[U-Boot-Users] libgcc.a uses VFP instructions, whereas u -boot does not
The version of the u-boot is u-boot-1.1.4 and the version of the tool chain is 3.4.3 when I compile the u-boot , the following error is displayed:
arm-linux-ld: ERROR: /usr/local/arm-linux/lib/gcc/arm-linux/3.4.3/libgcc.a(_divsi3.oS) uses VFP instructions, whereas u-boot does not File in wrong format: failed to merge target specific data of file /usr/local/arm-linux/lib/gcc/arm-linux/3.4.3/libgcc.a(_divsi3.oS) arm-linux-ld: ERROR: /usr/local/arm-linux/lib/gcc/arm-linux/3.4.3/libgcc.a(_modsi3.oS) uses VFP instructions, whereas u-boot does not File in wrong format: failed to merge target specific data of file /usr/local/arm-linux/lib/gcc/arm-linux/3.4.3/libgcc.a(_modsi3.oS) make: *** [u-boot] Error 1
Then who can tell me how to fix up this problem? Thank you in advance! Zhang
Old source code, and an even older tool chain.
These are your first two errors.
Use a working toolchain?
--Boundary-=_QWqwfkxXvJolKvsSsOVYgWhmSXcn Content-Type: text/html; charset="gb2312" Content-Transfer-Encoding: quoted-printable
<div>The version of the u-boot is u-boot-1.1.4 and the version of the too=
And NEVER post HTML here, please.
zhangqh0528@126.com
