[U-Boot] [PATCH] fsl-layerscape: dpaa: fix fsl-mc status in fdt with bootefi
fsl-mc lazyapply command applies dpl from efi_exit_boot_services(). Status of fsl-mc node in working fdt is updated at this stage. However, an efi application like grub may already have copied the fdt. So the updates to fdt done at efi_exit_boot_services() may not be visible to the OS. Fix it by updating fdt earlier if fsl-mc lazyapply command is used.
Fixes: b7b8410a8f (ls2080: Exit dpaa only right before exiting U-Boot) Signed-off-by: Mian Yousaf Kaukab ykaukab@suse.de --- board/freescale/ls1088a/ls1088a.c | 3 ++- board/freescale/ls2080a/ls2080a.c | 3 ++- board/freescale/ls2080aqds/ls2080aqds.c | 3 ++- board/freescale/ls2080ardb/ls2080ardb.c | 3 ++- drivers/net/fsl-mc/mc.c | 5 +++++ include/fsl-mc/fsl_mc.h | 1 + 6 files changed, 14 insertions(+), 4 deletions(-)
diff --git a/board/freescale/ls1088a/ls1088a.c b/board/freescale/ls1088a/ls1088a.c index 1e2ad98c6e..1b87b33e50 100644 --- a/board/freescale/ls1088a/ls1088a.c +++ b/board/freescale/ls1088a/ls1088a.c @@ -535,7 +535,8 @@ void fdt_fixup_board_enet(void *fdt) return; }
- if ((get_mc_boot_status() == 0) && (get_dpl_apply_status() == 0)) + if (get_mc_boot_status() == 0 && + (is_lazy_dpl_addr_valid() || get_dpl_apply_status() == 0)) fdt_status_okay(fdt, offset); else fdt_status_fail(fdt, offset); diff --git a/board/freescale/ls2080a/ls2080a.c b/board/freescale/ls2080a/ls2080a.c index 698ae1f9a6..c352bccb10 100644 --- a/board/freescale/ls2080a/ls2080a.c +++ b/board/freescale/ls2080a/ls2080a.c @@ -89,7 +89,8 @@ void fdt_fixup_board_enet(void *fdt) return; }
- if ((get_mc_boot_status() == 0) && (get_dpl_apply_status() == 0)) + if (get_mc_boot_status() == 0 && + (is_lazy_dpl_addr_valid() || get_dpl_apply_status() == 0)) fdt_status_okay(fdt, offset); else fdt_status_fail(fdt, offset); diff --git a/board/freescale/ls2080aqds/ls2080aqds.c b/board/freescale/ls2080aqds/ls2080aqds.c index d336ef840c..a0a3301691 100644 --- a/board/freescale/ls2080aqds/ls2080aqds.c +++ b/board/freescale/ls2080aqds/ls2080aqds.c @@ -294,7 +294,8 @@ void fdt_fixup_board_enet(void *fdt) return; }
- if ((get_mc_boot_status() == 0) && (get_dpl_apply_status() == 0)) + if (get_mc_boot_status() == 0 && + (is_lazy_dpl_addr_valid() || get_dpl_apply_status() == 0)) fdt_status_okay(fdt, offset); else fdt_status_fail(fdt, offset); diff --git a/board/freescale/ls2080ardb/ls2080ardb.c b/board/freescale/ls2080ardb/ls2080ardb.c index cf91bc30fb..79f2bcc52f 100644 --- a/board/freescale/ls2080ardb/ls2080ardb.c +++ b/board/freescale/ls2080ardb/ls2080ardb.c @@ -330,7 +330,8 @@ void fdt_fixup_board_enet(void *fdt) return; }
- if ((get_mc_boot_status() == 0) && (get_dpl_apply_status() == 0)) + if (get_mc_boot_status() == 0 && + (is_lazy_dpl_addr_valid() || get_dpl_apply_status() == 0)) fdt_status_okay(fdt, offset); else fdt_status_fail(fdt, offset); diff --git a/drivers/net/fsl-mc/mc.c b/drivers/net/fsl-mc/mc.c index b245fbc681..a51b8a4625 100644 --- a/drivers/net/fsl-mc/mc.c +++ b/drivers/net/fsl-mc/mc.c @@ -834,6 +834,11 @@ int get_dpl_apply_status(void) return mc_dpl_applied; }
+int is_lazy_dpl_addr_valid(void) +{ + return !!mc_lazy_dpl_addr; +} + /* * Return the MC address of private DRAM block. * As per MC design document, MC initial base address diff --git a/include/fsl-mc/fsl_mc.h b/include/fsl-mc/fsl_mc.h index aef40d3911..0abd797cc4 100644 --- a/include/fsl-mc/fsl_mc.h +++ b/include/fsl-mc/fsl_mc.h @@ -54,6 +54,7 @@ struct mc_ccsr_registers { void fdt_fsl_mc_fixup_iommu_map_entry(void *blob); int get_mc_boot_status(void); int get_dpl_apply_status(void); +int is_lazy_dpl_addr_valid(void); #ifdef CONFIG_SYS_LS_MC_DRAM_AIOP_IMG_OFFSET int get_aiop_apply_status(void); #endif
Applied to fsl-qoriq master, awaiting upstream. Thanks.
York
Mian Yousaf Kaukab
York Sun
