[PATCH] Revert "i2c: rcar_i2c: Set the slave address from rcar_i2c_xfer"
This reverts commit 7c8f821e ("i2c: rcar_i2c: Set the slave address from rcar_i2c_xfer"), as it blindly called rcar_i2c_set_addr() with read argument always set to 1 during xfer which introduced read errors, whereas earlier rcar_i2c_read_common() called rcar_i2c_set_addr() with read set to 1 and rcar_i2c_write_common() called rcar_i2c_set_addr() with read set 0.
Signed-off-by: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com Reviewed-by: Biju Das biju.das.jz@bp.renesas.com --- drivers/i2c/rcar_i2c.c | 14 +++++++++----- 1 file changed, 9 insertions(+), 5 deletions(-)
diff --git a/drivers/i2c/rcar_i2c.c b/drivers/i2c/rcar_i2c.c index 4267bbfa5a..75448c8368 100644 --- a/drivers/i2c/rcar_i2c.c +++ b/drivers/i2c/rcar_i2c.c @@ -162,6 +162,10 @@ static int rcar_i2c_read_common(struct udevice *dev, struct i2c_msg *msg) u32 icmcr = RCAR_I2C_ICMCR_MDBS | RCAR_I2C_ICMCR_MIE; int i, ret = -EREMOTEIO;
+ ret = rcar_i2c_set_addr(dev, msg->addr, 1); + if (ret) + return ret; + for (i = 0; i < msg->len; i++) { if (msg->len - 1 == i) icmcr |= RCAR_I2C_ICMCR_FSB; @@ -188,6 +192,10 @@ static int rcar_i2c_write_common(struct udevice *dev, struct i2c_msg *msg) u32 icmcr = RCAR_I2C_ICMCR_MDBS | RCAR_I2C_ICMCR_MIE; int i, ret = -EREMOTEIO;
+ ret = rcar_i2c_set_addr(dev, msg->addr, 0); + if (ret) + return ret; + for (i = 0; i < msg->len; i++) { writel(msg->buf[i], priv->base + RCAR_I2C_ICRXD_ICTXD); writel(icmcr, priv->base + RCAR_I2C_ICMCR); @@ -211,10 +219,6 @@ static int rcar_i2c_xfer(struct udevice *dev, struct i2c_msg *msg, int nmsgs) int ret;
for (; nmsgs > 0; nmsgs--, msg++) { - ret = rcar_i2c_set_addr(dev, msg->addr, 1); - if (ret) - return ret; - if (msg->flags & I2C_M_RD) ret = rcar_i2c_read_common(dev, msg); else @@ -224,7 +228,7 @@ static int rcar_i2c_xfer(struct udevice *dev, struct i2c_msg *msg, int nmsgs) return ret; }
- return 0; + return ret; }
static int rcar_i2c_probe_chip(struct udevice *dev, uint addr, uint flags)
Hello Lad,
Am 21.09.2020 um 18:33 schrieb Lad Prabhakar:
- if (ret)
return ret;
- for (i = 0; i < msg->len; i++) { if (msg->len - 1 == i) icmcr |= RCAR_I2C_ICMCR_FSB;
- ret = rcar_i2c_set_addr(dev, msg->addr, 0);
- if (ret)
return ret;
- for (i = 0; i < msg->len; i++) { writel(msg->buf[i], priv->base + RCAR_I2C_ICRXD_ICTXD); writel(icmcr, priv->base + RCAR_I2C_ICMCR);
Instead of reverting, can you do:
rcar_i2c_set_addr(dev, msg->addr, msg->flags & I2C_M_RD);
if (ret)
return ret;
return ret; }
bye, Heiko
Hi Heiko,
Thank you for the review.
On Wed, Sep 30, 2020 at 8:18 AM Heiko Schocher hs@denx.de wrote:
Hello Lad,
if (ret)
return ret;
if (ret)
return ret;
Sure that too fixes the issue. I'll post a v2 soon.
Cheers, Prabhakar
Heiko Schocher
Lad Prabhakar
Lad, Prabhakar
