[U-Boot] [PATCH] ppc4xx: Fix SDRAM inititialization of multiple 405 based board ports
This patch fixes a problem introdiced with patch bbeff30c [ppc4xx: Remove superfluous dram_init() call or replace it by initdram()].
The boards affected are: - PCI405 - PPChameleonEVB - quad100hd - taihu - zeus
Signed-off-by: Stefan Roese sr@denx.de --- board/amcc/taihu/taihu.c | 9 -------- board/dave/PPChameleonEVB/PPChameleonEVB.c | 25 ---------------------- board/esd/pci405/pci405.c | 31 ---------------------------- board/quad100hd/quad100hd.c | 5 ---- board/zeus/zeus.c | 23 -------------------- cpu/ppc4xx/sdram.c | 14 +++++++++--- include/configs/quad100hd.h | 1 - 7 files changed, 10 insertions(+), 98 deletions(-)
diff --git a/board/amcc/taihu/taihu.c b/board/amcc/taihu/taihu.c index 266f260..ee0939a 100644 --- a/board/amcc/taihu/taihu.c +++ b/board/amcc/taihu/taihu.c @@ -78,15 +78,6 @@ int checkboard(void) return 0; }
-/************************************************************************* - * phys_size_t initdram - * - ************************************************************************/ -phys_size_t initdram(int board) -{ - return CFG_SDRAM_SIZE_PER_BANK * CFG_SDRAM_BANKS; /* 128Mbytes */ -} - static int do_sw_stat(cmd_tbl_t* cmd_tp, int flags, int argc, char *argv[]) { char stat; diff --git a/board/dave/PPChameleonEVB/PPChameleonEVB.c b/board/dave/PPChameleonEVB/PPChameleonEVB.c index c9b288a..c715ad4 100644 --- a/board/dave/PPChameleonEVB/PPChameleonEVB.c +++ b/board/dave/PPChameleonEVB/PPChameleonEVB.c @@ -203,31 +203,6 @@ int checkboard (void)
-phys_size_t initdram (int board_type) -{ - unsigned long val; - - mtdcr(memcfga, mem_mb0cf); - val = mfdcr(memcfgd); - -#if 0 /* test-only */ - for (;;) { - NAND_DISABLE_CE(1); - udelay(100); - NAND_ENABLE_CE(1); - udelay(100); - } -#endif -#if 0 - printf("\nmb0cf=%x\n", val); /* test-only */ - printf("strap=%x\n", mfdcr(strap)); /* test-only */ -#endif - - return (4*1024*1024 << ((val & 0x000e0000) >> 17)); -} - -/* ------------------------------------------------------------------------- */ - int testdram (void) { /* TODO: XXX XXX XXX */ diff --git a/board/esd/pci405/pci405.c b/board/esd/pci405/pci405.c index f740d59..f8d7c28 100644 --- a/board/esd/pci405/pci405.c +++ b/board/esd/pci405/pci405.c @@ -357,37 +357,6 @@ int checkboard (void) }
/* ------------------------------------------------------------------------- */ - -phys_size_t initdram (int board_type) -{ - unsigned long val; - - mtdcr(memcfga, mem_mb0cf); - val = mfdcr(memcfgd); - -#if 0 - printf("\nmb0cf=%x\n", val); /* test-only */ - printf("strap=%x\n", mfdcr(strap)); /* test-only */ -#endif - -#if 0 /* test-only: all PCI405 version must report 16mb */ - return (4*1024*1024 << ((val & 0x000e0000) >> 17)); -#else - return (16*1024*1024); -#endif -} - -/* ------------------------------------------------------------------------- */ - -int testdram (void) -{ - /* TODO: XXX XXX XXX */ - printf ("test: 16 MB - ok\n"); - - return (0); -} - -/* ------------------------------------------------------------------------- */ int wpeeprom(int wp) { int wp_state = wp; diff --git a/board/quad100hd/quad100hd.c b/board/quad100hd/quad100hd.c index 8118678..ffc47de 100644 --- a/board/quad100hd/quad100hd.c +++ b/board/quad100hd/quad100hd.c @@ -86,8 +86,3 @@ int checkboard(void)
return 0; } - -phys_size_t initdram(int board_type) -{ - return CFG_SDRAM_SIZE; -} diff --git a/board/zeus/zeus.c b/board/zeus/zeus.c index 33d971a..2a4ec5c 100644 --- a/board/zeus/zeus.c +++ b/board/zeus/zeus.c @@ -190,29 +190,6 @@ int checkboard(void) return (0); }
-static u32 detect_sdram_size(void) -{ - u32 val; - u32 size; - - mfsdram(mem_mb0cf, val); - size = (4 << 20) << ((val & 0x000e0000) >> 17); - - /* - * Check if 2nd bank is enabled too - */ - mfsdram(mem_mb1cf, val); - if (val & 1) - size += (4 << 20) << ((val & 0x000e0000) >> 17); - - return size; -} - -phys_size_t initdram (int board_type) -{ - return detect_sdram_size(); -} - static int default_env_var(char *buf, char *var) { char *ptr; diff --git a/cpu/ppc4xx/sdram.c b/cpu/ppc4xx/sdram.c index 7d60ad6..b5a6a4c 100644 --- a/cpu/ppc4xx/sdram.c +++ b/cpu/ppc4xx/sdram.c @@ -209,15 +209,15 @@ phys_size_t initdram(int board_type) udelay(10000);
if (get_ram_size(0, mb0cf[i].size) == mb0cf[i].size) { + phys_size_t size = mb0cf[i].size; + /* * OK, size detected. Enable second bank if * defined (assumes same type as bank 0) */ #ifdef CONFIG_SDRAM_BANK1 - u32 b1cr = mb0cf[i].size | mb0cf[i].reg; - mtsdram(mem_mcopt1, 0x00000000); - mtsdram(mem_mb1cf, b1cr); /* SDRAM0_B1CR */ + mtsdram(mem_mb1cf, mb0cf[i].size | mb0cf[i].reg); mtsdram(mem_mcopt1, 0x80800000); udelay(10000);
@@ -230,13 +230,19 @@ phys_size_t initdram(int board_type) mb0cf[i].size) { mtsdram(mem_mb1cf, 0); mtsdram(mem_mcopt1, 0); + } else { + /* + * We have two identical banks, so the size + * is twice the bank size + */ + size = 2 * size; } #endif
/* * OK, size detected -> all done */ - return mb0cf[i].size; + return size; } }
diff --git a/include/configs/quad100hd.h b/include/configs/quad100hd.h index d464734..c41f5c9 100644 --- a/include/configs/quad100hd.h +++ b/include/configs/quad100hd.h @@ -82,7 +82,6 @@ * SDRAM configuration (please see cpu/ppc/sdram.[ch]) */ #define CONFIG_SDRAM_BANK0 1 -#define CFG_SDRAM_SIZE 0x02000000 /* 32 MB */
/* FIX! SDRAM timings used in datasheet */ #define CFG_SDRAM_CL 3 /* CAS latency */
- PCI405
- PPChameleonEVB
- quad100hd
- taihu
- zeus
Looks good for PCI405.
Acked-by: Matthias Fuchs matthias.fuchs@esd-electronics.com
- phys_size_t initdram
- for (;;) {
NAND_DISABLE_CE(1);
udelay(100);
NAND_ENABLE_CE(1);
udelay(100);
-#endif -#if 0
-#endif
-#if 0
-#endif
-#else
-#endif -}
- return (0);
return 0; }
- u32 val;
- u32 size;
- if (val & 1)
- return size;
} else {
size = 2 * size; }
#endif
} }return size;
- SDRAM configuration (please see cpu/ppc/sdram.[ch])
Matthias Fuchs
Stefan Roese
