[U-Boot] [PATCH] common/memsize.c: Simplify RAM size detection
The case of memory of size 0 is not that different from a memory of any other size, so we remove the duplicate code and treat the small differences when it is the case.
Series-to: u-boot Signed-off-by: Eddy Petrișor eddy.petrisor@gmail.com --- common/memsize.c | 47 +++++++++++++++++++++-------------------------- 1 file changed, 21 insertions(+), 26 deletions(-)
diff --git a/common/memsize.c b/common/memsize.c index 0fb9ba5..5c0d279 100644 --- a/common/memsize.c +++ b/common/memsize.c @@ -33,38 +33,28 @@ long get_ram_size(long *base, long maxsize) long size; int i = 0;
- for (cnt = (maxsize / sizeof(long)) >> 1; cnt > 0; cnt >>= 1) { + for (cnt = (maxsize / sizeof(long)) >> 1; cnt >= 0; cnt >>= 1) { addr = base + cnt; /* pointer arith! */ sync(); - save[i++] = *addr; + save[i] = *addr; sync(); - *addr = ~cnt; - } - - addr = base; - sync(); - save[i] = *addr; - sync(); - *addr = 0; - - sync(); - if ((val = *addr) != 0) { - /* Restore the original data before leaving the function. */ - sync(); - *addr = save[i]; - for (cnt = 1; cnt < maxsize / sizeof(long); cnt <<= 1) { - addr = base + cnt; - sync(); - *addr = save[--i]; + if (cnt) { + i++; + *addr = ~cnt; + } else { + *addr = 0; } - return (0); }
- for (cnt = 1; cnt < maxsize / sizeof(long); cnt <<= 1) { + sync(); + cnt = 0; + do { addr = base + cnt; /* pointer arith! */ val = *addr; - *addr = save[--i]; - if (val != ~cnt) { + *addr = save[i--]; + sync(); + if (((cnt == 0) && (val != 0)) || + ((cnt != 0) && (val != ~cnt))) { size = cnt * sizeof(long); /* * Restore the original data @@ -74,11 +64,16 @@ long get_ram_size(long *base, long maxsize) cnt < maxsize / sizeof(long); cnt <<= 1) { addr = base + cnt; - *addr = save[--i]; + *addr = save[i--]; } return (size); } - } + + if (cnt) + cnt = cnt << 1; + else + cnt = 1; + } while (cnt < maxsize / sizeof(long));
return (maxsize); }
v2: Removed patman stuff from commit message
return (maxsize); }
Hello Eddy,
On Tue, 2 Feb 2016 22:15:28 +0200, Eddy Petrișor eddy.petrisor@gmail.com wrote:
Sorry for asking, but since you're mentioning it... If you are using patman, then why do you alter its mails rather than just letting it post them as-is?
Amicalement,
2016-02-03 15:38 GMT+02:00 Albert ARIBAUD albert.u.boot@aribaud.net:
Hello Eddy,
Actually I tried using patman, but got all sorts of errors and wasn't able to use it. Then I manually sent the patches with git send-email, but forgot to remove the patman header. So in the repost I removed the patman header since it was of no use. I hope is more clear now.
Hello Eddy,
(re-titling)
On Wed, 3 Feb 2016 18:32:45 +0200, Eddy Petrișor eddy.petrisor@gmail.com wrote:
Hello Eddy,
If you can send with git send-email, then you should be able to, and should, use patman. What were these errors?
-- Eddy Petrișor
Amicalement,
2016-02-08 22:49 GMT+02:00 Tom Rini trini@konsulko.com:
Thank you!
- for (cnt = (maxsize / sizeof(long)) >> 1; cnt >= 0; cnt >>= 1) { addr = base + cnt; /* pointer arith! */ sync();
save[i++] = *addr;
sync();save[i] = *addr;
*addr = ~cnt;
- addr = base;
- sync();
- save[i] = *addr;
- sync();
- *addr = 0;
- sync();
sync();
*addr = save[i];
addr = base + cnt;
sync();
*addr = save[--i];
if (cnt) {
i++;
*addr = ~cnt;
} else {
}*addr = 0;
return (0);
- sync();
- cnt = 0;
- do { addr = base + cnt; /* pointer arith! */ val = *addr;
*addr = save[--i];
if (val != ~cnt) {
*addr = save[i--];
sync();
*addr = save[--i];
}*addr = save[i--]; } return (size);
if (cnt)
cnt = cnt << 1;
else
cnt = 1;
return (maxsize); }
Hi Eddy,
this commit breaks my BuR AM335x boards. The board stucks at boot:
U-Boot 2016.03-rc1-00195-g437cc77-dirty (Feb 09 2016 - 09:25:51 +0100)
initcall: 8080a384 U-Boot code: 80800000 -> 8083A6F4 BSS: -> 8088433C initcall: 8080a174 initcall: 8080a3f0 I2C: ready initcall: 8080a3d8 DRAM: initcall: 80800784
has anybody else experience on am335x boards with this ?
best regards, Hannes
2016-02-09 12:14 GMT+02:00 Hannes Schmelzer hannes@schmelzer.or.at:
save[i++] = *addr;
*addr = ~cnt;
addr = base;
sync();
save[i] = *addr;
sync();
*addr = 0;
sync();
sync();
*addr = save[i];
addr = base + cnt;
sync();
*addr = save[--i];
if (cnt) {
i++;
*addr = ~cnt;
} else {
*addr = 0; }
return (0); }
sync();
cnt = 0;
*addr = save[--i];
if (val != ~cnt) {
*addr = save[i--];
sync();
*addr = save[--i];
if (cnt)
cnt = cnt << 1;
else
cnt = 1;
}} while (cnt < maxsize / sizeof(long)); return (maxsize);
Hi Eddy,
Hi Hannes,
You are correct, it seems that during my clean up phase before sending the patch I managed to send an outdated version of the patch. The easiest fix is to add a 'break;' after the '*addr = 0;' part, but the reported size will be incorrect.
I will work on a correct fixup. Sorry for the inconvenience.
Albert ARIBAUD
Eddy Petrișor
Hannes Schmelzer
