Re: [U-Boot-Users] PATCH for U-Boot 1.3.3 DHCP fails with netgearWGR614v6
Hi Robin,
Robin Getz wrote:
On Fri 11 Jul 2008 14:21, Ben Warren pondered:
Robin Getz wrote:
[snip]
This seems goofy. Have you tried your fix with other DHCP servers to verify that it works? If so, which ones? I unfortunately can't try anything right now but will play around a bit tonight.
Some other random netgears that I have in my home, plus whatever is attached to our corp network - it works on them all (but on those it worked before as well).
-Robin
While your fix works, wouldn't it be more correct to remove the call to BootpCopyNetParams() on line 927? My understanding of the purpose of the DHCPDISCOVER state is for determining if there are reachable DHCP servers, not for actually acquiring an address. I'm a bit wary because I don't know why that call was put there in the first place. I guess in theory you could short-circuit the DHCPREQUEST state, but the code doesn't do that.
thanks, Ben
Ben Warren
