[U-Boot] [PATCH v3 0/6] cmd: remove NET and CMD_NET dependency for CMD_PXE
It allows to use sysboot command on board which have no NET support.
Currently, sysboot command can't be used if CMD_NET and NET flags are not set, while sysboot allows to load extlinux.conf file from local filesystem, so it doesn't need to depend of CMD_NET and NET flags.
- Move from_env() from pxe.c to nvedit.c. - As sysboot and pxe commands are sharing piece of code, put this common code into a new file pxe_utils.c. - Extract sysboot command's code outside pxe.c and create a new sysboot.c file. - Fix some checkpatch issues.
Patrice Chotard (6): cmd: Migrate from_env() from pxe.c to nvedit.c cmd: Prepare sysboot command independence cmd: sysboot: Create a sysboot command dedicated file cmd: pxe_utils: Fix checkpatch WARNING/CHECK cmd: sysboot: Fix checkpatch WARNING/CHECK cmd: pxe: Fix checkpatch WARNING/CHECK
Kconfig | 1 + cmd/Kconfig | 6 + cmd/Makefile | 3 +- cmd/nvedit.c | 17 + cmd/pxe.c | 1730 ++--------------------------------------------- cmd/pxe_utils.c | 1413 ++++++++++++++++++++++++++++++++++++++ cmd/pxe_utils.h | 90 +++ cmd/sysboot.c | 134 ++++ include/env.h | 10 + 9 files changed, 1726 insertions(+), 1678 deletions(-) create mode 100644 cmd/pxe_utils.c create mode 100644 cmd/pxe_utils.h create mode 100644 cmd/sysboot.c
Migrate from_env() from pxe.c to nvedit.c as it's not pxe specific.
Signed-off-by: Patrice Chotard patrice.chotard@st.com ---
cmd/nvedit.c | 17 +++++++++++++++++ cmd/pxe.c | 17 ----------------- include/env.h | 10 ++++++++++ 3 files changed, 27 insertions(+), 17 deletions(-)
diff --git a/cmd/nvedit.c b/cmd/nvedit.c index 99a3bc57b1..979def9c9c 100644 --- a/cmd/nvedit.c +++ b/cmd/nvedit.c @@ -680,6 +680,23 @@ char *env_get(const char *name) return NULL; }
+/* + * Like env_get, but prints an error if envvar isn't defined in the + * environment. It always returns what env_get does, so it can be used in + * place of env_get without changing error handling otherwise. + */ +char *from_env(const char *envvar) +{ + char *ret; + + ret = env_get(envvar); + + if (!ret) + printf("missing environment variable: %s\n", envvar); + + return ret; +} + /* * Look up variable from environment for restricted C runtime env. */ diff --git a/cmd/pxe.c b/cmd/pxe.c index 2059975446..2665c4f88d 100644 --- a/cmd/pxe.c +++ b/cmd/pxe.c @@ -37,23 +37,6 @@ const char *pxe_default_paths[] = {
static bool is_pxe;
-/* - * Like env_get, but prints an error if envvar isn't defined in the - * environment. It always returns what env_get does, so it can be used in - * place of env_get without changing error handling otherwise. - */ -static char *from_env(const char *envvar) -{ - char *ret; - - ret = env_get(envvar); - - if (!ret) - printf("missing environment variable: %s\n", envvar); - - return ret; -} - #ifdef CONFIG_CMD_NET /* * Convert an ethaddr from the environment to the format used by pxelinux diff --git a/include/env.h b/include/env.h index b72239f6a5..d6c2d751d6 100644 --- a/include/env.h +++ b/include/env.h @@ -113,6 +113,16 @@ int env_match(unsigned char *name, int index); */ char *env_get(const char *varname);
+/* + * Like env_get, but prints an error if envvar isn't defined in the + * environment. It always returns what env_get does, so it can be used in + * place of env_get without changing error handling otherwise. + * + * @varname: Variable to look up + * @return value of variable, or NULL if not found + */ +char *from_env(const char *envvar); + /** * env_get_f() - Look up the value of an environment variable (early) *
As sysboot and pxe commands are sharing piece of code, migrate this common code into a new file pxe_utils.c to prepare sysboot command code extraction from pxe.c
cmd/Makefile | 2 +- cmd/pxe.c | 1478 +---------------------------------------------- cmd/pxe_utils.c | 1414 +++++++++++++++++++++++++++++++++++++++++++++ cmd/pxe_utils.h | 90 +++ 4 files changed, 1507 insertions(+), 1477 deletions(-) create mode 100644 cmd/pxe_utils.c create mode 100644 cmd/pxe_utils.h
diff --git a/cmd/Makefile b/cmd/Makefile index 2d723ea0f0..723b461e0d 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -108,7 +108,7 @@ ifdef CONFIG_PCI obj-$(CONFIG_CMD_PCI) += pci.o endif obj-$(CONFIG_CMD_PINMUX) += pinmux.o -obj-$(CONFIG_CMD_PXE) += pxe.o +obj-$(CONFIG_CMD_PXE) += pxe.o pxe_utils.o obj-$(CONFIG_CMD_WOL) += wol.o obj-$(CONFIG_CMD_QFW) += qfw.o obj-$(CONFIG_CMD_READ) += read.o diff --git a/cmd/pxe.c b/cmd/pxe.c index 2665c4f88d..5fe7d45b3d 100644 --- a/cmd/pxe.c +++ b/cmd/pxe.c @@ -6,23 +6,11 @@
#include <common.h> #include <command.h> -#include <env.h> -#include <malloc.h> -#include <mapmem.h> -#include <lcd.h> -#include <linux/string.h> -#include <linux/ctype.h> -#include <errno.h> -#include <linux/list.h> #include <fs.h> -#include <splash.h> -#include <asm/io.h>
-#include "menu.h" -#include "cli.h" - -#define MAX_TFTP_PATH_LEN 127 +#include "pxe_utils.h"
+#ifdef CONFIG_CMD_NET const char *pxe_default_paths[] = { #ifdef CONFIG_SYS_SOC #ifdef CONFIG_SYS_BOARD @@ -35,85 +23,6 @@ const char *pxe_default_paths[] = { NULL };
-static bool is_pxe; - -#ifdef CONFIG_CMD_NET -/* - * Convert an ethaddr from the environment to the format used by pxelinux - * filenames based on mac addresses. Convert's ':' to '-', and adds "01-" to - * the beginning of the ethernet address to indicate a hardware type of - * Ethernet. Also converts uppercase hex characters into lowercase, to match - * pxelinux's behavior. - * - * Returns 1 for success, -ENOENT if 'ethaddr' is undefined in the - * environment, or some other value < 0 on error. - */ -static int format_mac_pxe(char *outbuf, size_t outbuf_len) -{ - uchar ethaddr[6]; - - if (outbuf_len < 21) { - printf("outbuf is too small (%zd < 21)\n", outbuf_len); - - return -EINVAL; - } - - if (!eth_env_get_enetaddr_by_index("eth", eth_get_dev_index(), ethaddr)) - return -ENOENT; - - sprintf(outbuf, "01-%02x-%02x-%02x-%02x-%02x-%02x", - ethaddr[0], ethaddr[1], ethaddr[2], - ethaddr[3], ethaddr[4], ethaddr[5]); - - return 1; -} -#endif - -/* - * Returns the directory the file specified in the bootfile env variable is - * in. If bootfile isn't defined in the environment, return NULL, which should - * be interpreted as "don't prepend anything to paths". - */ -static int get_bootfile_path(const char *file_path, char *bootfile_path, - size_t bootfile_path_size) -{ - char *bootfile, *last_slash; - size_t path_len = 0; - - /* Only syslinux allows absolute paths */ - if (file_path[0] == '/' && !is_pxe) - goto ret; - - bootfile = from_env("bootfile"); - - if (!bootfile) - goto ret; - - last_slash = strrchr(bootfile, '/'); - - if (last_slash == NULL) - goto ret; - - path_len = (last_slash - bootfile) + 1; - - if (bootfile_path_size < path_len) { - printf("bootfile_path too small. (%zd < %zd)\n", - bootfile_path_size, path_len); - - return -1; - } - - strncpy(bootfile_path, bootfile, path_len); - - ret: - bootfile_path[path_len] = '\0'; - - return 1; -} - -static int (*do_getfile)(cmd_tbl_t *cmdtp, const char *file_path, char *file_addr); - -#ifdef CONFIG_CMD_NET static int do_get_tftp(cmd_tbl_t *cmdtp, const char *file_path, char *file_addr) { char *tftp_argv[] = {"tftp", NULL, NULL, NULL}; @@ -169,176 +78,8 @@ static int do_get_any(cmd_tbl_t *cmdtp, const char *file_path, char *file_addr) return -ENOENT; }
-/* - * As in pxelinux, paths to files referenced from files we retrieve are - * relative to the location of bootfile. get_relfile takes such a path and - * joins it with the bootfile path to get the full path to the target file. If - * the bootfile path is NULL, we use file_path as is. - * - * Returns 1 for success, or < 0 on error. - */ -static int get_relfile(cmd_tbl_t *cmdtp, const char *file_path, - unsigned long file_addr) -{ - size_t path_len; - char relfile[MAX_TFTP_PATH_LEN+1]; - char addr_buf[18]; - int err; - - err = get_bootfile_path(file_path, relfile, sizeof(relfile)); - - if (err < 0) - return err; - - path_len = strlen(file_path); - path_len += strlen(relfile); - - if (path_len > MAX_TFTP_PATH_LEN) { - printf("Base path too long (%s%s)\n", - relfile, - file_path); - - return -ENAMETOOLONG; - } - - strcat(relfile, file_path); - - printf("Retrieving file: %s\n", relfile); - - sprintf(addr_buf, "%lx", file_addr); - - return do_getfile(cmdtp, relfile, addr_buf); -} - -/* - * Retrieve the file at 'file_path' to the locate given by 'file_addr'. If - * 'bootfile' was specified in the environment, the path to bootfile will be - * prepended to 'file_path' and the resulting path will be used. - * - * Returns 1 on success, or < 0 for error. - */ -static int get_pxe_file(cmd_tbl_t *cmdtp, const char *file_path, - unsigned long file_addr) -{ - unsigned long config_file_size; - char *tftp_filesize; - int err; - char *buf; - - err = get_relfile(cmdtp, file_path, file_addr); - - if (err < 0) - return err; - - /* - * the file comes without a NUL byte at the end, so find out its size - * and add the NUL byte. - */ - tftp_filesize = from_env("filesize"); - - if (!tftp_filesize) - return -ENOENT; - - if (strict_strtoul(tftp_filesize, 16, &config_file_size) < 0) - return -EINVAL; - - buf = map_sysmem(file_addr + config_file_size, 1); - *buf = '\0'; - unmap_sysmem(buf); - - return 1; -} - #ifdef CONFIG_CMD_NET
-#define PXELINUX_DIR "pxelinux.cfg/" - -/* - * Retrieves a file in the 'pxelinux.cfg' folder. Since this uses get_pxe_file - * to do the hard work, the location of the 'pxelinux.cfg' folder is generated - * from the bootfile path, as described above. - * - * Returns 1 on success or < 0 on error. - */ -static int get_pxelinux_path(cmd_tbl_t *cmdtp, const char *file, - unsigned long pxefile_addr_r) -{ - size_t base_len = strlen(PXELINUX_DIR); - char path[MAX_TFTP_PATH_LEN+1]; - - if (base_len + strlen(file) > MAX_TFTP_PATH_LEN) { - printf("path (%s%s) too long, skipping\n", - PXELINUX_DIR, file); - return -ENAMETOOLONG; - } - - sprintf(path, PXELINUX_DIR "%s", file); - - return get_pxe_file(cmdtp, path, pxefile_addr_r); -} - -/* - * Looks for a pxe file with a name based on the pxeuuid environment variable. - * - * Returns 1 on success or < 0 on error. - */ -static int pxe_uuid_path(cmd_tbl_t *cmdtp, unsigned long pxefile_addr_r) -{ - char *uuid_str; - - uuid_str = from_env("pxeuuid"); - - if (!uuid_str) - return -ENOENT; - - return get_pxelinux_path(cmdtp, uuid_str, pxefile_addr_r); -} - -/* - * Looks for a pxe file with a name based on the 'ethaddr' environment - * variable. - * - * Returns 1 on success or < 0 on error. - */ -static int pxe_mac_path(cmd_tbl_t *cmdtp, unsigned long pxefile_addr_r) -{ - char mac_str[21]; - int err; - - err = format_mac_pxe(mac_str, sizeof(mac_str)); - - if (err < 0) - return err; - - return get_pxelinux_path(cmdtp, mac_str, pxefile_addr_r); -} - -/* - * Looks for pxe files with names based on our IP address. See pxelinux - * documentation for details on what these file names look like. We match - * that exactly. - * - * Returns 1 on success or < 0 on error. - */ -static int pxe_ipaddr_paths(cmd_tbl_t *cmdtp, unsigned long pxefile_addr_r) -{ - char ip_addr[9]; - int mask_pos, err; - - sprintf(ip_addr, "%08X", ntohl(net_ip.s_addr)); - - for (mask_pos = 7; mask_pos >= 0; mask_pos--) { - err = get_pxelinux_path(cmdtp, ip_addr, pxefile_addr_r); - - if (err > 0) - return err; - - ip_addr[mask_pos] = '\0'; - } - - return -ENOENT; -} - /* * Entry point for the 'pxe get' command. * This Follows pxelinux's rules to download a config file from a tftp server. @@ -400,1222 +141,7 @@ do_pxe_get(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
return 1; } -#endif - -/* - * Wrapper to make it easier to store the file at file_path in the location - * specified by envaddr_name. file_path will be joined to the bootfile path, - * if any is specified. - * - * Returns 1 on success or < 0 on error. - */ -static int get_relfile_envaddr(cmd_tbl_t *cmdtp, const char *file_path, const char *envaddr_name) -{ - unsigned long file_addr; - char *envaddr; - - envaddr = from_env(envaddr_name); - - if (!envaddr) - return -ENOENT; - - if (strict_strtoul(envaddr, 16, &file_addr) < 0) - return -EINVAL; - - return get_relfile(cmdtp, file_path, file_addr); -} - -/* - * A note on the pxe file parser. - * - * We're parsing files that use syslinux grammar, which has a few quirks. - * String literals must be recognized based on context - there is no - * quoting or escaping support. There's also nothing to explicitly indicate - * when a label section completes. We deal with that by ending a label - * section whenever we see a line that doesn't include. - * - * As with the syslinux family, this same file format could be reused in the - * future for non pxe purposes. The only action it takes during parsing that - * would throw this off is handling of include files. It assumes we're using - * pxe, and does a tftp download of a file listed as an include file in the - * middle of the parsing operation. That could be handled by refactoring it to - * take a 'include file getter' function. - */ - -/* - * Describes a single label given in a pxe file. - * - * Create these with the 'label_create' function given below. - * - * name - the name of the menu as given on the 'menu label' line. - * kernel - the path to the kernel file to use for this label. - * append - kernel command line to use when booting this label - * initrd - path to the initrd to use for this label. - * attempted - 0 if we haven't tried to boot this label, 1 if we have. - * localboot - 1 if this label specified 'localboot', 0 otherwise. - * list - lets these form a list, which a pxe_menu struct will hold. - */ -struct pxe_label { - char num[4]; - char *name; - char *menu; - char *kernel; - char *config; - char *append; - char *initrd; - char *fdt; - char *fdtdir; - int ipappend; - int attempted; - int localboot; - int localboot_val; - struct list_head list; -}; - -/* - * Describes a pxe menu as given via pxe files. - * - * title - the name of the menu as given by a 'menu title' line. - * default_label - the name of the default label, if any. - * bmp - the bmp file name which is displayed in background - * timeout - time in tenths of a second to wait for a user key-press before - * booting the default label. - * prompt - if 0, don't prompt for a choice unless the timeout period is - * interrupted. If 1, always prompt for a choice regardless of - * timeout. - * labels - a list of labels defined for the menu. - */ -struct pxe_menu { - char *title; - char *default_label; - char *bmp; - int timeout; - int prompt; - struct list_head labels; -}; - -/* - * Allocates memory for and initializes a pxe_label. This uses malloc, so the - * result must be free()'d to reclaim the memory. - * - * Returns NULL if malloc fails. - */ -static struct pxe_label *label_create(void) -{ - struct pxe_label *label; - - label = malloc(sizeof(struct pxe_label)); - - if (!label) - return NULL; - - memset(label, 0, sizeof(struct pxe_label)); - - return label; -} - -/* - * Free the memory used by a pxe_label, including that used by its name, - * kernel, append and initrd members, if they're non NULL. - * - * So - be sure to only use dynamically allocated memory for the members of - * the pxe_label struct, unless you want to clean it up first. These are - * currently only created by the pxe file parsing code. - */ -static void label_destroy(struct pxe_label *label) -{ - if (label->name) - free(label->name); - - if (label->kernel) - free(label->kernel); - - if (label->config) - free(label->config); - - if (label->append) - free(label->append); - - if (label->initrd) - free(label->initrd); - - if (label->fdt) - free(label->fdt); - - if (label->fdtdir) - free(label->fdtdir); - - free(label); -} - -/* - * Print a label and its string members if they're defined. - * - * This is passed as a callback to the menu code for displaying each - * menu entry. - */ -static void label_print(void *data) -{ - struct pxe_label *label = data; - const char *c = label->menu ? label->menu : label->name; - - printf("%s:\t%s\n", label->num, c); -} - -/* - * Boot a label that specified 'localboot'. This requires that the 'localcmd' - * environment variable is defined. Its contents will be executed as U-Boot - * command. If the label specified an 'append' line, its contents will be - * used to overwrite the contents of the 'bootargs' environment variable prior - * to running 'localcmd'. - * - * Returns 1 on success or < 0 on error. - */ -static int label_localboot(struct pxe_label *label) -{ - char *localcmd; - - localcmd = from_env("localcmd"); - - if (!localcmd) - return -ENOENT; - - if (label->append) { - char bootargs[CONFIG_SYS_CBSIZE]; - - cli_simple_process_macros(label->append, bootargs); - env_set("bootargs", bootargs); - } - - debug("running: %s\n", localcmd); - - return run_command_list(localcmd, strlen(localcmd), 0); -} - -/* - * Boot according to the contents of a pxe_label. - * - * If we can't boot for any reason, we return. A successful boot never - * returns. - * - * The kernel will be stored in the location given by the 'kernel_addr_r' - * environment variable. - * - * If the label specifies an initrd file, it will be stored in the location - * given by the 'ramdisk_addr_r' environment variable. - * - * If the label specifies an 'append' line, its contents will overwrite that - * of the 'bootargs' environment variable. - */ -static int label_boot(cmd_tbl_t *cmdtp, struct pxe_label *label) -{ - char *bootm_argv[] = { "bootm", NULL, NULL, NULL, NULL }; - char initrd_str[28]; - char mac_str[29] = ""; - char ip_str[68] = ""; - char *fit_addr = NULL; - int bootm_argc = 2; - int len = 0; - ulong kernel_addr; - void *buf; - - label_print(label); - - label->attempted = 1; - - if (label->localboot) { - if (label->localboot_val >= 0) - label_localboot(label); - return 0; - } - - if (label->kernel == NULL) { - printf("No kernel given, skipping %s\n", - label->name); - return 1; - } - - if (label->initrd) { - if (get_relfile_envaddr(cmdtp, label->initrd, "ramdisk_addr_r") < 0) { - printf("Skipping %s for failure retrieving initrd\n", - label->name); - return 1; - } - - bootm_argv[2] = initrd_str; - strncpy(bootm_argv[2], env_get("ramdisk_addr_r"), 18); - strcat(bootm_argv[2], ":"); - strncat(bootm_argv[2], env_get("filesize"), 9); - } - - if (get_relfile_envaddr(cmdtp, label->kernel, "kernel_addr_r") < 0) { - printf("Skipping %s for failure retrieving kernel\n", - label->name); - return 1; - } - - if (label->ipappend & 0x1) { - sprintf(ip_str, " ip=%s:%s:%s:%s", - env_get("ipaddr"), env_get("serverip"), - env_get("gatewayip"), env_get("netmask")); - } - -#ifdef CONFIG_CMD_NET - if (label->ipappend & 0x2) { - int err; - strcpy(mac_str, " BOOTIF="); - err = format_mac_pxe(mac_str + 8, sizeof(mac_str) - 8); - if (err < 0) - mac_str[0] = '\0'; - } -#endif - - if ((label->ipappend & 0x3) || label->append) { - char bootargs[CONFIG_SYS_CBSIZE] = ""; - char finalbootargs[CONFIG_SYS_CBSIZE]; - - if (strlen(label->append ?: "") + - strlen(ip_str) + strlen(mac_str) + 1 > sizeof(bootargs)) { - printf("bootarg overflow %zd+%zd+%zd+1 > %zd\n", - strlen(label->append ?: ""), - strlen(ip_str), strlen(mac_str), - sizeof(bootargs)); - return 1; - } else { - if (label->append) - strncpy(bootargs, label->append, - sizeof(bootargs)); - strcat(bootargs, ip_str); - strcat(bootargs, mac_str); - - cli_simple_process_macros(bootargs, finalbootargs); - env_set("bootargs", finalbootargs); - printf("append: %s\n", finalbootargs); - } - } - - bootm_argv[1] = env_get("kernel_addr_r"); - /* for FIT, append the configuration identifier */ - if (label->config) { - int len = strlen(bootm_argv[1]) + strlen(label->config) + 1; - - fit_addr = malloc(len); - if (!fit_addr) { - printf("malloc fail (FIT address)\n"); - return 1; - } - snprintf(fit_addr, len, "%s%s", bootm_argv[1], label->config); - bootm_argv[1] = fit_addr; - } - - /* - * fdt usage is optional: - * It handles the following scenarios. All scenarios are exclusive - * - * Scenario 1: If fdt_addr_r specified and "fdt" label is defined in - * pxe file, retrieve fdt blob from server. Pass fdt_addr_r to bootm, - * and adjust argc appropriately. - * - * Scenario 2: If there is an fdt_addr specified, pass it along to - * bootm, and adjust argc appropriately. - * - * Scenario 3: fdt blob is not available. - */ - bootm_argv[3] = env_get("fdt_addr_r"); - - /* if fdt label is defined then get fdt from server */ - if (bootm_argv[3]) { - char *fdtfile = NULL; - char *fdtfilefree = NULL; - - if (label->fdt) { - fdtfile = label->fdt; - } else if (label->fdtdir) { - char *f1, *f2, *f3, *f4, *slash; - - f1 = env_get("fdtfile"); - if (f1) { - f2 = ""; - f3 = ""; - f4 = ""; - } else { - /* - * For complex cases where this code doesn't - * generate the correct filename, the board - * code should set $fdtfile during early boot, - * or the boot scripts should set $fdtfile - * before invoking "pxe" or "sysboot". - */ - f1 = env_get("soc"); - f2 = "-"; - f3 = env_get("board"); - f4 = ".dtb"; - } - - len = strlen(label->fdtdir); - if (!len) - slash = "./"; - else if (label->fdtdir[len - 1] != '/') - slash = "/"; - else - slash = ""; - - len = strlen(label->fdtdir) + strlen(slash) + - strlen(f1) + strlen(f2) + strlen(f3) + - strlen(f4) + 1; - fdtfilefree = malloc(len); - if (!fdtfilefree) { - printf("malloc fail (FDT filename)\n"); - goto cleanup; - } - - snprintf(fdtfilefree, len, "%s%s%s%s%s%s", - label->fdtdir, slash, f1, f2, f3, f4); - fdtfile = fdtfilefree; - } - - if (fdtfile) { - int err = get_relfile_envaddr(cmdtp, fdtfile, "fdt_addr_r"); - free(fdtfilefree); - if (err < 0) { - printf("Skipping %s for failure retrieving fdt\n", - label->name); - goto cleanup; - } - } else { - bootm_argv[3] = NULL; - } - } - - if (!bootm_argv[3]) - bootm_argv[3] = env_get("fdt_addr"); - - if (bootm_argv[3]) { - if (!bootm_argv[2]) - bootm_argv[2] = "-"; - bootm_argc = 4; - } - - kernel_addr = genimg_get_kernel_addr(bootm_argv[1]); - buf = map_sysmem(kernel_addr, 0); - /* Try bootm for legacy and FIT format image */ - if (genimg_get_format(buf) != IMAGE_FORMAT_INVALID) - do_bootm(cmdtp, 0, bootm_argc, bootm_argv); -#ifdef CONFIG_CMD_BOOTI - /* Try booting an AArch64 Linux kernel image */ - else - do_booti(cmdtp, 0, bootm_argc, bootm_argv); -#elif defined(CONFIG_CMD_BOOTZ) - /* Try booting a Image */ - else - do_bootz(cmdtp, 0, bootm_argc, bootm_argv); -#endif - unmap_sysmem(buf); - -cleanup: - if (fit_addr) - free(fit_addr); - return 1; -} - -/* - * Tokens for the pxe file parser. - */ -enum token_type { - T_EOL, - T_STRING, - T_EOF, - T_MENU, - T_TITLE, - T_TIMEOUT, - T_LABEL, - T_KERNEL, - T_LINUX, - T_APPEND, - T_INITRD, - T_LOCALBOOT, - T_DEFAULT, - T_PROMPT, - T_INCLUDE, - T_FDT, - T_FDTDIR, - T_ONTIMEOUT, - T_IPAPPEND, - T_BACKGROUND, - T_INVALID -};
-/* - * A token - given by a value and a type. - */ -struct token { - char *val; - enum token_type type; -}; - -/* - * Keywords recognized. - */ -static const struct token keywords[] = { - {"menu", T_MENU}, - {"title", T_TITLE}, - {"timeout", T_TIMEOUT}, - {"default", T_DEFAULT}, - {"prompt", T_PROMPT}, - {"label", T_LABEL}, - {"kernel", T_KERNEL}, - {"linux", T_LINUX}, - {"localboot", T_LOCALBOOT}, - {"append", T_APPEND}, - {"initrd", T_INITRD}, - {"include", T_INCLUDE}, - {"devicetree", T_FDT}, - {"fdt", T_FDT}, - {"devicetreedir", T_FDTDIR}, - {"fdtdir", T_FDTDIR}, - {"ontimeout", T_ONTIMEOUT,}, - {"ipappend", T_IPAPPEND,}, - {"background", T_BACKGROUND,}, - {NULL, T_INVALID} -}; - -/* - * Since pxe(linux) files don't have a token to identify the start of a - * literal, we have to keep track of when we're in a state where a literal is - * expected vs when we're in a state a keyword is expected. - */ -enum lex_state { - L_NORMAL = 0, - L_KEYWORD, - L_SLITERAL -}; - -/* - * get_string retrieves a string from *p and stores it as a token in - * *t. - * - * get_string used for scanning both string literals and keywords. - * - * Characters from *p are copied into t-val until a character equal to - * delim is found, or a NUL byte is reached. If delim has the special value of - * ' ', any whitespace character will be used as a delimiter. - * - * If lower is unequal to 0, uppercase characters will be converted to - * lowercase in the result. This is useful to make keywords case - * insensitive. - * - * The location of *p is updated to point to the first character after the end - * of the token - the ending delimiter. - * - * On success, the new value of t->val is returned. Memory for t->val is - * allocated using malloc and must be free()'d to reclaim it. If insufficient - * memory is available, NULL is returned. - */ -static char *get_string(char **p, struct token *t, char delim, int lower) -{ - char *b, *e; - size_t len, i; - - /* - * b and e both start at the beginning of the input stream. - * - * e is incremented until we find the ending delimiter, or a NUL byte - * is reached. Then, we take e - b to find the length of the token. - */ - b = e = *p; - - while (*e) { - if ((delim == ' ' && isspace(*e)) || delim == *e) - break; - e++; - } - - len = e - b; - - /* - * Allocate memory to hold the string, and copy it in, converting - * characters to lowercase if lower is != 0. - */ - t->val = malloc(len + 1); - if (!t->val) - return NULL; - - for (i = 0; i < len; i++, b++) { - if (lower) - t->val[i] = tolower(*b); - else - t->val[i] = *b; - } - - t->val[len] = '\0'; - - /* - * Update *p so the caller knows where to continue scanning. - */ - *p = e; - - t->type = T_STRING; - - return t->val; -} - -/* - * Populate a keyword token with a type and value. - */ -static void get_keyword(struct token *t) -{ - int i; - - for (i = 0; keywords[i].val; i++) { - if (!strcmp(t->val, keywords[i].val)) { - t->type = keywords[i].type; - break; - } - } -} - -/* - * Get the next token. We have to keep track of which state we're in to know - * if we're looking to get a string literal or a keyword. - * - * *p is updated to point at the first character after the current token. - */ -static void get_token(char **p, struct token *t, enum lex_state state) -{ - char *c = *p; - - t->type = T_INVALID; - - /* eat non EOL whitespace */ - while (isblank(*c)) - c++; - - /* - * eat comments. note that string literals can't begin with #, but - * can contain a # after their first character. - */ - if (*c == '#') { - while (*c && *c != '\n') - c++; - } - - if (*c == '\n') { - t->type = T_EOL; - c++; - } else if (*c == '\0') { - t->type = T_EOF; - c++; - } else if (state == L_SLITERAL) { - get_string(&c, t, '\n', 0); - } else if (state == L_KEYWORD) { - /* - * when we expect a keyword, we first get the next string - * token delimited by whitespace, and then check if it - * matches a keyword in our keyword list. if it does, it's - * converted to a keyword token of the appropriate type, and - * if not, it remains a string token. - */ - get_string(&c, t, ' ', 1); - get_keyword(t); - } - - *p = c; -} - -/* - * Increment *c until we get to the end of the current line, or EOF. - */ -static void eol_or_eof(char **c) -{ - while (**c && **c != '\n') - (*c)++; -} - -/* - * All of these parse_* functions share some common behavior. - * - * They finish with *c pointing after the token they parse, and return 1 on - * success, or < 0 on error. - */ - -/* - * Parse a string literal and store a pointer it at *dst. String literals - * terminate at the end of the line. - */ -static int parse_sliteral(char **c, char **dst) -{ - struct token t; - char *s = *c; - - get_token(c, &t, L_SLITERAL); - - if (t.type != T_STRING) { - printf("Expected string literal: %.*s\n", (int)(*c - s), s); - return -EINVAL; - } - - *dst = t.val; - - return 1; -} - -/* - * Parse a base 10 (unsigned) integer and store it at *dst. - */ -static int parse_integer(char **c, int *dst) -{ - struct token t; - char *s = *c; - - get_token(c, &t, L_SLITERAL); - - if (t.type != T_STRING) { - printf("Expected string: %.*s\n", (int)(*c - s), s); - return -EINVAL; - } - - *dst = simple_strtol(t.val, NULL, 10); - - free(t.val); - - return 1; -} - -static int parse_pxefile_top(cmd_tbl_t *cmdtp, char *p, unsigned long base, - struct pxe_menu *cfg, int nest_level); - -/* - * Parse an include statement, and retrieve and parse the file it mentions. - * - * base should point to a location where it's safe to store the file, and - * nest_level should indicate how many nested includes have occurred. For this - * include, nest_level has already been incremented and doesn't need to be - * incremented here. - */ -static int handle_include(cmd_tbl_t *cmdtp, char **c, unsigned long base, - struct pxe_menu *cfg, int nest_level) -{ - char *include_path; - char *s = *c; - int err; - char *buf; - int ret; - - err = parse_sliteral(c, &include_path); - - if (err < 0) { - printf("Expected include path: %.*s\n", - (int)(*c - s), s); - return err; - } - - err = get_pxe_file(cmdtp, include_path, base); - - if (err < 0) { - printf("Couldn't retrieve %s\n", include_path); - return err; - } - - buf = map_sysmem(base, 0); - ret = parse_pxefile_top(cmdtp, buf, base, cfg, nest_level); - unmap_sysmem(buf); - - return ret; -} - -/* - * Parse lines that begin with 'menu'. - * - * base and nest are provided to handle the 'menu include' case. - * - * base should point to a location where it's safe to store the included file. - * - * nest_level should be 1 when parsing the top level pxe file, 2 when parsing - * a file it includes, 3 when parsing a file included by that file, and so on. - */ -static int parse_menu(cmd_tbl_t *cmdtp, char **c, struct pxe_menu *cfg, - unsigned long base, int nest_level) -{ - struct token t; - char *s = *c; - int err = 0; - - get_token(c, &t, L_KEYWORD); - - switch (t.type) { - case T_TITLE: - err = parse_sliteral(c, &cfg->title); - - break; - - case T_INCLUDE: - err = handle_include(cmdtp, c, base, cfg, - nest_level + 1); - break; - - case T_BACKGROUND: - err = parse_sliteral(c, &cfg->bmp); - break; - - default: - printf("Ignoring malformed menu command: %.*s\n", - (int)(*c - s), s); - } - - if (err < 0) - return err; - - eol_or_eof(c); - - return 1; -} - -/* - * Handles parsing a 'menu line' when we're parsing a label. - */ -static int parse_label_menu(char **c, struct pxe_menu *cfg, - struct pxe_label *label) -{ - struct token t; - char *s; - - s = *c; - - get_token(c, &t, L_KEYWORD); - - switch (t.type) { - case T_DEFAULT: - if (!cfg->default_label) - cfg->default_label = strdup(label->name); - - if (!cfg->default_label) - return -ENOMEM; - - break; - case T_LABEL: - parse_sliteral(c, &label->menu); - break; - default: - printf("Ignoring malformed menu command: %.*s\n", - (int)(*c - s), s); - } - - eol_or_eof(c); - - return 0; -} - -/* - * Handles parsing a 'kernel' label. - * expecting "filename" or "<fit_filename>#cfg" - */ -static int parse_label_kernel(char **c, struct pxe_label *label) -{ - char *s; - int err; - - err = parse_sliteral(c, &label->kernel); - if (err < 0) - return err; - - s = strstr(label->kernel, "#"); - if (!s) - return 1; - - label->config = malloc(strlen(s) + 1); - if (!label->config) - return -ENOMEM; - - strcpy(label->config, s); - *s = 0; - - return 1; -} - -/* - * Parses a label and adds it to the list of labels for a menu. - * - * A label ends when we either get to the end of a file, or - * get some input we otherwise don't have a handler defined - * for. - * - */ -static int parse_label(char **c, struct pxe_menu *cfg) -{ - struct token t; - int len; - char *s = *c; - struct pxe_label *label; - int err; - - label = label_create(); - if (!label) - return -ENOMEM; - - err = parse_sliteral(c, &label->name); - if (err < 0) { - printf("Expected label name: %.*s\n", (int)(*c - s), s); - label_destroy(label); - return -EINVAL; - } - - list_add_tail(&label->list, &cfg->labels); - - while (1) { - s = *c; - get_token(c, &t, L_KEYWORD); - - err = 0; - switch (t.type) { - case T_MENU: - err = parse_label_menu(c, cfg, label); - break; - - case T_KERNEL: - case T_LINUX: - err = parse_label_kernel(c, label); - break; - - case T_APPEND: - err = parse_sliteral(c, &label->append); - if (label->initrd) - break; - s = strstr(label->append, "initrd="); - if (!s) - break; - s += 7; - len = (int)(strchr(s, ' ') - s); - label->initrd = malloc(len + 1); - strncpy(label->initrd, s, len); - label->initrd[len] = '\0'; - - break; - - case T_INITRD: - if (!label->initrd) - err = parse_sliteral(c, &label->initrd); - break; - - case T_FDT: - if (!label->fdt) - err = parse_sliteral(c, &label->fdt); - break; - - case T_FDTDIR: - if (!label->fdtdir) - err = parse_sliteral(c, &label->fdtdir); - break; - - case T_LOCALBOOT: - label->localboot = 1; - err = parse_integer(c, &label->localboot_val); - break; - - case T_IPAPPEND: - err = parse_integer(c, &label->ipappend); - break; - - case T_EOL: - break; - - default: - /* - * put the token back! we don't want it - it's the end - * of a label and whatever token this is, it's - * something for the menu level context to handle. - */ - *c = s; - return 1; - } - - if (err < 0) - return err; - } -} - -/* - * This 16 comes from the limit pxelinux imposes on nested includes. - * - * There is no reason at all we couldn't do more, but some limit helps prevent - * infinite (until crash occurs) recursion if a file tries to include itself. - */ -#define MAX_NEST_LEVEL 16 - -/* - * Entry point for parsing a menu file. nest_level indicates how many times - * we've nested in includes. It will be 1 for the top level menu file. - * - * Returns 1 on success, < 0 on error. - */ -static int parse_pxefile_top(cmd_tbl_t *cmdtp, char *p, unsigned long base, - struct pxe_menu *cfg, int nest_level) -{ - struct token t; - char *s, *b, *label_name; - int err; - - b = p; - - if (nest_level > MAX_NEST_LEVEL) { - printf("Maximum nesting (%d) exceeded\n", MAX_NEST_LEVEL); - return -EMLINK; - } - - while (1) { - s = p; - - get_token(&p, &t, L_KEYWORD); - - err = 0; - switch (t.type) { - case T_MENU: - cfg->prompt = 1; - err = parse_menu(cmdtp, &p, cfg, - base + ALIGN(strlen(b) + 1, 4), - nest_level); - break; - - case T_TIMEOUT: - err = parse_integer(&p, &cfg->timeout); - break; - - case T_LABEL: - err = parse_label(&p, cfg); - break; - - case T_DEFAULT: - case T_ONTIMEOUT: - err = parse_sliteral(&p, &label_name); - - if (label_name) { - if (cfg->default_label) - free(cfg->default_label); - - cfg->default_label = label_name; - } - - break; - - case T_INCLUDE: - err = handle_include(cmdtp, &p, - base + ALIGN(strlen(b), 4), cfg, - nest_level + 1); - break; - - case T_PROMPT: - eol_or_eof(&p); - break; - - case T_EOL: - break; - - case T_EOF: - return 1; - - default: - printf("Ignoring unknown command: %.*s\n", - (int)(p - s), s); - eol_or_eof(&p); - } - - if (err < 0) - return err; - } -} - -/* - * Free the memory used by a pxe_menu and its labels. - */ -static void destroy_pxe_menu(struct pxe_menu *cfg) -{ - struct list_head *pos, *n; - struct pxe_label *label; - - if (cfg->title) - free(cfg->title); - - if (cfg->default_label) - free(cfg->default_label); - - list_for_each_safe(pos, n, &cfg->labels) { - label = list_entry(pos, struct pxe_label, list); - - label_destroy(label); - } - - free(cfg); -} - -/* - * Entry point for parsing a pxe file. This is only used for the top level - * file. - * - * Returns NULL if there is an error, otherwise, returns a pointer to a - * pxe_menu struct populated with the results of parsing the pxe file (and any - * files it includes). The resulting pxe_menu struct can be free()'d by using - * the destroy_pxe_menu() function. - */ -static struct pxe_menu *parse_pxefile(cmd_tbl_t *cmdtp, unsigned long menucfg) -{ - struct pxe_menu *cfg; - char *buf; - int r; - - cfg = malloc(sizeof(struct pxe_menu)); - - if (!cfg) - return NULL; - - memset(cfg, 0, sizeof(struct pxe_menu)); - - INIT_LIST_HEAD(&cfg->labels); - - buf = map_sysmem(menucfg, 0); - r = parse_pxefile_top(cmdtp, buf, menucfg, cfg, 1); - unmap_sysmem(buf); - - if (r < 0) { - destroy_pxe_menu(cfg); - return NULL; - } - - return cfg; -} - -/* - * Converts a pxe_menu struct into a menu struct for use with U-Boot's generic - * menu code. - */ -static struct menu *pxe_menu_to_menu(struct pxe_menu *cfg) -{ - struct pxe_label *label; - struct list_head *pos; - struct menu *m; - int err; - int i = 1; - char *default_num = NULL; - - /* - * Create a menu and add items for all the labels. - */ - m = menu_create(cfg->title, DIV_ROUND_UP(cfg->timeout, 10), - cfg->prompt, label_print, NULL, NULL); - - if (!m) - return NULL; - - list_for_each(pos, &cfg->labels) { - label = list_entry(pos, struct pxe_label, list); - - sprintf(label->num, "%d", i++); - if (menu_item_add(m, label->num, label) != 1) { - menu_destroy(m); - return NULL; - } - if (cfg->default_label && - (strcmp(label->name, cfg->default_label) == 0)) - default_num = label->num; - - } - - /* - * After we've created items for each label in the menu, set the - * menu's default label if one was specified. - */ - if (default_num) { - err = menu_default_set(m, default_num); - if (err != 1) { - if (err != -ENOENT) { - menu_destroy(m); - return NULL; - } - - printf("Missing default: %s\n", cfg->default_label); - } - } - - return m; -} - -/* - * Try to boot any labels we have yet to attempt to boot. - */ -static void boot_unattempted_labels(cmd_tbl_t *cmdtp, struct pxe_menu *cfg) -{ - struct list_head *pos; - struct pxe_label *label; - - list_for_each(pos, &cfg->labels) { - label = list_entry(pos, struct pxe_label, list); - - if (!label->attempted) - label_boot(cmdtp, label); - } -} - -/* - * Boot the system as prescribed by a pxe_menu. - * - * Use the menu system to either get the user's choice or the default, based - * on config or user input. If there is no default or user's choice, - * attempted to boot labels in the order they were given in pxe files. - * If the default or user's choice fails to boot, attempt to boot other - * labels in the order they were given in pxe files. - * - * If this function returns, there weren't any labels that successfully - * booted, or the user interrupted the menu selection via ctrl+c. - */ -static void handle_pxe_menu(cmd_tbl_t *cmdtp, struct pxe_menu *cfg) -{ - void *choice; - struct menu *m; - int err; - -#ifdef CONFIG_CMD_BMP - /* display BMP if available */ - if (cfg->bmp) { - if (get_relfile(cmdtp, cfg->bmp, load_addr)) { - run_command("cls", 0); - bmp_display(load_addr, - BMP_ALIGN_CENTER, BMP_ALIGN_CENTER); - } else { - printf("Skipping background bmp %s for failure\n", - cfg->bmp); - } - } -#endif - - m = pxe_menu_to_menu(cfg); - if (!m) - return; - - err = menu_get_choice(m, &choice); - - menu_destroy(m); - - /* - * err == 1 means we got a choice back from menu_get_choice. - * - * err == -ENOENT if the menu was setup to select the default but no - * default was set. in that case, we should continue trying to boot - * labels that haven't been attempted yet. - * - * otherwise, the user interrupted or there was some other error and - * we give up. - */ - - if (err == 1) { - err = label_boot(cmdtp, choice); - if (!err) - return; - } else if (err != -ENOENT) { - return; - } - - boot_unattempted_labels(cmdtp, cfg); -} - -#ifdef CONFIG_CMD_NET /* * Boots a system using a pxe file * diff --git a/cmd/pxe_utils.c b/cmd/pxe_utils.c new file mode 100644 index 0000000000..c318f98417 --- /dev/null +++ b/cmd/pxe_utils.c @@ -0,0 +1,1414 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2010-2011 Calxeda, Inc. + * Copyright (c) 2014, NVIDIA CORPORATION. All rights reserved. + */ + +#include <common.h> +#include <env.h> +#include <malloc.h> +#include <mapmem.h> +#include <lcd.h> +#include <linux/string.h> +#include <linux/ctype.h> +#include <errno.h> +#include <linux/list.h> + +#include <splash.h> +#include <asm/io.h> + +#include "menu.h" +#include "cli.h" + +#include "pxe_utils.h" + +#define MAX_TFTP_PATH_LEN 127 + +bool is_pxe; + +/* + * Convert an ethaddr from the environment to the format used by pxelinux + * filenames based on mac addresses. Convert's ':' to '-', and adds "01-" to + * the beginning of the ethernet address to indicate a hardware type of + * Ethernet. Also converts uppercase hex characters into lowercase, to match + * pxelinux's behavior. + * + * Returns 1 for success, -ENOENT if 'ethaddr' is undefined in the + * environment, or some other value < 0 on error. + */ +static int format_mac_pxe(char *outbuf, size_t outbuf_len) +{ + uchar ethaddr[6]; + + if (outbuf_len < 21) { + printf("outbuf is too small (%zd < 21)\n", outbuf_len); + + return -EINVAL; + } + + if (!eth_env_get_enetaddr_by_index("eth", eth_get_dev_index(), ethaddr)) + return -ENOENT; + + sprintf(outbuf, "01-%02x-%02x-%02x-%02x-%02x-%02x", + ethaddr[0], ethaddr[1], ethaddr[2], + ethaddr[3], ethaddr[4], ethaddr[5]); + + return 1; +} + +/* + * Returns the directory the file specified in the bootfile env variable is + * in. If bootfile isn't defined in the environment, return NULL, which should + * be interpreted as "don't prepend anything to paths". + */ +static int get_bootfile_path(const char *file_path, char *bootfile_path, + size_t bootfile_path_size) +{ + char *bootfile, *last_slash; + size_t path_len = 0; + + /* Only syslinux allows absolute paths */ + if (file_path[0] == '/' && !is_pxe) + goto ret; + + bootfile = from_env("bootfile"); + + if (!bootfile) + goto ret; + + last_slash = strrchr(bootfile, '/'); + + if (last_slash == NULL ) + goto ret; + + path_len = (last_slash - bootfile) + 1; + + if (bootfile_path_size < path_len) { + printf("bootfile_path too small. (%zd < %zd)\n", + bootfile_path_size, path_len); + + return -1; + } + + strncpy(bootfile_path, bootfile, path_len); + + ret: + bootfile_path[path_len] = '\0'; + + return 1; +} + +int (*do_getfile)(cmd_tbl_t *cmdtp, const char *file_path, char *file_addr); + +/* + * As in pxelinux, paths to files referenced from files we retrieve are + * relative to the location of bootfile. get_relfile takes such a path and + * joins it with the bootfile path to get the full path to the target file. If + * the bootfile path is NULL, we use file_path as is. + * + * Returns 1 for success, or < 0 on error. + */ +static int get_relfile(cmd_tbl_t *cmdtp, const char *file_path, + unsigned long file_addr) +{ + size_t path_len; + char relfile[MAX_TFTP_PATH_LEN+1]; + char addr_buf[18]; + int err; + + err = get_bootfile_path(file_path, relfile, sizeof(relfile)); + + if (err < 0) + return err; + + path_len = strlen(file_path); + path_len += strlen(relfile); + + if (path_len > MAX_TFTP_PATH_LEN) { + printf("Base path too long (%s%s)\n", + relfile, + file_path); + + return -ENAMETOOLONG; + } + + strcat(relfile, file_path); + + printf("Retrieving file: %s\n", relfile); + + sprintf(addr_buf, "%lx", file_addr); + + return do_getfile(cmdtp, relfile, addr_buf); +} + +/* + * Retrieve the file at 'file_path' to the locate given by 'file_addr'. If + * 'bootfile' was specified in the environment, the path to bootfile will be + * prepended to 'file_path' and the resulting path will be used. + * + * Returns 1 on success, or < 0 for error. + */ +int get_pxe_file(cmd_tbl_t *cmdtp, const char *file_path, + unsigned long file_addr) +{ + unsigned long config_file_size; + char *tftp_filesize; + int err; + char *buf; + + err = get_relfile(cmdtp, file_path, file_addr); + + if (err < 0) + return err; + + /* + * the file comes without a NUL byte at the end, so find out its size + * and add the NUL byte. + */ + tftp_filesize = from_env("filesize"); + + if (!tftp_filesize) + return -ENOENT; + + if (strict_strtoul(tftp_filesize, 16, &config_file_size) < 0) + return -EINVAL; + + buf = map_sysmem(file_addr + config_file_size, 1); + *buf = '\0'; + unmap_sysmem(buf); + + return 1; +} + +#define PXELINUX_DIR "pxelinux.cfg/" + + +/* + * Retrieves a file in the 'pxelinux.cfg' folder. Since this uses get_pxe_file + * to do the hard work, the location of the 'pxelinux.cfg' folder is generated + * from the bootfile path, as described above. + * + * Returns 1 on success or < 0 on error. + */ +int get_pxelinux_path(cmd_tbl_t *cmdtp, const char *file, + unsigned long pxefile_addr_r) +{ + size_t base_len = strlen(PXELINUX_DIR); + char path[MAX_TFTP_PATH_LEN+1]; + + if (base_len + strlen(file) > MAX_TFTP_PATH_LEN) { + printf("path (%s%s) too long, skipping\n", + PXELINUX_DIR, file); + return -ENAMETOOLONG; + } + + sprintf(path, PXELINUX_DIR "%s", file); + + return get_pxe_file(cmdtp, path, pxefile_addr_r); +} + +/* + * Looks for a pxe file with a name based on the pxeuuid environment variable. + * + * Returns 1 on success or < 0 on error. + */ +int pxe_uuid_path(cmd_tbl_t *cmdtp, unsigned long pxefile_addr_r) +{ + char *uuid_str; + + uuid_str = from_env("pxeuuid"); + + if (!uuid_str) + return -ENOENT; + + return get_pxelinux_path(cmdtp, uuid_str, pxefile_addr_r); +} + +/* + * Looks for a pxe file with a name based on the 'ethaddr' environment + * variable. + * + * Returns 1 on success or < 0 on error. + */ +int pxe_mac_path(cmd_tbl_t *cmdtp, unsigned long pxefile_addr_r) +{ + char mac_str[21]; + int err; + + err = format_mac_pxe(mac_str, sizeof(mac_str)); + + if (err < 0) + return err; + + return get_pxelinux_path(cmdtp, mac_str, pxefile_addr_r); +} + +/* + * Looks for pxe files with names based on our IP address. See pxelinux + * documentation for details on what these file names look like. We match + * that exactly. + * + * Returns 1 on success or < 0 on error. + */ +int pxe_ipaddr_paths(cmd_tbl_t *cmdtp, unsigned long pxefile_addr_r) +{ + char ip_addr[9]; + int mask_pos, err; + + sprintf(ip_addr, "%08X", ntohl(net_ip.s_addr)); + + for (mask_pos = 7; mask_pos >= 0; mask_pos--) { + err = get_pxelinux_path(cmdtp, ip_addr, pxefile_addr_r); + + if (err > 0) + return err; + + ip_addr[mask_pos] = '\0'; + } + + return -ENOENT; +} + +/* + * Wrapper to make it easier to store the file at file_path in the location + * specified by envaddr_name. file_path will be joined to the bootfile path, + * if any is specified. + * + * Returns 1 on success or < 0 on error. + */ +static int get_relfile_envaddr(cmd_tbl_t *cmdtp, const char *file_path, const char *envaddr_name) +{ + unsigned long file_addr; + char *envaddr; + + envaddr = from_env(envaddr_name); + + if (!envaddr) + return -ENOENT; + + if (strict_strtoul(envaddr, 16, &file_addr) < 0) + return -EINVAL; + + return get_relfile(cmdtp, file_path, file_addr); +} + +/* + * Allocates memory for and initializes a pxe_label. This uses malloc, so the + * result must be free()'d to reclaim the memory. + * + * Returns NULL if malloc fails. + */ +static struct pxe_label *label_create(void) +{ + struct pxe_label *label; + + label = malloc(sizeof(struct pxe_label)); + + if (!label) + return NULL; + + memset(label, 0, sizeof(struct pxe_label)); + + return label; +} + +/* + * Free the memory used by a pxe_label, including that used by its name, + * kernel, append and initrd members, if they're non NULL. + * + * So - be sure to only use dynamically allocated memory for the members of + * the pxe_label struct, unless you want to clean it up first. These are + * currently only created by the pxe file parsing code. + */ +static void label_destroy(struct pxe_label *label) +{ + if (label->name) + free(label->name); + + if (label->kernel) + free(label->kernel); + + if (label->config) + free(label->config); + + if (label->append) + free(label->append); + + if (label->initrd) + free(label->initrd); + + if (label->fdt) + free(label->fdt); + + if (label->fdtdir) + free(label->fdtdir); + + free(label); +} + +/* + * Print a label and its string members if they're defined. + * + * This is passed as a callback to the menu code for displaying each + * menu entry. + */ +static void label_print(void *data) +{ + struct pxe_label *label = data; + const char *c = label->menu ? label->menu : label->name; + + printf("%s:\t%s\n", label->num, c); +} + +/* + * Boot a label that specified 'localboot'. This requires that the 'localcmd' + * environment variable is defined. Its contents will be executed as U-Boot + * command. If the label specified an 'append' line, its contents will be + * used to overwrite the contents of the 'bootargs' environment variable prior + * to running 'localcmd'. + * + * Returns 1 on success or < 0 on error. + */ +static int label_localboot(struct pxe_label *label) +{ + char *localcmd; + + localcmd = from_env("localcmd"); + + if (!localcmd) + return -ENOENT; + + if (label->append) { + char bootargs[CONFIG_SYS_CBSIZE]; + + cli_simple_process_macros(label->append, bootargs); + env_set("bootargs", bootargs); + } + + debug("running: %s\n", localcmd); + + return run_command_list(localcmd, strlen(localcmd), 0); +} + +/* + * Boot according to the contents of a pxe_label. + * + * If we can't boot for any reason, we return. A successful boot never + * returns. + * + * The kernel will be stored in the location given by the 'kernel_addr_r' + * environment variable. + * + * If the label specifies an initrd file, it will be stored in the location + * given by the 'ramdisk_addr_r' environment variable. + * + * If the label specifies an 'append' line, its contents will overwrite that + * of the 'bootargs' environment variable. + */ +static int label_boot(cmd_tbl_t *cmdtp, struct pxe_label *label) +{ + char *bootm_argv[] = { "bootm", NULL, NULL, NULL, NULL }; + char initrd_str[28]; + char mac_str[29] = ""; + char ip_str[68] = ""; + char *fit_addr = NULL; + int bootm_argc = 2; + int len = 0; + ulong kernel_addr; + void *buf; + + label_print(label); + + label->attempted = 1; + + if (label->localboot) { + if (label->localboot_val >= 0) + label_localboot(label); + return 0; + } + + if (label->kernel == NULL) { + printf("No kernel given, skipping %s\n", + label->name); + return 1; + } + + if (label->initrd) { + if (get_relfile_envaddr(cmdtp, label->initrd, "ramdisk_addr_r") < 0) { + printf("Skipping %s for failure retrieving initrd\n", + label->name); + return 1; + } + + bootm_argv[2] = initrd_str; + strncpy(bootm_argv[2], env_get("ramdisk_addr_r"), 18); + strcat(bootm_argv[2], ":"); + strncat(bootm_argv[2], env_get("filesize"), 9); + } + + if (get_relfile_envaddr(cmdtp, label->kernel, "kernel_addr_r") < 0) { + printf("Skipping %s for failure retrieving kernel\n", + label->name); + return 1; + } + + if (label->ipappend & 0x1) { + sprintf(ip_str, " ip=%s:%s:%s:%s", + env_get("ipaddr"), env_get("serverip"), + env_get("gatewayip"), env_get("netmask")); + } + +#ifdef CONFIG_CMD_NET + if (label->ipappend & 0x2) { + int err; + strcpy(mac_str, " BOOTIF="); + err = format_mac_pxe(mac_str + 8, sizeof(mac_str) - 8); + if (err < 0) + mac_str[0] = '\0'; + } +#endif + + if ((label->ipappend & 0x3) || label->append) { + char bootargs[CONFIG_SYS_CBSIZE] = ""; + char finalbootargs[CONFIG_SYS_CBSIZE]; + + if (strlen(label->append ?: "") + + strlen(ip_str) + strlen(mac_str) + 1 > sizeof(bootargs)) { + printf("bootarg overflow %zd+%zd+%zd+1 > %zd\n", + strlen(label->append ?: ""), + strlen(ip_str), strlen(mac_str), + sizeof(bootargs)); + return 1; + } else { + if (label->append) + strncpy(bootargs, label->append, + sizeof(bootargs)); + strcat(bootargs, ip_str); + strcat(bootargs, mac_str); + + cli_simple_process_macros(bootargs, finalbootargs); + env_set("bootargs", finalbootargs); + printf("append: %s\n", finalbootargs); + } + } + + bootm_argv[1] = env_get("kernel_addr_r"); + /* for FIT, append the configuration identifier */ + if (label->config) { + int len = strlen(bootm_argv[1]) + strlen(label->config) + 1; + + fit_addr = malloc(len); + if (!fit_addr) { + printf("malloc fail (FIT address)\n"); + return 1; + } + snprintf(fit_addr, len, "%s%s", bootm_argv[1], label->config); + bootm_argv[1] = fit_addr; + } + + /* + * fdt usage is optional: + * It handles the following scenarios. All scenarios are exclusive + * + * Scenario 1: If fdt_addr_r specified and "fdt" label is defined in + * pxe file, retrieve fdt blob from server. Pass fdt_addr_r to bootm, + * and adjust argc appropriately. + * + * Scenario 2: If there is an fdt_addr specified, pass it along to + * bootm, and adjust argc appropriately. + * + * Scenario 3: fdt blob is not available. + */ + bootm_argv[3] = env_get("fdt_addr_r"); + + /* if fdt label is defined then get fdt from server */ + if (bootm_argv[3]) { + char *fdtfile = NULL; + char *fdtfilefree = NULL; + + if (label->fdt) { + fdtfile = label->fdt; + } else if (label->fdtdir) { + char *f1, *f2, *f3, *f4, *slash; + + f1 = env_get("fdtfile"); + if (f1) { + f2 = ""; + f3 = ""; + f4 = ""; + } else { + /* + * For complex cases where this code doesn't + * generate the correct filename, the board + * code should set $fdtfile during early boot, + * or the boot scripts should set $fdtfile + * before invoking "pxe" or "sysboot". + */ + f1 = env_get("soc"); + f2 = "-"; + f3 = env_get("board"); + f4 = ".dtb"; + } + + len = strlen(label->fdtdir); + if (!len) + slash = "./"; + else if (label->fdtdir[len - 1] != '/') + slash = "/"; + else + slash = ""; + + len = strlen(label->fdtdir) + strlen(slash) + + strlen(f1) + strlen(f2) + strlen(f3) + + strlen(f4) + 1; + fdtfilefree = malloc(len); + if (!fdtfilefree) { + printf("malloc fail (FDT filename)\n"); + goto cleanup; + } + + snprintf(fdtfilefree, len, "%s%s%s%s%s%s", + label->fdtdir, slash, f1, f2, f3, f4); + fdtfile = fdtfilefree; + } + + if (fdtfile) { + int err = get_relfile_envaddr(cmdtp, fdtfile, "fdt_addr_r"); + free(fdtfilefree); + if (err < 0) { + printf("Skipping %s for failure retrieving fdt\n", + label->name); + goto cleanup; + } + } else { + bootm_argv[3] = NULL; + } + } + + if (!bootm_argv[3]) + bootm_argv[3] = env_get("fdt_addr"); + + if (bootm_argv[3]) { + if (!bootm_argv[2]) + bootm_argv[2] = "-"; + bootm_argc = 4; + } + + kernel_addr = genimg_get_kernel_addr(bootm_argv[1]); + buf = map_sysmem(kernel_addr, 0); + /* Try bootm for legacy and FIT format image */ + if (genimg_get_format(buf) != IMAGE_FORMAT_INVALID) + do_bootm(cmdtp, 0, bootm_argc, bootm_argv); +#ifdef CONFIG_CMD_BOOTI + /* Try booting an AArch64 Linux kernel image */ + else + do_booti(cmdtp, 0, bootm_argc, bootm_argv); +#elif defined(CONFIG_CMD_BOOTZ) + /* Try booting a Image */ + else + do_bootz(cmdtp, 0, bootm_argc, bootm_argv); +#endif + unmap_sysmem(buf); + +cleanup: + if (fit_addr) + free(fit_addr); + return 1; +} + +/* + * Tokens for the pxe file parser. + */ +enum token_type { + T_EOL, + T_STRING, + T_EOF, + T_MENU, + T_TITLE, + T_TIMEOUT, + T_LABEL, + T_KERNEL, + T_LINUX, + T_APPEND, + T_INITRD, + T_LOCALBOOT, + T_DEFAULT, + T_PROMPT, + T_INCLUDE, + T_FDT, + T_FDTDIR, + T_ONTIMEOUT, + T_IPAPPEND, + T_BACKGROUND, + T_INVALID +}; + +/* + * A token - given by a value and a type. + */ +struct token { + char *val; + enum token_type type; +}; + +/* + * Keywords recognized. + */ +static const struct token keywords[] = { + {"menu", T_MENU}, + {"title", T_TITLE}, + {"timeout", T_TIMEOUT}, + {"default", T_DEFAULT}, + {"prompt", T_PROMPT}, + {"label", T_LABEL}, + {"kernel", T_KERNEL}, + {"linux", T_LINUX}, + {"localboot", T_LOCALBOOT}, + {"append", T_APPEND}, + {"initrd", T_INITRD}, + {"include", T_INCLUDE}, + {"devicetree", T_FDT}, + {"fdt", T_FDT}, + {"devicetreedir", T_FDTDIR}, + {"fdtdir", T_FDTDIR}, + {"ontimeout", T_ONTIMEOUT,}, + {"ipappend", T_IPAPPEND,}, + {"background", T_BACKGROUND,}, + {NULL, T_INVALID} +}; + +/* + * Since pxe(linux) files don't have a token to identify the start of a + * literal, we have to keep track of when we're in a state where a literal is + * expected vs when we're in a state a keyword is expected. + */ +enum lex_state { + L_NORMAL = 0, + L_KEYWORD, + L_SLITERAL +}; + +/* + * get_string retrieves a string from *p and stores it as a token in + * *t. + * + * get_string used for scanning both string literals and keywords. + * + * Characters from *p are copied into t-val until a character equal to + * delim is found, or a NUL byte is reached. If delim has the special value of + * ' ', any whitespace character will be used as a delimiter. + * + * If lower is unequal to 0, uppercase characters will be converted to + * lowercase in the result. This is useful to make keywords case + * insensitive. + * + * The location of *p is updated to point to the first character after the end + * of the token - the ending delimiter. + * + * On success, the new value of t->val is returned. Memory for t->val is + * allocated using malloc and must be free()'d to reclaim it. If insufficient + * memory is available, NULL is returned. + */ +static char *get_string(char **p, struct token *t, char delim, int lower) +{ + char *b, *e; + size_t len, i; + + /* + * b and e both start at the beginning of the input stream. + * + * e is incremented until we find the ending delimiter, or a NUL byte + * is reached. Then, we take e - b to find the length of the token. + */ + b = e = *p; + + while (*e) { + if ((delim == ' ' && isspace(*e)) || delim == *e) + break; + e++; + } + + len = e - b; + + /* + * Allocate memory to hold the string, and copy it in, converting + * characters to lowercase if lower is != 0. + */ + t->val = malloc(len + 1); + if (!t->val) + return NULL; + + for (i = 0; i < len; i++, b++) { + if (lower) + t->val[i] = tolower(*b); + else + t->val[i] = *b; + } + + t->val[len] = '\0'; + + /* + * Update *p so the caller knows where to continue scanning. + */ + *p = e; + + t->type = T_STRING; + + return t->val; +} + +/* + * Populate a keyword token with a type and value. + */ +static void get_keyword(struct token *t) +{ + int i; + + for (i = 0; keywords[i].val; i++) { + if (!strcmp(t->val, keywords[i].val)) { + t->type = keywords[i].type; + break; + } + } +} + +/* + * Get the next token. We have to keep track of which state we're in to know + * if we're looking to get a string literal or a keyword. + * + * *p is updated to point at the first character after the current token. + */ +static void get_token(char **p, struct token *t, enum lex_state state) +{ + char *c = *p; + + t->type = T_INVALID; + + /* eat non EOL whitespace */ + while (isblank(*c)) + c++; + + /* + * eat comments. note that string literals can't begin with #, but + * can contain a # after their first character. + */ + if (*c == '#') { + while (*c && *c != '\n') + c++; + } + + if (*c == '\n') { + t->type = T_EOL; + c++; + } else if (*c == '\0') { + t->type = T_EOF; + c++; + } else if (state == L_SLITERAL) { + get_string(&c, t, '\n', 0); + } else if (state == L_KEYWORD) { + /* + * when we expect a keyword, we first get the next string + * token delimited by whitespace, and then check if it + * matches a keyword in our keyword list. if it does, it's + * converted to a keyword token of the appropriate type, and + * if not, it remains a string token. + */ + get_string(&c, t, ' ', 1); + get_keyword(t); + } + + *p = c; +} + +/* + * Increment *c until we get to the end of the current line, or EOF. + */ +static void eol_or_eof(char **c) +{ + while (**c && **c != '\n') + (*c)++; +} + +/* + * All of these parse_* functions share some common behavior. + * + * They finish with *c pointing after the token they parse, and return 1 on + * success, or < 0 on error. + */ + +/* + * Parse a string literal and store a pointer it at *dst. String literals + * terminate at the end of the line. + */ +static int parse_sliteral(char **c, char **dst) +{ + struct token t; + char *s = *c; + + get_token(c, &t, L_SLITERAL); + + if (t.type != T_STRING) { + printf("Expected string literal: %.*s\n", (int)(*c - s), s); + return -EINVAL; + } + + *dst = t.val; + + return 1; +} + +/* + * Parse a base 10 (unsigned) integer and store it at *dst. + */ +static int parse_integer(char **c, int *dst) +{ + struct token t; + char *s = *c; + + get_token(c, &t, L_SLITERAL); + + if (t.type != T_STRING) { + printf("Expected string: %.*s\n", (int)(*c - s), s); + return -EINVAL; + } + + *dst = simple_strtol(t.val, NULL, 10); + + free(t.val); + + return 1; +} + +static int parse_pxefile_top(cmd_tbl_t *cmdtp, char *p, unsigned long base, + struct pxe_menu *cfg, int nest_level); + +/* + * Parse an include statement, and retrieve and parse the file it mentions. + * + * base should point to a location where it's safe to store the file, and + * nest_level should indicate how many nested includes have occurred. For this + * include, nest_level has already been incremented and doesn't need to be + * incremented here. + */ +static int handle_include(cmd_tbl_t *cmdtp, char **c, unsigned long base, + struct pxe_menu *cfg, int nest_level) +{ + char *include_path; + char *s = *c; + int err; + char *buf; + int ret; + + err = parse_sliteral(c, &include_path); + + if (err < 0) { + printf("Expected include path: %.*s\n", + (int)(*c - s), s); + return err; + } + + err = get_pxe_file(cmdtp, include_path, base); + + if (err < 0) { + printf("Couldn't retrieve %s\n", include_path); + return err; + } + + buf = map_sysmem(base, 0); + ret = parse_pxefile_top(cmdtp, buf, base, cfg, nest_level); + unmap_sysmem(buf); + + return ret; +} + +/* + * Parse lines that begin with 'menu'. + * + * base and nest are provided to handle the 'menu include' case. + * + * base should point to a location where it's safe to store the included file. + * + * nest_level should be 1 when parsing the top level pxe file, 2 when parsing + * a file it includes, 3 when parsing a file included by that file, and so on. + */ +static int parse_menu(cmd_tbl_t *cmdtp, char **c, struct pxe_menu *cfg, + unsigned long base, int nest_level) +{ + struct token t; + char *s = *c; + int err = 0; + + get_token(c, &t, L_KEYWORD); + + switch (t.type) { + case T_TITLE: + err = parse_sliteral(c, &cfg->title); + + break; + + case T_INCLUDE: + err = handle_include(cmdtp, c, base, cfg, + nest_level + 1); + break; + + case T_BACKGROUND: + err = parse_sliteral(c, &cfg->bmp); + break; + + default: + printf("Ignoring malformed menu command: %.*s\n", + (int)(*c - s), s); + } + + if (err < 0) + return err; + + eol_or_eof(c); + + return 1; +} + +/* + * Handles parsing a 'menu line' when we're parsing a label. + */ +static int parse_label_menu(char **c, struct pxe_menu *cfg, + struct pxe_label *label) +{ + struct token t; + char *s; + + s = *c; + + get_token(c, &t, L_KEYWORD); + + switch (t.type) { + case T_DEFAULT: + if (!cfg->default_label) + cfg->default_label = strdup(label->name); + + if (!cfg->default_label) + return -ENOMEM; + + break; + case T_LABEL: + parse_sliteral(c, &label->menu); + break; + default: + printf("Ignoring malformed menu command: %.*s\n", + (int)(*c - s), s); + } + + eol_or_eof(c); + + return 0; +} + +/* + * Handles parsing a 'kernel' label. + * expecting "filename" or "<fit_filename>#cfg" + */ +static int parse_label_kernel(char **c, struct pxe_label *label) +{ + char *s; + int err; + + err = parse_sliteral(c, &label->kernel); + if (err < 0) + return err; + + s = strstr(label->kernel, "#"); + if (!s) + return 1; + + label->config = malloc(strlen(s) + 1); + if (!label->config) + return -ENOMEM; + + strcpy(label->config, s); + *s = 0; + + return 1; +} + +/* + * Parses a label and adds it to the list of labels for a menu. + * + * A label ends when we either get to the end of a file, or + * get some input we otherwise don't have a handler defined + * for. + * + */ +static int parse_label(char **c, struct pxe_menu *cfg) +{ + struct token t; + int len; + char *s = *c; + struct pxe_label *label; + int err; + + label = label_create(); + if (!label) + return -ENOMEM; + + err = parse_sliteral(c, &label->name); + if (err < 0) { + printf("Expected label name: %.*s\n", (int)(*c - s), s); + label_destroy(label); + return -EINVAL; + } + + list_add_tail(&label->list, &cfg->labels); + + while (1) { + s = *c; + get_token(c, &t, L_KEYWORD); + + err = 0; + switch (t.type) { + case T_MENU: + err = parse_label_menu(c, cfg, label); + break; + + case T_KERNEL: + case T_LINUX: + err = parse_label_kernel(c, label); + break; + + case T_APPEND: + err = parse_sliteral(c, &label->append); + if (label->initrd) + break; + s = strstr(label->append, "initrd="); + if (!s) + break; + s += 7; + len = (int)(strchr(s, ' ') - s); + label->initrd = malloc(len + 1); + strncpy(label->initrd, s, len); + label->initrd[len] = '\0'; + + break; + + case T_INITRD: + if (!label->initrd) + err = parse_sliteral(c, &label->initrd); + break; + + case T_FDT: + if (!label->fdt) + err = parse_sliteral(c, &label->fdt); + break; + + case T_FDTDIR: + if (!label->fdtdir) + err = parse_sliteral(c, &label->fdtdir); + break; + + case T_LOCALBOOT: + label->localboot = 1; + err = parse_integer(c, &label->localboot_val); + break; + + case T_IPAPPEND: + err = parse_integer(c, &label->ipappend); + break; + + case T_EOL: + break; + + default: + /* + * put the token back! we don't want it - it's the end + * of a label and whatever token this is, it's + * something for the menu level context to handle. + */ + *c = s; + return 1; + } + + if (err < 0) + return err; + } +} + +/* + * This 16 comes from the limit pxelinux imposes on nested includes. + * + * There is no reason at all we couldn't do more, but some limit helps prevent + * infinite (until crash occurs) recursion if a file tries to include itself. + */ +#define MAX_NEST_LEVEL 16 + +/* + * Entry point for parsing a menu file. nest_level indicates how many times + * we've nested in includes. It will be 1 for the top level menu file. + * + * Returns 1 on success, < 0 on error. + */ +static int parse_pxefile_top(cmd_tbl_t *cmdtp, char *p, unsigned long base, + struct pxe_menu *cfg, int nest_level) +{ + struct token t; + char *s, *b, *label_name; + int err; + + b = p; + + if (nest_level > MAX_NEST_LEVEL) { + printf("Maximum nesting (%d) exceeded\n", MAX_NEST_LEVEL); + return -EMLINK; + } + + while (1) { + s = p; + + get_token(&p, &t, L_KEYWORD); + + err = 0; + switch (t.type) { + case T_MENU: + cfg->prompt = 1; + err = parse_menu(cmdtp, &p, cfg, + base + ALIGN(strlen(b) + 1, 4), + nest_level); + break; + + case T_TIMEOUT: + err = parse_integer(&p, &cfg->timeout); + break; + + case T_LABEL: + err = parse_label(&p, cfg); + break; + + case T_DEFAULT: + case T_ONTIMEOUT: + err = parse_sliteral(&p, &label_name); + + if (label_name) { + if (cfg->default_label) + free(cfg->default_label); + + cfg->default_label = label_name; + } + + break; + + case T_INCLUDE: + err = handle_include(cmdtp, &p, + base + ALIGN(strlen(b), 4), cfg, + nest_level + 1); + break; + + case T_PROMPT: + eol_or_eof(&p); + break; + + case T_EOL: + break; + + case T_EOF: + return 1; + + default: + printf("Ignoring unknown command: %.*s\n", + (int)(p - s), s); + eol_or_eof(&p); + } + + if (err < 0) + return err; + } +} + +/* + * Free the memory used by a pxe_menu and its labels. + */ +void destroy_pxe_menu(struct pxe_menu *cfg) +{ + struct list_head *pos, *n; + struct pxe_label *label; + + if (cfg->title) + free(cfg->title); + + if (cfg->default_label) + free(cfg->default_label); + + list_for_each_safe(pos, n, &cfg->labels) { + label = list_entry(pos, struct pxe_label, list); + + label_destroy(label); + } + + free(cfg); +} + +/* + * Entry point for parsing a pxe file. This is only used for the top level + * file. + * + * Returns NULL if there is an error, otherwise, returns a pointer to a + * pxe_menu struct populated with the results of parsing the pxe file (and any + * files it includes). The resulting pxe_menu struct can be free()'d by using + * the destroy_pxe_menu() function. + */ +struct pxe_menu *parse_pxefile(cmd_tbl_t *cmdtp, unsigned long menucfg) +{ + struct pxe_menu *cfg; + char *buf; + int r; + + cfg = malloc(sizeof(struct pxe_menu)); + + if (!cfg) + return NULL; + + memset(cfg, 0, sizeof(struct pxe_menu)); + + INIT_LIST_HEAD(&cfg->labels); + + buf = map_sysmem(menucfg, 0); + r = parse_pxefile_top(cmdtp, buf, menucfg, cfg, 1); + unmap_sysmem(buf); + + if (r < 0) { + destroy_pxe_menu(cfg); + return NULL; + } + + return cfg; +} + +/* + * Converts a pxe_menu struct into a menu struct for use with U-Boot's generic + * menu code. + */ +static struct menu *pxe_menu_to_menu(struct pxe_menu *cfg) +{ + struct pxe_label *label; + struct list_head *pos; + struct menu *m; + int err; + int i = 1; + char *default_num = NULL; + + /* + * Create a menu and add items for all the labels. + */ + m = menu_create(cfg->title, DIV_ROUND_UP(cfg->timeout, 10), + cfg->prompt, label_print, NULL, NULL); + + if (!m) + return NULL; + + list_for_each(pos, &cfg->labels) { + label = list_entry(pos, struct pxe_label, list); + + sprintf(label->num, "%d", i++); + if (menu_item_add(m, label->num, label) != 1) { + menu_destroy(m); + return NULL; + } + if (cfg->default_label && + (strcmp(label->name, cfg->default_label) == 0)) + default_num = label->num; + + } + + /* + * After we've created items for each label in the menu, set the + * menu's default label if one was specified. + */ + if (default_num) { + err = menu_default_set(m, default_num); + if (err != 1) { + if (err != -ENOENT) { + menu_destroy(m); + return NULL; + } + + printf("Missing default: %s\n", cfg->default_label); + } + } + + return m; +} + +/* + * Try to boot any labels we have yet to attempt to boot. + */ +static void boot_unattempted_labels(cmd_tbl_t *cmdtp, struct pxe_menu *cfg) +{ + struct list_head *pos; + struct pxe_label *label; + + list_for_each(pos, &cfg->labels) { + label = list_entry(pos, struct pxe_label, list); + + if (!label->attempted) + label_boot(cmdtp, label); + } +} + +/* + * Boot the system as prescribed by a pxe_menu. + * + * Use the menu system to either get the user's choice or the default, based + * on config or user input. If there is no default or user's choice, + * attempted to boot labels in the order they were given in pxe files. + * If the default or user's choice fails to boot, attempt to boot other + * labels in the order they were given in pxe files. + * + * If this function returns, there weren't any labels that successfully + * booted, or the user interrupted the menu selection via ctrl+c. + */ +void handle_pxe_menu(cmd_tbl_t *cmdtp, struct pxe_menu *cfg) +{ + void *choice; + struct menu *m; + int err; + +#ifdef CONFIG_CMD_BMP + /* display BMP if available */ + if (cfg->bmp) { + if (get_relfile(cmdtp, cfg->bmp, load_addr)) { + run_command("cls", 0); + bmp_display(load_addr, + BMP_ALIGN_CENTER, BMP_ALIGN_CENTER); + } else { + printf("Skipping background bmp %s for failure\n", + cfg->bmp); + } + } +#endif + + m = pxe_menu_to_menu(cfg); + if (!m) + return; + + err = menu_get_choice(m, &choice); + + menu_destroy(m); + + /* + * err == 1 means we got a choice back from menu_get_choice. + * + * err == -ENOENT if the menu was setup to select the default but no + * default was set. in that case, we should continue trying to boot + * labels that haven't been attempted yet. + * + * otherwise, the user interrupted or there was some other error and + * we give up. + */ + + if (err == 1) { + err = label_boot(cmdtp, choice); + if (!err) + return; + } else if (err != -ENOENT) { + return; + } + + boot_unattempted_labels(cmdtp, cfg); +} diff --git a/cmd/pxe_utils.h b/cmd/pxe_utils.h new file mode 100644 index 0000000000..65aadc0f4e --- /dev/null +++ b/cmd/pxe_utils.h @@ -0,0 +1,90 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ + +#ifndef __PXE_UTILS_H +#define __PXE_UTILS_H + +/* + * A note on the pxe file parser. + * + * We're parsing files that use syslinux grammar, which has a few quirks. + * String literals must be recognized based on context - there is no + * quoting or escaping support. There's also nothing to explicitly indicate + * when a label section completes. We deal with that by ending a label + * section whenever we see a line that doesn't include. + * + * As with the syslinux family, this same file format could be reused in the + * future for non pxe purposes. The only action it takes during parsing that + * would throw this off is handling of include files. It assumes we're using + * pxe, and does a tftp download of a file listed as an include file in the + * middle of the parsing operation. That could be handled by refactoring it to + * take a 'include file getter' function. + */ + +/* + * Describes a single label given in a pxe file. + * + * Create these with the 'label_create' function given below. + * + * name - the name of the menu as given on the 'menu label' line. + * kernel - the path to the kernel file to use for this label. + * append - kernel command line to use when booting this label + * initrd - path to the initrd to use for this label. + * attempted - 0 if we haven't tried to boot this label, 1 if we have. + * localboot - 1 if this label specified 'localboot', 0 otherwise. + * list - lets these form a list, which a pxe_menu struct will hold. + */ +struct pxe_label { + char num[4]; + char *name; + char *menu; + char *kernel; + char *config; + char *append; + char *initrd; + char *fdt; + char *fdtdir; + int ipappend; + int attempted; + int localboot; + int localboot_val; + struct list_head list; +}; + +/* + * Describes a pxe menu as given via pxe files. + * + * title - the name of the menu as given by a 'menu title' line. + * default_label - the name of the default label, if any. + * bmp - the bmp file name which is displayed in background + * timeout - time in tenths of a second to wait for a user key-press before + * booting the default label. + * prompt - if 0, don't prompt for a choice unless the timeout period is + * interrupted. If 1, always prompt for a choice regardless of + * timeout. + * labels - a list of labels defined for the menu. + */ +struct pxe_menu { + char *title; + char *default_label; + char *bmp; + int timeout; + int prompt; + struct list_head labels; +}; + +extern bool is_pxe; + +extern int (*do_getfile)(cmd_tbl_t *cmdtp, const char *file_path, + char *file_addr); +void destroy_pxe_menu(struct pxe_menu *cfg); +int get_pxe_file(cmd_tbl_t *cmdtp, const char *file_path, + unsigned long file_addr); +int get_pxelinux_path(cmd_tbl_t *cmdtp, const char *file, + unsigned long pxefile_addr_r); +void handle_pxe_menu(cmd_tbl_t *cmdtp, struct pxe_menu *cfg); +struct pxe_menu *parse_pxefile(cmd_tbl_t *cmdtp, unsigned long menucfg); +int pxe_ipaddr_paths(cmd_tbl_t *cmdtp, unsigned long pxefile_addr_r); +int pxe_mac_path(cmd_tbl_t *cmdtp, unsigned long pxefile_addr_r); +int pxe_uuid_path(cmd_tbl_t *cmdtp, unsigned long pxefile_addr_r); + +#endif /* __PXE_UTILS_H */
On Mon, Nov 25, 2019 at 09:07:37AM +0100, Patrice Chotard wrote:
As sysboot and pxe commands are sharing piece of code, migrate this common code into a new file pxe_utils.c to prepare sysboot command code extraction from pxe.c
Signed-off-by: Patrice Chotard patrice.chotard@st.com
With a little function shuffling to reduce the size growth (due to how gcc optimizes things) of the now shared functions:
Extract all sysboot command related code from pxe.c to new sysboot.c Update Kconfig to insure that DISTRO_DEFAULT select new CMD_SYSBOOT command.
Signed-off-by: Patrice Chotard patrice.chotard@st.com ---
Kconfig | 1 + cmd/Kconfig | 6 +++ cmd/Makefile | 1 + cmd/pxe.c | 132 ------------------------------------------------ cmd/sysboot.c | 135 ++++++++++++++++++++++++++++++++++++++++++++++++++ 5 files changed, 143 insertions(+), 132 deletions(-) create mode 100644 cmd/sysboot.c
diff --git a/Kconfig b/Kconfig index cda4f58ff7..0a1643f7d6 100644 --- a/Kconfig +++ b/Kconfig @@ -88,6 +88,7 @@ config DISTRO_DEFAULTS select CMD_PART if PARTITIONS select CMD_PING if CMD_NET select CMD_PXE if NET + select CMD_SYSBOOT select ENV_VARS_UBOOT_CONFIG select HUSH_PARSER select SUPPORT_RAW_INITRD diff --git a/cmd/Kconfig b/cmd/Kconfig index cf982ff65e..23634a7818 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1667,6 +1667,12 @@ config CMD_SOUND sound init - set up sound system sound play - play a sound
+config CMD_SYSBOOT + bool "sysboot" + select MENU + help + Boot image via local extlinux.conf file + config CMD_QFW bool "qfw" select QFW diff --git a/cmd/Makefile b/cmd/Makefile index 723b461e0d..3d3ed184fd 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -127,6 +127,7 @@ obj-$(CONFIG_CMD_SETEXPR) += setexpr.o obj-$(CONFIG_CMD_SPI) += spi.o obj-$(CONFIG_CMD_STRINGS) += strings.o obj-$(CONFIG_CMD_SMC) += smccc.o +obj-$(CONFIG_CMD_SYSBOOT) += sysboot.o pxe_utils.o obj-$(CONFIG_CMD_TERMINAL) += terminal.o obj-$(CONFIG_CMD_TIME) += time.o obj-$(CONFIG_CMD_TRACE) += trace.o diff --git a/cmd/pxe.c b/cmd/pxe.c index 5fe7d45b3d..757e186d32 100644 --- a/cmd/pxe.c +++ b/cmd/pxe.c @@ -6,7 +6,6 @@
#include <common.h> #include <command.h> -#include <fs.h>
@@ -35,50 +34,6 @@ static int do_get_tftp(cmd_tbl_t *cmdtp, const char *file_path, char *file_addr)
return 1; } -#endif - -static char *fs_argv[5]; - -static int do_get_ext2(cmd_tbl_t *cmdtp, const char *file_path, char *file_addr) -{ -#ifdef CONFIG_CMD_EXT2 - fs_argv[0] = "ext2load"; - fs_argv[3] = file_addr; - fs_argv[4] = (void *)file_path; - - if (!do_ext2load(cmdtp, 0, 5, fs_argv)) - return 1; -#endif - return -ENOENT; -} - -static int do_get_fat(cmd_tbl_t *cmdtp, const char *file_path, char *file_addr) -{ -#ifdef CONFIG_CMD_FAT - fs_argv[0] = "fatload"; - fs_argv[3] = file_addr; - fs_argv[4] = (void *)file_path; - - if (!do_fat_fsload(cmdtp, 0, 5, fs_argv)) - return 1; -#endif - return -ENOENT; -} - -static int do_get_any(cmd_tbl_t *cmdtp, const char *file_path, char *file_addr) -{ -#ifdef CONFIG_CMD_FS_GENERIC - fs_argv[0] = "load"; - fs_argv[3] = file_addr; - fs_argv[4] = (void *)file_path; - - if (!do_load(cmdtp, 0, 5, fs_argv, FS_TYPE_ANY)) - return 1; -#endif - return -ENOENT; -} - -#ifdef CONFIG_CMD_NET
/* * Entry point for the 'pxe get' command. @@ -221,90 +176,3 @@ U_BOOT_CMD( "boot [pxefile_addr_r] - boot from the pxe file at pxefile_addr_r\n" ); #endif - -/* - * Boots a system using a local disk syslinux/extlinux file - * - * Returns 0 on success, 1 on error. - */ -static int do_sysboot(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - unsigned long pxefile_addr_r; - struct pxe_menu *cfg; - char *pxefile_addr_str; - char *filename; - int prompt = 0; - - is_pxe = false; - - if (argc > 1 && strstr(argv[1], "-p")) { - prompt = 1; - argc--; - argv++; - } - - if (argc < 4) - return cmd_usage(cmdtp); - - if (argc < 5) { - pxefile_addr_str = from_env("pxefile_addr_r"); - if (!pxefile_addr_str) - return 1; - } else { - pxefile_addr_str = argv[4]; - } - - if (argc < 6) - filename = env_get("bootfile"); - else { - filename = argv[5]; - env_set("bootfile", filename); - } - - if (strstr(argv[3], "ext2")) - do_getfile = do_get_ext2; - else if (strstr(argv[3], "fat")) - do_getfile = do_get_fat; - else if (strstr(argv[3], "any")) - do_getfile = do_get_any; - else { - printf("Invalid filesystem: %s\n", argv[3]); - return 1; - } - fs_argv[1] = argv[1]; - fs_argv[2] = argv[2]; - - if (strict_strtoul(pxefile_addr_str, 16, &pxefile_addr_r) < 0) { - printf("Invalid pxefile address: %s\n", pxefile_addr_str); - return 1; - } - - if (get_pxe_file(cmdtp, filename, pxefile_addr_r) < 0) { - printf("Error reading config file\n"); - return 1; - } - - cfg = parse_pxefile(cmdtp, pxefile_addr_r); - - if (cfg == NULL) { - printf("Error parsing config file\n"); - return 1; - } - - if (prompt) - cfg->prompt = 1; - - handle_pxe_menu(cmdtp, cfg); - - destroy_pxe_menu(cfg); - - return 0; -} - -U_BOOT_CMD( - sysboot, 7, 1, do_sysboot, - "command to get and boot from syslinux files", - "[-p] <interface> <dev[:part]> <ext2|fat|any> [addr] [filename]\n" - " - load and parse syslinux menu file 'filename' from ext2, fat\n" - " or any filesystem on 'dev' on 'interface' to address 'addr'" -); diff --git a/cmd/sysboot.c b/cmd/sysboot.c new file mode 100644 index 0000000000..965799a1cb --- /dev/null +++ b/cmd/sysboot.c @@ -0,0 +1,135 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include <common.h> +#include <command.h> +#include <env.h> +#include <fs.h> +#include "pxe_utils.h" + +static char *fs_argv[5]; + +static int do_get_ext2(cmd_tbl_t *cmdtp, const char *file_path, char *file_addr) +{ +#ifdef CONFIG_CMD_EXT2 + fs_argv[0] = "ext2load"; + fs_argv[3] = file_addr; + fs_argv[4] = (void *)file_path; + + if (!do_ext2load(cmdtp, 0, 5, fs_argv)) + return 1; +#endif + return -ENOENT; +} + +static int do_get_fat(cmd_tbl_t *cmdtp, const char *file_path, char *file_addr) +{ +#ifdef CONFIG_CMD_FAT + fs_argv[0] = "fatload"; + fs_argv[3] = file_addr; + fs_argv[4] = (void *)file_path; + + if (!do_fat_fsload(cmdtp, 0, 5, fs_argv)) + return 1; +#endif + return -ENOENT; +} + +static int do_get_any(cmd_tbl_t *cmdtp, const char *file_path, char *file_addr) +{ +#ifdef CONFIG_CMD_FS_GENERIC + fs_argv[0] = "load"; + fs_argv[3] = file_addr; + fs_argv[4] = (void *)file_path; + + if (!do_load(cmdtp, 0, 5, fs_argv, FS_TYPE_ANY)) + return 1; +#endif + return -ENOENT; +} + +/* + * Boots a system using a local disk syslinux/extlinux file + * + * Returns 0 on success, 1 on error. + */ +static int do_sysboot(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + unsigned long pxefile_addr_r; + struct pxe_menu *cfg; + char *pxefile_addr_str; + char *filename; + int prompt = 0; + + is_pxe = false; + + if (argc > 1 && strstr(argv[1], "-p")) { + prompt = 1; + argc--; + argv++; + } + + if (argc < 4) + return cmd_usage(cmdtp); + + if (argc < 5) { + pxefile_addr_str = from_env("pxefile_addr_r"); + if (!pxefile_addr_str) + return 1; + } else { + pxefile_addr_str = argv[4]; + } + + if (argc < 6) + filename = env_get("bootfile"); + else { + filename = argv[5]; + env_set("bootfile", filename); + } + + if (strstr(argv[3], "ext2")) + do_getfile = do_get_ext2; + else if (strstr(argv[3], "fat")) + do_getfile = do_get_fat; + else if (strstr(argv[3], "any")) + do_getfile = do_get_any; + else { + printf("Invalid filesystem: %s\n", argv[3]); + return 1; + } + fs_argv[1] = argv[1]; + fs_argv[2] = argv[2]; + + if (strict_strtoul(pxefile_addr_str, 16, &pxefile_addr_r) < 0) { + printf("Invalid pxefile address: %s\n", pxefile_addr_str); + return 1; + } + + if (get_pxe_file(cmdtp, filename, pxefile_addr_r) < 0) { + printf("Error reading config file\n"); + return 1; + } + + cfg = parse_pxefile(cmdtp, pxefile_addr_r); + + if (cfg == NULL) { + printf("Error parsing config file\n"); + return 1; + } + + if (prompt) + cfg->prompt = 1; + + handle_pxe_menu(cmdtp, cfg); + + destroy_pxe_menu(cfg); + + return 0; +} + +U_BOOT_CMD( + sysboot, 7, 1, do_sysboot, + "command to get and boot from syslinux files", + "[-p] <interface> <dev[:part]> <ext2|fat|any> [addr] [filename]\n" + " - load and parse syslinux menu file 'filename' from ext2, fat\n" + " or any filesystem on 'dev' on 'interface' to address 'addr'" +);
Fix checkpatch WARNING and CHECK issues
cmd/pxe_utils.c | 93 ++++++++++++++++++++++++------------------------- 1 file changed, 46 insertions(+), 47 deletions(-)
diff --git a/cmd/pxe_utils.c b/cmd/pxe_utils.c index c318f98417..86a669fa79 100644 --- a/cmd/pxe_utils.c +++ b/cmd/pxe_utils.c @@ -78,14 +78,14 @@ static int get_bootfile_path(const char *file_path, char *bootfile_path,
- if (last_slash == NULL ) + if (!last_slash) goto ret;
if (bootfile_path_size < path_len) { printf("bootfile_path too small. (%zd < %zd)\n", - bootfile_path_size, path_len); + bootfile_path_size, path_len);
return -1; } @@ -109,10 +109,10 @@ int (*do_getfile)(cmd_tbl_t *cmdtp, const char *file_path, char *file_addr); * Returns 1 for success, or < 0 on error. */ static int get_relfile(cmd_tbl_t *cmdtp, const char *file_path, - unsigned long file_addr) + unsigned long file_addr) { size_t path_len; - char relfile[MAX_TFTP_PATH_LEN+1]; + char relfile[MAX_TFTP_PATH_LEN + 1]; char addr_buf[18]; int err;
@@ -125,9 +125,7 @@ static int get_relfile(cmd_tbl_t *cmdtp, const char *file_path, path_len += strlen(relfile);
if (path_len > MAX_TFTP_PATH_LEN) { - printf("Base path too long (%s%s)\n", - relfile, - file_path); + printf("Base path too long (%s%s)\n", relfile, file_path);
return -ENAMETOOLONG; } @@ -149,7 +147,7 @@ static int get_relfile(cmd_tbl_t *cmdtp, const char *file_path, * Returns 1 on success, or < 0 for error. */ int get_pxe_file(cmd_tbl_t *cmdtp, const char *file_path, - unsigned long file_addr) + unsigned long file_addr) { unsigned long config_file_size; char *tftp_filesize; @@ -182,7 +180,6 @@ int get_pxe_file(cmd_tbl_t *cmdtp, const char *file_path,
- /* * Retrieves a file in the 'pxelinux.cfg' folder. Since this uses get_pxe_file * to do the hard work, the location of the 'pxelinux.cfg' folder is generated @@ -191,14 +188,14 @@ int get_pxe_file(cmd_tbl_t *cmdtp, const char *file_path, * Returns 1 on success or < 0 on error. */ int get_pxelinux_path(cmd_tbl_t *cmdtp, const char *file, - unsigned long pxefile_addr_r) + unsigned long pxefile_addr_r) { size_t base_len = strlen(PXELINUX_DIR); - char path[MAX_TFTP_PATH_LEN+1]; + char path[MAX_TFTP_PATH_LEN + 1];
if (base_len + strlen(file) > MAX_TFTP_PATH_LEN) { printf("path (%s%s) too long, skipping\n", - PXELINUX_DIR, file); + PXELINUX_DIR, file); return -ENAMETOOLONG; }
@@ -276,7 +273,8 @@ int pxe_ipaddr_paths(cmd_tbl_t *cmdtp, unsigned long pxefile_addr_r) * * Returns 1 on success or < 0 on error. */ -static int get_relfile_envaddr(cmd_tbl_t *cmdtp, const char *file_path, const char *envaddr_name) +static int get_relfile_envaddr(cmd_tbl_t *cmdtp, const char *file_path, + const char *envaddr_name) { unsigned long file_addr; char *envaddr; @@ -427,16 +425,16 @@ static int label_boot(cmd_tbl_t *cmdtp, struct pxe_label *label) return 0; }
- if (label->kernel == NULL) { + if (!label->kernel) { printf("No kernel given, skipping %s\n", - label->name); + label->name); return 1; }
if (label->initrd) { if (get_relfile_envaddr(cmdtp, label->initrd, "ramdisk_addr_r") < 0) { printf("Skipping %s for failure retrieving initrd\n", - label->name); + label->name); return 1; }
@@ -448,7 +446,7 @@ static int label_boot(cmd_tbl_t *cmdtp, struct pxe_label *label)
if (get_relfile_envaddr(cmdtp, label->kernel, "kernel_addr_r") < 0) { printf("Skipping %s for failure retrieving kernel\n", - label->name); + label->name); return 1; }
@@ -461,6 +459,7 @@ static int label_boot(cmd_tbl_t *cmdtp, struct pxe_label *label) #ifdef CONFIG_CMD_NET if (label->ipappend & 0x2) { int err; + strcpy(mac_str, " BOOTIF="); err = format_mac_pxe(mac_str + 8, sizeof(mac_str) - 8); if (err < 0) @@ -479,17 +478,17 @@ static int label_boot(cmd_tbl_t *cmdtp, struct pxe_label *label) strlen(ip_str), strlen(mac_str), sizeof(bootargs)); return 1; - } else { - if (label->append) - strncpy(bootargs, label->append, - sizeof(bootargs)); - strcat(bootargs, ip_str); - strcat(bootargs, mac_str); - - cli_simple_process_macros(bootargs, finalbootargs); - env_set("bootargs", finalbootargs); - printf("append: %s\n", finalbootargs); } + + if (label->append) + strncpy(bootargs, label->append, sizeof(bootargs)); + + strcat(bootargs, ip_str); + strcat(bootargs, mac_str); + + cli_simple_process_macros(bootargs, finalbootargs); + env_set("bootargs", finalbootargs); + printf("append: %s\n", finalbootargs); }
bootm_argv[1] = env_get("kernel_addr_r"); @@ -573,11 +572,13 @@ static int label_boot(cmd_tbl_t *cmdtp, struct pxe_label *label) }
if (fdtfile) { - int err = get_relfile_envaddr(cmdtp, fdtfile, "fdt_addr_r"); + int err = get_relfile_envaddr(cmdtp, fdtfile, + "fdt_addr_r"); + free(fdtfilefree); if (err < 0) { printf("Skipping %s for failure retrieving fdt\n", - label->name); + label->name); goto cleanup; } } else { @@ -720,7 +721,8 @@ static char *get_string(char **p, struct token *t, char delim, int lower) * e is incremented until we find the ending delimiter, or a NUL byte * is reached. Then, we take e - b to find the length of the token. */ - b = e = *p; + b = *p; + e = *p;
while (*e) { if ((delim == ' ' && isspace(*e)) || delim == *e) @@ -880,7 +882,7 @@ static int parse_integer(char **c, int *dst) }
static int parse_pxefile_top(cmd_tbl_t *cmdtp, char *p, unsigned long base, - struct pxe_menu *cfg, int nest_level); + struct pxe_menu *cfg, int nest_level);
/* * Parse an include statement, and retrieve and parse the file it mentions. @@ -891,7 +893,7 @@ static int parse_pxefile_top(cmd_tbl_t *cmdtp, char *p, unsigned long base, * incremented here. */ static int handle_include(cmd_tbl_t *cmdtp, char **c, unsigned long base, - struct pxe_menu *cfg, int nest_level) + struct pxe_menu *cfg, int nest_level) { char *include_path; char *s = *c; @@ -902,8 +904,7 @@ static int handle_include(cmd_tbl_t *cmdtp, char **c, unsigned long base, err = parse_sliteral(c, &include_path);
if (err < 0) { - printf("Expected include path: %.*s\n", - (int)(*c - s), s); + printf("Expected include path: %.*s\n", (int)(*c - s), s); return err; }
@@ -932,7 +933,7 @@ static int handle_include(cmd_tbl_t *cmdtp, char **c, unsigned long base, * a file it includes, 3 when parsing a file included by that file, and so on. */ static int parse_menu(cmd_tbl_t *cmdtp, char **c, struct pxe_menu *cfg, - unsigned long base, int nest_level) + unsigned long base, int nest_level) { struct token t; char *s = *c; @@ -947,8 +948,7 @@ static int parse_menu(cmd_tbl_t *cmdtp, char **c, struct pxe_menu *cfg, break;
case T_INCLUDE: - err = handle_include(cmdtp, c, base, cfg, - nest_level + 1); + err = handle_include(cmdtp, c, base, cfg, nest_level + 1); break;
case T_BACKGROUND: @@ -957,7 +957,7 @@ static int parse_menu(cmd_tbl_t *cmdtp, char **c, struct pxe_menu *cfg,
default: printf("Ignoring malformed menu command: %.*s\n", - (int)(*c - s), s); + (int)(*c - s), s); }
if (err < 0) @@ -972,7 +972,7 @@ static int parse_menu(cmd_tbl_t *cmdtp, char **c, struct pxe_menu *cfg, * Handles parsing a 'menu line' when we're parsing a label. */ static int parse_label_menu(char **c, struct pxe_menu *cfg, - struct pxe_label *label) + struct pxe_label *label) { struct token t; char *s; @@ -995,7 +995,7 @@ static int parse_label_menu(char **c, struct pxe_menu *cfg, break; default: printf("Ignoring malformed menu command: %.*s\n", - (int)(*c - s), s); + (int)(*c - s), s); }
eol_or_eof(c); @@ -1146,7 +1146,7 @@ static int parse_label(char **c, struct pxe_menu *cfg) * Returns 1 on success, < 0 on error. */ static int parse_pxefile_top(cmd_tbl_t *cmdtp, char *p, unsigned long base, - struct pxe_menu *cfg, int nest_level) + struct pxe_menu *cfg, int nest_level) { struct token t; char *s, *b, *label_name; @@ -1169,8 +1169,8 @@ static int parse_pxefile_top(cmd_tbl_t *cmdtp, char *p, unsigned long base, case T_MENU: cfg->prompt = 1; err = parse_menu(cmdtp, &p, cfg, - base + ALIGN(strlen(b) + 1, 4), - nest_level); + base + ALIGN(strlen(b) + 1, 4), + nest_level); break;
case T_TIMEOUT: @@ -1196,8 +1196,8 @@ static int parse_pxefile_top(cmd_tbl_t *cmdtp, char *p, unsigned long base,
case T_INCLUDE: err = handle_include(cmdtp, &p, - base + ALIGN(strlen(b), 4), cfg, - nest_level + 1); + base + ALIGN(strlen(b), 4), cfg, + nest_level + 1); break;
case T_PROMPT: @@ -1212,7 +1212,7 @@ static int parse_pxefile_top(cmd_tbl_t *cmdtp, char *p, unsigned long base,
default: printf("Ignoring unknown command: %.*s\n", - (int)(p - s), s); + (int)(p - s), s); eol_or_eof(&p); }
@@ -1313,7 +1313,6 @@ static struct menu *pxe_menu_to_menu(struct pxe_menu *cfg) if (cfg->default_label && (strcmp(label->name, cfg->default_label) == 0)) default_num = label->num; - }
cmd/sysboot.c | 25 ++++++++++++------------- 1 file changed, 12 insertions(+), 13 deletions(-)
diff --git a/cmd/sysboot.c b/cmd/sysboot.c index 965799a1cb..793d67d2f5 100644 --- a/cmd/sysboot.c +++ b/cmd/sysboot.c @@ -79,20 +79,20 @@ static int do_sysboot(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) pxefile_addr_str = argv[4]; }
- if (argc < 6) + if (argc < 6) { filename = env_get("bootfile"); - else { + } else { filename = argv[5]; env_set("bootfile", filename); }
- if (strstr(argv[3], "ext2")) + if (strstr(argv[3], "ext2")) { do_getfile = do_get_ext2; - else if (strstr(argv[3], "fat")) + } else if (strstr(argv[3], "fat")) { do_getfile = do_get_fat; - else if (strstr(argv[3], "any")) + } else if (strstr(argv[3], "any")) { do_getfile = do_get_any; - else { + } else { printf("Invalid filesystem: %s\n", argv[3]); return 1; } @@ -111,7 +111,7 @@ static int do_sysboot(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
- if (cfg == NULL) { + if (!cfg) { printf("Error parsing config file\n"); return 1; } @@ -126,10 +126,9 @@ static int do_sysboot(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return 0; }
-U_BOOT_CMD( - sysboot, 7, 1, do_sysboot, - "command to get and boot from syslinux files", - "[-p] <interface> <dev[:part]> <ext2|fat|any> [addr] [filename]\n" - " - load and parse syslinux menu file 'filename' from ext2, fat\n" - " or any filesystem on 'dev' on 'interface' to address 'addr'" +U_BOOT_CMD(sysboot, 7, 1, do_sysboot, + "command to get and boot from syslinux files", + "[-p] <interface> <dev[:part]> <ext2|fat|any> [addr] [filename]\n" + " - load and parse syslinux menu file 'filename' from ext2, fat\n" + " or any filesystem on 'dev' on 'interface' to address 'addr'" );
cmd/pxe.c | 13 ++++++------- 1 file changed, 6 insertions(+), 7 deletions(-)
diff --git a/cmd/pxe.c b/cmd/pxe.c index 757e186d32..ca1e1b188b 100644 --- a/cmd/pxe.c +++ b/cmd/pxe.c @@ -67,7 +67,7 @@ do_pxe_get(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return 1;
err = strict_strtoul(pxefile_addr_str, 16, - (unsigned long *)&pxefile_addr_r); + (unsigned long *)&pxefile_addr_r); if (err < 0) return 1;
@@ -129,7 +129,7 @@ do_pxe_boot(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
- if (cfg == NULL) { + if (!cfg) { printf("Error parsing config file\n"); return 1; } @@ -169,10 +169,9 @@ static int do_pxe(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return CMD_RET_USAGE; }
-U_BOOT_CMD( - pxe, 3, 1, do_pxe, - "commands to get and boot from pxe files", - "get - try to retrieve a pxe file using tftp\npxe " - "boot [pxefile_addr_r] - boot from the pxe file at pxefile_addr_r\n" +U_BOOT_CMD(pxe, 3, 1, do_pxe, + "commands to get and boot from pxe files", + "get - try to retrieve a pxe file using tftp\n" + "pxe boot [pxefile_addr_r] - boot from the pxe file at pxefile_addr_r\n" ); #endif
Patrice Chotard
