[U-Boot] [PATCH V2 1/3] mmc: tegra: port to standard clock/reset APIs
Tegra186 supports the new standard clock and reset APIs. Older Tegra SoCs still use custom APIs. Enhance the Tegra MMC driver so that it can operate with either set of APIs.
Signed-off-by: Stephen Warren swarren@nvidia.com --- v2: Add TODO comment describing the messy ifdefs. --- arch/arm/include/asm/arch-tegra/tegra_mmc.h | 8 +++- drivers/mmc/tegra_mmc.c | 64 +++++++++++++++++++++++++---- 2 files changed, 62 insertions(+), 10 deletions(-)
diff --git a/arch/arm/include/asm/arch-tegra/tegra_mmc.h b/arch/arm/include/asm/arch-tegra/tegra_mmc.h index 75e56c4ea786..07ef4c04c858 100644 --- a/arch/arm/include/asm/arch-tegra/tegra_mmc.h +++ b/arch/arm/include/asm/arch-tegra/tegra_mmc.h @@ -9,6 +9,9 @@ #ifndef __TEGRA_MMC_H_ #define __TEGRA_MMC_H_
+#include <common.h> +#include <clk.h> +#include <reset.h> #include <fdtdec.h> #include <asm/gpio.h>
@@ -134,7 +137,10 @@ struct mmc_host { int id; /* device id/number, 0-3 */ int enabled; /* 1 to enable, 0 to disable */ int width; /* Bus Width, 1, 4 or 8 */ -#ifndef CONFIG_TEGRA186 +#ifdef CONFIG_TEGRA186 + struct reset_ctl reset_ctl; + struct clk clk; +#else enum periph_id mmc_id; /* Peripheral ID: PERIPH_ID_... */ #endif struct gpio_desc cd_gpio; /* Change Detect GPIO */ diff --git a/drivers/mmc/tegra_mmc.c b/drivers/mmc/tegra_mmc.c index c9d9432e5e87..7a6671e44ae9 100644 --- a/drivers/mmc/tegra_mmc.c +++ b/drivers/mmc/tegra_mmc.c @@ -9,6 +9,7 @@
#include <bouncebuf.h> #include <common.h> +#include <dm/device.h> #include <asm/gpio.h> #include <asm/io.h> #ifndef CONFIG_TEGRA186 @@ -19,6 +20,15 @@ #include <asm/arch-tegra/tegra_mmc.h> #include <mmc.h>
+/* + * FIXME: TODO: This driver contains a number of ifdef CONFIG_TEGRA186 that + * should not be present. These are needed because newer Tegra SoCs support + * only the standard clock/reset APIs, whereas older Tegra SoCs support only + * a custom Tegra-specific API. ASAP the older Tegra SoCs' code should be + * fixed to implement the standard APIs, and all drivers converted to solely + * use the new standard APIs, with no ifdefs. + */ + DECLARE_GLOBAL_DATA_PTR;
struct mmc_host mmc_host[CONFIG_SYS_MMC_MAX_DEVICE]; @@ -359,11 +369,14 @@ static void mmc_change_clock(struct mmc_host *host, uint clock) */ if (clock == 0) goto out; -#ifndef CONFIG_TEGRA186 +#ifdef CONFIG_TEGRA186 + { + ulong rate = clk_set_rate(&host->clk, clock); + div = (rate + clock - 1) / clock; + } +#else clock_adjust_periph_pll_div(host->mmc_id, CLOCK_ID_PERIPH, clock, &div); -#else - div = (20000000 + clock - 1) / clock; #endif debug("div = %d\n", div);
@@ -538,6 +551,9 @@ static int do_mmc_init(int dev_index, bool removable) { struct mmc_host *host; struct mmc *mmc; +#ifdef CONFIG_TEGRA186 + int ret; +#endif
/* DT should have been read & host config filled in */ host = &mmc_host[dev_index]; @@ -549,7 +565,21 @@ static int do_mmc_init(int dev_index, bool removable) gpio_get_number(&host->cd_gpio));
host->clock = 0; -#ifndef CONFIG_TEGRA186 + +#ifdef CONFIG_TEGRA186 + ret = reset_assert(&host->reset_ctl); + if (ret) + return ret; + ret = clk_enable(&host->clk); + if (ret) + return ret; + ret = clk_set_rate(&host->clk, 20000000); + if (IS_ERR_VALUE(ret)) + return ret; + ret = reset_deassert(&host->reset_ctl); + if (ret) + return ret; +#else clock_start_periph_pll(host->mmc_id, CLOCK_ID_PERIPH, 20000000); #endif
@@ -576,11 +606,7 @@ static int do_mmc_init(int dev_index, bool removable) * (actually 52MHz) */ host->cfg.f_min = 375000; -#ifndef CONFIG_TEGRA186 host->cfg.f_max = 48000000; -#else - host->cfg.f_max = 375000; -#endif
host->cfg.b_max = CONFIG_SYS_MMC_MAX_BLK_COUNT;
@@ -612,7 +638,27 @@ static int mmc_get_config(const void *blob, int node, struct mmc_host *host, return -FDT_ERR_NOTFOUND; }
-#ifndef CONFIG_TEGRA186 +#ifdef CONFIG_TEGRA186 + { + /* + * FIXME: This variable should go away when the MMC device + * actually is a udevice. + */ + struct udevice dev; + int ret; + dev.of_offset = node; + ret = reset_get_by_name(&dev, "sdmmc", &host->reset_ctl); + if (ret) { + debug("reset_get_by_index() failed: %d\n", ret); + return ret; + } + ret = clk_get_by_name(&dev, "sdmmc", &host->clk); + if (ret) { + debug("clk_get_by_index() failed: %d\n", ret); + return ret; + } + } +#else host->mmc_id = clock_decode_periph_id(blob, node); if (host->mmc_id == PERIPH_ID_NONE) { debug("%s: could not decode periph id\n", __func__);
Tegra186 supports the new standard clock, reset, and power domain APIs. Older Tegra SoCs still use custom APIs. Enhance the Tegra PCIe driver so that it can operate with either set of APIs.
On Tegra186, the BPMP handles all aspects of PCIe PHY (UPHY) programming. Consequently, this logic is disabled too.
Signed-off-by: Stephen Warren swarren@nvidia.com --- v2: Add TODO comment describing the messy ifdefs. --- drivers/pci/Kconfig | 1 + drivers/pci/pci_tegra.c | 163 ++++++++++++++++++++++++++++++++++++++++++++++-- 2 files changed, 159 insertions(+), 5 deletions(-)
diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index 26aa2b0930a0..669e37bb5dc5 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -31,6 +31,7 @@ config PCI_SANDBOX config PCI_TEGRA bool "Tegra PCI support" depends on TEGRA + depends on (TEGRA186 && POWER_DOMAIN) || (!TEGRA186) help Enable support for the PCIe controller found on some generations of Tegra. Tegra20 has 2 root ports with a total of 4 lanes, Tegra30 has diff --git a/drivers/pci/pci_tegra.c b/drivers/pci/pci_tegra.c index 352cdef56ab4..ea8adb98db33 100644 --- a/drivers/pci/pci_tegra.c +++ b/drivers/pci/pci_tegra.c @@ -13,22 +13,35 @@ #define pr_fmt(fmt) "tegra-pcie: " fmt
#include <common.h> +#include <clk.h> #include <dm.h> #include <errno.h> #include <fdtdec.h> #include <malloc.h> #include <pci.h> +#include <power-domain.h> +#include <reset.h>
#include <asm/io.h> #include <asm/gpio.h>
+#include <linux/list.h> + +#ifndef CONFIG_TEGRA186 #include <asm/arch/clock.h> #include <asm/arch/powergate.h> #include <asm/arch-tegra/xusb-padctl.h> - -#include <linux/list.h> - #include <dt-bindings/pinctrl/pinctrl-tegra-xusb.h> +#endif + +/* + * FIXME: TODO: This driver contains a number of ifdef CONFIG_TEGRA186 that + * should not be present. These are needed because newer Tegra SoCs support + * only the standard clock/reset APIs, whereas older Tegra SoCs support only + * a custom Tegra-specific API. ASAP the older Tegra SoCs' code should be + * fixed to implement the standard APIs, and all drivers converted to solely + * use the new standard APIs, with no ifdefs. + */
@@ -103,6 +116,9 @@ DECLARE_GLOBAL_DATA_PTR; #define AFI_PCIE_CONFIG_SM2TMS0_XBAR_CONFIG_222 (0x1 << 20) #define AFI_PCIE_CONFIG_SM2TMS0_XBAR_CONFIG_X4_X1 (0x1 << 20) #define AFI_PCIE_CONFIG_SM2TMS0_XBAR_CONFIG_411 (0x2 << 20) +#define AFI_PCIE_CONFIG_SM2TMS0_XBAR_CONFIG_T186_401 (0x0 << 20) +#define AFI_PCIE_CONFIG_SM2TMS0_XBAR_CONFIG_T186_211 (0x1 << 20) +#define AFI_PCIE_CONFIG_SM2TMS0_XBAR_CONFIG_T186_111 (0x2 << 20)
#define AFI_FUSE 0x104 #define AFI_FUSE_PCIE_T0_GEN2_DIS (1 << 2) @@ -110,6 +126,7 @@ DECLARE_GLOBAL_DATA_PTR; #define AFI_PEX0_CTRL 0x110 #define AFI_PEX1_CTRL 0x118 #define AFI_PEX2_CTRL 0x128 +#define AFI_PEX2_CTRL_T186 0x19c #define AFI_PEX_CTRL_RST (1 << 0) #define AFI_PEX_CTRL_CLKREQ_EN (1 << 1) #define AFI_PEX_CTRL_REFCLK_EN (1 << 3) @@ -173,6 +190,7 @@ enum tegra_pci_id { TEGRA30_PCIE, TEGRA124_PCIE, TEGRA210_PCIE, + TEGRA186_PCIE, };
struct tegra_pcie_port { @@ -189,6 +207,7 @@ struct tegra_pcie_soc { unsigned int num_ports; unsigned long pads_pll_ctl; unsigned long tx_ref_sel; + unsigned long afi_pex2_ctrl; u32 pads_refclk_cfg0; u32 pads_refclk_cfg1; bool has_pex_clkreq_en; @@ -209,7 +228,17 @@ struct tegra_pcie { unsigned long xbar;
const struct tegra_pcie_soc *soc; + +#ifdef CONFIG_TEGRA186 + struct clk clk_afi; + struct clk clk_pex; + struct reset_ctl reset_afi; + struct reset_ctl reset_pex; + struct reset_ctl reset_pcie_x; + struct power_domain pwrdom; +#else struct tegra_xusb_phy *phy; +#endif };
static void afi_writel(struct tegra_pcie *pcie, unsigned long value, @@ -229,10 +258,12 @@ static void pads_writel(struct tegra_pcie *pcie, unsigned long value, writel(value, pcie->pads.start + offset); }
+#ifndef CONFIG_TEGRA186 static unsigned long pads_readl(struct tegra_pcie *pcie, unsigned long offset) { return readl(pcie->pads.start + offset); } +#endif
static unsigned long rp_readl(struct tegra_pcie_port *port, unsigned long offset) @@ -400,6 +431,24 @@ static int tegra_pcie_get_xbar_config(const void *fdt, int node, u32 lanes, return 0; } break; + case TEGRA186_PCIE: + switch (lanes) { + case 0x0010004: + debug("x4 x1 configuration\n"); + *xbar = AFI_PCIE_CONFIG_SM2TMS0_XBAR_CONFIG_T186_401; + return 0; + + case 0x0010102: + debug("x2 x1 x1 configuration\n"); + *xbar = AFI_PCIE_CONFIG_SM2TMS0_XBAR_CONFIG_T186_211; + return 0; + + case 0x0010101: + debug("x1 x1 x1 configuration\n"); + *xbar = AFI_PCIE_CONFIG_SM2TMS0_XBAR_CONFIG_T186_111; + return 0; + } + break; default: break; } @@ -471,6 +520,7 @@ static int tegra_pcie_parse_dt(const void *fdt, int node, enum tegra_pci_id id, return err; }
+#ifndef CONFIG_TEGRA186 pcie->phy = tegra_xusb_phy_get(TEGRA_XUSB_PADCTL_PCIE); if (pcie->phy) { err = tegra_xusb_phy_prepare(pcie->phy); @@ -479,6 +529,7 @@ static int tegra_pcie_parse_dt(const void *fdt, int node, enum tegra_pci_id id, return err; } } +#endif
fdt_for_each_subnode(fdt, subnode, node) { unsigned int index = 0, num_lanes = 0; @@ -523,6 +574,44 @@ static int tegra_pcie_parse_dt(const void *fdt, int node, enum tegra_pci_id id, return 0; }
+#ifdef CONFIG_TEGRA186 +static int tegra_pcie_power_on(struct tegra_pcie *pcie) +{ + int ret; + + ret = power_domain_on(&pcie->pwrdom); + if (ret) { + error("power_domain_on() failed: %d\n", ret); + return ret; + } + + ret = clk_enable(&pcie->clk_afi); + if (ret) { + error("clk_enable(afi) failed: %d\n", ret); + return ret; + } + + ret = clk_enable(&pcie->clk_pex); + if (ret) { + error("clk_enable(pex) failed: %d\n", ret); + return ret; + } + + ret = reset_deassert(&pcie->reset_afi); + if (ret) { + error("reset_deassert(afi) failed: %d\n", ret); + return ret; + } + + ret = reset_deassert(&pcie->reset_pex); + if (ret) { + error("reset_deassert(pex) failed: %d\n", ret); + return ret; + } + + return 0; +} +#else static int tegra_pcie_power_on(struct tegra_pcie *pcie) { const struct tegra_pcie_soc *soc = pcie->soc; @@ -639,6 +728,7 @@ static int tegra_pcie_phy_enable(struct tegra_pcie *pcie)
return 0; } +#endif
static int tegra_pcie_enable_controller(struct tegra_pcie *pcie) { @@ -647,7 +737,11 @@ static int tegra_pcie_enable_controller(struct tegra_pcie *pcie) u32 value; int err;
+#ifdef CONFIG_TEGRA186 + { +#else if (pcie->phy) { +#endif value = afi_readl(pcie, AFI_PLLE_CONTROL); value &= ~AFI_PLLE_CONTROL_BYPASS_PADS2PLLE_CONTROL; value |= AFI_PLLE_CONTROL_PADS2PLLE_CONTROL_EN; @@ -675,6 +769,7 @@ static int tegra_pcie_enable_controller(struct tegra_pcie *pcie)
afi_writel(pcie, value, AFI_FUSE);
+#ifndef CONFIG_TEGRA186 if (pcie->phy) err = tegra_xusb_phy_enable(pcie->phy); else @@ -684,9 +779,18 @@ static int tegra_pcie_enable_controller(struct tegra_pcie *pcie) error("failed to power on PHY: %d\n", err); return err; } +#endif
/* take the PCIEXCLK logic out of reset */ +#ifdef CONFIG_TEGRA186 + err = reset_deassert(&pcie->reset_pcie_x); + if (err) { + error("reset_deassert(pcie_x) failed: %d\n", err); + return err; + } +#else reset_set_enable(PERIPH_ID_PCIEXCLK, 0); +#endif
/* finally enable PCIe */ value = afi_readl(pcie, AFI_CONFIGURATION); @@ -787,7 +891,7 @@ static unsigned long tegra_pcie_port_get_pex_ctrl(struct tegra_pcie_port *port) break;
case 2: - ret = AFI_PEX2_CTRL; + ret = port->pcie->soc->afi_pex2_ctrl; break; }
@@ -945,6 +1049,7 @@ static const struct tegra_pcie_soc pci_tegra_soc[] = { .num_ports = 3, .pads_pll_ctl = PADS_PLL_CTL_TEGRA30, .tx_ref_sel = PADS_PLL_CTL_TXCLKREF_BUF_EN, + .afi_pex2_ctrl = AFI_PEX2_CTRL, .pads_refclk_cfg0 = 0xfa5cfa5c, .pads_refclk_cfg1 = 0xfa5cfa5c, .has_pex_clkreq_en = true, @@ -972,7 +1077,16 @@ static const struct tegra_pcie_soc pci_tegra_soc[] = { .has_cml_clk = true, .has_gen2 = true, .force_pca_enable = true, - } + }, + [TEGRA186_PCIE] = { + .num_ports = 3, + .afi_pex2_ctrl = AFI_PEX2_CTRL_T186, + .pads_refclk_cfg0 = 0x80b880b8, + .pads_refclk_cfg1 = 0x000480b8, + .has_pex_clkreq_en = true, + .has_pex_bias_ctrl = true, + .has_gen2 = true, + }, };
static int pci_tegra_ofdata_to_platdata(struct udevice *dev) @@ -996,6 +1110,44 @@ static int pci_tegra_probe(struct udevice *dev) struct tegra_pcie *pcie = dev_get_priv(dev); int err;
+#ifdef CONFIG_TEGRA186 + err = clk_get_by_name(dev, "afi", &pcie->clk_afi); + if (err) { + debug("clk_get_by_name(afi) failed: %d\n", err); + return err; + } + + err = clk_get_by_name(dev, "pex", &pcie->clk_pex); + if (err) { + debug("clk_get_by_name(pex) failed: %d\n", err); + return err; + } + + err = reset_get_by_name(dev, "afi", &pcie->reset_afi); + if (err) { + debug("reset_get_by_name(afi) failed: %d\n", err); + return err; + } + + err = reset_get_by_name(dev, "pex", &pcie->reset_pex); + if (err) { + debug("reset_get_by_name(pex) failed: %d\n", err); + return err; + } + + err = reset_get_by_name(dev, "pcie_x", &pcie->reset_pcie_x); + if (err) { + debug("reset_get_by_name(pcie_x) failed: %d\n", err); + return err; + } + + err = power_domain_get(dev, &pcie->pwrdom); + if (err) { + debug("power_domain_get() failed: %d\n", err); + return err; + } +#endif + err = tegra_pcie_power_on(pcie); if (err < 0) { error("failed to power on"); @@ -1033,6 +1185,7 @@ static const struct udevice_id pci_tegra_ids[] = { { .compatible = "nvidia,tegra30-pcie", .data = TEGRA30_PCIE }, { .compatible = "nvidia,tegra124-pcie", .data = TEGRA124_PCIE }, { .compatible = "nvidia,tegra210-pcie", .data = TEGRA210_PCIE }, + { .compatible = "nvidia,tegra186-pcie", .data = TEGRA186_PCIE }, { } };
clk/reset API was tested on T186 platform and previous chip like T210/T124 will still use the old APIs.
Signed-off-by: Bryan Wu pengw@nvidia.com (swarren, simplified some ifdefs, removed indent level inside an ifdef) (swarren, added comment about the ifdefs) Signed-off-by: Stephen Warren swarren@nvidia.com --- v2: Add TODO comment describing the messy ifdefs. --- drivers/i2c/tegra_i2c.c | 89 ++++++++++++++++++++++++++++++++++++++++++++++--- 1 file changed, 85 insertions(+), 4 deletions(-)
diff --git a/drivers/i2c/tegra_i2c.c b/drivers/i2c/tegra_i2c.c index 2fa07f9c57c4..31ba263b7295 100644 --- a/drivers/i2c/tegra_i2c.c +++ b/drivers/i2c/tegra_i2c.c @@ -12,13 +12,27 @@ #include <fdtdec.h> #include <i2c.h> #include <asm/io.h> +#ifdef CONFIG_TEGRA186 +#include <clk.h> +#include <reset.h> +#else #include <asm/arch/clock.h> #include <asm/arch/funcmux.h> -#include <asm/arch/gpio.h> #include <asm/arch/pinmux.h> #include <asm/arch-tegra/clk_rst.h> +#endif +#include <asm/arch/gpio.h> #include <asm/arch-tegra/tegra_i2c.h>
enum i2c_type { @@ -30,7 +44,12 @@ enum i2c_type { /* Information about i2c controller */ struct i2c_bus { int id; +#ifdef CONFIG_TEGRA186 + struct reset_ctl reset_ctl; + struct clk clk; +#else enum periph_id periph_id; +#endif int speed; int pinmux_config; struct i2c_control *control; @@ -62,12 +81,41 @@ static void set_packet_mode(struct i2c_bus *i2c_bus) static void i2c_reset_controller(struct i2c_bus *i2c_bus) { /* Reset I2C controller. */ +#ifdef CONFIG_TEGRA186 + reset_assert(&i2c_bus->reset_ctl); + udelay(1); + reset_deassert(&i2c_bus->reset_ctl); + udelay(1); +#else reset_periph(i2c_bus->periph_id, 1); +#endif
/* re-program config register to packet mode */ set_packet_mode(i2c_bus); }
+#ifdef CONFIG_TEGRA186 +static int i2c_init_clock(struct i2c_bus *i2c_bus, unsigned rate) +{ + int ret; + + ret = reset_assert(&i2c_bus->reset_ctl); + if (ret) + return ret; + ret = clk_enable(&i2c_bus->clk); + if (ret) + return ret; + ret = clk_set_rate(&i2c_bus->clk, rate); + if (IS_ERR_VALUE(ret)) + return ret; + ret = reset_deassert(&i2c_bus->reset_ctl); + if (ret) + return ret; + + return 0; +} +#endif + static void i2c_init_controller(struct i2c_bus *i2c_bus) { if (!i2c_bus->speed) @@ -78,8 +126,12 @@ static void i2c_init_controller(struct i2c_bus *i2c_bus) * here, in section 23.3.1, but in fact we seem to need a factor of * 16 to get the right frequency. */ +#ifdef CONFIG_TEGRA186 + i2c_init_clock(i2c_bus, i2c_bus->speed * 2 * 8); +#else clock_start_periph_pll(i2c_bus->periph_id, CLOCK_ID_PERIPH, i2c_bus->speed * 2 * 8); +#endif
if (i2c_bus->type == TYPE_114) { /* @@ -94,12 +146,17 @@ static void i2c_init_controller(struct i2c_bus *i2c_bus) * is running, we hang, and we need it for the new calc. */ int clk_div_stdfst_mode = readl(&i2c_bus->regs->clk_div) >> 16; + unsigned rate = CLK_MULT_STD_FAST_MODE * + (clk_div_stdfst_mode + 1) * i2c_bus->speed * 2; debug("%s: CLK_DIV_STD_FAST_MODE setting = %d\n", __func__, clk_div_stdfst_mode);
+#ifdef CONFIG_TEGRA186 + i2c_init_clock(i2c_bus, rate); +#else clock_start_periph_pll(i2c_bus->periph_id, CLOCK_ID_PERIPH, - CLK_MULT_STD_FAST_MODE * (clk_div_stdfst_mode + 1) * - i2c_bus->speed * 2); + rate); +#endif }
/* Reset I2C controller. */ @@ -112,7 +169,9 @@ static void i2c_init_controller(struct i2c_bus *i2c_bus) setbits_le32(&dvc->ctrl3, DVC_CTRL_REG3_I2C_HW_SW_PROG_MASK); }
+#ifndef CONFIG_TEGRA186 funcmux_select(i2c_bus->periph_id, i2c_bus->pinmux_config); +#endif }
static void send_packet_headers( @@ -333,8 +392,12 @@ static int tegra_i2c_set_bus_speed(struct udevice *dev, unsigned int speed) static int tegra_i2c_probe(struct udevice *dev) { struct i2c_bus *i2c_bus = dev_get_priv(dev); +#ifdef CONFIG_TEGRA186 + int ret; +#else const void *blob = gd->fdt_blob; int node = dev->of_offset; +#endif bool is_dvc;
i2c_bus->id = dev->seq; @@ -345,6 +408,18 @@ static int tegra_i2c_probe(struct udevice *dev) * We don't have a binding for pinmux yet. Leave it out for now. So * far no one needs anything other than the default. */ +#ifdef CONFIG_TEGRA186 + ret = reset_get_by_name(dev, "i2c", &i2c_bus->reset_ctl); + if (ret) { + error("reset_get_by_name() failed: %d\n", ret); + return ret; + } + ret = clk_get_by_name(dev, "i2c", &i2c_bus->clk); + if (ret) { + error("clk_get_by_name() failed: %d\n", ret); + return ret; + } +#else i2c_bus->pinmux_config = FUNCMUX_DEFAULT; i2c_bus->periph_id = clock_decode_periph_id(blob, node);
@@ -359,6 +434,7 @@ static int tegra_i2c_probe(struct udevice *dev) */ if (i2c_bus->periph_id == -1) return -EINVAL; +#endif
is_dvc = dev_get_driver_data(dev) == TYPE_DVC; if (is_dvc) { @@ -370,7 +446,12 @@ static int tegra_i2c_probe(struct udevice *dev) i2c_init_controller(i2c_bus); debug("%s: controller bus %d at %p, periph_id %d, speed %d: ", is_dvc ? "dvc" : "i2c", dev->seq, i2c_bus->regs, - i2c_bus->periph_id, i2c_bus->speed); +#ifndef CONFIG_TEGRA186 + i2c_bus->periph_id, +#else + -1, +#endif + i2c_bus->speed);
return 0; }
Hello Stephen,
Am 06.08.2016 um 00:10 schrieb Stephen Warren:
Reviewed-by: Heiko Schocher hs@denx.de
bye, Heiko
- FIXME: TODO: This driver contains a number of ifdef CONFIG_TEGRA186 that
- should not be present. These are needed because newer Tegra SoCs support
- only the standard clock/reset APIs, whereas older Tegra SoCs support only
- a custom Tegra-specific API. ASAP the older Tegra SoCs' code should be
- fixed to implement the standard APIs, and all drivers converted to solely
- use the new standard APIs, with no ifdefs.
enum i2c_type {
- struct reset_ctl reset_ctl;
- struct clk clk;
- reset_assert(&i2c_bus->reset_ctl);
- udelay(1);
- reset_deassert(&i2c_bus->reset_ctl);
- udelay(1);
- int ret;
- ret = reset_assert(&i2c_bus->reset_ctl);
- if (ret)
return ret;
- ret = clk_enable(&i2c_bus->clk);
- if (ret)
return ret;
- ret = clk_set_rate(&i2c_bus->clk, rate);
- if (IS_ERR_VALUE(ret))
return ret;
- ret = reset_deassert(&i2c_bus->reset_ctl);
- if (ret)
return ret;
+} +#endif
- static void i2c_init_controller(struct i2c_bus *i2c_bus) { if (!i2c_bus->speed)
- i2c_init_clock(i2c_bus, i2c_bus->speed * 2 * 8);
debug("%s: CLK_DIV_STD_FAST_MODE setting = %d\n", __func__, clk_div_stdfst_mode);(clk_div_stdfst_mode + 1) * i2c_bus->speed * 2;
rate);
+#endif }
- int ret;
- ret = reset_get_by_name(dev, "i2c", &i2c_bus->reset_ctl);
- if (ret) {
return ret;
- ret = clk_get_by_name(dev, "i2c", &i2c_bus->clk);
- if (ret) {
return ret;
i2c_bus->periph_id,
+#else
-1,
i2c_bus->speed);
return 0; }
Heiko Schocher
Stephen Warren
