[U-Boot] Uboot send pull request
Hi Tom,
Please pull some riscv update: 1. Add DM drivers to support RISC-V CPU and timer, plus some bug fixes. 2. Support SiFive UART 3. Rename ax25-ae350 defconfig
https://travis-ci.org/rickchen36/u-boot-riscv/builds/469364551
Thanks
Rick
The following changes since commit 1f2e948d6d53f77a2ddb2dde3531b0d5bc2815ad:
Prepare v2019.01-rc2 (2018-12-17 20:25:24 -0500)
git://git.denx.de/u-boot-riscv.git
for you to fetch changes up to 368ff57805b03bebf99e97e703ce07aec721bc71:
doc: README.ae350: Sync for ax25-ae350 rename (2018-12-18 13:26:02 +0800)
---------------------------------------------------------------- Anup Patel (4): riscv: Introduce a Kconfig option for machine mode riscv: Implement riscv_get_time() API using rdtime instruction drivers: serial: Add SiFive UART driver riscv: qemu: Imply SIFIVE_SERIAL for emulation
Bin Meng (22): dm: cpu: Add timebase frequency to the platdata riscv: qemu: Create a simple-bus driver for the soc node cpu: Add a RISC-V CPU driver timer: Add generic driver for RISC-V privileged architecture defined timer riscv: ax25: Hide the ax25-specific Kconfig option riscv: Add a SYSCON driver for SiFive's Core Local Interruptor riscv: qemu: Add platform-specific Kconfig options riscv: Enlarge the default SYS_MALLOC_F_LEN riscv: Probe cpus during boot riscv: Remove non-DM version of print_cpuinfo() riscv: Add CSR numbers riscv: Add exception codes for xcause register riscv: Update supports_extension() to use desc from cpu driver riscv: Add indirect stringification to csr_xxx ops riscv: Do some basic architecture level cpu initialization riscv: Move trap handler codes to mtrap.S riscv: Fix context restore before returning from trap handler riscv: Return to previous privilege level after trap handling riscv: Adjust the _exit_trap() position to come before handle_trap() riscv: Save boot hart id to the global data riscv: bootm: Change to use boot_hart from global data riscv: Remove ae350.dts
Lukas Auer (1): riscv: add Kconfig entries for the code model
Rick Chen (2): riscv: configs: Rename ax25-ae350 defconfig doc: README.ae350: Sync for ax25-ae350 rename
arch/riscv/Kconfig | 60 +++++++++++++++++++++-- arch/riscv/Makefile | 9 +++- arch/riscv/cpu/Makefile | 2 +- arch/riscv/cpu/ax25/Kconfig | 17 +++++-- arch/riscv/cpu/ax25/cache.c | 12 ++--- arch/riscv/cpu/cpu.c | 98 ++++++++++++++++++++++++++------------ arch/riscv/cpu/mtrap.S | 103 ++++++++++++++++++++++++++++++++++++++++ arch/riscv/cpu/qemu/Kconfig | 12 +++++ arch/riscv/cpu/qemu/cpu.c | 14 ++++++ arch/riscv/cpu/start.S | 93 ++---------------------------------- arch/riscv/dts/ae350.dts | 229 ---------------------------------------------------------------------------------------- arch/riscv/include/asm/csr.h | 16 ++++--- arch/riscv/include/asm/encoding.h | 236 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/riscv/include/asm/global_data.h | 4 ++ arch/riscv/include/asm/syscon.h | 19 ++++++++ arch/riscv/lib/Makefile | 2 + arch/riscv/lib/asm-offsets.c | 19 ++++++++ arch/riscv/lib/bootm.c | 2 +- arch/riscv/lib/interrupts.c | 62 ++++++++++++------------ arch/riscv/lib/rdtime.c | 38 +++++++++++++++ arch/riscv/lib/sifive_clint.c | 84 +++++++++++++++++++++++++++++++++ board/AndesTech/ax25-ae350/Kconfig | 4 ++ board/AndesTech/ax25-ae350/MAINTAINERS | 5 +- board/emulation/qemu-riscv/Kconfig | 2 + configs/{a25-ae350_32_defconfig => ae350_rv32_defconfig} | 0 configs/{ax25-ae350_64_defconfig => ae350_rv64_defconfig} | 0 doc/README.ae350 | 2 +- drivers/cpu/Kconfig | 6 +++ drivers/cpu/Makefile | 1 + drivers/cpu/riscv_cpu.c | 116 +++++++++++++++++++++++++++++++++++++++++++++ drivers/serial/Kconfig | 13 +++++ drivers/serial/Makefile | 1 + drivers/serial/serial_sifive.c | 215 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/timer/Kconfig | 7 +++ drivers/timer/Makefile | 1 + drivers/timer/riscv_timer.c | 56 ++++++++++++++++++++++ include/cpu.h | 3 ++ 37 files changed, 1154 insertions(+), 409 deletions(-) create mode 100644 arch/riscv/cpu/mtrap.S create mode 100644 arch/riscv/cpu/qemu/Kconfig delete mode 100644 arch/riscv/dts/ae350.dts create mode 100644 arch/riscv/include/asm/syscon.h create mode 100644 arch/riscv/lib/asm-offsets.c create mode 100644 arch/riscv/lib/rdtime.c create mode 100644 arch/riscv/lib/sifive_clint.c rename configs/{a25-ae350_32_defconfig => ae350_rv32_defconfig} (100%) rename configs/{ax25-ae350_64_defconfig => ae350_rv64_defconfig} (100%) create mode 100644 drivers/cpu/riscv_cpu.c create mode 100644 drivers/serial/serial_sifive.c create mode 100644 drivers/timer/riscv_timer.c
uboot@andestech.com
