[PATCH 0/2] Enable ethernet for ti am62x
These patches enable ethernet from u-boot on the ti am62x EVM. They are based on the u-boot next branch (9c955393) to take advantage of recent dts sync of these boards with linux
Sjoerd Simons (2): arm: dts: k3-am625-sk: Enable first ethernet port configs: am62x_evm_a53: Enable ethernet
arch/arm/dts/k3-am625-sk-u-boot.dtsi | 22 ++++++++++++++++++++++ configs/am62x_evm_a53_defconfig | 11 ++++++++--- 2 files changed, 30 insertions(+), 3 deletions(-)
The K3 am625 sk EVM has two ethernet ports; Enable the first one for usage in u-boot.
Signed-off-by: Sjoerd Simons sjoerd@collabora.com ---
arch/arm/dts/k3-am625-sk-u-boot.dtsi | 22 ++++++++++++++++++++++ 1 file changed, 22 insertions(+)
diff --git a/arch/arm/dts/k3-am625-sk-u-boot.dtsi b/arch/arm/dts/k3-am625-sk-u-boot.dtsi index 92788bae3e0..f275e3b46ca 100644 --- a/arch/arm/dts/k3-am625-sk-u-boot.dtsi +++ b/arch/arm/dts/k3-am625-sk-u-boot.dtsi @@ -126,3 +126,25 @@ }; }; }; + +&cpsw3g { + reg = <0x0 0x8000000 0x0 0x200000>, + <0x0 0x43000200 0x0 0x8>; + reg-names = "cpsw_nuss", "mac_efuse"; + /delete-property/ ranges; + u-boot,dm-spl; + + cpsw-phy-sel@04044 { + compatible = "ti,am64-phy-gmii-sel"; + reg = <0x0 0x00104044 0x0 0x8>; + u-boot,dm-spl; + }; +}; + +&cpsw_port1 { + u-boot,dm-spl; +}; + +&cpsw_port2 { + status = "disabled"; +};
Enable configuration ethernet for u-boot on am62x; Some unrelated things also got moved around due to running through savedefconfig.
configs/am62x_evm_a53_defconfig | 11 ++++++++--- 1 file changed, 8 insertions(+), 3 deletions(-)
diff --git a/configs/am62x_evm_a53_defconfig b/configs/am62x_evm_a53_defconfig index e6ffd166927..30b19428e9e 100644 --- a/configs/am62x_evm_a53_defconfig +++ b/configs/am62x_evm_a53_defconfig @@ -7,6 +7,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_SOC_K3_AM625=y CONFIG_K3_ATF_LOAD_ADDR=0x9e780000 CONFIG_TARGET_AM625_A53_EVM=y +CONFIG_SPL_DM_SPI=y CONFIG_DEFAULT_DEVICE_TREE="k3-am625-sk" CONFIG_SPL_TEXT_BASE=0x80080000 CONFIG_SPL_MMC=y @@ -14,6 +15,7 @@ CONFIG_SPL_SERIAL=y CONFIG_SPL_STACK_R_ADDR=0x82000000 CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y @@ -32,12 +34,10 @@ CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" CONFIG_SPL_DM_MAILBOX=y -CONFIG_SPL_DM_SPI=y CONFIG_SPL_DM_SPI_FLASH=y CONFIG_SPL_POWER_DOMAIN=y # CONFIG_SPL_SPI_FLASH_TINY is not set CONFIG_SPL_SPI_FLASH_SFDP_SUPPORT=y -CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x280000 CONFIG_SPL_YMODEM_SUPPORT=y @@ -57,6 +57,8 @@ CONFIG_SPL_OF_TRANSLATE=y CONFIG_CLK=y CONFIG_SPL_CLK=y CONFIG_CLK_TI_SCI=y +CONFIG_DMA_CHANNELS=y +CONFIG_TI_K3_NAVSS_UDMA=y CONFIG_TI_SCI_PROTOCOL=y CONFIG_DM_MAILBOX=y CONFIG_K3_SEC_PROXY=y @@ -71,7 +73,10 @@ CONFIG_SPI_FLASH_SFDP_SUPPORT=y CONFIG_SPI_FLASH_SOFT_RESET=y CONFIG_SPI_FLASH_SOFT_RESET_ON_BOOT=y CONFIG_SPI_FLASH_SPANSION=y -CONFIG_SPI_FLASH_S28HS512T=y +CONFIG_PHY_TI_DP83867=y +CONFIG_PHY_FIXED=y +CONFIG_TI_AM65_CPSW_NUSS=y +CONFIG_PHY=y CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y CONFIG_PINCTRL_SINGLE=y
Removing this might break S28HS512T Octal SPI NOR Flash. Please let this stay if it isn't related to the eth configs.
This got removed by savedefconfig ; CONFIG_SPI_FLASH_S28HS512T doesn't exist in u-boot anymore[0], it's been replaced by CONFIG_SPI_FLASH_S28HX_T.
I can do quick respin to seperate out cleaning the defconfig, correcting that option and then add ethernet on top to make things more clear.
0:https://source.denx.de/u-boot/u-boot/-/commit/f422c4bec7c654d185abb9bb29f797...
Dhruva Gole
Sjoerd Simons
