[PATCH] arm64: zynqmp: Add support for DLC21 (Smartlynq+) board
DLC21 is used as fast jtag cable. The patch adds support for this board from PS perspective. The most interesting part on the board is seps525 oled display. Also i2c, gpio, ethernet, uart, SD and eMMC are tested.
arch/arm/dts/Makefile | 1 + arch/arm/dts/zynqmp-dlc21-revA.dts | 221 +++++ .../zynqmp/zynqmp-dlc21-revA/psu_init_gpl.c | 922 ++++++++++++++++++ configs/xilinx_zynqmp_virt_defconfig | 2 +- 4 files changed, 1145 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/zynqmp-dlc21-revA.dts create mode 100644 board/xilinx/zynqmp/zynqmp-dlc21-revA/psu_init_gpl.c
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index ed3d360bb101..5adf0c8126c9 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -312,6 +312,7 @@ dtb-$(CONFIG_ARCH_ZYNQMP) += \ avnet-ultra96-rev1.dtb \ avnet-ultrazedev-cc-v1.0-ultrazedev-som-v1.0.dtb \ zynqmp-a2197-revA.dtb \ + zynqmp-dlc21-revA.dtb \ zynqmp-e-a2197-00-revA.dtb \ zynqmp-g-a2197-00-revA.dtb \ zynqmp-m-a2197-01-revA.dtb \ diff --git a/arch/arm/dts/zynqmp-dlc21-revA.dts b/arch/arm/dts/zynqmp-dlc21-revA.dts new file mode 100644 index 000000000000..cf0aadf03ca4 --- /dev/null +++ b/arch/arm/dts/zynqmp-dlc21-revA.dts @@ -0,0 +1,221 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * dts file for Xilinx ZynqMP DLC21 revA + * + * (C) Copyright 2019 - 2021, Xilinx, Inc. + * + * Michal Simek michal.simek@xilinx.com + */ +/dts-v1/; + +#include "zynqmp.dtsi" +#include "zynqmp-clk-ccf.dtsi" +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/phy/phy.h> +#include <include/dt-bindings/gpio/gpio.h> + +/ { + model = "Smartlynq+ DLC21 RevA"; + compatible = "xlnx,zynqmp-dlc21-revA", "xlnx,zynqmp-dlc21", + "xlnx,zynqmp"; + + aliases { + ethernet0 = &gem0; + gpio0 = &gpio; + i2c0 = &i2c0; + mmc0 = &sdhci0; + mmc1 = &sdhci1; + rtc0 = &rtc; + serial0 = &uart0; + serial2 = &dcc; + usb0 = &usb0; + usb1 = &usb1; + spi0 = &spi0; + nvmem0 = &eeprom; + }; + + chosen { + bootargs = "earlycon"; + stdout-path = "serial0:115200n8"; + }; + + memory@0 { + device_type = "memory"; + reg = <0 0 0 0x80000000>, <0x8 0 0x3 0x80000000>; + }; + + si5332_1: si5332_1 { /* clk0_sgmii - u142 */ + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <125000000>; + }; + + si5332_2: si5332_2 { /* clk1_usb - u142 */ + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <26000000>; + }; +}; + +&sdhci0 { /* emmc MIO 13-23 - with some settings 16GB */ + status = "okay"; + non-removable; + disable-wp; + bus-width = <8>; + xlnx,mio_bank = <0>; +}; + +&sdhci1 { /* sd1 MIO45-51 cd in place */ + status = "okay"; + no-1-8-v; + disable-wp; + xlnx,mio_bank = <1>; +}; + +&psgtr { + status = "okay"; + /* sgmii, usb3 */ + clocks = <&si5332_1>, <&si5332_2>; + clock-names = "ref0", "ref1"; +}; + +&uart0 { /* uart0 MIO38-39 */ + status = "okay"; + u-boot,dm-pre-reloc; +}; + +&gem0 { + status = "okay"; + phy-handle = <&phy0>; + phy-mode = "sgmii"; /* DTG generates this properly 1512 */ + is-internal-pcspma; + /* phy-reset-gpios = <&gpio 142 GPIO_ACTIVE_LOW>; */ + phy0: ethernet-phy@0 { + reg = <0>; + }; +}; + +&gpio { + status = "okay"; + gpio-line-names = "", "", "", "", "", /* 0 - 4 */ + "", "", "", "", "", /* 5 - 9 */ + "", "", "", "EMMC_DAT0", "EMMC_DAT1", /* 10 - 14 */ + "EMMC_DAT2", "EMMC_DAT3", "EMMC_DAT4", "EMMC_DAT5", "EMMC_DAT6", /* 15 - 19 */ + "EMMC_DAT7", "EMMC_CMD", "EMMC_CLK", "EMMC_RST_B", "", /* 20 - 24 */ + "", "DISP_SCL", "DISP_DC_B", "DISP_RES_B", "DISP_CS_B", /* 25 - 29 */ + "", "DISP_SDI", "SYSTEM_RST_R_B", "", "I2C0_SCL", /* 30 - 34 */ + "I2C0_SDA", "", "", "UART0_RXD_IN", "UART0_TXD_OUT", /* 35 - 39 */ + "", "", "ETH_RESET_B", "", "", /* 40 - 44 */ + "SD1_CD_B", "SD1_DATA0", "SD1_DATA1", "SD1_DATA2", "SD1_DATA3", /* 45 - 49 */ + "SD1_CMD", "SD1_CLK", "USB0_CLK", "USB0_DIR", "USB0_DATA2", /* 50 - 54 */ + "USB0_NXT", "USB0_DATA0", "USB0_DATA1", "USB0_STP", "USB0_DATA3", /* 55 - 59 */ + "USB0_DATA4", "USB0_DATA5", "USB0_DATA6", "USB0_DATA7", "USB1_CLK", /* 60 - 64 */ + "USB1_DIR", "USB1_DATA2", "USB1_NXT", "USB1_DATA0", "USB1_DATA1", /* 65 - 69 */ + "USB1_STP", "USB1_DATA3", "USB1_DATA4", "USB1_DATA5", "USB1_DATA6", /* 70 - 74 */ + "USB1_DATA7", "ETH_MDC", "ETH_MDIO", /* 75 - 77, MIO end and EMIO start */ + "", "", /* 78 - 79 */ + "", "", "", "", "", /* 80 - 84 */ + "", "", "", "", "", /* 85 -89 */ + "", "", "", "", "", /* 90 - 94 */ + "", "VCCO_500_RBIAS", "VCCO_501_RBIAS", "VCCO_502_RBIAS", "VCCO_500_RBIAS_LED", /* 95 - 99 */ + "VCCO_501_RBIAS_LED", "VCCO_502_RBIAS_LED", "SYSCTLR_VCCINT_EN", "SYSCTLR_VCC_IO_SOC_EN", "SYSCTLR_VCC_PMC_EN", /* 100 - 104 */ + "", "", "", "", "", /* 105 - 109 */ + "SYSCTLR_VCCO_500_EN", "SYSCTLR_VCCO_501_EN", "SYSCTLR_VCCO_502_EN", "SYSCTLR_VCCO_503_EN", "SYSCTLR_VCC1V8_EN", /* 110 - 114 */ + "SYSCTLR_VCC3V3_EN", "SYSCTLR_VCC1V2_DDR4_EN", "SYSCTLR_VCC1V1_LP4_EN", "SYSCTLR_VDD1_1V8_LP4_EN", "SYSCTLR_VADJ_FMC_EN", /* 115 - 119 */ + "", "", "", "SYSCTLR_UTIL_1V13_EN", "SYSCTLR_UTIL_1V8_EN", /* 120 - 124 */ + "SYSCTLR_UTIL_2V5_EN", "", "", "", "", /* 125 - 129 */ + "", "", "SYSCTLR_USBC_SBU1", "SYSCTLR_USBC_SBU2", "", /* 130 - 134 */ + "", "SYSCTLR_MIC2005_EN_B", "SYSCTLR_MIC2005_FAULT_B", "SYSCTLR_TUSB320_INT_B", "SYSCTLR_TUSB320_ID", /* 135 - 139 */ + "", "", "SYSCTLR_ETH_RESET_B", "", "", /* 140 - 144 */ + "", "", "", "", "", /* 145 - 149 */ + "", "", "", "", "", /* 150 - 154 */ + "", "", "", "", "", /* 155 - 159 */ + "", "", "", "", "", /* 160 - 164 */ + "", "", "", "", "", /* 165 - 169 */ + "", "", "", ""; /* 170 - 174 */ +}; + +&i2c0 { /* MIO34/35 */ + status = "okay"; + clock-frequency = <400000>; + + jtag_vref: mcp4725@62 { + compatible = "microchip,mcp4725"; + reg = <0x62>; + vref-millivolt = <3300>; + }; + + eeprom: eeprom@50 { /* u46 */ + compatible = "atmel,24c32"; + reg = <0x50>; + }; + /* u138 - TUSB320IRWBR - for USB-C */ +}; + + +&usb0 { + status = "okay"; + xlnx,usb-polarity = <0>; + xlnx,usb-reset-mode = <0>; +}; + +&dwc3_0 { + status = "okay"; + dr_mode = "peripheral"; + snps,dis_u2_susphy_quirk; + snps,dis_u3_susphy_quirk; + maximum-speed = "super-speed"; + phy-names = "usb3-phy"; + phys = <&psgtr 1 PHY_TYPE_USB3 0 1>; +}; + +&usb1 { + status = "disabled"; /* Any unknown issue with USB-C */ + xlnx,usb-polarity = <0>; + xlnx,usb-reset-mode = <0>; +}; + +&dwc3_1 { + /delete-property/ phy-names ; + /delete-property/ phys ; + dr_mode = "host"; + maximum-speed = "high-speed"; + snps,dis_u2_susphy_quirk ; + snps,dis_u3_susphy_quirk ; + status = "okay"; +}; + +&xilinx_ams { + status = "okay"; +}; + +&ams_ps { + status = "okay"; +}; + +&ams_pl { + status = "okay"; +}; + +&spi0 { + status = "okay"; + is-decoded-cs = <0>; + num-cs = <1>; + u-boot,dm-pre-reloc; + displayspi@0 { + compatible = "syncoam,seps525"; + u-boot,dm-pre-reloc; + reg = <0>; + status = "okay"; + spi-max-frequency = <10000000>; + spi-cpol; + spi-cpha; + rotate = <0>; + fps = <50>; + buswidth = <8>; + txbuflen = <64000>; + reset-gpios = <&gpio 0x1c GPIO_ACTIVE_LOW>; + dc-gpios = <&gpio 0x1b GPIO_ACTIVE_HIGH>; + debug = <0>; + }; +}; diff --git a/board/xilinx/zynqmp/zynqmp-dlc21-revA/psu_init_gpl.c b/board/xilinx/zynqmp/zynqmp-dlc21-revA/psu_init_gpl.c new file mode 100644 index 000000000000..528958d83ed6 --- /dev/null +++ b/board/xilinx/zynqmp/zynqmp-dlc21-revA/psu_init_gpl.c @@ -0,0 +1,922 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (c) Copyright 2015 Xilinx, Inc. All rights reserved. + */ + +#include <asm/arch/psu_init_gpl.h> +#include <xil_io.h> + +static unsigned long psu_pll_init_data(void) +{ + psu_mask_write(0xFF5E0034, 0xFE7FEDEFU, 0x7E4B0C62U); + psu_mask_write(0xFF5E0030, 0x00717F00U, 0x00014000U); + psu_mask_write(0xFF5E0030, 0x00000008U, 0x00000008U); + psu_mask_write(0xFF5E0030, 0x00000001U, 0x00000001U); + psu_mask_write(0xFF5E0030, 0x00000001U, 0x00000000U); + mask_poll(0xFF5E0040, 0x00000002U); + psu_mask_write(0xFF5E0030, 0x00000008U, 0x00000000U); + psu_mask_write(0xFF5E0048, 0x00003F00U, 0x00000200U); + psu_mask_write(0xFF5E0038, 0x8000FFFFU, 0x00000000U); + psu_mask_write(0xFF5E0108, 0x013F3F07U, 0x01012300U); + psu_mask_write(0xFF5E0024, 0xFE7FEDEFU, 0x7E4B0C82U); + psu_mask_write(0xFF5E0020, 0x00717F00U, 0x00015A00U); + psu_mask_write(0xFF5E0020, 0x00000008U, 0x00000008U); + psu_mask_write(0xFF5E0020, 0x00000001U, 0x00000001U); + psu_mask_write(0xFF5E0020, 0x00000001U, 0x00000000U); + mask_poll(0xFF5E0040, 0x00000001U); + psu_mask_write(0xFF5E0020, 0x00000008U, 0x00000000U); + psu_mask_write(0xFF5E0044, 0x00003F00U, 0x00000300U); + psu_mask_write(0xFF5E0028, 0x8000FFFFU, 0x00000000U); + psu_mask_write(0xFD1A0024, 0xFE7FEDEFU, 0x7E4B0C62U); + psu_mask_write(0xFD1A0020, 0x00717F00U, 0x00014800U); + psu_mask_write(0xFD1A0020, 0x00000008U, 0x00000008U); + psu_mask_write(0xFD1A0020, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD1A0020, 0x00000001U, 0x00000000U); + mask_poll(0xFD1A0044, 0x00000001U); + psu_mask_write(0xFD1A0020, 0x00000008U, 0x00000000U); + psu_mask_write(0xFD1A0048, 0x00003F00U, 0x00000300U); + psu_mask_write(0xFD1A0028, 0x8000FFFFU, 0x00000000U); + psu_mask_write(0xFD1A0030, 0xFE7FEDEFU, 0x7E4B0C62U); + psu_mask_write(0xFD1A002C, 0x00717F00U, 0x00014000U); + psu_mask_write(0xFD1A002C, 0x00000008U, 0x00000008U); + psu_mask_write(0xFD1A002C, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD1A002C, 0x00000001U, 0x00000000U); + mask_poll(0xFD1A0044, 0x00000002U); + psu_mask_write(0xFD1A002C, 0x00000008U, 0x00000000U); + psu_mask_write(0xFD1A004C, 0x00003F00U, 0x00000200U); + psu_mask_write(0xFD1A0034, 0x8000FFFFU, 0x00000000U); + psu_mask_write(0xFD1A003C, 0xFE7FEDEFU, 0x7E4B0C62U); + psu_mask_write(0xFD1A0038, 0x00717F00U, 0x00014000U); + psu_mask_write(0xFD1A0038, 0x00000008U, 0x00000008U); + psu_mask_write(0xFD1A0038, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD1A0038, 0x00000001U, 0x00000000U); + mask_poll(0xFD1A0044, 0x00000004U); + psu_mask_write(0xFD1A0038, 0x00000008U, 0x00000000U); + psu_mask_write(0xFD1A0050, 0x00003F00U, 0x00000200U); + psu_mask_write(0xFD1A0040, 0x8000FFFFU, 0x00000000U); + + return 1; +} + +static unsigned long psu_clock_init_data(void) +{ + psu_mask_write(0xFF5E0050, 0x063F3F07U, 0x06013C00U); + psu_mask_write(0xFF180360, 0x00000003U, 0x00000001U); + psu_mask_write(0xFF180308, 0x00000006U, 0x00000006U); + psu_mask_write(0xFF5E0100, 0x013F3F07U, 0x01010600U); + psu_mask_write(0xFF5E0060, 0x023F3F07U, 0x02010600U); + psu_mask_write(0xFF5E0064, 0x023F3F07U, 0x02010600U); + psu_mask_write(0xFF5E004C, 0x023F3F07U, 0x02031900U); + psu_mask_write(0xFF5E006C, 0x013F3F07U, 0x01010800U); + psu_mask_write(0xFF5E0070, 0x013F3F07U, 0x01010800U); + psu_mask_write(0xFF18030C, 0x00020003U, 0x00000000U); + psu_mask_write(0xFF5E0074, 0x013F3F07U, 0x01010F00U); + psu_mask_write(0xFF5E0120, 0x013F3F07U, 0x01010F00U); + psu_mask_write(0xFF5E007C, 0x013F3F07U, 0x01010702U); + psu_mask_write(0xFF5E0090, 0x01003F07U, 0x01000302U); + psu_mask_write(0xFF5E009C, 0x01003F07U, 0x01000400U); + psu_mask_write(0xFF5E00A4, 0x01003F07U, 0x01000800U); + psu_mask_write(0xFF5E00A8, 0x01003F07U, 0x01000200U); + psu_mask_write(0xFF5E00AC, 0x01003F07U, 0x01000F02U); + psu_mask_write(0xFF5E00B0, 0x01003F07U, 0x01000602U); + psu_mask_write(0xFF5E00B8, 0x01003F07U, 0x01000200U); + psu_mask_write(0xFF5E00C0, 0x013F3F07U, 0x01010502U); + psu_mask_write(0xFF5E00C4, 0x013F3F07U, 0x01010802U); + psu_mask_write(0xFF5E00C8, 0x013F3F07U, 0x01010402U); + psu_mask_write(0xFF5E00CC, 0x013F3F07U, 0x01030A00U); + psu_mask_write(0xFF5E0108, 0x013F3F07U, 0x01011E02U); + psu_mask_write(0xFF5E0104, 0x00000007U, 0x00000000U); + psu_mask_write(0xFF5E0128, 0x01003F07U, 0x01000104U); + psu_mask_write(0xFD1A0060, 0x03003F07U, 0x03000100U); + psu_mask_write(0xFD1A0068, 0x01003F07U, 0x01000200U); + psu_mask_write(0xFD1A0080, 0x00003F07U, 0x00000200U); + psu_mask_write(0xFD1A0084, 0x07003F07U, 0x07000100U); + psu_mask_write(0xFD1A00B8, 0x01003F07U, 0x01000203U); + psu_mask_write(0xFD1A00BC, 0x01003F07U, 0x01000203U); + psu_mask_write(0xFD1A00C0, 0x01003F07U, 0x01000202U); + psu_mask_write(0xFD1A00C4, 0x01003F07U, 0x01000502U); + psu_mask_write(0xFD1A00F8, 0x00003F07U, 0x00000200U); + psu_mask_write(0xFF180380, 0x000000FFU, 0x00000000U); + psu_mask_write(0xFD610100, 0x00000001U, 0x00000000U); + psu_mask_write(0xFF180300, 0x00000001U, 0x00000000U); + psu_mask_write(0xFF410050, 0x00000001U, 0x00000000U); + + return 1; +} + +static unsigned long psu_ddr_init_data(void) +{ + psu_mask_write(0xFD1A0108, 0x00000008U, 0x00000008U); + psu_mask_write(0xFD070000, 0xE30FBE3DU, 0x43041010U); + psu_mask_write(0xFD070010, 0x8000F03FU, 0x00000030U); + psu_mask_write(0xFD070020, 0x000003F3U, 0x00000200U); + psu_mask_write(0xFD070024, 0xFFFFFFFFU, 0x00800000U); + psu_mask_write(0xFD070030, 0x0000007FU, 0x00000008U); + psu_mask_write(0xFD070034, 0x00FFFF1FU, 0x00408410U); + psu_mask_write(0xFD070050, 0x00F1F1F4U, 0x00210000U); + psu_mask_write(0xFD070054, 0x0FFF0FFFU, 0x00000000U); + psu_mask_write(0xFD070060, 0x00000073U, 0x00000001U); + psu_mask_write(0xFD070064, 0x0FFF83FFU, 0x00818126U); + psu_mask_write(0xFD070070, 0x00000017U, 0x00000010U); + psu_mask_write(0xFD070074, 0x00000003U, 0x00000000U); + psu_mask_write(0xFD0700C4, 0x3F000391U, 0x10000200U); + psu_mask_write(0xFD0700C8, 0x01FF1F3FU, 0x0040051FU); + psu_mask_write(0xFD0700D0, 0xC3FF0FFFU, 0x00020106U); + psu_mask_write(0xFD0700D4, 0x01FF7F0FU, 0x00020000U); + psu_mask_write(0xFD0700D8, 0x0000FF0FU, 0x00002305U); + psu_mask_write(0xFD0700DC, 0xFFFFFFFFU, 0x07300501U); + psu_mask_write(0xFD0700E0, 0xFFFFFFFFU, 0x00200200U); + psu_mask_write(0xFD0700E4, 0x00FF03FFU, 0x00210004U); + psu_mask_write(0xFD0700E8, 0xFFFFFFFFU, 0x00000700U); + psu_mask_write(0xFD0700EC, 0xFFFF0000U, 0x08190000U); + psu_mask_write(0xFD0700F0, 0x0000003FU, 0x00000010U); + psu_mask_write(0xFD0700F4, 0x00000FFFU, 0x0000066FU); + psu_mask_write(0xFD070100, 0x7F3F7F3FU, 0x110C2412U); + psu_mask_write(0xFD070104, 0x001F1F7FU, 0x0004041CU); + psu_mask_write(0xFD070108, 0x3F3F3F3FU, 0x0708060DU); + psu_mask_write(0xFD07010C, 0x3FF3F3FFU, 0x0050400CU); + psu_mask_write(0xFD070110, 0x1F0F0F1FU, 0x08030309U); + psu_mask_write(0xFD070114, 0x0F0F3F1FU, 0x06060403U); + psu_mask_write(0xFD070118, 0x0F0F000FU, 0x01010004U); + psu_mask_write(0xFD07011C, 0x00000F0FU, 0x00000606U); + psu_mask_write(0xFD070120, 0x7F7F7F7FU, 0x04040D0BU); + psu_mask_write(0xFD070124, 0x40070F3FU, 0x0002020BU); + psu_mask_write(0xFD07012C, 0x7F1F031FU, 0x1607010EU); + psu_mask_write(0xFD070130, 0x00030F1FU, 0x00020608U); + psu_mask_write(0xFD070180, 0xF7FF03FFU, 0x81000040U); + psu_mask_write(0xFD070184, 0x3FFFFFFFU, 0x020196E5U); + psu_mask_write(0xFD070190, 0x1FBFBF3FU, 0x048B820BU); + psu_mask_write(0xFD070194, 0xF31F0F0FU, 0x00030304U); + psu_mask_write(0xFD070198, 0x0FF1F1F1U, 0x07000101U); + psu_mask_write(0xFD07019C, 0x000000F1U, 0x00000021U); + psu_mask_write(0xFD0701A0, 0xC3FF03FFU, 0x00400003U); + psu_mask_write(0xFD0701A4, 0x00FF00FFU, 0x00C800FFU); + psu_mask_write(0xFD0701B0, 0x00000007U, 0x00000000U); + psu_mask_write(0xFD0701B4, 0x00003F3FU, 0x00000909U); + psu_mask_write(0xFD0701C0, 0x00000007U, 0x00000001U); + psu_mask_write(0xFD070200, 0x0000001FU, 0x00000018U); + psu_mask_write(0xFD070204, 0x001F1F1FU, 0x001F0909U); + psu_mask_write(0xFD070208, 0x0F0F0F0FU, 0x01010101U); + psu_mask_write(0xFD07020C, 0x0F0F0F0FU, 0x0F010101U); + psu_mask_write(0xFD070210, 0x00000F0FU, 0x00000F0FU); + psu_mask_write(0xFD070214, 0x0F0F0F0FU, 0x070F0707U); + psu_mask_write(0xFD070218, 0x8F0F0F0FU, 0x07070707U); + psu_mask_write(0xFD07021C, 0x00000F0FU, 0x00000F07U); + psu_mask_write(0xFD070220, 0x00001F1FU, 0x00000700U); + psu_mask_write(0xFD070224, 0x0F0F0F0FU, 0x07070707U); + psu_mask_write(0xFD070228, 0x0F0F0F0FU, 0x07070707U); + psu_mask_write(0xFD07022C, 0x0000000FU, 0x00000007U); + psu_mask_write(0xFD070240, 0x0F1F0F7CU, 0x06000600U); + psu_mask_write(0xFD070244, 0x00003333U, 0x00000201U); + psu_mask_write(0xFD070250, 0x7FFF3F07U, 0x01002001U); + psu_mask_write(0xFD070264, 0xFF00FFFFU, 0x08000040U); + psu_mask_write(0xFD07026C, 0xFF00FFFFU, 0x08000040U); + psu_mask_write(0xFD070280, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD070284, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD070288, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD07028C, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD070290, 0x0000FFFFU, 0x00000000U); + psu_mask_write(0xFD070294, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD070300, 0x00000011U, 0x00000001U); + psu_mask_write(0xFD07030C, 0x80000033U, 0x00000000U); + psu_mask_write(0xFD070320, 0x00000001U, 0x00000000U); + psu_mask_write(0xFD070400, 0x00000111U, 0x00000101U); + psu_mask_write(0xFD070404, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070408, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070490, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD070494, 0x0033000FU, 0x0020000BU); + psu_mask_write(0xFD070498, 0x07FF07FFU, 0x00000000U); + psu_mask_write(0xFD0704B4, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD0704B8, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070540, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD070544, 0x03330F0FU, 0x02000B03U); + psu_mask_write(0xFD070548, 0x07FF07FFU, 0x00000000U); + psu_mask_write(0xFD070564, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070568, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD0705F0, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD0705F4, 0x03330F0FU, 0x02000B03U); + psu_mask_write(0xFD0705F8, 0x07FF07FFU, 0x00000000U); + psu_mask_write(0xFD070614, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070618, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD0706A0, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD0706A4, 0x0033000FU, 0x00100003U); + psu_mask_write(0xFD0706A8, 0x07FF07FFU, 0x0000004FU); + psu_mask_write(0xFD0706AC, 0x0033000FU, 0x00100003U); + psu_mask_write(0xFD0706B0, 0x000007FFU, 0x0000004FU); + psu_mask_write(0xFD0706C4, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD0706C8, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070750, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD070754, 0x0033000FU, 0x00100003U); + psu_mask_write(0xFD070758, 0x07FF07FFU, 0x0000004FU); + psu_mask_write(0xFD07075C, 0x0033000FU, 0x00100003U); + psu_mask_write(0xFD070760, 0x000007FFU, 0x0000004FU); + psu_mask_write(0xFD070774, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070778, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070800, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD070804, 0x0033000FU, 0x00100003U); + psu_mask_write(0xFD070808, 0x07FF07FFU, 0x0000004FU); + psu_mask_write(0xFD07080C, 0x0033000FU, 0x00100003U); + psu_mask_write(0xFD070810, 0x000007FFU, 0x0000004FU); + psu_mask_write(0xFD070F04, 0x000001FFU, 0x00000000U); + psu_mask_write(0xFD070F08, 0x000000FFU, 0x00000000U); + psu_mask_write(0xFD070F0C, 0x000001FFU, 0x00000010U); + psu_mask_write(0xFD070F10, 0x000000FFU, 0x0000000FU); + psu_mask_write(0xFD072190, 0x1FBFBF3FU, 0x07828002U); + psu_mask_write(0xFD1A0108, 0x0000000CU, 0x00000000U); + psu_mask_write(0xFD080010, 0xFFFFFFFFU, 0x07001E00U); + psu_mask_write(0xFD080018, 0xFFFFFFFFU, 0x00F10010U); + psu_mask_write(0xFD08001C, 0xFFFFFFFFU, 0x55AA5480U); + psu_mask_write(0xFD080024, 0xFFFFFFFFU, 0x010100F4U); + psu_mask_write(0xFD080040, 0xFFFFFFFFU, 0x42C21590U); + psu_mask_write(0xFD080044, 0xFFFFFFFFU, 0xD05512C0U); + psu_mask_write(0xFD080068, 0xFFFFFFFFU, 0x01100000U); + psu_mask_write(0xFD080090, 0xFFFFFFFFU, 0x02A04161U); + psu_mask_write(0xFD0800C0, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD0800C4, 0xFFFFFFFFU, 0x000000E0U); + psu_mask_write(0xFD080100, 0xFFFFFFFFU, 0x0800040CU); + psu_mask_write(0xFD080110, 0xFFFFFFFFU, 0x06240F08U); + psu_mask_write(0xFD080114, 0xFFFFFFFFU, 0x28170008U); + psu_mask_write(0xFD080118, 0xFFFFFFFFU, 0x000F0300U); + psu_mask_write(0xFD08011C, 0xFFFFFFFFU, 0x83000800U); + psu_mask_write(0xFD080120, 0xFFFFFFFFU, 0x024B2B07U); + psu_mask_write(0xFD080124, 0xFFFFFFFFU, 0x00370F08U); + psu_mask_write(0xFD080128, 0xFFFFFFFFU, 0x00000E0FU); + psu_mask_write(0xFD080140, 0xFFFFFFFFU, 0x08400020U); + psu_mask_write(0xFD080144, 0xFFFFFFFFU, 0x00000C80U); + psu_mask_write(0xFD080150, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080154, 0xFFFFFFFFU, 0x00000200U); + psu_mask_write(0xFD080180, 0xFFFFFFFFU, 0x00000630U); + psu_mask_write(0xFD080184, 0xFFFFFFFFU, 0x00000501U); + psu_mask_write(0xFD080188, 0xFFFFFFFFU, 0x00000020U); + psu_mask_write(0xFD08018C, 0xFFFFFFFFU, 0x00000200U); + psu_mask_write(0xFD080190, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080194, 0xFFFFFFFFU, 0x00000700U); + psu_mask_write(0xFD080198, 0xFFFFFFFFU, 0x00000819U); + psu_mask_write(0xFD0801AC, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD0801B0, 0xFFFFFFFFU, 0x0000004DU); + psu_mask_write(0xFD0801B4, 0xFFFFFFFFU, 0x00000008U); + psu_mask_write(0xFD0801B8, 0xFFFFFFFFU, 0x0000004DU); + psu_mask_write(0xFD0801D8, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080200, 0xFFFFFFFFU, 0x810091C7U); + psu_mask_write(0xFD080204, 0xFFFFFFFFU, 0x00030236U); + psu_mask_write(0xFD080240, 0xFFFFFFFFU, 0x00141054U); + psu_mask_write(0xFD080250, 0xFFFFFFFFU, 0x00088000U); + psu_mask_write(0xFD080414, 0xFFFFFFFFU, 0x12344000U); + psu_mask_write(0xFD0804F4, 0xFFFFFFFFU, 0x00000005U); + psu_mask_write(0xFD080500, 0xFFFFFFFFU, 0x30000028U); + psu_mask_write(0xFD080508, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD08050C, 0xFFFFFFFFU, 0x00000005U); + psu_mask_write(0xFD080510, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080520, 0xFFFFFFFFU, 0x0300B0CEU); + psu_mask_write(0xFD080528, 0xFFFFFFFFU, 0xF9032019U); + psu_mask_write(0xFD08052C, 0xFFFFFFFFU, 0x07F001E3U); + psu_mask_write(0xFD080544, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080548, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080558, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD08055C, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080560, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080564, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080680, 0xFFFFFFFFU, 0x008AAA58U); + psu_mask_write(0xFD080684, 0xFFFFFFFFU, 0x000079DDU); + psu_mask_write(0xFD080694, 0xFFFFFFFFU, 0x01E10210U); + psu_mask_write(0xFD080698, 0xFFFFFFFFU, 0x01E10000U); + psu_mask_write(0xFD0806A4, 0xFFFFFFFFU, 0x000879DBU); + psu_mask_write(0xFD080700, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080704, 0xFFFFFFFFU, 0x00007FFFU); + psu_mask_write(0xFD08070C, 0xFFFFFFFFU, 0x3F000008U); + psu_mask_write(0xFD080710, 0xFFFFFFFFU, 0x0E00B03CU); + psu_mask_write(0xFD080714, 0xFFFFFFFFU, 0x09094F4FU); + psu_mask_write(0xFD080718, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080800, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080804, 0xFFFFFFFFU, 0x00007FFFU); + psu_mask_write(0xFD08080C, 0xFFFFFFFFU, 0x3F000008U); + psu_mask_write(0xFD080810, 0xFFFFFFFFU, 0x0E00B03CU); + psu_mask_write(0xFD080814, 0xFFFFFFFFU, 0x09094F4FU); + psu_mask_write(0xFD080818, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080900, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080904, 0xFFFFFFFFU, 0x00007FFFU); + psu_mask_write(0xFD08090C, 0xFFFFFFFFU, 0x3F000008U); + psu_mask_write(0xFD080910, 0xFFFFFFFFU, 0x0E00B00CU); + psu_mask_write(0xFD080914, 0xFFFFFFFFU, 0x09094F4FU); + psu_mask_write(0xFD080918, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080A00, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080A04, 0xFFFFFFFFU, 0x00007FFFU); + psu_mask_write(0xFD080A0C, 0xFFFFFFFFU, 0x3F000008U); + psu_mask_write(0xFD080A10, 0xFFFFFFFFU, 0x0E00B00CU); + psu_mask_write(0xFD080A14, 0xFFFFFFFFU, 0x09094F4FU); + psu_mask_write(0xFD080A18, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080B00, 0xFFFFFFFFU, 0x80803660U); + psu_mask_write(0xFD080B04, 0xFFFFFFFFU, 0x55556000U); + psu_mask_write(0xFD080B08, 0xFFFFFFFFU, 0xAAAAAAAAU); + psu_mask_write(0xFD080B0C, 0xFFFFFFFFU, 0x0029A4A4U); + psu_mask_write(0xFD080B10, 0xFFFFFFFFU, 0x0C00B000U); + psu_mask_write(0xFD080B14, 0xFFFFFFFFU, 0x09094F4FU); + psu_mask_write(0xFD080B18, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080C00, 0xFFFFFFFFU, 0x80803660U); + psu_mask_write(0xFD080C04, 0xFFFFFFFFU, 0x55556000U); + psu_mask_write(0xFD080C08, 0xFFFFFFFFU, 0xAAAAAAAAU); + psu_mask_write(0xFD080C0C, 0xFFFFFFFFU, 0x0029A4A4U); + psu_mask_write(0xFD080C10, 0xFFFFFFFFU, 0x0C00B000U); + psu_mask_write(0xFD080C14, 0xFFFFFFFFU, 0x09094F4FU); + psu_mask_write(0xFD080C18, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080D00, 0xFFFFFFFFU, 0x80803660U); + psu_mask_write(0xFD080D04, 0xFFFFFFFFU, 0x55556000U); + psu_mask_write(0xFD080D08, 0xFFFFFFFFU, 0xAAAAAAAAU); + psu_mask_write(0xFD080D0C, 0xFFFFFFFFU, 0x0029A4A4U); + psu_mask_write(0xFD080D10, 0xFFFFFFFFU, 0x0C00B000U); + psu_mask_write(0xFD080D14, 0xFFFFFFFFU, 0x09094F4FU); + psu_mask_write(0xFD080D18, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080E00, 0xFFFFFFFFU, 0x80803660U); + psu_mask_write(0xFD080E04, 0xFFFFFFFFU, 0x55556000U); + psu_mask_write(0xFD080E08, 0xFFFFFFFFU, 0xAAAAAAAAU); + psu_mask_write(0xFD080E0C, 0xFFFFFFFFU, 0x0029A4A4U); + psu_mask_write(0xFD080E10, 0xFFFFFFFFU, 0x0C00B000U); + psu_mask_write(0xFD080E14, 0xFFFFFFFFU, 0x09094F4FU); + psu_mask_write(0xFD080E18, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080F00, 0xFFFFFFFFU, 0x80803660U); + psu_mask_write(0xFD080F04, 0xFFFFFFFFU, 0x55556000U); + psu_mask_write(0xFD080F08, 0xFFFFFFFFU, 0xAAAAAAAAU); + psu_mask_write(0xFD080F0C, 0xFFFFFFFFU, 0x0029A4A4U); + psu_mask_write(0xFD080F10, 0xFFFFFFFFU, 0x0C00B000U); + psu_mask_write(0xFD080F14, 0xFFFFFFFFU, 0x09094F4FU); + psu_mask_write(0xFD080F18, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD081400, 0xFFFFFFFFU, 0x2A019FFEU); + psu_mask_write(0xFD081404, 0xFFFFFFFFU, 0x01100000U); + psu_mask_write(0xFD08141C, 0xFFFFFFFFU, 0x01264300U); + psu_mask_write(0xFD08142C, 0xFFFFFFFFU, 0x00041800U); + psu_mask_write(0xFD081430, 0xFFFFFFFFU, 0x70800000U); + psu_mask_write(0xFD081440, 0xFFFFFFFFU, 0x2A019FFEU); + psu_mask_write(0xFD081444, 0xFFFFFFFFU, 0x01100000U); + psu_mask_write(0xFD08145C, 0xFFFFFFFFU, 0x01264300U); + psu_mask_write(0xFD08146C, 0xFFFFFFFFU, 0x00041800U); + psu_mask_write(0xFD081470, 0xFFFFFFFFU, 0x70800000U); + psu_mask_write(0xFD081480, 0xFFFFFFFFU, 0x15019FFEU); + psu_mask_write(0xFD081484, 0xFFFFFFFFU, 0x21100000U); + psu_mask_write(0xFD08149C, 0xFFFFFFFFU, 0x01266300U); + psu_mask_write(0xFD0814AC, 0xFFFFFFFFU, 0x00041800U); + psu_mask_write(0xFD0814B0, 0xFFFFFFFFU, 0x70400000U); + psu_mask_write(0xFD0814C0, 0xFFFFFFFFU, 0x15019FFEU); + psu_mask_write(0xFD0814C4, 0xFFFFFFFFU, 0x21100000U); + psu_mask_write(0xFD0814DC, 0xFFFFFFFFU, 0x01266300U); + psu_mask_write(0xFD0814EC, 0xFFFFFFFFU, 0x00041800U); + psu_mask_write(0xFD0814F0, 0xFFFFFFFFU, 0x70400000U); + psu_mask_write(0xFD081500, 0xFFFFFFFFU, 0x15019FFEU); + psu_mask_write(0xFD081504, 0xFFFFFFFFU, 0x21100000U); + psu_mask_write(0xFD08151C, 0xFFFFFFFFU, 0x01266300U); + psu_mask_write(0xFD08152C, 0xFFFFFFFFU, 0x00041800U); + psu_mask_write(0xFD081530, 0xFFFFFFFFU, 0x70400000U); + psu_mask_write(0xFD0817DC, 0xFFFFFFFFU, 0x012643C4U); + + return 1; +} + +static unsigned long psu_ddr_qos_init_data(void) +{ + psu_mask_write(0xFD360008, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFD36001C, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFD370008, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFD37001C, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFD380008, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFD38001C, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFD390008, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFD39001C, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFD3A0008, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFD3A001C, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFD3B0008, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFD3B001C, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFF9B0008, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFF9B001C, 0x0000000FU, 0x00000000U); + + return 1; +} + +static unsigned long psu_mio_init_data(void) +{ + psu_mask_write(0xFF180034, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF180038, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF18003C, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF180040, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF180044, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF180048, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF18004C, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF180050, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF180054, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF180058, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF18005C, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF180068, 0x000000FEU, 0x00000080U); + psu_mask_write(0xFF18006C, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180070, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180074, 0x000000FEU, 0x00000080U); + psu_mask_write(0xFF180078, 0x000000FEU, 0x00000080U); + psu_mask_write(0xFF18007C, 0x000000FEU, 0x00000080U); + psu_mask_write(0xFF180080, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180084, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180088, 0x000000FEU, 0x00000040U); + psu_mask_write(0xFF18008C, 0x000000FEU, 0x00000040U); + psu_mask_write(0xFF180090, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180094, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180098, 0x000000FEU, 0x000000C0U); + psu_mask_write(0xFF18009C, 0x000000FEU, 0x000000C0U); + psu_mask_write(0xFF1800A0, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF1800A4, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF1800A8, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF1800AC, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF1800B0, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF1800B4, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800B8, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800BC, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800C0, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800C4, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800C8, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800CC, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800D0, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800D4, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800D8, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800DC, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800E0, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800E4, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800E8, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800EC, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800F0, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800F4, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800F8, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800FC, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF180100, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF180104, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF180108, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF18010C, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF180110, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF180114, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF180118, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF18011C, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF180120, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF180124, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF180128, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF18012C, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF180130, 0x000000FEU, 0x00000060U); + psu_mask_write(0xFF180134, 0x000000FEU, 0x00000060U); + psu_mask_write(0xFF180204, 0xFCFFE000U, 0x00000000U); + psu_mask_write(0xFF180208, 0xFFFFFFFFU, 0x00B02040U); + psu_mask_write(0xFF18020C, 0x00003FFFU, 0x0000000BU); + psu_mask_write(0xFF180138, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF18013C, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180140, 0x03FFFFFFU, 0x033FFFFFU); + psu_mask_write(0xFF180144, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180148, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF18014C, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180154, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180158, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF18015C, 0x03FFFFFFU, 0x01FF9FFFU); + psu_mask_write(0xFF180160, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180164, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180168, 0x03FFFFFFU, 0x03F76FFFU); + psu_mask_write(0xFF180170, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180174, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180178, 0x03FFFFFFU, 0x02FBFFBFU); + psu_mask_write(0xFF18017C, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180180, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180184, 0x03FFFFFFU, 0x03FF4FF4U); + psu_mask_write(0xFF180200, 0x0000000FU, 0x00000000U); + + return 1; +} + +static unsigned long psu_peripherals_pre_init_data(void) +{ + psu_mask_write(0xFF5E0108, 0x013F3F07U, 0x01012302U); + + return 1; +} + +static unsigned long psu_peripherals_init_data(void) +{ + psu_mask_write(0xFD1A0100, 0x0000807CU, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x001A0000U, 0x00000000U); + psu_mask_write(0xFF5E023C, 0x0093C018U, 0x00000000U); + psu_mask_write(0xFF5E0230, 0x00000001U, 0x00000000U); + psu_mask_write(0xFF5E023C, 0x00000C00U, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x00000060U, 0x00000000U); + psu_mask_write(0xFF180310, 0x00008001U, 0x00000001U); + psu_mask_write(0xFF180320, 0x33843384U, 0x00801284U); + psu_mask_write(0xFF18031C, 0x00007FFEU, 0x00006450U); + psu_mask_write(0xFF180358, 0x00080000U, 0x00080000U); + psu_mask_write(0xFF18031C, 0x7FFE0000U, 0x64500000U); + psu_mask_write(0xFF180358, 0x00000008U, 0x00000008U); + psu_mask_write(0xFF180324, 0x000003C0U, 0x00000000U); + psu_mask_write(0xFF180324, 0x03C00000U, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x00000200U, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x00008000U, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x00000008U, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x00007800U, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x00000002U, 0x00000000U); + psu_mask_write(0xFF000034, 0x000000FFU, 0x00000005U); + psu_mask_write(0xFF000018, 0x0000FFFFU, 0x0000008FU); + psu_mask_write(0xFF000000, 0x000001FFU, 0x00000017U); + psu_mask_write(0xFF000004, 0x000003FFU, 0x00000020U); + psu_mask_write(0xFF5E0238, 0x00040000U, 0x00000000U); + psu_mask_write(0xFF4B0024, 0x000000FFU, 0x000000FFU); + psu_mask_write(0xFFCA5000, 0x00001FFFU, 0x00000000U); + psu_mask_write(0xFD5C0060, 0x000F000FU, 0x00000000U); + psu_mask_write(0xFFA60040, 0x80000000U, 0x80000000U); + psu_mask_write(0xFF260020, 0xFFFFFFFFU, 0x01FC9F08U); + psu_mask_write(0xFF260000, 0x00000001U, 0x00000001U); + psu_mask_write(0xFF5E0250, 0x00000F0FU, 0x00000202U); + + mask_delay(1); + psu_mask_write(0xFF5E0250, 0x00000F0FU, 0x00000002U); + + mask_delay(5); + psu_mask_write(0xFF5E0250, 0x00000F0FU, 0x00000202U); + + return 1; +} + +static unsigned long psu_serdes_init_data(void) +{ + psu_mask_write(0xFD410000, 0x0000001FU, 0x0000000FU); + psu_mask_write(0xFD410004, 0x0000001FU, 0x00000008U); + psu_mask_write(0xFD402860, 0x00000080U, 0x00000080U); + psu_mask_write(0xFD402864, 0x00000080U, 0x00000080U); + psu_mask_write(0xFD406094, 0x00000010U, 0x00000010U); + psu_mask_write(0xFD406368, 0x000000FFU, 0x00000038U); + psu_mask_write(0xFD40636C, 0x00000007U, 0x00000003U); + psu_mask_write(0xFD406370, 0x000000FFU, 0x000000F4U); + psu_mask_write(0xFD406374, 0x000000FFU, 0x00000031U); + psu_mask_write(0xFD406378, 0x000000FFU, 0x00000002U); + psu_mask_write(0xFD40637C, 0x00000033U, 0x00000030U); + psu_mask_write(0xFD40106C, 0x0000000FU, 0x0000000FU); + psu_mask_write(0xFD4000F4, 0x0000000BU, 0x0000000BU); + psu_mask_write(0xFD40506C, 0x00000003U, 0x00000003U); + psu_mask_write(0xFD4040F4, 0x00000003U, 0x00000003U); + psu_mask_write(0xFD4050CC, 0x00000020U, 0x00000020U); + psu_mask_write(0xFD401074, 0x00000010U, 0x00000010U); + psu_mask_write(0xFD405074, 0x00000010U, 0x00000010U); + psu_mask_write(0xFD409074, 0x00000010U, 0x00000010U); + psu_mask_write(0xFD40D074, 0x00000010U, 0x00000010U); + psu_mask_write(0xFD40189C, 0x00000080U, 0x00000080U); + psu_mask_write(0xFD4018F8, 0x000000FFU, 0x0000007DU); + psu_mask_write(0xFD4018FC, 0x000000FFU, 0x0000007DU); + psu_mask_write(0xFD401990, 0x000000FFU, 0x00000000U); + psu_mask_write(0xFD401924, 0x000000FFU, 0x00000082U); + psu_mask_write(0xFD401928, 0x000000FFU, 0x00000000U); + psu_mask_write(0xFD401900, 0x000000FFU, 0x00000064U); + psu_mask_write(0xFD40192C, 0x000000FFU, 0x00000000U); + psu_mask_write(0xFD401980, 0x000000FFU, 0x000000FFU); + psu_mask_write(0xFD401914, 0x000000FFU, 0x000000FFU); + psu_mask_write(0xFD401918, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD401940, 0x000000FFU, 0x000000FFU); + psu_mask_write(0xFD401944, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD401994, 0x00000007U, 0x00000007U); + psu_mask_write(0xFD40589C, 0x00000080U, 0x00000080U); + psu_mask_write(0xFD4058F8, 0x000000FFU, 0x0000001AU); + psu_mask_write(0xFD4058FC, 0x000000FFU, 0x0000001AU); + psu_mask_write(0xFD405990, 0x000000FFU, 0x00000010U); + psu_mask_write(0xFD405924, 0x000000FFU, 0x000000FEU); + psu_mask_write(0xFD405928, 0x000000FFU, 0x00000000U); + psu_mask_write(0xFD405900, 0x000000FFU, 0x0000001AU); + psu_mask_write(0xFD40592C, 0x000000FFU, 0x00000000U); + psu_mask_write(0xFD405980, 0x000000FFU, 0x000000FFU); + psu_mask_write(0xFD405914, 0x000000FFU, 0x000000F7U); + psu_mask_write(0xFD405918, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD405940, 0x000000FFU, 0x000000F7U); + psu_mask_write(0xFD405944, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD405994, 0x00000007U, 0x00000007U); + psu_mask_write(0xFD409994, 0x00000007U, 0x00000007U); + psu_mask_write(0xFD40D994, 0x00000007U, 0x00000007U); + psu_mask_write(0xFD40107C, 0x0000000FU, 0x00000001U); + psu_mask_write(0xFD40507C, 0x0000000FU, 0x00000001U); + psu_mask_write(0xFD40907C, 0x0000000FU, 0x00000001U); + psu_mask_write(0xFD40D07C, 0x0000000FU, 0x00000001U); + psu_mask_write(0xFD4019A4, 0x000000FFU, 0x000000FFU); + psu_mask_write(0xFD401038, 0x00000040U, 0x00000040U); + psu_mask_write(0xFD40102C, 0x00000040U, 0x00000040U); + psu_mask_write(0xFD4059A4, 0x000000FFU, 0x000000FFU); + psu_mask_write(0xFD405038, 0x00000040U, 0x00000040U); + psu_mask_write(0xFD40502C, 0x00000040U, 0x00000040U); + psu_mask_write(0xFD4099A4, 0x000000FFU, 0x000000FFU); + psu_mask_write(0xFD409038, 0x00000040U, 0x00000040U); + psu_mask_write(0xFD40902C, 0x00000040U, 0x00000040U); + psu_mask_write(0xFD40D9A4, 0x000000FFU, 0x000000FFU); + psu_mask_write(0xFD40D038, 0x00000040U, 0x00000040U); + psu_mask_write(0xFD40D02C, 0x00000040U, 0x00000040U); + psu_mask_write(0xFD4019AC, 0x00000003U, 0x00000000U); + psu_mask_write(0xFD4059AC, 0x00000003U, 0x00000000U); + psu_mask_write(0xFD4099AC, 0x00000003U, 0x00000000U); + psu_mask_write(0xFD40D9AC, 0x00000003U, 0x00000000U); + psu_mask_write(0xFD401978, 0x00000010U, 0x00000010U); + psu_mask_write(0xFD405978, 0x00000010U, 0x00000010U); + psu_mask_write(0xFD409978, 0x00000010U, 0x00000010U); + psu_mask_write(0xFD40D978, 0x00000010U, 0x00000010U); + psu_mask_write(0xFD410010, 0x00000077U, 0x00000035U); + psu_mask_write(0xFD410040, 0x00000003U, 0x00000000U); + psu_mask_write(0xFD410044, 0x00000003U, 0x00000000U); + + return 1; +} + +static unsigned long psu_resetout_init_data(void) +{ + psu_mask_write(0xFF5E023C, 0x00000400U, 0x00000000U); + psu_mask_write(0xFF9D0080, 0x00000001U, 0x00000001U); + psu_mask_write(0xFF9D007C, 0x00000001U, 0x00000000U); + psu_mask_write(0xFF5E023C, 0x00000140U, 0x00000000U); + psu_mask_write(0xFF5E023C, 0x00000800U, 0x00000000U); + psu_mask_write(0xFF9E0080, 0x00000001U, 0x00000001U); + psu_mask_write(0xFF9E007C, 0x00000001U, 0x00000001U); + psu_mask_write(0xFF5E023C, 0x00000280U, 0x00000000U); + psu_mask_write(0xFF5E0230, 0x00000001U, 0x00000000U); + psu_mask_write(0xFE20C200, 0x00023FFFU, 0x00022457U); + psu_mask_write(0xFE20C630, 0x003FFF00U, 0x00000000U); + psu_mask_write(0xFE20C11C, 0x00000600U, 0x00000600U); + psu_mask_write(0xFE20C12C, 0x00004000U, 0x00004000U); + psu_mask_write(0xFE30C200, 0x00023FFFU, 0x00022457U); + psu_mask_write(0xFE30C630, 0x003FFF00U, 0x00000000U); + psu_mask_write(0xFE30C12C, 0x00004000U, 0x00004000U); + psu_mask_write(0xFE30C11C, 0x00000400U, 0x00000400U); + psu_mask_write(0xFD480064, 0x00000200U, 0x00000200U); + mask_poll(0xFD4023E4, 0x00000010U); + mask_poll(0xFD4063E4, 0x00000010U); + + return 1; +} + +static unsigned long psu_resetin_init_data(void) +{ + psu_mask_write(0xFF5E023C, 0x00000540U, 0x00000540U); + psu_mask_write(0xFF5E023C, 0x00000A80U, 0x00000A80U); + psu_mask_write(0xFF5E0230, 0x00000001U, 0x00000001U); + + return 1; +} + +static unsigned long psu_afi_config(void) +{ + psu_mask_write(0xFD1A0100, 0x00001F80U, 0x00000000U); + psu_mask_write(0xFF5E023C, 0x00080000U, 0x00000000U); + psu_mask_write(0xFD615000, 0x00000F00U, 0x00000A00U); + psu_mask_write(0xFF419000, 0x00000300U, 0x00000000U); + psu_mask_write(0xFD360000, 0x00000003U, 0x00000000U); + psu_mask_write(0xFD360014, 0x00000003U, 0x00000000U); + + return 1; +} + +static unsigned long psu_ddr_phybringup_data(void) +{ + unsigned int regval = 0; + unsigned int pll_retry = 10; + unsigned int pll_locked = 0; + int cur_r006_trefprd; + + while ((pll_retry > 0) && (!pll_locked)) { + Xil_Out32(0xFD080004, 0x00040010); + Xil_Out32(0xFD080004, 0x00040011); + + while ((Xil_In32(0xFD080030) & 0x1) != 1) + ; + pll_locked = (Xil_In32(0xFD080030) & 0x80000000) + >> 31; + pll_locked &= (Xil_In32(0xFD0807E0) & 0x10000) + >> 16; + pll_locked &= (Xil_In32(0xFD0809E0) & 0x10000) + >> 16; + pll_retry--; + } + Xil_Out32(0xFD0800C4, Xil_In32(0xFD0800C4) | (pll_retry << 16)); + if (!pll_locked) + return 0; + + Xil_Out32(0xFD080004U, 0x00040063U); + + while ((Xil_In32(0xFD080030U) & 0x0000000FU) != 0x0000000FU) + ; + prog_reg(0xFD080004U, 0x00000001U, 0x00000000U, 0x00000001U); + + while ((Xil_In32(0xFD080030U) & 0x000000FFU) != 0x0000001FU) + ; + Xil_Out32(0xFD0701B0U, 0x00000001U); + Xil_Out32(0xFD070320U, 0x00000001U); + while ((Xil_In32(0xFD070004U) & 0x0000000FU) != 0x00000001U) + ; + prog_reg(0xFD080014U, 0x00000040U, 0x00000006U, 0x00000001U); + Xil_Out32(0xFD080004, 0x0004FE01); + regval = Xil_In32(0xFD080030); + while (regval != 0x80000FFF) + regval = Xil_In32(0xFD080030); + regval = ((Xil_In32(0xFD080030) & 0x1FFF0000) >> 18); + if (regval != 0) + return 0; + + Xil_Out32(0xFD080200U, 0x110091C7U); + + cur_r006_trefprd = (Xil_In32(0xFD080018U) & 0x0003FFFFU) >> 0x00000000U; + prog_reg(0xFD080018, 0x3FFFF, 0x0, cur_r006_trefprd); + + prog_reg(0xFD08001CU, 0x00000018U, 0x00000003U, 0x00000003U); + prog_reg(0xFD08142CU, 0x00000030U, 0x00000004U, 0x00000003U); + prog_reg(0xFD08146CU, 0x00000030U, 0x00000004U, 0x00000003U); + prog_reg(0xFD0814ACU, 0x00000030U, 0x00000004U, 0x00000003U); + prog_reg(0xFD0814ECU, 0x00000030U, 0x00000004U, 0x00000003U); + prog_reg(0xFD08152CU, 0x00000030U, 0x00000004U, 0x00000003U); + + Xil_Out32(0xFD080004, 0x00060001); + regval = Xil_In32(0xFD080030); + while ((regval & 0x80004001) != 0x80004001) + regval = Xil_In32(0xFD080030); + + prog_reg(0xFD08001CU, 0x00000018U, 0x00000003U, 0x00000000U); + prog_reg(0xFD08142CU, 0x00000030U, 0x00000004U, 0x00000000U); + prog_reg(0xFD08146CU, 0x00000030U, 0x00000004U, 0x00000000U); + prog_reg(0xFD0814ACU, 0x00000030U, 0x00000004U, 0x00000000U); + prog_reg(0xFD0814ECU, 0x00000030U, 0x00000004U, 0x00000000U); + prog_reg(0xFD08152CU, 0x00000030U, 0x00000004U, 0x00000000U); + + Xil_Out32(0xFD080200U, 0x810091C7U); + prog_reg(0xFD080018, 0x3FFFF, 0x0, cur_r006_trefprd); + + Xil_Out32(0xFD080004, 0x0000C001); + regval = Xil_In32(0xFD080030); + while ((regval & 0x80000C01) != 0x80000C01) + regval = Xil_In32(0xFD080030); + + Xil_Out32(0xFD070180U, 0x01000040U); + Xil_Out32(0xFD070060U, 0x00000000U); + prog_reg(0xFD080014U, 0x00000040U, 0x00000006U, 0x00000000U); + + return 1; +} + +static int serdes_enb_coarse_saturation(void) +{ + Xil_Out32(0xFD402094, 0x00000010); + Xil_Out32(0xFD406094, 0x00000010); + Xil_Out32(0xFD40A094, 0x00000010); + Xil_Out32(0xFD40E094, 0x00000010); + return 1; +} + +static int serdes_fixcal_code(void) +{ + int maskstatus = 1; + unsigned int rdata = 0; + unsigned int match_pmos_code[23]; + unsigned int match_nmos_code[23]; + unsigned int match_ical_code[7]; + unsigned int match_rcal_code[7]; + unsigned int p_code = 0, n_code = 0, i_code = 0, r_code = 0; + unsigned int repeat_count = 0; + unsigned int L3_TM_CALIB_DIG20 = 0; + unsigned int L3_TM_CALIB_DIG19 = 0; + unsigned int L3_TM_CALIB_DIG18 = 0; + unsigned int L3_TM_CALIB_DIG16 = 0; + unsigned int L3_TM_CALIB_DIG15 = 0; + unsigned int L3_TM_CALIB_DIG14 = 0; + int count = 0, i = 0; + + rdata = Xil_In32(0xFD40289C); + rdata = rdata & ~0x03; + rdata = rdata | 0x1; + Xil_Out32(0xFD40289C, rdata); + + do { + if (count == 1100000) + break; + rdata = Xil_In32(0xFD402B1C); + count++; + } while ((rdata & 0x0000000E) != 0x0000000E); + + for (i = 0; i < 23; i++) { + match_pmos_code[i] = 0; + match_nmos_code[i] = 0; + } + for (i = 0; i < 7; i++) { + match_ical_code[i] = 0; + match_rcal_code[i] = 0; + } + + do { + Xil_Out32(0xFD410010, 0x00000000); + Xil_Out32(0xFD410014, 0x00000000); + + Xil_Out32(0xFD410010, 0x00000001); + Xil_Out32(0xFD410014, 0x00000000); + + maskstatus = mask_poll(0xFD40EF14, 0x2); + if (maskstatus == 0) { + xil_printf("#SERDES initialization timed out\n\r"); + return maskstatus; + } + + p_code = mask_read(0xFD40EF18, 0xFFFFFFFF); + n_code = mask_read(0xFD40EF1C, 0xFFFFFFFF); + ; + i_code = mask_read(0xFD40EF24, 0xFFFFFFFF); + r_code = mask_read(0xFD40EF28, 0xFFFFFFFF); + ; + + if (p_code >= 0x26 && p_code <= 0x3C) + match_pmos_code[p_code - 0x26] += 1; + + if (n_code >= 0x26 && n_code <= 0x3C) + match_nmos_code[n_code - 0x26] += 1; + + if (i_code >= 0xC && i_code <= 0x12) + match_ical_code[i_code - 0xc] += 1; + + if (r_code >= 0x6 && r_code <= 0xC) + match_rcal_code[r_code - 0x6] += 1; + + } while (repeat_count++ < 10); + + for (i = 0; i < 23; i++) { + if (match_pmos_code[i] >= match_pmos_code[0]) { + match_pmos_code[0] = match_pmos_code[i]; + p_code = 0x26 + i; + } + if (match_nmos_code[i] >= match_nmos_code[0]) { + match_nmos_code[0] = match_nmos_code[i]; + n_code = 0x26 + i; + } + } + + for (i = 0; i < 7; i++) { + if (match_ical_code[i] >= match_ical_code[0]) { + match_ical_code[0] = match_ical_code[i]; + i_code = 0xC + i; + } + if (match_rcal_code[i] >= match_rcal_code[0]) { + match_rcal_code[0] = match_rcal_code[i]; + r_code = 0x6 + i; + } + } + + L3_TM_CALIB_DIG20 = mask_read(0xFD40EC50, 0xFFFFFFF0); + L3_TM_CALIB_DIG20 = L3_TM_CALIB_DIG20 | 0x8 | ((p_code >> 2) & 0x7); + + L3_TM_CALIB_DIG19 = mask_read(0xFD40EC4C, 0xFFFFFF18); + L3_TM_CALIB_DIG19 = L3_TM_CALIB_DIG19 | ((p_code & 0x3) << 6) + | 0x20 | 0x4 | ((n_code >> 3) & 0x3); + + L3_TM_CALIB_DIG18 = mask_read(0xFD40EC48, 0xFFFFFF0F); + L3_TM_CALIB_DIG18 = L3_TM_CALIB_DIG18 | ((n_code & 0x7) << 5) | 0x10; + + L3_TM_CALIB_DIG16 = mask_read(0xFD40EC40, 0xFFFFFFF8); + L3_TM_CALIB_DIG16 = L3_TM_CALIB_DIG16 | ((r_code >> 1) & 0x7); + + L3_TM_CALIB_DIG15 = mask_read(0xFD40EC3C, 0xFFFFFF30); + L3_TM_CALIB_DIG15 = L3_TM_CALIB_DIG15 | ((r_code & 0x1) << 7) + | 0x40 | 0x8 | ((i_code >> 1) & 0x7); + + L3_TM_CALIB_DIG14 = mask_read(0xFD40EC38, 0xFFFFFF3F); + L3_TM_CALIB_DIG14 = L3_TM_CALIB_DIG14 | ((i_code & 0x1) << 7) | 0x40; + + Xil_Out32(0xFD40EC50, L3_TM_CALIB_DIG20); + Xil_Out32(0xFD40EC4C, L3_TM_CALIB_DIG19); + Xil_Out32(0xFD40EC48, L3_TM_CALIB_DIG18); + Xil_Out32(0xFD40EC40, L3_TM_CALIB_DIG16); + Xil_Out32(0xFD40EC3C, L3_TM_CALIB_DIG15); + Xil_Out32(0xFD40EC38, L3_TM_CALIB_DIG14); + return maskstatus; +} + +static int init_serdes(void) +{ + int status = 1; + + status &= psu_resetin_init_data(); + + status &= serdes_fixcal_code(); + status &= serdes_enb_coarse_saturation(); + + status &= psu_serdes_init_data(); + status &= psu_resetout_init_data(); + + return status; +} + +static void init_peripheral(void) +{ + psu_mask_write(0xFD5F0018, 0x8000001FU, 0x8000001FU); +} + +int psu_init(void) +{ + int status = 1; + + status &= psu_mio_init_data(); + status &= psu_peripherals_pre_init_data(); + status &= psu_pll_init_data(); + status &= psu_clock_init_data(); + status &= psu_ddr_init_data(); + status &= psu_ddr_phybringup_data(); + status &= psu_peripherals_init_data(); + status &= init_serdes(); + init_peripheral(); + + status &= psu_afi_config(); + psu_ddr_qos_init_data(); + + if (status == 0) + return 1; + return 0; +} diff --git a/configs/xilinx_zynqmp_virt_defconfig b/configs/xilinx_zynqmp_virt_defconfig index f14ea5ee142a..e56ed781e3e9 100644 --- a/configs/xilinx_zynqmp_virt_defconfig +++ b/configs/xilinx_zynqmp_virt_defconfig @@ -83,7 +83,7 @@ CONFIG_CMD_MTDPARTS_SHOW_NET_SIZES=y CONFIG_CMD_UBI=y CONFIG_PARTITION_TYPE_GUID=y CONFIG_SPL_OF_CONTROL=y -CONFIG_OF_LIST="avnet-ultra96-rev1 zynqmp-a2197-revA zynqmp-e-a2197-00-revA zynqmp-g-a2197-00-revA zynqmp-m-a2197-01-revA zynqmp-m-a2197-02-revA zynqmp-m-a2197-03-revA zynqmp-p-a2197-00-revA zynqmp-zc1232-revA zynqmp-zc1254-revA zynqmp-zc1751-xm015-dc1 zynqmp-zc1751-xm016-dc2 zynqmp-zc1751-xm017-dc3 zynqmp-zc1751-xm018-dc4 zynqmp-zc1751-xm019-dc5 zynqmp-zcu100-revC zynqmp-zcu102-rev1.1 zynqmp-zcu102-rev1.0 zynqmp-zcu102-revA zynqmp-zcu102-revB zynqmp-zcu104-revA zynqmp-zcu104-revC zynqmp-zcu106-revA zynqmp-zcu111-revA zynqmp-zcu1275-revA zynqmp-zcu1275-revB zynqmp-zcu1285-revA zynqmp-zcu208-revA zynqmp-zcu216-revA zynqmp-topic-miamimp-xilinx-xdp-v1r1 zynqmp-sm-k26-revA zynqmp-smk-k26-revA" +CONFIG_OF_LIST="avnet-ultra96-rev1 zynqmp-a2197-revA zynqmp-e-a2197-00-revA zynqmp-g-a2197-00-revA zynqmp-m-a2197-01-revA zynqmp-m-a2197-02-revA zynqmp-m-a2197-03-revA zynqmp-p-a2197-00-revA zynqmp-zc1232-revA zynqmp-zc1254-revA zynqmp-zc1751-xm015-dc1 zynqmp-zc1751-xm016-dc2 zynqmp-zc1751-xm017-dc3 zynqmp-zc1751-xm018-dc4 zynqmp-zc1751-xm019-dc5 zynqmp-zcu100-revC zynqmp-zcu102-rev1.1 zynqmp-zcu102-rev1.0 zynqmp-zcu102-revA zynqmp-zcu102-revB zynqmp-zcu104-revA zynqmp-zcu104-revC zynqmp-zcu106-revA zynqmp-zcu111-revA zynqmp-zcu1275-revA zynqmp-zcu1275-revB zynqmp-zcu1285-revA zynqmp-zcu208-revA zynqmp-zcu216-revA zynqmp-topic-miamimp-xilinx-xdp-v1r1 zynqmp-sm-k26-revA zynqmp-smk-k26-revA zynqmp-dlc21-revA" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names interrupt-parent interrupts iommus power-domains" CONFIG_ENV_IS_NOWHERE=y CONFIG_ENV_IS_IN_FAT=y
- zynqmp-dlc21-revA.dtb \ zynqmp-e-a2197-00-revA.dtb \ zynqmp-g-a2197-00-revA.dtb \ zynqmp-m-a2197-01-revA.dtb \
- dts file for Xilinx ZynqMP DLC21 revA
- (C) Copyright 2019 - 2021, Xilinx, Inc.
- Michal Simek michal.simek@xilinx.com
+/dts-v1/;
- model = "Smartlynq+ DLC21 RevA";
- compatible = "xlnx,zynqmp-dlc21-revA", "xlnx,zynqmp-dlc21",
"xlnx,zynqmp";
- aliases {
ethernet0 = &gem0;
gpio0 = &gpio;
i2c0 = &i2c0;
mmc0 = &sdhci0;
mmc1 = &sdhci1;
rtc0 = &rtc;
serial0 = &uart0;
serial2 = &dcc;
usb0 = &usb0;
usb1 = &usb1;
spi0 = &spi0;
nvmem0 = &eeprom;
- chosen {
- memory@0 {
- si5332_1: si5332_1 { /* clk0_sgmii - u142 */
#clock-cells = <0>;
- si5332_2: si5332_2 { /* clk1_usb - u142 */
#clock-cells = <0>;
- status = "okay";
- non-removable;
- disable-wp;
- bus-width = <8>;
- xlnx,mio_bank = <0>;
- status = "okay";
- no-1-8-v;
- disable-wp;
- xlnx,mio_bank = <1>;
+&psgtr {
- status = "okay";
- /* sgmii, usb3 */
- clocks = <&si5332_1>, <&si5332_2>;
- clock-names = "ref0", "ref1";
- status = "okay";
- u-boot,dm-pre-reloc;
+&gem0 {
- status = "okay";
- phy-handle = <&phy0>;
- phy-mode = "sgmii"; /* DTG generates this properly 1512 */
- is-internal-pcspma;
- /* phy-reset-gpios = <&gpio 142 GPIO_ACTIVE_LOW>; */
- phy0: ethernet-phy@0 {
reg = <0>;
+&gpio {
- status = "okay";
- gpio-line-names = "", "", "", "", "", /* 0 - 4 */
- status = "okay";
- clock-frequency = <400000>;
- jtag_vref: mcp4725@62 {
reg = <0x62>;
- eeprom: eeprom@50 { /* u46 */
reg = <0x50>;
- /* u138 - TUSB320IRWBR - for USB-C */
+&usb0 {
- status = "okay";
- xlnx,usb-polarity = <0>;
- xlnx,usb-reset-mode = <0>;
+&dwc3_0 {
- status = "okay";
- dr_mode = "peripheral";
- snps,dis_u2_susphy_quirk;
- snps,dis_u3_susphy_quirk;
- maximum-speed = "super-speed";
- phy-names = "usb3-phy";
- phys = <&psgtr 1 PHY_TYPE_USB3 0 1>;
+&usb1 {
- status = "disabled"; /* Any unknown issue with USB-C */
+&dwc3_1 {
- /delete-property/ phy-names ;
- /delete-property/ phys ;
- dr_mode = "host";
- maximum-speed = "high-speed";
- snps,dis_u2_susphy_quirk ;
- snps,dis_u3_susphy_quirk ;
- status = "okay";
+&xilinx_ams {
- status = "okay";
+&ams_ps {
- status = "okay";
+&ams_pl {
- status = "okay";
+&spi0 {
- status = "okay";
- is-decoded-cs = <0>;
- num-cs = <1>;
- displayspi@0 {
reg = <0>;
status = "okay";
spi-cpol;
spi-cpha;
rotate = <0>;
fps = <50>;
buswidth = <8>;
txbuflen = <64000>;
debug = <0>;
- (c) Copyright 2015 Xilinx, Inc. All rights reserved.
- psu_mask_write(0xFF5E0034, 0xFE7FEDEFU, 0x7E4B0C62U);
- psu_mask_write(0xFF5E0030, 0x00717F00U, 0x00014000U);
- psu_mask_write(0xFF5E0030, 0x00000008U, 0x00000008U);
- psu_mask_write(0xFF5E0030, 0x00000001U, 0x00000001U);
- psu_mask_write(0xFF5E0030, 0x00000001U, 0x00000000U);
- mask_poll(0xFF5E0040, 0x00000002U);
- psu_mask_write(0xFF5E0030, 0x00000008U, 0x00000000U);
- psu_mask_write(0xFF5E0048, 0x00003F00U, 0x00000200U);
- psu_mask_write(0xFF5E0038, 0x8000FFFFU, 0x00000000U);
- psu_mask_write(0xFF5E0108, 0x013F3F07U, 0x01012300U);
- psu_mask_write(0xFF5E0024, 0xFE7FEDEFU, 0x7E4B0C82U);
- psu_mask_write(0xFF5E0020, 0x00717F00U, 0x00015A00U);
- psu_mask_write(0xFF5E0020, 0x00000008U, 0x00000008U);
- psu_mask_write(0xFF5E0020, 0x00000001U, 0x00000001U);
- psu_mask_write(0xFF5E0020, 0x00000001U, 0x00000000U);
- mask_poll(0xFF5E0040, 0x00000001U);
- psu_mask_write(0xFF5E0020, 0x00000008U, 0x00000000U);
- psu_mask_write(0xFF5E0044, 0x00003F00U, 0x00000300U);
- psu_mask_write(0xFF5E0028, 0x8000FFFFU, 0x00000000U);
- psu_mask_write(0xFD1A0024, 0xFE7FEDEFU, 0x7E4B0C62U);
- psu_mask_write(0xFD1A0020, 0x00717F00U, 0x00014800U);
- psu_mask_write(0xFD1A0020, 0x00000008U, 0x00000008U);
- psu_mask_write(0xFD1A0020, 0x00000001U, 0x00000001U);
- psu_mask_write(0xFD1A0020, 0x00000001U, 0x00000000U);
- mask_poll(0xFD1A0044, 0x00000001U);
- psu_mask_write(0xFD1A0020, 0x00000008U, 0x00000000U);
- psu_mask_write(0xFD1A0048, 0x00003F00U, 0x00000300U);
- psu_mask_write(0xFD1A0028, 0x8000FFFFU, 0x00000000U);
- psu_mask_write(0xFD1A0030, 0xFE7FEDEFU, 0x7E4B0C62U);
- psu_mask_write(0xFD1A002C, 0x00717F00U, 0x00014000U);
- psu_mask_write(0xFD1A002C, 0x00000008U, 0x00000008U);
- psu_mask_write(0xFD1A002C, 0x00000001U, 0x00000001U);
- psu_mask_write(0xFD1A002C, 0x00000001U, 0x00000000U);
- mask_poll(0xFD1A0044, 0x00000002U);
- psu_mask_write(0xFD1A002C, 0x00000008U, 0x00000000U);
- psu_mask_write(0xFD1A004C, 0x00003F00U, 0x00000200U);
- psu_mask_write(0xFD1A0034, 0x8000FFFFU, 0x00000000U);
- psu_mask_write(0xFD1A003C, 0xFE7FEDEFU, 0x7E4B0C62U);
- psu_mask_write(0xFD1A0038, 0x00717F00U, 0x00014000U);
- psu_mask_write(0xFD1A0038, 0x00000008U, 0x00000008U);
- psu_mask_write(0xFD1A0038, 0x00000001U, 0x00000001U);
- psu_mask_write(0xFD1A0038, 0x00000001U, 0x00000000U);
- mask_poll(0xFD1A0044, 0x00000004U);
- psu_mask_write(0xFD1A0038, 0x00000008U, 0x00000000U);
- psu_mask_write(0xFD1A0050, 0x00003F00U, 0x00000200U);
- psu_mask_write(0xFD1A0040, 0x8000FFFFU, 0x00000000U);
- return 1;
- psu_mask_write(0xFF5E0050, 0x063F3F07U, 0x06013C00U);
- psu_mask_write(0xFF180360, 0x00000003U, 0x00000001U);
- psu_mask_write(0xFF180308, 0x00000006U, 0x00000006U);
- psu_mask_write(0xFF5E0100, 0x013F3F07U, 0x01010600U);
- psu_mask_write(0xFF5E0060, 0x023F3F07U, 0x02010600U);
- psu_mask_write(0xFF5E0064, 0x023F3F07U, 0x02010600U);
- psu_mask_write(0xFF5E004C, 0x023F3F07U, 0x02031900U);
- psu_mask_write(0xFF5E006C, 0x013F3F07U, 0x01010800U);
- psu_mask_write(0xFF5E0070, 0x013F3F07U, 0x01010800U);
- psu_mask_write(0xFF18030C, 0x00020003U, 0x00000000U);
- psu_mask_write(0xFF5E0074, 0x013F3F07U, 0x01010F00U);
- psu_mask_write(0xFF5E0120, 0x013F3F07U, 0x01010F00U);
- psu_mask_write(0xFF5E007C, 0x013F3F07U, 0x01010702U);
- psu_mask_write(0xFF5E0090, 0x01003F07U, 0x01000302U);
- psu_mask_write(0xFF5E009C, 0x01003F07U, 0x01000400U);
- psu_mask_write(0xFF5E00A4, 0x01003F07U, 0x01000800U);
- psu_mask_write(0xFF5E00A8, 0x01003F07U, 0x01000200U);
- psu_mask_write(0xFF5E00AC, 0x01003F07U, 0x01000F02U);
- psu_mask_write(0xFF5E00B0, 0x01003F07U, 0x01000602U);
- psu_mask_write(0xFF5E00B8, 0x01003F07U, 0x01000200U);
- psu_mask_write(0xFF5E00C0, 0x013F3F07U, 0x01010502U);
- psu_mask_write(0xFF5E00C4, 0x013F3F07U, 0x01010802U);
- psu_mask_write(0xFF5E00C8, 0x013F3F07U, 0x01010402U);
- psu_mask_write(0xFF5E00CC, 0x013F3F07U, 0x01030A00U);
- psu_mask_write(0xFF5E0108, 0x013F3F07U, 0x01011E02U);
- psu_mask_write(0xFF5E0104, 0x00000007U, 0x00000000U);
- psu_mask_write(0xFF5E0128, 0x01003F07U, 0x01000104U);
- psu_mask_write(0xFD1A0060, 0x03003F07U, 0x03000100U);
- psu_mask_write(0xFD1A0068, 0x01003F07U, 0x01000200U);
- psu_mask_write(0xFD1A0080, 0x00003F07U, 0x00000200U);
- psu_mask_write(0xFD1A0084, 0x07003F07U, 0x07000100U);
- psu_mask_write(0xFD1A00B8, 0x01003F07U, 0x01000203U);
- psu_mask_write(0xFD1A00BC, 0x01003F07U, 0x01000203U);
- psu_mask_write(0xFD1A00C0, 0x01003F07U, 0x01000202U);
- psu_mask_write(0xFD1A00C4, 0x01003F07U, 0x01000502U);
- psu_mask_write(0xFD1A00F8, 0x00003F07U, 0x00000200U);
- psu_mask_write(0xFF180380, 0x000000FFU, 0x00000000U);
- psu_mask_write(0xFD610100, 0x00000001U, 0x00000000U);
- psu_mask_write(0xFF180300, 0x00000001U, 0x00000000U);
- psu_mask_write(0xFF410050, 0x00000001U, 0x00000000U);
- return 1;
- psu_mask_write(0xFD1A0108, 0x00000008U, 0x00000008U);
- psu_mask_write(0xFD070000, 0xE30FBE3DU, 0x43041010U);
- psu_mask_write(0xFD070010, 0x8000F03FU, 0x00000030U);
- psu_mask_write(0xFD070020, 0x000003F3U, 0x00000200U);
- psu_mask_write(0xFD070024, 0xFFFFFFFFU, 0x00800000U);
- psu_mask_write(0xFD070030, 0x0000007FU, 0x00000008U);
- psu_mask_write(0xFD070034, 0x00FFFF1FU, 0x00408410U);
- psu_mask_write(0xFD070050, 0x00F1F1F4U, 0x00210000U);
- psu_mask_write(0xFD070054, 0x0FFF0FFFU, 0x00000000U);
- psu_mask_write(0xFD070060, 0x00000073U, 0x00000001U);
- psu_mask_write(0xFD070064, 0x0FFF83FFU, 0x00818126U);
- psu_mask_write(0xFD070070, 0x00000017U, 0x00000010U);
- psu_mask_write(0xFD070074, 0x00000003U, 0x00000000U);
- psu_mask_write(0xFD0700C4, 0x3F000391U, 0x10000200U);
- psu_mask_write(0xFD0700C8, 0x01FF1F3FU, 0x0040051FU);
- psu_mask_write(0xFD0700D0, 0xC3FF0FFFU, 0x00020106U);
- psu_mask_write(0xFD0700D4, 0x01FF7F0FU, 0x00020000U);
- psu_mask_write(0xFD0700D8, 0x0000FF0FU, 0x00002305U);
- psu_mask_write(0xFD0700DC, 0xFFFFFFFFU, 0x07300501U);
- psu_mask_write(0xFD0700E0, 0xFFFFFFFFU, 0x00200200U);
- psu_mask_write(0xFD0700E4, 0x00FF03FFU, 0x00210004U);
- psu_mask_write(0xFD0700E8, 0xFFFFFFFFU, 0x00000700U);
- psu_mask_write(0xFD0700EC, 0xFFFF0000U, 0x08190000U);
- psu_mask_write(0xFD0700F0, 0x0000003FU, 0x00000010U);
- psu_mask_write(0xFD0700F4, 0x00000FFFU, 0x0000066FU);
- psu_mask_write(0xFD070100, 0x7F3F7F3FU, 0x110C2412U);
- psu_mask_write(0xFD070104, 0x001F1F7FU, 0x0004041CU);
- psu_mask_write(0xFD070108, 0x3F3F3F3FU, 0x0708060DU);
- psu_mask_write(0xFD07010C, 0x3FF3F3FFU, 0x0050400CU);
- psu_mask_write(0xFD070110, 0x1F0F0F1FU, 0x08030309U);
- psu_mask_write(0xFD070114, 0x0F0F3F1FU, 0x06060403U);
- psu_mask_write(0xFD070118, 0x0F0F000FU, 0x01010004U);
- psu_mask_write(0xFD07011C, 0x00000F0FU, 0x00000606U);
- psu_mask_write(0xFD070120, 0x7F7F7F7FU, 0x04040D0BU);
- psu_mask_write(0xFD070124, 0x40070F3FU, 0x0002020BU);
- psu_mask_write(0xFD07012C, 0x7F1F031FU, 0x1607010EU);
- psu_mask_write(0xFD070130, 0x00030F1FU, 0x00020608U);
- psu_mask_write(0xFD070180, 0xF7FF03FFU, 0x81000040U);
- psu_mask_write(0xFD070184, 0x3FFFFFFFU, 0x020196E5U);
- psu_mask_write(0xFD070190, 0x1FBFBF3FU, 0x048B820BU);
- psu_mask_write(0xFD070194, 0xF31F0F0FU, 0x00030304U);
- psu_mask_write(0xFD070198, 0x0FF1F1F1U, 0x07000101U);
- psu_mask_write(0xFD07019C, 0x000000F1U, 0x00000021U);
- psu_mask_write(0xFD0701A0, 0xC3FF03FFU, 0x00400003U);
- psu_mask_write(0xFD0701A4, 0x00FF00FFU, 0x00C800FFU);
- psu_mask_write(0xFD0701B0, 0x00000007U, 0x00000000U);
- psu_mask_write(0xFD0701B4, 0x00003F3FU, 0x00000909U);
- psu_mask_write(0xFD0701C0, 0x00000007U, 0x00000001U);
- psu_mask_write(0xFD070200, 0x0000001FU, 0x00000018U);
- psu_mask_write(0xFD070204, 0x001F1F1FU, 0x001F0909U);
- psu_mask_write(0xFD070208, 0x0F0F0F0FU, 0x01010101U);
- psu_mask_write(0xFD07020C, 0x0F0F0F0FU, 0x0F010101U);
- psu_mask_write(0xFD070210, 0x00000F0FU, 0x00000F0FU);
- psu_mask_write(0xFD070214, 0x0F0F0F0FU, 0x070F0707U);
- psu_mask_write(0xFD070218, 0x8F0F0F0FU, 0x07070707U);
- psu_mask_write(0xFD07021C, 0x00000F0FU, 0x00000F07U);
- psu_mask_write(0xFD070220, 0x00001F1FU, 0x00000700U);
- psu_mask_write(0xFD070224, 0x0F0F0F0FU, 0x07070707U);
- psu_mask_write(0xFD070228, 0x0F0F0F0FU, 0x07070707U);
- psu_mask_write(0xFD07022C, 0x0000000FU, 0x00000007U);
- psu_mask_write(0xFD070240, 0x0F1F0F7CU, 0x06000600U);
- psu_mask_write(0xFD070244, 0x00003333U, 0x00000201U);
- psu_mask_write(0xFD070250, 0x7FFF3F07U, 0x01002001U);
- psu_mask_write(0xFD070264, 0xFF00FFFFU, 0x08000040U);
- psu_mask_write(0xFD07026C, 0xFF00FFFFU, 0x08000040U);
- psu_mask_write(0xFD070280, 0xFFFFFFFFU, 0x00000000U);
- psu_mask_write(0xFD070284, 0xFFFFFFFFU, 0x00000000U);
- psu_mask_write(0xFD070288, 0xFFFFFFFFU, 0x00000000U);
- psu_mask_write(0xFD07028C, 0xFFFFFFFFU, 0x00000000U);
- psu_mask_write(0xFD070290, 0x0000FFFFU, 0x00000000U);
- psu_mask_write(0xFD070294, 0x00000001U, 0x00000001U);
- psu_mask_write(0xFD070300, 0x00000011U, 0x00000001U);
- psu_mask_write(0xFD07030C, 0x80000033U, 0x00000000U);
- psu_mask_write(0xFD070320, 0x00000001U, 0x00000000U);
- psu_mask_write(0xFD070400, 0x00000111U, 0x00000101U);
- psu_mask_write(0xFD070404, 0x000073FFU, 0x0000200FU);
- psu_mask_write(0xFD070408, 0x000073FFU, 0x0000200FU);
- psu_mask_write(0xFD070490, 0x00000001U, 0x00000001U);
- psu_mask_write(0xFD070494, 0x0033000FU, 0x0020000BU);
- psu_mask_write(0xFD070498, 0x07FF07FFU, 0x00000000U);
- psu_mask_write(0xFD0704B4, 0x000073FFU, 0x0000200FU);
- psu_mask_write(0xFD0704B8, 0x000073FFU, 0x0000200FU);
- psu_mask_write(0xFD070540, 0x00000001U, 0x00000001U);
- psu_mask_write(0xFD070544, 0x03330F0FU, 0x02000B03U);
- psu_mask_write(0xFD070548, 0x07FF07FFU, 0x00000000U);
- psu_mask_write(0xFD070564, 0x000073FFU, 0x0000200FU);
- psu_mask_write(0xFD070568, 0x000073FFU, 0x0000200FU);
- psu_mask_write(0xFD0705F0, 0x00000001U, 0x00000001U);
- psu_mask_write(0xFD0705F4, 0x03330F0FU, 0x02000B03U);
- psu_mask_write(0xFD0705F8, 0x07FF07FFU, 0x00000000U);
- psu_mask_write(0xFD070614, 0x000073FFU, 0x0000200FU);
- psu_mask_write(0xFD070618, 0x000073FFU, 0x0000200FU);
- psu_mask_write(0xFD0706A0, 0x00000001U, 0x00000001U);
- psu_mask_write(0xFD0706A4, 0x0033000FU, 0x00100003U);
- psu_mask_write(0xFD0706A8, 0x07FF07FFU, 0x0000004FU);
- psu_mask_write(0xFD0706AC, 0x0033000FU, 0x00100003U);
- psu_mask_write(0xFD0706B0, 0x000007FFU, 0x0000004FU);
- psu_mask_write(0xFD0706C4, 0x000073FFU, 0x0000200FU);
- psu_mask_write(0xFD0706C8, 0x000073FFU, 0x0000200FU);
- psu_mask_write(0xFD070750, 0x00000001U, 0x00000001U);
- psu_mask_write(0xFD070754, 0x0033000FU, 0x00100003U);
- psu_mask_write(0xFD070758, 0x07FF07FFU, 0x0000004FU);
- psu_mask_write(0xFD07075C, 0x0033000FU, 0x00100003U);
- psu_mask_write(0xFD070760, 0x000007FFU, 0x0000004FU);
- psu_mask_write(0xFD070774, 0x000073FFU, 0x0000200FU);
- psu_mask_write(0xFD070778, 0x000073FFU, 0x0000200FU);
- psu_mask_write(0xFD070800, 0x00000001U, 0x00000001U);
- psu_mask_write(0xFD070804, 0x0033000FU, 0x00100003U);
- psu_mask_write(0xFD070808, 0x07FF07FFU, 0x0000004FU);
- psu_mask_write(0xFD07080C, 0x0033000FU, 0x00100003U);
- psu_mask_write(0xFD070810, 0x000007FFU, 0x0000004FU);
- psu_mask_write(0xFD070F04, 0x000001FFU, 0x00000000U);
- psu_mask_write(0xFD070F08, 0x000000FFU, 0x00000000U);
- psu_mask_write(0xFD070F0C, 0x000001FFU, 0x00000010U);
- psu_mask_write(0xFD070F10, 0x000000FFU, 0x0000000FU);
- psu_mask_write(0xFD072190, 0x1FBFBF3FU, 0x07828002U);
- psu_mask_write(0xFD1A0108, 0x0000000CU, 0x00000000U);
- psu_mask_write(0xFD080010, 0xFFFFFFFFU, 0x07001E00U);
- psu_mask_write(0xFD080018, 0xFFFFFFFFU, 0x00F10010U);
- psu_mask_write(0xFD08001C, 0xFFFFFFFFU, 0x55AA5480U);
- psu_mask_write(0xFD080024, 0xFFFFFFFFU, 0x010100F4U);
- psu_mask_write(0xFD080040, 0xFFFFFFFFU, 0x42C21590U);
- psu_mask_write(0xFD080044, 0xFFFFFFFFU, 0xD05512C0U);
- psu_mask_write(0xFD080068, 0xFFFFFFFFU, 0x01100000U);
- psu_mask_write(0xFD080090, 0xFFFFFFFFU, 0x02A04161U);
- psu_mask_write(0xFD0800C0, 0xFFFFFFFFU, 0x00000000U);
- psu_mask_write(0xFD0800C4, 0xFFFFFFFFU, 0x000000E0U);
- psu_mask_write(0xFD080100, 0xFFFFFFFFU, 0x0800040CU);
- psu_mask_write(0xFD080110, 0xFFFFFFFFU, 0x06240F08U);
- psu_mask_write(0xFD080114, 0xFFFFFFFFU, 0x28170008U);
- psu_mask_write(0xFD080118, 0xFFFFFFFFU, 0x000F0300U);
- psu_mask_write(0xFD08011C, 0xFFFFFFFFU, 0x83000800U);
- psu_mask_write(0xFD080120, 0xFFFFFFFFU, 0x024B2B07U);
- psu_mask_write(0xFD080124, 0xFFFFFFFFU, 0x00370F08U);
- psu_mask_write(0xFD080128, 0xFFFFFFFFU, 0x00000E0FU);
- psu_mask_write(0xFD080140, 0xFFFFFFFFU, 0x08400020U);
- psu_mask_write(0xFD080144, 0xFFFFFFFFU, 0x00000C80U);
- psu_mask_write(0xFD080150, 0xFFFFFFFFU, 0x00000000U);
- psu_mask_write(0xFD080154, 0xFFFFFFFFU, 0x00000200U);
- psu_mask_write(0xFD080180, 0xFFFFFFFFU, 0x00000630U);
- psu_mask_write(0xFD080184, 0xFFFFFFFFU, 0x00000501U);
- psu_mask_write(0xFD080188, 0xFFFFFFFFU, 0x00000020U);
- psu_mask_write(0xFD08018C, 0xFFFFFFFFU, 0x00000200U);
- psu_mask_write(0xFD080190, 0xFFFFFFFFU, 0x00000000U);
- psu_mask_write(0xFD080194, 0xFFFFFFFFU, 0x00000700U);
- psu_mask_write(0xFD080198, 0xFFFFFFFFU, 0x00000819U);
- psu_mask_write(0xFD0801AC, 0xFFFFFFFFU, 0x00000000U);
- psu_mask_write(0xFD0801B0, 0xFFFFFFFFU, 0x0000004DU);
- psu_mask_write(0xFD0801B4, 0xFFFFFFFFU, 0x00000008U);
- psu_mask_write(0xFD0801B8, 0xFFFFFFFFU, 0x0000004DU);
- psu_mask_write(0xFD0801D8, 0xFFFFFFFFU, 0x00000000U);
- psu_mask_write(0xFD080200, 0xFFFFFFFFU, 0x810091C7U);
- psu_mask_write(0xFD080204, 0xFFFFFFFFU, 0x00030236U);
- psu_mask_write(0xFD080240, 0xFFFFFFFFU, 0x00141054U);
- psu_mask_write(0xFD080250, 0xFFFFFFFFU, 0x00088000U);
- psu_mask_write(0xFD080414, 0xFFFFFFFFU, 0x12344000U);
- psu_mask_write(0xFD0804F4, 0xFFFFFFFFU, 0x00000005U);
- psu_mask_write(0xFD080500, 0xFFFFFFFFU, 0x30000028U);
- psu_mask_write(0xFD080508, 0xFFFFFFFFU, 0x00000000U);
- psu_mask_write(0xFD08050C, 0xFFFFFFFFU, 0x00000005U);
- psu_mask_write(0xFD080510, 0xFFFFFFFFU, 0x00000000U);
- psu_mask_write(0xFD080520, 0xFFFFFFFFU, 0x0300B0CEU);
- psu_mask_write(0xFD080528, 0xFFFFFFFFU, 0xF9032019U);
- psu_mask_write(0xFD08052C, 0xFFFFFFFFU, 0x07F001E3U);
- psu_mask_write(0xFD080544, 0xFFFFFFFFU, 0x00000000U);
- psu_mask_write(0xFD080548, 0xFFFFFFFFU, 0x00000000U);
- psu_mask_write(0xFD080558, 0xFFFFFFFFU, 0x00000000U);
- psu_mask_write(0xFD08055C, 0xFFFFFFFFU, 0x00000000U);
- psu_mask_write(0xFD080560, 0xFFFFFFFFU, 0x00000000U);
- psu_mask_write(0xFD080564, 0xFFFFFFFFU, 0x00000000U);
- psu_mask_write(0xFD080680, 0xFFFFFFFFU, 0x008AAA58U);
- psu_mask_write(0xFD080684, 0xFFFFFFFFU, 0x000079DDU);
- psu_mask_write(0xFD080694, 0xFFFFFFFFU, 0x01E10210U);
- psu_mask_write(0xFD080698, 0xFFFFFFFFU, 0x01E10000U);
- psu_mask_write(0xFD0806A4, 0xFFFFFFFFU, 0x000879DBU);
- psu_mask_write(0xFD080700, 0xFFFFFFFFU, 0x40800604U);
- psu_mask_write(0xFD080704, 0xFFFFFFFFU, 0x00007FFFU);
- psu_mask_write(0xFD08070C, 0xFFFFFFFFU, 0x3F000008U);
- psu_mask_write(0xFD080710, 0xFFFFFFFFU, 0x0E00B03CU);
- psu_mask_write(0xFD080714, 0xFFFFFFFFU, 0x09094F4FU);
- psu_mask_write(0xFD080718, 0xFFFFFFFFU, 0x09092B2BU);
- psu_mask_write(0xFD080800, 0xFFFFFFFFU, 0x40800604U);
- psu_mask_write(0xFD080804, 0xFFFFFFFFU, 0x00007FFFU);
- psu_mask_write(0xFD08080C, 0xFFFFFFFFU, 0x3F000008U);
- psu_mask_write(0xFD080810, 0xFFFFFFFFU, 0x0E00B03CU);
- psu_mask_write(0xFD080814, 0xFFFFFFFFU, 0x09094F4FU);
- psu_mask_write(0xFD080818, 0xFFFFFFFFU, 0x09092B2BU);
- psu_mask_write(0xFD080900, 0xFFFFFFFFU, 0x40800604U);
- psu_mask_write(0xFD080904, 0xFFFFFFFFU, 0x00007FFFU);
- psu_mask_write(0xFD08090C, 0xFFFFFFFFU, 0x3F000008U);
- psu_mask_write(0xFD080910, 0xFFFFFFFFU, 0x0E00B00CU);
- psu_mask_write(0xFD080914, 0xFFFFFFFFU, 0x09094F4FU);
- psu_mask_write(0xFD080918, 0xFFFFFFFFU, 0x09092B2BU);
- psu_mask_write(0xFD080A00, 0xFFFFFFFFU, 0x40800604U);
- psu_mask_write(0xFD080A04, 0xFFFFFFFFU, 0x00007FFFU);
- psu_mask_write(0xFD080A0C, 0xFFFFFFFFU, 0x3F000008U);
- psu_mask_write(0xFD080A10, 0xFFFFFFFFU, 0x0E00B00CU);
- psu_mask_write(0xFD080A14, 0xFFFFFFFFU, 0x09094F4FU);
- psu_mask_write(0xFD080A18, 0xFFFFFFFFU, 0x09092B2BU);
- psu_mask_write(0xFD080B00, 0xFFFFFFFFU, 0x80803660U);
- psu_mask_write(0xFD080B04, 0xFFFFFFFFU, 0x55556000U);
- psu_mask_write(0xFD080B08, 0xFFFFFFFFU, 0xAAAAAAAAU);
- psu_mask_write(0xFD080B0C, 0xFFFFFFFFU, 0x0029A4A4U);
- psu_mask_write(0xFD080B10, 0xFFFFFFFFU, 0x0C00B000U);
- psu_mask_write(0xFD080B14, 0xFFFFFFFFU, 0x09094F4FU);
- psu_mask_write(0xFD080B18, 0xFFFFFFFFU, 0x09092B2BU);
- psu_mask_write(0xFD080C00, 0xFFFFFFFFU, 0x80803660U);
- psu_mask_write(0xFD080C04, 0xFFFFFFFFU, 0x55556000U);
- psu_mask_write(0xFD080C08, 0xFFFFFFFFU, 0xAAAAAAAAU);
- psu_mask_write(0xFD080C0C, 0xFFFFFFFFU, 0x0029A4A4U);
- psu_mask_write(0xFD080C10, 0xFFFFFFFFU, 0x0C00B000U);
- psu_mask_write(0xFD080C14, 0xFFFFFFFFU, 0x09094F4FU);
- psu_mask_write(0xFD080C18, 0xFFFFFFFFU, 0x09092B2BU);
- psu_mask_write(0xFD080D00, 0xFFFFFFFFU, 0x80803660U);
- psu_mask_write(0xFD080D04, 0xFFFFFFFFU, 0x55556000U);
- psu_mask_write(0xFD080D08, 0xFFFFFFFFU, 0xAAAAAAAAU);
- psu_mask_write(0xFD080D0C, 0xFFFFFFFFU, 0x0029A4A4U);
- psu_mask_write(0xFD080D10, 0xFFFFFFFFU, 0x0C00B000U);
- psu_mask_write(0xFD080D14, 0xFFFFFFFFU, 0x09094F4FU);
- psu_mask_write(0xFD080D18, 0xFFFFFFFFU, 0x09092B2BU);
- psu_mask_write(0xFD080E00, 0xFFFFFFFFU, 0x80803660U);
- psu_mask_write(0xFD080E04, 0xFFFFFFFFU, 0x55556000U);
- psu_mask_write(0xFD080E08, 0xFFFFFFFFU, 0xAAAAAAAAU);
- psu_mask_write(0xFD080E0C, 0xFFFFFFFFU, 0x0029A4A4U);
- psu_mask_write(0xFD080E10, 0xFFFFFFFFU, 0x0C00B000U);
- psu_mask_write(0xFD080E14, 0xFFFFFFFFU, 0x09094F4FU);
- psu_mask_write(0xFD080E18, 0xFFFFFFFFU, 0x09092B2BU);
- psu_mask_write(0xFD080F00, 0xFFFFFFFFU, 0x80803660U);
- psu_mask_write(0xFD080F04, 0xFFFFFFFFU, 0x55556000U);
- psu_mask_write(0xFD080F08, 0xFFFFFFFFU, 0xAAAAAAAAU);
- psu_mask_write(0xFD080F0C, 0xFFFFFFFFU, 0x0029A4A4U);
- psu_mask_write(0xFD080F10, 0xFFFFFFFFU, 0x0C00B000U);
- psu_mask_write(0xFD080F14, 0xFFFFFFFFU, 0x09094F4FU);
- psu_mask_write(0xFD080F18, 0xFFFFFFFFU, 0x09092B2BU);
- psu_mask_write(0xFD081400, 0xFFFFFFFFU, 0x2A019FFEU);
- psu_mask_write(0xFD081404, 0xFFFFFFFFU, 0x01100000U);
- psu_mask_write(0xFD08141C, 0xFFFFFFFFU, 0x01264300U);
- psu_mask_write(0xFD08142C, 0xFFFFFFFFU, 0x00041800U);
- psu_mask_write(0xFD081430, 0xFFFFFFFFU, 0x70800000U);
- psu_mask_write(0xFD081440, 0xFFFFFFFFU, 0x2A019FFEU);
- psu_mask_write(0xFD081444, 0xFFFFFFFFU, 0x01100000U);
- psu_mask_write(0xFD08145C, 0xFFFFFFFFU, 0x01264300U);
- psu_mask_write(0xFD08146C, 0xFFFFFFFFU, 0x00041800U);
- psu_mask_write(0xFD081470, 0xFFFFFFFFU, 0x70800000U);
- psu_mask_write(0xFD081480, 0xFFFFFFFFU, 0x15019FFEU);
- psu_mask_write(0xFD081484, 0xFFFFFFFFU, 0x21100000U);
- psu_mask_write(0xFD08149C, 0xFFFFFFFFU, 0x01266300U);
- psu_mask_write(0xFD0814AC, 0xFFFFFFFFU, 0x00041800U);
- psu_mask_write(0xFD0814B0, 0xFFFFFFFFU, 0x70400000U);
- psu_mask_write(0xFD0814C0, 0xFFFFFFFFU, 0x15019FFEU);
- psu_mask_write(0xFD0814C4, 0xFFFFFFFFU, 0x21100000U);
- psu_mask_write(0xFD0814DC, 0xFFFFFFFFU, 0x01266300U);
- psu_mask_write(0xFD0814EC, 0xFFFFFFFFU, 0x00041800U);
- psu_mask_write(0xFD0814F0, 0xFFFFFFFFU, 0x70400000U);
- psu_mask_write(0xFD081500, 0xFFFFFFFFU, 0x15019FFEU);
- psu_mask_write(0xFD081504, 0xFFFFFFFFU, 0x21100000U);
- psu_mask_write(0xFD08151C, 0xFFFFFFFFU, 0x01266300U);
- psu_mask_write(0xFD08152C, 0xFFFFFFFFU, 0x00041800U);
- psu_mask_write(0xFD081530, 0xFFFFFFFFU, 0x70400000U);
- psu_mask_write(0xFD0817DC, 0xFFFFFFFFU, 0x012643C4U);
- return 1;
- psu_mask_write(0xFD360008, 0x0000000FU, 0x00000000U);
- psu_mask_write(0xFD36001C, 0x0000000FU, 0x00000000U);
- psu_mask_write(0xFD370008, 0x0000000FU, 0x00000000U);
- psu_mask_write(0xFD37001C, 0x0000000FU, 0x00000000U);
- psu_mask_write(0xFD380008, 0x0000000FU, 0x00000000U);
- psu_mask_write(0xFD38001C, 0x0000000FU, 0x00000000U);
- psu_mask_write(0xFD390008, 0x0000000FU, 0x00000000U);
- psu_mask_write(0xFD39001C, 0x0000000FU, 0x00000000U);
- psu_mask_write(0xFD3A0008, 0x0000000FU, 0x00000000U);
- psu_mask_write(0xFD3A001C, 0x0000000FU, 0x00000000U);
- psu_mask_write(0xFD3B0008, 0x0000000FU, 0x00000000U);
- psu_mask_write(0xFD3B001C, 0x0000000FU, 0x00000000U);
- psu_mask_write(0xFF9B0008, 0x0000000FU, 0x00000000U);
- psu_mask_write(0xFF9B001C, 0x0000000FU, 0x00000000U);
- return 1;
- psu_mask_write(0xFF180034, 0x000000FEU, 0x00000008U);
- psu_mask_write(0xFF180038, 0x000000FEU, 0x00000008U);
- psu_mask_write(0xFF18003C, 0x000000FEU, 0x00000008U);
- psu_mask_write(0xFF180040, 0x000000FEU, 0x00000008U);
- psu_mask_write(0xFF180044, 0x000000FEU, 0x00000008U);
- psu_mask_write(0xFF180048, 0x000000FEU, 0x00000008U);
- psu_mask_write(0xFF18004C, 0x000000FEU, 0x00000008U);
- psu_mask_write(0xFF180050, 0x000000FEU, 0x00000008U);
- psu_mask_write(0xFF180054, 0x000000FEU, 0x00000008U);
- psu_mask_write(0xFF180058, 0x000000FEU, 0x00000008U);
- psu_mask_write(0xFF18005C, 0x000000FEU, 0x00000008U);
- psu_mask_write(0xFF180068, 0x000000FEU, 0x00000080U);
- psu_mask_write(0xFF18006C, 0x000000FEU, 0x00000000U);
- psu_mask_write(0xFF180070, 0x000000FEU, 0x00000000U);
- psu_mask_write(0xFF180074, 0x000000FEU, 0x00000080U);
- psu_mask_write(0xFF180078, 0x000000FEU, 0x00000080U);
- psu_mask_write(0xFF18007C, 0x000000FEU, 0x00000080U);
- psu_mask_write(0xFF180080, 0x000000FEU, 0x00000000U);
- psu_mask_write(0xFF180084, 0x000000FEU, 0x00000000U);
- psu_mask_write(0xFF180088, 0x000000FEU, 0x00000040U);
- psu_mask_write(0xFF18008C, 0x000000FEU, 0x00000040U);
- psu_mask_write(0xFF180090, 0x000000FEU, 0x00000000U);
- psu_mask_write(0xFF180094, 0x000000FEU, 0x00000000U);
- psu_mask_write(0xFF180098, 0x000000FEU, 0x000000C0U);
- psu_mask_write(0xFF18009C, 0x000000FEU, 0x000000C0U);
- psu_mask_write(0xFF1800A0, 0x000000FEU, 0x00000000U);
- psu_mask_write(0xFF1800A4, 0x000000FEU, 0x00000000U);
- psu_mask_write(0xFF1800A8, 0x000000FEU, 0x00000000U);
- psu_mask_write(0xFF1800AC, 0x000000FEU, 0x00000000U);
- psu_mask_write(0xFF1800B0, 0x000000FEU, 0x00000000U);
- psu_mask_write(0xFF1800B4, 0x000000FEU, 0x00000010U);
- psu_mask_write(0xFF1800B8, 0x000000FEU, 0x00000010U);
- psu_mask_write(0xFF1800BC, 0x000000FEU, 0x00000010U);
- psu_mask_write(0xFF1800C0, 0x000000FEU, 0x00000010U);
- psu_mask_write(0xFF1800C4, 0x000000FEU, 0x00000010U);
- psu_mask_write(0xFF1800C8, 0x000000FEU, 0x00000010U);
- psu_mask_write(0xFF1800CC, 0x000000FEU, 0x00000010U);
- psu_mask_write(0xFF1800D0, 0x000000FEU, 0x00000004U);
- psu_mask_write(0xFF1800D4, 0x000000FEU, 0x00000004U);
- psu_mask_write(0xFF1800D8, 0x000000FEU, 0x00000004U);
- psu_mask_write(0xFF1800DC, 0x000000FEU, 0x00000004U);
- psu_mask_write(0xFF1800E0, 0x000000FEU, 0x00000004U);
- psu_mask_write(0xFF1800E4, 0x000000FEU, 0x00000004U);
- psu_mask_write(0xFF1800E8, 0x000000FEU, 0x00000004U);
- psu_mask_write(0xFF1800EC, 0x000000FEU, 0x00000004U);
- psu_mask_write(0xFF1800F0, 0x000000FEU, 0x00000004U);
- psu_mask_write(0xFF1800F4, 0x000000FEU, 0x00000004U);
- psu_mask_write(0xFF1800F8, 0x000000FEU, 0x00000004U);
- psu_mask_write(0xFF1800FC, 0x000000FEU, 0x00000004U);
- psu_mask_write(0xFF180100, 0x000000FEU, 0x00000004U);
- psu_mask_write(0xFF180104, 0x000000FEU, 0x00000004U);
- psu_mask_write(0xFF180108, 0x000000FEU, 0x00000004U);
- psu_mask_write(0xFF18010C, 0x000000FEU, 0x00000004U);
- psu_mask_write(0xFF180110, 0x000000FEU, 0x00000004U);
- psu_mask_write(0xFF180114, 0x000000FEU, 0x00000004U);
- psu_mask_write(0xFF180118, 0x000000FEU, 0x00000004U);
- psu_mask_write(0xFF18011C, 0x000000FEU, 0x00000004U);
- psu_mask_write(0xFF180120, 0x000000FEU, 0x00000004U);
- psu_mask_write(0xFF180124, 0x000000FEU, 0x00000004U);
- psu_mask_write(0xFF180128, 0x000000FEU, 0x00000004U);
- psu_mask_write(0xFF18012C, 0x000000FEU, 0x00000004U);
- psu_mask_write(0xFF180130, 0x000000FEU, 0x00000060U);
- psu_mask_write(0xFF180134, 0x000000FEU, 0x00000060U);
- psu_mask_write(0xFF180204, 0xFCFFE000U, 0x00000000U);
- psu_mask_write(0xFF180208, 0xFFFFFFFFU, 0x00B02040U);
- psu_mask_write(0xFF18020C, 0x00003FFFU, 0x0000000BU);
- psu_mask_write(0xFF180138, 0x03FFFFFFU, 0x03FFFFFFU);
- psu_mask_write(0xFF18013C, 0x03FFFFFFU, 0x03FFFFFFU);
- psu_mask_write(0xFF180140, 0x03FFFFFFU, 0x033FFFFFU);
- psu_mask_write(0xFF180144, 0x03FFFFFFU, 0x03FFFFFFU);
- psu_mask_write(0xFF180148, 0x03FFFFFFU, 0x03FFFFFFU);
- psu_mask_write(0xFF18014C, 0x03FFFFFFU, 0x03FFFFFFU);
- psu_mask_write(0xFF180154, 0x03FFFFFFU, 0x03FFFFFFU);
- psu_mask_write(0xFF180158, 0x03FFFFFFU, 0x03FFFFFFU);
- psu_mask_write(0xFF18015C, 0x03FFFFFFU, 0x01FF9FFFU);
- psu_mask_write(0xFF180160, 0x03FFFFFFU, 0x03FFFFFFU);
- psu_mask_write(0xFF180164, 0x03FFFFFFU, 0x03FFFFFFU);
- psu_mask_write(0xFF180168, 0x03FFFFFFU, 0x03F76FFFU);
- psu_mask_write(0xFF180170, 0x03FFFFFFU, 0x03FFFFFFU);
- psu_mask_write(0xFF180174, 0x03FFFFFFU, 0x03FFFFFFU);
- psu_mask_write(0xFF180178, 0x03FFFFFFU, 0x02FBFFBFU);
- psu_mask_write(0xFF18017C, 0x03FFFFFFU, 0x03FFFFFFU);
- psu_mask_write(0xFF180180, 0x03FFFFFFU, 0x03FFFFFFU);
- psu_mask_write(0xFF180184, 0x03FFFFFFU, 0x03FF4FF4U);
- psu_mask_write(0xFF180200, 0x0000000FU, 0x00000000U);
- return 1;
- psu_mask_write(0xFF5E0108, 0x013F3F07U, 0x01012302U);
- return 1;
- psu_mask_write(0xFD1A0100, 0x0000807CU, 0x00000000U);
- psu_mask_write(0xFF5E0238, 0x001A0000U, 0x00000000U);
- psu_mask_write(0xFF5E023C, 0x0093C018U, 0x00000000U);
- psu_mask_write(0xFF5E0230, 0x00000001U, 0x00000000U);
- psu_mask_write(0xFF5E023C, 0x00000C00U, 0x00000000U);
- psu_mask_write(0xFF5E0238, 0x00000060U, 0x00000000U);
- psu_mask_write(0xFF180310, 0x00008001U, 0x00000001U);
- psu_mask_write(0xFF180320, 0x33843384U, 0x00801284U);
- psu_mask_write(0xFF18031C, 0x00007FFEU, 0x00006450U);
- psu_mask_write(0xFF180358, 0x00080000U, 0x00080000U);
- psu_mask_write(0xFF18031C, 0x7FFE0000U, 0x64500000U);
- psu_mask_write(0xFF180358, 0x00000008U, 0x00000008U);
- psu_mask_write(0xFF180324, 0x000003C0U, 0x00000000U);
- psu_mask_write(0xFF180324, 0x03C00000U, 0x00000000U);
- psu_mask_write(0xFF5E0238, 0x00000200U, 0x00000000U);
- psu_mask_write(0xFF5E0238, 0x00008000U, 0x00000000U);
- psu_mask_write(0xFF5E0238, 0x00000008U, 0x00000000U);
- psu_mask_write(0xFF5E0238, 0x00007800U, 0x00000000U);
- psu_mask_write(0xFF5E0238, 0x00000002U, 0x00000000U);
- psu_mask_write(0xFF000034, 0x000000FFU, 0x00000005U);
- psu_mask_write(0xFF000018, 0x0000FFFFU, 0x0000008FU);
- psu_mask_write(0xFF000000, 0x000001FFU, 0x00000017U);
- psu_mask_write(0xFF000004, 0x000003FFU, 0x00000020U);
- psu_mask_write(0xFF5E0238, 0x00040000U, 0x00000000U);
- psu_mask_write(0xFF4B0024, 0x000000FFU, 0x000000FFU);
- psu_mask_write(0xFFCA5000, 0x00001FFFU, 0x00000000U);
- psu_mask_write(0xFD5C0060, 0x000F000FU, 0x00000000U);
- psu_mask_write(0xFFA60040, 0x80000000U, 0x80000000U);
- psu_mask_write(0xFF260020, 0xFFFFFFFFU, 0x01FC9F08U);
- psu_mask_write(0xFF260000, 0x00000001U, 0x00000001U);
- psu_mask_write(0xFF5E0250, 0x00000F0FU, 0x00000202U);
- mask_delay(1);
- psu_mask_write(0xFF5E0250, 0x00000F0FU, 0x00000002U);
- mask_delay(5);
- return 1;
- psu_mask_write(0xFD410000, 0x0000001FU, 0x0000000FU);
- psu_mask_write(0xFD410004, 0x0000001FU, 0x00000008U);
- psu_mask_write(0xFD402860, 0x00000080U, 0x00000080U);
- psu_mask_write(0xFD402864, 0x00000080U, 0x00000080U);
- psu_mask_write(0xFD406094, 0x00000010U, 0x00000010U);
- psu_mask_write(0xFD406368, 0x000000FFU, 0x00000038U);
- psu_mask_write(0xFD40636C, 0x00000007U, 0x00000003U);
- psu_mask_write(0xFD406370, 0x000000FFU, 0x000000F4U);
- psu_mask_write(0xFD406374, 0x000000FFU, 0x00000031U);
- psu_mask_write(0xFD406378, 0x000000FFU, 0x00000002U);
- psu_mask_write(0xFD40637C, 0x00000033U, 0x00000030U);
- psu_mask_write(0xFD40106C, 0x0000000FU, 0x0000000FU);
- psu_mask_write(0xFD4000F4, 0x0000000BU, 0x0000000BU);
- psu_mask_write(0xFD40506C, 0x00000003U, 0x00000003U);
- psu_mask_write(0xFD4040F4, 0x00000003U, 0x00000003U);
- psu_mask_write(0xFD4050CC, 0x00000020U, 0x00000020U);
- psu_mask_write(0xFD401074, 0x00000010U, 0x00000010U);
- psu_mask_write(0xFD405074, 0x00000010U, 0x00000010U);
- psu_mask_write(0xFD409074, 0x00000010U, 0x00000010U);
- psu_mask_write(0xFD40D074, 0x00000010U, 0x00000010U);
- psu_mask_write(0xFD40189C, 0x00000080U, 0x00000080U);
- psu_mask_write(0xFD4018F8, 0x000000FFU, 0x0000007DU);
- psu_mask_write(0xFD4018FC, 0x000000FFU, 0x0000007DU);
- psu_mask_write(0xFD401990, 0x000000FFU, 0x00000000U);
- psu_mask_write(0xFD401924, 0x000000FFU, 0x00000082U);
- psu_mask_write(0xFD401928, 0x000000FFU, 0x00000000U);
- psu_mask_write(0xFD401900, 0x000000FFU, 0x00000064U);
- psu_mask_write(0xFD40192C, 0x000000FFU, 0x00000000U);
- psu_mask_write(0xFD401980, 0x000000FFU, 0x000000FFU);
- psu_mask_write(0xFD401914, 0x000000FFU, 0x000000FFU);
- psu_mask_write(0xFD401918, 0x00000001U, 0x00000001U);
- psu_mask_write(0xFD401940, 0x000000FFU, 0x000000FFU);
- psu_mask_write(0xFD401944, 0x00000001U, 0x00000001U);
- psu_mask_write(0xFD401994, 0x00000007U, 0x00000007U);
- psu_mask_write(0xFD40589C, 0x00000080U, 0x00000080U);
- psu_mask_write(0xFD4058F8, 0x000000FFU, 0x0000001AU);
- psu_mask_write(0xFD4058FC, 0x000000FFU, 0x0000001AU);
- psu_mask_write(0xFD405990, 0x000000FFU, 0x00000010U);
- psu_mask_write(0xFD405924, 0x000000FFU, 0x000000FEU);
- psu_mask_write(0xFD405928, 0x000000FFU, 0x00000000U);
- psu_mask_write(0xFD405900, 0x000000FFU, 0x0000001AU);
- psu_mask_write(0xFD40592C, 0x000000FFU, 0x00000000U);
- psu_mask_write(0xFD405980, 0x000000FFU, 0x000000FFU);
- psu_mask_write(0xFD405914, 0x000000FFU, 0x000000F7U);
- psu_mask_write(0xFD405918, 0x00000001U, 0x00000001U);
- psu_mask_write(0xFD405940, 0x000000FFU, 0x000000F7U);
- psu_mask_write(0xFD405944, 0x00000001U, 0x00000001U);
- psu_mask_write(0xFD405994, 0x00000007U, 0x00000007U);
- psu_mask_write(0xFD409994, 0x00000007U, 0x00000007U);
- psu_mask_write(0xFD40D994, 0x00000007U, 0x00000007U);
- psu_mask_write(0xFD40107C, 0x0000000FU, 0x00000001U);
- psu_mask_write(0xFD40507C, 0x0000000FU, 0x00000001U);
- psu_mask_write(0xFD40907C, 0x0000000FU, 0x00000001U);
- psu_mask_write(0xFD40D07C, 0x0000000FU, 0x00000001U);
- psu_mask_write(0xFD4019A4, 0x000000FFU, 0x000000FFU);
- psu_mask_write(0xFD401038, 0x00000040U, 0x00000040U);
- psu_mask_write(0xFD40102C, 0x00000040U, 0x00000040U);
- psu_mask_write(0xFD4059A4, 0x000000FFU, 0x000000FFU);
- psu_mask_write(0xFD405038, 0x00000040U, 0x00000040U);
- psu_mask_write(0xFD40502C, 0x00000040U, 0x00000040U);
- psu_mask_write(0xFD4099A4, 0x000000FFU, 0x000000FFU);
- psu_mask_write(0xFD409038, 0x00000040U, 0x00000040U);
- psu_mask_write(0xFD40902C, 0x00000040U, 0x00000040U);
- psu_mask_write(0xFD40D9A4, 0x000000FFU, 0x000000FFU);
- psu_mask_write(0xFD40D038, 0x00000040U, 0x00000040U);
- psu_mask_write(0xFD40D02C, 0x00000040U, 0x00000040U);
- psu_mask_write(0xFD4019AC, 0x00000003U, 0x00000000U);
- psu_mask_write(0xFD4059AC, 0x00000003U, 0x00000000U);
- psu_mask_write(0xFD4099AC, 0x00000003U, 0x00000000U);
- psu_mask_write(0xFD40D9AC, 0x00000003U, 0x00000000U);
- psu_mask_write(0xFD401978, 0x00000010U, 0x00000010U);
- psu_mask_write(0xFD405978, 0x00000010U, 0x00000010U);
- psu_mask_write(0xFD409978, 0x00000010U, 0x00000010U);
- psu_mask_write(0xFD40D978, 0x00000010U, 0x00000010U);
- psu_mask_write(0xFD410010, 0x00000077U, 0x00000035U);
- psu_mask_write(0xFD410040, 0x00000003U, 0x00000000U);
- psu_mask_write(0xFD410044, 0x00000003U, 0x00000000U);
- return 1;
- psu_mask_write(0xFF5E023C, 0x00000400U, 0x00000000U);
- psu_mask_write(0xFF9D0080, 0x00000001U, 0x00000001U);
- psu_mask_write(0xFF9D007C, 0x00000001U, 0x00000000U);
- psu_mask_write(0xFF5E023C, 0x00000140U, 0x00000000U);
- psu_mask_write(0xFF5E023C, 0x00000800U, 0x00000000U);
- psu_mask_write(0xFF9E0080, 0x00000001U, 0x00000001U);
- psu_mask_write(0xFF9E007C, 0x00000001U, 0x00000001U);
- psu_mask_write(0xFF5E023C, 0x00000280U, 0x00000000U);
- psu_mask_write(0xFE20C200, 0x00023FFFU, 0x00022457U);
- psu_mask_write(0xFE20C630, 0x003FFF00U, 0x00000000U);
- psu_mask_write(0xFE20C11C, 0x00000600U, 0x00000600U);
- psu_mask_write(0xFE20C12C, 0x00004000U, 0x00004000U);
- psu_mask_write(0xFE30C200, 0x00023FFFU, 0x00022457U);
- psu_mask_write(0xFE30C630, 0x003FFF00U, 0x00000000U);
- psu_mask_write(0xFE30C12C, 0x00004000U, 0x00004000U);
- psu_mask_write(0xFE30C11C, 0x00000400U, 0x00000400U);
- psu_mask_write(0xFD480064, 0x00000200U, 0x00000200U);
- mask_poll(0xFD4023E4, 0x00000010U);
- mask_poll(0xFD4063E4, 0x00000010U);
- return 1;
- psu_mask_write(0xFF5E023C, 0x00000540U, 0x00000540U);
- psu_mask_write(0xFF5E023C, 0x00000A80U, 0x00000A80U);
- psu_mask_write(0xFF5E0230, 0x00000001U, 0x00000001U);
- return 1;
- psu_mask_write(0xFD1A0100, 0x00001F80U, 0x00000000U);
- psu_mask_write(0xFF5E023C, 0x00080000U, 0x00000000U);
- psu_mask_write(0xFD615000, 0x00000F00U, 0x00000A00U);
- psu_mask_write(0xFF419000, 0x00000300U, 0x00000000U);
- psu_mask_write(0xFD360000, 0x00000003U, 0x00000000U);
- psu_mask_write(0xFD360014, 0x00000003U, 0x00000000U);
- return 1;
- unsigned int regval = 0;
- unsigned int pll_retry = 10;
- unsigned int pll_locked = 0;
- int cur_r006_trefprd;
- while ((pll_retry > 0) && (!pll_locked)) {
>> 31;
>> 16;
>> 16;
pll_retry--;
- Xil_Out32(0xFD0800C4, Xil_In32(0xFD0800C4) | (pll_retry << 16));
- if (!pll_locked)
- Xil_Out32(0xFD080004U, 0x00040063U);
- while ((Xil_In32(0xFD080030U) & 0x0000000FU) != 0x0000000FU)
- prog_reg(0xFD080004U, 0x00000001U, 0x00000000U, 0x00000001U);
- while ((Xil_In32(0xFD080030U) & 0x000000FFU) != 0x0000001FU)
- Xil_Out32(0xFD0701B0U, 0x00000001U);
- Xil_Out32(0xFD070320U, 0x00000001U);
- while ((Xil_In32(0xFD070004U) & 0x0000000FU) != 0x00000001U)
- prog_reg(0xFD080014U, 0x00000040U, 0x00000006U, 0x00000001U);
- Xil_Out32(0xFD080004, 0x0004FE01);
- regval = Xil_In32(0xFD080030);
- while (regval != 0x80000FFF)
- regval = ((Xil_In32(0xFD080030) & 0x1FFF0000) >> 18);
- if (regval != 0)
- Xil_Out32(0xFD080200U, 0x110091C7U);
- cur_r006_trefprd = (Xil_In32(0xFD080018U) & 0x0003FFFFU) >> 0x00000000U;
- prog_reg(0xFD080018, 0x3FFFF, 0x0, cur_r006_trefprd);
- prog_reg(0xFD08001CU, 0x00000018U, 0x00000003U, 0x00000003U);
- prog_reg(0xFD08142CU, 0x00000030U, 0x00000004U, 0x00000003U);
- prog_reg(0xFD08146CU, 0x00000030U, 0x00000004U, 0x00000003U);
- prog_reg(0xFD0814ACU, 0x00000030U, 0x00000004U, 0x00000003U);
- prog_reg(0xFD0814ECU, 0x00000030U, 0x00000004U, 0x00000003U);
- prog_reg(0xFD08152CU, 0x00000030U, 0x00000004U, 0x00000003U);
- Xil_Out32(0xFD080004, 0x00060001);
- while ((regval & 0x80004001) != 0x80004001)
- prog_reg(0xFD08001CU, 0x00000018U, 0x00000003U, 0x00000000U);
- prog_reg(0xFD08142CU, 0x00000030U, 0x00000004U, 0x00000000U);
- prog_reg(0xFD08146CU, 0x00000030U, 0x00000004U, 0x00000000U);
- prog_reg(0xFD0814ACU, 0x00000030U, 0x00000004U, 0x00000000U);
- prog_reg(0xFD0814ECU, 0x00000030U, 0x00000004U, 0x00000000U);
- prog_reg(0xFD08152CU, 0x00000030U, 0x00000004U, 0x00000000U);
- Xil_Out32(0xFD080200U, 0x810091C7U);
- Xil_Out32(0xFD080004, 0x0000C001);
- while ((regval & 0x80000C01) != 0x80000C01)
- Xil_Out32(0xFD070180U, 0x01000040U);
- Xil_Out32(0xFD070060U, 0x00000000U);
- prog_reg(0xFD080014U, 0x00000040U, 0x00000006U, 0x00000000U);
- return 1;
- Xil_Out32(0xFD402094, 0x00000010);
- Xil_Out32(0xFD406094, 0x00000010);
- Xil_Out32(0xFD40A094, 0x00000010);
- Xil_Out32(0xFD40E094, 0x00000010);
- return 1;
- int maskstatus = 1;
- unsigned int rdata = 0;
- unsigned int match_pmos_code[23];
- unsigned int match_nmos_code[23];
- unsigned int match_ical_code[7];
- unsigned int match_rcal_code[7];
- unsigned int p_code = 0, n_code = 0, i_code = 0, r_code = 0;
- unsigned int repeat_count = 0;
- unsigned int L3_TM_CALIB_DIG20 = 0;
- unsigned int L3_TM_CALIB_DIG19 = 0;
- unsigned int L3_TM_CALIB_DIG18 = 0;
- unsigned int L3_TM_CALIB_DIG16 = 0;
- unsigned int L3_TM_CALIB_DIG15 = 0;
- unsigned int L3_TM_CALIB_DIG14 = 0;
- int count = 0, i = 0;
- rdata = Xil_In32(0xFD40289C);
- rdata = rdata & ~0x03;
- rdata = rdata | 0x1;
- Xil_Out32(0xFD40289C, rdata);
- do {
break;
count++;
- } while ((rdata & 0x0000000E) != 0x0000000E);
- for (i = 0; i < 23; i++) {
- for (i = 0; i < 7; i++) {
- do {
return maskstatus;
- } while (repeat_count++ < 10);
p_code = 0x26 + i;
n_code = 0x26 + i;
i_code = 0xC + i;
r_code = 0x6 + i;
- L3_TM_CALIB_DIG20 = mask_read(0xFD40EC50, 0xFFFFFFF0);
- L3_TM_CALIB_DIG20 = L3_TM_CALIB_DIG20 | 0x8 | ((p_code >> 2) & 0x7);
- L3_TM_CALIB_DIG19 = mask_read(0xFD40EC4C, 0xFFFFFF18);
- L3_TM_CALIB_DIG19 = L3_TM_CALIB_DIG19 | ((p_code & 0x3) << 6)
- L3_TM_CALIB_DIG18 = mask_read(0xFD40EC48, 0xFFFFFF0F);
- L3_TM_CALIB_DIG18 = L3_TM_CALIB_DIG18 | ((n_code & 0x7) << 5) | 0x10;
- L3_TM_CALIB_DIG16 = mask_read(0xFD40EC40, 0xFFFFFFF8);
- L3_TM_CALIB_DIG16 = L3_TM_CALIB_DIG16 | ((r_code >> 1) & 0x7);
- L3_TM_CALIB_DIG15 = mask_read(0xFD40EC3C, 0xFFFFFF30);
- L3_TM_CALIB_DIG15 = L3_TM_CALIB_DIG15 | ((r_code & 0x1) << 7)
- L3_TM_CALIB_DIG14 = mask_read(0xFD40EC38, 0xFFFFFF3F);
- L3_TM_CALIB_DIG14 = L3_TM_CALIB_DIG14 | ((i_code & 0x1) << 7) | 0x40;
- Xil_Out32(0xFD40EC50, L3_TM_CALIB_DIG20);
- Xil_Out32(0xFD40EC4C, L3_TM_CALIB_DIG19);
- Xil_Out32(0xFD40EC48, L3_TM_CALIB_DIG18);
- Xil_Out32(0xFD40EC40, L3_TM_CALIB_DIG16);
- Xil_Out32(0xFD40EC3C, L3_TM_CALIB_DIG15);
- Xil_Out32(0xFD40EC38, L3_TM_CALIB_DIG14);
- return maskstatus;
- int status = 1;
- status &= psu_resetin_init_data();
- status &= serdes_fixcal_code();
- status &= serdes_enb_coarse_saturation();
- status &= psu_serdes_init_data();
- status &= psu_resetout_init_data();
- return status;
- psu_mask_write(0xFD5F0018, 0x8000001FU, 0x8000001FU);
- int status = 1;
- status &= psu_mio_init_data();
- status &= psu_peripherals_pre_init_data();
- status &= psu_pll_init_data();
- status &= psu_clock_init_data();
- status &= psu_ddr_init_data();
- status &= psu_ddr_phybringup_data();
- status &= psu_peripherals_init_data();
- status &= init_serdes();
- init_peripheral();
- status &= psu_afi_config();
- psu_ddr_qos_init_data();
- if (status == 0)
return 1;
Applied. M
Michal Simek
