[PATCH 1/1] cli: always show cursor
We may enter the command line interface in a state where on the remote console the cursor is not shown. Send an escape sequence to enable it.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- common/main.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/common/main.c b/common/main.c index 682f3359ea..4e7e7b17d6 100644 --- a/common/main.c +++ b/common/main.c @@ -7,6 +7,7 @@ /* #define DEBUG */
#include <common.h> +#include <ansi.h> #include <autoboot.h> #include <bootstage.h> #include <cli.h> @@ -66,6 +67,9 @@ void main_loop(void)
autoboot_command(s);
+ if (!CONFIG_IS_ENABLED(DM_VIDEO) || CONFIG_IS_ENABLED(VIDEO_ANSI)) + printf(ANSI_CURSOR_SHOW "\n"); + cli_loop(); panic("No CLI available"); }
Hi Heinrich,
On Sat, 22 Oct 2022 at 03:21, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
Could we create a library which emits these codes? Like ansi_cursor_show() ?
2.37.2
On 10/26/22 01:35, Simon Glass wrote:
Hi Heinrich,
The question is not if we could but if we should.
Up to now we tried to call printf() only once where ANSI_* is only one part of the output string.
E.g. cmd/eficonfig.c:415: printf(ANSI_CLEAR_CONSOLE ANSI_CURSOR_POSITION ANSI_CURSOR_SHOW, 1, 1);
This minimizes the number of call library calls but may not be very elegant.
Creating a library function for ANSI_CURSOR_SHOW alone does not make much sense to me. Should you want to convert our code base from using ANSI_* to library functions this should cover the whole code base.
So I think we should let this patch pass as it solves a current problem and leave creating a ANSI_* function library to a separate exercise.
Best regards
Heinrich
}cli_loop(); panic("No CLI available");
-- 2.37.2
Hi Heinrich,
On Wed, 26 Oct 2022 at 00:13, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
Hi Heinrich,
Then we should add this to the serial API...what we have here is quite bizarre in a way, since it outputs escape characters as the default for U-Boot. Mostly we don't need it.
So add a set_cursor_visible() method to the serial API and allow it to be controlled via platform data in the serial driver.
Regards, SImon
On 10/27/22 17:22, Simon Glass wrote:
Hi Heinrich,
Hi Heinrich,
I have no clue which platform data you might be thinking of.
It is also not my intention to eject the escape sequence whenever a serial console is probed.
Using serial_puts() in this patch instead of printf() would help to avoid the CONFIG dependency.
Best regards
Heinrich
Regards, SImon
Hi Heinrich,
On Thu, 27 Oct 2022 at 10:41, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
Hi Heinrich,
Hi Heinrich,
Here's what should happen:
1. ANSI codes should not appear in logs or on CI (this is currently a problem with EFI tests) 2. We cannot show an ANSI code on boot by default, since that puts ctrl characters into every start-up of U-Boot
So I think my suggestion makes sense. See drivers/serial/sandbox.c and have a way of calling isatty() to check the terminal type (with a cmdline flag to override it, see -t for example). Then we can get the correct behaviour.
On 10/30/22 02:43, Simon Glass wrote:
Hi Heinrich,
Hi Heinrich,
Hi Heinrich,
#include <common.h>
- ANSI codes should not appear in logs or on CI (this is currently a
A program outputting different things in continuous integration then in real live does not provide realistic testing.
It is the CI that has to adapt not the program under test.
Which logs are you talking about?
- We cannot show an ANSI code on boot by default, since that puts
Why would that be a problem?
isatty() is not a U-Boot function. So it is irrelevant in this context.
You cannot detect if a serial console understands ANSI sequences without sending any.
Best regards
Heinrich
Hi Heinrich,
On Sat, 29 Oct 2022 at 20:56, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
Hi Heinrich,
Hi Heinrich,
Hi Heinrich,
On Sat, 22 Oct 2022 at 03:21, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote: > > We may enter the command line interface in a state where on the remote > console the cursor is not shown. Send an escape sequence to enable it. > > Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com > --- > common/main.c | 4 ++++ > 1 file changed, 4 insertions(+) > > diff --git a/common/main.c b/common/main.c > index 682f3359ea..4e7e7b17d6 100644 > --- a/common/main.c > +++ b/common/main.c > @@ -7,6 +7,7 @@ > /* #define DEBUG */ > > #include <common.h> > +#include <ansi.h> > #include <autoboot.h> > #include <bootstage.h> > #include <cli.h> > @@ -66,6 +67,9 @@ void main_loop(void) > > autoboot_command(s); > > + if (!CONFIG_IS_ENABLED(DM_VIDEO) || CONFIG_IS_ENABLED(VIDEO_ANSI)) > + printf(ANSI_CURSOR_SHOW "\n");
NAK
Please try a little harder to understand my POV above.
On 10/31/22 20:27, Simon Glass wrote:
Hi Heinrich,
Hi Heinrich,
Hi Heinrich,
On 10/26/22 01:35, Simon Glass wrote: > Hi Heinrich, > > On Sat, 22 Oct 2022 at 03:21, Heinrich Schuchardt > heinrich.schuchardt@canonical.com wrote: >> >> We may enter the command line interface in a state where on the remote >> console the cursor is not shown. Send an escape sequence to enable it. >> >> Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com >> --- >> common/main.c | 4 ++++ >> 1 file changed, 4 insertions(+) >> >> diff --git a/common/main.c b/common/main.c >> index 682f3359ea..4e7e7b17d6 100644 >> --- a/common/main.c >> +++ b/common/main.c >> @@ -7,6 +7,7 @@ >> /* #define DEBUG */ >> >> #include <common.h> >> +#include <ansi.h> >> #include <autoboot.h> >> #include <bootstage.h> >> #include <cli.h> >> @@ -66,6 +67,9 @@ void main_loop(void) >> >> autoboot_command(s); >> >> + if (!CONFIG_IS_ENABLED(DM_VIDEO) || CONFIG_IS_ENABLED(VIDEO_ANSI)) >> + printf(ANSI_CURSOR_SHOW "\n"); > > Could we create a library which emits these codes? Like ansi_cursor_show() ?
NAK
I don't understand what your point of view as you did not answer my question.
The only case of logs being written in a production U-Boot is given by CONGIG_LOG_SYSLOG=y which is not affected by the patch. So no clue what logs you refer to.
Concerning CI it is clear that the CI has to handle ANSI sequences in the U-Boot output sensibly. The idea of U-Boot producing different output running in CI than outside CI would contradict the purpose of the CI.
I further have no clue what problem you face with the output of the EFI unit tests. Could you, please, be more specific.
Best regards
Heinrich
Hi Heinrich,
On Mon, 31 Oct 2022 at 15:58, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
Hi Heinrich,
Hi Heinrich,
Hi Heinrich,
On Wed, 26 Oct 2022 at 00:13, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote: > > > > On 10/26/22 01:35, Simon Glass wrote: >> Hi Heinrich, >> >> On Sat, 22 Oct 2022 at 03:21, Heinrich Schuchardt >> heinrich.schuchardt@canonical.com wrote: >>> >>> We may enter the command line interface in a state where on the remote >>> console the cursor is not shown. Send an escape sequence to enable it. >>> >>> Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com >>> --- >>> common/main.c | 4 ++++ >>> 1 file changed, 4 insertions(+) >>> >>> diff --git a/common/main.c b/common/main.c >>> index 682f3359ea..4e7e7b17d6 100644 >>> --- a/common/main.c >>> +++ b/common/main.c >>> @@ -7,6 +7,7 @@ >>> /* #define DEBUG */ >>> >>> #include <common.h> >>> +#include <ansi.h> >>> #include <autoboot.h> >>> #include <bootstage.h> >>> #include <cli.h> >>> @@ -66,6 +67,9 @@ void main_loop(void) >>> >>> autoboot_command(s); >>> >>> + if (!CONFIG_IS_ENABLED(DM_VIDEO) || CONFIG_IS_ENABLED(VIDEO_ANSI)) >>> + printf(ANSI_CURSOR_SHOW "\n"); >> >> Could we create a library which emits these codes? Like ansi_cursor_show() ? > > The question is not if we could but if we should. > > Up to now we tried to call printf() only once where ANSI_* is only one > part of the output string. > > E.g. cmd/eficonfig.c:415: > printf(ANSI_CLEAR_CONSOLE > ANSI_CURSOR_POSITION > ANSI_CURSOR_SHOW, 1, 1); > > This minimizes the number of call library calls but may not be very elegant. > > Creating a library function for ANSI_CURSOR_SHOW alone does not make > much sense to me. Should you want to convert our code base from using > ANSI_* to library functions this should cover the whole code base. > > So I think we should let this patch pass as it solves a current problem > and leave creating a ANSI_* function library to a separate exercise.
NAK
If you run the tests (e.g. make check) and get a failure you can see the output from them on the console. At the moment some tests clear the console, change colour and all sorts of things. That is not good behaviour. Can you see that?
Have you actually looked at the CI output? I am attaching it at the end of this email so you can see it.
That is a whole other topic. We definitely need more C tests and fewer of these large Python end-to-end tests.
But for now, all I am saying is that ANSI characters should not be output in CI. For sandbox they can be output but only if sending to a terminal, or specifically enabled with a flag. Tests that clear the console or output thousands of lines of gibberish output are not acceptable in my book.
output:
$ pyt eficonfig ================================================ test session starts ================================================= platform linux -- Python 3.10.6, pytest-6.2.5, py-1.10.0, pluggy-0.13.0 rootdir: /scratch/sglass/cosarm/src/third_party/u-boot/files/test/py, configfile: pytest.ini plugins: hypothesis-6.36.0, forked-1.4.0, xdist-2.5.0 collected 1022 items / 1021 deselected / 1 selected
test/py/tests/test_eficonfig/test_eficonfig.py F [100%]
** UEFI Maintenance Menu **
Add Boot Option Edit Boot Option Change Boot Order Delete Boot Option Quit
====================================================== FAILURES ====================================================== _________________________________________________ test_efi_eficonfig _________________________________________________ test/py/tests/test_eficonfig/test_eficonfig.py:352: in test_efi_eficonfig assert False E assert False ----------------------------------------------- Captured stdout setup ------------------------------------------------ /u-boot Creating new bloblist size 400 at c000 sandbox_serial serial: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19
U-Boot 2022.10-00013-g695b6238212-dirty (Oct 29 2022 - 17:59:55 -0600)
Reset Status: WARM Reset Status: COLD Model: sandbox DRAM: 256 MiB single-pinctrl pinctrl-single-no-width: missing register width Core: 258 devices, 95 uclasses, devicetree: board WDT: Not starting wdt-gpio-toggle wdt_gpio wdt-gpio-level: Request for wdt gpio failed: -16 WDT: Not starting wdt@0 MMC: mmc2: 2 (SD), mmc1: 1 (SD), mmc0: 0 (SD) Loading Environment from nowhere... OK In: cros-ec-keyb Out: vidconsole Err: vidconsole Model: sandbox Net: eth0: eth@10002000, eth5: eth@10003000, eth3: sbe5, eth6: eth@10004000, eth8: phy-test-eth, eth4: dsa-test-eth, eth2: lan0, eth7: lan1 Hit any key to stop autoboot: 0 => ------------------------------------------------ Captured stdout call ------------------------------------------------ /u-boot Creating new bloblist size 400 at c000 sandbox_serial serial: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19
Reset Status: WARM Reset Status: COLD Model: sandbox DRAM: 256 MiB single-pinctrl pinctrl-single-no-width: missing register width Core: 258 devices, 95 uclasses, devicetree: board WDT: Not starting wdt-gpio-toggle wdt_gpio wdt-gpio-level: Request for wdt gpio failed: -16 WDT: Not starting wdt@0 MMC: mmc2: 2 (SD), mmc1: 1 (SD), mmc0: 0 (SD) Loading Environment from nowhere... OK In: cros-ec-keyb Out: vidconsole Err: vidconsole Model: sandbox Net: eth0: eth@10002000, eth5: eth@10003000, eth3: sbe5, eth6: eth@10004000, eth8: phy-test-eth, eth4: dsa-test-eth, eth2: lan0, eth7: lan1 Hit any key to stop autoboot: 0 => => eficonfig ** Bad device specification host 0 ** Couldn't find partition host 0:0 Cannot read EFI system partition
Press UP/DOWN to move, ENTER to select, ESC/CTRL+C to quit
** Add Boot Option **
Description: File: Initrd File: Optional Data: Save Quit
=> => host bind 0 /tmp/b/sandbox/persistent-data/efi_eficonfig.img => => eficonfig Cannot read EFI system partition Failed to persist EFI variables Cannot read EFI system partition Failed to persist EFI variables
** Change Boot Order **
[*] host 0:1 Save Quit
Press UP/DOWN to move, +/- to change order Press SPACE to activate or deactivate the entry Select [Save] to complete, ESC/CTRL+C to quit
[ ] host 0:1 Save Quit
[ ] host 0:1 Save QuitCannot read EFI system partition Failed to persist EFI variables Press UP/DOWN to move, +/- to change order Press SPACE to activate or deactivate the entry Select [Save] to complete, ESC/CTRL+C to quit
** Edit Description **
enter description: test 1
Press ENTER to complete, ESC/CTRL+C to quit
Description: test 1 File: Initrd File: Optional Data: Save Quit
** Update File **
Select File Clear Quit
** Select Volume **
host 0:1 Quit
** Select File **
initrd-1.img initrd-2.img initrddump.efi Quit
Description: test 1 File: host 0:1/initrddump.efi Initrd File: Optional Data: Save Quit
** Update File **
** Select Volume **
host 0:1 Quit
** Select File **
Description: test 1 File: host 0:1/initrddump.efi Initrd File: host 0:1/initrd-1.img Optional Data: Save Quit
** Edit Optional Data **
enter optional data: nocolor
Description: test 1 File: host 0:1/initrddump.efi Initrd File: host 0:1/initrd-1.img Optional Data: nocolor Save Quit
=> => bootefi bootmgr Booting: test 1
INITRD Dump ===========
=> => load length: 0x8 crc32: 0x181464af => => exit
=> => eficonfig
enter description: test 2
Description: test 2 File: Initrd File: Optional Data: Save Quit
** Update File **
** Select Volume **
host 0:1 Quit
** Select File **
Description: test 2 File: host 0:1/initrddump.efi Initrd File: Optional Data: Save Quit
** Update File **
** Select Volume **
host 0:1 Quit
** Select File **
Description: test 2 File: host 0:1/initrddump.efi Initrd File: host 0:1/initrd-2.img Optional Data: Save Quit
Description: test 2 File: host 0:1/initrddump.efi Initrd File: host 0:1/initrd-2.img Optional Data: nocolor Save Quit
[*] test 1 [*] test 2 [ ] host 0:1 Save Quit
[*] test 2 [*] test 1 [ ] host 0:1 Save Quit
[*] test 2 [*] test 1 [ ] host 0:1 Save QuitCannot read EFI system partition Failed to persist EFI variables Press UP/DOWN to move, +/- to change order Press SPACE to activate or deactivate the entry Select [Save] to complete, ESC/CTRL+C to quit
=> => bootefi bootmgr Booting: test 2
=> => load length: 0x8 crc32: 0x811d3515 => => exit
=> => eficonfig
[*] test 1 [*] test 2 [ ] host 0:1 Save QuitCannot read EFI system partition Failed to persist EFI variables Press UP/DOWN to move, +/- to change order Press SPACE to activate or deactivate the entry Select [Save] to complete, ESC/CTRL+C to quit
=> => eficonfig
** Select Boot Option **
test 1 test 2 Quit
test 1 Quit
=> => eficonfig
test 1 Quit
** Edit Boot Option **
enter description: test 3
Description: test 3 File: host 0:1/initrddump.efi Initrd File: host 0:1/initrd-1.img Optional Data: nocolor Save Quit
** Update File **
** Select Volume **
host 0:1 Quit
** Select File **
** Update File **
** Select Volume **
host 0:1 Quit
** Select File **
Description: test 3 File: host 0:1/initrddump.efi Initrd File: host 0:1/initrd-2.img Optional Data: nocolor Save Quit
Description: test 3 File: host 0:1/initrddump.efi Initrd File: host 0:1/initrd-2.img Optional Data: Save Quit
test 3 Quit
=> => bootefi bootmgr Booting: test 3
=> => eficonfig
test 3 Quit
Quit
=> => host bind -r 0 => => eficonfig
** Update File **
No block device found!
Press any key to continue ============================================== short test summary info =============================================== FAILED test/py/tests/test_eficonfig/test_eficonfig.py::test_efi_eficonfig - assert False ========================================= 1 failed, 1021 deselected in 5.98s ========================================= ^[[33;118R1 (<detached:remotes/us/master=a90af test/ cspell.json u.code-workspace) sglass@ELLESMERE ~/u> ;118R
On 11/1/22 00:52, Simon Glass wrote:
Hi Heinrich,
Hi Heinrich,
Hi Heinrich,
On 10/27/22 17:22, Simon Glass wrote: > Hi Heinrich, > > On Wed, 26 Oct 2022 at 00:13, Heinrich Schuchardt > heinrich.schuchardt@canonical.com wrote: >> >> >> >> On 10/26/22 01:35, Simon Glass wrote: >>> Hi Heinrich, >>> >>> On Sat, 22 Oct 2022 at 03:21, Heinrich Schuchardt >>> heinrich.schuchardt@canonical.com wrote: >>>> >>>> We may enter the command line interface in a state where on the remote >>>> console the cursor is not shown. Send an escape sequence to enable it. >>>> >>>> Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com >>>> --- >>>> common/main.c | 4 ++++ >>>> 1 file changed, 4 insertions(+) >>>> >>>> diff --git a/common/main.c b/common/main.c >>>> index 682f3359ea..4e7e7b17d6 100644 >>>> --- a/common/main.c >>>> +++ b/common/main.c >>>> @@ -7,6 +7,7 @@ >>>> /* #define DEBUG */ >>>> >>>> #include <common.h> >>>> +#include <ansi.h> >>>> #include <autoboot.h> >>>> #include <bootstage.h> >>>> #include <cli.h> >>>> @@ -66,6 +67,9 @@ void main_loop(void) >>>> >>>> autoboot_command(s); >>>> >>>> + if (!CONFIG_IS_ENABLED(DM_VIDEO) || CONFIG_IS_ENABLED(VIDEO_ANSI)) >>>> + printf(ANSI_CURSOR_SHOW "\n"); >>> >>> Could we create a library which emits these codes? Like ansi_cursor_show() ? >> >> The question is not if we could but if we should. >> >> Up to now we tried to call printf() only once where ANSI_* is only one >> part of the output string. >> >> E.g. cmd/eficonfig.c:415: >> printf(ANSI_CLEAR_CONSOLE >> ANSI_CURSOR_POSITION >> ANSI_CURSOR_SHOW, 1, 1); >> >> This minimizes the number of call library calls but may not be very elegant. >> >> Creating a library function for ANSI_CURSOR_SHOW alone does not make >> much sense to me. Should you want to convert our code base from using >> ANSI_* to library functions this should cover the whole code base. >> >> So I think we should let this patch pass as it solves a current problem >> and leave creating a ANSI_* function library to a separate exercise. > > Then we should add this to the serial API...what we have here is quite > bizarre in a way, since it outputs escape characters as the default > for U-Boot. Mostly we don't need it. > > So add a set_cursor_visible() method to the serial API and allow it to > be controlled via platform data in the serial driver.
NAK
None of the tests in lib/efi_selftests clears the screen. To provide better readability they use colored output which should not pose any problem if your console in ANSI enabled. To view logs with ANSI colors correctly displayed just use the 'less -rf' command.
For the bootmenu there is a test that invokes the bootmenu command which clears the screen. This is unavoidable for testing. Inside the CI that does not cause problems bug you may dislike it when running the tests manually. We could think of adding some property to the test to allow you to exclude the test more easily.
In the log I see no gibberish but the actual screen output. If you think the output is too verbose, we must find a way to exclude the test.
Best regards
Heinrich
Hi Heinrich,
On Tue, 1 Nov 2022 at 03:03, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
Hi Heinrich,
Hi Heinrich,
Hi Heinrich,
On Thu, 27 Oct 2022 at 10:41, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote: > > > > On 10/27/22 17:22, Simon Glass wrote: >> Hi Heinrich, >> >> On Wed, 26 Oct 2022 at 00:13, Heinrich Schuchardt >> heinrich.schuchardt@canonical.com wrote: >>> >>> >>> >>> On 10/26/22 01:35, Simon Glass wrote: >>>> Hi Heinrich, >>>> >>>> On Sat, 22 Oct 2022 at 03:21, Heinrich Schuchardt >>>> heinrich.schuchardt@canonical.com wrote: >>>>> >>>>> We may enter the command line interface in a state where on the remote >>>>> console the cursor is not shown. Send an escape sequence to enable it. >>>>> >>>>> Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com >>>>> --- >>>>> common/main.c | 4 ++++ >>>>> 1 file changed, 4 insertions(+) >>>>> >>>>> diff --git a/common/main.c b/common/main.c >>>>> index 682f3359ea..4e7e7b17d6 100644 >>>>> --- a/common/main.c >>>>> +++ b/common/main.c >>>>> @@ -7,6 +7,7 @@ >>>>> /* #define DEBUG */ >>>>> >>>>> #include <common.h> >>>>> +#include <ansi.h> >>>>> #include <autoboot.h> >>>>> #include <bootstage.h> >>>>> #include <cli.h> >>>>> @@ -66,6 +67,9 @@ void main_loop(void) >>>>> >>>>> autoboot_command(s); >>>>> >>>>> + if (!CONFIG_IS_ENABLED(DM_VIDEO) || CONFIG_IS_ENABLED(VIDEO_ANSI)) >>>>> + printf(ANSI_CURSOR_SHOW "\n"); >>>> >>>> Could we create a library which emits these codes? Like ansi_cursor_show() ? >>> >>> The question is not if we could but if we should. >>> >>> Up to now we tried to call printf() only once where ANSI_* is only one >>> part of the output string. >>> >>> E.g. cmd/eficonfig.c:415: >>> printf(ANSI_CLEAR_CONSOLE >>> ANSI_CURSOR_POSITION >>> ANSI_CURSOR_SHOW, 1, 1); >>> >>> This minimizes the number of call library calls but may not be very elegant. >>> >>> Creating a library function for ANSI_CURSOR_SHOW alone does not make >>> much sense to me. Should you want to convert our code base from using >>> ANSI_* to library functions this should cover the whole code base. >>> >>> So I think we should let this patch pass as it solves a current problem >>> and leave creating a ANSI_* function library to a separate exercise. >> >> Then we should add this to the serial API...what we have here is quite >> bizarre in a way, since it outputs escape characters as the default >> for U-Boot. Mostly we don't need it. >> >> So add a set_cursor_visible() method to the serial API and allow it to >> be controlled via platform data in the serial driver. > > I have no clue which platform data you might be thinking of. > > It is also not my intention to eject the escape sequence whenever a > serial console is probed. > > Using serial_puts() in this patch instead of printf() would help to > avoid the CONFIG dependency.
NAK
Running less separately is too fiddly. It should show up properly in gitlab as other tests do. This needs to be designed for humans, not computers. That is my criticism of so much of the EFI stuff.
The test should not clear the screen. All of that ANSI stuff should be suppressed (by default) when testing
About 4000 of the 4600 lines are blank!
Here is what I think you should do: - add a flag to sandbox (like the existing -t) which tells U-Boot whether to send ANSI output to serial output -a auto - use ANSI output if a terminal is detected (isatty()) - this should be the default -a ansi - output ANSI always -a none - don't output ANSI - flag is checked in sandbox serial driver, like -t is now - can create per-device uclass data containing the setting, so all serial drivers are affected - the ANSI stuff is handled in the serial driver with a new call added to struct dm_serial_ops - ANSI sequences are handled in C so they can be sent or not sent (perhaps there is a clever way of using printf() format characters like %sC to clear the screen?)
- if (!CONFIG_IS_ENABLED(DM_VIDEO) || CONFIG_IS_ENABLED(VIDEO_ANSI))
I think that this does not work anymore. Support for "h"/"l" ansi escape sequences to show and hide cursor was removed from U-Boot together with cfg_console.c driver done by Simon for v2022.07 version.
Now I verified that cursor is really permanently turned off (meaning unsupported) on Nokia N900 even when CONFIG_VIDEO_ANSI is enabled.
So prior adding ANSI_CURSOR_SHOW on new places, I would suggest to first revert and implement functions for showing and hiding cursor.
- cli_loop(); panic("No CLI available");
2.37.2
Pali Rohár
