[U-Boot] [PATCH 1/1] efi_loader: optional data in load options are binary
The field boot OptionalData in structure _EFI_LOAD_OPTIONS is for binary data.
When we use `efidebug boot add` we should convert the 5th argument from UTF-8 to UTF-16 before putting it into the BootXXXX variable.
When printing boot variables with `efidebug boot dump` we should support the OptionalData being arbitrary binary data. So let's dump the data as hexadecimal values.
Here is an example session protocol:
=> efidebug boot add 00a1 label1 scsi 0:1 doit1 'my option' => efidebug boot add 00a2 label2 scsi 0:1 doit2 => efidebug boot dump Boot00A0: attributes: A-- (0x00000001) label: label1 file_path: .../HD(1,MBR,0xeac4e18b,0x800,0x3fffe)/doit1 data: 00000000: 6d 00 79 00 20 00 6f 00 70 00 74 00 69 00 6f 00 m.y. .o.p.t.i.o. 00000010: 6e 00 00 00 n... Boot00A1: attributes: A-- (0x00000001) label: label2 file_path: .../HD(1,MBR,0xeac4e18b,0x800,0x3fffe)/doit2 data:
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- cmd/efidebug.c | 27 +++++++++++++++++---------- include/efi_loader.h | 2 +- lib/efi_loader/efi_bootmgr.c | 15 ++++++++------- 3 files changed, 26 insertions(+), 18 deletions(-)
diff --git a/cmd/efidebug.c b/cmd/efidebug.c index a40c4f4be2..e4cc92ec0e 100644 --- a/cmd/efidebug.c +++ b/cmd/efidebug.c @@ -11,6 +11,7 @@ #include <efi_loader.h> #include <environment.h> #include <exports.h> +#include <hexdump.h> #include <malloc.h> #include <search.h> #include <linux/ctype.h> @@ -545,7 +546,10 @@ static int do_efi_boot_add(cmd_tbl_t *cmdtp, int flag, + sizeof(struct efi_device_path); /* for END */
/* optional data */ - lo.optional_data = (u8 *)(argc == 6 ? "" : argv[6]); + if (argc < 6) + lo.optional_data = NULL; + else + lo.optional_data = (const u8 *)argv[6];
size = efi_serialize_load_option(&lo, (u8 **)&data); if (!size) { @@ -615,12 +619,13 @@ static int do_efi_boot_rm(cmd_tbl_t *cmdtp, int flag, /** * show_efi_boot_opt_data() - dump UEFI load option * - * @id: Load option number - * @data: Value of UEFI load option variable + * @id: load option number + * @data: value of UEFI load option variable + * @size: size of the boot option * * Decode the value of UEFI load option variable and print information. */ -static void show_efi_boot_opt_data(int id, void *data) +static void show_efi_boot_opt_data(int id, void *data, size_t size) { struct efi_load_option lo; char *label, *p; @@ -638,7 +643,7 @@ static void show_efi_boot_opt_data(int id, void *data) utf16_utf8_strncpy(&p, lo.label, label_len16);
printf("Boot%04X:\n", id); - printf("\tattributes: %c%c%c (0x%08x)\n", + printf(" attributes: %c%c%c (0x%08x)\n", /* ACTIVE */ lo.attributes & LOAD_OPTION_ACTIVE ? 'A' : '-', /* FORCE RECONNECT */ @@ -646,14 +651,16 @@ static void show_efi_boot_opt_data(int id, void *data) /* HIDDEN */ lo.attributes & LOAD_OPTION_HIDDEN ? 'H' : '-', lo.attributes); - printf("\tlabel: %s\n", label); + printf(" label: %s\n", label);
dp_str = efi_dp_str(lo.file_path); - printf("\tfile_path: %ls\n", dp_str); + printf(" file_path: %ls\n", dp_str); efi_free_pool(dp_str);
- printf("\tdata: %s\n", lo.optional_data); - + printf(" data:\n"); + print_hex_dump(" ", DUMP_PREFIX_OFFSET, 16, 1, + lo.optional_data, size + (u8 *)data - + (u8 *)lo.optional_data, true); free(label); }
@@ -686,7 +693,7 @@ static void show_efi_boot_opt(int id) data)); } if (ret == EFI_SUCCESS) - show_efi_boot_opt_data(id, data); + show_efi_boot_opt_data(id, data, size); else if (ret == EFI_NOT_FOUND) printf("Boot%04X: not found\n", id);
diff --git a/include/efi_loader.h b/include/efi_loader.h index 39ed8a6fa5..07b913d256 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -560,7 +560,7 @@ struct efi_load_option { u16 file_path_length; u16 *label; struct efi_device_path *file_path; - u8 *optional_data; + const u8 *optional_data; };
void efi_deserialize_load_option(struct efi_load_option *lo, u8 *data); diff --git a/lib/efi_loader/efi_bootmgr.c b/lib/efi_loader/efi_bootmgr.c index 4ccba22875..7bf51874c1 100644 --- a/lib/efi_loader/efi_bootmgr.c +++ b/lib/efi_loader/efi_bootmgr.c @@ -53,19 +53,20 @@ void efi_deserialize_load_option(struct efi_load_option *lo, u8 *data) */ unsigned long efi_serialize_load_option(struct efi_load_option *lo, u8 **data) { - unsigned long label_len, option_len; + unsigned long label_len; unsigned long size; u8 *p;
label_len = (u16_strlen(lo->label) + 1) * sizeof(u16); - option_len = strlen((char *)lo->optional_data);
/* total size */ size = sizeof(lo->attributes); size += sizeof(lo->file_path_length); size += label_len; size += lo->file_path_length; - size += option_len + 1; + if (lo->optional_data) + size += (utf8_utf16_strlen((const char *)lo->optional_data) + + 1) * sizeof(u16); p = malloc(size); if (!p) return 0; @@ -84,10 +85,10 @@ unsigned long efi_serialize_load_option(struct efi_load_option *lo, u8 **data) memcpy(p, lo->file_path, lo->file_path_length); p += lo->file_path_length;
- memcpy(p, lo->optional_data, option_len); - p += option_len; - *(char *)p = '\0'; - + if (lo->optional_data) { + utf8_utf16_strcpy((u16 **)&p, (const char *)lo->optional_data); + p += sizeof(u16); /* size of trailing \0 */ + } return size; }
-- 2.20.1
