[U-Boot] [PATCH] marvell: add support for Synology DS109 board
From 842431a0cc2acb336f5c57a3ca822ba0673e712d Mon Sep 17 00:00:00 2001
From: Walter Schweizer swwa@users.sourceforge.net Date: Sat, 18 Jun 2016 12:56:37 +0200 Subject: [PATCH] add support for Synology DS109 board
Synology DS109 is based on MV88F6281. The code is based on Dreamplug code with modificatons from Synologys open source repository.
Signed-off-by: Walter Schweizer swwa@users.sourceforge.net ---
arch/arm/mach-kirkwood/Kconfig | 4 + board/Synology/ds109/Kconfig | 12 +++ board/Synology/ds109/Makefile | 9 ++ board/Synology/ds109/ds109.c | 169 ++++++++++++++++++++++++++++++++++++++ board/Synology/ds109/ds109.h | 44 ++++++++++ board/Synology/ds109/kwbimage.cfg | 147 +++++++++++++++++++++++++++++++++ board/Synology/ds109/openocd.cfg | 115 ++++++++++++++++++++++++++ configs/ds109_defconfig | 16 ++++ include/configs/ds109.h | 118 ++++++++++++++++++++++++++ 9 files changed, 634 insertions(+) create mode 100644 board/Synology/ds109/Kconfig create mode 100644 board/Synology/ds109/Makefile create mode 100644 board/Synology/ds109/ds109.c create mode 100644 board/Synology/ds109/ds109.h create mode 100644 board/Synology/ds109/kwbimage.cfg create mode 100644 board/Synology/ds109/openocd.cfg create mode 100644 configs/ds109_defconfig create mode 100644 include/configs/ds109.h
diff --git a/arch/arm/mach-kirkwood/Kconfig b/arch/arm/mach-kirkwood/Kconfig index 9205b1e..9c24921 100644 --- a/arch/arm/mach-kirkwood/Kconfig +++ b/arch/arm/mach-kirkwood/Kconfig @@ -10,6 +10,9 @@ config TARGET_OPENRD config TARGET_DREAMPLUG bool "DreamPlug Board"
+config TARGET_DS109 + bool "Synology DS109" + config TARGET_GURUPLUG bool "GuruPlug Board"
@@ -59,6 +62,7 @@ config SYS_SOC
source "board/Marvell/openrd/Kconfig" source "board/Marvell/dreamplug/Kconfig" +source "board/Synology/ds109/Kconfig" source "board/Marvell/guruplug/Kconfig" source "board/Marvell/sheevaplug/Kconfig" source "board/buffalo/lsxl/Kconfig" diff --git a/board/Synology/ds109/Kconfig b/board/Synology/ds109/Kconfig new file mode 100644 index 0000000..a7c75ae --- /dev/null +++ b/board/Synology/ds109/Kconfig @@ -0,0 +1,12 @@ +if TARGET_DS109 + +config SYS_BOARD + default "ds109" + +config SYS_VENDOR + default "Synology" + +config SYS_CONFIG_NAME + default "ds109" + +endif diff --git a/board/Synology/ds109/Makefile b/board/Synology/ds109/Makefile new file mode 100644 index 0000000..eeeb64d --- /dev/null +++ b/board/Synology/ds109/Makefile @@ -0,0 +1,9 @@ +# +# (C) Copyright 2009 +# Marvell Semiconductor <www.marvell.com> +# Written-by: Prafulla Wadaskar prafulla@marvell.com +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := ds109.o diff --git a/board/Synology/ds109/ds109.c b/board/Synology/ds109/ds109.c new file mode 100644 index 0000000..8ab1387 --- /dev/null +++ b/board/Synology/ds109/ds109.c @@ -0,0 +1,169 @@ +/* + * Copyright (C) 2009-2012 + * Wojciech Dubowik wojciech.dubowik@neratec.com + * Luka Perkov luka@openwrt.org + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <miiphy.h> +#include <asm/arch/cpu.h> +#include <asm/arch/soc.h> +#include <asm/arch/mpp.h> +#include "ds109.h" + +DECLARE_GLOBAL_DATA_PTR; + +int board_early_init_f(void) +{ + /* + * default gpio configuration + * There are maximum 64 gpios controlled through 2 sets of registers + * the below configuration configures mainly initial LED status + */ + mvebu_config_gpio(DS109_OE_VAL_LOW, + DS109_OE_VAL_HIGH, + DS109_OE_LOW, DS109_OE_HIGH); + + /* Multi-Purpose Pins Functionality configuration */ + static const u32 kwmpp_config[] = { + MPP0_SPI_SCn, /* SPI Flash */ + MPP1_SPI_MOSI, + MPP2_SPI_SCK, + MPP3_SPI_MISO, + MPP4_GPIO, + MPP5_GPO, + MPP6_SYSRST_OUTn, /* Reset signal */ + MPP7_GPO, + MPP8_TW_SDA, /* I2C */ + MPP9_TW_SCK, /* I2C */ + MPP10_UART0_TXD, + MPP11_UART0_RXD, + MPP12_GPO, + MPP13_UART1_TXD, + MPP14_UART1_RXD, + MPP15_GPIO, + MPP16_GPIO, + MPP17_GPIO, + MPP18_GPO, + MPP19_GPO, + MPP20_SATA1_ACTn, + MPP21_SATA0_ACTn, + MPP22_GPIO, /* HDD2 FAIL LED */ + MPP23_GPIO, /* HDD1 FAIL LED */ + MPP24_GPIO, + MPP25_GPIO, + MPP26_GPIO, + MPP27_GPIO, + MPP28_GPIO, + MPP29_GPIO, + MPP30_GPIO, + MPP31_GPIO, /* HDD2 */ + MPP32_GPIO, /* FAN A */ + MPP33_GPIO, /* FAN B */ + MPP34_GPIO, /* FAN C */ + MPP35_GPIO, /* FAN SENSE */ + MPP36_GPIO, + MPP37_GPIO, + MPP38_GPIO, + MPP39_GPIO, + MPP40_GPIO, + MPP41_GPIO, + MPP42_GPIO, + MPP43_GPIO, + MPP44_GPIO, + MPP45_GPIO, + MPP46_GPIO, + MPP47_GPIO, + MPP48_GPIO, + MPP49_GPIO, + 0 + }; + kirkwood_mpp_conf(kwmpp_config, NULL); + return 0; +} + +int board_init(void) +{ + /* address of boot parameters */ + gd->bd->bi_boot_params = mvebu_sdram_bar(0) + 0x100; + + return 0; +} + +/* Synology reset uses UART */ +#include <ns16550.h> +#define SOFTWARE_SHUTDOWN 0x31 +#define SOFTWARE_REBOOT 0x43 +#define CONFIG_SYS_NS16550_COM2 KW_UART1_BASE +void reset_misc(void) +{ + int b_d; + printf("Synology reset..."); + udelay(50000); + + b_d = ns16550_calc_divisor((NS16550_t)CONFIG_SYS_NS16550_COM2, + CONFIG_SYS_NS16550_CLK, 9600); + NS16550_init((NS16550_t)CONFIG_SYS_NS16550_COM2, b_d); + NS16550_putc((NS16550_t)CONFIG_SYS_NS16550_COM2, SOFTWARE_REBOOT); +} + +/* Support old kernels */ +void setup_board_tags(struct tag **in_params) +{ + unsigned int boardId; + struct tag *params; + struct tag_mv_uboot *t; + + printf("Synology board tags..."); + params = *in_params; + t = (struct tag_mv_uboot *)¶ms->u; + + t->uboot_version = VER_NUM; + + boardId = SYNO_DS109_ID; + t->uboot_version |= boardId; + + t->tclk = CONFIG_SYS_TCLK; + t->sysclk = CONFIG_SYS_TCLK*2; + + params->hdr.tag = ATAG_MV_UBOOT; + params->hdr.size = tag_size(tag_mv_uboot); + params = tag_next(params); + *in_params = params; +} + +#ifdef CONFIG_RESET_PHY_R +/* Configure and enable MV88E1116 PHY */ +void reset_phy(void) +{ + u16 reg; + u16 devadr; + char *name = "egiga0"; + + if (miiphy_set_current_dev(name)) + return; + + /* command to read PHY dev address */ + if (miiphy_read(name, 0xEE, 0xEE, (u16 *)&devadr)) { + printf("Error: 88E1116 could not read PHY dev address\n"); + return; + } + + /* + * Enable RGMII delay on Tx and Rx for CPU port + * Ref: sec 4.7.2 of chip datasheet + */ + miiphy_write(name, devadr, MV88E1116_PGADR_REG, 2); + miiphy_read(name, devadr, MV88E1116_MAC_CTRL_REG, ®); + reg |= (MV88E1116_RGMII_RXTM_CTRL | MV88E1116_RGMII_TXTM_CTRL); + miiphy_write(name, devadr, MV88E1116_MAC_CTRL_REG, reg); + miiphy_write(name, devadr, MV88E1116_PGADR_REG, 0); + + /* reset the phy */ + miiphy_reset(name, devadr); + + printf("88E1116 Initialized on %s\n", name); +} +#endif /* CONFIG_RESET_PHY_R */ diff --git a/board/Synology/ds109/ds109.h b/board/Synology/ds109/ds109.h new file mode 100644 index 0000000..95d924c --- /dev/null +++ b/board/Synology/ds109/ds109.h @@ -0,0 +1,44 @@ +/* + * Copyright (C) 2009-2012 + * Wojciech Dubowik wojciech.dubowik@neratec.com + * Luka Perkov luka@openwrt.org + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __DS109_H +#define __DS109_H + +#define DS109_OE_LOW (~(0)) +#define DS109_OE_HIGH (~(0)) +#define DS109_OE_VAL_LOW ((1 << 22)|(1 << 23)) +#define DS109_OE_VAL_HIGH ((1 << 1)|1) + +/* PHY related */ +#define MV88E1116_LED_FCTRL_REG 10 +#define MV88E1116_CPRSP_CR3_REG 21 +#define MV88E1116_MAC_CTRL_REG 21 +#define MV88E1116_MAC_CTRL2_REG 21 + +#define MV88E1116_PGADR_REG 22 +#define MV88E1116_RGMII_TXTM_CTRL (1 << 4) +#define MV88E1116_RGMII_RXTM_CTRL (1 << 5) + +/* Marvell uboot parameters */ +#define ATAG_MV_UBOOT 0x41000403 +#define VER_NUM 0x03040400 /* 3.4.4 */ +#define BOARD_ID_BASE 0x0 +#define SYNO_DS109_ID (BOARD_ID_BASE+0x15) + +struct tag_mv_uboot { + u32 uboot_version; + u32 tclk; + u32 sysclk; + u32 isusbhost; + char macaddr[4][6]; + u16 mtu[4]; + u32 fw_image_base; + u32 fw_image_size; +}; + +#endif /* __DS109_H */ diff --git a/board/Synology/ds109/kwbimage.cfg b/board/Synology/ds109/kwbimage.cfg new file mode 100644 index 0000000..19d77e3 --- /dev/null +++ b/board/Synology/ds109/kwbimage.cfg @@ -0,0 +1,147 @@ +# +# (C) Copyright 2011 +# Jason Cooper u-boot@lakedaemon.net +# +# Based on work by: +# Marvell Semiconductor <www.marvell.com> +# Written-by: Siddarth Gore gores@marvell.com +# +# SPDX-License-Identifier: GPL-2.0+ +# +# Refer doc/README.kwbimage for more details about how-to configure +# and create kirkwood boot image +# + +# Boot Media configurations +BOOT_FROM spi + +# SOC registers configuration using bootrom header extension +# Maximum KWBIMAGE_MAX_CONFIG configurations allowed + +# Configure RGMII-0/1 interface pad voltage to 1.8V +DATA 0xFFD100e0 0x1b1b9b9b + +#Dram initalization for SINGLE x16 CL=5 @ 400MHz +DATA 0xFFD01400 0x43000c30 # DDR Configuration register +# bit13-0: 0xc30 (3120 DDR2 clks refresh rate) +# bit23-14: zero +# bit24: 1= enable exit self refresh mode on DDR access +# bit25: 1 required +# bit29-26: zero +# bit31-30: 01 + +DATA 0xFFD01404 0x37543000 # DDR Controller Control Low +# bit 4: 0=addr/cmd in smame cycle +# bit 5: 0=clk is driven during self refresh, we don't care for APX +# bit 6: 0=use recommended falling edge of clk for addr/cmd +# bit14: 0=input buffer always powered up +# bit18: 1=cpu lock transaction enabled +# bit23-20: 5=recommended value for CL=5 and STARTBURST_DEL disabled bit31=0 +# bit27-24: 7= CL+2, STARTBURST sample stages, for freqs 400MHz, unbuffered DIMM +# bit30-28: 3 required +# bit31: 0=no additional STARTBURST delay + +DATA 0xFFD01408 0x22125451 # DDR Timing (Low) (active cycles value +1) +# bit3-0: TRAS lsbs +# bit7-4: TRCD +# bit11- 8: TRP +# bit15-12: TWR +# bit19-16: TWTR +# bit20: TRAS msb +# bit23-21: 0x0 +# bit27-24: TRRD +# bit31-28: TRTP + +DATA 0xFFD0140C 0x00000a33 # DDR Timing (High) +# bit6-0: TRFC +# bit8-7: TR2R +# bit10-9: TR2W +# bit12-11: TW2W +# bit31-13: zero required + +DATA 0xFFD01410 0x000000cc # DDR Address Control +# bit1-0: 01, Cs0width=x8 +# bit3-2: 10, Cs0size=1Gb +# bit5-4: 01, Cs1width=x8 +# bit7-6: 10, Cs1size=1Gb +# bit9-8: 00, Cs2width=nonexistent +# bit11-10: 00, Cs2size =nonexistent +# bit13-12: 00, Cs3width=nonexistent +# bit15-14: 00, Cs3size =nonexistent +# bit16: 0, Cs0AddrSel +# bit17: 0, Cs1AddrSel +# bit18: 0, Cs2AddrSel +# bit19: 0, Cs3AddrSel +# bit31-20: 0 required + +DATA 0xFFD01414 0x00000000 # DDR Open Pages Control +# bit0: 0, OpenPage enabled +# bit31-1: 0 required + +DATA 0xFFD01418 0x00000000 # DDR Operation +# bit3-0: 0x0, DDR cmd +# bit31-4: 0 required + +DATA 0xFFD0141C 0x00000C52 # DDR Mode +# bit2-0: 2, BurstLen=2 required +# bit3: 0, BurstType=0 required +# bit6-4: 4, CL=5 +# bit7: 0, TestMode=0 normal +# bit8: 0, DLL reset=0 normal +# bit11-9: 6, auto-precharge write recovery ???????????? +# bit12: 0, PD must be zero +# bit31-13: 0 required + +DATA 0xFFD01420 0x00000040 # DDR Extended Mode +# bit0: 0, DDR DLL enabled +# bit1: 0, DDR drive strenght normal +# bit2: 0, DDR ODT control lsd (disabled) +# bit5-3: 000, required +# bit6: 1, DDR ODT control msb, (disabled) +# bit9-7: 000, required +# bit10: 0, differential DQS enabled +# bit11: 0, required +# bit12: 0, DDR output buffer enabled +# bit31-13: 0 required + +DATA 0xFFD01424 0x0000F17F # DDR Controller Control High +# bit2-0: 111, required +# bit3 : 1 , MBUS Burst Chop disabled +# bit6-4: 111, required +# bit7 : 0 +# bit8 : 1 , add writepath sample stage, must be 1 for DDR freq >= 300MHz +# bit9 : 0 , no half clock cycle addition to dataout +# bit10 : 0 , 1/4 clock cycle skew enabled for addr/ctl signals +# bit11 : 0 , 1/4 clock cycle skew disabled for write mesh +# bit15-12: 1111 required +# bit31-16: 0 required + +DATA 0xFFD01428 0x00085520 # DDR2 ODT Read Timing (default values) +DATA 0xFFD0147C 0x00008552 # DDR2 ODT Write Timing (default values) + +DATA 0xFFD01500 0x00000000 # CS[0]n Base address to 0x0 +DATA 0xFFD01504 0x0FFFFFF1 # CS[0]n Size +# bit0: 1, Window enabled +# bit1: 0, Write Protect disabled +# bit3-2: 00, CS0 hit selected +# bit23-4: ones, required +# bit31-24: 0x0F, Size (i.e. 256MB) + +DATA 0xFFD01508 0x10000000 # CS[1]n Base address to 256Mb +DATA 0xFFD0150C 0x0FFFFFF5 # CS[1]n Size 256Mb Window enabled for CS1 + +DATA 0xFFD01514 0x00000000 # CS[2]n Size, window disabled +DATA 0xFFD0151C 0x00000000 # CS[3]n Size, window disabled + +DATA 0xFFD01494 0x00030000 # DDR ODT Control (Low) +DATA 0xFFD01498 0x00000000 # DDR ODT Control (High) +# bit1-0: 00, ODT0 controlled by ODT Control (low) register above +# bit3-2: 01, ODT1 active NEVER! +# bit31-4: zero, required + +DATA 0xFFD0149C 0x0000E803 # CPU ODT Control +DATA 0xFFD01480 0x00000001 # DDR Initialization Control +#bit0=1, enable DDR init upon this register write + +# End of Header extension +DATA 0x0 0x0 diff --git a/board/Synology/ds109/openocd.cfg b/board/Synology/ds109/openocd.cfg new file mode 100644 index 0000000..baa512a --- /dev/null +++ b/board/Synology/ds109/openocd.cfg @@ -0,0 +1,115 @@ +# Synology DS109 + +interface ftdi +ftdi_vid_pid 0x0403 0x6010 + +ftdi_layout_init 0x0008 0x000b +ftdi_layout_signal nTRST -data 0x0010 -oe 0x0010 +ftdi_layout_signal nSRST -data 0x0040 -oe 0x0040 + +adapter_khz 2000 + +# length of reset signal: [ms] +adapter_nsrst_assert_width 1000 + +# don't talk to JTAG after reset for: [ms] +adapter_nsrst_delay 200 + +source [find target/feroceon.cfg] + +reset_config trst_and_srst srst_nogate + +proc ds109_init { } { + + # We need to assert DBGRQ while holding nSRST down. + # However DBGACK will be set only when nSRST is released. + # Furthermore, the JTAG interface doesn't respond at all when + # the CPU is in the WFI (wait for interrupts) state, so it is + # possible that initial tap examination failed. So let's + # re-examine the target again here when nSRST is asserted which + # should then succeed. + jtag_reset 0 1 + feroceon.cpu arp_examine + halt 0 + jtag_reset 0 0 + wait_halt + #reset run + #soft_reset_halt + + arm mcr 15 0 0 1 0 0x00052078 + + mww 0xD00100e0 0x1b1b1b9b ;# + mww 0xD0020134 0xbbbbbbbb ;# + mww 0xD0020138 0x00bbbbbb ;# + mww 0xD0001400 0x43000C30 ;# DDR SDRAM Configuration Register + mww 0xD0001404 0x39743000 ;# Dunit Control Low Register + mww 0xD0001408 0x22125551 ;# DDR SDRAM Timing (Low) Register + mww 0xD000140C 0x00000833 ;# DDR SDRAM Timing (High) Register + mww 0xD0001410 0x0000000d ;# DDR SDRAM Address Control Register + mww 0xD0001414 0x00000000 ;# DDR SDRAM Open Pages Control Register + mww 0xD0001418 0x00000000 ;# DDR SDRAM Operation Register + mww 0xD000141C 0x00000C62 ;# DDR SDRAM Mode Register + mww 0xD0001420 0x00000042 ;# DDR SDRAM Extended Mode Register + mww 0xD0001424 0x0000F1FF ;# Dunit Control High Register + mww 0xD0001428 0x00085520 ;# Dunit Control High Register + mww 0xD000147c 0x00008552 ;# Dunit Control High Register + mww 0xD0001500 0x00000000 ;# + mww 0xD0001504 0x07FFFFF1 ;# CS0n Size Register + mww 0xD0001508 0x10000000 ;# CS1n Base Register + mww 0xD000150C 0x00000000 ;# CS1n Size Register + mww 0xD0001510 0x20000000 ;# + mww 0xD0001514 0x00000000 ;# CS2n Size Register + mww 0xD000151C 0x00000000 ;# CS3n Size Register + mww 0xD0001494 0x003C0000 ;# DDR2 SDRAM ODT Control (Low) Register + mww 0xD0001498 0x00000000 ;# DDR2 SDRAM ODT Control (High) REgister + mww 0xD000149C 0x0000F80F ;# DDR2 Dunit ODT Control Register + mww 0xD0001480 0x00000001 ;# DDR SDRAM Initialization Control Register + mww 0xD0020204 0x00000000 ;# Main IRQ Interrupt Mask Register + mww 0xD0020204 0x00000000 ;# " + mww 0xD0020204 0x00000000 ;# " + mww 0xD0020204 0x00000000 ;# " + mww 0xD0020204 0x00000000 ;# " + mww 0xD0020204 0x00000000 ;# " + mww 0xD0020204 0x00000000 ;# " + mww 0xD0020204 0x00000000 ;# " + mww 0xD0020204 0x00000000 ;# " + mww 0xD0020204 0x00000000 ;# " + mww 0xD0020204 0x00000000 ;# " + mww 0xD0020204 0x00000000 ;# " + mww 0xD0020204 0x00000000 ;# " + mww 0xD0020204 0x00000000 ;# " + mww 0xD0020204 0x00000000 ;# " + mww 0xD0020204 0x00000000 ;# " + mww 0xD0020204 0x00000000 ;# " + mww 0xD0020204 0x00000000 ;# " + mww 0xD0020204 0x00000000 ;# " + mww 0xD0020204 0x00000000 ;# " + mww 0xD0020204 0x00000000 ;# " + mww 0xD0020204 0x00000000 ;# " + mww 0xD0020204 0x00000000 ;# " + mww 0xD0020204 0x00000000 ;# " + mww 0xD0020204 0x00000000 ;# " + mww 0xD0020204 0x00000000 ;# " + mww 0xD0020204 0x00000000 ;# " + mww 0xD0020204 0x00000000 ;# " + mww 0xD0020204 0x00000000 ;# " + mww 0xD0020204 0x00000000 ;# " + mww 0xD0020204 0x00000000 ;# " + mww 0xD0020204 0x00000000 ;# " + mww 0xD0020204 0x00000000 ;# " + mww 0xD0020204 0x00000000 ;# " + mww 0xD0020204 0x00000000 ;# " + mww 0xD0020204 0x00000000 ;# " + mww 0xD0020204 0x00000000 ;# " + + mww 0xD0010000 0x01111111 ;# MPP 0 to 7 + mww 0xD0010004 0x11113322 ;# MPP 8 to 15 + mww 0xD0010008 0x00001111 ;# MPP 16 to 23 +} + +proc ds109_load { } { + # load u-Boot into RAM and execute it + ds109_init + load_image u-boot.bin 0x00600000 bin + resume 0x00600000 +} diff --git a/configs/ds109_defconfig b/configs/ds109_defconfig new file mode 100644 index 0000000..34a4673 --- /dev/null +++ b/configs/ds109_defconfig @@ -0,0 +1,16 @@ +CONFIG_ARM=y +CONFIG_KIRKWOOD=y +CONFIG_TARGET_DS109=y +CONFIG_HUSH_PARSER=y +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SYS_NS16550=y diff --git a/include/configs/ds109.h b/include/configs/ds109.h new file mode 100644 index 0000000..987038f --- /dev/null +++ b/include/configs/ds109.h @@ -0,0 +1,118 @@ +/* + * (C) Copyright 2011 + * Jason Cooper u-boot@lakedaemon.net + * + * Based on work by: + * Marvell Semiconductor <www.marvell.com> + * Written-by: Siddarth Gore gores@marvell.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _CONFIG_DS109_H +#define _CONFIG_DS109_H + +/* + * FIXME: This belongs in mach-types.h. However, we only pull mach-types + * from Linus' kernel.org tree. This hasn't been updated primarily due to + * the recent arch/arm reshuffling. So, in the meantime, we'll place it + * here. + */ +#include <asm/mach-types.h> +#ifdef MACH_TYPE_SYNOLOGY +#error "MACH_TYPE_SYNOLOGY has been defined properly, please remove this." +#else +#define MACH_TYPE_SYNOLOGY 527 +#endif + +/* + * Version number information + */ +#define CONFIG_IDENT_STRING "\nDS109" + +/* + * High Level Configuration Options (easy to change) + */ +#define CONFIG_SHEEVA_88SV131 1 /* CPU Core subversion */ +#define CONFIG_MACH_TYPE MACH_TYPE_SYNOLOGY + +/* + * Commands configuration + */ +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT + +/* + * mv-plug-common.h should be defined after CMD configs since it used them + * to enable certain macros + */ +#include "mv-plug-common.h" + +/* + * Environment variables configurations + */ +#ifdef CONFIG_SPI_FLASH +#define CONFIG_ENV_IS_IN_SPI_FLASH 1 +#define CONFIG_ENV_SECT_SIZE 0x10000 /* 64k */ +#else +#define CONFIG_ENV_IS_NOWHERE 1 /* if env in SDRAM */ +#endif + +#ifdef CONFIG_CMD_SF +#define CONFIG_HARD_SPI 1 +#define CONFIG_KIRKWOOD_SPI 1 +#define CONFIG_ENV_SPI_BUS 0 +#define CONFIG_ENV_SPI_CS 0 +#define CONFIG_ENV_SPI_MAX_HZ 50000000 /* 50 MHz */ +#endif + +/* + * max 4k env size is enough, but in case of nand + * it has to be rounded to sector size + */ +#define CONFIG_ENV_SIZE 0x10000 +#define CONFIG_ENV_ADDR 0x3d0000 +#define CONFIG_ENV_OFFSET 0x3d0000 /* env starts here */ + +/* + * Default environment variables + */ +#define CONFIG_BOOTCOMMAND "setenv ethact egiga0; " \ + "${x_bootcmd_ethernet}; ${x_bootcmd_usb}; ${x_bootcmd_kernel}; "\ + "setenv bootargs ${x_bootargs} ${x_bootargs_root}; " \ + "bootm 0x6400000;" + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "x_bootcmd_ethernet=ping 192.168.1.2\0" \ + "x_bootcmd_usb=usb start\0" \ + "x_bootcmd_kernel=fatload usb 0 0x6400000 uImage\0" \ + "x_bootargs=console=ttyS0,115200\0" \ + "x_bootargs_root=root=/dev/sda2 rootdelay=10\0" \ + "ipaddr=192.168.1.5\0" + +/* + * Ethernet Driver configuration + */ +#ifdef CONFIG_CMD_NET +#define CONFIG_MVGBE_PORTS {1, 0} /* enable one port */ +#define CONFIG_PHY_BASE_ADR 8 +#endif /* CONFIG_CMD_NET */ + +/* + * SATA Driver configuration + */ +#ifdef CONFIG_MVSATA_IDE +#define CONFIG_SYS_ATA_IDE0_OFFSET MV_SATA_PORT0_OFFSET +#endif /*CONFIG_MVSATA_IDE*/ + +#endif /* _CONFIG_DS109_H */ + +/* + * * RTC driver configuration + * */ +#ifdef CONFIG_CMD_DATE +#undef CONFIG_RTC_MV +#define CONFIG_RTC_RS5C372A +#endif /* CONFIG_CMD_DATE */ + +
Hi Walter,
sorry for the late review.
On 18.06.2016 13:25, Walter Schweizer wrote:
From 842431a0cc2acb336f5c57a3ca822ba0673e712d Mon Sep 17 00:00:00 2001 From: Walter Schweizer swwa@users.sourceforge.net Date: Sat, 18 Jun 2016 12:56:37 +0200 Subject: [PATCH] add support for Synology DS109 board
Your patch seems to have some line wraps included. Please fix this in v2.
MATAINERS file missing.
Please check in v2 that your patch passes checkpatch without errors. There seem to be many whitespace errors.
Thanks, Stefan
Viele Grüße, Stefan
Stefan Roese
Walter Schweizer
