2C3, NORMAL, NORMAL, INPUT, DEFAULT, ENABLE), - I2C_PINMUX(CAM_I2C_SDA_PBB2, I2C3, NORMAL, NORMAL, INPUT, DEFAULT, ENABLE), - - /* I2C2 pinmux */ - I2C_PINMUX(GEN2_I2C_SCL_PT5, I2C2, NORMAL, NORMAL, INPUT, DEFAULT, ENABLE), - I2C_PINMUX(GEN2_I2C_SDA_PT6, I2C2, NORMAL, NORMAL, INPUT, DEFAULT, ENABLE), - - /* UARTD pinmux (UART4 on Servo board, unused) */ - DEFAULT_PINMUX(PJ7, UARTD, NORMAL, NORMAL, OUTPUT), - DEFAULT_PINMUX(PB0, UARTD, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(PB1, UARTD, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(PK7, UARTD, NORMAL, NORMAL, OUTPUT), - - /* SPI4 (Winbond 'boot ROM') */ - DEFAULT_PINMUX(PG5, SPI4, NORMAL, NORMAL, INPUT), - DEFAULT_PINMUX(PG6, SPI4, UP, NORMAL, INPUT), - DEFAULT_PINMUX(PG7, SPI4, UP, NORMAL, INPUT), - DEFAULT_PINMUX(PI3, SPI4, NORMAL, NORMAL, INPUT), - - /* Touch IRQ */ - DEFAULT_PINMUX(GPIO_W3_AUD_PW3, RSVD1, NORMAL, NORMAL, INPUT), - - /* PWM1 pinmux */ - DEFAULT_PINMUX(PH1, PWM1, NORMAL, NORMAL, OUTPUT), - - /* SDMMC1 pinmux */ - DEFAULT_PINMUX(SDMMC1_CLK_PZ0, SDMMC1, NORMAL, NORMAL, INPUT), - DEFAULT_PINMUX(SDMMC1_CMD_PZ1, SDMMC1, UP, NORMAL, INPUT), - DEFAULT_PINMUX(SDMMC1_DAT0_PY7, SDMMC1, UP, NORMAL, INPUT), - DEFAULT_PINMUX(SDMMC1_DAT1_PY6, SDMMC1, UP, NORMAL, INPUT), - DEFAULT_PINMUX(SDMMC1_DAT2_PY5, SDMMC1, UP, NORMAL, INPUT), - DEFAULT_PINMUX(SDMMC1_DAT3_PY4, SDMMC1, UP, NORMAL, INPUT), - - /* SDMMC3 pinmux */ - DEFAULT_PINMUX(SDMMC3_CLK_PA6, SDMMC3, NORMAL, NORMAL, INPUT), - DEFAULT_PINMUX(SDMMC3_CMD_PA7, SDMMC3, UP, NORMAL, INPUT), - DEFAULT_PINMUX(SDMMC3_DAT0_PB7, SDMMC3, UP, NORMAL, INPUT), - DEFAULT_PINMUX(SDMMC3_DAT1_PB6, SDMMC3, UP, NORMAL, INPUT), - DEFAULT_PINMUX(SDMMC3_DAT2_PB5, SDMMC3, UP, NORMAL, INPUT), - DEFAULT_PINMUX(SDMMC3_DAT3_PB4, SDMMC3, UP, NORMAL, INPUT), - DEFAULT_PINMUX(SDMMC3_CLK_LB_IN_PEE5, SDMMC3, UP, TRISTATE, INPUT), - DEFAULT_PINMUX(SDMMC3_CLK_LB_OUT_PEE4, SDMMC3, DOWN, NORMAL, INPUT), - - /* SDMMC4 pinmux */ - DEFAULT_PINMUX(SDMMC4_CLK_PCC4, SDMMC4, NORMAL, NORMAL, INPUT), - DEFAULT_PINMUX(SDMMC4_CMD_PT7, SDMMC4, UP, NORMAL, INPUT), - DEFAULT_PINMUX(SDMMC4_DAT0_PAA0, SDMMC4, UP, NORMAL, INPUT), - DEFAULT_PINMUX(SDMMC4_DAT1_PAA1, SDMMC4, UP, NORMAL, INPUT), - DEFAULT_PINMUX(SDMMC4_DAT2_PAA2, SDMMC4, UP, NORMAL, INPUT), - DEFAULT_PINMUX(SDMMC4_DAT3_PAA3, SDMMC4, UP, NORMAL, INPUT), - DEFAULT_PINMUX(SDMMC4_DAT4_PAA4, SDMMC4, UP, NORMAL, INPUT), - DEFAULT_PINMUX(SDMMC4_DAT5_PAA5, SDMMC4, UP, NORMAL, INPUT), - DEFAULT_PINMUX(SDMMC4_DAT6_PAA6, SDMMC4, UP, NORMAL, INPUT), - DEFAULT_PINMUX(SDMMC4_DAT7_PAA7, SDMMC4, UP, NORMAL, INPUT), - - /* BLINK pinmux */ - DEFAULT_PINMUX(CLK_32K_OUT_PA0, BLINK, NORMAL, NORMAL, OUTPUT), - - /* KBC pinmux */ - DEFAULT_PINMUX(KB_COL0_PQ0, KBC, UP, NORMAL, INPUT), - DEFAULT_PINMUX(KB_COL1_PQ1, KBC, UP, NORMAL, INPUT), - DEFAULT_PINMUX(KB_COL2_PQ2, KBC, UP, NORMAL, INPUT), - DEFAULT_PINMUX(KB_ROW0_PR0, KBC, UP, NORMAL, INPUT), - DEFAULT_PINMUX(KB_ROW1_PR1, KBC, UP, NORMAL, INPUT), - - /* Misc */ - DEFAULT_PINMUX(PV0, RSVD1, NORMAL, TRISTATE, OUTPUT), - DEFAULT_PINMUX(KB_ROW7_PR7, RSVD1, UP, NORMAL, INPUT), - - /* UARTA pinmux (BR_UART_TXD/RXD on Servo board) */ - DEFAULT_PINMUX(KB_ROW9_PS1, UARTA, UP, NORMAL, OUTPUT), - DEFAULT_PINMUX(KB_ROW10_PS2, UARTA, UP, TRISTATE, INPUT), - - /* I2CPWR pinmux (I2C5) */ - I2C_PINMUX(PWR_I2C_SCL_PZ6, I2CPWR, NORMAL, NORMAL, INPUT, DEFAULT, ENABLE), - I2C_PINMUX(PWR_I2C_SDA_PZ7, I2CPWR, NORMAL, NORMAL, INPUT, DEFAULT, ENABLE), - - /* RTCK pinmux */ - DEFAULT_PINMUX(JTAG_RTCK, RTCK, NORMAL, NORMAL, INPUT), - - /* CLK pinmux */ - DEFAULT_PINMUX(CLK_32K_IN, CLK, NORMAL, TRISTATE, INPUT), - - /* PWRON pinmux */ - DEFAULT_PINMUX(CORE_PWR_REQ, PWRON, NORMAL, NORMAL, OUTPUT), - - /* CPU pinmux */ - DEFAULT_PINMUX(CPU_PWR_REQ, CPU, NORMAL, NORMAL, OUTPUT), - - /* PMI pinmux */ - DEFAULT_PINMUX(PWR_INT_N, PMI, NORMAL, TRISTATE, INPUT), - - /* RESET_OUT_N pinmux */ - DEFAULT_PINMUX(RESET_OUT_N, RESET_OUT_N, NORMAL, NORMAL, OUTPUT), - - /* EXTPERIPH3 pinmux */ - DEFAULT_PINMUX(CLK3_OUT_PEE0, EXTPERIPH3, NORMAL, NORMAL, OUTPUT), - - /* I2C1 pinmux */ - I2C_PINMUX(GEN1_I2C_SCL_PC4, I2C1, NORMAL, NORMAL, INPUT, DEFAULT, ENABLE), - I2C_PINMUX(GEN1_I2C_SDA_PC5, I2C1, NORMAL, NORMAL, INPUT, DEFAULT, ENABLE), - - /* UARTB, GPS */ - DEFAULT_PINMUX(UART2_CTS_N_PJ5, UARTB, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(UART2_RTS_N_PJ6, UARTB, NORMAL, NORMAL, OUTPUT), - DEFAULT_PINMUX(UART2_RXD_PC3, IRDA, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(UART2_TXD_PC2, IRDA, NORMAL, NORMAL, OUTPUT), - - /* UARTC (WIFI/BT) */ - DEFAULT_PINMUX(UART3_CTS_N_PA1, UARTC, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(UART3_RTS_N_PC0, UARTC, NORMAL, NORMAL, OUTPUT), - DEFAULT_PINMUX(UART3_RXD_PW7, UARTC, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(UART3_TXD_PW6, UARTC, NORMAL, NORMAL, OUTPUT), - - /* CEC pinmux */ - CEC_PINMUX(HDMI_CEC_PEE3, CEC, NORMAL, NORMAL, INPUT, DEFAULT, DISABLE), - - /* I2C4 (HDMI_DDC) pinmux */ - DDC_PINMUX(DDC_SCL_PV4, I2C4, NORMAL, NORMAL, INPUT, DEFAULT, HIGH), - DDC_PINMUX(DDC_SDA_PV5, I2C4, NORMAL, NORMAL, INPUT, DEFAULT, HIGH), - - /* USB pinmux */ - USB_PINMUX(USB_VBUS_EN0_PN4, USB, NORMAL, NORMAL, INPUT, DEFAULT, ENABLE), - USB_PINMUX(USB_VBUS_EN1_PN5, USB, NORMAL, NORMAL, INPUT, DEFAULT, ENABLE), - - /* Unused, marked SNN_ on schematic, TRISTATE 'em */ - DEFAULT_PINMUX(PBB0, RSVD3, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(PBB3, RSVD3, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(PBB4, RSVD3, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(PBB5, RSVD2, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(PBB6, RSVD1, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(PBB7, RSVD1, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(PCC1, RSVD1, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(PCC2, RSVD1, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(PH3, GMI, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(PI7, GMI, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(PJ2, RSVD1, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(GPIO_X5_AUD_PX5, RSVD3, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(GPIO_X6_AUD_PX6, GMI, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(GPIO_W2_AUD_PW2, RSVD1, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(PFF2, RSVD1, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(USB_VBUS_EN2_PFF1, RSVD1, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(KB_COL5_PQ5, RSVD1, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(KB_ROW2_PR2, RSVD1, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(KB_ROW3_PR3, KBC, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(KB_ROW5_PR5, RSVD2, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(KB_ROW6_PR6, KBC, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(KB_ROW13_PS5, RSVD1, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(KB_ROW14_PS6, RSVD1, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(KB_ROW16_PT0, RSVD1, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(OWR, RSVD1, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(ULPI_DATA7_PO0, ULPI, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(DAP3_DIN_PP1, RSVD1, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(DAP3_FS_PP0, RSVD1, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(DAP3_SCLK_PP3, RSVD2, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(CLK2_OUT_PW5, RSVD1, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(SDMMC1_WP_N_PV3, RSVD1, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(CAM_MCLK_PCC0, RSVD1, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(CLK3_REQ_PEE1, RSVD1, NORMAL, TRISTATE, INPUT), - DEFAULT_PINMUX(SPDIF_OUT_PK5, RSVD1, NORMAL, TRISTATE, INPUT), -}; - -static struct pmux_pingrp_config unused_pins_lowpower[] = { - DEFAULT_PINMUX(DAP_MCLK1_REQ_PEE2, RSVD3, DOWN, TRISTATE, OUTPUT), -}; - -/* Initially setting all used GPIO's to non-TRISTATE */ -static struct pmux_pingrp_config tegra124_pinmux_set_nontristate[] = { - DEFAULT_PINMUX(GPIO_X4_AUD_PX4, RSVD1, DOWN, NORMAL, OUTPUT), - DEFAULT_PINMUX(GPIO_X7_AUD_PX7, RSVD1, DOWN, NORMAL, OUTPUT), - DEFAULT_PINMUX(GPIO_W2_AUD_PW2, RSVD1, UP, NORMAL, INPUT), - DEFAULT_PINMUX(GPIO_X3_AUD_PX3, RSVD3, UP, NORMAL, INPUT), - - /* EN_VDD_BL */ - DEFAULT_PINMUX(DAP3_DOUT_PP2, I2S2, DOWN, NORMAL, OUTPUT), - - /* MODEM */ - DEFAULT_PINMUX(PV0, RSVD3, NORMAL, NORMAL, INPUT), - DEFAULT_PINMUX(PV1, RSVD1, NORMAL, NORMAL, INPUT), - - /* BOOT_SEL0-3 */ - DEFAULT_PINMUX(PG0, GMI, NORMAL, NORMAL, INPUT), - DEFAULT_PINMUX(PG1, GMI, NORMAL, NORMAL, INPUT), - DEFAULT_PINMUX(PG2, GMI, NORMAL, NORMAL, INPUT), - DEFAULT_PINMUX(PG3, GMI, NORMAL, NORMAL, INPUT), - - DEFAULT_PINMUX(CLK2_REQ_PCC5, RSVD3, NORMAL, NORMAL, OUTPUT), - - DEFAULT_PINMUX(KB_COL3_PQ3, KBC, UP, NORMAL, OUTPUT), - DEFAULT_PINMUX(KB_COL4_PQ4, SDMMC3, UP, NORMAL, INPUT), - DEFAULT_PINMUX(KB_COL6_PQ6, KBC, UP, NORMAL, OUTPUT), - DEFAULT_PINMUX(KB_COL7_PQ7, KBC, UP, NORMAL, OUTPUT), - DEFAULT_PINMUX(KB_ROW4_PR4, KBC, DOWN, NORMAL, INPUT), - DEFAULT_PINMUX(KB_ROW8_PS0, KBC, UP, NORMAL, INPUT), - - DEFAULT_PINMUX(PU4, RSVD3, NORMAL, NORMAL, INPUT), - DEFAULT_PINMUX(PU5, RSVD3, NORMAL, NORMAL, OUTPUT), - DEFAULT_PINMUX(PU6, RSVD3, NORMAL, NORMAL, INPUT), - - DEFAULT_PINMUX(HDMI_INT_PN7, RSVD1, DOWN, NORMAL, INPUT), - DEFAULT_PINMUX(SPDIF_IN_PK6, RSVD2, NORMAL, NORMAL, INPUT), - DEFAULT_PINMUX(SDMMC3_CD_N_PV2, SDMMC3, UP, NORMAL, INPUT), - - /* TS_SHDN_L */ - DEFAULT_PINMUX(PK1, GMI, NORMAL, NORMAL, OUTPUT), +static const struct pmux_drvgrp_config venice2_drvgrps[] = { };
-static struct pmux_drvgrp_config venice2_padctrl[] = { - /* (_drvgrp, _slwf, _slwr, _drvup, _drvdn, _lpmd, _schmt, _hsm) */ - DEFAULT_PADCFG(SDIO3, SDIOCFG_DRVUP_SLWF, SDIOCFG_DRVDN_SLWR, - SDIOCFG_DRVUP, SDIOCFG_DRVDN, NONE, NONE, NONE), -}; #endif /* PINMUX_CONFIG_VENICE2_H */ diff --git a/board/nvidia/venice2/venice2.c b/board/nvidia/venice2/venice2.c index 15082c419507..c56ef129d6c7 100644 --- a/board/nvidia/venice2/venice2.c +++ b/board/nvidia/venice2/venice2.c @@ -6,12 +6,9 @@ */
#include <common.h> -#include <asm-generic/gpio.h> #include <asm/arch/gpio.h> -#include <asm/arch/gp_padctrl.h> #include <asm/arch/pinmux.h> #include "pinmux-config-venice2.h" -#include <i2c.h>
/* * Routine: pinmux_init @@ -19,16 +16,14 @@ */ void pinmux_init(void) { - pinmux_config_pingrp_table(tegra124_pinmux_set_nontristate, - ARRAY_SIZE(tegra124_pinmux_set_nontristate)); + pinmux_set_tristate_input_clamping();
- pinmux_config_pingrp_table(tegra124_pinmux_common, - ARRAY_SIZE(tegra124_pinmux_common)); + gpio_config_table(venice2_gpio_inits, + ARRAY_SIZE(venice2_gpio_inits));
- pinmux_config_pingrp_table(unused_pins_lowpower, - ARRAY_SIZE(unused_pins_lowpower)); + pinmux_config_pingrp_table(venice2_pingrps, + ARRAY_SIZE(venice2_pingrps));
- /* Initialize any non-default pad configs (APB_MISC_GP regs) */ - pinmux_config_drvgrp_table(venice2_padctrl, - ARRAY_SIZE(venice2_padctrl)); + pinmux_config_drvgrp_table(venice2_drvgrps, + ARRAY_SIZE(venice2_drvgrps)); }
Stephen Warren
