[U-Boot-Users] Help with serial port set-up for PPC 8540
Hi I am trying to write an Assembly code , just to set-up the UART , so as to send a few characters via the serial port.
I am working on a 8540 Motorola PowerPC . As I am starting right from the scratch I dont have the boot -loader doing the board initializations for me and so have to have my own start.S file to do those .
I just have set-up the necessary registers for UART and as I am not doing any high level coding I havent set up the MMU , TLB etc. But my code doesnt seem to work !!!
I assumed that that CPU would direclty read from the Flash .I am new to this and so I need some advise of what all have to be done during board bring up, or where should I look for such documentation.
Any help would be appreciated .
Thanks Junita
__________________________________ Do you Yahoo!? Take Yahoo! Mail with you! Get it on your mobile phone. http://mobile.yahoo.com/maildemo
Why? There is a full-blown serial driver available written in C? Is this intended as a replacement for a missing BDI2000? Save your time, abd buy the BDI2000 _now_. Other wise your time is just wasted, as you will buy the BDI2000 later anyway.
Forget it. U-Boot was explicitely designed to bring up a serial console port as early as possible during initialization. OK, there are a few things that could be saved before running the serial driver, but this is just a tiny piece of the code you need to get right before you will see the first character on the serial line.
Don't try to re-invent the wheel.
Use the existing U-Boot code. Attach a BDI2000 and just type "ti" at the telnet prompt, or "d/i $pc" + "si" in GDB...
Junita Ajith
