[U-Boot] [PATCH] efi_loader: fix comments indent_string()
Provide a better description for indent_string. Fix a typo.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_loader/efi_boottime.c | 9 ++++++--- 1 file changed, 6 insertions(+), 3 deletions(-)
diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index e7714bcbc6..8acd26a93b 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -111,8 +111,11 @@ void efi_restore_gd(void) }
/* - * Two spaces per indent level, maxing out at 10.. which ought to be - * enough for anyone ;-) + * Return a string for indenting with two spaces per level. A maximum of ten + * indent levels is supported. Higher indent levels will be truncated. + * + * @level indent level + * @return indent string */ static const char *indent_string(int level) { @@ -1456,7 +1459,7 @@ error: * for details. * * @boot_policy true for request originating from the boot manager - * @parent_image the calles's image handle + * @parent_image the caller's image handle * @file_path the path of the image to load * @source_buffer memory location from which the image is installed * @source_size size of the memory area from which the image is
