[U-Boot] question about boot timing -- should it all depend on BOOTSTAGE?
looking at another Kconfig file -- common/Kconfig -- and i find it curious that there are a couple BOOTSTAGE config options that don't depend on BOOTSTAGE:
config BOOTSTAGE_USER_COUNT hex "Number of boot ID numbers available for user use" default 20 help This is the number of available user bootstage records. Each time you call bootstage_mark(BOOTSTAGE_ID_ALLOC, ...) a new ID will be allocated from this stash. If you exceed the limit, recording will stop.
... snip ...
config BOOTSTAGE_STASH_ADDR hex "Address to stash boot timing information" default 0 help Provide an address which will not be overwritten by the OS when it starts, so that it can read this information when ready.
config BOOTSTAGE_STASH_SIZE hex "Size of boot timing stash region" default 4096 help This should be large enough to hold the bootstage stash. A value of 4096 (4KiB) is normally plenty.
endmenu
do those Kbuild options really not need BOOTSTAGE to be selected first?
rday
Robert P. J. Day
