[PATCH v2] cmd: clk: probe the clock before dump them
The clock UCLASS need to be probed to allow availability of the private data (struct clk *), get in show_clks() with dev_get_clk_ptr() before use them.
Without this patch the clock dump can cause crash because all the private data are not available before calling the API clk_get_rate().
It is the case for the SCMI clocks, priv->channel is needed for scmi_clk_get_rate() and it is initialized only in scmi_clk_probe(). This issue causes a crash for "clk dump" command on STM32MP135F-DK board for SCMI clock not yet probed.
Fixes: 1a725e229096 ("clk: fix clock tree dump to properly dump out every registered clock") Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com ---
Changes in v2: - simplify the patch after Simon review of V1: always probe the clk device before call to show_clks(), by using device_foreach_child_probe() and uclass_foreach_dev_probe() - test UCLASS_CLK only when show_clks is called for child device
cmd/clk.c | 15 +++++---------- 1 file changed, 5 insertions(+), 10 deletions(-)
diff --git a/cmd/clk.c b/cmd/clk.c index a483fd898122..ff7c7649a159 100644 --- a/cmd/clk.c +++ b/cmd/clk.c @@ -22,7 +22,7 @@ static void show_clks(struct udevice *dev, int depth, int last_flag) u32 rate;
clkp = dev_get_clk_ptr(dev); - if (device_get_uclass_id(dev) == UCLASS_CLK && clkp) { + if (clkp) { parent = clk_get_parent(clkp); if (!IS_ERR(parent) && depth == -1) return; @@ -49,10 +49,11 @@ static void show_clks(struct udevice *dev, int depth, int last_flag) printf("%s\n", dev->name); }
- list_for_each_entry(child, &dev->child_head, sibling_node) { + device_foreach_child_probe(child, dev) { + if (device_get_uclass_id(child) != UCLASS_CLK) + continue; if (child == dev) continue; - is_last = list_is_last(&child->sibling_node, &dev->child_head); show_clks(child, depth, (last_flag << 1) | is_last); } @@ -61,17 +62,11 @@ static void show_clks(struct udevice *dev, int depth, int last_flag) int __weak soc_clk_dump(void) { struct udevice *dev; - struct uclass *uc; - int ret; - - ret = uclass_get(UCLASS_CLK, &uc); - if (ret) - return ret;
printf(" Rate Usecnt Name\n"); printf("------------------------------------------\n");
- uclass_foreach_dev(dev, uc) + uclass_foreach_dev_probe(UCLASS_CLK, dev) show_clks(dev, -1, 0);
Changes in v2:
- if (clkp) { parent = clk_get_parent(clkp); if (!IS_ERR(parent) && depth == -1) return;
- device_foreach_child_probe(child, dev) {
if (child == dev) continue;continue;
struct uclass *uc;
int ret;
if (ret)
return ret;
Reviewed-by: Sean Anderson seanga2@gmail.com
Applied, thanks!
[1/1] cmd: clk: probe the clock before dump them commit: dbd5ad09d2625cc631c1a98ec4517bde59f49b0d
Patrick Delaunay
Sean Anderson
