[U-Boot] [PATCH] net: bootp fix vci string on SPL-Boot
If CONFIG_CMD_DHCP is enabled, the vci (vendor-class-identifier) string isn't inserted into the bootp-packet during SPL stage because the
CONFIG_BOOTP_VCI_STRING instead CONFIG_SPL_NET_VCI_STRING
We fix this with testing for CONFIG_SPL_BUILD and testing for existing CONFIG_SPL_NET_VCI_STRING.
Signed-off-by: Hannes Schmelzer oe5hpm@oevsv.at
net/bootp.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/net/bootp.c b/net/bootp.c index 43466af..b547786 100644 --- a/net/bootp.c +++ b/net/bootp.c @@ -498,7 +498,9 @@ static int dhcp_extended(u8 *e, int message_type, struct in_addr server_ip, } #endif
-#ifdef CONFIG_BOOTP_VCI_STRING +#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_NET_VCI_STRING) + put_vci(e, CONFIG_SPL_NET_VCI_STRING); +#elif defined(CONFIG_BOOTP_VCI_STRING) put_vci(e, CONFIG_BOOTP_VCI_STRING); #endif
Hi Hannes,
just checked my upstream branch and noticed that this patch is outstanding. How about merge?
regards, Hannes
On 25.08.2015 18:01, Joe Hershberger wrote:
Hi Hannes,
Hi Hannes,
On Tue, Sep 29, 2015 at 3:19 AM, Hannes Schmelzer hannes@schmelzer.or.at wrote:
Do you think this is a critical bug fix? I was planning to wait for next release since the patch came after the merge window.
regards, Hannes
Hi Hannes,
Hi Hannes,
Hi Joe,
outstanding.
How about merge?
Absolutely not critical. no problem to wait for next release.
regards, Hannes
Hi Hannes,
string
existing
Applied to u-boot-net/master, thanks! -Joe
participants (5)
Hannes Schmelzer
Hannes Schmelzer
Hannes Schmelzer
Joe Hershberger
