RE: [U-Boot-Users] U-Boot/Kermit Problem
I had a similar problem I ended up getting it to work with using the following
SET PREFIXING ALL SET PARITY NONE SET CARRIER-WATCH OFF
also ensure there is no handshaking see the kermit manual for more information.
I have placed the above commands in ~/.kermrc so they are picked up by minicom when it calls kermit.
btw they recommend not using minicom for serial transfers, I have used U-boot v 1.1.1 with minicom serial file transfer with no problems though.
Daren
From: Ashish R Dhawane <ashish@cdotb.ernet.in> To: u-boot-users@lists.sourceforge.net Subject: [U-Boot-Users] U-Boot/Kermit Problem Date: Thu, 29 Apr 2004 11:58:28 +0500 (GMT+0500)
I am facing a problem in loading a binary file from minicom. Whenver I try to load, it is going in an infinite loop.
=> loadb 100000 ## Ready for binary (kermit) download to 0x00100000 at 9600 bps...
I configured kermit as told in the DULG/SystemSetup Manual.... Only change I made is
set speed 9600 instead of 115200
I am getting stuck here. After going through the u-boot source code .... The calling sequence is ....
-load_serial_bin -k_recv
Inside k_recv the code where I stucked up here is ...
----------------------------ACTUAL CODE----------------------------------- /* get a packet */ /* wait for the starting character or ^C */ for (;;) { switch (serial_getc ()) { case START_CHAR: /* start packet */ goto START; case ETX_CHAR: /* ^C waiting for packet*/ return (0); default: ; } } ----------------------------ACTUAL CODE UP TO HERE------------------------
I think it continiously in the for loop. When I press control-C then it will come comeout saying ....
## Total Size = 0x00000000 = 0 Bytes ## Start Addr = 0x00100000
Can anyabody help me why it is happening ? Any help will be appreciated.
-regards, -Ashish
########################################################################### Ashish R Dhawane Research Engineer W-CDMA Group (3G RAN)
Contacts: --------- Tel(O) :+91-80-2282168 (Direct Line) Tel(O/Lab) :+91-80-2263399 X 329 Fax(O) :+91-80-2282168 Mobile :98455 36814 E-Mail(s) :ashishdhawane@yahoo.com, ashish@cyberspace.org
Surface Address (O): Surface Address (R): -------------------- -------------------- Centre for Development of Telematics, #50, Ground Floor, 12th Cross, 71/1, Sneha Complex, Ayyappa Block, Manorayan Palya, Millers Road, Sultan Palya Main Road, Bangalore-560052, RT Nagar Post,Bangalore-560032, Karnataka, India. Karnataka, India. ###########################################################################
------------------------------------------------------- This SF.Net email is sponsored by: Oracle 10g Get certified on the hottest thing ever to hit the market... Oracle 10g. Take an Oracle 10g class now, and we'll give you the exam FREE. http://ads.osdn.com/?ad_id=3149&alloc_id=8166&op=click _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
_________________________________________________________________ It's fast, it's easy and it's free. Get MSN Messenger today! http://www.msn.co.uk/messenger
Daren Hayward
