[PATCH v4 0/5] cmd: bind allow to bind driver with driver_data
- fix the bind command - add a bind command test - add bind command documentation
Changes in v4: - fix make htmldocs error "Title underline too short"
Changes in v3: - fix typo - fix typo - add bind/unbind parameters description and how to find them
Changes in v2: - add a bind command test - add bind command documentation in doc/driver/model/bind.rst - simplify patch 1 by using lists_bind_fdt()
Patrice Chotard (5): cmd: bind: allow to bind driver with driver data sandbox: phy: add driver_data for bind test cmd sandbox: dts: Add compatible string for bind-test node test/py: Update test_bind doc: add bind/unbind command documentation
arch/sandbox/dts/test.dts | 1 + cmd/bind.c | 5 ++-- doc/driver-model/bind.rst | 49 ++++++++++++++++++++++++++++++++++++++ doc/driver-model/index.rst | 1 + drivers/phy/sandbox-phy.c | 18 +++++++++++++- test/py/tests/test_bind.py | 18 +++++++------- 6 files changed, 80 insertions(+), 12 deletions(-) create mode 100644 doc/driver-model/bind.rst
Initial implementation invokes device_bind_with_driver_data() with driver_data parameter equal to 0. For driver with driver data, the bind command can't bind correctly this driver or even worse causes data abort as shown below:
As example, for debug purpose on STM32MP1 platform, ethernet (dwc_eth_qos.c) driver needed to be unbinded/binded. This driver is using driver data:
static const struct udevice_id eqos_ids[] = { { .compatible = "nvidia,tegra186-eqos", .data = (ulong)&eqos_tegra186_config }, { .compatible = "snps,dwmac-4.20a", .data = (ulong)&eqos_stm32_config },
After unbinding/binding this driver and probing it (with the dhcp command), we got a prefetch abort as below:
STM32MP> unbind eth ethernet@5800a000 STM32MP> bind /soc/ethernet@5800a000 eth_eqos STM32MP> dhcp prefetch abort pc : [<4310801c>] lr : [<ffc8f4ad>] reloc pc : [<035ba01c>] lr : [<c01414ad>] sp : fdaf19b0 ip : ffcea83c fp : 00000001 r10: ffcfd4a0 r9 : fdaffed0 r8 : 00000000 r7 : ffcff304 r6 : fdc63220 r5 : 00000000 r4 : fdc5b108 r3 : 43108020 r2 : 00003d39 r1 : ffcea544 r0 : fdc63220 Flags: nZCv IRQs off FIQs off Mode SVC_32 Code: data abort pc : [<ffc4f9c0>] lr : [<ffc4f9ad>] reloc pc : [<c01019c0>] lr : [<c01019ad>] sp : fdaf18b8 ip : 00000000 fp : 00000001 r10: ffcd69b2 r9 : fdaffed0 r8 : ffcd69aa r7 : 00000000 r6 : 00000008 r5 : 4310801c r4 : fffffffc r3 : 00000001 r2 : 00000028 r1 : 00000000 r0 : 00000006 Flags: NzCv IRQs on FIQs on Mode SVC_32 (T) Code: 2f00 d1e9 2c00 dce9 (f855) 2024 Resetting CPU ...
Signed-off-by: Patrice Chotard patrice.chotard@st.com Cc: Jean-Jacques Hiblot jjhiblot@ti.com Reviewed-by: Simon Glass sjg@chromium.org
Changes in v4: None Changes in v3: None Changes in v2: - add a bind command test - add bind command documentation in doc/driver/model/bind.rst - simplify patch 1 by using lists_bind_fdt()
cmd/bind.c | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/cmd/bind.c b/cmd/bind.c index 44a5f17f0d..0aefc531d8 100644 --- a/cmd/bind.c +++ b/cmd/bind.c @@ -7,6 +7,7 @@ #include <dm.h> #include <dm/device-internal.h> #include <dm/lists.h> +#include <dm/root.h> #include <dm/uclass-internal.h>
static int bind_by_class_index(const char *uclass, int index, @@ -150,8 +151,8 @@ static int bind_by_node_path(const char *path, const char *drv_name) }
ofnode = ofnode_path(path); - ret = device_bind_with_driver_data(parent, drv, ofnode_get_name(ofnode), - 0, ofnode, &dev); + ret = lists_bind_fdt(parent, ofnode, &dev, false); + if (!dev || ret) { printf("Unable to bind. err:%d\n", ret); return ret;
Sorry for the delay in getting to this. Currently, this breaks the dm unit tests on sandbox, can you please investigate? Thanks!
Hi Tom
Sorry for the delay, i was on vacation.
I launched dm unit tests on current master (ada61f1ee2a4eaa1b29d699b5ba940483171df8a)
and everything seems ok, perhaps i don't execute them correctly, see my log below :
./test/py/test.py --bd sandbox --build -k ut_dm -v
+make O=/local/home/nxp11987/projects/community/u-boot.denx/build-sandbox -s sandbox_defconfig +make O=/local/home/nxp11987/projects/community/u-boot.denx/build-sandbox -s -j8 ======================================================================================= test session starts ======================================================================================= platform linux -- Python 3.6.9, pytest-5.2.1, py-1.8.0, pluggy-0.13.0 -- /usr/bin/python3 cachedir: .pytest_cache rootdir: /local/home/nxp11987/projects/community/u-boot.denx/test/py, inifile: pytest.ini collected 672 items / 370 deselected / 302 selected
test/py/tests/test_ut.py::test_ut_dm_init PASSED [ 0%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_basic] PASSED [ 0%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_cmd_dump] PASSED [ 0%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_cmd_items] PASSED [ 1%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_cmd_list] PASSED [ 1%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_create_dmar] PASSED [ 1%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_device] PASSED [ 2%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_device_path] PASSED [ 2%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_device_status] PASSED [ 2%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_dp_array] PASSED [ 3%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_dp_child] PASSED [ 3%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_dp_copy] PASSED [ 3%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_dp_gpio] PASSED [ 4%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_dp_int] PASSED [ 4%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_dp_int16] PASSED [ 4%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_dp_int64] PASSED [ 5%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_dp_int8] PASSED [ 5%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_dp_multiple] PASSED [ 5%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_dp_new_table] PASSED [ 6%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_emit_simple] PASSED [ 6%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_emit_stream] PASSED [ 6%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_emit_string] PASSED [ 7%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_fill_header] PASSED [ 7%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_fill_ssdt] PASSED [ 7%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_get_name] PASSED [ 8%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_get_table_revision] PASSED [ 8%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_gpio] PASSED [ 8%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_gpio_irq] PASSED [ 9%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_gpio_toggle] PASSED [ 9%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_i2c] PASSED [ 9%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_inject_dsdt] PASSED [ 10%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_integer] PASSED [ 10%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_interrupt] PASSED [ 10%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_interrupt_or_gpio] PASSED [ 11%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_len] PASSED [ 11%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_misc] PASSED [ 11%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_name] PASSED [ 12%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_package] PASSED [ 12%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_power_res] PASSED [ 12%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_power_seq] PASSED [ 13%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_resource_template] PASSED [ 13%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_scope] PASSED [ 13%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_setup_base_tables] PASSED [ 14%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_spi] PASSED [ 14%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_string] PASSED [ 14%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_uuid] PASSED [ 15%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_write_name] PASSED [ 15%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_write_tables] PASSED [ 15%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_write_values] PASSED [ 16%] test/py/tests/test_ut.py::test_ut[ut_dm_adc_bind] PASSED [ 16%] test/py/tests/test_ut.py::test_ut[ut_dm_adc_multi_channel_conversion] PASSED [ 16%] test/py/tests/test_ut.py::test_ut[ut_dm_adc_multi_channel_shot] PASSED [ 17%] test/py/tests/test_ut.py::test_ut[ut_dm_adc_raw_to_uV] PASSED [ 17%] test/py/tests/test_ut.py::test_ut[ut_dm_adc_single_channel_conversion] PASSED [ 17%] test/py/tests/test_ut.py::test_ut[ut_dm_adc_single_channel_shot] PASSED [ 18%] test/py/tests/test_ut.py::test_ut[ut_dm_adc_supply] PASSED [ 18%] test/py/tests/test_ut.py::test_ut[ut_dm_adc_wrong_channel_selection] PASSED [ 18%] test/py/tests/test_ut.py::test_ut[ut_dm_alias_highest_id] PASSED [ 19%] test/py/tests/test_ut.py::test_ut[ut_dm_audio] PASSED [ 19%] test/py/tests/test_ut.py::test_ut[ut_dm_autobind] PASSED [ 19%] test/py/tests/test_ut.py::test_ut[ut_dm_autobind_uclass_pdata_alloc] PASSED [ 20%] test/py/tests/test_ut.py::test_ut[ut_dm_autobind_uclass_pdata_valid] PASSED [ 20%] test/py/tests/test_ut.py::test_ut[ut_dm_autoprobe] PASSED [ 20%] test/py/tests/test_ut.py::test_ut[ut_dm_axi_base] PASSED [ 21%] test/py/tests/test_ut.py::test_ut[ut_dm_axi_busnum] PASSED [ 21%] test/py/tests/test_ut.py::test_ut[ut_dm_axi_store] PASSED [ 21%] test/py/tests/test_ut.py::test_ut[ut_dm_blk_base] PASSED [ 22%] test/py/tests/test_ut.py::test_ut[ut_dm_blk_devnum] PASSED [ 22%] test/py/tests/test_ut.py::test_ut[ut_dm_blk_find] PASSED [ 22%] test/py/tests/test_ut.py::test_ut[ut_dm_blk_get_from_parent] PASSED [ 23%] test/py/tests/test_ut.py::test_ut[ut_dm_blk_usb] PASSED [ 23%] test/py/tests/test_ut.py::test_ut[ut_dm_board] PASSED [ 23%] test/py/tests/test_ut.py::test_ut[ut_dm_bootcount] PASSED [ 24%] test/py/tests/test_ut.py::test_ut[ut_dm_bus_child_post_bind] PASSED [ 24%] test/py/tests/test_ut.py::test_ut[ut_dm_bus_child_post_bind_uclass] PASSED [ 24%] test/py/tests/test_ut.py::test_ut[ut_dm_bus_child_post_probe_uclass] PASSED [ 25%] test/py/tests/test_ut.py::test_ut[ut_dm_bus_child_pre_probe_uclass] PASSED [ 25%] test/py/tests/test_ut.py::test_ut[ut_dm_bus_children] PASSED [ 25%] test/py/tests/test_ut.py::test_ut[ut_dm_bus_children_funcs] PASSED [ 26%] test/py/tests/test_ut.py::test_ut[ut_dm_bus_children_iterators] PASSED [ 26%] test/py/tests/test_ut.py::test_ut[ut_dm_bus_children_of_offset] PASSED [ 26%] test/py/tests/test_ut.py::test_ut[ut_dm_bus_parent_data] PASSED [ 27%] test/py/tests/test_ut.py::test_ut[ut_dm_bus_parent_data_uclass] PASSED [ 27%] test/py/tests/test_ut.py::test_ut[ut_dm_bus_parent_ops] PASSED [ 27%] test/py/tests/test_ut.py::test_ut[ut_dm_bus_parent_platdata] PASSED [ 28%] test/py/tests/test_ut.py::test_ut[ut_dm_bus_parent_platdata_uclass] PASSED [ 28%] test/py/tests/test_ut.py::test_ut[ut_dm_child_ofdata] PASSED [ 28%] test/py/tests/test_ut.py::test_ut[ut_dm_children] PASSED [ 29%] test/py/tests/test_ut.py::test_ut[ut_dm_clk] PASSED [ 29%] test/py/tests/test_ut.py::test_ut[ut_dm_clk_base] PASSED [ 29%] test/py/tests/test_ut.py::test_ut[ut_dm_clk_bulk] PASSED [ 30%] test/py/tests/test_ut.py::test_ut[ut_dm_clk_ccf] PASSED [ 30%] test/py/tests/test_ut.py::test_ut[ut_dm_cpu] PASSED [ 30%] test/py/tests/test_ut.py::test_ut[ut_dm_device_get_uclass_id] PASSED [ 31%] test/py/tests/test_ut.py::test_ut[ut_dm_devres_alloc] PASSED [ 31%] test/py/tests/test_ut.py::test_ut[ut_dm_devres_free] PASSED [ 31%] test/py/tests/test_ut.py::test_ut[ut_dm_devres_kcalloc] PASSED [ 32%] test/py/tests/test_ut.py::test_ut[ut_dm_devres_kmalloc_array] PASSED [ 32%] test/py/tests/test_ut.py::test_ut[ut_dm_devres_kzalloc] PASSED [ 32%] test/py/tests/test_ut.py::test_ut[ut_dm_devres_phase] PASSED [ 33%] test/py/tests/test_ut.py::test_ut[ut_dm_dma] PASSED [ 33%] test/py/tests/test_ut.py::test_ut[ut_dm_dma_m2m] PASSED [ 33%] test/py/tests/test_ut.py::test_ut[ut_dm_dma_rx] PASSED [ 34%] test/py/tests/test_ut.py::test_ut[ut_dm_dsi_host] PASSED [ 34%] test/py/tests/test_ut.py::test_ut[ut_dm_eth] PASSED [ 34%] test/py/tests/test_ut.py::test_ut[ut_dm_eth_act] PASSED [ 35%] test/py/tests/test_ut.py::test_ut[ut_dm_eth_alias] PASSED [ 35%] test/py/tests/test_ut.py::test_ut[ut_dm_eth_async_arp_reply] PASSED [ 35%] test/py/tests/test_ut.py::test_ut[ut_dm_eth_async_ping_reply] PASSED [ 36%] test/py/tests/test_ut.py::test_ut[ut_dm_eth_prime] PASSED [ 36%] test/py/tests/test_ut.py::test_ut[ut_dm_eth_rotate] PASSED [ 36%] test/py/tests/test_ut.py::test_ut[ut_dm_fdt] PASSED [ 37%] test/py/tests/test_ut.py::test_ut[ut_dm_fdt_disable_enable_by_path] PASSED [ 37%] test/py/tests/test_ut.py::test_ut[ut_dm_fdt_livetree_writing] PASSED [ 37%] test/py/tests/test_ut.py::test_ut[ut_dm_fdt_offset] PASSED [ 38%] test/py/tests/test_ut.py::test_ut[ut_dm_fdt_phandle] PASSED [ 38%] test/py/tests/test_ut.py::test_ut[ut_dm_fdt_pre_reloc] PASSED [ 38%] test/py/tests/test_ut.py::test_ut[ut_dm_fdt_remap_addr_flat] PASSED [ 39%] test/py/tests/test_ut.py::test_ut[ut_dm_fdt_remap_addr_index_flat] PASSED [ 39%] test/py/tests/test_ut.py::test_ut[ut_dm_fdt_remap_addr_index_live] PASSED [ 39%] test/py/tests/test_ut.py::test_ut[ut_dm_fdt_remap_addr_live] PASSED [ 40%] test/py/tests/test_ut.py::test_ut[ut_dm_fdt_remap_addr_name_flat] PASSED [ 40%] test/py/tests/test_ut.py::test_ut[ut_dm_fdt_remap_addr_name_live] PASSED [ 40%] test/py/tests/test_ut.py::test_ut[ut_dm_fdt_translation] PASSED [ 41%] test/py/tests/test_ut.py::test_ut[ut_dm_fdt_uclass_seq] PASSED [ 41%] test/py/tests/test_ut.py::test_ut[ut_dm_fdtdec_add_reserved_memory] PASSED [ 41%] test/py/tests/test_ut.py::test_ut[ut_dm_fdtdec_set_carveout] PASSED [ 42%] test/py/tests/test_ut.py::test_ut[ut_dm_firmware_probe] PASSED [ 42%] test/py/tests/test_ut.py::test_ut[ut_dm_first_child] PASSED [ 42%] test/py/tests/test_ut.py::test_ut[ut_dm_first_child_probe] PASSED [ 43%] test/py/tests/test_ut.py::test_ut[ut_dm_first_next_device] PASSED [ 43%] test/py/tests/test_ut.py::test_ut[ut_dm_first_next_ok_device] PASSED [ 43%] test/py/tests/test_ut.py::test_ut[ut_dm_gpio] PASSED [ 44%] test/py/tests/test_ut.py::test_ut[ut_dm_gpio_anon] PASSED [ 44%] test/py/tests/test_ut.py::test_ut[ut_dm_gpio_copy] PASSED [ 44%] test/py/tests/test_ut.py::test_ut[ut_dm_gpio_get_acpi] PASSED [ 45%] test/py/tests/test_ut.py::test_ut[ut_dm_gpio_get_acpi_irq] PASSED [ 45%] test/py/tests/test_ut.py::test_ut[ut_dm_gpio_get_dir_flags] PASSED [ 45%] test/py/tests/test_ut.py::test_ut[ut_dm_gpio_leak] PASSED [ 46%] test/py/tests/test_ut.py::test_ut[ut_dm_gpio_opendrain_opensource] PASSED [ 46%] test/py/tests/test_ut.py::test_ut[ut_dm_gpio_phandles] PASSED [ 46%] test/py/tests/test_ut.py::test_ut[ut_dm_gpio_requestf] PASSED [ 47%] test/py/tests/test_ut.py::test_ut[ut_dm_hwspinlock_base] PASSED [ 47%] test/py/tests/test_ut.py::test_ut[ut_dm_i2c_addr_offset] PASSED [ 47%] test/py/tests/test_ut.py::test_ut[ut_dm_i2c_bytewise] PASSED [ 48%] test/py/tests/test_ut.py::test_ut[ut_dm_i2c_find] PASSED [ 48%] test/py/tests/test_ut.py::test_ut[ut_dm_i2c_offset] PASSED [ 48%] test/py/tests/test_ut.py::test_ut[ut_dm_i2c_offset_len] PASSED [ 49%] test/py/tests/test_ut.py::test_ut[ut_dm_i2c_probe_empty] PASSED [ 49%] test/py/tests/test_ut.py::test_ut[ut_dm_i2c_read_write] PASSED [ 49%] test/py/tests/test_ut.py::test_ut[ut_dm_i2c_speed] PASSED [ 50%] test/py/tests/test_ut.py::test_ut[ut_dm_i2s] PASSED [ 50%] test/py/tests/test_ut.py::test_ut[ut_dm_inactive_child] PASSED [ 50%] test/py/tests/test_ut.py::test_ut[ut_dm_irq_base] PASSED [ 50%] test/py/tests/test_ut.py::test_ut[ut_dm_irq_get_acpi] PASSED [ 51%] test/py/tests/test_ut.py::test_ut[ut_dm_irq_type] PASSED [ 51%] test/py/tests/test_ut.py::test_ut[ut_dm_leak] PASSED [ 51%] test/py/tests/test_ut.py::test_ut[ut_dm_led_base] PASSED [ 52%] test/py/tests/test_ut.py::test_ut[ut_dm_led_blink] PASSED [ 52%] test/py/tests/test_ut.py::test_ut[ut_dm_led_default_state] PASSED [ 52%] test/py/tests/test_ut.py::test_ut[ut_dm_led_gpio] PASSED [ 53%] test/py/tests/test_ut.py::test_ut[ut_dm_led_label] PASSED [ 53%] test/py/tests/test_ut.py::test_ut[ut_dm_led_toggle] PASSED [ 53%] test/py/tests/test_ut.py::test_ut[ut_dm_lifecycle] PASSED [ 54%] test/py/tests/test_ut.py::test_ut[ut_dm_mailbox] PASSED [ 54%] test/py/tests/test_ut.py::test_ut[ut_dm_mdio] PASSED [ 54%] test/py/tests/test_ut.py::test_ut[ut_dm_mdio_mux] PASSED [ 55%] test/py/tests/test_ut.py::test_ut[ut_dm_misc] PASSED [ 55%] test/py/tests/test_ut.py::test_ut[ut_dm_mmc_base] PASSED [ 55%] test/py/tests/test_ut.py::test_ut[ut_dm_mmc_blk] PASSED [ 56%] test/py/tests/test_ut.py::test_ut[ut_dm_net_retry] PASSED [ 56%] test/py/tests/test_ut.py::test_ut[ut_dm_nop] PASSED [ 56%] test/py/tests/test_ut.py::test_ut[ut_dm_ofdata_order] PASSED [ 57%] test/py/tests/test_ut.py::test_ut[ut_dm_ofnode_by_prop_value] PASSED [ 57%] test/py/tests/test_ut.py::test_ut[ut_dm_ofnode_compatible] PASSED [ 57%] test/py/tests/test_ut.py::test_ut[ut_dm_ofnode_fmap] PASSED [ 58%] test/py/tests/test_ut.py::test_ut[ut_dm_ofnode_get_child_count] PASSED [ 58%] test/py/tests/test_ut.py::test_ut[ut_dm_ofnode_get_property_by_prop] PASSED [ 58%] test/py/tests/test_ut.py::test_ut[ut_dm_ofnode_read] PASSED [ 59%] test/py/tests/test_ut.py::test_ut[ut_dm_ofnode_read_chosen] PASSED [ 59%] test/py/tests/test_ut.py::test_ut[ut_dm_operations] PASSED [ 59%] test/py/tests/test_ut.py::test_ut[ut_dm_ordering] PASSED [ 60%] test/py/tests/test_ut.py::test_ut[ut_dm_osd_basics] PASSED [ 60%] test/py/tests/test_ut.py::test_ut[ut_dm_osd_extended] PASSED [ 60%] test/py/tests/test_ut.py::test_ut[ut_dm_p2sb_base] PASSED [ 61%] test/py/tests/test_ut.py::test_ut[ut_dm_panel] PASSED [ 61%] test/py/tests/test_ut.py::test_ut[ut_dm_pch_base] PASSED [ 61%] test/py/tests/test_ut.py::test_ut[ut_dm_pch_ioctl] PASSED [ 62%] test/py/tests/test_ut.py::test_ut[ut_dm_pci_addr_flat] PASSED [ 62%] test/py/tests/test_ut.py::test_ut[ut_dm_pci_addr_live] PASSED [ 62%] test/py/tests/test_ut.py::test_ut[ut_dm_pci_base] PASSED [ 63%] test/py/tests/test_ut.py::test_ut[ut_dm_pci_busdev] PASSED [ 63%] test/py/tests/test_ut.py::test_ut[ut_dm_pci_cap] PASSED [ 63%] test/py/tests/test_ut.py::test_ut[ut_dm_pci_drvdata] PASSED [ 64%] test/py/tests/test_ut.py::test_ut[ut_dm_pci_ea] PASSED [ 64%] test/py/tests/test_ut.py::test_ut[ut_dm_pci_ep_base] PASSED [ 64%] test/py/tests/test_ut.py::test_ut[ut_dm_pci_mixed] PASSED [ 65%] test/py/tests/test_ut.py::test_ut[ut_dm_pci_on_bus] PASSED [ 65%] test/py/tests/test_ut.py::test_ut[ut_dm_pci_swapcase] PASSED [ 65%] test/py/tests/test_ut.py::test_ut[ut_dm_phy_base] PASSED [ 66%] test/py/tests/test_ut.py::test_ut[ut_dm_phy_bulk] PASSED [ 66%] test/py/tests/test_ut.py::test_ut[ut_dm_phy_ops] PASSED [ 66%] test/py/tests/test_ut.py::test_ut[ut_dm_platdata] PASSED [ 67%] test/py/tests/test_ut.py::test_ut[ut_dm_pmc_base] PASSED [ 67%] test/py/tests/test_ut.py::test_ut[ut_dm_power_domain] PASSED [ 67%] test/py/tests/test_ut.py::test_ut[ut_dm_power_pmic_get] PASSED [ 68%] test/py/tests/test_ut.py::test_ut[ut_dm_power_pmic_io] PASSED [ 68%] test/py/tests/test_ut.py::test_ut[ut_dm_power_pmic_mc34708_get] PASSED [ 68%] test/py/tests/test_ut.py::test_ut[ut_dm_power_pmic_mc34708_regs_check] PASSED [ 69%] test/py/tests/test_ut.py::test_ut[ut_dm_power_pmic_mc34708_rw_val] PASSED [ 69%] test/py/tests/test_ut.py::test_ut[ut_dm_power_regulator_autoset] PASSED [ 69%] test/py/tests/test_ut.py::test_ut[ut_dm_power_regulator_autoset_list] PASSED [ 70%] test/py/tests/test_ut.py::test_ut[ut_dm_power_regulator_get] PASSED [ 70%] test/py/tests/test_ut.py::test_ut[ut_dm_power_regulator_set_enable_if_allowed] PASSED [ 70%] test/py/tests/test_ut.py::test_ut[ut_dm_power_regulator_set_get_current] PASSED [ 71%] test/py/tests/test_ut.py::test_ut[ut_dm_power_regulator_set_get_enable] PASSED [ 71%] test/py/tests/test_ut.py::test_ut[ut_dm_power_regulator_set_get_mode] PASSED [ 71%] test/py/tests/test_ut.py::test_ut[ut_dm_power_regulator_set_get_suspend_enable] PASSED [ 72%] test/py/tests/test_ut.py::test_ut[ut_dm_power_regulator_set_get_suspend_voltage] PASSED [ 72%] test/py/tests/test_ut.py::test_ut[ut_dm_power_regulator_set_get_voltage] PASSED [ 72%] test/py/tests/test_ut.py::test_ut[ut_dm_pre_reloc] PASSED [ 73%] test/py/tests/test_ut.py::test_ut[ut_dm_pwm_base] PASSED [ 73%] test/py/tests/test_ut.py::test_ut[ut_dm_ram_base] PASSED [ 73%] test/py/tests/test_ut.py::test_ut[ut_dm_read_and_clear] PASSED [ 74%] test/py/tests/test_ut.py::test_ut[ut_dm_read_int] PASSED [ 74%] test/py/tests/test_ut.py::test_ut[ut_dm_read_int_index] PASSED [ 74%] test/py/tests/test_ut.py::test_ut[ut_dm_regmap_base] PASSED [ 75%] test/py/tests/test_ut.py::test_ut[ut_dm_regmap_getset] PASSED [ 75%] test/py/tests/test_ut.py::test_ut[ut_dm_regmap_poll] PASSED [ 75%] test/py/tests/test_ut.py::test_ut[ut_dm_regmap_rw] PASSED [ 76%] test/py/tests/test_ut.py::test_ut[ut_dm_regmap_syscon] PASSED [ 76%] test/py/tests/test_ut.py::test_ut[ut_dm_remoteproc_base] PASSED [ 76%] test/py/tests/test_ut.py::test_ut[ut_dm_remoteproc_elf] PASSED [ 77%] test/py/tests/test_ut.py::test_ut[ut_dm_remove] PASSED [ 77%] test/py/tests/test_ut.py::test_ut[ut_dm_remove_active_dma] PASSED [ 77%] test/py/tests/test_ut.py::test_ut[ut_dm_request] PASSED [ 78%] test/py/tests/test_ut.py::test_ut[ut_dm_reset] PASSED [ 78%] test/py/tests/test_ut.py::test_ut[ut_dm_reset_base] PASSED [ 78%] test/py/tests/test_ut.py::test_ut[ut_dm_reset_bulk] PASSED [ 79%] test/py/tests/test_ut.py::test_ut[ut_dm_rng_read] PASSED [ 79%] test/py/tests/test_ut.py::test_ut[ut_dm_rtc_base] PASSED [ 79%] test/py/tests/test_ut.py::test_ut[ut_dm_rtc_cmd_list] PASSED [ 80%] test/py/tests/test_ut.py::test_ut[ut_dm_rtc_cmd_rw] PASSED [ 80%] test/py/tests/test_ut.py::test_ut[ut_dm_rtc_dual] PASSED [ 80%] test/py/tests/test_ut.py::test_ut[ut_dm_rtc_read_write] PASSED [ 81%] test/py/tests/test_ut.py::test_ut[ut_dm_rtc_reset] PASSED [ 81%] test/py/tests/test_ut.py::test_ut[ut_dm_rtc_set_get] PASSED [ 81%] test/py/tests/test_ut.py::test_ut[ut_dm_serial] PASSED [ 82%] test/py/tests/test_ut.py::test_ut[ut_dm_simple_pm_bus] PASSED [ 82%] test/py/tests/test_ut.py::test_ut[ut_dm_smem_base] PASSED [ 82%] test/py/tests/test_ut.py::test_ut[ut_dm_sound] PASSED [ 83%] test/py/tests/test_ut.py::test_ut[ut_dm_sound_beep] PASSED [ 83%] test/py/tests/test_ut.py::test_ut[ut_dm_spi_find] PASSED [ 83%] test/py/tests/test_ut.py::test_ut[ut_dm_spi_flash] PASSED [ 84%] test/py/tests/test_ut.py::test_ut[ut_dm_spi_flash_func] PASSED [ 84%] test/py/tests/test_ut.py::test_ut[ut_dm_spi_xfer] PASSED [ 84%] test/py/tests/test_ut.py::test_ut[ut_dm_spmi_access] PASSED [ 85%] test/py/tests/test_ut.py::test_ut[ut_dm_spmi_access_peripheral] PASSED [ 85%] test/py/tests/test_ut.py::test_ut[ut_dm_spmi_probe] PASSED [ 85%] test/py/tests/test_ut.py::test_ut[ut_dm_syscon_base] PASSED [ 86%] test/py/tests/test_ut.py::test_ut[ut_dm_syscon_by_driver_data] PASSED [ 86%] test/py/tests/test_ut.py::test_ut[ut_dm_syscon_by_phandle] PASSED [ 86%] test/py/tests/test_ut.py::test_ut[ut_dm_syscon_reset] PASSED [ 87%] test/py/tests/test_ut.py::test_ut[ut_dm_sysreset_base] PASSED [ 87%] test/py/tests/test_ut.py::test_ut[ut_dm_sysreset_get_last] PASSED [ 87%] test/py/tests/test_ut.py::test_ut[ut_dm_sysreset_get_status] PASSED [ 88%] test/py/tests/test_ut.py::test_ut[ut_dm_sysreset_walk] PASSED [ 88%] test/py/tests/test_ut.py::test_ut[ut_dm_tee] PASSED [ 88%] test/py/tests/test_ut.py::test_ut[ut_dm_timer_base] PASSED [ 89%] test/py/tests/test_ut.py::test_ut[ut_dm_uclass] PASSED [ 89%] test/py/tests/test_ut.py::test_ut[ut_dm_uclass_before_ready] PASSED [ 89%] test/py/tests/test_ut.py::test_ut[ut_dm_uclass_devices_find] PASSED [ 90%] test/py/tests/test_ut.py::test_ut[ut_dm_uclass_devices_find_by_name] PASSED [ 90%] test/py/tests/test_ut.py::test_ut[ut_dm_uclass_devices_get] PASSED [ 90%] test/py/tests/test_ut.py::test_ut[ut_dm_uclass_devices_get_by_name] PASSED [ 91%] test/py/tests/test_ut.py::test_ut[ut_dm_uclass_drvdata] PASSED [ 91%] test/py/tests/test_ut.py::test_ut[ut_dm_uclass_foreach] PASSED [ 91%] test/py/tests/test_ut.py::test_ut[ut_dm_uclass_names] PASSED [ 92%] test/py/tests/test_ut.py::test_ut[ut_dm_usb_base] PASSED [ 92%] test/py/tests/test_ut.py::test_ut[ut_dm_usb_fdt_node] PASSED [ 92%] test/py/tests/test_ut.py::test_ut[ut_dm_usb_flash] PASSED [ 93%] test/py/tests/test_ut.py::test_ut[ut_dm_usb_keyb] PASSED [ 93%] test/py/tests/test_ut.py::test_ut[ut_dm_usb_multi] PASSED [ 93%] test/py/tests/test_ut.py::test_ut[ut_dm_usb_stop] PASSED [ 94%] test/py/tests/test_ut.py::test_ut[ut_dm_video_ansi] PASSED [ 94%] test/py/tests/test_ut.py::test_ut[ut_dm_video_base] PASSED [ 94%] test/py/tests/test_ut.py::test_ut[ut_dm_video_bmp] PASSED [ 95%] test/py/tests/test_ut.py::test_ut[ut_dm_video_bmp_comp] PASSED [ 95%] test/py/tests/test_ut.py::test_ut[ut_dm_video_chars] PASSED [ 95%] test/py/tests/test_ut.py::test_ut[ut_dm_video_context] PASSED [ 96%] test/py/tests/test_ut.py::test_ut[ut_dm_video_rotation1] PASSED [ 96%] test/py/tests/test_ut.py::test_ut[ut_dm_video_rotation2] PASSED [ 96%] test/py/tests/test_ut.py::test_ut[ut_dm_video_rotation3] PASSED [ 97%] test/py/tests/test_ut.py::test_ut[ut_dm_video_text] PASSED [ 97%] test/py/tests/test_ut.py::test_ut[ut_dm_video_truetype] PASSED [ 97%] test/py/tests/test_ut.py::test_ut[ut_dm_video_truetype_bs] PASSED [ 98%] test/py/tests/test_ut.py::test_ut[ut_dm_video_truetype_scroll] PASSED [ 98%] test/py/tests/test_ut.py::test_ut[ut_dm_virtio_all_ops] PASSED [ 98%] test/py/tests/test_ut.py::test_ut[ut_dm_virtio_base] PASSED [ 99%] test/py/tests/test_ut.py::test_ut[ut_dm_virtio_missing_ops] PASSED [ 99%] test/py/tests/test_ut.py::test_ut[ut_dm_virtio_remove] PASSED [ 99%] test/py/tests/test_ut.py::test_ut[ut_dm_wdt_base] PASSED [100%]
============================================================================== 302 passed, 370 deselected in 11.06s ===============================================================================
Patrice
On Mon, Jul 27, 2020 at 02:25:06PM +0000, Patrice CHOTARD wrote:
Hi Tom
Hunh, alright. The series isn't applying cleanly for me either, so can you please rebase and repost? It seems I must have messed something up in the rebase. Thanks!
don't take care of my previous email, i did a mistake ....
Patrice
On 7/27/20 4:25 PM, Patrice CHOTARD wrote:
Hi Tom
test/py/tests/test_ut.py::test_ut_dm_init PASSED [ 0%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_basic] PASSED [ 0%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_cmd_dump] PASSED [ 0%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_cmd_items] PASSED [ 1%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_cmd_list] PASSED [ 1%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_create_dmar] PASSED [ 1%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_device] PASSED [ 2%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_device_path] PASSED [ 2%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_device_status] PASSED [ 2%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_dp_array] PASSED [ 3%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_dp_child] PASSED [ 3%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_dp_copy] PASSED [ 3%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_dp_gpio] PASSED [ 4%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_dp_int] PASSED [ 4%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_dp_int16] PASSED [ 4%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_dp_int64] PASSED [ 5%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_dp_int8] PASSED [ 5%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_dp_multiple] PASSED [ 5%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_dp_new_table] PASSED [ 6%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_emit_simple] PASSED [ 6%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_emit_stream] PASSED [ 6%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_emit_string] PASSED [ 7%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_fill_header] PASSED [ 7%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_fill_ssdt] PASSED [ 7%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_get_name] PASSED [ 8%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_get_table_revision] PASSED [ 8%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_gpio] PASSED [ 8%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_gpio_irq] PASSED [ 9%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_gpio_toggle] PASSED [ 9%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_i2c] PASSED [ 9%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_inject_dsdt] PASSED [ 10%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_integer] PASSED [ 10%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_interrupt] PASSED [ 10%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_interrupt_or_gpio] PASSED [ 11%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_len] PASSED [ 11%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_misc] PASSED [ 11%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_name] PASSED [ 12%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_package] PASSED [ 12%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_power_res] PASSED [ 12%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_power_seq] PASSED [ 13%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_resource_template] PASSED [ 13%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_scope] PASSED [ 13%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_setup_base_tables] PASSED [ 14%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_spi] PASSED [ 14%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_string] PASSED [ 14%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_uuid] PASSED [ 15%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_write_name] PASSED [ 15%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_write_tables] PASSED [ 15%] test/py/tests/test_ut.py::test_ut[ut_dm_acpi_write_values] PASSED [ 16%] test/py/tests/test_ut.py::test_ut[ut_dm_adc_bind] PASSED [ 16%] test/py/tests/test_ut.py::test_ut[ut_dm_adc_multi_channel_conversion] PASSED [ 16%] test/py/tests/test_ut.py::test_ut[ut_dm_adc_multi_channel_shot] PASSED [ 17%] test/py/tests/test_ut.py::test_ut[ut_dm_adc_raw_to_uV] PASSED [ 17%] test/py/tests/test_ut.py::test_ut[ut_dm_adc_single_channel_conversion] PASSED [ 17%] test/py/tests/test_ut.py::test_ut[ut_dm_adc_single_channel_shot] PASSED [ 18%] test/py/tests/test_ut.py::test_ut[ut_dm_adc_supply] PASSED [ 18%] test/py/tests/test_ut.py::test_ut[ut_dm_adc_wrong_channel_selection] PASSED [ 18%] test/py/tests/test_ut.py::test_ut[ut_dm_alias_highest_id] PASSED [ 19%] test/py/tests/test_ut.py::test_ut[ut_dm_audio] PASSED [ 19%] test/py/tests/test_ut.py::test_ut[ut_dm_autobind] PASSED [ 19%] test/py/tests/test_ut.py::test_ut[ut_dm_autobind_uclass_pdata_alloc] PASSED [ 20%] test/py/tests/test_ut.py::test_ut[ut_dm_autobind_uclass_pdata_valid] PASSED [ 20%] test/py/tests/test_ut.py::test_ut[ut_dm_autoprobe] PASSED [ 20%] test/py/tests/test_ut.py::test_ut[ut_dm_axi_base] PASSED [ 21%] test/py/tests/test_ut.py::test_ut[ut_dm_axi_busnum] PASSED [ 21%] test/py/tests/test_ut.py::test_ut[ut_dm_axi_store] PASSED [ 21%] test/py/tests/test_ut.py::test_ut[ut_dm_blk_base] PASSED [ 22%] test/py/tests/test_ut.py::test_ut[ut_dm_blk_devnum] PASSED [ 22%] test/py/tests/test_ut.py::test_ut[ut_dm_blk_find] PASSED [ 22%] test/py/tests/test_ut.py::test_ut[ut_dm_blk_get_from_parent] PASSED [ 23%] test/py/tests/test_ut.py::test_ut[ut_dm_blk_usb] PASSED [ 23%] test/py/tests/test_ut.py::test_ut[ut_dm_board] PASSED [ 23%] test/py/tests/test_ut.py::test_ut[ut_dm_bootcount] PASSED [ 24%] test/py/tests/test_ut.py::test_ut[ut_dm_bus_child_post_bind] PASSED [ 24%] test/py/tests/test_ut.py::test_ut[ut_dm_bus_child_post_bind_uclass] PASSED [ 24%] test/py/tests/test_ut.py::test_ut[ut_dm_bus_child_post_probe_uclass] PASSED [ 25%] test/py/tests/test_ut.py::test_ut[ut_dm_bus_child_pre_probe_uclass] PASSED [ 25%] test/py/tests/test_ut.py::test_ut[ut_dm_bus_children] PASSED [ 25%] test/py/tests/test_ut.py::test_ut[ut_dm_bus_children_funcs] PASSED [ 26%] test/py/tests/test_ut.py::test_ut[ut_dm_bus_children_iterators] PASSED [ 26%] test/py/tests/test_ut.py::test_ut[ut_dm_bus_children_of_offset] PASSED [ 26%] test/py/tests/test_ut.py::test_ut[ut_dm_bus_parent_data] PASSED [ 27%] test/py/tests/test_ut.py::test_ut[ut_dm_bus_parent_data_uclass] PASSED [ 27%] test/py/tests/test_ut.py::test_ut[ut_dm_bus_parent_ops] PASSED [ 27%] test/py/tests/test_ut.py::test_ut[ut_dm_bus_parent_platdata] PASSED [ 28%] test/py/tests/test_ut.py::test_ut[ut_dm_bus_parent_platdata_uclass] PASSED [ 28%] test/py/tests/test_ut.py::test_ut[ut_dm_child_ofdata] PASSED [ 28%] test/py/tests/test_ut.py::test_ut[ut_dm_children] PASSED [ 29%] test/py/tests/test_ut.py::test_ut[ut_dm_clk] PASSED [ 29%] test/py/tests/test_ut.py::test_ut[ut_dm_clk_base] PASSED [ 29%] test/py/tests/test_ut.py::test_ut[ut_dm_clk_bulk] PASSED [ 30%] test/py/tests/test_ut.py::test_ut[ut_dm_clk_ccf] PASSED [ 30%] test/py/tests/test_ut.py::test_ut[ut_dm_cpu] PASSED [ 30%] test/py/tests/test_ut.py::test_ut[ut_dm_device_get_uclass_id] PASSED [ 31%] test/py/tests/test_ut.py::test_ut[ut_dm_devres_alloc] PASSED [ 31%] test/py/tests/test_ut.py::test_ut[ut_dm_devres_free] PASSED [ 31%] test/py/tests/test_ut.py::test_ut[ut_dm_devres_kcalloc] PASSED [ 32%] test/py/tests/test_ut.py::test_ut[ut_dm_devres_kmalloc_array] PASSED [ 32%] test/py/tests/test_ut.py::test_ut[ut_dm_devres_kzalloc] PASSED [ 32%] test/py/tests/test_ut.py::test_ut[ut_dm_devres_phase] PASSED [ 33%] test/py/tests/test_ut.py::test_ut[ut_dm_dma] PASSED [ 33%] test/py/tests/test_ut.py::test_ut[ut_dm_dma_m2m] PASSED [ 33%] test/py/tests/test_ut.py::test_ut[ut_dm_dma_rx] PASSED [ 34%] test/py/tests/test_ut.py::test_ut[ut_dm_dsi_host] PASSED [ 34%] test/py/tests/test_ut.py::test_ut[ut_dm_eth] PASSED [ 34%] test/py/tests/test_ut.py::test_ut[ut_dm_eth_act] PASSED [ 35%] test/py/tests/test_ut.py::test_ut[ut_dm_eth_alias] PASSED [ 35%] test/py/tests/test_ut.py::test_ut[ut_dm_eth_async_arp_reply] PASSED [ 35%] test/py/tests/test_ut.py::test_ut[ut_dm_eth_async_ping_reply] PASSED [ 36%] test/py/tests/test_ut.py::test_ut[ut_dm_eth_prime] PASSED [ 36%] test/py/tests/test_ut.py::test_ut[ut_dm_eth_rotate] PASSED [ 36%] test/py/tests/test_ut.py::test_ut[ut_dm_fdt] PASSED [ 37%] test/py/tests/test_ut.py::test_ut[ut_dm_fdt_disable_enable_by_path] PASSED [ 37%] test/py/tests/test_ut.py::test_ut[ut_dm_fdt_livetree_writing] PASSED [ 37%] test/py/tests/test_ut.py::test_ut[ut_dm_fdt_offset] PASSED [ 38%] test/py/tests/test_ut.py::test_ut[ut_dm_fdt_phandle] PASSED [ 38%] test/py/tests/test_ut.py::test_ut[ut_dm_fdt_pre_reloc] PASSED [ 38%] test/py/tests/test_ut.py::test_ut[ut_dm_fdt_remap_addr_flat] PASSED [ 39%] test/py/tests/test_ut.py::test_ut[ut_dm_fdt_remap_addr_index_flat] PASSED [ 39%] test/py/tests/test_ut.py::test_ut[ut_dm_fdt_remap_addr_index_live] PASSED [ 39%] test/py/tests/test_ut.py::test_ut[ut_dm_fdt_remap_addr_live] PASSED [ 40%] test/py/tests/test_ut.py::test_ut[ut_dm_fdt_remap_addr_name_flat] PASSED [ 40%] test/py/tests/test_ut.py::test_ut[ut_dm_fdt_remap_addr_name_live] PASSED [ 40%] test/py/tests/test_ut.py::test_ut[ut_dm_fdt_translation] PASSED [ 41%] test/py/tests/test_ut.py::test_ut[ut_dm_fdt_uclass_seq] PASSED [ 41%] test/py/tests/test_ut.py::test_ut[ut_dm_fdtdec_add_reserved_memory] PASSED [ 41%] test/py/tests/test_ut.py::test_ut[ut_dm_fdtdec_set_carveout] PASSED [ 42%] test/py/tests/test_ut.py::test_ut[ut_dm_firmware_probe] PASSED [ 42%] test/py/tests/test_ut.py::test_ut[ut_dm_first_child] PASSED [ 42%] test/py/tests/test_ut.py::test_ut[ut_dm_first_child_probe] PASSED [ 43%] test/py/tests/test_ut.py::test_ut[ut_dm_first_next_device] PASSED [ 43%] test/py/tests/test_ut.py::test_ut[ut_dm_first_next_ok_device] PASSED [ 43%] test/py/tests/test_ut.py::test_ut[ut_dm_gpio] PASSED [ 44%] test/py/tests/test_ut.py::test_ut[ut_dm_gpio_anon] PASSED [ 44%] test/py/tests/test_ut.py::test_ut[ut_dm_gpio_copy] PASSED [ 44%] test/py/tests/test_ut.py::test_ut[ut_dm_gpio_get_acpi] PASSED [ 45%] test/py/tests/test_ut.py::test_ut[ut_dm_gpio_get_acpi_irq] PASSED [ 45%] test/py/tests/test_ut.py::test_ut[ut_dm_gpio_get_dir_flags] PASSED [ 45%] test/py/tests/test_ut.py::test_ut[ut_dm_gpio_leak] PASSED [ 46%] test/py/tests/test_ut.py::test_ut[ut_dm_gpio_opendrain_opensource] PASSED [ 46%] test/py/tests/test_ut.py::test_ut[ut_dm_gpio_phandles] PASSED [ 46%] test/py/tests/test_ut.py::test_ut[ut_dm_gpio_requestf] PASSED [ 47%] test/py/tests/test_ut.py::test_ut[ut_dm_hwspinlock_base] PASSED [ 47%] test/py/tests/test_ut.py::test_ut[ut_dm_i2c_addr_offset] PASSED [ 47%] test/py/tests/test_ut.py::test_ut[ut_dm_i2c_bytewise] PASSED [ 48%] test/py/tests/test_ut.py::test_ut[ut_dm_i2c_find] PASSED [ 48%] test/py/tests/test_ut.py::test_ut[ut_dm_i2c_offset] PASSED [ 48%] test/py/tests/test_ut.py::test_ut[ut_dm_i2c_offset_len] PASSED [ 49%] test/py/tests/test_ut.py::test_ut[ut_dm_i2c_probe_empty] PASSED [ 49%] test/py/tests/test_ut.py::test_ut[ut_dm_i2c_read_write] PASSED [ 49%] test/py/tests/test_ut.py::test_ut[ut_dm_i2c_speed] PASSED [ 50%] test/py/tests/test_ut.py::test_ut[ut_dm_i2s] PASSED [ 50%] test/py/tests/test_ut.py::test_ut[ut_dm_inactive_child] PASSED [ 50%] test/py/tests/test_ut.py::test_ut[ut_dm_irq_base] PASSED [ 50%] test/py/tests/test_ut.py::test_ut[ut_dm_irq_get_acpi] PASSED [ 51%] test/py/tests/test_ut.py::test_ut[ut_dm_irq_type] PASSED [ 51%] test/py/tests/test_ut.py::test_ut[ut_dm_leak] PASSED [ 51%] test/py/tests/test_ut.py::test_ut[ut_dm_led_base] PASSED [ 52%] test/py/tests/test_ut.py::test_ut[ut_dm_led_blink] PASSED [ 52%] test/py/tests/test_ut.py::test_ut[ut_dm_led_default_state] PASSED [ 52%] test/py/tests/test_ut.py::test_ut[ut_dm_led_gpio] PASSED [ 53%] test/py/tests/test_ut.py::test_ut[ut_dm_led_label] PASSED [ 53%] test/py/tests/test_ut.py::test_ut[ut_dm_led_toggle] PASSED [ 53%] test/py/tests/test_ut.py::test_ut[ut_dm_lifecycle] PASSED [ 54%] test/py/tests/test_ut.py::test_ut[ut_dm_mailbox] PASSED [ 54%] test/py/tests/test_ut.py::test_ut[ut_dm_mdio] PASSED [ 54%] test/py/tests/test_ut.py::test_ut[ut_dm_mdio_mux] PASSED [ 55%] test/py/tests/test_ut.py::test_ut[ut_dm_misc] PASSED [ 55%] test/py/tests/test_ut.py::test_ut[ut_dm_mmc_base] PASSED [ 55%] test/py/tests/test_ut.py::test_ut[ut_dm_mmc_blk] PASSED [ 56%] test/py/tests/test_ut.py::test_ut[ut_dm_net_retry] PASSED [ 56%] test/py/tests/test_ut.py::test_ut[ut_dm_nop] PASSED [ 56%] test/py/tests/test_ut.py::test_ut[ut_dm_ofdata_order] PASSED [ 57%] test/py/tests/test_ut.py::test_ut[ut_dm_ofnode_by_prop_value] PASSED [ 57%] test/py/tests/test_ut.py::test_ut[ut_dm_ofnode_compatible] PASSED [ 57%] test/py/tests/test_ut.py::test_ut[ut_dm_ofnode_fmap] PASSED [ 58%] test/py/tests/test_ut.py::test_ut[ut_dm_ofnode_get_child_count] PASSED [ 58%] test/py/tests/test_ut.py::test_ut[ut_dm_ofnode_get_property_by_prop] PASSED [ 58%] test/py/tests/test_ut.py::test_ut[ut_dm_ofnode_read] PASSED [ 59%] test/py/tests/test_ut.py::test_ut[ut_dm_ofnode_read_chosen] PASSED [ 59%] test/py/tests/test_ut.py::test_ut[ut_dm_operations] PASSED [ 59%] test/py/tests/test_ut.py::test_ut[ut_dm_ordering] PASSED [ 60%] test/py/tests/test_ut.py::test_ut[ut_dm_osd_basics] PASSED [ 60%] test/py/tests/test_ut.py::test_ut[ut_dm_osd_extended] PASSED [ 60%] test/py/tests/test_ut.py::test_ut[ut_dm_p2sb_base] PASSED [ 61%] test/py/tests/test_ut.py::test_ut[ut_dm_panel] PASSED [ 61%] test/py/tests/test_ut.py::test_ut[ut_dm_pch_base] PASSED [ 61%] test/py/tests/test_ut.py::test_ut[ut_dm_pch_ioctl] PASSED [ 62%] test/py/tests/test_ut.py::test_ut[ut_dm_pci_addr_flat] PASSED [ 62%] test/py/tests/test_ut.py::test_ut[ut_dm_pci_addr_live] PASSED [ 62%] test/py/tests/test_ut.py::test_ut[ut_dm_pci_base] PASSED [ 63%] test/py/tests/test_ut.py::test_ut[ut_dm_pci_busdev] PASSED [ 63%] test/py/tests/test_ut.py::test_ut[ut_dm_pci_cap] PASSED [ 63%] test/py/tests/test_ut.py::test_ut[ut_dm_pci_drvdata] PASSED [ 64%] test/py/tests/test_ut.py::test_ut[ut_dm_pci_ea] PASSED [ 64%] test/py/tests/test_ut.py::test_ut[ut_dm_pci_ep_base] PASSED [ 64%] test/py/tests/test_ut.py::test_ut[ut_dm_pci_mixed] PASSED [ 65%] test/py/tests/test_ut.py::test_ut[ut_dm_pci_on_bus] PASSED [ 65%] test/py/tests/test_ut.py::test_ut[ut_dm_pci_swapcase] PASSED [ 65%] test/py/tests/test_ut.py::test_ut[ut_dm_phy_base] PASSED [ 66%] test/py/tests/test_ut.py::test_ut[ut_dm_phy_bulk] PASSED �� [ 66%] test/py/tests/test_ut.py::test_ut[ut_dm_phy_ops] PASSED [ 66%] test/py/tests/test_ut.py::test_ut[ut_dm_platdata] PASSED [ 67%] test/py/tests/test_ut.py::test_ut[ut_dm_pmc_base] PASSED [ 67%] test/py/tests/test_ut.py::test_ut[ut_dm_power_domain] PASSED [ 67%] test/py/tests/test_ut.py::test_ut[ut_dm_power_pmic_get] PASSED [ 68%] test/py/tests/test_ut.py::test_ut[ut_dm_power_pmic_io] PASSED [ 68%] test/py/tests/test_ut.py::test_ut[ut_dm_power_pmic_mc34708_get] PASSED [ 68%] test/py/tests/test_ut.py::test_ut[ut_dm_power_pmic_mc34708_regs_check] PASSED [ 69%] test/py/tests/test_ut.py::test_ut[ut_dm_power_pmic_mc34708_rw_val] PASSED [ 69%] test/py/tests/test_ut.py::test_ut[ut_dm_power_regulator_autoset] PASSED [ 69%] test/py/tests/test_ut.py::test_ut[ut_dm_power_regulator_autoset_list] PASSED [ 70%] test/py/tests/test_ut.py::test_ut[ut_dm_power_regulator_get] PASSED [ 70%] test/py/tests/test_ut.py::test_ut[ut_dm_power_regulator_set_enable_if_allowed] PASSED [ 70%] test/py/tests/test_ut.py::test_ut[ut_dm_power_regulator_set_get_current] PASSED [ 71%] test/py/tests/test_ut.py::test_ut[ut_dm_power_regulator_set_get_enable] PASSED [ 71%] test/py/tests/test_ut.py::test_ut[ut_dm_power_regulator_set_get_mode] PASSED [ 71%] test/py/tests/test_ut.py::test_ut[ut_dm_power_regulator_set_get_suspend_enable] PASSED [ 72%] test/py/tests/test_ut.py::test_ut[ut_dm_power_regulator_set_get_suspend_voltage] PASSED [ 72%] test/py/tests/test_ut.py::test_ut[ut_dm_power_regulator_set_get_voltage] PASSED [ 72%] test/py/tests/test_ut.py::test_ut[ut_dm_pre_reloc] PASSED [ 73%] test/py/tests/test_ut.py::test_ut[ut_dm_pwm_base] PASSED [ 73%] test/py/tests/test_ut.py::test_ut[ut_dm_ram_base] PASSED [ 73%] test/py/tests/test_ut.py::test_ut[ut_dm_read_and_clear] PASSED [ 74%] test/py/tests/test_ut.py::test_ut[ut_dm_read_int] PASSED [ 74%] test/py/tests/test_ut.py::test_ut[ut_dm_read_int_index] PASSED [ 74%] test/py/tests/test_ut.py::test_ut[ut_dm_regmap_base] PASSED [ 75%] test/py/tests/test_ut.py::test_ut[ut_dm_regmap_getset] PASSED [ 75%] test/py/tests/test_ut.py::test_ut[ut_dm_regmap_poll] PASSED [ 75%] test/py/tests/test_ut.py::test_ut[ut_dm_regmap_rw] PASSED [ 76%] test/py/tests/test_ut.py::test_ut[ut_dm_regmap_syscon] PASSED [ 76%] test/py/tests/test_ut.py::test_ut[ut_dm_remoteproc_base] PASSED [ 76%] test/py/tests/test_ut.py::test_ut[ut_dm_remoteproc_elf] PASSED [ 77%] test/py/tests/test_ut.py::test_ut[ut_dm_remove] PASSED [ 77%] test/py/tests/test_ut.py::test_ut[ut_dm_remove_active_dma] PASSED [ 77%] test/py/tests/test_ut.py::test_ut[ut_dm_request] PASSED [ 78%] test/py/tests/test_ut.py::test_ut[ut_dm_reset] PASSED [ 78%] test/py/tests/test_ut.py::test_ut[ut_dm_reset_base] PASSED [ 78%] test/py/tests/test_ut.py::test_ut[ut_dm_reset_bulk] PASSED [ 79%] test/py/tests/test_ut.py::test_ut[ut_dm_rng_read] PASSED [ 79%] test/py/tests/test_ut.py::test_ut[ut_dm_rtc_base] PASSED [ 79%] test/py/tests/test_ut.py::test_ut[ut_dm_rtc_cmd_list] PASSED [ 80%] test/py/tests/test_ut.py::test_ut[ut_dm_rtc_cmd_rw] PASSED [ 80%] test/py/tests/test_ut.py::test_ut[ut_dm_rtc_dual] PASSED [ 80%] test/py/tests/test_ut.py::test_ut[ut_dm_rtc_read_write] PASSED [ 81%] test/py/tests/test_ut.py::test_ut[ut_dm_rtc_reset] PASSED [ 81%] test/py/tests/test_ut.py::test_ut[ut_dm_rtc_set_get] PASSED [ 81%] test/py/tests/test_ut.py::test_ut[ut_dm_serial] PASSED [ 82%] test/py/tests/test_ut.py::test_ut[ut_dm_simple_pm_bus] PASSED [ 82%] test/py/tests/test_ut.py::test_ut[ut_dm_smem_base] PASSED [ 82%] test/py/tests/test_ut.py::test_ut[ut_dm_sound] PASSED [ 83%] test/py/tests/test_ut.py::test_ut[ut_dm_sound_beep] PASSED [ 83%] test/py/tests/test_ut.py::test_ut[ut_dm_spi_find] PASSED [ 83%] test/py/tests/test_ut.py::test_ut[ut_dm_spi_flash] PASSED [ 84%] test/py/tests/test_ut.py::test_ut[ut_dm_spi_flash_func] PASSED [ 84%] test/py/tests/test_ut.py::test_ut[ut_dm_spi_xfer] PASSED [ 84%] test/py/tests/test_ut.py::test_ut[ut_dm_spmi_access] PASSED [ 85%] test/py/tests/test_ut.py::test_ut[ut_dm_spmi_access_peripheral] PASSED [ 85%] test/py/tests/test_ut.py::test_ut[ut_dm_spmi_probe] PASSED [ 85%] test/py/tests/test_ut.py::test_ut[ut_dm_syscon_base] PASSED [ 86%] test/py/tests/test_ut.py::test_ut[ut_dm_syscon_by_driver_data] PASSED [ 86%] test/py/tests/test_ut.py::test_ut[ut_dm_syscon_by_phandle] PASSED [ 86%] test/py/tests/test_ut.py::test_ut[ut_dm_syscon_reset] PASSED [ 87%] test/py/tests/test_ut.py::test_ut[ut_dm_sysreset_base] PASSED [ 87%] test/py/tests/test_ut.py::test_ut[ut_dm_sysreset_get_last] PASSED [ 87%] test/py/tests/test_ut.py::test_ut[ut_dm_sysreset_get_status] PASSED [ 88%] test/py/tests/test_ut.py::test_ut[ut_dm_sysreset_walk] PASSED [ 88%] test/py/tests/test_ut.py::test_ut[ut_dm_tee] PASSED [ 88%] test/py/tests/test_ut.py::test_ut[ut_dm_timer_base] PASSED [ 89%] test/py/tests/test_ut.py::test_ut[ut_dm_uclass] PASSED [ 89%] test/py/tests/test_ut.py::test_ut[ut_dm_uclass_before_ready] PASSED [ 89%] test/py/tests/test_ut.py::test_ut[ut_dm_uclass_devices_find] PASSED [ 90%] test/py/tests/test_ut.py::test_ut[ut_dm_uclass_devices_find_by_name] PASSED [ 90%] test/py/tests/test_ut.py::test_ut[ut_dm_uclass_devices_get] PASSED [ 90%] test/py/tests/test_ut.py::test_ut[ut_dm_uclass_devices_get_by_name] PASSED [ 91%] test/py/tests/test_ut.py::test_ut[ut_dm_uclass_drvdata] PASSED [ 91%] test/py/tests/test_ut.py::test_ut[ut_dm_uclass_foreach] PASSED [ 91%] test/py/tests/test_ut.py::test_ut[ut_dm_uclass_names] PASSED [ 92%] test/py/tests/test_ut.py::test_ut[ut_dm_usb_base] PASSED [ 92%] test/py/tests/test_ut.py::test_ut[ut_dm_usb_fdt_node] PASSED [ 92%] test/py/tests/test_ut.py::test_ut[ut_dm_usb_flash] PASSED [ 93%] test/py/tests/test_ut.py::test_ut[ut_dm_usb_keyb] PASSED [ 93%] test/py/tests/test_ut.py::test_ut[ut_dm_usb_multi] PASSED [ 93%] test/py/tests/test_ut.py::test_ut[ut_dm_usb_stop] PASSED [ 94%] test/py/tests/test_ut.py::test_ut[ut_dm_video_ansi] PASSED [ 94%] test/py/tests/test_ut.py::test_ut[ut_dm_video_base] PASSED [ 94%] test/py/tests/test_ut.py::test_ut[ut_dm_video_bmp] PASSED [ 95%] test/py/tests/test_ut.py::test_ut[ut_dm_video_bmp_comp] PASSED [ 95%] test/py/tests/test_ut.py::test_ut[ut_dm_video_chars] PASSED [ 95%] test/py/tests/test_ut.py::test_ut[ut_dm_video_context] PASSED [ 96%] test/py/tests/test_ut.py::test_ut[ut_dm_video_rotation1] PASSED [ 96%] test/py/tests/test_ut.py::test_ut[ut_dm_video_rotation2] PASSED [ 96%] test/py/tests/test_ut.py::test_ut[ut_dm_video_rotation3] PASSED [ 97%] test/py/tests/test_ut.py::test_ut[ut_dm_video_text] PASSED [ 97%] test/py/tests/test_ut.py::test_ut[ut_dm_video_truetype] PASSED [ 97%] test/py/tests/test_ut.py::test_ut[ut_dm_video_truetype_bs] PASSED [ 98%] test/py/tests/test_ut.py::test_ut[ut_dm_video_truetype_scroll] PASSED [ 98%] test/py/tests/test_ut.py::test_ut[ut_dm_virtio_all_ops] PASSED [ 98%] test/py/tests/test_ut.py::test_ut[ut_dm_virtio_base] PASSED [ 99%] test/py/tests/test_ut.py::test_ut[ut_dm_virtio_missing_ops] PASSED [ 99%] test/py/tests/test_ut.py::test_ut[ut_dm_virtio_remove] PASSED [ 99%] test/py/tests/test_ut.py::test_ut[ut_dm_wdt_base] PASSED [100%]
Patrice
Hi Tom
A v5 has been submitted fixing the dm unit test regression
Thanks
Patrice
Add driver data to existing compatible string "sandbox,phy". Add an additional compatible string without driver_data
This will verify that bind command parses, finds and passes the correct driver data to device_bind_with_driver_data() by using driver_data in the second sandbox_phy_ids table entry. In sandbox_phy_bind() a check is added to validate driver_data content.
Signed-off-by: Patrice Chotard patrice.chotard@st.com Reviewed-by: Simon Glass sjg@chromium.org ---
Changes in v4: None Changes in v3: None Changes in v2: None
drivers/phy/sandbox-phy.c | 18 +++++++++++++++++- 1 file changed, 17 insertions(+), 1 deletion(-)
diff --git a/drivers/phy/sandbox-phy.c b/drivers/phy/sandbox-phy.c index 84ff5c6275..5f36da7692 100644 --- a/drivers/phy/sandbox-phy.c +++ b/drivers/phy/sandbox-phy.c @@ -8,6 +8,8 @@ #include <dm.h> #include <generic-phy.h>
+#define DRIVER_DATA 0x12345678 + struct sandbox_phy_priv { bool initialized; bool on; @@ -71,6 +73,14 @@ static int sandbox_phy_exit(struct phy *phy) return 0; }
+static int sandbox_phy_bind(struct udevice *dev) +{ + if (dev_get_driver_data(dev) != DRIVER_DATA) + return -ENODATA; + + return 0; +} + static int sandbox_phy_probe(struct udevice *dev) { struct sandbox_phy_priv *priv = dev_get_priv(dev); @@ -90,13 +100,19 @@ static struct phy_ops sandbox_phy_ops = { };
static const struct udevice_id sandbox_phy_ids[] = { - { .compatible = "sandbox,phy" }, + { .compatible = "sandbox,phy_no_driver_data", + }, + + { .compatible = "sandbox,phy", + .data = DRIVER_DATA + }, { } };
U_BOOT_DRIVER(phy_sandbox) = { .name = "phy_sandbox", .id = UCLASS_PHY, + .bind = sandbox_phy_bind, .of_match = sandbox_phy_ids, .ops = &sandbox_phy_ops, .probe = sandbox_phy_probe,
Usage of lists_bind_fdt() in bind command imposes to add a compatible string for bind-test node. The other impact, is that bind-test node is binded at sandbox start, so no need to bind it in test_bind_unbind_with_node() test
arch/sandbox/dts/test.dts | 1 + test/py/tests/test_bind.py | 3 --- 2 files changed, 1 insertion(+), 3 deletions(-)
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index df9f1835c9..7c6b14887f 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -131,6 +131,7 @@ };
bind-test { + compatible = "simple-bus"; bind-test-child1 { compatible = "sandbox,phy"; #phy-cells = <1>; diff --git a/test/py/tests/test_bind.py b/test/py/tests/test_bind.py index 20c6050342..0b7cd9a808 100644 --- a/test/py/tests/test_bind.py +++ b/test/py/tests/test_bind.py @@ -25,9 +25,6 @@ def in_tree(response, name, uclass, drv, depth, last_child): @pytest.mark.buildconfigspec('cmd_bind') def test_bind_unbind_with_node(u_boot_console):
- #bind /bind-test. Device should come up as well as its children - response = u_boot_console.run_command('bind /bind-test generic_simple_bus') - assert response == '' tree = u_boot_console.run_command('dm tree') assert in_tree(tree, 'bind-test', 'simple_bus', 'generic_simple_bus', 0, True) assert in_tree(tree, 'bind-test-child1', 'phy', 'phy_sandbox', 1, False)
As bind-test is now binded at sandbox startup and no more by test_bind.py, bind-test nodes are not located at the end of "dm tree" output, but can be located everywhere in the tree, so bind-test output could either be:
simple_bus 0 [ ] generic_simple_bus |-- bind-test phy 0 [ ] phy_sandbox | |-- bind-test-child1 simple_bus 1 [ ] generic_simple_bus | `-- bind-test-child2
or:
simple_bus 5 [ ] generic_simple_bus `-- bind-test phy 2 [ ] phy_sandbox |-- bind-test-child1 simple_bus 6 [ ] generic_simple_bus `-- bind-test-child2
in_tree() function need to be updated to take care of that change.
Changes in v4: None Changes in v3: - fix typo
Changes in v2: None
test/py/tests/test_bind.py | 15 +++++++++------ 1 file changed, 9 insertions(+), 6 deletions(-)
diff --git a/test/py/tests/test_bind.py b/test/py/tests/test_bind.py index 0b7cd9a808..4753c7ea7b 100644 --- a/test/py/tests/test_bind.py +++ b/test/py/tests/test_bind.py @@ -7,13 +7,16 @@ import re
def in_tree(response, name, uclass, drv, depth, last_child): lines = [x.strip() for x in response.splitlines()] - leaf = ' ' * 4 * depth; - if not last_child: - leaf = leaf + r'|' - else: - leaf = leaf + '`' + leaf = '' + if depth != 0: + leaf = ' ' + ' ' * (depth - 1) ; + if not last_child: + leaf = leaf + r'|' + else: + leaf = leaf + '`' + leaf = leaf + '-- ' + name - line = (r' *{:10.10} [0-9]* [ [ +] ] {:20.20} {}$' + line = (r' *{:10.10} [0-9]* [ [ +] ] {:20.20} [` |]{}$' .format(uclass, drv, leaf)) prog = re.compile(line) for l in lines:
Add documentation in doc/drivel-model for the bind/unbind command. Part of this documentation is extracted from original patch commit message: commit 49c752c93a78 ("cmd: Add bind/unbind commands to bind a device to a driver from the command line")
Changes in v3: - fix typo - add bind/unbind parameters description and how to find them
Changes in v2: None
doc/driver-model/bind.rst | 49 ++++++++++++++++++++++++++++++++++++++ doc/driver-model/index.rst | 1 + 2 files changed, 50 insertions(+) create mode 100644 doc/driver-model/bind.rst
diff --git a/doc/driver-model/bind.rst b/doc/driver-model/bind.rst new file mode 100644 index 0000000000..e3e9cb4d3c --- /dev/null +++ b/doc/driver-model/bind.rst @@ -0,0 +1,49 @@ +.. SPDX-License-Identifier: GPL-2.0+ +.. sectionauthor:: Patrice Chotard patrice.chotard@st.com + +Binding/unbinding a driver +========================== + +This document aims to describe the bind and unbind commands. + +For debugging purpose, it should be useful to bind or unbind a driver from +the U-boot command line. + +The unbind command calls the remove device driver callback and unbind the +device from its driver. + +The bind command binds a device to its driver. + +In some cases it can be useful to be able to bind a device to a driver from +the command line. +The obvious example is for versatile devices such as USB gadget. +Another use case is when the devices are not yet ready at startup and +require some setup before the drivers are bound (ex: FPGA which bitsream is +fetched from a mass storage or ethernet) + +usage: + +bind <node path> <driver> +bind <class> <index> <driver> + +unbind <node path> +unbind <class> <index> +unbind <class> <index> <driver> + +Where: + - <node path> is the node's device tree path + - <class> is one of the class available in the list given by the "dm uclass" + command or first column of "dm tree" command. + - <index> is the index of the parent's node (second column of "dm tree" output). + - <driver> is the driver name to bind given by the "dm drivers" command or the by + the fourth column of "dm tree" output. + +example: + +bind usb_dev_generic 0 usb_ether +unbind usb_dev_generic 0 usb_ether +or +unbind eth 1 + +bind /ocp/omap_dwc3@48380000/usb@48390000 usb_ether +unbind /ocp/omap_dwc3@48380000/usb@48390000 diff --git a/doc/driver-model/index.rst b/doc/driver-model/index.rst index b9df221627..37ef3721df 100644 --- a/doc/driver-model/index.rst +++ b/doc/driver-model/index.rst @@ -6,6 +6,7 @@ Driver Model .. toctree:: :maxdepth: 2
+ bind debugging design ethernet
Changes in v4:
Changes in v3:
- fix typo
Changes in v2: None
I'm still a bit unsure why we must specify the driver name.
Patrice CHOTARD
Patrice Chotard
