[U-Boot] [PATCH v6] spi: pl022_spi: Add support for ARM PL022 spi controller
This patch adds the support for the ARM PL022 SPI controller for the standard variant (0x00041022), which has a 16bit wide and 8 locations deep TX/RX FIFO.
Signed-off-by: Armando Visconti armando.visconti@st.com Signed-off-by: Vipin Kumar vipin.kumar@st.com Acked-by: Stefan Roese sr@denx.de --- v5->v6
1. Make use of spi_alloc_slave() macro. 2. Changed the identation on 'if statement' as requested by Jagan.
drivers/spi/Makefile | 1 + drivers/spi/pl022_spi.c | 308 ++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 309 insertions(+) create mode 100644 drivers/spi/pl022_spi.c
diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index d08609e..b6443b1 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -47,6 +47,7 @@ COBJS-$(CONFIG_MXC_SPI) += mxc_spi.o COBJS-$(CONFIG_MXS_SPI) += mxs_spi.o COBJS-$(CONFIG_OC_TINY_SPI) += oc_tiny_spi.o COBJS-$(CONFIG_OMAP3_SPI) += omap3_spi.o +COBJS-$(CONFIG_PL022_SPI) += pl022_spi.o COBJS-$(CONFIG_SOFT_SPI) += soft_spi.o COBJS-$(CONFIG_SH_SPI) += sh_spi.o COBJS-$(CONFIG_FSL_ESPI) += fsl_espi.o diff --git a/drivers/spi/pl022_spi.c b/drivers/spi/pl022_spi.c new file mode 100644 index 0000000..5b47413 --- /dev/null +++ b/drivers/spi/pl022_spi.c @@ -0,0 +1,308 @@ +/* + * (C) Copyright 2012 + * Armando Visconti, ST Microelectronics, armando.visconti@st.com. + * + * Driver for ARM PL022 SPI Controller. Based on atmel_spi.c + * by Atmel Corporation. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <malloc.h> +#include <spi.h> +#include <asm/io.h> +#include <asm/arch/hardware.h> + +/* SSP registers mapping */ +struct pl022 { + u32 ssp_cr0; /* 0x000 */ + u32 ssp_cr1; /* 0x004 */ + u32 ssp_dr; /* 0x008 */ + u32 ssp_sr; /* 0x00c */ + u32 ssp_cpsr; /* 0x010 */ + u32 ssp_imsc; /* 0x014 */ + u32 ssp_ris; /* 0x018 */ + u32 ssp_mis; /* 0x01c */ + u32 ssp_icr; /* 0x020 */ + u32 ssp_dmacr; /* 0x024 */ + u8 reserved_1[0x080 - 0x028]; + u32 ssp_itcr; /* 0x080 */ + u32 ssp_itip; /* 0x084 */ + u32 ssp_itop; /* 0x088 */ + u32 ssp_tdr; /* 0x08c */ + u8 reserved_2[0xFE0 - 0x090]; + u32 ssp_pid0; /* 0xfe0 */ + u32 ssp_pid1; /* 0xfe4 */ + u32 ssp_pid2; /* 0xfe8 */ + u32 ssp_pid3; /* 0xfec */ + u32 ssp_cid0; /* 0xff0 */ + u32 ssp_cid1; /* 0xff4 */ + u32 ssp_cid2; /* 0xff8 */ + u32 ssp_cid3; /* 0xffc */ +}; + +/* SSP Control Register 0 - SSP_CR0 */ +#define SSP_CR0_SPO (0x1 << 6) +#define SSP_CR0_SPH (0x1 << 7) +#define SSP_CR0_8BIT_MODE (0x07) +#define SSP_SCR_MAX (0xFF) +#define SSP_SCR_SHFT 8 + +/* SSP Control Register 0 - SSP_CR1 */ +#define SSP_CR1_MASK_SSE (0x1 << 1) + +#define SSP_CPSR_MAX (0xFE) + +/* SSP Status Register - SSP_SR */ +#define SSP_SR_MASK_TFE (0x1 << 0) /* Transmit FIFO empty */ +#define SSP_SR_MASK_TNF (0x1 << 1) /* Transmit FIFO not full */ +#define SSP_SR_MASK_RNE (0x1 << 2) /* Receive FIFO not empty */ +#define SSP_SR_MASK_RFF (0x1 << 3) /* Receive FIFO full */ +#define SSP_SR_MASK_BSY (0x1 << 4) /* Busy Flag */ + +struct pl022_spi_slave { + struct spi_slave slave; + void *regs; + unsigned int freq; +}; + +static inline struct pl022_spi_slave *to_pl022_spi(struct spi_slave *slave) +{ + return container_of(slave, struct pl022_spi_slave, slave); +} + +/* + * Following three functions should be provided by the + * board support package. + */ +int __weak spi_cs_is_valid(unsigned int bus, unsigned int cs) +{ + return 1; +} + +void __weak spi_cs_activate(struct spi_slave *slave) +{ + /* do nothing */ +} + +void __weak spi_cs_deactivate(struct spi_slave *slave) +{ + /* do nothing */ +} + +void spi_init(void) +{ + /* do nothing */ +} + +/* + * ARM PL022 exists in different 'flavors'. + * This drivers currently support the standard variant (0x00041022), that has a + * 16bit wide and 8 locations deep TX/RX FIFO. + */ +static int pl022_is_supported(struct pl022_spi_slave *ps) +{ + struct pl022 *pl022 = (struct pl022 *)ps->regs; + + /* PL022 version is 0x00041022 */ + if ((readl(&pl022->ssp_pid0) == 0x22) && + (readl(&pl022->ssp_pid1) == 0x10) && + ((readl(&pl022->ssp_pid2) & 0xf) == 0x04) && + (readl(&pl022->ssp_pid3) == 0x00)) + return 1; + + return 0; +} + +struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, + unsigned int max_hz, unsigned int mode) +{ + struct pl022_spi_slave *ps; + struct pl022 *pl022; + u16 scr = 1, prescaler, cr0 = 0, cpsr = 0; + + if (!spi_cs_is_valid(bus, cs)) + return NULL; + + ps = spi_alloc_slave(struct pl022_spi_slave, bus, cs); + if (!ps) + return NULL; + + ps->freq = max_hz; + + switch (bus) { + case 0: + ps->regs = (void *)CONFIG_SYS_SPI_BASE; + break; +#ifdef CONFIG_SYS_SPI_BASE1 + case 1: + ps->regs = (void *)CONFIG_SYS_SPI_BASE1; + break; +#endif +#ifdef CONFIG_SYS_SPI_BASE2 + case 2: + ps->regs = (void *)CONFIG_SYS_SPI_BASE2; + break; +#endif +#ifdef CONFIG_SYS_SPI_BASE3 + case 3: + ps->regs = (void *)CONFIG_SYS_SPI_BASE3; + break; +#endif + default: + free(ps); + return NULL; + } + + pl022 = (struct pl022 *)ps->regs; + + /* Check the PL022 version */ + if (!pl022_is_supported(ps)) { + free(ps); + return NULL; + } + + /* Set requested polarity and 8bit mode */ + cr0 = SSP_CR0_8BIT_MODE; + cr0 |= (mode & SPI_CPHA) ? SSP_CR0_SPH : 0; + cr0 |= (mode & SPI_CPOL) ? SSP_CR0_SPO : 0; + + writel(cr0, &pl022->ssp_cr0); + + /* Program the SSPClk frequency */ + prescaler = CONFIG_SYS_SPI_CLK / ps->freq; + + if (prescaler <= 0xFF) { + cpsr = prescaler; + } else { + for (scr = 1; scr <= SSP_SCR_MAX; scr++) { + if (!(prescaler % scr)) { + cpsr = prescaler / scr; + if (cpsr <= SSP_CPSR_MAX) + break; + } + } + + if (scr > SSP_SCR_MAX) { + scr = SSP_SCR_MAX; + cpsr = prescaler / scr; + cpsr &= SSP_CPSR_MAX; + } + } + + if (cpsr & 0x1) + cpsr++; + + writel(cpsr, &pl022->ssp_cpsr); + cr0 = readl(&pl022->ssp_cr0); + writel(cr0 | (scr - 1) << SSP_SCR_SHFT, &pl022->ssp_cr0); + + return &ps->slave; +} + +void spi_free_slave(struct spi_slave *slave) +{ + struct pl022_spi_slave *ps = to_pl022_spi(slave); + + free(ps); +} + +int spi_claim_bus(struct spi_slave *slave) +{ + struct pl022_spi_slave *ps = to_pl022_spi(slave); + struct pl022 *pl022 = (struct pl022 *)ps->regs; + + /* Enable the SPI hardware */ + setbits_le32(&pl022->ssp_cr1, SSP_CR1_MASK_SSE); + + return 0; +} + +void spi_release_bus(struct spi_slave *slave) +{ + struct pl022_spi_slave *ps = to_pl022_spi(slave); + struct pl022 *pl022 = (struct pl022 *)ps->regs; + + /* Disable the SPI hardware */ + writel(0x0, &pl022->ssp_cr1); +} + +int spi_xfer(struct spi_slave *slave, unsigned int bitlen, + const void *dout, void *din, unsigned long flags) +{ + struct pl022_spi_slave *ps = to_pl022_spi(slave); + struct pl022 *pl022 = (struct pl022 *)ps->regs; + u32 len_tx = 0, len_rx = 0, len; + u32 ret = 0; + const u8 *txp = dout; + u8 *rxp = din, value; + + if (bitlen == 0) + /* Finish any previously submitted transfers */ + goto out; + + /* + * TODO: The controller can do non-multiple-of-8 bit + * transfers, but this driver currently doesn't support it. + * + * It's also not clear how such transfers are supposed to be + * represented as a stream of bytes...this is a limitation of + * the current SPI interface. + */ + if (bitlen % 8) { + ret = -1; + + /* Errors always terminate an ongoing transfer */ + flags |= SPI_XFER_END; + goto out; + } + + len = bitlen / 8; + + if (flags & SPI_XFER_BEGIN) + spi_cs_activate(slave); + + while (len_tx < len) { + if (readl(&pl022->ssp_sr) & SSP_SR_MASK_TNF) { + value = (txp != NULL) ? *txp++ : 0; + writel(value, &pl022->ssp_dr); + len_tx++; + } + + if (readl(&pl022->ssp_sr) & SSP_SR_MASK_RNE) { + value = readl(&pl022->ssp_dr); + if (rxp) + *rxp++ = value; + len_rx++; + } + } + + while (len_rx < len_tx) { + if (readl(&pl022->ssp_sr) & SSP_SR_MASK_RNE) { + value = readl(&pl022->ssp_dr); + if (rxp) + *rxp++ = value; + len_rx++; + } + } + +out: + if (flags & SPI_XFER_END) + spi_cs_deactivate(slave); + + return ret; +}
Thanks for v6 sent.
Have you tested this? on which board, include/configs/*.h file?
-- Thanks, Jagan.
On Wed, Jun 12, 2013 at 6:17 PM, Armando Visconti armando.visconti@st.com wrote:
v5->v6
- Make use of spi_alloc_slave() macro.
- Changed the identation on 'if statement' as requested by Jagan.
- (C) Copyright 2012
- Armando Visconti, ST Microelectronics, armando.visconti@st.com.
- Driver for ARM PL022 SPI Controller. Based on atmel_spi.c
- by Atmel Corporation.
- MA 02111-1307 USA
void *regs;
unsigned int freq;
- Following three functions should be provided by the
- board support package.
return 1;
/* do nothing */
/* do nothing */
/* do nothing */
- ARM PL022 exists in different 'flavors'.
- This drivers currently support the standard variant (0x00041022), that has a
- 16bit wide and 8 locations deep TX/RX FIFO.
return 1;
return NULL;
if (!ps)
return NULL;
ps->freq = max_hz;
switch (bus) {
case 0:
break;
case 1:
break;
case 2:
break;
case 3:
break;
default:
free(ps);
return NULL;
free(ps);
return NULL;
cpsr = prescaler;
} else {
break;
scr = SSP_SCR_MAX;
if (cpsr & 0x1)
cpsr++;
return &ps->slave;
free(ps);
u32 ret = 0;
if (bitlen == 0)
goto out;
if (bitlen % 8) {
ret = -1;
goto out;
len = bitlen / 8;
len_tx++;
if (rxp)
*rxp++ = value;
len_rx++;
if (rxp)
*rxp++ = value;
len_rx++;
+out:
return ret;
1.7.11.7
On 06/12/2013 04:25 PM, Jagan Teki wrote:
Thanks for v6 sent.
No Jagan.
I have not tested v6, as I currently don't have a spare board. Nevertheless, Vipin tested it up to v3. And he tested it on spear1340 evaluation board.
After v3, no big changes have been performed. Just style changes and make use of spi_alloc_slave()...
But if you prefer to be on safer side I think we need to re-do some checks on a spare 1340 board...
Pls let me know, Arm
OK, maybe it is better to re-check again.
I need to find some time and a spare board...
I'll let you know, Arm
On Wed, Jun 12, 2013 at 8:49 PM, Armando Visconti armando.visconti@st.com wrote:
Do we have an config file available in master, i need to build at-least.
-- Thanks, Jagan.
Mmmh... currently in mainline there is only spear3xx config file, but there is no PL022 support there.
In fact, to compile locally here I had to change it in this way, even if they cannot be used for testing (only compiling):
diff --git a/include/configs/spear3xx_evb.h b/include/configs/spear3xx_evb.h index 3cd56dc..03a046e 100644 --- a/include/configs/spear3xx_evb.h +++ b/include/configs/spear3xx_evb.h @@ -54,6 +54,11 @@ /* Ethernet driver configuration */ #define CONFIG_DW_ALTDESCRIPTOR
+#define CONFIG_PL022_SPI 1 +#define CONFIG_SYS_SPI_BASE 0xE0100000 +#define CONFIG_SYS_SPI_CLK 83000000 +#define CONFIG_CMD_SPI 1
#if defined(CONFIG_SPEAR310) #define CONFIG_MACB #define CONFIG_MACB0_PHY 0x01
I know that Vipin was going to add support of spear1340 in mainline. His patches are currently already submitted and partially acked but I'm not sure what is the status now...
Vipin, can you update us?
Rgds, Arm
Any update on this.
On Wed, Jun 12, 2013 at 9:25 PM, Armando Visconti armando.visconti@st.com wrote:
Rgds, Arm
On 10/4/2013 1:22 AM, Jagan Teki wrote:
Any update on this.
This should already be in u-boot mainline
Regards Vipin
- #if defined(CONFIG_SPEAR310) #define CONFIG_MACB #define CONFIG_MACB0_PHY 0x01
Rgds, Arm
Couldn't find in master, can you provide the link atleast.
Any update on this.
Regards Vipin
Rgds, Arm
I am sorry. Got confused with something else You are right. It seems this is not merged yet
May be I have to take this and send a pull request. Meanwhile, can you try taking this patch from the mail itself
Regards Vipin
Any update on this.
Regards Vipin
> > > > But if you prefer to be on safer side I think we > need to re-do some checks on a spare 1340 board... >
Rgds, Arm
Hi Vipin,
I have few quick comments, please fix it. Please use the u-boot-spi.git with master-probe branch for testing this driver. Let me know for any issues/concerns.
On Wed, Jun 12, 2013 at 7:55 PM, Jagan Teki jagannadh.teki@gmail.com wrote:
Thanks for v6 sent.
-- Thanks, Jagan.
v5->v6
- MA 02111-1307 USA
Use latest SPDX-License-Identifier: check for any existing one.
Something like pl022_spi_regs
-- TAG+
--- TAG -
Bit mask macros - please place after headers. We follow a simple format to write spi driver - please check http://patchwork.ozlabs.org/patch/265683/
And try to verify your code w.r.t above format - let me know any comments.
void *regs;
Please use the structure pointer instead of void.
unsigned int freq;
return 1;
/* do nothing */
/* do nothing */
/* do nothing */
return 1;
return NULL;
if (!ps)
return NULL;
ps->freq = max_hz;
switch (bus) {
case 0:
break;
case 1:
break;
case 2:
break;
case 3:
break;
default:
free(ps);
return NULL;
free(ps);
return NULL;
cpsr = prescaler;
} else {
break;
scr = SSP_SCR_MAX;
if (cpsr & 0x1)
cpsr++;
return &ps->slave;
free(ps);
u32 ret = 0;
if (bitlen == 0)
goto out;
if (bitlen % 8) {
ret = -1;
goto out;
len = bitlen / 8;
len_tx++;
if (rxp)
*rxp++ = value;
len_rx++;
if (rxp)
*rxp++ = value;
len_rx++;
+out:
return ret;
1.7.11.7
On Fri, Oct 4, 2013 at 12:20 PM, Jagan Teki jagannadh.teki@gmail.com wrote:
Hi Vipin,
Thanks for v6 sent.
-- Thanks, Jagan.
v5->v6
- MA 02111-1307 USA
-- TAG+
--- TAG -
void *regs;
unsigned int freq;
return 1;
/* do nothing */
/* do nothing */
/* do nothing */
return 1;
return NULL;
if (!ps)
return NULL;
ps->freq = max_hz;
switch (bus) {
case 0:
break;
case 1:
break;
case 2:
break;
case 3:
break;
default:
free(ps);
return NULL;
free(ps);
return NULL;
cpsr = prescaler;
} else {
break;
scr = SSP_SCR_MAX;
if (cpsr & 0x1)
cpsr++;
return &ps->slave;
free(ps);
u32 ret = 0;
if (bitlen == 0)
goto out;
if (bitlen % 8) {
ret = -1;
goto out;
len = bitlen / 8;
len_tx++;
if (rxp)
*rxp++ = value;
len_rx++;
if (rxp)
*rxp++ = value;
len_rx++;
+out:
return ret;
1.7.11.7
Ping
Hello Jagan,
Sorry for late reply.
Hi Vipin,
Thanks for v6 sent.
-- Thanks, Jagan.
v5->v6
- MA 02111-1307 USA
-- TAG+
--- TAG -
void *regs;
unsigned int freq;
return 1;
/* do nothing */
/* do nothing */
/* do nothing */
return 1;
return NULL;
if (!ps)
return NULL;
ps->freq = max_hz;
switch (bus) {
case 0:
break;
case 1:
break;
case 2:
break;
case 3:
break;
default:
free(ps);
return NULL;
free(ps);
return NULL;
cpsr = prescaler;
} else {
break;
scr = SSP_SCR_MAX;
if (cpsr & 0x1)
cpsr++;
return &ps->slave;
free(ps);
u32 ret = 0;
if (bitlen == 0)
goto out;
if (bitlen % 8) {
ret = -1;
goto out;
len = bitlen / 8;
len_tx++;
if (rxp)
*rxp++ = value;
len_rx++;
if (rxp)
*rxp++ = value;
len_rx++;
+out:
return ret;
1.7.11.7
Ping
Unfortunately lot of changes happened to our organization and we (myself and Vipin) are no longer able to proceed in doing this job.
So I think we need to drop this patch, unless someone from the u-boot community has the possibility to (and is willing to) proceed in implementing and testing the proper changes.
Sorry for that, Armando
On Wed, Jan 8, 2014 at 2:49 PM, Armando Visconti armando.visconti@st.com wrote:
Hello Jagan,
Hi Vipin,
Thanks for v6 sent.
-- Thanks, Jagan.
v5->v6
- MA 02111-1307 USA
-- TAG+
--- TAG -
void *regs;
unsigned int freq;
return 1;
/* do nothing */
/* do nothing */
/* do nothing */
that has a
return 1;
return NULL;
if (!ps)
return NULL;
ps->freq = max_hz;
switch (bus) {
case 0:
break;
case 1:
break;
case 2:
break;
case 3:
break;
default:
free(ps);
return NULL;
free(ps);
return NULL;
cpsr = prescaler;
} else {
break;
scr = SSP_SCR_MAX;
if (cpsr & 0x1)
cpsr++;
return &ps->slave;
free(ps);
u32 ret = 0;
if (bitlen == 0)
goto out;
if (bitlen % 8) {
ret = -1;
goto out;
len = bitlen / 8;
len_tx++;
if (rxp)
*rxp++ = value;
len_rx++;
if (rxp)
*rxp++ = value;
len_rx++;
+out:
return ret;
1.7.11.7
Ping
Thanks,
-- Jagan.
Armando Visconti
Jagan Teki
Vipin Kumar
