[U-Boot] [PATCH v2] power: axp818: Fix typo in axp_set_dldo
Fix typo in axp_set_dldo() so that it correctly uses AXP818_DLDO1_CTRL register to configure the voltage instead of setting AXP818_ELDO1_CTRL register which is obviously incorrect.
Signed-off-by: Ondřej Jirman megous@megous.com --- This was previously sent as a part of other series of patches, but it's unrelated to the rest of the patches, so I'm resending it individually.
v2: - improved description
drivers/power/axp818.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/power/axp818.c b/drivers/power/axp818.c index c737da1180..834919ddd4 100644 --- a/drivers/power/axp818.c +++ b/drivers/power/axp818.c @@ -161,7 +161,7 @@ int axp_set_dldo(int dldo_num, unsigned int mvolt) cfg = axp818_mvolt_to_cfg(mvolt, 700, 3300, 100); if (dldo_num == 2 && mvolt > 3300) cfg += 1 + axp818_mvolt_to_cfg(mvolt, 3400, 4200, 200); - ret = pmic_bus_write(AXP818_ELDO1_CTRL + (dldo_num - 1), cfg); + ret = pmic_bus_write(AXP818_DLDO1_CTRL + (dldo_num - 1), cfg); if (ret) return ret;
Applied to u-boot-sunxi/master
Jagan Teki
megous@megous.com
