[U-Boot] [PATCH 1/2] mx6: Select MX6QDL option via Kconfig
Currently the MX6QDL option is selected via CONFIG_SYS_EXTRA_OPTIONS, but it is better to select it directly via Kconfig.
Signed-off-by: Fabio Estevam fabio.estevam@nxp.com --- arch/arm/mach-imx/mx6/Kconfig | 11 +++++++++++ configs/cgtqmx6eval_defconfig | 2 +- configs/cm_fx6_defconfig | 2 +- configs/dh_imx6_defconfig | 2 +- configs/gwventana_emmc_defconfig | 2 +- configs/gwventana_gw5904_defconfig | 2 +- configs/gwventana_nand_defconfig | 2 +- configs/mccmon6_nor_defconfig | 2 +- configs/mccmon6_sd_defconfig | 2 +- configs/mx6cuboxi_defconfig | 2 +- configs/mx6sabreauto_defconfig | 2 +- configs/mx6sabresd_defconfig | 2 +- configs/pfla02_defconfig | 2 +- configs/udoo_defconfig | 2 +- configs/wandboard_defconfig | 2 +- 15 files changed, 25 insertions(+), 14 deletions(-)
diff --git a/arch/arm/mach-imx/mx6/Kconfig b/arch/arm/mach-imx/mx6/Kconfig index fd73c67..6f5a92a 100644 --- a/arch/arm/mach-imx/mx6/Kconfig +++ b/arch/arm/mach-imx/mx6/Kconfig @@ -109,6 +109,7 @@ config TARGET_ARISTAINETOS2B
config TARGET_CGTQMX6EVAL bool "cgtqmx6eval" + select MX6QDL select BOARD_LATE_INIT select SUPPORT_SPL select DM @@ -117,6 +118,7 @@ config TARGET_CGTQMX6EVAL config TARGET_CM_FX6 bool "CM-FX6" select SUPPORT_SPL + select MX6QDL select DM select DM_SERIAL select DM_GPIO @@ -131,6 +133,7 @@ config TARGET_COLIBRI_IMX6
config TARGET_DHCOMIMX6 bool "dh_imx6" + select MX6QDL select BOARD_LATE_INIT select BOARD_EARLY_INIT_F select SUPPORT_SPL @@ -165,6 +168,7 @@ config TARGET_GE_B850V3
config TARGET_GW_VENTANA bool "gw_ventana" + select MX6QDL select SUPPORT_SPL imply CMD_SATA imply CMD_SPL @@ -176,10 +180,12 @@ config TARGET_KOSAGI_NOVENA
config TARGET_MCCMON6 bool "mccmon6" + select MX6QDL select SUPPORT_SPL
config TARGET_MX6CUBOXI bool "Solid-run mx6 boards" + select MX6QDL select BOARD_LATE_INIT select SUPPORT_SPL
@@ -231,6 +237,7 @@ config TARGET_MX6Q_ICORE_RQS
config TARGET_MX6SABREAUTO bool "mx6sabreauto" + select MX6QDL select BOARD_LATE_INIT select SUPPORT_SPL select DM @@ -239,6 +246,7 @@ config TARGET_MX6SABREAUTO
config TARGET_MX6SABRESD bool "mx6sabresd" + select MX6QDL select BOARD_LATE_INIT select SUPPORT_SPL select DM @@ -360,6 +368,7 @@ config TARGET_PCM058
config TARGET_PFLA02 bool "Phytec PFLA02 (PhyFlex) i.MX6 Quad" + select MX6QDL select BOARD_LATE_INIT select SUPPORT_SPL
@@ -378,6 +387,7 @@ config TARGET_TQMA6
config TARGET_UDOO bool "udoo" + select MX6QDL select BOARD_LATE_INIT select SUPPORT_SPL
@@ -398,6 +408,7 @@ config TARGET_SAMTEC_VINING_2000
config TARGET_WANDBOARD bool "wandboard" + select MX6QDL select BOARD_LATE_INIT select SUPPORT_SPL
diff --git a/configs/cgtqmx6eval_defconfig b/configs/cgtqmx6eval_defconfig index 3521500..47c0b4c 100644 --- a/configs/cgtqmx6eval_defconfig +++ b/configs/cgtqmx6eval_defconfig @@ -10,7 +10,7 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg,MX6QDL" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/cm_fx6_defconfig b/configs/cm_fx6_defconfig index 68ae70e..0773aca 100644 --- a/configs/cm_fx6_defconfig +++ b/configs/cm_fx6_defconfig @@ -13,7 +13,7 @@ CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_DEFAULT_DEVICE_TREE="imx6q-cm-fx6" CONFIG_AHCI=y CONFIG_OF_BOARD_SETUP=y -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg,MX6QDL" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SPL=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x80 diff --git a/configs/dh_imx6_defconfig b/configs/dh_imx6_defconfig index 175f9fa..814df1c 100644 --- a/configs/dh_imx6_defconfig +++ b/configs/dh_imx6_defconfig @@ -10,7 +10,7 @@ CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_FIT=y -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg,MX6QDL" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SPL=y diff --git a/configs/gwventana_emmc_defconfig b/configs/gwventana_emmc_defconfig index 76bfbfd..5379cf3 100644 --- a/configs/gwventana_emmc_defconfig +++ b/configs/gwventana_emmc_defconfig @@ -14,7 +14,7 @@ CONFIG_CMD_HDMIDETECT=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg,MX6QDL" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 # CONFIG_SYS_STDIO_DEREGISTER is not set # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/gwventana_gw5904_defconfig b/configs/gwventana_gw5904_defconfig index 9e6e458..fe364d0 100644 --- a/configs/gwventana_gw5904_defconfig +++ b/configs/gwventana_gw5904_defconfig @@ -14,7 +14,7 @@ CONFIG_CMD_HDMIDETECT=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg,MX6QDL" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 # CONFIG_SYS_STDIO_DEREGISTER is not set # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/gwventana_nand_defconfig b/configs/gwventana_nand_defconfig index c9e8b8b..dd4d73c 100644 --- a/configs/gwventana_nand_defconfig +++ b/configs/gwventana_nand_defconfig @@ -15,7 +15,7 @@ CONFIG_CMD_HDMIDETECT=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg,MX6QDL" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 # CONFIG_SYS_STDIO_DEREGISTER is not set # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/mccmon6_nor_defconfig b/configs/mccmon6_nor_defconfig index 0f9794c..7c46579 100644 --- a/configs/mccmon6_nor_defconfig +++ b/configs/mccmon6_nor_defconfig @@ -5,7 +5,7 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_MCCMON6=y CONFIG_SPL_SERIAL_SUPPORT=y # CONFIG_CMD_BMODE is not set -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/liebherr/mccmon6/mon6_imximage_nor.cfg,MX6QDL" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/liebherr/mccmon6/mon6_imximage_nor.cfg" CONFIG_SPL=y CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/mccmon6_sd_defconfig b/configs/mccmon6_sd_defconfig index 01a20e6..97f7f9a 100644 --- a/configs/mccmon6_sd_defconfig +++ b/configs/mccmon6_sd_defconfig @@ -6,7 +6,7 @@ CONFIG_TARGET_MCCMON6=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y # CONFIG_CMD_BMODE is not set -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/liebherr/mccmon6/mon6_imximage_sd.cfg,MX6QDL" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/liebherr/mccmon6/mon6_imximage_sd.cfg" CONFIG_SPL=y CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/mx6cuboxi_defconfig b/configs/mx6cuboxi_defconfig index 97a79e5..e729def 100644 --- a/configs/mx6cuboxi_defconfig +++ b/configs/mx6cuboxi_defconfig @@ -11,7 +11,7 @@ CONFIG_SPL_WATCHDOG_SUPPORT=y # CONFIG_CMD_BMODE is not set CONFIG_CMD_HDMIDETECT=y CONFIG_DISTRO_DEFAULTS=y -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg,MX6QDL" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" # CONFIG_SYS_STDIO_DEREGISTER is not set CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y diff --git a/configs/mx6sabreauto_defconfig b/configs/mx6sabreauto_defconfig index 7e344a1..d80a7e4 100644 --- a/configs/mx6sabreauto_defconfig +++ b/configs/mx6sabreauto_defconfig @@ -8,7 +8,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg,SPL,MX6QDL" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg,SPL" CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx6sabresd_defconfig b/configs/mx6sabresd_defconfig index 90102b3..caed261 100644 --- a/configs/mx6sabresd_defconfig +++ b/configs/mx6sabresd_defconfig @@ -8,7 +8,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg,MX6QDL" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/pfla02_defconfig b/configs/pfla02_defconfig index 456ae65..029c9de 100644 --- a/configs/pfla02_defconfig +++ b/configs/pfla02_defconfig @@ -12,7 +12,7 @@ CONFIG_SPL_SPI_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_CMD_HDMIDETECT=y CONFIG_FIT=y -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg,MX6QDL" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y diff --git a/configs/udoo_defconfig b/configs/udoo_defconfig index f064928..b92b181 100644 --- a/configs/udoo_defconfig +++ b/configs/udoo_defconfig @@ -8,7 +8,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg,MX6QDL" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig index 23a6403..a4518fc 100644 --- a/configs/wandboard_defconfig +++ b/configs/wandboard_defconfig @@ -10,7 +10,7 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_CMD_HDMIDETECT=y CONFIG_DISTRO_DEFAULTS=y -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg,MX6QDL" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y
SPL option is already selected via Kconfig, so remove it from the CONFIG_SYS_EXTRA_OPTIONS line.
Signed-off-by: Fabio Estevam fabio.estevam@nxp.com --- configs/mx6sabreauto_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/mx6sabreauto_defconfig b/configs/mx6sabreauto_defconfig index d80a7e4..98c39bb 100644 --- a/configs/mx6sabreauto_defconfig +++ b/configs/mx6sabreauto_defconfig @@ -8,7 +8,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg,SPL" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y
Fabio Estevam
