[PATCH v3] arm64: zynqmp: Add support for u-boot.itb generation with ATF
Follow i.MX, Sunxi, RISC-V and Rockchip to generate u-boot.itb which includes U-Boot proper, ATF and DTBs in FIT format. ZynqMP supports FIT for quite a long time but with using out of tree solution. The patch is filling this gap.
Tested on zcu102, zcu104 and zcu100/Ultra96.
zcu100/Ultra96 v2.2 ATF build by: make DEBUG=0 ZYNQMP_CONSOLE=cadence1 RESET_TO_BL31=1 PLAT=zynqmp bl31
Changes in v3: - remove bl31 size report - detect u-boot address based on text base - enable build without ATF - add license to its - setup default option based on DEVICE_TREE variable - add note about readelf - add entry field to uboot - call only awk instead of grep and awk - add support for filling load DTB address based on CONFIG_XILINX_OF_BOARD_DTB_ADDR
Changes in v2: - Exchange u-boot/atf in config section - Use default ATF baseaddr from mainline - Update commit message
Based on my discussion with Tom this should be converted to common shell script which will contain ITB generation. To enable this generation for ZynqMP make sense to include this script to let distribution like Fedora to use and conversion can be done on the top of this. For more information please take a look at https://lists.denx.de/pipermail/u-boot/2019-December/393556.html
--- Kconfig | 3 +- arch/arm/mach-zynqmp/mkimage_fit_atf.sh | 123 ++++++++++++++++++++++++ include/configs/xilinx_zynqmp.h | 6 +- 3 files changed, 130 insertions(+), 2 deletions(-) create mode 100755 arch/arm/mach-zynqmp/mkimage_fit_atf.sh
diff --git a/Kconfig b/Kconfig index 92fc4fc135a4..526a5a2e2bde 100644 --- a/Kconfig +++ b/Kconfig @@ -254,7 +254,7 @@ config BUILD_TARGET default "u-boot-spl.kwb" if ARCH_MVEBU && SPL default "u-boot-elf.srec" if RCAR_GEN3 default "u-boot.itb" if SPL_LOAD_FIT && (ARCH_ROCKCHIP || \ - ARCH_SUNXI || RISCV) + ARCH_SUNXI || RISCV || ARCH_ZYNQMP) default "u-boot.kwb" if KIRKWOOD default "u-boot-with-spl.bin" if ARCH_AT91 && SPL_NAND_SUPPORT default "u-boot-with-spl.imx" if ARCH_MX6 && SPL @@ -482,6 +482,7 @@ config SPL_FIT_GENERATOR depends on SPL_FIT default "board/sunxi/mksunxi_fit_atf.sh" if SPL_LOAD_FIT && ARCH_SUNXI default "arch/arm/mach-rockchip/make_fit_atf.py" if SPL_LOAD_FIT && ARCH_ROCKCHIP + default "arch/arm/mach-zynqmp/mkimage_fit_atf.sh" if SPL_LOAD_FIT && ARCH_ZYNQMP default "arch/riscv/lib/mkimage_fit_opensbi.sh" if SPL_LOAD_FIT && RISCV help Specifies a (platform specific) script file to generate the FIT diff --git a/arch/arm/mach-zynqmp/mkimage_fit_atf.sh b/arch/arm/mach-zynqmp/mkimage_fit_atf.sh new file mode 100755 index 000000000000..9c6f973bfa70 --- /dev/null +++ b/arch/arm/mach-zynqmp/mkimage_fit_atf.sh @@ -0,0 +1,123 @@ +#!/bin/sh +# SPDX-License-Identifier: GPL-2.0+ +# +# script to generate FIT image source for Xilinx ZynqMP boards with +# ARM Trusted Firmware and multiple device trees (given on the command line) +# +# usage: $0 <dt_name> [<dt_name> [<dt_name] ...] + +BL33="u-boot-nodtb.bin" +[ -z "$BL31" ] && BL31="bl31.bin" +# Can be also done as ${CROSS_COMPILE}readelf -l bl31.elf | awk '/Entry point/ { print $3 }' +[ -z "$ATF_LOAD_ADDR" ] && ATF_LOAD_ADDR="0xfffea000" + +if [ -z "$BL33_LOAD_ADDR" ];then + BL33_LOAD_ADDR=`awk '/CONFIG_SYS_TEXT_BASE/ { print $3 }' include/generated/autoconf.h` +fi + +DTB_LOAD_ADDR=`awk '/CONFIG_XILINX_OF_BOARD_DTB_ADDR/ { print $3 }' include/generated/autoconf.h` +if [ ! -z "$DTB_LOAD_ADDR" ]; then + DTB_LOAD="load = <$DTB_LOAD_ADDR>;" +else + DTB_LOAD="" +fi + +if [ -z "$*" ]; then + DT=arch/arm/dts/${DEVICE_TREE}.dtb +else + DT=$* +fi + +if [ ! -f $BL31 ]; then + echo "WARNING: BL31 file $BL31 NOT found, resulting binary is non-functional" >&2 + BL31=/dev/null + # But U-Boot proper could be loaded in EL3 by specifying + # firmware = "uboot"; + # instead of "atf" in config node +fi + +cat << __HEADER_EOF +// SPDX-License-Identifier: (GPL-2.0-only OR BSD-2-Clause) + +/dts-v1/; + +/ { + description = "Configuration to load ATF before U-Boot"; + + images { + uboot { + description = "U-Boot (64-bit)"; + data = /incbin/("$BL33"); + type = "firmware"; + os = "u-boot"; + arch = "arm64"; + compression = "none"; + load = <$BL33_LOAD_ADDR>; + entry = <$BL33_LOAD_ADDR>; + hash { + algo = "md5"; + }; + }; + atf { + description = "ARM Trusted Firmware"; + data = /incbin/("$BL31"); + type = "firmware"; + os = "arm-trusted-firmware"; + arch = "arm64"; + compression = "none"; + load = <$ATF_LOAD_ADDR>; + entry = <$ATF_LOAD_ADDR>; + hash { + algo = "md5"; + }; + }; +__HEADER_EOF + +DEFAULT=1 +cnt=1 +for dtname in $DT +do + cat << __FDT_IMAGE_EOF + fdt_$cnt { + description = "$(basename $dtname .dtb)"; + data = /incbin/("$dtname"); + type = "flat_dt"; + arch = "arm64"; + compression = "none"; + $DTB_LOAD + hash { + algo = "md5"; + }; + }; +__FDT_IMAGE_EOF + +[ "$(basename $dtname .dtb)" == "${DEVICE_TREE}" ] && DEFAULT=$cnt + +cnt=$((cnt+1)) +done + +cat << __CONF_HEADER_EOF + }; + configurations { + default = "config_$DEFAULT"; + +__CONF_HEADER_EOF + +cnt=1 +for dtname in $DT +do +cat << __CONF_SECTION1_EOF + config_$cnt { + description = "$(basename $dtname .dtb)"; + firmware = "atf"; + loadables = "uboot"; + fdt = "fdt_$cnt"; + }; +__CONF_SECTION1_EOF +cnt=$((cnt+1)) +done + +cat << __ITS_EOF + }; +}; +__ITS_EOF diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index 9e08ed510805..b094dce49afb 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -242,7 +242,11 @@ # define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR 0 /* unused */ # define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS 0 /* unused */ # define CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR 0 /* unused */ -# define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" +# if defined(CONFIG_SPL_LOAD_FIT) +# define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.itb" +# else +# define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" +# endif #endif
#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_DFU)
po 6. 1. 2020 v 10:28 odesÃlatel Michal Simek michal.simek@xilinx.com napsal:
Changes in v3:
Changes in v2:
+fi
+else
DTB_LOAD=""
+fi
+else
DT=$*
+fi
BL31=/dev/null
+fi
+/dts-v1/;
images {
uboot {
type = "firmware";
os = "u-boot";
arch = "arm64";
hash {
algo = "md5";
atf {
type = "firmware";
arch = "arm64";
hash {
algo = "md5";
+__HEADER_EOF
fdt_$cnt {
type = "flat_dt";
arch = "arm64";
$DTB_LOAD
hash {
algo = "md5";
+__FDT_IMAGE_EOF
configurations {
+__CONF_HEADER_EOF
config_$cnt {
firmware = "atf";
fdt = "fdt_$cnt";
+cat << __ITS_EOF
2.24.0
Apply to have this is tree before start unification.
M
Michal Simek
Michal Simek
