[U-Boot] [PATCH 1/5] x86: Support QEMU x86 targets
This commit introduces the initial U-Boot support for QEMU x86 targets. U-Boot can boot from coreboot as a payload, or directly without coreboot.
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
arch/x86/Kconfig | 5 +++ arch/x86/cpu/Makefile | 1 + arch/x86/cpu/qemu/Kconfig | 21 +++++++++++++ arch/x86/cpu/qemu/Makefile | 8 +++++ arch/x86/cpu/qemu/car.S | 26 ++++++++++++++++ arch/x86/cpu/qemu/dram.c | 46 ++++++++++++++++++++++++++++ arch/x86/cpu/qemu/pci.c | 49 ++++++++++++++++++++++++++++++ arch/x86/cpu/qemu/qemu.c | 37 +++++++++++++++++++++++ arch/x86/dts/Makefile | 3 +- arch/x86/dts/qemu-x86.dts | 34 +++++++++++++++++++++ arch/x86/include/asm/arch-qemu/gpio.h | 13 ++++++++ arch/x86/include/asm/arch-qemu/qemu.h | 17 +++++++++++ board/emulation/Kconfig | 25 +++++++++++++++ board/emulation/qemu-x86/Kconfig | 24 +++++++++++++++ board/emulation/qemu-x86/MAINTAINERS | 6 ++++ board/emulation/qemu-x86/Makefile | 7 +++++ board/emulation/qemu-x86/qemu-x86.c | 13 ++++++++ board/emulation/qemu-x86/start.S | 9 ++++++ configs/qemu-x86_defconfig | 6 ++++ include/configs/qemu-x86.h | 57 +++++++++++++++++++++++++++++++++++ 20 files changed, 406 insertions(+), 1 deletion(-) create mode 100644 arch/x86/cpu/qemu/Kconfig create mode 100644 arch/x86/cpu/qemu/Makefile create mode 100644 arch/x86/cpu/qemu/car.S create mode 100644 arch/x86/cpu/qemu/dram.c create mode 100644 arch/x86/cpu/qemu/pci.c create mode 100644 arch/x86/cpu/qemu/qemu.c create mode 100644 arch/x86/dts/qemu-x86.dts create mode 100644 arch/x86/include/asm/arch-qemu/gpio.h create mode 100644 arch/x86/include/asm/arch-qemu/qemu.h create mode 100644 board/emulation/Kconfig create mode 100644 board/emulation/qemu-x86/Kconfig create mode 100644 board/emulation/qemu-x86/MAINTAINERS create mode 100644 board/emulation/qemu-x86/Makefile create mode 100644 board/emulation/qemu-x86/qemu-x86.c create mode 100644 board/emulation/qemu-x86/start.S create mode 100644 configs/qemu-x86_defconfig create mode 100644 include/configs/qemu-x86.h
diff --git a/arch/x86/Kconfig b/arch/x86/Kconfig index 8e734fd..3d02620 100644 --- a/arch/x86/Kconfig +++ b/arch/x86/Kconfig @@ -17,6 +17,9 @@ choice config VENDOR_COREBOOT bool "coreboot"
+config VENDOR_EMULATION + bool "emulation" + config VENDOR_GOOGLE bool "Google"
@@ -27,6 +30,7 @@ endchoice
# board-specific options below source "board/coreboot/Kconfig" +source "board/emulation/Kconfig" source "board/google/Kconfig" source "board/intel/Kconfig"
@@ -34,6 +38,7 @@ source "board/intel/Kconfig" source "arch/x86/cpu/baytrail/Kconfig" source "arch/x86/cpu/coreboot/Kconfig" source "arch/x86/cpu/ivybridge/Kconfig" +source "arch/x86/cpu/qemu/Kconfig" source "arch/x86/cpu/quark/Kconfig" source "arch/x86/cpu/queensbay/Kconfig"
diff --git a/arch/x86/cpu/Makefile b/arch/x86/cpu/Makefile index 043bea2..307545a 100644 --- a/arch/x86/cpu/Makefile +++ b/arch/x86/cpu/Makefile @@ -14,6 +14,7 @@ obj-y += interrupts.o cpu.o call64.o
obj-$(CONFIG_INTEL_BAYTRAIL) += baytrail/ obj-$(CONFIG_SYS_COREBOOT) += coreboot/ +obj-$(CONFIG_QEMU) += qemu/ obj-$(CONFIG_NORTHBRIDGE_INTEL_SANDYBRIDGE) += ivybridge/ obj-$(CONFIG_NORTHBRIDGE_INTEL_IVYBRIDGE) += ivybridge/ obj-$(CONFIG_INTEL_QUARK) += quark/ diff --git a/arch/x86/cpu/qemu/Kconfig b/arch/x86/cpu/qemu/Kconfig new file mode 100644 index 0000000..fb775d7 --- /dev/null +++ b/arch/x86/cpu/qemu/Kconfig @@ -0,0 +1,21 @@ +# +# Copyright (C) 2015, Bin Meng bmeng.cn@gmail.com +# +# SPDX-License-Identifier: GPL-2.0+ +# + +config QEMU + bool + select TSC_CALIBRATION_BYPASS + +if QEMU + +config SYS_CAR_ADDR + hex + default 0xd0000 + +config SYS_CAR_SIZE + hex + default 0x10000 + +endif diff --git a/arch/x86/cpu/qemu/Makefile b/arch/x86/cpu/qemu/Makefile new file mode 100644 index 0000000..be79723 --- /dev/null +++ b/arch/x86/cpu/qemu/Makefile @@ -0,0 +1,8 @@ +# +# Copyright (C) 2015, Bin Meng bmeng.cn@gmail.com +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += car.o dram.o qemu.o +obj-$(CONFIG_PCI) += pci.o diff --git a/arch/x86/cpu/qemu/car.S b/arch/x86/cpu/qemu/car.S new file mode 100644 index 0000000..13b3aea --- /dev/null +++ b/arch/x86/cpu/qemu/car.S @@ -0,0 +1,26 @@ +/* + * Copyright (C) 2015, Bin Meng bmeng.cn@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <config.h> +#include <asm/post.h> + +.globl car_init +car_init: + /* Save the BIST result */ + movl %eax, %ebp + + post_code(POST_CAR_START) + + /* + * Since we know we are running inside emulator, + * we can do nothing here for CAR initialization. + */ + + /* Restore the BIST result */ + movl %ebp, %eax + + post_code(POST_CAR_CPU_CACHE) + jmp car_init_ret diff --git a/arch/x86/cpu/qemu/dram.c b/arch/x86/cpu/qemu/dram.c new file mode 100644 index 0000000..a88d0d2 --- /dev/null +++ b/arch/x86/cpu/qemu/dram.c @@ -0,0 +1,46 @@ +/* + * Copyright (C) 2015, Bin Meng bmeng.cn@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/post.h> +#include <asm/arch/qemu.h> + +DECLARE_GLOBAL_DATA_PTR; + +int dram_init(void) +{ + u32 ram; + + outb(HIGH_RAM_ADDR, CMOS_ADDR_PORT); + ram = ((u32)inb(CMOS_DATA_PORT)) << 14; + outb(LOW_RAM_ADDR, CMOS_ADDR_PORT); + ram |= ((u32)inb(CMOS_DATA_PORT)) << 6; + ram += 16 * 1024; + + gd->ram_size = ram * 1024; + post_code(POST_DRAM); + + return 0; +} + +void dram_init_banksize(void) +{ + gd->bd->bi_dram[0].start = 0; + gd->bd->bi_dram[0].size = gd->ram_size; +} + +/* + * This function looks for the highest region of memory lower than 4GB which + * has enough space for U-Boot where U-Boot is aligned on a page boundary. + * It overrides the default implementation found elsewhere which simply + * picks the end of ram, wherever that may be. The location of the stack, + * the relocation address, and how far U-Boot is moved by relocation are + * set in the global data structure. + */ +ulong board_get_usable_ram_top(ulong total_size) +{ + return gd->ram_size; +} diff --git a/arch/x86/cpu/qemu/pci.c b/arch/x86/cpu/qemu/pci.c new file mode 100644 index 0000000..d50ab75 --- /dev/null +++ b/arch/x86/cpu/qemu/pci.c @@ -0,0 +1,49 @@ +/* + * Copyright (C) 2015, Bin Meng bmeng.cn@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <pci.h> + +DECLARE_GLOBAL_DATA_PTR; + +void board_pci_setup_hose(struct pci_controller *hose) +{ + hose->first_busno = 0; + hose->last_busno = 0; + + /* PCI memory space */ + pci_set_region(hose->regions + 0, + CONFIG_PCI_MEM_BUS, + CONFIG_PCI_MEM_PHYS, + CONFIG_PCI_MEM_SIZE, + PCI_REGION_MEM); + + /* PCI IO space */ + pci_set_region(hose->regions + 1, + CONFIG_PCI_IO_BUS, + CONFIG_PCI_IO_PHYS, + CONFIG_PCI_IO_SIZE, + PCI_REGION_IO); + + pci_set_region(hose->regions + 2, + CONFIG_PCI_PREF_BUS, + CONFIG_PCI_PREF_PHYS, + CONFIG_PCI_PREF_SIZE, + PCI_REGION_PREFETCH); + + pci_set_region(hose->regions + 3, + 0, + 0, + gd->ram_size, + PCI_REGION_MEM | PCI_REGION_SYS_MEMORY); + + hose->region_count = 4; +} + +int board_pci_post_scan(struct pci_controller *hose) +{ + return 0; +} diff --git a/arch/x86/cpu/qemu/qemu.c b/arch/x86/cpu/qemu/qemu.c new file mode 100644 index 0000000..0f98476 --- /dev/null +++ b/arch/x86/cpu/qemu/qemu.c @@ -0,0 +1,37 @@ +/* + * Copyright (C) 2015, Bin Meng bmeng.cn@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/post.h> +#include <asm/processor.h> + +int arch_cpu_init(void) +{ + int ret; + + post_code(POST_CPU_INIT); +#ifdef CONFIG_SYS_X86_TSC_TIMER + timer_set_base(rdtsc()); +#endif + + ret = x86_cpu_init_f(); + if (ret) + return ret; + + return 0; +} + +int print_cpuinfo(void) +{ + post_code(POST_CPU_INFO); + return default_print_cpuinfo(); +} + +void reset_cpu(ulong addr) +{ + /* cold reset */ + x86_full_reset(); +} diff --git a/arch/x86/dts/Makefile b/arch/x86/dts/Makefile index 431bbd8..ca2eab3 100644 --- a/arch/x86/dts/Makefile +++ b/arch/x86/dts/Makefile @@ -2,7 +2,8 @@ dtb-y += chromebook_link.dtb \ chromebox_panther.dtb \ crownbay.dtb \ galileo.dtb \ - minnowmax.dtb + minnowmax.dtb \ + qemu-x86.dtb
targets += $(dtb-y)
diff --git a/arch/x86/dts/qemu-x86.dts b/arch/x86/dts/qemu-x86.dts new file mode 100644 index 0000000..f1291b5 --- /dev/null +++ b/arch/x86/dts/qemu-x86.dts @@ -0,0 +1,34 @@ +/* + * Copyright (C) 2015, Bin Meng bmeng.cn@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; + +/include/ "skeleton.dtsi" +/include/ "serial.dtsi" + +/ { + model = "QEMU x86"; + compatible = "qemu,x86"; + + config { + silent_console = <0>; + }; + + chosen { + stdout-path = "/serial"; + }; + + pci { + compatible = "pci-x86"; + #address-cells = <3>; + #size-cells = <2>; + u-boot,dm-pre-reloc; + ranges = <0x02000000 0x0 0xc0000000 0xc0000000 0 0x10000000 + 0x42000000 0x0 0xd0000000 0xd0000000 0 0x10000000 + 0x01000000 0x0 0x2000 0x2000 0 0xe000>; + }; + +}; diff --git a/arch/x86/include/asm/arch-qemu/gpio.h b/arch/x86/include/asm/arch-qemu/gpio.h new file mode 100644 index 0000000..ca8cba4 --- /dev/null +++ b/arch/x86/include/asm/arch-qemu/gpio.h @@ -0,0 +1,13 @@ +/* + * Copyright (C) 2015, Bin Meng bmeng.cn@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _X86_ARCH_GPIO_H_ +#define _X86_ARCH_GPIO_H_ + +/* Where in config space is the register that points to the GPIO registers? */ +#define PCI_CFG_GPIOBASE 0x44 + +#endif /* _X86_ARCH_GPIO_H_ */ diff --git a/arch/x86/include/asm/arch-qemu/qemu.h b/arch/x86/include/asm/arch-qemu/qemu.h new file mode 100644 index 0000000..8d7e986 --- /dev/null +++ b/arch/x86/include/asm/arch-qemu/qemu.h @@ -0,0 +1,17 @@ +/* + * Copyright (C) 2015, Bin Meng bmeng.cn@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _ARCH_QEMU_H_ +#define _ARCH_QEMU_H_ + +/* I/O Ports */ +#define CMOS_ADDR_PORT 0x70 +#define CMOS_DATA_PORT 0x71 + +#define LOW_RAM_ADDR 0x34 +#define HIGH_RAM_ADDR 0x35 + +#endif /* _ARCH_QEMU_H_ */ diff --git a/board/emulation/Kconfig b/board/emulation/Kconfig new file mode 100644 index 0000000..36809fd --- /dev/null +++ b/board/emulation/Kconfig @@ -0,0 +1,25 @@ +# +# Copyright (C) 2015, Bin Meng bmeng.cn@gmail.com +# +# SPDX-License-Identifier: GPL-2.0+ +# + +if VENDOR_EMULATION + +choice + prompt "Mainboard model" + +config TARGET_QEMU_X86 + bool "QEMU x86" + help + This is the QEMU emulated x86 board. U-Boot supports running + as a coreboot payload as well as bare boot without coreboot. + There are two types of x86 boards supported by QEMU which are + supported by U-Boot. They are via QEMU '-M pc', an i440FX/PIIX + chipset platform and '-M q35', a Q35/ICH9 chipset platform. + +endchoice + +source "board/emulation/qemu-x86/Kconfig" + +endif diff --git a/board/emulation/qemu-x86/Kconfig b/board/emulation/qemu-x86/Kconfig new file mode 100644 index 0000000..e777ef4 --- /dev/null +++ b/board/emulation/qemu-x86/Kconfig @@ -0,0 +1,24 @@ +if TARGET_QEMU_X86 + +config SYS_BOARD + default "qemu-x86" + +config SYS_VENDOR + default "emulation" + +config SYS_SOC + default "qemu" + +config SYS_CONFIG_NAME + default "qemu-x86" + +config SYS_TEXT_BASE + default 0xfff00000 + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + select X86_RESET_VECTOR + select QEMU + select BOARD_ROMSIZE_KB_1024 + +endif diff --git a/board/emulation/qemu-x86/MAINTAINERS b/board/emulation/qemu-x86/MAINTAINERS new file mode 100644 index 0000000..ea4dd19 --- /dev/null +++ b/board/emulation/qemu-x86/MAINTAINERS @@ -0,0 +1,6 @@ +QEMU X86 BOARD +M: Bin Meng bmeng.cn@gmail.com +S: Maintained +F: board/emulation/qemu-x86/ +F: include/configs/qemu-x86.h +F: configs/qemu-x86_defconfig diff --git a/board/emulation/qemu-x86/Makefile b/board/emulation/qemu-x86/Makefile new file mode 100644 index 0000000..ad2bbb9 --- /dev/null +++ b/board/emulation/qemu-x86/Makefile @@ -0,0 +1,7 @@ +# +# Copyright (C) 2015, Bin Meng bmeng.cn@gmail.com +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += qemu-x86.o start.o diff --git a/board/emulation/qemu-x86/qemu-x86.c b/board/emulation/qemu-x86/qemu-x86.c new file mode 100644 index 0000000..fedea81 --- /dev/null +++ b/board/emulation/qemu-x86/qemu-x86.c @@ -0,0 +1,13 @@ +/* + * Copyright (C) 2015, Bin Meng bmeng.cn@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <netdev.h> + +int board_eth_init(bd_t *bis) +{ + return pci_eth_init(bis); +} diff --git a/board/emulation/qemu-x86/start.S b/board/emulation/qemu-x86/start.S new file mode 100644 index 0000000..a71db69 --- /dev/null +++ b/board/emulation/qemu-x86/start.S @@ -0,0 +1,9 @@ +/* + * Copyright (C) 2015, Bin Meng bmeng.cn@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +.globl early_board_init +early_board_init: + jmp early_board_init_ret diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig new file mode 100644 index 0000000..9b02322 --- /dev/null +++ b/configs/qemu-x86_defconfig @@ -0,0 +1,6 @@ +CONFIG_X86=y +CONFIG_VENDOR_EMULATION=y +CONFIG_TARGET_QEMU_X86=y +CONFIG_OF_CONTROL=y +CONFIG_OF_SEPARATE=y +CONFIG_DEFAULT_DEVICE_TREE="qemu-x86" diff --git a/include/configs/qemu-x86.h b/include/configs/qemu-x86.h new file mode 100644 index 0000000..463620d --- /dev/null +++ b/include/configs/qemu-x86.h @@ -0,0 +1,57 @@ +/* + * Copyright (C) 2015, Bin Meng bmeng.cn@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/* + * board/config.h - configuration options, board specific + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <configs/x86-common.h> + +#define CONFIG_SYS_MONITOR_LEN (1 << 20) + +#define CONFIG_NR_DRAM_BANKS 1 + +#define CONFIG_X86_SERIAL + +#define CONFIG_PCI_MEM_BUS 0xc0000000 +#define CONFIG_PCI_MEM_PHYS CONFIG_PCI_MEM_BUS +#define CONFIG_PCI_MEM_SIZE 0x10000000 + +#define CONFIG_PCI_PREF_BUS 0xd0000000 +#define CONFIG_PCI_PREF_PHYS CONFIG_PCI_PREF_BUS +#define CONFIG_PCI_PREF_SIZE 0x10000000 + +#define CONFIG_PCI_IO_BUS 0x2000 +#define CONFIG_PCI_IO_PHYS CONFIG_PCI_IO_BUS +#define CONFIG_PCI_IO_SIZE 0xe000 + +#define CONFIG_PCI_PNP +#define CONFIG_E1000 + +#define CONFIG_STD_DEVICES_SETTINGS "stdin=serial\0" \ + "stdout=serial\0" \ + "stderr=serial\0" + +#define CONFIG_SCSI_DEV_LIST \ + {PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_82371SB_1} + +/* GPIO is not supported */ +#undef CONFIG_INTEL_ICH6_GPIO +#undef CONFIG_CMD_GPIO + +/* SPI is not supported */ +#undef CONFIG_ICH_SPI +#undef CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_IS_NOWHERE + +/* Video is not supported */ +#undef CONFIG_VIDEO +#undef CONFIG_CFB_CONSOLE + +#endif /* __CONFIG_H */
Hi Bin,
Acked-by: Simon Glass sjg@chromium.org Tested-by: Simon Glass sjg@chromium.org
Bin this is a great addition, thanks for putting this together!
What is involved in getting graphics to work? BTW did you ever get graphics running on your board?
Hi Simon,
On Wed, May 6, 2015 at 12:01 PM, Simon Glass sjg@chromium.org wrote:
Hi Bin,
Thanks for the encouragement!
I will try to enable the QEMU graphics support today. Sorry I have not got time to continue the Crown Bay graphics support, so far it is still stuck :(
Regards, Bin
Bin Meng
