[PATCH v2 0/2] arm64: meson: add libretech cc v2 support
This patchset adds support for the Amlogic based libretech cc v2. Like the v1, this revised platform used the s905x SoC.
Changes since v1: - Move Makefile change to patch #1 - Amend documentation for libretech cc v2
Jerome Brunet (2): arm64: dts: import libretech-cc-v2 from linux v5.10-rc1 arm64: meson: add support for libretech-cc v2
arch/arm/dts/Makefile | 1 + ...eson-gxl-s905x-libretech-cc-v2-u-boot.dtsi | 7 + .../dts/meson-gxl-s905x-libretech-cc-v2.dts | 318 ++++++++++++++++++ configs/libretech-cc_v2_defconfig | 82 +++++ 4 files changed, 408 insertions(+) create mode 100644 arch/arm/dts/meson-gxl-s905x-libretech-cc-v2-u-boot.dtsi create mode 100644 arch/arm/dts/meson-gxl-s905x-libretech-cc-v2.dts create mode 100644 configs/libretech-cc_v2_defconfig
Sync the libretech cc v2 device tree from Linux v5.10-rc1 commit 3650b228f83a ("Linux 5.10-rc1")
Signed-off-by: Jerome Brunet jbrunet@baylibre.com --- .../dts/meson-gxl-s905x-libretech-cc-v2.dts | 318 ++++++++++++++++++ 1 file changed, 318 insertions(+) create mode 100644 arch/arm/dts/meson-gxl-s905x-libretech-cc-v2.dts
diff --git a/arch/arm/dts/meson-gxl-s905x-libretech-cc-v2.dts b/arch/arm/dts/meson-gxl-s905x-libretech-cc-v2.dts new file mode 100644 index 000000000000..675eaa87963e --- /dev/null +++ b/arch/arm/dts/meson-gxl-s905x-libretech-cc-v2.dts @@ -0,0 +1,318 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2020 BayLibre, SAS. + * Author: Jerome Brunet jbrunet@baylibre.com + */ + +/dts-v1/; + +#include <dt-bindings/input/input.h> +#include <dt-bindings/leds/common.h> +#include <dt-bindings/sound/meson-aiu.h> + +#include "meson-gxl-s905x.dtsi" + +/ { + compatible = "libretech,aml-s905x-cc-v2", "amlogic,s905x", + "amlogic,meson-gxl"; + model = "Libre Computer AML-S905X-CC V2"; + + aliases { + serial0 = &uart_AO; + ethernet0 = ðmac; + spi0 = &spifc; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + emmc_pwrseq: emmc-pwrseq { + compatible = "mmc-pwrseq-emmc"; + reset-gpios = <&gpio BOOT_9 GPIO_ACTIVE_LOW>; + }; + + hdmi-connector { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_connector_in: endpoint { + remote-endpoint = <&hdmi_tx_tmds_out>; + }; + }; + }; + + leds { + compatible = "gpio-leds"; + + led-blue { + color = <LED_COLOR_ID_BLUE>; + function = LED_FUNCTION_STATUS; + gpios = <&gpio GPIODV_24 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + panic-indicator; + }; + + led-green { + color = <LED_COLOR_ID_GREEN>; + function = LED_FUNCTION_DISK_ACTIVITY; + gpios = <&gpio_ao GPIOAO_2 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "disk-activity"; + }; + }; + + memory@0 { + device_type = "memory"; + reg = <0x0 0x0 0x0 0x80000000>; + }; + + ao_5v: regulator-ao_5v { + compatible = "regulator-fixed"; + regulator-name = "AO_5V"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&dc_in>; + regulator-always-on; + }; + + dc_in: regulator-dc_in { + compatible = "regulator-fixed"; + regulator-name = "DC_IN"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + }; + + + vcck: regulator-vcck { + compatible = "regulator-fixed"; + regulator-name = "VCCK"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&ao_5v>; + regulator-always-on; + }; + + vcc_card: regulator-vcc_card { + compatible = "regulator-fixed"; + regulator-name = "VCC_CARD"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vddio_ao3v3>; + + gpio = <&gpio GPIOCLK_1 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + vcc5v: regulator-vcc5v { + compatible = "regulator-fixed"; + regulator-name = "VCC5V"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&ao_5v>; + + gpio = <&gpio GPIOH_3 GPIO_OPEN_DRAIN>; + }; + + vddio_ao3v3: regulator-vddio_ao3v3 { + compatible = "regulator-fixed"; + regulator-name = "VDDIO_AO3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&ao_5v>; + regulator-always-on; + }; + + + vddio_card: regulator-vddio-card { + compatible = "regulator-gpio"; + regulator-name = "VDDIO_CARD"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + + gpios = <&gpio_ao GPIOAO_3 GPIO_ACTIVE_HIGH>; + gpios-states = <0>; + + states = <3300000 0>, + <1800000 1>; + + regulator-settling-time-up-us = <200>; + regulator-settling-time-down-us = <50000>; + }; + + vddio_ao18: regulator-vddio_ao18 { + compatible = "regulator-fixed"; + regulator-name = "VDDIO_AO18"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vddio_ao3v3>; + regulator-always-on; + }; + + vcc_1v8: regulator-vcc_1v8 { + compatible = "regulator-fixed"; + regulator-name = "VCC 1V8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vddio_ao3v3>; + regulator-always-on; + }; + + sound { + compatible = "amlogic,gx-sound-card"; + model = "GXL-LIBRETECH-S905X-CC-V2"; + assigned-clocks = <&clkc CLKID_MPLL0>, + <&clkc CLKID_MPLL1>, + <&clkc CLKID_MPLL2>; + assigned-clock-parents = <0>, <0>, <0>; + assigned-clock-rates = <294912000>, + <270950400>, + <393216000>; + status = "okay"; + + dai-link-0 { + sound-dai = <&aiu AIU_CPU CPU_I2S_FIFO>; + }; + + dai-link-1 { + sound-dai = <&aiu AIU_CPU CPU_I2S_ENCODER>; + dai-format = "i2s"; + mclk-fs = <256>; + + codec-0 { + sound-dai = <&aiu AIU_HDMI CTRL_I2S>; + }; + }; + + dai-link-2 { + sound-dai = <&aiu AIU_HDMI CTRL_OUT>; + + codec-0 { + sound-dai = <&hdmi_tx>; + }; + }; + }; +}; + + +&aiu { + status = "okay"; +}; + +&cec_AO { + status = "okay"; + pinctrl-0 = <&ao_cec_pins>; + pinctrl-names = "default"; + hdmi-phandle = <&hdmi_tx>; +}; + + +ðmac { + status = "okay"; +}; + +&internal_phy { + pinctrl-0 = <ð_link_led_pins>, <ð_act_led_pins>; + pinctrl-names = "default"; +}; + +&ir { + status = "okay"; + pinctrl-0 = <&remote_input_ao_pins>; + pinctrl-names = "default"; +}; + +&hdmi_tx { + status = "okay"; + pinctrl-0 = <&hdmi_hpd_pins>, <&hdmi_i2c_pins>; + hdmi-supply = <&vcc5v>; + pinctrl-names = "default"; +}; + +&hdmi_tx_tmds_port { + hdmi_tx_tmds_out: endpoint { + remote-endpoint = <&hdmi_connector_in>; + }; +}; + +&saradc { + status = "okay"; + vref-supply = <&vddio_ao18>; +}; + +/* SD card */ +&sd_emmc_b { + pinctrl-0 = <&sdcard_pins>; + pinctrl-1 = <&sdcard_clk_gate_pins>; + pinctrl-names = "default", "clk-gate"; + + bus-width = <4>; + cap-sd-highspeed; + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr50; + sd-uhs-ddr50; + max-frequency = <100000000>; + disable-wp; + + cd-gpios = <&gpio CARD_6 GPIO_ACTIVE_LOW>; + + vmmc-supply = <&vcc_card>; + vqmmc-supply = <&vddio_card>; + + status = "okay"; +}; + +/* eMMC */ +&sd_emmc_c { + pinctrl-0 = <&emmc_pins>; + pinctrl-1 = <&emmc_clk_gate_pins>; + pinctrl-names = "default", "clk-gate"; + + bus-width = <8>; + cap-mmc-highspeed; + mmc-hs200-1_8v; + max-frequency = <200000000>; + disable-wp; + + mmc-pwrseq = <&emmc_pwrseq>; + vmmc-supply = <&vddio_ao3v3>; + vqmmc-supply = <&vcc_1v8>; + + status = "okay"; +}; + +&spifc { + status = "okay"; + pinctrl-0 = <&nor_pins>; + pinctrl-names = "default"; + + nor_4u1: spi-flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "jedec,spi-nor"; + reg = <0>; + spi-max-frequency = <3000000>; + }; +}; + +&uart_AO { + status = "okay"; + pinctrl-0 = <&uart_ao_a_pins>; + pinctrl-names = "default"; +}; + +&usb { + status = "okay"; + dr_mode = "host"; +}; + +&usb2_phy0 { + pinctrl-names = "default"; + phy-supply = <&vcc5v>; +}; + +&usb2_phy1 { + phy-supply = <&vcc5v>; +};
Add support for the Amlogic based libretech cc version 2. As version 1, it is based on the s905x SoC.
Signed-off-by: Jerome Brunet jbrunet@baylibre.com --- arch/arm/dts/Makefile | 1 + ...eson-gxl-s905x-libretech-cc-v2-u-boot.dtsi | 7 ++ configs/libretech-cc_v2_defconfig | 82 +++++++++++++++++++ 3 files changed, 90 insertions(+) create mode 100644 arch/arm/dts/meson-gxl-s905x-libretech-cc-v2-u-boot.dtsi create mode 100644 configs/libretech-cc_v2_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index b195723f1645..e957820e8e62 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -159,6 +159,7 @@ dtb-$(CONFIG_ARCH_MESON) += \ meson-gxl-s905x-p212.dtb \ meson-gxl-s805x-libretech-ac.dtb \ meson-gxl-s905x-libretech-cc.dtb \ + meson-gxl-s905x-libretech-cc-v2.dtb \ meson-gxl-s905x-khadas-vim.dtb \ meson-gxl-s905d-libretech-pc.dtb \ meson-gxm-khadas-vim2.dtb \ diff --git a/arch/arm/dts/meson-gxl-s905x-libretech-cc-v2-u-boot.dtsi b/arch/arm/dts/meson-gxl-s905x-libretech-cc-v2-u-boot.dtsi new file mode 100644 index 000000000000..8ff5a0ef2ba5 --- /dev/null +++ b/arch/arm/dts/meson-gxl-s905x-libretech-cc-v2-u-boot.dtsi @@ -0,0 +1,7 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2020 BayLibre, SAS. + * Author: Jerome Brunet jbrunet@baylibre.com + */ + +#include "meson-gxl-u-boot.dtsi" diff --git a/configs/libretech-cc_v2_defconfig b/configs/libretech-cc_v2_defconfig new file mode 100644 index 000000000000..e71f88edaec6 --- /dev/null +++ b/configs/libretech-cc_v2_defconfig @@ -0,0 +1,82 @@ +CONFIG_ARM=y +CONFIG_ARCH_MESON=y +CONFIG_SYS_TEXT_BASE=0x01000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xFFFF0000 +CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_DM_GPIO=y +CONFIG_MESON_GXL=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_DEBUG_UART_BASE=0xc81004c0 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_IDENT_STRING=" libretech-cc-v2" +CONFIG_DEBUG_UART=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_USE_PREBOOT=y +CONFIG_PREBOOT="usb start" +CONFIG_MISC_INIT_R=y +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_DISPLAY_BOARDINFO is not set +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_IMI is not set +CONFIG_CMD_ADC=y +CONFIG_CMD_GPIO=y +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_REGULATOR=y +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="meson-gxl-s905x-libretech-cc-v2" +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SARADC_MESON=y +CONFIG_DM_KEYBOARD=y +CONFIG_DM_MMC=y +CONFIG_MMC_MESON_GX=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_PHY_ADDR_ENABLE=y +CONFIG_PHY_ADDR=8 +CONFIG_PHY_MESON_GXL=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_PHY=y +CONFIG_MESON_GXL_USB_PHY=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_MESON_GXL=y +CONFIG_POWER_DOMAIN=y +CONFIG_MESON_GX_VPU_POWER_DOMAIN=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_RESET=y +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_DEBUG_UART_SKIP_INIT=y +CONFIG_MESON_SERIAL=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_MESON_SPIFC=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_XHCI_DWC3_OF_SIMPLE=y +CONFIG_USB_DWC3=y +# CONFIG_USB_DWC3_GADGET is not set +CONFIG_USB_KEYBOARD=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_VENDOR_NUM=0x1b8e +CONFIG_USB_GADGET_PRODUCT_NUM=0xfada +CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_DM_VIDEO=y +# CONFIG_VIDEO_BPP8 is not set +# CONFIG_VIDEO_BPP16 is not set +CONFIG_SYS_WHITE_ON_BLACK=y +CONFIG_VIDEO_MESON=y +CONFIG_VIDEO_DT_SIMPLEFB=y +CONFIG_OF_LIBFDT_OVERLAY=y
Changes since v1:
Seems you had a patch issue, the following patches are the same as v1
Neil
Changes since v1:
Ugh indeed, sorry about that
Neil
Jerome Brunet
Neil Armstrong
