[U-Boot] [PATCH 1/1] usb: host: xhci-dwc3: add missing #ifdef CONFIG_PHY
To avoid compilation breakage on platform that don't support DM PHY, add the missing CONFIG_PHY flag.
Introduced by patch : 84e53877 "usb: host: xhci-dwc3: Add generic PHY support"
Cc: Ran Wang ran.wang_1@nxp.com Cc: Bin Meng bmeng.cn@gmail.com
Signed-off-by: Patrice Chotard patrice.chotard@st.com --- drivers/usb/host/xhci-dwc3.c | 13 ++++++++++++- 1 file changed, 12 insertions(+), 1 deletion(-)
diff --git a/drivers/usb/host/xhci-dwc3.c b/drivers/usb/host/xhci-dwc3.c index 374fe74..e34f937 100644 --- a/drivers/usb/host/xhci-dwc3.c +++ b/drivers/usb/host/xhci-dwc3.c @@ -21,9 +21,11 @@
DECLARE_GLOBAL_DATA_PTR;
+#ifdef CONFIG_PHY struct xhci_dwc3_platdata { struct phy usb_phy; }; +#endif
void dwc3_set_mode(struct dwc3 *dwc3_reg, u32 mode) { @@ -113,17 +115,21 @@ void dwc3_set_fladj(struct dwc3 *dwc3_reg, u32 val)
static int xhci_dwc3_probe(struct udevice *dev) { +#ifdef CONFIG_PHY struct xhci_dwc3_platdata *plat = dev_get_platdata(dev); +#endif struct xhci_hcor *hcor; struct xhci_hccr *hccr; struct dwc3 *dwc3_reg; enum usb_dr_mode dr_mode; - int ret;
hccr = (struct xhci_hccr *)devfdt_get_addr(dev); hcor = (struct xhci_hcor *)((phys_addr_t)hccr + HC_LENGTH(xhci_readl(&(hccr)->cr_capbase)));
+#ifdef CONFIG_PHY + int ret; + ret = generic_phy_get_by_index(dev, 0, &plat->usb_phy); if (ret) { if (ret != -ENOENT) { @@ -137,6 +143,7 @@ static int xhci_dwc3_probe(struct udevice *dev) return ret; } } +#endif
dwc3_reg = (struct dwc3 *)((char *)(hccr) + DWC3_REG_OFFSET);
@@ -154,6 +161,7 @@ static int xhci_dwc3_probe(struct udevice *dev)
static int xhci_dwc3_remove(struct udevice *dev) { +#ifdef CONFIG_PHY struct xhci_dwc3_platdata *plat = dev_get_platdata(dev); int ret;
@@ -164,6 +172,7 @@ static int xhci_dwc3_remove(struct udevice *dev) return ret; } } +#endif
return xhci_deregister(dev); } @@ -181,6 +190,8 @@ U_BOOT_DRIVER(xhci_dwc3) = { .remove = xhci_dwc3_remove, .ops = &xhci_usb_ops, .priv_auto_alloc_size = sizeof(struct xhci_ctrl), +#ifdef CONFIG_PHY .platdata_auto_alloc_size = sizeof(struct xhci_dwc3_platdata), +#endif .flags = DM_FLAG_ALLOC_PRIV_DMA, };
Can we fix this _without_ introducing boatload of ifdefs throughout the code ?
int ret;
+#ifdef CONFIG_PHY
- int ret;
- ret = generic_phy_get_by_index(dev, 0, &plat->usb_phy); if (ret) { if (ret != -ENOENT) {
Hi Marek
You mean fix directly in phy framework ? I will check that ....
Patrice
int ret;
+#ifdef CONFIG_PHY
- int ret;
On 07/20/2017 01:48 PM, Patrice CHOTARD wrote:
Hi Marek
Possibly
Patrice CHOTARD
