[PATCH v2] mtd: spi-nor: Add support for Spansion S25FL256L
The S25FL256L is a part of the S25FL-L family and has the same feature set as S25FL128L except the density.
The datasheet can be found in the following link. https://www.cypress.com/file/316171/download
The S25FL256L is 32MB NOR Flash that does not support Bank Address Register. This fixup is activated if CONFIG_SPI_FLASH_BAR is enabled and returns ENOTSUPP in setup() hook to avoid further ops.
Tested on Xilinx Zynq-7000 FPGA board.
Signed-off-by: Takahiro Kuwano Takahiro.Kuwano@infineon.com --- Changes in v2: - Merge separated patches into one - Remove #ifdef CONFIG_SPI_FLASH_BAR
drivers/mtd/spi/spi-nor-core.c | 19 +++++++++++++++++++ drivers/mtd/spi/spi-nor-ids.c | 1 + 2 files changed, 20 insertions(+)
diff --git a/drivers/mtd/spi/spi-nor-core.c b/drivers/mtd/spi/spi-nor-core.c index f1b4e5ea8e..7572be5e34 100644 --- a/drivers/mtd/spi/spi-nor-core.c +++ b/drivers/mtd/spi/spi-nor-core.c @@ -3224,6 +3224,21 @@ static struct spi_nor_fixups s25hx_t_fixups = { .post_bfpt = s25hx_t_post_bfpt_fixup, .post_sfdp = s25hx_t_post_sfdp_fixup, }; + +static int s25fl256l_setup(struct spi_nor *nor, const struct flash_info *info, + const struct spi_nor_flash_parameter *params) +{ + return -ENOTSUPP; /* Bank Address Register is not supported */ +} + +static void s25fl256l_default_init(struct spi_nor *nor) +{ + nor->setup = s25fl256l_setup; +} + +static struct spi_nor_fixups s25fl256l_fixups = { + .default_init = s25fl256l_default_init, +}; #endif
#ifdef CONFIG_SPI_FLASH_S28HS512T @@ -3646,6 +3661,10 @@ void spi_nor_set_fixups(struct spi_nor *nor) break; } } + + if (CONFIG_IS_ENABLED(SPI_FLASH_BAR) && + !strcmp(nor->info->name, "s25fl256l")) + nor->fixups = &s25fl256l_fixups; #endif
#ifdef CONFIG_SPI_FLASH_S28HS512T diff --git a/drivers/mtd/spi/spi-nor-ids.c b/drivers/mtd/spi/spi-nor-ids.c index 4aef1ddd6e..11d7d4fcaa 100644 --- a/drivers/mtd/spi/spi-nor-ids.c +++ b/drivers/mtd/spi/spi-nor-ids.c @@ -227,6 +227,7 @@ const struct flash_info spi_nor_ids[] = { { INFO("s25fl208k", 0x014014, 0, 64 * 1024, 16, SECT_4K | SPI_NOR_DUAL_READ) }, { INFO("s25fl064l", 0x016017, 0, 64 * 1024, 128, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, { INFO("s25fl128l", 0x016018, 0, 64 * 1024, 256, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, + { INFO("s25fl256l", 0x016019, 0, 64 * 1024, 512, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, { INFO6("s25hl512t", 0x342a1a, 0x0f0390, 256 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES | USE_CLSR) },
Changes in v2:
+}; #endif
#endif
This look we have fixups for individual parts, better use default fixup and handle it based on the part specific ID.
Jagan.
Jagan Teki
