[U-Boot] Atmel SAMA5D31 NOR boot - sanity check required
Hello!
I am currently working on an implementation of NOR boot support for the Atmel SAMA5D31-EK reference platform as a precursor to a custom hardware platform. When tested and working I will push the support back to the community but what I have at the moment doesn't appear to do anything so I would appreciate a sanity check on the work done so far.
For reference the documentation for the Atmel SoC says:
If BMS signal is tied to 0, BMS_BIT is read at 1. The ROM code allows execution of the code contained in the memory connected to Chip Select 0 of the External Bus Interface (J828F128P33TF70A) and then goes on to detail the startup mode and changes that need to be made to the PLL and SMC.
For simplicity sake, I have taken the standard SAMA5D31-EK configuration of SPL+U-Boot and have added NOR boot support to SPL based on one of the other boards. The board header file has the following configuration:
#define CONFIG_SPL_NOR_SUPPORT #define CONFIG_SYS_FLASH_CFI 1 #define CONFIG_FLASH_CFI_DRIVER 1 #define CONFIG_SYS_FLASH_BASE 0x00000000 #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE
As per the standard SPL build for this hardware platform the CONFIG_SYS_INIT_SP_ADDR value is set to 0x310000 but I haven't found a definitive statement that confirms that the internal SRAM is mapped to that location when in this boot mode.
So my questions are...
Is the SPL+U-Boot implementation the best way for NOR booting or should it all just be built as a single U-Boot image?
Do the settings above look correct, particularly the value for the initial stack pointer?
How best do I debug SPL to determine where it is getting lost in the weeds?
Many thanks,
Andy.
Andy Pont
