[PATCH v1] rockchip: move ROCKCHIP_STIMER_BASE to Kconfig
Move ROCKCHIP_STIMER_BASE to Kconfig.
Signed-off-by: Johan Jonker jbx6244@gmail.com --- arch/arm/mach-rockchip/Kconfig | 15 +++++++++++++++ arch/arm/mach-rockchip/px30/Kconfig | 3 +++ arch/arm/mach-rockchip/rk3036/Kconfig | 3 +++ arch/arm/mach-rockchip/rk3128/Kconfig | 3 +++ arch/arm/mach-rockchip/rk322x/Kconfig | 3 +++ arch/arm/mach-rockchip/rk3288/Kconfig | 3 +++ arch/arm/mach-rockchip/rk3308/Kconfig | 10 ++++++---- arch/arm/mach-rockchip/rk3328/Kconfig | 3 +++ arch/arm/mach-rockchip/rk3368/Kconfig | 3 +++ arch/arm/mach-rockchip/rk3399/Kconfig | 3 +++ arch/arm/mach-rockchip/rk3568/Kconfig | 3 +++ include/configs/px30_common.h | 1 - include/configs/rk3036_common.h | 1 - include/configs/rk3128_common.h | 1 - include/configs/rk322x_common.h | 1 - include/configs/rk3288_common.h | 1 - include/configs/rk3308_common.h | 1 - include/configs/rk3328_common.h | 1 - include/configs/rk3368_common.h | 1 - include/configs/rk3399_common.h | 1 - include/configs/rk3568_common.h | 1 - 21 files changed, 48 insertions(+), 14 deletions(-)
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index da6871eb..7fafb63d 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -343,6 +343,21 @@ config ROCKCHIP_BOOT_MODE_REG The Soc will enter to different boot mode(defined in asm/arch-rockchip/boot_mode.h) according to the value from this register.
+config ROCKCHIP_STIMER_BASE + hex "Rockchip secure timer base address" + depends on (ROCKCHIP_PX30|| \ + ROCKCHIP_RK3036|| \ + ROCKCHIP_RK3128|| \ + ROCKCHIP_RK322X|| \ + ROCKCHIP_RK3288|| \ + ROCKCHIP_RK3308|| \ + ROCKCHIP_RK3328|| \ + ROCKCHIP_RK3368|| \ + ROCKCHIP_RK3399|| \ + ROCKCHIP_RK3568) + help + Rockchip secure timer base address. + config ROCKCHIP_SPL_RESERVE_IRAM hex "Size of IRAM reserved in SPL" default 0 diff --git a/arch/arm/mach-rockchip/px30/Kconfig b/arch/arm/mach-rockchip/px30/Kconfig index aa5cc471..42cc111b 100644 --- a/arch/arm/mach-rockchip/px30/Kconfig +++ b/arch/arm/mach-rockchip/px30/Kconfig @@ -30,6 +30,9 @@ config TARGET_PX30_CORE config ROCKCHIP_BOOT_MODE_REG default 0xff010200
+config ROCKCHIP_STIMER_BASE + default 0xff220020 + config SYS_SOC default "px30"
diff --git a/arch/arm/mach-rockchip/rk3036/Kconfig b/arch/arm/mach-rockchip/rk3036/Kconfig index b746795d..111531be 100644 --- a/arch/arm/mach-rockchip/rk3036/Kconfig +++ b/arch/arm/mach-rockchip/rk3036/Kconfig @@ -16,6 +16,9 @@ endchoice config ROCKCHIP_BOOT_MODE_REG default 0x200081c8
+config ROCKCHIP_STIMER_BASE + default 0x200440a0 + config SYS_SOC default "rk3036"
diff --git a/arch/arm/mach-rockchip/rk3128/Kconfig b/arch/arm/mach-rockchip/rk3128/Kconfig index b867401c..9cc494eb 100644 --- a/arch/arm/mach-rockchip/rk3128/Kconfig +++ b/arch/arm/mach-rockchip/rk3128/Kconfig @@ -16,6 +16,9 @@ endchoice config ROCKCHIP_BOOT_MODE_REG default 0x100a0038
+config ROCKCHIP_STIMER_BASE + default 0x200440a0 + config SYS_SOC default "rk3128"
diff --git a/arch/arm/mach-rockchip/rk322x/Kconfig b/arch/arm/mach-rockchip/rk322x/Kconfig index 6458cd55..058f848d 100644 --- a/arch/arm/mach-rockchip/rk322x/Kconfig +++ b/arch/arm/mach-rockchip/rk322x/Kconfig @@ -8,6 +8,9 @@ config TARGET_EVB_RK3229 config ROCKCHIP_BOOT_MODE_REG default 0x110005c8
+config ROCKCHIP_STIMER_BASE + default 0x110d0020 + config SYS_SOC default "rk322x"
diff --git a/arch/arm/mach-rockchip/rk3288/Kconfig b/arch/arm/mach-rockchip/rk3288/Kconfig index f37b1bdf..dd8c7826 100644 --- a/arch/arm/mach-rockchip/rk3288/Kconfig +++ b/arch/arm/mach-rockchip/rk3288/Kconfig @@ -148,6 +148,9 @@ config ROCKCHIP_FAST_SPL config ROCKCHIP_BOOT_MODE_REG default 0xff730094
+config ROCKCHIP_STIMER_BASE + default 0xff810020 + config SYS_SOC default "rk3288"
diff --git a/arch/arm/mach-rockchip/rk3308/Kconfig b/arch/arm/mach-rockchip/rk3308/Kconfig index 8fa536e1..194353e4 100644 --- a/arch/arm/mach-rockchip/rk3308/Kconfig +++ b/arch/arm/mach-rockchip/rk3308/Kconfig @@ -8,6 +8,12 @@ config TARGET_ROC_RK3308_CC bool "Firefly roc-rk3308-cc" select BOARD_LATE_INIT
+config ROCKCHIP_BOOT_MODE_REG + default 0xff000500 + +config ROCKCHIP_STIMER_BASE + default 0xff1b00a0 + config SYS_SOC default "rk3308"
@@ -17,10 +23,6 @@ config SYS_MALLOC_F_LEN config SPL_SERIAL default y
-config ROCKCHIP_BOOT_MODE_REG - default 0xff000500 - - source "board/rockchip/evb_rk3308/Kconfig" source "board/firefly/firefly-rk3308/Kconfig"
diff --git a/arch/arm/mach-rockchip/rk3328/Kconfig b/arch/arm/mach-rockchip/rk3328/Kconfig index d13a1690..f6f1e06a 100644 --- a/arch/arm/mach-rockchip/rk3328/Kconfig +++ b/arch/arm/mach-rockchip/rk3328/Kconfig @@ -15,6 +15,9 @@ endchoice config ROCKCHIP_BOOT_MODE_REG default 0xff1005c8
+config ROCKCHIP_STIMER_BASE + default 0xff1d0020 + config SYS_SOC default "rk3328"
diff --git a/arch/arm/mach-rockchip/rk3368/Kconfig b/arch/arm/mach-rockchip/rk3368/Kconfig index 78eb96df..104db367 100644 --- a/arch/arm/mach-rockchip/rk3368/Kconfig +++ b/arch/arm/mach-rockchip/rk3368/Kconfig @@ -45,6 +45,9 @@ endchoice config ROCKCHIP_BOOT_MODE_REG default 0xff738200
+config ROCKCHIP_STIMER_BASE + default 0xff830020 + config SYS_SOC default "rk3368"
diff --git a/arch/arm/mach-rockchip/rk3399/Kconfig b/arch/arm/mach-rockchip/rk3399/Kconfig index 17628f91..4bc15c1b 100644 --- a/arch/arm/mach-rockchip/rk3399/Kconfig +++ b/arch/arm/mach-rockchip/rk3399/Kconfig @@ -114,6 +114,9 @@ endchoice config ROCKCHIP_BOOT_MODE_REG default 0xff320300
+config ROCKCHIP_STIMER_BASE + default 0xff8680a0 + config SYS_SOC default "rk3399"
diff --git a/arch/arm/mach-rockchip/rk3568/Kconfig b/arch/arm/mach-rockchip/rk3568/Kconfig index 201c63c2..4e7c02cc 100644 --- a/arch/arm/mach-rockchip/rk3568/Kconfig +++ b/arch/arm/mach-rockchip/rk3568/Kconfig @@ -9,6 +9,9 @@ config TARGET_EVB_RK3568 config ROCKCHIP_BOOT_MODE_REG default 0xfdc20200
+config ROCKCHIP_STIMER_BASE + default 0xfdd1c020 + config SYS_SOC default "rk3568"
diff --git a/include/configs/px30_common.h b/include/configs/px30_common.h index 09923871..dc609013 100644 --- a/include/configs/px30_common.h +++ b/include/configs/px30_common.h @@ -12,7 +12,6 @@
#define CONFIG_SYS_NS16550_MEM32
-#define CONFIG_ROCKCHIP_STIMER_BASE 0xff220020 #define COUNTER_FREQUENCY 24000000
/* FIXME: ff020000 is pmu_mem (10k), while ff0e0000 is regular int_mem */ diff --git a/include/configs/rk3036_common.h b/include/configs/rk3036_common.h index b133d8ec..10cba727 100644 --- a/include/configs/rk3036_common.h +++ b/include/configs/rk3036_common.h @@ -10,7 +10,6 @@
#define CONFIG_SYS_CBSIZE 1024
-#define CONFIG_ROCKCHIP_STIMER_BASE 0x200440a0 #define COUNTER_FREQUENCY 24000000 #define CONFIG_SYS_ARCH_TIMER #define CONFIG_SYS_HZ_CLOCK 24000000 diff --git a/include/configs/rk3128_common.h b/include/configs/rk3128_common.h index 8b7a0bbb..71f66d57 100644 --- a/include/configs/rk3128_common.h +++ b/include/configs/rk3128_common.h @@ -11,7 +11,6 @@ #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_CBSIZE 1024
-#define CONFIG_ROCKCHIP_STIMER_BASE 0x200440a0 #define COUNTER_FREQUENCY 24000000 #define CONFIG_SYS_ARCH_TIMER #define CONFIG_SYS_HZ_CLOCK 24000000 diff --git a/include/configs/rk322x_common.h b/include/configs/rk322x_common.h index a46b1ffe..aff24018 100644 --- a/include/configs/rk322x_common.h +++ b/include/configs/rk322x_common.h @@ -11,7 +11,6 @@ #define CONFIG_SYS_CBSIZE 1024 #define CONFIG_SYS_BOOTM_LEN (64 << 20) /* 64M */
-#define CONFIG_ROCKCHIP_STIMER_BASE 0x110d0020 #define COUNTER_FREQUENCY 24000000 #define CONFIG_SYS_ARCH_TIMER #define CONFIG_SYS_HZ_CLOCK 24000000 diff --git a/include/configs/rk3288_common.h b/include/configs/rk3288_common.h index abbb2739..c781bc7e 100644 --- a/include/configs/rk3288_common.h +++ b/include/configs/rk3288_common.h @@ -13,7 +13,6 @@
-#define CONFIG_ROCKCHIP_STIMER_BASE 0xff810020 #define COUNTER_FREQUENCY 24000000 #define CONFIG_SYS_ARCH_TIMER #define CONFIG_SYS_HZ_CLOCK 24000000 diff --git a/include/configs/rk3308_common.h b/include/configs/rk3308_common.h index 496f4628..edc535fe 100644 --- a/include/configs/rk3308_common.h +++ b/include/configs/rk3308_common.h @@ -16,7 +16,6 @@
-#define CONFIG_ROCKCHIP_STIMER_BASE 0xff1b00a0 #define CONFIG_IRAM_BASE 0xfff80000 #define CONFIG_SYS_INIT_SP_ADDR 0x00800000 #define CONFIG_SPL_STACK 0x00400000 diff --git a/include/configs/rk3328_common.h b/include/configs/rk3328_common.h index c1e26a01..8a5f0c89 100644 --- a/include/configs/rk3328_common.h +++ b/include/configs/rk3328_common.h @@ -10,7 +10,6 @@
#define CONFIG_IRAM_BASE 0xff090000
-#define CONFIG_ROCKCHIP_STIMER_BASE 0xff1d0020 #define COUNTER_FREQUENCY 24000000
#define CONFIG_SYS_CBSIZE 1024 diff --git a/include/configs/rk3368_common.h b/include/configs/rk3368_common.h index 8b239ca0..239296c1 100644 --- a/include/configs/rk3368_common.h +++ b/include/configs/rk3368_common.h @@ -15,7 +15,6 @@ #define SDRAM_MAX_SIZE 0xff000000 #define CONFIG_SYS_CBSIZE 1024
-#define CONFIG_ROCKCHIP_STIMER_BASE 0xff830020 #define COUNTER_FREQUENCY 24000000
#define CONFIG_IRAM_BASE 0xff8c0000 diff --git a/include/configs/rk3399_common.h b/include/configs/rk3399_common.h index ed72c8bb..4037dba5 100644 --- a/include/configs/rk3399_common.h +++ b/include/configs/rk3399_common.h @@ -11,7 +11,6 @@ #define CONFIG_SYS_CBSIZE 1024
#define COUNTER_FREQUENCY 24000000 -#define CONFIG_ROCKCHIP_STIMER_BASE 0xff8680a0
diff --git a/include/configs/rk3568_common.h b/include/configs/rk3568_common.h index afe5050e..705c3454 100644 --- a/include/configs/rk3568_common.h +++ b/include/configs/rk3568_common.h @@ -11,7 +11,6 @@ #define CONFIG_SYS_CBSIZE 1024
#define COUNTER_FREQUENCY 24000000 -#define CONFIG_ROCKCHIP_STIMER_BASE 0xfdd1c020
#define CONFIG_IRAM_BASE 0xfdcc0000
Johan Jonker
